H3C S9500 Command Manual-Release2132[V2.03]-05 MPLS VPN Volume
HomeSupportSwitchesS9500 SwitchesReference GuidesCommand ReferencesH3C S9500 Command Manual-Release2132[V2.03]-05 MPLS VPN Volume
03-VPLS Commands
03-VPLS Commands 104.12 KB
Chapter 1  VPLS Configuration Commands
1.1  VPLS Configuration Commands
1.1.1  bandwidth
bandwidth vpn-speed
undo bandwidth
View
VSI view
Default Level
2: System level
vpn-speed: Speed limit of the VPLS instance, in kbps.
Use the bandwidth command to set the speed limit of a VPLS instance.
Use the undo bandwidth command to restore the default.
By default, the speed limit of a VPLS instance is 102400 kbps.
# Set the speed limit of VPLS instance aaa to 10 Mbps.
[Sysname] vsi aaa static
[Sysname-vsi-aaa] bandwidth 10240
1.1.2  broadcast-restrain
broadcast-restrain ratio
undo broadcast-restrain
View
VSI view
Default Level
2: System level
ratio: Broadcast suppression percentage of the VPLS instance, in the range 1 to 100.
Use the broadcast-restrain command to set the broadcast suppression percentage of a VPLS instance.
Use the undo broadcast-restrain command to restore the default.
By default, the broadcast suppression percentage of a VPLS instance is 5.
&  Note:
With this command configured, the broadcast traffic (including broadcast, multicast, and unknown unicast) of the VPLS instance that is over the threshold will be dropped.
# Set the broadcast suppression percentage of VPLS instance aaa to 10.
[Sysname-vsi-aaa] broadcast-restrain 10
1.1.3  description
View
VSI view
Default Level
2: System level
text: Description for the VPLS instance.
Use the description command to set a description for a VPLS instance.
Use the undo description command to remove the configuration.
By default, no description is set for a VPLS instance.
# Set the description of VPLS instance aaa to “Aaa_Technologies_Co._Ltd.”.
[Sysname-vsi-aaa] description Aaa_Technologies_Co._Ltd.
1.1.4  display bgp vpls
display bgp vpls { all | group [ group-name ] | peer [ [ ip-address ] verbose ] | route-distinguisher route-distinguisher [ site-id site-id [ label-offset label-offset ] ] }
View
Default Level
1: Monitor level
all: Specifies all VPLS information in the BGP routing table.
group group-name: Specifies a peer group by its name.
ip-address: IP address of the peer.
verbose: Displays detailed information.
route-distinguisher route-distinguisher: Specifies the route distinguisher (RD) in the format nn:nn or IP_address:nn.
site-id site-id: Specifies the ID of the site in the VPLS instance.
label-offset label-offset: Specifies the label offset.
Use the display bgp vpls command to display the VPLS information in a BGP routing table.
# Display all VPLS information in the BGP routing table.
<Sysname> display bgp vpls all
 BGP Local Router ID : 2.2.2.9 Local AS number : 100
 Origin codes:i – IGP e - EGP ? - incomplete
 BGP.VPLS: 1 destination
 **Route Distinguisher: 100:1
 SITE ID    LB Offset    LB Size    LB Base    Nexthop    LocPref
 1          0            10         131346     3.3.3.9    100
Table 1-1 Description on the fields of the display bgp vpls all command
BGP Local Router ID
Router ID of the local BGP router
Local AS number
Number of the local AS
Origin codes
Route origin codes. Valid values include:
i - IGP (learned from within the AS)
e - EGP (learned through EGP)
? - incomplete (learned in any other way)
BGP.VPLS
Number of BGP VPLS
Route Distinguisher
Route distinguisher (RD)
SITE ID
ID of a site in the VPLS instance
LB Offset
Label offset value
LB Size
Label size
LB Base
Initial label of the label base
Nexthop
IP address of the next hop
LocPref
Local preference
# Display detailed information about VPLS peer 3.3.3.9 in the BGP routing table.
<Sysname> display bgp vpls peer 3.3.3.9 verbose
         Peer: 3.3.3.9   Local: 2.2.2.9
         Type: IBGP link
         BGP version 4, remote router ID 3.3.3.9
         BGP current state: Established, Up for 01h06m42s
         BGP last state: OpenConfirm
         Port:  Local - 1040      Remote - 179
         Configured: Active Hold Time: 180 sec   Keep Alive Time:60 sec
         Received  : Active Hold Time: 180 sec
         Negotiated: Active Hold Time: 180 sec   Keep Alive Time:60 sec
         Peer optional capabilities:
         Peer support bgp multi-protocol extended
         Peer support bgp route refresh capability
         Graceful Restart Capability: received
             Restart Timer Value of Peer: 150 seconds
             Forwarding State preserved by Peer for following Address families:
                 IPv4 Unicast
                 VPLS
         Address family IPv4 Unicast: advertised and received
         Address family VPLS: advertised and received
 Received: Total 26 messages, Update messages 2
 Sent: Total 28 messages, Update messages 2
 Threshold: 75%
 Minimum time between advertisement runs is 15 seconds
 Optional capabilities:
 Connect-interface has been configured
 Peer Preferred Value: 0
 Routing policy configured:
Table 1-2 Description on the fields of the display bgp vpls peer verbose command
Peer
Local
IP address of the local router
BGP type
BGP version 4
BGP version information
remote router ID
IP address of the remote router
BGP current state
Current status of the BGP session
BGP current event
Current event of the BGP session
BGP last state
State that the BGP session was in before transitioning to the current status
Port
Local and remote ports of the BGP session
Configured
Settings of the local timers
Received
Received active hold interval
Negotiated
Negotiated settings of the timers
Optional peer capabilities, including the support for BGP multicast protocol extension and the support for BGP route refreshing
Information about Graceful Restart (GR) capability, including the peer restart timer and the address families for which forwarding state is preserved.
IPv4 unicast address family capability
Address family VPLS
VPLS address family
Received
Counts of received messages, including the total number of received messages and the number of received update messages.
Sent
Counts of sent messages, including the total number of sent messages and the number of sent update messages.
Maximum number of routes allowed
Threshold
Threshold value
Minimum time between advertisement runs is XX seconds
Minimum advertising interval
Optional capabilities. In this example, route refresh capability is enabled and the directly connected interface is configured.
Peer preference value
Routing policy configured for the peer
# Display the VPLS information for RD 100:1 in the BGP routing table.
<Sysname> display bgp vpls route-distinguisher 100:1
 BGP Local Router ID : 2.2.2.9, Local AS Number : 100
 Origin codes:i - IGP, e - EGP, ? - incomplete
 8          0            10         524624     3.3.3.9    100
Table 1-3 Description on the fields of display bgp vpls route-distinguisher
BGP Local Router ID
Local AS Number
Origin codes
BGP.VPLS
Number of BGP VPLS
SITE ID
LB Offset
Label offset value
LB Size
Label size
LB Base
Nexthop
LocPref
Local preference
# Display the VPLS information for a specified RD, CE number, and label offset in the BGP routing table.
<Sysname> display bgp vpls route-distinguisher 100:1 site-id 4 label-offset 0
 BGP Local router ID : 2.2.2.9, local AS number : 100
 *Nexthop : 3.3.3.9    ,  Locpref      : 100
 Metric   : 133        ,  Flag         : 0x85
 LB Base  : 132096     ,  LB NewBase   : 0
 LB Size  : 10         ,  Label Offset : 0
 MTU      : 1500       ,  Encap Type   : Ethernet
 Path Attribute : RefCount : 1, MED 133: , AS Path : 200
Table 1-4 Fields of display bgp vpls route-distinguisher site-id label-offset
BGP Local router ID
local AS number
Origin codes
*Nexthop
IP adddress of the next hop
Locpref
Local preference
Metric
Cost value
Flag
Current status of the label. Possible values are:
0x0001 (BGP_VPLS_LB_NOT_SENTTO_VPLS)
0x0002 (BGP_VPLS_LB_SENTTO_VPLS)
0x0004 (BGP_VPLS_LB_SELECTED)
0x0008 (BGP_VPLS_LB_ASBR_TNLDOWN)
0x0010 (BGP_VPLS_LB_FROM_RR_IBGP)
0x0020 (BGP_VPLS_LB_FROM_RR_EBGP)
0x0040 (BGP_VPLS_LB_FROM_IBGP)
0x0080 (BGP_VPLS_LB_FROM_EBGP)
0x0085 (BGP_VPLS_LB_NOT_SENTTO_VPLS |
BGP_VPLS_LB_SELECTED |
It is always 0x0046 when the VSI is up.
LB Offset
Label offset value
LB Size
Label size
LB Base
LB NewBase
New label base
RefCount
Label reference count
MED
Cost value
AS Path
AS path of the route
MTU
Maximum transmission unit at Layer 2
Encap Type
Encapsulation type
1.1.5  display mac-address vsi
display mac-address vsi [ vsi-name ] [ dynamic ] [ count ]
View
Default Level
1: Monitor level
vsi-name: Name of a VPLS instance.
dynamic: Dynamic MAC forwarding entries.
count: Number of MAC forwarding entries.
Use the display mac-address vsi command to display the MAC address table information of a specified VPLS instance or all VPLS instances.
Related commands: vsi, mac-address.
# Display the MAC address table information of VPLS instances.
<Sysname> display mac-address vsi
MAC ADDR         STATE            VSI ID   PEER IP           AGING TIME
 0000-0000-000a  dynamic          1        Vlan 300          AGING
 0000-0000-0009  dynamic          1        LinkId 1          AGING
--- 2 mac address(es) found  ---
# Display the total number of entries in the MAC address table for VPLS instances.
<Sysname> display mac-address vsi count
Table 1-5 Description on the fields of the display mac-address vsi command
MAC ADDR
MAC address
STATE
Status of the MAC address
VSI ID
ID of the VPLS instance
PEER IP
IP address of the peer in the VPLS instance. For a device on the private network side, it is the ID of the VLAN to which the device belongs. For a device on the public network side, it is the PW ID.
AGING TIME
Whether the MAC address gets aged.
XX mac address(es) found
Total number of MAC addresses in the MAC address table of the VPLS instance
1.1.6  display vpls connection
display vpls connection [ bgp | ldp | vsi vsi-name ] [ block | down | up ] [ verbose ]
View
Default Level
1: Monitor level
bgp: Specifies all Kompella VPLS connections.
ldp: Specifies all Martini VPLS connections.
vsi vsi-name: Specifies a VPLS instance by its name.
block: Specifies VPLS connections that are blocked.
down: Specifies VPLS connections that are down.
up: Specifies VPLS connections that are up.
Use the display vpls connection command to display information about VPLS connections.
Related commands: vsi.
# Display information about VPLS connections of VPLS instance aaa.
<Sysname> display vpls connection vsi aaa
1 total connection,
connection: 1 up, 0 block, 0 down
VSI Name: aaa                           Signaling: ldp
VsiID   VsiType   PeerAddr   InLabel   OutLabel   LinkID   VCState
500     vlan      1.1.1.9    524288    524289       1        up
Table 1-6 Description on the fields of the display vpls connection command
VSI Name
Name of the VPLS instance
Signaling
Type of the PW signaling protocol used by the VPLS instance
VsiID
VsiType
Access type of the VPLS instance
PeerAddr
Address of the peer in the VPLS instance
InLabel
Incoming label of the VPLS instance
OutLabel
Outgoing label of the VPLS instance
LinkID
ID of the PW in the VPLS instance
VCState
Status of the VC
1.1.7  display vpls fib
display vpls fib [ vsi vsi-name [ link link-id ] ] [ verbose ]
View
Default Level
1: Monitor level
link link-id: Specifies ID of the PW in the VPLS instance.
Use the display vpls fib command to display the forwarding information base (FIB) information of a specified VPLS instance or all VPLS instances.
# Display the FIB information of VPLS instance aaa.
<Sysname> display vpls fib vsi aaa
VsiName    LinkId    Inlabel    OutLabel    TnlIdx         NextHop
aaa       1         524288     524289      149946398      60.12.12.1
Table 1-7 Description on the fields of the display vpls fib command
VsiName
LinkId
Inlabel
OutLabel
TnlIdx
Index of the tunnel of the VPLS instance
NextHop
Next hop for forwarding
1.1.8  display vsi
display vsi [ vsi-name ] [ verbose ]
View
Default Level
1: Monitor level
Use the display vsi command to display information about a specified or all VPLS instances.
# Display configuration information about VPLS instance aaa, which uses LDP as the PW signaling protocol.
<Sysname> display vsi aaa
Vsi                         Mem    PW   Mac       Encap     Mtu   Vsi
Name                        Disc   Type Learn     Type      Value State
aaa                         static ldp  unqualify vlan      1500  down
Table 1-8 Description on the fields of the display vsi command
Vsi Name
Mem Disc
Peer discovery mechanism of the VPLS instance
PW Type
Mac Learn
MAC address learning type
Encap Type
Encapsulation type of the VPLS instance
Mtu Value
Vsi State
Status of the VPLS instance
# Display detailed configuration information about VPLS instance aaa, which uses LDP as the PW signaling protocol.
<Sysname> display vsi aaa verbose
***VSI Name               : aaa
    VSI Index              : 0
    VSI Description        : 1
    PW Signaling           : ldp
    Member Discovery Style : static
    PW MAC Learn Style     : unqualify
    Encapsulation Type     : vlan
    IntfIndex              : 4294967295
    MTU                    : 1500
    Bandwidth              : 102400 kbps
    BroadcastRestrain      : 5%
    MacTabLimit            : 128
    MacLearnEnable         : enable
    QoSLevel               : 0
    QoSTable               : 0  0  0  1  1  1  1  2
    VSI State              : down
    VSI ID                 : 100
   *Peer Router ID         : 2.2.2.2
    VC Label               : 524288
    Session                : up
# Display detailed configuration information about VPLS instance bbb, which uses BGP as the PW signaling protocol.
<Sysname> display vsi bbb verbose
***VSI Name                : bbb
    VSI Index              : 1
    PW Signaling           : bgp
    Member Discovery Style : auto
    Encapulation Type      : vlan
    MTU                    : 1500
    MacTabLimit            : 128
    QoSLevel               : 0
    VSI State              : down
    BGP RD                 : 111:1
    SiteID/Range/Offset    : 100/10/0
    Import vpn target      : 111:1
    Export vpn target      : 111:1
        Local Label Block      : 524288/10/0,
Table 1-9 Description on the fields of the display vsi verbose command
VSI Name
VSI Index
Index of the VPLS instance
VSI Description
Description of the VPLS instance
PW Signaling
PW MAC Learn Style
Encapulation Type
IntfIndex
Index of the interface
MTU
Bandwidth
Bandwidth threshold of the VPLS instance
BroadcastRestrain
MacTabLimit
Maximum number of MAC addresses for a VPLS instance
MacLearnEnable
Whether MAC address learning is enable
QoSLevel
QoS level
QoSTable
QoS level mapping table for the VPLS instance
VSI State
VSI ID
Peer Router ID
ID of the peer
VC Label
Label of the VC
Session
Status of the session
BGP RD
BGP router distinguisher
SiteID/Range/Offset
Site ID/site range/CE offset of a site in the VPLS instance
Import vpn target
Incoming routing information from the destination VPN extended community
Export vpn target
Outgoing routing information to the destination VPN extended community
Local Label Block
Local label block
&  Note:
Valid value ranges of the parameters displayed varies by device.
1.1.9  display vsi remote
display vsi remote { bgp | ldp }
View
Default Level
1: Monitor level
bgp: Displays information about remote VPLS connections using the signaling protocol of BGP.
ldp: Displays information about remote VPLS connections using the signaling protocol of LDP.
Use the display vsi remote command to display information about remote VPLS connections using a specified signaling protocol.
# Display information about remote VPLS connections using LDP.
<Sysname> display vsi remote ldp
Vsi         Peer              VC      Group   Vsi          MTU      Vsi
ID          RouterID          Label   ID      Type         Value    Index
500         60.1.1.1          524688  0       vlan         1500     0
Table 1-10 Description on the fields of the display vsi remote command
Vsi ID
Peer Router ID
ID of the peer
VC Label
Label of the VC
Group ID
ID of the group
Vsi Type
MTU Value
Vsi Index
1.1.10  encapsulation
encapsulation { ethernet | vlan }
View
VSI view
Default Level
2: System level
ethernet: Uses the encapsulation type of Ethernet. This type corresponds to the VPLS instance PW encapsulation type of raw.
vlan: Uses the encapsulation type of VLAN. This type corresponds to the VPLS instance PW encapsulation type of tagged.
Use the encapsulation command to specify the encapsulation type of a VPLS instance.
By default, the encapsulation type of a VPLS instance is VLAN, which corresponds to the VPLS instance PW encapsulation type of tagged.
# Set the VPLS instance encapsulation type to Ethernet.
[Sysname-vsi-aaa] pwsignal ldp
[Sysname-vsi-aaa-ldp] vsi-id 500
[Sysname-vsi-aaa-ldp] quit
[Sysname-vsi-aaa] encapsulation ethernet
1.1.11  l2 binding vsi
l2 binding vsi vsi-name [ access-mode { ethernet | vlan } ]
undo l2 binding vsi vsi-name
View
VLAN interface view
Default Level
2: System level
access-mode: Specifies the access mode for the VPLS instance, which can be ethernet or vlan.
Use the l2 binding vsi command to bind a VPLS instance to a VLAN interface.
Use the undo l2 binding vsi command to remove the binding.
By default, the access mode of a VPLS instance is ethernet.
  Caution:
With the l2 binding vsi command configured on a VLAN interface, services bound to the VLAN are considered the internal VPN services of the VPLS instance.
Related commands: vsi, peer.
# Bind VPLS instance aaa to VLAN-interface 100.
[Sysname] vlan 100
[Sysname-vlan100] port Ethernet 3/1/1
[Sysname-vlan100] quit
[Sysname-Vlan-interface100] l2 binding vsi aaa
1.1.12  mac-table limit
mac-table limit mac-limit-num
undo mac-table limit
View
VSI view
Default Level
2: System level
mac-limit-num: Maximum number of MAC addresses in the VPLS instance
Use the mac-table limit command to set the maximum number of MAC addresses in the VPLS instance.
Use the undo mac-table limit command to restore the default setting.
By default, the maximum number of MAC addresses in a VPLS instance is 128.
Once the number of MAC addresses learned in a VPLS instance reaches this threshold, the system does not learn source MAC addresses any more.
# Set the maximum number of MAC addresses in VPLS instance aaa to 1024.
[Sysname-vsi-aaa] mac-table limit 1024
1.1.13  mtu (VSI view)
mtu mtu
undo mtu
View
VSI view
Default Level
2: System level
mtu: Maximum transmission unit (MTU) for the VPLS instance. The default is 1,500.
Use the mtu command to set the MTU of the VPLS instance.
Use the undo mtu command to restore the default.
Note that the MTU of a VPLS instance is a global attribute and is also the MTU of PWs. For Martini VPLS, the MTUs set for the instances on peer PEs must be identical; while for Kompella VPLS, this is not required.
# Set the MTU of VPLS instance aaa to 1400.
[Sysname-vsi-aaa] mtu 1400
1.1.14  peer (VSI-LDP view)
peer ip-address [ negotiation-vc-id pw-id ] [ tnl-policy tunnel-policy-name ] [ upe | dual-npe ] [ trans-mode { raw | tagged } ]
undo peer ip-address
View
VSI LDP view
Default Level
2: System level
ip-address: IP address of the VPLS remote peer PE.
pw-id: ID of the PW to the VPLS peer PE. The default is VSI ID.
tunnel-policy-name: Name of a tunneling policy, containing no blank space. If you do not specify this argument or no tunneling policy with that name exists, the system uses the policy specified by the tnl-policy command in VSI view.
upe: Specifies that the peer PE is a UPE in the H-VPLS model. This is the default setting.
dual-npe: Specifies the peer PE is the primary or secondary NPE.
trans-mode: Specifies the PW encapsulation type. By default, the PW encapsulation type is that specified by the encapsulation command.
raw: Uses raw mode.
Use the peer command to create a peer PE for a VPLS instance.
Use the undo peer command to remove a peer PE.
  Caution:
l      If the PW encapsulation type specified by the peer command is not that specified by the encapsulation command, the former takes precedence.
l      If the tunneling policy specified by the peer command is not that specified by the tnl-policy command in VSI view, the former takes precedence.
Related commands: vsi, vsi-id, encapsulation.
# Create a peer PE, which is of the UPE type, with the IP address of 4.4.4.4 and the VC ID of 200.
[Sysname-vsi-aaa-ldp] peer 4.4.4.4 negotiation-vc-id 200 upe
1.1.15  pwsignal
pwsignal { ldp | bgp }
View
VSI view
Default Level
2: System level
ldp: Specifies to use LDP signaling, that is, Martini mode.
bgp: Specifies to use BGP signaling, that is, Kompella mode.
Use the pwsignal command to specify the PW signaling protocol for VPLS to use, and enter VSI LDP view (Martini mode) or VSI BGP view (Kompella mode).
# Specify that VPLS instance aaa uses the connection mode of Martini and enter VSI LDP view.
1.1.16  reset bgp vpls
reset bgp vpls { as-number | ip-address | all | external | internal }
View
Default Level
2: System level
as-number: Resets VPLS BGP connections to peers in a specified AS.
ip-address: Resets the VPLS BGP connection to a specified peer.
all: Resets all VPLS BGP connections.
external: Resets VPLS EBGP session.
internal: Resets VPLS IBGP session.
Use the reset bgp vpls command to reset a specified or all VPLS BGP connections.
# Reset all VPLS BGP connections.
<Sysname> reset bgp vpls all
1.1.17  reset mac-address vsi
reset mac-address vsi [ vsi-name ]
View
Default Level
2: System level
Use the reset mac-address vsi command to clear the MAC address table of a specified VPLS instance or all VPLS instances.
# Clear the MAC address table of VPLS instance aaa.
<Sysname>reset mac-address vsi aaa
1.1.18  route-distinguisher (VSI-BGP view)
View
VSI BGP view
Default Level
2: System level
route-distinguisher: Route distinguisher (RD), a string of 3 to 21 characters in the format of nn:nn or IP_address:nn.
An RD can be either of these two formats:
l           16-bit AS number:32-bit user-defined number. For example, 101:3.
l           32-bit IP address:16-bit user-defined number. For example, 192.168.122.15:1.
Use the route-distinguisher command to configure an RD for a VPLS instance.
Different VPLS instances on a PE must have different RDs, while a VPLS instance can have the same RD or different RDs on different PEs.
&  Note:
l      RD has no default value. You must configure an RD for a VPLS instance to make the instance take effect.
l      To change the RD of a VPLS instance, you must remove the VPLS instance and then reconfigure the VPLS instance and RD.
# Set the RD to 111:1.
[Sysname] vsi aaa auto
[Sysname-vsi-aaa] pwsignal bgp
[Sysname-vsi-aaa-bgp] route-distinguisher 111:1
1.1.19  shutdown (VSI view)
shutdown
View
VSI view
Default Level
2: System level
None
Use the shutdown command to shut down the VPLS service of the VPLS instance.
Use the undo shutdown command to restart the VPLS service of the VPLS instance.
By default, the VPLS service of a VPLS instance is started.
Note that when a VPLS instance is shut down, the system does not handle any traffic in the VPLS instance.
# Shut down the VPLS service of VPLS instance aaa.
[Sysname-vsi-aaa] shutdown
1.1.20  site
site site-id [ range site-range ] [ default-offset { 0 | 1 } ]
undo site site-id
View
VSI BGP view
Default Level
2: System level
site-id: ID of a site in the VPLS instance.
site-range: Maximum number of sites (including this site and its peer sites) supported on the PE. The default is 10.
default-offset { 0 | 1 }: Default initial CE offset. It can be 0 or 1 and defaults to 0.
Use the site command to create a site for the VPLS instance.
Use the undo site command to remove a site of the VPLS instance.
Only one site can be created for a VPLS instance. You can use natural numbers as the site IDs.
# Create a site and set the site range to 20.
[Sysname-vsi-aaa-bgp] route-distinguisher 101:3
[Sysname-vsi-aaa-bgp] site 1 range 20
1.1.21  tnl-policy
undo tnl-policy
View
VSI view
Default Level
2: System level
tunnel-policy-name: Name of a tunneling policy for the VPLS instance, containing no blank space.
Use the tnl-policy command to specify a tunneling policy for a VPLS instance.
Use the undo tnl-policy command to remove the configuration.
By default, the tunneling policy is used, which prefers LSP tunnels and the load balancing route number is 1. If a tunneling policy name is specified but no policy is configured, the default policy is used.
Related commands: refer to MPLS L3VPN Commands.
# Specify that VPLS instance aaa uses the tunneling policy of policy1.
[Sysname-vsi-aaa] tnl-policy policy1
1.1.22  vpls-family
vpls-family
View
BGP view
Default Level
2: System level
None
Use the vpls-family command to enter VPLS address family view.
# Enter VPLS address family view.
[Sysname] bgp 100
[Sysname-bgp] vpls-family
[Sysname-bgp-af-vpls]
1.1.23  vpn-target (VSI-BGP view)
vpn-target vpn-target &<1-16> [ both | export-extcommunity | import-extcommunity ]
undo vpn-target { all | vpn-target &<1-16> } [ both | export-extcommunity | import-extcommunity ]
View
VSI BGP view
Default Level
2: System level
vpn-target&<1-16>: Adds the VPN target extended community attribute to the import or export VPN target extended community list. &<1-16> means that you can enter the argument before it up to 16 times.
A VPN target can be either of the following formats:
l           16-bit AS number:32-bit user-defined number, such as 101:3.
l           32-bit IP address:16-bit user-defined number, such as 192.168.122.15:1.
both: Specifies both the incoming and outgoing routing information from and to the destination VPN extended community. The both keyword is the default setting.
export-extcommunity: Specifies the outgoing routing information to the destination VPN extended community.
import-extcommunity: Specifies the incoming routing information from the destination VPN extended community.
all: Specifies all routing information from and to the destination VPN extended community.
Use the vpn-target command to associate a VPLS instance with one or more VPN targets.
Use the undo vpn-target command to delete the VPN target(s) associated with a VPLS instance.
VPN Target has no default value, and you need to configure it when creating VPN.
# Associate VPLS instance aaa with multiple VPN targets.
[Sysname-vsi-aaa-bgp] vpn-target 100:1
[Sysname-vsi-aaa-bgp] vpn-target 1:1 2:2 export-extcommunity
[Sysname-vsi-aaa-bgp] vpn-target 1.2.3.4:11 12:12 import-extcommunity
1.1.24  vsi
vsi vsi-name [ auto | static ]
undo vsi vsi-name
View
Default Level
2: System level
vsi-name: Name of the VPLS instance.
static: Configures the peer discovery mechanism as static. This corresponds to LDP mode.
auto: Configures the peer discovery mechanism as dynamic. This corresponds to BGP mode.
Use the vsi command to create a VPLS instance and enter VSI view.
Use the undo vsi command to remove a VPLS instance.
The VPLS instance name must be globally unique. When creating a VPLS instance, you must specify the peer discovery mechanism.
Related commands: display vsi.
# Create a VPLS instance named aaa that uses the peer discovery mechanism of manual configuration.
[Sysname-vsi-aaa]
# Create a VPLS instance named bbb that uses the peer discovery mechanism of auto.
[Sysname] vsi bbb auto
[Sysname-vsi-bbb]
1.1.25  vsi-id
vsi-id vsi-id
View
VSI LDP view
Default Level
2: System level
vsi-id: ID for the VPLS instance.
Use the vsi-id command to specify the ID of a VPLS instance. Make sure that the VSI ID of the VPLS instance is consistent in a VPN.
# Set the ID of VPLS instance aaa to 100.
[Sysname-vsi-aaa-ldp] vsi-id 100
