12-WLAN advanced features
HomeSupportResource CenterConfigure & DeployConfiguration ExamplesH3C Access Controllers Configuration Examples(V7)-6W10212-WLAN advanced features
11-BLE Module iBeacon Transmission Configuration Examples
Comware 7 BLE Module iBeacon Transmission
Copyright © 2021 New H3C Technologies Co., Ltd. All rights reserved.
Introduction
The following information provides an example for configuring iBeacon transmission for a BLE module.
This document applies to Comware 7-based access controllers and access points. Procedures and information in the examples might be slightly different depending on the software or hardware version of the access controllers and access points.
This document assumes that you have basic knowledge of IoT AP and wireless location.
Example: Configure iBeacon transmission for a BLE module
As shown in Figure 1, the IMC server acts as an IoT server, and UAP300 acts as an IoT AP to provide IoT services for the connected IoT modules T300M-B and T300-B.
Figure 1 Network diagram
When you configure iBeacon transmission for a BLE module, follow these restrictions and guidelines:
·     Use the serial ID labeled on the AP's rear panel to specify an AP.
·     Enable LLDP on the PoE switch.
·     The number of cascaded T300-B connected to T300M-B depends on the power supply capacity of the uplink device (UAP300).
Procedures
# Make sure the devices can reach each other (Details not shown.).
# Create a manual AP named ap1, and specify its model and serial ID.
<AC> system-view
[AC] wlan ap ap1 model UAP300
[AC-wlan-ap-ap1] serial-id 219801A15K816AE00029
# Enable PoE for UAP300.
[AC-wlan-ap-ap1] poe port 3 enable
# Enter the view of module 1.
[AC-wlan-ap-ap1] module 1
# Enable module 1.
[AC-wlan-ap-ap1-module-1] module enable
# Specify BLE as the supported module type for module 1.
[AC-wlan-ap-ap1-module-1] type ble
# Specify the serial number for module 1.
[AC-wlan-ap-ap1-module-1] serial-number 219801A0YQ8164E00101
# Enable the iBeacon transmission feature for module 1.
[AC-wlan-ap-ap1-module-1] rfid-tracking ble advertisement enable
# Configure the advertisement information for module 1.
[AC-wlan-ap-ap1-module-1] rfid-tracking ble advertisement uuid fda50693a4e24fb1afcfc6eb07647825
[AC-wlan-ap-ap1-module-1] rfid-tracking ble advertisement major-id 10
[AC-wlan-ap-ap1-module-1] rfid-tracking ble advertisement minor-id 7
[AC-wlan-ap-ap1-module-1] quit
# Enter the view of module 2
[AC-wlan-ap-ap1] module 2
# Enable module 1.
[AC-wlan-ap-ap1-module-2] module enable
# Specify BLE as the supported module type for module 2.
[AC-wlan-ap-ap1-module-2] type ble
# Specify the serial number for module 2.
[AC-wlan-ap-ap1-module-2] serial-number 219801A0YQ8164E20022
# Enable the iBeacon transmission feature for module 2.
[AC-wlan-ap-ap1-module-2] rfid-tracking ble advertisement enable
# Configure the advertisement information for module 2.
[AC-wlan-ap-ap1-module-2] rfid-tracking ble advertisement uuid fda50693a4e24fb1afcfc6eb07647825
[AC-wlan-ap-ap1-module-2] rfid-tracking ble advertisement major-id 10
[AC-wlan-ap-ap1-module-2] rfid-tracking ble advertisement minor-id 7
[AC-wlan-ap-ap1-module-2] quit
# Set the IPv4 address and port number for the BLE location server to 3.3.3.204 and 1145, respectively, for AP ap1.
[AC-wlan-ap-ap1] rfid-tracking ble engine-address 3.3.3.204 engine-port 1145
# Enable BLE location for AP ap1.
[AC-wlan-ap-ap1] rfid-tracking ble enable
# Enable neighbor list reporting for AP ap1.
[AC-wlan-ap-ap1] rfid-tracking ble report enable
[AC-wlan-ap-ap1] quit
# Display UAP information and connected module information.
[AC] display wlan uap name ap1
UAP name : ap1
Model : UAP300
Serial ID : 219801A15K816AE00029
MAC address : b0f9-633f-dfa0
Modules : 1
 Port ID: 3
  Module ID Model Serial Number
  1 T300 219801A0YQ8164E00101
  2 T300 219801A0YQ8164E20022
# Display information about module 1.
[AC] display wlan module-information ap ap1 module 1
Module administrative type : BLE
Module physical type : H3C
Model : T300-B
HW version : 1.0
SW version : 0.08
Sequence ID : 00000000000000000023
Node physical status : Normal
Module physical status : Normal
Module administrative status : Enabled
# Display information about module 2.
[AC] display wlan module-information ap ap1 module 2
Model : T300-B
HW version : 1.0
SW version : 0.08
Module administrative status : Disabled
