03-安全命令参考
23-会话管理命令
本章节下载: 23-会话管理命令  (3.43 MB)
23-会话管理命令
1 会话管理
1.1 会话管理配置命令
1.1.1 destination-ip
1.1.2 display session aging-time application
1.1.3 display session aging-time state
1.1.4 display session alg-app-change
1.1.5 display session dual-active transparent statistics
1.1.6 display session fast-drop statistics
1.1.7 display session fast-drop table ipv4
1.1.8 display session fast-drop table ipv6
1.1.9 display session fast-drop top-statistics
1.1.10 display session ip-top-count policy
1.1.11 display session ipv6-top-count policy
1.1.12 display session relation-table
1.1.13 display session relation-table aging-time application
1.1.14 display session statistics
1.1.15 display session statistics flow-redirect
1.1.16 display session statistics ipv4
1.1.17 display session statistics ipv6
1.1.18 display session statistics multicast
1.1.19 display session statistics summary all
1.1.20 display session table ipv4
1.1.21 display session table ipv6
1.1.22 display session table multicast ipv4
1.1.23 display session table multicast ipv6
1.1.24 display session top-statistics
1.1.25 reset session alg-app-change
1.1.26 reset session relation-table
1.1.27 reset session statistics
1.1.28 reset session statistics multicast
1.1.29 reset session table
1.1.30 reset session table ipv4
1.1.31 reset session table ipv6
1.1.32 reset session table multicast
1.1.33 reset session table multicast ipv4
1.1.34 reset session table multicast ipv6
1.1.35 session aging-time application
1.1.36 session aging-time state
1.1.37 session alarm rate-abrupt enable
1.1.38 session alarm rate-abrupt threshold
1.1.39 session alarm try-rate-abrupt enable
1.1.40 session alarm try-rate-abrupt threshold
1.1.41 session alarm usage-abrupt enable
1.1.42 session alarm usage-abrupt threshold
1.1.43 session alarm-log enable
1.1.44 session alg fragment
1.1.45 session dual-active create-mode
1.1.46 session dual-active enable
1.1.47 session dual-active transparent udp enable
1.1.48 session fast-drop aging-time
1.1.49 session fast-drop enable
1.1.50 session fast-drop hardware-fast-forwarding
1.1.51 session fast-drop resource-ratio
1.1.52 session fast-drop top-statistics enable
1.1.53 session fast-drop-usage threshold
1.1.54 session flow-redirect enable
1.1.55 session flow-redirect hardware-fast-forwarding
1.1.56 session hotbackup-mode
1.1.57 session ip-top-count enable
1.1.58 session ip-top-count policy
1.1.59 session ipv6-top-count enable
1.1.60 session ipv6-top-count policy
1.1.61 session log { bytes-active | packets-active }
1.1.62 session log enable
1.1.63 session log flow-begin
1.1.64 session log flow-end
1.1.65 session log time-active
1.1.66 session log with-endtime
1.1.67 session persistent acl
1.1.68 session relation-table aging-time application sunrpc
1.1.69 session relation-table match destination-ip sip enable
1.1.70 session relation-table-usage threshold
1.1.71 session reliable-backup enable
1.1.72 session state-machine mode
1.1.73 session statistics enable
1.1.74 session statistics hardware-fast-forwarding
1.1.75 session synchronization { dns | http } *
1.1.76 session synchronization enable
1.1.77 session table-state-backup enable
1.1.78 session top-statistics enable
1.1.79 session usage threshold
1.1.80 source-ip
1 会话管理
非缺省vSystem不支持本特性的部分命令,具体情况请见本文相关描述。有关vSystem的详细介绍请参见“虚拟化技术配置指导”中的“vSystem”。
1.1  会话管理配置命令
destination-ip命令用于配置作为会话数据Top排名统计策略过滤条件的目的IP地址。
undo destination-ip命令用于删除作为会话数据Top排名统计策略过滤条件的目的IP地址。
IPv4会话数据Top排名统计策略视图:
destination-ip subnet subnet-ip-address mask-length
undo destination-ip
IPv6会话数据Top排名统计策略视图:
destination-ip subnet subnet-ipv6-address prefix-length
undo destination-ip
不存在目的IP地址的过滤条件。
IPv4会话数据Top排名统计策略视图
IPv6会话数据Top排名统计策略视图
context-admin
vsys-admin
subnet subnet-ipv4-address mask-length:指定子网IPv4地址。subnet-ipv4-address表示子网IPv4地址;mask-length表示子网掩码长度,取值范围为16~32。
subnet subnet-ipv6-address prefix-length:指定子网IPv6地址。subnet-ipv6-address表示子网IPv6地址;prefix-length表示子网前缀长度,取值范围为96~128。
工作机制
配置会话数据Top排名统计策略过滤条件的目的IP地址后,则仅对符合目的IP地址过滤条件的会话进行统计。
注意事项
IPv4或IPv6会话数据Top排名统计策略只能配置一个目的IP子网地址作为过滤条件,多次执行本命令,最后一次执行的命令生效。
# 作为会话数据Top排名统计策略过滤条件的目的IP地址为10.1.0.0/16。
[Sysname] session ip-top-count policy
[Sysname-session-ip-top-count-policy] destination-ip subnet 10.1.0.0 16
·     session ip-top-count policy
·     session ipv6-top-count policy
display session aging-time application命令用来显示应用层协议或应用的会话老化时间。
context-admin
context-operator
vsys-admin
vsys-operator
# 显示当前各应用层协议或应用的会话老化时间。
<Sysname> display session aging-time application
Application                                                    Aging time(s)
bootpc                                                         120
bootps                                                         120
dns                                                            30
ftp                                                            3600
ftp-data                                                       240
gprs-data                                                      60
gprs-sig                                                       60
gtp-control                                                    60
gtp-user                                                       60
h225                                                           3600
h245                                                           3600
https                                                          600
ils                                                            3600
l2tp                                                           120
mgcp-callagent                                                 60
mgcp-gateway                                                   60
netbios-dgm                                                    3600
netbios-ns                                                     3600
netbios-ssn                                                    3600
ntp                                                            120
pptp                                                           3600
qq                                                             120
ras                                                            300
rip                                                            120
rsh                                                            60
rtsp                                                           3600
sccp                                                           3600
sip                                                            300
snmp                                                           120
snmptrap                                                       120
sqlnet                                                         600
syslog                                                         120
tacacs-ds                                                      120
tftp                                                           60
who                                                            120
xdmcp                                                          3600
others                                                         1200
表1-1 display session aging-time application命令显示信息描述表
Application
应用层协议或应用的名称
Aging time(s)
会话老化时间,单位为秒
others
老化时间为1200秒的应用层协议或应用都显示为others
·     session aging-time application
display session aging-time state命令用来显示各协议状态的会话老化时间。
context-admin
context-operator
vsys-admin
vsys-operator
# 显示当前各协议状态的会话老化时间。
<Sysname> display session aging-time state
State                     Aging Time(s)
SYN                       10
TCP-EST                   3600
FIN                       10
UDP-OPEN                  10
UDP-READY                 30
ICMP-REQUEST              30
ICMP-REPLY                10
RAWIP-OPEN                30
RAWIP-READY               60
UDPLITE-OPEN              30
UDPLITE-READY             60
DCCP-REQUEST              30
DCCP-EST                  3600
DCCP-CLOSEREQ             30
SCTP-INIT                 30
SCTP-EST                  3600
SCTP-SHUTDOWN             30
ICMPV6-REQUEST            60
ICMPV6-REPLY              30
TCP-TIME-WAIT             2
TCP-CLOSE                 2
表1-2 display session aging-time state命令显示信息描述表
各协议的状态类型
Aging Time(s)
会话老化时间,单位为秒
·     session aging-time state
display session alg-app-change命令用来显示APP ID变更处理统计信息。
display session alg-app-change [ slot slot-number ]
context-admin
context-operator
vsys-admin
vsys-operator
slot slot-number:指定成员设备。slot-number为设备在IRF中的成员编号。如果不指定本参数,则表示所有成员设备。对于本产品,slot-number只能为固定取值,无论是否指定本参数,均表示整台设备。‌‌
# 显示APP ID变更统计信息。
<Sysname> display system internal session alg-app-change
Slot 1:
IPV4  : Failed to change session to session             : 0
IPV4  : Success to change session to session            : 0
IPV4  : Failed to change session to ext-session         : 0
IPV4  : Success to change ext-session to ext-session    : 0
IPV4  : Failed to change ext-session to ext-session     : 0
IPV4  : Success change L7 application                   : 1
        other:FileDownload:2024-03-07 11:25:4
IPV6  : Failed to change session to session             : 0
IPV6  : Success to change session to session            : 0
IPV6  : Failed to change session to ext-session         : 0
IPV6  : Success to change ext-session to ext-session    : 0
IPV6  : Failed to change ext-session to ext-session     : 0
IPV6  : Success change L7 application
表1-3 display session alg-app-change命令显示信息描述表
常规会话变更为常规会话,变更失败的会话数
常规会话变更为常规会话,变更成功的会话数。若存在变更,会详细列出会话的变更信息(变更前的APP ID: 变更后的APP ID: 变更时间)
常规会话变更为扩展会话,变更失败的会话数
常规会话变更为扩展会话,变更成功的会话数。若存在变更,会详细列出会话的变更信息(变更前的APP ID: 变更后的APP ID: 变更时间)
扩展会话变更为扩展会话,变更失败的会话数
L7 APP ID变更成功的数量。若存在变更,会详细列出会话的变更信息(变更前的APP ID: 变更后的APP ID: 变更时间)
·     reset session alg-app-change
display session dual-active transparent statistics命令用来显示双主模式下会话透传报文的统计信息。
display session dual-active transparent statistics [ slot slot-number ]
context-admin
context-operator
slot slot-number:显示指定成员设备上双主模式下会话透传报文的统计信息,slot-number表示设备在IRF中的成员编号。不指定该参数时,显示所有成员设备上双主模式下会话透传报文的统计信息。对于本产品,slot-number只能为固定取值,无论是否指定本参数,均表示整台设备。‌‌
非缺省vSystem不支持本命令。
# 显示双主模式下会话透传报文的统计信息。‌‌
<Sysname> display session dual-active transparent statistics
Slot 1:
                   UDP relay packets :                    0
                  Hash relay packets :                    0
                  Sent relay packets :                    0
              Received relay packets :                    0
    Driver-sent failed relay packets :                    0
   Transferring failed relay packets :                    0
            Processing error packets :                    0
    Driver not support relay packets :                    0
          Sent invalid relay packets :                    0
  Malloc memory failed relay packets :                    0
         Received null relay packets :                    0
      Received invalid relay packets :                    0
表1-4 display session dual-active transparent statistics命令显示信息描述表
UDP relay packets
UDP报文透传的统计数
Hash relay packets
报文按源地址哈希选板透传的统计数
Sent relay packets
设备发送透传报文的统计数
设备接收的透传报文的统计数
报文调用驱动发送失败的统计数
透传报文转换失败的统计数
报文处理错误的统计数
报文调用驱动发送空透传报文的统计数
设备发送无效透传报文的统计数
内存申请失败的统计数
设备接收的空透传报文的统计数
设备接收的无效透传报文的统计数
·     session dual-active enable
·     session statistics enable
display session fast-drop statistics命令用来显示单播丢包会话的统计信息。
display session fast-drop statistics [ summary ] [ slot slot-number ]
context-admin
context-operator
summary:显示丢包会话统计信息的概要信息。不指定该参数时,显示丢包会话统计信息的详细信息。
非缺省vSystem不支持本命令。
# 显示丢包会话的详细统计信息。‌‌
<Sysname> display session fast-drop statistics
Slot 1:
Current : 1
  Session type              Est count
           TCP :                    0
           UDP :                    0
          ICMP :                    1
        ICMPv6 :                    0
      UDP-Lite :                    0
          SCTP :                    0
          DCCP :                    0
         RAWIP :                    0
           DNS :                    0
           FTP :                    0
           GTP :                    0
          H323 :                    0
          HTTP :                    0
           ILS :                    0
          MGCP :                    0
           NBT :                    0
          PPTP :                    0
           RSH :                    0
          RTSP :                    0
          SCCP :                    0
           SIP :                    0
          SMTP :                    0
        SQLNET :                    0
           SSH :                    0
        TELNET :                    0
          TFTP :                    0
         XDMCP :                    0
Deny session establishment rate: 0/s
          TCP :                   0/s
          UDP :                   0/s
         ICMP :                   0/s
       ICMPv6 :                   0/s
     UDP-Lite :                   0/s
         SCTP :                   0/s
         DCCP :                   0/s
        RAWIP :                   0/s
表1-5 display session fast-drop statistics命令显示信息描述表
Current
系统当前的丢包会话总数
Session type
丢包会话的类型,其取值包括:
·     TCP
·     UDP
·     ICMP
·     ICMPv6
·     UDP-Lite
·     SCTP
·     DCCP
·     RAWIP
·     DNS
·     FTP
·     GTP
·     H323
·     HTTP
·     ILS
·     MGCP
·     NBT
·     PPTP
·     RSH
·     RTSP
·     SCCP
·     SIP
·     SMTP
·     SQLNET
·     SSH
·     TELNET
·     TFTP
·     XDMCP
Est count
各协议新建丢包会话的数量
系统新建丢包会话的速率
Session type
丢包会话的类型,其取值包括:
·     TCP
·     UDP
·     ICMP
·     ICMPv6
·     UDP-Lite
·     SCTP
·     DCCP
·     RAWIP
Est count
系统各协议新建丢包会话的速率
# 显示丢包会话的概要统计信息。‌‌
<Sysname> display session fast-drop statistics summary
Slot 1:
type      Sessions  TCP sessions  UDP sessions  Rate      TCP rate  UDP rate
Est       1         0             0             1/s       0/s       0/s
Try       47        0             0             1/s       0/s       0/s
表1-6 display session fast-drop statistics summary命令显示信息描述表
type
丢包会话类型,其取值包括:
·     Est:表示当前存在的丢包会话数量,随丢包会话的变化而更新,会话老化后计数减少。
·     Try:表示累积的丢包会话总数,不区分创建丢包会话成功或失败,reset后清零。
Sessions
系统当前的单播总丢包会话数
TCP sessions
系统当前的TCP单播丢包会话数
UDP sessions
系统当前的UDP单播丢包会话数
Rate
系统创建单播丢包会话的速率
TCP rate
系统创建TCP单播丢包会话的速率
UDP rate
系统创建UDP单播丢包会话的速率
display session fast-drop table ipv4命令用来显示IPv4单播丢包会话表项信息。
display session fast-drop table ipv4 [ { destination-ip start-destination-ip [ end-destination-ip ] | destination-port destination-port | protocol { dccp | icmp | raw-ip | sctp | tcp | udp | udp-lite } | source-ip start-source-ip [ end-source-ip ] | source-port source-port } * ] [ slot slot-number ] [ verbose ]
context-admin
context-operator
vsys-admin
vsys-operator
destination-ip start-destination-ip [ end-destination-ip ]:显示指定目的IPv4地址的单播丢包会话表项。其中,start-destination-ip表示目的IPv4地址范围的起始地址,end-destination-ip目的IPv4地址范围的结束地址。
destination-port destination-port:显示指定目的端口号的IPv4单播丢包会话表项。其中,destination-port表示目的端口号,取值为0~65535。
protocol { dccp | icmp | raw-ip | sctp | tcp | udp | udp-lite }:显示指定协议类型的IPv4单播丢包会话表项。其中,IPv4传输层协议类型可包括:DCCP、ICMP、RawIP、SCTP、TCP、UDP和UDP-Lite。
source-ip start-source-ip [ end-source-ip ]:显示指定源IP地址的单播丢包会话表项。其中,start-source-ip表示源IPv4地址范围的起始地址,end-source-ip表示源IPv4地址范围的结束地址。
source-port source-port:显示指定源端口号的IPv4单播丢包会话表项。其中,source-port表示源端口号,取值为0~65535。
slot slot-number:指定成员设备。slot-number为设备在IRF中的成员编号。如果不指定本参数,则表示所有成员设备。‌‌
verbose:显示IPv4单播丢包会话表项的详细信息。不指定该参数时,显示IPv4单播丢包会话表项的概要信息。
如果不指定任何参数,则显示所有的IPv4单播丢包会话表项。
# 显示所有的IPv4单播丢包会话表项的概要信息。‌‌‌
<Sysname> display session fast-drop table ipv4
Slot 1:
Initiator:
  Source      IP/port: 192.168.1.18/1877
  Destination IP/port: 192.168.1.55/22
  DS-Lite tunnel peer: -
  Protocol: TCP(6)
  Inbound interface: GigabitEthernet1/0/1
  Source security zone: Trust
Total deny session found: 1
# 显示所有的IPv4单播丢包会话表项的详细信息。‌‌‌
<Sysname> display session fast-drop table ipv4 verbose
Slot 1:
Initiator:
  Protocol: TCP(6)
Responder:
  Source      IP/port: 192.168.1.55/22
  Destination IP/port: 192.168.1.18/1877
  Protocol: TCP(6)
  Inbound interface: GigabitEthernet1/0/2
  Source security zone: Local
State: TCP_SYN_SENT
Application: SSH
Rule ID: 1
Rule name: test
Start time: 2011-07-29 19:12:36  TTL: 28s
Initiator->Responder:         1 packets         48 bytes
Responder->Initiator:         0 packets          0 bytes
表1-7 display session fast-drop table ipv4命令显示信息描述表
Initiator
发起方到响应方的连接对应的丢包会话信息
Responder
响应方到发起方的连接对应的丢包会话信息
Source IP/port
源IP地址/端口号
Destination IP/port
目的IP地址/端口号
DS-Lite tunnel peer
DS-Lite隧道对端地址。会话不属于任何DS-Lite隧道时,本字段显示为“-”
各字段含义解释如下:
·     会话所属的MPLS L3VPN
·     二层转发时会话所属的VLAN ID
·     二层转发时会话所属的INLINE
未指定的参数则显示为“-”
Protocol
传输层协议类型,取值包括:DCCP、ICMP、ICMPv6、Raw IP、SCTP、TCP、UDP、UDP-Lite
括号中的数字表示协议号
Inbound interface
报文的入接口
源安全域,即入接口所属的安全域。若接口不属于任何安全域,则显示为“-”
会话状态
Application
应用层协议类型,取值包括:FTP、DNS等,OTHER表示未知协议类型,其对应的端口为非知名端口
Rule ID
安全策略规则的ID
Rule name
安全策略规则的名称
Start time
会话创建时间
TTL
会话剩余存活时间,单位为秒
发起方到响应方的报文数、报文字节数
响应方到发起方的报文数、报文字节数
当前查找到的丢包会话表项总数
display session fast-drop table ipv6命令用来显示IPv6单播丢包会话表项信息。
display session fast-drop table ipv6 [ { destination-ip start-destination-ip [ end-destination-ip ] | destination-port destination-port | protocol { dccp | icmp | raw-ip | sctp | tcp | udp | udp-lite } | source-ip start-source-ip [ end-source-ip ] | source-port source-port } * ] [ slot slot-number ] [ verbose ]
context-admin
context-operator
vsys-admin
vsys-operator
destination-ip start-destination-ip [ end-destination-ip ]:显示指定目的IPv6地址的单播丢包会话表项。其中,start-destination-ip表示目的IPv6地址范围的起始地址,end-destination-ip目的IPv6地址范围的结束地址。
destination-port destination-port:显示指定目的端口号的IPv6单播丢包会话表项。其中,destination-port表示目的端口号,取值为0~65535。
protocol { dccp | icmp | raw-ip | sctp | tcp | udp | udp-lite }:显示指定协议类型的IPv6单播丢包会话表项。其中,IPv6传输层协议类型可包括:DCCP、ICMPv6、RawIP、SCTP、TCP、UDP和UDP-Lite。
source-ip start-source-ip [ end-source-ip ]:显示指定源IP地址的单播丢包会话表项。其中,start-source-ip表示源IPv6地址范围的起始地址,end-source-ip表示源IPv6地址范围的结束地址。
source-port source-port:显示指定源端口号的IPv6单播丢包会话表项。其中,source-port表示源端口号,取值为0~65535。
verbose:显示IPv6单播丢包会话表项的详细信息。不指定该参数时,显示IPv6单播丢包会话表项的概要信息。
如果不指定任何参数,则显示所有的IPv6单播丢包会话表项。
# 显示所有的IPv6单播丢包会话表项的概要信息。‌‌‌
<Sysname> display session fast-drop table ipv6
Slot 1:
Initiator:
  Source      IP/port: 2011::2/58473
  Destination IP/port: 2011::8/32768
  Protocol: TCP(6)
# 显示所有的IPv6单播丢包会话表项的详细信息。‌‌‌
<Sysname> display session fast-drop table ipv6 verbose
Slot 1:
Initiator:
  Protocol: TCP(6)
Responder:
  Protocol: TCP(6)
State: TCP_SYN_SENT
Application: SSH
Rule ID: 1
Rule name: test
表1-8 display session fast-drop table ipv6命令显示信息描述表
Initiator
发起方到响应方的连接对应的丢包会话信息
Responder
响应方到发起方的连接对应的丢包会话信息
Source IP/port
源IP地址/端口号
Destination IP/port
目的IP地址/端口号
DS-Lite tunnel peer
各字段含义解释如下:
·     会话所属的MPLS L3VPN
·     二层转发时会话所属的VLAN ID
·     二层转发时会话所属的INLINE
未指定的参数则显示为“-”
Protocol
括号中的数字表示协议号
Inbound interface
报文的入接口
会话状态
Application
Rule ID
安全策略规则的ID
Rule name
安全策略规则的名称
Start time
会话创建时间
TTL
会话剩余存活时间,单位为秒
发起方到响应方的报文数、报文字节数
响应方到发起方的报文数、报文字节数
当前查找到的丢包会话表项总数
display session fast-drop top-statistics命令用来显示丢包会话数目的Top的排名统计信息。
display session fast-drop top-statistics { last-1-hour | last-24-hours | last-30-days }
context-admin
context-operator
last-1-hour:显示最近1小时的丢包会话数目的Top排名统计信息。
last-24-hours:显示最近24小时的丢包会话数目的Top排名统计信息。
last-30-days:显示最近30天的丢包会话
非缺省vSystem不支持本命令。
未开启丢包会话数目的TOP排名统计功能时,统计信息为空。
# 显示全局Top的丢包会话信息。
<Sysname> display session fast-drop top-statistics last-1-hour
Counting by source addresses:
No.      Source address          Sessions
1        8.1.1.1                 6085
2        111.15.111.16           10
3        6::2                    2
Counting by destination addresses:
No.      Destination address     Sessions
1        8.1.1.2                 6085
2        6::3                    2
3        30.1.1.8                1
4        30.1.1.4                1
5        30.1.1.11               1
6        30.1.1.9                1
7        30.1.1.6                1
8        30.1.1.5                1
9        30.1.1.7                1
10       30.1.1.3                1
表1-9 display session fast-drop top-statistics命令显示信息描述表
基于源IP地址的丢包会话数目Top 的排名统计信息
基于目的IP地址的丢包会话数目Top 的排名统计信息
No.
Top 排名
Source address
丢包会话的源IP地址
Destination address
丢包会话的目的IP地址
Sessions
丢包会话数目
·     session fast-drop enable
·     session fast-drop top-statistics enable
display session ip-top-count policy命令用于显示IPv4会话数据Top排名统计策略的配置内容。
context-admin
context-operator
vsys-admin
vsys-operator
# 显示IPv4会话数据Top排名统计策略的配置内容
[Sysname] display session ip-top-count policy
Top IPv4 session statistics policy:
  Source IP Subnet: 1.1.1.0 24
  Destination IP Subnet: 2.2.2.0 24
表1-10 display session ip-top-count policy命令显示信息描述表
Source IP subnet
表示IPv4会话数据Top排名统计策略源IP地址过滤条件
Destination IP subnet
表示IPv4会话数据Top排名统计策略目的IP地址过滤条件
display session ipv6-top-count policy命令用于显示IPv6会话数据Top排名统计策略的配置内容。
context-admin
context-operator
vsys-admin
vsys-operator
#显示IPv6会话数据Top排名统计策略的配置内容
[Sysname] display session ipv6-top-count policy
Top IPv6 session statistics policy:
  Source IPv6 Subnet: 1234::ss96
  Destination IPv6 Subnet: 5678::96
表1-11 display session ipv6-top-count policy命令显示信息描述表
Source IP subnet
表示IPv6会话数据Top排名统计策略源IP地址过滤条件
表示IPv6会话数据Top排名统计策略目的IP地址过滤条件
display session relation-table命令用来显示关联表项信息。
display session relation-table { ipv4 | ipv6 } [ slot slot-number ] [ count number ] [ { application application-name | destination-ip destination-ip | destination-port destination-port | protocol { dccp | icmp | raw-ip | sctp | tcp | udp | udp-lite } | source-ip source-ip | source-port source-port } * ]
context-admin
context-operator
vsys-admin
vsys-operator
ipv4:显示IPv4关联表项。
ipv6:显示IPv6关联表项。
slot slot-number:显示指定成员设备上的关联表项信息,slot-number表示设备在IRF中的成员编号。不指定该参数时,显示所有成员设备上的关联表项信息。对于本产品,slot-number只能为固定取值,无论是否指定本参数,均表示整台设备。‌‌
count number:显示指定个数的关联表项信息,number表示显示的关联表项个数,取值范围为1~100000。
application application-name:显示指定应用的关联表项。application-name表示应用的名称,为1~63个字符的字符串,不区分大小写,不允许为系统保留的“invalid”和“other”。
destination-ip destination-ip:显示指定目的IP地址的关联表项。其中, destination-ip表示目的IP地址。
destination-port destination-port:显示指定目的端口号的关联表项。其中,destination-port表示目的端口号,取值范围为0~65535。
protocol { dccp | icmp | raw-ip | sctp | tcp | udp | udp-lite }:显示指定协议类型的关联表项。其中,传输层协议类型可包括:DCCP、ICMP、RawIP、SCTP、TCP、UDP和UDP-Lite。
source-ip source-ip:显示指定源IP地址的关联表项。其中,source-ip表示源IP地址。
source-port source-port:显示指定源端口号的IPv4关联表项。其中,source-port表示源端口号,取值范围为0~65535。
# 显示所有的IPv4关联表项。‌‌
<Sysname> display session relation-table ipv4
Slot 1:
Source IP/port:      192.168.1.100/-
Destination IP/port: 192.168.2.100/99
VPN instance/VLAN ID/Inline ID: 1/-/-
Protocol: TCP(6)    TTL: 1234s
Application: FTP-DATA
Source IP/port:      -/-
Destination IP/port: 192.168.2.200/1212
Protocol: TCP(6)    TTL: 3100s
Application: H225
Source IP/port:       10.1.1.2/-
Destination IP/port: 30.1.1.4/10000
Protocol: UDP(17)    TTL: 266s
Application: RTP
CallID: [email protected]
Total entries found:  3
# 显示所有的IPv6关联表项。‌‌
<Sysname> display session relation-table ipv6
Slot 1:
Source IP:             2011::0002
Destination IP/port: 2011::0008/1212
Protocol: TCP(6)    TTL: 567s
Total entries found:  1
# 显示所有源IP地址为192.168.1.100的IPv4关联表项。‌‌
<Sysname> display session relation-table ipv4 source-ip 192.168.1.100
Slot 1:
表1-12 display session relation-table命令显示信息描述表
Source IP/port
会话的源IP地址和端口号。如果未指定则显示“-/-”
IPv6会话无源端口号字段
Destination IP/port
会话的目的IP地址/端口号
DS-Lite tunnel peer
会话所属的DS-Lite隧道对端地址。未指定的参数则显示为“-”
VPN instance/VLAN ID/ Inline ID
各字段含义解释如下:
·     关联表项所属的MPLS L3VPN
·     二层转发时会话所属的VLAN ID
·     二层转发时会话所属的INLINE
未指定的参数则显示为“-”
Protocol
传输层协议类型
TTL
关联表的剩余存活时间,单位为秒
Application
应用层协议类型
CallID
唯一标识一个SIP通话的ID号
Total entries found
当前查找到的关联表总数
display session relation-table aging-time application命令用来显示会话关联表的老化时间。
context-admin
# 显示SUNRPC协议会话关联表的老化时间。
<Sysname> display session relation-table aging-time application
  SUNRPC                    14400
表1-13 display session relation-table aging-time application命令显示信息描述表
Application
应用层协议名称,仅支持SUNRPC协议
Aging time(s)
会话关联表的老化时间,单位为秒
display session statistics命令用来显示单播会话统计信息。
display session statistics [ history-max | summary ] [ slot slot-number ]
context-admin
context-operator
vsys-admin
vsys-operator
history-max:显示单播历史会话数最大值和历史新建会话速率最大值的统计信息。
summary:显示会话单播统计信息的概要信息。不指定该参数时,显示单播会话统计信息的详细信息。
slot slot-number:显示指定成员设备上的单播会话统计信息,slot-number表示设备在IRF中的成员编号。不指定该参数时,显示所有成员设备上的单播会话统计信息。‌‌
若不指定任何参数,则显示当前单播会话统计信息的详细信息。
# 显示所有单播会话统计信息的详细信息。
<Sysname> display session statistics
Slot 1:
Current sessions: 3
          TCP sessions:                    0
          UDP sessions:                    0
         ICMP sessions:                    3
       ICMPv6 sessions:                    0
     UDP-Lite sessions:                    0
         SCTP sessions:                    0
         DCCP sessions:                    0
        RAWIP sessions:                    0
          DNS sessions:                    0
          FTP sessions:                    0
          GTP sessions:                    0
         H323 sessions:                    0
         HTTP sessions:                    0
          ILS sessions:                    0
         MGCP sessions:                    0
          NBT sessions:                    0
         PPTP sessions:                    0
          RSH sessions:                    0
         RTSP sessions:                    0
         SCCP sessions:                    0
          SIP sessions:                    0
         SMTP sessions:                    0
       SQLNET sessions:                    0
          SSH sessions:                    0
       SUNRPC sessions:                    0
       TELNET sessions:                    0
         TFTP sessions:                    0
        XDMCP sessions:                    0
History average sessions per second:
      Past hour: 1
      Past 24 hours: 0
      Past 30 days: 0
History average session establishment rate:
      Past hour: 0/s
      Past 24 hours: 0/s
      Past 30 days: 0/s
Current relation-table entries: 0
Relation table establishment rate: 0/s
Session establishment rate: 0/s
          TCP:                   0/s
          UDP:                   0/s
         ICMP:                   0/s
       ICMPv6:                   0/s
     UDP-Lite:                   0/s
         SCTP:                   0/s
         DCCP:                   0/s
        RAWIP:                   0/s
Received TCP      :                   0 packets                    0 bytes
Received UDP      :                 118 packets                13568 bytes
Received ICMP     :                 105 packets                 8652 bytes
Received ICMPv6   :                   0 packets                    0 bytes
Received UDP-Lite :                   0 packets                    0 bytes
Received SCTP     :                   0 packets                    0 bytes
Received DCCP     :                   0 packets                    0 bytes
Received RAWIP    :                   0 packets                    0 bytes
表1-14 display session statistics命令显示信息描述表
Current sessions
系统当前的总会话数
TCP sessions
系统当前的TCP会话数
UDP sessions
系统当前的UDP会话数
ICMP sessions
系统当前的ICMP会话数
ICMPv6 sessions
系统当前的ICMPv6会话数
UDP-Lite sessions
系统当前的UDP-Lite会话数
SCTP sessions
系统当前的SCTP会话数
DCCP sessions
系统当前的DCCP会话数
RAWIP sessions
系统当前的Raw IP会话数
DNS sessions
系统当前的DNS会话数
FTP sessions
系统当前的FTP会话数
GTP sessions
系统当前的GTP会话数
H323 sessions
系统当前的H323会话数
HTTP sessions
系统当前的HTTP会话数
ILS sessions
系统当前的ILS会话数
MGCP sessions
系统当前的MGCP会话数
NBT sessions
系统当前的NBT会话数
PPTP sessions
系统当前的PPTP会话数
RSH sessions
系统当前的RSH会话数
RTSP sessions
系统当前的RTSP会话数
SCCP sessions
系统当前的SCCP会话数
SIP sessions
系统当前的SIP会话数
SMTP sessions
系统当前的SMTP会话数
SQLNET sessions
系统当前的SQLNET会话数
SSH sessions
系统当前的SSH会话数
SUNRPC sessions
系统当前的SUNRPC会话数
TELNET sessions
系统当前的TELNET会话数
TFTP sessions
系统当前的TFTP会话数
XDMCP sessions
系统当前的XDMCP会话数
会话数的历史统计信息,以当前时间为基准
Past hour
最近一小时内每秒钟系统会话数目的平均值
Past 24 hours
最近一天内每秒钟系统会话数目的平均值
Past 30 days
最近三十天内每秒钟系统会话数目的平均值
新建会话速率的历史统计信息,以当前时间为基准
Past hour
最近一小时内系统新建会话速率的平均值
Past 24 hours
最近一天内系统新建会话速率的平均值
Past 30 days
最近三十天内系统新建会话速率的平均值
总关联表项个数
关联表创建速率
系统创建会话的速率,以及创建各协议会话的速率
Received TCP
系统当前收到的TCP报文数、报文字节数
Received UDP
系统当前收到的UDP报文数、报文字节数
Received ICMP
系统当前收到的ICMP报文数、报文字节数
Received ICMPv6
系统当前收到的ICMPv6报文数、报文字节数
Received UDP-Lite
系统当前收到的UDP-Lite报文数、报文字节数
Received SCTP
系统当前收到的SCTP报文数、报文字节数
Received DCCP
系统当前收到的DCCP报文数、报文字节数
Received RAWIP
系统当前收到的Raw IP报文数、报文字节数
# 显示单播会话统计信息的概要信息。‌‌
<Sysname> display session statistics summary
Slot Sessions  TCP       UDP       Rate      TCP rate  UDP rate
1    3         0         0         0/s       0/s       0/s
表1-15 display session statistics summary命令显示信息描述表
Sessions
系统当前的单播总会话数
TCP
系统当前的TCP单播会话数
UDP
系统当前的UDP单播会话数
Rate
系统创建单播会话的速率
TCP rate
系统创建TCP单播会话的速率
UDP rate
系统创建UDP单播会话的速率
# 显示单播会话历史会话数最大值和历史新建会话速率最大值的统计信息。‌‌
<Sysname> display session statistics history-max
Slot 1
Max sessions: 20084                            Time: 2017-03-04 12:03:53
Max session establishment rate: 9080/s         Time: 2017-03-04 12:03:53
Max TCP sessions: 20084                        Time: 2017-03-04 12:03:53
Max TCP session establishment rate: 9080/s     Time: 2017-03-04 12:03:53
Max UDP sessions: 0                            Time: 2017-03-04 12:03:53
Max UDP session establishment rate:0           Time: 2017-03-04 12:03:53
表1-16 display session statistics history-max命令显示信息描述表
Max sessions
系统历史单播会话数目的最大值
系统历史新建单播会话速率的最大值,单位为:个/秒
Max TCP sessions
系统历史TCP单播会话数目的最大值
系统历史新建TCP单播会话速率的最大值,单位为:个/秒
Max UDP sessions
系统历史UDP单播会话数目的最大值
系统历史新建UDP单播会话速率的最大值,单位为:个/秒
display session statistics flow-redirect命令用来显示引流会话的相关统计信息。
display session statistics flow-redirect { message | packet | session } [ slot slot-number cpu cpu-number ]
本命令的支持情况与设备型号有关,请以设备的实际情况为准。
系列
型号
F5000系列
F5000-CN160、F5000-AI360、F5000-AI160、F5000-AI120、F5000-E、F5000-AI-160-G、F5000-AI-130-G、F5000-AI-110-G、F5000-CN160-G、F5000-E-G、F5000-E-G2
支持
F5080、F5060、F5030、F5000-CN-G85、F5000-CN-G65、F5000-CN-G55、F5000-AI-120-G、F5000-AI-55-G、F5000-AI-25-G、F5000-AI-15-G、F5000-S-G2、F5000-M-G2、F5000-A-G2、F5000-AI-15
不支持
F1000系列
F1000-AI-90、F1000-AI-80、F1000-AI-75、F1000-AI-70、F1000-AI-65、F1000-AI-60、F1000-AI-55、F1000-AI-35、F1000-AI-25、F1000-AI-15、F1000-AI-10、F1000-AI-05、F1000-AK9130、F1000-AI-90-G、F1000-AI-80-G、F1000-AI-75-G、F1000-AI-65-G、F1000-AI-55-G、F1000-AI-35-G、F1000-AI-25-G、F1000-AI-15-G、F1000-AI-05-G、F1000-AI-03-G、F1000-AI-05-GS、F1000-AI-03-E、F1000-AK1380-G、F1000-AK1300-G、F1000-AK1220-G、F1000-AK1180-G、F1000-AK1080-G、F1000-AK1050-G、F1000-V90、F1000-V60、F1000-V50
不支持
插卡
LSEM1FWESD0、LSXM1FWDF1、LSUM1FWDEC0、IM-NGFWX-IV、LSQM1FWDSC0、LSWM1FWD0、LSPM6FWD、LSPM6FWDB、LSCM1FWDSD0
不支持
context-admin
context-operator
message:显示引流会话消息的统计信息。
packet:显示引流会话接收和发送报文的统计信息。
session:显示引流会话同步的统计信息。
slot slot-number:显示指定单板上的引流会话的相关统计信息,slot-number表示单板所在槽位号。若不指定该参数时,显示所有单板上的引流会话的相关统计信息。‌
非缺省vSystem不支持本命令。
由会话引流功能产生的会话,称作“引流会话”。
仅在开启会话引流功能后,执行此命令才有统计信息。
# 显示引流会话消息的统计信息。‌
<Sysname> display session statistics flow-redirect message
Slot CPU RecvMsg      SentMsg
0    1   90           2
1    1   2            90
5    0   0            0
0    0   0            0
4    1   10           3
5    1   4            10
表1-17 display session statistics flow-redirect message命令显示信息描述表
RecvMsg
接收的引流会话消息的数目
SentMsg
发送的引流会话消息的数目
# 显示引流会话接收和发送报文的统计信息。‌
<Sysname> display session statistics flow-redirect packet
Slot CPU RecvPkts     SentPkts
0    1   90           2
1    1   2            90
5    0   0            0
0    0   0            0
4    1   10           3
5    1   4            10
表1-18 display session statistics flow-redirect packet命令显示信息描述表
RecvPkts
引流会话接收报文的数目
SentPkts
引流会话发送报文的数目
# 显示引流会话同步的统计信息。‌
<Sysname> display session statistics flow-redirect session
Slot CPU Out       Resent      In      InRate InHotback    InHotbackRate
0    1   0         7           0       0      0            0
1    1   7         0           1       0      0            0
5    0   0         0           0       0      0            0
0    0   0         0           0       0      0            0
4    1   0         571         2       0      0            0
5    1   571       0           0       0      1            0
表1-19 display session statistics flow-redirect session命令显示信息描述表
Out
发送引流会话的数目
Resent
重复发送引流会话的数目
In
接收的引流会话的数目
InRate
接收的引流会话的新建速率
InHotback
接收的热备会话的数目
InHotbackRate
接收的热备会话的新建速率
·     session flow-redirect enable
display session statistics ipv4命令用来根据五元组显示IPv4单播会话统计信息。
display session statistics ipv4 [ [ responder ] { application application-name | destination-ip destination-ip | destination-port destination-port | destination-zone destination-zone-name | interface interface-type interface-number | protocol { dccp | dns | ftp | gtp | h323 | http | icmp | ils | mgcp | nbt | pptp | raw-ip | rsh | rtsp | sccp | sctp | sip | smtp | sqlnet | ssh | tcp | telnet | tftp | udp | udp-lite | xdmcp } | security-policy-rule rule-name | source-ip source-ip | source-port source-port | source-zone source-zone-name | state { dccp-closereq | dccp-closing | dccp-open | dccp-partopen | dccp-request | dccp-respond | dccp-timewait | icmp-reply | icmp-request | rawip-open | rawip-ready | sctp-closed | sctp-cookie-echoed | sctp-cookie-wait | sctp-established | sctp-shutdown-ack-sent | sctp-shutdown-recd | sctp-shutdown-sent | tcp-close | tcp-close-wait | tcp-est | tcp-fin-wait | tcp-last-ack | tcp-syn-recv | tcp-syn-sent | tcp-syn-sent2 | tcp-time-wait | udp-open | udp-ready | udplite-open | udplite-ready } | vpn-instance vpn-instance-name } * ] [ slot slot-number ]
context-admin
context-operator
vsys-admin
vsys-operator
responder:表示以响应方的信息筛选显示IPv4单播会话统计信息。若不指定该参数时,则以发起方的信息筛选显示IPv4单播会话统计信息。
application application-name:显示指定应用的IPv4单播会话统计信息。application-name表示应用的名称,为1~63个字符的字符串,不区分大小写,不允许为系统保留的“invalid”和“other”。
destination-ip destination-ip:显示指定目的IPv4地址的单播会话统计信息。其中,destination-ip表示IPv4地址。
destination-port destination-port:显示指定目的端口号的IPv4单播会话表项。其中,destination-port表示端口号,取值为0~65535。
destination-zone destination-zone-name:显示指定目的安全域的IPv4单播会话统计信息。其中destination-zone-name表示安全域的名称,安全域的名称为1~31个字符的字符串,不区分大小写。
interface interface-type interface-num:显示指定接口的IPv4单播会话统计信息。interface-type interface-number表示接口类型和接口编号。
protocol { dccp | dns | ftp | gtp | h323 | http | icmp | ils | mgcp | nbt | pptp | raw-ip | rsh | rtsp | sccp | sctp | sip | smtp | sqlnet | ssh | tcp | telnet | tftp | udp | udp-lite | xdmcp }:显示指定协议类型的IPv4单播会话表项。
security-policy-rule rule-name:显示与指定安全策略规则匹配的IPv4单播会话统计信息 rule-name表示安全策略规则名称,为1~127个字符的字符串,区分大小写。
source-ip source-ip:显示指定源IP地址的单播会话统计信息。其中,source-ip表示IPv4地址。
source-port source-port:显示指定源端口号的IPv4单播会话表项。其中,source-port表示端口号,取值为0~65535。
source-zone source-zone-name:显示指定源安全域的IPv4单播会话统计信息。其中source-zone-name表示安全域的名称,安全域的名称为1~31个字符的字符串,不区分大小写。
state { dccp-closereq | dccp-closing | dccp-open | dccp-partopen | dccp-request | dccp-respond | dccp-timewait | icmp-reply | icmp-request | rawip-open | rawip-ready | sctp-closed | sctp-cookie-echoed | sctp-cookie-wait | sctp-established | sctp-shutdown-ack-sent | sctp-shutdown-recd | sctp-shutdown-sent | tcp-close | tcp-close-wait | tcp-est | tcp-fin-wait | tcp-last-ack | tcp-syn-recv | tcp-syn-sent | tcp-syn-sent2 | tcp-time-wait | udp-open | udp-ready | udplite-open | udplite-ready }:显示指定状态的IPv4单播会话统计信息。
vpn-instance vpn-instance-name:显示指定VPN实例的IPv4单播会话统计信息。vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。若不指定此参数,则显示公网的IPv4单播会话统计信息。
如果不指定任何参数,则显示所有的IPv4单播会话统计信息。
# 根据源IP地址111.15.111.66显示单播会话统计信息的详细信息。
<Sysname> display session statistics ipv4 source-ip 111.15.111.66
Slot 1:
Current sessions: 3
          TCP sessions:                    0
          UDP sessions:                    0
         ICMP sessions:                    3
         SCTP sessions:                    0
         DCCP sessions:                    0
        RAWIP sessions:                    0
          DNS sessions:                    0
          FTP sessions:                    0
          GTP sessions:                    0
         H323 sessions:                    0
         HTTP sessions:                    0
          ILS sessions:                    0
         MGCP sessions:                    0
          NBT sessions:                    0
         PPTP sessions:                    0
          RSH sessions:                    0
         RTSP sessions:                    0
         SCCP sessions:                    0
          SIP sessions:                    0
         SMTP sessions:                    0
       SQLNET sessions:                    0
          SSH sessions:                    0
       TELNET sessions:                    0
         TFTP sessions:                    0
        XDMCP sessions:                    0
# 根据TCP协议显示单播会话统计信息的详细信息。
<Sysname> display session statistics ipv4 protocol tcp
Slot 1:
Current sessions: 3
          TCP sessions:                    3
表1-20 display session statistics ipv4命令显示信息描述表
Current sessions
系统当前的总会话数
TCP sessions
系统当前的TCP会话数
UDP sessions
系统当前的UDP会话数
ICMP sessions
系统当前的ICMP会话数
UDP-Lite sessions
系统当前的UDP-Lite会话数
SCTP sessions
系统当前的SCTP会话数
DCCP sessions
系统当前的DCCP会话数
RAWIP sessions
系统当前的Raw IP会话数
DNS sessions
系统当前的DNS会话数
FTP sessions
系统当前的FTP会话数
GTP sessions
系统当前的GTP会话数
H323 sessions
系统当前的H323会话数
HTTP sessions
系统当前的HTTP会话数
ILS sessions
系统当前的ILS会话数
MGCP sessions
系统当前的MGCP会话数
NBT sessions
系统当前的NBT会话数
PPTP sessions
系统当前的PPTP会话数
RSH sessions
系统当前的RSH会话数
RTSP sessions
系统当前的RTSP会话数
SCCP sessions
系统当前的SCCP会话数
SIP sessions
系统当前的SIP会话数
SMTP sessions
系统当前的SMTP会话数
SQLNET sessions
系统当前的SQLNET会话数
SSH sessions
系统当前的SSH会话数
TELNET sessions
系统当前的TELNET会话数
TFTP sessions
系统当前的TFTP会话数
XDMCP sessions
系统当前的XDMCP会话数
display session statistics ipv6命令用来根据五元组显示IPv6单播会话统计信息。
display session statistics ipv6 [ [ responder ] { application application-name | destination-ip destination-ip | destination-port destination-port | destination-zone destination-zone-name | interface interface-type interface-number | protocol { dccp | dns | ftp | gtp | h323 | http | icmpv6 | ils | mgcp | nbt | pptp | raw-ip | rsh | rtsp | sccp | sctp | sip | smtp | sqlnet | ssh | tcp | telnet | tftp | udp | udp-lite | xdmcp } | security-policy-rule rule-name | source-ip source-ip | source-port source-port | source-zone source-zone-name | state { dccp-closereq | dccp-closing | dccp-open | dccp-partopen | dccp-request | dccp-respond | dccp-timewait | icmpv6-reply | icmpv6-request | rawip-open | rawip-ready | sctp-closed | sctp-cookie-echoed | sctp-cookie-wait | sctp-established | sctp-shutdown-ack-sent | sctp-shutdown-recd | sctp-shutdown-sent | tcp-close | tcp-close-wait | tcp-est | tcp-fin-wait | tcp-last-ack | tcp-syn-recv | tcp-syn-sent | tcp-syn-sent2 | tcp-time-wait | udp-open | udp-ready | udplite-open | udplite-ready } | vpn-instance vpn-instance-name } * ] [ slot slot-number ]
context-admin
context-operator
vsys-admin
vsys-operator
responder:表示以响应方的信息筛选显示IPv6单播会话统计信息。若不指定该参数时,则以发起方的信息筛选显示IPv6单播会话统计信息。
application application-name:显示指定应用的IPv6单播会话统计信息。application-name表示应用的名称,为1~63个字符的字符串,不区分大小写,不允许为系统保留的“invalid”和“other”。
destination-ip destination-ip:显示指定目的IPv6地址的单播会话统计信息。其中,destination-ip表示IPv6地址。
destination-port destination-port:显示指定目的端口号的IPv6单播会话表项。其中,destination-port表示端口号,取值为0~65535。
destination-zone destination-zone-name:显示指定目的安全域的IPv6单播会话统计信息。其中destination-zone-name表示安全域的名称,安全域的名称为1~31个字符的字符串,不区分大小写。
interface interface-type interface-num:显示指定接口的IPv6单播会话统计信息。interface-type interface-number表示接口类型和接口编号。
protocol { dccp | dns | ftp | gtp | h323 | http | icmpv6 | ils | mgcp | nbt | pptp | raw-ip | rsh | rtsp | sccp | sctp | sip | smtp | sqlnet | ssh | tcp | telnet | tftp | udp | udp-lite | xdmcp }:显示指定协议类型的IPv6单播会话表项。
security-policy-rule rule-name:显示与指定安全策略规则匹配的IPv6单播会话统计信息 rule-name表示安全策略规则名称,为1~127个字符的字符串,区分大小写。
source-ip source-ip:显示指定源IP地址的单播会话统计信息。其中,source-ip表示IPv6地址。
source-port source-port:显示指定源端口号的IPv6单播会话表项。其中,source-port表示端口号,取值为0~65535。
source-zone source-zone-name:显示指定源安全域的IPv6单播会话统计信息。其中source-zone-name表示安全域的名称,安全域的名称为1~31个字符的字符串,不区分大小写。
state { dccp-closereq | dccp-closing | dccp-open | dccp-partopen | dccp-request | dccp-respond | dccp-timewait | icmpv6-reply | icmpv6-request | rawip-open | rawip-ready | sctp-closed | sctp-cookie-echoed | sctp-cookie-wait | sctp-established | sctp-shutdown-ack-sent | sctp-shutdown-recd | sctp-shutdown-sent | tcp-close | tcp-close-wait | tcp-est | tcp-fin-wait | tcp-last-ack | tcp-syn-recv | tcp-syn-sent | tcp-syn-sent2 | tcp-time-wait | udp-open | udp-ready | udplite-open | udplite-ready }:显示指定状态的IPv6单播会话统计信息。
vpn-instance vpn-instance-name:显示指定VPN实例的IPv6单播会话统计信息。vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。若不指定此参数,则显示公网的IPv6单播会话统计信息。
# 根据源IPv6地址100::2显示单播会话统计信息的详细信息。
<Sysname> display session statistics ipv6 source-ip 100::2
Slot 1:
Current sessions: 3
          TCP sessions:                    0
          UDP sessions:                    0
       ICMPv6 sessions:                    3
         SCTP sessions:                    0
         DCCP sessions:                    0
        RAWIP sessions:                    0
          DNS sessions:                    0
          FTP sessions:                    0
          GTP sessions:                    0
         H323 sessions:                    0
         HTTP sessions:                    0
          ILS sessions:                    0
         MGCP sessions:                    0
          NBT sessions:                    0
         PPTP sessions:                    0
          RSH sessions:                    0
         RTSP sessions:                    0
         SCCP sessions:                    0
          SIP sessions:                    0
         SMTP sessions:                    0
       SQLNET sessions:                    0
          SSH sessions:                    0
       TELNET sessions:                    0
         TFTP sessions:                    0
        XDMCP sessions:                    0
<Sysname> display session statistics ipv6 protocol tcp
Slot 1:
Current sessions: 3
          TCP sessions:                    3
表1-21  display session statistics ipv6命令显示信息描述表
Current sessions
系统当前的总会话数
TCP sessions
系统当前的TCP会话数
UDP sessions
系统当前的UDP会话数
ICMPv6 sessions
系统当前的ICMPv6会话数
UDP-Lite sessions
系统当前的UDP-Lite会话数
SCTP sessions
系统当前的SCTP会话数
DCCP sessions
系统当前的DCCP会话数
RAWIP sessions
系统当前的Raw IP会话数
DNS sessions
系统当前的DNS会话数
FTP sessions
系统当前的FTP会话数
GTP sessions
系统当前的GTP会话数
H323 sessions
系统当前的H323会话数
HTTP sessions
系统当前的HTTP会话数
ILS sessions
系统当前的ILS会话数
MGCP sessions
系统当前的MGCP会话数
NBT sessions
系统当前的NBT会话数
PPTP sessions
系统当前的PPTP会话数
RSH sessions
系统当前的RSH会话数
RTSP sessions
系统当前的RTSP会话数
SCCP sessions
系统当前的SCCP会话数
SIP sessions
系统当前的SIP会话数
SMTP sessions
系统当前的SMTP会话数
SQLNET sessions
系统当前的SQLNET会话数
SSH sessions
系统当前的SSH会话数
TELNET sessions
系统当前的TELNET会话数
TFTP sessions
系统当前的TFTP会话数
XDMCP sessions
系统当前的XDMCP会话数
display session statistics multicast命令用来显示组播会话统计信息。
display session statistics multicast [ slot slot-number ]
context-admin
context-operator
vsys-admin
vsys-operator
slot slot-number:显示指定成员设备上的组播会话统计信息,slot-number表示设备在IRF中的成员编号。若不指定该参数,则表示显示所有成员设备上的组播会话统计信息。对于本产品,slot-number只能为固定取值,无论是否指定本参数,均表示整台设备。‌‌
# 显示组播会话统计信息。‌‌
<Sysname> display session statistics multicast
Slot 1:
Current sessions: 0
History max sessions: 0                                Time: 2017-04-25 11:28:00
History max session establishment rate: 0/s            Time: 2017-04-25 11:28:00
Received:                   0 packets                    0 bytes
Sent    :                   0 packets                    0 bytes
表1-22 display session statistics multicast命令显示信息描述表
Current sessions
系统当前为业务流量创建的组播会话数
系统创建组播会话的速率
系统历史组播会话数目的最大值
系统创建组播会话历史速率的最大值
Time
各个最大值对应的时间
Received
系统当前收到的组播报文数、报文字节数
Sent
系统当前发出的组播报文数、报文字节数
display session statistics summary all命令用来显示设备整机的会话统计概要信息。
context-admin
context-operator
vsys-admin
vsys-operator
# 显示设备整机的会话统计概要信息。
[Sysname] display session statistics summary all
Total sessions  Session creation rate
10              0
表1-23 display session statistics summary all命令显示信息描述表
Total sessions
设备整机当前的总会话数
设备整机的会话新建速率
·     display session statistics summary
display session table ipv4命令用来显示IPv4单播会话表项信息。
display session table ipv4 [ slot slot-number ] [ [ responder ] { application application-name | destination-ip start-destination-ip [ end-destination-ip ] | destination-port start-destination-port [ end-destination-port ] | destination-zone destination-zone-name | interface interface-type interface-number | protocol { dccp | icmp | raw-ip | sctp | tcp | udp | udp-lite } | security-policy-rule rule-name | security-policy-rule-id rule-id | source-ip start-source-ip [ end-source-ip ] | source-port start-source-port [ end-source-port ] | source-zone source-zone-name | state { dccp-closereq | dccp-closing | dccp-open | dccp-partopen | dccp-request | dccp-respond | dccp-timewait | icmp-reply | icmp-request | rawip-open | rawip-ready | sctp-closed | sctp-cookie-echoed | sctp-cookie-wait | sctp-established | sctp-shutdown-ack-sent | sctp-shutdown-recd | sctp-shutdown-sent | tcp-close | tcp-close-wait | tcp-est | tcp-fin-wait | tcp-last-ack | tcp-syn-recv | tcp-syn-sent | tcp-syn-sent2 | tcp-time-wait | udp-open | udp-ready | udplite-open | udplite-ready } | vpn-instance vpn-instance-name } * ] [ verbose | brief ]
context-admin
context-operator
vsys-admin
vsys-operator
slot slot-number:显示指定成员设备上的IPv4单播会话表项,slot-number表示设备在IRF中的成员编号。不指定该参数时,显示所有成员设备上的IPv4单播会话表项。‌‌
responder:表示以响应方的信息筛选显示IPv4单播会话表项。若不指定该参数时,则以发起方的信息筛选显示IPv4单播会话表项。
application application-name:显示指定应用的IPv4单播会话表项。application-name表示应用的名称,为1~63个字符的字符串,不区分大小写,不允许为系统保留的“invalid”和“other”。
destination-ip start-destination-ip [ end-destination-ip ]:显示指定目的IPv4地址的单播会话表项。其中,start-destination-ip表示目的IPv4地址范围的起始地址,end-destination-ip目的IPv4地址范围的结束地址。
destination-port start-destination-port [ end-destination-port ]:显示指定目的端口号的IPv4单播会话表项。其中,start-destination-port表示目的端口的起始端口号,end-destination-port表示目的端口的结束端口号,取值范围为0~65535。
destination-zone destination-zone-name:显示指定目的安全域的IPv4单播会话表项。其中destination-zone-name表示安全域的名称,安全域的名称为1~31个字符的字符串,不区分大小写。
interface interface-type interface-number:显示指定接口的IPv4单播会话表项。interface-type interface-number表示接口类型和接口编号。
protocol { dccp | icmp | raw-ip | sctp | tcp | udp | udp-lite }:显示指定协议类型的IPv4单播会话表项。其中,IPv4传输层协议类型可包括:DCCP、ICMP、RawIP、SCTP、TCP、UDP和UDP-Lite。
security-policy-rule rule-name:显示与指定安全策略规则匹配的IPv4单播会话表项。rule-name为安全策略规则的名称,为1~127个字符的字符串,区分大小写。
security-policy-rule-id rule-id:显示与指定安全策略规则ID匹配的IPv4单播会话表项。rule-id为安全策略规则的ID,取值为0~4294967295。
source-ip start-source-ip [ end-source-ip ]:显示指定源IP地址的单播会话表项。其中,start-source-ip表示源IPv4地址范围的起始地址,end-source-ip表示源IPv4地址范围的结束地址。
source-port start-source-port [ end-source-port ]:显示指定源端口号的IPv4单播会话表项。其中,start-source-port表示源端口的起始端口号,end-source-port表示源端口的结束端口号,取值范围为0~65535。
source-zone source-zone-name:显示指定源安全域的IPv4单播会话表项。其中source-zone-name表示安全域的名称,安全域的名称为1~31个字符的字符串,不区分大小写。
state { dccp-closereq | dccp-closing | dccp-open | dccp-partopen | dccp-request | dccp-respond | dccp-timewait | icmp-reply | icmp-request | rawip-open | rawip-ready | sctp-closed | sctp-cookie-echoed | sctp-cookie-wait | sctp-established | sctp-shutdown-ack-sent | sctp-shutdown-recd | sctp-shutdown-sent | tcp-close | tcp-close-wait | tcp-est | tcp-fin-wait | tcp-last-ack | tcp-syn-recv | tcp-syn-sent | tcp-syn-sent2 | tcp-time-wait | udp-open | udp-ready | udplite-open | udplite-ready }:显示指定状态的IPv4单播会话表项。
vpn-instance vpn-instance-name:显示指定VPN实例的IPv4单播会话表项。vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。若不指定此参数,则显示公网的IPv4单播会话表项。
verbose:显示IPv4单播会话表项的详细信息。不指定该参数时,显示IPv4单播会话表项的概要信息。
brief:显示IPv4单播会话表项的简要信息。不指定该参数时,显示IPv4单播会话表项的概要信息。
如果不指定任何参数,则显示所有的IPv4单播会话表项。
# 显示所有的IPv4单播会话表项的概要信息。‌‌‌
<Sysname> display session table ipv4
Total number of sessions on all slots: 1
Slot 1:
Initiator:
  Protocol: TCP(6)
  NAT global policy: example
Total sessions found: 1
# 显示所有的IPv4单播会话表项的详细信息。‌‌‌
<Sysname> display session table ipv4 verbose
Slot 1:
Initiator:
  Protocol: TCP(6)
Responder:
  Protocol: TCP(6)
State: TCP_SYN_SENT
Application: SSH (Service name: SSH)
Rule ID: 4294967292
Rule name: default
# 显示所有的IPv4单播会话表项的简要信息。‌‌
<Sysname> display session table ipv4 brief
Slot 1:
Application      VPN(Src->Dst)   SIP/Port->DIP/Port
GENERAL_TCP      public->public  (backup)192.168.1.1/4398(1.1.1.1/2107)->192.168.2.2/2048
表1-24 display session table命令显示信息描述表
Initiator
发起方到响应方的连接对应的会话信息
Responder
响应方到发起方的连接对应的会话信息
Source IP/port
源IP地址/端口号
Destination IP/port
目的IP地址/端口号
DS-Lite tunnel peer
各字段含义解释如下:
·     会话所属的MPLS L3VPN
·     二层转发时会话所属的VLAN ID
·     二层转发时会话所属的INLINE
未指定的参数则显示为“-”
Protocol
括号中的数字表示协议号
Inbound interface
报文的入接口
NAT global policy
表示全局NAT规则的名称
会话状态
Application
Sevice name表示服务协议类型,取值包括:DNS、FTP、SSH等
Rule ID
安全策略规则的ID
Rule name
安全策略规则的名称
Start time
会话创建时间
TTL
会话剩余存活时间,单位为秒
发起方到响应方的报文数、报文字节数
响应方到发起方的报文数、报文字节数
当前查找到的会话表项总数
VPN(Src->Dst)
VPN实例名称,表示方式为:源方向->目的方向
(backup)
双机热备场景下,当前会话是备份会话,该会话是从对端设备备份过来的
SIP/Port->DIP/Port
源IP地址/端口号->目的IP地址/端口号,如果会话信息中有NAT转换,则使用“[]”标识NAT转换后的地址
display session table ipv6命令用来显示IPv6单播会话表项信息。
display session table ipv6 [ slot slot-number ] [ [ responder ] { application application-name | destination-ip start-destination-ip [ end-destination-ip ] | destination-port start-destination-port [ end-destination-port ] | destination-zone destination-zone-name | interface interface-type interface-number | protocol { dccp | icmpv6 | raw-ip | sctp | tcp | udp | udp-lite } | security-policy-rule rule-name | security-policy-rule-id rule-id | source-ip start-source-ip [ end-source-ip ] | source-port start-source-port [ end-source-port ] | source-zone source-zone-name | state { dccp-closereq | dccp-closing | dccp-open | dccp-partopen | dccp-request | dccp-respond | dccp-timewait | icmpv6-reply | icmpv6-request | rawip-open | rawip-ready | sctp-closed | sctp-cookie-echoed | sctp-cookie-wait | sctp-established | sctp-shutdown-ack-sent | sctp-shutdown-recd | sctp-shutdown-sent | tcp-close | tcp-close-wait | tcp-est | tcp-fin-wait | tcp-last-ack | tcp-syn-recv | tcp-syn-sent | tcp-syn-sent2 | tcp-time-wait | udp-open | udp-ready | udplite-open | udplite-ready } | vpn-instance vpn-instance-name } * ] [ verbose | brief ]
context-admin
context-operator
vsys-admin
vsys-operator
slot slot-number:显示指定成员设备上的IPv6单播会话表项,slot-number表示设备在IRF中的成员编号。不指定该参数时,显示所有成员设备上的IPv6单播会话表项。‌‌
responder:表示以响应方的信息筛选显示IPv6单播会话表项。若不指定该参数时,则以发起方的信息筛选显示IPv6单播会话表项。
application application-name:显示指定应用的IPv6单播会话表项。application-name表示应用的名称,为1~63个字符的字符串,不区分大小写,不允许为系统保留的“invalid”和“other”。
destination-ip start-destination-ip [ end-destination-ip ]:显示指定目的IPv6地址的单播会话表项。其中,start-destination-ip表示目的IPv6地址范围的起始地址,end-destination-ip目的IPv6地址范围的结束地址。
destination-port start-destination-port [ end-destination-port ]:显示指定目的端口号的IPv6单播会话表项。其中,start-destination-port表示目的端口的起始端口号,end-destination-port表示目的端口的结束端口号,取值范围为0~65535。
destination-zone destination-zone-name:显示指定目的安全域的IPv6单播会话表项。其中destination-zone-name表示安全域的名称,安全域的名称为1~31个字符的字符串,不区分大小写。
interface interface-type interface-number:显示指定接口的IPv6单播会话表项。interface-type interface-number表示接口类型和接口编号。
protocol { dccp | icmp | raw-ip | sctp | tcp | udp | udp-lite }:显示指定协议类型的IPv6单播会话表项。其中,IPv6传输层协议类型可包括:DCCP、ICMP、RawIP、SCTP、TCP、UDP和UDP-Lite。
security-policy-rule rule-name:显示与指定安全策略规则匹配的IPv6单播会话表项。rule-name为安全策略规则的名称,为1~127个字符的字符串,区分大小写。
security-policy-rule-id rule-id:显示与指定安全策略规则ID匹配的IPv6单播会话表项。rule-id为安全策略规则的ID,取值为0~4294967295。
source-ip start-source-ip [ end-source-ip ]:显示指定源IP地址的单播会话表项。其中,start-source-ip表示源IPv6地址范围的起始地址,end-source-ip表示源IPv6地址范围的结束地址。
source-port start-source-port [ end-source-port ]:显示指定源端口号的IPv6单播会话表项。其中,start-source-port表示源端口的起始端口号,end-source-port表示源端口的结束端口号,取值范围为0~65535。
source-zone source-zone-name:显示指定源安全域的IPv6单播会话表项。其中source-zone-name表示安全域的名称,安全域的名称为1~31个字符的字符串,不区分大小写。
state { dccp-closereq | dccp-closing | dccp-open | dccp-partopen | dccp-request | dccp-respond | dccp-timewait | icmpv6-reply | icmpv6-request | rawip-open | rawip-ready | sctp-closed | sctp-cookie-echoed | sctp-cookie-wait | sctp-established | sctp-shutdown-ack-sent | sctp-shutdown-recd | sctp-shutdown-sent | tcp-close | tcp-close-wait | tcp-est | tcp-fin-wait | tcp-last-ack | tcp-syn-recv | tcp-syn-sent | tcp-syn-sent2 | tcp-time-wait | udp-open | udp-ready | udplite-open | udplite-ready }:显示指定状态的IPv6单播会话表项。
vpn-instance vpn-instance-name:显示指定VPN实例的IPv6单播会话表项。vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。若不指定此参数,则显示公网的IPv6单播会话表项。
verbose:显示IPv6单播会话表项的详细信息。不指定该参数时,显示IPv6单播会话表项的概要信息。
brief:显示IPv6单播会话表项的简要信息。不指定该参数时,显示IPv6单播会话表项的概要信息。
如果不指定任何参数,则显示所有的IPv6单播会话表项。
# 显示所有的IPv6单播会话表项的概要信息。‌‌‌
<Sysname> display session table ipv6
Slot 1:
Initiator:
  Protocol: IPV6-ICMP(58)
# 显示所有的IPv6单播会话表项的详细信息。‌‌‌
<Sysname> display session table ipv6 verbose
Slot 1:
Initiator:
Responder:
  Source      IP/port: 2011::8/58473
  Destination IP/port: 2011::2/33024
State: ICMPV6_REQUEST
Application: OTHER (Service name: ICMP)
Rule ID: 4294967292
Rule name: default
Start time: 2011-07-29 19:23:41  TTL: 55s
Initiator->Responder:         1 packets         104 bytes
# 显示所有的IPv6单播会话表项的简要信息。‌‌
<Sysname> display session table ipv6 brief
Slot 1:
GENERAL_TCP      public->public  (backup)1:1::/1(3:3::/1213)->2:2::/32768
表1-25 display session table命令显示信息描述表
Initiator
发起方到响应方的连接对应的会话信息
Responder
响应方到发起方的连接对应的会话信息
Source IP/port
源IP地址/端口号
Destination IP/port
目的IP地址/端口号
DS-Lite tunnel peer
各字段含义解释如下:
·     会话所属的MPLS L3VPN
·     二层转发时会话所属的VLAN ID
·     二层转发时会话所属的INLINE
未指定的参数则显示为“-”
Protocol
括号中的数字表示协议号
Inbound interface
报文的入接口
NAT global policy
表示全局NAT规则的名称
会话状态
Application
Rule ID
安全策略规则的ID
Rule name
安全策略规则的名称
Start time
会话创建时间
TTL
会话剩余存活时间,单位为秒
发起方到响应方的报文数、报文字节数
响应方到发起方的报文数、报文字节数
当前查找到的会话表项总数
VPN(Src->Dst)
(backup)
SIP/Port->DIP/Port
display session table multicast ipv4命令用来显示IPv4组播会话表项信息。
display session table multicast ipv4 [ slot slot-number ] [ [ responder ] { destination-ip start-destination-ip [ end-destination-ip ] | destination-port destination-port | protocol { dccp | icmp | raw-ip | sctp | tcp | udp | udp-lite } | source-ip start-source-ip [ end-source-ip ] | source-port source-port } * ] [ verbose ]
context-admin
context-operator
vsys-admin
vsys-operator
slot slot-number:显示指定成员设备上的IPv4组播会话表项,slot-number表示设备在IRF中的成员编号。不指定该参数时,显示所有成员设备上的IPv4组播会话表项。对于本产品,slot-number只能为固定取值,无论是否指定本参数,均表示整台设备。‌‌
responder:表示以响应方的信息筛选显示IPv4组播会话表项。若不指定该参数时,则以发起方的信息筛选显示IPv4组播会话表项。
destination-ip start-destination-ip [ end-destination-ip ]:显示指定目的IPv4地址的组播会话表项。其中,start-destination-ip表示目的IPv4地址范围的起始地址,end-destination-ip目的IPv4地址范围的结束地址。
destination-port destination-port:显示指定目的端口号的IPv4组播会话表项。其中,destination-port表示端口号,取值为0~65535。
protocol { dccp | icmp | raw-ip | sctp | tcp | udp | udp-lite }:显示指定协议类型的IPv4组播会话表项。
source-ip start-source-ip [ end-source-ip ]:显示指定源IP地址的组播会话表项。其中,start-source-ip表示源IPv4地址范围的起始地址,end-source-ip表示源IPv4地址的结束地址。
source-port source-port:显示指定源端口号的IPv4组播会话表项。其中,source-port表示源端口号,取值为0~65535。
verbose:显示IPv4组播会话表项的详细信息。不指定该参数时,显示IPv4组播会话表项的概要信息。
如果不指定任何参数,则显示所有的IPv4组播会话表项。
# 显示所有的IPv4组播会话表项的概要信息。‌‌‌
<Sysname> display session table multicast ipv4
Slot 1:
Inbound initiator:
  Source      IP/port: 3.3.3.4/1609
  Destination IP/port: 232.0.0.1/1025
  Protocol: UDP(17)
Outbound interface list:
    GigabitEthernet1/0/3
# 显示所有的IPv4组播会话表项的详细信息。‌‌‌
<Sysname> display session table multicast ipv4 verbose
Slot 1:
Inbound initiator:
  Protocol: UDP(17)
Inbound responder:
  Source      IP/port: 232.0.0.1/1025
  Destination IP/port: 3.3.3.4/1609
  Protocol: UDP(17)
State: UDP_OPEN
Application: OTHER
Start time: 2014-03-03 15:59:22  TTL: 18s
Initiator->Responder:            1 packets         84 bytes
Outbound initiator:
  Protocol: UDP(17)
Outbound responder:
  Protocol: UDP(17)
Outbound interface: GigabitEthernet1/0/2
Destination security zone: aaa
State: UDP_OPEN
Application: OTHER
Outbound initiator:
  Protocol: UDP(17)
Outbound responder:
  Protocol: UDP(17)
Outbound interface: GigabitEthernet1/0/3
Destination security zone: bbb
State: UDP_OPEN
Application: OTHER
Total sessions found: 3
表1-26 display session table multicast ipv4命令显示信息描述表
Inbound initiator
入接口上发起方到响应方的连接对应的组播会话信息
Inbound responder
入接口上响应方到发起方的连接对应的组播会话信息
Outbound initiator
出接口上发起方到响应方的连接对应的组播会话信息
Outbound responder
出接口上响应方到发起方的连接对应的组播会话信息
Source IP/port
源IP地址/端口号
Destination IP/port
目的IP地址/端口号
DS-Lite tunnel peer
各字段含义解释如下:
·     组播会话所属的MPLS L3VPN
·     二层转发时会话所属的VLAN ID
·     二层转发时会话所属的INLINE
未指定的参数则显示为“-”
Protocol
传输层协议类型,取值包括:DCCP、ICMP、Raw IP、SCTP、TCP、UDP、UDP-Lite,括号中的数字表示协议号
组播会话状态
Application
Start time
组播会话创建时间
TTL
组播会话剩余存活时间,单位为秒
Inbound interface
发起方到响应方首报文的入接口
Outbound interface
发起方到响应方首报文的出接口
发起方到响应方首报文的出接口列表
目的安全域,即出接口所属的安全域。若接口不属于任何安全域,则显示为“-”
发起方到响应方的报文数、报文字节数
当前查找到的组播会话表项总数
display session table multicast ipv6命令用来显示IPv6组播会话表项信息。
display session table multicast ipv6 [ slot slot-number ] [ [ responder ] { destination-ip start-destination-ip [ end-destination-ip ] | destination-port destination-port | protocol { dccp | icmpv6 | raw-ip | sctp | tcp | udp | udp-lite } | source-ip start-source-ip [ end-source-ip ] | source-port source-port } * ] [ verbose ]
context-admin
context-operator
vsys-admin
vsys-operator
slot slot-number:显示指定成员设备上的IPv6组播会话表项,slot-number表示设备在IRF中的成员编号。不指定该参数时,显示所有成员设备上的IPv6组播会话表项。对于本产品,slot-number只能为固定取值,无论是否指定本参数,均表示整台设备。‌‌
destination-ip start-destination-ip [ end-destination-ip ]:显示指定目的IPv6地址的组播会话表项。其中,start-destination-ip表示目的IPv6地址的起始地址,end-destination-ip表示目的IPv6地址的结束地址。
destination-port destination-port:显示指定目的端口号的IPv6组播会话表项。其中,destination-port表示端口号,取值为0~65535。
protocol { dccp | icmpv6 | raw-ip | sctp | tcp | udp | udp-lite }:显示指定协议类型的IPv6组播会话表项。
source-ip start-source-ip [ end-source-ip ]:显示指定源IPv6地址的组播会话表项。其中,start-source-ip表示源IPv6地址的起始地址,end-source-ip表示源IPv6地址的结束地址。
source-port source-port:显示指定源端口号的IPv6组播会话表项。其中,source-port表示端口号,取值为0~65535。
verbose:显示IPv6组播会话表项的详细信息。不指定该参数时,显示IPv6组播会话表项的概要信息。
如果不指定任何参数,则显示所有的IPv6组播会话表项。
# 显示所有的IPv6组播会话表项的概要信息。‌‌‌
<Sysname> display session table multicast ipv6
Slot 1:
Inbound initiator:
  Source      IP/port: 3::4/1617
  Destination IP/port: FF0E::1/1025
  Protocol: UDP(17)
# 显示所有的IPv6组播会话表项的详细信息。‌‌‌
<Sysname> display session table multicast ipv6 verbose
Slot 1:
Inbound initiator:
  Protocol: UDP(17)
Inbound responder:
  Source      IP/port: FF0E::1/1025
  Destination IP/port: 3::4/1617
  Protocol: UDP(17)
State: UDP_OPEN
Application: OTHER
Start time: 2014-03-03 16:10:58  TTL: 23s
Initiator->Responder:            5 packets        520 bytes
Outbound initiator:
  Protocol: UDP(17)
Outbound responder:
  Protocol: UDP(17)
State: UDP_OPEN
Application: OTHER
Outbound initiator:
  Protocol: UDP(17)
Outbound responder:
  Protocol: UDP(17)
Destination security zone: ccc
State: UDP_OPEN
Application: OTHER
表1-27 display session table multicast ipv6命令显示信息描述表
Inbound initiator
Inbound responder
Outbound initiator
Outbound responder
Source IP/port
源IP地址/端口号
Destination IP/port
目的IP地址/端口号
DS-Lite tunnel peer
各字段含义解释如下:
·     组播会话所属的MPLS L3VPN
·     二层转发时会话所属的VLAN ID
·     二层转发时会话所属的INLINE
未指定的参数则显示为“-”
Protocol
传输层协议类型,取值包括:DCCP、ICMPv6、Raw IP、SCTP、TCP、UDP、UDP-Lite,括号中的数字表示协议号
组播会话状态
Application
Start time
组播会话创建时间
TTL
组播会话剩余存活时间,单位为秒
Inbound interface
发起方到响应方首报文的入接口
Outbound interface
发起方到响应方首报文的出接口
发起方到响应方首报文的出接口列表
发起方到响应方的报文数、报文字节数
当前查找到的组播会话表项总数
display session top-statistics命令用来显示会话数目的Top 10排名统计信息。
display session top-statistics { last-1-hour | last-24-hours | last-30-days }
context-admin
context-operator
vsys-admin
vsys-operator
last-1-hour:显示最近1小时的会话数目的Top 10排名统计信息。
last-24-hours:显示最近24小时的会话数目的Top 10排名统计信息。
last-30-days:显示最近30天的会话数据的Top 10排名统计信息。
未开启会话数目的Top排名统计功能时,统计信息为空。
# 显示最近1小时的会话数目Top 10的排名统计信息。
<Sysname> display session top-statistics last-1-hour
1        10.1.2.3                      50004302
2        10.1.2.2                      40123255
3        10.2.2.10                     26664302
4        10.1.2.11                     7123255
5        10.1.2.12                     424302
6        10.1.2.13                     253255
7        10.1.2.14                     55302
8        10.1.2.15                     50025
9        10.1.2.16                     3555
10       10.1.2.1                      995
1        20.1.2.3                      50004302
2        20.1.2.2                      40123255
3        20.2.2.10                     26664302
4        20.1.2.11                     7123255
5        20.1.2.12                     424302
6        20.1.2.13                     325325
7        20.1.2.14                     55530
8        20.1.2.15                     50025
9        20.1.2.16                     3555
10       20.1.2.1                      995
表1-28 display session top-statistics命令显示信息描述表
基于源IP地址的新建会话数目Top 10的排名统计信息
基于目的IP地址的新建会话数目Top 10的排名统计信息
No.
Top 10排名
Source address
会话的源IP地址
Destination address
会话的目的IP地址
Sessions
会话数目
·     session top-statistics enable
reset session alg-app-change命令用来清除APP ID变更处理统计信息。
reset session alg-app-change [ slot slot-number ]
context-admin
vsys-admin
# 清除APP ID变更处理统计信息。
<Sysname> reset session alg-app-change
·     display session alg-app-change
reset session relation-table命令用来删除关联表项。
reset session relation-table [ ipv4 | ipv6 ] [ slot slot-number ] [ { application application-name | destination-ip destination-ip | destination-port destination-port | protocol { dccp | icmp | raw-ip | sctp | tcp | udp | udp-lite } | source-ip source-ip | source-port source-port } * ]
context-admin
vsys-admin
ipv4:删除IPv4关联表项。
ipv6:删除IPv6关联表项。
slot slot-number:删除指定成员设备上的关联表项,slot-number表示设备在IRF中的成员编号。不指定该参数时,删除所有成员设备上的关联表项。对于本产品,slot-number只能为固定取值,无论是否指定本参数,均表示整台设备。‌‌
application application-name:删除指定应用的关联表项。application-name表示应用的名称,为1~63个字符的字符串,不区分大小写,不允许为系统保留的“invalid”和“other”。
destination-ip destination-ip:删除指定目的IP地址的关联表项。其中, destination-ip表示目的IP地址。
destination-port destination-port:删除指定目的端口号的关联表项。其中,destination-port表示目的端口号,取值范围为0~65535。
protocol { dccp | icmp | raw-ip | sctp | tcp | udp | udp-lite }:删除指定协议类型的关联表项。其中,传输层协议类型可包括:DCCP、ICMP、RawIP、SCTP、TCP、UDP和UDP-Lite。
source-ip  source-ip :删除指定源IP地址的关联表项。其中,source-ip表示源IP地址。
source-port source-port:删除指定源端口号的关联表项。其中,source-port表示源端口号,取值范围为0~65535。
如果不指定任何参数,则删除所有关联表项。
# 删除所有的IPv4关联表项。
<Sysname> reset session relation-table ipv4
# 删除所有发起方源IP地址为10.10.10.10的IPv4关联表项。
<Sysname> reset session relation-table ipv4 source-ip 10.10.10.10
·     display session relation-table
reset session statistics命令用来清除单播会话统计信息。
reset session statistics [ slot slot-number ]
context-admin
vsys-admin
slot slot-number:清除指定成员设备上的单播会话统计信息,slot-number表示设备在IRF中的成员编号。不指定该参数时,清除所有成员设备上的单播会话统计信息。对于本产品,slot-number只能为固定取值,无论是否指定本参数,均表示整台设备。‌‌
# 清除所有的单播会话统计信息。
<Sysname> reset session statistics
reset session statistics multicast命令用来清除组播会话统计信息。
reset session statistics multicast [ slot slot-number ]
context-admin
vsys-admin
slot slot-number:清除指定成员设备上的组播会话统计信息,slot-number表示设备在IRF中的成员编号。不指定该参数时,清除所有成员设备上的组播会话统计信息。对于本产品,slot-number只能为固定取值,无论是否指定本参数,均表示整台设备。‌‌
# 清除所有的组播会话统计信息。
<Sysname> reset session statistics multicast
·     display session statistics multicast
reset session table命令用来删除所有IP类型的单播会话表项。
reset session table [ slot slot-number ]
context-admin
vsys-admin
slot slot-number:删除指定成员设备上的所有单播会话表项,slot-number表示设备在IRF中的成员编号。不指定该参数时,删除所有成员设备上的所有单播会话表项。对于本产品,slot-number只能为固定取值,无论是否指定本参数,均表示整台设备。‌‌
本命令仅删除当前时间之前创建的会话,后续新建的会话不受影响。
# 删除所有单播会话表项。
<Sysname> reset session table
·     display session table ipv4
·     display session table ipv6
reset session table ipv4命令用来删除IPv4单播会话表项。
reset session table ipv4 [ slot slot-number ] [ source-ip source-ip ] [ destination-ip destination-ip ] [ protocol { dccp | icmp | raw-ip | sctp | tcp | udp | udp-lite } ] [ source-port start-source-port [ end-source-port ] ] [ destination-port start-destination-port [ end-destination-port ] ] [ vpn-instance vpn-instance-name ]
context-admin
vsys-admin
slot slot-number:删除指定成员设备上的IPv4单播会话表项,slot-number表示设备在IRF中的成员编号。不指定该参数时,删除所有成员设备上的IPv4单播会话表项。‌‌
source-ip source-ip:删除指定源IP地址的IPv4单播会话表项。其中,source-ip表示发起方到响应方会话的源IPv4地址。
destination-ip destination-ip:删除指定目的IP地址的IPv4单播会话表项。其中,destination-ip表示发起方到响应方会话的目的IPv4地址。
protocol { dccp | icmp | raw-ip | sctp | tcp | udp | udp-lite }:删除指定协议类型的单播会话表项。其中,IPv4传输层协议类型可包括:DCCP、ICMP、RawIP、SCTP、TCP、UDP和UDP-Lite。
source-port start-source-port [ end-source-port ]:删除指定源端口号的IPv4单播会话表项。其中,start-source-port表示发起方到响应方会话源端口的起始端口号,end-source-port表示发起方到响应方会话源端口的结束端口号,取值范围为0~65535。
destination-port start-destination-port [ end-destination-port ]:删除指定目的端口号的IPv4单播会话表项。其中,start-destination-port表示发起方到响应方会话目的端口的起始端口号,end-destination-port表示发起方到响应方会话目的端口的结束端口号,取值范围为0~65535。
vpn-instance vpn-instance-name:删除指定VPN实例的IPv4单播会话表项。其中,vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。不指定该参数时,删除公网中的IPv4单播会话表项。
如果不指定任何参数,则删除所有公网中的IPv4单播会话表项。
# 删除所有IPv4单播会话表项。
<Sysname> reset session table ipv4
# 删除所有发起方源IP地址为10.10.10.10的IPv4单播会话表项。
<Sysname> reset session table ipv4 source-ip 10.10.10.10
reset session table ipv6命令用来删除IPv6单播会话表项。
reset session table ipv6 [ slot slot-number ] [ source-ip source-ip ] [ destination-ip destination-ip ] [ protocol { dccp | icmpv6 | raw-ip | sctp | tcp | udp | udp-lite } ] [ source-port start-source-port [ end-source-port ] ] [ destination-port start-destination-port [ end-destination-port ] ] [ vpn-instance vpn-instance-name ]
context-admin
vsys-admin
slot slot-number:删除指定成员设备上的IPv6单播会话表项,slot-number表示设备在IRF中的成员编号。不指定该参数时,删除所有成员设备上的IPv6单播会话表项。‌‌
source-ip source-ip:删除指定源IP地址的IPv6单播会话表项。其中,source-ip表示发起方到响应方会话的源IPv6地址。
destination-ip destination-ip:删除指定目的IP地址的IPv6单播会话表项。其中,destination-ip表示发起方到响应方会话的目的IPv6地址。
protocol { dccp | icmpv6 | raw-ip | sctp | tcp | udp | udp-lite }:删除指定协议类型的IPv6单播会话表项。其中,IPv6传输层协议类型可包括:DCCP、ICMPv6、RawIP、SCTP、TCP、UDP和UDP-Lite。
source-port start-source-port [ end-source-port ]:删除指定源端口号的IPv6单播会话表项。其中,start-source-port表示发起方到响应方会话源端口的起始端口号,end-source-port表示发起方到响应方会话源端口的结束端口号,取值范围为0~65535。
destination-port start-destination-port [ end-destination-port ]:删除指定目的端口号的IPv6单播会话表项。其中,destination-port表示发起方到响应方会话的目的端口号,取值范围为0~65535。
vpn-instance vpn-instance-name:删除指定VPN实例的IPv6单播会话表项。其中,vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。不指定该参数时,删除公网中的IPv6单播会话表项。
如果不指定任何参数,则删除所有公网中的IPv6单播会话表项。
# 删除所有IPv6单播会话表项。
<Sysname> reset session table ipv6
# 删除所有发起方源IP地址为2011::0002的IPv6单播会话表项。
<Sysname> reset session table ipv6 source-ip 2011::0002
reset session table multicast命令用来删除所有IP类型的组播会话表项。
reset session table multicast [ slot slot-number ]
context-admin
vsys-admin
slot slot-number:删除指定成员设备上的所有组播会话表项,slot-number表示设备在IRF中的成员编号。不指定该参数时,删除所有成员设备上的所有组播会话表项。对于本产品,slot-number只能为固定取值,无论是否指定本参数,均表示整台设备。‌‌
# 删除所有组播会话表项。
<Sysname> reset session table multicast
·     display session table multicast ipv4
·     display session table multicast ipv6
reset session table multicast ipv4命令用来删除IPv4组播会话表项。
reset session table multicast ipv4 [ slot slot-number ] [ source-ip source-ip ] [ destination-ip destination-ip ] [ protocol { dccp | icmp | raw-ip | sctp | tcp | udp | udp-lite } ] [ source-port source-port ] [ destination-port destination-port ] [ vpn-instance vpn-instance-name ]
context-admin
vsys-admin
slot slot-number:删除指定成员设备上的IPv4组播会话表项,slot-number表示设备在IRF中的成员编号。不指定该参数时,删除所有成员设备上的IPv4组播会话表项。对于本产品,slot-number只能为固定取值,无论是否指定本参数,均表示整台设备。‌‌
source-ip source-ip:删除指定源IP地址的IPv4组播会话表项。其中,source-ip表示发起方到响应方组播会话的源IPv4地址。
destination-ip destination-ip:删除指定目的IP地址的IPv4组播会话表项。其中,destination-ip表示发起方到响应方组播会话的目的IPv4地址。
protocol { dccp | icmp | raw-ip | sctp | tcp | udp | udp-lite }:删除指定协议类型的组播会话表项。其中,IPv4传输层协议类型可包括:DCCP、ICMP、RawIP、SCTP、TCP、UDP和UDP-Lite。
source-port source-port:删除指定源端口号的IPv4组播会话表项。其中,source-port表示发起方到响应方组播会话的源端口号,取值为0~65535。
destination-port destination-port:删除指定目的端口号的IPv4组播会话表项。其中,destination-port表示发起方到响应方组播会话的目的端口号,取值为0~65535。
vpn-instance vpn-instance-name:删除指定VPN实例的IPv4组播会话表项。其中,vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。不指定该参数时,删除公网中的IPv4组播会话表项。
如果不指定任何参数,则删除所有公网中的IPv4组播会话表项。
# 删除所有IPv4组播会话表项。
<Sysname> reset session table multicast ipv4
# 删除所有发起方源IP地址为10.10.10.10的IPv4组播会话表项。
<Sysname> reset session table multicast ipv4 source-ip 10.10.10.10
reset session table multicast ipv6命令用来删除IPv6组播会话表项。
reset session table multicast ipv6 [ slot slot-number ] [ source-ip source-ip ] [ destination-ip destination-ip ] [ protocol { dccp | icmpv6 | raw-ip | sctp | tcp | udp | udp-lite } ] [ source-port source-port ] [ destination-port destination-port ] [ vpn-instance vpn-instance-name ]
context-admin
vsys-admin
slot slot-number:删除指定成员设备上的IPv6组播会话表项,slot-number表示设备在IRF中的成员编号。不指定该参数时,删除所有成员设备上的IPv6组播会话表项。对于本产品,slot-number只能为固定取值,无论是否指定本参数,均表示整台设备。‌‌
source-ip source-ip:删除指定源IP地址的IPv6组播会话表项。其中,source-ip表示发起方到响应方组播会话的源IPv6地址。
destination-ip destination-ip:删除指定目的IP地址的IPv6组播会话表项。其中,destination-ip表示发起方到响应方组播会话的目的IPv6地址。
protocol { dccp | icmpv6 | raw-ip | sctp | tcp | udp | udp-lite }:删除指定协议类型的IPv6组播会话表项。其中,IPv6传输层协议类型可包括:DCCP、ICMPv6、RawIP、SCTP、TCP、UDP和UDP-Lite。
source-port source-port:删除指定源端口号的IPv6组播会话表项。其中,source-port表示发起方到响应方组播会话的源端口号,取值为0~65535。
destination-port destination-port:删除指定目的端口号的IPv6组播会话表项。其中,destination-port表示发起方到响应方组播会话的目的端口号,取值为0~65535。
vpn-instance vpn-instance-name:删除指定VPN实例的IPv6组播会话表项。其中,vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。不指定该参数时,删除公网中的IPv6组播会话表项。
如果不指定任何参数,则删除所有公网中的IPv6组播会话表项。
# 删除所有IPv6组播会话表项。
<Sysname> reset session table multicast ipv6
# 删除所有发起方源IP地址为2011::0002的IPv6组播会话表项。
<Sysname> reset session table multicast ipv6 source-ip 2011::0002
1.1.35  session aging-time application
session aging-time application命令用来设置应用层协议或应用的会话老化时间。
undo session aging-time application命令用来恢复缺省情况。如果不指定应用层协议或应用的名称,则将所有应用层协议和应用的会话老化时间都恢复为缺省情况。
session aging-time application application-name time-value
undo session aging-time application [ application-name ]
部分应用层协议或应用的会话老化时间如下,单位为秒:
·     DNS:30
·     FTP:3600
·     GTP-CONTROL:60
·     GTP-USER:60
·     GPRS-DATA:60
·     GPRS-SIG:60
·     H225:3600
·     H245:3600
·     RAS:300
·     RTSP:3600
·     SIP:300
·     TFTP:60
·     ILS:3600
·     MGCP-CALLAGENT:60
·     MGCP-GATEWAY:60
·     PPTP:3600
·     RSH:60
·     SCCP:3600
·     SQLNET:600
·     XDMCP:3600
·     BOOTPC:120
·     BOOTPS:120
·     FTP-DATA:240
·     HTTPS:600
·     L2TP:120
·     NETBIOS-DGM:3600
·     NETBIOS-NS:3600
·     NETBIOS-SSN:3600
·     NTP:120
·     QQ:120
·     RIP:120
·     SNMP:120
·     SNMPTRAP:120
·     SYSLOG:120
·     TACACS-DS:120
·     WHO:120
除以上列举的之外,系统中其他的所有应用层协议或应用的会话老化时间均为1200秒。
context-admin
vsys-admin
application-name:表示应用协议或应用的名称,为1~63个字符的字符串,不区分大小写,可以为数字、字母、连字符、下划线,但不允许为系统保留的“invalid”和“other”。该应用层协议或应用必须在设备上已存在。
time-value:指定的老化时间,取值范围为1~100000,单位为秒。
应用层协议的会话老化时间仅在会话进入稳态时生效(TCP会话的稳态为TCP-EST,UDP会话的稳态为UDP-READY)。
会话进入稳态后,如果该会话属于本命令中指定的一种应用层协议或应用,则此会话的老化时间为指定的应用层协议或应用老化时间;否则为传输层协议状态的老化时间(由session aging-time state命令配置)。
对TCP会话来说,如果会话符合长连接会话的规则,那么该会话稳态的老化时间为长连接老化时间(由session persistent acl命令配置)。
此命令中的应用层协议或应用由APR模块定义,有关APR功能的详细介绍请参见“安全配置指导”中的“APR”。
# 设置FTP协议的会话老化时间为1800秒。
[Sysname] session aging-time application ftp 1800
# 设置应用126WebEmail的会话老化时间为1800秒。
[Sysname] session aging-time application 126WebEmail 1800
·     display session aging-time application
·     nbar application(安全命令参考/APR)
·     port-mapping(安全命令参考/APR)
·     session persistent acl
1.1.36  session aging-time state
session aging-time state命令用来设置各协议状态的会话老化时间。
undo session aging-time state命令用来恢复缺省情况,如果不指定任何参数,则将所有协议状态的会话老化时间都恢复为缺省情况。
session aging-time state { fin | icmp-reply | icmp-request | icmpv6-reply | icmpv6-request | rawip-open | rawip-ready | syn | tcp-close | tcp-est | tcp-time-wait | udp-open | udp-ready } time-value
undo session aging-time state [ fin | icmp-reply | icmp-request | icmpv6-reply | icmpv6-request | rawip-open | rawip-ready | syn | tcp-close | tcp-est | tcp-time-wait | udp-open | udp-ready ]
各协议状态的会话老化时间如下,单位为秒:
·     FIN:30
·     ICMP-REPLY:30
·     ICMP-REQUEST:60
·     ICMPv6-REPLY:30
·     ICMPv6-REQUEST:60
·     RAWIP-OPEN:30
·     RAWIP-READY:60
·     SYN:30
·     TCP-CLOSE:2
·     TCP-EST:3600
·     TCP-TIME-WAIT:2
·     UDP-OPEN:30
·     UDP-READY:60
context-admin
vsys-admin
fin:表示TCP协议FIN-WAIT状态的会话老化时间。
icmp-reply:表示ICMP协议REPLY状态的会话老化时间。
icmp-request:表示ICMP协议REQUEST状态的会话老化时间。
icmpv6-reply:表示ICMPv6协议REPLY状态的会话老化时间。
icmpv6-request:表示ICMPv6协议REQUEST状态的会话老化时间。
rawip-open:表示RAWIP-OPEN状态的会话老化时间。
rawip-ready:表示RAWIP-READY状态的会话老化时间。
syn:表示TCP协议SYN-SENT和SYN-RCV状态的会话老化时间。
tcp-close:表示TCP协议CLOSE状态的会话老化时间。
tcp-est:表示TCP协议ESTABLISHED状态的会话老化时间。
tcp-time-wait:表示TCP协议TIME-WAIT状态的会话老化时间。
udp-open:表示UDP协议OPEN状态的会话老化时间。
udp-ready:表示UDP协议READY状态的会话老化时间。
time-value:指定的老化时间,其中tcp-close、tcp-time-wait状态取值范围为0~100000,其他状态会话老化时间取值范围为1~100000,单位为秒。
会话进入稳态后,如果该会话属于session aging-time application命令中指定的一种应用层协议,则此会话的老化时间为指定的应用层协议老化时间;否则为四层协议状态的老化时间(由session aging-time state命令配置)。
# 设置TCP协议SYN-SENT和SYN-RCV状态的老化时间为60秒。
[Sysname] session aging-time state syn 60
·     display session aging-time state
·     session aging-time application
1.1.37  session alarm rate-abrupt enable
session alarm rate-abrupt enable命令用来开启会话新建速率突变告警功能。
undo session alarm rate-abrupt enable命令用来关闭会话新建速率突变告警功能。
会话新建速率突变告警功能处于关闭状态。
context-admin
非缺省vSystem不支持本命令。
开启会话新建速率突变告警功能后,若设备达到会话新建速率突变告警阈值,则会输出相应的会话告警信息。用于对会话表项新建速率突然大幅升高或降低的情况进行监控,以便实时了解设备会话表项的稳定性。
# 开启会话新建速率突变告警功能。
[Sysname] session alarm rate-abrupt enable
·     session alarm rate-abrupt threshold
1.1.38  session alarm rate-abrupt threshold
session alarm rate-abrupt threshold命令用来配置会话新建速率突变的告警阈值。
undo session alarm rate-abrupt threshold命令用来恢复缺省情况。
session alarm rate-abrupt threshold threshold-value [ base-threshold base-value ]
会话新建速率突变告警阈值为20%,会话新建速率起始告警阈值为10%。
context-admin
threshold-value:会话新建速率的突变告警阈值,取值范围为1~100,单位为百分比。
base-threshold base-value:会话新建速率的起始告警阈值,取值范围为1~100,单位为百分比。
非缺省vSystem不支持本命令。
开启会话新建速率突变告警功能后,系统会以10秒为周期对会话表项新建速率进行统计。会话新建速率变化率是指周期结束时与周期起始时会话新建速率的差值所占周期起始时的会话新建速率的百分比。会话新建速率起始百分比是指设备检测周期起始时新建速率所占10万的百分比值。
当会话新建速率在一个周期的变化率达到会话新建速率突变告警阈值,且会话新建速率起始百分比大于起始告警阈值时,产生告警。
# 配置会话新建速率的突变告警阈值为30%。
[Sysname] session alarm rate-abrupt threshold 30
·     session alarm rate-abrupt enable
1.1.39  session alarm try-rate-abrupt enable
session alarm try-rate-abrupt enable命令用来开启会话尝试新建速率突变告警功能。
undo session alarm try-rate-abrupt enable命令用来关闭会话尝试新建速率突变告警功能。
会话尝试新建速率突变告警功能处于关闭状态。
context-admin
非缺省vSystem不支持本命令。
开启会话尝试新建速率突变告警功能后,若设备达到会话尝试新建速率突变告警阈值,则会输出相应的会话告警信息。用于对会话表项尝试新建速率突然大幅升高或降低的情况进行监控,以便实时了解设备会话表项的稳定性。
# 开启会话尝试新建速率突变告警功能。
[Sysname] session alarm try-rate-abrupt enable
·     session alarm try-rate-abrupt threshold
1.1.40  session alarm try-rate-abrupt threshold
session alarm try-rate-abrupt threshold命令用来配置会话尝试新建速率突变的告警阈值。
undo session alarm try-rate-abrupt threshold命令用来恢复缺省情况。
session alarm try-rate-abrupt threshold threshold-value [ base-threshold base-value ]
会话尝试新建速率突变告警阈值为20%,会话尝试新建速率起始告警阈值为10%。
context-admin
threshold-value:会话尝试新建速率的突变告警阈值,取值范围为1~100,单位为百分比。
base-threshold base-value:会话尝试新建速率的起始告警阈值,取值范围为1~100,单位为百分比。
非缺省vSystem不支持本命令。
开启会话尝试新建速率突变告警功能后,系统会以10秒为周期对会话表项尝试新建速率进行统计。会话尝试新建速率变化率是指周期结束时与周期起始时会话尝试新建速率的差值所占周期起始时的会话尝试新建速率的百分比。会话尝试新建速率起始百分比是指设备检测周期起始时尝试新建速率所占10万的百分比值。
当会话尝试新建速率在一个周期的变化率达到会话新建速率突变告警阈值,且会话尝试新建速率起始百分比大于起始告警阈值百分比时,产生告警。
# 配置会话尝试新建速率的突变告警阈值为30%。
[Sysname] session alarm try-rate-abrupt threshold 30
·     session alarm try-rate-abrupt enable
1.1.41  session alarm usage-abrupt enable
session alarm usage-abrupt enable命令用来开启会话表项使用率突变告警功能。
undo session alarm usage-abrupt enable命令用来关闭会话表项使用率突变告警功能。
会话表项使用率突变告警功能处于关闭状态。
context-admin
非缺省vSystem不支持本命令。
开启会话表项使用率突变告警功能后,若设备达到会话表项使用率突变告警阈值,则会输出相应的会话告警信息。用于对会话表项突然大幅升高或降低的情况进行监控,以便实时了解设备会话表项的稳定性。
# 开启会话表项使用率突变告警功能。
[Sysname] session alarm usage-abrupt enable
·     session alarm usage-abrupt threshold
1.1.42  session alarm usage-abrupt threshold
session alarm usage-abrupt threshold命令用来配置会话表项使用率的突变告警阈值。
undo session alarm usage-abrupt threshold命令用来恢复缺省情况。
session alarm usage-abrupt threshold threshold-value [ base-threshold base-value ]
会话表项使用率的突变告警阈值为20%,会话表项起始使用率告警阈值为10%。
context-admin
threshold-value:会话表项使用率的突变告警阈值,取值范围为1~100,单位为百分比。
base-threshold base-value:会话表项使用率的起始告警阈值,取值范围是1~100,单位为百分比。
非缺省vSystem不支持本命令。
开启会话表项使用率突变告警功能后,系统会以10秒为周期对会话表项使用率进行统计。会话表项变化率是指周期结束时与周期起始时会话表项数量的差值所占周期起始时的会话表项数的百分比。会话表项起始使用率是指设备检测周期起始时的会话数所占系统会话最大规格数的百分比。
当会话数在一个周期的变化率达到会话表项突变告警阈值,且会话表项的起始使用率大于起始告警阈值时,则会产生告警。
# 配置会话表项使用率的突变告警阈值为30%。
[Sysname] session alarm usage-abrupt threshold 30
·     session alarm usage-abrupt enable
1.1.43  session alarm-log enable
session alarm-log enable命令用来开启会话上限使用率告警日志功能。
undo session alarm-log命令用来关闭会话上限使用率告警日志功能。
undo session alarm-log enable
会话上限使用率告警日志功能处于关闭状态。
context-admin
vsys-admin
只有打开会话上限使用率告警日志功能后,会话表项上限使用率、关联会话表项上限使用率、丢包会话表项上限使用率告警日志才会被发送。
# 开启会话上限使用率告警日志功能。
[Sysname] session alarm-log enable
·     session usage threshold
·     session relation-table-usage threshold
·     session fast-drop-usage threshold
1.1.44  session alg fragment
session alg fragment命令用来开启ALG支持IP分片和TCP分段报文处理功能。
undo session alg fragment命令用来关闭ALG支持IP分片和TCP分段报文处理功能。
session alg fragment sip
undo session alg fragment sip
ALG支持IP分片和TCP分段报文处理功能处于关闭状态。
context-admin
sip:表示开启ALG支持SIP协议IP分片和TCP分段报文处理功能。
工作机制
缺省情况下ALG不支持对IP分片和TCP分段报文进行处理,开启该功能后,指定协议的IP分片和TCP分段报文将支持进行ALG处理,当前仅支持对SIP协议的分片报文开启该功能。
注意事项
非缺省vSystem不支持本命令。
TCP分段报文处理的功能对于进行了NAT地址转换的报文不生效。
# 开启ALG支持SIP协议IP分片和TCP分段报文处理功能。
<Sysname> system
[Sysname] session alg fragment sip
1.1.45  session dual-active create-mode
session dual-active create-mode命令用来配置双主模式下会话的创建方式。
undo session dual-active create-mode命令用来恢复缺省情况。
session dual-active create-mode { hash | local }
系列
型号
F5000系列
F5080、F5060、F5030、F5000-CN-G85、F5000-CN-G65、F5000-CN-G55、F5000-AI-55-G、F5000-AI-25-G、F5000-AI-15-G、F5000-S-G2、F5000-M-G2、F5000-A-G2、F5000-AI-15
支持
不支持
F1000系列
F1000-AI-90、F1000-AI-80、F1000-AI-75、F1000-AI-70、F1000-AI-65、F1000-AI-60、F1000-AI-55、F1000-AI-35、F1000-AI-25、F1000-AK9130、F1000-AI-90-G、F1000-AI-80-G、F1000-AI-75-G、F1000-AI-65-G、F1000-AI-55-G、F1000-AI-35-G、F1000-AI-25-G、F1000-AI-15-G、F1000-AI-05-G、F1000-AI-03-G、F1000-AI-05-GS、F1000-AI-15、F1000-AI-10、F1000-AI-05、F1000-AI-03-E、F1000-AK1380-G、F1000-AK1300-G、F1000-AK1220-G、F1000-AK1180-G、F1000-AK1080-G、F1000-AK1050-G、F1000-V90、F1000-V60、F1000-V50
支持
插卡
支持
双主模式下会话的创建方式为本地优先。
context-admin
hash:表示会话的创建方式为哈希算法方式。
local:表示会话的创建方式为本地创建方式。
非缺省vSystem不支持本命令。
在双主组网环境中,两台设备同时处理业务。为达到两台设备比较均衡处理业务的目的,设备必须能够根据不同的组网环境支持不同的会话创建方式。目前,设备支持的会话创建方式包括如下几种:
·     哈希算法方式:根据哈希结果将首包流量送到相应设备创建会话,同一条流量的接收设备和创建会话的设备可能不同。此种方式适用于流量在两台设备上分布不太均匀的网络情况。
·     本地创建方式:首包流量在接收此报文的设备上进行创建会话,同一条流量的接收设备和创建会话的设备是同一台设备。此种方式适用于流量在两台设备上分布比较均匀的网络情况。
本功能只有开启会话的双主功能后才生效。
# 配置双主模式下会话的创建方式为哈希算法方式。
[Sysname] session dual-active create-mode hash
·     session dual-active enable
1.1.46  session dual-active enable
session dual-active enable命令用来开启会话的双主功能。
undo session dual-active enable命令用来关闭会话的双主功能。
会话的双主功能处于关闭状态,会话工作在主备模式下。
context-admin
非缺省vSystem不支持本命令。
开启本功能后,会话将工作在双主模式下。
在双机热备环境中,会话工作在主备模式下,只能有一台设备处理安全业务;会话工作在双主模式下,两台设备可以同时处理安全业务。
# 开启会话的双主功能。
[Sysname] session dual-active enable
·     session synchronization enable
1.1.47  session dual-active transparent udp enable
session dual-active transparent udp enable命令用来在双主模式下开启未匹配会话时透传UDP报文的功能。
undo session dual-active transparent udp enable命令用来在双主模式下关闭未匹配会话时透传UDP报文的功能。
系列
型号
F5000系列
支持
不支持
F1000系列
支持
插卡
支持
在双主模式下未匹配会话时透传UDP报文的功能处于关闭状态。
context-admin
应用场景
在双主组网环境中,由于UDP协议自身机制原因,对于同一条UDP流量的报文设备无法区分其是正向报文还是反向报文。所以在缺省情况下,当UDP反向报文未匹配到会话时,设备不会将此报文透传到另一台设备,而是将此报文当作一个新的正向报文尝试为其创建会话,这时会产生如下两种问题:
·     如果设备上的安全控制策略仅允许单向流量通过,则会导致反向报文被丢弃。
·     如果设备上的安全控制策略允许双向流量通过,则会导致同一条UDP流量创建了两条会话,这种情况下会影响某些安全业务对报文的处理。
为了解决以上问题,可以在双主模式下开启未匹配会话时透传UDP报文的功能。开启本功能后,当UDP报文在接收设备上未匹配到会话时,设备会将此UDP报文透传到另一台设备进行处理,若在另一台设备上也未匹配会话,则会在此设备上为其创建会话。
一般情况下,不建议开启本功能。仅建议在双主组网环境中,如果同一条UDP流量出现了非对称路径,且会话备份不及时的情况下开启本功能。开启本功能后,会影响设备的转发性能。
配置准备
本功能只有开启会话的双主功能后才生效。
工作机制
开启未匹配会话时透传UDP报文的功能后,当UDP报文未匹配会话时,若会话的创建方式为哈希算法方式,则根据哈希结果决定在哪个设备上为此UDP报文创建会话,若会话的创建方式为本地创建方式,则会将此UDP报文透传到另一台设备。
注意事项
非缺省vSystem不支持本命令。
# 开启未匹配会话时透传UDP报文的功能。
[Sysname] session dual-active transparent udp enable
1.1.48  session fast-drop aging-time
session fast-drop aging-time命令用来配置丢包会话的老化时间。
undo session fast-drop aging-time命令用来恢复缺省情况。
session fast-drop aging-time time-value
丢包会话的老化时间是3秒。
context-admin
time-value:表示丢包会话的老化时间,取值范围为1~3,单位为秒。
非缺省vSystem不支持本命令。
系统会按照指定的老化时间定期删除丢包会话,丢包会话的老化时间不会被报文刷新而重新计时。
# 配置丢包会话的老化时间为1秒。
[Sysname] session fast-drop aging-time 1
·     session fast-drop aspf enable
1.1.49  session fast-drop enable
session fast-drop enable命令用来开启丢包会话功能。
undo session fast-drop enable命令用来关闭丢包会话功能。
session fast-drop { aspf | connection-limit } * enable
undo session fast-drop { aspf | connection-limit } * enable
丢包会话功能处于关闭状态。
aspf:表示开启ASPF模块的丢包会话功能。
connection-limit:表示开启连接数限制模块的丢包会话功能。
context-admin
工作机制
开启此功能后,设备对丢弃的报文生成会话表项,此类会话表项称之为丢包会话。此条流量的后续报文直接匹配丢包会话进行快速丢包,从而提高设备处理报文的性能。
注意事项
非缺省vSystem不支持本命令。在缺省vSystem下配置本命令后,缺省vSystem和非缺省vSystem中均会生效。
丢包会话功能仅适用于ASPF和连接数限制模块处理的报文,其他模块丢弃报文时不能生成丢包会话。
# 开启ASPF模块的丢包会话功能。
[Sysname] session fast-drop aspf enable
·     display session fast-drop table ipv4
·     display session fast-drop table ipv6
1.1.50  session fast-drop hardware-fast-forwarding
session fast-drop hardware-fast-forwarding命令用来开启丢包会话的硬件快速转发功能。
undo session fast-drop hardware-fast-forwarding命令用来关闭丢包会话的硬件快速转发功能。
系列
型号
F5000系列
支持
不支持
F1000系列
F1000-AK9130、F1000-AI-90、F1000-AI-80、F1000-AI-75、F1000-AI-70、F1000-AI-65、F1000-AI-60、F1000-AI-55、F1000-AI-35、F1000-AI-25、F1000-AI-15、F1000-AI-10、F1000-AI-05、F1000-AI-90-G、F1000-AI-80-G、F1000-AI-75-G、F1000-AI-65-G、F1000-AI-55-G、F1000-AI-35-G、F1000-AI-25-G、F1000-AI-15-G、F1000-AI-05-G、F1000-AI-03-G、F1000-AI-05-GS、F1000-AI-03-E、F1000-AK1380-G、F1000-AK1300-G、F1000-AK1220-G、F1000-AK1180-G、F1000-AK1080-G、F1000-AK1050-G、F1000-V90、F1000-V60、F1000-V50
不支持
插卡
不支持
丢包会话的硬件快速转发功能处于关闭状态。
context-admin
工作机制
开启此功能后,设备会将丢包流量触发创建的丢包会话表项下发硬件芯片,后续报文将直接匹配硬件芯片中的丢包会话表项进行报文丢弃,从而实现设备的快速丢包。
配置准备
此功能仅在丢包会话功能和硬件快速转发功能均处于开启状态时才能生效。有关硬件快速转发功能的详细介绍,请参见“三层技术-IP业务配置指导”中的“快速转发”。
推荐配置
一般情况下建议开启此功能,当需要定位硬件芯片是否存在故障时,可以关闭此功能。
注意事项
非缺省vSystem不支持本命令。
# 开启丢包会话的硬件快速转发功能。
<Sysname> system
[Sysname] session fast-drop hardware-fast-forwarding
·     hardware fast-forwarding enable(三层技术-IP业务命令参考/快速转发)
1.1.51  session fast-drop resource-ratio
session fast-drop resource-ratio命令用来配置丢包会话在会话总数中的最大占比。
undo session fast-drop resource-ratio命令用来恢复缺省情况。
session fast-drop resource-ratio ratio
丢包会话在会话总数中的最大占比50‰。
context-admin
ratio:表示丢包会话在会话总数中的最大占比,取值范围为1~100,单位为千分比。
非缺省vSystem不支持本命令。
当设备上的丢包会话表项数量达到指定的阈值时,设备对后续丢弃的报文不再生成丢包会话表项。
# 配置丢包会话在会话总数中的最大占比1‰。
[Sysname] session fast-drop resource-ratio 1
1.1.52  session fast-drop top-statistics enable
session fast-drop top-statistics enable命令用来开启丢包会话Top排名统计功能。
undo session fast-drop top-statistics enable命令用来关闭丢包会话Top排名统计功能。
丢包会话Top排名统计功能处于关闭状态。
context-admin
非缺省vSystem不支持本命令。
开启丢包会话Top排名统计功能后,设备将对基于丢包会话的业务进行丢包会话数目统计,分别基于源地址和目的地址对新建丢包会话数目进行排序。丢包会话Top排名统计信息可以通过display session fast-drop top-statistics命令查看。
# 开启丢包会话数目的Top排名统计功能。
[Sysname] session fast-drop top-statistics enable
·     display session fast-drop top-statistics
·     session fast-drop enable
1.1.53  session fast-drop-usage threshold
session fast-drop-usage threshold命令用来配置丢包会话表项上限使用率告警阈值。
undo session fast-drop-usage threshold命令用来恢复缺省情况。
session fast-drop-usage threshold threshold-value
丢包会话表项上限使用率阈值为95%。
context-admin
threshold-value:丢包会话表项上限使用率告警阈值,取值范围为1~99,单位为百分比。
工作机制
当设备上丢包会话表项上限使用率达到指定阈值时,发送超过丢包会话表项上限使用率阈值告警;当丢包会话表项上限使用率低于指定阈值时,发送低于丢包会话表项上限使用率阈值告警。
配置准备
只有通过session alarm-log enable命令打开会话上限使用率告警日志功能后,丢包会话表项上限使用率告警日志才会被发送。
注意事项
非缺省vSystem不支持本命令。
# 配置丢包会话表项上限使用率告警阈值为80%。
[Sysname] session fast-drop-usage threshold 80
·     session alarm-log enable
1.1.54  session flow-redirect enable
session flow-redirect enable命令用来开启会话引流功能。
undo session flow-redirect enable命令用来关闭会话引流功能。
系列
型号
F5000系列
支持
不支持
F1000系列
不支持
插卡
不支持
会话引流功能处于关闭状态,流量由OpenFlow流表进行引流。
context-admin
工作机制
开启会话引流功能后,当同一条数据流的正反向报文被转发到不同安全业务板处理时,正向报文的会话创建成功后会被立即同步到处理反向报文的安全业务板。之后,当此条数据流的反向报文被转发到相应安全业务板后就能被正常处理。正向流量的会话被删除后,被同步到其他安全业务板的会话也会被同步删除。
缺省情况下,系统使用OpenFlow流表对设备上的报文进行转发,以保证同一条数据流的正反向报文被转发到相同的安全业务板进行处理。当设备上已配置业务所需的OpenFlow流表数量超过设备允许的最大限制时,可能会造成同一条数据流的正反向报文被转发到不同的安全业务板,这时会导致报文处理失败。为解决以上问题,需要先在相应业务模块中关闭生成OpenFlow流表功能,然后再开启会话引流功能。
配置准备
此功能仅在相应业务模块关闭生成OpenFlow流表功能后才生效。有关各业务模块关闭生成OpenFlow流表功能的详细介绍,请参见各业务模块的配置指导手册。
注意事项
非缺省vSystem不支持本命令。
开启硬件快速转发功能的情况下,开启会话引流功能后,安全业务板上的会话表项不下发硬件芯片,因此安全业务的硬件快速转发功能将失效。有关硬件快速转发功能的详细介绍,请参见“三层技术-IP业务配置指导”中的“快速转发”。
# 开启会话引流功能。
[Sysname] session flow-redirect enable
·     session flow-redirect hardware-fast-forwarding
·     undo nat flow-redirect all(三层技术-IP业务命令参考/NAT)
1.1.55  session flow-redirect hardware-fast-forwarding
session flow-redirect hardware-fast-forwarding命令用来开启会话引流的硬件快速转发功能。
undo session flow-redirect hardware-fast-forwarding命令用来关闭会话引流的硬件快速转发功能。
系列
型号
F5000系列
支持
不支持
F1000系列
不支持
插卡
不支持
会话引流的硬件快速转发功能处于关闭状态。
context-admin
工作机制
开启此功能后,设备会将首报文触发创建的会话表项下发硬件芯片,后续报文将直接匹配硬件芯片中的会话表项进行转发,从而提高设备对报文的转发速度。
配置准备
此功能仅在会话引流功能和硬件快速转发功能均处于开启状态时才能生效。有关硬件快速转发功能的详细介绍,请参见“三层技术-IP业务配置指导”中的“快速转发”。
注意事项
非缺省vSystem不支持本命令。
# 开启会话引流的硬件快速转发功能。
[Sysname] session flow-redirect hardware-fast-forwarding
1.1.56  session hotbackup-mode
session hotbackup-mode命令用来配置双机热备中会话表项备份的负载分担模式。
undo session hotbackup-mode命令用来恢复缺省情况。
session hotbackup-mode { per-flow | per-packet }
双机热备中会话表项备份的负载分担模式为逐包模式。
context-admin
vsys-admin
per-flow:表示双机热备中会话表项备份的负载分担模式为逐流模式。
per-packet:表示双机热备中会话表项备份的负载分担模式为逐包模式。
在HA联动路由的三层双主组网环境中,需要在上下行设备上通过ip load-sharing mode命令配置IP报文转发的负载分担模式,以实现两台RBM成员设备均衡处理业务的目的。同时,需要在RBM成员设备上通过本命令配置与IP报文转发负载分担模式相同的会话表项备份负载分担模式。
本命令只在RBM双主组网中生效,且两台设备上配置的会话表项备份的负载分担模式必须保持一致。
# 配置双机热备中会话表项备份的负载分担模式为逐流模式。
<Sysname> system
[Sysname] session hotbackup-mode per-flow
·     hot-backup enable(高可靠性/双机热备(RBM))
·     ip load-sharing mode(三层技术-IP业务命令参考/IP转发基础)
1.1.57  session ip-top-count enable
session ip-top-count enable命令用来开启IPv4会话数据的Top排名统计功能。
undo session ip-top-count enable用来关闭IPv4会话数据的Top排名统计功能。
IPv4会话数据的Top排名统计功能处于关闭状态。
context-admin
vsys-admin
开启IPv4会话数据的Top排名统计功能之后,设备将对设备基于会话业务的新建会话速率和并发会话数量进行统计,并根据源IPv4地址或目的IPv4地址进行排行。排行结果可以通过登录设备Web管理页面查看。
# 开启IPv4会话数据的Top排名统计功能。
[Sysname] session ip-top-count enable
·     session ip-top-count policy
1.1.58  session ip-top-count policy
session ip-top-count policy 命令用来进入IPv4会话数据Top排名统计策略视图。
IPv4会话数据Top排名统计策略视图下不存在配置。
context-admin
vsys-admin
IPv4会话数据Top排名统计策略用于指定统计会话的源或目的IPv4地址。若指定了源或目的IPv4地址,则仅对指定的IPv4地址进行统计;若不指定任何源或目的IPv4地址,则对所有的会话进行统计。
# 进入IPv4会话数据Top排名统计策略视图。
[Sysname] session ip-top-count policy
·     display session ip-top-count policy
·     source-ip
·     destination-ip
1.1.59  session ipv6-top-count enable
session ipv6-top-count enable命令用来开启IPv6会话数据的Top排名统计功能。
undo session ipv6-top-count enable用来关闭IPv6会话数据的Top排名统计功能。
IPv6会话数据的Top排名统计功能处于关闭的状态。
context-admin
vsys-admin
开启IPv6会话数据的Top排名统计功能之后,设备将对设备基于会话业务的新建会话速率和并发会话数量进行统计,并根据源IPv6地址或目的IPv6地址进行排行。排行结果可以通过登录设备Web管理页面查看。
# 开启IPv6会话数据的Top排名统计功能。
[Sysname] session ipv6-top-count enable
·     session ipv6-top-count policy
1.1.60  session ipv6-top-count policy
session ipv6-top-count policy 命令用来进入IPv6会话数据Top排名统计策略视图。
IPv6会话数据Top排名统计策略视图下不存在配置。
context-admin
vsys-admin
IPv6会话数据Top排名统计策略用于指定统计会话的源或目的IPv6地址。若指定了源或目的IPv6地址,则仅对指定的IPv6地址进行统计;若不指定任何源或目的IPv6地址,则对所有的会话进行统计。
# 进入IPv6会话数据Top排名统计策略视图。
[Sysname] Session ipv6-top-count policy
·     display session ipv6-top-count policy
·     source-ip
·     destination-ip
1.1.61  session log { bytes-active | packets-active }
session log { bytes-active | packets-active }命令用来配置输出会话日志的流量阈值。
undo session log { bytes-active | packets-active }命令用来恢复缺省情况。
session log { bytes-active bytes-value | packets-active packets-value }
未配置输出会话日志的流量阈值。
context-admin
vsys-admin
bytes-value:表示字节数阈值,取值范围为1~100000,单位为兆字节。
packets-value:表示报文数阈值,取值范围为1~100000,单位为兆包。
工作机制
如果设置的流量阈值为n,则一个会话每传输n兆个字节整数倍时或n兆个报文,设备就输出一次相应的会话日志。
同时配置了时间阈值和流量阈值的情况下,只要有一个阈值到达,就会输出相应的会话日志,并将所有的阈值统计信息清零。
多次执行本命令,最后一次执行的命令生效。
配置准备
配置的流量阈值在软件快速转发的会话统计功能处于开启的状态下才能生效。否则,会话由于无法统计报文的流量信息而不能通过流量阈值触发输出会话日志。
# 设置输出会话日志的流量阈值为10兆包。
[Sysname] session statistics enable
[Sysname] session log packets-active 10
·     session log enable
·     session statistics enable
1.1.62  session log enable
session log enable命令用来开启会话日志功能。
undo session log enable命令用来关闭会话日志功能。
session log enable { ipv4 | ipv6 } [ acl acl-number ] { inbound | outbound }
undo session log enable { ipv4 | ipv6 } [ acl acl-number ] { inbound | outbound }
会话日志功能处于关闭状态。
context-admin
vsys-admin
ipv4:表示IPv4会话日志。
ipv6:表示IPv6会话日志。
acl acl-number:对与指定ACL相匹配的会话输出会话日志,其中acl-number表示ACL的编号,取值范围为2000~3999。如果不指定ACL,则表示允许输出经过接口的所有IPv4或IPv6会话的日志。
inbound:指定输出入方向的会话日志。
outbound:指定输出出方向的会话日志。
工作机制
开启会话日志功能后,若指定了相关阈值(流量阈值、时间阈值),则达到阈值条件时输出相应的会话日志。
可配置仅输出单方向的会话日志,也可以配置输出双向的会话日志。每个方向上最多可以配置一个IPv4 ACL规则和一个IPv6 ACL规则。
开启会话日志功能后,若开启了新建会话日志功能和删除会话日志功能,则在会话表创建和删除时分别输出一次会话日志;否则在会话表创建和删除时不输出会话日志。
配置准备
因为会话日志仅支持通过Flow日志或快速日志输出方式进行输出,缺省使用Flow日志形式,所以开启会话日志功能后,必须配置Flow日志或快速日志输出的相关功能才能输出会话日志信息。有关Flow日志模块的相关配置请参见“网络管理和监控配置指导”中的“Flow日志”。有关快速日志输出模块的相关配置请参见“网络管理和监控配置指导”中的“快速日志输出”。
# 在GigabitEthernet1/0/1接口下开启会话日志功能,指定输出此接口入方向上的所有IPv4会话日志。‌
[Sysname] session log flow-begin
[Sysname] session log flow-end
[Sysname-GigabitEthernet1/0/1] session log enable ipv4 inbound
# 在GigabitEthernet1/0/2接口下开启会话日志功能,指定输出此接口出方向上匹配ACL 2050的IPv4会话日志。‌
[Sysname-GigabitEthernet1/0/2] session log enable ipv4 acl 2050 outbound
# 在GigabitEthernet1/0/3接口下开启会话日志功能,指定输出此接口出方向上匹配ACL 2050的IPv6会话日志。‌
[Sysname] interface gigabitethernet 1/0/3
[Sysname-GigabitEthernet1/0/3] session log enable ipv6 acl 2050 outbound
·     session log bytes-active
·     session log flow-begin
·     session log flow-end
·     session log packets-active
·     session log time-active
1.1.63  session log flow-begin
session log flow-begin命令用来开启新建会话日志功能,即新建会话时输出会话日志。
undo session log flow-begin命令用来关闭新建会话日志功能。
undo ssession log flow-begin
新建会话日志功能处于关闭状态。
context-admin
vsys-admin
只有同时开启了会话日志功能和新建会话日志功能,新建会话时才会输出会话日志。
# 开启新建会话日志功能。
1.1.64  session log flow-end
session log flow-end命令用来开启删除会话日志功能,即删除会话时输出会话日志。
undo session log flow-end命令用来关闭删除会话日志功能。
删除会话日志功能处于关闭状态。
context-admin
vsys-admin
只有同时开启了会话日志功能和删除会话日志功能,删除会话时才会输出会话日志。
# 开启删除会话日志功能。
1.1.65  session log time-active
session log time-active命令用来配置输出会话日志的时间阈值。
undo session log time-active用来恢复缺省情况。
session log time-active time-value
不依据时间阈值发送会话日志。
context-admin
vsys-admin
time-value:表示发送会话日志的时间阈值,取值范围为10~120,单位为分钟,只能为10的整数倍。
如果设置的时间阈值为n,则每经过n分钟,设备就输出一次相应的会话日志。
# 设置输出会话日志的时间阈值为50分钟。
<Sysname> system
[Sysname] session log time-active 50
·     session log { bytes-active | packets-active }
1.1.66  session log with-endtime
session log with-endtime命令用来配置所有会话日志均携带会话删除时间字段。
undo session log with-endtime用来恢复缺省情况。
仅删除会话日志携带会话删除时间字段。
context-admin
非缺省vSystem不支持本命令。
除了删除会话时输出的日志,输出其他会话日志时由于会话还没有删除,所以缺省情况下会话删除时间(EndTime)字段显示为空。若需满足部分特殊场景规范要求,可通过该功能将其他会话日志的会话删除时间字段显示为创建会话的时间,在一般场景中无需配置。
# 配置新建会话日志和活跃会话日志携带会话删除时间字段。
[Sysname] session log with-endtime
1.1.67  session persistent acl
session persistent acl命令用来配置长连接会话规则。
undo session persistent acl命令用来恢复缺省情况。
session persistent acl [ ipv6 ] acl-number [ aging-time time-value ]
undo session persistent acl [ ipv6 ] acl-number
无长连接会话规则。
context-admin
vsys-admin
ipv6:指定IPv6 ACL。如果没有指定本参数,则表示IPv4 ACL。
acl-number:ACL的编号,取值范围为2000~3999。
aging-time time-value:长连接会话的老化时间。其中,time-value表示指定的老化时间,取值范围为0~360,单位为小时,缺省值为24。0表示永不老化。
长连接老化时间仅在TCP会话进入稳态(TCP-EST状态)时生效。在TCP会话处于稳态时,长连接老化时间具有最高的优先级,其次为应用层协议老化时间,最后为协议状态老化时间。
对于长连接会话规则触发生成的长连接会话不会因为其配置的删除、修改或没有报文命中而被删除,只有当会话的发起方或响应方主动发起关闭连接请求、达到长连接会话老化时间或管理员使用reset session table命令手动删除该会话时,才会被删除。
长连接会话的配置仅影响后续生成的会话,对于已经生效的会话不产生作用。
可通过多次执行此命令来配置多条长连接会话规则。
# 配置符合ACL 2000规则的IPv4会话为长连接,老化时间为72小时。
[Sysname] session persistent acl 2000 aging-time 72
# 配置符合ACL 3000规则的IPv6会话为长连接,老化时间为100小时。
[Sysname] session persistent acl ipv6 3000 aging-time 100
·     session aging-time state
1.1.68  session relation-table aging-time application sunrpc
session relation-table aging-time application sunrpc命令用来配置SUNRPC协议会话关联表的老化时间。
undo session relation-table aging-time application命令用来恢复缺省情况。
session relation-table aging-time application sunrpc time-value
undo session relation-table aging-time application [ sunrpc ]
SUNRPC协议会话关联表的老化时间为115200秒。
context-admin
time-value:SUNRPC协议会话关联表的老化时间,取值范围为1~259200,单位为秒。
sunrpc:恢复SUNRPC协议会话关联表的老化时间到缺省值。若未指定本参数,则恢复所有协议会话管理表项的老化时间到缺省值
通过执行本命令可以指定SUNRPC协议会话关联表的老化时间,如果在老化时间内没有流量匹配到此会话关联表,则此会话关联表自行老化。
# 配置SUNRPC协议会话关联表的老化时间为14400秒。
[Sysname] session relation-table aging-time application sunrpc 14400
·     display session relation-table aging-time application
1.1.69  session relation-table match destination-ip sip enable
session relation-table match destination-ip sip enable命令开启SIP协议关联表项匹配目的地址功能。
undo session relation-table match destination-ip sip enable命令用来关闭SIP协议关联表项匹配目的地址功能。
SIP协议关联表项匹配目的地址功能处于关闭状态。
context-admin
vsys-admin
在SIP应用组网环境中,由于数据流量在匹配关联表项时不会匹配目的地址,若同一客户端需要通过设备多个出接口访问多个服务器则有可能匹配错误的关联表项,导致数据流量无法正常转发。
开启SIP协议关联表项匹配目的地址功能后,当数据流量匹配关联表项时,需要同时匹配目的地址,从而准确匹配关联表项转发数据流量。
# 开启SIP协议关联表项匹配目的地址功能。
[Sysname] session relation-table match destination-ip sip enable
1.1.70  session relation-table-usage threshold
session relation-table-usage threshold命令用来配置关联表项上限使用率告警阈值。
undo session relation-table-usage threshold命令用来恢复缺省情况。
session relation-table-usage threshold threshold-value
关联表项上限使用率告警阈值为95%。
context-admin
threshold-value:关联表项上限使用率阈值,取值范围为1~99,单位为百分比。
工作机制
当设备上关联表项上限使用率达到指定阈值时,发送超过关联表项上限使用率阈值告警;当关联表项上限使用率低于指定阈值时,发送低于关联表项上限使用率阈值告警。
配置准备
只有通过session alarm-log enable命令打开会话上限使用率告警日志功能后,关联会话表项上限使用率告警日志才会被发送。
注意事项
非缺省vSystem不支持本命令。
# 配置关联表项上限使用率告警阈值为80%。
[Sysname] session relation-table-usage threshold 80
1.1.71  session reliable-backup enable
session reliable-backup enable命令用来开启会话可靠备份功能。
undo session reliable-backup enable命令用来关闭会话可靠备份功能。
会话可靠备份功能处于关闭状态。
context-admin
应用场景
在会话引流或广播流量场景下,存在端口快速复用或会话快速新建和删除的情况,由于多核CPU处理及备份时序等可能会导致备机会话残留或会话备份后立即被错误删除的问题,具体如下:
·     当同一会话快速新建和删除时,热备份的新建和删除消息可能会乱序到达备机,若删除消息先到新建消息后到,则会导致RBM备机上会话残留。
·     当同一五元组的不同会话先后进行删除和新建时,热备份的删除和新建消息也可能乱序,若新建消息先到而删除消息后到,则会导致新建的会话被错误删除,进而引发服务中断。
为解决上述问题,建议开启会话可靠备份功能,以确保网络服务的连续性和数据的完整性。
注意事项
非缺省vSystem不支持本命令。
开启会话可靠备份功能后,会话主备关系不再切换,主会话删除可能会存在延迟等现象。
# 开启会话可靠备份功能。
[Sysname] session reliable-backup enable
·     reliable-backup enable(高可靠性/双机热备(RBM))
1.1.72  session state-machine mode
session state-machine mode命令用来配置会话状态机的模式。
undo session state-machine mode命令用来恢复缺省情况。
session state-machine mode { compact | loose }
会话状态机为严格模式。
context-admin
vsys-admin
compact:表示会话简化状态机模式。
loose:表示会话宽松状态机模式。
应用场景
严格模式:此模式下设备会严格根据协议的运行机制进行报文合法性检查。比如对于TCP报文,设备会根据TCP“三次握手”建立连接,“四次挥手”断开连接的运行机制,对TCP报文进行合法性检查,只有检查合法的报文(比如设备收到的首个报文必须是SYN报文或ACK报文)才能创建会话,并进行后续安全业务检查,保证业务安全。此模式适用于来回报文路径一致,对业务安全性要求较高的场景。
简化模式:此模式下设备可以加速会话的老化速度,节省设备资源,保证其他业务的正常处理。在报文来回路径不一致的网络环境中,当TCP连接断开时,设备可能只会收到FIN报文,不会收到后续的ACK报文。这种情况下,如果是严格模式,会话进入FIN状态,且此状态的老化时间(缺省30秒)到达后删除会话;如果是简化模式,会话则直接进入TCP-TIME-WAIT状态,且此状态的老化时间(缺省2秒)到达后删除会话。以上不同协议状态的等待时间均为设备的缺省情况,用户可以根据网络实际情况使用session aging-time state命令来调整会话的老化时间。此模式适用于来回报文路径不一致,网络业务流量大,设备资源占用率高的场景。
宽松模式:此模式下设备将不对报文进行合法性检查。比如对于TCP报文,即使收到的首个报文不是SYN报文或ACK报文,也会放行此报文,进行后续业务处理,保证业务的互通,但是不会在设备上创建会话。此模式适用于来回报文路径不一致,对业务安全性要求不高的场景。
推荐配置
在报文来回路径一致的网络场景中,不建议更改会话状态机的模式,保持缺省的严格模式即可。
在报文来回路径不一致的网络场景中,建议根据实际需求来选择不同的会话状态机模式,以保证业务的正常处理。
工作机制
# 配置会话状态机为宽松模式。
[Sysname] session state-machine mode loose
1.1.73  session statistics enable
session statistics enable命令用来开启软件快速转发的会话统计功能。
undo session statistics enable命令用来关闭软件快速转发的会话统计功能。
软件快速转发的会话统计功能处于关闭状态。
context-admin
vsys-admin
开启软件快速转发的会话统计功能之后,设备将对经软件快速转发收到和发送的基于会话的业务报文数目和报文字节数进行统计,基于会话的报文统计信息可以通过display session table命令查看,基于报文类型的报文统计信息可以通过display session statistics命令查看。
开启此功能后,会占用较多的CPU和内存资源,请只在需要时开启。
# 开启软件快速转发的会话统计功能。
1.1.74  session statistics hardware-fast-forwarding
session statistics hardware-fast-forwarding命令用来开启硬件快速转发的会话统计功能,并配置输出统计的阈值。
undo session statistics hardware-fast-forwarding命令用来关闭硬件快速转发的会话统计功能。
session statistics hardware-fast-forwarding { bytes-active bytes-value | packets-active packets-value }
undo session statistics hardware-fast-forwarding { bytes-active | packets-active }
本命令的支持情况与设备型号有关,请以设备的实际情况为准。
系列
型号
F5000系列
F5000-CN160、F5000-AI360、F5000-AI160、F5000-AI120、F5000-E、F5000-AI-160-G、F5000-AI-130-G、F5000-AI-110-G、F5000-CN160-G、F5000-E-G、F5000-E-G2
支持
F5080、F5060、F5030、F5000-CN-G85、F5000-CN-G65、F5000-CN-G55、F5000-AI-120-G、F5000-AI-55-G、F5000-AI-25-G、F5000-AI-15-G、F5000-S-G2、F5000-M-G2、F5000-A-G2、F5000-AI-15
不支持
F1000系列
不支持
插卡
LSEM1FWESD0、LSXM1FWDF1、LSUM1FWDEC0、IM-NGFWX-IV、LSQM1FWDSC0、LSWM1FWD0、LSPM6FWD、LSPM6FWDB、LSCM1FWDSD0
不支持
硬件快速转发的会话统计功能处于关闭状态。
context-admin
vsys-admin
bytes-active:表示字节数阈值。
bytes-value:表示字节数阈值,取值范围为1~100000,缺省单位为兆字节。
packets-active packets-value:表示报文数阈值,取值范围为1~100000,单位为兆包。
工作机制
如果设置的流量阈值为n,则一个会话每传输n兆个字节整数倍时或n兆个报文,设备就对硬件快速转发输出一次相应的会话统计信息。
硬件快速转发的会话统计功能可为会话以及其他业务模块提供经硬件快速转发的报文的统计信息,会话以及其他业务模块可根据这些报文统计信息对流经设备的流量做更精准的统计。
注意事项
当设备上同时配置session statistics hardware-fast-forwarding { bytes-active | packets-active }命令和session log { bytes-active | packets-active }命令时,请指定相同类型的流量阈值,比如同时使用字节数阈值或同时使用报文数阈值。
# 开启硬件快速转发的会话统计功能,并配置输出统计的字节数阈值为10兆字节。
[Sysname] session statistics hardware-fast-forwarding bytes-active 10
1.1.75  session synchronization { dns | http } *
session synchronization { dns | http } *命令用来开启应用协议的会话备份功能。
undo session synchronization { dns | http } *命令用来关闭应用协议的会话备份功能。
DNS、HTTP应用协议的会话备份功能处于关闭状态。
context-admin
dns:应用协议类型为DNS。
http:应用协议类型为HTTP。
应用场景
对于DNS和HTTP类型的应用协议,通常在很少的报文交互之后就会断开连接,当发生主备切换造成当前连接中断时,客户端会立即重新发起请求,用户通常感知不到连接异常。因此,在大多数情况下这些应用协议不需要进行会话备份。
缺省情况下,DNS和HTTP的应用协议备份功能处于关闭状态,即不会备份DNS会话和HTTP会话。如果用户明确知道当前的HTTP会话或者DNS会话将会持续较长的连接时间,或者确实希望对这两个应用协议创建的会话进行备份,可以通过该命令开启DNS或者HTTP的会话备份功能。
注意事项
除了DNS和HTTP应用协议,其它应用协议创建的会话不受该命令控制,只要会话备份功能处于开启状态,就会进行会话备份。
非缺省vSystem不支持本命令。
# 开启会话业务热备份功能,并开启HTTP应用协议的会话备份功能。
<Sysname> system
[Sysname] session synchronization enable
[Sysname] session synchronization http
1.1.76  session synchronization enable
session synchronization enable命令用来开启会话业务热备份功能。
undo session synchronization enable命令用来关闭会话业务热备份功能。
session synchronization enable [ asymmetric ]
会话业务热备份功能处于关闭状态。
context-admin
asymmetric:表示会话业务热备份功能支持处理非对称流量。如果不配置该参数,会话业务热备份功能仅支持处理对称流量。
兼容性说明
此功能不能与RBM热备功能(hot-backup enable)同时使用。有关RBM热备功能的详细介绍,请参见“高可靠性命令参考”中的“双机热备(RBM)”。
应用场景
当网络中有可能存在非对称流量时,如果业务流量很大,需要备份的会话比较多,这时可能会由于备份不及时使部分业务有延时甚至不通,为解决此问题可在设备上配置“支持非对称流量”功能。例如,TCP业务的SYN报文由一台设备转发,而ACK报文由另一台设备转发,若会话表还未备份过来,将导致报文因状态错误被丢弃。
工作机制
会话业务热备份功能实现了多台设备之间会话以及基于会话的业务的动态表项的热备份。
注意事项
非缺省vSystem不支持本命令。
# 开启会话业务热备份能。
# 开启会话业务热备份能,并支持处理非对称流量。
[Sysname] session synchronization enable asymmetric
·     hot-backup enable(高可靠性命令参考/双机热备(RBM))
1.1.77  session table-state-backup enable
session table-state-backup enable命令用来开启会话表状态同步功能。
undo session table-state-backup enable命令用来关闭会话表状态同步功能。
会话表状态同步功能处于关闭状态。
context-admin
当通过执行本命令开启会话表状态同步功能后,会话表状态达到稳态时,设备会将会话表状态同步给备会话。用于解决双机组网中,由于主机故障,备机会话又恰逢老化导致的断流问题。通过会话表状态备份后,当主机故障后,备会话可以切换成稳态,处理流量。
# 配置会话表状态同步功能。
<Sysname> system
[Sysname] session table-state-backup enable
1.1.78  session top-statistics enable
session top-statistics enable命令用来开启会话数目的Top排名统计功能。
undo session top-statistics enable命令用来关闭会话数目的Top排名统计功能。
会话数目的Top排名统计功能处于关闭状态。
context-admin
vsys-admin
开启会话数目的Top排名统计功能之后,设备将对基于会话的业务进行会话数目统计,分别基于源地址和目的地址对新建会话数目进行排序。会话数目的Top排名统计信息可以通过display session top-statistics命令查看。
# 开启会话数目的Top排名统计功能。
[Sysname] session top-statistics enable
·     display session top-statistics
1.1.79  session usage threshold
session usage threshold命令用来配置会话表项上限使用率告警阈值。
undo session usage threshold命令用来恢复缺省情况。
session usage threshold threshold-value
会话表项上限使用率告警阈值为95%。
context-admin
threshold-value:会话表项上限使用率阈值,取值范围为1~99,单位为百分比。
工作机制
当设备上会话表项上限使用率达到指定阈值时,发送超过会话表项上限使用率阈值告警;当会话表项上限使用率低于指定阈值时,发送低于会话表项上限使用率阈值告警。
配置准备
只有通过session alarm-log enable命令打开会话上限使用率告警日志功能后,会话表项上限使用率告警日志才会被发送。
注意事项
非缺省vSystem不支持本命令。
# 配置会话表项上限使用率阈值为90%。
[Sysname] session usage threshold 90
1.1.80  source-ip
source-ip命令用于配置作为会话数据Top排名统计策略过滤条件的源IP地址。
undo source-ip命令用于配置作为会话数据Top排名统计策略过滤条件的源IP地址。
IPv4会话数据Top排名统计策略视图:
source-ip subnet subnet-ip-address mask-length
undo source-ip
IPv6会话数据Top排名统计策略视图:
source-ip subnet subnet-ipv6-address prefix-length
undo source-ip
不存在源IP地址的过滤条件。
IPv4会话数据Top排名统计策略视图
IPv6会话数据Top排名统计策略视图
context-admin
vsys-admin
subnet subnet-ipv4-address mask-length:指定子网IPv4地址。subnet-ipv4-address表示子网IPv4地址;mask-length表示子网掩码长度,取值范围为16~32。
subnet subnet-ipv6-address prefix-length:指定子网IPv6地址。subnet-ipv6-address表示子网IPv6地址;prefix-length表示子网前缀长度,取值范围为96~128。
配置会话数据Top排名统计策略过滤条件的源IP地址后,则仅对符合源IP地址过滤条件的会话进行统计。
IPv4或IPv6会话数据Top排名统计策略只能配置一个源IP子网地址作为过滤条件,多次执行本命令,最后一次执行的命令生效。
# 作为会话数据Top排名统计策略过滤条件的源IP地址为10.1.0.0/16。
[Sysname-session-ip-top-count-policy] source-ip subnet 10.1.0.0 16
