Title | Size | Downloads |
H3C LSX1SUP10B1 Card Manual-6PW103-book.pdf | 21.43 KB |
LSX1SUP10B1 Service Processing Engine
1 Card identifier
The mark LSX1SUP10B1 is printed at the upper left corner of the front panel, and is used to identify the card.
2 Specifications
Table 1 LSX1SUP10B1 specifications
Item |
Specification |
Processor |
MIPS64 (Quad Core), 1.2GHz |
SDRAM |
8GB DDR3 SDRAM (2 DIMM slots) |
Flash |
1GB (NOR flash) |
NVRAM |
512KB |
Power consumption |
45 W to 50 W |
Connector |
RJ-45 |
Ports |
· 1 console port · 1 10/100/1000Base-T port for management and upgrade · 1 USB port (USB2.0, host port) |
Transmission rate |
· Console port: 9600 bps (default) to 115200 bps · 10/100/1000Base-T port: 10/100/1000 Mbps |
Transmission medium and max transmission distance |
· Console port: 15 m (49.21 ft) over asynchronous serial cable · 10/100/1000Base-T port: 100 m (328.08 ft) over category-5 UTP |
Compatible device models |
Only for the S12510-X switch |
IMPORTANT: · To verify compatibility of the card with the software release you are using, see the release notes. · Before you install the card to the switch, remove the protective box for the card. · The USB port outputs power as prescribed by USB 2.0. You can only install a USB 2.0-compliant device to the USB port. · Set the same speed and duplex mode for a management Ethernet interface and its peer port. |
3 Obtaining documentation
For module installation, see H3C S12500-X Switch Series Installation Guide.
To access the most up-to-date H3C product documentation, go to
http://www.h3c.com.hk/Technical_Documents
For software upgrade, see the release notes for the device.
To access the release notes, go to
http://www.h3c.com.hk/Software_Download
Copyright © 2017 New H3C Technologies Co., Ltd.
