H3C S9500 Command Manual-Release2132[V2.03]-05 MPLS VPN Volume
HomeSupportSwitchesS9500 SwitchesReference GuidesCommand ReferencesH3C S9500 Command Manual-Release2132[V2.03]-05 MPLS VPN Volume
01-MPLS Basics Commands
01-MPLS Basics Commands 222.98 KB
Table of Contents
Chapter 1 MPLS Basics Configuration Commands. 1-1
1.1 MPLS Basic Configuration Commands. 1-1
1.1.1 debugging mpls ldp. 1-1
1.1.2 debugging mpls lfib. 1-8
1.1.3 debugging mpls lfib slot drv 1-9
1.1.4 debugging mpls lspc. 1-11
1.1.5 debugging mpls management 1-12
1.1.6 debugging mpls packet 1-24
1.1.7 display mpls interface. 1-26
1.1.8 display mpls label 1-28
1.1.9 display mpls ldp. 1-29
1.1.10 display mpls ldp cr-lsp. 1-30
1.1.11 display mpls ldp interface. 1-31
1.1.12 display mpls ldp Isp. 1-33
1.1.13 display mpls ldp peer 1-34
1.1.14 display mpls ldp remote-peer 1-36
1.1.15 display mpls ldp session. 1-37
1.1.16 display mpls ldp vpn-instance. 1-39
1.1.17 display mpls lsp. 1-40
1.1.18 display mpls lsp statistics. 1-43
1.1.19 display mpls route-state. 1-44
1.1.20 display mpls static-lsp. 1-44
1.1.21 display mpls statistics interface. 1-45
1.1.22 display mpls statistics lsp. 1-47
1.1.23 du-readvertise. 1-49
1.1.24 du-readvertise timer 1-50
1.1.25 hops-count 1-51
1.1.26 label advertise. 1-51
1.1.27 label-distribution. 1-53
1.1.28 label-retention. 1-54
1.1.29 loop-detect 1-55
1.1.30 lsp-trigger 1-55
1.1.31 lsr-id. 1-56
1.1.32 md5-password. 1-57
1.1.33 mpls. 1-58
1.1.34 mpls ldp (system view) 1-59
1.1.35 mpls ldp (interface view) 1-60
1.1.36 mpls ldp advertisement 1-61
1.1.37 mpls ldp remote-peer 1-62
1.1.38 mpls ldp timer hello-hold. 1-63
1.1.39 mpls ldp timer keepalive-hold. 1-64
1.1.40 mpls ldp transport-address. 1-65
1.1.41 mpls lsr-id. 1-66
1.1.42 mtu-signalling. 1-67
1.1.43 path-vectors. 1-68
1.1.44 ping lsp. 1-69
1.1.45 remote-ip. 1-70
1.1.46 reset mpls ldp. 1-71
1.1.47 reset mpls statistics interface. 1-72
1.1.48 reset mpls statistics lsp. 1-72
1.1.49 snmp-agent trap enable mpls. 1-73
1.1.50 static-lsp egress. 1-73
1.1.51 static-lsp ingress. 1-74
1.1.52 static-lsp transit 1-75
1.1.53 statistics interval 1-76
1.1.54 tracert lsp. 1-77
1.1.55 ttl expiration. 1-78
1.1.56 ttl propagate. 1-79
&  Note:
l      Except for the LDP GR feature, all commands in MPLS LDP view are available in MPLS LDP VPN instance view. The difference is that the commands serves the public network LDP in MPLS LDP view but serves the MPLS LDP VPN instance in MPLS LDP VPN instance view.
l      For information about GR commands, refer to GR Commands in System Volume.
debugging mpls ldp { advertisement | all | error | hsb | main | notification | pdu | session | socket | timer } [ interface interface-type interface-number ]
debugging mpls ldp remote-peer [ remote-peer-name ]
undo debugging mpls ldp { advertisement | all | error | hsb | main | notification | pdu | session | socket | timer } [ interface interface-type interface-number ]
undo debugging mpls ldp remote-peer [ remote-peer-name ]
View
Default Level
1: Monitor level
advertisement: Specifies advertisement event debugging.
all: Specifies all event debugging.
error: Specifies error event debugging.
hsb: Specifies hot standby event debugging.
main: Specifies debugging for external module related main interface event .
notification: Specifies notification event debugging.
pdu: Specifies PDU packet event debugging.
session: Specifies session event debugging.
socket: Specifies socket event debugging.
timer: Specifies timer event debugging.
interface-type interface-number: Specifies an LDP-enabled interface by its type and number.
remote-peer remote-peer-name: Specifies a remote peer name.
Use the debugging mpls ldp command to enable debugging for LDP.
Use the undo debugging mpls ldp command to disable debugging for LDP.
By default, debugging is disabled for LDP.
# Enable LDP advertisement event debugging by executing the debugging mpls ldp advertisement command
Start two switches, connect the two switches, and configure MPLS and MPLS LDP for them to establish a session between them. Enable LDP advertisement event debugging by executing the debugging mpls ldp advertisement command on one switch while restarting LDP on the other switch.
<PE1> debugging mpls ldp advertisement
<PE1>
*0.16830023 PE1 LDP/8/Advertisement:
 DU Re-advertise for FEC: 140.2.2.2/0xffffffff.
 0 - FEC: 140.2.2.2/0xffffffff, Successful Next Hop Query
// The DU Re-adverse timer refreshes the FEC information periodically.
#Dec 22 14:55:50:388 2005 PE1 LDP/5/SessionDown: Session(140.2.2.2:0. public Instance)'s state change to Down
// A Trap message on Session Down.
*0.16838403 PE1 LDP/8/Advertisement: Vlan-interface 12
 FEC: 140.2.2.2/0xffffffff, DU DS state machine process, DS Peer 140.2.2.2:0, DSCB's state: Established , Event: DownStream Lost
// The opposite end restarts LDP, and the upstream state machine processes upstream events.
 FEC: 140.2.2.2/0xffffffff, DU Ingress US state machine process, USCB's state: Established   Event: Internal DownStream Withdraw
// The downstream state machine processes upstream events.
 LDP send LSP Message (Event: 3) to LSPM for LSP:
 0     140.2.2.2/32       -----/3     140.12.1.2      -------      Vlan12
 The token is: 0. The MTU is: 1500.
// Send an LSP message to LSPM.
 Delete USCB, FEC: 140.2.2.2/0xffffffff.
 Delete DSCB, FEC: 140.2.2.2/0xffffffff.
*0.16838419 PE1 LDP/8/Advertisement:
 Delete FEC Radix Tree Node, Destination: 140.2.2.2,Mask: 0xffffffff
 Downstream Lost, Cleanup Successful
// Delete the USCB, DSCB, and FEC node; the downstream is lost; and the USCB, DSCB, and FEC node information is cleaned up successfully.
*0.16838538 PE1 LDP/8/Advertisement:
 Start to process LSP Message(Type: 13) from LSPM - FEC: 140.2.2.2/0xffffffff, Nexthop: 140.12.1.2
// Re-establish the session, and process the LSPM message.
 Start to process Route add (FEC: 140.2.2.2/0xffffffff, OutIf: Vlan-interface 12 Nexthop: 140.12.1.2)
// Process a route adding event.
*0.16868001 PE1 LDP/8/Advertisement: Vlan-interface 12
 Receive Label Mapping Message from Peer(140.2.2.2:0) for FEC: 140.2.2.2/0xffffffff
// Receive a label mapping message.
 Create FEC Radix Tree Node, Destination: 140.2.2.2, Mask: 0xffffffff
 Create cross node for FEC: 140.2.2.2, Mask: 0xffffffff.
 Create DSCB, FEC: 140.2.2.2/0xffffffff.
// Create FEC node, cross node, and DSCB.
 Update OutSeg Info, FEC: 140.2.2.2/0xffffffff, NHCount: 1.
// Update the information of an outgoing label.
 Add Info Out_If: 3145744, NHAddr: 140.12.1.2.
 FEC: 140.2.2.2/0xffffffff, DU DS state machine process, DS Peer 140.2.2.2:0, DSCB's state: Idle , Event: LDP Mapping
// The downstream state machine processes the LDP Mapping event.
*0.16868017 PE1 LDP/8/Advertisement:
 Create USCB, FEC: 140.2.2.2/0xffffffff.
// Create a USCB.
*0.16868032 PE1 LDP/8/Advertisement:
 FEC: 140.2.2.2/0xffffffff, DU Ingress US state machine process, USCB's state: Idle   Event: Internal DownStream Mapping
// The upstream state machine processes the Internal DownStream Mapping event.
 LDP send LSP Message (Event: 1) to LSPM for LSP:
 The token is: 557235. The MTU is: 1500.
// Inform LSPM that an LSP is created successfully.
# Enable LDP session event debugging by executing the debugging mpls ldp session command.
Start two switches, connect the two switches, and configure MPLS and MPLS LDP for them to establish a session between them. Enable LDP session event debugging by executing the debugging mpls ldp session command on one switch while restarting LDP on the other switch.
<PE1> debugging mpls ldp session
<PE1>
*0.19200353 PE1 LDP/8/Session: Vlan-interface 12
 Link Hello message sent on interface: Vlan-interface 12
// Send a Hello message.
*0.19201475 PE1 LDP/8/Session:
 Session(140.3.3.3) received keep alive message on Operational state.
// Receive a Keepalive message.
*0.19202353 PE1 LDP/8/Session: Vlan-interface 12
 Link Hello message received on interface: Vlan-interface 12
// Receive a Hello message.
*0.19202695 PE1 LDP/8/Session:
 Sent keep alive message to LSR: 140.3.3.3.
// Send a Keepalive message.
#Dec 22 15:32:40:498 2005 PE1 LDP/5/SessionDown: Session(140.2.2.2:0. public Instance)'s state change to Down
// Restart the opposite end, and print a Trap message on Session DOWN.
*0.19212498 PE1 LDP/8/Session: Vlan-interface 12
 Session(140.2.2.2) received address withdraw message on Operational state.
// Receive an address withdrawing message.
 Session(140.2.2.2) received notification in Operational state.
// Receive a notification.
 Send shut down notify,Tcp connid is 3!
// Send a shutdown notification.
 Informed Session Down event to L2VPN
// Inform L2VPN of Session DOWN.
 Session counter is 1
*0.19215395 PE1 LDP/8/Session: Vlan-interface 12
 Created session with LSR: 140.2.2.2
// Create a session.
*0.19215421 PE1 LDP/8/Session: Vlan-interface 12
 Session(140.2.2.2) received init msg in Initialised state.
// Receive an initialization message.
 Session Init message sent to LSR: 140.2.2.2
// Send an initialization message.
 Sent keep alive message to LSR: 140.2.2.2.
 Session(140.2.2.2)'s state changed from Initialised to Open received.
// The session’s state is changed.
#Dec 22 15:32:43:437 2005 PE1 LDP/5/SessionUp: Session(140.2.2.2:0. public Instance)'s state change to Up
// Display a Session-UP Trap message.
*0.19215437 PE1 LDP/8/Session: Vlan-interface 12
 Session(140.2.2.2) received keep alive message on Open Received state.
 Session(140.2.2.2)'s state changed from Open received to operational.
// The session’s state is changed to Operational.
 Address message sent to LSR: 140.2.2.2
// Send an address message to the opposite end.
 Informed Session Up event to L2VPN
// Inform L2VPN of Session UP.
 Session(140.2.2.2) received address message on Operational state.
// Receive an address message.
*0.19216438 PE1 LDP/8/Session:
# Enable PDU packet event debugging by executing the debugging mpls ldp pdu command.
Start two switches, connect the two switches, and configure MPLS and MPLS LDP for them to establish a session between them. Execute the debugging mpls ldp pdu command on one switch.
<PE1>debugging mpls ldp pdu
<PE1>
*0.19804957 PE1 LDP/8/PDU:
 Receive UDP Message from Peer: 140.3.3.3. Message content:
 01 00 00 1c 00 00 17 bf 04 00 00 04 00 2d c0 00
 04 01 00 04 8c 03 03 03 04 02 00 04 00 00 00 00
 The message type: Hello Message.
*0.19806530 PE1 LDP/8/PDU: Vlan-interface 12
 Send UDP Link Hello Message on interface: Vlan-interface 12. Message content:
 01 00 00 1c 00 00 17 ab 04 00 00 04 00 0f 00 00
 04 01 00 04 8c 01 01 01 04 02 00 04 00 00 00 00
*0.19807692 PE1 LDP/8/PDU:
 Receive UDP Message from Peer: 140.2.2.2. Message content:
 01 00 00 1c 00 00 2a 05 04 00 00 04 00 0f 00 00
 04 01 00 04 8c 02 02 02 04 02 00 04 00 00 00 00
*0.19810159 PE1 LDP/8/PDU:
 Received an LDP PDU from LSR: 140.2.2.2
*0.19810159 PE1 LDP/8/PDU: Vlan-interface 12
 Receive TCP Message from Peer: 140.2.2.2. Message content:
 02 01 00 04 00 00 2a 08
 The message type: Keepalive Message.
*0.19811519 PE1 LDP/8/PDU:
 Received an LDP PDU from LSR: 140.3.3.3
 Receive TCP Message from Peer: 140.3.3.3. Message content:
 02 01 00 04 00 00 17 c2
*0.19811550 PE1 LDP/8/PDU: Vlan-interface 12
 01 00 00 1c 00 00 17 ac 04 00 00 04 00 0f 00 00
*0.19812630 PE1 LDP/8/PDU:
 01 00 00 1c 00 00 2a 09 04 00 00 04 00 0f 00 00
*0.19815620 PE1 LDP/8/PDU: Vlan-interface 12
 Send TCP Message to Peer: 140.2.2.2. Message content:
 02 01 00 04 00 00 17 ad
debugging mpls lfib [ code | sync ]
undo debugging mpls lfib [ code | sync ]
View
Default Level
2: System level
code: Enables debugging for MPLS entry encoding and decoding.
sync: Enables debugging for MPLS entry synchronization.
Use the debugging mpls lfib command to enable debugging for MPLS entry synchronization or encoding and decoding.
Use the undo debugging mpls lfib command to disable debugging for MPLS entry synchronization or encoding and decoding.
By default, the debugging for MPLS entry synchronization and encoding/decoding is disabled.
  Caution:
l      Do not enable debugging for MPLS entry encoding and decoding when there are a large number of entries to be sent. Otherwise, there will be large amounts of command output information, affecting the normal operation of the system.
l      The output debugging information for encoding is from the main board, and that for decoding is from the interface board and the backup main board.
Table 1-1 debugging mpls lfib code command output description
SourceId
Entry ID
OperType
Operation type
Size
Number of valid bytes in the entry
CmdBlk Count
Number of entries in the compressed packet
CmdBlk Size
Total number of entry bytes in the compressed packet
Table 1-2 debugging mpls lfib sync command output description
time cost
Time cost, in milliseconds
total size
Total number of bytes
CmdQ length
Number of entries in the queue
CmdQ size
Total number of entry bytes in the queue
Table 1-3 debugging mpls lfib command output description
MFW-BFD
Interaction between the MFW module and the BFD module
Begin Process
Begun creating/canceling BFD sessions
End Process
Stopped creating/canceling BFD sessions
BFD MSG
BFD message type
SESS
BFD session information: source address, destination address and egress interface
# Enable debugging for MPLS entry encoding and decoding.
<sysname> debugging mpls lfib code
debugging mpls lfib slot slot-number drv
undo debugging mpls lfib slot slot-number drv
View
Default Level
2: System level
lfib: Enables debugging for MFW.
slot slot-number: Enables debugging for the specified slot.
drv: Enables debugging for distribution to drive.
Use the debugging mpls lfib slot drv command to enable debugging for MFW-to-drive entry distribution.
Use the undo debugging mpls lfib slot slot-num drv command to disable debugging for MFW-to-drive entry distribution.
By default, debugging for MFW-to-drive entry distribution is disabled.
This command is supported on devices with single-core CPUs only.
Table 1-4 debugging mpls lfib slot drv command output description
MFW
Forwarding module
DRV
Drive module
VC
Virtual circuit
ILM
Incoming label mapping
PW
Pseudo wire
Del
Delete
FRR
Fast reroute
MFW-DRV
Interaction between the MFW module and the DRV module
NHLFE
Next hop label forwarding entry
DrvContext
Information returned to the upper layer by the drive
Result is
Operation result, 0 for success and 1 for failure.
# Enable debugging for MFW-to-drive entry distribution on slot 1.
<sysname> debugging mpls lfib slot 1 drv
debugging mpls lspc { all | error | event | packet }
undo debugging mpls lspc { all | error | event | packet }
View
Default Level
2: System level
all: Specifies all types of debugging.
error: Specifies error debugging.
event: Specifies event debugging.
packet: Specifies packet debugging.
Use the debugging mpls lspc command to enable debugging for the LSP control module.
Use the undo debugging mpls lspc command to disable debugging for the LSP control module.
By default, debugging for the LSP control module is disabled.
Table 1-5 debugging mpls lspc command output description
DS TLV is invalid.
The downstream mapping TLV is invalid.
Socket send error!
Failed to send packets by socket
# Enable all types of debugging for the LSP control module.
<Sysname> terminal debugging
<Sysname> debuggiing mpls lspc all
debugging mpls management { agent | all | event | interface | policy | process| tunnel }
undo debugging mpls management { agent | all | event | interface | policy | process| tunnel }
View
Default Level
2: System level
agent: Enables MPLS Agent debugging.
all: Enables MPLS debugging.
event: Enables MPLS event debugging..
interface: Enables MPLS interface debugging.
policy: Enables debugging for the policy whereby LDP establishes LSPs.
process: Enables MPLS process debugging.
tunnel: Enables MPLS tunnel debugging.
Use the debugging mpls management command to enable MPLS LSP debugging.
Use the undo debugging mpls management command to disable the debugging.
By default, MPLS debugging is disabled.
If the LSP management (LSPM) module works improperly, you can execute the debugging mpls management command to locate the fault. However, the execution of this command will affect system performance. Therefore, use this command with caution.
# Enable MPLS agent debugging by executing the debugging mpls management agent command.
Start two switches, connect the two switches, and configure MPLS and MPLS LDP for them to establish a session between them. Enable MPLS agent debugging by executing the debugging mpls management agent command on one switch while executing the reset mpls ldp all command on the other.
<PE1> debugging mpls management agent
*0.21301372 PE1 LSPAGENT/8/Event:A Message  from Main Board Lspagt Queue has been processed , Message Source is:LSPAGT_ENTITY_MPLS_LSPM; OperType is:LSPM_LSPAGT_DELETE_ILM
// The Agent deletes an ILM entry.
----------------Begin to Print Debug Info,Current Slot ID:0 -----------------
 ulLspIndex : 9253
 ulLspToken : 557239
 enLabelOperation : LSPM_LABEL_PUSH
 ulInLabel : 4294967295
 ulInIfIndex :             0      InIfName :
 ulOutLabel : 3
 ulLabelStackDepth : 0
 ulLabelStack :
 ulOutIfIndex :      3145744      OutIfName :      Vlan-interface 12
 ulOutAtIndex : 0
 ulVrfIndex : 0
 ulDestAddr : 140.2.2.2
 ulDestMask : 255.255.255.255
 ulSlotNumber : 0
 ulNextHop : 140.12.1.2
 ulTunnelIFIndex : 0
 ulFRRFlag : 0
 ulFRRBackupIFIndex : 0
 ulFRRBackupIFInLabel : 4294967295
 ulMtu : 1500
 ulFRRKeyword : 0
 ulRouteType : LSPM_IGP
 ulOutgoingToken : 0
 ulDownloadFlag : 1
 Information from product :
        ulDrvContext[0] : 0
        ulDrvContext[1] : 0
 ulMplsTeEnabled : 0
 ul6PEFlag : 0
 aulIPV6DestAddr :  0 :  0 :  0 :  0 :
 ulPrefixLength : 0
 aulIPV6NextHop :  0 :  0 :  0 :  0 :
 ucCT : 0
 ulBandWidth : 4294967295
 ulOperType : LSPM_LSPAGT_DELETE_NHLFE
 ulRefToken : 0
 ulSlotNumInToken : 0
 ------------------------------- End of Debug Info--------------------------
// Content of the deleted entry.
 Agent-MFW: Return value of Call MPLSFW_AgentSendMsgForLspm API function,return VOS_OK!
// Delete the entry successfully.
*0.21301372 PE1 LSPAGENT/8/Event:A Message  from Main Board Lspagt Queue has been processed , Message Source is:LSPAGT_ENTITY_MPLS_LSPM; OperType is:LSPM_LSPAGT_DELETE_NHLFE
// The Agent deletes the NHLFE entry.
 ulLspIndex : 9254
 ulLspToken : 557240
 ulOutLabel : 1024
 ulLabelStack :
 ulOutAtIndex : 0
 ulVrfIndex : 0
 ulDestAddr : 140.3.3.3
 ulSlotNumber : 0
 ulTunnelIFIndex : 0
 ulFRRFlag : 0
 ulMtu : 1500
 ulFRRKeyword : 0
 ulOutgoingToken : 0
 ulDownloadFlag : 1
        ulDrvContext[0] : 0
        ulDrvContext[1] : 0
 ulMplsTeEnabled : 0
 ul6PEFlag : 0
 ulPrefixLength : 0
 ucCT : 0
 ulRefToken : 0
*0.21305797 PE1 LSPAGENT/8/Event:A Message  from Main Board Lspagt Queue has been processed , Message Source is:LSPAGT_ENTITY_MPLS_LSPM; OperType is:LSPM_LSPAGT_ADD_ILM
// Add an ILM entry after the Session is Up again.
*0.21331182 PE1 LSPAGENT/8/Event:
 ulLspIndex : 9257
 ulLspToken : 557241
 ulOutLabel : 3
 ulLabelStack :
 ulOutAtIndex : 1
 ulVrfIndex : 0
 ulSlotNumber : 0
 ulTunnelIFIndex : 0
 ulFRRFlag : 0
 ulMtu : 1500
 ulFRRKeyword : 0
 ulOutgoingToken : 0
 ulDownloadFlag : 1
        ulDrvContext[0] : 0
        ulDrvContext[1] : 0
 ulMplsTeEnabled : 0
 ul6PEFlag : 0
 ulPrefixLength : 0
 ucCT : 0
 ulOperType : LSPM_LSPAGT_ADD_NHLFE
 ulRefToken : 0
// Entry content.
*0.21331197 PE1 LSPAGENT/8/Event:
// Add the entry successfully.
*0.21331197 PE1 LSPAGENT/8/Event:A Message  from Main Board Lspagt Queue has been processed , Message Source is:LSPAGT_ENTITY_MPLS_LSPM; OperType is:LSPM_LSPAGT_ADD_NHLFE
// Add an NHLFE.
 ulLspIndex : 9258
 ulLspToken : 557242
 ulOutLabel : 1025
 ulLabelStack :
 ulOutAtIndex : 1
 ulVrfIndex : 0
 ulSlotNumber : 0
 ulTunnelIFIndex : 0
 ulFRRFlag : 0
 ulMtu : 1500
 ulFRRKeyword : 0
 ulOutgoingToken : 0
 ulDownloadFlag : 1
        ulDrvContext[0] : 0
        ulDrvContext[1] : 0
 ulMplsTeEnabled : 0
 ul6PEFlag : 0
 ulPrefixLength : 0
 ucCT : 0
 ulRefToken : 0
// Entry content.
# Enable MPLS interface debugging by executing the debugging mpls management interface command.
Start two switches, connect the two switches, and configure MPLS and MPLS LDP for them to establish a session between them. Enable MPLS interface debugging by executing the debugging mpls management interface command on one switch while executing the reset mpls ldp all command on the other.
<PE1>debugging mpls management interface
*0.22430627 PE1 LSPM/8/LSPM INTERFACE:
 Received Signal DELETE message, VRF Index: 0 destination: 0x8c010101 destination mask: 0xffffffff Nexthop: 0x7f000001 OutIfIndex: 0x150000 InIfIndex: 0x300010
// The interface receives a Signal DELETE message.
 Received Signal DELETE message, VRF Index: 0 destination: 0x8c030303 destination mask: 0xffffffff Nexthop: 0x8c0c0102 OutIfIndex: 0x300010 InIfIndex: 0x0
#Dec 22 16:22:17:972 2005 PE1 LDP/5/SessionUp: Session(140.2.2.2:0. public Instance)'s state change to Up
// The Session is Up again.
*0.22435678 PE1 LSPM/8/LSPM INTERFACE:
 Received Route CREATE message, destination: 0x8c010101 destination mask: 0xffffffff.
# Enable debugging for the policy whereby LDP establishes LSPs by executing the debugging mpls management policy command.
Start two switches, connect the two switches, and configure MPLS and MPLS LDP for them to establish a session between them. Enable debugging for the policy whereby LDP establishes LSPs by executing the debugging mpls management policy command on one switch while executing the reset mpls ldp all command on the other.
<PE1>debugging mpls management policy
<PE1>
#Dec 23 10:12:18:552 2005 PE1 LDP/5/SessionDown: Session(140.2.2.2:0. public Instance)'s state change to Down
// Restart the opposite end, and the Session is down.
*0.92036640 PE1 LSPM/8/LSPM POLICY:
 LSP deleted, VRF:0 Destination: 0x8c010101 Destination mask: 0xffffffff Nexthop: 0x7f000001 IfIndex:0x150000 LSPIndex:0x2443.
// Delete an LSP.
 LSP deleted, VRF:0 Destination: 0x8c030303 Destination mask: 0xffffffff Nexthop: 0x8c0c0102 IfIndex:0x300010 LSPIndex:0x2444.
// Delete an LSP.
 LSP deleted, VRF:0 Destination: 0x8c020202 Destination mask: 0xffffffff Nexthop: 0x8c0c0102 IfIndex:0x300010 LSPIndex:0x2445.
// Delete an LSP.
 Route Doesnot Satisfy Policy!. Sig Prot is informed.
// The route does not satisfy the policy; The signaling protocol is informed.
 Calling Signalling protocol for VRF:0 Dst Addr:0x8c030303 Dst Mask:0xffffffff NextHop: 0x8c0c0102 If Index: 0x300010 Event: 13
// Call the signaling protocol.
 Calling Signalling protocol for VRF:0 Dst Addr:0x8c020202 Dst Mask:0xffffffff NextHop: 0x8c0c0102 If Index: 0x300010 Event: 13
#Dec 23 10:12:23:365 2005 PE1 LDP/5/SessionUp: Session(140.2.2.2:0. public Instance)'s state change to Up
*0.92041801 PE1 LSPM/8/LSPM POLICY:
 Received Route Add message, VRF:0 Destination: 0x8c010101 Destination mask: 0xffffffff Nexthop: 0x7f000001 IfIndex:1376256.
// Receive a Route Add message.
 Calling Signalling protocol for VRF:0 Dst Addr:0x8c010101 Dst Mask:0xffffffff NextHop: 0x7f000001 If Index: 0x150000 Event: 1
// Process by calling the signaling protocol.
 Route added successfully
// Add a route successfully.
*0.92042024 PE1 LSPM/8/LSPM POLICY:
 LSP added, VRF:0 Destination: 0x8c010101 Destination mask: 0xffffffff Nexthop:0x7f000001 IfIndex:0x150000 LSPIndex:0x2446.
// Add an LSP.
*0.92066067 PE1 LSPM/8/LSPM POLICY:
 LSP added, VRF:0 Destination: 0x8c020202 Destination mask: 0xffffffff Nexthop:0x8c0c0102 IfIndex:0x300010 LSPIndex:0x2447.
// Add an LSP.
*0.92066083 PE1 LSPM/8/LSPM POLICY:
 LSP added, VRF:0 Destination: 0x8c030303 Destination mask: 0xffffffff Nexthop:0x8c0c0102 IfIndex:0x300010 LSPIndex:0x2448.
// Add an LSP.
# Enable MPLS process debugging by executing the debugging mpls management process command.
Start two switches, connect the two switches, and configure MPLS and MPLS LDP for them to establish a session between them. Enable MPLS process debugging by executing the debugging mpls management process command on one switch while executing the reset mpls ldp all command on the other.
<PE1>debugging mpls management process
<PE1>
#Dec 22 17:05:57:766 2005 PE1 LDP/5/SessionDown: Session(140.2.2.2:0. public Instance)'s state change to Down
*0.25271766 PE1 LSPM/8/LSPM PROCESS:
Rcv delete lsp msg from signaling protocol 0x8c010101/0xffffffff !
// Receive an LSP Delete message from the signaling protocol.
Rcv delete lsp msg from signaling protocol 0x8c020202/0xffffffff !
Rcv delete lsp msg from signaling protocol 0x8c030303/0xffffffff !
// Receive a Delete LSP message from the signaling protocol.
*0.25271844 PE1 LSPM/8/LSPM PROCESS:
Received Signaling message.
// Receive a signaling message.
// Receive a Signal DELETE message.
 Setting MTU = LSP MTU
// Set the MTU.
Down to Agent success: evt/lsptype 4/3
//Advertise the MTU to the Agent successfully.
 Received Signal DELETE message, VRF Index: 0 destination: 0x8c020202 destination mask: 0xffffffff Nexthop: 0x8c0c0102 OutIfIndex: 0x300010 InIfIndex: 0x0
Down to Agent success: evt/lsptype 5/3
// For details, refer to the above flow.
Notify to TNLM SUCCESS. Event: 2, LspIndex: 9265, 0x8c020202/0x20/token557247.
// Notify the TNLM.
Free Token success: 557247
// Free the Token successfully.
*0.25271860 PE1 LSPM/8/LSPM PROCESS:
Notify to TNLM SUCCESS. Event: 2, LspIndex: 9267, 0x8c030303/0x20/token557248.
Free Token success: 557248
#Dec 22 17:05:59:280 2005 PE1 LDP/5/SessionUp: Session(140.2.2.2:0. public Instance)'s state change to Up
*0.25274675 PE1 LSPM/8/LSPM PROCESS:
Alloc Token success: 557249/0x300010
// Allocate the Token successfully.
Rcv create lsp msg from signaling protocol 0x8c020202/0xffffffff In If - 0x0 !
// Receive a Create LSP message from the signaling protocol.
*0.25274690 PE1 LSPM/8/LSPM PROCESS:
 Received Signal CREATE message, VRF Index: 0 destination: 0x8c020202 destination mask: 0xffffffff Nexthop: 0x8c0c0102 OutIfIndex: 0x300010 InIfIndex: 0x0
 Add route success, VRF:0 Destination: 0x8c020202 Destination mask: 0xffffffff Nexthop: 0x8c0c0102 IfIndex:0x300010 .
 Added LSP in LM Successfully
// Add an LSP successfully.
Down to Agent success: evt/lsptype 2/3
//Advertise the LSP information to the Agent successfully.
Notify to TNLM SUCCESS. Event: 1, LspIndex: 9268, 0x8c020202/0x20/token557249.
// Notify the TNLM.
*0.25275573 PE1 LSPM/8/LSPM PROCESS:
Received Route message.
 Add route success, VRF:0 Destination: 0x8c010101 Destination mask: 0xffffffff Nexthop: 0x7f000001 IfIndex:0x150000 .
Rcv create lsp msg from signaling protocol 0x8c010101/0xffffffff In If - 0x300010 !
*0.25275812 PE1 LSPM/8/LSPM PROCESS:
 Received Signal CREATE message, VRF Index: 0 destination: 0x8c010101 destination mask: 0xffffffff Nexthop: 0x7f000001 OutIfIndex: 0x150000 InIfIndex: 0x300010
Error: No LSP found for the route.
Down to Agent success: evt/lsptype 1/3
# Enable MPLS tunnel debugging by executing the debugging mpls management tunnel command.
Start two switches, connect the two switches, and configure MPLS, MPLS LDP and MPLS TE for them to establish a session and tunnel between them. Enable MPLS tunnel debugging by executing the debugging mpls management tunnel command on one switch while executing the shutdown command first and then the undo shutdown command on the other switch.
<PE1>debugging mpls management tunnel
<PE1>
*0.94534296 PE1 LSPM/8/LSPM TUNNEL:
 Begin physic check,ulIfIndex:3407872
 TE tunnel get mode data ok when check physic,ulTunnelIfIndex:3407872
 End physic check,the tunnel can up
// The interfaces are Up. The tunnel can be Up.
%Dec 23 10:51:12:310 2005 PE1 IFNET/5/UPDOWN:
 Line protocol on the interface Tunnel0 is DOWN
// The opposite interface is shut down, so the tunnel is down.
*0.94564310 PE1 LSPM/8/LSPM TUNNEL:
 End physic check,the tunnel can't up
// A failure message is returned when the interface is checked. The tunnel cannot be Up.
%Dec 23 10:52:12:591 2005 PE1 IFNET/5/UPDOWN:
 Line protocol on the interface Tunnel0 is UP
// The undo shutdown command is executed on the opposite end. The tunnel is Up.
*0.94629360 PE1 LSPM/8/LSPM TUNNEL:
// OK is returned after a physical check is performed. The tunnel can be Up.
debugging mpls packet [ acl acl-number] [error] [ inlabel outer-in-label [ inner-in-label ] ] [ l2vpn-in-interface interface-type interface-number ]
undo debugging mpls packet
View
Default Level
2: System level
acl: Outputs debugging information about the MPLS packets that satisfy the ACL criteria.
acl-number: Advanced ACL number.
error: Outputs debugging information about MPLS error packets.
inlabel: Outputs debugging information about the MPLS packets with the specified incoming label.
outer-in-label: Outer incoming label.
inner-in-label: Inner incoming label.
l2vpn-in-interface: Outputs debugging information about the MPLS packets sent/received by the L2VPN-enabled interface.
Use the debugging mpls packet command to enable debugging for forwarded MPLS packets. Use the undo debugging mpls packet command to disable debugging for forwarded MPLS packets.
By default, debugging is disabled for forwarded MPLS packets.
# Enable debugging for forwarded MPLS packets by executing the debugging mpls packet command.
Start five switches, configure L3VPN for networking, and execute the debugging mpls packet command on one PE.
<PE1> debugging mpls packet
<PE1>
*0.3815709 F-RT1 MFW/8/MPLSFW PACKET:
PUSH Label=3
PKTTYPE_IP :Sending to Vlan3, Dest=15.33.33.33, Nexthop=15.20.1.1
// Push Label 3 into a packet, and send the packet to DUT3.
*0.3823332 F-RT1 MFW/8/MPLSFW PACKET:
PUSH Label=3
*0.3824701 F-RT1 MFW/8/MPLSFW PACKET:
PUSH Label=1024, EXP=0, TTL=255
PKTTYPE_MPLS :Sending to Vlan3, PktLen=92, Label(s)=1024,1024, EXP=0, TTL=255
// Push inner incoming Label 1024 and outer incoming Label 1024, and send the packets from VLAN-interface 3.
*0.3824701 F-RT1 MFW/8/MPLSFW PACKET:Slot=2;
MPLSFW_Input: Receiving from Vlan3, PktLen=88, Label(s)=1024, EXP=0, TTL=254
POP Label=1024, EXP=0, TTL=254
Delivering up to IP!
// Receive a packet (length: 88; label: 1024; POP label: 1024) from VLAN-interface 3, and forward the packet like an IP packet.
PKTTYPE_IP :Sending to Slot 6, Dest=15.40.1.1, InnerLabel=1024, Vpn=1, Token=9371650
// Send the packet (it is destined to 15.40.1.1 and has an inner label 1024) to the LPU.
*0.3824779 F-RT1 MFW/8/MPLSFW PACKET:
// Push inner incoming Label 1024 and outer incoming Label 1024, and send the packet from VLAN- interface 3.
*0.3824779 F-RT1 MFW/8/MPLSFW PACKET:Slot=2;
// Receive a packet (length: 88; label: 1024; POP label: 1024) from VLAN- interface 3, and forward the packet like an IP packet.
*0.3824851 F-RT1 MFW/8/MPLSFW PACKET:
*0.3824851 F-RT1 MFW/8/MPLSFW PACKET:Slot=2;
display mpls interface [ interface-type interface-number ] [ verbose ]
View
Default Level
1: Monitor level
verbose: Displays detailed information.
Use the display mpls interface command to display information about a specified or all interfaces with MPLS enabled.
l           If no parameters are specified, the command displays only the brief information about all MPLS-enabled interfaces.
l           If you specify interface-type interface-number, the command displays the brief information about the specified MPLS-enabled interface.
Related commands: display mpls statistics interface and mpls.
# Display information about all interfaces with MPLS enabled.
<Sysname> display mpls interface
Interface   Status     TE Attr    LSP Count   CRLSP Count
Vlan12      Up         En         0           0
Vlan14      Up         En         0           0
# Display detailed information about the specified MPLS-enabled interface.
<Sysname> display mpls interface vlan-interface 12 verbose
No             : 1
Interface      : Vlan12
Status         : Down
TE Attribute   : Disable
LSPCount       : 0
CR-LSPCount    : 0
FRR            : Disabled
&  Note:
For information about FRR, refer to MPLS TE Configuration in the MPLS VPN Volume.
display mpls label { label-value1 [ to label-value2 ] | all }
View
Default Level
1: Monitor level
label-value1: Specifies a label or, when used with the label-value2 argument, the start label of a range of labels.
to label-value2: End label of a range of labels.
all: Specifies all labels.
Use the display mpls label command to display the status of one or more specified or all labels.
# Display the status of a specified label.
<Sysname> display mpls label 1280
Label alloc state: '.' means not used, '$' means used
-------------Dynamic Label--------------------------------
  1280:.
# Display the status of all labels.
<Sysname> display mpls label all
------------------------Static Label---------------------------------
16:.... ........ ........ ........  ........ ........ ........ ........
976:........ ........ ........ ........  ........ ........
------------------------Dynamic Label--------------------------------
1024: $ $$...... ........ ........  ........ ........ ........ ........
1088:.. ........ ........ ........  ........ ........ ........ ........
display mpls ldp [ all [ verbose ] ] [ | { begin | exclude | include } regular-expression ]
View
Default Level
1: Monitor level
all: Displays all LDP information.
|: Filters the output information.
begin: Begins with the specified string.
include: Includes the specified string.
exclude: Excludes the specified string.
regular-expression: Regular expression. No blank space is acceptable.
Use the display mpls ldp command to display information about LDP.
If you do not specify any parameter, the command will display all LDP information in detail.
Related commands: mpls ldp.
# Display all LDP information in detail.
<Sysname> display mpls ldp all verbose
                           LDP Global Information
 Protocol Version        : V1           Neighbor Liveness    : 60 Sec
 Graceful Restart        : Off          FT Reconnect Timer   : 60 Sec
 MTU Signaling           : On           Recovery Timer       : 60 Sec
                          LDP Instance Information
 Instance ID            : 0          VPN-Instance         :
 Instance Status        : Active      LSR ID              : 1.1.1.1
 Hop Count Limit        : 32         Path Vector Limit    : 32
 Loop Detection         : Off
 DU Re-advertise Timer  : 30 Sec     DU Re-advertise Flag : On
 DU Explicit Request    : Off        Request Retry Flag   : On
 Label Distribution Mode: Ordered    Label Retention Mode : Liberal
display mpls ldp cr-lsp [ lspid lsr-id lsp-id ] [ | { begin | exclude | include } regular-expression ]
View
Default Level
1: Monitor level
lsr-id: MPLS LSR ID of the device, in the format of IP address.
lsp-id: Local LSP ID of the ingress.
Use the display mpls ldp cr-lsp command to display information about CR-LSPs established by LDP.
Related commands: display mpls lsp.
# Display information about CR-LSPs established by LDP.
<Sysname> display mpls ldp cr-lsp
        Displaying All LDP CR-LSP(s) for public network
 CR-LSP ID      DestAddress/Mask   In/OutLabel  In/Out-Interface
 1.1.1.9:0       2.2.2.9/32         NULL/1027    -------/Vlan12
 2.2.2.9:0       1.1.1.9/32         1027/NULL    Vlan12/-------
The Total LDP CR-LSP(s): 2
display mpls ldp interface [ all ] [ [ vpn-instance vpn-instance-name ] [ interface-type interface-number ] ] [ verbose ] [ | { begin | exclude | include } regular-expression ]
display mpls ldp interface [ all ] [ verbose ] [ | { begin | exclude | include } regular-expression ]
View
Default Level
1: Monitor level
all: Displays all information.
vpn-instance-name: Name of the VPN instance.
Use the display mpls ldp interface command to display the information about the LDP-enabled interfaces.
Related commands: mpls ldp (System view) and mpls ldp (Interface view).
# Display the information about the LDP-enabled interfaces.
<Sysname> display mpls ldp interface
     LDP Interface Information in Public Network
 IF-Name         Status       LAM   Transport-Address   Hello-Sent/Rcv
 Vlan12            Active       DU    172.17.1.1          583/1017
 Vlan14            Active       DU    172.17.1.1          578/1015
 Vlan16            Active       DU    172.17.1.1          531/444
 LAM: Label Advertisement Mode         IF-Name: Interface name
# Display detailed information about all interfaces.
<Sysname> display mpls ldp interface verbose
 Interface Name : Vlan12
 LDP ID         : 172.17.1.1:0          Transport Address : 172.17.1.1
 Entity Status  : Active                Interface MTU     : 1500
 Configured Hello Timer     : 15 Sec
 Negotiated Hello Timer     : 15 Sec
 Configured Keepalive Timer : 45 Sec
 Label Advertisement Mode   : Downstream Unsolicited
 Hello Message Sent/Rcvd    : 591/1033 (Message Count)
 Interface Name : Vlan14
 Hello Message Sent/Rcvd    : 586/1031 (Message Count)
 Interface Name : Vlan16
 Hello Message Sent/Rcvd    : 539/452 (Message Count)
display mpls ldp lsp [ vpn-instance vpn-instance-name [ dest-addr mask-length ] ] [ | { begin | exclude | include } regular-expression ]
display mpls ldp lsp all [ | { begin | exclude | include } regular-expression ]
display mpls ldp lsp [dest-addr mask-length ] [ | { begin | exclude | include } regular-expression ]
View
Default Level
1: Monitor level
all: Displays information about all LSPs established by LDP.
vpn-instance vpn-instance-name: Specifies a VPN instance by its name.
dest-addr: Destination address of the LSP.
mask-length: Length of the mask for the destination address.
Use the display mpls ldp lsp command to display information about LSPs established by LDP.
Related commands: display mpls ldp.
# Display the information about the LSP created by LDP.
<Sysname> display mpls ldp lsp
                              LDP LSP Information
 SN     DestAddress/Mask   In/OutLabel   Next-Hop        In/Out-Interface
 1      100.10.1.0/24      3/NULL        100.10.1.2      Vlan12/Vlan16
 2      172.17.0.0/16      3/NULL        172.17.1.1      Vlan16/Vlan14
*3      100.1.1.1/32       Liberal(1025)
 A '*' before an LSP means the LSP is not established
 A '*' before a Label means the USCB or DSCB is stale
display mpls ldp peer [ peer-id ] [ vpn-instance vpn-instance-name [ verbose ] [ peer-id ] ] [ | { begin | exclude | include } regular-expression ]
display mpls ldp peer [ all ] [ verbose ] [ | { begin | exclude | include } regular-expression ]
View
Default Level
1: Monitor level
peer-id: LSR ID of the peer.
all: Display information about all peers.
Use the display mpls ldp peer command to display information about specified or all peers of the current LSR.
# Display the peer information.
<Sysname> display mpls ldp peer
         LDP Peer Information in Public network
Total number of peers: 3
 Peer-ID                Transport-Address  Discovery-Source
 172.17.1.2:0           172.17.1.2          Vlan-interface12
 168.1.1.1:0            168.1.1.1           Vlan-interface12
 100.10.1.1:0           100.10.1.1          Vlan-interface16
# Display detailed information about the peer end.
<Sysname> display mpls ldp peer verbose
 Peer LDP ID         : 172.17.1.2:0
 Peer Max PDU Length : 4096             Peer Transport Address : 172.17.1.2
 Peer Loop Detection : Off              Peer Path Vector Limit : 0
 Peer FT Flag        : Off              Peer Keepalive Timer   : 45 Sec
 Recovery Timer      : ----             Reconnect Timer        : ----
 Peer Label Advertisement Mode : Downstream Unsolicited
 Peer Discovery Source         : Vlan-interface12
 Peer LDP ID         : 168.1.1.1:0
 Peer Max PDU Length : 4096             Peer Transport Address : 168.1.1.1
 Peer LDP ID         : 100.10.1.1:0
 Peer Max PDU Length : 4096             Peer Transport Address : 100.10.1.1
 Peer Discovery Source         : Vlan-interface16
display mpls ldp remote-peer [ remote-name remote-peer-name ] [ | { begin | exclude | include } regular-expression ]
View
Default Level
1: Monitor level
remote-name remote-peer-name: Specifies a remote peer end by its name.
Use the display mpls ldp remote-peer command to display information about LDP remote peers.
Related commands: mpls ldp and remote-ip.
# Display information about remote peer BJI.
<Sysname> display mpls ldp remote-peer remote-name BJI
                        LDP Remote Entity Information                    --------------------------------------------------------------------------
 Remote Peer Name  : BJI
 Remote Peer IP    : 3.3.3.3          LDP ID : 1.1.1.1:0
 Transport Address : 1.1.1.1
 Configured Hello Timer     : 45 Sec
 Negotiated Hello Timer     : 45 Sec
 Hello Message Sent/Rcvd    : 3/2 (Message Count)
display mpls ldp session [ vpn-instance vpn-instance-name [ verbose ] ] [ peer-id ] [ | { begin | exclude | include } regular-expression ]
display mpls ldp session [ all ] [ verbose ] [ | { begin | exclude | include } regular-expression ]
View
Default Level
1: Monitor level
vpn-instance vpn-instance-name: Specifies a VPN instance by its name. The parameter is used to display the information about all peers of the specified VPN.
Use the display mpls ldp session command to display the information about the sessions between peers.
# Display the information about a session between peers.
<Sysname> display mpls ldp session
               LDP Session(s) in Public Network
 Total number of sessions: 1
 Peer-ID            Status        LAM  SsnRole  FT   MD5  KA-Sent/Rcv
 1.1.1.1:0          Operational   DU   Active   Off  Off  4582/4582
 LAM : Label Advertisement Mode         FT  : Fault Tolerance
# Display detailed information about a session between peers.
<Sysname> display mpls ldp session verbose
 Peer LDP ID     : 1.1.1.1:0            Local LDP ID   : 3.3.3.3:0
 TCP Connection  : 3.3.3.3 -> 1.1.1.1
 Session State   : Operational          Session Role   : Active
 Session FT Flag : Off                  MD5 Flag       : Off
 Reconnect Timer : ---                  Recovery Timer : ---
 Negotiated Keepalive Timer        : 45 Sec
 Keepalive Message Sent/Rcvd       : 6/6 (Message Count)
 Label Resource Status(Peer/Local) : Available/Available
 Peer Discovery Mechanism          : Extended
 Session existed time              : 000:00:01  (DDD:HH:MM)
 LDP Extended Discovery Source     : Remote peer: 1
 Addresses received from peer: (Count: 2)
 10.1.1.1            1.1.1.1
 Peer LDP ID     : 2.2.2.2:0            Local LDP ID   : 3.3.3.3:0
 TCP Connection  : 3.3.3.3 -> 2.2.2.2
 Keepalive Message Sent/Rcvd       : 25/25 (Message Count)
 Peer Discovery Mechanism          : Basic
 Session existed time              : 000:00:06  (DDD:HH:MM)
 LDP Basic Discovery Source        :  Vlan-interface 12
 Addresses received from peer: (Count: 3)
 10.1.1.2            20.1.1.1            2.2.2.2
display mpls ldp vpn-instance vpn-instance-name [ | { begin | exclude | include } regular-expression ]
View
Default Level
1: Monitor level
vpn-instance-name: The name of an LDP-enabled VPN instance.
Use the display mpls ldp vpn-instance command to display information about a specified VPN instance.
Related commands: mpls ldp (system view), mpls ldp (interface view).
# Display information about VPN instance vpn1.
<Sysname> display mpls ldp vpn-instance vpn1
 Instance ID             : 1            VPN-Instance         : vpn1
 Instance Status         : Active       LSR ID               : 1.1.1.9
 Label Distribution Mode : Ordered      Label Retention Mode : Liberal
display mpls lsp [ { incoming-interface | outgoing-interface } interface-type interface-number ] [ in-label in-label-value ] [ out-label out-label-value ] [ { exclude | include } dest-addr mask-length ] [ vpn-instance vpn-instance-name ] [ asbr | protocol { bgp | bgp-ipv6 | crldp | ldp | rsvp-te | static | static-cr } ] [ egress | ingress | transit ] [ verbose ]
View
Default Level
1: Monitor level
incoming-interface: Incoming interface of the LSPs.
outgoing-interface: Outgoing interface of the LSPs.
in-label in-label-value: Value of the incoming label.
out-label out-label-value: Value of the outgoing label.
exclude: Excludes the specified FEC.
include: Includes the specified FEC.
dest-addr: Destination address.
vpn-instance vpn-instance-name: Name of the LDP-enabled VPN instance.
asbr: Displays information about ASBR established LSPs.
protocol: Displays information about LSPs established by a specified protocol.
bgp: Displays information about BGP LSPs.
bgp-ipv6: Displays information about IPv6 BGP LSPs, that is, BGP4+ LSPs.
crldp: Displays information about LDP CR-LSPs.
ldp: Displays information about LDP LSPs.
rsvp-te: Displays information about CR-LSPs established by RSVP-TE.
static: Displays information about static LSPs.
static-cr: Displays information about static CR-LSPs.
egress: Displays information about LSPs taking the current LSR as egress.
ingress: Displays information about LSPs taking the current LSR as ingress.
transit: Displays information about LSPs taking the current LSR as transit LSR.
Use the display mpls lsp command to display information about LSPs.
With no parameters specified, the command displays information about all LSPs.
Related commands: display mpls lsp, display mpls statistics lsp, display mpls static-lsp.
&  Note:
l      This command supports these interface types: POS interface, tunnel interface, and VLAN interface.
l      The S9500 series does not support CR-LDP.
# Display information about all LSPs.
<Sysname> display mpls lsp
                 LSP Information: L3VPN LSP
FEC              In/Out Label  In/Out IF Route-Distinguisher   Vrf Name
100.1.1.1        1025/1024     -/-       100:1                 ASBRLSP
                 LSP Information: LDP LSP
FEC              In/Out Label  In/Out IF                       Vrf Name
100.10.1.0/24    3/NULL        vlan12/-
100.10.1.0/24    3/NULL        vlan14/-
168.1.0.0/16     3/NULL        vlan16/-
172.17.0.0/16    3/NULL        vlan18/-
Table 1-6 display mpls lsp command output description
FEC
Forwarding equivalence class, in either of the following two forms:
l      IP address/mask: Assigning labels based on destination addresses.
l      IP address: Assigning labels based on the addresses of the next hops.
# Display detailed information about all LSPs.
<Sysname> display mpls lsp verbose
  No                  :  1
  VrfIndex            :
  Fec                 :  1.1.1.9/32
  Nexthop             :  127.0.0.1
  In-Label            :  3
  Out-Label           :  NULL
  In-Interface        :   Vlan-interface12
  Out-Interface       :  ----------
  LspIndex            :  10241
  Token               :  0
  LsrType             :  Egress
  Outgoing token      :  0
Label Operation     :  POP
Table 1-7 display mpls lsp verbose command output description
Fec
Token
Token ID (the public network)
LsrType
Role of the LSR for the LSP
Outgoing Token
Token ID (inter-AS VPN)
View
Default Level
1: Monitor level
None
Use the display mpls lsp statistics command to display LSP statistics.
&  Note:
# Display LSP statistics.
<Sysname> display mpls lsp statistics
Lsp Type       Total     Ingress   Transit   Egress
STATIC LSP     1         1         0         0
STATIC CRLSP   1         1         0         0
LDP LSP        0         0         0         0
CRLDP CRLSP    0         0         0         0
RSVP CRLSP     1         1         0         0
BGP LSP        0         0         0         0
ASBR LSP       0         0         0         0
BGP IPV6 LSP   0         0         0         0
LSP            1         1         0         0
CRLSP          2         2         0         0
display mpls route-state [ vpn-instance vpn-instance-name ] [ dest-addr mask-length ]
View
Default Level
1: Monitor level
vpn-instance vpn-instance-name: Name of the VPN instance.
dest-addr: Destination IP address.
mask-length: Length of the mask for the destination IP address.
Use the display mpls route-state command to display route related information.
With no VPN instance specified, the command displays route related information of the public network.
With the dest-addr dest-mask arguments not specified, the command displays all route related information.
# Display all route related information.
<Sysname> display mpls route-state
DEST/MASK   NEXT-HOP    OUT-INTERFACE  STATE LSP-COUNT  VPN-INDEX
1.1.1.1/32  10.0.0.1    Vlan16           ESTA  1           0
display mpls static-lsp [ lsp-name lsp-name ] [ { exclude | include } dest-addr mask-length ] [ verbose ]
View
Default Level
1: Monitor level
lsp-name lsp-name: Name for the LSP.
dest-addr: Destination IP address of the FEC.
Use the display mpls static-lsp command to display information about static LSPs.
Related commands: display mpls lsp, display mpls statistics lsp.
# Display brief information about static LSPs.
<Sysname> display mpls static-lsp
Name       FEC               I/O Label  I/O If                 Stat
lsp1       3.3.3.9/32        NULL/100   -/Vlan14               Up
# Display detailed information about static LSPs.
<Sysname> display mpls static-lsp verbose
No             : 1
LSP-Name       : lsp1
LSR-Type       : Ingress
FEC            : 3.3.3.9/32
In-Label       : NULL
Out-Label      : 100
In-Interface   : -
Out-Interface  : Vlan-interface14
NextHop        : 30.1.1.2
Static-Lsp Type: IPTN
Lsp Status     : Up
display mpls statistics interface { interface-type interface-number | all }
View
Default Level
1: Monitor level
all: Displays MPLS statistics for all interfaces.
Use the display mpls statistics interface command to display MPLS statistics for a specified or all interfaces.
To display statistics, set the statistics interval first. By default, the interval is 0 and the system does not collect MPLS statistics, in which case the value of every statistical item is 0.
Related commands: statistics interval.
# Display MPLS statistics for all interfaces.
<Sysname> display mpls statistics interface all
  Statistics for Interface IN :
  Incoming Interface Vlan-interface12
       Octets                  : 0
       Packets                 : 0
       Errors                  : 0
       Disables                : 0
       Failed Label Lookup     : 0
       Start Time              : 2004/04/28  10:23:55
       End Time                : 2004/04/28  10:23:55
  Statistics for Interface OUT :
  Outgoing Interface Vlan-interface12
       Octets                  : 0
       Packets                 : 0
       Errors                  : 0
       Disables                : 0
  Incoming Interface Vlan-interface14
       Octets                  : 0
       Packets                 : 0
       Errors                  : 0
       Disables                : 0
       Start Time              : 2004/04/28  10:24:04
       End Time                : 2004/04/28  10:24:04
  Outgoing Interface Vlan-interface14
       Octets                  : 0
       Packets                 : 0
       Errors                  : 0
       Disables                : 0
  Incoming Interface Vlan-interface16
       Octets                  : 0
       Packets                 : 0
       Errors                  : 0
       Disables                : 0
       Start Time              : 2004/04/28  10:24:10
       End Time                : 2004/04/28  10:24:10
  Outgoing Interface Vlan-interface16
       Octets                  : 0
       Packets                 : 0
       Errors                  : 0
       Disables                : 0
display mpls statistics lsp { index | all | name lsp-name }
View
Default Level
1: Monitor level
index: Index number of the LSP.
all: Specifies all LSPs.
lsp-name: Name of the LSP.
Use the display mpls statistics lsp command to display MPLS statistics for a specified or all LSPs.
To display the statistics, set the statistics interval first. By default, the interval is 0 and the system does not collect LSP statistics, in which case the value of every statistical item is 0.
# Display MPLS statistics for all LSPs.
<Sysname> display mpls statistics lsp all
Statistics for Lsp IN : LSP Name /LSP Index :  DynamicLsp/9217
   InSegment
       Octets                : 0
       Packets               : 0
       Errors                : 0
       Down                  : 0
       Start Time            : 2006/05/20  15:52:30
       End Time              : 2006/05/20  15:52:30
  Statistics for Lsp OUT : LSP Name /LSP Index :  DynamicLsp/9217
   OutSegment
       Octets                : 0
       Packets               : 0
       Errors                : 0
       Down                  : 0
       Start Time            : 0000/00/00  00:00:00
       End Time              : 0000/00/00  00:00:00
  Statistics for Lsp IN : LSP Name /LSP Index :  DynamicLsp/9218
   InSegment
       Octets                : 0
       Packets               : 0
       Errors                : 0
       Down                  : 0
  Statistics for Lsp OUT : LSP Name /LSP Index :  DynamicLsp/9218
   OutSegment
       Octets                : 0
       Packets               : 0
       Errors                : 0
       Down                  : 0
&  Note:
l      For an ingress, no statistics is collected in the incoming direction and the start time and end time in the InSegment part of the command output are both 0.
l      Similarly, for an egress, no statistics is collected in the outgoing direction and the start time and end time in the OutSegment part of the command output are both 0.
du-readvertise
undo du-readvertise
View
MPLS LDP view/MPLS LDP VPN instance view
Default Level
1: Monitor level
None
Use the du-readvertise command to enable label readvertisement for DU mode.
Use the undo du-readvertise command to disable the feature.
By default, label readvertisement is enabled in DU mode.
# Enable DU mode label readvertisement for the public network LDP.
[Sysname] mpls ldp
[Sysname-mpls-ldp] du-readvertise
# Enable DU mode label readvertisement for LDP instance named vpn1.
[Sysname] mpls ldp vpn-instance vpn1
[Sysname-mpls-ldp-vpn-instance-vpn1] du-readvertise
du-readvertise timer value
undo du-readvertise timer
View
Default Level
1: Monitor level
value: Label readvertisement interval in seconds.
Use the du-readvertise timer command to set the interval for label readvertisement in DU mode.
Use the undo du-readvertise timer command to restore the default.
By default, the interval for label readvertisement in DU mode is 30 seconds.
# Set the DU mode label readvertisement interval to 100 seconds for the public network LDP.
[Sysname] mpls ldp
[Sysname-mpls-ldp] du-readvertise timer 100
# Set the DU mode label readvertisement interval to 100 seconds for LDP instance named vpn1.
[Sysname-mpls-ldp-vpn-instance-vpn1] du-readvertise timer 100
1.1.25  hops-count
hops-count hop-number
undo hops-count
View
Default Level
1: Monitor level
hop-number: Hop count.
Use the hops-count command to set the maximum hop count for loop detection.
Use the undo hops-count command to restore the default.
By default, the maximum hop count for loop detection is 32.
Note that:
l           You must configure the command before enabling LDP on any interface.
l           The maximum hop count dictates how fast LDP detects a loop. Adjust this argument as required.
Related commands: loop-detect, path-vectors.
# Set the maximum hop count for loop detection to 25 for the public network LDP.
[Sysname] mpls ldp
[Sysname-mpls-ldp] hops-count 25
# Set the maximum hop count for loop detection to 25 for LDP instance named vpn1.
[Sysname-mpls-ldp-vpn-instance-vpn1] hops-count 25
label advertise { explicit-null | implicit-null | non-null }
undo label advertise
View
MPLS view
Default Level
2: System level
explicit-null: Specifies the egress to support PHP and distribute to the penultimate hop an explicit null label, whose value is 0.
implicit-null: Specifies the egress to support PHP and distribute to the penultimate hop an implicit null label, whose value is 3.
non-null: Specifies the egress to distribute the label to the penultimate hop normally and not to support PHP. The value of the distributed label will be equal to or greater than 1024.
Use the label advertise command to specify whether the egress supports PHP and what type of label the egress should distribute to the penultimate hop.
Use the undo label advertise command to restore the default.
By default, an egress supports PHP and distributes to the penultimate hop an implicit null label.
&  Note:
l      The type of label for the egress to distribute depends on whether the penultimate hop supports PHP.
l      You must use the reset mpls ldp command to reset LDP sessions for the configuration to take effect.
# Specify the egress to distribute an explicit null label to the penultimate hop.
[Sysname] mpls
[Sysname-mpls] label advertise explicit-null
label-distribution { independent | ordered }
undo label-distribution
View
Default Level
1: Monitor level
independent: Works in independent mode, advertising label bindings anytime.
ordered: Works in ordered mode, advertising to its upstream a label binding only when it receives a specific label binding message from the next hop for a FEC or the LSR itself is the egress node of the FEC.
Use the label-distribution command to configure the label distribution control mode.
Use the undo label-distribution command to restore the default.
The default mode is ordered.
&  Note:
# Set the label distribution control mode to independent for the public network LDP.
[Sysname] mpls ldp
[Sysname-mpls-ldp] label-distribution independent
# Set the label distribution control mode to independent for LDP instance named vpn1.
[Sysname-mpls-ldp-vpn-instance-vpn1] label-distribution independent
label-retention { conservative | liberal }
undo label-retention
View
MPLS LDP VPN instance view/MPLS LDP view
Default Level
1: Monitor level
conservative: Works in conservative mode, keeping only label to FEC bindings that are from its next hops for the FECs
liberal: Works in liberal mode, keeping any received label to FEC binding, whether the binding is from its next hop for the FEC or not.
Use the label-retention command to configure the label retention mode.
Use the undo label-retention command to restore the default.
The default label retention mode is liberal.
&  Note:
# Set the label retention mode to conservative for the public network LDP.
[Sysname] mpls ldp
[Sysname-mpls-ldp] label-retention conservative
# Set the label retention mode to conservative for LDP instance named vpn1.
[Sysname-mpls-ldp-vpn-instance-vpn1] label-retention conservative
1.1.29  loop-detect
loop-detect
undo loop-detect
View
Default Level
1: Monitor level
None
Use the loop-detect command to enable loop detection.
Use the undo loop-detect command to disable loop detection.
By default, loop detection is disabled.
Note that you must enable loop detection before enabling LDP on any interfaces.
Related commands: hops-count, path-vectors.
# Enable loop detection for the public network LDP.
[Sysname] mpls ldp
[Sysname-mpls-ldp] loop-detect
# Enable loop detection for LDP instance named vpn1.
[Sysname-mpls-ldp-vpn-instance-vpn1] loop-detect
1.1.30  lsp-trigger
lsp-trigger { all | ip-prefix prefix-name }
undo lsp-trigger { all | ip-prefix prefix-name }
View
MPLS view
Default Level
1: Monitor level
all: Specifies all FECs, that is, all static routes and IGP routes.
ip-prefix prefix-name: Name of the IP address prefix list.
Use the lsp-trigger command to configure the LSP establishment triggering policy.
Use the undo lsp-trigger command to restore the default.
By default, only loopback addresses with 32-bit masks can trigger LDP to establish LSPs.
Note that:
l           With the all keyword specified in the lsp-trigger command, all static and IGP routes can trigger LDP to establish LSPs.
l           Using ip-prefix prefix-name keyword and argument combination in the lsp-trigger command, only IGP routes surviving the IGP route filtering based on an IP address prefix list can trigger LDP to establish LSPs.
l           For an LSP to be established, an exactly matched routing entry must exist on the LSR. With loopback addresses using 32-bit masks, only exactly matched host routing entries can trigger LDP to establish LSPs.
l           An IP address prefix list affects only static routes and IGP routes.
l           For information about IP address prefix list, refer to Routing Policy Configuration in IP Routing Volume.
# Specify LDP to allow all static and IGP routes to trigger LSP establishment.
[Sysname] mpls
[Sysname-mpls] lsp-trigger all
1.1.31  lsr-id
lsr-id lsr-id
undo lsr-id
View
Default Level
1: Monitor level
lsr-id: LDP LSR ID.
Use the lsr-id command to configure an LDP LSR ID.
Use the undo lsr-id command to remove a configured LDP LSR ID and all LDP sessions.
By default, the LDP LSR ID takes the value of the MPLS LSR ID.
# Configure the LDP LSR ID of the public network LDP.
[Sysname] mpls ldp
[Sysname-mpls-ldp] lsr-id 2.2.2.3
# Configure the LDP LSR ID of LDP instance named vpn1.
[Sysname-mpls-ldp-vpn-instance-vpn1] lsr-id 4.2.2.3
1.1.32  md5-password
md5-password { cipher | plain } peer-lsr-id password
undo md5-password peer-lsr-id
View
Default Level
1: Monitor level
plain: Displays the password in plain text.
cipher: Displays the password in cipher text.
peer-lsr-id: MPLS LSR ID of the peer. An LSR and its peer use the same password.
password: Password string, case sensitive. If you specify the plain keyword, it must be a string of 1 to 16 characters in plain text. If you specify the cipher keyword, it can be either a string of 1 to 16 characters in plain text or a string of 24 characters in cipher text.
Use the md5-password command to enable LDP MD5 authentication and set the password, which must be the same as that configured on the peer.
Use the undo md5-password command to disable LDP MD5 authentication.
By default, LDP MD5 authentication is disabled.
Changing of the password will cause the session to be reestablished and all existing LSPs related to the session to be deleted.
This command takes effect only when MPLS LDP is enabled in the corresponding view.
# Enable MD5 authentication for the public network LDP, setting the password display mode to plain text.
[Sysname] mpls ldp
[Sysname-mpls-ldp] md5-password plain 3.3.3.3 beijingpass
# Enable MD5 authentication for LDP instance named vpn1, setting the password display mode to plain text.
[Sysname-mpls-ldp-vpn-instance-vpn1] md5-password plain 3.3.3.3 beijingpass
1.1.33  mpls
mpls
undo mpls
View
System view/interface view
Default Level
2: System level
None
Use the mpls command in system view to enable MPLS for the current node and enter MPLS view.
Use the undo mpls command in system view to disable MPLS for the current node.
Use the mpls command in interface view to enable MPLS for the interface.
Use the undo mpls command in interface view to disable MPLS for the interface.
By default, MPLS capability is not enabled.
Note that:
l           You need to configure the LSR ID before enabling MPLS capability.
l           You need to enable MPLS globally before enabling it for an interface.
l           You need to enter MPLS view to configure other MPLS commands.
Related commands: mpls lsr-id.
# Enable MPLS for the current node and enter MPLS view.
<Sysname> System-view
[Sysname] mpls lsr-id 1.1.1.1
[Sysname] mpls
[Sysname-mpls] quit
# Enable MPLS for interface VLAN-interface 1.
[Sysname-Vlan-interface1] mpls
mpls ldp [ vpn-instance vpn-instance-name ]
undo mpls ldp [ vpn-instance vpn-instance-name ]
View
Default Level
1: Monitor level
Use the mpls ldp command to enable LDP for the current node and enter MPLS LDP view.
Use the undo mpls ldp command to disable LDP for the current node and remove all LDP instances
Use the mpls ldp vpn-instance command to enable LDP for a VPN instance, create an LDP instance, and enter MPLS LDP VPN instance view.
Use the undo mpls ldp vpn-instance command to disable LDP for a VPN instance.
Configure the mpls ldp command after configuring MPLS LSR ID and enabling MPLS for the current node.
# Enable LDP for the current node.
[Sysname] mpls
[Sysname-mpls] quit
[Sysname] mpls ldp
[Sysname-mpls-ldp] quit
# Enable LDP for VPN instance vpn1.
1.1.35  mpls ldp (interface view)
mpls ldp
undo mpls ldp
View
Interface view
Default Level
1: Monitor level
None
Use the mpls ldp command to enable LDP on an interface.
Use the undo mpls ldp command to disable LDP on an interface.
By default, LDP is disabled on an interface.
After you enable LDP on an interface, the interface will create an entity and periodically sends Hello messages.
Before enabling LDP in interface view, be sure to complete the following tasks:
l           Use the mpls command in system view to enable MPLS.
l           Use the mpls ldp command in system view to enable MPLS LDP.
l           Use the mpls command in interface view to enable MPLS.
If the interface is bound to a VPN instance, you must use the mpls ldp vpn-instance command to enable LDP for the VPN instance before enabling LDP on the interface to add the interface into the VPN instance.
&  Note:
# Enable LDP for interface VLAN-interface 1.
[Sysname-Vlan-interface1] mpls ldp
1.1.36  mpls ldp advertisement
mpls ldp advertisement { dod | du }
undo mpls ldp advertisement
View
Interface view
Default Level
1: Monitor level
dod: Works in downstream on demand (DoD) mode, advertising a label to FEC binding in response to the explicit request of an upstream LSR.
du: Works in downstream unsolicited (DU) mode, advertising label to FEC bindings to LSRs without explicitly requesting bindings.
Use the mpls ldp advertisement command to specify the label advertisement mode.
Use the undo mpls ldp advertisement command to restore the default.
By default, DU mode is used.
Note that changing the label advertisement mode will cause the existing sessions to be reestablished, and the LSPs established by the sessions to be deleted and reestablished.
# Configure the label advertisement mode.
[Sysname] interface vlan-interface 12
[Sysname-Vlan-interface12] mpls
[Sysname-Vlan-interface12] mpls ldp
[Sysname-Vlan-interface12] mpls ldp advertisement du
[Sysname-Vlan-interface12] mpls ldp advertisement dod
# Restore the default advertisement mode.
[Sysname-Vlan-interface12] undo mpls ldp advertisement
1.1.37  mpls ldp remote-peer
mpls ldp remote-peer remote-peer-name
undo mpls ldp remote-peer remote-peer-name
View
Default Level
1: Monitor level
remote-peer-name: Name of the remote peer, case-insensitive.
Use the mpls ldp remote-peer command to create a remote peer entity and enter MPLS LDP remote peer view.
Use the undo mpls ldp remote-peer command to remove a remote peer entity.
Related commands: remote-ip.
# Create a remote peer entity named BJI.
[Sysname] mpls ldp remote-peer BJI
[Sysname-mpls-ldp-remote-bji]
1.1.38  mpls ldp timer hello-hold
mpls ldp timer hello-hold value
undo mpls ldp timer hello-hold
View
Interface view/MPLS LDP remote peer view
Default Level
1: Monitor level
value: Length of time for the Hello timer.
Use the mpls ldp timer hello-hold command to set the Hello timers.
Use the undo mpls ldp timer hello-hold command to restore the defaults.
In interface view, you configure the link Hello timer; in MPLS LDP remote peer view, you configure the targeted Hello timer.
By default, the value of the link Hello timer is 15 seconds, while that of the targeted Hello timer is 45 seconds.
&  Note:
Changing the values of the Hello timers does not affect any existing session.
# Set the link Hello timer for local sessions to 100 seconds on interface VLAN-interface 1.
[Sysname-Vlan-interface1] mpls ldp timer hello-hold 100
# Set the targeted Hello timer for remote sessions to 1000 seconds.
[Sysname-mpls-ldp-remote-bji] remote-ip 3.3.3.3
[Sysname-mpls-ldp-remote-bji] mpls ldp timer hello-hold 1000
1.1.39  mpls ldp timer keepalive-hold
mpls ldp timer keepalive-hold value
undo mpls ldp timer keepalive-hold
View
Default Level
1: Monitor level
value: Length of time for the Keepalive timer.
Use the mpls ldp timer keepalive-hold command to set the keepalive timers.
Use the undo mpls ldp timer keepalive-hold command to restore the defaults.
In interface view, you configure the link Keepalive timer; in MPLS LDP remote peer view, you configure the targeted Keepalive timer.
By default, both the link Keepalive timer and targeted Keepalive timer are set to 45 seconds.
  Caution:
l      If more than one link with LDP enabled exists between two LSRs when, for example, the two LSRs are connected through multiple interfaces, the Keepalive timers of all the links must be identical for sessions to be stable.
l      Changing the values of the Keepalive timers will cause existing LDP sessions to be reestablished.
# Set the link Keepalive timer for local sessions to 50 seconds on interface VLAN-interface 1.
[Sysname-Vlan-interface1] mpls ldp timer keepalive-hold 50
# Set the targeted Keepalive timer for remote sessions to 1000 seconds.
[Sysname-mpls-ldp-remote-bji] mpls ldp timer keepalive-hold 1000
1.1.40  mpls ldp transport-address
mpls ldp transport-address { interface-type interface-number | interface }
undo mpls ldp transport-address
View
Default Level
1: Monitor level
interface-type interface-number: Specifies an interface by its type and number, making LDP use the address of this interface as the TCP transport address.
interface: Specifies that LDP use the IP address of the current interface as the TCP transport address. This keyword is available only in interface view.
Use the mpls ldp transport-address command to configure the LDP transport addresses.
Use the undo mpls ldp transport-address command to restore the defaults.
By default, the transport addresses are both the MPLS LSR ID.
In interface view, you configure the link Hello transport address; in MPLS LDP remote peer view, you configure the targeted Hello transport address.
# On interface VLAN-interface 1, configure the link Hello transport address for local sessions as the IP address of the current interface.
[Sysname-Vlan-interface1] mpls ldp transport-address interface
# Configure the targeted Hello transport address for remote sessions to be the IP address of interface VLAN-interface 1.
[Sysname-mpls-ldp-remote-bji] mpls ldp transport-address vlan-interface 1
1.1.41  mpls lsr-id
mpls lsr-id lsr-id
undo mpls lsr-id
View
Default Level
2: System level
lsr-id: ID for identifying the LSR, in dotted decimal notation.
Use the mpls lsr-id command to configure the ID of an LSR.
Use the undo mpls lsr-id command to remove the ID of an LSR.
By default, no LSR ID is configured.
Your must configure the LSR ID of an LSR before configuring any other MPLS commands.
You are recommended to use the address of a loopback interface on the LSR as the ID.
Related commands: display mpls interface.
# Set the LSR ID to 3.3.3.3.
[Sysname] mpls lsr-id 3.3.3.3
1.1.42  mtu-signalling
mtu-signalling
undo mtu-signalling
View
MPLS LDP view
Default Level
1: Monitor level
None
Use the mtu-signalling command to enable MTU signaling.
Use the undo mtu-signalling command to disable MTU signaling.
By default, MTU signaling is enabled.
Enabling/disabling MTU signaling will cause the existing sessions to be reestablished, and the LSPs established by the sessions to be deleted and reestablished.
# Enable MTU signaling.
[Sysname] mpls ldp
[Sysname-mpls-ldp] mtu-signalling
1.1.43  path-vectors
path-vectors pv-number
undo path-vectors
View
Default Level
1: Monitor level
pv-number: Path vector maximum hop count32.
Use the path-vectors command to set the path vector maximum hop count.
Use the undo path-vectors command to restore the default.
By default, the path vector maximum hop count for an instance is 32.
Note that this command takes effect only when MPLS LDP is enabled on all interfaces.
Related commands: loop-detect, hops-count.
# Set the path vector maximum hop count to 3 for the public network LDP.
[Sysname] mpls ldp
[Sysname-mpls-ldp] path-vectors 3
# Set the path vector maximum hop count to 3 for LDP instance named vpn1.
[Sysname-mpls-ldp-vpn-instance-vpn1] path-vectors 3
1.1.44  ping lsp
ping lsp [ -a source-ip | -c count | -exp exp-value | -h ttl-value | -m wait-time | -r reply-mode | -s packet-size | -t time-out | -v ] * { ipv4 dest-addr mask-length [ destination-ip-addr-header ] | te interface-type interface-number }
View
Default Level
0: Visit level
-a source-ip: Specifies the source address for the echo request message.
-c count: Specifies the number of attempts to sending the request message.
-exp exp-value: Specifies the EXP value for the echo request message.
-h ttl-value: Specifies the TTL value for the echo request message.
-m wait-time: Specifies the interval for sending echo request messages.
-r reply-mode: Specifies the reply mode in response to an echo request message. The S9500 series supports only two of the four reply modes in RFC 4397. A value of 1 means “Do not response”, while a value of 2 means “Respond using a UDP packet”.
-s packet-size: Specifies the payload length of the echo request message.
-t time-out: Specifies the timeout interval for the response to an echo request message.
-v: Displays detailed response information.
ipv4 dest-addr mask-length: Specifies the LDP Ipv4 destination address and the mask.
destination-ip-addr-header: Specifies the IP header destination address for the MPLS echo request message, which can be any address on segment 127.0.0.0/8, that is, any local loopback address.
te interface-type interface-number: Specifies a tunnel interface by its type and number.
Use the ping lsp command to check the validity and reachabiliity of an LSP.
# Ping a specified address by send five packets.
<Sysname> ping lsp –c 5 ipv4 3.3.3.9 32
LSP PING FEC: LDP IPV4 PREFIX 3.3.3.9/32 : 100  data bytes, press CTRL_C to break
    Reply from 100.1.2.1: bytes=100 Sequence=0 time = 31 ms
    Reply from 100.1.2.1: bytes=100 Sequence=1 time = 62 ms
    Reply from 100.1.2.1: bytes=100 Sequence=2 time = 62 ms
    Reply from 100.2.3.1: bytes=100 Sequence=3 time = 62 ms
    Reply from 100.1.2.1: bytes=100 Sequence=4 time = 62 ms
  --- FEC: LDP IPV4 PREFIX 3.3.3.9/32 ping statistics ---
    5 packet(s) transmitted
    5 packet(s) received
    0.00% packet loss
    round-trip min/avg/max = 31/55/62 ms
1.1.45  remote-ip
remote-ip ip-address
undo remote-ip
View
Default Level
1: Monitor level
ip-address: IP address of the remote peer.
Use the remote-ip command to configure the LDP remote peer IP address.
Use the undo remote-ip command to remove the configuration.
Note that the LDP remote peer IP address must be the MPLS LSR ID of the remote peer. Two peers use their respective MPLS LSR ID as the transport addresses to establish the TCP connection.
Related commands: mpls ldp remote-peer.
# Configure the LDP remote peer IP address.
1.1.46  reset mpls ldp
reset mpls ldp [ all | [ vpn-instance vpn-instance-name ] [ peer peer-id ] ]
View
Default Level
1: Monitor level
peer-id: MPLS LSR ID of the peer.
all: Specified all LDP instances.
Use the reset mpls ldp command to reset LDP sessions.
l           With no parameters specified, the command resets the sessions of all public network LDP instances.
l           With only the all keyword specified, the command resets the sessions of all LDP instances, including those of the public LDP instances and those of the VPN LDP instances.
l           With the vpn-instance vpn-instance-name keyword and argument combination specified, the command resets the sessions of the specified LDP instance.
l           With the peer peer-id keyword and argument combination specified, the command resets the sessions with the specified peer.
# Reset the sessions of all public network LDP instances.
<Sysname> reset mpls ldp
# Reset the sessions of all LDP instances.
<Sysname> reset mpls ldp all
# Reset the sessions of LDP instance vpn1.
<Sysname> reset mpls ldp vpn-instance vpn1
# Reset the sessions with a specified peer.
<Sysname> reset mpls ldp peer 2.2.2.9
1.1.47  reset mpls statistics interface
reset mpls statistics interface { interface-type interface-number | all }
View
Default Level
2: System level
all: Specifies all interfaces.
Use the reset mpls statistics interface command to clear MPLS statistics for a specified or all MPLS interfaces.
Related commands: display mpls statistics interface.
# Clear MPLS statistics for interface VLAN-interface 1.
<Sysname> reset mpls statistics interface vlan-interface 1
1.1.48  reset mpls statistics lsp
reset mpls statistics lsp { index | all | name lsp-name }
View
Default Level
2: System level
index: Index number of the LSP, in the range 0 to 4,294,967,295.
lsp-name: Name of the LSP, a string of 1 to 15 characters.
Use the reset mpls statistics lsp command to clear MPLS statistics for a specified or all LSPs.
Related commands: display mpls statistics lsp.
# Clear MPLS statistics for LSP lsp1.
<Sysname> reset mpls statistics lsp lsp1
1.1.49  snmp-agent trap enable mpls
undo snmp-agent trap enable mpls
View
Default Level
3: Manage level
None
Use the snmp-agent trap enable mpls command to enable the MPLS trap function.
Use the undo snmp-agent trap enable command to disable the function.
By default, the function is disabled.
# Enable the MPLS trap function.
[Sysname] snmp-agent trap enable mpls
1.1.50  static-lsp egress
static-lsp egress lsp-name incoming-interface interface-type interface-number in-label in-label
undo static-lsp egress lsp-name
View
Default Level
2: System level
in-label: Incoming label value.
Use the static-lsp egress command to configure a static LSP taking the current LSR as the egress.
Use the undo static-lsp egress command to remove a static LSP taking the current LSR as the egress.
Related commands: static-lsp ingress, static-lsp transit, display mpls static-lsp.
# Configure a static LSP named bj-sh, taking the current LSR as the egress.
[Sysname] static-lsp egress bj-sh incoming-interface vlan-interface 12 in-label 233
1.1.51  static-lsp ingress
static-lsp ingress lsp-name destination dest-addr { mask | mask-length } { nexthop next-hop-addr | outgoing-interface interface-type interface-number } out-label out-label
undo static-lsp ingress lsp-name
View
Default Level
2: System level
dest-addr: Destination IP address of the LSP.
mask: Mask of the destination IP address.
next-hop-addr: Address of the next hop.
outgoing-interface interface-type interface-number: Specifies an interface by its type and number.
out-label: Outgoing label value.
Use the static-lsp ingress command to configure a static LSP taking the current LSR as the ingress.
Use the undo static-lsp ingress command to remove a static LSP taking the current LSR as the ingress.
Note that:
l           If you specify the next hop when configuring a static LSP, and the address of the next hop is present in the routing table, you must also specify the next hop when configuring the static IP route.
l           If you specify the outgoing interface when configuring a static LSP, you must also specify the outgoing interface when configuring the static IP route.
l           The address of the next hop cannot be any local public network IP address.
Related commands: static-lsp egress, static-lsp transit, display mpls static-lsp.
# Configure a static LSP to destination address 202.25.38.1, taking the current LSR as the ingress.
[Sysname] static-lsp ingress bj-sh destination 202.25.38.1 24 nexthop 202.55.25.33 out-label 237
1.1.52  static-lsp transit
static-lsp transit lsp-name incoming-interface interface-type interface-number in-label in-label { nexthop next-hop-addr | outgoing-interface interface-type interface-number } out-label out-label
undo static-lsp transit lsp-name
View
Default Level
2: System level
interface-type interface-number: Specifies an incoming interface by its type and number.
nexthop next-hop-addr: Address of the next hop.
outgoing-interface interface-type interface-number: Specifies an outgoing interface by its type and number.
Use the static-lsp transit command to configure a static LSP taking the current LSR as a transit LSR.
Use the undo static-lsp transit command to remove a static LSP taking the current LSR as a transit LSR.
Note that:
Related commands: static-lsp egress, static-lsp ingress.
# Configure a static LSP, taking VLAN-interface 12 as the incoming interface and setting the incoming label as 123 and the outgoing label as 253.
[Sysname] static-lsp transit bj-sh incoming-interface vlan-interface 12 in-label 123 nexthop 202.34.114.7 out-label 253
1.1.53  statistics interval
statistics interval interval-time
undo statistics interval
View
MPLS view
Default Level
2: System level
interval-time: Statistics Interval.
Use the statistics interval command to set the statistics interval, that is, the interval for collecting statistics.
Use the undo statistics interval command to restore the default.
By default, the interval is 0.
Related commands: display mpls statistics interface, display mpls statistics lsp.
# Set the statistics interval to 30 seconds.
[Sysname] mpls
[Sysname-mpls] statistics interval 30
1.1.54  tracert lsp
tracert lsp [-a source-ip | -exp exp-value | -h ttl-value | -r reply-mode |-t time-out ] * { ipv4 dest-addr mask-length [ destination-ip-addr-header ] | te interface-type interface-number }
View
Default Level
0: Visit level
-r reply-mode: Specifies the reply mode in response to an echo request message. The reply-mode argument can be 1 or 2. A value of 1 means “Do not response”, while a value of 2 means “Respond using a UDP packet”.
-t time-out: Specifies the timeout interval for the response to an echo request message (milliseconds).
ipv4 dest-addr mask: Specifies the LDP Ipv4 destination address and the mask.
Use the tracert lsp command to locate an MPLS LSP error.
# Locate an error along the LSP to 3.3.3.9 on host 1.1.1.1.
<Sysname> tracert lsp ipv4 3.3.3.9 32
LSP Trace Route FEC: LDP IPV4 PREFIX 3.3.3.9/32 , press CTRL_C to break.
  TTL   Replier            Time    Type      Downstream
  0                                Ingress   10.4.5.1/[1025]
  1     10.4.5.1           1       Transit   100.3.4.1/[1024]
  2     100.1.4.2          63      Transit   100.1.2.1/[3]
  3     100.1.2.1          129     Egress
1.1.55  ttl expiration
ttl expiration pop
undo ttl expiration pop
View
MPLS view
Default Level
2: System level
None
Use the ttl expiration pop command to specify that the ICMP response message be transported back along the IP route when the TTL of an MPLS packet expires.
Use the undo ttl expiration pop command to specify that the ICMP response be transported back along the LSP when the TTL of an MPLS packet expires.
By default, the ICMP response message of an MPLS packet with a one-level label is transported back along the IP route.
Note that configuring the undo mpls command will remove the configuration of the ttl expiration pop command.
Related commands: ttl propagate.
# Specify that the ICMP response be transported back along the LSP when the TTL of an MPLS packet expires
[Sysname] mpls
[Sysname-mpls] undo ttl expiration pop
1.1.56  ttl propagate
ttl propagate { public | vpn }
undo ttl propagate { public | vpn }
View
MPLS view
Default Level
2: System level
public: Enables MPLS IP TTL propagation for public network packets.
vpn: Enables MPLS IP TTL propagation for VPN packets.
Use the ttl propagate command to enable MPLS IP TTL propagation for either public network packets or VPN packets.
Use the undo ttl propagate command to disable the function.
By default, MPLS IP TTL propagation is enabled for only public network packets.
Related commands: ttl expiration.
# Enable MPLS IP TTL propagation for VPN packets.
[Sysname] mpls
[Sysname-mpls] ttl propagate vpn
