H3C S9500 Command Manual-Release1648[v1.24]-07 Security Volume
HomeSupportSwitchesS9500 SwitchesReference GuidesCommand ReferencesH3C S9500 Command Manual-Release1648[v1.24]-07 Security Volume
08-VBAS Commands
08-VBAS Commands 18.88 KB
Chapter 1  VBAS Configuration Commands
1.1  VBAS Configuration Commands
1.1.1  debugging vbas
debugging vbas { all | general | error | packet }
undo debugging vbas { all | general | error | packet }
View
all: Enables all debugging functions.
general: Enables the debugging function of operations.
error: Enables the debugging function of program errors.
packet: Enables the debugging function of packets.
Use the debugging vbas command to enable the VBAS debugging function and specify the VBAS module debugging information.
Use the undo debugging vbas command to cancel the current configuration.
By default, the VBAS debugging function is disabled.
Table 1-1 Descriptions on the fields of the debugging vbas command
The VBAS request packet:
Display the VBAS request packet received by the equipment
The VBAS response packet:
Display the VBAS response packet received by the equipment
VbasPorcPkt: The input buffer is null.
The VbasPorcPkt function receives null pointer.
VbasPorcPkt: VBAS is not enable;
VBAS is not enabled on the port or on the VLAN.
VbasPorcPkt: VBAS is not enable; PortIndex = %d
VBAS is not enabled when the port is not in the VLAN.
VbasPorcPkt: L2Output error.
Error occurs when invoking the underlying function to output packets.
VbasParseInputPkt: Version error; Version = %x
Version number error in the VBAS request
VbasParseInputPkt: Reserve error; Reserve[0] = %d, Reserve[1] = %d, Reserve[2] = %d
Reserved fields error in the VBAS request
VbasParseInputPkt: TransInfoType error; TransInfoType = %x
Transfer information error in the VBAS request
VbasParseInputPkt: OperType error; OperType = %x
Operation type error in the VBAS request
VbasComposeOutputPkt: malloc for mbuf error
MBUF memory distribution error
VbasComposeOutputPkt: OperResult = %d is not OK
Wrong fields exist in the received VBAS request.
VbasComposeOutputPkt: Can't find the user accessing port, OperResult = %d
Can not find the user accessing port
VbasComposeOutputPkt: Get user info error
Error occurs when the underlying function gets the information of user accessing port.
# Enable the debugging function of general operations of the VBAS module.
<H3C> debugging vbas general
1.1.2  vbas enable
vbas enable
undo vbas enable
View
VLAN view/Ethernet port view
None
Use the vbas enable command to enable the VBAS function.
Use the undo vbas enable command to disable the VBAS function.
By default, the VBAS function on the VLAN and the port are disabled.
# Enable the VBAS function on port Ethernet 2/1/1.
<H3C> system-view
[H3C] interface ethernet 2/1/1
[H3C-ethernet2/1/1] vbas enable
1.1.3  vbas deviceId_type
vbas deviceId_type [ sysname | bridge_mac ]
undo vbas deviceId_type
View
sysname: System name of the equipment.
bridge_mac: Name of bridge MAC.
Use the vbas deviceld_type command to set the type of user AccessNodeIdentifier. The type of AccessNodeIdentifier can be the bridge MAC or the system name of the equipment.
Use the undo vbas deviceld_type command to restore the type of AccessNodeIdentifer to the default type.
By default, the type of user AccessNodeIdentifier is the bridge MAC address.
Note that when there is space or ‘/’ character in the system name, the vbas deviceld_type sysname command will not be executed successfully. If you have successfully configured this command, when you change the system name of the equipment, no space or ‘/’ character is allowed to be used.
# Specify the type of AccessNodeIdentifer as the system name of the equipment.
<H3C> system-view
[H3C] vbas deviceId_type sysname
