H3C S3610[S5510] Series Ethernet Switches Command Manual-Release 5301-(V1.03)
HomeSupportSwitchesH3C S3610[S5510] Switch SeriesReference GuidesCommand ReferencesH3C S3610[S5510] Series Ethernet Switches Command Manual-Release 5301-(V1.03)
00-1Cover
00-1Cover 69 KB
H3C S3610&S5510 Series Ethernet Switches
Command Manual
Hangzhou H3C Technologies Co., Ltd.
http://www.h3c.com
Manual Version: T2-08192P-20070813-C-1.03
Product Version: Release 5301
Copyright © 2006-2007, Hangzhou H3C Technologies Co., Ltd. and its licensors
All Rights Reserved
No part of this manual may be reproduced or transmitted in any form or by any means without prior written consent of Hangzhou H3C Technologies Co., Ltd.
Trademarks
H3C, Adobe Systems, Aolynk, , H3Care, , TOP G, , IRF, NetPilot, Neocean, NeoVTL, SecPro, SecPoint, SecEngine, SecPath, Comware, Secware, Storware, NQA, VVG, V2G, VnG, PSPT, XGbus, N-Bus, TiGem, InnoVision and HUASAN are trademarks of Hangzhou H3C Technologies Co., Ltd.
All other trademarks that may be mentioned in this manual are the property of their respective owners.
Notice
The information in this document is subject to change without notice. Every effort has been made in the preparation of this document to ensure accuracy of the contents, but all statements, information, and recommendations in this document do not constitute the warranty of any kind, express or implied.
To obtain the latest information, please access:
http://www. h3c.com
Technical Support
[email protected]
http://www. h3c.com
About This Manual
Related Documentation
In addition to this manual, each H3C S3610&S5510 Series Ethernet Switches documentation set includes the following:
Manual
H3C S3610&S5510 Series Ethernet Switches  Operation Manual-Release 5301
It is used for assisting the users in data configurations and typical applications.
H3C S3610 Series Ethernet Switches  Installation Manual
It provides information for the system installation.
H3C S5510 Series Ethernet Switches  Installation Manual
Organization
H3C S3610&S5510 Series Ethernet Switches Command Manual Release 5301 is organized as follows:
Part
1 Login
Introduces the commands used for logging into the Ethernet switch.
2 VLAN
Introduces the commands used for configuring VLAN, Voice VLAN, and GVRP.
3 IP Addressing and Performance
Introduces the commands used for configuring IP address and IP performance
4 QinQ-BPDU Tunneling
Introduces the commands used for configuring QinQ and BPDU Tunneling.
5 Port Correlation Configuration
Introduces the commands used for configuring basic port configuration and port isolation.
6 Link Aggregation
Introduces the commands used for configuring manual link aggregation static LACP link aggregation.
7 MAC Address Table Management
Introduces the commands used for configuring MAC address forwarding table.
8 IP Source Guard
Introduces the commands used for configuring IP Source Guard.
9 MSTP
Introduces the commands used for configuring STP and BRDU tunnel.
10 IPv6
Introduces the commands used for configuring IPv6 application, IPv6 tunneling, and so on.
11 Routing Overview
Introduces the commands used for display and debugging IPv4/IPv6 routing protocols.
12 IPv4 Routing
Introduces the commands used for configuring IPv4 routing, static routing, RIP, OSPF, IS-IS, BGP, and route policy.
13 BFD-GR
Introduces the commands used for configuring BFD and GR.
14 IPv6 Routing
Introduces the commands used for configuring IPv6 routing, static routing, RIPng, OSPFv3, IPv6 IS-IS, and IPv6 BGP.
15 Multicast Protocol
Introduces the commands used for configuring  IGMP Snooping, MLD Snooping, multicast VLAN, IGMP, PIM-DM, PIM-SM, and MSDP.
16 802.1x-HABP-MAC Authentication
Introduces the commands used for 802.1x, HABP and MAC address authentication related configurations.
17 AAA-RADIUS-HWTACACS
Introduces the commands used for AAA, RADIUS, HWTACACS, and the related configurations.
18 ARP
Introduces the commands used for ARP and the related configuration.
19 DHCP
Introduces the commands used for DHCP and the related configuration.
20 ACL
Introduces the commands used for IPv4&IPv6-based ACL and the related configuration.
21 QoS
Introduces the commands used for QoS and the related configuration.
22 Port Mirroring
Introduces the commands used for port mirroring and the related configuration.
23 Cluster Management
Introduces the commands used for cluster and the related configuration.
24 UDP Helper
Introduces the commands used for UDP Helper and the related configuration.
25 SNMP-RMON
Introduces the commands used for the configuration to manage network devices through SNMP and RMON.
26 NTP
Introduces the commands used for NTP and the related configuration.
27 DNS
Introduces the commands used for DNS and the related configuration.
28 File System Management
Introduces the commands used for file system management.
29 Information Center
Introduces the commands used for the configuration to analyze and diagnose networks using the information center.
30 System Maintaining and Debugging
Introduces the commands used for daily system maintenance and debugging.
31 NQA
Introduces the commands used for NQA and the related configuration.
32 VRRP
Introduces the commands used for VRRP and the related configuration.
33 SSH
Introduces the commands used for SSH and the related configurations.
34 MCE
Introduces the commands used for MCE and the related configurations.
35 OAM
Introduces the commands used for OAM and the related configurations.
36 DLDP
Introduces the commands used for DLDP and the related configurations.
37 RRPP
Introduces the commands used for RRPP and the related configurations.
38 SSL-HTTPS
Introduces the commands used for SSL and HTTPS configurations.
39 PKI
Introduces the commands used for PKI and the related configurations.
40 Appendix
Lists all the commands described in this command manual in an alphabetic order. The parts and pages where the commands are described are also given.
Conventions
The manual uses the following conventions:
I. Command conventions
Convention
Boldface
The keywords of a command line are in Boldface.
italic
Command arguments are in italic.
Items (keywords or arguments) in square brackets [ ] are optional.
{ x | y | ... }
Alternative items are grouped in braces and separated by vertical bars. One is selected.
[ x | y | ... ]
Optional alternative items are grouped in square brackets and separated by vertical bars. One or none is selected.
{ x | y | ... } *
Alternative items are grouped in braces and separated by vertical bars. A minimum of one or a maximum of all can be selected.
[ x | y | ... ] *
Optional alternative items are grouped in square brackets and separated by vertical bars. Many or none can be selected.
&<1-n>
The argument(s) before the ampersand (&) sign can be entered 1 to n times.
A line starting with the # sign is comments.
II. GUI conventions
Convention
Button names are inside angle brackets. For example, click <OK>.
Window names, menu items, data table and field names are inside square brackets. For example, pop up the [New User] window.
Multi-level menus are separated by forward slashes. For example, [File/Create/Folder].
III. Symbols
Convention
  Warning
Means reader be extremely careful. Improper operation may cause bodily injury.
  Caution
Means reader be careful. Improper operation may cause data loss or damage to equipment.
&  Note
Means a complementary description.
