H3C S5500-SI Series Ethernet Switches Command Manual(V1.01)
HomeSupportSwitchesS5500 SeriesReference GuidesCommand ReferencesH3C S5500-SI Series Ethernet Switches Command Manual(V1.01)
19-ACL Commands
19-ACL Commands 136 KB
Chapter 1  ACL Configuration Commands
1.1  Common Configuration Commands
1.1.1  display acl resource
View
None
Use the display acl resource command to display the ACL uses on a switch.
# Display the ACL uses on the switch.
<Sysname> display acl resource
 Interface:
    GE1/0/1 to GE1/0/28
  Type       Total   Reserved  Configured  Remaining
 IFP ACL     2048     0         84          1964
 IFP Meter   1024     0         35          989
 IFP Counter 1024     0         34          990
Table 1-1 Description on the fields of the display acl resource command
Interface indicated by its type and number
Resource type:
l      ACL indicates ACL rule resources,
l      Meter indicates  traffic policing resources,
l      Counter indicates traffic statistics resources,
l      IFP indicates the count of resources in the inbound direction.
Total
Total number of ACLs supported
Reserved
Number of reserved ACLs
Configured
Number of configured ACLs
Remaining
Number of remaining ACLs
1.1.2  display time-range
display time-range { time-name | all }
View
time-name: Time range name comprising 1 to 32 characters. It is case insensitive and must start with an English letter. To avoid confusion, this name cannot be all.
all: All existing time ranges.
Use the display time-range command to display the configuration and state of a specified or all time ranges.
A time range is active if the system time falls into its range, and if otherwise, inactive.
# Display the configuration and state of time range trname.
<Sysname> display time-range trname
Current time is 22:20:18 1/5/2006 Thursday
Time-range : trname ( Inactive )
 from 15:00 1/28/2006 to 15:00 1/28/2008
Table 1-2 Description on the fields of the display time-range command
Current time
Current system time
Time-range
The configuration and state of time range, such as time range name, its activated state, and start time and ending time.
1.1.3  time-range
time-range time-name { start-time to end-time days [ from time1 date1 ] [ to time2 date2 ] | from time1 date1 [ to time2 date2 ] | to time2 date2 }
undo time-range time-name [ start-time to end-time days [ from time1 date1 ] [ to time2 date2 ] | from time1 date1 [ to time2 date2 ] | to time2 date2 ]
View
start-time: Start time of a periodic time range, in hh:mm format as 24-hour time, where hh is hours and mm is minutes. Its value ranges from 00:00 to 23:59.
end-time: End time of the periodic time range, in hh:mm format as 24-hour time, where hh is hours and mm is minutes. Its value ranges from 00:00 to 24:00. The end time must be greater than the start time.
days: Indicates on which day or days of the week the periodic time range is valid. You may specify multiple values, in words or in digits, separated by spaces, for this argument, but make sure that they do not overlap. These values can take one of the following forms:
l           A digit in the range 0 to 6, respectively for Sunday, Monday, Tuesday, Wednesday, Thursday, Friday, and Saturday.
l           Week in words, that is, Mon, Tue, Wed, Thu, Fri, Sat, or Sun.
l           working-day for Monday through Friday.
l           off-day for Saturday and Sunday.
l           daily for seven days of a week.
from time1 date1: Indicates the start time and date of an absolute time range. The time1 argument specifies the time of the day in hh:mm format as 24-hour time, where hh is hours and mm is minutes. Its value ranges from 00:00 to 23:59. The date1 argument specifies a date in MM/DD/YYYY or YYYY/MM/DD format, where MM is the month of the year in the range 1 to 12, DD is the day of the month in the range 1 to 31, and YYYY is the year in the usual Gregorian calendar in the range 1970 to 2100. If not specified, the start time is the earliest time available from the system, namely, 01/01/1970 00:00:00 AM.
to time2 date2: Indicates the end time and date of the absolute time range. The format of the time2 argument is the same as that of the time1 argument, but its value ranges from 00:00 to 24:00. The end time must be greater than the start time. If not specified, the end time is the maximum time available from the system, namely, 12/31/2100 24:00:00 PM. The format and value range of the date2 argument are the same as those of the date1 argument.
Use the time-range command to create a time range.
Use the undo time-range command to remove a time range.
A time range can be one of the following:
l           Periodic time range created using the time-range time-name start-time to end-time days command. A time range thus created recurs periodically on the day or days of the week.
l           Absolute time range created using the time-range time-name { from time1 date1 [ to time2 date2 ] | to time2 date2 } command. Unlike a periodic time range, a time range thus created does not recur. For example, to create an absolute time range that is active between January 1, 2004 00:00 and December 31, 2004 23:59, you may use the time-range test from 00:00 01/01/2004 to 23:59 12/31/2004 command.
l           Compound time range created using the time-range time-name start-time to end-time days { from time1 date1 [ to time2 date2 ] | to time2 date2 } command. A time range thus created recurs on the day or days of the week only within the specified period. For example, to create a time range that is active from 12:00 to 14:00 on Wednesdays between January 1, 2004 00:00 and December 31, 2004 23:59, you may use the time-range test 12:00 to 14:00 wednesday from 00:00 01/01/2004 to 23:59 12/31/2004 command.
Note that:
l           You may create individual time ranges identified with the same name. They are regarded as one time range whose active period is the result of ORing periodic ones, ORing absolute ones, and ANDing periodic and absolute ones.
l           Up to 256 time ranges can be defined.
# Create an absolute time range named test, setting it to become active from 00:00 on January 1, 2008.
[Sysname] time-range test from 0:0 2008/1/1
# Create a periodic time range named test, setting it to be active between 14:00 and 18:00 on Saturday and Sunday.
[Sysname] time-range test 14:00 to 18:00 off-day
1.2  IPv4 ACL Configuration Commands
1.2.1  acl
acl number acl-number [ name acl-name ] [ match-order { auto | config } ]
undo acl { all | name acl-name | number acl-number }
View
number: Defines a numbered access control list (ACL).
acl-number: IPv4 ACL number, in the range of 2000 to 4999.
l           2000 to 2999 for basic IPv4 ACLs
l           3000 to 3999 for advanced IPv4 ACLs
l           4000 to 4999 for Ethernet frame header ACLs
name acl-name: Specifies the name of the ACL, which is a case insensitive string of 1 to 32 characters. It must start with an English letter and cannot be the English word of all to avoid confusion.
match-order: Sets the order in which ACL rules are matched.
l           auto: Performs depth-first match.
l           config: Performs matching against rules in the order in which they are configured.
all: All IPv4 ACLs.
Use the acl command to enter IPv4 ACL view. If the ACL does not exist, it is created first.
Use the undo acl command to remove a specified or all IPv4 ACLs.
By default, the match order is config.
Note that:
l           You can specify a name for an IPv4 ACL only when you create the ACL. After creating an ACL, you cannot specify a name for it, nor can you change or remove the name of the ACL.
l           The name of an IPv4 ACL must be unique among IPv4 ACLs. However, an IPv4 ACL and an IPv6 ACL can share the same name.
l           If you specify both an ACL number and an ACL name in one command to enter the view of an existing ACL, be sure that the ACL number and ACL name identify the same ACL.
l           You can also use this command to modify the match order of an existing ACL but only when it is empty.
# Create IPv4 ACL 2000.
[Sysname] acl number 2000
[Sysname-acl-basic-2000]
# Create IPv4 ACL 2002, giving the ACL a name of flow.
[Sysname] acl number 2002 name flow
[Sysname-acl-basic-2002-flow]
# Enter the view of an IPv4 ACL that has no name by specifying its number.
# Enter the view of an IPv4 ACL that has a name by specifying its number.
# Delete the IPv4 ACL with the number of 2000.
[Sysname] undo acl number 2000
# Delete the IPv4 ACL named flow.
[Sysname] undo acl name flow
1.2.2  acl copy
acl copy { source-acl-number | name source-acl-name } to { dest-acl-number | name dest-acl-name }
View
source-acl-number: Number of an existing IPv4 ACL, which must be in the following ranges:
source-acl-name: Name of an existing IPv4 ACL, a case insensitive string of 1 to 32 characters. It must start with an English letter and cannot be the English word of all to avoid confusion.
dest-acl-number: Number of a non-existent IPv4 ACL, which must be in the following ranges:
dest-acl-name: Name for the new IPv4 ACL, a case insensitive string of 1 to 32 characters. It must start with an English letter and cannot be the English word of all to avoid confusion. The system will automatically assign the new ACL a sequence number which is the smallest one among the available ones in the ACL range for the ACL type.
Use the acl copy command to copy an existent IPv4 ACL (namely, the source IPv4 ACL) to generate a new one (namely, the destination IPv4 ACL). The new ACL is of the same type and has the same match order, match rules, rule numbering step and descriptions.
Note that:
l           The source IPv4 ACL and the destination IPv4 ACL must be of the same type.
l           The generated ACL does not take the name of the source IPv4 ACL.
# Copy basic IPv4 ACL 2008 to generate basic IPv4 ACL 2009.
[Sysname] acl copy 2008 to 2009
1.2.3  acl name
acl name acl-name
View
acl-name: Name of the IPv4 ACL, a case insensitive string of 1 to 32 characters. It must start with an English letter and cannot be the English word of all to avoid confusion.
Use the acl name command to enter the view of an existing IPv4 ACL by specifying its name.
# Enter the view of the IPv4 ACL named flow.
[Sysname] acl name flow
1.2.4  description (for IPv4)
View
Basic IPv4 ACL view, advanced IPv4 ACL view, Ethernet frame header ACL view
text: ACL description, a case-sensitive string of 1 to 127 characters.
Use the description command to create an IPv4 ACL description, to describe the purpose of the ACL for example.
Use the undo description command to remove the ACL description.
By default, no IPv4 ACL description is present.
# Create a description for IPv4 ACL 2000.
[Sysname-acl-basic-2000] description This acl is used in geth 1/0/1
# Define the description of IPv4 ACL 3000.
[Sysname] acl number 3000
[Sysname-acl-adv-3000] description This acl is used in geth 1/0/1
# Define the description of ACL 4000.
[Sysname] acl number 4000
[Sysname-acl-ethernetframe-4000] description This acl is used in geth 1/0/1
1.2.5  display acl
display acl { acl-number | all | name acl-name }
View
acl-number: IPv4 ACL number, which must be in the following ranges:
all: All IPv4 ACLs.
Use the display acl command to display information about the specified or all IPv4 ACLs.
This command displays IPv4 ACL rules in the order in which the system compares a packet against them.
# Display information about IPv4 ACL 2001.
<Sysname> display acl 2001
Basic ACL  2001, named flow, 1 rule,
ACL's step is 5
 rule 5 permit source 1.1.1.1 0 (5 times matched)
 rule 5 comment This rule is used in geth 1/0/1
Table 1-3 Description on the fields of the display acl command
Basic ACL  2001
The displayed information is about the basic IPv4 ACL 2001.
named flow
The name of the ACL is flow.
1 rule
The ACL contains one rule.
ACL's step is 5
The rules in this ACL are numbered in steps of 5.
5 times matched
Five matches for the rule. Only ACL matches performed by software are counted.
This field appears as long as one match is found.
The description of ACL rule 5 is “This rule is used in geth 1/0/1.”
1.2.6  reset acl counter
reset acl counter { acl-number | all | name acl-name }
View
all: All IPv4 ACLs except for user-defined ACLs.
Use the reset acl counter command to clear statistics about a specified or all IPv4 ACLs that are referenced by upper layer software.
# Clear statistics about IPv4 ACL 2001, which is referenced by upper layer software.
# Clear statistics about the IPv4 ACL named flow, which is referenced by upper layer software.
<Sysname> reset acl counter name flow
1.2.7  rule (in basic IPv4 ACL view)
rule [ rule-id ] { deny | permit } [ fragment | logging | source { sour-addr sour-wildcard | any } | time-range time-name ] *
undo rule rule-id [ fragment | logging | source | time-range ] *
View
Basic IPv4 ACL view
rule-id: Basic IPv4 ACL rule number in the range 0 to 65534.
deny: Defines a deny statement to drop matched packets.
permit: Defines a permit statement to allow matched packets to pass.
fragment: Indicates that the rule applies only to non-first fragments.
logging: Specifies to log matched packets.
source { sour-addr sour-wildcard | any }: Specifies a source address. The sour-addr sour-wildcard argument specifies a source IP address in dotted decimal notation. Setting the wildcard to a zero indicates a host address. The any keyword indicates any source IP address.
time-range time-name: Specifies the time range in which the rule takes effect. The time-name argument specifies a time range name with 1 to 32 characters. It is case insensitive and must start with an English letter. To avoid confusion, this name cannot be all.
Use the rule command to create a basic IPv4 ACL rule or modify the rule if it has existed.
Use the undo rule command to remove a basic IPv4 ACL rule or parameters from the rule.
With the undo rule command, if no parameters are specified, the entire ACL rule is removed; if other parameters are specified, only the involved information is removed.
Note that:
l           You will fail to create or modify a rule if its permit/deny statement is exactly the same as another rule. In addition, if the ACL match order is set to auto rather than config, you cannot modify ACL rules.
l           When defining ACL rules, you need not assign them IDs. The system can automatically assign rule IDs starting with 0 and increasing in certain rule numbering steps. A rule ID thus assigned is greater than the current highest rule ID. For example, if the rule numbering step is 5 and the current highest rule ID is 28, the next rule will be numbered 30.
l           You may use the display acl command to verify rules configured in an ACL. If the match order for this ACL is auto, rules are displayed in the depth-first match order rather than by rule number.
&  Note:
For a basic IPv4 ACL rule to be referenced by a QoS policy for traffic classification, the logging keyword is not supported.
# Create a rule to deny packets with the source IP address 1.1.1.1.
[Sysname-acl-basic-2000] rule deny source 1.1.1.1 0
1.2.8  rule (in advanced IPv4 ACL view)
rule [ rule-id ] { deny | permit } protocol [ destination { dest-addr dest-wildcard | any } | destination-port operator port1 [ port2 ] | dscp dscp | established | fragment | icmp-type { icmp-type icmp-code | icmp-message } | logging | precedence precedence | reflective | source { sour-addr sour-wildcard | any } | source-port operator port1 [ port2 ] | time-range time-name | tos tos ] *
undo rule rule-id [ destination | destination-port | dscp | established | fragment | icmp-type | logging | precedence | reflective | source | source-port | time-range | tos ] *
View
Advanced IPv4 ACL view
rule-id: Advanced IPv4 ACL rule number in the range 0 to 65534.
protocol: Protocol carried by IP. It can be a number in the range 0 to 255, or in words, gre (47), icmp (1), igmp (2), ip, ipinip (4), ospf (89), tcp (6), udp (17).
Table 1-4 Parameters for advanced IPv4 ACL rules
Function
Specifies a destination address.
The dest-addr dest-wildcard argument specifies a destination IP address in dotted decimal notation. Setting the dest-wildcard to a zero indicates a host address. The any keyword indicates any destination IP address.
Specifies an IP precedence value.
The precedence argument can be a number in the range 0 to 7, or in words, routine(0), priority(1), immediate(2), flash(3), flash-override(4), critical(5), internet(6), or network(7).
tos tos
Specifies a ToS preference.
The tos argument can be a number in the range 0 to 15, or in words, max-reliability (2), max-throughput (4), min-delay (8), min-monetary-cost (1), or normal (0).
dscp dscp
Specifies a DSCP priority.
The dscp argument can be a number in the range 0 to 63, or in words, af11(10), af12(12), af13(14), af21(18), af22(20), af23(22), af31(26), af32(28), af33(30), af41(34), af42(36), af43(38), cs1(8), cs2(16), cs3(24), cs4(32), cs5(40), cs6(48), cs7(56), default(0), or ef(46).
logging
reflective
Specifies the rule to be reflective.
A rule with the reflective keyword can be defined only for TCP, UDP, or ICMP packets and its statement can only be permit.
fragment
Specifies the time range in which the rule can take effect.
The time-name argument comprises 1 to 32 characters. It is case insensitive and must start with an English letter. To avoid confusion, this name cannot be all.
If the protocol argument is set to tcp or udp, you may define the parameters in the following table.
Table 1-5 TCP/UDP-specific parameters for advanced IPv4 ACL rules
Function
Defines a UDP or TCP source port against which UDP or TCP packets are matched.
The operator argument can be lt (lower than), gt (greater than), eq (equal to), neq (not equal to), and range (inclusive range).
port1, port2: TCP or UDP port number, represented by a number in the range 0 to 65535. TCP port number can be represented in words as follows:
chargen (19), bgp (179), cmd (514), daytime (13), discard (9), domain (53), echo (7), exec (512), finger (79), ftp (21), ftp-data (20), gopher (70), hostname (101), irc (194), klogin (543), kshell (544), login (513), lpd (515), nntp (119), pop2 (109), pop3 (110), smtp (25), sunrpc (111), tacacs (49), talk (517), telnet (23), time (37), uucp (540), whois (43), or www (80).
UDP port number can be represented in words as follows: biff (512), bootpc (68), bootps (67), discard (9), dns (53), dnsix (90), echo (7), mobilip-ag (434), mobilip-mn (435), nameserver (42), netbios-dgm (138), netbios-ns (137), netbios-ssn (139), ntp (123), rip (520), snmp (161), snmptrap (162), sunrpc (111), syslog (514), tacacs-ds (65), talk (517), tftp (69), time (37), who (513), xdmcp (177).
With the range operator, the value of port2 does not need to be greater than that of port1 because the switch can automatically judge the value range. If the two values are the same, the switch will convert the operator range to eq.
Note that if you specify a combination of lt 1 or gt 65534, the switch will convert it to eq 0 or eq 65535.
Defines a UDP or TCP destination port against which UDP or TCP packets are matched.
established
Defines the rule for TCP connection packets.
A rule defined with this keyword matches TCP connection packets with the ack flag set.
If the protocol argument is set to icmp, you may define the parameters in the following table.
Table 1-6 Parameters for advanced IPv4 ACL rules
Function
Specifies the ICMP message type and code.
The icmp-type argument ranges from 0 to 255.
The icmp-code argument ranges from 0 to 255.
The icmp-message argument specifies a message name. For available ICMP messages, see Table 1-7..
The following table provides the ICMP messages that you can specify in advanced IPv4 ACL rules.
Table 1-7 ICMP messages and their codes
ICMP message
Code
echo
8
0
echo-reply
0
0
fragmentneed-DFset
3
4
host-redirect
5
1
host-tos-redirect
5
3
host-unreachable
3
1
information-reply
16
0
information-request
15
0
net-redirect
5
0
net-tos-redirect
5
2
net-unreachable
3
0
parameter-problem
12
0
port-unreachable
3
3
protocol-unreachable
3
2
reassembly-timeout
11
1
source-quench
4
0
source-route-failed
3
5
timestamp-reply
14
0
timestamp-request
13
0
ttl-exceeded
11
0
Use the rule command to define or modify an advanced IPv4 ACL rule. If the rule does not exist, it is created first.
Use the undo rule command to remove an advanced IPv4 ACL rule or parameters from the rule.
Note that:
l           When defining ACL rules, you need not assign them IDs. The system can automatically assign rule IDs starting with 0 and increasing in certain rule numbering steps. A rule ID thus assigned is greater than the current highest rule ID. For example, if the rule numbering step is five and the current highest rule ID is 28, the next rule will be numbered 30.
l           You may use the display acl command to verify rules configured in an ACL. If the match order for this ACL is auto, rules are displayed in the depth-first order rather than by rule number.
&  Note:
For an advanced IPv4 ACL to be referenced by a QoS policy for traffic classification:
l      The logging and reflective keywords are not supported.
l      The operator cannot be neq.
# Define a rule to permit the TCP packets to pass with the destination port 80 sent from 129.9.0.0 to 202.38.160.0.
[Sysname-acl-adv-3000] rule permit tcp source 129.9.0.0 0.0.255.255 destination 202.38.160.0 0.0.0.255 destination-port eq 80
1.2.9  rule (in Ethernet frame header ACL view)
rule [ rule-id ] { deny | permit } [ cos vlan-pri | dest-mac dest-addr dest-mask | lsap lsap-code lsap-wildcard | source-mac sour-addr source-mask | time-range time-name | type type-code type-wildcard ] *
undo rule rule-id
View
rule-id: Ethernet frame header ACL rule number in the range 0 to 65534.
cos vlan-pri: Defines an 802.1p priority. The vlan-pri argument takes a value in the range 0 to 7; or its equivalent in words, best-effort, background, spare, excellent-effort, controlled-load, video, voice, or network-management.
dest-mac dest-addr dest-mask: Specifies a destination MAC address range. The dest-addr and dest-mask arguments indicate a destination MAC address and mask in xxxx-xxxx-xxxx format.
lsap lsap-code lsap-wildcard: Defines the DSAP and SSAP fields in the LLC encapsulation. The lsap-code argument is a 16-bit hexadecimal number indicating frame encapsulation. The lsap-wildcard argument is a 16-bit hexadecimal number indicating the wildcard of the LSAP code.
source-mac sour-addr source-mask: Specifies a source MAC address range. The sour-addr and sour-mask arguments indicate a source MAC address and mask in xxxx-xxxx-xxxx format.
time-range time-name: Specifies the time range in which the rule can take effect. The time-name argument comprises 1 to 32 characters.  It is case insensitive and must start with an English letter. To avoid confusion, this name cannot be all.
type type-code type-wildcard: Defines a link layer protocol. The type-code argument is a 16-bit hexadecimal number indicating frame type. It is corresponding to the type-code field in Ethernet_II and Ethernet_SNAP frames. The type-wildcard argument is a 16-bit hexadecimal number indicating the wildcard.
Use the rule command to create an Ethernet frame header ACL rule or modify the rule if it has existed.
Use the undo rule command to remove an Ethernet frame header ACL rule.
Note that:
l           When defining ACL rules, you need not assign them IDs. The system can automatically assign rule IDs, starting with 0 and increasing in certain rule numbering steps. A rule ID thus assigned is greater than the current highest rule ID. For example, if the rule numbering step is five and the current highest rule ID is 28, the next rule will be numbered 30.
&  Note:
For an Ethernet frame header ACL to be referenced by a QoS policy for traffic classification, the lsap keyword is not supported.
# Create a rule to deny packets with the 802.1p priority of 3.
[Sysname-acl-ethernetframe-4000] rule deny cos 3
1.2.10  rule comment (for IPv4)
rule rule-id comment text
undo rule rule-id comment
View
rule-id: IPv4 ACL rule number in the range 0 to 65534.
text: IPv4 ACL rule description, a case-sensitive string of 1 to 127 characters.
Use the rule comment command to create a rule description for an existing ACL rule or modify the rule description of an ACL rule to, for example, describe the purpose of the ACL rule or the parameters it contains.
Use the undo rule comment command to remove the ACL rule description.
By default, no rule description is created.
# Create a rule in ACL 2000 and define the rule description.
[Sysname-acl-basic-2000] rule 0 deny source 1.1.1.1 0
[Sysname-acl-basic-2000] rule 0 comment This rule is used in geth 1/0/1
# Create a rule in ACL 3000 and define the rule description.
[Sysname-acl-adv-3000] rule 0 permit ip source 1.1.1.1 0
[Sysname-acl-adv-3000] rule 0 comment This rule is used in geth 1/0/1
# Create a rule in ACL 4000 and define the rule description.
[Sysname-acl-ethernetframe-4000] rule 0 deny cos 3
[Sysname-acl-ethernetframe-4000] rule 0 comment This rule is used in geth 1/0/1
1.2.11  step (for IPv4)
step step-value
undo step
View
step-value: IPv4 ACL rule numbering step, in the range 1 to 20.
Use the step command to set a rule numbering step.
Use the undo step command to restore the default.
By default, rule numbering step is five.
# Set the rule numbering step to 2 for ACL 2000.
[Sysname-acl-basic-2000] step 2
# Set the rule numbering step to 2 for ACL 3000.
[Sysname-acl-adv-3000] step 2
# Set the rule numbering step to 2 for ACL 4000.
[Sysname-acl-ethernetframe-4000] step 2
1.3  IPv6 ACL Configuration Commands
1.3.1  acl ipv6
acl ipv6 number acl6-number [ name acl6-name ] [ match-order { auto | config } ]
undo acl ipv6 { all | name acl6-name | number acl6-number }
View
number: Defines a numbered IPv6 ACL.
acl6-number: IPv6 ACL number, which must be in the following ranges:
l           2000 to 2999 for basic IPv6 ACLs
l           3000 to 3999 for advanced IPv6 ACLs
name acl6-name: Specifies the name of the ACL, which is a case insensitive string of 1 to 32 characters. It must start with an English letter and cannot be the English word of all to avoid confusion.
l           auto: Performs depth-first match. For how depth-first match works, refer to the “IPv6 ACL Match Order” section in accompanied ACL Configuration.
all: All IPv6 ACLs.
Use the acl ipv6 command to enter IPv6 ACL view. If the ACL does not exist, it is created first.
Use the undo acl ipv6 command to remove a specified or all IPv6 ACLs.
Note that:
l           The match order setting is not available for simple IPv6 ACLs, because a simple IPv6 ACL can contain only one rule.
l           You can specify a name for an IPv6 ACL only when you create the ACL. After creating an ACL, you cannot specify a name for it, nor can you change or remove the name of the ACL.
l           The name of an IPv6 ACL must be unique among IPv6 ACLs. However, an IPv4 ACL and an IPv6 ACL can share the same name.
l           You can also use this command to modify the match order of an existing IPv6 ACL but only when it is empty.
# Create IPv6 ACL 2000.
[Sysname] acl ipv6 number 2000
[Sysname-acl6-basic-2000]
# Create IPv6 ACL 2002, giving the ACL a name of flow.
[Sysname] acl ipv6 number 2002 name flow
[Sysname-acl6-basic-2002-flow]
# Enter the view of an IPv6 ACL that has no name by specifying its number.
# Enter the view of an IPv6 ACL that has a name by specifying its number.
# Delete the IPv6 ACL with the number of 2000.
[Sysname] undo acl ipv6 number 2000
# Delete the IPv6 ACL named flow.
[Sysname] undo acl ipv6 name flow
1.3.2  acl ipv6 copy
acl ipv6 copy { source-acl6-number | name source-acl6-name } to { dest-acl6-number | name dest-acl6-name }
View
source-acl6-number: Number of an existing IPv6 ACL, which must be in the following ranges:
source-acl6-name: Name of an existing IPv6 ACL, a case insensitive string of 1 to 32 characters. It must start with an English letter and cannot be the English word of all to avoid confusion.
dest-acl6-number: Number of a non-existent IPv6 ACL, which must be in the following ranges:
dest-acl6-name: Name for the new IPv6 ACL, a case insensitive string of 1 to 32 characters. It must start with an English letter and cannot be the English word of all to avoid confusion. The system will automatically assign the new ACL a sequence number which is the smallest one among the available ones in the ACL range for the ACL type.
Use the acl ipv6 copy command to copy an existent IPv6 ACL (namely, the source IPv6 ACL) to generate a new one (namely, the destination IPv6 ACL), which is of the same type and has the same match order, match rules, rule numbering step and descriptions.
Note that:
l           The source IPv6 ACL and the destination IPv6 ACL must be of the same type.
l           The generated IPv6 ACL does not take the name of the source IPv4 ACL.
# Copy IPv6 ACL 2008 to generate IPv6 ACL 2009.
[Sysname] acl ipv6 copy 2008 to 2009
1.3.3  acl ipv6 name
acl ipv6 name acl6-name
View
acl6-name: Name of the IPv6 ACL, a case insensitive string of 1 to 32 characters. It must start with an English letter and cannot be the English word of all to avoid confusion.
Use the acl ipv6 name command to enter the view of an existing IPv6 ACL by specifying its name.
# Enter the view of the IPv6 ACL named flow.
[Sysname] acl ipv6 name flow
1.3.4  description (for IPv6)
View
Basic IPv6 ACL view, advanced IPv6 ACL view
Use the description command to create an IPv6 ACL description, to describe the purpose of the ACL for example.
Use the undo description command to remove the IPv6 ACL description.
By default, no IPv6 ACL description is present.
# Create a description for IPv6 ACL 2000.
[Sysname-acl6-basic-2000] description This acl is used in geth 1/0/1
# Create a description for IPv6 ACL 3000.
[Sysname-acl6-adv-3000] description This acl is used in geth 1/0/1
1.3.5  display acl ipv6
display acl ipv6 { acl6-number | all | name acl6-name }
View
all: All IPv6 ACLs.
Use the display acl ipv6 command to display information about specified or all IPv6 ACLs.
The output will be displayed in matching order.
# Display information about IPv6 ACL 2001.
<Sysname> display acl ipv6 2001
 Basic IPv6 ACL  2001, named flow, 1 rule,
 ACL's step is 5
 rule 0 permit source 1::2/128 (5 times matched)
Table 1-8 Description on the fields of the display acl ipv6 command
Basic IPv6 ACL  2001
named flow
1 rule
Acl's step is 5
5 times matched
The field appears as long as one match is found.
1.3.6  reset acl ipv6 counter
reset acl ipv6 counter { acl6-number | all | name acl6-name }
View
all: All basic and advanced IPv6 ACLs.
Use the reset acl ipv6 counter command to clear statistics about a specified or all IPv6 ACLs that are referenced by upper layer software.
# Clear statistics about IPv6 ACL 2001, which is referenced by upper layer software.
<Sysname> reset acl ipv6 counter 2001
# Clear statistics about the IPv6 ACL named flow, which is referenced by upper layer software.
<Sysname> reset acl ipv6 counter name flow
1.3.7  rule (in basic IPv6 ACL view)
rule [ rule-id ] { deny | permit } [ fragment | logging | source { ipv6-address prefix-length | ipv6-address/prefix-length | any } | time-range time-name ] *
View
Basic IPv6 ACL view
rule-id: IPv6 ACL rule number in the range 0 to 65534.
fragment: Specifies that the rule applies to only IP fragments.
source { ipv6-address prefix-length | ipv6-address/prefix-length | any }: Specifies a source address. The ipv6-address and prefix-length arguments specify a source IPv6 address, and its address prefix length in the range 1 to 128. The any keyword indicates any IPv6 source address.
Use the rule command to create an IPv6 ACL rule or modify the rule if it has existed.
Use the undo rule command to remove an IPv6 ACL rule or parameters from the rule.
Note that:
l           You may use the display acl ipv6 command to verify rules configured in an ACL. If the match order for this IPv6 ACL is auto, rules are displayed in the depth-first match order rather than by rule number.
&  Note:
For a basic IPv6 ACL to be referenced by a QoS policy for traffic classification, the logging and fragment keywords are not supported.
# Create rules in IPv6 ACL 2000, to permit packets with source address being 2030:5060::9050/64 to pass.
[Sysname-acl6-basic-2000] rule permit source 2030:5060::9050/64
1.3.8  rule (in advanced IPv6 ACL view)
rule [ rule-id ] { deny | permit } protocol [ destination { dest dest-prefix | dest/dest-prefix | any } | destination-port operator port1 [ port2 ] | dscp dscp | fragment | icmpv6-type { icmpv6-type icmpv6-code | icmpv6-message } | logging | source { source source-prefix | source/source-prefix | any } | source-port operator port1 [ port2 ] | time-range time-name ] *
undo rule rule-id [ destination | destination-port | dscp | fragment | icmpv6-type | logging | source | source-port | time-range ] *
View
Advanced IPv6 ACL view
protocol: Protocol carried on IPv6. It can be a number in the range 0 to 255, or in words, gre (47), icmpv6 (58), ipv6, ipv6-ah (51), ipv6-esp (50), ospf (89), tcp (6), udp (17).
Table 1-9 Match criteria and other rule information for advanced IPv6 ACL rules
Function
Specifies a source IPv6 address.
The source and source-prefix arguments specify an IPv6 source address and its prefix length in the range 1 to 128.
Specifies a destination IPv6 address.
The dest and dest-prefix arguments specify a destination IPv6 address, and its prefix length in the range 1 to 128.
The any keyword indicates any IPv6 destination address.
dscp dscp
Specifies a DSCP preference
logging
fragment
Table 1-10 TCP/UDP-specific match criteria for advanced IPv6 ACL rules
Function
Defines the source port in the UDP/TCP packet.
The operator argument can be lt (lower than), gt (greater than), eq (equal to), or range (inclusive range).
The port1 and port2 arguments each specify a TCP or UDP port, represented by a number in the range 0 to 65535. TCP port number can be represented in words as follows:
Defines the destination port in the UDP/TCP packet.
If the protocol argument is set to ICMPv6, you may define the parameters in the following table.
Table 1-11 ICMPv6-specific match criteria for advanced IPv6 ACL rules
Function
Specifies the ICMPv6 message type and code
The icmpv6-type argument ranges from 0 to 255.
The icmpv6-code argument ranges from 0 to 255.
The icmpv6-message argument specifies a message name. For available ICMPv6 messages, see Table 1-12
The following table provides the ICMPv6 messages that you can specify in advanced IPv6 ACL rules.
Table 1-12 Available ICMPv6 messages
ICMPv6 message
Code
redirect
137
0
echo-request
128
0
echo-reply
129
0
err-Header-field
4
0
frag-time-exceeded
3
1
hop-limit-exceeded
3
0
host-admin-prohib
1
1
host-unreachable
1
3
neighbor-advertisement
136
0
neighbor-solicitation
135
0
network-unreachable
1
0
packet-too-big
2
0
port-unreachable
1
4
router-advertisement
134
0
router-solicitation
133
0
unknown-ipv6-opt
4
2
unknown-next-hdr
4
1
Note that:
l           When defining ACL rules, you need not assign them IDs. The system can automatically assign rule IDs, starting with 0 and increasing in certain rule numbering steps. A rule ID thus assigned is greater than the current highest rule ID. For example, if the rule numbering step is 5 and the current highest rule ID is 28, the next rule will be numbered 30.
l           You may use the display acl ipv6 command to verify rules configured in an IPv6 ACL. If the match order for this IPv6 ACL is auto, rules are displayed in the depth-first match order rather than by rule number.
&  Note:
For an advanced IPv6 ACL to be referenced by a QoS policy for traffic classification,
l      The logging and fragment keywords are not supported.
# Create a rule in IPv6 ACL 3000 to permit the TCP packets with the source address 2030:5060::9050/64 to pass.
[Sysname-acl6-adv-3000] rule permit tcp source 2030:5060::9050/64
1.3.9  rule comment (for IPv6)
View
text: IPv6 ACL rule description, a case-sensitive string of 1 to 127 characters.
Use the rule comment command to create a rule description for an existing ACL rule or modify the rule description of an ACL rule to, for example, describe the purpose of the ACL rule or its attributes.
Use the undo rule comment command to remove the IPv6 ACL rule description.
# Define a rule in IPv6 ACL 2000 and create a description for the rule.
[Sysname-acl6-basic-2000] rule 0 permit source 2030:5060::9050/64
[Sysname-acl6-basic-2000] rule 0 comment This rule is used in geth 1/0/1
# Define a rule in IPv6 ACL 3000 and create a description for the rule.
[Sysname-acl6-adv-3000] rule 0 permit tcp source 2030:5060::9050/64
[Sysname-acl6-adv-3000] rule 0 comment This rule is used in geth 1/0/1
1.3.10  step (for IPv6)
step step-value
undo step
View
step-value: The step in which the rules in the IPv6 ACL is numbered, in the range 1 to 20.
Use the step command to set a rule numbering step for the IPv6 ACL.
By default, the rule numbering step is five.
# Set the rule numbering step to 2 for IPv6 ACL 2000.
[Sysname-acl6-basic-2000] step 2
# Set the rule numbering step to 2 for IPv6 ACL 3000.
[Sysname-acl6-adv-3000] step 2
