H3C S9500 Command Manual-Release1648[v1.24]-07 Security Volume
HomeSupportSwitchesS9500 SwitchesReference GuidesCommand ReferencesH3C S9500 Command Manual-Release1648[v1.24]-07 Security Volume
09-Traffic Accounting Commands
09-Traffic Accounting Commands 40.3 KB
Chapter 1  Traffic Accounting Configuration Commands
1.1  Traffic Accounting Configuration Commands
1.1.1  accounting enable
accounting enable
undo accounting enable
View
Traffic statistics view
None
Use the accounting enable command to enable the traffic accounting function on the traffic accounting card.
Use the undo accounting enable command to disable the traffic accounting function on the traffic accounting card.
The traffic accounting card starts traffic accounting immediately after the traffic accounting function is enabled.
By default, the traffic accounting function is disabled on the traffic accounting card.
# Enable the traffic accounting function.
<H3C> system-view
[H3C] traffic-accounting accounting-slot 5
[H3C-accounting-slot-5] accounting enable
# Disable the traffic accounting function.
[H3C-accounting-slot-5] undo accounting enable
1.1.2  accounting-mode traffic
View
ISP domain view
None
Use the accounting-mode traffic command to specify the accounting mode as traffic accounting.
Use the undo accounting-mode traffic command to restore the default accounting mode of the system.
By default, the system adopts the time accounting mode.
# Specify the accounting mode as traffic accounting.
<H3C> system-view
[H3C] domain cams
[H3C-isp-cams] accounting-mode traffic
# Restore the default accounting mode of the system.
[H3C-isp-cams] undo accounting-mode traffic
1.1.3  debugging traffic-accounting event
View
None
Use the debugging traffic-accounting event command to enable debugging for traffic accounting.
Use the undo debugging traffic-accounting event command to disable debugging for traffic accounting.
By default, the debugging for traffic accounting disabled.
Enable debugging for traffic accounting.
<H3C> debugging traffic-accounting event
1.1.4  display traffic-accounting accounting-slot
display traffic-accounting accounting-slot [ slot-num ]
View
slot-num: Slots for traffic accounting.
Use the display traffic-accounting-slot command to display the configuration information of the traffic accounting slots. If you specify the slot-num parameter, the command displays the configuration information of the specified traffic accounting slot. Otherwise, the command displays the configuration information of all traffic accounting slots.
&  Note:
At present, the system supports only one traffic accounting slot. Therefore the configuration information of a specified traffic accounting slot is the same with the configuration information of all traffic accounting slots when you execute the command.
# Display the configuration information of the traffic accounting slot 4.
<H3C> display traffic-accounting accounting-slot 4
Accounting slot number : 4
 traffic accounting is enabled
1.1.5  display traffic-accounting statistics
display traffic-accounting statistics [ ip-address ]
View
ip-address: IP address.
Use the display traffic-accounting statistics command to display the traffic statistics information of the current online users. If you specify the ip-address parameter, the command displays the traffic information of a specified IP address. Otherwise, this command displays the traffic information of all the online IP addresses.
# Display the traffic statistics information of the current online users.
<H3C> display traffic-accounting statistics
User IP: 10.0.0.1
  group name :somegroup
    output octets low-32: 0           output octets high-32: 0
    input octets low-32 : 0           input octets high-32 : 0
1.1.6  display traffic-accounting traffic-group
display traffic-accounting traffic-group [ group-name ]
View
group-name: Name of a traffic group.
Use the display traffic-accounting traffic-group command to display the configuration information of the traffic groups.
If you specify the group-name parameter, the configuration information of the specified traffic group is displayed. Otherwise, the configuration information of all traffic groups is displayed.
# Display the configuration information of the traffic group somegroup.
<H3C> display traffic-accounting traffic-group somegroup
Traffic group : somegroup
      1.1.1.0/255.255.255.0
Total 1 networks.      Not referenced
# Display the configuration information of all traffic groups.
Traffic group : default-group
      0.0.0.0/0.0.0.0
1.1.7  network
network ip-address { mask | masklen }
undo network ip-address { mask | masklen }
View
Traffic group view
mask: Subnet mask.
masklen: Mask length.
Use the network command to add network segment.
Use the undo network command to delete network segment.
&  Note:
Each traffic group is allowed to configure up to 512 traffic group addresses.
The network segment to be added in a traffic group shall not overlap the existed network segment in this traffic group, or be identical with the network segment in other traffic groups.
# Add a network segment.
<H3C> system-view
[H3C] traffic-accounting traffic-group somegroup
[H3C-traffic-group-somegroup] network 10.0.0.0 16
# Delete a network segment.
[H3C-traffic-group-somegroup] undo network 10.0.0.0 16
1.1.8  traffic-accounting accounting-slot
traffic-accounting accounting-slot slot-num
undo traffic-accounting accounting-slot slot-num
View
slot-num: Slot number.
Use the traffic-accounting accounting-slot command to specify a traffic accounting slot.
Use the undo traffic-accounting accounting-slot command to remove the specified traffic accounting slot.
By default, no slot is specified for traffic accounting.
Related commands: display traffic-accounting accounting-slot.
# Specify slot 6 for traffic accounting.
<H3C> system-view
[H3C] traffic-accounting accounting-slot 6
# Remove the specified traffic accounting slot 6.
[H3C] undo traffic-accounting accounting-slot 6
1.1.9  traffic-accounting traffic-group
traffic-accounting traffic-group group-name
undo traffic-accounting traffic-group group-name
View
group-name: Name of a traffic group. The length of the name is up to 32 characters.
Use the traffic-accounting traffic-group command to create a traffic group or enter an existed traffic group.
Use the undo traffic-accounting traffic-group command to delete the created traffic group.
The system is allowed to configure up to 7 traffic groups. And there is still a default traffic group which is not allowed to configure.
By default, there is a default traffic group.
Related commands: display traffic-accounting traffic-group.
# Create a traffic group test-group.
<H3C> system-view
[H3C] traffic-accounting traffic-group test-group
# Delete the created traffic group test-group.
[H3C] undo traffic-accounting traffic-group test-group
1.1.10  traffic-group
traffic-group group-name rate idnum
View
Domain view
idnum: ID of the charging rate, in the range of 1 to 255, identifies different charging rate. Ignore the configuration for current implementation; leave it for extension.
Use the traffic-group command to set a domain-applied traffic group.
Use the undo traffic-group command to cancel a domain-applied traffic group.
If a traffic group is applied to a domain, when a user who belongs to the domain accesses the traffic group, the generated traffic is accounted and the user is charged based on the generated traffic.
By default, no traffic group is applied to a domain.
# Configure to apply the traffic group “test-group” to domain “CAMS”. The rate is 1.
<H3C> system-view
[H3C] domain cams
[H3C-isp-cams] traffic-group test-group rate 1
