- H3C S5500-SI Series Ethernet Switches Operation Manual(V1.01)
- 00-1Cover
- 00-2Overview
- 01-Login Configuration
- 02-VLAN Configuration
- 03-IP Addressing and IP Performance Configuration
- 04-QinQ-BPDU TUNNEL Configuration
- 05-Port Correlation Configuration
- 06-Link Aggregation Configuration
- 07-MAC Address Table Management Configuration
- 08-Port Security Configuration
- 09-MSTP Configuration
- 10-IPv6 Configuration
- 11-IP Routing Overview Configuration
- 12-IPv4 Routing Configuration
- 13-IPv6 Routing Configuration
- 14-Multicast Configuration
- 15-802.1x-HABP-MAC Authentication Configuration
- 16-AAA-RADIUS-HWTACACS Configuration
- 17-ARP Configuration
- 18-DHCP Configuration
- 19-ACL Configuration
- 20-QoS Configuration
- 21-Port Mirroring Configuration
- 22-UDP Helper Configuration
- 23-Cluster Management Configuration
- 24-SNMP-RMON Configuration
- 25-NTP Configuration
- 26-DNS Configuration
- 27-File System Management Configuration
- 28-Information Center Configuration
- 29-System Maintaining and Debugging Configuration
- 30-NQA Configuration
- 31-SSH Configuration
- 32-Track Configuration
- 33-PoE Configuration
- 34-SSL-HTTPS Configuration
- 35-PKI Configuration
- 36-Stack Management Configuration
- 37-Appendix
| 00-1Cover | 68 KB |
H3C S5500-SI Series Ethernet Switches |
Operation Manual |
Hangzhou H3C Technologies Co., Ltd. http://www.h3c.com
Manual Version: 20071208-C-1.01 |
Copyright © 2007, Hangzhou H3C Technologies Co., Ltd. and its licensors
All Rights Reserved
No part of this manual may be reproduced or transmitted in any form or by any means without prior written consent of Hangzhou H3C Technologies Co., Ltd.
Trademarks
H3C,
, Aolynk,
, H3Care,
, TOP G,
, IRF, NetPilot, Neocean, NeoVTL,
SecPro, SecPoint, SecEngine, SecPath, Comware, Secware, Storware, NQA, VVG, V2G,
VnG, PSPT, XGbus, N-Bus, TiGem, InnoVision and HUASAN are trademarks
All other trademarks that may be mentioned in this manual are the property of their respective owners.
Notice
The information in this document is subject to change without notice. Every effort has been made in the preparation of this document to ensure accuracy of the contents, but all statements, information, and recommendations in this document do not constitute the warranty of any kind, express or implied.
To obtain the latest information, please access:
http://www. h3c.com
Technical Support
service@h3c.com
http://www. h3c.com
About This Manual
Related Documentation
In addition to this manual, each H3C S5500-SI Series Ethernet Switches documentation set includes the following:
Manual |
H3C S5500-SI Complete Series Ethernet Switches Installation Manual |
It provides information for the system installation. |
H3C S5500-SI Series Ethernet Switches Command Manual |
It is used for assisting the users in using various commands. |
Organization
H3C S5500-SI Series Ethernet Switches Operation Manual is organized as follows:
Part |
Contents |
0 Overview |
Introduces the system features, service features, and network application of the switches. |
1 Login |
Introduces the ways to log into an Ethernet switch. |
2 VLAN |
Introduces VLAN basics and the related configuration. |
3 IP Addressing and IP Performance |
Introduces IP address and IP performance fundamental and the related configuration. |
4 QinQ-BPDU TUNNEL |
Introduces QinQ and the related configuration |
5 Port Correlation Configuration |
Introduces basic port configuration, link aggregation, and port isolation configuration. |
6 Link Aggregation |
Introduces link aggregation fundamental and the related configuration. |
7 MAC Address Table Management |
Introduces MAC address forwarding table and the related configuration. |
8 Port Security |
Introduces port security and the related configuration. |
9 MSTP |
Introduces STP and the related configurations. |
10 IPv6 |
Introduces IPv6 basic configuration and application. |
11 IP Routing Overview |
Introduces the overview of Routing. |
12 IPv4 Routing |
Introduces IPv4 routing related configurations, such as static routing, RIP, and route policy. |
13 IPv6 Routing |
Introduces IPv6 routing related configurations, such as static routing, RIPng, and route policy. |
14 Multicast |
Introduces the IGMP-snooping-related configurations. |
15 802.1x-HABP-MAC Authentication |
Introduces 802.1x, HABP and MAC related configurations. |
16 AAA-RADIUS-HWTACACS |
Introduces AAA, RADIUS, HWTACACS, and the related configurations. |
17 ARP |
Introduces ARP and the related configuration. |
18 DHCP |
Introduces DHCP Relay, DHCP-Snooping, BOOTP client and the related configuration. |
19 ACL |
Introduces ACL and the related configuration. |
20 QoS |
Introduces QoS and the related configuration. |
21 Port Mirroring |
Introduces port mirroring and the related configuration. |
22 UDP Helper |
Introduces UDP Helper and the related configuration. |
23 Cluster Management |
Introduces cluster and the related configuration. |
24 SNMP-RMON |
Introduces the configuration to manage network devices through SNMP and RMON. |
25 NTP |
Introduces NTP and the related configuration. |
26 DNS |
Introduces DNS and the related configuration. |
27 File System Management |
Introduces basic configuration for file system management. |
28 Information Center |
Introduces the configuration to analyze and diagnose networks using the information center. |
29 System Maintaining and Debugging |
Introduces daily system maintenance and debugging. |
30 NQA |
Introduces NQA and the related configuration. |
31 SSH |
Introduces SSH2.0 and the related configuration. |
32 Track |
Introduces Track and the related configuration. |
33 PoE |
Introduces PoE, PoE profile and the related configuration. |
34 SSL-HTTPS |
Introduces SSL, HTTPS and the related configuration. |
35 PKI |
Introduces PKI and the related configuration. |
36 Stack Management |
Introduces Stack Management and the related configuration. |
37 Appendix |
Lists the acronyms used in this manual. |
Conventions
The manual uses the following conventions:
I. Command conventions
Convention |
Boldface |
The keywords of a command line are in Boldface. |
italic |
Command arguments are in italic. |
Items (keywords or arguments) in square brackets [ ] are optional. |
{ x | y | ... } |
Alternative items are grouped in braces and separated by vertical bars. One is selected. |
[ x | y | ... ] |
Optional alternative items are grouped in square brackets and separated by vertical bars. One or none is selected. |
{ x | y | ... } * |
Alternative items are grouped in braces and separated by vertical bars. A minimum of one or a maximum of all can be selected. |
[ x | y | ... ] * |
Optional alternative items are grouped in square brackets and separated by vertical bars. Many or none can be selected. |
&<1-n> |
The argument(s) before the ampersand (&) sign can be entered 1 to n times. |
A line starting with the # sign is comments. |
II. GUI conventions
Convention |
Button names are inside angle brackets. For example, click <OK>. |
Window names, menu items, data table and field names are inside square brackets. For example, pop up the [New User] window. |
Multi-level menus are separated by forward slashes. For example, [File/Create/Folder]. |
III. Symbols
Convention |
Means reader be extremely careful. Improper operation may cause bodily injury. |
Means reader be careful. Improper operation may cause data loss or damage to equipment. |
& Note |
Means a complementary description. |
