H3C S3610[S5510] Series Ethernet Switches Command Manual-Release 5301-(V1.03)
HomeSupportSwitchesH3C S3610[S5510] Switch SeriesReference GuidesCommand ReferencesH3C S3610[S5510] Series Ethernet Switches Command Manual-Release 5301-(V1.03)
06-Link Aggregation Commands
06-Link Aggregation Commands 56 KB
Chapter 1  Link Aggregation Configuration Commands
1.1  Link Aggregation Configuration Commands
1.1.1  display lacp system-id
View
None
Use the display lacp system-id command to display the local system ID (also called the actor system ID), which comprises the system LACP priority and the system MAC address.
# Display the local system ID.
<Sysname> display lacp system-id
 Actor System ID: 0x8000, 0000-fc00-0100
1.1.2  display link-aggregation interface
display link-aggregation interface interface-type interface-number [ to interface-type interface-number ]
View
interface interface-type interface-number [ to interface-type interface-number ]: Specifies a port range or a port if the to keyword and the second port are not specified.
Use the display link-aggregation interface command to display detailed information about link aggregation for the specified port or ports.
You may find that information about the remote system is replaced by 0 and no statistics about LACPDUs are provided for manual link aggregation groups. This is normal because this type of aggregation group has no knowledge of its partner and does not use LACP PDUs for maintaining link aggregation.
# Display detailed information about link aggregation for port Ethernet 1/0/1 in a manual aggregation group.
<Sysname> display link-aggregation interface ethernet 1/0/1
Flags:  A -- LACP_Activity, B -- LACP_timeout, C -- Aggregation,
         G -- Defaulted, H -- Expired
 Ethernet1/0/1:
   Selected AggID: 1
   Local:
     Port-Priority: 32768, Oper key: 1, Flag: {}
   Remote:
     System ID: 0x0, 0000-0000-0000
     Port Number: 0, Port-Priority: 0, Oper-key: 0, Flag: {}
# Display detailed information about link aggregation for port Ethernet 1/0/2 in a static aggregation group.
<Sysname> display link-aggregation interface ethernet 1/0/2
Ethernet1/0/2:
   Selected AggID: 20
   Local:
     Port-Priority: 32768, Oper key: 2, Flag: {ACDEF}
   Remote:
     System ID: 0x8000, 000e-84a6-fb00
     Port Number: 2, Port-Priority: 32768 , Oper-key: 10, Flag: {ACDEF}
   Received LACP Packets: 8 packet(s), Illegal: 0 packet(s)
   Sent LACP Packets: 9 packet(s)
Table 1-1 Description on the fields of the display link-aggregation interface command
Flags
One-octet LACP state flags field. From the least to the most significant bit, they are represented by A through H as follows:
l      A indicates whether LACP is enabled, 1 for enabled and 0 for disabled.
l      B indicates the timeout control value, 1 for short timeout, and 0 for long timeout.
l      C indicates whether the sending system considers this link to be aggregatable, 1 for true, and 0 for false.
l      D indicates whether the sending system considers that this link is synchronized, 1 for true, and 0 for false.
l      E indicates whether the sending end considers that collection of incoming frames is enabled on the link, 1 for true and 0 for false.
l      F indicates whether the sending system considers that distribution of outgoing frames is enabled on the link, 1 for true and 0 for false.
l      G indicates whether the receive state machine of the sending system is using default operational partner information, 1 for true and 0 for false.
l      H indicates whether the receive state machine of the sending system is in the expired state, 1 for true and 0 for false.
If a flag bit is set to 1, the corresponding English letter that otherwise is not output displays.
Selected AggID
ID of the link aggregation group of which this port is a member
Local:
Port-Priority, Oper key, Flag
Local port LACP priority, operational key, LACP state flag
Remote:
System ID, Port Number, Port-Priority, Oper-key, Flag
Remote system ID, port number, port LACP priority, operational key, and LACP state flag
Received LACP Packets, Illegal, Sent LACP Packets
Statistics about received, invalid, and sent LACP packets
1.1.3  display link-aggregation service-type
display link-aggregation service-type [ agg-id ]
View
agg-id: ID of an existing service loop group.
Use the display link-aggregation service-type command to display information about the specified service loop groups.
If no aggregation group is specified, information about all service loop groups is displayed.
# Display information about service loop group 1.
<Sysname> display link-aggregation service-type 1
 Service-Loop         Service                    Quote
   Group ID            Type                      Number
     1                tunnel                          0
Table 1-2 Description on the fields of the display link-aggregation service-type command
Service-Loop Group ID
Service loop group ID
Service Type
Service type supported by the group
Quote Number
Reference count for the service loop group. Only after it decreases to zero can you remove the group.
1.1.4  display link-aggregation summary
View
None
Use the display link-aggregation summary command to display a summary for all link aggregation groups.
You may find that information about the remote system for a manual link aggregation group is either replaced by none or not displayed at all. This is normal because this type of aggregation group has no knowledge of its partner.
# Display the link aggregation group summary.
<Sysname> display link-aggregation summary
Aggregation Group Type:S -- Static , M -- Manual
Actor ID: 0x8000, 000f-e200-2200
  AL  AL   Partner ID            Select Unselect Share Master
  ID  Type                       Ports  Ports    Type  Port
  1   M    none                  1      0        Shar  Ethernet1/0/2
Table 1-3 Description on the fields of the display link-aggregation summary command
Aggregation group type.
l      S: static LACP aggregation
l      M: manual aggregation
Loadsharing Type
Load sharing type
Actor ID
Local system ID
AL ID
Link aggregation group ID
AL Type
Link aggregation type
Partner ID
Remote system ID
Select Ports
Number of selected ports
Unselect Ports
Number of unselected ports
Share Type
Load sharing type
Master Port
Master port
1.1.5  display link-aggregation verbose
display link-aggregation verbose [ agg-id ]
View
agg-id: ID of an existing link aggregation group.
Use the display link-aggregation verbose command to display detailed information about the specified or all link aggregation groups.
# Display detailed information about all the link aggregation groups.
<Sysname> display link-aggregation verbose
Aggregation ID: 1,  AggregationType: Manual,   Loadsharing Type: Shar
Aggregation Description:
System ID: 0x8000, 000f-e200-2200
Port Status: S -- Selected,  U -- Unselected
Local:
  Port             Status  Priority  Oper-Key  Flag
  Eth1/0/2        S       32768     1         {}
Remote:
  Actor            Partner Priority  Oper-Key  SystemID               Flag
  Eth1/0/2        0       0         0         0x0000,0000-0000-0000  {}
Table 1-4 Description on the fields of the display link-aggregation verbose command
Loadsharing Type
Load sharing type, either shar for load sharing or NonS for non-load sharing
Flags
One-octet LACP flags field indicates the actor state variables for the port. From the least to the most significant bit, they are represented by A through H as follows:
l      A indicates the enabling/disabling state of LACP, 1 for enabled and 0 for disabled
l      E indicates whether the sending system considers that collection of incoming frames is enabled on the link, 1 for true and 0 for false
Aggregation ID
AggregationType
Link aggregation type: manual or static LACP.
Link aggregation group name
System ID
Local system ID
Port Status
Port state in a link aggregation group: selected or unselected
Local:
Port, Status, Priority, Oper-key, Flag
Other information about the local end, including member ports, port state, port LACP priority, operational key, and flags
Remote:
Actor, Partner, Priority, Oper-key, SystemID, Flag
Detailed information about the remote end, including corresponding local port, port ID, port LACP priority, operational key, system ID, and flags
1.1.6  lacp port-priority
lacp port-priority port-priority
undo lacp port-priority
View
Ethernet port view
port-priority: Port LACP priority, in the range 0 to 65535.
Use the lacp port-priority command to assign an LACP priority to the port.
Use the undo lacp port-priority command to restore the default.
By default, port LACP priority is 32768.
# Assign LACP priority 64 to a port.
[Sysname-Ethernet1/0/1] lacp port-priority 64
1.1.7  lacp system-priority
lacp system-priority system-priority
undo lacp system-priority
View
system-priority: System LACP priority, in the range 0 to 65535.
Use the lacp system-priority command to assign an LACP priority to the local system.
Use the undo lacp system-priority command to restore the default.
By default, system LACP priority is 32768.
# Assign LACP priority 64 to the local system.
[Sysname] lacp system-priority 64
1.1.8  link-aggregation group description
link-aggregation group agg-id description agg-name
undo link-aggregation group agg-id description
View
agg-id: Link aggregation group ID.
agg-name: Link aggregation group name, a string of 1 to 32 characters.
Use the link-aggregation group description command to configure a name for the specified link aggregation group.
Use the undo link-aggregation group description command to remove the name of the specified link aggregation group.
Related commands: display link-aggregation verbose.
# Name link aggregation group 22 as abc.
[Sysname] link-aggregation group 22 description abc
1.1.9  link-aggregation group mode
link-aggregation group agg-id mode { manual | static }
View
manual: Creates a manual link aggregation group.
static: Creates a static LACP link aggregation group.
Use the link-aggregation group mode command to create a link aggregation group.
Use the undo link-aggregation group command to remove a link aggregation group. If the group is functioning as a service loop group, this can result in the removal of the service loop group.
An aggregation group currently being referenced by other modules cannot be removed.
Related commands: display link-aggregation summary.
# Create manual link aggregation group 22.
[Sysname] link-aggregation group 22 mode manual
1.1.10  link-aggregation group service-type
link-aggregation group agg-id service-type tunnel
undo link-aggregation group agg-id service-type
View
tunnel: Sets the service type to tunnel.
Use the link-aggregation group service-type command to configure a manual aggregation group as a service loop group that is of specific type.
Use the undo link-aggregation group service-type command to change a service loop group back to a common manual aggregation group.
&  Note:
You can remove an existing service loop group using the undo link-aggregation group command. However, service loop groups currently referenced by modules cannot be removed.
# Configure link aggregation group 5 as a tunnel service loop group.
[Sysname] link-aggregation group 5 service-type tunnel
1.1.11  port link-aggregation group
port link-aggregation group agg-id
undo port link-aggregation group
View
Ethernet port view
Use the port link-aggregation group command to add the Ethernet port to the specified link aggregation group (manual or static LACP) or service loop group.
Use the undo port link-aggregation group command to remove the Ethernet port from the specified aggregation group or service loop group.
# Add port Ethernet 1/0/1 to link aggregation group 22.
[Sysname-Ethernet1/0/1] port link-aggregation group 22
1.1.12  port-group aggregation
port-group aggregation agg-id
View
agg-id: Aggregation port group ID, same as the ID of its corresponding link aggregation group.
Use the port-group aggregation command to enter aggregation port group view.
Instead of being created administratively, an aggregation port group is created automatically upon creation of a link aggregation group and assigned the ID of the link aggregation group. In aggregation port group view, you can configure aggregation related settings such as STP, VLAN, QoS, GVRP, Q-in-Q, BPDU tunnel, and MAC address learning, but cannot add or remove member ports.
# Enter aggregation port group view.
[Sysname] port-group aggregation 10
[Sysname-port-group-aggregation-10]
1.1.13  reset lacp statistics
reset lacp statistics [ interface interface-type interface-number [ to interface-type interface-number ] ]
View
interface interface-type interface-number [ to interface-type interface-number ]: Specifies an interface range or an interface if the to keyword and the second interface are not specified.
Use the reset lacp statistics command to clear statistics about LACP on a specified port or ports.
Related commands: display link-aggregation interface.
# Clear statistics about LACP on all ports.
<Sysname> reset lacp statistics
