- H3C S3610[S5510] Series Ethernet Switches Command Manual-Release 5301-(V1.03)
- 00-1Cover
- 01-Login Commands
- 02-VLAN Commands
- 03-IP Addressing and Performance Commands
- 04-QinQ-BPDU Tunneling Commands
- 05-Port Correlation Configuration Commands
- 06-Link Aggregation Commands
- 07-MAC Address Table Management Commands
- 08-IP Source Guard Commands
- 09-MSTP Commands
- 10-IPv6 Commands
- 11-Routing Overview Commands
- 12-IPv4 Routing Commands
- 13-BFD-GR Commands
- 14-IPv6 Routing Commands
- 15-Multicast Protocol Commands
- 16-802.1x-HABP-MAC Authentication Commands
- 17-AAA-RADIUS-HWTACACS Commands
- 18-ARP Commands
- 19-DHCP Commands
- 20-ACL Commands
- 21-QoS Commands
- 22-Port Mirroring Commands
- 23-Cluster Management Commands
- 24-UDP Helper Commands
- 25-SNMP-RMON Commands
- 26-NTP Commands
- 27-DNS Commands
- 28-File System Management Commands
- 29-Information Center Commands
- 30-System Maintaining and Debugging Commands
- 31-NQA Commands
- 32-VRRP Commands
- 33-SSH Commands
- 34-MCE Commands
- 35-OAM Commands
- 36-DLDP Commands
- 37-RRPP Commands
- 38-SSL-HTTPS Commands
- 39-PKI Commands
- 40-Appendix
| 13-BFD-GR Commands | 53 KB |
Table of Contents
Chapter 1 BFD Configuration Commands
1.1 BFD Configuration Commands
1.1.4 bfd min-echo-receive-interval
1.1.5 bfd min-receive-interval
1.1.6 bfd min-transmit-interval
1.1.11 reset bfd session statistics
1.1.12 snmp-agent trap enable bfd
1.1.1 bfd authentication-mode
bfd authentication-mode{md5 key-id key | sha1 key-id key | simple key-id password }
undo bfd authentication-mode
View
Interface view
md5: Uses message digest 5 (MD5) authentications.
sha1: Uses secure hash algorithm (SHA-1) authentication.
simple: Uses plaint text authentication.
key-id: Authentication key ID, in the range 1 to 255.
key: A string of 1 to 16 characters. It is displayed as a 24-byte cipher text string when the display current-configuration command is executed.
password: Password, a string of 1 to 16 characters when the simple keyword is used. It is displayed when the display current-configuration command is executed.
Use the bfd authentication-mode command to configure the BFD authentication mode and key on the interface.
Use the undo bfd authentication-mode command to remove the authentication mode on the interface (only one authentication mode can be configured on an interface).
By default, no authentication is configured on an interface.
& Note:
The authentication mode, key-id, key (or password) used by both ends trying to establish a BFD session must be the same. If one end changes its authentication mode, it sends the authentication packets in both the new and the old mode at the same time until the other end also changes to the same authentication mode.
# Configure VLAN-interface 1 to support MD5 authentication, setting the authentication key-id to 15 and authentication key to BfdKey.
[Sysname-Vlan-interface 1] bfd authentication-mode md5 15 BfdKey
1.1.2 bfd detect-multiplier
bfd detect-multiplier value
undo bfd detect-multiplier
View
Interface view
value: Maximum number of consecutive BFD control packets that the remote device fails to receive from the local device interface before considering the BFD session down, in the range of 3 to 50.
Use the bfd detect-multiplier command to configure the maximum number of consecutive BFD control packets that the remote device fails to receive from the local device before considering the BFD session down.
Use the undo bfd detect-multiplier command to restore the default.
The default is 5.
# Configure the detect multiplier as 6 on VLAN-interface 1.
[Sysname-Vlan-interface 1] bfd detect-multiplier 6
1.1.3 bfd echo-source-ip
bfd echo-source-ip ip-address
undo bfd echo-source-ip
View
ip-address: Source IP address of BFD echo packets.
Use the bfd echo-source-ip command to configure the source IP address of BFD echo packets.
Use the undo bfd echo-source-ip command to remove the configured source IP address of BFD echo packets.
Note that, since a large amount of ICMP redirect packets may be sent by the remote device, causing network congestion, do not configure the source IP address of the BFD echo packets to belong to the same network segment as any interface address of the device.
# Configure the source IP address of BFD echo packets as 10.1.1.1.
[Sysname] bfd echo-source-ip 10.1.1.1
bfd min-echo-receive-interval value
undo bfd min-echo-receive-interval
View
Interface view
value: Minimum BFD echo receiving interval, in milliseconds. This value is in the range of 200 to 1000 and defaults to 400.
Use the bfd min-echo-receive-interval command to configure the minimum BFD echo packet receiving interval on the interface.
Use the undo bfd min-echo-receive-interval command to restore the default.
The default value is 400 milliseconds.
# Configure the minimum BFD echo receiving interval on VLAN-interface 1 as 300 milliseconds.
[Sysname-Vlan-interface 1] bfd min-echo-receive-interval 300
bfd min-receive-interval value
undo bfd min-receive-interval
View
Interface view
value: Minimum interval for receiving BFD control packets, in milliseconds. It is a multiple of 100 milliseconds. It is in the range of 200 ms to 1000 ms and defaults to 400 ms.
Use the bfd min-receive-interval command to configure the minimum interval for receiving BFD control packets.
If the remote device sends BFD control packets at an interval smaller than the minimum receiving interval of the local device, the remote device changes its sending interval to the minimum receiving interval of the local device.
Use the undo bfd min-receive-interval command to restore the default.
By default, the minimum interval for receiving BFD control packets is 400 milliseconds.
# Configure the minimum interval for receiving BFD control packets on VLAN-interface 1 as 300 milliseconds.
[Sysname-Vlan-interface 1] bfd min-receive-interval 300
bfd min-transmit-interval value
undo bfd min-transmit-interval
View
Interface view
value: Minimum interval for transmitting BFD control packets, in milliseconds. It is a multiple of 100. It is in the range of 200 to 1000 and defaults to 400.
Use the bfd min-transmit-interval command to configure the minimum interval for transmitting BFD control packets.
The minimum interval for transmitting BFD control packets through an interface ensures BFD control packets are not transmitted faster than the device can deal with. The actual interval for transmitting BFD control packets at the local device should be the greater between the minimum interval for sending BFD control packets configured on the local interface and the minimum interval for receiving BFD control packets on the remote device.
Use the undo bfd min-transmit-interval command to restore the default.
By default, the minimum BFD transmit interval is 400 milliseconds.
# Configure the minimum interval for transmitting BFD control packets on VLAN-interface 1 as 300 milliseconds.
[Sysname-Vlan-interface 1] bfd min-transmit-interval 300
1.1.7 bfd session init-mode
bfd session init-mode{ active | passive }
undo bfd session init-mode
View
active: Uses the active mode. In the active mode, upon being enabled with BFD, an interface actively transmits a BFD control packet to the remote device.
passive: Uses the passive mode. In the passive mode, an interface does not actively transmit a BFD control packet to the remote end; it transmits a BFD control packet only after receiving a BFD control packet from the remote end.
Use the bfd session init-mode command to configure the mode for establishing a BFD session.
Use the undo bfd session init-mode command to restore the default. By default, BFD sessions are established in the active mode.
# Configure the session establishment mode as passive.
[Sysname] bfd session init-mode passive
1.1.8 display bfd interface
display bfd interface [ verbose ]
View
verbose: Displays detailed interface information.
Use the display bfd interface command to display information about BFD-enabled interfaces.
Besides the information displayed by the display bfd interface command, the display bfd interface verbose command displays brief session information of the interfaces.
# Display information about BFD-enabled interfaces.
<Sysname> display bfd interface
Total Interface Num: 1
Interface: Vlan-interface1 Session Num: 1
Min Trans Inter: 400ms Min Recv Inter: 400ms
DetectMult: 5 Min Echo Recv Inter: 400ms
Auth mode: Simple
# Display detailed information about BFD-enabled interfaces.
<Sysname> display bfd interface verbose
Auth mode: Simple
LD/RD SourceAddr DestAddr ConnType State Mode
1 192.168.0.136 192.168.0.138 Direct Up Echo
Table 1-1 Description on the fields of the display bfd interface command
Interface name |
Session Num |
Number of sessions established on the local interface |
Min Trans Inter |
Expected minimum transmit interval configured on the interface |
Min Recv Inter |
Expected minimum receive interval configured on the interface |
DetectMult |
Session detection multiplier |
Min Echo Recv Inter |
Minimum interval for receiving echo packets |
Auth mode |
Session authentication mode: simple, MD5, or SHA-1 |
LD |
Local ID of the session |
RD |
Remote ID of the session |
SourceAddr |
Source IP address of the session |
DestAddr |
Destination IP address of the session |
ConnType |
Connection type of the interface |
State |
Session state |
Mode |
Mode |
1.1.9 display bfd paf
display bfd paf
View
None
Use the display bfd paf command to display PAF configuration information.
# Display BFD PAF configuration information.
<Sysname> display bfd paf
BFD PAF Information:
Control Packet Min-Transmit-Interval(ms): 200
Control Packet Min-Receive-Interval(ms) : 200
Echo Packet Min-Receive-Interval(ms) : 200
Max Session Number : 10
Table 1-2 Description on the fields of the display bfd paf command
Control Packet Min-Transmit-Interval(ms) |
Minimum interval for transmitting control packets |
Control Packet Min-Receive-Interval(ms) |
Minimum interval for receiving control packets |
Echo Packet Min-Receive-Interval(ms) |
Max Session Number |
Supported maximum number of sessions |
1.1.10 display bfd session
display bfd session [ verbose ]
View
verbose: Displays detailed session information.
slot slot-id: Displays the session information of the specified board/slot.
Use the display bfd session command to display BFD session information. This command displays the following interface-related information: session local ID, session remote ID, source address, destination address, session state, length of time before session detection timer expires, and the name of the interface of the session.
Besides the information displayed by the display bfd session command (except the length of time before session detection timer expires), the display bfd session verbose command displays:
Minimum transmit interval, minimum receive interval, actual transmit interval, actual session detection timer, packets sent and received by the session, time when the session was established, last time when the session was down, last time when the session was up, authentication mode, connection type, registered protocol, and diagnostic information.
# Display information about all the BFD sessions.
<Sysname> display bfd session
Total Session Num: 1 Init Mode: Active
Session Working Under Echo Mode:
LD SourceAddr DestAddr State Holdtime Interface
1 192.168.0.136 192.168.0.138 Up 1700ms Vlan1
# Display detailed information about the sessions maintained by the device.
<Sysname> display bfd session verbose
Local Discr: 1
Source IP: 192.168.0.136 Destination IP: 192.168.0.138
Session State: Up Interface: Vlan-interface1
Min Recv Inter: 400ms Act Trans Inter: 400ms
Act Detect Inter: 2000ms Hold Time: 1700ms
Recv Pkt Num: 1809 Send Pkt Num: 1809
Connect Type: Direct Establish Time: 05:28:42
Last Down Time: 05:28:42 Last Up Time: 05:38:15
Protocol: STATIC
Diag Info: No Diagnostic
Table 1-3 Description on the fields of the display bfd session command
LD/ Local Discr |
SourceAddr/ Source IP |
DestAddr/ Destination IP |
State/Session State |
Session state |
Holdtime/ Hold Time |
Length of time before session detection timer expires |
Name of the interface of the session |
Min Recv Inter |
Act Trans Inter |
Actual transmit interval |
Act Detect Inter |
Actual session detection timer |
Recv Pkt Num |
Number of packets received |
Send Pkt Num |
Number of packets sent |
Connect Type |
Establish Time |
Time when the session was established |
Last Down Time |
Time when the session last became down |
Last Up Time |
Time when the session was last brought up |
Protocol |
Registered protocol |
Diag Info |
Diagnostic information about the session |
View
None
Use the reset bfd session statistics command to clear the BFD session statistics of the current protocol.
# Clear statistics about all the BFD sessions of the current protocol.
<Sysname> reset bfd session statistics
undo snmp-agent trap enable bfd
None
View
Use the snmp-agent trap enable bfd command to enable sending BFD traps.
Use the undo snmp-agent trap enable bfd command to disable sending BFD traps.
By default, sending BFD traps is enabled.
Currently, the switches do not support this command.
Chapter 2 GR Commands
2.1 GR Commands
This part involves no specific commands. For GR-related commands, refer to BGP Configuration Commands, OSPF Configuration Commands, and IS-IS Configuration Commands in IPv4 Routing.
