H3C S9500 Command Manual-Release1648[v1.24]-07 Security Volume
HomeSupportSwitchesS9500 SwitchesReference GuidesCommand ReferencesH3C S9500 Command Manual-Release1648[v1.24]-07 Security Volume
06-IDS Linkage Commands
06-IDS Linkage Commands 24.47 KB
Chapter 1  IDS Linkage Configuration Commands
1.1  IDS Linkage Configuration Commands
1.1.1  ids-acl
ids-acl enable
undo ids-acl enable
View
Ethernet port view
disable: Disable IDS linkage on the port.
enable: Enable IDS linkage on the port.
Use the acl-ids enable command to enable IDS linkage function.
Use the undo ids-acl enable command to disable IDS linkage function.
# Enable IDS linkage on port Ethernet 3/1/1.
<H3C> system-view
[H3C] interface Ethernet 3/1/1
[H3C-Ethernet3/1/1] ids-acl enable
1.1.2  display ids
display ids { all | controlled-interface | name name | source ip-addr | destination ip-addr }
View
all: Displays all information about IDS linkage.
name: Name of the IDS item to be displayed.
source ip-addr: Displays IDS linkage information about the specified source IP address.
destination ip-addr: Displays IDS linkage information about the specified destination IP address.
controlled-interface: Displays a list of ports with IDS linkage currently enabled.
Use the display ids command to display IDS linkage information, which includes:
l           The total number of IDS linkage messages
l           The list of ports available for IDS linkage
l           Displays the IDS linkage information which meets the requirement on by one
# Display all information about IDS linkage.
<H3C> system-view
[H3C]display ids all
Port list under IDS control is:
   Ethernet2/1/10          Ethernet2/1/11          Ethernet2/1/12
   Ethernet2/1/13          Ethernet2/1/14          Ethernet2/1/15
ACL group ID list used by IDS is:
    3997 3996 3995 3994 3993 3992 3991 3990 3989 3988
Number of items 1, running items 1
ACL rules created by IDS is:
  1  Name 4
    Action deny,  time 3000, curtime 2860, group 3997, subitem 0
    Smac any,    sip any,  swild 255.255.255.255,        prot 1
    Dmac any,    dip any,  dwild 255.255.255.255,        prot 1
1.1.3  debugging ids-acl
debugging ids-acl
undo debugging ids-acl
View
None
Use the debugging ids-acl command to enable IDS linkage debugging.
Use the undo debugging ids-acl command to disable IDS linkage debugging.
By default, IDS linkage debugging is disabled.
# Enable IDS linkage debugging.
<H3C>debugging ids-acl
# Disable IDS linkage debugging.
<H3C>undo debugging ids-acl
