H3C S9500 Command Manual-Release1648[v1.24]-07 Security Volume
HomeSupportSwitchesS9500 SwitchesReference GuidesCommand ReferencesH3C S9500 Command Manual-Release1648[v1.24]-07 Security Volume
05-SSH Commands
05-SSH Commands 124.64 KB
Table of Contents
Chapter 1 SSH Terminal Service Configuration Commands. 1-1
1.1 SSH Server Configuration Commands. 1-1
1.1.1 debugging ssh server 1-1
1.1.2 display rsa local-key-pair public. 1-2
1.1.3 display rsa peer-public-key. 1-3
1.1.4 display ssh server 1-4
1.1.5 display ssh user-information. 1-5
1.1.6 peer-public-key end. 1-6
1.1.7 protocol inbound. 1-7
1.1.8 public-key-code begin. 1-8
1.1.9 public-key-code end. 1-9
1.1.10 rsa local-key-pair create. 1-10
1.1.11 rsa local-key-pair destroy. 1-11
1.1.12 rsa peer-public-key. 1-12
1.1.13 ssh server authentication-retries. 1-12
1.1.14 ssh server compatible_ssh1x enable. 1-13
1.1.15 ssh server rekey-interval 1-14
1.1.16 ssh server timeout 1-14
1.1.17 ssh user assign rsa-key. 1-15
1.1.18 ssh user authentication-type. 1-16
1.1.19 ssh authentication-type default 1-17
1.2 SSH Client Configuration Commands. 1-18
1.2.1 display ssh server-info. 1-18
1.2.2 quit 1-18
1.2.3 ssh client assign rsa-key. 1-19
1.2.4 ssh client first-time enable. 1-19
1.2.5 ssh2. 1-20
1.3 SFTP Server Configuration Commands. 1-22
1.3.1 sftp server enable. 1-22
1.3.2 ssh service-type default 1-22
1.3.3 ssh user service-type. 1-23
1.4 SFTP Client Configuration Commands. 1-24
1.4.1 bye. 1-24
1.4.2 cd. 1-25
1.4.3 cdup. 1-25
1.4.4 delete. 1-25
1.4.5 dir 1-26
1.4.6 exit 1-27
1.4.7 get 1-27
1.4.8 help. 1-28
1.4.9 ls. 1-28
1.4.10 mkdir 1-29
1.4.11 put 1-29
1.4.12 pwd. 1-30
1.4.13 quit 1-30
1.4.14 remove. 1-31
1.4.15 rename. 1-31
1.4.16 rmdir 1-32
1.4.17 sftp. 1-32
debugging ssh server { vty index | all }
undo debugging ssh server { vty index | all }
View
index: SSH channel to be debugged, whose value is dictated by VTY numbers. The default VTY numbers are 0 to 4.
all: Specifies all the SSH channels.
Use the debugging ssh server command to send information regulated by the SSH2.0 protocol, such as the negotiation procedure, to the information center in the format of Debugging information. You can also use it to debug a user interface individually.
Use the undo debugging ssh server command to disable the debugging.
By default, the debugging is disabled.
Logs related to the SSH server are recorded into the log file or log buffer only if debugging is enabled.
Related commands: ssh server authentication-retries, ssh server rekey-interval, ssh server timeout.
# Print the debugging information when the SSH is running.
<H3C> debugging ssh server vty 0
*0.1426091 9505A SSH/8/debugging_msg_send:SSH_VERSION_SEND message sent on VTY 0
*0.1426188 9505A SSH/8/SSH2 debug:debug info:The server's ssh version sent SSH-1
SSH-1.99-CMW-3.3
*0.1426299 9505A SSH/8/msg_rcv_vty:SSH_VERSION_RECEIVE message received on VTY 0
*0.1426995 9505A SSH/8/SSH2 debug:debug info:Now the server version is ssh2
*0.1427088 9505A SSH/8/SSH2 debug:debug info: The algorithm negotiation begins
*0.1427190 9505A SSH/8/SSH2 debug:debug info:SSH2_MSG_KEXINIT sent
*0.1427269 9505A SSH/8/SSH2 debug:debug info: SSH2_MSG_KEXINIT received
*0.1427360 9505A SSH/8/SSH2 debug:debug info:kex: client->server des-cbc hmac-sh
a1
*0.1427461 9505A SSH/8/SSH2 debug:debug info:kex: server->client des-cbc hmac-sh
a1
*0.1427562 9505A SSH/8/SSH2 debug:debug info:The key exchange algorithm is diffi
e-hellman-group1-sha1
*0.1427695 9505A SSH/8/SSH2 debug:debug info: The algorithm choose is done
*0.1427784 9505A SSH/8/SSH2 debug:debug info:SSH2_MSG_KEXDH_INIT received
*0.1427875 9505A SSH/8/SSH2 debug:debug info:SSH2_MSG_KEXDH_REPLY sent
*0.1427966 9505A SSH/8/SSH2 debug:debug info:SSH2_MSG_NEWKEYS  sent
*0.1428047 9505A SSH/8/SSH2 debug:debug info:SSH2_MSG_NEWKEYS  received
*0.1428138 9505A SSH/8/SSH2 debug:debug info:The key exchange is done
*0.1428229 9505A SSH/8/SSH2 debug:debug info:User authentication begins
*0.1428320 9505A SSH/8/SSH2 debug:debug info:SSH2_MSG_SERVICE_REQUEST received
*0.1428421 9505A SSH/8/SSH2 debug:debug info:SSH2_MSG_SERVICE_ACCEPT sent
*0.1428513 9505A SSH/8/SSH2 debug:debug info:SSH2_MSG_USERAUTH_REQUEST received
with user:admin,service:ssh-connection,metho
d:none
View
None
Use the display rsa local-key-pair public command to display the public key of the server’s host key pair and server key pair.
Related commands: rsa local-key-pair create.
# Display the public key of the server’s host key pair and server key pair.
<H3C> display rsa local-key-pair public
% Key pair was generated at: 12:26:33 UTC 2002/4/4
 Key name: rtvrp_Host
 Usage: Encryption Key
 Key Data:
30470240 AF7DB1D0 DA78944F 53B7B59B 40D425D0 DC9C57D2 A60916C2 1F165807 08B84DDB 5F4DB8E7 A115B74E 2D41D96C AC61D276 AA027E41 DD48DE64 696E0934 EB872805 02030100 01
% Key pair was generated at: 12:26:45 UTC 2002/4/4
 Key name: rtvrp_Server
 Key Data:
30670260 C05280D9 BA0D56C8 7BE43379 8634CDE7 83ABA9A2 3F36280E 25995487 4FF6AD7A 0E57871C 761E6D92 9914D8C5 CC577388 5B580B94 C2172C8F 36039EED 160A0478 651DED3A 9CCF1AAD D800AAF2 DF7FBEC4 A13ADA59 9E738319 AF366B8B 519D39F5 02030100 01
display rsa peer-public-key [ brief | name keyname ]
View
brief: Displays the brief information about all client public keys.
keyname: Public key name of the client to be displayed. The key name is a consecutive string whose length ranges from 1 to 64 characters.
Use the display rsa peer-public-key command to display the public key of RSA key pair specified by the client. If you do not specify the keyname argument, all public keys will be displayed.
# Display the public key of the specified RSA key pair of the client.
<H3C> display rsa peer-public-key brief
Address        Bits   Name
                1023   abcd
                1024   hq
                1024   wn1
                1024   hq_all
# Display the public key of the specified RSA key pair named abcd of the client.
<H3C> display rsa peer-public-key name 127.0.0.1
    Key name: 127.0.0.1
    Key address:
Key Code:
308188
  028180
    CFC6A68B 39F742A2 76E55B07 39D60B73 D7B4040D 515B2516 17CE9380 53829FF5
    C0489BD9 559CC425 CAF37E6F E6417337 693DF5CD 02F12469 420BBD5C 38741295
    D74B2336 A5F28FE8 00E0429F FCF47A7F AEF0A1B9 740FC2BE 99F26F35 39C8867D
    FAE8C2A1 EAC4CB42 A64982C9 4BA1DD63 49619762 E46F17DF ED1C1ACC DFAB8CB5
  0203
    010001
display ssh server { status | session }
View
status: Displays the SSH status information.
session: Displays the SSH session information.
Use the display ssh server command to display the status information or session information of an SSH server.
# Display the status information of the SSH server.
<H3C> display ssh server status
SSH - version 1.5
SSH connection timeout: 60 seconds
SSH server key generating interval : 1 hours
SSH Authentication retries: 3 times
SFTP Server: Disable
# Display the session information of the SSH server.
<H3C> display ssh server session
Connection   Version Encryption  State           Username
VTY0         1.99        DES         Session started H3C
VTY3         2.0     DES         Session started router
View
username: Valid SSH user name, a string of 1 to 32 characters.
Use the display ssh user-information command to display the information of the current SSH user, such as username, name of the corresponding peer public key, authentication mode, and authorized service type. If you specify a username for the username argument in the command, the system displays the information of the specified user.
Related commands: ssh user assign rsa-key, ssh user authentication-type, ssh user service-type, display local-user, display rsa peer-public-key.
# Display the information of the current SSH user.
<H3C> display ssh user-information
Username       Authentication-type  Public-key-name  Service-type  Directory
sftp             password             null             stelnet       null
 aaaaaaaaaaaaaa.. password-publickey   12345678901234.. stelnet       null
Total 92 ssh user(s) Matched, 8 listed.
Up to 15 characters of the username or the public key name can be displayed, while up to 9 characters of the directory can be displayed. When the username, public-key-name, and directory contain too many characters, the system displays the result with the wildcards “...”, as shown in the following example:
Username      Authentication-type  User-public-key-name  Service-type Directory
admin              password             aaaaaaaaaabbbbbbb...  sftp flash:
aaaaaaaaaabbbbbb... all         aaaaaaaaaabbbbbbb...  stelnet null
fxdfxdfxdfxdfxdf... null         null          stelnet|sftp null
You can use the display local-user and display rsa peer-public-key commands respectively to view too long a username, public-key-name, and directory.
peer-public-key end
View
Public key view
None
Use the peer-public-key end command to exit the public key view and return to the system view.
Related commands: rsa peer-public-key, public-key-code begin.
# Exit the public key view and save the configuration.
<H3C> system-view
[H3C] rsa peer-public-key H3C003
RSA public key view: return to System View with "peer-public-key end".
[H3C-rsa-public-key] peer-public-key end
[H3C]
View
VTY user interface view
all: Supports all protocols, including Telnet and SSH.
ssh: Supports the SSH protocol only, and does not support the Telnet protocol.
telnet: Supports the Telnet protocol only, and does not support the SSH protocol.
Use the protocol inbound command to specify the protocol supported by the current user interface.
By default, all protocols are supported.
This configuration takes effect at the next login. Note that after enabling SSH by this command, you still cannot log in through SSH if the client RSA key is not configured.
  Caution:
l      If the supported protocol configured in the user interface is SSH, make sure to configure the corresponding authentication mode to authentication-mode scheme (using AAA authentication mode).
l      If the authentication mode is configured as authentication-mode password or authentication-mode none, the configuration of protocol inbound ssh will fail; contrarily, if a user interface is configured to support the SSH protocol, you will fail to configure authentication-mode password and authentication-mode none.
Related commands: user-interface vty.
# Set VTY 0 to 4 to support the SSH protocol only.
<H3C> system-view
[H3C] user-interface vty 0 4
[H3C-ui-vty0-4] protocol inbound ssh
# Disable the Telnet function of VTY 0 and make it support SSH only.
<H3C> system-view
[H3C-ui-vty0] protocol inbound ssh
View
Public key view
None
Use the public-key-code begin command to enter the public key edit view and input the public key of the client. Note that you must use the rsa peer-public-key command to specify a client key name before performing this command.
When inputting the public key, you may type spaces between the characters (the system will delete the spaces automatically), or press <Enter> and then continue to input the key. Note that the public key must be a hexadecimal string coded in the public key format and is randomly generated by the SSH 2.0-enabled client software or the client switch.
Related commands: rsa peer-public-key, public-key-code end.
# Enter the public key edit view and input the key.
<H3C> system-view
[H3C-rsa-public-key] public-key-code begin
RSA key code view: return to last view with "public-key-code end".
[H3C-key-code] 308186028180739A291ABDA704F5D93DC8FDF84C427463
[H3C-key-code] 1991C164B0DF178C55FA833591C7D47D5381D09CE82913
[H3C-key-code] D7EDF9C08511D83CA4ED2B30B809808EB0D1F52D045DE4
[H3C-key-code] 0861B74A0E135523CCD74CAC61F8E58C452B2F3F2DA0DC
[H3C-key-code] C48E3306367FE187BDD944018B3B69F3CBB0A573202C16
[H3C-key-code] BB2FC1ACF3EC8F828D55A36F1CDDC4BB45504F020125
[H3C-key-code] public-key-code end
public-key-code end
View
Public key edit view
None
Use the public-key-code end command to return from the public key edit view to the public key view and save the public key entered.
After this command is performed to end the public key edit procedure, the system will check the validity of the key before saving the input public key. If the public key string contains any illegal character, the system will prompt the failure of the configuration and the configured key will be discarded; otherwise, the key is valid and will be saved to the user public keys in the system.
# Exit the public key edit view and save the configured public key.
<H3C> system-view
[H3C-rsa-key-code] public-key-code end
View
None
Use the rsa local-key-pair create command to generate the RSA key pair (including the host key and server key) of the server. The naming conventions for the keys are switch name + host and switch name + server respectively, for example, H3C_host, H3C_server.
When configuring by this command, if the RSA key pair already exists, you will get a warning asking if you want to replace the existing one. Note that the host key and the server key must have a difference of 128 bits at least, and that the minimum and maximum lengths for the host key and the server key are 512 bits and 2048 bits.
Generating the RSA key pair of the server is the first step to perform after SSH login. It needs to be performed only once; you need not re-perform it after rebooting the switch.
  Caution:
When you log in through SSH user, the key generated by the server must be longer than 768 bits. The RSA key generated by the server is 1,024 bits by default.
Related commands: rsa local-key-pair destroy.
# Generate the local RSA key pair.
<H3C> system-view
[H3C] rsa local-key-pair create
The name for the keys will be: rtvrp_Host
% You already have RSA keys defined for rtvrp_Host
% Do you really want to replace them? [yes/no]:y
Choose the size of the key modulus in the range of 512 to 2048 for your Keys.
Choosing a key modulus greater than 512 may take a few minutes.
How many bits in the modulus [512]:512
Generating keys...
View
None
Use the rsa local-key-pair destroy command to destroy all the RSA key pairs of the server, including the host keys and server keys.
# Destroy all the RSA keys of the server.
<H3C> system-view
[H3C] rsa local-key-pair destroy
% Keys to be removed are named rtvrp_Host .
% Do you really want to remove these keys? [yes/no]:y
rsa peer-public-key key-name
View
key-name: Name of the public key of the client. It is a consecutive string whose length ranges from 1 to 64 characters.
Use the rsa peer-public-key command to enter the public key view.
Performing this command, you can enter the public key view. Then you can use the public-key-code begin command to configure the client public key on the server. The client public key is generated randomly by the SSH 2.0-enabled client software.
Related commands: public-key-code begin, public-key-code end.
# Enter the public key view named H3C002.
<H3C> system-view
[H3C] rsa peer-public-key H3C002
ssh server authentication-retries times
undo ssh server authentication-retries
View
times: Number of authentication retries, in the range from 1 to 5. By default, the value is 3.
Use the ssh server authentication-retries command to set the number of SSH connection authentication retries.
Use the ssh server authentication-retries command to restore the default number of SSH connection authentication retries.
Related commands: display ssh server.
# Specify the number of login authentication retries as 4.
<H3C> system-view
[H3C] ssh server authentication-retries 4
undo ssh server compatible_ssh1x
View
None
Use the ssh server compatible_ssh1x enable command to make the server compatible with the SSH 1.x client.
Use the undo ssh server compatible_ssh1x command to make the server not compatible with an SSH 1.x client.
By default, the server is compatible with the SSH 1.x client.
# Set the server to be compatible with the SSH 1.x client.
<H3C> system-view
[H3C] ssh server compatible_ssh1x enable
ssh server rekey-interval hours
undo ssh server rekey-interval
View
hours: Update interval of the server key, in range of 1 to 24 (hours). It cannot be 0.
Use the ssh server rekey-interval command to set update interval of the server key.
Use the undo ssh server rekey-interval command to remove the configuration.
By default, the system does not update the server key.
# Set to update the server key every three hours.
<H3C> system-view
[H3C] ssh server rekey-interval 3
ssh server timeout seconds
undo ssh server timeout
View
seconds: Login timeout (in seconds), in the range from 1 to 120. By default, the value is 60.
Use the ssh server timeout command to set the authentication timeout of SSH connections.
Use the undo ssh server timeout command to restore the default SSH authentication timeout.
The configuration takes effect at the next login.
# Set the login timeout to 80 seconds.
<H3C> system-view
[H3C] ssh server timeout 80
ssh user username assign rsa-key keyname
undo ssh user username assign rsa-key
View
keyname: Name of the client public key. It is a consecutive string whose length ranges from 1 to 64 characters.
username: Valid SSH username. It is a consecutive string whose length ranges from 1 to 32 characters.
Use the ssh user assign rsa-key command to assign an existing public key for the specified SSH user.
Use the undo ssh user assign rsa-key command to cancel the corresponding relationship between the user and the public key.
The new public key takes effect at the next login.
If a public key already exists before this command is performed, the newly configured key takes effect.
Related commands: display ssh user-information.
# Assign public key1 for user zhangsan.
<H3C> system-view
[H3C] ssh user zhangsan assign rsa-key key1
ssh user username authentication-type { password | rsa | password-publickey | all }
undo ssh user username authentication-type
View
password: Forces the user’s authentication mode to password authentication.
rsa: Forces the user’s authentication mode to RSA public key authentication.
password-publickey: Forces the user’s authentication mode to password authentication plus RSA public key authentication.
all: Specifies that the user’s authentication mode can be either password authentication or public authentication.
Use the ssh user authentication-type command to specify an authentication mode for a user.
Use the undo ssh user authentication-type command to restore the user authentication mode to NULL, namely, the unable-to-login mode.
The new authentication mode takes effect at the next login.
By default, no login authentication mode is specified, that is, SSH users are unable to login.
For a new user, you must specify an authentication mode; otherwise, the new user will not be able to log in.
# Specify the authentication mode of user zhangsan to password authentication.
<H3C> system-view
[H3C] ssh user zhangsan authentication-type password
ssh authentication-type default { password | rsa | all | password-publickey }
undo ssh authentication-type default
View
password: Configures the default user authentication mode as password authentication.
rsa: Configures the default user authentication mode as RSA public key authentication.
all: Specifies that the default user authentication mode can be either password authentication or public key authentication.
password-publickey: Configures the default user authentication mode as a combination of password authentication and public key authentication.
Use the ssh authentication-type default command to configure the default authentication mode for SSH users.
Use the undo ssh authentication-type default command to cancel the default authentication mode for SSH users.
The default authentication mode is NULL, which means that an authentication mode needs to be configured for each SSH user.
# Configure the default user authentication mode as password authentication.
<H3C> system-view
[H3C] ssh authentication-type default password
View
None
Use the display ssh server-info command to view the corresponding relationship between the client’s servers and public keys.
# Display the corresponding relationship between the client’s servers and public keys.
<H3C> display ssh server-info
Server Name(IP)  Server public key name
192.168.0.1    test_key01
192.168.0.2    test_key02
1.2.2  quit
View
None
Use the quit command to terminate the connection with the remote SSH server.
# Terminate the connection with the remote SSH server.
<H3C> quit
ssh client server-ip assign rsa-key keyname
undo ssh client server-ip assign rsa-key
View
server-ip: IP address of the server.
keyname: Public key name of the client.
Use the ssh client assign rsa-key command to specify the IP address and the corresponding public key name of the server on the client.
Use the undo ssh client assign rsa-key command to cancel the configuration.
# Specify the public key of a server with IP address 192.168.0.1 on the client as serverkey01.
<H3C> system-view
[H3C] ssh client 192.168.0.1 assign rsa-key serverkey01
undo ssh client first-time
View
None
Use the ssh client first-time enable command to set the SSH client to perform the first-time authentication of the SSH server to be accessed.
Use the undo ssh client first-time command to cancel the first-time authentication.
The first-time authentication means that when the SSH client accesses the server for the first time in the case that there is no local copy of the server’s public key, the user can proceed to access the server and save a local copy of the server’s public key; when the client accesses the server next time, it uses the saved public key to authenticate the server.
If the first-time authentication is not supported, when there is no local copy of the public key of the connected server, the client assumes that the server is illegal and will refuse to access the server. The user can save a copy of the server’s public key locally by other means beforehand.
By default, the client does not perform the first-time authentication.
# Set the SSH client to perform the first-time authentication of the SSH server to be accessed.
<H3C> system-view
[H3C] ssh client first-time enable
1.2.5  ssh2
ssh2 { host-ip | host-name } [ port-num ] [ prefer_kex { dh_group1 | dh_exchange_group } ] [ prefer_ctos_cipher { des | 3des | aes128 } ] [ prefer_stoc_cipher { des | 3des | aes128 } ] [ prefer_ctos_hmac { sha1 | sha1_96 | md5 | md5_96 } ] [ prefer_stoc_hmac { sha1 | sha1_96 | md5 | md5_96 } ]
View
host-ip: IP address of the server.
host-name: Server name, a string of 1 to 20 characters.
port-num: Server port number, ranges from 0 to 65535, and defaults to 22.
prefer_kex: Preferred key exchange algorithm, which can be one of the two algorithms.
dh_group1: Key exchange algorithm diffie-hellman-group1-sha1, which is the default algorithm.
dh_exchange_group: Key exchange algorithm diffie-hellman-group-exchange-sha1.
prefer_ctos_cipher: Preferred encryption algorithm from the client to the server. The default algorithm is aes128.
prefer_stoc_cipher: Preferred encryption algorithm from the server to the client. The default algorithm is aes128.
des: Encryption algorithm des_cbc.
3des: Encryption algorithm 3des_cbc.
aes128: Encryption algorithm aes_128.
prefer_ctos_hmac: Preferred HMAC algorithm from the client to the server. The default algorithm is sha1_96.
prefer_stoc_hmac: Preferred HMAC algorithm from the server to the client. The default algorithm is sha1_96.
sha1: HMAC algorithm hmac-sha1.
sha1_96: HMAC algorithm hmac-sha1-96.
md5: HMAC algorithm hmac-md5.
md5_96: HMAC algorithm hmac-md5-96.
Use the ssh2 command to enable the connection between the SSH client and the server, and specify the preferred key exchange algorithm, encryption algorithm and HMAC algorithm of the client and the server.
# Log in to remote SSH2 server with IP address 10.214.50.51, and configure encryption algorithms as follows:
l           Preferred key exchange algorithm: dh_exchange_group
l           Preferred encryption algorithm from the client to the server: 3DES-CBC
l           Preferred HMAC algorithm from the client to the server: HMAC-MD5
l           Preferred encryption algorithm from the server to the client: AES-128
l           Preferred HMAC algorithm from the server to the client: HMAC-SHA1-96
The command is as follows:
<H3C> system-view
[H3C] ssh2 10.214.50.51 prefer_kex dh_exchange_group prefer_ctos_cipher 3des prefer_ctos_hmac md5
sftp server enable
undo sftp server
View
None
Use the sftp server enable command to start the SFTP server.
Use the undo sftp server enable command to shutdown the SFTP server.
By default, the SFTP server is shutdown.
# Start the SFTP server.
<H3C> system-view
[H3C] sftp server enable
# Shutdown the SFTP server.
[H3C] undo sftp server
ssh service-type default { all [ sftp-directory directory ] | sftp [ sftp-directory directory ] | stelnet }
 undo ssh service-type default
View
all: Sets the default service type to Stelnet or SFTP.
sftp: Sets the default service type to SFTP.
stelnet: Sets the default service type to Stelnet.
sftp-directory directory: Sets the default SFTP login directory.
Use the ssh service-type default command to configure the default service type and SFTP login directory.
Use the undo ssh service-type default command to cancel the default service type and the SFTP login directory.
The default service type and the default SFTP login directory are both NULL.
# Set the default service type to SFTP and the default directory to cf:.
<H3C> system-view
[H3C] ssh service-type default sftp sftp-directory cf:
ssh user username service-type { stelnet | sftp [ sftp-directory directory ] | all [ sftp-directory directory ] }
undo ssh user username service-type
View
username: Local username or username defined by a remote RADIUS server.
stelnet: Sets the service type to Stelnet.
sftp: Sets the service type to SFTP.
all: Includes Stelnet and SFTP.
sftp-directory directory: Specifies the default SFTP login directory, consisting of a string of 1 to 64 characters.
Use the ssh user service-type command to specify the service type for a particular user.
Use the undo ssh user service-type command to restore the default service type.
By default, the service type is Stelnet.
When you configure the ssh user username service-type sftp sftp-directory directory command, make sure the input directory is existing on both the active and standby cards.
# Set the service type to SFTP and the directory to cf: for user zhangsan.
<H3C> system-view
[H3C] ssh user zhangsan service-type sftp sftp-directory cf:
1.4.1  bye
bye
View
SFTP Client view
None
Use the bye command to terminate the connection with the remote SFTP server and return to the user view.
This command has the same functionality as the exit and quit commands.
# Terminate the connection with the remote SFTP server.
<H3C> system-view
sftp-client> bye
<H3C>
1.4.2  cd
cd [remote-path ]
View
SFTP Client view
remote-path: Name of a path on the server.
Use the cd command to change the current path on the SFTP server. If you do not specify the remote-path argument, the current path will be displayed.
# Change the current path to d:/temp.
sftp-client> cd d:/temp
1.4.3  cdup
cdup
View
SFTP Client view
None
Use the cdup command to change the current path to its upper directory.
# Change the current path to its upper directory.
sftp-client> cdup
1.4.4  delete
delete remote-file
View
SFTP Client view
remote-file: Name of a file on the server.
Use the delete command to delete the specified file from the server.
This command has the same functionality as the remove command.
# Delete file temp.c from the server.
sftp-client> delete temp.c
1.4.5  dir
dir [ remote-path ]
View
SFTP Client view
remote-path: Name of the directory to view.
Use the dir command to view the files in the specified directory.
If the remote-path argument is not specified, the files in the current directory will be displayed.
This command has the same functionality as the ls command.
# View directory flash:/
sftp-client> dir flash:/
-rwxrwxrwx   1 noone    nogroup      1759 Aug 23 06:52 config.cfg
-rwxrwxrwx   1 noone    nogroup       225 Aug 24 08:01 pubkey2
-rwxrwxrwx   1 noone    nogroup       283 Aug 24 07:39 pubkey1
-rwxrwxrwx   1 noone    nogroup       225 Sep 28 08:28 pub1
drwxrwxrwx   1 noone    nogroup         0 Sep 28 08:24 new1
drwxrwxrwx   1 noone    nogroup         0 Sep 28 08:18 new2
-rwxrwxrwx   1 noone    nogroup       225 Sep 28 08:30 pub2
1.4.6  exit
exit
View
SFTP Client view
None
Use the exit command to terminate the connection with the remote SFTP server and return to the user view.
This command has the same functionality as the bye and quit commands.
sftp-client> exit
<H3C>
1.4.7  get
View
SFTP Client view
remote-file: Name of a file on the remote SFTP server.
local-file: Name of a local file.
Use the get command to download a file from the remote server and save it locally.
By default, if no local file name is specified, it is assumed that the local file has the same name as the file on the SFTP server.
# Download file temp1.c and save it with name temp.c.
sftp-client> get temp1.c temp.c
1.4.8  help
help [ command ]
View
SFTP Client view
command: Name of a command.
Use the help command to view the help information for SFTP client commands.
If the command argument is not specified, all command names will be displayed.
# View the help information for the get command.
sftp-client> help get
get remote-path [local-path]  Download file
Default local-path is the same with remote-path
1.4.9  ls
ls [ remote-path ]
View
SFTP Client view
Use the ls command to view the files in the specified directory.
This command has the same functionality as the dir command.
# View directory flash:/.
sftp-client> ls flash:/
1.4.10  mkdir
mkdir remote-path
View
SFTP Client view
remote-path: Name of a directory on the remote SFTP server.
Use the mkdir command to create a directory on the remote SFTP server.
# Create directory test on the remote SFTP server.
sftp-client> mkdir test
1.4.11  put
View
SFTP Client view
Use the put command to upload a local file to the remote SFTP server.
By default, if no name of the file on the remote server is specified, it is assumed that the file on the remote server has the same name as the local file.
# Upload local file temp.c to the remote SFTP server and save it with the name temp1.c.
sftp-client> put temp.c temp1.c
1.4.12  pwd
pwd
View
SFTP Client view
None
Use the pwd command to display the current directory on the SFTP server.
# Display the current directory on the SFTP server.
sftp-client> pwd
flash:
1.4.13  quit
View
SFTP Client view
None
Use the quit command to terminate the connection with the remote SFTP server and return to the user view.
This command has the same functionality as the bye and exit commands.
sftp-client> quit
<H3C>
1.4.14  remove
remove remote-file
View
SFTP Client view
Use the remove command to delete the specified file from the server.
This command has the same functionality as the delete command.
# Delete the file temp.c from the server.
sftp-client> remove temp.c
1.4.15  rename
rename oldname newname
View
SFTP Client view
oldname: Original file name.
newname: New file name.
Use the rename command to change the name of the specified file on the SFTP server.
# Rename the file temp1 on the SFTP server to temp2.
sftp-client> rename temp1 temp2
1.4.16  rmdir
rmdir remote-path
View
SFTP Client view
Use the rmdir command to delete the specified directory from the SFTP server.
# Delete the directory d:/temp1 from the SFTP server.
sftp-client> rmdir d:/temp1
1.4.17  sftp
sftp host-ip [ prefer_kex { dh_group1 | dh_exchange_group } ] [ prefer_ctos_cipher { des | 3des | aes128 } ]  [ prefer_stoc_cipher { des | 3des | aes128 } ] [ prefer_ctos_hmac { sha1 | sha1_96 | md5 | md5_96 } ] [ prefer_stoc_hmac { sha1 | sha1_96 | md5 | md5_96 } ]
View
prefer_key: Preferred key exchange algorithm, which can be either diffie-hellman-group1-sha1 or diffie-hellman-group-exchange-sha1.
dh_group1: Key exchange algorithm diffie-hellman-group1-sha1, which is default algorithm.
Use the sftp command to establish the connection with the remote SFTP server and enter the SFTP Client view.
# Connect to the SFTP server with IP address 10.214.49.126 using the default encryption algorithm.
<H3C> system-view
[H3C] sftp 10.214.49.126
