H3C S9500 Command Manual-Release1648[v1.24]-07 Security Volume
HomeSupportSwitchesS9500 SwitchesReference GuidesCommand ReferencesH3C S9500 Command Manual-Release1648[v1.24]-07 Security Volume
07-Portal Commands
07-Portal Commands 65.44 KB
Chapter 1  Portal Configuration Commands
1.1  Portal Configuration Commands
1.1.1  debugging portal
debugging portal { acm | all | arp-handshake | server | tcp-cheat }
undo debugging portal { acm | all | arp-handshake | server | tcp-cheat }
View
Parameter
acm: Enables the debugging for authentication connection management (ACM), that is to say, enables the debugging for state machines related with authentication, connection and management.
all: Enables all the debugging for Portal.
arp-handshake: Enables the debugging for ARP-handshake.
server: Enables the debugging for Portal server.
tcp-cheat: Enables the debugging for TCP cheat.
Use the debugging portal command to enable the debugging for Portal.
Use the undo debugging portal command to disable the debugging output.
Example
# Enable all the debugging for Portal.
<H3C> debugging portal all
1.1.2  display portal
1. display portal { acm | server | tcp-cheat } statistics
2. display portal [ auth-network [ auth-vlan-id ] | free-ip | free-user | server [ server-name ] | vlan [ vlan-id ] ]
3. display portal user [ ip ipaddress | interface interface-type interface-number | vlan vlan-id ]
View
Any View
Parameter
acm statistics: Displays the statistics about ACM, that is to say, displays the statistics about the state machines related with authentication, connection and management.
auth-network auth-vlan-id: Displays the authentication network section. auth-vlan-id is the ID of the VLAN where the access port (where the authentication users access into the switch across the network) lies in.
free-ip: Displays the configured authentication-free IP addresses.
free-user: Displays the configured authentication-free users.
server server-name: Displays the information about the Portal server with the specified name.
server statistics: Displays the statistics about the Portal server.
tcp-cheat statistics: Displays the statistics about TCP cheats.
ipaddress: Information about users using the specified IP address.
interface-type: Port type, whose value is Ethernet or GigabitEthernet.
interface-number: Port number, expressed in the form of slot number/card number/port number.
vlan vlan-id: Displays the information about all the users in a VLAN.
Use the display portal command to display the information about Portal.
Example
# Display the information about Portal.
<H3C> display portal
Run Method:
 Direct
Free IP:
  1)IP = 192.168.80.80        Net Mask = 255.255.255.255
  2)IP = 1.1.1.1              Net Mask = 255.255.255.255
  3)IP = 192.168.80.81        Net Mask = 255.255.255.255
  4)IP = 192.168.2.0          Net Mask = 255.255.255.0
Authenticate network:
  1)IP = 6.6.6.1              Net Mask = 255.255.255.0        VLAN ID = 6
  2)IP = 7.7.0.0              Net Mask = 255.255.0.0          VLAN ID = 7
Free User:
  1)Active=Y MAC=000d-88f6-60e0 IP=7.7.7.7         vlan=7    Intf=Ethernet4/1/2
Portal Server:
  1)pt:
    IP   = 192.168.80.80
    Key  = hello
    Port = 50100
    URL  = http://192.168.80.80/portal/index_default.jsp
  2)test:
    IP   = 1.1.1.1
    Key  = Not configured
    Port = 50100
    URL  = "http://1.1.1.1"
ARP-HandShake:
 Interval: 60s    Retry Times: 5
VLAN Portal Configuration:
 VLAN 7    : Portal Started    Portal Server: pt
 VLAN 80   : Portal Started    Portal Server: test
Table 1-1 Description on the fields displayed by using the display portal command
Run Method
Portal servers run in one of the three methods: direct, ReDHCP and Layer3
Free IP
Free IP addresses. A Portal server will use one free IP address automatically
Free User
Authentication-free users
Portal Server
The basic information about the configuration of a Portal server, including its IP address, key, port and URL that HTTP redirects
ARP-HandShake
The information about the ARP handshake, including the interval of handshake and retry times.
Information about the Portal-enabled VLANs, including whether Portal is enabled and the name of the enabled Portal server.
# Display the statistics about Portal ACM.
<H3C> system-view
[H3C] display portal acm statistics
ACM Statistics            Running State Statistics
 WAIT_MAC_ACK              0
 DISCOVERED                0
 WAIT_AUTH_ACK             0
 WAIT_LOGIN_ACK            0
 WAIT_ACL_ACK              0
 WAIT_NEW_IP               0
 ONLINE                    0
 WAIT_LOGOUT_ACK           0
 WAIT_LEAVING_ACK          0
 Message Statistics :
 MSG NAME                  RCV MSG NUM
 PT_MSG_AUTH_ACK           0
 PT_MSG_LOGIN_ACK          0
 PT_MSG_LOGOUT_ACK         0
 PT_MSG_LEAVING_ACK        0
 PT_MSG_CUT_REQ            0
 PT_MSG_MAC_ACK            0
 PT_MSG_ACL_ACK            0
 PT_MSG_ARPPKT             77
 PT_MSG_TMR_REQAUTH        0
 PT_MSG_TMR_AUT            0
 PT_MSG_TMR_LGN            0
 PT_MSG_TMR_LGT            0
 PT_MSG_TMR_LEV            0
 PT_MSG_TMR_HDS            85249
 PT_MSG_ARP_FAIL           0
 PT_MSG_TMR_ACL            0
 PT_MSG_TMR_MAC            0
 PT_MSG_TMR_NIP            0
 PT_MSG_PORT_REMOVE        0
 PT_MSG_TMR_USERIPCHANGE   0
 ERROR Statistics:
 MEM Error: 0           RCV MSG ERR: 0           SND MSG ERR: 0
Table 1-2 Description on the fields displayed by using the display portal statistics command
ACM Statistics
Statistics about state machines
WAIT_MAC_ACK
Number of users in WAIT_MAC_ACK state. This value is 0 for the Layer 3 method
DISCOVERED
Number of users discovered
WAIT_AUTH_ACK
Number of users in WAIT_AUTH_ACK state.
WAIT_LOGIN_ACK
Number of users in WAIT_LOGIN_ACK state.
WAIT_ACL_ACK
Number of users in WAIT_ACL_ACK state. This value is 0 for ReDHCP method
WAIT_NEW_IP
Number of users in WAIT_NEW_IP state. This value is 0 for both Direct and Layer 3 methods.
ONLINE
Number of online users
WAIT_LOGOUT_ACK
Number of users in WAIT_LOGOUT_ACK state
WAIT_LEAVING_ACK
Number of users in WAIT_LEAVING_ACK state
PT_MSG_AUTH_ACK
Number of PT_MSG_AUTH_ACK messages received
PT_MSG_LOGIN_ACK
Number of PT_MSG_LOGIN_ACK messages received
PT_MSG_LOGOUT_ACK
Number of PT_MSG_LOGOUT_ACK messages received
PT_MSG_LEAVING_ACK
Number of PT_MSG_LEAVING_ACK messages received
PT_MSG_CUT_REQ
Number of PT_MSG_CUT_REQ messages received.
PT_MSG_MAC_ACK
Number of PT_MSG_MAC_ACK messages received. This value is 0 for Layer 3 method.
PT_MSG_ACL_ACK
Number of PT_MSG_ACL_ACK messages received. This value is 0 for ReDHCP method.
PT_MSG_ARPPKT
Number of PT_MSG_ARPPKT messages received. This value is 0 for Layer 3 method.
PT_MSG_TMR_AUT
Number of PT_MSG_TMR_AUT messages received
PT_MSG_TMR_LGN
Number of PT_MSG_TMR_LGN messages received
PT_MSG_TMR_LGT
Number of PT_MSG_TMR_LGT messages received
PT_MSG_TMR_LEV
Number of PT_MSG_TMR_LEV messages received
PT_MSG_TMR_HDS
Number of PT_MSG_TMR_HDS messages received. This value is 0 for Layer 3 method
PT_MSG_ARP_FAIL
Number of PT_MSG_ARP_FAIL messages received. This value is 0 for Layer 3 method
PT_MSG_TMR_ACL
Number of PT_MSG_TMR_ACL messages received. This value is 0 for ReDHCP method
PT_MSG_TMR_MAC
Number of PT_MSG_TMR_MAC messages received. This value is 0 for Layer 3 method
PT_MSG_TMR_NIP
Number of PT_MSG_TMR_NIP messages received. This value is 0 for Direct and Layer 3 methods
MEM Error/RCV MSG ERR/SND MSG ERR
Number of MEM Error/RCV MSG ERR/SND MSG ERR messages received, including memory errors, received message errors and sent message errors
PT_MSG_TMR_REQAUTH
Number of PT_MSG_TMR_REQAUTH messages received
PT_MSG_PORT_REMOVE
Number of PT_MSG_PORT_REMOVE messages received
Number of PT_MSG_TMR_USERIPCHANGE messages received
Received Invalid Packets
Number of invalid packets received
Server
Name of Portal server
Index
Index number
Pkt_Type
Packet type
Total
Total number of packets
Errs
Number of error packets
Discard
Number of discarded packets
REQ_CHALLENGE
Number of REQ_CHALLENGE messages received
ACK_CHALLENGE
Number of ACK_CHALLENGE messages received
REQ_AUTH
Number of REQ_AUTH messages received
ACK_AUTH
Number of ACK_AUTH messages received
REQ_LOGOUT
Number of REQ_LOGOUT messages received
ACK_LOGOUT
Number of ACK_LOGOUT messages received
AFF_ACK_AUTH
Number of AFF_ACK_AUTH messages received
NTF_LOGOUT
Number of NTF_LOGOUT messages received.
REQ_INFO
Number of REQ_INFO messages received
ACK_INFO
Number of ACK_INFO messages received
NTF_USERDISCOVER
Number of NTF_USERDISCOVER messages received
NTF_USERIPCHANGE
Number of NTF_USERIPCHANGE messages received
AFF_NTF_USERIPCHANGE
Number of AFF_NTF_USERIPCHANGE messages received
ACK_NTF_LOGOUT
Number of ACK_NTF_LOGOUT messages received
TCP Cheat Statistic
TCP spoofing statistics
Total Opens
Total number of TCP spoofing connections
Resets Connections
Number of the connections reset through RST packets
Current Opens
Number of active connections
Packets Received
Number of received packets
Packets Sent
Number of sent packets
Packets Retransmitted
Number of retransmitted packets
Packets Dropped
Number of dropped packets
HTTP Packets Sent
Number of HTTP packets that have been sent
Connection State
State of a TCP spoofing connection
SYN_RECVD
Number of connections in SYN_RECVD state
ESTABLISHED
Number of connections in ESTABLISHED state
CLOSE_WAIT
Number of connections in CLOSE_WAIT state
LAST_ACK
Number of connections in LAST-ACK state
FIN_WAIT_1
Number of connections in FIN_WAIT_1 state
FIN_WAIT_2
Number of connections in FIN_WAIT_2 state
CLOSING
Number of connections in CLOSING state
# Display information about Portal users.
<H3C> display portal user
 This operation may take a few minutes ,please wait
 VLAN 7      Total users: 1        Online users: 0
 Index  State          MAC             IP        VLAN  ACL   Port
 3      WAIT_LOGIN_ACK     000d-88f6-60e0      7.7.7.7       7       3000     Ethernet4/1/2
Table 1-3 Description on the fields displayed by using the display portal user command
Total users
Total number of users in the VLAN
Online users
Total number of online users in the VLAN
Index
Index of the portal user
Current state of the portal user
MAC
MAC address of the portal user
IP
IP address of the portal user
VLAN
VLAN to which the portal user belongs
ACL
ACL assigned for the portal user
Port
Port number
1.1.3  portal
Example
portal server-name
undo portal
View
VLAN interface view.
Parameter
server-name: Name of a Portal server, a string of 1 to 32 characters that must be made up of letters, numbers or underlines.
Use the portal command to enable the Portal authentication function on a VLAN interface.
Use the undo portal command to disable this function.
If the Portal runs in the Layer 3 Portal authentication method, you must configure an authentication section before enabling the Portal authentication function on a VLAN interface.
When you enable the Portal authentication function on a VLAN interface, you must make sure that VLAN IDs are in the range of 2 to 4094 firstly, and furthermore, make sure that a valid IP address is configured for this VLAN interface and the specified Portal server has existed.
Example
# Enable the Portal authentication function on VLAN-interface 10. Specify H3C as the Portal server.
<H3C> system-view
[H3C] interface Vlan-interface 10
[H3C-Vlan-interface10] portal H3C
1.1.4  portal arp-handshake
portal arp-handshake { interval interval | retry-times retry-times }*
undo portal arp-handshake { interval | retry-times }
View
Parameter
interval: Interval of ARP handshakes in seconds, in the range of 10 to 180. Its step is 10. It is 60 seconds by default.
retry-times: Maximum retry times of ARP packets, that is to say, the maximum times of permitted handshake failures. This value is in the range of three times to 10 times. It is five times by default.
Use the portal arp-handshake command to configure the interval of handshakes between the portal server and the host and the maximum retry times.
Use the undo portal arp-handshake command to restore the default value.
When authentications are performed in the Direct method or ReDHCP method, the switch handshakes with the host through ARP packets after the host (user PC) has passed the Portal authentication. The switch sends ARP packets at the interval. If the user PC still does not respond after the sending times exceed the retry times, the switch will regard the handshakes as abnormal, cut the connection with this user actively and notify the Portal server about this case.
This command is ineffective for the Layer 3 Portal authentication method.
Example
# Set the interval of handshakes between the switch and the host to 120 seconds, and set the maximum retry times to six times.
<H3C> system-view
[H3C] portal arp-handshake interval 120 retry-times 6
1.1.5  portal auth-network
portal auth-network network-address net-mask vlan vlan-id
undo portal auth-network { network-address net-mask | vlan vlan-id | all }
View
Parameter
network-address net-mask: Address and subnet mask of the authentication network section.
vlan-id: ID of the VLAN where the access port (where the authentication users access into the switch across the network) lies in.
all: Disables all the configured authentication network sections.
Use the portal auth-network command to configure the authentication network section of a Portal client.
Use the undo portal auth-network command to disable the authentication network section for a Portal client.
No authentications network section is configured by default.
This command is effective only for the Layer 3 Portal authentication method.
Example
# Configure the authentication network section for a Portal client: 192.168.0.200/16.
<H3C> system-view
[H3C] portal auth-network 192.168.0.200 255.255.0.0 vlan 1
1.1.6  portal delete-user
portal delete-user ip-address
View
ip-address: Deletes the Portal users using the specified IP address.
Use the portal delete-user command to delete the Portal users using the specified IP address.
# Delete users using the IP address 10.153.94.8.
<H3C> system-view
[H3C] portal delete-user 10.153.94.8
1.1.7  portal free-ip
portal free-ip ip-address [ mask | mask-length ]
undo portal free-ip ip-address [ mask | mask-length ]
View
ip-address: Free IP address of the host.
mask: Mask.
mask-length: Length of a mask.
Use the portal free-ip command to set the free IP addressees for a Portal client.
Use the undo portal free-ip command to delete the specified free IP address.
No free IP address is configured by default. .
Free IP addresses can be the IP addresses of DNS servers or the IP addresses that ISP provides to access free websites. All users can access these free IP addresses unrestrictedly.
Up to 8 free IP addresses can be configured in one system. .A Portal server will use one free IP address automatically.
# Set the IP address 10.1.1.0 as a free IP address
<H3C> system-view
[H3C] portal free-ip 10.1.1.0
1.1.8  portal free-user
In system view:
portal free-user mac mac-address ip ip-address vlan vlan-id interface interface-type interface-number
undo portal free-user { mac mac-address | all }
In Ethernet port view:
View
System view, Ethernet port view
mac mac-address: Sets the Mac addresses of authentication-free users.
ip ip-address: Sets the IP addresses of authentication-free users. These addresses cannot be full-zero addresses, loopback addresses, multicast addresses or broadcast addresses.
vlan vlan-id: ID of the VLAN that the authentication-free users belongs to, in the range of 1 to 4094.
interface: Port of the switch that the authentication-free users lie in. This port must belong to the VLAN that this command specifies.
all: Deletes all authentication-free users.
Use the portal free-user command to configure the Portal authentication-free users.
Use the undo portal free-user command to delete the specified or all authentication-free users.
In the network practice, you can configure network devices attached to the switch or several servers as authentication-free users, so that they can access all networks without authentication.
The information about authentication-free users includes IP addresses, MAC addresses, and the connected switch ports and VLANs. Only the users who match all the information can access networks without authentication. In direct authentication, the authentication-free users do not need to match the MAC addresses due to the restrictions of the flow template on S9500 series switches.
  Caution:
l      The ReDHCP authentication method requires that the IP address of an authentication-free user and the master IP address of the interface belong to the same network section. The Direct authentication method requires that the IP address of an authentication-free user and that of the VLAN interface belong to the same network section.
l      This configuration takes effect after Portal is enabled in the VLAN that the authentication-free users belongs to.
l      Authentication-free users enjoy the same priority as the authentication users. First delivered packets are validated first. You need to avoid the conflict with authentication users in the configuration.
l      The Layer 3 Portal authentication method does not support the authentication-free user configuration.
# Configure authentication-free users for the Portal authentication.
<H3C> system-view
[H3C] portal free-user mac 00e0-fc01-0101 ip 10.110.1.1 vlan 10 interface ethernet 2/1/1
1.1.9  portal method
portal method { direct | layer3 | redhcp }
undo portal method
View
direct: Adopts the direct authentication method in Portal authentication.
layer3: Adopts the Layer 3 Portal authentication method, namely, accoss-layer-3 Portal authentication method in authentication.
redhcp: Adopts the ReDHCP authentication method in Portal authentication.
Use the portal method command to set the running method of Portal authentication.
Use the undo portal method command to restore the default running method of Portal authentication.
The direct authentication method is adopted in Portal authentication by default.
# Set to adopt the ReDHCP method in Portal authentication.
<H3C> system-view
[H3C] portal method redhcp
1.1.10  portal server
portal server server-name { ip ip-address | key key-string | port port | url url-string } *
undo portal server server-name [ key | port | url ]
View
server-name: Name of a Portal server. It is a string in the range of 1 to 32 characters.
ip-address: IP address of a Portal server. This address cannot be full-zero addresses, loopback addresses, multicast addresses or broadcast addresses.
key-string: Shared keys that the Portal server needs when it communicates with the switch. It is a string in the range of 1 to 16 characters. It is not configured by default.
port: Port that a switch uses to send packets to a Portal server. It is in the range of 1 to 65534. It is 50100 by default.
url-string: URL that HTTP redirects to, which is the string form of the ip-address by default. For example, if the ip-address is 10.110.100.100, the default URL is http://10.110.100.100. The string need not be bracketed when entered.
Use the portal server command to create a Portal server or modify the configuration of a Portal server.
Use the undo portal server command to delete the specified server, or restore the default parameter configuration of the specified server.
  Caution:
l      When a Portal server is firstly configured, you must configure the IP address for it.
l      If the Portal server has been configured on a VLAN virtual interface, you must disable this Portal server on the virtual VLAN interface before modifying its parameters. Enable the Portal server again after parameters are modified.
l      A Portal server will use a free IP address automatically. If the number of free IP addresses has reached the maximum when a Portal server is configured, this configuration will fail.
# Set the IP address of the Portal server named H3C to 10.10.100.100, communication key to lanswitch, port to 50101, and the URL that HTTP redirects to http://www.h3c.com.
<H3C> system-view
[H3C] portal server H3C ip 10.10.100.100 key lanswitch port 50101 url http://www.h3c.com
1.1.11  reset portal
reset portal { acm | server | tcp-cheat } statistics
View
acm: Clears the statistics about ACM, that is to say, clears the statistics about the state machines related with authentication, connection and management.
server: Clears the statistics about the Portal server.
tcp-cheat: Clears the statistics about TCP cheats.
Use the reset portal command to clear the related statistics about Portal.
# Clear the statistics about ACM of the Portal client.
<H3C> reset portal acm statistics
