H3C S9500 Operation Manual-Release2132[V2.03]-08 System Volume
HomeSupportSwitchesS9500 SwitchesConfigure & DeployConfiguration GuidesH3C S9500 Operation Manual-Release2132[V2.03]-08 System Volume
00-1Cover
00-1Cover 55.09 KB
H3C S9500 Series Routing Switches
Operation Manual
Hangzhou H3C Technologies Co., Ltd.
http://www.h3c.com
Manual Version: T2-081655-20080820-C-2.03
Product Version: S9500-CMW520-R2132
Copyright © 2007-2008, Hangzhou H3C Technologies Co., Ltd. and its licensors
All Rights Reserved
No part of this manual may be reproduced or transmitted in any form or by any means without prior written consent of Hangzhou H3C Technologies Co., Ltd.
Trademarks
H3C, Adobe Systems, Aolynk, , H3Care, , TOP G, , IRF, NetPilot, Neocean, NeoVTL, SecPro, SecPoint, SecEngine, SecPath, Comware, Secware, Storware, NQA, VVG, V2G, VnG, PSPT, XGbus, N-Bus, TiGem, InnoVision and HUASAN are trademarks of Hangzhou H3C Technologies Co., Ltd.
All other trademarks that may be mentioned in this manual are the property of their respective owners.
Notice
The information in this document is subject to change without notice. Every effort has been made in the preparation of this document to ensure accuracy of the contents, but all statements, information, and recommendations in this document do not constitute the warranty of any kind, express or implied.
To obtain the latest information, please access:
http://www.h3c.com
Technical Support
[email protected]
http://www.h3c.com
About This Manual
Related Documentation
In addition to this manual, each H3C S9500 Series Routing Switches documentation set includes the following:
Manual
H3C S9500 Series Routing Switches  Installation Manual
It introduces the installation procedure, commissioning, maintenance and monitoring of the S9500 series routing switches.
H3C S9500 Series Routing Switches  Command Manual
It includes Feature List and Command Index, Access Volume, IP Service Volume, IP Routing Volume, IP Multicast Volume, MPLS VPN Volume, QoS ACL Volume, Security Volume, System Volume, and unsupported commands.
Organization
H3C Configuration Manual is organized as follows:
Part
00 Product Overview
includes Obtaining the Documentation, Product Features, and Features.
01 Access Volume
includes Ethernet Interface Configuration, POS Interface Configuration, GVRP Configuration, Link Aggregation Configuration, Port Mirroring Configuration, RPR Configuration, Ethernet OAM Configuration MSTP Configuration, VLAN Configuration, QinQ Configuration, BPDU Tunneling Configuration, and Port Isolation Configuration.
02 IP Services Volume
includes ARP Configuration, DHCP Configuration, DNS Configuration, IP Addressing Configuration, IP Performance Configuration, UDP Helper Configuration IPv6 Basics Configuration, Dual Stack Configuration, Tunneling Configuration, and Adjacency Table Configuration.
03 IP Routing Volume
includes IP Routing Overview, BGP Configuration, IS-IS Configuration, OSPF Configuration, RIP Configuration, Routing Policy Configuration, Static Routing Configuration, IPv6 BGP Configuration, IPv6 IS-IS Configuration, IPv6 OSPFv3 Configuration, IPv6 RIPng Configuration, and IPv6 Static Routing Configuration.
04 IP Multicast Volume
includes Multicast Overview, Multicast Routing and Forwarding Configuration, IGMP Snooping Configuration, IGMP Configuration, PIM Configuration, MSDP Configuration, IPv6 Multicast Routing and Forwarding Configuration, MLD Snooping Configuration, MLD Configuration, IPv6 PIM Configuration, and Multicast VLAN Configuration.
05 MPLS VPN Volume
includes MPLS Basics Configuration, MPLS TE Configuration, VPLS Configuration, MPLS L2VPN Configuration, MPLS L3VPN Configuration, MPLS Hybrid Insertion Configuration, and GRE Configuration.
06 QoS ACL Volume
includes QoS Configuration and ACL Configuration.
07 Security Volume
includes 802.1x Configuration, AAA RADIUS HWTACACS Configuration, MAC Authentication Configuration, L3+NAT Configuration, Password Control Configuration, SSH2.0 Configuration, and Portal Configuration.
08 System Volume
includes GR Configuration, VRRP Configuration, HA Configuration, Device Management Configuration, NQA Configuration, NetStream Configuration, NTP Configuration, RMON Configuration, SNMP Configuration, File System Management Configuration, System Maintaining and Debugging Configuration, Basic System Configuration, Information Center Configuration, User Interface Configuration, MAC Address Table Management Configuration, PoE Configuration, and Clock Monitoring Configuration.
09 OAA Volume
includes OAP Module Configuration and ACSEI Configuration.
10 Acronyms
Offers the acronyms used in this manual.
Conventions
The manual uses the following conventions:
I. Command conventions
Convention
Boldface
The keywords of a command line are in Boldface.
italic
Command arguments are in italic.
Items (keywords or arguments) in square brackets [ ] are optional.
{ x | y | ... }
Alternative items are grouped in braces and separated by vertical bars. One is selected.
[ x | y | ... ]
Optional alternative items are grouped in square brackets and separated by vertical bars. One or none is selected.
{ x | y | ... } *
Alternative items are grouped in braces and separated by vertical bars. A minimum of one or a maximum of all can be selected.
[ x | y | ... ] *
Optional alternative items are grouped in square brackets and separated by vertical bars. Many or none can be selected.
&<1-n>
The argument(s) before the ampersand (&) sign can be entered 1 to n times.
A line starting with the # sign is comments.
II. GUI conventions
Convention
Button names are inside angle brackets. For example, click <OK>.
Window names, menu items, data table and field names are inside square brackets. For example, pop up the [New User] window.
Multi-level menus are separated by forward slashes. For example, [File/Create/Folder].
III. Symbols
Convention
  Warning
Means reader be extremely careful. Improper operation may cause bodily injury.
  Caution
Means reader be careful. Improper operation may cause data loss or damage to equipment.
&  Note
Means a complementary description.
