H3C S9500 Command Manual-Release2132[V2.03]-05 MPLS VPN Volume
HomeSupportSwitchesS9500 SwitchesReference GuidesCommand ReferencesH3C S9500 Command Manual-Release2132[V2.03]-05 MPLS VPN Volume
05-MPLS L3VPN Commands
05-MPLS L3VPN Commands 222.85 KB
Table of Contents
Chapter 1 MPLS L3VPN Configuration Commands. 1-1
1.1 MPLS L3VPN Configuration Commands. 1-1
1.1.1 debugging vrffib. 1-1
1.1.2 debugging mpls l3vpn. 1-1
1.1.3 default local-preference (BGP-VPNv4 subaddress family view) 1-2
1.1.4 default med (BGP-VPNv4 subaddress family view) 1-3
1.1.5 description (VPN instance view) 1-4
1.1.6 display bgp vpnv4 all routing-table. 1-4
1.1.7 display bgp vpnv4 group. 1-7
1.1.8 display bgp vpnv4 network. 1-9
1.1.9 display bgp vpnv4 paths. 1-10
1.1.10 display bgp vpnv4 peer 1-11
1.1.11 display bgp vpnv4 route-distinguisher routing-table. 1-16
1.1.12 display bgp vpnv4 routing-table label 1-19
1.1.13 display bgp vpnv4 vpn-instance routing-table. 1-21
1.1.14 display fib statistics vpn-instance. 1-24
1.1.15 display fib vpn-instance. 1-25
1.1.16 display ip vpn-instance. 1-26
1.1.17 display ospf sham-link. 1-27
1.1.18 display tunnel-policy. 1-29
1.1.19 domain-id. 1-30
1.1.20 export route-policy. 1-30
1.1.21 filter-policy export (BGP-VPNv4 subaddress family view) 1-31
1.1.22 filter-policy import (BGP-VPNv4 subaddress family view) 1-32
1.1.23 import route-policy. 1-33
1.1.24 ip binding vpn-instance. 1-34
1.1.25 ip vpn-instance. 1-35
1.1.26 ipv4-family. 1-35
1.1.27 peer advertise-community (BGP-VPNv4 subaddress family view) 1-36
1.1.28 peer allow-as-loop. 1-37
1.1.29 peer as-path-acl (BGP-VPNv4 subaddress family view) 1-38
1.1.30 peer default-route-advertise vpn-instance. 1-39
1.1.31 peer enable. 1-40
1.1.32 peer filter-policy (BGP-VPNv4 subaddress family view) 1-41
1.1.33 peer group. 1-42
1.1.34 peer ip-prefix (BGP-VPNv4 subaddress family view) 1-43
1.1.35 peer label-route-capability (BGP view/BGP VPN instance view) 1-44
1.1.36 peer next-hop-invariable (BGP-VPNv4 subaddress family view) 1-45
1.1.37 peer next-hop-local 1-45
1.1.38 peer public-as-only (BGP-VPNv4 subaddress family view) 1-46
1.1.39 peer reflect-client 1-47
1.1.40 peer route-policy (BGP-VPNv4 subaddress family view) 1-48
1.1.41 peer upe. 1-49
1.1.42 policy vpn-target 1-50
1.1.43 reflect between-clients. 1-51
1.1.44 reflector culster-id. 1-52
1.1.45 refresh bgp vpn-instance. 1-53
1.1.46 refresh bgp vpnv4. 1-54
1.1.47 reset bgp vpn-instance. 1-55
1.1.48 reset bgp vpn-instance dampening. 1-56
1.1.49 reset bgp vpn-instance flap-info. 1-56
1.1.50 reset bgp vpnv4. 1-57
1.1.51 route-distinguisher (VPN instance view) 1-58
1.1.52 route-tag. 1-59
1.1.53 routing-table limit 1-60
1.1.54 rr-filter 1-61
1.1.55 sham-link. 1-62
1.1.56 tnl-policy (VPN instance view) 1-64
1.1.57 tunnel-policy. 1-65
1.1.58 tunnel select-seq load-balance-number 1-65
1.1.59 vpn-instance-capability simple. 1-66
1.1.60 vpn-target (VPN instance view) 1-67
debugging vrffib { error | rtmsg | synmsg }
undo debugging vrffib { error | rtmsg | synmsg }
View
Default Level
2: System level
error: Specifies error debugging.
rtmsg: Specifies entry operation debugging.
synmsg: Specifies synchronization entry operation debugging.
Use the debugging vrffib command to enable VRFFIB debugging.
Use the undo debugging vrffib command to disable VRFFIB debugging.
By default, VRFFIB debugging is disabled.
# Enable entry operation debugging. Then, creating VPN instance vpn1, you can see the debugging information.
<Sysname> debugging vrffib rtmsg
*Mar 28 08:57:31:352 2007 Sysname VRFFIB/7/ip_vrffib:
Create VRF 3: write fib-vpn queue Ok !
debugging mpls l3vpn { all | hsb }
undo debugging mpls l3vpn { all | hsb }
View
Default Level
2: System level
all: Specifies debugging of all MPLS L3VPN messages.
hsb: Specifies MPLS L3VPN hot backup debugging.
Use the debugging mpls l3vpn command to enable debugging for MPLS L3VPN hot backup messages or all MPLS L3VPN messages.
Use the undo debugging mpls l3vpn command to disable debugging for MPLS L3VPN hot backup messages or all MPLS L3VPN messages.
# Enable debugging for all MPLS L3VPN messages.
<Sysname> debugging mpls l3vpn all
undo default local-preference
View
Default Level
2: System level
value: Default value for the local preference. A greater value represents a higher priority.
Use the default local-preference command to set the default value of the local preference.
Use the undo default local-preference command to restore the default.
By default, the default value of the local preference is 100.
# With devices A and B connected to the outside AS, configure B with a default local preference of 180 in BGP-VPNv4 subaddress family view, allowing the route going through B to be preferred when more than one route is present.
[Sysname] bgp 100
[Sysname-bgp] ipv4-family vpnv4
[Sysname-bgp-af-vpnv4] default local-preference 180
default med med-value
undo default med
View
Default Level
2: System level
med-value: MED value.
Use the default med command to set the default system metric.
Use the undo default med command to restore the default.
With other criteria the same, the system selects the route with a smaller MED value as the AS external route.
By default, the MED value is 0.
# Set the default MED to 10 for PE1 in BGP-VPNv4 subaddress family view.
[Sysname] bgp 100
[Sysname] ipv4-family vpnv4
[Sysname-bgp-af-vpnv4] default med 10
View
VPN instance view
Default Level
2: System level
text: Description for the VPN instance.
Use the description command to configure a description for a VPN instance.
Use the undo description command to delete the description.
# Configure the description of VPN instance vpn1.
[Sysname-vpn-instance-vpn1] description This is vpn1
display bgp vpnv4 all routing-table [ network-address [ { mask | mask-length } [ longer-prefixes ] ] | as-path-acl as-path-acl-number | cidr | community [ aa:nn ]&<1-13> [ no-export-subconfed | no-advertise | no-export ]* [ whole-match ] | community-list { basic-community-list-number [ whole-match ] | adv-community-list-number }&<1-16> | different-origin-as | peer ip-address { advertised-routes | received-routes } [ statistic ] | regular-expression as-regular-expression | statistic ]
View
Default Level
1: Monitor level
network-address: IP address of the destination segment.
mask: Network mask.
mask-length: Length of the network mask.
longer-prefixes: Specifies to match the longest prefix.
as-path-acl as-path-acl-number: Filters routing information using the specified AS_PATH list.
cidr: Displays classless inter-domain routing (CIDR) information.
community: Displays routing information of the specified BGP community in the routing table.
aa:nn&<1-13>: Community number. &<1-13> means that you can enter the parameter combination up to 13 times.
no-export-subconfed: A route with this attribute is neither advertised out of the local AS, nor advertised to the other sub-ASs in the confederation.
no-advertise: A route with this attribute is not advertised to any other BGP peer.
no-export: A route with this attribute is not advertised out of the local AS or, If existing, confederation. However, it is advertised to the other sub-ASs in the confederation.
whole-match: Performs exact match.
community-list: Displays routing information of the specified BGP community list in the routing table.
basic-community-list-number: Basic community list number, in the range 1 to 99.
adv-community-list-number: Advanced community list number, in the range 100 to 199.
&<1-16>: Specifies that the argument before it can be entered up to 16 times.
different-origin-as: Displays information about routes with different AS origins.
peer ip-address: Specifies a BGP VPNv4 peer by its IP address.
advertised-routes: Specifies the routing information advertised to the specified peer.
received-routes: Specifies the routing information received from the specified peer.
regular-expression as-regular-expression: Displays routing information matching the specified AS_PATH regular expression.
statistic: Displays BGP VPNv4 route statistics.
Use the display bgp vpnv4 all routing-table command to display all BGP VPNv4 routing information.
# Display all BGP VPNv4 routing information.
<Sysname> display bgp vpnv4 all routing-table
 BGP Local router ID is 2.2.2.2
 Status codes: * - valid, > - best, d - damped,
               h - history,  i - internal, s - suppressed, S - Stale
               Origin : i - IGP, e - EGP, ? - incomplete
 Total number of routes from all PE: 2
 Route Distinguisher: 100:1
    Network            NextHop         Label(recv/app)  MED        LocPrf
*>i 10.0.0.0           1.1.1.1         (1025 /NULL )    0          100
*>i 123.1.1.1/32       1.1.1.1         (1024 /NULL )   0          100
 Total routes of vpn-instance vpn1: 5
*>i 10.0.0.0           1.1.1.1                          0          100
*>  10.1.1.0/24        0.0.0.0         (NULL /1025 )    0
*>  20.0.0.0           10.1.1.1        (NULL /1026 )    0
*>i 123.1.1.1/32       1.1.1.1                          0          100
*>  124.1.1.1/32       0.0.0.0         (NULL /1024 )    0
Table 1-1 Description on the fields of display bgp vpnv4 all routing-table
BGP Local router ID
Router ID of the local BGP device
Status codes
Route status codes. Valid values include:
* - valid: Valid route
> - best: Best route
d - damped: Route damped for route flap
h - history: History route
i - internal: Internal route
s - suppressed: Suppressed route
S - Stale: Stale route
Origin
Route origin codes. Valid values include:
i - IGP (learned from the AS)
e - EGP (learned through EGP)
? - incomplete (learned in any other way)
Total number of VPNv4 routes from all PEs
Route Distinguisher
RD
Network
Network address
NextHop
Address of the next hop
Label(recv/app)
Incoming and outgoing labels
MED
Metric associated with the destination network
Total number of routes of the specified VPN instance
LocPrf
Local preference
display bgp vpnv4 { all | vpn-instance vpn-instance-name } group [ group-name ]
View
Default Level
1: Monitor level
all: Specifies all VPNv4 peers.
vpn-instance-name: Name of the VPN instance.
group-name: Name of the BGP peer group.
Use the display bgp vpnv4 group command to display information about a specified or all BGP VPNv4 peer groups.
# Display information about BGP VPNv4 peer group a for VPN instance vpn1.
<Sysname> display bgp vpnv4 vpn-instance vpn1 group a
 BGP peer-group is a
 remote AS 200
 Type : external
 Maximum allowed prefix number: 150000
 Threshold: 75%
 Configured hold timer value: 180
 Keepalive timer value: 60
 Minimum time between advertisement runs is 30 seconds
 Peer Preferred Value: 99
  Members:
  Peer       V    AS  MsgRcvd  MsgSent  OutQ PrefRcv Up/Down  State
  10.1.1.1  4   200       18       21     0       1     00:12:58 Established
Table 1-2 Description on the fields of the display bgp vpnv4 group command
BGP peer-group
remote AS number
Number of the remote AS
Type of the BGP peer group
Maximum number of routes that the VPN instance supports
Threshold
Threshold value
Setting of the hold timer
Keepalive interval
Minimum route advertisement interval
Weight for the routes from the peer
Whether the VPN instance is configured with a routing policy
Peer
IP address of the peer
V
Version of BGP that the peer runs
AS
AS number of the peer group
MsgRcvd
Number of messages received
MsgSent
Number of messages sent
OutQ
Number of messages waiting to be sent to the peer
PrefRcv
Number of prefixes received
Up/Down
Duration of the BGP session in the current state
Status of the peer
display bgp vpnv4 { all | vpn-instance vpn-instance-name } network
View
Default Level
1: Monitor level
Use the display bgp vpnv4 network command to display information about BGP VPNv4 routes injected into a specified or all VPN instances.
# Display information about BGP VPNv4 routes injected into VPN instance vpn1.
<Sysname> display bgp vpnv4 vpn-instance vpn1 network
  BGP Local Router ID is 1.1.1.1.
  Local AS Number is 100.
  Network          Mask            Route-policy
  10.0.0.0         255.0.0.0
Table 1-3 Description on the fields of the display bgp vpnv4 network command
BGP Local Router ID
Router ID of the local BGP router
Local AS Number
Number of the local AS
Network
Advertised network route
Mask
Mask of the advertised network route
Route-policy
Routing policy configured
display bgp vpnv4 { all | vpn-instance vpn-instance-name } paths [ as-regular-expression ]
View
Default Level
1: Monitor level
as-regular-expression: Regular expression for filtering the AS path information to be displayed.
Use the display bgp vpnv4 paths command to display the BGP VPNv4 AS path information.
# Display the BGP VPNv4 AS path information of VPN instance vpn1.
<Sysname> display bgp vpnv4 vpn-instance vpn1 paths
    Address       Hash    Refcount  MED         Path/Origin
    0x6E72D18     0       1           0           200?
    0x6E72E50     0       1           0           i
    0x6E72B78     1       1           0           ?
    0x6E72BE0     1       2           0           ?
# Display all BGP VPNv4 AS path information.
<Sysname> display bgp vpnv4 all paths
    0x6E72D80     4       1           0           200?
    0x6E72CB0     15      2           0           ?
Table 1-4 Description on the fields of the display bgp vpnv4 paths command
Address
Routing address in the local database
Hash
Hash bucket for storing routes
Refcount
Number of times that the path is referenced
MED
Metric for routes
Path/Origin
AS_PATH and origin attributes of the route, see Table 1-1.
display bgp vpnv4 { all | vpn-instance vpn-instance-name } peer [ group-name log-info | ip-address { log-info | verbose } | verbose ]
View
Default Level
1: Monitor level
group-name: Name of the peer group.
log-info: Displays log information.
ip-address: IP address of the peer.
verbose: Displays detailed information.
Use the display bgp vpnv4 peer command to display information about BGP VPNv4 peers.
# Display information about BGP VPNv4 peers of VPN instance vpn1.
<Sysname> display bgp vpnv4 vpn-instance vpn1 peer
 BGP local router ID : 2.2.2.2
 Local AS number : 100
 Total number of peers : 1                 Peers in established state : 1
 10.1.1.1    4   200    24       29       0       1      00:18:47 Established
Table 1-5 Description on the fields of display bgp vpnv4 vpn-instance peer
BGP Local router ID
local AS number
Local AS number
Number of peers in the state of established
Peer
V
AS
MsgRcvd
MsgSent
OutQ
PrefRcv
Number of received prefixes
Up/Down
Status of the peer
# Display detailed information about BGP VPNv4 peers of VPN instance vpn1.
<Sysname> display bgp vpnv4 vpn-instance vpn1 peer verbose
         Peer: 10.1.1.1  Local: 2.2.2.2
         Type: EBGP link
         BGP version 4, remote router ID 10.1.1.1
         BGP current state: Established, Up for 00h19m26s
         BGP last state: OpenConfirm
         Port:  Local - 179      Remote - 1025
         Configured: Active Hold Time: 180 sec   Keepalive Time:60 sec
         Received  : Active Hold Time: 180 sec
         Negotiated: Active Hold Time: 180 sec   Keepalive Time:60 sec
         Peer optional capabilities:
         Peer support bgp multi-protocol extended
         Peer support bgp route refresh capability
         Address family IPv4 Unicast: advertised and received
 Received: Total 25 messages, Update messages 1
 Sent: Total 30 messages, Update messages 4
 Threshold: 75%
 Optional capabilities:
 Routing policy configured:
Table 1-6 Description on the fields of the display bgp vpnv4 peer verbose command
Peer
Local
IP address of the local device
BGP type
BGP version
remote router ID
Router ID of the remote device
BGP current state
Current status of the BGP session
Up for
Duration since the peer is established
BGP current event
Current event of the BGP session
BGP last state
State that the BGP session was in before transitioning to the current status
Port
Local and remote ports of the BGP session
Configured
Settings of the local timers, including the active hold interval and keepalive interval
Received
Received active hold interval
Negotiated
Negotiated active hold interval
Optional capabilities of the peer
The peer supports multiprotocol extension.
The peer supports route refresh capability.
IPv4 unicast family capability
Received
Total number of received messages and the number of received update messages
Sent
Total number of sent messages and the number of sent update messages
Threshold
Threshold value
Local optional capabilities
Whether the route refresh capability is supported
# Display all BGP VPNv4 peer information.
<Sysname> display bgp vpnv4 all peer
  1.1.1.1  4  100   51       64        0     2      00:45:16  Established
Table 1-7 Description on the fields of the display bgp vpnv4 all peer command
Peer
V
AS
AS number
MsgRcvd
MsgSent
OutQ
Up/Down
Status of the peer
# Display detailed information about BGP VPNv4 peer 1.1.1.1.
<Sysname> display bgp vpnv4 all peer 1.1.1.1 verbose
         Peer: 1.1.1.1   Local: 2.2.2.2
         Type: IBGP link
         BGP version 4, remote router ID 1.1.1.1
         BGP current state: Established, Up for 00h46m01s
         BGP current event: RecvKeepalive
         Port:  Local - 1039     Remote - 179
         Address family VPNv4: advertised and received
 Received: Total 52 messages, Update messages 2
 Sent: Total 65 messages, Update messages 5
 Threshold: 75%
 Minimum time between advertisement runs is 15 seconds
 Connect-interface has been configured
 Peer Preferred Value: 0
Table 1-8 Description on the fields of display bgp vpnv4 all peer verbose
Peer
Local
BGP type
BGP version
remote router ID
BGP current state
Up for
BGP current event
 Current event of the peer
BGP last state
Port
Local and remote BGP port numbers
Configured
Received
Negotiated
IPv4 address group VPNv4 capability
Received
Counts of received messages
Sent
Counts of sent messages
Threshold
Threshold value
Connect-interface
Whether a source interface is configured for route update messages
Weight configured for routes from the peer
display bgp vpnv4 route-distinguisher route-distinguisher routing-table [ network-address [ { mask | mask-length } [ longer-prefixes ] ] | as-path-acl as-path-acl-number | cidr | community [ aa:nn ]&<1-13> [ no-export-subconfed | no-advertise | no-export ] * [ whole-match ] | community-list { basic-community-list-number [ whole-match ] | adv-community-list-number }&<1-16> | different-origin-as | regular-expression as-regular-expression ]
View
Default Level
1: Monitor level
route-distinguisher: Route distinguisher (RD).
mask-length: Length of the network mask, in the range 0 to 32.
mask-address: Network mask, in the format of X.X.X.X.
longer-prefixes: Matches the longest prefix.
as-path-acl as-path-acl-number: Filters routing information using the specified AS_PATH list. The as-path-acl-number argument ranges from 1 to 256.
cidr: Displays classless interdomain routing (CIDR) information.
aa:nn&<1-13>: Community number. Both the aa and nn parameters range from 0 to 65535. &<1-13> means that you can enter the parameter combination up to 13 times.
whole-match: Performs exact matching.
community-list: Displays routing information of the specified BGP community list.
regular-expression as-regular-expression: Displays routing information matching the specified AS regular expression.
Use the display bgp vpnv4 route-distinguisher routing-table command to display the BGP VPNv4 routing information of a specified RD.
Related commands: route-distinguisher.
# Display the BGP VPNv4 routing information of RD 100:1.
<Sysname> display bgp vpnv4 route-distinguisher 100:1 routing-table
Table 1-9 Fields of display bgp vpnv4 route-distinguisher routing-table
Network
Network address
NextHop
Label(recv/app)
Incoming/outgoing label
MED
LocPrf
Local preference
# Display the BGP VPNv4 routing information of RD 100:1, with the network segment address being 10.0.0.0.
<Sysname> display bgp vpnv4 route-distinguisher 100:1 routing-table 10.0.0.0 255.0.0.0
 Total number of routes: 1
Table 1-10 Fields of the above output
Route Distinguisher
RD
BGP Local router ID
Status codes
> - best: Best route
Origin
Network
Network address in the BGP routing table
NextHop
Label(recv/app)
MED
LocPrf
Local preference
Total Number of Routes
display bgp vpnv4 { all | vpn-instance vpn-instance-name } routing-table label
View
Default Level
1: Monitor level
Use the display bgp vpnv4 routing-table label command to display information about labeled routes in the BGP routing table.
# Display information about labeled routes in the BGP routing table.
<Sysname> display bgp vpnv4 all routing-table label
 Total number of routes from all PE: 1
        Network           NextHop           In/Out Label
 *>i    123.1.1.1         1.1.1.1           NULL/1024
 Total routes of vpn-instance vpn1: 4
 *>     10.1.1.0          0.0.0.0           1025/NULL
 *>     20.0.0.0          0.0.0.0           1026/NULL
 *>     124.1.1.1         0.0.0.0           1024/NULL
Table 1-11 Description on the fields of display bgp vpnv4 routing-table label
Total number of routes from all PEs
BGP Local router ID
Status
> - best: Best route
Origin
Route Distinguisher
RD
Network
Network address
NextHop
In/Out Label
Incoming/outgoing label. exp-null indicates an explicit null label.
Total number of routes from the specified VPN instance
display bgp vpnv4 vpn-instance vpn-instance-name routing-table [ network-address [ { mask | mask-length } [ longer-prefixes ] ] | as-path-acl as-path-acl-number | cidr | community [ aa:nn ]&<1-13>[ no-export-subconfed | no-advertise | no-export ]* [ whole-match ] | community-list { basic-community-list-number [ whole-match ] | adv-community-list-number }&<1-16> | dampened | dampening parameter | different-origin-as | flap-info [ as-path-acl as-path-acl-number | network-address [ mask [ longer-match ] | mask-length [ longer-match ] ] | regular-expression as-regular-expression ] | peer ip-address { advertised-routes | received-routes } | regular-expression as-regular-expression | statistic ]
View
Default Level
1: Monitor level
mask: Network mask, in the format of X.X.X.X.
basic-community-list-number: Basic community list number.
adv-community-list-number: Advanced community list number.
dampened: Displays information about dampened BGP VPNv4 routes.
dampening parameter: Displays information about configured BGP VPNv4 route dampening parameters.
flap-info: Displays BGP VPNv4 route flap statistics.
longer-match: Displays flap statistics for routes with masks longer than that specified by the network-address { mask | mask-length } combination.
peer ip-address: Specifies a peer by its IP address.
advertised-routes: Displays routing information sent to the specified peer.
received-routes: Displays routing information received from the specified peer.
Use the display bgp vpnv4 vpn-instance routing-table command to display the BGP VPNv4 routing information of a specified VPN instance.
# Display the BGP VPNv4 routing information of VPN instance vpn1.
<Sysname> display bgp vpnv4 vpn-instance vpn1 routing-table
 Total Number of Routes: 5
 Network            NextHop         MED        LocPrf   PrefVal Path/Ogn
 *>i 10.0.0.0      1.1.1.1         0          100        0       i
 *>  10.1.1.0/24   0.0.0.0         0                     0       ?
 *>  20.0.0.0      10.1.1.1        0                     99      200?
 *>i 123.1.1.1/32  1.1.1.1         0          100        0       ?
 *>  124.1.1.1/32  0.0.0.0         0                     0       ?
Table 1-12 Fields of display bgp vpnv4 vpn-instance routing-table
BGP Local router ID
ID of the BGP-enabled local router
Status codes
> - best: Best route
Origin
Network
NextHop
MED
LocPrf
Local preference
PrefVal
Preferred value of the protocol
Path/Ogn
AS_PATH attribute/route origin of the route.
View
Default Level
1: Monitor level
None
Use the display fib statistics vpn-instance command to display statistics about the VPN instance forwarding table.
# Display statistics about the VPN instance forwarding table.
<Sysname> display fib statistics vpn-instance
Route Entry Count             : 10
Table 1-13 Description on the fields of display fib statistics vpn-instance
Route Entry Count
Total route number of all created VPN instances
display fib vpn-instance vpn-instance-name [ include text ]
View
Default Level
1: Monitor level
include text: Displays only information that includes the specified string.
Use the display fib vpn-instance command to display information about the forwarding information base (FIB) of a VPN instance.
# Display information about the FIB of VPN instance vpn1.
<Sysname> display fib vpn-instance vpn1
FIB Table For vpn1:
 Total number of Routes : 2
Destination/Mask    OutInterface                  InnerLabel     Token
66.1.1.1/32         InLoopBack0                   NULL           invalid
66.1.1.0/24         Vlan-interface 12             NULL           invalid
Table 1-14 Description on the fields of the display fib vpn-instance command
FIB Table For vpn1
FIB information about VPN instance vpn1
Destination/Mask
Forwarding destination address and mask of the VPN instance
OutInterface
Outbound interface of the VPN instance
InnerLabel
Inner label
Token
Token
display ip vpn-instance [ instance-name vpn-instance-name ]
View
Default Level
1: Monitor level
Use the display ip vpn-instance command to display information about a VPN instance or all VPN instances.
If you do not specify any parameter, the command displays brief information about all VPN instances.
# Display information about VPN instance vpn1.
<Sysname> display ip vpn-instance instance-name vpn1
  VPN-Instance Name and ID : vpn1, 1
  Create time : 2006/04/08 13:01:30
  Up time : 0 days, 00 hours, 11 minutes and 42 seconds
  Route Distinguisher : 22:1
  Export VPN Targets :  3:3 5:5
  Import VPN Targets :  4:4 5:5
  Import Route Policy : poly-1
  Description : This is vpn1
  Maximum number of Routes : 500
  Interfaces :  vlan-interface12
Table 1-15 Description on the fields of display ip vpn-instance instance-name
Name and ID of the VPN instance
CreateTime
Time when the VPN instance was created
Up time
Duration of the VPN instance
Route Distinguisher
RD of the VPN instance
Export VPN Targets
Export target attribute of the VPN instance
Import VPN Targets
Import target attribute of the VPN instance
Import Route Policy
Import routing policy of the VPN instance
Description of the VPN instance
Maximum number of routes of the VPN instance
Interfaces
Interface to which the VPN instance is bound
display ospf [ process-id ] sham-link [ area area-id ]
View
Default Level
1: Monitor level
process-id: OSPF process ID.
area-id: OSPF area ID. It can be an integer or in the format of an IPv4 address.
Use the display ospf sham-link command to display information about sham links.
With neither process ID nor area ID specified, the command displays information about all configured sham links.
Related commands: sham-link.
# Display information about all OSPF sham links.
<Sysname> display ospf sham-link
           OSPF Process 100 with Router ID 100.1.1.2
 Sham Link:
 Area        NeighborId     Source-IP     Destination-IP  State Cost
 0.0.0.1     100.1.1.2    3.3.3.3       5.5.5.5         P-2-P 10
Table 1-16 Description on the fields of the display ospf sham-link command
Area
OSPF area to which the sham link belongs
NeighborId
Router ID of the sham link
Source-IP
Source IP address of the sham link
Destination-IP
Destination IP address of the sham link
Status of the sham link interface
Cost
Cost of the sham link
# Display information about OSPF sham links in area 1.
<Sysname> display ospf sham-link area 1
  Sham-Link: 3.3.3.3 --> 5.5.5.5
  Neighbour State: Full
  Area: 0.0.0.1
  Cost: 10  State: P-2-P, Type: Sham
  Timers: Hello 10 , Dead 40 , Retransmit 5 , Transmit Delay 1
Table 1-17 Description on the fields of the display ospf sham-link area command
Sham-Link
Sham link expressed in the format of source IP address to destination IP address
Neighbour State
Status of the sham link neighbor
Area
Cost
Type of the sham link
Timers
Timers of the sham link
display tunnel-policy { all | policy-name tunnel-policy-name }
View
Default Level
1: Monitor level
all: Specifies all tunneling policies.
tunnel-policy-name: Name of a tunneling policy.
Use the display tunnel-policy command to display information about a tunneling policy or all tunneling policies.
Related commands: tunnel-policy, tunnel select-seq load-balance-number.
# Display all tunneling policies.
<Sysname> display tunnel-policy all
Tunnel Policy Name   Select-Seq       Load balance No
t                    LSP              1
aaa                  LSP CR-LSP       1
bbb                  LSP              1
# Display tunneling policy aaa.
<Sysname> display tunnel-policy policy-name aaa
aaa                  LSP CR-LSP       1
Table 1-18 Description on the fields of the display tunnel-policy command
Tunnel Policy Name
Name of the tunneling policy
Select-Seq
preference order for tunnel selection
Load balance No
Number of tunnels for load balancing
1.1.19  domain-id
undo domain-id [ domain-id ]
View
OSPF view
Default Level
2: System level
domain-id: OSPF domain ID, in integer or dotted decimal notation.
secondary: Uses the domain ID as secondary. With this keyword not specified, the domain ID configured is primary.
Use the domain-id command to configure an OSPF domain ID.
Use the undo domain-id command to restore the default.
By default, the OSPF domain ID is 0.
With no parameter specified, the undo domain-id command deletes all domain IDs.
Usually, routes injected from PEs are advertised as External-LSAs. However, routes to different destinations in the same OSPF domain must be advertised as Type-3 LSAs. Therefore, using the same domain ID for an OSPF domain is required.
# Configure the OSPF domain ID.
[Sysname] ospf 100
[Sysname-ospf-100] domain-id 234
undo export route-policy
View
VPN instance view
Default Level
2: System level
route-policy: Name of the export routing policy for the VPN instance.
Use the export route-policy command to apply an export routing policy to a VPN instance.
Use the undo export route-policy command to remove the application.
You can configure an export routing policy when a finer control on the VPN instance routes to be redistributed is required, that is, when the control provided by the extended community attribute is not enough. An export routing policy may deny routes that are permitted by the export target attribute.
By default, all VPN instance routes permitted by the export target attribute can be redistributed.
# Apply export routing policy poly-1 to VPN instance vpn1.
[Sysname-vpn-instance-vpn1] export route-policy poly-1
filter-policy { acl-number | ip-prefix ip-prefix-name } export [ direct | isis process-id | ospf process-id | rip process-id | static ]
undo filter-policy export [ direct | isis process-id | ospf process-id | rip process-id | static ]
View
Default Level
2: System level
acl-number: IP ACL number.
ip-prefix-name: IP address prefix list name.
direct: Filters direct routes to be advertised.
isis process-id: Filters ISIS routes to be advertised that are from a specified ISIS process.
ospf process-id: Filters OSPF routes to be advertised that are from a specified OSPF process..
rip process-id: Filters RIP routes to be advertised that are from a specified RIP process.
static: Filters static routes to be advertised.
Use the filter-policy export command to specify to filter all or certain types of routes to be advertised.
Use the undo filter-policy export command to remove the configuration.
If you specify no routing protocol parameters for the filter-policy export command, all routes to be advertised will be filtered.
By default, MP-BGP does not filter routes to be advertised.
Only routes that survive the filtering are advertised by MP-BGP.
# In BGP-VPNv4 subaddress family view, specify to filter routes to be advertised by MP-BGP using ACL 2555.
[Sysname] bgp 100
[Sysname-bgp-af-vpnv4] filter-policy 2555 export
filter-policy { acl-number | ip-prefix ip-prefix-name } import
undo filter-policy import
View
Default Level
2: System level
Use the filter-policy import command to specify to filter received routes.
Use the undo filter-policy import command to remove the configuration.
By default, received routes are not filtered.
Only routes that survive the filtering are added into the BGP routing table.
# In BGP-VPNv4 subaddress family view, specify to use ACL 2255 to filter received routes.
[Sysname] bgp 100
[Sysname-bgp-af-vpnv4] filter-policy 2255 import
undo import route-policy
View
VPN instance view
Default Level
2: System level
route-policy: Name of the import routing policy for the VPN instance.
Use the import route-policy command to apply an import routing policy to a VPN instance.
Use the undo import route-policy command to remove the application.
You can configure an import routing policy when a finer control on the routes to be redistributed into a VPN instance is required, that is, when the control provided by the extended community attributes is not enough. An import routing policy may deny routes that are permitted by the import target attribute.
By default, all routes permitted by the import target attribute can be redistributed into the VPN instance.
# Apply import routing policy poly-1 to VPN instance vpn1.
[Sysname-vpn-instance-vpn1] import route-policy poly-1
undo ip binding vpn-instance vpn-instance-name
View
Interface view
Default Level
2: System level
vpn-instance-name: Name of the VPN instance to be associated.
Use the ip binding vpn-instance command to associate an interface with a VPN instance.
Use the undo ip binding vpn-instance command to remove the association.
By default, an interface is associated with no VPN instance; it belongs to the public network.
When configured on an interface, the ip binding vpn-instance command clears the IP address of the interface. Therefore, you must re-configure the IP address of the interface after configuring the command.
# Associate interface VLAN-interface 12 with VPN instance vpn1.
[Sysname] interface vlan-interface 12
[Sysname-Vlan-interface12] ip binding vpn-instance vpn1
View
Default Level
2: System level
vpn-instance-name: Name for the VPN instance.
Use the ip vpn-instance command to create a VPN instance and enter VPN instance view.
Use the undo ip vpn-instance command to delete a VPN instance.
A VPN instance takes effect only after you configure an RD for it.
# Create a VPN instance named vpn1.
1.1.26  ipv4-family
ipv4-family { vpnv4 | vpn-instance vpn-instance-name }
undo ipv4-family { vpnv4 | vpn-instance vpn-instance-name }
View
BGP view
Default Level
2: System level
vpnv4: Enters BGP-VPNv4 subaddress family view.
vpn-instance vpn-instance-name: Associates a VPN instance with an IPv4 address family and enter BGP VPN instance view.
Use the ipv4-family command to enter BGP-VPNv4 subaddress family view or BGP VPN instance view.
Use the undo ipv4-family command to remove all configurations performed in either of the two views.
Before entering BGP VPN instance view, you must create the VPN instance.
# Enter BGP-VPNv4 subaddress family view.
[Sysname] bgp 100
# Associate VPN instance vpn1 with an IPv4 address family and enter BGP VPN instance view.
[Sysname] bgp 100
[Sysname-bgp] ipv4-family vpn-instance vpn1
[Sysname-bgp-vpn1]
peer { group-name | ip-address } advertise-community
undo peer { group-name | ip-address } advertise-community
View
Default Level
2: System level
Use the peer advertise-community command to specify to advertise community attributes to a peer or peer group.
Use the undo peer advertise-community command to remove the configuration.
By default, no community attributes are advertised to any peer or peer group.
# In BGP-VPNv4 subaddress family view, specify to advertise community attributes to peer 3.3.3.3.
[Sysname] bgp 100
[Sysname-bgp-af-vpnv4] peer 3.3.3.3 advertise-community
peer { group-name | ip-address } allow-as-loop [ number ]
undo peer { group-name | ip-address } allow-as-loop
View
BGP-VPNv4 subaddress family view/BGP-L2VPN address family view/VPLS address family view
Default Level
2: System level
number: Maximum number that the local AS number can appear repeatedly in the AS-PATH attribute. It ranges from 1 to 10 and defaults to 1.
Use the peer allow-as-loop command to allow the local AS number to appear in the AS-PATH attribute of a received route and to set the allowed maximum number of repetitions.
Use the undo peer allow-as-loop command to remove the configuration.
# In BGP-VPNv4 subaddress family view, allow the local AS number to appear repeatedly in the AS-PATH attribute of a route received from peer 1.1.1.1 for up to twice.
[Sysname] bgp 100
[Sysname-bgp-af-vpnv4] peer 1.1.1.1 allow-as-loop 2
# In BGP-L2VPN address family view, allow the local AS number to appear repeatedly in the AS-PATH attribute of a route received from peer 1.1.1.1 for up to twice.
[Sysname] bgp 100
[Sysname-bgp] l2vpn-family
[Sysname-bgp-af-l2vpn] peer 1.1.1.1 allow-as-loop 2
# In VPLS address family view, allow the local AS number to appear repeatedly in the AS-PATH attribute of a route received from peer 1.1.1.1 for up to twice.
[Sysname] bgp 100
[Sysname] vpls-family
[Sysname-bgp-af-vpls] peer 1.1.1.1 allow-as-loop 2
peer { ip-address | group-name } as-path-acl aspath-filter-number { import | export }
undo peer { ip-address | group-name } as-path-acl aspath-filter-number { import | export }
View
Default Level
2: System level
aspath-filter-number: AS_PATH filtering list number.
import: Filters the received routes.
export: Filters the routes to be advertised.
Use the peer as-path-acl command to specify to filter routes received from or to be advertised to a specified peer or peer group based on an AS_PATH list.
Use the undo peer as-path-acl command to remove the configuration.
By default, no AS filtering list is applied to a peer or peer group.
# In BGP-VPNv4 subaddress family view, apply AS filtering list 3 to routes advertised by peer group test.
[Sysname] bgp 100
[Sysname-bgp-af-vpnv4] peer test as-path-acl 3 export
peer { group-name | ip-address } default-route-advertise vpn-instance vpn-instance-name
undo peer { group-name | ip-address } default-route-advertise vpn-instance vpn-instance-name
View
Default Level
2: System level
Use the peer default-route-advertise vpn-instance command to specify to advertise all default routes of a VPN instance to a peer or peer group.
Use the undo peer default-route-advertise vpn-instance command to remove the configuration.
By default, no default route is advertised to a peer or peer group.
Related commands: peer upe.
# In BGP-VPNv4 subaddress family view, specify to advertise default routes of VPN instance vpn1 to peer 1.1.1.1.
[Sysname] bgp 100
[Sysname-bgp-af-vpnv4] peer 1.1.1.1 enable
[Sysname-bgp-af-vpnv4] peer 1.1.1.1 upe
[Sysname-bgp-af-vpnv4] peer 1.1.1.1 default-route-advertise vpn-instance vpn1
1.1.31  peer enable
peer { ip-address | group-name } enable
undo peer { ip-address | group-name } enable
View
Default Level
2: System level
Use the peer enable command to enable a peer or peer group for an address family and enable the exchange of BGP routing information of the address family.
Use the undo peer enable command to disable the capability.
By default, only IPv4 routing information is exchanged between BGP peers/peer groups.
# Configure peer 1.1.1.1 and enable the peer for the BGP-VPNv4 subaddress family.
[Sysname] bgp 100
[Sysname-bgp] peer 1.1.1.1 as-number 100
# Configure peer 1.1.1.1 and enable the peer for the BGP-L2VPN address family.
[Sysname] bgp 100
[Sysname-bgp-af-l2vpn] peer 1.1.1.1 enable
# Configure peer 1.1.1.1 and enable the peer for the VPLS address family.
[Sysname] bgp 100
[Sysname-bgp-af-vpls] peer 1.1.1.1 enable
peer { ip-address | group-name } filter-policy acl-number { import | export }
undo peer { ip-address | group-name } filter-policy acl-number { import | export }
View
Default Level
2: System level
acl-number: ACL number.
Use the peer filter-policy command to apply a filtering policy to a peer or peer group .
Use the undo peer filter-policy command to remove the configuration.
By default, no filtering policy is applied to a peer or peer group.
Related commands: peer as-path-acl.
# Apply a filtering policy to filter the received routes of a peer group.
[Sysname] bgp 100
[Sysname-bgp-af-vpnv4] peer test filter-policy 2003 import
1.1.33  peer group
peer ip-address group group-name
undo peer ip-address group group-name
View
Default Level
2: System level
Use the peer group command to add a peer into an existing peer group.
Use the undo peer group command to remove a peer from a peer group.
# In BGP-VPNv4 subaddress family view, add peer 1.1.1.1 into peer group test.
[Sysname] bgp 100
[Sysname-bgp] group test external
[Sysname-bgp-af-vpnv4] peer 1.1.1.1 group test
# In BGP-L2VPN address family view, add peer 1.1.1.1 into peer group test.
[Sysname] bgp 100
[Sysname-bgp-af-l2vpn] peer 1.1.1.1 group test
# In VPLS address family view, add peer 1.1.1.1 into peer group test.
[Sysname] bgp 100
[Sysname-bgp-af-vpls] peer 1.1.1.1 group test
peer { ip-address | group-name } ip-prefix prefix-name { import | export }
undo peer { ip-address | group-name } ip-prefix prefix-name { import | export }
View
Default Level
2: System level
prefix-name: Name of the IP prefix list.
Use the peer ip-prefix command to apply a route filtering policy based on IP prefix list to a peer or peer group.
Use the undo peer ip-prefix command to remove the configuration.
By default, no route filtering policy based on IP prefix list is applied to a peer or peer group.
# In BGP-VPNv4 subaddress family view, specify to filter the received routes of a peer group using IP prefix list list1.
[Sysname] bgp 100
[Sysname-bgp-af-vpnv4] peer group1 ip-prefix list1 import
peer { ip-address | group-name } label-route-capability
undo peer { ip-address | group-name } label-route-capability
View
Default Level
2: System level
Use the peer label-route-capability command to enable the exchange of labeled routes with an IPv4 peer or peer group.
Use the undo peer label-route-capability command to disable the capability.
By default, the device does not advertise labeled routes to an IPv4 peer.
According to the networking scheme, the peer label-route-capability command enables the exchange of labeled IPv4 routes with:
l           ASBR PEs in the same AS.
l           PEs in the same AS.
l           the peer ASBR PE.
# Specify to exchange labeled IPv4 routes with peer 2.2.2.2.
[Sysname] bgp 100
[Sysname-bgp] peer 2.2.2.2 label-route-capability
peer { ip-address | group-name } next-hop-invariable
undo peer { ip-address | group-name } next-hop-invariable
View
Default Level
2: System level
Use the peer next-hop-invariable command to configure the device not to change the next hop of a route when advertising it to an EBGP peer.
Use the undo peer next-hop-invariable command to restore the default.
By default, a device uses its address as the next hop when advertising a route to its EBGP peer.
Related commands: refer to BGP Commands.
# In BGP-VPNv4 subaddress family view, configure the device not to change the next hop of a route when advertising it to EBGP peer 1.1.1.1.
[Sysname] bgp 100
[Sysname-bgp-af-vpnv4] peer 1.1.1.1 next-hop-invariable
peer { group-name | ip-address } next-hop-local
undo peer { group-name | ip-address } next-hop-local
View
Default Level
2: System level
Use the peer next-hop-local command to configure the device to use the local address as the next hop of a route when advertising it to a peer or peer group.
Use the undo peer next-hop-local command to remove the configuration.
# In BGP-VPNv4 subaddress family view, configure the device to use the local address as the next hop of a route when advertising it to peer group test.
[Sysname] bgp 100
[Sysname-bgp-af-vpnv4] peer test next-hop-local
# In BGP-L2VPN address family view, configure the device to use the local address as the next hop of a route when advertising it to peer group test.
[Sysname] bgp 100
[Sysname-bgp-af-l2vpn] peer test next-hop-local
# In VPLS address family view, configure the device to use the local address as the next hop of a route when advertising it to peer group test.
[Sysname] bgp 100
[Sysname-bgp-af-vpls] peer test next-hop-local
peer { group-name | ip-address } public-as-only
undo peer { group-name | ip-address } public-as-only
View
Default Level
2: System level
Use the peer public-as-only command to make outbound BGP updates carry no private AS numbers.
Use the undo peer public-as-only command to make outbound BGP updates carry private AS numbers.
By default, a BGP update carries private AS numbers.
If a BGP update to be sent carries any public AS number, this command does not take effect. The private AS number ranges from 64512 to 65535.
# In BGP-VPNv4 subaddress family view, configure the device to make BGP updates to be sent to peer group test carry no private AS numbers.
[Sysname] bgp 100
[Sysname-bgp-af-vpnv4] peer test public-as-only
peer { group-name | ip-address } reflect-client
undo peer { group-name | ip-address } reflect-client
View
Default Level
2: System level
Use the peer reflect-client command to configure the local device to be a route reflector (RR) and set a peer or peer group as the client of the RR.
Use the undo peer reflect-client command to remove the configuration.
By default, no RR or RR client is configured.
# In BGP-VPNv4 subaddress family view, configure the local device to be an RR and set peer group test as the client of the RR.
[Sysname] bgp 100
[Sysname-bgp-af-vpnv4] peer test reflect-client
# In BGP-L2VPN address family view, configure the local device to be an RR and set peer group test as the client of the RR.
[Sysname] bgp 100
[Sysname-bgp-af-l2vpn] peer test reflect-client
# In VPLS address family view, configure the local device to be an RR and set peer group test as the client of the RR.
[Sysname] bgp 100
[Sysname-bgp-af-vpls] peer test reflect-client
peer { ip-address | group-name } route-policy route-policy-name { import | export }
undo peer { ip-address | group-name } route-policy route-policy-name { import | export }
View
Default Level
2: System level
route-policy-name: Name of the routing policy.
Use the peer route-policy command to apply a routing policy to a peer or peer group.
Use the undo peer route-policy command to remove the application.
By default, no routing policy is applied to a peer or peer group.
# In BGP-VPNv4 subaddress family view, apply routing policy test-policy to peer group test to filter the received routes.
[Sysname] bgp 100
[Sysname-bgp-af-vpnv4] peer test route-policy test-policy import
1.1.41  peer upe
peer { ip-address | group-name } upe
undo peer { ip-address | group-name } upe
View
Default Level
2: System level
Use the peer upe command to configure a BGP peer or peer group as an HoVPN UPE for a BGP-VPNv4 subaddress family.
Use the undo peer upe command to remove the configuration.
UPE is a kind of special VPNv4 peer. It accepts only one default route for each related VPN instance on an SPE, rather than common VPNv4 routes. An SPE is a common VPN peer.
# Configure peer 1.1.1.1 as a UPE.
[Sysname] bgp 100
policy vpn-target
undo policy vpn-target
View
Default Level
2: System level
None
Use the policy vpn-target command to enable VPN target filtering for received VPNv4 routes.
Use the undo policy vpn-target command to disable the filtering, permitting all VPNv4 routes.
Only VPNv4 routes with export route target attributes matching the local import route target attributes are added into the routing table.
By default, the VPN target filtering function is enabled for received VPNv4 routes.
&  Note:
The command applies to inter-provider VPN option B schemes.
# In BGP-VPNv4 subaddress family view, enable VPN target filtering for received VPNv4 routes.
[Sysname] bgp 100
[Sysname-bgp-af-vpnv4] policy vpn-target
# In BGP-L2VPN address family view, enable VPN target filtering for received VPNv4 routes.
[Sysname] bgp 100
[Sysname-bgp-af-l2vpn] policy vpn-target
# In VPLS address family view, enable VPN target filtering for received VPNv4 routes.
[Sysname] bgp 100
[Sysname-bgp-af-vpls] policy vpn-target
undo reflect between-clients
View
Default Level
2: System level
None
Use the reflect between-clients command to enable route reflection between clients.
Use the undo reflect between-clients command to disable the function.
By default, route reflection between clients is enabled.
If fully meshed interconnections exist between the clients, route reflection is not required. Otherwise, an RR is required for routes to be reflected from one client to every other client.
# In BGP-VPNv4 subaddress family view, disable route reflection between clients.
[Sysname] bgp 100
[Sysname-bgp-af-vpnv4] undo reflect between-clients
# In BGP-L2VPN address family view, disable route reflection between clients.
[Sysname] bgp 100
[Sysname-bgp-af-l2vpn] undo reflect between-clients
# In VPLS address family view, disable route reflection between clients.
[Sysname] bgp 100
[Sysname-bgp-af-vpls] undo reflect between-clients
undo reflector cluster-id
View
Default Level
2: System level
cluster-id: Cluster ID of the route reflector (RR).
ip-address: IP address of the peer, which is to be used as the cluster ID of the RR.
Use the reflector cluster-id command to specify a cluster ID for an RR.
Use the undo reflector cluster-id command to remove the cluster ID.
By default, the cluster ID is the router ID of an RR in the cluster.
Generally, a cluster contains only one RR, in which case the router ID of the RR is used for identifying the cluster. Setting multiple RRs can improve the network reliability. When there is more than one RR in a cluster, use the reflector cluster-id command to configure the same cluster ID for all RRs in the cluster.
# In BGP-VPNv4 subaddress family view, configure the local router as an RR of a cluster.
[Sysname] bgp 100
[Sysname-bgp-af-vpnv4] reflector cluster-id 50
# In BGP-L2VPN address family view, configure the local router as an RR of a cluster.
[Sysname] bgp 100
[Sysname-bgp-af-l2vpn] reflector cluster-id 50
# In VPLS address family view, configure the local router as an RR of a cluster.
[Sysname] bgp 100
[Sysname-bgp-af-vpls] reflector cluster-id 50
refresh bgp vpn-instance vpn-instance-name { all | ip-address | group group-name | external } { import | export }
View
Default Level
1: Monitor level
all: Performs a soft reset of all BGP VPN instance connections.
ip-address: Performs a soft reset of the BGP connection with a BGP peer identified by this IP address.
group group-name: Performs a soft reset of the connections with a BGP peer group identified by this name.
external: Performs a soft reset of EBGP sessions.
import: Performs a soft reset in the inbound direction.
export: Performs a soft reset in the outbound direction.
Use the refresh bgp vpn-instance command to perform a soft reset of BGP connections in a VPN instance.
# Perform a soft reset of all BGP connections in VPN instance vpn1 in the inbound direction to make new configurations take effect.
<Sysname> refresh bgp vpn-instance vpn1 all import
refresh bgp vpnv4 { all | ip-address | group group-name | internal | external } { import | export }
View
Default Level
1: Monitor level
all: Performs a soft reset of all BGP VPNv4 connections.
ip-address: Performs a soft reset of the BGP VPNv4 connection with a BGP peer identified by this IP address.
group group-name: Performs a soft reset of the VPNv4 connections with a BGP peer group identified by this name.
internal: Performs a soft reset of IBGP sessions.
Use the refresh bgp vpnv4 command to perform a soft reset of BGP VPNv4 connections.
# Perform a soft reset of all BGP VPNv4 connections in the inbound direction to make new configurations take effect.
<Sysname> refresh bgp vpnv4 all import
reset bgp vpn-instance vpn-instance-name { as-number | ip-address | all | external | group group-name }
View
Default Level
1: Monitor level
as-number: Resets BGP connections with the peers in an AS identified by this number.
ip-address: Resets the connection with a BGP peer identified by this IP address.
group group-name: Resets the connections with a BGP peer group identified by this name.
all: Resets all BGP connections.
external: Resets EBGP sessions.
Use the reset bgp vpn-instance command to reset the BGP connections of a VPN instance.
# Reset all BGP connections of VPN instance vpn1.
<Sysname> reset bgp vpn-instance vpn1 all
reset bgp vpn-instance vpn-instance-name dampening [ network-address [ mask | mask-length ] ]
View
Default Level
1: Monitor level
dampening: Specifies route flap dampening information.
Use the reset bgp vpn-instance dampening command to clear the route flap dampening information of a VPN instance.
# Clear the route flap dampening information of VPN instance vpn1.
<Sysname> reset bgp vpn-instance vpn1 dampening
reset bgp vpn-instance vpn-instance-name ip-address flap-info
reset bgp vpn-instance vpn-instance-name flap-info [ ip-address [ mask | mask-length ] | as-path-acl as-path-acl-number | regexp as-path-regexp ]
View
Default Level
1: Monitor level
ip-address: IP address of the BGP peer.
as-path-acl-number: Number of the AS_PATH list.
as-path-regexp: AS_PATH regular expression.
Use the reset bgp vpn-instance flap-info command to clear the route flap history information about BGP peers of a VPN instance.
# Clear route flap history information about BGP peer 2.2.2.2 of VPN instance vpn1.
<Sysname> reset bgp vpn-instance vpn1 2.2.2.2 flap-info
reset bgp vpnv4 { as-number | ip-address | group group-name | all | internal | external }
View
Default Level
1: Monitor level
as-number: Resets VPNv4 connections with the peers in an AS identified by this number.
ip-address: Resets the VPNv4 connection with a BGP peer identified by this IP address.
group-name: Resets the VPNv4 connections with a BGP peer group identified by this name.
all: Resets all BGP VPNv4 connections.
internal: Resets IBGP sessions of VPNv4 connections.
external: Resets EBGP sessions of VPNv4 connections.
Use the reset bgp vpnv4 command to reset BGP VPNv4 connections.
# Reset all BGP VPNv4 connections to make new configurations take effect.
<Sysname> reset bgp vpnv4 all
View
VPN instance view
Default Level
2: System level
route-distinguisher: Route distinguisher (RD) for the VPN instance, a string of 3 to 21 characters in either of the following two formats:
l           16-bit AS number:32-bit user-defined number. For example, 101:3.
l           32-bit IP address:16-bit user-defined number. For example, 192.168.122.15:1.
Use the route-distinguisher command to configure a route distinguisher (RD) for a VPN instance.
An RD is used to create the routing and forwarding table of a VPN.  By prefixing an RD to an IPv4 prefix, you get a VPN IPv4 prefix unique globally.
&  Note:
l      No RD is configured by default; you must configure an RD for each VPN instance.
l      A VPN instance takes effect only after you configure an RD for it.
l      Once you configure an RD for a VPN, you cannot remove the association.
l      You cannot change an RD directly; you can only delete the VPN instance, and then re-create the VPN instance and re-configure a new RD.
# Configure the RD of VPN instance vpn1.
[Sysname-vpn-instance-vpn1] route-distinguisher 22:1
1.1.52  route-tag
route-tag tag-value
undo route-tag
View
OSPF view
Default Level
2: System level
tag-value: Tag for identifying injected VPN routes.
Use the route-tag command to configure the tag for identifying injected VPN routes.
Use the undo route-tag command to restore the default.
The first two octets of the default tag is always 0xD000, while the last two octets is the AS number of the local BGP. For example, if the local BGP AS number is 100, the default tag is 3489661028 in decimal.
An OSPF instance-related VPN instance on a PE is usually configured with a VPN route tag, which must be included in Type 5/7 LSAs. PEs in the same AS are recommended to have the same route tag. The route tag is local significant and can be configured and take effect on only PEs receiving BGP routes and generating OSPF LSAs; it is not transferred in any BGP extended community attribute. Different OSPF processes can have the same route tag.
Tags configured with different commands have different priorities:
l           A tag configured with the import-route command has the highest priority.
l           A tag configured with the route-tag command has the second highest priority.
l           A tag configured with the default tag command has the lowest priority.
A received Type 5 or Type 7 LSA is neglected in route calculation if its tag is the same as the local one.
&  Note:
A configured route tag takes effect after you issue the reset ospf command.
Related commands: import-route in OSPF Commands.
# Configure the route tag for OSPF process 100 as 100.
[Sysname] ospf 100
[Sysname-ospf-100] route-tag 100
undo routing-table limit
View
VPN instance view
Default Level
2: System level
number: Maximum number of routes for the VPN instance to support.
warn-threshold: Threshold for rejecting new routes. It is expressed in the percentage of the specified maximum number of routes for the VPN instance.
simply-alert: Specifies that when the maximum number of routes exceeds the threshold, the system still accepts routes and generates only a SYSLOG error message.
Use the routing-table limit command to limit the maximum number of routes in a VPN instance, preventing too many routes from being accepted by a PE.
Use he undo routing-table limit command to restore the default.
# Specify that VPN instance vpn1 can receive up to 1000 routes, and can receive new routes after the threshold is exceeded.
[Sysname-vpn-instance-vpn1] routing-table limit 1000 simply-alert
1.1.54  rr-filter
rr-filter extended-community-list-number
undo rr-filter
View
Default Level
2: System level
extended-community-list-number: Number of the extended community list supported by the RR group.
Use the rr-filter command to create an RR reflection policy.
Use the undo rr-filter command to disable the function.
Only IBGP routes whose route target extended community attributes satisfy the matching conditions are reflected. This provides a way to implement load balancing between RRs.
# In BGP-VPNv4 subaddress family view, create an RR group and configure it to automatically filter the incoming VPNv4 route update packets based on the route target extended community attribute.
[Sysname] bgp 100
[Sysname-bgp-af-vpnv4] rr-filter 10
# In BGP-L2VPN address family view, create an RR group and configure it to automatically filter the incoming VPNv4 route update packets based on the route target extended community attribute.
[Sysname] bgp 100
[Sysname-bgp-af-l2vpn] rr-filter 10
# In VPLS address family view, create an RR group and configure it to automatically filter the incoming VPNv4 route update packets based on the route target extended community attribute.
[Sysname] bgp 100
[Sysname-bgp-af-vpls] rr-filter 10
1.1.55  sham-link
sham-link source-ip-address destination-ip-address [ cost cost | dead dead-interval | hello hello-interval | retransmit retrans-interval | trans-delay delay | simple [ cipher | plain ] password1 | { md5 | hmac-md5 } key-id [ cipher | plain ] password2 ] *
undo sham-link source-ip-address destination-ip-address [ cost | dead | hello | retransmit | trans-delay | simple | { md5 | hmac-md5 } key-id ] *
View
OSPF area view
Default Level
2: System level
source-ip-address: Source IP address for the sham link.
destination-ip-address: Destination IP address for the sham link.
cost: Cost for the sham link, one by default.
dead-interval: Dead Interval in seconds, 40 seconds by default. It must be equal to the dead interval of the router on the other end of the virtual link and be at least four times the hello interval.
hello-interval: Interval at which the interface sends Hello packets, 10 seconds by default. It must be equal to the hello interval of the router on the other end of the virtual link.
retrans-interval: Interval at which the interface retransmits LSAs, five seconds by default.
delay: Delay interval before the interface sends an LSA, one second by default.
simple [ cipher | plain ] password1: Uses simple authentication. If you specify neither the cipher nor the plain keyword, the password1 argument is a string of 1 to 8 characters. For the plain mode, the password1 argument is a string of 1 to 8 characters. For the cipher mode, the password1 argument can be either a string of 1 to 8 characters in plain text, or a string of 24 characters in cipher text.
md5: Uses MD5 algorithm for authentication.
hmac-md5: Uses HMAC-MD5 algorithm for authentication.
key-id: Authentication key ID of the interface, in the range 1 to 255. It must be the same as that of the peer.
cipher: Uses cipher text.
plain: Uses plain text.
password2: Password string, case sensitive. If you specify neither the cipher nor the plain keyword, it is a string of 1 to 16 characters in plain text or a string of 24 characters in cipher text. For the plain mode, it is a string of 1 to 16 characters. For the cipher mode, it can be either a string of 1 to 16 characters in plain text, or a string of 24 characters in cipher text.
Use the sham link command to configure a sham link.
Use the undo sham link command with no optional keyword to remove a sham link.
Use the undo sham link command with optional keywords to restore the defaults of the parameters for a sham link.
If two PEs belong to the same AS and a backdoor link is present, a sham link can be established between them.
For plain text authentication, the default authentication key type is plain. For authentication using MD5 algorithm or HMAC-MD5 algorithm, the default authentication key type is cipher.
# Create a sham link with the source address of 1.1.1.1 and the destination address of 2.2.2.2.
[Sysname] ospf
[Sysname-ospf-1] area 0
[Sysname-ospf-1-area-0.0.0.1] sham-link 1.1.1.1 2.2.2.2
1.1.56  tnl-policy (VPN instance view)
tnl-policy tunnel-policy-name
undo tnl-policy
View
VPN instance view
Default Level
2: System level
tunnel-policy-name: Name of the tunneling policy for the VPN instance.
Use the tnl-policy command to associate the current VPN instance with a tunneling policy.
Use the undo tnl-policy command to remove the association.
When selecting tunnels from the VPN tunnel management module, an application can use the tunneling policy as the criterion. With no tunneling policy associated with a VPN instance, the default tunneling policy is used.
Related commands: tunnel select-seq load-balance-number.
# Associate VPN instance vpn2 with tunneling policy po1.
[Sysname] tunnel-policy po1
[Sysname-tunnel-policy-po1] tunnel select-seq lsp load-balance-number 1
[Sysname-tunnel-policy-po1] quit
[Sysname] ip vpn-instance vpn2
[Sysname-vpn-instance-vpn2] route-distinguisher 22:33
[Sysname-vpn-instance-vpn2] tnl-policy po1
1.1.57  tunnel-policy
tunnel-policy tunnel-policy-name
undo tunnel-policy tunnel-policy-name
View
Default Level
2: System level
tunnel-policy-name: Name for the tunneling policy.
Use the tunnel-policy command to establish a tunneling policy and enter tunneling policy view.
Use the undo tunnel-policy command to delete a tunneling policy.
# Establish a tunneling policy named po1 and enter tunneling policy view.
1.1.58  tunnel select-seq load-balance-number
tunnel select-seq { cr-lsp | lsp } * load-balance-number number
undo tunnel select-seq
View
Tunneling policy view
Default Level
2: System level
cr-lsp: Specifies CR-LSP tunnels.
lsp: Specifies LSP tunnels.
number: Number of tunnels for load balancing, one by default.
Use the tunnel select-seq load-balance-number command to configure the preference order for tunnel selection and the number of tunnels for load balancing.
Use the undo tunnel select-seq command to restore the default.
Note that:
l           Only tunnels of the types specified in the tunnel select-seq load-balance-number command can be used.
l           A tunnel type closer to the select-seq keyword has a higher priority.
l           The number of tunnels for load balancing refers to the number of tunnels that an application can use.
By default, one LSP tunnel can be used. That is, only LSP tunnels can be used and the number of tunnels for load balancing is 1.
# Define a tunneling policy, specifying that only CR-LSP tunnels can be used and the number of tunnels for load balancing be 2.
[Sysname-tunnel-policy-po1] tunnel select-seq cr-lsp load-balance-number 2
1.1.59  vpn-instance-capability simple
undo vpn-instance-capability
View
OSPF multi-instance view
Default Level
2: System level
None
Use the vpn-instance-capability simple command to enable multi-VPN-instance CE.
Use the undo vpn-instance-capability command to disable the function.
By default, the function is disabled.
# Enable multi-VPN-instance CE.
[Sysname] ospf 100 vpn-instance vpna
[Sysname-ospf-100] vpn-instance-capability simple
1.1.60  vpn-target (VPN instance view)
vpn-target vpn-target &<1-8> [ both | export-extcommunity | import-extcommunity ]
undo vpn-target { all | { vpn-target &<1-8> [ both | export-extcommunity | import-extcommunity ] }
View
VPN instance view
Default Level
2: System level
vpn-target&<1-8>: Adds the VPN target extended community attribute to the import or export VPN target extended community list and specify the VPN target in the format nn:nn or IP-address:nn. &<1-8> means that you can specify this argument for up to 8 times.
A VPN target attribute can be in either of these two formats:
both: Specifies both the export routing information to the destination VPN extended community and the import routing information from the destination VPN extended community. This is the default.
export-extcommunity: Specifies the export routing information to the destination VPN extended community.
import-extcommunity: Specifies the import routing information from the destination VPN extended community.
all: Specifies all export routing information to the destination VPN extended community and import routing information from the destination VPN extended community.
Use the vpn-target command to associate the current VPN instance with one or more VPN targets.
Use the undo vpn-target command to remove the association of the current VPN instance with VPN targets.
VPN target has no default. You must configure it when creating a VPN instance.
# Associate the current VPN instance with VPN targets.
[Sysname-vpn-instance-vpn1] vpn-target 3:3 export-extcommunity
[Sysname-vpn-instance-vpn1] vpn-target 4:4 import-extcommunity
[Sysname-vpn-instance-vpn1] vpn-target 5:5 both
