Title | Size | Downloads |
H3C LSX1TGS48FC1 Card Manual-5PW102-book.pdf | 71.57 KB |
48-port 10-GE SFP+ Fiber Interface Card–LSX1TGS48FC1
1 Card identifier
The mark LSX1TGS48FC1 is printed at the upper right corner of the front panel, and is used to identify the card.
2 Specifications
Table 1 LSX1TGS48FC1 specifications
Item |
Specification |
Processor |
MIPS64 (Dual Core), 1.2GHz |
SDRAM |
4GB DDR3 SDRAM |
Power consumption |
160 W to 275 W |
Connector |
LC |
Ports |
48 SFP+ ports |
Transmission rate |
10 Gbps, 1 Gbps |
Transmission medium and max transmission distance |
Compatible device models |
S12500-X Switch Series |
System software version |
Release 1102 and later versions |
IMPORTANT: Before you install the card to the switch, remove the protective box for the card. |
The LSX1TGS48FC1 supports the following transceiver modules and cables.
Table 2 10-Gigabit SFP+ module specifications
10-Gigabit SFP+ module |
Central wavelength |
Connector type |
Fiber diameter |
Mode bandwidth |
Maximum transmission distance |
SFP-XG-SX-MM850-A |
850 nm |
LC |
50/125μm MMF |
2000 MHz*km |
300 m (984.26 ft.) |
500 MHz*km |
82 m (269.03 ft) |
400 MHz*km |
66 m (216.54 ft) |
62.5/125μm MMF |
200 MHz*km |
33 m (108.27 ft) |
160 MHz*km |
26 m (85.30 ft) |
SFP-XG-LX-SM1310 |
1310 nm |
LC |
9/125μm SMF |
N/A |
10 km (6.21 miles) |
SFP-XG-LH40-SM1550 |
1550nm |
LC |
9/125μm SMF |
N/A |
40 km (24.86 miles) |
SFP-XG-LH80-SM1550 |
1550nm |
LC |
9/125μm SMF |
N/A |
80 km (49.71 miles) |
Table 3 SFP+ cable specifications
10-Gigabit SFP+ cable |
Length |
Data rate |
Type |
Remarks |
LSWM2STK |
1.2 m (3.94 ft.) |
10.31 Gbps |
SFP+ cable |
Dedicated to interconnecting SFP+ ports |
LSWM3STK |
3 m (9.84 ft.) |
LSTM1STK |
5 m (16.40 ft.) |
LSTM2STK |
7 m (22.97 ft) |
Table 4 Gigabit SFP module specifications
Gigabit SFP module |
Connector type |
Fiber diameter |
Mode bandwidth |
SFP-GE-SX-MM850-A |
850 nm |
LC |
50/125μm MMF |
500 MHz*km |
550 m (1804.46 ft) |
400 MHz*km |
500 m (1640.42 ft) |
62.5/125μm MMF |
200 MHz*km |
275 m (902.23 ft) |
160 MHz*km |
220 m (721.78 ft) |
SFP-GE-LX-SM1310-A |
1310 nm |
LC |
9/125μm SMF |
N/A |
50/125μm MMF |
500 MHz*km |
400 MHz*km |
62.5/125μm MMF |
500 MHz*km |
SFP-GE-LH40-SM1310 |
1310 nm |
LC |
9/125μm SMF |
N/A |
40 km (18.64 miles) |
SFP-GE-LH40-SM1550 |
1550 nm |
LC |
9/125μm SMF |
N/A |
SFP-GE-LH70-SM1550 |
1550 nm |
LC |
9/125μm SMF |
N/A |
70 km (43.50 miles) |
SFP-GE-LH100-SM1550 |
1550 nm |
LC |
9/125μm SMF |
N/A |
100 km (62.14 miles) |
SFP-GE-LX-SM1310-BIDI |
TX: 1310 nm RX: 1490 nm |
The two modules must be used together. |
LC |
9/125μm SMF |
N/A |
SFP-GE-LX-SM1490-BIDI |
TX: 1490 nm RX: 1310 nm |
LC |
9/125μm SMF |
N/A |
SFP-GE-LH70-SM1470-CW |
1470 nm |
LC |
9/125μm SMF |
N/A |
SFP-GE-LH70-SM1490-CW |
1490 nm |
LC |
9/125μm SMF |
N/A |
SFP-GE-LH70-SM1510-CW |
1510 nm |
LC |
9/125μm SMF |
N/A |
SFP-GE-LH70-SM1530-CW |
1530 nm |
LC |
9/125μm SMF |
N/A |
SFP-GE-LH70-SM1550-CW |
1550 nm |
LC |
9/125μm SMF |
N/A |
SFP-GE-LH70-SM1570-CW |
1570 nm |
LC |
9/125μm SMF |
N/A |
SFP-GE-LH70-SM1590-CW |
1590 nm |
LC |
9/125μm SMF |
N/A |
SFP-GE-LH70-SM1610-CW |
1610 nm |
LC |
9/125μm SMF |
N/A |
3 Obtaining documentation
For card installation, see the H3C S12500-X Switch Series Installation Guide.
For software upgrade, see the H3C S12500-X Switch Series Software Upgrade Guide.
Take the following steps to get the latest documentation from the H3C website at www.h3c.com.
· Go to http://www.h3c.com/portal/Technical_Documents, or click Technical Support & Documents > Technical Documents on the top navigation bar at http://www.h3c.com.
· Choose the desired product category and model.
Copyright © 2013 Hangzhou H3C Technologies Co., Ltd.
