12-WLAN advanced features
HomeSupportResource CenterH3C Access Controllers Configuration Examples(V7)-6W10212-WLAN advanced features
01-WLAN Probe Configuration Examples
01-WLAN Probe Configuration Examples 82.27 KB
Comware 7 WLAN Probe
Copyright © 2021 New H3C Technologies Co., Ltd. All rights reserved.
Introduction
The following information provides examples for configuring WLAN probe.
The following information applies to Comware 7-based access controllers and access points. Procedures and information in the examples might be slightly different depending on the software or hardware version of the access controllers and access points.
The following information is provided based on the assumption that you have basic knowledge of WIPS.
Example: Configuring WLAN probe
As shown in Figure 1, AP 1 and AP 2 provide wireless services for clients through SSID service.
Enable WLAN probe on the sensor, and configure the sensor to report the received wireless device information to the AC.
Figure 1 Network diagram
Procedures
Configuring the AC
1.     Configure interfaces on the AC:
# Configure VLAN-interface 100 and assign it an IP address. The AC will use this IP address to establish CAPWAP tunnels with APs.
<AC> system-view
[AC] vlan 100
[AC-vlan100] quit
[AC-Vlan-interface100] ip address 112.12.1.25 16
[AC-Vlan-interface100] quit
# Configure VLAN-interface 200 and assign it an IP address. The AC will use VLAN 200 for client access.
[AC] vlan 200
[AC-vlan200] quit
[AC-Vlan-interface200] ip address 112.13.1.25 16
[AC-Vlan-interface200] quit
# Configure GigabitEthernet 1/0/1 that connects the AC to the switch as a trunk port.
[AC] interface gigabitethernet1/0/1
# Remove the trunk port from VLAN 1, and assign the port to VLANs 100 and 200.
[AC-GigabitEthernet1/0/1] undo port trunk permit vlan 1
[AC-GigabitEthernet1/0/1] port trunk permit vlan 100 200
# Specify the PVID of the trunk port as VLAN 100.
[AC-GigabitEthernet1/0/1] port trunk pvid vlan 100
2.     Configure DHCP:
# Enable DHCP.
[AC] dhcp enable
# Create DHCP address pool vlan100 to assign IP addresses for APs, and specify the IP address range for the DHCP address pool.
[AC] dhcp server ip-pool vlan100
[AC-dhcp-pool-vlan100] network 112.12.0.0 mask 255.255.0.0
# Specify gateway IP address 112.12.1.25 in the DHCP address pool.
[AC-dhcp-pool-vlan100] gateway-list 112.12.1.25
[AC-dhcp-pool-vlan100] quit
# Create DHCP address pool vlan200 to assign IP addresses for clients, and specify the IP address range for the DHCP address pool.
[AC] dhcp server ip-pool vlan200
[AC-dhcp-pool-vlan200] network 112.13.0.0 mask 255.255.0.0
# Specify gateway IP address 112.13.1.25 in the DHCP address pool.
[AC-dhcp-pool-vlan200] gateway-list 112.13.1.25
# Configure the DNS server according to the actual network plan. In this example, the gateway is specified as the DNS server.
[AC-dhcp-pool-vlan200] dns-list 112.13.1.25
[AC-dhcp-pool-vlan200] quit
3.     Configure the AP:
# Create a service template named service.
[AC] wlan service-template service
# Set the SSID to service.
[AC-wlan-st-service] ssid service
# Assign clients coming online through the service template to VLAN 200.
[AC-wlan-st-service] vlan 200
# Enable the service template.
[AC-wlan-st-service] service-template enable
[AC-wlan-st-service] quit
# Create AP ap1, and specify its model and serial ID.
[AC] wlan ap ap1 model WA4320i-ACN
[AC-wlan-ap-ap1] serial-id 210235A1GQC157001570
# Enable radio 1 and bind service template service to radio 1.
[AC-wlan-ap-ap1] radio 1
[AC-wlan-ap-ap1-radio-1] service-template service
[AC-wlan-ap-ap1-radio-1] quit
# Create AP ap2, and specify its model and serial ID.
[AC] wlan ap ap2 model WA4320i-ACN
[AC-wlan-ap-ap2] serial-id 210235A1GQC157001571
[AC-wlan-ap-ap2] radio 1
[AC-wlan-ap-ap2-radio-1] radio enable
[AC-wlan-ap-ap2-radio-1] service-template service
[AC-wlan-ap-ap2-radio-1] quit
# Create AP sensor and specify its model and serial ID.
[AC] wlan ap sensor model WA4320i-ACN
[AC-wlan-ap-sensor] serial-id 210235A1GQC157001572
# Enable radio 1 of AP sensor, and enable WLAN probe for the radio.
[AC-wlan-ap-sensor] radio 1
[AC-wlan-ap-sensor-radio-1] radio enable
[AC-wlan-ap-sensor-radio-1] scan scan-time 100
[AC-wlan-ap-sensor-radio-1] client-proximity-sensor enable
[AC-wlan-ap-sensor-radio-1] quit
[AC-wlan-ap-sensor] return
Configuring the switch
# Create VLANs 100 and 200. The switch will use VLAN 100 to forward the traffic on CAPWAP tunnels between the AC and APs, and use VLAN 200 to forward client traffic.
<Switch> system-view
[Switch] vlan 100
[Switch-vlan100] quit
[Switch] vlan 200
[Switch-vlan200] quit
# Configure GigabitEthernet 1/0/1 that connects the switch to the AC as a trunk port.
[Switch] interface gigabitethernet1/0/1
# Remove the trunk port from VLAN 1, and assign the port to VLAN 100 and VLAN 200.
[Switch-GigabitEthernet1/0/1] undo port trunk permit vlan 1
[Switch-GigabitEthernet1/0/1] port trunk permit vlan 100 200
[Switch-GigabitEthernet1/0/1] port trunk pvid vlan 100
# Configure GigabitEthernet 1/0/2 as an access port and assign the port to VLAN 100.
[Switch] interface gigabitethernet1/0/2
# Enable PoE.
# Configure GigabitEthernet 1/0/3 that connects the switch to the AP 1 as a trunk port.
[Switch] interfac gigabitEthernet 1/0/3
[Switch-GigabitEthernet1/0/3] port link-type trunk
[Switch-GigabitEthernet1/0/3] undo port trunk permit vlan 1
[Switch-GigabitEthernet1/0/3] port trunk permit vlan 100 200
[Switch-GigabitEthernet1/0/3] port trunk pvid vlan 100
# Enable PoE.
[Switch-GigabitEthernet1/0/3] poe enable
[Switch-GigabitEthernet1/0/3] quit
# Configure GigabitEthernet 1/0/4 that connects the switch to the AP 2 as a trunk port.
[Switch] interfac gigabitEthernet 1/0/4
[Switch-GigabitEthernet1/0/4] port link-type trunk
[Switch-GigabitEthernet1/0/4] undo port trunk permit vlan 1
[Switch-GigabitEthernet1/0/4] port trunk permit vlan 100 200
[Switch-GigabitEthernet1/0/4] port trunk pvid vlan 100
# Enable PoE.
[Switch-GigabitEthernet1/0/4] poe enable
[Switch-GigabitEthernet1/0/4] quit
# Display wireless device information detected by the sensor
<Sysname> display client-proximity-sensor device
Total 3 detected devices
MAC address    Type      Duration    Sensors Channel Status
0AFB-423B-893C AP        00h 10m 46s 1       11      Active
0AFB-423B-893D AP        00h 10m 46s 1       6       Active
0AFB-423B-893E AP        00h 10m 46s 1       1       Active
Configuration files
·     AC:
dhcp enable
vlan 100
vlan 200
 ssid service
 vlan 200
interface Vlan-interface100
 ip address 112.12.1.25 255.255.0.0
interface Vlan-interface200
 ip address 112.13.1.25 255.255.0.0
 radio 1
  radio enable
 radio 1
  radio enable
 radio 1
  radio enable
  scan scan-time 100
·     Switch:
vlan 100
vlan 200
 poe enable
 poe enable
interface GigabitEthernet1/0/4
 poe enable
Related documentation
·     WLAN Advanced Features Command Reference in H3C Access Controllers Command References
·     WLAN Advanced Features Configuration Guide in H3C Access Controllers Configuration Guides
