H3C S5500-SI Series Ethernet Switches Command Manual(V1.01)
HomeSupportSwitchesS5500 SeriesReference GuidesCommand ReferencesH3C S5500-SI Series Ethernet Switches Command Manual(V1.01)
00-1Cover
00-1Cover 71 KB
Command Manual
Hangzhou H3C Technologies Co., Ltd.
http://www.h3c.com
Manual Version: 20071208-C-1.01
Copyright © 2007, Hangzhou H3C Technologies Co., Ltd. and its licensors
All Rights Reserved
No part of this manual may be reproduced or transmitted in any form or by any means without prior written consent of Hangzhou H3C Technologies Co., Ltd.
Trademarks
H3C, , Aolynk, , H3Care, , TOP G, , IRF, NetPilot, Neocean, NeoVTL, SecPro, SecPoint, SecEngine, SecPath, Comware, Secware, Storware, NQA, VVG, V2G, VnG, PSPT, XGbus, N-Bus, TiGem, InnoVision and HUASAN are trademarks of Hangzhou H3C Technologies Co., Ltd.
All other trademarks that may be mentioned in this manual are the property of their respective owners.
Notice
The information in this document is subject to change without notice. Every effort has been made in the preparation of this document to ensure accuracy of the contents, but all statements, information, and recommendations in this document do not constitute the warranty of any kind, express or implied.
To obtain the latest information, please access:
http://www. h3c.com
Technical Support
[email protected]
http://www. h3c.com
About This Manual
Related Documentation
In addition to this manual, each H3C S5500-SI Series Ethernet Switches documentation set includes the following:
Manual
H3C S5500-SI Complete Series Ethernet Switches  Installation Manual
It provides information for the system installation.
H3C S5500-SI Series Ethernet Switches  Operation Manual
It is used for assisting the users in data configurations and typical applications.
Organization
H3C S5500-SI Series Ethernet Switches Command Manual is organized as follows:
Part
1 Login
Introduces the commands used for logging into an Ethernet switch.
2 VLAN
Introduces the commands used for configuring VLAN.
3 IP Address and IP Performance
Introduces the commands used for configuring IP address and IP performance.
4 QinQ-BPDU TUNNEL
Introduces the commands used for configuring QinQ.
5 Port Correlation
Introduces the commands used for configuring link aggregation and port isolation.
6 Link Aggregation
Introduces the commands used for link aggregation.
7 MAC Address Table Management
Introduces the commands used for configuring MAC address forwarding table.
8 Port Security
Introduces the commands used for port security.
9 MSTP
Introduces the commands used for configuring MSTP.
10 IPv6
Introduces the commands used for configuring IPv6 application.
11 IP Routing Overview
Introduces the commands of Routing Overview.
12 IPv4 Routing
Introduces the commands used for configuring IPv4 routing, static routing, RIP, and route policy.
13 IPv6 Routing
Introduces IPv6 routing related configurations, such as static routing, RIPng, and route policy.
Introduces the commands used for configuring IPv6 routing, static routing, RIPng, and route policy.
14 Multicast
Introduces the commands used for configuring IGMP Snooping.
15 802.1x-HABP-MAC Authentication
Introduces the commands used for 802.1x, HABP and MAC related configurations.
16 AAA-RADIUS-HWTACACS
Introduces the commands used for AAA, RADIUS, HWTACACS, and the related configurations.
17 ARP
Introduces the commands used for configuring ARP.
18 DHCP
Introduces the commands used for DHCP and the related configuration.
19 ACL
Introduces the commands used for configuring ACL.
20 QoS
Introduces the commands used for configuring QoS.
21 Port Mirroring
Introduces the commands used for configuring port mirroring.
22 UDP Helper
Introduces the commands used for UDP Helper and the related configuration.
23 Cluster Management
Introduces the commands used for configuring cluster.
24 SNMP-RMON
Introduces the commands used for the configuration to manage network devices through SNMP and RMON.
25 NTP
Introduces the commands used for configuring NTP.
26 DNS
Introduces the commands used for configuring DNS.
27 File System Management
Introduces the commands used for file system management.
28 Information Center
Introduces the commands used for the configuration to analyze and diagnose networks using the information center.
29 System Maintaining and Debugging
Introduces the commands used for daily system maintenance and debugging.
30 NQA
Introduces the commands used for configuring NQA.
31 SSH
Introduces the commands used for configuring SSH2.0.
32 Track
Introduces the commands used for configuring Track.
33 PoE
Introduces the commands used for configuring PoE and PoE profile.
34 SSL-HTTPS
Introduces the commands used for configuring SSL and HTTPS.
35 PKI
Introduces the commands used for configuring PKI.
36 Stack Management
Introduces the commands used for configuring Stack Management.
37 Command Index
Lists all the commands in this command manual, which are arranged alphabetically.
Conventions
The manual uses the following conventions:
I. Command conventions
Convention
Boldface
The keywords of a command line are in Boldface.
italic
Command arguments are in italic.
Items (keywords or arguments) in square brackets [ ] are optional.
{ x | y | ... }
Alternative items are grouped in braces and separated by vertical bars. One is selected.
[ x | y | ... ]
Optional alternative items are grouped in square brackets and separated by vertical bars. One or none is selected.
{ x | y | ... } *
Alternative items are grouped in braces and separated by vertical bars. A minimum of one or a maximum of all can be selected.
[ x | y | ... ] *
Optional alternative items are grouped in square brackets and separated by vertical bars. Many or none can be selected.
A line starting with the # sign is comments.
II. Symbols
Convention
  Warning
Means reader be extremely careful. Improper operation may cause bodily injury.
  Caution
Means reader be careful. Improper operation may cause data loss or damage to equipment.
&  Note
Means a complementary description.
