H3C S5500-SI Series Ethernet Switches Command Manual(V1.01)
HomeSupportSwitchesH3C S5500 Switch SeriesReference GuidesCommand ReferencesH3C S5500-SI Series Ethernet Switches Command Manual(V1.01)
Manual Version
20071208-C-1.01
Product Version
This manual is for S5500 series Ethernet switches that are of two software versions and thus only applies to the two software versions. To avoid confusion caused by software version, make sure this manual matches the software version of your product.
This manual applies to the following products:
S5500-SI series Ethernet switches, Release1207
S5500-20TP-SI Ethernet switches, Release1301
Organization
H3C S5500-SI Series Ethernet Switches Command Manual is organized as follows:
Part
1 Login
Introduces the commands used for logging into an Ethernet switch.
2 VLAN
Introduces the commands used for configuring VLAN.
3 IP Address and IP Performance
Introduces the commands used for configuring IP address and IP performance.
4 QinQ-BPDU TUNNEL
Introduces the commands used for configuring QinQ.
5 Port Correlation
Introduces the commands used for configuring link aggregation and port isolation.
6 Link Aggregation
Introduces the commands used for link aggregation.
7 MAC Address Table Management
Introduces the commands used for configuring MAC address forwarding table.
8 Port Security
Introduces the commands used for port security.
9 MSTP
Introduces the commands used for configuring MSTP.
10 IPv6
Introduces the commands used for configuring IPv6 application.
11 IP Routing Overview
Introduces the commands of Routing Overview.
12 IPv4 Routing
Introduces the commands used for configuring IPv4 routing, static routing, RIP, and route policy.
13 IPv6 Routing
Introduces IPv6 routing related configurations, such as static routing, RIPng, and route policy.
Introduces the commands used for configuring IPv6 routing, static routing, RIPng, and route policy.
14 Multicast
Introduces the commands used for configuring IGMP Snooping.
15 802.1x-HABP-MAC Authentication
Introduces the commands used for 802.1x, HABP and MAC related configurations.
16 AAA-RADIUS-HWTACACS
Introduces the commands used for AAA, RADIUS, HWTACACS, and the related configurations.
17 ARP
Introduces the commands used for configuring ARP.
18 DHCP
Introduces the commands used for DHCP and the related configuration.
19 ACL
Introduces the commands used for configuring ACL.
20 QoS
Introduces the commands used for configuring QoS.
21 Port Mirroring
Introduces the commands used for configuring port mirroring.
22 UDP Helper
Introduces the commands used for UDP Helper and the related configuration.
23 Cluster Management
Introduces the commands used for configuring cluster.
24 SNMP-RMON
Introduces the commands used for the configuration to manage network devices through SNMP and RMON.
25 NTP
Introduces the commands used for configuring NTP.
26 DNS
Introduces the commands used for configuring DNS.
27 File System Management
Introduces the commands used for file system management.
28 Information Center
Introduces the commands used for the configuration to analyze and diagnose networks using the information center.
29 System Maintaining and Debugging
Introduces the commands used for daily system maintenance and debugging.
30 NQA
Introduces the commands used for configuring NQA.
31 SSH
Introduces the commands used for configuring SSH2.0.
32 Track
Introduces the commands used for configuring Track.
33 PoE
Introduces the commands used for configuring PoE and PoE profile.
34 SSL-HTTPS
Introduces the commands used for configuring SSL and HTTPS.
35 PKI
Introduces the commands used for configuring PKI.
36 Stack Management
Introduces the commands used for configuring Stack Management.
37 Command Index
Lists all the commands in this command manual, which are arranged alphabetically.
