H3C S5500-SI Series Ethernet Switches Command Manual(V1.01)
HomeSupportSwitchesS5500 SeriesReference GuidesCommand ReferencesH3C S5500-SI Series Ethernet Switches Command Manual(V1.01)
37-Appendix
37-Appendix 83 KB
Appendix A  Command Index
The command index includes all the commands in the Command Manual, which are arranged alphabetically.
A B C D E F G H I J K L M N O P Q R S T U V W X Y Z
A
access-limit
AAA-RADIUS-HWTACACS Commands
1-1
accounting
QoS Commands
2-6
accounting default
1-2
accounting lan-access
1-3
accounting login
1-4
accounting optional
1-5
accounting-on enable
1-30
accounting-on enable interval
1-30
accounting-on enable send
1-31
acl
Login Commands
2-1
acl
ACL Commands
1-5
acl copy
ACL Commands
1-6
acl ipv6
ACL Commands
1-21
acl ipv6 copy
ACL Commands
1-23
acl ipv6 name
ACL Commands
1-24
acl name
ACL Commands
1-8
activation-key
Login Commands
1-1
active region-configuration
MSTP Commands
1-1
add-member
Cluster Management Commands
1-16
administrator-address
1-17
apply cost
IPv4 Routing Commands
3-1
apply ip-address next-hop
3-7
apply ipv6 next-hop
IPv6 Routing Commands
3-1
apply poe-profile
PoE Commands
1-1
apply poe-profile interface
PoE Commands
1-2
apply preference
3-2
apply tag
3-3
arp check enable
ARP Commands
1-1
arp max-learning-num
ARP Commands
1-1
arp static
ARP Commands
1-2
arp timer aging
ARP Commands
1-3
ascii
File System Management Commands
2-5
attribute
1-6
attribute
PKI Commands
1-1
authentication default
1-7
authentication lan-access
1-8
authentication login
1-9
authentication-mode
Login Commands
1-2
authorization command
1-10
authorization default
1-11
authorization lan-access
1-12
authorization login
1-13
auto-build
1-18
auto-execute command
Login Commands
1-3
B
backup startup-configuration
1-11
binary
2-5
black-list add-mac
1-19
black-list delete-mac
1-20
boot-loader
System Maintaining and Debugging Commands
3-1
bootrom
3-2
bootrom-update security-check enable
3-2
bpdu-tunnel dot1q enable
BPDU TUNNEL Commands
2-2
bpdu-tunnel dot1q stp
2-1
bpdu-tunnel tunnel-dmac
2-3
broadcast-suppression
Port Correlation Commands
1-1
build
1-21
bye
2-6
bye
SSH Commands
1-32
C
ca identifier
PKI Commands
1-2
car
QoS Commands
2-7
cd
1-1
cd
2-6
cd
SSH Commands
1-33
cdup
2-7
cdup
SSH Commands
1-33
certificate request entity
PKI Commands
1-3
certificate request from
PKI Commands
1-3
certificate request mode
PKI Commands
1-4
certificate request polling
PKI Commands
1-5
certificate request url
PKI Commands
1-6
check region-configuration
MSTP Commands
1-1
checkzero
2-1
checkzero
2-1
ciphersuite
HTTPS Commands
1-1
classifier behavior
QoS Commands
2-18
client-verify enable
HTTPS Commands
1-2
clock datetime
1-1
clock summer-time one-off
1-2
clock summer-time repeating
1-3
clock timezone
1-4
close
2-7
close-mode wait
HTTPS Commands
1-2
cluster
1-21
cluster enable
1-22
cluster switch-to
1-23
command-privilege
1-5
common-name
PKI Commands
1-6
copy
1-2
country
PKI Commands
1-7
crl check
PKI Commands
1-8
crl update-period
PKI Commands
1-8
crl url
PKI Commands
1-9
cut connection
1-14
D
databits
Login Commands
1-4
data-fill
NQA Commands
1-1
data-flow-format
1-32
data-flow-format
1-59
data-size
NQA Commands
1-2
debugging
2-8
debugging
2-7
default cost
2-2
default cost
2-2
default-route originate
2-2
delete
1-2
delete
2-9
delete
SSH Commands
1-34
delete ipv6 static-routes all
1-1
delete static-routes all
1-1
delete-member
1-24
description
VLAN Commands
1-1
description
1-2
description
NQA Commands
1-2
description (for IPv4)
ACL Commands
1-8
description (for IPv6)
ACL Commands
1-24
destination ip
NQA Commands
1-3
destination port
NQA Commands
1-4
dhcp enable
DHCP Commands
1-1
dhcp relay address-check
DHCP Commands
1-2
dhcp relay information enable
DHCP Commands
1-2
dhcp relay information format
DHCP Commands
1-3
dhcp relay information strategy
DHCP Commands
1-4
dhcp relay release
DHCP Commands
1-5
dhcp relay security static
DHCP Commands
1-5
dhcp relay security tracker
DHCP Commands
1-6
dhcp relay server-detect
DHCP Commands
1-7
dhcp relay server-group
DHCP Commands
1-8
dhcp relay server-select
DHCP Commands
1-9
dhcp select relay
DHCP Commands
1-9
dhcp-snooping
DHCP Commands
3-1
dhcp-snooping information enable
DHCP Commands
3-2
dhcp-snooping information format
DHCP Commands
3-2
dhcp-snooping information strategy
DHCP Commands
3-3
dhcp-snooping trust
DHCP Commands
3-4
dir
1-3
dir
2-10
dir
SSH Commands
1-34
disconnect
2-11
display acl
ACL Commands
1-9
display acl ipv6
ACL Commands
1-25
display acl resource
ACL Commands
1-1
display arp
ARP Commands
1-4
display arp ip-address
ARP Commands
1-5
display arp timer aging
ARP Commands
1-6
display boot-loader
3-5
display bootp client
DHCP Commands
4-1
display brief interface
1-3
display channel
Information Center Commands
1-1
display clipboard
1-6
display clock
1-7
display cluster
1-25
display cluster base-topology
1-26
display cluster black-list
1-27
display cluster candidates
1-28
display cluster current-topology
1-30
display cluster members
1-32
display connection
1-15
display cpu-usage
3-3
display current-configuration
1-8
display debugging
2-8
display device
3-6
display device manuinfo
3-7
display dhcp client
DHCP Commands
2-1
display dhcp relay
DHCP Commands
1-10
display dhcp relay security
DHCP Commands
1-11
display dhcp relay security statistics
DHCP Commands
1-12
display dhcp relay security tracker
DHCP Commands
1-13
display dhcp relay server-group
DHCP Commands
1-13
display dhcp relay statistics
DHCP Commands
1-14
display dhcp-snooping
DHCP Commands
3-5
display dhcp-snooping trust
DHCP Commands
3-6
display diagnostic-information
1-10
display dns domain
DNS Commands
1-1
display dns dynamic-host
DNS Commands
1-2
display dns ipv6 dynamic-host
IPv6 Commands
1-1
display dns ipv6 server
IPv6 Commands
1-2
display dns proxy table
DNS Commands
1-3
display dns server
DNS Commands
1-4
display domain
1-16
display dot1x
MAC Authentication Commands
1-1
display environment
3-8
display fan
3-8
display fib
IP Addressing and IP Performance Commands
2-1
display fib ip-address
2-3
display fib statistics
2-4
display ftp client configuration
2-11
display ftp-server
2-1
display ftp-user
2-1
display garp statistics
VLAN Commands
3-1
display garp timer
VLAN Commands
3-2
display gvrp local-vlan interface
VLAN Commands
3-5
display gvrp state
VLAN Commands
3-6
display gvrp statistics
VLAN Commands
3-6
display gvrp status
VLAN Commands
3-8
display gvrp vlan-operation interface
VLAN Commands
3-8
display habp
3-1
display habp table
3-1
display habp traffic
3-2
display history-command
1-10
display hotkey
1-11
display hwtacacs
1-60
display icmp statistics
2-5
display igmp-snooping group
Multicast Commands
1-1
display igmp-snooping statistics
Multicast Commands
1-2
display info-center
1-2
display interface
1-5
display interface Vlan-interface
VLAN Commands
1-2
display ip host
DNS Commands
1-5
display ip https
HTTPS Commands
2-1
display ip interface
1-1
display ip interface brief
1-3
display ip ip-prefix
3-8
display ip ipv6-prefix
3-2
display ip relay-route
IP Routing Overview Commands
1-1
display ip routing-table
1-2
display ip routing-table acl
1-7
display ip routing-table ip-address
1-8
display ip routing-table ip-prefix
1-11
display ip routing-table protocol
1-13
display ip routing-table statistics
1-14
display ip socket
2-6
display ip statistics
2-9
display ipv6 fib
IPv6 Commands
1-3
display ipv6 host
IPv6 Commands
1-4
display ipv6 interface
IPv6 Commands
1-5
display ipv6 neighbors
IPv6 Commands
1-7
display ipv6 neighbors count
IPv6 Commands
1-9
display ipv6 pathmtu
IPv6 Commands
1-9
display ipv6 relay-route
1-15
display ipv6 routing-table
1-16
display ipv6 routing-table acl
1-17
display ipv6 routing-table ipv6-address
1-17
display ipv6 routing-table ipv6-address1 ipv6-address2
1-19
display ipv6 routing-table ipv6-prefix
1-20
display ipv6 routing-table protocol
1-21
display ipv6 routing-table statistics
1-21
display ipv6 routing-table verbose
1-22
display ipv6 socket
IPv6 Commands
1-10
display ipv6 statistics
IPv6 Commands
1-12
display lacp system-id
Link Aggregation Commands
1-1
display link-aggregation interface
1-1
display link-aggregation summary
1-3
display link-aggregation verbose
1-5
display local-proxy-arp
ARP Commands
2-1
display local-user
1-18
display logbuffer
1-4
display logbuffer summary
1-7
display loopback-detection
1-8
display mac-address
MAC Address Table Management Commands
1-1
display mac-address aging-time
1-2
display mac-authentication
4-1
display mac-vlan
VLAN Commands
1-15
display mac-vlan interface
VLAN Commands
1-15
display memory
3-9
display mirroring-group
Port Mirroring Commands
1-1
display mld-snooping group
Multicast Commands
2-1
display mld-snooping statistics
Multicast Commands
2-2
display multicast-vlan
Multicast Commands
3-1
display multicast-vlan ipv6
Multicast Commands
4-1
display ndp
1-1
display nqa
NQA Commands
1-4
display nqa server status
NQA Commands
1-29
display ntdp
1-7
display ntdp device-list
1-8
display ntdp single-device mac-address
1-10
display ntp-service sessions
NTP Commands
1-1
display ntp-service status
NTP Commands
1-3
display ntp-service trace
NTP Commands
1-4
display pki certificate
PKI Commands
1-10
display pki certificate access-control-policy
PKI Commands
1-11
display pki certificate attribute-group
PKI Commands
1-12
display pki crl domain
PKI Commands
1-13
display poe device
PoE Commands
1-3
display poe interface
PoE Commands
1-3
display poe interface power
PoE Commands
1-7
display poe pse
PoE Commands
1-9
display poe-profile
PoE Commands
1-11
display poe-profile interface
PoE Commands
1-13
display port combo
1-9
display port-group manual
1-10
display port-isolate group
2-1
display port-security
Port Security Commands
1-1
display port-security mac-address block
1-3
display port-security mac-address security
1-4
display power
3-10
display proxy-arp
ARP Commands
2-1
display public-key local
SSH Commands
1-1
display public-key peer
SSH Commands
1-3
display qos lr interface
QoS Commands
1-1
display qos map-table
QoS Commands
4-1
display qos policy
QoS Commands
2-18
display qos policy interface
QoS Commands
2-19
display qos sp interface
QoS Commands
3-1
display qos trust interface
QoS Commands
4-4
display qos vlan-policy
QoS Commands
5-1
display qos wrr interface
QoS Commands
3-1
display radius scheme
1-33
display radius statistics
1-35
display reboot-type
3-10
display rip
2-3
display rip database
2-5
display rip interface
2-6
display rip route
2-7
display ripng
2-2
display ripng database
2-4
display ripng interface
2-5
display ripng route
2-6
display rmon alarm
RMON Commands
2-1
display rmon event
RMON Commands
2-2
display rmon eventlog
RMON Commands
2-3
display rmon history
RMON Commands
2-4
display rmon prialarm
RMON Commands
2-6
display rmon statistics
RMON Commands
2-7
display route-policy
3-3
display saved-configuration
1-12
display schedule reboot
3-11
display sftp client source
SSH Commands
1-4
display snmp-agent community
RMON Commands
1-1
display snmp-agent group
RMON Commands
1-2
display snmp-agent local-engineid
RMON Commands
1-1
display snmp-agent mib-view
RMON Commands
1-3
display snmp-agent statistics
RMON Commands
1-5
display snmp-agent sys-info
RMON Commands
1-7
display snmp-agent trap-list
RMON Commands
1-8
display snmp-agent usm-user
RMON Commands
1-9
display ssh client source
SSH Commands
1-5
display ssh server
SSH Commands
1-5
display ssh server-info
SSH Commands
1-7
display ssh user-information
SSH Commands
1-8
display ssl client-policy
HTTPS Commands
1-3
display ssl server-policy
HTTPS Commands
1-4
display stack
Stack Management Commands
1-1
display startup
1-17
display stop-accounting-buffer
1-38
1-62
display storm-constrain
1-11
display stp
MSTP Commands
1-3
display stp abnormal-port
MSTP Commands
1-5
display stp down-port
MSTP Commands
1-6
display stp history
MSTP Commands
1-7
display stp region-configuration
MSTP Commands
1-8
display stp root
MSTP Commands
1-9
display stp tc
MSTP Commands
1-10
display tcp ipv6 statistics
IPv6 Commands
1-16
display tcp ipv6 status
IPv6 Commands
1-19
display tcp statistics
2-10
display tcp status
2-13
display telnet client configuration
Login Commands
1-5
display tftp client configuration
3-1
display this
1-13
display time-range
ACL Commands
1-2
display track
Track Commands
1-1
display traffic behavior
QoS Commands
2-8
display traffic classifier
QoS Commands
2-1
display trapbuffer
1-8
display udp ipv6 statistics
IPv6 Commands
1-20
display udp statistics
2-14
display udp-helper server
UDP Helper Commands
1-1
display user-interface
Login Commands
1-6
display users
Login Commands
1-7
display version
1-13
display vlan
VLAN Commands
1-3
display voice vlan oui
VLAN Commands
2-1
display voice vlan state
VLAN Commands
2-2
display web users
Login Commands
1-9
dns domain
DNS Commands
1-5
dns proxy enable
DNS Commands
1-6
dns resolve
DNS Commands
1-7
dns server
DNS Commands
1-7
dns server ipv6
IPv6 Commands
1-21
domain
1-19
domain default
1-20
dot1x
1-4
dot1x authentication-method
1-5
dot1x free-ip
2-1
dot1x guest-vlan
1-6
dot1x handshake
1-8
dot1x max-user
1-9
dot1x multicast-trigger
1-10
dot1x port-control
1-10
dot1x port-method
1-12
dot1x quiet-period
1-13
dot1x retry
1-13
dot1x timer
1-14
dot1x timer ead-timeout
2-2
dot1x url
2-2
duplex
1-12
E
enable snmp trap updown
RMON Commands
1-10
escape-key
Login Commands
1-9
execute
1-4
exit
SSH Commands
1-35
F
fast-leave
Multicast Commands
1-3
fast-leave
Multicast Commands
2-3
file prompt
1-5
filename
NQA Commands
1-8
filter
QoS Commands
2-10
filter-policy export
2-10
2-7
filter-policy import
2-11
2-8
fixdisk
1-5
flow-control
Login Commands
1-11
flow-control
1-13
format
1-6
fqdn
PKI Commands
1-15
free ftp user
2-2
free user-interface
Login Commands
1-11
free web-users
Login Commands
2-2
frequency
NQA Commands
1-9
ftp
2-12
ftp client source
2-13
ftp ipv6
2-14
ftp server enable
2-3
ftp timeout
2-3
ftp update
2-4
ftp-server
1-34
G
garp timer
VLAN Commands
3-2
garp timer leaveall
VLAN Commands
3-4
get
2-16
get
SSH Commands
1-36
gratuitous-arp-learning enable
ARP Commands
1-7
gratuitous-arp-sending enable
ARP Commands
1-7
group-member
1-14
group-policy
Multicast Commands
1-4
group-policy
Multicast Commands
2-4
gvrp
VLAN Commands
3-9
gvrp registration
VLAN Commands
3-10
H
habp enable
3-3
habp server vlan
3-4
habp timer
3-4
handshake timeout
HTTPS Commands
1-5
header
1-14
help
SSH Commands
1-36
history-command max-size
Login Commands
1-12
history-records
NQA Commands
1-10
holdtime
1-35
host-aging-time
Multicast Commands
1-5
host-aging-time
Multicast Commands
2-5
host-route
2-11
hotkey
1-16
http-version
NQA Commands
1-11
hwtacacs nas-ip
1-63
hwtacacs scheme
1-64
I
idle-cut
1-21
idle-timeout
Login Commands
1-13
if-match
QoS Commands
2-2
if-match acl
3-9
if-match cost
3-4
if-match interface
3-5
if-match ip
3-10
if-match ip-prefix
3-11
if-match ipv6
3-3
if-match tag
3-6
igmp-snooping
Multicast Commands
1-6
igmp-snooping drop-unknown
Multicast Commands
1-6
igmp-snooping enable
Multicast Commands
1-7
igmp-snooping fast-leave
Multicast Commands
1-8
igmp-snooping general-query source-ip
Multicast Commands
1-9
igmp-snooping group-limit
Multicast Commands
1-10
igmp-snooping group-policy
Multicast Commands
1-11
igmp-snooping host-aging-time
Multicast Commands
1-12
igmp-snooping host-join
Multicast Commands
1-13
igmp-snooping last-member-query-interval
Multicast Commands
1-14
igmp-snooping max-response-time
Multicast Commands
1-15
igmp-snooping overflow-replace
Multicast Commands
1-15
igmp-snooping querier
Multicast Commands
1-16
igmp-snooping query-interval
Multicast Commands
1-17
igmp-snooping router-aging-time
Multicast Commands
1-18
igmp-snooping source-deny
Multicast Commands
1-18
igmp-snooping special-query source-ip
Multicast Commands
1-19
igmp-snooping static-group
Multicast Commands
1-20
igmp-snooping static-router-port
Multicast Commands
1-21
igmp-snooping version
Multicast Commands
1-22
import
QoS Commands
4-3
import-route
2-12
import-route
2-9
info-center channel name
1-9
info-center console channel
1-10
info-center enable
1-11
info-center logbuffer
1-11
info-center loghost
1-12
info-center loghost source
1-13
info-center monitor channel
1-14
info-center snmp channel
1-15
info-center source
1-16
info-center synchronous
1-18
info-center timestamp
1-19
info-center timestamp loghost
1-20
info-center trapbuffer
1-21
instance
MSTP Commands
1-11
interface
1-15
VLAN Commands
1-4
ip
PKI Commands
1-15
ip address
VLAN Commands
1-5
ip address
1-4
ip address bootp-alloc
DHCP Commands
4-2
ip address dhcp-alloc
DHCP Commands
2-3
ip forward-broadcast (interface view)
2-15
ip forward-broadcast (system view)
2-16
ip host
DNS Commands
1-8
ip http acl
Login Commands
2-2
ip http enable
Login Commands
1-14
ip https acl
HTTPS Commands
2-2
ip https certificate access-control-policy
HTTPS Commands
2-2
ip https enable
HTTPS Commands
2-3
ip https ssl-server-policy
HTTPS Commands
2-4
ip ip-prefix
3-11
ip ipv6-prefix
3-3
ip redirects enable
2-17
ip route-static
1-2
ip route-static default-preference
1-3
ip ttl-expires enable
2-17
ip unreachables enable
2-18
ip-pool
1-36
ipv6
IPv6 Commands
1-22
ipv6
IPv6 Commands
2-1
ipv6 address
IPv6 Commands
1-22
ipv6 address
IPv6 Commands
2-1
ipv6 address auto link-local
IPv6 Commands
1-23
IPv6 Commands
2-2
ipv6 address eui-64
IPv6 Commands
1-24
ipv6 address eui-64
IPv6 Commands
2-3
ipv6 address link-local
IPv6 Commands
1-24
IPv6 Commands
2-3
ipv6 host
IPv6 Commands
1-25
ipv6 icmp-error
IPv6 Commands
1-26
IPv6 Commands
1-26
IPv6 Commands
1-27
ipv6 nd autoconfig other-flag
IPv6 Commands
1-28
ipv6 nd dad attempts
IPv6 Commands
1-28
ipv6 nd hop-limit
IPv6 Commands
1-29
ipv6 nd ns retrans-timer
IPv6 Commands
1-30
ipv6 nd nud reachable-time
IPv6 Commands
1-30
ipv6 nd ra halt
IPv6 Commands
1-31
ipv6 nd ra interval
IPv6 Commands
1-32
ipv6 nd ra prefix
IPv6 Commands
1-32
ipv6 nd ra router-lifetime
IPv6 Commands
1-33
ipv6 neighbor
IPv6 Commands
1-34
ipv6 neighbors max-learning-num
IPv6 Commands
1-35
ipv6 pathmtu
IPv6 Commands
1-36
ipv6 pathmtu age
IPv6 Commands
1-36
ipv6 route-static
1-2
J
jumboframe enable
1-15
K
key
1-39
key
1-64
L
lacp port-priority
1-7
lacp system-priority
1-7
last-listener-query-interval
Multicast Commands
2-6
Multicast Commands
1-23
lcd
2-16
ldap-server
PKI Commands
1-16
level
1-22
link-aggregation group description
1-8
link-aggregation group mode
1-9
locality
PKI Commands
1-16
local-proxy-arp enable
ARP Commands
2-2
local-user
1-23
local-user password-display-mode
1-24
lock
Login Commands
1-14
logging-host
1-36
loopback
1-16
loopback-detection control enable
1-17
loopback-detection enable
1-17
loopback-detection interval-time
1-19
loopback-detection per-vlan enable
1-19
ls
2-17
ls
SSH Commands
1-37
M
mac-address (Ethernet port view)
1-3
mac-address (System view)
1-4
mac-address max-mac-count
1-5
mac-address timer
1-6
mac-authentication
4-3
mac-authentication domain
4-4
mac-authentication timer
4-5
mac-authentication user-name-format
4-6
mac-vlan enable
VLAN Commands
1-18
mac-vlan mac-address
VLAN Commands
1-17
management-vlan
1-37
max-response-time
Multicast Commands
1-24
max-response-time
Multicast Commands
2-7
mdi
1-20
mirroring-group
1-2
mirroring-group mirroring-port
1-3
mirroring-group monitor-egress
1-4
mirroring-group monitor-port
1-5
mirroring-group remote-probe vlan
1-6
mirroring-port
1-7
mirror-to
QoS Commands
6-1
mkdir
1-7
mkdir
2-18
mkdir
SSH Commands
1-38
mld-snooping
Multicast Commands
2-7
mld-snooping drop-unknown
Multicast Commands
2-8
mld-snooping enable
Multicast Commands
2-9
mld-snooping fast-leave
Multicast Commands
2-9
mld-snooping general-query source-ip
Multicast Commands
2-11
mld-snooping group-limit
Multicast Commands
2-11
mld-snooping group-policy
Multicast Commands
2-12
mld-snooping host-aging-time
Multicast Commands
2-14
mld-snooping host-join
Multicast Commands
2-14
mld-snooping last-listener-query-interval
Multicast Commands
2-16
mld-snooping max-response-time
Multicast Commands
2-16
mld-snooping overflow-replace
Multicast Commands
2-17
mld-snooping querier
Multicast Commands
2-18
mld-snooping query-interval
Multicast Commands
2-19
mld-snooping router-aging-time
Multicast Commands
2-19
mld-snooping source-deny
Multicast Commands
2-20
mld-snooping special-query source-ip
Multicast Commands
2-21
mld-snooping static-group
Multicast Commands
2-22
mld-snooping static-router-port
Multicast Commands
2-23
mld-snooping version
Multicast Commands
2-24
monitor-port
1-8
more
1-7
move
1-8
multicast-suppression
1-21
multicast-vlan enable
Multicast Commands
3-1
multicast-vlan ipv6 enable
Multicast Commands
4-1
multicast-vlan ipv6 subvlan
Multicast Commands
4-2
multicast-vlan subvlan
Multicast Commands
3-2
N
nas-ip
1-40
nas-ip
1-65
ndp enable
1-4
ndp timer aging
1-5
ndp timer hello
1-6
nest
QoS Commands
2-10
network
2-13
next-hop
NQA Commands
1-11
nm-interface vlan-interface
1-38
nqa
NQA Commands
1-12
nqa agent enable
NQA Commands
1-13
nqa agent max-concurrent
NQA Commands
1-13
nqa schedule
NQA Commands
1-14
nqa server enable
NQA Commands
1-30
nqa server tcp-connect
NQA Commands
1-31
nqa server udp-echo
NQA Commands
1-32
ntdp enable
1-11
ntdp explore
1-12
ntdp hop
1-13
ntdp timer
1-14
ntdp timer hop-delay
1-14
ntdp timer port-delay
1-15
ntp-service access
NTP Commands
1-5
ntp-service authentication enable
NTP Commands
1-6
ntp-service authentication-keyid
NTP Commands
1-7
ntp-service broadcast-client
NTP Commands
1-8
ntp-service broadcast-server
NTP Commands
1-9
ntp-service in-interface disable
NTP Commands
1-9
ntp-service max-dynamic-sessions
NTP Commands
1-10
ntp-service multicast-client
NTP Commands
1-11
ntp-service multicast-server
NTP Commands
1-11
ntp-service reliable authentication-keyid
NTP Commands
1-12
ntp-service source-interface
NTP Commands
1-13
ntp-service unicast-peer
NTP Commands
1-14
ntp-service unicast-server
NTP Commands
1-15
O
open
2-19
open ipv6
2-19
operation (FTP test type view)
NQA Commands
1-15
operation (HTTP test type view)
NQA Commands
1-15
operation interface
NQA Commands
1-16
organization
PKI Commands
1-17
organizational-unit
PKI Commands
1-18
overflow-replace
Multicast Commands
1-24
overflow-replace
Multicast Commands
2-24
P
parity
Login Commands
1-15
passive
2-20
password
1-24
password
NQA Commands
1-17
peer
2-14
peer-public-key end
SSH Commands
1-8
ping
2-1
ping ipv6
2-3
PKI Commands
1-18
PKI Commands
1-19
pki delete-certificate
PKI Commands
1-20
pki domain
PKI Commands
1-20
pki entity
PKI Commands
1-21
pki import-certificate
PKI Commands
1-22
pki request-certificate domain
PKI Commands
1-22
pki retrieval-certificate
PKI Commands
1-23
pki retrieval-crl domain
PKI Commands
1-24
pki validate-certificate
PKI Commands
1-24
pki-domain
HTTPS Commands
1-6
poe disconnect
PoE Commands
1-14
poe enable
PoE Commands
1-15
poe legacy enable
PoE Commands
1-16
poe max-power
PoE Commands
1-16
poe mode
PoE Commands
1-17
poe pd-description
PoE Commands
1-18
poe pd-policy priority
PoE Commands
1-19
poe priority
PoE Commands
1-19
poe update
PoE Commands
1-21
poe utilization-threshold
PoE Commands
1-21
poe-profile
PoE Commands
1-22
port
VLAN Commands
1-8
port access vlan
VLAN Commands
1-9
port hybrid pvid vlan
VLAN Commands
1-10
port hybrid vlan
VLAN Commands
1-11
port link-aggregation group
1-9
port link-type
VLAN Commands
1-12
port trunk permit vlan
VLAN Commands
1-13
port trunk pvid vlan
VLAN Commands
1-14
port-group
1-22
port-group aggregation
1-10
port-isolate enable
2-2
port-security authorization ignore
1-6
port-security enable
1-7
port-security intrusion-mode
1-8
1-9
port-security max-mac-count
1-10
port-security ntk-mode
1-11
port-security oui
1-11
port-security port-mode
1-12
port-security timer disableport
1-14
port-security trap
1-14
prefer-cipher
HTTPS Commands
1-6
preference
2-15
preference
2-9
primary accounting
1-41
primary accounting
1-66
primary authentication
1-42
1-67
primary authorization
1-68
probe count
NQA Commands
1-17
probe packet-interval
NQA Commands
1-18
probe packet-number
NQA Commands
1-19
probe packet-timeout
NQA Commands
1-19
probe timeout
NQA Commands
1-20
protocol inbound
Login Commands
1-16
proxy-arp enable
ARP Commands
2-2
public-key local create
SSH Commands
1-11
public-key local destroy
SSH Commands
1-12
public-key local export dsa
SSH Commands
1-14
public-key local export rsa
SSH Commands
1-13
public-key peer
SSH Commands
1-15
public-key peer import sshkey
SSH Commands
1-16
public-key-code begin
SSH Commands
1-9
public-key-code end
SSH Commands
1-10
put
2-21
put
SSH Commands
1-38
pwd
1-8
pwd
2-21
pwd
SSH Commands
1-39
Q
qinq enable
1-2
qinq ethernet-type
1-2
qinq vid
1-3
qos apply policy
QoS Commands
2-21
qos lr outbound
QoS Commands
1-2
qos map-table
QoS Commands
4-2
qos policy
QoS Commands
2-22
qos priority
QoS Commands
4-3
qos sp
QoS Commands
3-3
qos trust
QoS Commands
4-5
qos vlan-policy
QoS Commands
5-2
qos wrr
QoS Commands
3-3
2-22
1-18
SSH Commands
1-39
R
radius client
1-43
radius nas-ip
1-44
radius scheme
1-45
radius trap
1-46
raw-vlan-id inbound
1-1
reaction
NQA Commands
1-21
reaction trap
NQA Commands
1-22
reboot
3-11
reboot member
1-39
redirect
QoS Commands
2-11
region-name
MSTP Commands
1-12
remark customer-vlan-id
QoS Commands
2-12
remark dot1p
QoS Commands
2-12
remark drop-precedence
QoS Commands
2-13
remark dscp
QoS Commands
2-14
remark ip-precedence
QoS Commands
2-15
remark local-precedence
QoS Commands
2-16
remark service-vlan-id
QoS Commands
2-16
remotehelp
2-22
remove
SSH Commands
1-40
rename
1-9
rename
SSH Commands
1-41
report-aggregation
Multicast Commands
1-25
report-aggregation
Multicast Commands
2-25
reset acl counter
ACL Commands
1-10
reset acl ipv6 counter
ACL Commands
1-26
reset arp
ARP Commands
1-6
reset counters interface
1-23
reset dhcp relay statistics
DHCP Commands
1-16
reset dhcp-snooping
DHCP Commands
3-7
reset dns dynamic-host
DNS Commands
1-9
reset dns ipv6 dynamic-host
IPv6 Commands
1-37
reset dot1x statistics
1-16
reset garp statistics
VLAN Commands
3-5
reset hwtacacs statistics
1-68
reset igmp-snooping group
Multicast Commands
1-26
reset igmp-snooping statistics
Multicast Commands
1-26
reset ip ip-prefix
3-13
reset ip ipv6-prefix
3-5
reset ip routing-table statistics protocol
1-24
reset ip statistics
2-18
reset ipv6 neighbors
IPv6 Commands
1-38
reset ipv6 pathmtu
IPv6 Commands
1-38
reset ipv6 routing-table statistics
1-24
reset ipv6 statistics
IPv6 Commands
1-39
reset lacp statistics
1-10
reset logbuffer
1-22
reset mac-authentication statistics
4-7
reset mld-snooping group
Multicast Commands
2-26
reset mld-snooping statistics
Multicast Commands
2-27
reset ndp statistics
1-6
reset qos vlan-policy
QoS Commands
5-3
reset radius statistics
1-46
reset recycle-bin
1-10
reset rip statistics
2-15
reset saved-configuration
1-17
reset stop-accounting-buffer
1-47
1-69
reset stp
MSTP Commands
1-12
reset tcp ipv6 statistics
IPv6 Commands
1-39
reset tcp statistics
2-19
reset trapbuffer
1-22
reset udp ipv6 statistics
IPv6 Commands
1-40
reset udp statistics
2-19
reset udp-helper packet
UDP Helper Commands
1-1
reset unused porttag
3-12
restore startup-configuration
1-18
retry
1-48
retry realtime-accounting
1-49
retry stop-accounting
1-50
1-70
return
1-18
revision-level
MSTP Commands
1-13
rip
2-16
rip authentication-mode
2-17
rip input
2-18
rip metricin
2-18
rip metricout
2-19
rip output
2-20
rip poison-reverse
2-21
rip split-horizon
2-22
rip summary-address
2-22
rip version
2-23
ripng
2-10
ripng default-route
2-11
ripng enable
2-12
ripng metricin
2-12
ripng metricout
2-13
ripng poison-reverse
2-14
ripng split-horizon
2-14
ripng summary-address
2-15
rmdir
1-10
rmdir
2-25
rmdir
SSH Commands
1-41
rmon alarm
RMON Commands
2-9
rmon event
RMON Commands
2-11
rmon history
RMON Commands
2-12
rmon prialarm
RMON Commands
2-13
rmon statistics
RMON Commands
2-16
root-certificate fingerprint
PKI Commands
1-25
route-option bypass-route
NQA Commands
1-23
route-policy
3-6
router-aging-time
Multicast Commands
1-27
router-aging-time
Multicast Commands
2-27
rule
PKI Commands
1-26
rule (in advanced IPv4 ACL view)
ACL Commands
1-13
rule (in advanced IPv6 ACL view)
ACL Commands
1-28
rule (in basic IPv4 ACL view)
ACL Commands
1-11
rule (in basic IPv6 ACL view)
ACL Commands
1-27
rule (in Ethernet frame header ACL view)
ACL Commands
1-18
rule comment (for IPv4)
ACL Commands
1-19
rule comment (for IPv6)
ACL Commands
1-32
S
save
1-19
schedule reboot at
3-13
schedule reboot delay
3-15
screen-length
Login Commands
1-17
secondary accounting
1-51
1-70
secondary authentication
1-51
1-71
secondary authorization
1-72
security-policy-server
1-52
self-service-url
1-25
send
Login Commands
1-18
server-type
1-53
service-type
Login Commands
1-19
service-type
1-27
service-type ftp
1-27
session
HTTPS Commands
1-7
set authentication password
Login Commands
1-20
sftp
SSH Commands
1-17
sftp client ipv6 source
SSH Commands
1-18
sftp client source
SSH Commands
1-18
sftp ipv6
SSH Commands
1-19
sftp server enable
SSH Commands
1-20
sftp server idle-timeout
SSH Commands
1-21
shell
Login Commands
1-21
shutdown
VLAN Commands
1-6
shutdown
1-24
silent-interface
2-24
snmp-agent
RMON Commands
1-10
snmp-agent calculate-password
RMON Commands
1-11
Login Commands
2-3
RMON Commands
1-12
snmp-agent group
Login Commands
2-4
snmp-agent group
RMON Commands
1-13
RMON Commands
1-14
snmp-agent log
RMON Commands
1-15
snmp-agent mib-view
RMON Commands
1-16
snmp-agent packet max-size
RMON Commands
1-17
snmp-agent sys-info
RMON Commands
1-17
snmp-agent target-host
RMON Commands
1-18
snmp-agent trap enable
RMON Commands
1-20
snmp-agent trap if-mib link extended
RMON Commands
1-21
snmp-agent trap life
RMON Commands
1-22
snmp-agent trap queue-size
RMON Commands
1-22
snmp-agent trap source
RMON Commands
1-23
snmp-agent usm-user
Login Commands
2-5
snmp-agent usm-user { v1 | v2c }
RMON Commands
1-24
snmp-agent usm-user v3
RMON Commands
1-25
snmp-host
1-40
source interface
NQA Commands
1-23
source ip
NQA Commands
1-24
source port
NQA Commands
1-25
source-deny
Multicast Commands
1-27
source-deny
Multicast Commands
2-28
speed
Login Commands
1-22
speed
1-24
ssh client authentication server
SSH Commands
1-21
ssh client first-time enable
SSH Commands
1-22
ssh client ipv6 source
SSH Commands
1-23
ssh client source
SSH Commands
1-24
ssh server authentication-retries
SSH Commands
1-24
ssh server authentication-timeout
SSH Commands
1-25
ssh server compatible-ssh1x enable
SSH Commands
1-26
ssh server enable
SSH Commands
1-26
ssh server rekey-interval
SSH Commands
1-27
ssh user
SSH Commands
1-28
ssh2
SSH Commands
1-29
ssh2 ipv6
SSH Commands
1-31
ssl client-policy
HTTPS Commands
1-8
ssl server-policy
HTTPS Commands
1-9
stack ip-pool
1-3
stack role master
1-4
stack stack-port
1-4
stack switch-to
1-5
startup saved-configuration
1-20
state
1-28
state
1-54
state
PKI Commands
1-26
step (for IPv4)
ACL Commands
1-20
step (for IPv6)
ACL Commands
1-33
stop-accounting-buffer enable
1-55
1-73
stopbits
Login Commands
1-23
storm-constrain
1-25
storm-constrain control
1-26
storm-constrain enable log
1-27
storm-constrain enable trap
1-28
storm-constrain interval
1-28
stp
MSTP Commands
1-14
stp bpdu-protection
MSTP Commands
1-15
stp bridge-diameter
MSTP Commands
1-16
stp compliance
MSTP Commands
1-16
stp config-digest-snooping
MSTP Commands
1-18
stp cost
MSTP Commands
1-18
stp edged-port
MSTP Commands
1-19
stp loop-protection
MSTP Commands
1-20
stp max-hops
MSTP Commands
1-21
stp mcheck
MSTP Commands
1-22
stp mode
MSTP Commands
1-23
stp no-agreement-check
MSTP Commands
1-23
stp pathcost-standard
MSTP Commands
1-24
stp point-to-point
MSTP Commands
1-26
stp port priority
MSTP Commands
1-27
stp port-log
MSTP Commands
1-27
stp priority
MSTP Commands
1-28
MSTP Commands
1-29
stp root primary
MSTP Commands
1-30
stp root secondary
MSTP Commands
1-31
stp root-protection
MSTP Commands
1-32
stp tc-protection
MSTP Commands
1-32
stp tc-protection threshold
MSTP Commands
1-33
stp timer forward-delay
MSTP Commands
1-34
stp timer hello
MSTP Commands
1-35
stp timer max-age
MSTP Commands
1-36
stp timer-factor
MSTP Commands
1-37
stp transmit-limit
MSTP Commands
1-37
summary
2-25
super
1-19
super password
1-20
sysname
1-21
1-22
T
tcp ipv6 timer fin-timeout
IPv6 Commands
1-40
tcp ipv6 timer syn-timeout
IPv6 Commands
1-41
tcp ipv6 window
IPv6 Commands
1-41
tcp timer fin-timeout
2-20
tcp timer syn-timeout
2-21
tcp window
2-21
telnet
Login Commands
1-24
telnet client source
Login Commands
1-25
telnet ipv6
Login Commands
1-25
telnet server enable
Login Commands
1-26
terminal debugging
1-22
terminal logging
1-23
terminal monitor
1-24
terminal trapping
1-25
terminal type
Login Commands
1-27
tftp
3-2
tftp client source
3-4
tftp ipv6
3-5
tftp-server
1-40
tftp-server acl
3-1
timer
1-41
timer quiet
1-56
timer quiet
1-74
timer realtime-accounting
1-56
1-74
timer response-timeout
1-57
1-75
time-range
ACL Commands
1-3
timers
2-26
timers
2-16
topology accept
1-42
topology restore-from
1-43
topology save-to
1-43
tos
NQA Commands
1-26
tracert
2-4
tracert ipv6
2-6
track nqa
Track Commands
1-2
traffic behavior
QoS Commands
2-17
traffic classifier
QoS Commands
2-5
ttl
NQA Commands
1-26
type
NQA Commands
1-27
U
udp-helper enable
UDP Helper Commands
1-2
udp-helper port
UDP Helper Commands
1-2
udp-helper server
UDP Helper Commands
1-3
undelete
1-11
unicast-suppression
1-29
url
NQA Commands
1-28
user
2-25
user privilege level
Login Commands
1-28
user-interface
Login Commands
1-28
username
NQA Commands
1-29
user-name-format
1-58
user-name-format
1-76
V
validate-source-address
2-27
verbose
2-26
version
2-28
version
HTTPS Commands
1-9
virtual-cable-test
1-31
vlan
VLAN Commands
1-7
vlan-mapping modulo
MSTP Commands
1-38
voice vlan
VLAN Commands
2-3
voice vlan aging
VLAN Commands
2-4
voice vlan enable
VLAN Commands
2-4
voice vlan mac-address
VLAN Commands
2-5
voice vlan mode auto
VLAN Commands
2-7
voice vlan security enable
VLAN Commands
2-8
W
work-directory
1-29
X
Y
Z
