Title | Size | Downloads |
H3C LSX1CGC4EB1 Card Manual-APW101-book.pdf | 75.11 KB |
4-port 100-GE CFP Fiber Interface Card–LSX1CGC4EB1
1 Card identifier
The card identifier LSX1CGC4EB1 is printed at the upper right corner of the front panel.
2 Specifications
Table 1 LSX1CGC4EB1 specifications
Item |
Specification |
Processor |
MIPS64 (dual core), 1.2 GHz |
SDRAM |
4-GB DDR3 SDRAM |
Power consumption |
271 W to 430 W |
Connector |
LC |
Ports |
Four CFP Ethernet ports |
Port speed |
100 Gbps |
Optional modules |
See Table 2 |
Compatible device models |
S12500-X Switch Series |
System software version |
Release 1005 and later versions |
IMPORTANT: Before you install the card to the switch, remove the protective box for the card. |
Table 2 list the available CFP modules.
Table 2 100G CFP module specifications
Model |
Central wavelength |
Connector |
Fiber |
Max transmission distance |
CFP-100G-LR4-WDM1300 |
1295.56 nm 1300.05 nm 1304.58 nm 1309.14 nm |
LC |
9/125 μm single-mode optical fiber |
10 km (6.21 miles) |
3 Obtaining documentation
For card installation, see H3C S12500-X Switch Series Installation Guide.
For software upgrade, see H3C S12500-X Switch Series Software Upgrade Guide.
Take the following steps to get the latest documentation from the H3C website at www.h3c.com.
· Go to http://www.h3c.com/portal/Technical_Documents, or click Technical Support & Documents > Technical Documents on the top navigation bar at http://www.h3c.com.
· Choose the desired product category and model.
Copyright © 2013 Hangzhou H3C Technologies Co., Ltd.
