H3C S5500-SI Series Ethernet Switches Command Manual(V1.01)
HomeSupportSwitchesS5500 SeriesReference GuidesCommand ReferencesH3C S5500-SI Series Ethernet Switches Command Manual(V1.01)
33-PoE Commands
33-PoE Commands 84 KB
Chapter 1  PoE Configuration Commands
1.1  PoE Configuration Commands
1.1.1  apply poe-profile
apply poe-profile { index index | name profile-name }
undo apply poe-profile { index index | name profile-name }
View
PoE interface view
index index: Index number of the PoE configuration file, in the range 1 to 100.
name profile-name: Name of the PoE configuration file, a string of 1 to 15 characters.
Use the apply poe-profile command to apply the PoE configuration file to the current PoE interface.
Use the undo apply poe-profile command to remove the application of the PoE configuration file to the current PoE interface.
Note that the index number, instead of the name, of the PoE configuration file is displayed when you execute the display this command.
Related commands: display poe-profile, apply poe-profile interface.
# Apply the PoE configuration file named A20 to the PoE interface GigabitEthernet 1/0/2.
[Sysname] interface GigabitEthernet 1/0/2
[Sysname-GigabitEthernet1/0/2] apply poe-profile name A20
[Sysname-GigabitEthernet1/0/2] display this
apply poe-profile index 1
1.1.2  apply poe-profile interface
apply poe-profile { index index | name profile-name } interface interface-range
undo apply poe-profile { index index | name profile-name } interface interface-range
View
interface-range: Range of Ethernet interface numbers, indicating multiple Ethernet interfaces. The expression is interface-range = interface-type interface-number [ to interface-type interface-number ], where interface-type interface-number represents the interface type and interface number. The start interface number should be smaller than the end interface number. Ethernet interface numbers can be in any range. If any interface in the specified range does not support PoE, it is ignored when the PoE configuration file is applied.
Use the apply poe-profile interface command to apply the PoE configuration file to one or more PoE interfaces.
Use the undo apply poe-profile interface command to remove the application of the PoE configuration file to the specified PoE interface(s).
Related commands: display poe-profile interface, apply poe-profile.
# Apply the PoE configuration file named ABC to the PoE interface GigabitEthernet 1/0/2.
[Sysname] apply poe-profile name ABC interface GigabitEthernet 1/0/2
# Apply the PoE configuration file with the index of 5 to PoE interfaces GigabitEthernet 1/0/2 through GigabitEthernet 1/0/8.
[Sysname] apply poe-profile index 5 interface GigabitEthernet 1/0/2 to GigabitEthernet 1/0/8
1.1.3  display poe device
display poe device
View
None
Use the display poe device command to display the mapping between ID, module, and slot of all the power sourcing equipments (PSEs).
# Display the mapping between ID, module, and slot of each PSE.
<Sysname> display poe device
 PSE ID  SlotNo SubSNo PortNum  MaxPower(W)  State  Model
 1       0      0      48       0            off    LSP1POEA
Table 1-1 Description on the fields of the display poe device command
PSE ID
ID of the PSE
SlotNo
Slot number of the PSE
SubSNo
Subslot number of the PSE
PortNum
Number of PoE interfaces on the PSE
MaxPower(W)
Maximum power of the PSE (W)
PSE state:
on: The PSE is supplying power.
off: The PSE stops supplying power.
faulty: The PSE fails.
Model
PSE model
1.1.4  display poe interface
display poe interface [ interface-type interface-number ]
View
Use the display poe interface command to display the power information of the specified interface.
If no interface is specified, the power information of all PoE interfaces is displayed.
# Display the power state of GigabitEthernet 1/0/2.
<Sysname> display poe interface GigabitEthernet 1/0/2
 Port Power Enabled               : enable
 Port Power Priority              : critical
 Port Operating Status            : on
 Port IEEE Class                   : 0
 Port Detection Status            : delivering-power
 Port Power Mode                   : signal
 Port Current Power               : 5400     mW
 Port Average Power               : 5490     mW
 Port Peak Power                   : 6500     mW
 Port Max Power                    : 15400    mW
 Port Current                       : 108      mA
 Port Voltage                       : 50.8     V
 Port PD Description               : IP Phone For Room 101
Table 1-2 Description on the fields of the display poe interface GigabitEthernet command
Port Power Enabled
PoE state: enabled/disabled
l      enable: PoE is enabled.
l      disable: PoE is disabled.
Port Power Priority
Power priority of the PoE interface:
l      critical (highest)
l      high
l      low
Operating state of a PoE interface:
l      off: PoE is disabled.
l      on: Power is supplied for a PoE interface normally.
l      power lack: The guaranteed remaining power of the PSE is not high enough to supply power for a critical PoE interface.
l      power-deny: The PSE refuses to supply power. The power required by the powered device (PD) is higher than the configured power.
l      power-itself: The external equipment is supplying power for itself.
power-limit: The PSE is supplying a limited power. The power required by the PD is higher than the configured power and the PSE still supplies the configured power.
Port IEEE class
PD power class: 0, 1, 2, 3, 4
Power detection state of a PoE interface:
l      disabled: The PoE function is disabled.
l      searching: The PoE interface is searching for the PD.
l      delivering-power: The PoE interface is supplying power for the PD.
l      fault: There is a fault defined in 802.3af.
l      test: The PoE interface is under test.
l      other-fault: There is a fault other than defined in 802.3af.
l      pd-disconnect: The PD is disconnected.
Port Power Mode
Power mode of a PoE interface:
signal: Power is supplied over signal cables.
Port Current Power
Current power of a PoE interface, including PD consumption power and transmission loss
The transmission loss usually does not exceed one watt.
Port Average Power
Average power of a PoE interface
Port Peak Power
Peak power of a PoE interface
Port Max Power
Maximum power of a PoE interface
Port Current
Current of a PoE interface
Port Voltage
Voltage of a PoE interface
Port PD Description
Description of the PD connected to the PoE interface, which is used to identify the type and location of the PD.
# Display the state of all PoE interfaces.
 Interface  Enable   Priority  CurPower  Operating    IEEE   Detection
                                    (W)        Status       class  Status
 GE1/0/1   disable  low       0.0       off         0      disabled
 GE1/0/2   disable  low       0.0       off         0      disabled
 GE1/0/3   disable  low       0.0       off         0      disabled
 GE1/0/4   disable  low       0.0       off         0      disabled
 GE1/0/5   disable  low       0.0       off         0      disabled
 GE1/0/6   disable  low       0.0       off         0      disabled
 GE1/0/7   disable  low       0.0       off         0      disabled
 GE1/0/8   disable  low       0.0       off         0      disabled
 GE1/0/9   disable  low       0.0       off         0      disabled
 GE1/0/10  disable  low       0.0       off         0      disabled
 GE1/0/11  disable  low       0.0       off         0      disabled
 GE1/0/12  disable  low       0.0       off         0      disabled
 GE1/0/13  disable  low       0.0       off         0      disabled
 GE1/0/14  disable  low       0.0       off         0      disabled
 GE1/0/15  enable   high      3.8       on          0      delivering-power
 GE1/0/16  enable   low       5.4       on          0      delivering-power
 GE1/0/17  disable  low       0.0       off         0      disabled
 GE1/0/18  disable  low       0.0       off         0      disabled
 GE1/0/19  disable  low       0.0       off         0      disabled
 GE1/0/20  disable  low       0.0       off         0      disabled
 GE1/0/21  disable  low       0.0       off         0      disabled
 GE1/0/22  disable  low       0.0       off         0      disabled
 GE1/0/23  disable  low       0.0       off         0      disabled
 GE1/0/24  disable  low       0.0       off         0      disabled
  ---  2 port(s) on,    9.2 (W) consumed,   90.8 (W) remaining ---
Table 1-3 Description on the fields of the display poe interface command
Shortened form of a PoE interface
Enable
Priority
Power priority of a PoE interface:
l      high
l      low
CurPower
Operating Status
IEEE class
PD power class defined by IEEE
Detection Status
l      There is a fault other than defined in 802.3af.
port(s) on
Number of PoE interfaces that are supplying power
consumed
Power consumed by the current PoE interface
Remaining
Total remaining power of the system
1.1.5  display poe interface power
display poe interface power [ interface-type interface-number ]
View
Use the display poe interface power command to display the power information of a PoE interface(s).
If no interface is specified, the power information of all PoE interfaces will be displayed.
# Display the power information of GigabitEthernet 1/0/2.
<Sysname> display poe interface power GigabitEthernet 1/0/2
Interface  CurPower PeakPower MaxPower PD Description
            (W)        (W)        (W)
 GE1/0/2  15.0       15.3       15.4      Access Point on Room 509 for Peter
# Display the power information of all PoE interfaces.
              (W)       (W)         (W)
 GE1/0/1    0.0       0.0         15.4
 GE1/0/2    0.0       0.0         15.4
 GE1/0/3    0.0       0.0         15.4
 GE1/0/4    0.0       0.0         15.4
 GE1/0/5    0.0       0.0         15.4
 GE1/0/6    0.0       0.0         15.4
 GE1/0/7    0.0       0.0         15.4
 GE1/0/8    0.0       0.0         15.4
 GE1/0/9    0.0       0.0         15.4
 GE1/0/10   0.0       0.0         15.4
 GE1/0/11   0.0       0.0         15.4
 GE1/0/12   0.0       0.0         15.4
 GE1/0/13   0.0       0.0         15.4
 GE1/0/14   0.0       0.0         15.4
 GE1/0/15   3.8       3.9         10.0
 GE1/0/16   5.4       6.5         15.4
 GE1/0/17   0.0       0.0         15.4
 GE1/0/18   0.0       0.0         15.4
 GE1/0/19   0.0       0.0         15.4
 GE1/0/20   0.0       0.0         15.4
 GE1/0/21   0.0       0.0         15.4
 GE1/0/22   0.0       0.0         15.4
 GE1/0/23   0.0       0.0         15.4
 GE1/0/24   0.0       0.0         15.4
  ---  2 port(s) on,    9.1 (W) consumed,   90.9 (W) remaining ---
Table 1-4 Description on the fields of the display poe interface power command
CurPower
PeakPower
MaxPower
PD Description
Description of the PD connected with a PoE interface When the description contains more than 34 characters, the first 30 characters followed by four dots are displayed.
port(s) on
consumed
Power currently consumed by all PoE interfaces
Remaining
1.1.6  display poe pse
display poe pse
View
None
Use the display poe pse command to display the information of the PSE.
# Display the information of the PSE.
<Sysname> display poe pse
 PSE ID                           : 1
 PSE Slot No                      : 1
 PSE SubSlot No                   : 0
 PSE Model                        : LSP1LTSUC
 PSE Current Power                : 9        W
 PSE Average Power                : 9        W
 PSE Peak Power                   : 10       W
 PSE Max Power                    : 370      W
 PSE Remaining Guaranteed         : 370      W
 PSE CPLD Version                 : -
 PSE Software Version             : 501
 PSE Hardware Version             : 1
 PSE Legacy Detection             : disable
 PSE Utilization-threshold        : 80
 PSE Pd-policy Mode               : disable
 PSE PD Disconnect Detect Mode    : AC
Table 1-5 Description on the fields of the display poe pse command
PSE ID
ID of the PSE
PSE Slot No
PSE SubSlot No
PSE Model
Model of the PSE module
PSE Power Enabled
PoE is enabled for the PSE
PSE Power Preempted
PSE power preempted state
l      no: The power of the PSE is not preempted.
l      yes: The power of the PSE is preempted so that it cannot supply power, although PoE is enabled for the PSE
PSE Power Priority
Power priority of the PSE
PSE Current Power
Current power of the PSE
PSE Average Power
Average power of the PSE
PSE Peak Power
Peak power of the PSE
PSE Max Power
Guaranteed remaining power of the PSE = Maximum power of the PSE– the sum of the maximum power of the critical PoE interfaces of the PSE
PSE CPLD Version
PSE CPLD version
PSE software version number
PSE hardware version number
Nonstandard PD detection by the PSE:
l      enable: Enabled
l      disable: Disabled
PSE power alarm threshold
PSE Pse-policy Mode
PSE power management policy mode
PSE Pd-policy Mode
PD power management policy mode
PD disconnection detection mode
1.1.7  display poe-profile
display poe-profile [ index index | name profile-name ]
View
Use the display poe-profile command to display all information of the configurations and applications of the PoE configuration file.
If no argument is specified, all information of the configurations and applications of existing PoE configuration files is displayed.
# Display all information of the configurations and applications of the current PoE configuration file.
<Sysname> display poe-profile
Poe-profile       Index  ApplyNum  Interface   Configuration
 AA3456789012345  1      3           GE1/0/1        poe enable
                                     GE1/0/2        poe priority critical
                                     GE1/0/3
 poe-profileAA    2      1           GE1/0/4       poe enable
                                                   poe max-power 12300
 poe-profileBB    3      0                         poe enable
                                                   poe max-power 15400
 ---  3 poe-profile(s) created, 4 port(s) applied  ---
Table 1-6 Description on the fields of the display poe-profile command
Poe-profile
Index
ApplyNum
Number of PoE interfaces to which a PoE configuration file is applied
Shortened form of the PoE interface to which the PoE configuration is applied
Configuration
Configurations of the PoE configuration file
Number of PoE configuration files
port(s) applied
Sum of the number of PoE interfaces to which all PoE configuration files are respectively applied
# Display all information of the configurations and applications of the PoE configuration file whose index number is 1.
<Sysname> display poe-profile index 1
 AA3456789012345  1      2           GE1/0/2      poe enable
                                     GE1/0/4      poe priority critical
                                                  poe max-power 12300
 ---  2 port(s) applied  ---
Table 1-7 Description on the fields of the display poe-profile index command
Poe-profile
Index
ApplyNum
Configuration
port(s) applied
# Display all information of the configurations and applications of the PoE configuration file named AA.
<Sysname> display poe-profile name AA
 AA                 1       2          GE1/0/1      poe enable
                                                    poe max-power 12300
Table 1-8 Description on the fields of the display poe-profile name command
Poe-profile
Index
ApplyNum
Configuration
port(s) applied
1.1.8  display poe-profile interface
display poe-profile interface interface-type interface-number
View
Use the display poe-profile interface command to display all information of the configurations and applications of the PoE configuration file that currently takes effect on the specified PoE interface.
# Display all information of the configurations and applications of the current PoE configuration file applied to GigabitEthernet 1/0/2.
<Sysname> display poe-profile interface GigabitEthernet 1/0/2
Poe-profile      Index  ApplyNum  Interface  Current Configuration
Table 1-9 Description on the fields of the display poe-profile interface command
Poe-profile
Index
ApplyNum
Number of PoE interfaces to which the PoE configuration file is applied
Configurations of the PoE configuration file that currently take effect on a PoE interface
&  Note:
Because not all the configurations of a PoE configuration file can be applied successfully, only the configurations that currently take effect on the interface are displayed.
1.1.9  poe disconnect
poe disconnect { ac | dc }
undo poe disconnect
View
ac: Specifies the PD disconnection detection mode as ac.
dc: Specifies the PD disconnection detection mode as dc.
Use the poe disconnect command to configure a PD disconnection detection mode.
Use the undo poe disconnect command to restore the default.
The default PD disconnection detection mode is AC.
Note that change to the PD disconnection detection mode may lead to power-off of some PDs.
# Set the PD disconnection detection mode to dc.
[Sysname] poe disconnect dc
1.1.10  poe enable
poe enable
undo poe enable
View
PoE interface view, PoE-profile file view
None
Use the poe enable command to enable PoE on a PoE interface.
Use the undo poe enable command to disable PoE on a PoE interface.
By default, PoE is disabled on a PoE interface.
  Caution:
l      If a PoE configuration file is already applied to a PoE interface, you need to remove the application of the file to the PoE interface before configuring the interface in PoE-profile view.
l      If a PoE configuration file is applied to a PoE interface, you need to remove the application of the file to the PoE interface before configuring the interface in PoE interface view.
# Enable PoE on a PoE interface.
[Sysname-GigabitEthernet1/0/2] poe enable
# Enable PoE on a PoE interface through a PoE configuration file.
[Sysname] poe-profile abc
[Sysname-poe-profile-abc-1] poe enable
[Sysname-poe-profile-abc-1] quit
[Sysname-GigabitEthernet1/0/1] apply poe-profile name abc
1.1.11  poe legacy enable
poe legacy enable
undo poe legacy enable
View
None
Use the poe legacy enable command to enable the PSE to detect nonstandard PDs.
Use the undo poe legacy enable command to disable the PSE from detecting nonstandard PDs.
By default, the PSE is disabled from detecting nonstandard PDs.
# Enable the PSE to detect nonstandard PDs.
[Sysname] poe legacy enable
1.1.12  poe max-power
poe max-power max-power
undo poe max-power
View
max-power: Maximum power in milliwatts allocated to a PoE interface, in the range 1000 to 15400.
Use the poe max-power command to configure the maximum power for a PoE interface.
Use the undo poe max-power command to restore the default.
By default, the maximum power of the PoE interface is 15,400 milliwatts.
# Set the maximum power of GigabitEthernet 1/0/2 to 12,000 milliwatts.
[Sysname-GigabitEthernet1/0/2] poe max-power 12000
# Set the maximum power of GigabitEthernet 1/0/2 to 12,000 milliwatts through a PoE configuration file.
[Sysname-poe-profile-abc-1] poe max-power 12000
[Sysname-GigabitEthernet1/0/2] apply poe-profile name abc
1.1.13  poe mode
poe mode signal
undo poe mode
View
None
Use the poe mode single command to configure the PoE mode of the PoE interface as single (power over signal cables).
Use the undo poe mode command to restore the default.
By default, the PoE mode is signal (power over signal cables).
# Set the PoE mode to signal (power over signal cables).
[Sysname-GigabitEthernet1/0/2] poe mode signal
# Set the PoE mode to signal (power over signal cables) through a PoE configuration file.
[Sysname-poe-profile-abc-1] poe mode signal
1.1.14  poe pd-description
poe pd-description string
undo poe pd-description
View
PoE interface view
string: Description of the PD connected to a PoE interface, a string of 1 to 80 characters.
Use the poe pd-description command to configure a description for the PD connected to a PoE interface.
Use the undo poe pd-description command to restore the default.
By default, no description is available for the PD connected to a PoE interface.
# Configure the description for the PD connected to Ethernet 1/0 as IP Phone for Room 101.
[Sysname-GigabitEthernet1/0/2] poe pd-description IP Phone For Room 101
1.1.15  poe pd-policy priority
undo poe pd-policy priority
View
None
Use the poe pd-policy priority command to configure a PD power management priority policy.
Use the undo poe pd-policy priority command to remove the PD power management priority policy.
By default, no PD power management priority policy is configured.
# Configure a PD power management priority policy
[Sysname] poe pd-policy priority
1.1.16  poe priority
poe priority { critical | high | low }
undo poe priority
View
critical: Sets the power priority of a PoE interface to critical. The PoE interface whose power priority level is critical works in guaranteed mode, that is, power is first supplied to the PD connected to this critical PoE interface.
high: Sets the power priority of a PoE interface to high.
low: Sets the power priority of a PoE interface to low.
Use the poe priority command to configure a power priority level for a PoE interface.
Use the undo poe priority command to restore the default.
By default, the power priority of a PoE interface is low.
Note that:
l           When the PoE power is insufficient, power is first supplied to PoE interfaces with a higher priority level.
l           If two PoE interfaces have the same priority level, the PoE interface with a smaller ID has the higher priority level.
# Set the power priority of Ethernet 1/0 to critical.
[Sysname-GigabitEthernet1/0/2] poe priority critical
# Set the power priority of GigabitEthernet 1/0/2 to critical through a PoE configuration file.
[Sysname-poe-profile-abc-1] poe priority critical
1.1.17  poe update
poe update { full | refresh } filename
View
full: Specifies to upgrade the PSE processing software in full mode when the software is unavailable.
refresh: Specifies to upgrade the PSE processing software in refresh mode when the software is available.
filename: Name of the upgrade file, a string of 1 to 64 characters. This file must be under the root directory of the file system of the device. The extension of the upgrade file is .s19.
Use the poe update command to upgrade the PSE processing software online.
# Upgrade the processing software of the PSE online.
[Sysname] poe update refresh 0400_001.S19
1.1.18  poe utilization-threshold
poe utilization-threshold utilization-threshold-value
undo poe utilization-threshold
View
utilization-threshold-value: Power alarm threshold in percentage, in the range 1 to 99.
Use the poe utilization-threshold command to configure a power alarm threshold for the PSE.
Use the undo poe utilization-threshold command to restore the default power alarm threshold of the PSE.
By default, the power alarm threshold for the PSE is 80%.
The system sends a Trap message when the percentage of power utilization exceeds the alarm threshold. If the percentage of the power utilization always keeps above the alarm threshold, the system does not send any Trap message. Instead, when the percentage of the power utilization drops below the alarm threshold, the system sends a Trap message again.
# Set the power alarm threshold of the PSE to 90%.
[Sysname] poe utilization-threshold 90
1.1.19  poe-profile
poe-profile profile-name [ index ]
undo poe-profile { index index | name profile-name }
View
profile-name: Name of a PoE configuration file, a string of 1 to 15 characters. A PoE configuration file name begins with a letter (a through z or A through Z) and must not contain reserved keywords such as undo, all, name, interface, user, poe, disable, max-power, mode, priority and enable.
index: Index number of a PoE configuration file, in the range 1 to 100.
Use the poe-profile profile-name command to create a PoE configuration file and enter PoE-profile view.
Use the undo poe-profile command to delete the specified PoE configuration file.
If no index is specified, the system automatically assigns an index to the PoE configuration file, starting from 1.
Note that if a PoE configuration file is already applied to a PoE interface, you cannot delete it. To delete the file, you must first execute the undo apply poe-profile command to remove the application of the PoE configuration file to the PoE interface.
# Create a PoE configuration file, name it abc, and specify the index number as 3.
[Sysname] poe-profile abc 3
