12-WLAN advanced features
HomeSupportResource CenterConfigure & DeployConfiguration ExamplesH3C Access Controllers Configuration Examples(V7)-6W10212-WLAN advanced features
09-AP License Synchronization Configuration Examples
Comware 7 AP License Synchronization
Copyright © 2021 New H3C Technologies Co., Ltd. All rights reserved.
Introduction
The following information provides an AP license synchronization configuration example.
The following information applies to Comware 7-based access controllers and access points. Procedures and information in the examples might be slightly different depending on the software or hardware version of the access controllers and access points.
The following information is provided based on the assumption that you have basic knowledge of AP license synchronization.
Example: Configuring AP license synchronization
Network requirements
As shown in Figure 1, the APs connect to AC 1 and AC 2 through the switch and the APs provide wireless service for clients. Set the SSID to service and enable AP license synchronization on AC 1 and AC 2. The two ACs back up licenses for each other.
Figure 1 Network diagram
When the master AC fails, the backup AC will take over and becomes the new master AC. The licenses synchronized to the new master AC will be valid for a 30-day grace period.
Configuration procedures
Configuring the AC 1
1.     Configure interfaces on the AC 1:
# Configure VLAN-interface 100 and assign it an IP address. The AC 1 will use this IP address to establish CAPWAP tunnels with APs.
<AC1> system-view
[AC1] vlan 100
[AC1-vlan100] quit
[AC1] interface vlan-interface 100
[AC1-Vlan-interface100] ip address 112.12.1.25 16
[AC1-Vlan-interface100] quit
# Configure VLAN-interface 200 and assign it an IP address. The AC 1 will use VLAN 200 for client access.
[AC1] vlan 200
[AC1-vlan200] quit
[AC1] interface vlan-interface 200
[AC1-Vlan-interface200] ip address 112.13.1.25 16
[AC1-Vlan-interface200] quit
# Configure GigabitEthernet 1/0/1 that connects the AC 1 to the switch as a trunk port.
[AC1] interface gigabitethernet1/0/1
[AC1-GigabitEthernet1/0/1] port link-type trunk
# Remove the trunk port from VLAN 1, and assign the port to VLANs 100 and 200.
[AC1-GigabitEthernet1/0/1] undo port trunk permit vlan 1
[AC1-GigabitEthernet1/0/1] port trunk permit vlan 100 200
# Specify the PVID of the trunk port as VLAN 100.
[AC1-GigabitEthernet1/0/1] port trunk pvid vlan 100
[AC1-GigabitEthernet1/0/1] quit
# Enable AP license synchronization on AC 1 and configure AC 1 as the master AC.
[AC1] wlan ap-license-group
[AC1-wlan-ap-license-group] local ip 112.12.1.25
[AC1-wlan-ap-license-group] member ip 112.12.1.26
[AC1-wlan-ap-license-group] ap-license-synchronization enable
[AC1-wlan-ap-license-group] quit
2.     Configure the wireless service:
# Create wireless service template service and enter its view.
[AC1] wlan service-template service
# Set the SSID to service.
[AC1-wlan-st-service] ssid service
# Assign clients coming online through service template service to VLAN 200.
[AC1-wlan-st-service] vlan 200
# Enable service template service.
[AC1-wlan-st-service] service-template enable
[AC1-wlan-st-service] quit
3.     Create APs and bind service template service to radio interfaces of the APs. (Details not shown.)
Configuring the AC 2
1.     Configure interfaces on the AC 2:
# Configure VLAN-interface 100 and assign it an IP address. The AC 2 will use this IP address to establish CAPWAP tunnels with APs.
<AC2> system-view
[AC2] vlan 100
[AC2-vlan100] quit
[AC2] interface vlan-interface 100
[AC2-Vlan-interface100] ip address 112.12.1.26 16
[AC2-Vlan-interface100] quit
# Configure VLAN-interface 200 and assign it an IP address. The AC 2 will use VLAN 200 for client access.
[AC2] vlan 200
[AC2-vlan200] quit
[AC2] interface vlan-interface 200
[AC2-Vlan-interface200] ip address 112.13.1.26 16
[AC2-Vlan-interface200] quit
# Configure GigabitEthernet 1/0/1 that connects the AC 2 to the switch as a trunk port.
[AC2] interface gigabitethernet1/0/1
[AC2-GigabitEthernet1/0/1] port link-type trunk
[AC2-GigabitEthernet1/0/1] undo port trunk permit vlan 1
[AC2-GigabitEthernet1/0/1] port trunk permit vlan 100 200
[AC2-GigabitEthernet1/0/1] port trunk pvid vlan 100
[AC2-GigabitEthernet1/0/1] quit
# Enable AP license synchronization on AC 2 and configure AC 2 as the master AC.
[AC2] wlan ap-license-group
[AC2-wlan-ap-license-group] local ip 112.12.1.26
[AC2-wlan-ap-license-group] member ip 112.12.1.25
[AC2-wlan-ap-license-group] ap-license-synchronization enable
[AC2-wlan-ap-license-group] quit
[AC2] wlan service-template service
[AC2-wlan-st-service] ssid service
[AC2-wlan-st-service] vlan 200
[AC2-wlan-st-service] service-template enable
[AC2-wlan-st-service] quit
Configuring the switch
# Create VLAN 100 and VLAN 200. The switch will use VLAN 100 to forward the traffic on CAPWAP tunnels between the AC and APs, and will use VLAN 200 to forward client traffic.
<Switch> system-view
[Switch] vlan 100
[Switch-vlan100] quit
[Switch] vlan 200
[Switch-vlan200] quit
# Configure GigabitEthernet 1/0/1 that connects the switch to the AC 1 as a trunk port.
[Switch] interface gigabitethernet1/0/1
# Remove the trunk port from VLAN 1, and assign the port to VLAN 100.
[Switch-GigabitEthernet1/0/1] undo port trunk permit vlan 1
[Switch-GigabitEthernet1/0/1] port trunk permit vlan 100
[Switch-GigabitEthernet1/0/1] port trunk pvid vlan 100
# Configure GigabitEthernet 1/0/2 that connects the switch to the AC 2 as a trunk port.
[Switch] interface gigabitethernet1/0/2
[Switch-GigabitEthernet1/0/2] port link-type trunk
[Switch-GigabitEthernet1/0/2] undo port trunk permit vlan 1
[Switch-GigabitEthernet1/0/2] port trunk permit vlan 100
[Switch-GigabitEthernet1/0/2] port trunk pvid vlan 100
# Configure the interface GigabitEthernet 1/0/3 that is connected to APs as an access port, and assign the port to VLAN 100.
[Switch] interface gigabitethernet1/0/3
[Switch-GigabitEthernet1/0/3] port link-type access
[Switch-GigabitEthernet1/0/3] port access vlan 100
# Enable PoE on GigabitEthernet 1/0/3.
[Switch-GigabitEthernet1/0/3] poe enable
[Switch-GigabitEthernet1/0/3] quit
# Specify 112.12.1.27/16 as the IP address of the VLAN 100.
[Switch-Vlan-interface100] ip address 112.12.1.27 16
# Specify 112.13.1.27/16 as the IP address of the VLAN 200.
[Switch] interface vlan-interface 200
[Switch-Vlan-interface200] ip address 112.13.1.27 16
[Switch-Vlan-interface200] quit
# Enable DHCP.
[Switch] dhcp enable
# Create DHCP IP pool 100 to assign IP addresses to APs, and specify the IP address range for the IP pool.
[Switch] dhcp server ip-pool 100
[Switch-dhcp-pool-100] network 112.12.0.0 mask 255.255.0.0
# Specify gateway IP address 112.12.1.27 in the DHCP IP pool.
[Switch-dhcp-pool-100] gateway-list 112.12.1.27
[Switch-dhcp-pool-100] quit
# Create DHCP IP pool 200 to assign IP addresses to clients, and specify the IP address range for the DHCP IP pool.
[Switch] dhcp server ip-pool 200
[Switch-dhcp-pool-200] network 112.13.0.0 mask 255.255.255.0
# Specify gateway IP address 112.13.1.27 in the DHCP IP pool.
[Switch-dhcp-pool-200] gateway-list 112.13.1.27
# Specify the DNS server according to the actual network plan. In this example, the gateway is specified as the DNS server.
[Switch-dhcp-pool-200] dns-list 112.13.1.27
[Switch-dhcp-pool-200] quit
1.     Display AP license synchronization group information on AC 1.
<AC1> display wlan ap-license-group
Group total licenses: 32
Group used licenses: 2
AP license synchronization: Enabled
Local IP: 112.12.1.25
Local role: Master
Member information:
 IP address       Total     Used    Member role   State   Online duration
 112.12.1.26      16        0       Master        UP      10hr 22min 04sec
2.     Display AP license synchronization group information on AC 2.
<AC2> display wlan ap-license-group
Local IP: 112.12.1.26
Local role: Master
Member information:
 112.12.1.25      16        2       Master        UP      10hr 22min 04sec
3.     When AC 2 fails, AC 1 takes over and the sum of licenses remains 32.
Local role: Master
Member information:
 112.12.1.26      16        0       Master        DOWM    00hr 00min 00sec
Configuration files
·     AC 1:
vlan 100
vlan 200
 ssid service
 vlan 200
interface Vlan-interface100
 ip address 112.12.1.25 255.255.0.0
interface Vlan-interface200
 ip address 112.13.1.25 255.255.0.0
·     AC 2:
vlan 100
vlan 200
 ssid service
 vlan 200
 ip address 112.12.1.26 255.255.0.0
 ip address 112.13.1.26 255.255.0.0
·     Switch:
 dhcp enable
vlan 100
vlan 200
dhcp server ip-pool vlan100
dhcp server ip-pool vlan200
 ip address 112.12.1.27 255.255.0.0
 ip address 112.13.1.27 255.255.255.0
Related documentation
·     License Management Command Reference in H3C Access Controllers Command References
·     License Management Configuration Guide in H3C Access Controllers Configuration Guides
  • Become a Partner
  • Partner Resources
