03-自动AP典型配置
本章节下载: 03-自动AP典型配置 (170.02 KB)
本文档介绍自动AP配置举例。
如图1所示,AC作为DHCP服务器为AP分配IP地址,现要求使用自动AP功能,实现AP与AC自动关联,并且在关联后将AP转化为固化AP。
图1 自动AP配置举例组网图
(1) 配置AC的接口
# 创建VLAN 100及其对应的VLAN接口,并为该接口配置IP地址。AP将获取该IP地址与AC建立CAPWAP隧道。
<AC> system-view
[AC] vlan 100
[AC-vlan100] quit
[AC-Vlan-interface100] ip address 192.1.0.1 16
[AC-Vlan-interface100] quit
# 将与Switch相连的接口GigabitEthernet1/0/1的链路类型配置为Trunk,禁止VLAN 1通过,允许VLAN 100通过。
[AC-GigabitEthernet1/0/1] undo port trunk permit vlan 1
[AC-GigabitEthernet1/0/1] port trunk permit vlan 100
(2) 配置DHCP功能
# 开启DHCP服务。
[AC] dhcp enable
# 配置DHCP地址池1为AP动态分配的网段为192.1.0.0/16,网关地址为192.1.0.1。
[AC] dhcp server ip-pool 1
[AC-dhcp-pool-1] network 192.1.0.0 16
[AC-dhcp-pool-1] gateway-list 192.1.0.1
[AC-dhcp-pool-1] quit
(3) 配置自动AP功能
# 开启自动AP功能。
[AC] wlan auto-ap enable
# 开启自动AP自动固化功能。
[AC] wlan auto-persistent enable
# 创建VLAN 100,用于转发AC和AP间CAPWAP隧道内的流量。
<Switch> system-view
[Switch] vlan 100
[Switch-vlan100] quit
# 配置Switch与AC相连的GigabitEthernet1/0/1接口的属性为Trunk,禁止VLAN 1通过,允许VLAN 100通过。
[Switch-GigabitEthernet1/0/1] undo port trunk permit vlan 1
[Switch-GigabitEthernet1/0/1] port trunk permit vlan 100
# 配置Switch与AP相连的GigabitEthernet1/0/2接口属性为Access,当前Access口允许VLAN 100通过。
# 配置Switch与AP相连的GigabitEthernet1/0/2接口使能PoE功能。
# 通过display wlan ap all命令可以看到AC与AP建立连接,AP的状态为R/M。
[AC] display wlan ap all
Total number of APs: 1
Total number of connected APs: 1
Total number of connected manual APs: 0
Total number of connected auto APs: 1
Total number of connected common APs: 1
Total number of connected WTUs: 0
Total number of inside APs: 0
Maximum supported APs: 3072
Remaining APs: 3071
Total AP licenses: 128
Local AP licenses: 128
Server AP licenses: 0
Remaining AP licenses: 127
Sync AP licenses: 0
AP information
State : I = Idle, J = Join, JA = JoinAck, IL = ImageLoad
C = Config, DC = DataCheck, R = Run, M = Master, B = Backup
AP name AP ID State Model Serial ID
741f-4a35-6e00 1 R/M WA6320 219801A28N819CE0002T
· AC
dhcp enable
vlan 100
network 192.1.0.0 mask 255.255.0.0
interface Vlan-interface100
ip address 192.1.0.1 255.255.0.0
wlan auto-ap enable
· Switch
vlan 100
poe enable
· 《H3C 无线控制器产品 配置指导》中的“AP管理配置指导”。
· 《H3C 无线控制器产品 命令参考》中的“AP管理命令参考”。
