H3C S5500-SI Series Ethernet Switches Command Manual(V1.01)
HomeSupportSwitchesS5500 SeriesReference GuidesCommand ReferencesH3C S5500-SI Series Ethernet Switches Command Manual(V1.01)
07-MAC Address Table Management Commands
07-MAC Address Table Management Commands 38 KB
Chapter 1  MAC Address Table Management Configuration Commands
1.1  MAC Address Table Management Configuration Commands
1.1.1  display mac-address
display mac-address blackhole [ vlan vlan-id ] [ count ]
display mac-address [ mac-address [ vlan vlan-id ] | [ dynamic | static ] [ interface interface-type interface-number ] [ vlan vlan-id ] [ count ] ]
View
blackhole: Displays blackhole MAC address entries. These entries do not age but you can add or remove them. The packets whose destination MAC addresses match blackhole MAC address entries are dropped.
vlan vlan-id: Displays MAC address entries of the specified VLAN, which is in the range 1 to 4094.
count: Displays the total number of MAC addresses in the MAC address table.
mac-address: Displays MAC address entries in a specified MAC address, in the format of H-H-H.
dynamic: Displays dynamic MAC address entries. Aging time is set for these entries.
static: Displays static MAC address entries. Similar to blackhole MAC address entries, these entries do not age but you can add or remove them.
interface interface-type interface-number: Displays MAC address learning status of the specified interface. interface-type interface-number specifies an interface by its type and number.
Use the display mac-address command to display information about the MAC address table.
Related commands: mac-address (system view), mac-address (Ethernet interface view)mac-address timer.
# Display the MAC address table entry for MAC address 000f-e201-0101.
<Sysname> display mac-address 000f-e201-0101
MAC ADDR         VLAN ID STATE     PORT INDEX            AGING TIME(s)
000f-e201-0101   1        Learned       GigabitEthernet1/0/1 AGING
  ---  1 mac address(es) found  ---
Table 1-1 Description on the fields of the display mac-address command
MAC ADDR
MAC address
VLAN ID
ID of the VLAN to which the MAC address belongs
STATE
State of a MAC address, which could be Config static, Config dynamic, Learned and Blackhole
PORT INDEX
Port number (Displayed as N/A for a blackhole MAC address)
 AGING TIME(s)
Aging time, which could be:
l      AGING, indicates that the entry is aging.
l      NOAGED, indicates that the entry does not age.
1.1.2  display mac-address aging-time
View
None
Use the display mac-address aging-time command to display the aging time of dynamic entries in the MAC address table.
Related commands: mac-address (system view), mac-address (Ethernet interface view), mac-address timer, display mac-address.
# Display the aging time of dynamic entries in the MAC address table.
<Sysname> display mac-address aging-time
Mac address aging time: 300s
The above information indicates that the aging time of dynamic entries in the MAC address table is 300 seconds.
1.1.3  mac-address (Ethernet port view)
mac-address { dynamic | static } mac-address vlan vlan-id
undo mac-address { dynamic | static } mac-address vlan vlan-id
View
Ethernet port view
dynamic: Dynamic MAC address entries. Aging time is set for these entries.
static: Static MAC address entries. Similar to blackhole MAC address entries, these entries do not age but you can add or remove them.
mac-address: Specifies a MAC address in the format of H-H-H.
vlan vlan-id: Specifies the VLAN to which the Ethernet port belongs., where vlan-id is the specified VLAN ID, in the range 1 to 4094.
Use the mac-address command to add or modify a MAC address entry on the specified Ethernet port.
Use the undo mac-address command to remove a MAC address entry on the Ethernet port.
Note that:
l           As your MAC address entries configuration cannot survive a reboot, save it after completing the configuration. The dynamic MAC address table entries however will be lost whether you save the configuration or not.
l           You cannot configure a static or dynamic MAC address entry on an aggregation port.
Related commands: display mac-address.
# Add a static entry for MAC address 000f-e201-0101 on port GigabitEthernet 1/0/1 which belongs to VLAN 2.
[Sysname-GigabitEthernet1/0/1] mac-address static 000f-e201-0101 vlan 2
1.1.4  mac-address (System view)
undo mac-address [ { dynamic | static } mac-address interface interface-type interface-number vlan vlan-id ]
undo mac-address [ blackhole | dynamic | static ] [ mac-address ] vlan vlan-id
undo mac-address [ dynamic | static ] mac-address interface interface-type interface-number vlan vlan-id
undo mac-address [ dynamic | static ] interface interface-type interface-number
View
blackhole: Blackhole MAC address entries. These entries do not age but you can add or remove them. The packets whose destination MAC addresses match blackhole MAC address entries are dropped.
interface interface-type interface-number: Outbound port, with interface-type interface-number representing the port type and number.
Use the mac-address command to add or modify a MAC address entry.
Use the undo mac-address command to delete a MAC address table entry.
Note the following:
l           MAC address entry attribute follows the following rules: If the existing address is a dynamic address, it can be modified as a static or blackhole MAC address, if the existing address is a static or blackhole MAC address, the system will prompt that the entry already exists and will not be modified.
l           All the addresses on a certain interface can be deleted. The user can choose to delete dynamic addresses, static addresses, or blackhole MAC addresses.
l           If you have not saved the configuration, all table entries will be lost after system resetting. If you have saved the configuration, after system resetting, static and blackhole MAC address entries will be kept, while dynamic table entries will be lost.
# Add a static entry for MAC address 000f-e201-0101. All frames destined to this MAC address are sent out of port GigabitEthernet 1/0/1 which belongs to VLAN 2.
[Sysname] mac-address static 000f-e201-0101 interface GigabitEthernet 1/0/1 vlan 2
1.1.5  mac-address max-mac-count
undo mac-address max-mac-count
View
Ethernet port view, port group view
count: Maximum number of MAC addresses that can be learned on a port. When the argument takes 0, the VLAN is not allowed to learn MAC addresses. The value ranges from 0 to 4096.
Use the mac-address max-mac-count count command to configure the maximum number of MAC addresses that can be learned on an Ethernet port.
Use the undo mac-address max-mac-count command to restore the default maximum number of MAC addresses that can be learned on an Ethernet port.
The default maximum number of MAC addresses that can be learned on a port is not configured.
Executed in Ethernet port view, the command takes effect on the current port only; executed in port group view, the command takes effect on all ports in the port group.
Related commands: mac-address, mac-address timer.
# Set the maximum number of MAC addresses that can be learned on port GigabitEthernet 1/0/1 to 600.
[Sysname-GigabitEthernet1/0/1] mac-address max-mac-count 600
1.1.6  mac-address timer
undo mac-address timer aging
View
aging seconds: Sets an aging timer in seconds for dynamic MAC address entries, in the range 10 to 1000000.
no-aging: Sets dynamic MAC address entries not to age.
Use the mac-address timer command to configure the aging timer for dynamic MAC address entries.
Use the undo mac-address timer command to restore the default.
By default the aging timer is 300 seconds.
Set the aging timer appropriately: a long aging interval may cause the MAC address table to retain outdated entries and fail to accommodate latest network changes; a short interval may result in removal of valid entries and hence unnecessary broadcasts which may affect device performance.
# Set the aging timer for dynamic MAC address entries to 500 seconds.
