H3C S9500 Command Manual-Release1648[v1.24]-07 Security Volume
HomeSupportSwitchesS9500 SwitchesReference GuidesCommand ReferencesH3C S9500 Command Manual-Release1648[v1.24]-07 Security Volume
01-Protocol Port Security Commands
01-Protocol Port Security Commands 42.45 KB
Chapter 1  Protocol Port Security Configuration Commands
1.1  Protocol Port Security Configuration Commands
1.1.1  ip portsafe
ip portsafe enable
undo ip portsafe enable
View
None
Use the ip portsafe enable command to enable the protocol port security function to check all IP packets on the interface board. If the destination IP is the virtual interface IP of the switch, and the corresponding destination protocol port is not open, the packet will be dropped.
Use the undo ip portsafe enable command to disable the protocol port security function. Then all packets on the interface board are not checked.
By default, the SRPU enables the protocol port security function. So do the standby board and the interface board.
Following table lists the protocols that can be checked.
Table 1-1 State of the protocol port
Protocol
Port
Default State
IGMP/IGSP
PROTOCOL:2
Close
OSPF
PROTOCOL:89
Close
PIM
PROTOCOL:123
Close
SSH
TCP:22
Close
TELNET
TCP:23
Close
HTTP
TCP:80
Open
BGP
TCP:179
Close
MPLS LDP
TCP:646
Close
DHCP
UDP:67,68
Close
NTP
UDP:123
Close
SNMP-AGENT
UDP:161
Close
RIP
UDP:520
Close
MPLS LDP
UDP:646
Close
RADIUS CLIENT
UDP:1812
Close
RADIUS LOCAL SERVER
UDP:1645,1646
Open
PORTAL SERVER
UDP:2000
Close
&  Note:
The protocol port security function is short for TCP, UDP protocol port close checking function. If a protocol is not enabled, this function can drop the packet whose destination IP is the virtual interface IP of the switch, so that it reduces the unnecessary communications between the boards and the CPU operation of the SRPU, and enhances the anti-interference ability of the switch to the packet.
# Enable the protocol port security function.
<H3C> system-view
[H3C] ip portsafe enable
1.1.2  ip http shutdown
ip http shutdown
undo ip http shutdown
View
None
Use the ip http shutdown command to shutdown the port 80 of the HTTP protocol. After the execution of this command, all packets requiring the port 80 of this device will be dropped.
Use the undo ip http shutdown command to enable the port 80 of the HTTP protocol. After the execution of the command, all packets requiring the port 80 of the device will be responded.
By default, the port 80 of the HTTP protocol is enabled.
# Shutdown the port 80 of the HTTP protocol.
<H3C> system-view
[H3C] ip http shutdown
