H3C S9500 Operation Manual-Release2132[V2.03]-08 System Volume
HomeSupportSwitchesS9500 SwitchesConfigure & DeployConfiguration GuidesH3C S9500 Operation Manual-Release2132[V2.03]-08 System Volume
09-SNMP Configuration
09-SNMP Configuration 73 KB
Chapter 1  SNMP Configuration
When configuring SNMP, go to these sections for information you are interested in:
l           SNMP Overview
l           SNMP Configuration
l           Trap Configuration
l           Displaying and Maintaining SNMP
l           SNMP Configuration Examples
1.1  SNMP Overview
Simple network management protocol (SNMP) offers a framework to monitor network devices through TCP/IP protocol suite. It provides a set of basic operations in monitoring and maintaining the Internet and has the following characteristics:
l           Automatic network management: SNMP enables network administrators to search and modify information, find and diagnose network problems, plan for network growth, and generate reports on network nodes.
l           SNMP shields the physical differences between various devices and thus realizes automatic management of products from different manufacturers. Offering only the basic set of functions, SNMP makes the management tasks independent of both the physical features of the managed devices and the underlying networking technology. Thus, SNMP achieves effective management of devices from different manufactures, especially so in small, high-speed and low cost network environments.
1.1.1  SNMP Mechanism
An SNMP enabled network is comprised of network management station (NMS) and Agent.
l           NMS is a station that runs the SNMP client software. It offers a user friendly human computer interface, making it easier for network administrators to perform most network management tasks. Currently, the most commonly used NMSs include Sun NetManager and IBM NetView.
l           Agent is a program on the device. It receives and handles requests sent from the NMS. Only under certain circumstances, such as interface state change, will the Agent inform the NMS.
l           NMS manages an SNMP enabled network, whereas Agent is the managed network device. They exchange management information through the SNMP protocol.
SNMP provides the following four basic operations:
l           Get operation: NMS gets the behavior information of the Agent through this operation.
l           Set operation: NMS can reconfigure certain values in the Agent MIB (management information base) to make the Agent perform certain tasks by means of this operation.
l           Trap operation: Agent sends Trap information to the NMS through this operation.
l           Inform operation: NMS sends Trap information to other NMSs through this operation.
1.1.2  SNMP Protocol Version
Currently, SNMP agents support SNMPv3 and are compatible with SNMPv1 and SNMPv2c.
SNMPv1 and SNMPv2c authenticate by means of community name, which defines the relationship between an SNMP NMS and an SNMP Agent. SNMP packets with community names that did not pass the authentication on the device will simply be discarded. A community name performs a similar role as a key word and can be used to regulate access from NMS to Agent.
SNMPv3 offers an authentication that is implemented with a User-Based Security Model (USM for short), which could be authentication with privacy, authentication without privacy, or no authentication no privacy. USM regulates the access from NMS to Agent in a more efficient way.
1.1.3  MIB Overview
Management information base (MIB) is a collection of all the objects managed by NMS. It defines the set of characteristics associated with the managed objects, such as the object identifier (OID), access right and data type of the objects.
MIB stores data using a tree structure. The node of the tree is the managed object and can be uniquely identified by a path starting from the root node. As illustrated in the following figure, the managed object B can be uniquely identified by a string of numbers {1.2.1.1}. This string of numbers is the OID of the managed object B.
Figure 1-1 MIB tree
1.2  SNMP Configuration
As configurations for SNMPv3 differ substantially from those of SNMPv1 and SNMPv2c, their SNMP functionalities will be introduced separately below.
Follow these steps to configure SNMPv3:
To do…
Use the command…
Remarks
Enter system view
Enable SNMP Agent
snmp-agent
Optional
Disabled by default
You can enable SNMP Agent through this command or any commands that begin with “snmp-agent”.
Configure SNMP Agent system information
snmp-agent sys-info { contact sys-contact | location sys-location | version { all | { v1 | v2c | v3 }* } }
Optional
The defaults are as follows:
Hangzhou H3C Technologies Co., Ltd. for contact,
Hangzhou, China for location, and <NONE> for the version.
Configure an SNMP agent group
snmp-agent group v3 group-name [ authentication | privacy ] [ read-view read-view ] [ write-view write-view ] [ notify-view notify-view ] [ acl acl-number ]
Required
Add a new user to an SNMP agent group
snmp-agent usm-user v3 user-name group-name [ authentication-mode { md5 | sha } auth-password [ privacy-mode { des56 | aes128 } priv-password ] ] [ acl acl-number ]
Required
Configure the maximum size of an SNMP packet that can be received or sent by an SNMP agent
Optional
1,500 bytes by default
Configure the engine ID for a local SNMP agent
Optional
Company ID and device ID by default
Create or update the MIB view content for an SNMP agent
snmp-agent mib-view { included | excluded } view-name oid-tree [ mask mask-value ]
Optional
MIB view name is ViewDefault and OID is 1 by default.
Follow these steps to configure SNMPv1 and SNMPv2c:
To do…
Use the command…
Remarks
Enter system view
Enable SNMP Agent
snmp-agent
Optional
Disabled by default
snmp-agent sys-info { contact sys-contact | location sys-location | version { { v1 | v2c | v3 }* | all } }
Required
Hangzhou, China for location and <NONE> for the version.
Configure SNMP NMS access right
Configure directly
Configure a community name
snmp-agent community { read | write } community-name [ acl acl-number | mib-view view-name ]*
Use either approach.
The community name of SNMPv1 or SNMPv2c is used in direct configuration.
The second approach was introduced to be compatible with SNMPv3. Adding a user to a specified group equals to the configuration of the community name of SNMPv1 and SNMPv2c.
The community name configured on NMS should be consistent with the corresponding username configured on the Agent.
Configure indirectly
Configure an SNMP group
snmp-agent group { v1 | v2c } group-name [ read-view read-view ] [ write-view write-view ] [ notify-view notify-view ] [ acl acl-number ]
Add a new user to an SNMP group
snmp-agent usm-user { v1 | v2c } user-name group-name [ acl acl-number ]
Optional
15,00 bytes by default
Optional
Create or update MIB view content for an SNMP agent
Optional
ViewDefault by default
  Caution:
The validity of a USM user depends on the engine ID of the SNMP agent. If the engine ID used for USM user creation is not identical to the current engine ID, the USM user is invalid.
1.3  Trap Configuration
SNMP Agent sends Trap messages to NMS to alert the latter of critical and important events (such as restart of the managed device).
1.3.1  Configuration Prerequisites
Basic SNMP configurations have been completed.
1.3.2  Configuration Procedure
I. Enabling Trap message transmission
Follow these steps to enable Trap packet transmission:
To do…
Use the command…
Remarks
Enter system view
Set to enable the device to send Trap packets globally
snmp-agent trap enable [ bgp | configuration | flash | mpls | ospf [ process-id ] [ ospf-trap-list ] | standard [ authentication | coldstart | linkdown | linkup | warmstart ]* | system | vrrp [ authfailure | newmaster ] ]
Optional
All types of Trap packets are allowed by default.
Enter interface view
Set to enable the device to send Trap packets of interface state change
enable snmp trap updown
Optional
Transmission of Trap packets of interface state change is allowed by default.
  Caution:
To enable an interface to send SNMP Trap packets when its state changes, you need to enable the Link up/down Trap packet transmission function on an interface and globally. Use the enable snmp trap updown command to enable this function on an interface, and use the snmp-agent trap enable [ standard [ linkdown | linkup ] * ] command to enable this function globally.
II. Configuring Trap message transmission parameters
Follow these steps to configure Trap:
To do…
Use the command…
Remarks
Enter system view
Configure target host attribute for Trap messages
snmp-agent target-host trap address udp-domain { ip-address | ipv6 ipv6-address } [ udp-port port-number ] params securityname security-string [ v1 | v2c | v3 [ authentication | privacy ] ]
Required
Configure the source address for Trap messages
snmp-agent trap source { interface-type interface-number }
Optional
Configure the queue size for sending Trap messages
Optional
100 by default
Configure the life for Trap messages
snmp-agent trap life seconds
Optional
120 seconds by default
1.4  Displaying and Maintaining SNMP
To do…
Use the command…
Remarks
Display SNMP-agent system information, including the contact, location, and version of the SNMP
display snmp-agent sys-info [ contact | location | version ]*
Available in any view
Display SNMP agent statistics
display snmp-agent statistics
Display the SNMP agent engine ID
display snmp-agent local-engineid
Display SNMP agent group information
display snmp-agent group [ group-name ]
Display SNMP v3 agent user information
display snmp-agent usm-user [ engineid engineid | username user-name | group group-name ] *
Display SNMP v1 or v2c agent community information
Display MIB view information for an SNMP agent
display snmp-agent mib-view [ exclude | include | viewname view-name ]
Display the modules that can send Traps and whether their Trap sending is enabled or not
display snmp-agent trap-list
1.5  SNMP Configuration Examples
I. Network requirements
l           The NMS connects to the agent, a switch, through an Ethernet.
l           The IP address of the NMS is 129.102.149.23/16.
l           The IP address of VLAN interface on the switch is 129.102.0.1/16.
l           On the switch, configure the following: community name, access right, administrator ID, contact, location, enabling sending of Trap messages.
II. Network diagram
Figure 1-2 Network diagram for SNMP
III. Configuration procedure
1)         Configuring SNMP Agent
# Configure the community name, the SNMP agent group, and SNMP agent user.
[Sysname] snmp-agent sys-info version all
[Sysname] snmp-agent community read public
[Sysname] snmp-agent community write private
[Sysname] snmp-agent mib-view include internet 1.3.6.1
[Sysname] snmp-agent group v3 managev3group write-view internet
[Sysname] snmp-agent usm-user v3 managev3user managev3group
# Configure the IP address of VLAN-interface 2 as 129.102.0.1/16 for network management. Add port Ethernet 2/1/3 used for network management to VLAN 2.
[Sysname] vlan 2
[Sysname-vlan2] port ethernet 2/1/3
[Sysname-vlan2] interface Vlan-interface 2
[Sysname-Vlan-interface2] ip address 129.102.0.1 255.255.0.0
[Sysname-Vlan-interface2] quit
# Configure the system information of the switch.
[Sysname] snmp-agent sys-info contact Mr.Wang-Tel:3306
[Sysname] snmp-agent sys-info location telephone-closet,3rd-floor
# Enable the sending of Trap messages to the NMS with an IP address of 129.102.149.23/16, using public as the community name.
[Sysname] snmp-agent target-host trap address udp-domain 129.102.149.23 udp-port 5000 params securityname public
2)         Configuring SNMP NMS
SNMPv3 uses authentication and privacy security model. In NMS, the user needs to specify username and security level, and based on that level, configure the authentication mode, authentication password, privacy mode, privacy password. In addition, the time-out time and number of retries should also be configured. The user can inquire and configure the switch through NMS. For detailed information, refer to the NMS manuals.
&  Note:
The configurations on the agent and the NMS must match in order to perform the related operations.
