H3C S3100 Series Ethernet Switches command Manual-Release 21XX Series(V1.06)
HomeSupportSwitchesS3100 SeriesReference GuidesCommand ReferencesH3C S3100 Series Ethernet Switches command Manual-Release 21XX Series(V1.06)
21-DHCP Commands
21-DHCP Commands 103.19 KB
DHCP Snooping Configuration Commands
dhcp-snooping
dhcp-snooping
undo dhcp-snooping
View
None
Use the dhcp-snooping command to enable the DHCP snooping function.
Use the undo dhcp-snooping command to disable the DHCP snooping function. After DHCP snooping is disabled, all the ports can forward DHCP replies from the DHCP server without recording the IP-to-MAC bindings of the DHCP clients.
By default, the DHCP snooping function is disabled.
Note that:
l          You need to disable DHCP relay agent before enabling DHCP snooping on the switch.
l          The clients connected to a DHCP snooping device cannot obtain an IP address through BOOTP.
Related commands: display dhcp-snooping.
# Enter system view.
# Enable the DHCP snooping function.
[Sysname] dhcp-snooping
dhcp-snooping information enable
undo dhcp-snooping information enable
View
None
Use the dhcp-snooping information enable command to enable DHCP snooping Option 82.
Use the undo dhcp-snooping information enable command to disable DHCP snooping Option 82.
DHCP snooping Option 82 is disabled by default.
Note that:
l          Among S3100 series switches, only S3100-EI series switches support the two commands.
l          Enable DHCP snooping before performing this configuration.
# Enable DHCP snooping Option 82.
[Sysname] dhcp-snooping information enable
dhcp-snooping information format
dhcp-snooping information format { hex | ascii }
View
hex: Specifies the storage format of Option 82 as HEX (namely, hexadecimal string).
ascii: Specifies the storage format of Option 82 as ASCII.
Use the dhcp-snooping information format command to configure the storage format of non-user-defined Option 82 as HEX or ASCII.
By default, the Option 82 is in HEX format.
Note that among S3100 series switches, only S3100-EI series switches support the two commands.
The dhcp-snooping information format command applies only to the default content of the Option 82 field. If you have configured the circuit ID or remote ID sub-option, the storage format of the sub-option is ASCII, instead of the one specified with the dhcp-snooping information format command.
# Configure the storage format of Option 82 as ASCII.
[Sysname] dhcp-snooping information format ascii
dhcp-snooping information packet-format
dhcp-snooping information packet-format { extended | standard }
View
extended: Specifies the padding format for Option 82 as the extended format.
standard: Specifies the padding format for Option 82 as the standard format.
Use the dhcp-snooping information packet-format command to configure the padding format for Option 82 as the extended or standard one.
By default, the padding format for Option 82 is the extended one.
# Configure the padding format for Option 82 as the standard one.
[Sysname] dhcp-snooping information packet-format standard
dhcp-snooping information remote-id
dhcp-snooping information remote-id { sysname | string string }
undo dhcp-snooping information remote-id
View
sysname: Uses the system name (sysname) of the DHCP snooping device to pad the remote ID sub-option in Option 82.
string: Customized content of the remote ID sub-option, a string of 1 to 63 ASCII characters.
Use the dhcp-snooping information remote-id command to configure the remote ID sub-option in Option 82.
Use the undo dhcp-snooping information remote-id command to restore the default value of the remote ID sub-option in Option 82.
By default, the remote ID sub-option in Option 82 is the MAC address of the DHCP Snooping device that received the DHCP client’s request.
# Configure the remote ID sub-option of Option 82 as the system name (sysname) of the DHCP snooping device.
[Sysname] dhcp-snooping information remote-id sysname
dhcp-snooping information strategy
dhcp-snooping information strategy { drop | keep | replace }
undo dhcp-snooping information strategy
View
System view, Ethernet port view
drop: If a packet contains Option 82, DHCP snooping drops this packet.
keep: If a packet contains Option 82, DHCP snooping keeps and forwards this packet.
replace: If a packet contains Option 82, DHCP snooping replaces the original Option 82 field with the Option 82 field having the specified padding content and forwards the packet.
Use the dhcp-snooping information strategy command in system view to configure a handling policy for DHCP requests that contain Option 82 sent by the DHCP client.
Use the undo dhcp-snooping information strategy command to restore the default handling policy.
Use the dhcp-snooping information strategy command in Ethernet port view to configure a handling policy for requests that contain Option 82 received on the current port.
By default, after DHCP-snooping Option 82 support is enabled, DHCP snooping replaces the Option 82 field in the requests sent by the DHCP clients.
l          Enable DHCP-snooping and DHCP-snooping Option 82 before performing this configuration.
l          If a handling policy is configured on a port, this configuration overrides the globally configured handling policy for requests received on this port, while the globally configured handling policy applies on those ports where a handling policy is not natively configured.
# Configure the keep handling policy for DHCP requests that contain Option 82 on the DHCP snooping device.
[Sysname] dhcp-snooping information strategy keep
dhcp-snooping information vlan circuit-id
dhcp-snooping information [ vlan vlan-id ] circuit-id string string
undo dhcp-snooping information { [ vlan vlan-id ] circuit-id | circuit-id all }
View
Ethernet port view
vlan vlan-id: Specifies a VLAN. DHCP packets from the VLAN are padded with the circuit ID sub-option.
string: Content of the circuit ID sub-option, a string of 3 to 63 ASCII characters.
Use the dhcp-snooping information vlan circuit-id command to configure the content of the circuit ID field in Option 82.
Use the undo dhcp-snooping information circuit-id command to restore the default.
With vlan vlan-id specified, the customized circuit ID sub-option applies only to the DHCP packets from the specified VLAN. With no vlan vlan-id specified, the customized circuit ID sub-option applies to all DHCP packets that pass through the current port.
Use the undo dhcp-snooping information vlan vlan-id circuit-id command to restore the default circuit ID in DHCP packets from the specified VLAN.
Use the undo dhcp-snooping information circuit-id command to restore the default circuit ID for all DHCP packets except those from the specified VLAN.
Use the undo dhcp-snooping information circuit-id all command to restore the default circuit ID for all DHCP packets.
By default, the circuit ID field in Option 82 contains the VLAN ID and index of the port that received the client’s request.
If you have configured a circuit ID with the vlan vlan-id argument specified, and the other one without the argument in Ethernet port view, the former circuit ID applies to the DHCP messages from the specified VLAN, while the latter one applies to DHCP messages from other VLANs.
# Set the circuit ID field in Option 82 of the DHCP messages sent through Ethernet 1/0/1 to abc.
[Sysname] interface Ethernet1/0/1
[Sysname-Ethernet1/0/1] dhcp-snooping information circuit-id string abc
dhcp-snooping information vlan remote-id
dhcp-snooping information [ vlan vlan-id ] remote-id string string
undo dhcp-snooping information { [ vlan vlan-id ] remote-id | remote-id all }
View
Ethernet port view
vlan vlan-id: Specifies the VLAN ID of the remote ID to be customized.
string: Customized content of the remote ID sub-option, a string of 3 to 63 ASCII characters.
Use the dhcp-snooping information vlan remote-id command to configure the content of the remote ID in Option 82
Use the undo dhcp-snooping information remote-id command to restore the default remote ID in Option 82.
With vlan vlan-id specified, the customized remote ID sub-option applies only to the DHCP packets from the specified VLAN. Without vlan vlan-id specified, the customized remote ID sub-option applies to all DHCP packets that pass through the current port.
Use the undo dhcp-snooping information vlan vlan-id remote-id command to restore the default remote ID in DHCP packets from the specified VLAN.
Use the undo dhcp-snooping information remote-id command to restore the default remote ID in all DHCP packets except those from the specified VLAN.
Use the undo dhcp-snooping information remote-id all command to restore the default remote ID in all DHCP packets.
If you have configured a remote ID with the vlan vlan-id argument specified, and the other one without the argument in Ethernet port view, the former remote ID applies to the DHCP messages from the specified VLAN, while the latter one applies to DHCP messages from other VLANs.
# Configure the remote ID of Option 82 in DHCP packets to abc on the port Ethernet 1/0/1.
[Sysname-Ethernet1/0/1] dhcp-snooping information remote-id string abc
dhcp-snooping server-guard enable
undo dhcp-snooping server-guard enable
View
Ethernet port view
None
Use the dhcp-snooping server-guard enable command to enable unauthorized DHCP server detection on the port, through which DHCP-DISCOVER messages will be sent to detect unauthorized DHCP servers.
Use the undo dhcp-snooping server-guard enable command to disable unauthorized DHCP server detection on the port.
Note that:
l          Among S3100 series switches, only S3100-SI series switches support the two commands.
l          You need to enable DHCP snooping before enabling unauthorized DHCP server detection on the switch.
# Enable unauthorized DHCP server detection on Ethernet 1/0/3.
[Sysname] interface Ethernet1/0/3
[Sysname-Ethernet1/0/3] dhcp-snooping server-guard enable
dhcp-snooping server-guard method
dhcp-snooping server-guard method { trap | shutdown }
undo dhcp-snooping server-guard method
View
Ethernet port view
trap: Sends a trap to notify the administrator when an unauthorized DHCP server is detected.
shutdown: Shuts down the port administratively when an unauthorized DHCP server is detected, and sends a trap to notify the administrator.
Use the dhcp-snooping server-guard method command to specify the method for handling unauthorized DHCP servers. With the keyword trap specified, when an unauthorized DHCP server is detected, the switch sends a trap to notify the administrator; with the keyword shutdown specified, when an unauthorized DHCP server is detected, the switch shuts down the port administratively, and sends a trap to notify the administrator.
Use the undo dhcp-snooping server-guard method command to restore the default.
By default, the unauthorized DHCP server detection handling method is trap.
Note that:
l          A port shut down administratively is in the closed state and cannot receive or forward packets; however, using the display current-configuration command cannot display the port state. You can use the undo shutdown command in port view to enable this port.
Example
# Specify the unauthorized DHCP server handling method as shutdown.
[Sysname-Ethernet1/0/3] dhcp-snooping server-guard method shutdown
dhcp-snooping server-guard source-mac
dhcp-snooping server-guard source-mac mac-address
undo dhcp-snooping server-guard source-mac
View
mac-address: MAC address, in the format of H-H-H.
Use the dhcp-snooping server-guard source-mac command to specify a source MAC address for DHCP-DISCOVER messages.
Use the undo dhcp-snooping server-guard source-mac command to restore the default MAC address.
By default, the source MAC address of DHCP-DISCOVER messages is the bridge MAC address of the switch.
Note that among S3100 series switches, only S3100-SI series switches support the two commands.
# Specify the source MAC address for DHCP-DISCOVER messages as 000f-e200-3100.
[Sysname] dhcp-snooping server-guard source-mac 000f-e200-3100
dhcp-snooping trust
dhcp-snooping trust
undo dhcp-snooping trust
View
Ethernet port view
None
Use the dhcp-snooping trust command to set an Ethernet port to a DHCP-snooping trusted port.
Use the undo dhcp-snooping trust command to restore an Ethernet port to a DHCP-snooping untrusted port.
By default, with the DHCP snooping enabled, all the ports of a switch are untrusted ports.
Note that:
l          After DHCP snooping is enabled, you need to specify the port connected to a valid DHCP server as trusted to ensure that DHCP clients can obtain valid IP addresses. The trusted port and the ports connected to DHCP clients must be in the same VLAN.
Related commands: display dhcp-snooping trust.
# Set the Ethernet 1/0/1 port to a trusted port.
[Sysname-Ethernet1/0/1] dhcp-snooping trust
display dhcp-snooping [ unit unit-id ]
View
unit unit-id: Indicates the number of the device whose DHCP-snooping information needs to be viewed, the value is 1.
Use the display dhcp-snooping command to display the user IP-MAC address mapping entries recorded by the DHCP snooping function.
Related commands: dhcp-snooping.
# Display the user IP-MAC address mapping entries recorded by the DHCP snooping function (S3100-EI).
<Sysname> display dhcp-snooping
 DHCP-Snooping is enabled.
 The client binding table for all untrusted ports.
 Type : D--Dynamic , S--Static
 Unit ID : 1
 Type IP Address       MAC Address      Lease      VLAN Interface
 D    10.1.1.1          00e0-fc00-0006   200        1     Ethernet1/0/1
---   1 dhcp-snooping item(s) of unit 1 found   ---
# Display the user IP-MAC address mapping entries recorded by the DHCP snooping function (S3100-SI).
 Type IP Address       MAC Address       Remaining  VLAN Interface
                                              lease
 D     10.1.1.1          00e0-fc00-0006   N/A         1    Ethernet1/0/1
display dhcp-snooping server-guard
View
None
Use the display dhcp-snooping server-guard command to display information about unauthorized DHCP server detection.
Note that among S3100 series switches, only S3100-SI series switches support this command.
# Display information about unauthorized DHCP server detection.
<Sysname> display dhcp-snooping server-guard
 DHCP-Snooping server guard become effective.
 Interface             Status                        Find Time
 Ethernet1/0/3         Server detected               223
 Ethernet1/0/4         No server detected            0
 Ethernet1/0/5         Server detected and shutdown  213
Table 1-1 Description on the fields of the display dhcp-snooping server-guard command
The DHCP snooping function is enabled.
Unauthorized DHCP server detection is enabled.
The ports enabled with unauthorized DHCP server detection
Status
Port status:
l      No server detected: No unauthorized DHCP server is detected on the port.
l      Server detected: An unauthorized DHCP server was detected on the port, and a trap was sent.
l      Server detected and shutdown: An unauthorized DHCP server was detected on the port. The port has been shut down administratively, and a trap was sent.
Find Time
The time interval between when the switch started and when the last unauthorized DHCP server was detected, in seconds. (If no unauthorized DHCP server is detected, 0 is displayed.)
View
None
Use the display dhcp-snooping trust command to display the (enabled/disabled) state of the DHCP snooping function and the trusted ports.
Note that among S3100 series switches, only S3100-EI series switches support the command.
Related commands: dhcp-snooping trust.
# Display the state of the DHCP snooping function and the trusted ports.
<Sysname> display dhcp-snooping trust
 DHCP-Snooping trust become effective.
 Interface                 Trusted
 Ethernet1/0/10          Trusted
The above display information indicates that the DHCP snooping function is enabled, and the Ethernet 1/0/10 port is a trusted port.
display ip source static binding
display ip source static binding [ vlan vlan-id | interface interface-type interface-number ]
View
vlan-id: ID of the VLAN whose IP static binding entries are to be displayed.
interface-type interface-number: Type and number of the port whose IP static binding entries are to be displayed.
Use the display ip source static binding command to display the IP static binding entries configured. If you specify a VLAN, all the IP static binding entries for the specified VLAN will be displayed. If you specify a port, all the IP static binding entries for the specified port will be displayed.
# Display all IP static binding entries configured.
<Sysname> display ip source static binding
                                      lease
 S    192.168.0.25    0015-e20f-0101  infinite     1    Ethernet1/0/2
 S    192.168.0.58    0001-e201-4f01  infinite     1    Ethernet1/0/3
 S    192.168.0.101   000f-0101-0204  infinite     1    Ethernet1/0/2
 S    192.168.0.122   000f-e20f-21a3  infinite     1    Ethernet1/0/3
 S    192.168.0.144   0015-e943-712f  infinite     1    Ethernet1/0/2
---   5 static binding item(s) found   ---
ip check source ip-address
ip check source ip-address [ mac-address ]
undo ip check source ip-address [ mac-address ]
View
Ethernet port view
mac-address: Enables IP filtering based on the source MAC address of the packets.
Use the ip check source ip-address command to enable the filtering of the IP packets received through the current port based on the source IP address of the packets.
Use the undo ip check source ip-address command to disable the filtering of the IP packets received through the current port based on the source IP address of the packets.
Use the ip check source ip-address mac-address command to enable the filtering of the IP packets received through the current port based on the source IP address and source MAC address of the packets.
Use the undo ip check source ip-address mac-address command to disable the filtering of the IP packets received through the current port based on the source IP address and source MAC address of the packets.
By default, the filtering of the IP packets received through a port based on the source IP address or source MAC address of the packets is disabled.
# Enable the filtering of the IP packets received through port Ethernet 1/0/11 based on the source IP address of the packets.
[Sysname] interface Ethernet 1/0/11
[Sysname-Ethernet1/0/11] ip check source ip-address
ip source static binding ip-address ip-address [ mac-address mac-address ]
undo ip source static binding ip-address ip-address
View
Ethernet port view
ip-address ip-address: Specifies the IP address to be statically bound.
mac-address mac-address: Specifies the MAC address to be statically bound.
Use the ip source static binding ip-address command to configure the static binding among source IP address, source MAC address, and the port number so as to generate static binding entries.
Use the undo ip source static binding ip-address command to remove the static binding among source IP address, source MAC address, and the port.
By default, no binding among source IP address, source MAC address, and the port number is configured.
To create a static binding after IP filtering is enabled with the mac-address keyword included on a port, the mac-address argument must be specified; otherwise, the packets sent from this IP address cannot pass the IP filtering.
Related commands: ip check source ip-address.
# Configure static binding among source IP address 1.1.1.1, source MAC address 0015-e20f-0101, and Ethernet 1/0/3.
[Sysname] interface Ethernet 1/0/3
[Sysname-Ethernet1/0/3] ip source static binding ip-address 1.1.1.1 mac-address 0015-e20f-0101
Among S3100 series Ethernet switches, only S3100-EI series switches support the DHCP Rate Limit function.
Rate Limit Configuration Commands
dhcp protective-down recover enable
undo dhcp protective-down recover enable
View
None
Use the dhcp protective-down recover enable command to enable port state auto-recovery on the switch.
Use the undo dhcp protective-down recover enable command to disable port state auto-recovery.
With the port state auto-recovery function, a port that is shut down because the DHCP traffic rate limit configured on it is exceeded can automatically be brought up after a specified interval.
By default, the port state auto-recovery function on the switch is disabled.
# Enable port state auto-recovery on the switch.
[Sysname] dhcp protective-down recover enable
dhcp protective-down recover interval
dhcp protective-down recover interval interval
undo dhcp protective-down recover interval
View
interval: Interval (in seconds) for a port disabled due to the DHCP traffic exceeding the set threshold to be brought up again. This argument ranges from 10 to 86,400.
Use the dhcp protective-down recover interval command to set an auto recovery interval.
Use the undo dhcp protective-down recover interval command to restore the default interval.
With the port state auto-recovery function enabled on a switch, the auto recovery interval defaults to 300 seconds.
Note that:
l          Before configuring the port state auto-recovery interval, you must enable port state auto-recovery on the switch first.
l          The new port state auto-recovery interval only applies to the ports that are shut down after the dhcp protective-down recover interval command is last executed.
# Set the port state auto-recovery interval to 30 seconds.
[Sysname] dhcp protective-down recover interval 30
dhcp rate-limit
dhcp rate-limit rate
undo dhcp rate-limit
View
Ethernet port view
rate: Maximum rate of DHCP traffic in pps. This argument ranges from 10 to 150.
Use the dhcp rate-limit command to configure the maximum rate of DHCP traffic for the port. When the number of DHCP packets received on the port per second exceeds the specified threshold, the switch will discard the exceeding DHCP packets.
Use the undo dhcp rate-limit command to restore the default.
By default, after the DHCP traffic limit is enabled, the maximum rate of DHCP traffic is 15 pps.
Note that:
You need to enable the function to limit DHCP traffic (refer to the dhcp rate-limit enable command) for a port before executing either of these two commands for the port.
# Configure the DHCP traffic threshold to 100 pps for port Ethernet 1/0/11.
[Sysname] interface ethernet 1/0/11
[Sysname-Ethernet1/0/11] dhcp rate-limit enable
[Sysname-Ethernet1/0/11] dhcp rate-limit 100
undo dhcp rate-limit enable
View
Ethernet port view
None
Use the dhcp rate-limit enable command to enable the function to limit DHCP traffic for an Ethernet port. You can use this command to limit the DHCP traffic passing through an Ethernet port. When the number of DHCP packets received on the port per second exceeds the specified threshold (the default value is 15 pps), the switch will discard the exceeding DHCP packets.
Use the undo dhcp rate-limit enable command to disable the function. You can use this command to relieve the DHCP traffic limit configured on an Ethernet port.
By default, the function to limit DHCP traffic is disabled on an Ethernet port. That is, DHCP traffic passing through an Ethernet port is not limited.
# Enable the function to limit DHCP traffic for Ethernet 1/0/11 port.
DHCP/BOOTP Client Configuration
DHCP Client Configuration Commands
display dhcp client
display dhcp client [ verbose ]
View
verbose: Displays the detailed address allocation information.
Use the display dhcp client command to display the information about the address allocation of DHCP clients.
Note that S3100 series Ethernet switches that operate as DHCP clients support a maximum lease duration of 24 days currently.
# Display the information about the address allocation of DHCP clients.
<Sysname> display dhcp client verbose
DHCP client statistic information:
Vlan-interface1:
Current machine state: BOUND
Allocated IP: 192.168.0.2 255.255.255.0
Allocated lease: 86400 seconds, T1: 43200 seconds, T2: 75600 seconds
Lease from 2002.09.20 01:05:03   to   2002.09.21 01:05:03
Server IP: 192.168.0.1
Transaction ID = 0x3d8a7431
Default router: 192.168.0.1
Next timeout will happen after 0 days 11 hours 56 minutes 1 seconds.
Table 3-1 Description on the fields of the display dhcp client command
Vlan-interface1
VLAN interface operating as a DHCP client to obtain an IP address dynamically
The state of the client state machine
Allocated IP
IP address allocated to the DHCP client
lease
Lease period
T1
Renewal timer setting
T2
Rebinding timer setting
Lease from….to….
The starting and end time of the lease period
Server IP
IP address of the DHCP server selected
Transaction ID
Transaction ID
Default router
Gateway address
The timer expires in 11 hours, 56 minutes, and 1 second.
ip address dhcp-alloc
undo ip address dhcp-alloc
View
VLAN interface view
None
Use the ip address dhcp-alloc command to configure a VLAN interface to obtain an IP address through DHCP.
Use the undo ip address dhcp-alloc command to cancel the configuration.
By default, a VLAN interface does not use DHCP to obtain an IP address.
To improve security and avoid malicious attacks to the unused sockets, S3100 Ethernet switches provide the following functions:
l          UDP ports 67 and 68 used by DHCP are enabled/disabled only when DHCP is enabled/disabled.
The implementation is as follows:
l          After the DHCP client is enabled by executing the ip address dhcp-alloc command, UDP port 68 is enabled.
l          After the DHCP client is disabled by executing the undo ip address dhcp-alloc command, UDP port 68 is disabled.
# Configure VLAN-interface 1 to obtain an IP address through DHCP.
[Sysname] interface Vlan-interface 1
[Sysname-Vlan-interface1] ip address dhcp-alloc
BOOTP Client Configuration Commands
display bootp client
display bootp client [ interface Vlan-interface vlan-id ]
View
vlan-id: ID of the VLAN interface.
Use the display bootp client command to display BOOTP client-related information, including the MAC address of the BOOTP client and the IP address obtained.
# Display the BOOTP client-related information.
<Sysname> display bootp client interface Vlan-interface 1
Vlan-interface1:
Mac Address  000f-e20a-c3ef
Table 3-2 Description on the fields of the display bootp client command
Vlan-interface1
VLAN-interface 1 is configured to obtain an IP address through BOOTP.
Allocated IP
IP address allocated to the VLAN interface
Transaction ID
Value of the XID field in BOOTP packets
Mac Address
Default router
Default router
ip address bootp-alloc
undo ip address bootp-alloc
View
VLAN interface view
None
Use the ip address bootp-alloc command to configure a VLAN interface to obtain an IP address through BOOTP.
Use the undo ip address bootp-alloc command to cancel the configuration.
By default, a VLAN interface does not use BOOTP to obtain an IP address.
Related commands: display bootp client.
# Configure VLAN-interface 1 to obtain an IP address through BOOTP.
[Sysname-Vlan-interface1] ip address bootp-alloc
