H3C S9500 Command Manual-Release2132[V2.03]-05 MPLS VPN Volume
HomeSupportSwitchesS9500 SwitchesReference GuidesCommand ReferencesH3C S9500 Command Manual-Release2132[V2.03]-05 MPLS VPN Volume
02-MPLS TE Commands
02-MPLS TE Commands 316.48 KB
Table of Contents
Chapter 1 MPLS TE Configuration Commands. 1-1
1.1 MPLS TE Configuration Commands. 1-1
1.1.1 add hop. 1-1
1.1.2 debugging isis traffic-eng. 1-2
1.1.3 debugging mpls rsvp-te. 1-3
1.1.4 debugging mpls te cspf 1-4
1.1.5 debugging mpls te management 1-5
1.1.6 debugging ospf mpls-te. 1-6
1.1.7 delete hop. 1-6
1.1.8 display explicit-path. 1-7
1.1.9 display isis traffic-eng advertisements. 1-8
1.1.10 display isis traffic-eng link. 1-11
1.1.11 display isis traffic-eng network. 1-13
1.1.12 display isis traffic-eng statistics. 1-15
1.1.13 display mpls rsvp-te. 1-16
1.1.14 display mpls rsvp-te established. 1-18
1.1.15 display mpls rsvp-te peer 1-19
1.1.16 display mpls rsvp-te psb-content 1-21
1.1.17 display mpls rsvp-te request 1-23
1.1.18 display mpls rsvp-te reservation. 1-24
1.1.19 display mpls rsvp-te rsb-content 1-26
1.1.20 display mpls rsvp-te sender 1-28
1.1.21 display mpls rsvp-te statistics. 1-30
1.1.22 display mpls static-cr-lsp. 1-33
1.1.23 display mpls te cspf tedb. 1-35
1.1.24 display mpls te link-administration admission-control 1-41
1.1.25 display mpls te link-administration bandwidth-allocation. 1-42
1.1.26 display mpls te tunnel 1-44
1.1.27 display mpls te tunnel path. 1-46
1.1.28 display mpls te tunnel statistics. 1-47
1.1.29 display mpls te tunnel-interface. 1-48
1.1.30 display ospf mpls-te. 1-51
1.1.31 display ospf traffic-adjustment 1-55
1.1.32 display tunnel-info. 1-56
1.1.33 enable traffic-adjustment 1-57
1.1.34 enable traffic-adjustment advertise. 1-58
1.1.35 explicit-path. 1-59
1.1.36 list hop. 1-59
1.1.37 modify hop. 1-60
1.1.38 mpls rsvp-te. 1-61
1.1.39 mpls rsvp-te authentication. 1-62
1.1.40 mpls rsvp-te blockade-multiplier 1-63
1.1.41 mpls rsvp-te hello. 1-64
1.1.42 mpls rsvp-te hello-lost 1-65
1.1.43 mpls rsvp-te keep-multiplier 1-66
1.1.44 mpls rsvp-te reliability. 1-67
1.1.45 mpls rsvp-te resvconfirm.. 1-67
1.1.46 mpls rsvp-te srefresh. 1-68
1.1.47 mpls rsvp-te timer hello. 1-69
1.1.48 mpls rsvp-te timer refresh. 1-69
1.1.49 mpls rsvp-te timer retransmission. 1-70
1.1.50 mpls te. 1-71
1.1.51 mpls te affinity property. 1-72
1.1.52 mpls te backup. 1-73
1.1.53 mpls te backup bandwidth. 1-74
1.1.54 mpls te bandwidth. 1-75
1.1.55 mpls te bandwidth change thresholds. 1-76
1.1.56 mpls te commit 1-77
1.1.57 mpls te cspf 1-77
1.1.58 mpls te cspf timer failed-link. 1-78
1.1.59 mpls te fast-reroute. 1-79
1.1.60 mpls te fast-reroute bypass-tunnel 1-80
1.1.61 mpls te igp advertise. 1-81
1.1.62 mpls te igp metric. 1-82
1.1.63 mpls te igp shortcut 1-82
1.1.64 mpls te link administrative group. 1-83
1.1.65 mpls te loop-detection. 1-84
1.1.66 mpls te max-link-bandwidth. 1-85
1.1.67 mpls te max-reservable-bandwidth. 1-86
1.1.68 mpls te metric. 1-86
1.1.69 mpls te path explicit-path. 1-87
1.1.70 mpls te path metric-type. 1-88
1.1.71 mpls te priority. 1-89
1.1.72 mpls te record-route. 1-89
1.1.73 mpls te reoptimization (user view) 1-90
1.1.74 mpls te reoptimization (tunnel interface view) 1-91
1.1.75 mpls te resv-style. 1-91
1.1.76 mpls te retry. 1-92
1.1.77 mpls te route-pinning. 1-93
1.1.78 mpls te signal-protocol 1-94
1.1.79 mpls te tie-breaking. 1-95
1.1.80 mpls te timer fast-reroute. 1-96
1.1.81 mpls te timer retry. 1-97
1.1.82 mpls te vpn-binding. 1-97
1.1.83 mpls-te. 1-98
1.1.84 next hop. 1-99
1.1.85 opaque-capability. 1-100
1.1.86 reset mpls rsvp-te statistics. 1-100
1.1.87 static-cr-lsp egress. 1-101
1.1.88 static-cr-lsp ingress. 1-102
1.1.89 static-cr-lsp transit 1-103
1.1.90 traffic-eng. 1-104
1.1.1  add hop
add hop ip-address1 [ include [ loose | strict ] | exclude ] { after | before } ip-address2
View
Explicit path view
Default Level
2: System level
ip-address1: IP address or Router ID of the node to be inserted in the explicit path, in dotted decimal notation.
include: Includes the specified IP address in the explicit path.
loose: Indicates that the next hop is a loose node which is not necessarily directly connected to the specified node.
strict: Indicates that the next hop is a strict node which must be directly connected to the specified node.
exclude: Excludes the node identified by the ip-address1 argument from the explicit path. Excluded addresses are not considered in path calculation.
after: Inserts the node identified by the ip-address1 argument after the reference node.
before: Inserts the node identified by the ip-address1 argument before the reference node.
ip-address2: IP address of the reference node, in dotted decimal notation.
Use the add hop command to insert a node to the explicit path.
By default, the specified node is included in the explicit path and its next hop is a strict node.
# Insert 3.3.29.3 behind 3.3.10.5 on the explicit path PL and exclude this IP address in path calculation.
[Sysname] explicit-path path1
[Sysname-explicit-path-path1] add hop 3.3.29.3 exclude after 3.3.10.5
debugging isis traffic-eng { advertisement | event } [ process-id | vpn-instance vpn-instance-name ]
undo debugging isis traffic-eng { advertisement | event } [ process-id | vpn-instance vpn-instance-name ]
View
Default Level
1: Monitor level
advertisement: Enables IS-IS advertisement debugging.
event: Enables IS-IS TE event debugging.
process-id: IS-IS process ID.
vpn-instance: Enables debugging for a VPN instance.
vpn-instance-name: VPN instance name.
Use the debugging isis traffic-eng command to enable IS-IS TE debugging.
Use the undo debugging isis traffic-eng command to disable IS-IS TE debugging.
By default, IS-IS TE debugging is disabled.
# Enable IS-IS TE event debugging.
<Sysname> debugging isis traffic-eng event
debugging mpls rsvp-te { all | authentication | bundle | encdec | error | hello | hsb | main | msg-hex | path | perr | ptear | rconf | rerr | resv | rtear | socket | srefresh | timer | tool | traffic-control | tunnel-id { tunnel-id | all } }
undo debugging mpls rsvp-te { all | authentication | bundle | encdec | error | hello | hsb | main | msg-hex | path | perr | ptear | rconf | rerr | resv | rtear | socket | srefresh | timer | tool | traffic-control | tunnel-id { tunnel-id | all } }
View
Default Level
1: Monitor level
all: Enables debugging for all MPLS RSVP-TE messages.
authentication: Enables authentication debugging.
bundle: Enables bundle debugging.
encdec: Enables encoding/decoding debugging.
error: Enables error debugging.
hello: Enables Hello debugging.
hsb: Enables hot backup bugging.
main: Enables main debugging.
msg-hex: Enables details debugging.
path: Enables path debugging.
perr: Enables path error debugging.
ptear: Enables path teardown debugging.
rconf: Enables reservation confirmation debugging.
rerr: Enables reservation error debugging.
resv: Enables reservation message debugging.
rtear: Enables reservation teardown debugging.
socket: Enables socket debugging.
srefresh: Enables Srefresh debugging.
timer: Enables timer debugging.
tool: Enables tool debugging.
traffic-control: Enables traffic control debugging.
tunnel-id: Enables debugging for a tunnel.
tunnel-id: Tunnel ID.
Use the debugging mpls rsvp-te command to enable MPLS RSVP-TE debugging.
Use the undo debugging mpls rsvp-te command to disable MPLS RSVP-TE debugging.
By default, MPLS RSVP-TE debugging is disabled.
To view debugging information about tunnel establishment, removing and refreshing, use the debugging mpls tunnel-id command.
# Enable debugging for all RSVP-TE messages.
<Sysname> debugging mpls rsvp-te all
# Disable RSVP-TE Srefresh debugging.
<Sysname> undo debugging mpls rsvp-te srefresh
debugging mpls te cspf { all | computation | errors | events | tedb }
undo debugging mpls te cspf { all | computation | errors | events | tedb }
View
Default Level
1: Monitor level
all: Enables debugging for all CSPF messages.
computation: Enables debugging for messages about how CSPF calculates the constraint-based shortest path.
errors: Enables CSPF error debugging.
events: Enables CSPF event debugging.
tedb: Enables CSPF TEDB (traffic engineering database) debugging.
Use the debugging mpls te cspf command to enable CSPF debugging.
Use the undo debugging mpls te cspf command to disable CSPF debugging.
By default, CSPF debugging is disabled.
# Enable debugging for all CSPF messages.
<Sysname> debugging mpls te cspf all
debugging mpls te management { all | events | fast-reroute | link-administration | reoptimization | states }
undo debugging mpls te management { all | events | fast-reroute | link-administration | reoptimization | states }
View
Default Level
1: Monitor level
all: Enables debugging for all MPLS TE messages.
events: Enables MPLS TE event debugging.
fast-reroute: Enables MPLS TE fast reroute (FRR) debugging.
link-administration: Enables debugging for admission control and bandwidth allocation of MPLS TE link administration.
reoptimization: Enables MPLS TE reoptimization debugging.
states: Enables MPLS TE tunnel status debugging.
Use the debugging mpls te management command to enable MPLS TE debugging.
Use the undo debugging mpls te management command to disable MPLS TE debugging.
By default, MPLS TE debugging is disabled.
# Enable MPLS TE event debugging.
<Sysname> debugging mpls te management events
# Disable debugging for all MPLS TE messages.
<Sysname> undo debugging mpls te management all
debugging ospf [ process-id ] mpls-te
undo debugging ospf [ process-id ] mpls-te
View
Default Level
1: Monitor level
process-id: OSPF process ID, in the range 1 to 65535.
Use the debugging ospf mpls-te command to enable OSPF TE debugging. With OSPF TE debugging enabled, all information about TE LSA receipt, generation, propagation, refreshing is displayed.
Use the undo debugging ospf mpls-te command to disable OSPF TE debugging.
By default, OSPF TE debugging is disabled.
# Enable OSPF TE debugging.
<Sysname> debugging ospf mpls-te
1.1.7  delete hop
delete hop ip-address
View
Explicit path view
Default Level
2: System level
ip-address: IP address of a node along the explicit path, in dotted decimal notation.
Use the delete hop command to remove a specified node from the explicit path.
# Remove the node identified by 10.0.0.120 from the explicit path p1.
[Sysname] explicit-path p1
[Sysname-explicit-path-p1] delete hop 10.0.0.120
display explicit-path [ pathname ]
View
Default Level
1: Monitor level
pathname: Specifies a path name.
Use the display explicit-path command to display information about an explicit path.
If no path name is specified, information about all explicit paths is displayed.
# Display information about all explicit paths.
<Sysname> display explicit-path
Path Name : ErHop-Path1  Path Status : Enabled
 1             1.1.1.10         Strict                    Include
 2             2.1.1.10         Strict                    Include
 3             1.1.1.20         Strict                    Include
 4             2.1.1.20         Strict                    Include
 5             2.1.1.30         Strict                    Include
 6             1.1.1.30         Strict                    Include
 7             9.4.4.4          Strict                    Include
Path Name : ErHop-Path2  Path Status : Enabled
 3             1.1.1.40         Strict                    Include
 4             2.1.1.40         Strict                    Include
 5             1.1.1.50         Strict                    Include
 6             2.1.1.40         Strict                    Include
 7             2.1.1.30         Strict                    Include
 8             1.1.1.30         Strict                    Include
 9             9.4.4.4          Strict                    Include
Table 1-1 Description on the fields of the display explicit-path command
Path Name
Explicit path name
Path Status
Explicit path status
display isis traffic-eng advertisements [ level-1 | level-1-2 | level-2 ] [ lsp-id | local ] [ process-id | vpn-instance vpn-instance-name ]
View
Default Level
1: Monitor level
level-1: Displays the TE information of IS-IS Level-1 devices.
level-1-2: Displays the TE information of IS-IS Level-1-2 devices.
level-2: Displays the TE information of IS-IS Level-2 devices.
lsp-id lsp-id: Specifies a link state packet ID (LSP ID) to display the TE information advertised by it. For more information about IS-IS LSP, refer to IS-IS Configuration in IP Routing Volume.
local: Displays local TE information.
process-id: Specifies an IS-IS process ID.
vpn-instance vpn-instance-name: Specifies a VPN instance. For the default VPN instance, you do not need to configure this keyword and argument combination.
Use the display isis traffic-eng advertisements command to display the latest TE information advertised by IS-IS TE.
If no IS-IS level is specified, the TE information of IS-IS Level-1-2 devices is displayed.
# Display the latest TE information advertised by IS-IS TE.
<Sysname> display isis traffic-eng advertisements
                           TE information for ISIS(1)
Level-1 Link State Database
LSPID                 LSP Seq Num  LSP Checksum  LSP Holdtime  ATT/P/OL
0000.0000.0001.00-00* 0x00000001   0x3f57        534           0/0/0
 NLPID      : IPV4
 AREA ADDR  : 00.0005
 INTF ADDR  : 10.1.1.1
 INTF ADDR  : 1.1.1.9
 INTF ADDR  : 30.1.1.1
Level-2 Link State Database
0000.0000.0001.00-00* 0x0000001c   0xf1ec        687           0/0/0
 NLPID      : IPV4
 AREA ADDR  : 00.0005
 INTF ADDR  : 1.1.1.9
 Router ID  : 1.1.1.9
+NBR        : 0000.0000.0002.02  COST: 10
    Affinity: 0x00000000
    Interface IP Address:  10.1.1.1
    Physical BW  :      12500 Bytes/sec
    Reservable BW:       6250 Bytes/sec
    Unreserved BW for Class Type 0:
    BW Unresrv[0]:       6250 Bytes/sec BW Unresrv[1]:       6250 Bytes/sec
    BW Unresrv[2]:       6250 Bytes/sec BW Unresrv[3]:       6250 Bytes/sec
    BW Unresrv[4]:       6250 Bytes/sec BW Unresrv[5]:       6250 Bytes/sec
    BW Unresrv[6]:       6250 Bytes/sec BW Unresrv[7]:       6250 Bytes/sec
    Unreserved BW for Class Type 1:
    BW Unresrv[0]:          0 Bytes/sec BW Unresrv[1]:          0 Bytes/sec
    BW Unresrv[2]:          0 Bytes/sec BW Unresrv[3]:          0 Bytes/sec
    BW Unresrv[4]:          0 Bytes/sec BW Unresrv[5]:          0 Bytes/sec
    BW Unresrv[6]:          0 Bytes/sec BW Unresrv[7]:          0 Bytes/sec
    TE Cost      :         10
    Bandwidth Constraint Model: Russian Doll
    Bandwidth Constraints:
    BC[0]        :       6250 Bytes/sec BC[1]        :          0 Bytes/sec
    Local Overbooking Multiplier:
    LOM[0]       :        100 %         LOM[1]       :        100 %
+NBR        : 0000.0000.0004.00  COST: 10
    Interface IP Address:  30.1.1.1
    Peer IP Address     :  30.1.1.2
    TE Cost      :         10
Table 1-2 Description on the fields of display isis traffic-eng advertisements
LSPID
LSP ID
LSP Seq Num
LSP sequence number
LSP Checksum
LSP checksum
LSP Holdtime
LSP holdtime
ATT/P/OL
Attach bit (ATT)
Partition bit (P)
Overload bit (OL)
NLPID
Network protocol type
AREA ADDR
IS-IS area address
INTF ADDR
Interface address
Router ID
Router ID
+NBR
Neighbor
COST
Cost
Affinity
Affinity attribute
Interface IP address
Physical BW
Physical bandwidth
Reservable BW
Reservable bandwidth
BW Unresrv[0]-[7]
Available subpool bandwidths at eight levels
TE Cost
TE cost
Bandwidth constraint model
BC[0]
Global pool
BC[1]
Subpool
Local overbooking multiplier
LOM[0]
LOM[1]
Local overbooking multiplier. The bracketed number indicates the level of bandwidth.
Peer IP Address
Peer IP address
display isis traffic-eng link [ level-1 | level-1-2 | level-2 ] [ verbose ] [ process-id | vpn-instance vpn-instance-name ]
View
Default Level
1: Monitor level
verbose: Displays details.
Use the display isis traffic-eng link command to display information about TE links for IS-IS.
If no IS-IS level is specified, the TE link information of IS-IS Level-1-2 devices is displayed.
# Display information about TE links for IS-IS.
<Sysname> display isis traffic-eng link
Level-2 Link Information
 0000.0000.0001.00-->0000.0000.0001.01    Type: MULACC  LinkID: 10.1.1.1
 0000.0000.0002.00-->0000.0000.0001.01    Type: MULACC  LinkID: 10.1.1.1
 0000.0000.0003.00-->0000.0000.0004.01    Type: MULACC  LinkID: 30.1.1.2
 0000.0000.0004.00-->0000.0000.0004.01    Type: MULACC  LinkID: 30.1.1.2
 Total Number of TE Links in Level-2 Area: 6, Num Active: 6
Table 1-3 Description on the fields of the display mpls lsp statistics command
Total number of TE links in the Level-2 area
Num Active
Number of active TE links
display isis traffic-eng network [ level-1 | level-1-2 | level-2 ] [ process-id | vpn-instance vpn-instance-name ]
View
Default Level
1: Monitor level
Use the display isis traffic-eng network command to display information about TE networks for IS-IS.
If no IS-IS level is specified, the TE network information in the IS-IS Level-1-2 area is displayed.
# Display information about TE networks for IS-IS.
<Sysname> display isis traffic-eng network
Level-1 Network Information
    DIS Router ID  : 89.1.1.1        DIS's Ip Address         : 86.1.1.1
    Status In CSPF : ACTIVE          Attached Router Count    : 2
    List of Attached Routers
 RouterId : 89.1.1.1   Nbr : 1111.1111.1111.00  Link State : 1
 RouterId : 89.2.2.2   Nbr : 1111.1111.1113.00  Link State : 1
 Total Number of TE Networks in Level-1 Area: 1, Num Active: 1
Level-2 Network Information
 Total Number of TE Networks in Level-2 Area: 1, Num Active: 1
Table 1-4 Description on the fields of the display isis traffic-eng network command
Level-1 network information
DIS Router ID
ID of the DR
DIS's Ip Address
IP address of the DR
Status In CSPF
CSPF state
Number of attached devices
List of attached devices
RouterId
Router ID
Nbr
Neighbors
Link State
Link state
Total number of TE networks in the Level-1 area
Num Active
Level-2 network information
Total number of TE networks in the Level-2 area
display isis traffic-eng statistics [ process-id | vpn-instance vpn-instance-name ]
View
Default Level
1: Monitor level
Use the display isis traffic-eng statistics command to display the statistics about TE for IS-IS.
If no IS-IS level is specified, the statistics about TE in the IS-IS Level-1-2 area is displayed.
# Display statistics about TE for IS-IS.
<Sysname> display isis traffic-eng statistics
TE Statistics Information
 IS-IS System Type                          : Level-1-2
 IS-IS Cost Style Status                    : Wide
 IS-IS Level-1 Traffic Engineering Status   : Disabled
 IS-IS Level-2 Traffic Engineering Status   : Enabled
 IS-IS Router ID                            : 1.1.1.9
Table 1-5 Description on the fields of the display isis traffic-eng statistics command
IS-IS System Type
System type
Cost type of the device
TE state of Level-1 device
TE state of Level-2 device
IS-IS Router ID
IS-IS router ID
display mpls rsvp-te [ interface [ interface-type interface-number ] [ | { begin | include | exclude } regular-expression ] ]
View
Default Level
1: Monitor level
interface: Displays RSVP-TE configuration for interfaces. If no interface is specified, the RSVP-TE configuration of all RSVP-TE enabled interfaces is displayed.
interface-type interface-number: Specifies an interface for which RSVP-TE configuration is displayed.
|: Filters output by regular expression.
begin: Displays information beginning with a defined regular expression.
include: Displays information that includes a defined regular expression.
exclude: Displays information that excludes a defined regular expression.
regular-expression: Regular expression, a string of 1 to 80 characters without spaces.
Use the display mpls rsvp-te interface command to display RSVP-TE configuration.
If the interface is not specified, the global RSVP-TE configuration is displayed.
# Display the global RSVP-TE configuration.
<Sysname> display mpls rsvp-te
 LSR ID: 4.4.4.4
 Resv Confirmation Request: DISABLE
 RSVP Hello Extension: ENABLE
 Hello interval: 3 sec         Max Hello misses: 3
 Path and Resv message refresh interval: 30 sec
 Path and Resv message refresh retries count: 3
 Blockade Multiplier: 4
Table 1-6 Description on the fields of the display mpls rsvp-te command
LSR ID
Label switched Router ID, in the format of X.X.X.X
Reserved confirmation request
State of the hello mechanism: enabled or disabled
Hello Interval
Hello interval, in seconds
Max Hello misses
Maximum number of consecutive hello losses before a neighbor is considered dead
Path and reservation message refresh interval, in seconds
Number of Path and Resv message retransmissions
Blockade Multiplier
Blockade multiplier
# Display the RSVP-TE configuration on interface VLAN-interface 12.
<Sysname> display mpls rsvp-te interface vlan-interface 12
Interface Vlan-interface 12
 Interface state: UP
 Total-BW: 80              Used-BW: 20
 Hello configured: NO      Num of Neighbors: 1
 SRefresh feature: ENABLE  SRefresh Interval: 30sec
 Authentication: DISABLE   Reliability configured: NO
 Retransmit Interval: 500msec  Increment Value: 1
Table 1-7 Description on the fields of the display mpls rsvp-te interface command
Interface state
Physical interface state
Total-BW
Total bandwidth (in kbps)
Used-BW
Used bandwidth (in kbps)
Hello configured
Num of Neighbors
Number of neighbors connected to the interface
Srefresh feature
State of the summary refresh function: enabled or disabled
Srefresh interval
Summary refresh interval (in seconds)
Authentication
State of authentication: enabled or disabled
Reliability
Whether the reliability feature is configured: yes or no
Retransmit interval
Initial retransmission interval (in milliseconds)
Increment value
Increment value delta which governs the speed with which the interface increases the retransmission interval
display mpls rsvp-te established [ interface interface-type interface-number ] [ | { begin | include | exclude } regular-expression ]
View
Default Level
1: Monitor level
regular-expression: Regular expression, a string without spaces.
Use the display mpls rsvp-te established command to display information about RSVP-TE globally or for an interface.
# Display RSVP-TE information for interface VLAN-interface 12.
<Sysname> display mpls rsvp-te established interface vlan-interface 12
 Token Bucket Rate: 0.00            Peak Data Rate: 0.00
 Tunnel Dest: 2.2.2.2               Ingress LSR ID: 3.3.3.3
 Local LSP ID: 4                    Session Tunnel ID: 4
 Next Hop Addr: 80.4.1.1
 Upstream Label: 1024               Downstream Label: 3
Table 1-8 Description on the fields of the display mpls rsvp-te established command
RSVP-TE enabled VLAN interface
Token Bucket rate
Token bucket rate, a traffic parameter
Peak Data Rate
Peak rate, a traffic parameter
Tunnel Dest
Tunnel destination, in the format of X.X.X.X
Ingress LSR ID
Ingress LSR ID, in the format of X.X.X.X
Local LSP ID
Local LSP ID
Session Tunnel ID
Session tunnel ID
Next Hop Addr
Next hop address, in the format of X.X.X.X
Upstream label
Upstream label
Downstream Label
Downstream label
display mpls rsvp-te peer [ interface interface-type interface-number ] [ | { begin | include | exclude } regular-expression ]
View
Default Level
1: Monitor level
Use the display mpls rsvp-te peer command to display information about RSVP-TE neighbors on the specified or all interfaces.
# Display information about RSVP-TE neighbors on all interfaces.
<Sysname> display mpls rsvp-te peer
Interface Vlan-interface12
 Neighbor Addr: 80.4.1.1
 SrcInstance: 841             NbrSrcInstance: 928
 PSB Count: 0                 RSB Count: 1
 Hello Type Sent: ACK         Neighbor Hello Extension: ENABLE
 SRefresh Enable: NO          Reliability Enable: YES
Interface Vlan-interface14
 Neighbor Addr: 80.2.1.1
 SrcInstance: 832             NbrSrcInstance: 920
 PSB Count: 1                 RSB Count: 0
 Hello Type Sent: REQ         Neighbor Hello Extension: ENABLE
Table 1-9 Description on the fields of the display mpls rsvp-te peer command
Neighbor Addr:
Neighbor address, in the format of  X.X.X.X.
SrcInstance
Instance of source Message ID
NbrSrcInstance
Instance of neighbor Message ID
PSB Count
Number of path state blocks
RSB Count
Number of reservation state blocks
Hello Type Sent
Type of hellos sent to the neighbor: REQ, ACK, or NONE
State of hello extension: enabled or disabled
SRefresh Enable
State of summary refresh: YES for enabled and NO for disabled
Reliability Enable
State of the reliability function: YES for enabled and NO for disabled
display mpls rsvp-te psb-content ingress-lsr-id lspid tunnel-id egress-lsr-id [ | { begin | include | exclude } regular-expression ]
View
Default Level
1: Monitor level
ingress-lsr-id: Ingress LSR ID.
lspid: Local LSR ID.
egress-lsr-id: Egress LSR ID.
Use the display mpls rsvp-te psb-content command to display information about RSVP-TE PSB.
# Display PSB information.
<Sysname> display mpls rsvp-te psb-content 19.19.19.19 1 0 29.29.29.29
The PSB Content:
 Tunnel Dest: 29.29.29.29     Session Tunnel ID: 0
 Tunnel ExtID: 19.19.19.19
 Ingress LSR ID: 19.19.19.19  Local LSP ID: 1
 Previous Hop : 101.101.101.1 Next Hop : -----
 Incoming / Outgoing Interface: Vlan-interface 12  /  -----
 InLabel : 3            OutLabel : NULL
Send Message ID : 1      Recv Message ID : 0
 Session Attribute-
   SetupPrio: 7         HoldPrio: 7
   SessionFlag: SE Style desired
  ERO Information-
     L-Type          ERO-IPAddr       ERO-PrefixLen
   ERHOP_STRICT    101.101.101.2         32
 RRO Information-
   RRO-CType: IPV4   RRO-IPAddress: 101.101.101.1   RRO-IPPrefixLen: 32
 SenderTspec Information-
   Token bucket rate: 0.00
   Token bucket size: 0.00
   Peak data rate: 0.00
   Minimum policed unit: 0
   Maximum packet size: 4294967295
 Path Message arrive on Vlan-interface 12 from PHOP 101.101.101.1
 Resource Reservation OK
Table 1-10 Description on the fields of display mpls rsvp-te psb content
Tunnel Dest
Session Tunnel ID
Session tunnel ID
Tunnel ExtID
Tunnel extension ID, in the format of X.X.X.X
Ingress LSR ID
Local LSP ID
Local LSP ID
Next Hop
Previous Hop
Previous hop address, in the format of X.X.X.X
In Label
Incoming label
Out Label
Outgoing label
Send message ID
Instance of sent Message ID
Resv Message ID
Instance of received Message ID
Setup Prio
Session setup priority
HoldPrio
Session hold priority
Session Flag
Session flag (local protection policy, label, SE style)
ERO Information
Information about explicit routes
L-Type
Explicit routing type: strict or loose
ERO-IPAddress
IP address for an explicit route
ERO-Prefix Len
Prefix length for an explicit route
RRO Information
Information about route recording
RRO-C Type
Type of route recording
RRO-IP Address
IP address of recorded route in the format of X.X.X.X
RRO-IPPrefixLen
IP prefix length of recorded route
Sender Tspec Information
Information about sender's service specifications
Token Bucket rate
Token bucket rate (in kbps), a traffic parameter
Token Bucket size
Token bucket size, a traffic parameter
Peak Data Rate
Peak data rate (in kbps), a traffic parameter
Maximum packet size
Maximum packet size, a traffic parameter
Minimum policed unit, a traffic parameter
Path message
Path message sent from the interface to the next hop at X.X.X.X
Resource
Available when the RSVP flag is configured
display mpls rsvp-te request [ interface interface-type interface-number ] [ | { begin | include | exclude } regular-expression ]
View
Default Level
1: Monitor level
Use the display mpls rsvp-te request command to display information about RSVP-TE requests on the specified or all interfaces.
# Display information about RSVP-TE requests on all interfaces.
<Sysname> display mpls rsvp-te request
Interface Vlan-interface 12:
 NextHopAddr: 80.4.1.1
 SessionFlag: SE Style desired.
 Token bucket rate: 0.00             Token bucket size: 1000.00
 Out Interface: Vlan-interface 14
Table 1-11 Description on the fields of the display mpls rsvp-te request command
Tunnel Dest
Ingress LSR ID
Local LSP ID
Local LSP ID
Session Tunnel ID
Session tunnel ID
Next Hop Address
SessionFlag
Reservation style
Token Bucket rate
Token Bucket Size
Out Interface
Output interface
display mpls rsvp-te reservation [ interface interface-type interface-number ] [ | { begin | include | exclude } regular-expression ]
View
Default Level
1: Monitor level
Use the display mpls rsvp-te reservation command to display information about RSVP-TE reservations on the specified or all interfaces.
# Display information about RSVP-TE reservations on interface VLAN-interface 12.
<Sysname> display mpls rsvp-te reservation interface vlan-interface 12
 Tunnel Dest: 29.29.29.29     Ingress LSR ID: 19.19.19.19
 LSP ID: 1                    Session Tunnel ID: 1
 Upstream Label: -----
 Token bucket rate: 0.00       Token bucket size: 0.00
# Display information about RSVP-TE reservations on all interfaces.
 Interface: Outgoing-Interface at the Egress
 Tunnel Dest: 19.19.19.19     Ingress LSR ID: 29.29.29.29
 Upstream Label: 3
Table 1-12 Description on the fields of display mpls rsvp-te reservation
Tunnel Dest
Ingress LSR ID
LSP ID
LSP ID
Session Tunnel ID
Session Tunnel ID
Upstream Label
Upstream label
Token Bucket rate
Token Bucket Size
display mpls rsvp-te rsb-content { ingress-lsr-id Ispid tunnel-id egress-lsr-id nexthop-address } [ | { begin | include | exclude } regular-expression ]
View
Default Level
1: Monitor level
lspid: Local LSP ID.
nexthop-address: Next hop address.
Use the display mpls rsvp-te rsb-content command to display information about RSVP-TE reservation state blocks (RSBs).
# Display information about RSVP-TE RSBs.
<Sysname> display mpls rsvp-te rsb-content 19.19.19.19 1 0 29.29.29.29 101.101.101.2
The RSB Content:
 Next Hop: 101.101.101.2    Resevation Style: SE Style
 Reservation Incoming Interface: Vlan-interface 12
 Reservation Interface: Vlan-interface 12
 Message ID : 2
 Filter Spec Information-
   The filter number: 1
   Ingress LSR ID: 19.19.19.19    Local LSP ID: 1      OutLabel: 3
 RRO Information-
   RRO-Flag is
   RRO-CType: IPV4   RRO-IPAddress: 101.101.101.2      RRO-IPPrefixLen: 32
 FlowSpec Information-
   Token bucket rate: 2500.00
   Maximum packet size: 0
   Bandwidth guarantees: 0.00
   Delay guarantees: 0
   Qos Service is Controlled
 Resv Message arrive on Vlan-interface 12 from NHOP 101.101.101.2
Table 1-13 Description on the fields of display mpls rsvp-te rsb content
Tunnel Dest
Session Tunnel ID
Session tunnel ID
Tunnel Ext ID
Tunnel extension (ingress LSR ID), in the format of X.X.X.X
Next Hop
Reservation Style
Reservation style: SE or FF
Reservation interface name
Reserve Incoming Interface
Incoming interface where the Resv message was received
Message ID
Message ID of the Refresh Reduction message
Filter specifications
The filter number
Number of filters
Ingress LSR ID
LSP ID
LSP ID
Out Label
Outgoing label
RRO Information
RRO-C Type
RRO-IP Address
RRO-IPPrefixLen
Flow Spec information
Flow specifications
Token Bucket rate
Token Bucket size
Peak Data Rate
Maximum packet size
Guaranteed bandwidth, a reservation specifications parameter
Delay guarantees
Delay guarantee, a reservation specifications parameter
QOS service
QoS guarantee/control
Resv Message
Reservation message received on a particular interface from next hop (X.X.X.X)
display mpls rsvp-te sender [ interface interface-type interface-number ] [ | { begin | include | exclude } regular-expression ]
View
Default Level
1: Monitor level
Use the display mpls rsvp-te sender command to display RSVP-TE sender message information.
# Display the RSVP-TE sender message information on interface VLAN-interface 12.
<Sysname> display mpls rsvp-te sender interface vlan-interface 12
Interface Vlan-interface 12;
 Session Name: Tunnel0/0/0
 Previous Hop Address: 101.101.101.1
# Display the RSVP-TE sender message information on all interfaces.
 Previous Hop Address: 101.101.101.2
Interface: Incoming-Interface at the Ingress
 Session Name: Tunnel0/0/1
 Previous Hop Address: 19.19.19.19
Table 1-14 Description on fields of the display mpls rsvp-te sender command
Tunnel Dest
Ingress LSR ID
LSP ID
LSP ID
Tunnel ID
Tunnel ID
Session Name:
Session name
Token Bucket rate
Token Bucket Size
display mpls rsvp-te statistics { global | interface [ interface-type interface-number ] }
View
Default Level
1: Monitor level
global: Display global RSVP-TE information.
interface: Displays statistics about RSVP-TE for a specified or all interfaces if no interface is specified.
interface-type interface-number: Specifies an interface for which statistics about RSVP-TE is displayed.
Use the display mpls rsvp-te statistics command to display statistics about RSVP-TE.
# Display global RSVP-TE statistics.
<Sysname> display mpls rsvp-te statistics global
LSR ID: 1.1.1.1
 PSB Count: 1                          RSB Count: 1
 RFSB Count: 0                         TCSB Count: 1
 LSP Count: 1
Total Statistics Information:
 PSB CleanupTimeOutCounter: 0          RSB CleanupTimeOutCounter: 0
 SendPacketCounter: 55                 RecPacketCounter: 54
 SendPathCounter: 5                    RecPathCounter: 0
 SendResvCounter: 0                    RecResvCounter: 4
 SendResvConfCounter: 0                RecResvConfCounter: 0
 SendHelloCounter: 2                   RecHelloCounter: 48
 SendAckCounter: 48                    RecAckCounter: 2
 SendPathErrCounter: 0                 RecPathErrCounter: 0
 SendResvErrCounter: 0                 RecResvErrCounter: 0
 SendPathTearCounter: 0                RecPathTearCounter: 0
 SendResvTearCounter: 0                RecResvTearCounter: 0
 SendSrefreshCounter: 0                RecSrefreshCounter: 0
 SendAckMsgCounter: 0                  RecAckMsgCounter: 0
 SendErrMsgCounter: 0                  RecErrMsgCounter: 0
 RecReqFaultCounter: 0
# Display the RSVP-TE statistics of interface VLAN-interface 12.
<Sysname> display mpls rsvp-te statistics interface
Vlan-interface 12:
 SendPacketCounter: 69                 RecPacketCounter: 68
 SendPathCounter: 6                    RecPathCounter: 0
 SendResvCounter: 0                    RecResvCounter: 5
 SendHelloCounter: 2                   RecHelloCounter: 61
 SendAckCounter: 61                    RecAckCounter: 2
Table 1-15 Description on the fields of the display mpls rsvp-te statistics command
LSR ID
LSR ID
PSB Count
Number of PSBs
RSB Count
Number of RSBs
RFSB Count
Number of RFSBs
TCSB Count
Number of TCSBs
LSP Count
Number of LSPs
Number of PSB timeouts
Number of RSB timeouts
SendPacketCounter
Number of transmitted packets
RecPacketCounter
Number of received packets
SendPathCounter
Number of transmitted Path messages
RecPathCounter
Number of received Path messages
SendResvCounter
Number of transmitted Resv messages
RecResvCounter
Number of received Resv messages
SendResvConfCounter
Number of transmitted ResvConf messages
RecResvConfCounter
Number of received ResvConf messages
SendHelloCounter
Number of transmitted Hello messages
RecHelloCounter
Number of received Hello messages
SendAckCounter
Number of transmitted Ack messages
RecAckCounter
Number of received Ack messages
SendPathErrCounter
Number of transmitted PathErr messages
RecPathErrCounter
Number of received PathErr messages
SendResvErrCounter
Number of transmitted ResvErr messages
RecResvErrCounter
Number of received ResvErr messages
SendPathTearCounter
Number of transmitted PathTear messages
RecPathTearCounter
Number of received PathTear messages
SendResvTearCounter
Number of transmitted ResvTear messages
RecResvTearCounter
Number of received ResvTear messages
SendSrefreshCounter
Number of transmitted Srefresh messages
RecSrefreshCounter
Number of received Srefresh messages
SendAckMsgCounter
Number of transmitted AckMsg messages
RecAckMsgCounter
Number of received AckMsg messages
SendErrMsgCounter
Number of transmitted errors
RecErrMsgCounter
Number of received errors
RecReqFaultCounter
Number of request failures
display mpls static-cr-lsp [ lsp-name lsp-name ] [ { exclude | include } ip-address prefix-length ] [ verbose ]
View
Default Level
1: Monitor level
lsp-name lsp-name: Label switched path name.
exclude: Displays only CR-LSPs with destination IP addresses other than the one specified by the ip-address prefix-length arguments.
include: Displays only CR-LSPs with the destination IP address specified by the ip-address prefix-length arguments.
ip-address: Destination IP address.
prefix-length: IP address prefix length.
verbose: Displays detailed information.
Use the display mpls static-cr-lsp command to display information about static CR-LSPs.
# Display brief information about all static CR-LSPs.
<Sysname> display mpls static-cr-lsp
total statics-cr-lsp : 1
Name       FEC               I/O Label  I/O If                Stat
abc        3.3.3.9/32        NULL/100   -/Vlan12              Down
Table 1-16 Description on the fields of the display mpls static-cr-lsp command
Name
Static CR-LSP name
FEC
Forwarding equivalence class (FEC) associated with the destination IP address of LSP
I/O Label
Incoming/outgoing label
I/O If
Incoming/outgoing interface
Stat
Current state of the CR-LSP
# Display detailed information about all static CR-LSPs.
<Sysname> display mpls static-cr-lsp verbose
No             : 1
LSP-Name       : abc
LSR-Type       : Transit
FEC            : -/-
In-Label       : 20
Out-Label      : 30
In-Interface   : Vlan-interface 12
Out-Interface  : Vlan-interface 14
NextHop        : 3.2.1.2
Lsp Status     : Down
Table 1-17 Description on the fields of display mpls static-cr-lsp verbose
LSP-Name
Static CR-LSP name
LSR-Type
LSR type: ingress, transit, or egress
FEC
In-Label
Incoming label
Out-Label
Outgoing label
In-Interface
Incoming interface
Out-Interface
Outgoing interface
NextHop
Next hop address
Lsp Status
LSP status
display mpls te cspf tedb { all | area area-id | interface ip-address | network-lsa | node [ mpls-lsr-id ] } [ | { begin | include | exclude } regular-expression ]
View
Default Level
1: Monitor level
area-id: Area ID.
ip-address: IP address of an interface.
network-lsa: Displays traffic engineering database (TEDB) information in network LSAs.
node: Displays the TEDB information on nodes. If no node is specified, the TEDB information on all nodes is displayed.
mpls-lsr-id: Specifies a node by its MPLS LSR ID.
Use the display mpls te cspf tedb command to display information about CSPF-based TEDB by specified criteria.
# Display TEDB information in network LSAs.
<Sysname> display mpls te cspf tedb network-lsa
Maximum Network LSA Supported:  500
Current Total Network LSA Number:       7
Id   DR MPLS LSR-Id DR-Address       IGP   Process-Id  Area  Neighbor
1    8.1.1.2        3.0.0.2          OSPF  100         0     1.1.1.1
                                                             2.1.1.1
                                                             8.1.1.2
2    2.1.1.1        3.0.0.3          OSPF  100         0     2.1.1.1
                                                             3.1.1.1
                                                             2.1.1.2
3    3.1.1.2        3.0.0.4          OSPF  100         0     3.1.1.1
                                                             4.1.1.1
                                                             3.1.1.2
4    4.1.1.2        3.0.0.5          OSPF  100         0     4.1.1.1
                                                             5.1.1.1
                                                             4.1.1.2
5    5.1.1.2        3.0.0.6          OSPF  100         0     5.1.1.1
                                                             6.1.1.1
                                                             5.1.1.2
6    6.1.1.2        3.0.0.9          OSPF  100         0     6.1.1.1
                                                             7.1.1.1
                                                             6.1.1.2
7    7.1.1.1        12.0.0.7         OSPF  100         0     3.1.1.1
                                                             7.1.1.1
                                                             7.1.1.2
Table 1-18 Description on the fields of the display mpls te cspf tedb command
ID
Number
DR MPLS LSR-Id
MPLS LSR ID of the designated router (DR)
DR-Address
Interface address of the DR
IGP
Interior gateway protocol: OSPF or IS-IS
Process-Id
IGP process ID
Area
Area to which the router belongs
Neighbor
Neighbor router ID
# Display all TEDB information.
<Sysname> display mpls te cspf tedb all
Maximum Node Supported: 512            Maximum Link Supported: 2048
Current Total Node Number: 3            Current Total Link Number: 44
Id     MPLS LSR-Id        IGP      Process-Id     Area            Link-Count
1     1.1.1.1         OSPF    100           1001,1002,1003  20
                                            1004,1005,1006
                                            1007,1008,1009
                                            1010,1,2
                                            13,14,15
                                            16,17,18
                                            19,20
2     2.1.1.1         ISIS    100           Level-1,2       20
3     3.1.1.1         OSPF    100           0               4
Table 1-19 Description on the fields of the display mpls te cspf tedb all command
ID
Number
MPLS LSR-Id
MPLS LSR ID
IGP
Process-Id
IGP process ID
Area
Area to which the device belongs
Link-count
Total number of connected links belonging to a particular IGP protocol process
# Display the TEDB information of IGP area 1.
<Sysname> display mpls te cspf tedb area 1
Router Node Information for Area 1:
1      2.2.2.2        OSPF    100            1               1
2      3.3.3.3        OSPF    100            1               1
3      2.2.2.2        ISIS    100            Level-1         1
4      3.3.3.3        ISIS    100            Level-1         1
Network LSA Information for Area 1:
1    3.3.3.3         20.1.1.2      OSPF 100        1       2.2.2.2
                                                           3.3.3.3
2    3.3.3.3         20.1.1.2      ISIS 100        Level-1 3.3.3.3
                                                           2.2.2.2
Table 1-20 Description on the fields of the display mpls te cspf tedb area command
Id
Number
MPLS LSR-Id
MPLS LSR ID, in dotted decimal notation
IGP
Process-Id
IGP process ID
Area
Link-Count
DR MPLS LSR-Id
MPLS LSR ID of the DR
DR-Address
Neighbor
MPLS LSR ID of the neighbor
# Display the TEDB information of all nodes.
<Sysname> display mpls te cspf tedb node
MPLS LSR-Id: 1.1.1.1
  IGP Type: OSPF   Process Id: 100
  MPLS-TE Link Count: 1
  Link[1] :
    Interface IP Address: 2.0.0.33, 2.0.0.35, 2.0.0.36,
    Neighbor  IP Address: 2.0.0.2, 2.0.0.42, 2.0.0.43,
                          2.0.0.44, 2.0.0.45, 2.0.0.46,
                          2.0.0.47, 2.0.0.32,
    Neighbor  MPLS LSR-Id: 1.1.1.2
    IGP Area: 1
    Link  Type: point-to-point  Link Status: Inactive
    IGP Metric: 100             TE Metric: 100         Color: 0xff
    Maximum Bandwidth: 100 (kbps)
    Maximum Reservable Bandwidth: 20 (kbps)
    Bandwidth Constraints:           Local Overbooking Multiplier:
         BC[0] :  100        (kbps)   LOM[0] :  1
         BC[1] :  20         (kbps)   LOM[1] :  1
    BW Unreserved for Class type 0:
         [0] :    10         (kbps),  [1] :     10         (kbps)
         [2] :    10         (kbps),  [3] :     10         (kbps)
         [4] :    10         (kbps),  [5] :     10         (kbps)
         [6] :    10         (kbps),  [7] :     10         (kbps)
    BW Unreserved for Class type 1:
  IGP Type: ISIS   Process Id: 100
  MPLS-TE Link Count: 2
  Link[1] :
                          2.0.0.47, 2.0.0.32, 2.0.0.33
    IGP Area: Level-1
    Link  Type: point-to-point  Link Status: Active
    IGP Metric: 10              TE Metric: 10          Color: 0x11
    Maximum Reservable Bandwidth: 100 (kbps)
Table 1-21 Description on the fields of the display mpls te cspf tedb node command
MPLS LSR-Id
MPLS LSR ID of node
IGP_Type
IGP type
Process Id
IGP process ID
MPLS-TE Link Count
Number of MPLS TE links
Link[x]
Specific link, with the bracketed x indicating the link number
DR Address
IGP Area
IGP area
Link Type
Link type
Link Status
Link status
IGP Metric
IGP metric of link
TE Metric
TE metric of link
Color
Link administrative attribute
Maximum Bandwidth
Maximum link bandwidth
Maximum reservable bandwidth of link
Bandwidth constraints
BW Unreserved for Class type0
Unreserved bandwidth at the CT0 level
BW Unreserved for Class type1
Unreserved bandwidth at the CT1 level
# Display TEDB information for a specified interface address.
<Sysname> display mpls te cspf tedb interface 20.1.1.1
MPLS LSR-Id: 2.2.2.2
  Link[1] :
    Interface IP Address: 20.1.1.1
    DR Address: 20.1.1.2
    IGP Area: Level-1
    Link  Type: multi-access  Link Status: Active
    IGP Metric: 10              TE Metric: 0           Color: 0x0
    Maximum Bandwidth: 0 (kbps)
    Maximum Reservable Bandwidth: 0 (kbps)
         BC[0] :  0          (kbps)   LOM[0] :  1
         BC[1] :  0          (kbps)   LOM[1] :  1
         [0] :    0          (kbps),  [1] :     0          (kbps)
         [2] :    0          (kbps),  [3] :     0          (kbps)
         [4] :    0          (kbps),  [5] :     0          (kbps)
         [6] :    0          (kbps),  [7] :     0          (kbps)
Table 1-22 Description on the fields of display mpls te cspf tedb interface
MPLS LSR-Id
MPLS LSR ID of node
IGP_Type
IGP type
Process Id
IGP process ID
MPLS-TE Link Count
Link[x]
DR Address
IGP Area
IGP area
Link Type
Link type
Link Status
Link status
IGP Metric
IGP metric of link
TE Metric
TE metric of link
Color
Maximum Bandwidth
display mpls te link-administration admission-control [ interface interface-type interface-number ]
View
Default Level
1: Monitor level
interface interface-type interface-number: Specifies an interface by its type and a number.
Use the display mpls te link-administration admission-control command to display information about CR-LSPs carried on the link of a specified interface or links of all interfaces if no interface is specified.
# Display information about the CR-LSPs carried on the links of all interfaces.
<Sysname> display mpls te link-administration admission-control
LspID           In/Out IF         S/H Prio    CT       BW(kbps)
1.1.1.9:1024    --- / Vlan12      7 /7        0        0
1.1.1.9:2048    --- / Vlan16      7 /7        0        0
Table 1-23 Description on fields of the command
LspID
ID of an LSP carried on a link
In/Out IF
Incoming/Outgoing interface
S/H Prio
Setup and holding priorities of CR-LSP
CT
Service class type
BW(kbps)
Bandwidth (in kbps)
display mpls te link-administration bandwidth-allocation [ interface interface-type interface-number ]
View
Default Level
1: Monitor level
Use the display mpls te link-administration bandwidth-allocation command to display bandwidth allocation on the specified or all MPLS TE enabled interfaces.
# Display bandwidth allocation on MPLS TE enabled interfaces.
<Sysname> display mpls te link-administration bandwidth-allocation
  Link ID:  Vlan-interface12
  Physical Bandwidth Type0   :  0 kbits/sec
  Physical Bandwidth Type1   :  0 kbits/sec
  Reservable Bandwidth Type0 :  0 kbits/sec
  Reservable Bandwidth Type1 :  0 kbits/sec
  Downstream LSP Count       :  0
  UpStream LSP Count         :  0
  Downstream Bandwidth       :  0 kbits/sec
  Upstream Bandwidth         :  0 kbits/sec
  IPUpdown Link Status       :  UP
  PhysicalUpdown Link Status :  UP
  TE CLASS    CLASS TYPE    PRIORITY     BW RESERVED(kbps)    BW AVAILABLE(kbps)
      0           0             0             0                  0
      1           0             1             0                  0
      2           0             2             0                  0
      3           0             3             0                  0
      4           0             4             0                  0
      5           0             5             0                  0
      6           0             6             0                  0
      7           0             7             0                  0
      8           1             0             0                  0
      9           1             1             0                  0
     10           1             2             0                  0
     11           1             3             0                  0
     12           1             4             0                  0
     13           1             5             0                  0
     14           1             6             0                  0
     15           1             7             0                  0
Table 1-24 Description on the fields of the command
Link ID
Link ID
CT0 physical bandwidth
CT1 physical bandwidth
CT0 reservable bandwidth
CT1 reservable bandwidth
Number of downstream LSPs
UpStream LSP Count
Number of upstream LSPs
IP layer link status
Physical layer link status
TE CLASS
TE class
CLASS TYPE
Service class type
PRIORITY
Priority
BW RESERVED
Reserved bandwidth
BW AVAILABLE
Available bandwidth
display mpls te tunnel [ destination dest-addr ] [ lsp-id lsr-id lsp-id ] [ lsr-role { all | egress | ingress | remote | transit } ] [ name name ] [ { incoming-interface | outgoing-interface | interface } interface-type interface-number ] [ verbose ]
View
Default Level
1: Monitor level
destination address: Specifies a destination IP address to display only the tunnels with the specified destination IP address.
lsr-id: LSR ID of the ingress node, in dotted decimal notation.
lsp-id: LSP ID.
lsr-role: Displays tunnels by LSR role (ingress, transit, egress, or remote).
all: Displays all tunnels.
ingress: Displays tunnels created taking current device as the ingress .
transit: Displays tunnels created taking current device as a transit node.
egress: Displays tunnels created taking current device as the egress.
name name: Displays the tunnel with a particular name. This could be configured as interface description or the interface name if no interface description is configured. The tunnel name should be signaled to all hops.
incoming-interface: Displays all tunnels that use the interface identified by the interface-type interface-number arguments as the incoming interface.
outgoing-interface: Displays all tunnels that use the interface identified by the interface-type interface-number arguments as the outgoing interface.
interface: Displays all tunnels that use the interface identified by the interface-type interface-number arguments as the incoming or outgoing interface.
Use the display mpls te tunnel command to display information about MPLS TE tunnels.
# Display information about MPLS TE tunnels.
<Sysname> display mpls te tunnel
LSP-Id            Destination     In/Out-If            Name
1.1.1.9:1024      3.3.3.9         -/Vlan12             Tunnel1/0/1
1.1.1.9:2048      3.3.3.9         -/Vlan14             Tunnel1/0/1
Table 1-25 Description on the fields of the display mpls te tunnel command
LSP-ID
LSP ID of tunnel
Destination
Destination device ID
In/Out-IF
Name
Tunnel name configured on the ingress node
# Display detailed information about MPLS TE tunnels.
<Sysname> display mpls te tunnel verbose
No             : 1
LSP-Id         : 1.1.1.9:1024
Tunnel-Name    : Tunnel1/0/1
Destination    : 3.3.3.9
In-Interface   : -
Out-Interface  : Vlan12
Tunnel BW      : 0 kbps
Class Type     : bc0
Ingress LSR-Id : 1.1.1.9
Egress LSR-Id  : 3.3.3.9
Setup-Priority : 7
Hold-Priority  : 7
Sign-Protocol  : RSVP TE
Resv Style     : SE
IncludeAnyAff  : 0x0
ExcludeAllAff  : 0x0
IncludeAllAff  : 0x0
Created Time   : 2004/10/18 16:05:17
Table 1-26 Description on the fields of the display mpls te tunnel verbose command
No
Number
LSP-Id
LSP ID of tunnel
Tunnel-Name
Destination
In-Interface
Incoming interface
Out-Interface
Outgoing interface
Tunnel BW
Tunnel bandwidth
Class Type
Service class type
Ingress LSR-Id
Ingress LSR ID
Setup-Priority
Setup priority of link
Hold-Priority
Holding priority of link
Sign-Protocol
Signaling protocol
Resv Style
Reservation style
IncludeAnyAff
Any affinity properties that must be included
ExcludeAllAff
Link properties that are excluded
IncludeAllAff
All link affinity properties that must be included
Created Time
Time when the tunnel was created
display mpls te tunnel path [ tunnel-name tunnel-name ] [ lsp-id lsr-id lsp-id ]
View
Default Level
1: Monitor level
tunnel-name tunnel-name: Tunnel name.
lsr-id: Ingress LSR ID, in dotted decimal notation.
lsp-id: LSP ID.
Use the display mpls te tunnel path command to display the path or paths that the specified or all MPLS TE tunnels traverse on this node.
# Display the paths that all MPLS TE tunnels traverse.
<Sysname> display mpls te tunnel path
Tunnel Interface Name Tunnel0/0/0:
Lsp ID :  1.1.1.9:10
Hop information:
Hop 0: 192.1.1.1
Hop 1: 12.1.1.2
Hop 2: 10.202.2.2.
Table 1-27 Description on the fields of the display mpls te tunnel path command
Tunnel interface name, Tunnel0/0/0 in this sample output
Lsp ID
LSP ID
Hop 0
Hop 0 on the path
Hop 1
Hop 1 on the path
Hop 2
Hop 2 on the path
View
Default Level
1: Monitor level
None
Use the display mpls te tunnel statistics command to display statistics about MPLS TE tunnels.
# Display statistics about MPLS TE tunnels.
<Sysname> display mpls te tunnel statistics
Ingress:   0 Tunnels,    0 Tunnels Up,    0 CRLSPs Up
           0 Modified,   0 In-Progress,   0 Failed
Transit:   0 Up
Egress :   0 Up
Table 1-28 Description on the fields of display mpls te tunnel statistics
Ingress
This device is the tunnel ingress.
Modified
Number of CR-LSP tunnels that use this device as the ingress and are in modified state.
In-Progress
Number of CR-LSP tunnels that use this device as the ingress and are in in-progress state.
Failed
Number of CR-LSP tunnels that use this device as the ingress and are in failed state.
Transit
This device is a transit node on the tunnel.
Egress
This device is the tunnel egress.
display mpls te tunnel-interface [ tunnel number ]
View
Default Level
1: Monitor level
number: Tunnel interface number, in the format slot number/sub-slot number/Tunnel interface number.
Use the display mpls te tunnel-interface command to display information about MPLS TE tunnel interfaces on this node.
# Display information about MPLS TE tunnel interfaces on this node.
<Sysname> display mpls te tunnel-interface
  Tunnel Name         :  Tunnel5/0/2
  Tunnel Desc         :  Tunnel5/0/2 Interface
  Tunnel State Desc   :  CR-LSP is Up
  Tunnel Attributes   :
    LSP ID              :  3.3.3.3:4
    Session ID          :  1
    Admin State         :  UP                    Oper State   :  UP
    Ingress LSR ID      :  3.3.3.3               Egress LSR ID:  4.4.4.4
    Signaling Prot      :  RSVP                  Resv Style   :  SE
    Class Type          :  CLASS 0               Tunnel BW    :  0 kbps
    Reserved BW         :  0 kbps
    Setup Priority      :  7                     Hold Priority:  7
    Affinity Prop/Mask  :  0x0/0x0
    Explicit Path Name  :  -
    Tie-Breaking Policy :  None
    Metric Type         :  None
    Loop Detection      :  Disabled
    Record Route        :  Enabled               Record Label :  Enabled
    FRR Flag            :  Enabled               BackUpBW Flag:  Not Supported
    BackUpBW Type       :  -                     BackUpBW     :  -
    Route Pinning       :  Disabled
    Retry Limit         :  5                     Retry Interval:  10 sec
    Reopt               :  Disabled              Reopt Freq   :  -
    Back Up Type        :  None
    Back Up LSPID       :  -
    Auto BW             :  Disabled              Auto BW Freq :  -
    Min BW              :  -                     Max BW       :  -
    Current Collected BW:  -
    Interfaces Protected:  -
    VPN Bind Type       :  NONE
    VPN Bind Value      :  -
    Car Policy          :  Disabled
Table 1-29 Description on the fields of display mpls te tunnel-interface command
Tunnel Name
Tunnel name
Tunnel Desc
Tunnel description
Tunnel State Desc
Tunnel state description
LSP ID
LSP ID
Session ID
Session ID
Admin State
Administrative state
Oper State
Operation state
Ingress LSR ID
Ingress LSR ID
Egress LSR ID
Egress LSR ID
Signaling Prot
Signaling protocol
Resv Style
Reservation style
Class Type
Service class type
Tunnel BW
Tunnel bandwidth
Setup Priority
Setup priority of LSP
Hold Priority
Hold priority of LSP
Affinity Prop/Mask
Affinity attribute and mask
Explicit Path Name
Explicit path name
Tie-Breaking Policy
Path selection policy
Metric Type
Metric type
Loop Detection
Whether loop detection is enabled
Record Route
State of the route recording function
Record Label
State of the label recording function
FRR Flag
Fast reroute (FRR) flag
BackUpBW Flag
Backup bandwidth flag
BackUpBW Type
Backup bandwidth type
BackUpBW
Backup bandwidth
Route Pinning
Route pinning function
Retry Limit
Maximum number of setup retries
Retry Interval
Retry interval
Reopt
State of the reoptimization function
Reopt Freq
Reoptimization interval
Back Up Type
Backup path type
Back Up LSPID
Backup LSP ID
Auto BW
State of the automatic bandwidth adjustment function
Auto BW Freq
Automatic bandwidth adjustment interval
Min BW
Lower limit for automatic bandwidth adjustment
Max BW
Upper limit for automatic bandwidth adjustment
Bandwidth information currently collected
FRR protected interfaces
VPN Bind Type
Type of the binding, VPN or ACL
VPN Bind Value
Value of the binding, the VPN instance name or ACL number
Car Policy
Whether CAR policy is enabled
display ospf [ process-id ] mpls-te [ area area-id ] [ self-originated ]
View
Default Level
1: Monitor level
process-id: OSPF process ID. If a process is specified, only the TE LSAs of this process are displayed; if no process is specified, the TE LSAs of all processes are displayed.
area area-id: Displays the TE LSAs of a specified OSPF area, in the form of an integer or an IPv4 address.
self-originated: Displays self originated TE LSAs.
Use the display ospf mpls-te command to display TE LSAs in the link state database (LSDB).
Example
# Display all TE LSAs in the LSDB.
<Sysname> display ospf mpls-te
 Area ID                   : 0.0.0.0
 Traffic Engineering LSA's of the database
 LSA [ 1 ]
   LSA  Type                : Opq-Area
   Opaque Type              : 1
   Opaque ID                : 4
   Advertising Router ID    : 4.4.4.4
   LSA  Age                 : 208
   Length                   : 200
   LSA  Options             : E O
   LS Seq Number            : 8000001A
   CheckSum                 : 1EB7
   Link Type                : MultiAccess
   Link ID                  : 34.1.1.2
   Local Interface Address  : 34.1.1.2
   Remote Interface Address : 0.0.0.0
   TE Metric                : 1
   Maximum Bandwidth        : 1250000 bytes/sec
   Maximum Reservable BW    : 625000 bytes/sec
   Admin Group              : 0X0
   Global Pool:
       Unreserved BW [ 0] =625000  bytes/sec
       Unreserved BW [ 1] =625000  bytes/sec
       Unreserved BW [ 2] =625000  bytes/sec
       Unreserved BW [ 3] =625000  bytes/sec
       Unreserved BW [ 4] =625000  bytes/sec
       Unreserved BW [ 5] =625000  bytes/sec
       Unreserved BW [ 6] =625000  bytes/sec
       Unreserved BW [ 7] =625000  bytes/sec
   Sub Pool :
       Unreserved BW [ 8] =   0  bytes/sec
       Unreserved BW [ 9] =   0  bytes/sec
       Unreserved BW [10] =   0  bytes/sec
       Unreserved BW [11] =   0  bytes/sec
       Unreserved BW [12] =   0  bytes/sec
       Unreserved BW [13] =   0  bytes/sec
       Unreserved BW [14] =   0  bytes/sec
       Unreserved BW [15] =   0  bytes/sec
       BC [ 0] =625000 bytes/sec  BC [ 1] =   0 bytes/sec
   Local OverBooking Multipliers:
       LOM [ 0] =   1     LOM [ 1] =   1
 LSA [ 2 ]
   LSA  Type                : Opq-Area
   Opaque Type              : 1
   Opaque ID                : 0
   LSA  Age                 : 762
   Length                   : 28
   LSA  Options             : E O
   LS Seq Number            : 800000AF
   CheckSum                 : 73A
   MPLS TE Router ID        : 4.4.4.4
Table 1-30 Description on the fields of the display ospf mpls-te command
Area ID
TE enabled OSPF area ID.
LSA Type
LSA type which must be Opd-Area, carried in the Opaque LSA header
Opaque Type
1 for TE, carried in the header of Opaque LSA
Opaque ID
Opaque ID, carried in the header of Opaque LSA
Router ID of the node where the LSA was generated
LSA Age
LSA age, carried in  the header of Opaque LSA
Length
LSA length, carried in the header of Opaque LSA
LSA Options
LSA options, carried in the header of Opaque LSA
LS Seq Number
LSA sequence number, carried in the header of Opaque LSA
Checksum
LSA checksum, carried in the header of Opaque LSA
Link Type
Link type: point to point, point to multipoint, or multiAccess
Link ID
Link ID
Local interface address
Remote interface address
TE Metric
TE metric
Maximum bandwidth
Maximum bandwidth
Admin Group
Administrative group attribute
Global Pool
Global pool
Unreserved BW [0] to [7]
Available bandwidths at the eight levels in the global pool
Sub Pool
Subpool (only significant for DS-TE LSAs)
Available bandwidths at the eight levels in the subpool
Bandwidth constraints (only significant for DS-TE LSAs)
BC 0–1
Two types of bandwidth constraints (only significant for DS-TE LSAs): BC0 and BC1
Local Overbooking Multipliers
Local overbooking multipliers
LOM 0-1
Two local overbooking multipliers (only significant for DS-TE LSAs): LOM 0 and LOM 1
MPLS TE Router ID
Router ID of the MPLS TE device
display ospf [ process-id ] traffic-adjustment
View
Default Level
1: Monitor level
Use the display ospf traffic-adjustment command to display the settings of tunnel traffic adjustment (IGP shortcut and forwarding adjacency) for a specified or all OSPF processes.
# Display the settings of tunnel traffic adjustment for all OSPF processes.
<Sysname> display ospf traffic-adjustment
                  Traffic Adjustment
 Interface: 8.1.1.1 (Tunnel5/0/2)
     Type: Forwarding Adjacency  State: Up
     Neighbor ID: 100.0.0.2   Cost: 1562
     Configuration:
     Neighbor Ip Address: 100.0.0.2
     Cost               : 1562
     Cost Type          : Relative
     Hold time          : 10ms
Table 1-31 Description on the fields of the display ospf traffic-adjustment command
Tunnel interface address and name
Approach to automatic route advertisement: IGP shortcut or forwarding adjacency
Neighbor ID
Remote neighbor ID
Cost
Cost
State: up or down
Neighbor Ip Address
Neighbor IP address
Cost Type
Cost type
Hold time
Hold time
display tunnel-info { tunnel-id | all | statistics }
View
Default Level
1: Monitor level
tunnel-id: Specifies a tunnel ID. If a tunnel is specified, only information about this tunnel will be displayed.
all: Display information about all tunnels.
statistics: Displays statistics about tunnels.
Use the display tunnel-info command to display information about tunnels.
# Display information about all tunnels.
<Sysname> display tunnel-info all
Tunnel ID           Type              Destination
0x1100002           cr lsp               2.2.2.2
# Display statistics about tunnels.
<Sysname> display tunnel-info statistics
Tunnel Allocation Method :    GLOBAL
Avail Tunnel ID Value :       65535
Total Tunnel ID Allocated :   1
LSP :                         1
GRE :                         0
CRLSP :                       0
LOCAL IFNET :                 0
MPLS LOCAL IFNET :            0
Table 1-32 Description on the fields of the display tunnel-info statistics command
The way that tunnels are allocated
Available tunnel ID
Total number of tunnel IDs that have been allocated
LSP
Number of LSP tunnels
GRE
Number of GRE tunnels
CRLSP
LOCAL IFNET
Number of CE-side interfaces in MPLS L2VPN
MPLS LOCAL IFNET
Number of outgoing interfaces in CCC remote mode in MPLS L2VPN
undo enable traffic-adjustment
View
OSPF view
Default Level
2: System level
None
Use the enable traffic-adjustment command to enable IGP shortcut.
Use the undo enable traffic-adjustment command to disable IGP shortcut.
By default, IGP shortcut is disabled.
IGP shortcut allows OSPF to include static LSP tunnels in SPF calculation and advertise them to OSPF neighbors.
# Enable IGP shortcut.
[Sysname] ospf 100
[Sysname-ospf-100] enable traffic-adjustment
undo enable traffic-adjustment advertise
View
OSPF view
Default Level
2: System level
None
Use the enable traffic-adjustment advertise command to enable forwarding adjacency.
Use the undo enable traffic-adjustment advertise command to disable forwarding adjacency.
By default, forwarding adjacency is disabled.
Forwarding adjacency allows OSPF to include static LSP tunnels in SPF calculation but not advertise them to OSPF neighbors.
# Enable forwarding adjacency.
[Sysname] ospf 100
[Sysname-ospf-100] enable traffic-adjustment advertise
explicit-path pathname [ enable | disable ]
undo explicit-path pathname
View
Default Level
2: System level
pathname: Name of an explicit path for a tunnel.
enable: Enables explicit routing.
disable: Disables explicit routing.
Use the explicit-path command to create an explicit path and enter its view.
Use the undo explicit-path command to remove an explicit path.
# Create an explicit path named path1 and enter its view.
1.1.36  list hop
list hop [ ip-address ]
View
Explicit path view
Default Level
2: System level
ip-address: Specifies the IP address of a node on the explicit path. If no IP address is specified, information about all the nodes on the explicit path is displayed.
Use the list hop command to display information about specified or all nodes on the explicit path.
# Display information about all nodes on an MPLS TE explicit path.
[Sysname-explicit-path-path1] list hop
Path Name :  path1        Path Status :  Enabled
1             1.1.1.9          Strict     Include
2             2.2.2.9          Strict     Exclude
1.1.37  modify hop
modify hop ip-address1 ip-address2 [ include [ strict | loose ] | exclude ]
View
Explicit path view
Default Level
2: System level
ip-address1 ip-address2: Substitutes the IP address specified by the ip-address2 argument for the IP address specified by the ip-address1 argument in the explicit path. The specified IP addresses could be link IP addresses or router IDs of nodes.
include: Includes the IP address specified by the ip-address2 argument on the explicit path.
exclude: Excludes the IP address specified by the ip-address2 argument from subsequent path calculations.
Use the modify hop command to change the IP address of a node on the explicit path.
By default, the changed IP address is included on the explicit path and its next hop is a strict node.
# Replace IP address 10.0.0.125 on explicit path named p1 with IP address 10.0.0.200 and exclude this new IP address from subsequent path calculations.
[Sysname-explicit-path-p1] modify hop 10.0.0.125 10.0.0.200 exclude
1.1.38  mpls rsvp-te
mpls rsvp-te
undo mpls rsvp-te
View
MPLS view, VLAN interface view, POS interface view
Default Level
2: System level
None
Use the mpls rsvp-te command to enable RSVP-TE.
Use the undo mpls rsvp-te command to disable RSVP-TE.
By default, RSVP-TE is disabled.
You must enable RSVP-TE before you can configure other RSVP-TE features.
Before enabling RSVP-TE, enable MPLS and MPLS TE in both system view and interface view.
Disabling RSVP-TE in MPLS view disables RSVP-TE on interfaces.
# Enable RSVP-TE on current node.
[Sysname] mpls
 Mpls starting, please wait... OK!
[Sysname-mpls] mpls te
Mpls te starting, please wait... OK!
[Sysname-mpls] mpls rsvp-te
# Enable RSVP-TE on interface VLAN-interface 12.
[Sysname] interface vlan-interface 12
[Sysname-Vlan-interface12] mpls rsvp-te
# Disable RSVP-TE on VLAN-interface 12.
[Sysname-Vlan-interface12] undo mpls rsvp-te
1.1.39  mpls rsvp-te authentication
mpls rsvp-te authentication { cipher | plain } auth-key
undo mpls rsvp-te authentication
View
Interface view
Default Level
2: System level
cipher: Indicates that the specified authentication key is a cipher-text key.
plain: Indicates that the specified authentication key is a plain-text key.
auth-key: Authentication key, case sensitive. Input in plain text, the string for it is 8 to 16 characters in length; input in cipher text, the string for it is 24 characters in length. If the plain keyword is specified, it can only be input in plain text. If the cipher keyword is specified, it can be input in both plain text or in cipher text.
Use the mpls rsvp-te authentication command to enable RSVP message authentication on the interface.
Use the undo mpls rsvp-te authentication command to disable RSVP message authentication on the interface.
The RSVP messages sent out of the interface convey a message authentication digest created using the hash algorithm and the configured authentication key. This authentication key also used by the interface to authenticate received RSVP messages. For the two interfaces at the two ends of a link to exchange RSVP messages, they must share the same authentication key.
This hop-by-hop authentication of RSVP is to prevent fake resource reservation requests from occupying network resources.
&  Note:
RSVP-TE supports only authentication on a direct link of the device.
# Enable authentication on VLAN-interface 1.
[Sysname-Vlan-interface1] mpls rsvp-te authentication plain partner123
1.1.40  mpls rsvp-te blockade-multiplier
mpls rsvp-te blockade-multiplier number
undo mpls rsvp-te blockade-multiplier
View
MPLS view
Default Level
2: System level
number: Blockade multiplier.
Use the mpls rsvp-te blockade-multiplier command to configure the blockade multiplier.
Use the undo mpls rsvp-te blockade-multiplier command to restore the default.
The default blockade multiplier is 4.
A ResvErr message establishes blockade state in each node through which it passes to solve the killer reservation problem where one request could deny service to another. The use of blockade state allows a smaller request to be forwarded or established.
The blockade timeout time is determined by the following equation:
Blockade_Expired_Time = Kb × refresh-time
Where, Kb is the blockade multiplier, and refresh-time is the refresh interval for reservation state.
Upon expiration of the blockade timeout time, the blockade state on the node is removed.
Before you can configure this command, enable RSVP-TE.
Related commands: mpls rsvp-te timer refresh.
# Set the blockade multiplier to five.
[Sysname] mpls
[Sysname-mpls] mpls rsvp-te blockade-multiplier 5
1.1.41  mpls rsvp-te hello
mpls rsvp-te hello
undo mpls rsvp-te hello
View
Default Level
2: System level
None
Use the mpls rsvp-te hello command to enable RSVP hello extension.
Use the undo mpls rsvp-te hello command to disable RSVP hello extension.
RSVP-TE uses the hello mechanism to detect whether an RSVP neighbor is still alive.
By default, RSVP hello extension is disabled.
Before you can enable RSVP hello extension in interface view, enable RSVP-TE in interface view and RSVP hello extension in MPLS view.
# Enable RSVP hello extension in MPLS view.
[Sysname] mpls
[Sysname-mpls] mpls rsvp-te hello
# Enable RSVP hello extension on VLAN-interface 1.
[Sysname-Vlan-interface1] mpls rsvp-te hello
1.1.42  mpls rsvp-te hello-lost
mpls rsvp-te hello-lost times
undo mpls rsvp-te hello-lost
View
MPLS view
Default Level
2: System level
times: Maximum number of consecutive hello losses before an RSVP neighbor is considered dead.
Use the mpls rsvp-te hello-lost command to configure the maximum number of consecutive hello losses before an RSVP neighbor is considered dead.
Use the undo mpls rsvp-te hello-lost command to restore the default.
By default, the RSVP node considers an RSVP neighbor is dead if no response is received after sending three consecutive hellos.
An RSVP node detects whether its RSVP neighbor is still alive by sending hellos regularly. If no response is received after the number of consecutive hellos reaches the specified limit, the RSVP node considers its RSVP neighbor as dead. The failure is handled the same as a link layer communication failure.
Related commands: mpls rsvp-te timer hello.
# Set the maximum number of consecutive hello losses before an RSVP neighbor is considered dead to five.
[Sysname] mpls
[Sysname-mpls] mpls rsvp-te hello-lost 5
1.1.43  mpls rsvp-te keep-multiplier
mpls rsvp-te keep-multiplier number
undo mpls rsvp-te keep-multiplier
View
MPLS view
Default Level
2: System level
number: Keep multiplier.
Use the mpls rsvp-te keep-multiplier command to configure the keep multiplier for the path state block (PSB) and reservation state block (RSB).
Use the undo mpls rsvp-te keep-multiplier command to restore default.
The default keep multiplier is 3.
The following equation determines the timeout time of the state stored in PSB and RSB:
Expired_Time = (keep-multiplier + 0.5) × 1.5 × refresh-time
Where, refresh-time is the refresh interval for reservation state set by the mpls rsvp-te timer refresh command.
Before you can configure the keep multiplier, enable RSVP-TE.
# Set the keep multiplier to five.
[Sysname] mpls
[Sysname-mpls] mpls rsvp-te keep-multiplier 5
1.1.44  mpls rsvp-te reliability
undo mpls rsvp-te reliability
View
Interface view
Default Level
2: System level
None
Use the mpls rsvp-te reliability command to enable the reliability mechanism of RSVP-TE, that is, the Message_ID extension mechanism.
Use the undo mpls rsvp-te reliability command to disable the reliability mechanism.
# Enable the reliability mechanism of RSVP-TE on VLAN-interface 1.
[Sysname-Vlan-interface1] mpls rsvp-te reliability
1.1.45  mpls rsvp-te resvconfirm
undo mpls rsvp-te resvconfirm
View
MPLS view
Default Level
2: System level
None
Use the mpls rsvp-te resvconfirm command to enable reservation confirmation on current node.
Use the undo mpls rsvp-te resvconfirm command to disable reservation confirmation.
By default, resource reservation confirmation is disabled.
After the mpls rsvp-te resvconfirm command is configured, resource reservation requests will be confirmed.
# Enable reservation confirmation on your device.
[Sysname] mpls
[Sysname-mpls] mpls rsvp-te resvconfirm
1.1.46  mpls rsvp-te srefresh
undo mpls rsvp-te srefresh
View
Interface view
Default Level
2: System level
None
Use the mpls rsvp-te srefresh command to enable summary refresh.
Use the undo mpls rsvp-te srefresh command to restore the default.
By default, summary refresh is disabled.
Summary refresh (Srefresh) messages refresh path state and reservation state. Enabling summary refresh disables conventional time-driven state refresh.
# Enable summary refresh on VLAN-interface 1.
[Sysname-Vlan-interface1] mpls rsvp-te srefresh
1.1.47  mpls rsvp-te timer hello
mpls rsvp-te timer hello timevalue
undo mpls rsvp-te timer hello
View
MPLS view
Default Level
2: System level
timevalue: Hello interval, in seconds.
Use the mpls rsvp-te timer hello command to configure the hello interval.
Use the undo mpls rsvp-te timer hello command to restore the default.
The default hello interval is three seconds.
Before configuring this command, enable the hello mechanism in MPLS view.
Related commands: mpls rsvp-te hello, mpls rsvp-te hello-lost.
# Set the hello interval to five seconds.
[Sysname] mpls
[Sysname-mpls] mpls rsvp-te timer hello 5
1.1.48  mpls rsvp-te timer refresh
mpls rsvp-te timer refresh timevalue
undo mpls rsvp-te timer refresh
View
MPLS view
Default Level
2: System level
timevalue: Refresh interval, in seconds.
Use the mpls rsvp-te timer refresh command to configure the path/reservation state refresh interval.
Use the undo mpls rsvp-te timer refresh command to restore the default.
Be sure to enable RSVP-TE before issuing the mpls rsvp-te timer refresh command.
The default path/reservation state refresh interval is 30 seconds.
Related commands: mpls rsvp-te keep-multiplier.
# Set the path/reservation state refresh interval to 60 seconds.
[Sysname] mpls
[Sysname-mpls] mpls rsvp-te timer refresh 60
1.1.49  mpls rsvp-te timer retransmission
mpls rsvp-te timer retransmission { increment-value [ increment-value ] | retransmit-value [ retrans-timer-value ] } *
undo mpls rsvp-te timer retransmission
View
Interface view
Default Level
2: System level
increment-value increment-value: Increment value delta. The default is 1.
retransmit-value retrans-timer-value: Initial retransmission interval, in milliseconds. The default is 500 milliseconds.
Use the mpls rsvp-te timer retransmission command to enable RSVP message retransmission.
Use the undo mpls rsvp-te timer retransmission command to restore the default.
By default, RSVP message retransmission is disabled.
On an interface enabled with the Message_ID (reliability) mechanism, you may configure RSVP message retransmission. After the interface sends an RSVP message, it waits for an acknowledgement. If no ACK is received before the initial retransmission interval (Rf seconds for example) expires, the interface resends the message. After that, the interface resends the message at an exponentially increased retransmission interval equivalent to (1 + Delta) × Rf seconds either until an acknowledgement is received or the retransmission attempt limit RI is reached. The Delta governs the speed with which the interface increases the retransmission interval.
# Enable RSVP message retransmission on VLAN-interface 1, setting the increment value delta to 2 and the initial retransmission interval to 1000 milliseconds.
[Sysname-Vlan-interface1] mpls rsvp-te timer retransmission increment-value 2 retransmit-value 1000
1.1.50  mpls te
mpls te
undo mpls te
View
MPLS view, interface view
Default Level
2: System level
None
Use the mpls te command to enable MPLS TE.
Use the undo mpls te command to disable MPLS TE.
By default, MPLS TE is disabled.
When performed in MPLS view, the mpls te command enables MPLS TE globally and its undo form disables MPLS TE and removes all CR-LSPs.
When performed in interface view, the mpls te command enables MPLS TE on an interface and its undo form disables MPLS TE and removes all CR-LSPs on the interface.
Before you can enable MPLS TE on an interface, enable MPLS TE globally first.
  Caution:
After changing the MTU of an interface where MPLS TE is enabled, you need to perform the shutdown command and then the undo shutdown command to refresh the TE tunnels on it.
# Enable MPLS TE globally in MPLS view.
[Sysname] mpls lsr-id 1.1.1.9
[Sysname] mpls
# Enable MPLS TE on VLAN-interface 1.
[Sysname-Vlan-interface1] mpls te
1.1.51  mpls te affinity property
mpls te affinity property properties [ mask mask-value ]
undo mpls te affinity property
View
Tunnel interface view
Default Level
2: System level
properties: Link properties affinity attribute of the tunnel, a 32-bit integer. Each affinity bit represents a property with a value of 1 or 0.
mask-value: 32-bit mask comprising 0s and 1s. This mask is used when ANDing the link affinity attribute with the link administrative group attribute.
Use the mpls te affinity property command to configure the link affinity attribute of the tunnel.
Use the undo mpls te affinity property command to restore the default.
The default affinity attribute of the tunnel is 0x00000000 and the mask is 0x00000000.
The affinity attribute of an MPLS TE tunnel identifies the properties of the links that the tunnel can use.
Related commands: mpls te link administrative group.
# Configure the link affinity attribute of Tunnel 3/0/1.
[Sysname] interface Tunnel 3/0/1
[Sysname-Tunnel3/0/1] mpls te affinity property 101 mask 303
1.1.52  mpls te backup
mpls te backup { hot-standby | ordinary }
undo mpls te backup
View
Default Level
2: System level
hot-standby: Sets the backup mode to hot backup for the tunnel.
ordinary: Sets the backup mode to ordinary backup for the tunnel.
Use the mpls te backup command to set the backup mode on the tunnel.
Use the undo mpls te backup command to restore the default.
By default, tunnel backup is disabled.
&  Note:
l      With backup enabled, the record route flag is automatically set to record reroute regardless of whether the mpls te record-route command is configured.
l      The backup function cannot be used together with these commands: mpls te reoptimization and mpls te resv-style ff.
# Enable hot backup on tunnel 3/0/1.
[Sysname-Tunnel3/0/1] mpls te backup hot-standby
1.1.53  mpls te backup bandwidth
mpls te backup bandwidth { bandwidth | { bc0 | bc1 } { bandwidth | un-limited } }
undo mpls te backup bandwidth
View
Default Level
2: System level
bandwidth: Total bandwidth that the bypass tunnel (also called the protection tunnel) can protect, in kbps.
bc0: Indicates that only the LSPs using BC0 bandwidth (global bandwidth) can use the bypass tunnel.
bc1: Indicates that only the LSPs using BC1 bandwidth (subpool bandwidth) can use the bypass tunnel.
If neither BC0 nor BC1 is specified, all LSPs can use the bypass tunnel.
un-limited: Puts on limit on total protected bandwidth.
Use the mpls te backup bandwidth command to configure the total bandwidth and type of LSP that the bypass tunnel can protect.
Use the undo mpls te backup bandwidth command to remove the configuration.
By default, bypass tunnels do not protect bandwidth.
If neither BC0 nor BC1 is specified, all LSP can use the bypass tunnel.
# Tunnel 3/0/1 provides protection for LSPs using BC0 bandwidth without protecting bandwidth. Tunnel 3/0/2 provides protection for LSPs using BC1 bandwidth and it can protect 1000 kbps bandwidth.
[Sysname-Tunnel3/0/1] mpls te backup bandwidth bc0 un-limited
[Sysname-Tunnel3/0/1] quit
[Sysname] interface Tunnel 3/0/2
[Sysname-Tunnel3/0/2] mpls te backup bandwidth bc1 1000
1.1.54  mpls te bandwidth
mpls te bandwidth [ bc1 | bc0 ] bandwidth
undo mpls te bandwidth
View
Default Level
2: System level
bc1: Obtains bandwidth from BC1.
bc0: Obtains bandwidth from BC0.
bandwidth: Bandwidth needed by the MPLS TE tunnel, in kbps.
Use the mpls te bandwidth command to assign bandwidth to the MPLS TE tunnel.
Use the undo mpls te bandwidth command to restore the default.
By default, no bandwidth is assigned to MPLS TE tunnels.
If neither the bc1 keyword nor the bc0 keyword is specified, bandwidth is assigned using the global bandwidth pool (BC0).
# Assign 1000 kbps bandwidth to MPLS TE tunnel 3/0/1.
[Sysname-Tunnel3/0/1] mpls te bandwidth 1000
1.1.55  mpls te bandwidth change thresholds
mpls te bandwidth change thresholds { down | up } percent
undo mpls te bandwidth change thresholds { down | up }
View
Interface view
Default Level
2: System level
down: Sets the threshold in percentages for IGP to flood when the bandwidth is decreasing. When the percentage of available bandwidth decrease exceeds the threshold, the change is flooded and the traffic engineering database (TEDB) is updated.
up: Sets the IGP flooding threshold in percentages that applies when the bandwidth is increasing. When the percentage of available bandwidth increase exceeds the threshold, the change is flooded and the TEDB is updated.
percent: IGP flooding threshold in percentages.
Use the mpls te bandwidth change thresholds command to set the IGP flooding thresholds that apply when bandwidth resources are increasing and decreasing.
Use the undo mpls te bandwidth change thresholds command to restore the default.
The default IGP flooding thresholds in both up and down directions are 10.
# On VLAN-interface 1 configure IGP to flood when the percentage of available bandwidth decrease reaches 100%.
[Sysname-Vlan-interface1] mpls te bandwidth change thresholds down 100
1.1.56  mpls te commit
mpls te commit
View
Default Level
2: System level
None
Use the mpls te commit command to submit current MPLS TE tunnel configuration.
The MPLS TE tunnel configuration you made can take effect only after you perform this command.
# Configure an MPLS TE tunnel and submit the configuration.
[Sysname] interface tunnel 3/0/0
[Sysname-Tunnel3/0/0] tunnel-protocol mpls te
[Sysname-Tunnel3/0/0] destination 2.2.2.9
[Sysname-Tunnel3/0/0] mpls te commit
1.1.57  mpls te cspf
mpls te cspf
undo mpls te cspf
View
MPLS view
Default Level
1: Monitor level
None
Use the mpls te cspf command to enable CSPF on current node.
Use the undo mpls te cspf command to disable CSPF on current node.
By default, CSPF is disabled on current node.
Before enabling CSPF, enable MPLS TE in MPLS view.
CSPF provides an approach to path selection in MPLS domains. You must enable CSPF before configuring other CSPF related functions.
# Enable CSPF.
[Sysname] mpls
[Sysname-mpls] mpls te cspf
1.1.58  mpls te cspf timer failed-link
mpls te cspf timer failed-link timer-interval
undo mpls te cspf timer failed-link
View
MPLS view
Default Level
1: Monitor level
timer-interval: Failed link timer setting, in seconds. The default is 10 seconds.
Use the mpls te cspf timer failed-link command to configure the failed link timer.
Use the undo mpls te cspf timer failed-link command to restore the default.
Related commands: mpls te cspf.
# Set the failed link timer to 50 seconds.
[Sysname] mpls
[Sysname-mpls] mpls te cspf timer failed-link 50
1.1.59  mpls te fast-reroute
undo mpls te fast-reroute
View
Default Level
2: System level
None
Use the mpls te fast-reroute command to enable fast reroute (FRR).
Use the undo mpls te fast-reroute command to disable FRR.
By default, FRR is disabled.
After FRR is enabled, the record route flag is automatically set to record reroute with label whether the mpls te record-route label command is configured or not.
Disable FRR before configuring the mpls te record-route command or its undo form.
&  Note:
Fast reroute cannot be used together with the mpls te resv-style ff command.
# Reroute MPLS TE tunnel 0 to an available bypass tunnel in case the protected link or node that it traverses fails.
[Sysname-Tunnel3/0/1] mpls te fast-reroute
1.1.60  mpls te fast-reroute bypass-tunnel
mpls te fast-reroute bypass-tunnel tunnel tunnel-number
undo mpls te fast-reroute bypass-tunnel tunnel tunnel-number
View
Interface view
Default Level
2: System level
tunnel-number: Bypass tunnel number.
Use the mpls te fast-reroute bypass-tunnel command to specify a bypass tunnel for the protected interface.
Use the undo mpls te fast-reroute bypass-tunnel command to remove the specified bypass tunnel.
You may perform the mpls te fast-reroute bypass-tunnel command multiple times to specify multiple bypass tunnels for the protected interface. At present, a maximum of three bypass tunnels can be specified for a protected interface.
When specifying a bypass tunnel, consider the following:
l           The state of the tunnel must be up.
l           The protected interface is not the outgoing interface in the route entries for the LSP of the bypass tunnel.
&  Note:
A bypass tunnel cannot be used for services such as VPN at the same time.
# Use Tunnel 3/0/2 as the bypass tunnel to protect the link connected to VLAN-interface 1.
[Sysname-Vlan-interface1] mpls te fast-reroute bypass-tunnel tunnel 3/0/2
1.1.61  mpls te igp advertise
mpls te igp advertise [ hold-time value ]
undo mpls te igp advertise
 View
Default Level
2: System level
hold-time value: Sets the delay that IGP waits to notify IGP neighbors of the down event of the TE tunnel. It is in milliseconds. The default is 0 milliseconds.
Use the mpls te igp advertise command to enable IGP to advertise the MPLS TE tunnel as a link to IGP neighbors.
Use the undo mpls te igp advertise command to remove the configuration.
By default, IGP does not advertise MPLS TE tunnels to IGP neighbors.
&  Note:
The mpls te igp advertise command cannot be used together with the mpls te igp shortcut command.
# Set the hold time to 10000 milliseconds.
[Sysname] interface Tunnel 3/0/0
[Sysname-Tunnel3/0/0] mpls te igp advertise hold-time 10000
1.1.62  mpls te igp metric
mpls te igp metric { absolute value | relative value }
undo mpls te igp metric
View
Default Level
2: System level
absolute value: Assigns an absolute metric to the TE tunnel for path calculation. The value argument is an integer. This value is directly used for path calculation.
relative value: Assigns a relative metric to the TE tunnel for path calculation. The value argument is an integer. The default is 0. The cost of the corresponding IGP path must be added to this relative metric before it can be used for path calculation.
Use the mpls te igp metric command to assign a metric to the MPLS TE tunnel.
Use the undo mpls te igp metric command to restore the default.
By default, TE tunnels take their IGP metrics.
# Assign MPLS TE tunnel 0 a relative metric of –1 for enhanced SPF calculation in IGP.
[Sysname-Tunnel3/0/0] mpls te igp metric relative -1
1.1.63  mpls te igp shortcut
mpls te igp shortcut [ is-is | ospf ]
undo mpls te igp shortcut
View
Default Level
2: System level
is-is: Sets the IGP protocol to IS-IS.
ospf: Sets the IGP protocol to OSPF.
Use the mpls te igp shortcut command to enable IS-IS or OSPF to consider the MPLS TE tunnel in its enhanced SPF calculation when the tunnel is up. If no IGP protocol is specified, the command applies to both OSPF and IS-IS.
Use the undo mpls te igp shortcut command to restore the default.
By default, IGP does not consider MPLS TE tunnels in its enhanced SPF calculation.
&  Note:
The mpls te igp shortcut command cannot be used together with the mpls te igp advertise command.
# Enable OSPF and IS-IS to consider TE tunnel 3/0/0 in enhanced SPF calculation when the tunnel is up.
[Sysname-Tunnel3/0/0] mpls te igp shortcut
1.1.64  mpls te link administrative group
mpls te link administrative group value
undo mpls te link administrative group
View
Interface view
Default Level
2: System level
value: Link administrative group attribute. It is a set of 32 link properties. Each bit represents a property with a value of 0 or 1. By ANDing the administrative group attribute bits with the corresponding link affinity attribute bits of an MPLS TE tunnel, MPLS TE identifies the properties of the links that the MPLS TE tunnel can use.
Use the mpls te link administrative group command to configure the link administrative group attribute.
Use the undo mpls te link administrative group command to restore the default.
The default link administrative group attribute is 0x0.
The interface properties are propagated globally and are used for path selection at the tunnel ingress.
Related commands: mpls te affinity property.
# Assign VLAN-interface 1 the link administrative group attribute of 0x0101.
[Sysname-Vlan-interface1] mpls te link administrative group 101
1.1.65  mpls te loop-detection
undo mpls te loop-detection
View
Default Level
2: System level
None
Use the mpls te loop-detection command to configure the node to perform loop detection when setting up the MPLS TE tunnel.
Use the undo mpls te loop-detection command to disable loop detection.
Loop detection is disabled by default.
# Configure the node to perform loop detection when setting up tunnel 0.
[Sysname] interface Tunnel 1/0/0
[Sysname-Tunnel1/0/0] mpls te loop-detection
1.1.66  mpls te max-link-bandwidth
mpls te max-link-bandwidth bandwidth-value [ bc1 bc1-bandwidth ]
undo mpls te max-link-bandwidth
View
Interface view
Default Level
2: System level
bandwidth-value: Maximum link bandwidth available for RSVP traffic, in kbps.
bc1 bc1-bandwidth: Reservable bandwidth on the interface, in kbps.
Use the mpls te max-link-bandwidth command to configure maximum link bandwidth.
Use the undo mpls te max-link-bandwidth command to remove the configuration.
The configured maximum bandwidth is available for both MPLS traffic and common best-effort traffic.
# On interface VLAN-interface 3 set maximum link bandwidth available for RSVP traffic to 1158 kbps, and the reservable bandwidth to 200 kbps.
[Sysname] interface vlan-interface 3
[Sysname-Vlan-interface3] mpls te max-link-bandwidth 1158 bc1 200
1.1.67  mpls te max-reservable-bandwidth
mpls te max-reservable-bandwidth bandwidth-value [ bc1 bc1-bandwidth ]
undo mpls te max-reservable-bandwidth
View
Interface view
Default Level
2: System level
bandwidth-value: Maximum reservable bandwidth for RSVP traffic, in kbps (global pool bandwidth).
bc1 value: Reservable bandwidth on the interface, in kbps.
Use the mpls te max-reservable-bandwidth command to configure the maximum reservable bandwidth.
Use the undo mpls te max-reservable-bandwidth command to remove the configuration.
The bandwidth in this command is configured only for MPLS traffic.
# On VLAN-interface 1 set maximum reservable bandwidth for MPLS TE to 1158 kbps, and the reservable BC1 bandwidth to 200 kbps.
[Sysname-Vlan-interface1] mpls te max-reservable-bandwidth 1158 bc1 200
1.1.68  mpls te metric
mpls te metric value
undo mpls te metric
View
Interface view
Default Level
2: System level
value: TE metric of the link.
Use the mpls te metric command to assign a TE metric to the link.
Use the undo mpls te metric command to restore the default.
By default, the link uses its IGP metric as its TE metric.
Related commands: mpls te path metric-type.
# Assign a TE metric of 20 to the link on VLAN-interface 12.
[Sysname-Vlan-interface12] mpls te metric 20
1.1.69  mpls te path explicit-path
mpls te path explicit-path pathname
undo mpls te path
View
Default Level
2: System level
pathname: Name of an MPLS-TE explicit path.
Use the mpls te path explicit-path command to associate an explicit path with the tunnel.
Use the undo mpls te path command to remove the association.
# Configure interface Tunnel 3/0/1 to use the explicit path named path1.
[Sysname-Tunnel3/0/1] mpls te path explicit-path path1
1.1.70  mpls te path metric-type
mpls te path metric-type { igp | te }
undo mpls te path metric-type
View
MPLS view, tunnel interface view
Default Level
2: System level
igp: Uses IGP metric for tunnel routing.
te: Uses TE metric for tunnel routing.
Use the mpls te path metric-type command in MPLS view to specify the link metric type used for routing tunnels not configured with link metric type.
Use the mpls te path metric-type command in tunnel interface view to specify the link metric type used for routing current tunnel.
Use the undo mpls te path metric-type command to restore the default. This undo form is only available in tunnel interface view.
By default, TE metrics of links are used in path calculation for TE tunnels.
Related commands: mpls te metric.
In MPLS view:
# Use the IGP metrics of links in path calculation for TE tunnels not configured with link metric type.
[Sysname] mpls
[Sysname-mpls] mpls te path metric-type igp
In tunnel interface view:
# Use the IGP metrics of links for routing tunnel 3/0/1.
[Sysname] interface tunnel 3/0/1
[Sysname-Tunnel3/0/1] mpls te path metric-type igp
1.1.71  mpls te priority
mpls te priority setup-priority [ hold-priority ]
undo mpls te priority
View
Default Level
2: System level
setup-priority: Setup priority of the tunnel. A lower numerical number indicates a higher priority.
hold-priority: Holding priority of the tunnel. A lower numerical number indicates a higher priority. If not configured, it is the same as the setup priority.
Use the mpls te priority command to assign a setup priority and holding priority to the MPLS TE tunnel.
Use the undo mpls te priority command to restore the default.
By default, both setup and holding priorities of TE tunnels are 7.
To avoid flapping caused by improper preemptions between TE tunnels, the setup priority of an MPLS TE tunnel should not be set higher than its holding priority.
# Set the setup and holding priorities of TE tunnel 3/0/1 to 1.
[Sysname-Tunnel3/0/1] mpls te priority 1
1.1.72  mpls te record-route
mpls te record-route [ label ]
undo mpls te record-route
View
Default Level
2: System level
label: Includes the record of labels in the route record.
Use the mpls te record-route command to enable route recording or label recording.
Use the undo mpls te record-route command to restore the default.
By default, route recording and label recording are disabled.
# Enable route recording on MPLS TE tunnel 3/0/1.
[Sysname-Tunnel3/0/1] mpls te record-route
1.1.73  mpls te reoptimization (user view)
View
Default Level
2: System level
None
Use the mpls te reoptimization command to start reoptimizing all reoptimization-enabled TE tunnels.
# Start reoptimizing all reoptimization-enabled TE tunnels.
<Sysname> mpls te reoptimization
1.1.74  mpls te reoptimization (tunnel interface view)
mpls te reoptimization [ frequency seconds ]
undo mpls te reoptimization
View
Default Level
2: System level
seconds: Reoptimization frequency, in seconds. The default is 3600 seconds, or 1 hour.
Use the mpls te reoptimization command to enable reoptimization on the tunnel.
Use the undo mpls te reoptimization command to disable reoptimization on the tunnel.
Reoptimization is disabled by default.
&  Note:
The reoptimization function cannot be used together with these commands:
mpls te route-pinning, mpls te backup, and mpls te resv-style ff.
# Enable reoptimization, setting the reoptimization (automatic rerouting) frequency to 43200 seconds (12 hours).
[Sysname-Tunnel3/0/1] mpls te reoptimization frequency 43200
1.1.75  mpls te resv-style
mpls te resv-style { ff | se }
undo mpls te resv-style
View
Default Level
2: System level
ff: Sets the resource reservation style to fixed filter (FF).
se: Sets the resource reservation style to shared explicit (SE).
Use the mpls te resv-style command to set the resource reservation style for the MPLS TE tunnel.
Use the undo mpls te resv-style command to restore the default.
The default resource reservation style is SE.
You may configure FF and SE only when the signaling protocol is set to RSVP-TE.
# Adopt the FF reservation style when setting up the CR-LSP tunnel for TE tunnel 1/0/0.
[Sysname-Tunnel1/0/0] mpls te signal-protocol rsvp-te
[Sysname-Tunnel1/0/0] mpls te resv-style ff
1.1.76  mpls te retry
mpls te retry times
undo mpls te retry
View
Default Level
2: System level
times: Number of tunnel setup retries.
Use the mpls te retry command to configure the maximum number of tunnel setup retries.
Use the undo mpls te retry command to restore the default.
The default maximum number of tunnel setup retries is 5.
You may configure the system to attempt setting up a tunnel multiple times until it is established successfully or until the number of attempts reaches the upper limit.
Related commands: mpls te timer retry.
# Set the maximum number of tunnel setup retries to 10.
[Sysname-Tunnel1/0/0] mpls te retry 10
1.1.77  mpls te route-pinning
undo mpls te route-pinning
View
Default Level
2: System level
None
Use the mpls te route-pinning command to enable route pinning.
Use the undo mpls te route-pinning command to restore the default.
By default, route pinning is disabled.
&  Note:
The mpls te route-pinning command cannot be used together with the mpls te reoptimization command and the mpls te auto-bandwidth adjustment command.
# Enable route pinning.
[Sysname-Tunnel3/0/1] mpls te route-pinning
1.1.78  mpls te signal-protocol
mpls te signal-protocol { rsvp-te | static }
View
Default Level
2: System level
rsvp-te: Sets the signaling protocol for MPLS TE tunnel establishment to RSVP-TE.
static: Sets up the tunnel using a static CR-LSP.
Use the mpls te signal-protocol command to configure the signaling protocol for MPLS TE tunnel establishment.
The default signaling protocol for MPLS TE tunnel establishment is RSVP-TE.
  Caution:
To use RSVP-TE as the signaling protocol for setting up the MPLS TE tunnel, you must enable both MPLS TE and RSVP-TE on the interface for the tunnel to use.
# Adopt RSVP-TE as the signaling protocol for establishing MPLS TE tunnel 3/0/1.
[Sysname-Tunnel3/0/1] mpls te signal-protocol rsvp-te
1.1.79  mpls te tie-breaking
mpls te tie-breaking { least-fill | most-fill | random }
undo mpls te tie-breaking
View
Default Level
2: System level
least-fill: Selects a path with the least bandwidth usage ratio (the used bandwidth to the maximum reservable link bandwidth).
most-fill: Selects a path with the most bandwidth usage ratio (the used bandwidth to the maximum reserved bandwidth).
random: Selects a path randomly.
Use the mpls te tie-breaking command to specify a tie breaker for CSPF to route a tunnel when multiple paths are present with the same metric.
Use the undo mpls te tie-breaking command to restore the default.
By default, the random keyword applies.
&  Note:
The tie breaker configured in MPLS TE tunnel interface view has higher priority over the one configured in MPLS view.
# Configure CSPF to route tunnel 3/0/1 over a path with the least bandwidth usage ratio in MPLS TE interface view.
[Sysname-Tunnel3/0/1] mpls te tie-breaking least-fill
# Configure CSPF to route tunnels over paths with the least bandwidth usage ratio.
[Sysname] mpls
[Sysname-mpls] mpls te tie-breaking least-fill
1.1.80  mpls te timer fast-reroute
mpls te timer fast-reroute [ seconds]
undo mpls te timer fast-reroute
View
MPLS view
Default Level
2: System level
seconds: FRR polling timer setting for the point of local repair (PLR) to poll available bypass tunnels for the best one, in seconds. 0 means disabling the PLR to poll available bypass tunnels regularly for the best one. The default is 300 seconds or 5 minutes.
Use the mpls te timer fast-reroute command to set the FRR polling timer.
Use the undo mpls te timer fast-reroute command to disable FRR polling.
The default FRR polling timer is 300 seconds.
# Set the FRR polling timer to 120 seconds or 2 minutes.
[Sysname] mpls
[Sysname-mpls] mpls te timer fast-reroute 120
1.1.81  mpls te timer retry
mpls te timer retry second
undo mpls te timer retry
View
Default Level
2: System level
second: Interval for re-establishing the tunnel, in seconds.
Use the mpls te timer retry command to configure the interval for re-establishing the tunnel.
Use the undo mpls te timer retry command to restore the default.
The default interval for re-establishing a tunnel is 10 seconds.
Related commands: mpls te retry.
# Set the interval for re-establishing tunnel 3/0/1 to 20 seconds.
[Sysname-Tunnel3/0/1] mpls te timer retry 20
1.1.82  mpls te vpn-binding
mpls te vpn-binding { acl acl-number | vpn-instance vpn-instance-name }
undo mpls te vpn-binding
View
Default Level
2: System level
acl-number: Referenced ACL number. The MPLS TE tunnel forwards only traffic that matches the referenced ACL.
vpn-instance-name: VPN instance name. The MPLS TE tunnel forwards only traffic of the specified VPN instance.
Use the mpls te vpn-binding command to define the traffic that can travel the MPLS TE tunnel.
Use the undo mpls te vpn-binding command to restore the default.
By default, no restriction is defined about what traffic can travel down a TE tunnel.
# Configure tunnel 1/0/0 to forward only traffic of VPN 1.
[Sysname-Tunnel1/0/0] mpls te vpn-binding vpn-instance vpn1
1.1.83  mpls-te
mpls-te enable
undo mpls-te
View
OSPF area view
Default Level
2: System level
enable: Enables the MPLS TE capability in the OSPF area.
Use the mpls-te enable command to enable the MPLS TE capability in current OSPF area.
Use the undo mpls-te command to disable the MPLS TE capability in current OSPF area.
By default, the MPLS TE capability is disabled in OSPF areas.
For an OSPF area to support the MPLS TE capability, its OSPF process must be available with the opaque LSA capability.
Related commands: opaque-capability.
Example
# Enable the MPLS TE capability in OSPF area 1.
[Sysname] ospf 100
[Sysname-ospf-100] area 1
[Sysname-ospf-100-area-0.0.0.1] mpls-te enable
1.1.84  next hop
next hop ip-address [ include [ strict | loose ] | exclude ]
View
Explicit path view
Default Level
2: System level
ip-address: Defines a node by its link IP address or router ID in dotted decimal notation. In the strict routing approach, this IP address must be a link IP address. In the loose routing approach, this IP address can be either a link IP address or router ID.
include: Includes the specified IP address on the explicit path.
loose: Indicates that the next hop is a loose node which is not necessarily directly connected to current node.
strict: Indicates that the next hop is a strict node which must be directly connected to current node.
exclude: Excludes the specified IP address from the explicit path.
Use the next hop command to define a node on the explicit path. By performing this command multiple times, you may define all nodes that the explicit path must traverse in sequence.
By default, next hops are strict hops on an explicit path.
Related commands: delete hop.
# Exclude IP address 10.0.0.125 from the MPLS TE explicit path p1.
[Sysname] explicit-path p1
[Sysname-explicit-path-p1] next hop 10.0.0.125 exclude
1.1.85  opaque-capability
opaque-capability enable
undo opaque-capability
View
OSPF view
Default Level
2: System level
enable: Enables the opaque LSA capability.
Use the opaque-capability command to enable the opaque LSA capability for the OSPF process to generate and receive from its neighbors Opaque LSAs.
Use the undo opaque-capability command to restore the default.
By default, the opaque LSA capability of OSPF is disabled.
# Enable the opaque LSA capability of OSPF.
[Sysname] ospf 100
[Sysname-ospf-100] opaque-capability enable
1.1.86  reset mpls rsvp-te statistics
reset mpls rsvp-te statistics { global | interface [ interface-type interface-number ]
View
Default Level
1: Monitor level
global: Clears statistics about global RSVP-TE.
interface: Clears statistics about RSVP-TE for all interfaces.
interface interface-type interface-number: Specifies an interface by its type and number. If an interface is specified, the command clears the statistics about RSVP-TE for the interface.
Use the reset mpls rsvp-te statistics command to clear statistics about RSVP-TE.
# Clear statistics about global RSVP-TE.
<Sysname> reset mpls rsvp-te statistics global
1.1.87  static-cr-lsp egress
static-cr-lsp egress tunnel-name incoming-interface interface-type interface-number in-label in-label-value
undo static-cr-lsp egress tunnel-name
View
Default Level
2: System level
in-label-value: Incoming label.
Use the static-cr-lsp egress command to configure a static CR-LSP on the egress node.
Use the undo static-cr-lsp egress command to remove the static CR-LSP.
# Configure a static CR-LSP on the egress node, setting its name to Tunnel4/0/3, incoming interface to VLAN-interface 12, and incoming label to 233.
[Sysname] static-cr-lsp egress Tunnel4/0/3 incoming-interface vlan-interface 12 in-label 233
1.1.88  static-cr-lsp ingress
static-cr-lsp ingress tunnel-name destination dest-addr { nexthop next-hop-addr | outgoing-interface interface-type interface-number } out-label out-label-value [ bandwidth [ bc1 | bc0 ] bandwidth-value ]
undo static-cr-lsp ingress tunnel-name
View
Default Level
2: System level
tunnel-name: LSP name, a case sensitive string. It must be an exact reference to a tunnel created by the interface tunnel command.
next-hop-addr: Next hop address.
outgoing-interface interface-type interface-number: Specifies an outgoing interface for the static CR-LSP.
out-label-value: Outgoing label.
bc1: Obtains bandwidth from the global pool.
bc0: Obtains bandwidth from a subpool.
bandwidth-value: Bandwidth assigned to the CR-LSP, in kbps.
Use the static-cr-lsp ingress command to configure a static CR-LSP at the ingress node.
Use the undo static-cr-lsp ingress command to remove the static CR-LSP.
&  Note:
l      The tunnel-name argument of the static-cr-lsp ingress command is case sensitive. For example, if you configure the interface tunnel 2/0/0 command, you must specify a value of Tunnel2/0/0 for the tunnel-name argument. Otherwise, the tunnel cannot be established. However, this is not true for the egress and transit nodes.
l      The next hop address cannot be a local public address when configuring the static CR-LSP on the ingress or a transit node.
# Configure a static CR-LSP on the ingress node, setting its name to Tunnel4/0/1, destination IP address to 202.25.38.1, destination address mask length to 24, next hop IP address to 202.55.25.33, outgoing label to 237, and required bandwidth to 20 kbps.
[Sysname] static-cr-lsp ingress Tunnel4/0/1 destination 202.25.38.1 nexthop 202.55.25.33 out-label 237 bandwidth 20
1.1.89  static-cr-lsp transit
static-cr-lsp transit tunnel-name incoming-interface interface-type interface-number in-label in-label-value { nexthop next-hop-addr | outgoing-interface interface-type interface-number } out-label out-label-value [ bandwidth [ bc1 | bc0 ] bandwidth-value ]
undo static-cr-lsp transit tunnel-name
View
Default Level
2: System level
Use the static-cr-lsp transit command to configure a static CR-LSP on a transit node.
Use the undo static-cr-lsp transit command to remove the static CR-LSP.
&  Note:
# Configure a static CR-LSP on the transit node, setting its name to Tunnel4/0/3, incoming interface to VLAN-interface 12, incoming label to 123, next hop to 3.2.1.2, and outgoing label to 30.
[Sysname] static-cr-lsp transit Tunnel4/0/3 incoming-interface vlan-interface 12 in-label 123 nexthop 3.2.1.2 out-label 30
1.1.90  traffic-eng
traffic-eng [ level-1 | level-2 | level-1-2 ]
undo traffic-eng [ level-1 | level-2 | level-1-2 ]
View
IS-IS view
Default Level
2: System level
level-1: Enables Level-1 IS-IS TE.
level-2: Enables Level-2 IS-IS TE.
level-1-2: Enables Level-1-2 IS-IS TE.
&  Note:
If no level is specified, IS-IS TE applies to Level-1-2.
Use the traffic-eng command to enable IS-IS TE.
Use the undo traffic-eng command to restore the default.
By default, IS-IS TE is disabled.
&  Note:
In order to enable IS-IS TE, you must use the cost-style command to configure the cost style of the IS-IS packet to wide, compatible or wide-compatible. Refer to the IP routing volume for detail information about the command.
# Enable TE for Level-2 IS-IS process 1.
[Sysname] isis 1
[Sysname-isis-1] cost-style compatible
[Sysname-isis-1] traffic-eng level-2
