H3C S9500 Operation Manual-Release2132[V2.03]-08 System Volume
HomeSupportSwitchesS9500 SwitchesConfigure & DeployConfiguration GuidesH3C S9500 Operation Manual-Release2132[V2.03]-08 System Volume
12-Basic System Configuration
12-Basic System Configuration 73.32 KB
Chapter 1  Basic Configurations
While performing basic configurations of the system, go to these sections for information you are interested in:
l           Basic Configurations
l           CLI Features
1.1  Basic Configurations
This section covers the following topics:
l           Entering/Exiting System View
l           Configuring the Device Name
l           Configuring the System Clock
l           Configuring a Banner
l           Configuring CLI Hotkeys
l           Configuring User Levels and Command Levels
l           Displaying and Maintaining Basic Configurations
1.1.1  Entering/Exiting System View
To do…
Use the command…
Remarks
Enter system view from user view
Return to user view from system view
&  Note:
With the quit command, you can return to the previous view. You can execute the return command or press the hot key <Ctrl+Z> to return to user view.
1.1.2  Configuring the Device Name
To do…
Use the command…
Remarks
Enter system view
Configure the device name
sysname sysname
Optional
The default device name is H3C.
1.1.3  Configuring the System Clock
To do…
Use the command…
Remarks
Set the standard time
clock datetime time date
Optional
Set the time zone
clock timezone zone-name { add | minus } time
Optional
Set a daylight summer time scheme
clock summer-time zone-name { one-off | repeating } start-time start-date end-time end-date offset-time
Optional
1.1.4  Configuring a Banner
I. Introduction to banners
Banners are prompt information displayed by the system when users are connected to the device, perform login authentication, and start interactive configuration. The administrator can set corresponding banners as needed.
At present, the system supports the following four kinds of welcome information.
l           shell banner, also called session banner, displayed when a non TTY Modem user enters user view.
l           incoming banner, also called user interface banner, displayed when a user interface is activated by a TTY Modem user.
l           login banner, welcome information at login authentications, displayed when password and scheme authentications are configured.
l           legal banner, also called authorization information. The system displays some copyright or authorization information, and then displays the legal banner before a user logs in, waiting for the user to confirm whether to continue the authentication or login. If entering Y or pressing the Enter key, the user enters the authentication or login process; if entering N, the user quits the authentication or login process. Y and N are case insensitive.
II. Configuring a banner
When you configure a banner, the system supports two input modes. One is to input all the banner information right after the command keywords. The start and end characters of the input text must be the same but are not part of the banner information. In this case, the input text, together with the command keywords, cannot exceed 510 characters. The other is to input all the banner information in multiple lines by pressing the Enter key. In this case, up to 2000 characters can be input.
The latter input mode can be achieved in the following three ways:
l           Press the Enter key directly after the command keywords, and end the setting with the % character. The Enter and % characters are not part of the banner information.
l           Input a character after the command keywords at the first line, and then press the Enter key. End the setting with the character input at the first line. The character at the first line and the end character are not part of the banner information.
l           Input multiple characters after the command keywords at the first line (with the first and last characters being different), then press the Enter key. End the setting with the first character at the first line. The first character at the first line and the end character are not part of the banner information.
Follow these steps to configure a banner:
To do…
Use the command…
Remarks
Enter system view
Configure the banner to be displayed at login (TTY Modem login)
header incoming text
Optional
Configure the authorization information before login
header legal text
Optional
Configure the banner to be displayed at login authentication
header login text
Optional
Configure the banner to be displayed when a user enters user view (Non-TTY Modem login)
header shell text
Optional
1.1.5  Configuring CLI Hotkeys
To do…
Use the command…
Remarks
Enter system view
Configure CLI hotkeys
hotkey { CTRL_G | CTRL_L | CTRL_O | CTRL_T | CTRL_U } command
Optional
The <Ctrl+G>, <Ctrl+L> and <Ctrl+O> hotkeys are specified with command lines by default.
Display hotkeys
display hotkey
Available in any view. Refer to Table 1-1 for hotkeys reserved by the system.
&  Note:
By default, the <Ctrl+G>, <Ctrl+L> and <Ctrl+O> hotkeys are configured with command line and the <Ctrl+T> and <Ctrl+U> commands are NULL.
l      <Ctrl+G> corresponds to the display current-configuration command.
l      <Ctrl+L> corresponds to the display ip routing-table command.
l      <Ctrl+O> corresponds to the undo debugging all command.
Table 1-1 Hotkeys reserved by the system
Hotkey
Function
<Ctrl+A>
Moves the cursor to the beginning of the current line.
<Ctrl+B>
Moves the cursor one character to the left.
<Ctrl+C>
Stops performing a command.
<Ctrl+D>
Deletes the character at the current cursor position.
<Ctrl+E>
Moves the cursor to the end of the current line.
<Ctrl+F>
Moves the cursor one character to the right.
<Ctrl+H>
Deletes the character to the left of the cursor.
<Ctrl+K>
Terminates an outgoing connection.
<Ctrl+N>
Displays the next command in the history command buffer.
<Ctrl+P>
Displays the previous command in the history command buffer.
<Ctrl+R>
Redisplays the current line information.
<Ctrl+V>
Pastes the content in the clipboard.
<Ctrl+W>
Deletes all the characters in a continuous string to the left of the cursor.
<Ctrl+X>
Deletes all the characters to the left of the cursor.
<Ctrl+Y>
Deletes all the characters to the right of the cursor.
<Ctrl+Z>
Exits to user view.
<Ctrl+]>
Terminates an incoming connection or a redirect connection.
<Esc+B>
Moves the cursor to the leading character of the continuous string to the left.
<Esc+D>
Deletes all the characters of the continuous string at the current cursor position and to the right of the cursor.
<Esc+F>
Moves the cursor to the front of the next continuous string to the right.
<Esc+N>
Moves the cursor down by one line (available before you press the Enter key)
<Esc+P>
Moves the cursor up by one line (available before you press the Enter key)
<Esc+<>
Specifies the cursor as the beginning of the clipboard.
<Esc+>>
Specifies the cursor as the ending of the clipboard.
&  Note:
These hotkeys are defined by the system. When you interact with the device from terminal software, these keys may be defined to perform other operations. If so, the definition of the terminal software will dominate.
1.1.6  Configuring User Levels and Command Levels
All the commands are defaulted to different views and categorized into four levels: visit, monitor, system, and manage, identified respectively by 0 through 3. If you want to acquire a higher privilege, you must switch to a higher user level, and it requires password to do so for AUX and VTY user interfaces for the security’s sake.
The following table describes the default level of the commands.
Table 1-2 Default command levels
Level
Privilege
Visit
ping, tracert, telnet
1
Monitor
refresh, reset, send
2
System
All configuration commands except for those at manage level
3
Manage
FTP, TFTP, XMODEM, and file system operation commands
Follow these steps to configure user level and command level:
To do…
Use the command…
Remarks
Switch the user level
super [ level ]
Optional
Enter system view
Configure the password for switching the user level
super password [ level user-level ] { simple | cipher } password
Optional
By default, no password is needed for switching the user level.
Configure the command level in system view
command-privilege level level view view command
Optional
&  Note:
The commands available depend on your user level when you log onto a device. For example, if your user level is 3 and the command level of VTY 0 interface is 1, you can use commands below level 3 (inclusive).
  Caution:
l      When you configure the password for switching user level with the super password command, the user level is defaulted to 3 if no user level is specified.
l      You can switch to a lower user level unconditionally. To switch to a higher user level, however, you need to enter the password needed (The password can be set with the super password command.). If the entered password is incorrect or no password is configured, the switch fails. Therefore, before switching to a higher user level, you should configure the password needed.
l      You are recommended to use the default user level; otherwise the change of user level may bring inconvenience to your maintenance and operation.
1.1.7  Displaying and Maintaining Basic Configurations
To do…
Use the command…
Remarks
Display information on system version
display version
Display information on the system clock
display clock
Display information on terminal users
display users [ all ]
Display the configuration files saved in the device storage medium.
display saved-configuration [ by-linenum ]
Display the current configurations
display current-configuration [ interface [ interface-type [ interface-number ] ] | configuration [ configuration ] | [ by-linenum ] | [ | { begin | exclude | include } regular-expression ] ] *
Display debugging information
display debugging [ interface interface-type interface-number ] [ module-name ]
Display the valid configuration under current view
display this [ by-linenum ]
Display clipboard information
display clipboard
Display and save statistics of each module’s running status
display diagnostic-information
Display the usage of the current system memory
display memory
During daily maintenance or when the system is operating abnormally, you need to view each module’s running status to find the problem. Therefore, you are required to execute the corresponding display commands one by one. To collect more information one time, you can execute the display diagnostic-information command in any view to display statistics of each module’s running status. Use the display diagnostic-information command to collect at one time the information displayed by each of the following commands:
l           display clock
l           display version
l           display device
l           display current-configuration
l           display saved-configuration
l           display interface
l           display controller
l           display fib
l           display ip interface
l           display ip statistics
l           display memory
l           display logbuffer
l           display history all
&  Note:
l      For the detailed description of the display users command, refer to User Interface Commands in the System Volume.
l      The display commands discussed above are for the global configuration. Refer to the corresponding section for the display command for specific protocol and interface.
l      If no configuration file is enabled when the device is started, no information is displayed by the display saved-configuration command; otherwise, the information of the configuration file is displayed. For the detailed information of the display saved-configuration command, refer to File System Management Commands in the System Volume.
l      You are recommended to execute the display diagnostic-information command for at least two consecutive times, so that you can compare the differences between output running information to locate the fault. However, you should use this command only when necessary because execution of the command will continuously print lots of information, affecting the system operation.
1.2  CLI Features
l           Online Help with Command Lines
l           Display Features
l           History Command
l           Command Line Error Information
l           Edit Features
1.2.1  Online Help with Command Lines
The following are the types of online help available with the CLI:
l           Full help
l           Fuzzy help
To obtain the desired help information, you can:
1)         Enter <?> in any view to access all the commands in this view and brief description about them as well.
<Sysname> ?
User view commands:
  backup             Backup next startup-configuration file to TFTP server
  boot-loader        Set boot loader
  bootrom            Update/read/backup/restore bootrom
  cd                 Change current directory
  clock              Specify the system clock
  cluster            Run cluster command
  copy               Copy from one file to another
  debugging          Enable system debugging functions
  delete             Delete a file
  dir                List files on a file system
  display            Display current system information
..<omitted>
2)         Enter a command and a <?> separated by a space. If <?> is at the position of a keyword, all the keywords are given with a brief description.
<Sysname> terminal ?
  debugging  Send debug information to terminal
  logging    Send log information to terminal
  monitor    Send information output to current terminal
  trapping   Send trap information to terminal
3)         Enter a command and a <?> separated by a space. If <?> is at the position of a parameter, the description about this parameter is given.
[Sysname] interface vlan-interface ?
  <1-4094>  VLAN interface number
<1-4094> indicates that you need to input a VLAN interface number at this position. The VLAN interface is in the range 1 to 4094.
[Sysname] interface vlan-interface 1 ?
  <cr>
<cr> indicates that there is no parameter at this position. The command is then repeated in the next command line and executed if you press <Enter>.
[Sysname] sysname ?
  TEXT  Host name (1 to 30 characters)
TEXT indicates that you need to input a string whose type is TEXT at this position. The string is in the range 1 to 30 characters.
[sysname-mpls-ldp] md5-password cipher 1.1.1.1 ?
  STRING<1-16>   Enter the Secret password
  STRING<24-24>  Enter the secret encrypted password
STRING<1-16> indicates that you need to input a string whose type is STRING at this position. The string is in the range 1 to 16 characters.
  Caution:
A string whose type is STRING cannot contain spaces.
4)         Enter a character string followed by a <?>. All the commands starting with this string are displayed.
<Sysname> pi?
   ping
5)         Enter a command followed by a character string and a <?>. All the keywords starting with this string are listed.
<Sysname> display ver?
   version
6)         Press <Tab> after entering the first several letters of a keyword to display the complete keyword, provided these letters can uniquely identify the keyword in this command.
1.2.2  Display Features
CLI offers the following feature:
When the information displayed exceeds one screen, you can pause using one of the methods shown in Table 1-3.
Table 1-3 Display functions
Action
Function
Enter <Ctrl+C> when information display pauses
Stops the display and the command execution.
Press <Space> when information display pauses
Continues to display information of the next screen page.
Press <Enter> when information display pauses
Continues to display information of the next line.
<Ctrl+E>
1.2.3  History Command
The CLI can automatically save the commands that have been used. You can invoke and repeatedly execute them as needed. By default, the CLI can save up to ten commands for each user. You can use the history-command max-size command to set the capacity of the history commands log buffer for the current user interface (For the detailed description of the history-command max-size command, refer to User Interface Commands in the System Volume). The following table lists the operations that you can perform.
Follow these steps to access history commands:
To do…
Use the key/command…
Result
View the history commands
display history-command
Displays the commands that you have entered
Access the previous history command
Up-arrow key or <Ctrl+P>
Displays the earlier history command, if there is any.
Access the next history command
Down-arrow key or <Ctrl+N>
Displays the next history command, if there is any.
&  Note:
You may use arrow keys to access history commands in Windows 200X and XP Terminal or Telnet. However, the up-arrow and down-arrow keys are invalid in Windows 9X HyperTerminal, because they are defined in a different way. You can use <Ctrl+P> and <Ctrl+N> instead.
1.2.4  Command Line Error Information
The commands are executed only if they have no syntax error. Otherwise, error information is reported. Table 1-4 lists some common errors.
Table 1-4 Common command line errors
Error information
Cause
Unrecognized command
The command was not found.
The keyword was not found.
Parameter type error
The parameter value is beyond the allowed range.
Incomplete command
Incomplete command
Ambiguous command
Ambiguous command
Too many parameters
Too many parameters
Wrong parameter
Wrong parameter
1.2.5  Edit Features
The CLI provides the basic command edit functions and supports multi-line editing. The maximum length of each command is 256 characters. Table 1-5 lists these functions.
Table 1-5 Edit functions
Key
Function
Common keys
If the editing buffer is not full, insert the character at the position of the cursor and move the cursor to the right.
<Backspace> key
Deletes the character to the left of the cursor and move the cursor back one character.
Left-arrow key or <Ctrl+B>
The cursor moves one character space to the left.
Right-arrow key or <Ctrl+F>
The cursor moves one character space to the right.
Displays history commands
<Tab> key
Pressing <Tab> after entering part of a keyword enables the fuzzy help function. If finding a unique match, the system substitutes the complete keyword for the incomplete one and displays it in the next line. If there are several matches or no match at all, the system does not modify the incomplete keyword and displays it again in the next line.
