H3C S5500-SI Series Ethernet Switches Operation Manual(V1.01)
HomeSupportSwitchesH3C S5500 Switch SeriesConfigure & DeployConfiguration GuidesH3C S5500-SI Series Ethernet Switches Operation Manual(V1.01)
Manual Version
20071208-C-1.01
Product Version
This manual is for S5500 series Ethernet switches that are of two software versions and thus only applies to the two software versions. To avoid confusion caused by software version, make sure this manual matches the software version of your product.
This manual applies to the following products:
S5500-SI series Ethernet switches, Release1207
S5500-20TP-SI Ethernet switches, Release1301
Organization
H3C S5500-SI Series Ethernet Switches Operation Manual is organized as follows:
Part
0 Overview
Introduces the system features, service features, and network application of the switches.
1 Login
Introduces the ways to log into an Ethernet switch.
2 VLAN
Introduces VLAN basics and the related configuration.
3 IP Addressing and IP Performance
Introduces IP address and IP performance fundamental and the related configuration.
4 QinQ-BPDU TUNNEL
Introduces QinQ and the related configuration
5 Port Correlation Configuration
Introduces basic port configuration, link aggregation, and port isolation configuration.
6 Link Aggregation
Introduces link aggregation fundamental and the related configuration.
7 MAC Address Table Management
Introduces MAC address forwarding table and the related configuration.
8 Port Security
Introduces port security and the related configuration.
9 MSTP
Introduces STP and the related configurations.
10 IPv6
Introduces IPv6 basic configuration and application.
11 IP Routing Overview
Introduces the overview of Routing.
12 IPv4 Routing
Introduces IPv4 routing related configurations, such as static routing, RIP, and route policy.
13 IPv6 Routing
Introduces IPv6 routing related configurations, such as static routing, RIPng, and route policy.
14 Multicast
Introduces the IGMP-snooping-related configurations.
15 802.1x-HABP-MAC Authentication
Introduces 802.1x, HABP and MAC related configurations.
16 AAA-RADIUS-HWTACACS
Introduces AAA, RADIUS, HWTACACS, and the related configurations.
17 ARP
Introduces ARP and the related configuration.
18 DHCP
Introduces DHCP Relay, DHCP-Snooping, BOOTP client and the related configuration.
19 ACL
Introduces ACL and the related configuration.
20 QoS
Introduces QoS and the related configuration.
21 Port Mirroring
Introduces port mirroring and the related configuration.
22 UDP Helper
Introduces UDP Helper and the related configuration.
23 Cluster Management
Introduces cluster and the related configuration.
24 SNMP-RMON
Introduces the configuration to manage network devices through SNMP and RMON.
25 NTP
Introduces NTP and the related configuration.
26 DNS
Introduces DNS and the related configuration.
27 File System Management
Introduces basic configuration for file system management.
28 Information Center
Introduces the configuration to analyze and diagnose networks using the information center.
29 System Maintaining and Debugging
Introduces daily system maintenance and debugging.
30 NQA
Introduces NQA and the related configuration.
31 SSH
Introduces SSH2.0 and the related configuration.
32 Track
Introduces Track and the related configuration.
33 PoE
Introduces PoE, PoE profile and the related configuration.
34 SSL-HTTPS
Introduces SSL, HTTPS and the related configuration.
35 PKI
Introduces PKI and the related configuration.
36 Stack Management
Introduces Stack Management and the related configuration.
37 Appendix
Lists the acronyms used in this manual.
