- H3C S9500 Series Routing Switches Installation Manual-(V1.24)
- 00-1Cover
- 01-Chapter 1 Product Overview
- 02-Chapter 2 Installation Preparations
- 03-Chapter 3 Switch Installation
- 04-Chapter 4 System Commissioning
- 05-Chapter 5 Switch Monitoring and Maintenance
- 06-Appendix A Cable Management
- 07-Appendix B Engineering Labels for Cables
- 08-Appendix C Installation of Lightning Arrester for AC Power
| 00-1Cover | 65 KB |
H3C S9500 Series Routing Switches |
Installation Manual |
Hangzhou H3C Technologies Co., Ltd. http://www.h3c.com
Manual Version: T2-08048T-20071015-C-1.24 Product Version: S9500-CMW310-R1632P03 |
Copyright © 2006-2007, Hangzhou H3C Technologies Co., Ltd. and its licensors
All Rights Reserved
No part of this manual may be reproduced or transmitted in any form or by any means without prior written consent of Hangzhou H3C Technologies Co., Ltd.
Trademarks
H3C,
, Aolynk,
, H3Care,
, TOP G,
, IRF, NetPilot, Neocean, NeoVTL, SecPro,
SecPoint, SecEngine, SecPath, Comware, Secware, Storware, NQA, VVG, V2G,
VnG, PSPT, XGbus, N-Bus, TiGem, InnoVision and HUASAN are trademarks
All other trademarks that may be mentioned in this manual are the property of their respective owners.
Notice
The information in this document is subject to change without notice. Every effort has been made in the preparation of this document to ensure accuracy of the contents, but all statements, information, and recommendations in this document do not constitute the warranty of any kind, express or implied.
To obtain the latest information, please access:
http://www. h3c.com
Technical Support
http://www. h3c.com
About This Manual
Related Documentation
The related manuals are listed in the following table.
Manual |
H3C S9500 Series Routing Switches Operation Manual |
It provides an operation guide. It consists of access volume, IP service volume, IP routing volume, IP multicast volume, MPLS/VPN volume, QoS/ACL volume, security volume, system volume, and acronyms. |
H3C S9500 Series Routing Switches Command Manual |
It explains all commands available in the S9500 series and provides a list of commands the S9500 series do not support. It consists of the same modules as the operation manual. |
Organization
H3C S9500 Series Routing Switches Installation Manual is organized as follows:
Chapter |
Contents |
1 Product Overview |
Introduces the appearance, architecture and system features of the S9500 series. |
2 Installation Preparations |
Lists the preparations and precautions for the installation. |
3 Switch Installation |
Details the installation of the chassis, PSUs, boards and cable connection for the S9500 series. |
4 System Commissioning |
Concentrates on the initial power-on and booting of the S9500 series. |
5 Switch Monitoring and Maintenance |
Presents the hardware and software upgrade. |
6 Appendix A Cable Management |
Introduces how to bind cables. |
7 Appendix B Engineering Labels for Cables |
Introduces the use of engineering labels. |
8 Appendix C Installation of Lightning Arrester for AC Power |
Introduces the installation of lightning arrester for AC power of S9500 series routing switches. |
Conventions
The manual uses the following conventions:
I. Command conventions
Convention |
Boldface |
The keywords of a command line are in Boldface. |
italic |
Command arguments are in italic. |
Items (keywords or arguments) in square brackets [ ] are optional. |
{ x | y | ... } |
Alternative items are grouped in braces and separated by vertical bars. One is selected. |
[ x | y | ... ] |
Optional alternative items are grouped in square brackets and separated by vertical bars. One or none is selected. |
{ x | y | ... } * |
Alternative items are grouped in braces and separated by vertical bars. A minimum of one or a maximum of all can be selected. |
[ x | y | ... ] * |
Optional alternative items are grouped in square brackets and separated by vertical bars. Many or none can be selected. |
&<1-n> |
The argument(s) before the ampersand (&) sign can be entered 1 to n times. |
A line starting with the # sign is comments. |
II. GUI conventions
Convention |
Button names are inside angle brackets. For example, click <OK>. |
Window names, menu items, data table and field names are inside square brackets. For example, pop up the [New User] window. |
Multi-level menus are separated by forward slashes. For example, [File/Create/Folder]. |
III. Symbols
Convention |
Means reader be extremely careful. Improper operation may cause bodily injury. |
Means reader be careful. Improper operation may cause data loss or damage to equipment. |
& Note |
Means a complementary description. |
Environmental Protection
This product has been designed to comply with the requirements on environmental protection. For the proper storage, use and disposal of this product, national laws and regulations must be observed.
