H3C S9500 Command Manual-Release2132[V2.03]-05 MPLS VPN Volume
HomeSupportSwitchesS9500 SwitchesReference GuidesCommand ReferencesH3C S9500 Command Manual-Release2132[V2.03]-05 MPLS VPN Volume
00-1Cover
00-1Cover 54.68 KB
H3C S9500 Series Routing Switches
Command Manual
Hangzhou H3C Technologies Co., Ltd.
http://www.h3c.com
Manual Version: T2-08194H-20080520-C-2.03
Product Version: S9500-CMW520-R2132
Copyright © 2007-2008, Hangzhou H3C Technologies Co., Ltd. and its licensors
All Rights Reserved
No part of this manual may be reproduced or transmitted in any form or by any means without prior written consent of Hangzhou H3C Technologies Co., Ltd.
Trademarks
H3C, Adobe Systems, Aolynk, , H3Care, , TOP G, , IRF, NetPilot, Neocean, NeoVTL, SecPro, SecPoint, SecEngine, SecPath, Comware, Secware, Storware, NQA, VVG, V2G, VnG, PSPT, XGbus, N-Bus, TiGem, InnoVision and HUASAN are trademarks of Hangzhou H3C Technologies Co., Ltd.
All other trademarks that may be mentioned in this manual are the property of their respective owners.
Notice
The information in this document is subject to change without notice. Every effort has been made in the preparation of this document to ensure accuracy of the contents, but all statements, information, and recommendations in this document do not constitute the warranty of any kind, express or implied.
To obtain the latest information, please access:
http://www.h3c.com
Technical Support
[email protected]
http://www.h3c.com
About This Manual
Related Documentation
In addition to this manual, each H3C S9500 Series Routing Switches documentation set includes the following:
Manual
H3C S9500 Series Routing Switches  Installation Manual
It introduces the installation procedure, commissioning, maintenance and monitoring of the S9500 series routing switches.
H3C S9500 Series Routing Switches  Operation Manual
It includes Product Overview, Access Volume, IP Service Volume, IP Routing Volume, IP Multicast Volume, MPLS VPN Volume, QoS ACL Volume, Security Volume, System Volume , OAA Volume and Acronyms.
Organization
H3C Command Manual is organized as follows:
Part
00 Feature List and Command Index
includes Feature List and Command Index.
01 Access Volume
includes Ethernet Interface Commands, POS Interface Commands, GVRP Commands, Link Aggregation Commands, Port Mirroring Commands, RPR Commands, Ethernet OAM Commands, MSTP Commands, VLAN Commands, QinQ Commands, BPDU Tunneling Commands, and Port Isolation Commands.
02 IP Services Volume
includes ARP Commands, DHCP Commands, DNS Commands, IP Addressing Commands, IP Performance Commands, UDP Helper Commands, IPv6 Basics Commands, Dual Stack Commands, Tunneling Commands, and Adjacency Table Command.
03 IP Routing Volume
includes IP Routing Table Display Commands, BGP Commands, IS-IS Commands, OSPF Commands, RIP Commands, Routing Policy Commands, Static Routing Commands,  IPv6 BGP Commands, IPv6 IS-IS Commands, IPv6 OSPFv3 Commands, IPv6 RIPng Commands, and IPv6 Static Routing Commands.
04 IP Multicast Volume
includes Multicast Routing and Forwarding Commands, IGMP Snooping Commands, IGMP Commands, PIM Commands, MSDP Commands, IPv6 Multicast Routing, and Forwarding Commands, MLD Snooping Commands, MLD Commands, IPv6 PIM Commands, Multicast VLAN Commands.
05 MPLS VPN Volume
includes MPLS Basics Commands, MPLS TE Commands, VPLS Commands, MPLS L2VPN Commands, MPLS L3VPN Commands, MPLS Hybrid Insertion Commands, and GRE Commands.
06 QoS ACL Volume
includes QoS Commands and ACL Commands.
07 Security Volume
includes 802.1x Commands, AAA, RADIUS HWTACACS Commands, MAC Authentication Commands, L3+NAT Commands, Password Control Commands, SSH2.0 Commands, and Portal Commands.
08 System Volume
includes GR Commands, VRRP Commands, HA Commands, Device Management Commands, NQA Commands, NetStream Commands, NTP Commands, RMON Commands, SNMP Commands, File System Management Commands, System Maintaining and Debugging Commands, Basic System Configuration Commands, Information Center Commands, User Interface Commands, MAC Address Table Management Commands, PoE Commands, and Clock Monitoring Commands.
09 OAA Volume
includes OAP Module Commands and ACSEI Commands.
10 Unsupported Commands
List of Unsupported Commands.
Conventions
The manual uses the following conventions:
I. Command conventions
Convention
Boldface
The keywords of a command line are in Boldface.
italic
Command arguments are in italic.
Items (keywords or arguments) in square brackets [ ] are optional.
{ x | y | ... }
Alternative items are grouped in braces and separated by vertical bars. One is selected.
[ x | y | ... ]
Optional alternative items are grouped in square brackets and separated by vertical bars. One or none is selected.
{ x | y | ... } *
Alternative items are grouped in braces and separated by vertical bars. A minimum of one or a maximum of all can be selected.
[ x | y | ... ] *
Optional alternative items are grouped in square brackets and separated by vertical bars. Many or none can be selected.
&<1-n>
The argument(s) before the ampersand (&) sign can be entered 1 to n times.
A line starting with the # sign is comments.
II. GUI conventions
Convention
Button names are inside angle brackets. For example, click <OK>.
Window names, menu items, data table and field names are inside square brackets. For example, pop up the [New User] window.
Multi-level menus are separated by forward slashes. For example, [File/Create/Folder].
III. Symbols
Convention
  Warning
Means reader be extremely careful. Improper operation may cause bodily injury.
  Caution
Means reader be careful. Improper operation may cause data loss or damage to equipment.
&  Note
Means a complementary description.
