- H3C S3610[S5510] Series Ethernet Switches Command Manual-Release 5301-(V1.03)
- 00-1Cover
- 01-Login Commands
- 02-VLAN Commands
- 03-IP Addressing and Performance Commands
- 04-QinQ-BPDU Tunneling Commands
- 05-Port Correlation Configuration Commands
- 06-Link Aggregation Commands
- 07-MAC Address Table Management Commands
- 08-IP Source Guard Commands
- 09-MSTP Commands
- 10-IPv6 Commands
- 11-Routing Overview Commands
- 12-IPv4 Routing Commands
- 13-BFD-GR Commands
- 14-IPv6 Routing Commands
- 15-Multicast Protocol Commands
- 16-802.1x-HABP-MAC Authentication Commands
- 17-AAA-RADIUS-HWTACACS Commands
- 18-ARP Commands
- 19-DHCP Commands
- 20-ACL Commands
- 21-QoS Commands
- 22-Port Mirroring Commands
- 23-Cluster Management Commands
- 24-UDP Helper Commands
- 25-SNMP-RMON Commands
- 26-NTP Commands
- 27-DNS Commands
- 28-File System Management Commands
- 29-Information Center Commands
- 30-System Maintaining and Debugging Commands
- 31-NQA Commands
- 32-VRRP Commands
- 33-SSH Commands
- 34-MCE Commands
- 35-OAM Commands
- 36-DLDP Commands
- 37-RRPP Commands
- 38-SSL-HTTPS Commands
- 39-PKI Commands
- 40-Appendix
| 07-MAC Address Table Management Commands | 40 KB |
Table of Contents
Chapter 1 MAC Address Table Management Configuration Commands
1.1 MAC Address Table Management Configuration Commands
1.1.2 display mac-address aging-time
1.1.3 mac-address (Ethernet port view)
1.1.4 mac-address (System view)
1.1.5 mac-address max-mac-count
1.1.1 display mac-address
display mac-address blackhole [ vlan vlan-id ] [ count ]
display mac-address [ mac-address [ vlan vlan-id ] | [ dynamic | static ] [ interface interface-type interface-number ] [ vlan vlan-id ] [ count ] ]
View
blackhole: Displays blackhole MAC address entries. These entries do not age but you can add or remove them. The packets whose destination MAC addresses match blackhole MAC address entries are dropped.
vlan vlan-id: Displays MAC address entries of the specified VLAN, which is in the range 1 to 4094.
count: Displays the total number of MAC addresses in the MAC address table.
mac-address: Displays MAC address entries in a specified MAC address, in the format of H-H-H.
dynamic: Displays dynamic MAC address entries. Aging time is set for these entries.
static: Displays static MAC address entries. Similar to blackhole MAC address entries, these entries do not age but you can add or remove them.
interface interface-type interface-number: Displays MAC address learning status of the specified interface. interface-type interface-number specifies an interface by its type and number.
Use the display mac-address command to display information about the MAC address table.
Related commands: mac-address (system view), mac-address (Ethernet interface view), mac-address timer.
# Display the MAC address table entry for MAC address 00e0-fc01-0101.
<Sysname> display mac-address 00e0-fc01-0101
MAC ADDR VLAN ID STATE PORT INDEX AGING TIME(s)
00e0-fc01-0101 1 Learned Ethernet1/0/1 AGING
Table 1-1 Description on the fields of the display mac-address command
MAC ADDR |
MAC address |
VLAN ID |
ID of the VLAN to which the MAC address belongs |
STATE |
State of a MAC address, which could be Config static, Dynamic, Learned and Blackhole |
PORT INDEX |
Port number (Displayed as N/A for a blackhole MAC address) |
AGING TIME(s) |
Aging time, which could be: l AGING, indicates that the entry is aging. l NOAGED, indicates that the entry does not age. |
View
None
Use the display mac-address aging-time command to display the aging time of dynamic entries in the MAC address table.
Related commands: mac-address (system view), mac-address (Ethernet interface view), mac-address timer, display mac-address.
# Display the aging time of dynamic entries in the MAC address table.
<Sysname> display mac-address aging-time
Mac address aging time: 300s
The above information indicates that the aging time of dynamic entries in the MAC address table is 300 seconds.
mac-address { dynamic | static } mac-address vlan vlan-id
undo mac-address { dynamic | static } mac-address vlan vlan-id
View
Ethernet port view
dynamic: Dynamic MAC address entries. Aging time is set for these entries.
static: Static MAC address entries. Similar to blackhole MAC address entries, these entries do not age but you can add or remove them.
mac-address: Specifies a MAC address in the format of H-H-H.
vlan vlan-id: Specifies the VLAN to which the Ethernet port belongs., where vlan-id is the specified VLAN ID, in the range 1 to 4094.
Use the mac-address command to add or modify a MAC address entry on the specified Ethernet port.
Use the undo mac-address command to remove a MAC address entry on the Ethernet port.
Note that:
l As your MAC address entries configuration cannot survive a reboot, save it after completing the configuration. The dynamic MAC address table entries however will be lost whether you save the configuration or not.
l You cannot configure a static or dynamic MAC address entry on an aggregation port.
Related commands: display mac-address.
# Add a static entry for MAC address 00e0-fc01-0101 on port Ethernet 1/0/1 which belongs to VLAN 2.
[Sysname-Ethernet1/0/1] mac-address static 00e0-fc01-0101 vlan 2
undo mac-address [ { dynamic | static } mac-address interface interface-type interface-number vlan vlan-id ]
undo mac-address [ blackhole | dynamic | static ] [ mac-address ] vlan vlan-id
undo mac-address [ dynamic | static ] mac-address interface interface-type interface-number vlan vlan-id
undo mac-address [ dynamic | static ] interface interface-type interface-number
View
blackhole: Blackhole MAC address entries. These entries do not age but you can add or remove them. The packets whose destination MAC addresses match blackhole MAC address entries are dropped.
interface interface-type interface-number: Outbound port, with interface-type interface-number representing the port type and number.
Use the mac-address command to add or modify a MAC address entry.
Use the undo mac-address [ { blackhole | dynamic | static } mac-address interface interface-type interface-number vlan vlan-id ] command to remove one or all MAC address entries.
Use the undo mac-address [ blackhole | dynamic | static ] [ mac-address ] vlan vlan-id command to remove a MAC address entry, MAC address entries of a specified type, or all MAC address entries for a VLAN.
Use the undo mac-address [ blackhole | dynamic | static ] interface interface-type interface-number command to remove a MAC address entry, MAC address entries of a specified type, or all MAC address entries for an Ethernet port.
Use the undo mac-address [ blackhole | dynamic | static ] [ mac-address ] interface interface-type interface-number vlan vlan-id command to remove a MAC address entry or all MAC address entries for an Ethernet port.
Note that you can change a dynamic entry to a static or blackhole entry but not vice versa.
As your MAC address entries configuration cannot survive a reboot, save it after completing the configuration. The dynamic entries however will be lost whether you save the configuration or not.
# Add a static entry for MAC address 00e0-fc01-0101. All frames destined to this MAC address are sent out of port Ethernet 1/0/1 which belongs to VLAN 2.
[Sysname] mac-address static 00e0-fc01-0101 interface ethernet 1/0/1 vlan 2
mac-address max-mac-count { count | disable-forwarding }
undo mac-address max-mac-count [ disable-forwarding ]
View
Ethernet port view, port group view
count: Maximum number of MAC addresses that can be learned on a port. When the argument takes 0, the VLAN is not allowed to learn MAC addresses. The value ranges from 0 to 16384.
disable-forwarding: Disables forwarding of frames with unknown destination MAC addresses after the number of learned MAC addresses reaches the upper limit.
Use the mac-address max-mac-count count command to configure the maximum number of MAC addresses that can be learned on an Ethernet port.
Use the mac-address max-mac-count disable-forwarding command to configure whether forwarding frames with unknown destination MAC addresses is allowed after the number of learned MAC addresses reaches the upper limit.
Use the undo mac-address max-mac-count command to restore the default maximum number of MAC addresses that can be learned on an Ethernet port.
Use the undo mac-address max-mac-count disable-forwarding command to allow forwarding frames received on an Ethernet port with unknown destination MAC addresses after the number of learned MAC addresses reaches the upper limit.
The default maximum number of MAC addresses that can be learned on a port is not configured.
Executed in Ethernet port view, the command takes effect on the current port only; executed in port group view, the command takes effect on all ports in the port group.
Related commands: mac-address, mac-address timer.
# Set the maximum number of MAC addresses that can be learned on port Ethernet 1/0/1 to 600. After this upper limit is reached, frames received with unknown destination MAC addresses on the port will not be forwarded.
[Sysname-Ethernet1/0/1] mac-address max-mac-count 600
[Sysname-Ethernet1/0/1] mac-address max-mac-count disable-forwarding
1.1.6 mac-address timer
undo mac-address timer aging
View
aging seconds: Sets an aging timer in seconds for dynamic MAC address entries, in the range 10 to 630.
no-aging: Sets dynamic MAC address entries not to age.
Use the mac-address timer command to configure the aging timer for dynamic MAC address entries.
Use the undo mac-address timer command to restore the default.
By default the aging timer is 300 seconds.
Set the aging timer appropriately: a long aging interval may cause the MAC address table to retain outdated entries and fail to accommodate latest network changes; a short interval may result in removal of valid entries and hence unnecessary broadcasts which may affect device performance.
# Set the aging timer for dynamic MAC address entries to 500 seconds.
