H3C S3100 Series Ethernet Switches command Manual-Release 21XX Series(V1.06)
HomeSupportSwitchesS3100 SeriesReference GuidesCommand ReferencesH3C S3100 Series Ethernet Switches command Manual-Release 21XX Series(V1.06)
39-Appendix
39-Appendix 68.96 KB
The command index includes all the in the Command Manual, which are arranged alphabetically.
A B C D E F G H I J K L M N O P Q R S T U V W X Y Z
A
access-limit
18-AAA
1-1
accounting
18-AAA
1-1
accounting optional
18-AAA
1-2
accounting optional
18-AAA
1-26
accounting-on enable
18-AAA
1-27
acl
02-Login
2-1
acl
22-ACL
1-1
active region-configuration
15-MSTP
1-1
add-member
25-Stack-Cluster
2-13
administrator-address
25-Stack-Cluster
2-14
am user-bind
12-Port Security-Port Binding
2-1
apply poe-profile
26-PoE-PoE Profile
2-1
apply qos-profile
23-QoS-QoS Profile
2-1
arp anti-attack valid-check enable
20-ARP
1-1
arp check enable
20-ARP
1-1
arp detection enable
20-ARP
1-2
arp detection trust
20-ARP
1-3
arp protective-down recover enable
20-ARP
1-3
arp protective-down recover interval
20-ARP
1-4
arp rate-limit
20-ARP
1-5
arp rate-limit enable
20-ARP
1-5
20-ARP
1-6
arp static
20-ARP
1-7
arp timer aging
20-ARP
1-7
ascii
31-FTP-SFTP-TFTP
1-5
attribute
18-AAA
1-3
authentication
18-AAA
1-4
authentication super
18-AAA
1-5
authentication-mode
02-Login
1-1
authorization
18-AAA
1-6
authorization vlan
18-AAA
1-7
auto-build
25-Stack-Cluster
2-15
auto-execute command
02-Login
1-3
B
binary
31-FTP-SFTP-TFTP
1-6
black-list
25-Stack-Cluster
2-38
boot attribute-switch
30-File System Management
1-14
boot boot-loader
1-15
boot boot-loader
33-System Maintenance and Debugging
3-1
boot boot-loader backup-attribute
1-15
boot bootrom
3-1
boot web-package
1-16
bpdu-drop any
15-MSTP
1-1
bpdu-tunnel
34-VLAN-VPN
4-1
bpdu-tunnel tunnel-dmac
34-VLAN-VPN
4-2
broadcast-suppression
09-Port Basic Configuration
1-1
build
25-Stack-Cluster
2-17
burst-mode enable
23-QoS-QoS Profile
1-1
bye
31-FTP-SFTP-TFTP
1-6
bye
31-FTP-SFTP-TFTP
1-21
C
calling-station-id mode
18-AAA
1-28
cd
1-1
cd
31-FTP-SFTP-TFTP
1-7
cd
31-FTP-SFTP-TFTP
1-21
cdup
31-FTP-SFTP-TFTP
1-7
cdup
31-FTP-SFTP-TFTP
1-22
check region-configuration
15-MSTP
1-2
clock datetime
1-1
clock summer-time
1-1
clock timezone
1-2
close
31-FTP-SFTP-TFTP
1-8
cluster
25-Stack-Cluster
2-19
cluster enable
25-Stack-Cluster
2-19
cluster switch-to
25-Stack-Cluster
2-20
cluster-mac
25-Stack-Cluster
2-21
cluster-mac syn-interval
25-Stack-Cluster
2-22
command-privilege level
01-CLI
1-1
copy
1-2
copy configuration
1-2
copyright-info enable
02-Login
1-4
count
35-HWPing
1-1
cut connection
18-AAA
1-8
D
databits
02-Login
1-4
data-flow-format
18-AAA
1-29
data-flow-format
18-AAA
1-55
datasize
35-HWPing
1-1
debugging
1-7
delete
1-3
delete
31-FTP-SFTP-TFTP
1-8
delete
31-FTP-SFTP-TFTP
1-22
delete static-routes all
05-Management VLAN
1-1
delete-member
25-Stack-Cluster
2-22
description
04-VLAN
1-1
description
1-4
description
22-ACL
1-2
destination-ip
35-HWPing
1-2
destination-port
35-HWPing
1-3
dhcp protective-down recover enable
21-DHCP
2-1
dhcp protective-down recover interval
21-DHCP
2-2
dhcp rate-limit
21-DHCP
2-2
dhcp rate-limit enable
21-DHCP
2-3
dhcp-snooping
21-DHCP
1-1
dhcp-snooping information enable
21-DHCP
1-1
dhcp-snooping information format
21-DHCP
1-2
dhcp-snooping information packet-format
21-DHCP
1-3
dhcp-snooping information remote-id
21-DHCP
1-3
dhcp-snooping information strategy
21-DHCP
1-4
dhcp-snooping information vlan circuit-id
21-DHCP
1-5
dhcp-snooping information vlan remote-id
21-DHCP
1-6
dhcp-snooping server-guard enable
21-DHCP
1-7
dhcp-snooping server-guard method
21-DHCP
1-7
dhcp-snooping server-guard source-mac
21-DHCP
1-8
dhcp-snooping trust
21-DHCP
1-9
dir
1-4
dir
31-FTP-SFTP-TFTP
1-9
dir
31-FTP-SFTP-TFTP
1-23
disconnect
31-FTP-SFTP-TFTP
1-10
display acl
22-ACL
1-3
display acl remaining entry
22-ACL
1-4
display am user-bind
2-2
display arp
20-ARP
1-8
display arp |
20-ARP
1-9
display arp count
20-ARP
1-10
display arp detection statistics interface
20-ARP
1-11
display arp timer aging
20-ARP
1-11
display boot-loader
1-17
display boot-loader
3-2
display bootp client
21-DHCP
3-3
display bpdu-tunnel
34-VLAN-VPN
4-3
display brief interface
1-5
display channel
32-Information Center
1-1
display clock
1-5
display cluster
25-Stack-Cluster
2-23
display cluster base-members
25-Stack-Cluster
2-39
display cluster base-topology
25-Stack-Cluster
2-40
display cluster black-list
25-Stack-Cluster
2-41
display cluster candidates
25-Stack-Cluster
2-25
display cluster current-topology
25-Stack-Cluster
2-42
display cluster members
25-Stack-Cluster
2-26
display connection
18-AAA
1-9
display cpu
3-2
display current-configuration
03-Configuration File Management
1-1
display current-configuration vlan
1-5
display debugging
1-6
display device
3-3
display dhcp client
21-DHCP
3-1
display dhcp-snooping
21-DHCP
1-10
display dhcp-snooping server-guard
21-DHCP
1-10
display dhcp-snooping trust
21-DHCP
1-11
display diagnostic-information
1-8
display dldp
13-DLDP
1-1
display dns domain
37-DNS
1-1
display dns dynamic-host
37-DNS
1-2
display dns ipv6 dynamic-host
36-IPv6 Management
1-1
display dns server
37-DNS
1-2
display domain
18-AAA
1-10
display dot1x
17-802.1x-System Guard
1-1
display environment
3-4
display fan
3-5
display fib
06-IP Address-IP Performance
2-1
display fib |
2-4
display fib acl
2-3
display fib ip-address
2-2
display fib statistics
2-4
display ftp-server
31-FTP-SFTP-TFTP
1-1
display ftp-user
31-FTP-SFTP-TFTP
1-2
display garp statistics
08-GVRP
1-1
display garp timer
08-GVRP
1-2
display gvrp statistics
08-GVRP
1-6
display gvrp status
08-GVRP
1-6
display habp
3-1
display habp table
3-1
display habp traffic
3-2
display history-command
01-CLI
1-3
display hwping
35-HWPing
1-4
display hwtacacs
18-AAA
1-56
display icmp statistics
2-5
display igmp-snooping configuration
16-Multicast
1-1
display igmp-snooping group
16-Multicast
1-2
display igmp-snooping statistics
16-Multicast
1-3
display info-center
1-1
display interface
1-7
display interface Vlan-interface
04-VLAN
1-2
05-Management VLAN
1-1
display ip host
37-DNS
1-3
display ip interface
05-Management VLAN
1-2
1-1
display ip interface brief
05-Management VLAN
1-4
1-2
display ip routing-table
05-Management VLAN
1-5
display ip routing-table acl
05-Management VLAN
1-6
display ip routing-table ip-address
05-Management VLAN
1-8
display ip routing-table ip-address1 ip-address2
05-Management VLAN
1-9
display ip routing-table protocol
05-Management VLAN
1-10
display ip routing-table radix
05-Management VLAN
1-11
display ip routing-table statistics
05-Management VLAN
1-11
display ip routing-table verbose
05-Management VLAN
1-12
display ip socket
2-6
display ip source static binding
21-DHCP
1-12
display ip statistics
2-8
display ipv6 fib
36-IPv6 Management
1-2
display ipv6 host
36-IPv6 Management
1-3
display ipv6 interface
36-IPv6 Management
1-4
display ipv6 neighbors
36-IPv6 Management
1-6
display ipv6 neighbors count
36-IPv6 Management
1-8
display ipv6 route-table
36-IPv6 Management
1-8
display ipv6 socket
36-IPv6 Management
1-10
display ipv6 statistics
36-IPv6 Management
1-11
display isolate port
11-Port Isolation
1-1
display lacp system-id
10-Link Aggregation
1-4
display link-aggregation interface
10-Link Aggregation
1-1
display link-aggregation summary
10-Link Aggregation
1-2
display link-aggregation verbose
10-Link Aggregation
1-3
display link-delay
1-10
display local-server statistics
18-AAA
1-30
display local-user
18-AAA
1-11
display logbuffer
1-3
display logbuffer summary
1-4
display loopback-detection
1-11
display mac-address
14-MAC Address Table Management
1-2
display mac-address aging-time
1-1
display mac-address multicast static
16-Multicast
2-1
display mac-address security
1-1
display mac-authentication
19-MAC Address Authentication
1-1
display memory
3-5
display mirroring-group
24-Mirroring
1-1
display monitor-link group
38-Smart Link-Monitor Link
2-1
display multicast-source-deny
16-Multicast
2-2
display ndp
25-Stack-Cluster
2-1
display ntdp
25-Stack-Cluster
2-6
display ntdp device-list
25-Stack-Cluster
2-7
display ntdp single-device mac-address
25-Stack-Cluster
2-43
display ntp-service sessions
28-NTP
1-1
display ntp-service status
28-NTP
1-2
display ntp-service trace
28-NTP
1-4
display packet-filter
22-ACL
1-5
display poe interface
26-PoE-PoE Profile
1-1
display poe interface power
26-PoE-PoE Profile
1-3
display poe powersupply
26-PoE-PoE Profile
1-4
display poe temperature-protection
26-PoE-PoE Profile
1-5
display poe-profile
26-PoE-PoE Profile
2-2
display port
04-VLAN
1-8
display port combo
1-12
display port vlan-vpn
34-VLAN-VPN
1-1
display port-mac
1-3
display port-security
1-2
display power
3-6
display priority-trust
23-QoS-QoS Profile
1-1
display protocol-vlan interface
04-VLAN
1-15
display protocol-vlan vlan
04-VLAN
1-16
display public-key local
29-SSH
1-1
display public-key peer
29-SSH
1-2
display qos cos-local-precedence-map
23-QoS-QoS Profile
1-2
display qos dscp-local-precedence-map
23-QoS-QoS Profile
1-2
display qos ip-precedence-local-precedence-map
23-QoS-QoS Profile
1-4
display qos-global
23-QoS-QoS Profile
1-5
display qos-interface all
23-QoS-QoS Profile
1-6
display qos-interface line-rate
23-QoS-QoS Profile
1-7
display qos-interface mirrored-to
23-QoS-QoS Profile
1-7
display qos-interface traffic-limit
23-QoS-QoS Profile
1-8
display qos-interface traffic-priority
23-QoS-QoS Profile
1-9
display qos-interface traffic-redirect
23-QoS-QoS Profile
1-10
display qos-interface traffic-shape
23-QoS-QoS Profile
1-11
display qos-interface traffic-statistic
23-QoS-QoS Profile
1-12
display qos-port-group
23-QoS-QoS Profile
1-13
display qos-profile
23-QoS-QoS Profile
2-2
display qos-vlan
23-QoS-QoS Profile
1-14
display queue-scheduler
23-QoS-QoS Profile
1-15
display radius scheme
18-AAA
1-30
display radius statistics
18-AAA
1-32
display rmon alarm
27-SNMP-RMON
2-1
display rmon event
27-SNMP-RMON
2-2
display rmon eventlog
27-SNMP-RMON
2-3
display rmon history
27-SNMP-RMON
2-4
display rmon prialarm
27-SNMP-RMON
2-5
display rmon statistics
27-SNMP-RMON
2-7
display rsa local-key-pair public
29-SSH
1-4
display rsa peer-public-key
29-SSH
1-5
display saved-configuration
1-6
display schedule reboot
3-6
display smart-link flush
1-1
display smart-link group
1-2
display snmp-agent
27-SNMP-RMON
1-1
display snmp-agent community
27-SNMP-RMON
1-1
display snmp-agent group
27-SNMP-RMON
1-3
display snmp-agent mib-view
27-SNMP-RMON
1-4
display snmp-agent statistics
27-SNMP-RMON
1-5
display snmp-agent sys-info
27-SNMP-RMON
1-8
display snmp-agent trap-list
27-SNMP-RMON
1-9
display snmp-agent usm-user
27-SNMP-RMON
1-9
display ssh server
29-SSH
1-6
display ssh server-info
29-SSH
1-7
display ssh user-information
29-SSH
1-8
display stacking
25-Stack-Cluster
1-1
display startup
1-8
display stop-accounting-buffer
18-AAA
1-34
18-AAA
1-57
display stp
15-MSTP
1-3
display stp abnormalport
15-MSTP
1-7
display stp portdown
15-MSTP
1-8
display stp region-configuration
15-MSTP
1-8
display stp root
15-MSTP
1-9
display system-guard attack-record
4-1
display system-guard config
5-1
display system-guard state
4-2
display tcp ipv6 statistics
36-IPv6 Management
1-14
display tcp ipv6 status
36-IPv6 Management
1-16
display tcp statistics
2-9
display tcp status
2-11
display this
1-9
display time-range
22-ACL
1-6
display transceiver alarm interface
3-7
display transceiver diagnosis interface
3-10
display transceiver interface
3-11
display transceiver manuinfo interface
3-12
display trapbuffer
1-5
display udp ipv6 statistics
36-IPv6 Management
1-17
display udp statistics
2-12
display unit
1-12
display user-interface
02-Login
1-5
display users
02-Login
1-7
display version
1-6
display vlan
04-VLAN
1-3
display vlan
07-Voice VLAN
1-3
display voice vlan error-info
07-Voice VLAN
1-1
display voice vlan oui
07-Voice VLAN
1-2
display voice vlan status
07-Voice VLAN
1-2
display web package
1-17
display web users
02-Login
1-8
dldp
13-DLDP
1-2
dldp authentication-mode
13-DLDP
1-3
dldp delaydown-timer
13-DLDP
1-7
dldp interval
13-DLDP
1-4
dldp reset
13-DLDP
1-5
dldp unidirectional-shutdown
13-DLDP
1-5
dldp work-mode
13-DLDP
1-6
dns domain
37-DNS
1-4
dns resolve
37-DNS
1-5
dns resolve-target
35-HWPing
1-10
dns server
37-DNS
1-5
dns server ipv6
36-IPv6 Management
1-18
dns-server
35-HWPing
1-10
domain
18-AAA
1-13
domain delimiter
18-AAA
1-14
dot1x
1-4
dot1x authentication-method
1-5
dot1x dhcp-launch
1-6
dot1x free-ip
2-1
dot1x guest-vlan
1-7
dot1x handshake
1-8
dot1x handshake secure
1-9
dot1x max-user
1-10
dot1x port-control
1-11
dot1x port-method
1-12
dot1x quiet-period
1-13
dot1x re-authenticate
1-15
dot1x retry
1-13
dot1x retry-version-max
1-14
dot1x supp-proxy-check
1-16
dot1x timer
1-17
dot1x timer acl-timeout
2-2
dot1x timer reauth-period
1-19
dot1x url
2-2
dot1x version-check
1-20
duplex
1-14
E
enable log updown
1-14
enable snmp trap updown
27-SNMP-RMON
1-10
execute
1-6
exit
31-FTP-SFTP-TFTP
1-24
F
file prompt
1-6
filename
35-HWPing
1-11
fixdisk
1-7
flow interval
1-15
flow-control
1-16
flush enable control-vlan
1-3
format
1-8
free user-interface
02-Login
1-9
free web-users
02-Login
2-1
frequency
35-HWPing
1-12
ftp
31-FTP-SFTP-TFTP
1-10
ftp cluster
25-Stack-Cluster
2-28
ftp disconnect
31-FTP-SFTP-TFTP
1-3
ftp server enable
31-FTP-SFTP-TFTP
1-4
ftp timeout
31-FTP-SFTP-TFTP
1-4
ftp-operation
35-HWPing
1-13
ftp-server
25-Stack-Cluster
2-29
G
garp timer
08-GVRP
1-3
garp timer leaveall
08-GVRP
1-4
get
31-FTP-SFTP-TFTP
1-11
get
31-FTP-SFTP-TFTP
1-24
gratuitous-arp-learning enable
20-ARP
1-12
gvrp
08-GVRP
1-7
gvrp registration
08-GVRP
1-8
H
habp enable
3-3
habp server vlan
3-3
habp timer
3-4
header
02-Login
1-9
help
31-FTP-SFTP-TFTP
1-25
history-command max-size
02-Login
1-11
history-records
35-HWPing
1-13
holdtime
25-Stack-Cluster
2-30
http-operation
35-HWPing
1-14
http-string
35-HWPing
1-15
hwping
35-HWPing
1-15
hwping-agent enable
35-HWPing
1-16
hwping-server enable
35-HWPing
1-27
hwping-server tcpconnect
35-HWPing
1-28
hwping-server udpecho
35-HWPing
1-28
hwtacacs nas-ip
18-AAA
1-57
hwtacacs scheme
18-AAA
1-58
I
icmp redirect send
2-13
icmp unreach send
2-14
idle-cut
18-AAA
1-15
idle-timeout
02-Login
1-12
igmp host-join
16-Multicast
1-14
igmp-snooping
16-Multicast
1-4
igmp-snooping fast-leave
16-Multicast
1-5
igmp-snooping general-query source-ip
16-Multicast
1-6
igmp-snooping group-limit
16-Multicast
1-7
igmp-snooping group-policy
16-Multicast
1-8
igmp-snooping host-aging-time
16-Multicast
1-10
igmp-snooping querier
16-Multicast
1-10
igmp-snooping query-interval
16-Multicast
1-11
igmp-snooping router-aging-time
16-Multicast
1-12
igmp-snooping version
16-Multicast
1-12
igmp-snooping vlan-mapping
16-Multicast
1-13
info-center channel name
1-6
info-center console channel
1-6
info-center enable
1-7
info-center logbuffer
1-8
info-center loghost
1-8
info-center loghost source
1-9
info-center monitor channel
1-10
info-center snmp channel
1-11
info-center source
1-11
info-center synchronous
1-13
info-center timestamp
1-14
info-center timestamp loghost
1-15
info-center timestamp utc
1-16
info-center trapbuffer
1-17
instance
15-MSTP
1-10
interface
1-16
04-VLAN
1-4
05-Management VLAN
1-13
ip address
05-Management VLAN
1-14
ip address
1-3
ip address bootp-alloc
21-DHCP
3-4
ip address dhcp-alloc
21-DHCP
3-2
ip check source ip-address
21-DHCP
1-13
ip host
37-DNS
1-6
ip http acl
02-Login
2-2
ip http shutdown
02-Login
1-13
ip route-static
05-Management VLAN
1-15
21-DHCP
1-14
ip-pool
25-Stack-Cluster
2-31
ipv6 address
36-IPv6 Management
1-19
ipv6 address auto link-local
36-IPv6 Management
1-19
ipv6 address eui-64
36-IPv6 Management
1-20
ipv6 address link-local
36-IPv6 Management
1-22
ipv6 host
36-IPv6 Management
1-22
ipv6 icmp-error
36-IPv6 Management
1-23
ipv6 nd dad attempts
36-IPv6 Management
1-24
ipv6 nd hop-limit
36-IPv6 Management
1-24
ipv6 nd ns retrans-timer
36-IPv6 Management
1-25
ipv6 nd nud reachable-time
36-IPv6 Management
1-25
ipv6 neighbor
36-IPv6 Management
1-26
ipv6 neighbors max-learning-num
36-IPv6 Management
1-27
ipv6 route-static
36-IPv6 Management
1-27
J
jitter-interval
35-HWPing
1-16
jitter-packetnum
35-HWPing
1-17
jumboframe enable
1-17
K
key
18-AAA
1-35
key
18-AAA
1-58
L
lacp enable
10-Link Aggregation
1-5
lacp port-priority
10-Link Aggregation
1-5
lacp system-priority
10-Link Aggregation
1-6
lcd
31-FTP-SFTP-TFTP
1-12
level
18-AAA
1-16
line-rate
23-QoS-QoS Profile
1-16
link-aggregation group
1-3
2-2
link-aggregation group description
10-Link Aggregation
1-6
link-aggregation group mode
10-Link Aggregation
1-7
link-delay
1-18
local-server
18-AAA
1-36
local-server nas-ip
18-AAA
1-36
local-user
18-AAA
1-16
local-user password-display-mode
18-AAA
1-17
lock
02-Login
1-14
logging-host
25-Stack-Cluster
2-31
loopback
1-19
loopback-detection control enable
1-19
loopback-detection enable
1-20
loopback-detection interface-list enable
1-22
loopback-detection interval-time
1-22
loopback-detection per-vlan enable
1-23
loopback-detection shutdown enable
1-23
ls
31-FTP-SFTP-TFTP
1-12
ls
31-FTP-SFTP-TFTP
1-25
M
mac-address
1-4
mac-address max-mac-count
1-5
mac-address max-mac-count 0
1-6
mac-address multicast interface
16-Multicast
2-3
mac-address multicast vlan
16-Multicast
2-3
1-5
mac-address timer
1-7
mac-authentication
1-3
mac-authentication authmode usernameasmacaddress
1-5
mac-authentication authmode usernamefixed
1-6
mac-authentication authpassword
1-7
mac-authentication authusername
1-7
mac-authentication domain
1-8
mac-authentication guest-vlan
1-10
mac-authentication interface
1-4
mac-authentication max-auth-num
1-12
mac-authentication timer
1-8
mac-authentication timer guest-vlan-reauth
1-13
mac-authenticiaon intrusion-mode block-mac
1-11
management-vlan
05-Management VLAN
1-16
management-vlan
25-Stack-Cluster
2-32
mdi
1-24
messenger
18-AAA
1-18
mirrored-to
23-QoS-QoS Profile
1-17
mirrored-to vlan
23-QoS-QoS Profile
1-18
mirroring-group
24-Mirroring
1-2
mirroring-group mirroring-port
24-Mirroring
1-3
mirroring-group monitor-port
24-Mirroring
1-4
mirroring-group reflector-port
24-Mirroring
1-5
mirroring-group remote-probe vlan
24-Mirroring
1-6
mirroring-port
24-Mirroring
1-6
mkdir
1-8
mkdir
31-FTP-SFTP-TFTP
1-13
mkdir
31-FTP-SFTP-TFTP
1-26
monitor-link group
2-3
monitor-port
24-Mirroring
1-7
more
1-9
move
1-10
multicast static-group interface
16-Multicast
1-15
multicast static-group vlan
16-Multicast
1-15
multicast static-router-port
16-Multicast
1-16
multicast static-router-port vlan
16-Multicast
1-17
16-Multicast
2-4
multicast-suppression
1-25
N
name
04-VLAN
1-5
name
18-AAA
1-19
nas-ip
18-AAA
1-37
nas-ip
18-AAA
1-59
ndp enable
25-Stack-Cluster
2-3
ndp timer aging
25-Stack-Cluster
2-3
ndp timer hello
25-Stack-Cluster
2-4
nslookup type
37-DNS
1-7
ntdp enable
25-Stack-Cluster
2-9
ntdp explore
25-Stack-Cluster
2-9
ntdp hop
25-Stack-Cluster
2-10
ntdp timer
25-Stack-Cluster
2-11
ntdp timer hop-delay
25-Stack-Cluster
2-12
ntdp timer port-delay
25-Stack-Cluster
2-12
ntp-service access
28-NTP
1-4
ntp-service authentication enable
28-NTP
1-5
ntp-service authentication-keyid
28-NTP
1-6
ntp-service broadcast-client
28-NTP
1-7
ntp-service broadcast-server
28-NTP
1-7
ntp-service in-interface disable
28-NTP
1-8
ntp-service max-dynamic-sessions
28-NTP
1-8
ntp-service multicast-client
28-NTP
1-9
ntp-service multicast-server
28-NTP
1-10
ntp-service reliable authentication-keyid
28-NTP
1-10
ntp-service source-interface
28-NTP
1-11
ntp-service unicast-peer
28-NTP
1-12
ntp-service unicast-server
28-NTP
1-13
O
open
31-FTP-SFTP-TFTP
1-14
P
packet-filter
22-ACL
1-7
packet-filter
23-QoS-QoS Profile
2-4
packet-filter vlan
22-ACL
1-8
parity
02-Login
1-14
passive
31-FTP-SFTP-TFTP
1-15
password
18-AAA
1-19
password
35-HWPing
1-18
peer-public-key end
29-SSH
1-9
ping
2-1
ping ipv6
36-IPv6 Management
2-1
poe enable
26-PoE-PoE Profile
1-5
poe legacy enable
26-PoE-PoE Profile
1-6
poe max-power
26-PoE-PoE Profile
1-6
poe mode
26-PoE-PoE Profile
1-7
poe power-management
26-PoE-PoE Profile
1-8
poe priority
26-PoE-PoE Profile
1-8
26-PoE-PoE Profile
1-9
poe update
26-PoE-PoE Profile
1-10
poe-profile
26-PoE-PoE Profile
2-3
port
04-VLAN
1-9
port
1-26
port
1-4
port
2-4
port access vlan
04-VLAN
1-9
port hybrid protocol-vlan vlan
04-VLAN
1-17
port hybrid pvid vlan
04-VLAN
1-10
port hybrid vlan
04-VLAN
1-11
port isolate
11-Port Isolation
1-1
port link-aggregation group
10-Link Aggregation
1-8
port link-type
04-VLAN
1-12
port monitor-link group
2-4
port smart-link group
1-5
port trunk permit vlan
04-VLAN
1-13
port trunk pvid vlan
04-VLAN
1-13
port-group
1-27
port-mac
1-8
port-security authorization ignore
1-9
port-security enable
1-6
port-security intrusion-mode
1-7
port-security max-mac-count
1-10
port-security ntk-mode
1-11
port-security oui
1-12
port-security port-mode
1-13
port-security timer disableport
1-16
port-security trap
1-17
primary accounting
18-AAA
1-38
primary accounting
18-AAA
1-60
primary authentication
18-AAA
1-39
18-AAA
1-60
primary authorization
18-AAA
1-61
priority
23-QoS-QoS Profile
1-19
priority trust
23-QoS-QoS Profile
1-20
priority-trust
23-QoS-QoS Profile
1-21
probe-failtimes
35-HWPing
1-19
protocol inbound
02-Login
1-15
protocol inbound
29-SSH
1-9
protocol-vlan
04-VLAN
1-18
public-key local create
29-SSH
1-10
public-key local destroy
29-SSH
1-12
public-key local export dsa
29-SSH
1-14
public-key local export rsa
29-SSH
1-13
public-key peer
29-SSH
1-16
public-key peer import sshkey
29-SSH
1-16
public-key-code begin
29-SSH
1-17
public-key-code end
29-SSH
1-18
put
31-FTP-SFTP-TFTP
1-15
put
31-FTP-SFTP-TFTP
1-26
pwd
1-11
pwd
31-FTP-SFTP-TFTP
1-16
pwd
31-FTP-SFTP-TFTP
1-27
Q
23-QoS-QoS Profile
1-22
23-QoS-QoS Profile
1-23
23-QoS-QoS Profile
1-26
qos-profile
23-QoS-QoS Profile
2-4
qos-profile port-based
23-QoS-QoS Profile
2-5
queue-scheduler
23-QoS-QoS Profile
1-27
31-FTP-SFTP-TFTP
1-16
31-FTP-SFTP-TFTP
1-27
1-3
R
radius client
18-AAA
1-40
radius nas-ip
18-AAA
1-40
radius scheme
18-AAA
1-41
radius trap
18-AAA
1-42
radius-scheme
18-AAA
1-20
raw-vlan-id inbound
34-VLAN-VPN
2-1
reboot
3-13
reboot member
25-Stack-Cluster
2-33
region-name
15-MSTP
1-11
remotehelp
31-FTP-SFTP-TFTP
1-17
remote-probe vlan enable
24-Mirroring
1-8
remove
31-FTP-SFTP-TFTP
1-28
rename
1-11
rename
31-FTP-SFTP-TFTP
1-17
rename
31-FTP-SFTP-TFTP
1-28
reset arp
20-ARP
1-13
reset counters interface
1-28
reset dns dynamic-host
37-DNS
1-7
reset dns ipv6 dynamic-host
36-IPv6 Management
1-28
reset dot1x statistics
1-20
reset garp statistics
08-GVRP
1-5
reset hwtacacs statistics
18-AAA
1-62
reset igmp-snooping statistics
16-Multicast
1-18
reset ip routing-table statistics protocol
05-Management VLAN
1-16
reset ip statistics
2-14
reset ipv6 neighbors
36-IPv6 Management
1-29
reset ipv6 statistics
36-IPv6 Management
1-29
reset lacp statistics
10-Link Aggregation
1-8
reset logbuffer
1-17
reset mac-authentication
1-9
reset ndp statistics
25-Stack-Cluster
2-5
reset radius statistics
18-AAA
1-43
reset recycle-bin
1-12
reset saved-configuration
1-10
reset smart-link packets counter
1-6
reset stop-accounting-buffer
18-AAA
1-43
18-AAA
1-63
reset stp
15-MSTP
1-11
reset tcp ipv6 statistics
36-IPv6 Management
1-30
reset tcp statistics
2-15
reset traffic-limit
23-QoS-QoS Profile
1-29
reset traffic-limit vlan
23-QoS-QoS Profile
1-29
reset traffic-statistic
23-QoS-QoS Profile
1-30
reset traffic-statistic vlan
23-QoS-QoS Profile
1-31
reset trapbuffer
1-18
reset udp ipv6 statistics
36-IPv6 Management
1-30
reset udp statistics
2-15
retry
18-AAA
1-44
retry realtime-accounting
18-AAA
1-45
retry stop-accounting
18-AAA
1-46
18-AAA
1-63
return
1-4
revision-level
15-MSTP
1-12
rmdir
1-13
rmdir
31-FTP-SFTP-TFTP
1-18
rmdir
31-FTP-SFTP-TFTP
1-29
rmon alarm
27-SNMP-RMON
2-8
rmon event
27-SNMP-RMON
2-10
rmon history
27-SNMP-RMON
2-11
rmon prialarm
27-SNMP-RMON
2-12
rmon statistics
27-SNMP-RMON
2-14
rsa local-key-pair create
29-SSH
1-19
rsa local-key-pair destroy
29-SSH
1-20
rsa peer-public-key
29-SSH
1-21
rsa peer-public-key import sshkey
29-SSH
1-22
rule (for Advanced ACLs)
22-ACL
1-11
rule (for Basic ACLs)
22-ACL
1-9
rule (for Layer 2 ACLs)
22-ACL
1-18
rule comment
22-ACL
1-20
S
save
1-11
schedule reboot at
3-14
schedule reboot delay
3-15
schedule reboot regularity
3-16
scheme
18-AAA
1-21
screen-length
02-Login
1-16
secondary accounting
18-AAA
1-47
18-AAA
1-64
secondary authentication
18-AAA
1-48
18-AAA
1-65
secondary authorization
18-AAA
1-65
security-policy-server
18-AAA
2-1
self-service-url
18-AAA
1-22
send
02-Login
1-17
send-trap
35-HWPing
1-19
server-type
18-AAA
1-48
service-type
02-Login
1-18
service-type
18-AAA
1-23
service-type multicast
16-Multicast
1-18
set authentication password
02-Login
1-19
sftp
31-FTP-SFTP-TFTP
1-29
sftp server enable
31-FTP-SFTP-TFTP
1-20
sftp timeout
31-FTP-SFTP-TFTP
1-20
shell
02-Login
1-20
shutdown
04-VLAN
1-6
shutdown
1-28
smart-link flush enable
1-6
smart-link group
1-7
smart-link group
2-5
snmp-agent
27-SNMP-RMON
1-11
snmp-agent calculate-password
27-SNMP-RMON
1-12
02-Login
2-2
27-SNMP-RMON
1-13
snmp-agent group
02-Login
2-3
snmp-agent group
27-SNMP-RMON
1-14
snmp-agent local-engineid
27-SNMP-RMON
1-16
snmp-agent log
27-SNMP-RMON
1-16
snmp-agent mib-view
27-SNMP-RMON
1-17
snmp-agent packet max-size
27-SNMP-RMON
1-19
snmp-agent sys-info
27-SNMP-RMON
1-19
snmp-agent target-host
27-SNMP-RMON
1-20
snmp-agent trap enable
27-SNMP-RMON
1-22
snmp-agent trap ifmib
27-SNMP-RMON
1-22
snmp-agent trap life
27-SNMP-RMON
1-23
snmp-agent trap queue-size
27-SNMP-RMON
1-24
snmp-agent trap source
27-SNMP-RMON
1-25
snmp-agent usm-user
02-Login
2-4
snmp-agent usm-user { v1 | v2c }
27-SNMP-RMON
1-26
snmp-agent usm-user v3
27-SNMP-RMON
1-27
snmp-host
25-Stack-Cluster
2-33
source-interface
35-HWPing
1-20
source-ip
35-HWPing
1-21
source-port
35-HWPing
1-22
speed
02-Login
1-21
speed
1-29
ssh authentication-type default
29-SSH
1-23
ssh client assign
29-SSH
1-24
ssh client first-time enable
29-SSH
1-25
ssh server authentication-retries
29-SSH
1-26
ssh server compatible-ssh1x enable
29-SSH
1-27
ssh server rekey-interval
29-SSH
1-27
ssh server timeout
29-SSH
1-28
ssh user
29-SSH
1-29
ssh user assign
29-SSH
1-30
ssh user authentication-type
29-SSH
1-31
ssh user service-type
29-SSH
1-32
ssh2
29-SSH
1-33
stacking
25-Stack-Cluster
1-3
stacking enable
25-Stack-Cluster
1-3
stacking ip-pool
25-Stack-Cluster
1-4
stack-port enable
25-Stack-Cluster
1-2
startup bootrom-access enable
1-18
startup saved-configuration
1-12
state
18-AAA
1-24
state
18-AAA
1-49
stop-accounting-buffer enable
18-AAA
1-50
stopbits
02-Login
1-21
stp
15-MSTP
1-13
stp bpdu-protection
15-MSTP
1-13
stp bridge-diameter
15-MSTP
1-14
stp compliance
15-MSTP
1-15
stp config-digest-snooping
15-MSTP
1-16
stp cost
15-MSTP
1-17
stp dot1d-trap
15-MSTP
1-18
stp edged-port
15-MSTP
1-19
stp interface
15-MSTP
1-20
stp interface compliance
15-MSTP
1-21
stp interface config-digest-snooping
15-MSTP
1-22
stp interface cost
15-MSTP
1-24
stp interface edged-port
15-MSTP
1-25
stp interface loop-protection
15-MSTP
1-26
stp interface mcheck
15-MSTP
1-26
stp interface no-agreement-check
15-MSTP
1-27
stp interface point-to-point
15-MSTP
1-28
stp interface port priority
15-MSTP
1-29
stp interface root-protection
15-MSTP
1-30
stp interface transmit-limit
15-MSTP
1-31
stp loop-protection
15-MSTP
1-32
stp max-hops
15-MSTP
1-32
stp mcheck
15-MSTP
1-33
stp mode
15-MSTP
1-34
stp no-agreement-check
15-MSTP
1-35
stp pathcost-standard
15-MSTP
1-36
stp point-to-point
15-MSTP
1-37
stp port priority
15-MSTP
1-38
stp portlog
15-MSTP
1-39
stp portlog all
15-MSTP
1-39
stp priority
15-MSTP
1-40
15-MSTP
1-40
stp root primary
15-MSTP
1-41
stp root secondary
15-MSTP
1-42
stp root-protection
15-MSTP
1-43
stp tc-protection
15-MSTP
1-44
stp tc-protection threshold
15-MSTP
1-45
stp timer forward-delay
15-MSTP
1-46
stp timer hello
15-MSTP
1-46
stp timer max-age
15-MSTP
1-47
stp timer-factor
15-MSTP
1-48
stp transmit-limit
15-MSTP
1-49
super
01-CLI
1-4
super authentication-mode
01-CLI
1-5
super password
01-CLI
1-6
sysname
1-4
system-guard detect-threshold
4-3
system-guard enable
4-3
system-guard enable
5-2
system-guard mode
5-2
system-guard permit
4-4
system-guard permit
5-3
system-guard timer-interval
4-5
system-monitor enable
3-17
1-5
T
tcp ipv6 timer fin-timeout
36-IPv6 Management
1-30
tcp ipv6 timer syn-timeout
36-IPv6 Management
1-31
tcp ipv6 window
36-IPv6 Management
1-31
tcp timer fin-timeout
2-16
tcp timer syn-timeout
2-16
tcp window
2-17
telnet
02-Login
1-22
telnet ipv6
02-Login
1-23
telnet ipv6
36-IPv6 Management
2-3
terminal debugging
1-18
terminal debugging
1-9
terminal logging
1-19
terminal monitor
1-19
terminal trapping
1-20
test-enable
35-HWPing
1-23
test-failtimes
35-HWPing
1-24
test-type
35-HWPing
1-23
tftp { ascii | binary }
31-FTP-SFTP-TFTP
2-1
tftp get
25-Stack-Cluster
2-34
tftp get
31-FTP-SFTP-TFTP
2-1
tftp ipv6
36-IPv6 Management
2-3
tftp put
25-Stack-Cluster
2-35
tftp put
31-FTP-SFTP-TFTP
2-3
tftp-server
25-Stack-Cluster
2-36
tftp-server acl
31-FTP-SFTP-TFTP
2-3
timeout
35-HWPing
1-25
timer
18-AAA
1-51
timer
25-Stack-Cluster
2-37
timer quiet
18-AAA
1-51
timer quiet
18-AAA
1-66
timer realtime-accounting
18-AAA
1-52
18-AAA
1-67
timer response-timeout
18-AAA
1-53
18-AAA
1-68
time-range
22-ACL
1-21
topology accept
25-Stack-Cluster
2-45
topology restore-from
25-Stack-Cluster
2-46
topology save-to
25-Stack-Cluster
2-46
tos
35-HWPing
1-25
tracemac
25-Stack-Cluster
2-37
tracert
2-3
tracert ipv6
36-IPv6 Management
2-4
traffic-limit
23-QoS-QoS Profile
1-31
traffic-limit
23-QoS-QoS Profile
2-6
traffic-limit vlan
23-QoS-QoS Profile
1-34
traffic-priority
23-QoS-QoS Profile
1-36
traffic-priority
23-QoS-QoS Profile
2-7
traffic-priority vlan
23-QoS-QoS Profile
1-37
traffic-redirect
23-QoS-QoS Profile
1-38
traffic-redirect vlan
23-QoS-QoS Profile
1-39
traffic-shape
23-QoS-QoS Profile
1-40
traffic-statistic
23-QoS-QoS Profile
1-41
23-QoS-QoS Profile
1-42
U
undelete
1-14
unknown-multicast drop enable
16-Multicast
2-5
user
31-FTP-SFTP-TFTP
1-18
user privilege level
02-Login
1-24
user-interface
02-Login
1-23
username
35-HWPing
1-26
user-name-format
18-AAA
1-54
user-name-format
18-AAA
1-68
V
verbose
31-FTP-SFTP-TFTP
1-19
virtual-cable-test
1-30
vlan
04-VLAN
1-7
vlan-assignment-mode
18-AAA
1-25
vlan-mapping
34-VLAN-VPN
3-1
vlan-mapping enable
34-VLAN-VPN
3-2
vlan-mapping modulo
15-MSTP
1-49
vlan-vpn enable
34-VLAN-VPN
1-2
vlan-vpn selective enable
34-VLAN-VPN
2-3
vlan-vpn tpid
34-VLAN-VPN
1-2
vlan-vpn tunnel
15-MSTP
1-50
vlan-vpn vid
34-VLAN-VPN
2-2
voice vlan
07-Voice VLAN
1-4
voice vlan aging
07-Voice VLAN
1-5
voice vlan enable
07-Voice VLAN
1-6
voice vlan legacy
07-Voice VLAN
1-7
voice vlan mac-address
07-Voice VLAN
1-7
voice vlan mode
07-Voice VLAN
1-8
voice vlan security enable
07-Voice VLAN
1-9
W
X
xmodem get
3-17
Y
Z
