H3C S9500 Command Manual-Release2132[V2.03]-05 MPLS VPN Volume
HomeSupportSwitchesS9500 SwitchesReference GuidesCommand ReferencesH3C S9500 Command Manual-Release2132[V2.03]-05 MPLS VPN Volume
04-MPLS L2VPN Commands
04-MPLS L2VPN Commands 118.74 KB
Chapter 1  MPLS L2VPN Configuration Commands
1.1  MPLS L2VPN Configuration Commands
1.1.1  ccc interface in-label out-label
ccc ccc-connection-name interface interface-type interface-number in-label in-label-value out-label out-label-value { nexthop ip-address | out-interface interface-type interface-number }
undo ccc ccc-connection-name
View
Default Level
2: System level
ccc-connection-name: Name for the CCC connection. It is used for uniquely identifying a CCC connection on a PE.
interface-type interface-number: Specifies the interface connecting the local CE by its type and number.
in-label-value: Incoming label.
out-label-value: Outgoing label.
nexthop ip-address: Specifies the IP address of the next hop.
out-interface interface-type interface-number: Specifies the outgoing interface by its type and number.
Use the ccc interface in-label out-label command to create a remote CCC connection between CEs connected to different PEs.
Use the undo ccc command to delete a CCC connection.
A PE uses connection names to identify different CCC connections. A CCC connection can have different names on different PEs.
&  Note:
If the outgoing interface is a VLAN interface, you need to use the nexthop ip-address combination to specify the IP address of the next hop. Otherwise, you need to use the out-interface interface-type interface-number combination to specify the outgoing interface.
# Create a remote CCC connection from CEA to CEB, setting the incoming interface to that connecting CEA, namely VLAN-interface 10; the next hop to 20.1.1.2; the incoming label to 100; and the outgoing label to 200.
[Sysname] ccc CEA-CEB interface vlan-interface 10 in-label 100 out-label 200 nexthop 20.1.1.2
1.1.2  ccc interface out-interface
ccc ccc-connection-name interface interface-type interface-number out-interface interface-type interface-number
View
Default Level
2: System level
interface interface-type interface-number: Specifies the interface for connecting the first CE by its type and number.
out-interface interface-type interface-number: Specifies the interface for connecting the second CE by its type and number.
&  Note:
Support for this feature varies by device.
Use the ccc interface out-interface command to create a local CCC connection between two CEs connected to the same PE.
# Create a local CCC connection between two CEs connected to the same PE.
[Sysname] ccc ccc-connect-1 interface vlan-interface 10 out-interface vlan-interface 2
1.1.3  ce
ce ce-name [ id ce-id [ range ce-range ] [ default-offset ce-offset ] ]
undo ce ce-name
View
MPLS L2VPN view, MPLS L2VPN CE view
Default Level
2: System level
ce-name: Unique name for a CE in the current VPN of the current PE. It cannot include the character of “-”.
ce-id: ID for the CE in the VPN.
ce-range: Maximum number of CEs that the current PE can support. It defaults to 10.
ce-offset: Original CE offset. It can be either 0 or 1. The default is 0.
Use the ce command to create a CE and enter MPLS L2VPN CE view.
Use the undo ce command to delete a CE.
# Create a CE named ce1 for a VPN.
[Sysname] mpls l2vpn vpn1 encapsulation ethernet
[Sysname-mpls-l2vpn-vpn1] route-distinguisher 100:1
[Sysname-mpls-l2vpn-vpn1] ce ce1 id 1
1.1.4  connection
connection [ ce-offset id ] interface interface-type interface-number [ tunnel-policy tunnel-policy-name ]
undo connection { ce-offset id | interface interface-type interface-number }
View
MPLS L2VPN CE view
Default Level
2: System level
id: ID of the peer CE of the L2VPN connection.
interface-type interface-number: Specifies the interface connecting the CE by its type and number. The encapsulation type must be same as that of the VPN.
tunnel-policy-name: Tunneling policy for the VC.
Use the connection command to create a Kompella connection.
Use the undo connection command to delete a Kompella connection on a CE interface.
When creating a Kompella connection, you must specify the ID of the peer CE and the local CE interface.
If you do not specify the tunneling policy, or specify the tunneling policy name but do not configure the policy, the default policy is used. The default tunneling policy uses LSP tunnels and the load balance number of one.
# Create a Kompella connection.
[Sysname-mpls-l2vpn-ce-vpn1-ce1] connection ce-offset 1 interface vlan-interface 10
1.1.5  debugging mpls l2vpn
debugging mpls l2vpn { all | advertisement | error | event | connections [ interface interface-type interface-number ] | hsb }
undo debugging mpls l2vpn { all | advertisement | error | event | connections [ interface interface-type interface-number ] | hsb }
View
Default Level
1: Monitor level
all: Enables/disables all L2VPN debugging.
advertisement: Enables/disables debugging of BGP or LDP advertisement for L2VPN.
error: Enables/disables error debugging for L2VPN.
event: Enables/disables event debugging for L2VPN.
connections: Enables/disables connection debugging for L2VPN.
hsb: Enables/disables hot standby debugging for L2VPN.
Use the debugging mpls l2vpn command to enable a specific or all the debugging functions for L2VPN.
Use the undo debugging mpls l2vpn command to disable a specific or all the debugging functions for L2VPN.
By default, L2VPN debugging is disabled.
# Enable all the L2VPN debugging functions.
<Sysname> debugging mpls l2vpn all
1.1.6  display bgp l2vpn
display bgp l2vpn { all | group [ group-name ] | peer [ [ ip-address ] verbose ] | route-distinguisher route-distinguisher [ ce-id ce-id [ label-offset label-offset ] ] }
View
Default Level
1: Monitor level
all: Displays all L2VPN information.
group-name: Name of the peer group.
ip-address: IP address of the peer.
verbose: Displays detailed information.
route-distinguisher: Route distinguisher in the format of nn:nn or IP-address:nn.
ce-id: VPN CE ID of the MPLS L2VPN connection. A remote connection requires the remote CE number.
label-offset: Label offset.
Use the display bgp l2vpn command to display information about BGP L2VPN in the BGP routing table.
Related commands: route-distinguisher.
# Display all information about L2VPN in the BGP routing table.
<Sysname> display bgp l2vpn all
BGP Local router ID : 2.2.2.9, local AS number : 100
 Origin codes:i - IGP, e - EGP, ? - incomplete
 bgp.l2vpn: 1 destination
 Route Distinguisher: 100:1
CE ID   Label Offset  Label Base    nexthop         pref    as-path
 4      0             61442        3.3.3.9         100
Table 1-1 Description on the fields of the display bgp l2vpn all command
BGP Local router ID
BGP local router ID
local AS number
Local AS number
Origin codes
Route origin codes, which can be:
i – IGP: Indicates that the network layer reachability information is from within the AS
e – EGP: Indicates that the network layer reachability information is learned through EGP
? – incomplete: Indicates that the network layer reachability information is learned through other ways
bgp l2vpn
Number of BGP L2VPNs
Route Distinguisher
RD
CE ID
CE number in the VPN
Label Offset
Label offset
Label Base
Label base
nexthop
pref
Local preference
as-path
AS-PATH of the route
# Display brief information about L2VPN peers in the BGP routing table.
<Sysname> display bgp l2vpn peer
BGP local router ID : 1.1.1.9
Local AS number : 100
Total number of peers : 1            Peers in established state : 1
  Peer       V    AS  MsgRcvd  MsgSent  OutQ  PrefRcv  Up/Down  State
  3.3.3.9    4   100     20      22     0           0  00:15:30 Established
Table 1-2 Description on the fields of the display bgp l2vpn peer command
BGP local router ID
ID of the local BGP route
Local AS number
Local AS number
Number of peers
Number of peers with BGP sessions in the state of established
Peer
V
BGP version that the peer is using
AS
AS number
MsgRcvd
Number of messages received
MsgSent
Number of messages sent
OutQ
Number of messages waiting to be sent to the peer
PrefRcv
Number of prefixes received
Up/Down
Duration that the BGP session is in the current status
Status of the peer
# Display detailed information about L2VPN peer 3.3.3.9 in the BGP routing table.
<Sysname> display bgp l2vpn peer 3.3.3.9 verbose
         Peer: 3.3.3.9   Local: 2.2.2.9
         Type: IBGP link
         BGP version 4, remote router ID 3.3.3.9
         BGP current state: Established, Up for   00:21:15
         BGP last state: OpenConfirm
         Port:  Local - 179      Remote - 1034
         Configured: Active Hold Time: 180 sec   Keep Alive Time:60 sec
         Received  : Active Hold Time: 180 sec
         Negotiated: Active Hold Time: 180 sec   Keep Alive Time:60 sec
         Peer optional capabilities:
         Peer support bgp multi-protocol extended
         Peer support bgp route refresh capability
         Address family IPv4 Unicast: advertised and received
         Address family L2VPN: advertised and received
 Received: Total 26 messages, Update messages 2
 Sent: Total 28 messages, Update messages 2
 Maximum allowed prefix number: 150000
 Threshold: 75%
 Minimum time between advertisement runs is 15 seconds
 Peer Preferred Value: 0
 Routing policy configured:
Table 1-3 Description on the fields of the display bgp l2vpn peer verbose command
Peer
Local
IP address of the local router
BGP type
BGP current state
Current status of the BGP session
BGP current event
Current event of the BGP session
BGP last state
Last status of the BGP session
Port
Ports used by the BGP session, one is local or the other remote
Configured
Settings of the local timers
Received
Settings of the remote timers
Negotiated
Negotiated settings of the timers
Optional peer capabilities, including the support for BGP multicast protocol extension and the support for BGP route refreshing
IPv4 unicast address family capability
L2VPN address family
Received
Total number of received messages and that of received update messages
Sent
Total number of sent messages and that of received update messages
Maximum number of routes allowed
Threshold
Threshold value
Routing policy specified for the peer
# Display L2VPN information with the RD being 100:1 in the BGP routing table.
<Sysname> display bgp l2vpn route-distinguisher 100:1
Table 1-4 Description on the fields of display bgp l2vpn route-distinguisher
BGP Local router ID
BGP local router ID
local AS number
Local AS number
Origin codes
bgp l2vpn
Route Distinguisher
RD
CE ID
Label Offset
Label offset
Label Base
Label base
nexthop
pref
Preference
as-path
# Display L2VPN information with the RD being 100:1 and the CE ID being 4 in the BGP routing table.
<Sysname> display bgp l2vpn route-distinguisher 100:1 ce-id 4
 1       0              61442         3.3.3.9          100
Table 1-5 Description on the fields of display bgp l2vpn route-distinguisher ce-id
BGP Local router ID
BGP local router ID
local AS number
Local AS number
Origin codes
Route Distinguisher
RD
CE ID
Label Offset
Label offset
Label Base
Label base
nexthop
pref
Preference
as-path
# Display L2VPN information with the RD being 100:1, the CE ID being 4, and the label offset being 0 in the BGP routing table.
<Sysname> display bgp l2vpn route-distinguisher 100:1 ce-id 4 label-offset 0
 nexthop:3.3.3.9,  pref :100,     as-path :
 label base:61442,label range:10,layer-2 mtu:1500,encap type:Ethernet
  label            state
  61442            down
  61443            up
  61444            down
  61445            down
  61446            down
  61447            down
  61448            down
  61449            down
  61450            down
  61451            down
Table 1-6 Fields of display bgp l2vpn route-distinguisher ce-id label-offset
BGP Local router ID
BGP local router ID
local AS number
Local AS number
Origin codes
nexthop
pref
Preference
as-path
label base
Label base
label range
Label range
layer-2 mtu
Layer 2 MTU
encap type
Encapsulation type
1.1.7  display ccc
display ccc [ ccc-name ccc-name | type { local | remote } ]
View
Default Level
1: Monitor level
ccc-name: CCC connection name.
type: Specifies the type of the CCC connections.
local: Specifies local CCC connections.
remote: Specifies remote CCC connections.
Use the display ccc command to display information about CCC connections.
If you do not specify the connection name or type, this command displays information about all CCC connections.
# Display information about CCC connection c1.
<Sysname> display ccc ccc-name c1
***Name                  : c1
Type                  : remote
State                    : up
Intf                 : Vlan-interface1 (up)
In-label             : 100
Out-label                : 200
Nexthop              : 20.1.1.1
# Display information about all local CCC connections.
<Sysname> display ccc type local
***Name                 : c2
Type                  : local
State                    : up
Intf1                    : vlan-interface12 (up)
Intf2                    : vlan-interface14 (up)
# Display information about all CCC connections.
Total  ccc vc            : 1
Local  ccc vc            : 0,  0 up
Remote ccc vc            : 1,  0 up
***Name                 : c1
Type                  : remote
State                    : down
Intf                 : vlan-interface12 (up)
In-label             : 100
Out-label                : 200
Nexthop              : 20.1.1.1
Table 1-7 Description on the fields of the display ccc command
Total  ccc vc
Total number of CCC connections
Local  ccc vc
Number of local CCC connections
Remote ccc vc
Number of remote CCC connections
Name
Name of the CCC connection
Type of the CCC connection
Status of the CCC connection
Intf
Interface of the CCC connection
In-label
Incoming label
Out-label
Outgoing label
Nexthop
1.1.8  display l2vpn ccc-interface vc-type
display l2vpn ccc-interface vc-type { all | bgp-vc | ccc | ldp-vc | static-vc } [ up | down ]
View
Default Level
1: Monitor level
all: Specifies interfaces of any encapsulation types.
bgp-vc: Specifies interfaces of Kompella L2VPN VCs.
ccc: Specifies interfaces of CCC L2VPN VCs.
ldp-vc: Specifies interfaces of Martini L2VPN VCs.
static-vc: Specifies interfaces of SVC L2VPN VCs.
up: Specifies CCC interfaces in the state of UP.
down: Specifies CCC interfaces in the state of DOWN.
Use the display l2vpn ccc-interface vc-type command to display information about specified L2VPN VC interfaces.
# Display information about interfaces of any encapsulation types.
<Sysname> display l2vpn ccc-interface vc-type all
Total ccc-interface of CCC VC: 1
up (1), down (0)
Interface              Encap Type  State   VC Type
Vlan-interface 2        vlan         up      CCC
<Sysname> display l2vpn ccc-interface vc-type bgp-vc
Total ccc-interface of BGP VC: 1
up (1), down (0)
Vlan-interface 2   vlan         up      bgp-vc
<Sysname> display l2vpn ccc-interface vc-type svc-vc up
Total ccc-interface of SVC VC: 1,
up (1), down (0)
Vlan-interface 2    vlan         up    static-vc
Table 1-8 Description on the fields of display l2vpn ccc-interface vc-type
Total ccc-interface of XXX VC
Total interface number of L2VPN VCs of type xxx
Name of the interface
Encap Type
Encapsulation type of the interface
Status of the interface
VC Type
Encapsulation type of the L2VPN VC interface
1.1.9  display mpls l2vc
display mpls l2vc [ interface interface-type interface-number | remote-info ]
View
Default Level
1: Monitor level
interface interface-type interface-number: Specifies the interface connecting the CE by its type and number.
remote-info: Specifies Martini VCs from the remote peer.
Use the display mpls l2vc command to display information about Martini VCs configured on the device.
If you specify an interface, the command displays information about Martini VCs configured on the CE interface.
# Display information about all Martini VCs configured on the device.
<Sysname> display mpls l2vc
total  ldp vc : 3     0 up       3 down
Transport  Client       VC      Local      Remote     Tunnel
VC ID      Intf         State   VC Label   VC Label   Policy
5        Vlan-interface 2  down  61442        0        lsp3
6        Vlan-interface 3  down  61451        0        lsp2
7        Vlan-interface 4  down  61463        0        plcy3
Table 1-9 Description on the fields of the display mpls l2vc command
total  ldp vc
Total number of Martini VCs
Transport VC ID
Remote VC ID
Client Intf
Interface connected with the CE
VC State
Status of the VC
Local VC Label
Local VC label
Remote VC Label
Remote VC label
Tunnel Policy
Tunnel policy configured
# Display information about all Martini VCs configured on interface VLAN-interface 2.
<Sysname> display mpls l2vc interface vlan-interface 2
***VC ID                  : 5
VC State               : down
Destination            : 4.5.6.8
Client Intf            : Vlan-interface 2 is down
Local Group ID         : 0
Remote Group ID        : 0
Local VC Label         : 61442
Remote VC Label        : 0
Tunnel Policy          : lsp3
Tunnel Type            : lsp
Tunnel ID              : 0x226013
Table 1-10 Description on the fields of the display mpls l2vc interface command
VC ID
Remote VC ID
VC State
Status of the VC
Destination
Destination IP address
Client Intf
Local Group ID
Local VC group ID, used for the L2VPN  VC FEC TLV field of LDP messages
Remote Group ID
Remote VC group ID, used for the L2VPN  VC FEC TLV field of LDP messages
Local VC Label
Local VC label
Remote VC Label
Remote VC label
Tunnel Policy
Tunnel Type
Type of the tunnel
Tunnel ID
Tunnel ID
# Display information about Martini VCs received from the remote peer.
<Sysname> display mpls l2vc remote-info
total remote ldp vc : 1
Transport  Group      Peer            Remote     Remote     C     Remote
VC ID      ID         Addr            Encap      VC Label   Bit   MTU
100        0          3.3.3.9         vlan        61442      0     1500
Table 1-11 Description on the fields of the display mpls l2vc remote-info command
total remote ldp vc
Total number of remote LDP VCs
Transport VC ID
Remote VC ID
Group ID
Peer Addr
Remote Encap
Encapsulation type of the remote interface
Remote VC Label
Remote VC label
C Bit
Control word, which can be 0 or 1
Remote MTU
MTU of the remote interface
1.1.10  display mpls l2vpn
display mpls l2vpn [ export-route-target-list | import-route-target-list | vpn-name vpn-name [ local-ce | remote-ce ] ]
View
Default Level
1: Monitor level
export-route-target-list: Displays the export route target list.
import-route-target-list: Displays the import route target list.
vpn-name: VPN name. It cannot include the character of “-“.
local-ce: Displays the configurations and status of all local CEs of a specified VPN.
remote-ce: Displays the configurations and status of remote CEs learned from other PEs.
Use the display mpls l2vpn command to display information about L2VPNs configured on a PE.
If you do not specify a VPN, the command displays information about all L2VPNs.
# Display the L2VPN export route target list.
<Sysname> display mpls l2vpn export-route-target-list
export vpn target list: 755:7  888:8
Table 1-12 Description on the fields of display mpls l2vpn export-route-target-list
BGP VPN export route target list
# Display information about all L2VPNs configured on the PE.
VPN Number: 1
 vpn-name  encap-type  route-distinguisher     mtu   ce(L)  ce(R)
vpn2       vlan      500:1                   888   0      0
Table 1-13 Description on the fields of the display mpls l2vpn command
VPN Number
Number of created VPNs
vpn-name
Name of the VPN
encap-type
Encapsulation type
route-distinguisher
RD
mtu
Maximum transmission unit
ce(L)
Local CE number
ce(R)
Remote CE number
# Display information about L2VPN vpn1.
<Sysname> display mpls l2vpn vpn-name vpn1
***VPN Name             : vpn1
Encap type             : vlan
Local ce number(s)   : 0
Remote ce number(s)  : 0
Route distinguisher  : 301:301
MTU                  : 1500
Import vpn target        : 302:302
Export vpn target        : 302:302
Table 1-14 Description on the fields of the display mpls l2vpn vpn-name command
VPN Name
Name of the VPN
Encap type
Encapsulation type
Local ce number(s)
Local CE number
Remote ce number(s)
Remote CE number
Route-distinguisher
RD
MTU
Import vpn target
Incoming VPN target
Export vpn target
Outgoing VPN target
# Display information about local CEs of L2VPN vpn1.
<Sysname> display mpls l2vpn vpn-name vpn1 local-ce
ce-name              ce-id   range   conn-num  LB
ce1                  1       10      0         61446/0/10
Table 1-15 Description on the fields of display mpls l2vpn vpn-name local-ce
ce-name
Name of the CE
ce-id
CE number
range
CE range
conn-num
Number of connections
LB
Label block
# Display information about remote CEs of L2VPN vpn1.
<Sysname> display mpls l2vpn vpn-name vpn1 remote-ce
no.  ce-id peer-id         route-distinguisher     LB
1    4     3.3.3.9         100:1                   61446/0/10
Table 1-16 Description on the fields of display mpls l2vpn vpn-name remote-ce
no
Sequence number
ce-id
CE ID
peer-id
route-distinguisher
RD
LB
Label block
1.1.11  display mpls l2vpn connection
display mpls l2vpn connection [ vpn-name vpn-name [ remote-ce ce-id | down | up | verbose ] ]
display mpls l2vpn connection [ summary | interface interface-type interface-number ]
View
Default Level
1: Monitor level
vpn-name: VPN name, a case insensitive string that cannot include the character of “-“.
ce-id: ID of the remote CE for the L2VPN connection.
up: Displays detailed information about the connections that are up.
down: Displays detailed information about the connections that are down. If you specify neither the down nor the up keyword, the command displays detailed information about connections that are either up or down.
verbose: Displays detailed connection information. This keyword is valid only when displaying information about all connections in a VPN.
summary: Displays summary information about connections.
Use the display mpls l2vpn connection command to display information about Kompella L2VPN connections.
# Display information about all Kompella L2VPN connections.
<Sysname> display mpls l2vpn connection
1 total connections,
connections: 1 up, 0 down, 0 local, 1 remote, 0 unknown
VPN name: vpn1,
  CE name: ce1, id: 1,
  Rid type status peer-id         route-distinguisher   intf
  4   rmt  up     3.3.3.9         100:1                 Vlan-interface3
Table 1-17 Description on the fields of the display mpls l2vpn connection command
connections
Statistics about connections, including the number of connections in the state of Up, the number of connections in the state of Down, the number of local connections, the number of remote connections, and the number of unknown connections
VPN name
Name of the VPN
CE name
Name of the CE
id
ID of the CE
Rid
ID of the remote CE
type
Type of the connection
status
Status of the connection
peer-id
route-distinguisher
RD
intf
Interface for the connection
# Display information about Kompella L2VPN connections for VPN vpn1.
<Sysname> display mpls l2vpn connection vpn-name vpn1
VPN name: vpn1,
For descriptions of the output fields of the command, see Table 1-17.
# Display information about Kompella L2VPN connections on interface VLAN-interface 3.
<Sysname> display mpls l2vpn connection interface vlan-interface 3
***Conn-type                 : remote
Local vc state            : up
Remote vc state          : up
Local ce-id              : 1
Local ce name                : ce1
Remote ce-id             : 4
Intf(state,encap)            : Vlan-interface 3(up,vlan)
Peer id                  : 3.3.3.9
Route-distinguisher      : 100:1
Local vc label           : 61450
Remote vc label          : 61447
Tunnel policy                : policy1
Tunnel type              : lsp
Table 1-18 Description on the fields of display mpls l2vpn connection interface
Conn-type
Local vc state
Local VC status
Remote vc state
Remote VC status
Local ce-id
ID of the local CE
Local ce name
Name of the local CE
Remote ce-id
ID of the remote CE
Intf(state,encap)
Interface name (interface status, interface encapsulation type)
Peer id
Route-distinguisher
RD
Local vc label
Local VC label
Remote vc label
Remote VC label
Tunnel policy
Name of the tunneling policy
Tunnel type
Type of the tunnel
Tunnel ID
ID of the tunnel
# Display summary information about all Kompella L2VPN connections.
<Sysname> display mpls l2vpn connection summary
connections: 1 up,  0 down , 0 local, 1 remote, 0 unknown
No.   vpn-name    local-num remote-num unknown-num up-num total-num
1     vpn1               0         1          0         1      1
Table 1-19 Description on the fields of mpls l2vpn connection summary
vpn-name
Name of the VPN
connections
No.
Sequence number
local-num
Number of local connections
remote-num
Number of remote connections
unknown-num
Number of unknown connections
up-num
Number of connections that are up
total-num
Total number of connections
1.1.12  display mpls l2vpn forwarding-info
display mpls l2vpn forwarding-info [ vc-label ] interface interface-type interface-number [ | { begin | exclude | include } regular-expression ]
View
Default Level
1: Monitor level
vc-label: L2VPN VC label.
|: Matches the output information by using the specified regular expression.
begin: Displays information starting from the line matching the regular expression.
exclude: Displays only the information excluding the contents specified by the regular expression.
include: Displays only the information including the contents specified by the regular expression.
regular-expression: Regular expression containing no blank space. It is used to filter the output information.
Use the display mpls l2vpn forwarding-info command to display MPLS L2VPN forwarding information.
# Display MPLS L2VPN forwarding information.
<Sysname> display mpls l2vpn forwarding-info interface vlan-interface 2
VCLABEL TUNNELTYPE ENTRYTYPE OUTINTERFACE
61442    LSP        SEND      vlan-interface12
   1   Record(s) Found.
Table 1-20 Description on the fields of display mpls l2vpn forwarding-info
VCLABEL
VC label
TUNNELTYPE
Tunnel type
ENTRYTYPE
Forwarding entry type
OUTINTERFACE
Outgoing interface
Record(s) Found
Number of discovered records
1.1.13  display mpls static-l2vc
display mpls static-l2vc [ interface interface-type interface-number ]
View
Default Level
1: Monitor level
interface interface-type interface-number: Specifies a CE interface by its type and number.
Use the display mpls static-l2vc command to display information about static VCs configured on the device.
If you specify an interface, the command displays only information about static VCs configured on the CE interface.
# Display information about all static VCs configured on the device.
<Sysname> display mpls static-l2vc
total connections:  1,  1 up,  0 down
ce-intf                state destination     tr-label  rcv-label tnl-policy
Vlan-interface 3       up    3.3.3.9         100       200       policy1
Table 1-21 Description on the fields of the display mpls static-l2vc command
total connections
Statistics about connection, including the total number of connections, number of connections that are up, and number of connections that are down
ce-intfe
CE interface
Status of the VC
destination
tr-label
Outgoing label
rcv-label
Incoming label
tnl-policy
# Display information about static VCs configured on interface VLAN-interface 3.
<Sysname> display mpls static-l2vc interface vlan-interface 3
***CE-interface          : Vlan-interface3 is up
VC State             : up
Destination          : 3.3.3.9
Transmit-vpn-label       : 100
Receive-vpn-label        : 200
Tunnel Policy            : policy1
Tunnel Type          : lsp
Table 1-22 Description on the fields of display mpls static-l2vc interface
CE-interface
Name of the CE interface
VC State
Status of the VC
Destination
Transmit-vpn-label
Outgoing label
Receive-vpn-label
Incoming label
Tunnel Policy
Tunnel Type
Type of the tunnel
Tunnel ID
ID of the tunnel
1.1.14  l2vpn-family
l2vpn-family
undo l2vpn-family
View
BGP view
Default Level
2: System level
None
Use the l2vpn-family command to enter BGP L2VPN address family view.
Use the undo l2vpn-family command to delete all configurations for the BGP L2VPN address family.
# Enter BGP L2VPN address family view.
[Sysname] bgp 100
[Sysname-bgp] l2vpn-family
[Sysname-bgp-af-l2vpn]
1.1.15  mpls l2vc
mpls l2vc destination vcid [ tunnel-policy tunnel-policy-name ]
undo mpls l2vc
View
Interface view
Default Level
2: System level
destination: IP address of the peer PE.
vc-id: VC ID of the L2VPN connection.
Use the mpls l2vc command to create a Martini L2VPN connection.
Use the undo mpls l2vc command to delete the Martini connection on the CE interface.
# Create a Martini MPLS L2VPN connection.
[Sysname] interface vlan-interface 3
[Sysname-Vlan-interface3] mpls l2vc 2.2.2.9 999
1.1.16  mpls l2vpn
mpls l2vpn
undo mpls l2vpn
View
Default Level
2: System level
None
Use the mpls l2vpn command to enable MPLS L2VPN.
Use the undo mpls l2vpn command to disable MPLS L2VPN and delete all L2VPN configurations.
You must use the mpls l2vpn command to enable MPLS L2VPN before configuring the other L2VPN commands.
# Enable MPLS L2VPN.
1.1.17  mpls l2vpn vpn-name
mpls l2vpn vpn-name [ encapsulation {ethernet | vlan } ]
undo mpls l2vpn vpn-name
View
System view/MPLS L2VPN view
Default Level
2: System level
vpn-name: Name for the VPN. It cannot include the character of “-“. It is used to identify a VPN uniquely on a PE.
encapsulation: Specifies the VPN encapsulation type.
ethernet: Uses Ethernet encapsulation.
vlan: Uses VLAN encapsulation.
Use the mpls l2vpn command to create a Kompella VPN and enter MPLS L2VPN view.
Use the undo mpls l2vpn command to delete a VPN.
The encapsulation type specified here must match that of the CE interface.
# Create a Kompella VPN named vpn1 that uses VLAN encapsulation and enter MPLS L2VPN view.
[Sysname] mpls l2vpn vpn1 encapsulation vlan
# Create a Kompella VPN named vpn2 that uses Ethernet encapsulation and enter MPLS L2VPN view.
[Sysname-mpls-l2vpn-vpn1] mpls l2vpn vpn2 encapsulation ethernet
[Sysname-mpls-l2vpn-vpn2]
1.1.18  mpls static-l2vc destination
mpls static-l2vc destination destination-router-id transmit-vpn-label transmit-label-value receive-vpn-label receive-label-value [ tunnel-policy tunnel-policy-name ]
undo mpls static-l2vc
View
Interface view
Default Level
2: System level
dest-router-id: Destination route ID.
transmit-label-value: Label used for transmitting VPN, namely the outgoing label for the static level 2 VC.
receive-label-value: Label used for receiving VPN, namely the incoming label for the static level 2 VC.
Use the mpls static-l2vc destination command to create a static VC between CEs connected to different PEs.
Use the undo mpls static-l2vc command to delete the static VC.
l           You must configure the command on both PEs. The destination address is the IP address of the peer PE. The outgoing label and incoming label are respectively the incoming label and outgoing label of the peer.
l           If you do not specify the tunneling policy, or specify the tunneling policy name but do not configure the policy, the default policy is used. The default tunneling policy uses LSP tunnels and the load balance number is one.
# Create a static VC between CEs connected to different PEs.
[Sysname-Vlan-interface10] mpls static-l2vc destination 1.1.1.1 transmit-vpn-label 111 receive-vpn-label 222 tunnel-policy pol1
1.1.19  mtu (MPLS L2VPN view)
mtu mtu
undo mtu
View
MPLS L2VPN view
Default Level
2: System level
mtu-value: MTU for the L2VPN. It defaults to 1,500.
Use the mtu command to set the maximum transmission unit (MTU) for the kompella connections.
Use the undo mtu command to restore the default.
&  Note:
The mtu command is not recommended because it affects only negotiation of protocol parameters that may take place and does not affects the forwarding.
# Set the MTU for Kompella connections to 1000.
[Sysname-mpls-l2vpn-vpn1] mtu 1000
1.1.20  reset bgp l2vpn
reset bgp l2vpn { as-number | ip-address | all | internal | external }
View
Default Level
1: Monitor level
as-number: Resets L2VPN BGP connections with the peers in the AS with this number.
ip-address: Resets the L2VPN BGP connection to the peer with this IP address.
all: Resets all L2VPN BGP connections.
internal: Resets L2VPN IBGP sessions.
external: Resets L2VPN EBGP sessions.
Use the reset bgp l2vpn command to reset L2VPN BGP connections.
# Reset all L2VPN BGP connections.
<Sysname> reset bgp l2vpn all
1.1.21  route-distinguisher (MPLS L2VPN view)
View
MPLS L2VPN view
Default Level
2: System level
route-distinguisher: Specifies the route distinguisher (RD) in the format of nn:nn or IP-address:nn.
Use the route-distinguisher command to configure an RD for the VPN.
Different VPNs on a PE must have different RDs, while a VPN can have the same or different RDs on different PEs.
&  Note:
l      You cannot change an RD directly; you can only delete the VPN and then re-create the VPN using the new RD.
l      No RD is configured by default; you must configure an RD for each VPN. A VPN takes effect only when it is configured with an RD. Once you configure an RD for a VPN, you cannot remove the association between the RD and the VPN.
# Configure the RD of a VPN.
[Sysname-mpls-l2vpn-vpn1] route-distinguisher 300:1
1.1.22  vpn-target (MPLS L2VPN view)
vpn-target vpn-target&<1-16> [ both | export-extcommunity | import-extcommunity ]
undo vpn-target { all | { vpn-target&<1-16> [ both | export-extcommunity | import-extcommunity ] }
View
MPLS L2VPN view
Default Level
2: System level
vpn-target: VPN target extended community attributes to be added to the import or export VPN target extended community list, in the format of nn:nn or IP-address:nn. &<1-16> means that you can specify this argument for up to 16 times.
A VPN target can be in either of the following formats:
l           16-bit AS number:32-bit user-defined number. For example, 101:3.
l           32-bit IP address:16-bit user-defined number. For example, 192.168.122.15:1.
both: Specifies both the export and import VPN extended communities. This is the default.
export-extcommunity: Specifies the export VPN extended community.
import-extcommunity: Specifies the import VPN extended community.
all: Specifies both the import and export VPN extended communities.
Use the vpn-target command to associate a particular VPN with one or more VPN targets.
Use the undo vpn-target command to delete the VPN target(s) associated with a particular VPN.
There is no default value for a VPN target. You must configure it when creating the VPN.
# Associate VPN vpn1 with VPN-targets.
[Sysname-mpls-l2vpn-vpn1] vpn-target 1:1 2:2 export-extcommunity
[Sysname-mpls-l2vpn-vpn1] vpn-target 1.2.3.4:11 import-extcommunity
