H3C S5500-SI Series Ethernet Switches Command Manual(V1.01)
HomeSupportSwitchesS5500 SeriesReference GuidesCommand ReferencesH3C S5500-SI Series Ethernet Switches Command Manual(V1.01)
32-Track Commands
32-Track Commands 24 KB
Chapter 1  Track Configuration Commands
1.1  Track Configuration Commands
1.1.1  display track
display track { track-entry-number | all }
View
track-entry-number: Displays information about the specified Track object, in the range 1 to 1024.
all: Displays information about all the Track objects.
Use the display track command to display Track object information.
# Display information about all the Track objects.
<Sysname> display track all
Track ID: 1
  Status: Positive
  Reference Object:
    NQA Entry: admin test
    Reaction: 10
Table 1-1 Description on the fields of the display track command
Track ID
ID of a Track object
Status
Status of a Track object:
l      Positive: The Track object is normal.
l      Invalid: The Track object is invalid.
l      Negative: The Track object is abnormal.
Reference Object
The objects referenced by the Track object
NQA Entry
The NQA test group referenced by the Track object
Reaction
The Reaction entry referenced by the Track object
1.1.2  track nqa
track track-entry-number nqa entry admin-name operation-tag reaction item-num
undo track track-entry-number
View
track-entry-number: Track object ID, in the range 1 to 1024.
entry admin-name operation-tag: Specifies the NQA test group to be associated with the Track object. admin-name is the name of the administrator creating the NQA operation, a string of 1 to 32 characters, case-insensitive. operation-tag is the NQA operation tag, a string of 1 to 32 characters, case-insensitive.
reaction item-num: Specifies the Reaction entry to be associated with the Track object. item-num is the Reaction entry ID, in the range 1 to 10.
Use the track command to create the Track object to be associated with the specified Reaction entry of the NQA test group.
Use the undo track command to remove the created Track object.
By default, no Track object is created.
Note that after a Track object is created, you cannot modify it using the track command.
# Create Track object 1 to associate it with Reaction entry 3 of the NQA test group (admin-test).
[Sysname] track 1 nqa entry admin test reaction 3
