12-WLAN advanced features
HomeSupportResource CenterH3C Access Controllers Configuration Examples(V7)-6W10212-WLAN advanced features
13-iBeacon Management Configuration Examples
13-iBeacon Management Configuration Examples 261.77 KB
Comware 7 iBeacon Management
Copyright © 2021 New H3C Technologies Co., Ltd. All rights reserved.
Introduction
The following information provides an example for configuring WA4320-ACN-B APs to realize iBeacon management.
This document applies to Comware 7-based access controllers and access points. Procedures and information in the examples might be slightly different depending on the software or hardware version of the access controllers and access points.
This document assumes that you have basic knowledge of IoT AP and WLAN location.
Example: Configuring iBeacon management
As shown in Figure 1, configure the AP to manage the iBeacon device. The AP collects BLE information and sends the information to the location server on the IMC server for calculation. Then, users can obtain information including electric quantity and RSSI of the iBeacon device. The AP also assigns management orders from the server to the iBeacon device.
Figure 1 Network diagram
Use the serial ID labeled on the AP's rear panel to specify an AP.
Procedures
Configuring the AC
1.     Configure interfaces on the AC:
# Create VLAN 100 and VLAN-interface 100, and assign an IP address to the VLAN interface. The AC will use this IP address to establish a CAPWAP tunnel with the AP.
<AC> system-view
[AC] vlan 100
[AC-vlan100] quit
[AC-Vlan-interface100] ip address 192.1.0.1 16
[AC-Vlan-interface100] quit
# Create VLAN 200 and VLAN-interface 200, and configure the VLAN interface to use DHCP for IP address acquisition.
<AC> system-view
[AC] vlan 200
[AC-vlan200] quit
[AC-Vlan-interface200] ip address dhcp-alloc
[AC-Vlan-interface200] quit
# Configure GigabitEthernet 1/0/1 that connects the AC and the switch as a trunk port, remove the port from VLAN 1, and assign it to VLANs 100 and 200.
[AC-GigabitEthernet1/0/1] undo port trunk permit vlan 1
[AC-GigabitEthernet1/0/1] port trunk permit vlan 100 200
2.     Create a manual AP named ap1, and specify the AP model and serial ID
[AC] wlan ap ap1 model WA4320-ACN-B
[AC-wlan-ap-ap1] serial-id 210236A35VA11A100678ACNB
3.     Configure a module:
# Enter the view of module 1.
[AC-wlan-ap-ap1] module 1
# Specify the supported module type BLE for module 1, and enable module 1.
[AC-wlan-ap-ap1-module-1] type ble
[AC-wlan-ap-ap1-module-1] module enable
[AC-wlan-ap-ap1-module-1] quit
4.     Configure BLE location:
# Enable BLE location.
[AC-wlan-ap-ap1] rfid-tracking ble enable
# Set the IPv4 address and port number of the location server to 192.2.0.1 and 1145, respectively. In this example, the IP address of the BLE location server is the IMC server's IP address obtained through DHCP.
[AC-wlan-ap-ap1] rfid-tracking ble engine-address 192.2.0.1 engine-port 1145
# Enable BLE neighbor list reporting for AP ap1.
[AC-wlan-ap-ap1] rfid-tracking ble report enable
# Configure the AP to send BLE neighbor list reports to the location server every 10 seconds.
[AC-wlan-ap-ap1] rfid-tracking ble report interval 10
# Specify the default password for deploying configuration to iBeacon devices as AprilBrother in plaintext form. Make sure the specified password is the same as the factory password of the iBeacon device.
[AC-wlan-ap-ap1] rfid-tracking ble command-password simple AprilBrother
[AC-wlan-ap-ap1] quit
Configuring the switch
1.     Configure interfaces on the switch:
# Create VLAN 100 and VLAN-interface 100, and assign an IP address to the VLAN interface. The switch will use this VLAN to communicate with the AC.
<Switch> system-view
[Switch] vlan 100
[Switch-vlan100] quit
[Switch-Vlan-interface100] ip address 192.1.0.2 16
# Create VLAN 200 and VLAN-interface 200, and assign an IP address to the VLAN interface. The switch will use this VLAN to forward traffic for the IMC server.
[Switch] vlan 200
[Switch-vlan200] quit
[Switch] interface vlan-interface 200
[Switch-Vlan-interface200] ip address 192.2.0.2 24
[Switch-Vlan-interface200] quit
# Configure GigabitEthernet 1/0/1 that connects the switch and the AC as a trunk port, remove the port from VLAN 1, and assign the trunk port to VLANs 100 and 200.
[Switch-GigabitEthernet1/0/1] undo port trunk permit vlan 1
[Switch-GigabitEthernet1/0/1] port trunk permit vlan 100 200
# Configure GigabitEthernet 1/0/2 that connects the switch and the IMC server as an access port, and assign the port to VLAN 200.
[Switch-GigabitEthernet1/0/2] port access vlan 200
# Configure GigabitEthernet 1/0/3 that connects the switch and AP as an access port, and assign the port to VLAN 100.
[Switch] interface gigabitethernet 1/0/3
[Switch-GigabitEthernet1/0/3] port link-type access
[Switch-GigabitEthernet1/0/3] port access vlan 100
# Enable PoE on GigabitEthernet 1/0/3.
[Switch-GigabitEthernet1/0/3] poe enable
[Switch-GigabitEthernet1/0/3] quit
2.     Configure DHCP services:
# Enable DHCP.
[Switch] dhcp enable
# Create a DHCP address pool named 1 to assign an IP address to the AP.
[Switch] dhcp server ip-pool 1
# In DHCP address pool 1, specify subnet 192.1.0.0/16 for dynamic allocation, exclude IP address 192.1.0.1 from dynamic allocation, and specify gateway IP address 192.1.0.2.
[Switch-dhcp-pool-1] network 192.1.0.0 mask 255.255.0.0
[Switch-dhcp-pool-1] forbidden-ip 192.1.0.1
[Switch-dhcp-pool-1] gateway-list 192.1.0.2
[Switch-dhcp-pool-1] quit
# Create a DHCP address pool named 2, and specify subnet 192.2.0.0/24 and gateway address 192.2.0.2 for the AC's VLAN-interface 200 and the IMC server.
[Switch] dhcp server ip-pool 2
[Switch-dhcp-pool-2] network 192.2.0.0 mask 255.255.255.0
[Switch-dhcp-pool-2] gateway-list 192.2.0.2
[Switch-dhcp-pool-2] quit
Configuring the IMC server
In this example, the RADIUS server runs IMC PLAT 7.2(E0403L02) and IMC WSM 7.2(E0502L03).
To configure the IMC server:
1.     Add a location:
a.     Click the Service tab.
b.     From the navigation tree, select WLAN Manager > Location View.
c.     Click Add.
The Add Location page opens.
d.     Configure the following parameters, as shown in Figure 2:
-     Enter BLE in the Location Name field.
-     Use the default settings for other parameters.
e.     Click OK.
Figure 2 Adding a location
2.     Add a Bluetooth AP:
a.     On the newly created location view page, click Add, as shown in Figure 3.
The Select Devices page opens.
b.     On the Device List area, select the target Bluetooth AP, as shown in Figure 4.
e.     Click OK.
Figure 3 Adding a Bluetooth AP
Figure 4 Selecting a Bluetooth AP
3.     Add a topology:
a.     On the newly created location view page, click the icon of viewing topology, as shown in Figure 5.
The topology configuration page opens.
b.     Click the icon of adding a map, as shown in Figure 6.
c.     Click the icon of setting the measuring scale, as shown in Figure 7.
d.     Click the save icon to save the topology, as shown in Figure 8.
Figure 5 Adding a topology
Figure 6 Adding a map
Figure 7 Adding a measuring scale
Figure 8 Saving the topology
1.     Log in to the IMC management platform, and click the Service tab.
2.     From the navigation tree, select WLAN Manager > Location Manager> iBeacon List.
3.     On the page that opens, view the iBeacon information, including electric quantity, RSSI, UUID, Major ID, Minor ID, and transmit power.
Configuration files
·     AC:
vlan 100
interface Vlan-interface100
 ip address 192.1.0.1 255.255.0.0
interface Vlan-interface200
 rfid-tracking ble command-password cipher $c$3$AAu3rmjHUmAE0W12Rk1Jco6MPJ3Iqoh+pFgqhkFihw==
 radio 1
 radio 2
 module 1
   type BLE
   module enable
·     Switch:
dhcp enable
vlan 100
vlan 200
 ip address 192.1.0.2 255.255.0.0
 ip address 192.2.0.2 255.255.255.0
 poe enable
Related documentation
·     Internet of Things Command Reference in H3C Access Controllers Command References
·     Internet of Things Configuration Guide in H3C Access Controllers Configuration Guides
·     WLAN Advanced Features Command Reference in H3C Access Controllers Command References
·     WLAN Advanced Features Configuration Guide in H3C Access Controllers Configuration Guides
