H3C S9500 Operation Manual-Release2132[V2.03]-08 System Volume
HomeSupportSwitchesS9500 SwitchesConfigure & DeployConfiguration GuidesH3C S9500 Operation Manual-Release2132[V2.03]-08 System Volume
14-User Interface Configuration
14-User Interface Configuration 79.69 KB
Chapter 1  User Interface Configuration
When configuring user interface, go to these sections for information you are interested in:
l           User Interface Overview
l           Configuring User Interface
l           Configuring Asynchronous Serial Interface Attributes
l           Configuring Terminal Attributes
l           Configuring Modem Attributes
l           Configuring the auto-execute Command
l           Configuring User Privilege Level
l           Configuring Access Restriction on VTY User Interface(s)
l           Configuring Supported Protocols on VTY User Interface(s)
l           Configuring Authentication Mode at Login
l           Sending Messages to the Specified User Interface(s)
l           Releasing the Connection Established on the User Interface(s)
l           Displaying and Maintaining User Interface(s)
1.1  User Interface Overview
1.1.1  Brief Introduction
User interface view is a feature that allows you to manage asynchronous serial interfaces that work in flow mode. By operating under user interface view, you can centralize the management of various configurations.
At present, the system supports the following three configuration modes:
l           Local configuration via the Console port
l           Local/Remote configuration via the AUX port (Auxiliary port)
l           Local/Remote configuration through Telnet or SSH
The three modes correspond to four types of user interfaces. They are:
l           Console port: A view which you log in from the console port. Console port is a line device port. The device has only one console port, with the port type as EIA/TIA-232 DCE.
l           AUX port: A view which you log in from the AUX port. AUX port is also a line device port. The device has only one AUX port of EIA/TIA-232 DTE type. This port is usually used for dialup access via modem.
l           VTY (Virtual Type Terminal): A view which you log in through VTY. VTY port is a logical terminal line used when you access the device by means of Telnet or SSH. Currently, each device supports up to five VTY users to access simultaneously.
1.1.2  User Interface Numbering
User interfaces can be numbered in two ways: absolute numbering and relative numbering.
I. Absolute numbering
Absolute numbering allows you to uniquely specify a user interface or a group of user interfaces. The numbering system starts from number 0 (representing the Console port), and followed by 1 (representing the AUX port), then 2 to represent VTY 0, and so on.
&  Note:
The numbering approach numbers the three types of user interfaces in the sequence of: console port, AUX port and VTY. The console port and the AUX port each occupy a number, and the VTY user interfaces are numbered from 2 to 6.
You can use the display user-interface command to view the number of the user interfaces.
II. Relative numbering
Relative numbering numbers a user interface in the form of “user interface type + number”. In this way, it can specify a user interface or a group of user interfaces of a specific type. This form of number is valid only when used under that type of user interface. It makes no sense when used under other types of user interfaces. The rules of relative numbering are as follows:
l           CON is numbered CON 0.
l           AUX is numbered AUX 0.
l           VTYs are numbered from 0 in ascending order, with a step of 1.
1.2  Configuring User Interface
Complete these tasks to configure user interface:
Remarks
Optional
Optional
Optional
Optional
Optional
Optional
Optional
Optional
Optional
Optional
1.3  Configuring Asynchronous Serial Interface Attributes
Follow these steps to configure asynchronous attributes of a serial interface:
To do…
Use the command…
Remarks
Enter system view
Enter user interface view
user-interface { first-num1 [ last-num1 ] | { aux | console | vty } first-num2 [ last-num2 ] }
Configure transmission speed
speed speed-value
Optional
9600 bps by default
Configure flow control mode
flow-control { none | software | hardware }
Optional
none by default
Set parity bits
parity { none | even | odd | mark | space }
Optional
none by default
Set stop bits
stopbits { 1.5 | 1 | 2 }
Optional
1 by default
Currently, stop bits 1.5 cannot be configured.
Set data bits
databits { 5 | 6 | 7 | 8 }
Optional
8 by default
Currently, data bits 5 and 6 cannot be configured.
&  Note:
The above configuration takes effect only when the asynchronous serial interface is working in asynchronous flow mode.
1.4  Configuring Terminal Attributes
To do…
Use the command…
Remarks
Enter system view
Start the terminal service
shell
Optional
The terminal service is enabled on all user interfaces by default.
Set the idle-timeout disconnection function for terminal users
Optional
10 minutes by default.
Set the screen-length of the terminal screen
screen-length screen-length
Optional
The screen displays 24 lines of data by default.
Set the display type of a terminal
Optional
ANSI by default.
Set the number of the history commands that can be stored in the history buffer
history-command max-size size-value
Optional
The history buffer can store 10 commands by default.
Return to user view
return
Lock user interface, preventing unauthorized users from using this interface
lock
Optional
Disabled by default.
&  Note:
The system supports two types of terminal display: ANSI and VT100. If the terminal display of the device and the client (for example, hyper terminal or Telnet terminal) is inconsistent or is set to ANSI, and if the total number of the characters of the currently using command line exceeds 80, anomalies such as cursor corruption or abnormal display of the terminal display may occur on the client. Therefore, you are recommended to set the display type of both the device and the client to VT100.
1.5  Configuring Modem Attributes
In the event of dial-in through a modem into an asynchronous interface, you can manage and configure the modem-concerned parameters in user interface view.
Follow these steps to configure the modem attributes:
To do…
Use the command…
Remarks
Enter system view
user-interface { first-num1 [ last-num1 ] | { aux | vty } first-num2 [ last-num2 ] }
Set the interval for a user from hookoff to dial-up when dial-in connection is established
modem timer answer time
Optional
30 seconds by default
Enable auto answer for the modem
modem auto-answer
Optional
Manual answer by default
Enable the modem to dial in, dial out or both
modem { both | call-in | call-out }
Optional
Disabled by default
&  Note:
The above configuration takes effect only for the AUX and VTY ports working in flow mode.
1.6  Configuring the auto-execute Command
With the auto-execute command command enabled, the system automatically executes the configured command when you log in. After the command is completed or after the tasks triggered by the command are completed, the connection breaks automatically.
This command is normally used to configure the Telnet command to enable you to connect to the specified host automatically.
Follow these steps to configure auto-execute command:
To do…
Use the command…
Remarks
Enter system view
Configure the command to be automatically executed
Required
No command is set to be automatically executed by default.
The auto-execute command command is supported on all types of user interfaces except the Console port and the AUX port functioning as the console port.
  Caution:
The auto-execute command command may disable you from configuring the system through the terminal line to which the command is applied. Therefore, before configuring the command and saving the configuration (using the save command), make sure that you can access the system by other means to remove the configuration in case a problem occurs.
1.7  Configuring User Privilege Level
You can restrict a user to use only a subset of all the system commands through settings on two aspects: user interface level and user level.
l           If username and password are needed in the configured authentication mode, the user privilege level is defined by the user level. For SSH users, when they use RSA public key authentication, their privilege level is defined by the level configured on the user interface.
l           If no authentication is adopted or the password authentication is adopted, the user privilege level is defined by the user interface level used when login.
l           If the setting of user interface level is inconsistent with that of the user level, the user level applies. For example, if user1 can use level 3 commands, and the user interface VTY0 can use level 2 commands, then user1 can use commands of level 3 or a lower level when logging onto the system through VTY0.
Setting of the user level: Use the local-user command in system view to create a user and enter local user view, in which use the level command to specify the user level. For the detailed description of the local-user and level commands, refer to AAA RADIUS HWTACACS Configuration Commands in Security Volume.
Follow these steps to configure the user privilege level under a user interface:
To do…
Use the command…
Remarks
Enter system view
Configure user’s privilege level under the current user interface
user privilege level level
Optional
By default, users logging in from Console port have a privilege level of 3; users logging in from other user interfaces have a privilege level of 0.
1.8  Configuring Access Restriction on VTY User Interface(s)
You can configure access restriction on the VTY user interface through referencing an ACL. For details regarding ACL, refer to ACL Configuration in QoS ACL Volume.
Follow these steps to configure access restriction on VTY user interfaces:
To do…
Use the command…
Remarks
Enter system view
Enter VTY user interface view
user-interface { first-num1 [ last-num1 ] | vty first-num2 [ last-num2 ] }
Configure the access restriction on the VTY user interface
By referencing basic/advanced ACL
acl [ ipv6 ] acl-number { inbound | outbound }
Use either command
No restriction is set by default.
By referencing Layer 2 ACL
acl acl-number inbound
1.9  Configuring Supported Protocols on VTY User Interface(s)
Currently, only the VTY user interface allows configuration on the supported protocols.
Follow these steps to configure supported protocols on the active VTY user interface:
To do…
Use the command…
Remarks
Enter system view
Configure the supported protocol(s) on the active user interface
Optional
Both Telnet and SSH are supported by default.
  Caution:
l      If SSH is configured, you must set the authentication mode to scheme using the authentication-mode scheme command to guarantee a successful login. The protocol inbound ssh command fails if the authentication mode is password or none. For the corresponding configuration, refer to the authentication-mode command in User Interface Commands in System Volume.
l      The protocol(s) configured through the protocol inbound command takes effect next time you log in from that user interface.
1.10  Configuring Authentication Mode at Login
With the configuration of user interface authentication mode, you can decide whether to authenticate users when they log on through the specified user interface, thus enhancing the security of the device. The supported authentication modes on the device are none, password, and scheme.
l           If you specify the authentication mode as none, then no username and password are needed when users log on through the specified user interface, which may be insecure.
l           If you specify the authentication mode as password, then password authentication is needed when users log on through the specified user interface. Input of empty or wrong password may result in login failure. Before terminating the redirected Telnet connection, set the password of the specified user interface.
l           If you specify the authentication mode as scheme, then username and password authentication is needed when users log on through the specified user interface. Input of empty or wrong password may result in login failure. Before terminating the redirected Telnet connection, set the username and password.
Follow these steps to configure authentication mode at login as none:
To do…
Use the command…
Remarks
Enter system view
Set authentication mode at login to none
authentication-mode none
Required
By default, the authentication mode is password for VTY and AUX user interfaces and is none for Console interface.
Follow these steps to configure authentication mode at login as password:
To do…
Use the command…
Remarks
Enter system view
Set authentication mode at login to password
authentication-mode password
Required
Set local authentication password
set authentication password { cipher | simple } password
Required
No local authentication password is set by default.
Follow these steps to configure authentication mode at login as scheme:
To do…
Use the command…
Remarks
Enter system view
Set authentication mode at login to scheme
authentication-mode scheme [ command-authorization ]
Required
Set authentication username and enter local user view
local-user user-name
Required
No local user is set on the device by default.
Set authentication password
Required
&  Note:
For the detailed description of the local-user and password commands, refer to AAA RADIUS HWTACACS Configuration Commands in Security Volume.
1.11  Sending Messages to the Specified User Interface(s)
To do…
Use the command…
Remarks
Send messages to the specified user interface(s)
send { all | num1 | { aux | console | vty } num2 }
Required
1.12  Releasing the Connection Established on the User Interface(s)
To do…
Use the command…
Remarks
Release the connection established on the specified user interface(s)
free user-interface { num1 | { aux | console | vty } num2 }
Required
&  Note:
You cannot use this command to release the connection that you are using.
1.13  Displaying and Maintaining User Interface(s)
To do…
Use the command…
Remarks
Display the information on the use of the user interface(s)
display users [ all ]
Available in any view
Display the information about the specified or all user interface(s)
display user-interface [ num1 | { aux | console | vty } num2 ] [ summary ]
Display the history commands that the current user has configured
display history-command
Chapter 2  Management Ethernet Port Configuration
When configuring management Ethernet port, go to these sections for information you are interested in:
l           Management Ethernet Port Overview
l           Management Ethernet Port Configuration
2.1  Management Ethernet Port Overview
Each SRPU on an S9500 series switch provides a 10/100Base-TX management Ethernet port (M-Ethernet) which has the functions listed below:
l           Connected with a PC, the port implements downloading and debugging of system programs.
l           Connected with a remote network management workstation, the port implements remote system management.
2.2  Management Ethernet Port Configuration
You can perform the following operations in management Ethernet port view:
l           Configure the IP address for an interface
l           Bring up/shut down an interface
l           Set the description for an interface
l           Display the current system information
l           Test network connectivity (ping, tracert)
For detailed information, refer to Ethernet Interface Configuration in Access Volume and System Maintaining and Debugging Configuration in System Volume.
  Caution:
l      A management Ethernet port is available only when being configured with an IP address.
l      Management Ethernet ports do not support dynamic routing protocols.
