H3C S3610[S5510] Series Ethernet Switches Command Manual-Release 5301-(V1.03)
HomeSupportSwitchesH3C S3610[S5510] Switch SeriesReference GuidesCommand ReferencesH3C S3610[S5510] Series Ethernet Switches Command Manual-Release 5301-(V1.03)
32-VRRP Commands
32-VRRP Commands 103 KB
Chapter 1  VRRP Configuration Commands
&  Note:
At present, the interfaces that VRRP involves can only be VLAN interfaces unless otherwise specified.
1.1  IPv4-Based VRRP Configuration Commands
1.1.1  display vrrp
display vrrp [ verbose ] [ interface interface-type interface-number [ vrid virtual-router-id ] ]
View
verbose: Displays detailed state information of VRRP.
interface interface-type interface-number: Displays VRRP state information of the specified interface. interface-type interface-number specifies an interface by its type and number.
vrid virtual-router-id: Displays state information of the specified VRRP group. virtual-router-id specifies a standby group by its group number, in the range 1 to 255.
Use the display vrrp command to display the state information of VRRP.
If you do not specify verbose, only the brief state information of VRRP is displayed.
If you specify both interface and standby group, only the state information of the specified standby group is displayed; if you only specify an interface, the state information of all the standby groups on the interface is displayed; if you specify neither, the state information of all the standby groups on the device is displayed.
# Display brief information about all standby groups on the device.
<Sysname> display vrrp
 IPv4 Standby Information:
 Run Method      : VIRTUAL-MAC
 Virtual IP Ping : Enable
 The total number of the virtual routers: 1
 Interface          VRID  State       Run     Adver.  Auth     Virtual
                                      Pri     Time    Type        IP
 Vlan100             1    Master      100     1       NONE     10.10.10.2
# Display detailed information about all standby groups on the device.
<Sysname> display vrrp verbose
 Interface       : Vlan-interface100
 VRID            : 1                    Adver. Timer    : 1
 Admin Status    : UP                   State           : Master
 Config Pri      : 100                  Run Pri         : 100
 Preempt Mode    : YES                  Delay Time      : 0
 Auth Type       : NONE
 Track IF        : Vlan-interface200    Pri Reduced     : 10
 Virtual IP      : 10.10.10.2
 Virtual MAC     : 0000-5e00-0101
 Master IP       : 10.10.10.1
Table 1-1 Description on the fields of the display vrrp command
Run Method
Current VRRP running mode, real MAC or virtual MAC
Virtual IP Ping
Whether you can ping the virtual IP address of the standby group
Interface to which the standby group belongs
VRID
Number of the standby group
Adver. Timer
VRRP advertisement interval
Admin Status
Administrative state: UP or DOWN
Status of the switch in the standby group, master, backup, or initialize
Config Pri
Configured priority
Run Pri
Running priority
Preempt Mode
Preemption mode
Delay Time
Preemption delay, not displayed when the device works in non-preemption mode.
Auth Type
Authentication type
Track IF
The interface to be tracked. It is displayed only after the execution of the vrrp vrid track command.
Pri Reduced
The priority value that is reduced when the interface being tracked is down.
Virtual IP
Virtual IP addresses of the standby group
Virtual MAC
Virtual MAC address corresponding to the virtual IP address of the standby group. It is displayed only when the switch is in the state of master.
Master IP
Primary IP address of the interface to which the switch in the state of master belongs
1.1.2  display vrrp statistics
View
interface interface-type interface-number: Displays VRRP statistics of the specified interface. interface-type interface-number specifies an interface by its type and number.
vrid virtual-router-id: Displays statistics of the specified VRRP group. virtual-router-id specifies a standby group by its group number, in the range 1 to 255.
Use the display vrrp statistics command to display statistics about VRRP.
If you specify both interface and standby group, only the statistics about the specified standby group are displayed; if you only specify an interface, the statistics about all the standby groups on the interface are displayed; if you specify neither, the statistics about all the standby groups on the device are displayed.
# Display the statistics about all standby groups.
<Sysname> display vrrp statistics
 VRID                   : 1
 CheckSum Errors        : 16         Version Errors                 : 0
 Invalid Type Pkts Rcvd : 0          Advertisement Interval Errors  : 0
 IP TTL Errors          : 0          Auth Failures                  : 0
 Invalid Auth Type      : 0          Auth Type Mismatch             : 0
 Packet Length Errors   : 0          Address List Errors            : 0
 Become Master          : 1          Priority Zero Pkts Rcvd        : 0
 Advertise Rcvd         : 16         Priority Zero Pkts Sent        : 0
Advertise Sent         : 40
 Interface              : Vlan-interface200
 VRID                   : 105
 CheckSum Errors        : 0          Version Errors                 : 0
 Become Master          : 0          Priority Zero Pkts Rcvd        : 0
 Advertise Rcvd         : 0          Priority Zero Pkts Sent        : 0
Advertise Sent         : 30
Global statistics
 Version Errors         : 0
 VRID Errors            : 20
Table 1-2 Description on the fields of the display vrrp statistics command
VRID
CheckSum Errors
Number of packets with checksum errors
Version Errors
Number of packets with version errors
Number of packets with incorrect packet type
Number of packets with advertisement interval errors
IP TTL Errors
Number of packets with TTL errors
Auth Failures
Number of packets with authentication failures
Invalid Auth Type
Number of packets with authentication failures due to invalid authentication types
Auth Type Mismatch
Number of packets with authentication failures due to mismatching authentication types
Number of packets with VRRP packet length errors
Address List Errors
Number of packets with virtual IP address list errors
Become Master
Number of times that the switch worked as the master
Number of received advertisements with the priority of 0
Advertise Rcvd
Advertise Sent
Number of advertisements sent
Global statistics
Statistics about all standby groups
CheckSum Errors
Total number of packets with checksum errors
Version Errors
Total number of packets with version errors
VRID Errors
Total number of packets with VRID errors
1.1.3  reset vrrp statistics
View
interface interface-type interface-number: Clears VRRP statistics of a specified interface. interface-type interface-number specifies an interface by its type and number.
vrid virtual-router-id: Clears VRRP statistics of the specified standby group. virtual-router-id specifies a standby group by its group number, in the range 1 to 255.
Use the reset vrrp statistics command to clear VRRP statistics.
If you specify both the interface and standby group, the statistics about the specified standby group on the specified interface are cleared; if you specify only the interface, the statistics about all the standby groups on the interface are cleared; if you specify neither, the statistics about all the standby groups on the device are cleared.
# Clear the statistics about all the standby groups on the device.
<Sysname> reset vrrp statistics
1.1.4  vrrp vrid authentication-mode
vrrp vrid virtual-router-id authentication-mode { md5 | simple } key
undo vrrp vrid virtual-router-id authentication-mode
View
Interface view
virtual-router-id: VRRP standby group number, in the range 1 to 255.
simple: Plain text authentication mode.
md5: Authentication header (AH) authentication using the MD5 algorithm.
key: Authentication key, case sensitive.
l           When simple authentication applies, the authentication key is in plain text with a length of 1 to 8 characters.
l           When md5 authentication applies, the authentication key is in MD5 cipher text or in plain text and the length of the key depends on its input format. If the key is input in plain text, its length is 1 to 8 characters, such as 1234567; if the key is input in cipher text, its length must be 24 characters, such as _(TT8F]Y\5SQ=^Q`MAF4<1!!.
Use the vrrp vrid authentication-mode command to configure authentication mode and authentication key for the VRRP standby groups to send and receive VRRP packets.
Use the undo vrrp vrid authentication-mode command to restore the default.
By default, authentication is disabled.
Note that:
l           Before executing the command, create a standby group on an interface and configure the virtual IP address of the standby group.
l           You may configure different authentication types and authentication keys for the standby groups on an interface. However, the members of the same standby group must use the same authentication mode and authentication key.
# Set the authentication mode and authentication key for VRRP standby group 1 on interface VLAN-interface 2 to send and receive VRRP packets.
[Sysname-Vlan-interface2] vrrp vrid 1 virtual-ip 10.1.1.1
[Sysname-Vlan-interface2] vrrp vrid 1 authentication-mode simple Sysname
1.1.5  vrrp method
vrrp method { real-mac | virtual-mac }
undo vrrp method
View
real-mac: Associates the real MAC address of the interface with the virtual IP address of the standby group.
virtual-mac: Associates the virtual MAC address of the switch with the virtual IP address of the standby group.
Use the vrrp method command to set the mappings between the virtual IP addresses and the MAC addresses of the standby groups.
Use the undo vrrp method command to restore the default mapping.
By default, the virtual MAC address of the standby group is associated with the virtual IP address.
You must configure the mapping between the virtual IP address and the MAC address before configuring a standby group. Otherwise, your configuration will fail.
# Associate the virtual IP address of the standby group with the real MAC address of the routing interface.
[Sysname] vrrp method real-mac
1.1.6  vrrp ping-enable
vrrp ping-enable
undo vrrp ping-enable
View
None
Use the vrrp ping-enable command to enable users to ping the virtual IP addresses of standby groups.
Use the undo vrrp ping-enable command to disable the virtual IP addresses of standby groups from being pinged.
By default, the virtual IP addresses of standby groups can be pinged.
Perform this configuration before configuring a standby group.
# Enable users to ping the virtual IP addresses of standby groups.
[Sysname] vrrp ping-enable
1.1.7  vrrp un-check ttl
vrrp un-check ttl
undo vrrp un-check ttl
View
Interface view
None
Use the vrrp un-check ttl command to disable TTL check on VRRP packets.
Use the undo vrrp un-check ttl command to enable TTL check on VRRP packets.
By default, TTL check on VRRP packets is enabled.
# Disable TTL check on VRRP packets.
[Sysname-Vlan-interface2] vrrp un-check ttl
1.1.8  vrrp vrid preempt-mode
vrrp vrid virtual-router-id preempt-mode [ timer delay delay-value ]
undo vrrp vrid virtual-router-id preempt-mode [ timer delay ]
View
Interface view
virtual-router-id: Virtual router ID or VRRP standby group number, in the range 1 to 255.
timer delay delay-value: Sets preemption delay. The delay-value argument is in the range of 0 to 255 seconds and defaults to 0 seconds.
Use the vrrp vrid preempt-mode command to enable preemption on the switch and configure its preemption delay in the specified standby group.
Use the undo vrrp vrid preempt-mode command to disable preemption on the switch in the specified standby group.
Use the undo vrrp vrid preempt-mode timer delay command to restore the default preemption delay, that is, zero seconds.
The default mode is immediate preemption without delay.
On an instable network, the standby group member in the backup state may not normally receive the packets from the master due to network congestion, resulting in frequent master/backup state transition of the standby group members. Preemption delay is introduced to solve this problem. With a preemption delay set, if the backup does not receive the packet from the master duly, it waits for a period to see whether it can receive any packet from the master. If the specified period elapses but it still receives no packet from the master, it becomes the master.
Note that before executing the command, you need to create a standby group on an interface and configure the virtual IP address of the standby group.
# Enable preemption on the router in VRRP standby group 1, and set the preemption delay to five seconds.
[Sysname-Vlan-interface2] vrrp vrid 1 preempt-mode timer delay 5
1.1.9  vrrp vrid priority
undo vrrp vrid virtual-router-id priority
View
Interface view
priority-value: Priority value of the router in the specified standby group, in the range 1 to 254, with a higher number indicating a higher priority.
Use the vrrp vrid priority command to configure the priority of the switch in the specified standby group.
Use the undo vrrp vrid priority command to restore the default.
By default, the priority of a switch in a standby group is 100.
l           In VRRP, the role that a switch plays in a standby group depends on its priority. A higher priority means that the switch is more likely to become the master. Note that priority 0 is reserved for special use and 255 for the IP address owner.
l           If the switch is the IP address owner, its priority is always 255. Therefore, it will be the master so long as it is functioning normally.
# Set the priority of standby group 1 on interface VLAN-interface 2 to 150.
[Sysname-Vlan-interface2] vrrp vrid 1 priority 150
1.1.10  vrrp vrid timer advertise
undo vrrp vrid virtual-router-id timer advertise
View
Interface view
adver-interval: Interval at which the master in the specified standby group sends VRRP advertisements. It ranges from 1 to 255 seconds.
Use the vrrp vrid timer advertise command to configure the Adver_Timer of the specified standby group.
Use the undo vrrp vrid timer advertise command to restore the default.
By default the Adver_Timer is 1 second.
The Adver_Timer controls the interval at which the master sends VRRP packets.
Note that:
l           Routers in the same VRRP standby group must use the same Adver_Timer setting.
# Set the master in standby group 1 to send VRRP advertisements at intervals of five seconds.
[Sysname-Vlan-interface2] vrrp vrid 1 timer advertise 5
1.1.11  vrrp vrid track
vrrp vrid virtual-router-id track interface interface-type interface-number [ reduced priority-reduced ]
undo vrrp vrid virtual-router-id track [ interface interface-type interface-number ]
View
Interface view
interface interface-type interface-number: Specifies an interface to be tracked by its type and number.
reduced priority-reduced: Value by which the priority decrements. priority-reduced ranges from 1 to 255 and defaults to 10.
Use the vrrp vrid track command to configure to track the specified interface.
Use the undo vrrp vrid track command to disable tracking the specified interface.
By default, no interface is being tracked.
Note that:
l           When the switch is the owner of the IP address, you cannot perform the configuration.
l           When the status of the tracked interface turns from down to up, the corresponding switch restores its priority automatically.
# On interface VLAN-interface 2, set the interface to be tracked as VLAN-interface 1, making the priority of standby group 1 on interface VLAN-interface 2 decrement by 50 when VLAN-interface 1 goes down.
[Sysname-Vlan-interface2] vrrp vrid 1 track interface vlan-interface 1 reduced 50
1.1.12  vrrp vrid virtual-ip
vrrp vrid virtual-router-id virtual-ip virtual-address
undo vrrp vrid virtual-router-id [ virtual-ip virtual-address ]
View
Interface view
virtual-address: Virtual IP address.
Use the vrrp vrid virtual-ip command to create a standby group the first time that you add a virtual IP address or add a virtual IP address to it after that.
Use the undo vrrp vrid virtual-router-id command to remove a standby group.
Use the undo vrrp vrid virtual-router-id virtual-ip virtual-address command to remove a virtual IP address from a standby group.
By default, no standby group is created.
Note that:
l           The system removes a standby group after you delete all the virtual IP addresses in it.
l           The virtual IP address of the standby group cannot be 0.0.0.0, 255.255.255.255, loopback address, non A/B/C address and other illegal IP addresses such as 0.0.0.1.
l           Only when the configured virtual IP address and the interface IP address belong to the same segment and are legal host addresses can the standby group operate normally. If they are not in the same network segment, or the configured IP address is the network address or network broadcast address of the network segment that the interface IP address belongs to, though you can perform the configuration successfully, the state of the standby group is always Initialize, that is, VRRP does not take effect in this case.
# Create standby group 1 and set its virtual IP address to 10.10.10.10.
[Sysname-Vlan-interface2] vrrp vrid 1 virtual-ip 10.10.10.10
# Add virtual IP address 10.10.10.11 to standby group 1.
[Sysname-Vlan-interface2] vrrp vrid 1 virtual-ip 10.10.10.11
1.2  VRRP Configuration Commands for IPv6
1.2.1  display vrrp ipv6
display vrrp ipv6 [ verbose ] [ interface interface-type interface-number [ vrid virtual-router-id ] ]
View
Use the display vrrp ipv6 command to display the state information of VRRP for IPv6.
# Display brief information about all VRRP standby groups on the device for IPv6.
<Sysname> display vrrp ipv6
 IPv6 Standby Information:
 The total number of the vitual routers: 1
                                      Pri     Time    Type        IP
 Vlan100             1    Master      100     100     NONE     FE80::1
<Sysname>display vrrp ipv6 verbose
 VRID            : 1                    Adver. Timer    : 100
 Auth Type       : NONE
 Virtual IP      : FE80::1
 Virtual MAC     : 0000-5e00-0201
 Master IP       : FE80::20F:E2FF:FE49:8060
Table 1-3 Description on the fields of the display vrrp ipv6 command
Run Method
Virtual IP Ping
Whether you can ping the virtual IPv6 address
VRID
Adver. Timer
VRRP advertisement interval in centiseconds
Admin Status
Config Pri
Configured priority
Run Pri
Running priority
Preempt Mode
Preemption mode
Delay Time
Auth Type
Authentication type
Track IF
The interface to be tracked. It is displayed only after the execution of the vrrp ipv6 vrid track command.
Pri Reduced
Virtual IP
Virtual IPv6 addresses of the standby group
Virtual MAC
Virtual MAC address corresponding to the virtual IPv6 address of the standby group. It is displayed only when the switch is in the state of master.
Master IP
Primary IPv6 address of the interface to which the switch in the state of master belongs
1.2.2  display vrrp ipv6 statistics
display vrrp ipv6 statistics [ interface interface-type interface-number [ vrid virtual-router-id ] ]
View
interface interface-type interface-number: Displays VRRP statistics information of the specified interface. interface-type interface-number specifies an interface by its type and number.
vrid virtual-router-id: Displays statistics information of the specified VRRP group. virtual-router-id specifies a standby group by its group number, in the range 1 to 255.
Use the display vrrp ipv6 statistics command to display statistics about VRRP for IPv6.
# Display the statistics about all standby groups for IPv6.
<Sysname> display vrrp ipv6 statistics
 VRID                   : 80
 Hop Limit Errors       : 0          Auth Failures                  : 0
 Advertise Sent         : 20
 VRID                   : 10
 Advertise Sent         : 30
 Global statistics
 CheckSum Errors        : 0
 Version Errors         : 0
 VRID Errors            : 1439
Table 1-4 Description on the fields of the display vrrp ipv6 statistics command
VRID
CheckSum Errors
Version Errors
Hop Limit Errors
Number of packets with hop limit errors
Auth Failures
Invalid Auth Type
Auth Type Mismatch
Address List Errors
Number of packets with virtual IPv6 address list errors
Become Master
Advertise Rcvd
Advertise Sent
Global statistics
CheckSum Errors
Version Errors
VRID Errors
1.2.3  reset vrrp ipv6 statistics
reset vrrp ipv6 statistics [ interface interface-type interface-number [ vrid virtual-router-id ] ]
View
interface interface-type interface-number: Clears VRRP statistics of a specific interface. interface-type interface-number specifies an interface by its type and number.
Use the reset vrrp ipv6 statistics command to clear VRRP statistics.
<Sysname> reset vrrp ipv6 statistics
1.2.4  vrrp ipv6 vrid authentication-mode
vrrp ipv6 vrid virtual-router-id authentication-mode simple key
undo vrrp ipv6 vrid virtual-router-id authentication-mode
View
Interface view
simple: Sets the authentication mode to plain text authentication.
key: Authentication key of 1 to 8 case-sensitive characters in plain text.
Use the vrrp ipv6 vrid virtual-router-id authentication-mode simple key command to configure authentication mode and authentication key for the VRRP standby groups to send and receive VRRP packets.
Use the undo vrrp ipv6 vrid virtual-router-id authentication-mode command to restore the default.
Note that:
# Set the authentication mode and authentication key for VRRP standby group 10 on interface VLAN-interface 2 to send and receive VRRP packets.
[Sysname-Vlan-interface2] vrrp ipv6 vrid 10 virtual-ip fe80::2 link-local
[Sysname-Vlan-interface2]vrrp ipv6 vrid 10 authentication-mode simple test
1.2.5  vrrp ipv6 method
vrrp ipv6 method { real-mac | virtual-mac }
undo vrrp ipv6 method
View
real-mac: Associates the real MAC address of the interface with the virtual IPv6 address of the standby group.
virtual-mac: Associates the virtual MAC address of the router with the virtual IPv6 address of the standby group.
Use the vrrp ipv6 method command to set the mappings between the virtual IPv6 addresses and the MAC addresses of the standby groups.
Use the undo vrrp ipv6 method command to restore the default mapping.
Configure the mapping between the virtual IPv6 address and the MAC address before configuring a standby group. Otherwise, your configuration will fail.
[Sysname] vrrp ipv6 method real-mac
1.2.6  vrrp ipv6 ping-enable
undo vrrp ipv6 ping-enable
View
None
Use the vrrp ipv6 ping-enable command to enable users to ping the virtual IPv6 addresses of standby groups.
Use the undo vrrp ipv6 ping-enable command to disable the virtual IPv6 addresses of standby groups from being pinged.
# Enable users to ping the virtual IPv6 addresses of standby groups.
[Sysname] vrrp ipv6 ping-enable
1.2.7  vrrp ipv6 vrid preempt-mode
vrrp ipv6 vrid virtual-router-id preempt-mode [ timer delay delay-value ]
undo vrrp ipv6 vrid virtual-router-id preempt-mode [ timer delay ]
View
Interface view
Use the vrrp ipv6 vrid preempt-mode command to configure preemption on the switch and configure its preemption delay in the specified standby group.
Use the undo vrrp ipv6 vrid preempt-mode command to disable preemption on the switch in the specified standby group.
Use the undo vrrp ipv6 vrid preempt-mode timer delay command to restore the default preemption delay, that is, zero seconds.
If you set the router in the standby group to work in non-preemption mode, the delay period changes to zero seconds automatically.
Note that before executing the command, you need to create a standby group on an interface and configure the virtual IPv6 address of the standby group.
# Enable preemption on the router in VRRP standby group 80 and set the preemption delay to five seconds.
[Sysname-Vlan-interface2] vrrp ipv6 vrid 80 virtual-ip fe80::2 link-local
[Sysname-Vlan-interface2] vrrp ipv6 vrid 80 preempt-mode timer delay 5
1.2.8  vrrp ipv6 vrid priority
vrrp ipv6 vrid virtual-router-id priority priority-value
undo vrrp ipv6 vrid virtual-router-id priority
View
Interface view
Use the vrrp ipv6 vrid priority command to configure the priority of the switch in the specified standby group.
Use the undo vrrp ipv6 vrid priority command to restore the default.
l           Before executing the command, create a standby group on an interface and configure the virtual IPv6 address of the standby group.
[Sysname-Vlan-interface2] vrrp ipv6 vrid 1 virtual-ip fe80::2 link-local
[Sysname-Vlan-interface2] vrrp ipv6 vrid 1 priority 150
1.2.9  vrrp ipv6 vrid timer advertise
vrrp ipv6 vrid virtual-router-id timer advertise adver-interval
undo vrrp ipv6 vrid virtual-router-id timer advertise
View
Interface view
adver-interval: Interval at which the master in the specified standby group sends VRRP advertisements. It ranges from 100 to 4095 centiseconds.
Use the vrrp ipv6 vrid timer advertise command to configure the Adver_Timer of the specified standby group.
Use the undo vrrp ipv6 vrid timer advertise command to restore the default.
By default the Adver_Timer is 100 centiseconds.
# Set the master in standby group 1 to send VRRP advertisements at intervals of 500 centiseconds.
[Sysname-Vlan-interface2] vrrp ipv6 vrid 1 timer advertise 500
1.2.10  vrrp ipv6 vrid track
vrrp ipv6 vrid virtual-router-id track interface interface-type interface-number [ reduced priority-reduced ]
undo vrrp ipv6 vrid virtual-router-id track [ interface interface-type interface-number ]
View
Interface view
Use the vrrp ipv6 vrid track command to configure to track the specified interface.
Use the undo vrrp ipv6 vrid track command to disable tracking the specified interface.
Note that:
[Sysname-Vlan-interface2] vrrp ipv6 vrid 1 track interface vlan-interface 1 reduced 50
1.2.11  vrrp ipv6 vrid virtual-ip
vrrp ipv6 vrid virtual-router-id virtual-ip virtual-address [link-local]
undo vrrp ipv6 vrid virtual-router-id [ virtual-ip virtual-address [ link-local ] ]
View
Interface view
virtual-address: Virtual IPv6 address.
link-local: Indicates that the virtual IPv6 address of the standby group is a link local address.
Use the vrrp ipv6 vrid virtual-ip link-local command to create a standby group and assign the first virtual IPv6 address to the specified standby group. The first virtual IPv6 address assigned to a standby group must be a link local address and only one such address is allowed in a standby group.
Use the vrrp ipv6 vrid virtual-ip command to add a virtual IPv6 address to a standby group.
Use the undo vrrp ipv6 vrid command to remove a standby group.
Use the undo vrrp ipv6 vrid virtual-router-id virtual-ip virtual-address [ link-local ] command to remove a virtual IPv6 address from a standby group.
After you remove all virtual IPv6 addresses, the standby group is automatically removed. Note that the first address assigned to the group must be removed the last.
# Create standby group 1, and configure its virtual IPv6 address as fe80::10.
[Sysname-Vlan-interface2] vrrp ipv6 vrid 1 virtual-ip fe80::10
# Configure the virtual IPv6 address of standby group 1 as 1::10.
[Sysname-Vlan-interface2] vrrp ipv6 vrid 1 virtual-ip 1::10
