Title | Size | Downloads |
H3C LSX1QGS24FC1 Card Manual-APW100-book.pdf | 67.24 KB |
24-port 40-GE QSFP+ Fiber Interface Card–LSX1QGS24FC1
1 Card identifier
The mark LSX1QGS24FC1 is printed at the upper right corner of the front panel, and is used to identify the card.
2 Specifications
Table 1 LSX1QGS24FC1 specifications
Item |
Specification |
Processor |
MIPS64 (Dual Core), 1.2GHz |
SDRAM |
4GB DDR3 SDRAM |
Power consumption |
270 W to 465 W |
Connector |
MPO |
Ports |
24 QSFP+ ports |
Transmission rate |
40 Gbps |
Transmission medium and max transmission distance |
Compatible device models |
S12500-X Switch Series |
System software version |
Release 1105 and later versions |
IMPORTANT: Before you install the card to the switch, remove the protective box for the card. |
The LSX1QGS24FC1 supports the following transceiver modules and cables.
Table 2 QSFP+ module specifications
QSFP+ module |
Central wavelength |
Connector |
Cable specifications |
Mode bandwidth |
Max. transmission distance |
LSUM1QSFP0 |
850 nm |
MPO |
Multi-mode 50/125 μm OM3 |
2000(MHz*km) |
100 m (328.08 ft) |
Table 3 QSFP+ cable specifications
QSFP+ cable |
Cable length |
Data rate |
LSWM1QSTK0 |
1 m (3.28 ft) |
40 Gbps |
Used for connecting 40 Gbps QSFP+ ports |
LSWM1QSTK1 |
3 m (9.84 ft) |
LSWM1QSTK2 |
5 m (16.40 ft) |
3 Obtaining documentation
For card installation, see the H3C S12500-X Switch Series Installation Guide.
For software upgrade, see the H3C S12500-X Switch Series Software Upgrade Guide.
Take the following steps to get the latest documentation from the H3C website at www.h3c.com.
· Go to http://www.h3c.com/portal/Technical_Documents, or click Technical Support & Documents > Technical Documents on the top navigation bar at http://www.h3c.com.
· Choose the desired product category and model.
Copyright © 2013 Hangzhou H3C Technologies Co., Ltd.
