02-负载均衡命令参考
07-SSLO流量编排命令
本章节下载: 07-SSLO流量编排命令  (580.01 KB)
07-SSLO流量编排命令
1 SSLO流量编排
1.1 SSLO流量编排命令
1.1.1 bypass
1.1.2 description
1.1.3 display loadbalance probe undetected
1.1.4 display sslo policy
1.1.5 display sslo security-node
1.1.6 display sslo security-node statistics
1.1.7 display sslo security-pool
1.1.8 display sslo service-chain
1.1.9 display ssl-transparent bypass-decrypt
1.1.10 display ssl-transparent bypass-decrypt domain
1.1.11 display ssl-transparent cm-certificate
1.1.12 fail-action
1.1.13 from-security-node-interface
1.1.14 from-security-node-nexthop
1.1.15 ip-address
1.1.16 loadbalance probe nqa-task-restrict disable
1.1.17 mac-address
1.1.18 match destination
1.1.19 match destination-port
1.1.20 match header
1.1.21 match interface
1.1.22 match source
1.1.23 match url
1.1.24 match user
1.1.25 match-mode
1.1.26 move match
1.1.27 predictor
1.1.28 priority (SSLO security pool member view)
1.1.29 probe (SSLO security node view)
1.1.30 probe (SSLO security pool view)
1.1.31 probe log enable
1.1.32 reset sslo security-node statistics
1.1.33 reset ssl-transparent bypass-decrypt ip
1.1.34 reset ssl-transparent server-certificate
1.1.35 security-node
1.1.36 security-pool
1.1.37 selected-node-limit
1.1.38 service enable (SSLO security node view)
1.1.39 service enable (SSLO security pool member view)
1.1.40 service-chain
1.1.41 ssl mapping-port
1.1.42 sslo policy
1.1.43 sslo security-node
1.1.44 sslo security-pool
1.1.45 sslo service-chain
1.1.46 sslo work-mode
1.1.47 ssl-transparent bypass-decrypt activate
1.1.48 ssl-transparent bypass-decrypt domain
1.1.49 ssl-transparent cm-certificate delete
1.1.50 ssl-transparent cm-certificate import
1.1.51 success-criteria (SSLO security node view)
1.1.52 success-criteria (SSLO security pool view)
1.1.53 to-security-node-interface
1.1.54 to-security-node-nexthop
1.1.55 type
1.1.56 weight (SSLO security node view)
1.1.57 weight (SSLO security pool member view)
1 SSLO流量编排
1.1  SSLO流量编排命令
1.1.1  bypass
bypass命令用来开启安全资源池的Bypass功能。
undo bypass命令用来关闭安全资源池的Bypass功能。
bypass
安全资源池的Bypass功能处于关闭状态。
安全资源池视图
context-admin
工作机制
安全资源池配置本命令后,流量会直接跳过该安全资源池,转发给服务链下一个安全资源池进行处理。
# 在安全资源池sp1视图下,开启安全资源池的Bypass功能。
[Sysname] sslo security-pool sp1 mode layer2
[Sysname-sslo-security-pool-l2-sp1] bypass
1.1.2  description
description命令用来配置描述信息。
undo description命令用来恢复缺省情况。
安全网元视图
安全资源池视图
服务链视图
SSLO编排策略视图
未配置描述信息。
context-admin
text:描述信息,为1~127个字符的字符串,区分大小写。
# 配置安全网元的描述信息为“security node test”。
[Sysname] sslo security-node sn
[Sysname-sslo-security-node-sn] description security node test
display loadbalance probe undetected显示由于NQA健康检测速率限制而未启动的健康检测任务信息。
display loadbalance probe undetected { dns-server | link | real-server | security-node }
context-admin
dns-server:显示DNS服务器下未启动的NQA健康检测任务信息。
link:显示链路下未启动的NQA健康检测任务信息。
real-server:显示实服务器下未启动的NQA健康检测任务信息。
security-node:显示安全网元下未启动的NQA健康检测任务信息。
仅在开启NQA健康检测速率限制功能的情况下,存在因超出速率限制而未能启动的NQA健康检测任务时,系统才会显示相关内容。
# 显示实服务器下未启动的NQA健康检测任务信息。
<Sysname> display loadbalance probe undetected real-server
Real server: rs
Port: 20
Server farm: sf1
NQA template: t1
Probe type: IPv6
Record time: 2023-06-25 17:14:39
Real server: rs
Port: 20
Server farm: -
NQA template: t2
Probe type: IPv4
Record time: 2023-06-25 17:14:40
# 显示链路下未启动的NQA健康检测任务信息。
<Sysname> display loadbalance probe undetected link
Link: LK1
Link group: lg
NQA template: t3
Probe type: IPv4
Record time: 2023-06-25 17:14:41
Link: LK2
Link group: -
NQA template: t
Probe type: IPv4
Record time: 2023-06-25 17:14:46
# 显示DNS服务器下未启动的NQA健康检测任务信息。
<Sysname> display loadbalance probe undetected dns-server
DNS server: dns1
Port:2
DNS server pool: dnspool1
NQA template: t
Probe type:IPv4
Record time: 2023-06-25 17:14:42
DNS server: dns2
Port: -
DNS server pool: -
NQA template: t7
Probe type: IPv4
Record time: 2023-06-25 17:14:43
# 显示安全网元下未启动的NQA健康检测任务信息。
<Sysname> display loadbalance probe undetected security node
Security node: n1
Security pool: p1
NQA template: t1
Probe type: IPv4
Record time: 2025-05-29 17:14:39
Security node: n2
Security pool: -
NQA template: t2
Probe type: IPv4
Record time: 2025-05-29 17:14:40
表1-1 display loadbalance probe undetected命令显示信息描述表
Real server
实服务器或实服务组成员的名称
Server farm
未启动NQA健康检测的实服务组名称,如果是实服务器,显示为“-”
Link group
未启动NQA健康检测的链路组名称,如果是链路,显示为“-”
Link
链路或链路组成员的名称
DNS server
DNS服务器或DNS服务池成员的名称
DNS server pool
未启动NQA健康检测的DNS服务池的名称,如果是DNS服务器,显示为“-”
Security node
安全网元或安全资源池成员的名称
Security pool
未启动NQA健康检测的安全资源池的名称,如果是安全网元,显示为“-”
Port
NQA探测任务使用的探测端口,“-”表示使用探测模板配置的端口号探测
NQA template
NQA健康检测模板的名称
Probe type
健康检测类型,包括IPv4、IPv6、Interface
Record time
加入等待启动队列的时间
display sslo policy命令用来显示SSLO编排策略的信息。
display sslo policy [ name policy-name ]
context-admin
context-operator
name policy-name:显示指定SSLO编排策略的信息。policy-name为SSLO编排策略的名称,为1~255个字符的字符串,不区分大小写。如果未指定本参数,将显示所有SSLO编排策略的信息。
# 显示所有SSLO编排策略的详细信息。
<Sysname> display sslo policy
SSLO policy: sslop1
  Description: sslo policy
  Type: Generic
  Match mode: Any
  Service chains: sc1
  Match rules:
    match r1 source range 1.2.3.4 1.2.3.9
    match r2 source ipv4 subnet 2.2.2.2
SSLO policy: sslop2
  Description:
  Type: HTTP
  Match mode: All
  Service chains: sc2
  Match rules:
    match r1 url .*.html
    match rule1 header user-agent pattern abcd
表1-2 表1-1 display sslo policy命令显示信息描述表
SSLO policy
SSLO编排策略的名称
SSLO编排策略的描述信息
SSLO编排策略的类型,包括:
·     Generic:表示通用类型
·     HTTP:表示HTTP类型
Match mode
SSLO编排策略的匹配方式
Service chains
SSLO编排策略下引用的服务链
Match rules
SSLO编排策略包含的匹配规则
sslo policy
display sslo security-node命令用来显示安全网元的信息。
display sslo security-node { brief | name node-name }
context-admin
context-operator
brief:显示安全网元的简要信息。如果未指定本参数,将显示安全网元的详细信息。
name node-name:显示指定安全网元的信息。node-name为安全网元的名称,为1~255个字符的字符串,不区分大小写。如果未指定本参数,将显示所有安全网元的信息。
# 显示所有安全网元的简要信息。
<Sysname> display sslo security-node brief
Security node             Mode         State          Service
sn1                       Layer2       Active         enable
sn2                       Mirror       Busy           enable
sn3                       Layer2       Bypass(Active) enable
# 显示所有安全网元的详细信息。
Security node: sn1
  Description:
  State: Active
  Mode: Mirror
  Interface to security node: GigabitEthernet 1/0/0
  IPv4 address: 1.1.1.1
  MAC address: 5632-7542-5697
  Weight: 150
  Probe log: Enabled
  Bypass: Disabled
  Probe information:
    Probe success criteria: All
    Probe method                    State
    icmp                            Succeeded
Security node: sn2
  Description: l2 security node
  State: Active
  Mode: Layer2
  Nexthop to security node: 1.1.1.1
  Interface from security node: GigabitEthernet 1/0/2
  Nexthop from security node: 1.1.1.2
  Weight: 150
  Probe log: Enabled
  Service: Enabled
  Probe information:
    Probe method                    State
    icmp                            Succeeded
Security node: sn3
  Description: l3 security node
  State: Active
  Mode: Layer3
  Interface to security node: GigabitEthernet 1/0/3
  Nexthop to security node: 1.1.1.3
  Interface from security node: GigabitEthernet 1/0/4
  Nexthop from security node: 1.1.1.4
  Weight: 150
  Probe log: Enabled
  Service: Enabled
  Probe information:
    Probe method                    State
icmp                            Succeeded
Security node: sn4
  Description:
  State: Bypass(Active)
  Mode: Layer2
  Interface to security node: GigabitEthernet1/0/1
  Nexthop to security node: 1.2.3.5
  Interface from security node: GigabitEthernet1/0/0
  Nexthop from security node: 1.2.3.4
  Weight: 100
  Priority: 4
  Probe log: Disabled
  Service: Enabled
  Probe information:
    Probe method                       State
    icmp                               Succeeded
表1-3 display sslo security-node命令显示信息描述表
Security node
安全网元的名称
Address
安全网元的IPv4地址
Mode
安全网元的部署模式,包括:
·     Layer2:二层部署模式
·     Layer3:三层部署模式
·     Mirror:镜像部署模式
安全网元的状态,包括:
·     Active:可用
·     Inactive:不可用(由于配置不完全、未被引用或安全网元尚未开启)
·     Probe-failed:健康检测失败
·     Unknown:未配置健康检测
·     Shutdown:安全网元或安全资源池成员处于关闭状态(当安全网元配置了undo service enable)
IPv4 address
安全网元的IPv4地址,只有镜像模式的安全网元才会显示本字段
MAC address
安全网元的MAC地址,只有镜像模式的安全网元才会显示本字段
设备上流向安全网元的请求流量对应的出接口
设备上流向安全网元的请求流量对应的出接口下一跳IP地址
设备上来自安全网元的请求流量对应的入接口下一跳IP地址
安全网元的描述信息
Weight
安全网元的权值
Probe log
安全网元健康检测日志的状态,包括:
·     Enabled:开启
·     Disabled:关闭
Service
安全网元服务状态,包括:
·     Enabled:开启
·     Disabled:关闭
安全网元健康检测的成功条件:
·     All:只有全部方法都通过检测才认为健康检测成功
·     At least X:健康检测成功所需通过检测的最少方法数为X
Probe method
健康检测方法所使用的NQA模板名称
NQA健康检测方法的状态,包括:
·     Failed:健康检测失败
·     In progress:正在进行健康检测
·     Invalid:健康检测不可用(因其所使用的NQA模板配置不完全),或者网元不可用
·     Succeeded:健康检测成功
·     Undetected:由于NQA健康检测速率限制,NQA健康检测未启动
display sslo security-node statistics命令用来显示安全网元或安全资源池成员的统计信息。
display sslo security-node statistics [ name security-node-name | service-chain service-chain-name [ security-pool security-pool-name [ name security-node-name ] ] ] [ slot slot-number ]
context-admin
context-operator
name security-node-name:显示指定安全网元或安全资源池成员的统计信息。security-node-name为安全网元的名称,为1~255个字符的字符串,不区分大小写。service-chain service-chain-name:显示指定服务链下安全资源池中成员的统计信息。security-chain-name表示服务链的名称,为1~255个字符的字符串,不区分大小写。
security-pool security-pool-name:显示指定安全资源池下成员的统计信息。security-pool-name表示安全资源池的名称,为1~255个字符的字符串,不区分大小写。
slot slot-number:显示指定单板上的安全网元或安全资源池成员的统计信息,slot-number表示单板所在槽位号。如果未指定本参数,将显示所有单板上的信息。‌
配置本命令时未指定任何参数,将显示所有安全网元的统计信息。
# 显示安全网元sn的统计信息。
<Sysname> display sslo security-node statistics name sn
Slot 1:
Security node: sn
  To security node:
    Total connections: 1798
    Active connections: 788
    Max connections: 803
        recorded at 11:02:49 on Tue May 21 2019
    Connections per second: 157
    Max connections per second: 163
    Total throughput: 4396 bps
    Input throughput: 1214 bps
    Output throughput: 3128 bps
    Max throughput: 4564 bps
    Max input throughput: 1214 bps
    Max output throughput: 3320 bps
    Received packets: 1557
    Sent packets: 1426
    Dropped packets: 0
  From security node:
    Max total throughput: 4564 bps
    Sent packets: 1426
    Dropped packets: 0
  State: Busy
# 显示服务链sc下所有安全资源池成员的统计信息。
<Sysname> display sslo security-node statistics service-chain sc
Slot 1:
Service chain: sc
 Security pool: sp
  Security node: sn1
    To security node:
      Total connections: 0
      Active connections: 0
      Max connections: 0
      Connections per second: 0
      Max connections per second: 0
      Total throughput: 0 bps
      Input throughput:0 bps
      Output throughput: 0 bps
      Max throughput: 0 bps
      Max input throughput: 0 bps
      Max output throughput: 0 bps
      Received packets: 0
      Sent packets: 0
      Dropped packets: 0
    From security node:
      Max connections: 0
      Received packets: 0
      Sent packets: 0
      Dropped packets: 0
    State: Busy
# 显示服务链sc下安全资源池sp中所有成员的统计信息。
<Sysname> display sslo security-node statistics service-chain sc security-pool sp
Slot 1:
Service chain: sc
 Security pool: sp
  Security node: sn1
    To security node:
      Max connections: 0
      Received packets: 0
      Sent packets: 0
      Dropped packets: 0
    From security node:
      Max connections: 0
      Received packets: 0
      Sent packets: 0
      Dropped packets: 0
    State: Busy
表1-4 display sslo security-node statistics命令显示信息描述表
Security node
安全网元的名称
Service chain
服务链的名称
Security pool
安全资源池的名称
To security node
设备到安全网元的请求流量对应的出接口统计信息
From security node
安全网元到设备的请求流量对应的入接口统计信息
Total connections
总连接数
Active connections
当前活动的连接数
Max connections
最大连接数
每秒连接数
最大每秒连接数
Total throughput
报文的总吞吐量,单位为bps
Input throughput
报文的入吞吐量,单位为bps
Output throughput
报文的出吞吐量,单位为bps
报文的最大总吞吐量,单位为bps
报文的最大入吞吐量,单位为bps
报文的最大出吞吐量,单位为bps
Received packets
接收报文数
Sent packets
发送报文数
Dropped packets
丢弃报文数
安全网元的状态,包括:
·     --:不可用
·     Normal:正常
·     Busy:繁忙
·     reset sslo security-node statistics
display sslo security-pool命令用来显示安全资源池的信息。
display sslo security-pool { brief | name security-pool-name }
context-admin
context-operator
brief:显示安全资源池的简要信息。如果未指定本参数,将显示资源池的详细信息。
name security-pool-name:显示指定安全资源池的信息。security-pool-name为安全资源池的名称,为1~255个字符的字符串,不区分大小写。如果未指定本参数,将显示所有安全资源池的信息。
# 显示所有安全资源池的简要信息。
<Sysname> display sslo security-pool brief
Predictor: RR - Round robin, RD - Random, LC - Least connection,
           LCM - Least connection member,
           HASH(SIP) - Hash address source IP,
           HASH(DIP) - Hash address destination IP,
           HASH(SIP-PORT) - Hash address source IP-port,
           LTM - Least time member,
           CARP(SIP) - CARP address source IP,
           CARP(DIP) - CARP address destination IP,
           CARP(SIP-PORT) - CARP address source IP-port,
           CARP(HTTP) - CARP HTTP payload,
           HASH(HTTP) - Hash HTTP payload
Security pool    Mode      Predictor    Total  Active
sp1              Layer2    RR           2      2
# 显示安全资源池sp1的详细信息。
<Sysname> display sslo security-pool name sp1
Security pool: sp1
  Description: security-pool sp1
  Mode:Layer2
  Type: WAF
  Predictor: Round robin
  SSL mapping port: 80
  Bypass: Enabled
  Fail-action: Bypass
  Selected node limit: Enabled
    Min nodes: 100
    Max nodes: 600
  Probe information:
    Probe method:
    t1
  Total security node: 2
  Active security node: 2
  Reference count: 1
  Security node list:
  Name         State            Weight Priority Service
  sn1          Probe-failed     120    3        enable
表1-5 display sslo security-pool命令显示信息描述表
Security pool
安全资源池的名称
Mode
安全资源池的部署模式,包括:
·     Layer2:二层部署模式
·     Layer3:三层部署模式
·     Mirror:镜像部署模式
安全资源池中安全网元的类型,包括:
·     FW:防火墙类型。
·     NGFW:下一代防火墙类型。
·     IPS:入侵防御系统类型。
·     WAF:Web应用防火墙类型。
·     ACG:访问控制网关类型。
·     DLP:数据防泄漏类型。
Predictor
安全资源池的调度算法,包括:
·     RR - Round robin ,加权轮转算法
·     RD – Random ,随机算法
·     LC - Least connection ,最小连接数算法
·     LCM - Least connection member ,基于成员的最小连接数算法
·     HASH(SIP):根据源IP地址进行的哈希算法
·     HASH(DIP):根据目的IP地址进行的哈希算法
·     HASH(SIP-PORT):根据源IP地址和端口号进行的哈希算法
·     LTM:安全资源池成员的最快响应算法
·     CARP(SIP):根据源IP地址进行的CARP哈希算法
·     CARP(DIP):根据目的IP地址进行的CARP哈希算法
·     CARP(SIP-PORT):根据源IP地址和端口号进行的CARP哈希算法
·     CARP(HTTP):基于HTTP载荷进行的CARP哈希算法
·     HASH(HTTP):基于HTTP载荷进行的哈希算法
Total
包含的安全网元数量
Active
活跃的安全网元数量
安全资源池的描述信息
Predictor
安全资源池的调度算法,包括:
·     Round robin ,加权轮转算法
·     Random ,随机算法
·     Least connection:最小连接数算法
·     Least connection member :基于成员的最小连接数算法
·     HASH address source IP:根据源IP地址进行的哈希算法
·     HASH address destination IP:根据目的IP地址进行的哈希算法
·     HASH address source IP-port:根据源IP地址和端口号进行的哈希算法
·     Least time:最快响应算法
·     CARP address source IP:根据源IP地址进行的CARP哈希算法
·     CARP address destination IP:根据目的IP地址进行的CARP哈希算法
·     CARP address source IP-port:根据源IP地址和端口号进行的CARP哈希算法
·     CARP HTTP:基于HTTP载荷进行的CARP哈希算法
·     HASH HTTP:基于HTTP载荷进行的哈希算法
SSL mapping port
安全资源池SSL流量的映射端口号
Bypass
安全资源池的Bypass功能状态,包括:
·     Enabled:开启
·     Disabled:关闭
Fail-action
安全资源池的故障处理方式,包括:
·     Bypass:跳过安全资源池
·     Drop:丢弃报文
Selected node limit
安全资源池中可被调度算法调用的安全网元数量限制功能的状态,包括Disabled(关闭)和Enabled(开启)两种。在开启状态下还会显示:
·     Min nodes:可被调度算法调用的安全网元最小数量
·     Max nodes:可被调度算法调用的安全网元最大数量
安全网元健康检测的成功条件:
·     At least x:健康检测成功所需通过检测的最少方法数为x
Probe method
健康检测方法所使用的NQA模板名称
Total security node
包含的安全网元数量
活跃的安全网元数量
Reference count
被引用次数
Security node list
安全资源池成员列表
Name
安全资源池成员的名称
安全资源池成员的状态,包括:
·     Active:可用
·     Unknown:未配置健康检测
·     Shutdown:安全网元或安全资源池成员处于关闭状态(当安全网元或者安全资源池成员配置了undo service enable)
Weight
安全资源池成员的权值
Priority
安全资源池成员的调用优先级
Service
安全资源池成员的服务状态
display sslo service-chain命令用来显示服务链的信息。
display sslo service-chain [ name service-chain-name ]
context-admin
context-operator
name service-chain-name:显示指定服务链的信息。service-chain-name为服务链的名称,为1~255个字符的字符串,不区分大小写。如果未指定本参数,将显示所有服务链的信息。
# 显示服务链sc的详细信息。
<Sysname> display sslo service-chain name sc
Service chain: sc
  Description:
  Operating mode: Normal
  Total security pools: 2
  Security pool list:
  Name         Mode
  sp1          Layer2
  sp2          Layer3
表1-6 display sslo service-chain命令显示信息描述表
Service chain
服务链的名称
服务链的描述信息
Operating mode
服务链的工作模式,包括:
·     Shutdown:一键断网模式,关闭所有服务链,丢弃走服务链的报文
·     Bypass:一键Bypass模式,报文跳过SSLO编排,直接转发
·     Normal:通用模式,报文走SSLO编排
服务链下引用的安全资源池数量
Security pool list
·     服务链下引用的安全资源池列表
Name
·     服务链下引用的安全资源池名称
Mode
·     服务链下引用的安全资源池部署模式,包括:
·     Layer2
·     Layer3
·     Mirror
display ssl-transparent bypass-decrypt命令用来显示SSL透明代理免卸载IP地址的信息。
display ssl-transparent bypass-decrypt { ipv4 [ ipv4-address ] | ipv6 [ ipv6-address ] } [ slot slot-number [ cpu cpu-number ] ]
networlk-operator
context-admin
context-operator
ipv4:表示显示免卸载的IPv4地址。
ipv6:表示显示免卸载的IPv6地址。
ipv4-address:指定IPv4地址。
ipv6-address:指定IPv6地址。
slot slot-number:显示指定单板上的信息,slot-number表示单板所在槽位号。如果未指定本参数,将显示所有单板上的信息。‌
cpu cpu-number:显示指定CPU上的信息,cpu-number表示CPU的编号。只有指定的slot支持多CPU时,才能配置该参数。
# 显示所有免卸载IPv4地址。
<Sysname> display ssl-transparent bypass-decrypt ipv4
Slot 0:
IPv4 address              Port
10.1.1.1                  443
10.10.1.1                 443
图1-1 display ssl-transparent bypass-decrypt命令显示信息描述表
IPv4 address
免卸载的IPv4地址
IPv6 address
免卸载的IPv6地址
Port
免卸载的IP地址对应的端口号
·     reset ssl-transparent bypass-decrypt ip
display ssl-transparent bypass-decrypt domain命令用来显示SSL透明代理的免卸载域名。
context-admin
context-operator
#显示SSL透明代理的免卸载域名。
<Sysname> display ssl-transparent bypass-decrypt domain
1.example.com
display ssl-transparent cm-certificate命令用来显示商密算法的SSL透明代理解密证书的信息。
context-admin
context-operator
# 显示SSL透明代理的解密证书。
<Sysname> display ssl-transparent cm-certificate
Trusted:
File name:abc.cer
Certificate:
    Data:
        Version: 3 (0x2)
        Serial number:
            aa:31:f8:3d:06:b0:9b:   Signature algorithm: sha1WithRSAEncryption
        Issuer: C=CN, ST=bj, L=cp, O=dpi, OU=sec, CN=trustca
        Validity
            Not before: Sep  7 12:00:43 2017 GMT
            Not after : Aug 28 12:00:43 2057 GMT
        Subject: C=CN, ST=bj, L=cp, O=dpi, OU=sec, CN=trustca
        Subject public key info:
            Public key algorithm: rsaEncryption
                Public key: (2048 bit)
                Modulus:
                    00:ec:d7:73:af:03:07:07:86:e6:31:4d:e5:32:09:
                    20:7f:93:19:20:b2:25:c4:cc:32:8e:e4:29:fd:e0:
                    30:48:4c:8d:0a:83:66:28:af:6a:e0:69:81:08:58:
                    ca:cf:e4:3d:5a:e8:69:92:67:71:e3:c0:66:87:8e:
                    16:cc:6a:89:1d:d4:22:5f:93:14:47:bd:39:60:44:
                    3c:ee:0a:d1:8d:d4:16:84:65:e9:b7:b1:0f:6d:af:
                    6e:ef:21:b5:5a:02:4f:63:46:6e:8b:73:b5:95:70:
                    8a:ed:5d:23:8b:d8:0e:45:2d:8b:52:ab:34:6d:3b:
                    d5:85:ae:1c:d4:26:6e:fb:2c:1e:18:db:55:22:96:
                    d8:1f:1a:33:e9:ff:1f:8c:be:28:9d:de:77:d8:9b:
                    a7:27:0f:7e:e2:52:3e:bd:02:ee:c3:06:93:d0:16:
                    b0:c7:96:bb:c8:b1:96:8d:ee:ca:6e:76:63:1e:b1:
                    b6:fb:31:bf:d0:13:66:ad:f6:97:cf:0b:37:f7:6c:
                    f8:46:b6:76:f1:70:6f:24:6c:92:a6:dd:c2:3b:cf:
                    3c:35:c7:74:60:dd:db:a3:bf:70:b4:55:05:4b:d7:
                    cd:dd:c1:1b:59:0d:41:e7:95:5a:79:44:9d:b0:8b:
                    a7:f2:f4:67:0e:0c:4a:b6:35:97:1e:e6:99:88:fc:
                    c8:e9
                Exponent: 65537 (0x10001)
        X509v3 extensions:
            X509v3 subject alternative name:
                IP address:1.1.1.1, DNS:trustca, email:[email protected]
            X509v3 basic constraints: Critical
                CA:TRUE
            X509v3 key usage: Critical
                Certificate sign, CRL sign
            X509v3 subject key identifier:
                D4:35:A8:66:63:03:04:2B:CA:4E:91:06:11:F5:72:1C:26:E0:BE:33
            Netscape cert type:
                SSL CA
            Netscape comment:
                example comment extension
         b9:d2:eb:98:bd:f9:8d:7e:03:a8:0e:b4:29:cf:3a:a1:fd:f4:
         2a:fa:56:1c:cf:40:a4:9e:7f:5a:15:6b:88:8a:dd:86:d2:03:
         c3:38:49:7a:11:09:78:81:8c:8f:0a:3b:fb:d6:60:59:c4:0b:
         12:0e:38:b0:92:f3:2e:b5:96:ab:d3:a4:2d:cb:ef:fd:a0:97:
         d0:63:43:8e:91:1f:f1:fc:39:c8:cf:e5:ee:4b:e7:8c:8b:f8:
         3b:ff:5e:dc:00:df:5b:2f:98:53:f2:c7:da:fa:b8:2e:92:dd:
         33:6a:80:df:0e:22:62:62:5d:2f:6c:eb:4c:80:c4:56:c9:00:
         01:a6:82:60:e4:32:69:f7:7b:8f:6c:93:e5:c3:64:65:fe:aa:
         e1:0b:10:92:bd:ea:2f:2f:e5:b6:fd:b5:5b:df:34:c8:5d:5a:
         91:9a:0d:89:10:76:b8:ed:28:ef:6a:c4:7b:48:d7:88:57:7c:
         cf:4e:c8:38:84:ad:54:6d:3f:40:a0:38:d7:36:61:23:7a:82:
         62:34:41:3d:cc:b2:ee:4a:23:f1:7d:12:e2:23:26:10:df:c8:
         a1:6f:00:00:b7:c2:1f:ce:1b:63:60:e0:63:33:e0:59:31:78:
         bc:27:99:b6:27:40:95:da:1b:37:07:75:2f:99:97:56:33:f5:
         4f:ad:14:31
图1-2 display ssl-transparent cm-certificate命令显示信息描述表
Trusted
证书的可信度,取值包括:
·     Trusted:客户端信任的证书
·     Untrusted:客户端不信任的证书
File name
证书文件的名称
Certificate
证书的信息
Data
证书的数据
Version
证书的版本
Serial number
证书的序列号
Signature algorithm
证书的签名算法
Issuer
证书的颁发者
Validity
证书的有效期
Subject
证书的主题
证书的主题公钥信息
公钥算法
Public key
公钥信息
Modulus
密钥模数
Exponent
密钥指数
X509v3 extensions
X.509v3证书扩展项
主题的备用名称
IP address
实体的IP地址
DNS
实体的DNS名
email
实体的电子邮箱地址
基本约束,指出一个证书是否是CA证书
X509v3 key usage
密钥用法,指出有效用途
主题密钥标识符
Netscape cert type
Netscape证书类型,可以用于指定网景软件的密钥用途
Netscape comment
Netscape注释,在某些浏览器中可以用于展示注释信息
1.1.12  fail-action
fail-action命令用来配置安全资源池的故障处理方式。
undo fail-action命令用来恢复缺省情况。
fail-action { drop | bypass }
安全资源池的故障处理方式为跳过故障安全资源池,放行报文。
安全资源池视图
context-admin
bypass:跳过故障安全资源池,放行报文。
drop:丢弃报文。
工作机制
当安全资源池中所有成员都发生故障时,设备将根据配置的故障处理方式来决定报文的处理方式。
注意事项
若同时在安全资源池下开启bypass功能后,本命令不生效。
# 配置安全资源池sp1中所有安全网元发生故障时的处理方式为跳过故障该故障资源池,放行报文。
[Sysname-sslo-security-pool-l2-sp1] fail-action bypass
·     bypass
from-security-node-interface命令用来指定设备上请求流量从安全网元返回的入接口。
undo from-security-node-interface命令用来恢复缺省情况。
from-security-node-interface { interface-name | interface-type interface-num }
二层/三层模式的安全网元视图
未配置设备上请求流量从安全网元返回的入接口
context-admin
interface-name:表示设备上请求流量从安全网元返回的入接口名。
interface-type interface-number:表示入接口类型和接口编号。
工作机制
SSLO设备上请求流量从安全网元返回的入接口,即从安全网元返回的客户端请求流量从此接口进入设备,服务器应答流量从此接口进入安全网元。
# 配置SSLO设备上请求流量从安全网元sn1返回的入接口为GigabitEthernet1/0/2。
[Sysname] sslo security-node sn1 mode layer2
[Sysname-sslo-security-node-l2-sn1] from-security-node-interface GigabitEthernet 1/0/2
·     from-security-node-nexthop
·     to-security-node-interface
from-security-node-nexthop命令用来配置设备上请求流量从安全网元返回的入接口互联地址。
undo from-security-node-nexthop命令用来恢复缺省情况。
from-security-node-nexthop ipv4-address
二层/三层模式的安全网元视图
未配置设备上请求流量从安全网元返回的入接口互联地址。
context-admin
ipv4-address:设备上请求流量从安全网元返回的入接口互联IPv4地址,不能为环回地址、组播地址、广播地址和0.X.X.X。
工作机制
对于二层模式安全网元:入接口互联IP地址:即设备的出接口IP地址。
对于三层模式安全网元:入接口互联IP地址:即安全网元的出接口IP地址。
# 配置设备上请求流量从安全网元sn1返回的入接口互联IP地址为1.1.1.1。
[Sysname-sslo-security-node-l2-sn1] from-security-node-nexthop 1.1.1.1
·     from-node-interface
1.1.15  ip-address
ip-address命令用来配置镜像模式的安全网元的IPv4地址。
undo ip-address命令用来恢复缺省情况。
ip-address ipv4-address
undo ip-address
镜像模式的安全网元视图
未配置镜像模式安全网元的IPv4地址。
context-admin
ipv4-address:镜像模式的安全网元IPv4地址,不能为环回地址、组播地址、广播地址和0.X.X.X。
工作机制
对于镜像部署模式的安全网元,需要配置其IPv4地址,否则该安全网元不生效。
# 配置镜像模式的安全网元sn1的IPv4地址为1.1.1.1。
[Sysname] sslo security-node sn1 mode mirror
[Sysname-sslo-security-node-mirror-sn1] ip-address 1.1.1.1
·     mac-address
loadbalance probe nqa-task-restrict disable命令用来关闭NQA健康检测速率限制功能。
undo loadbalance probe nqa-task-restrict disable命令用来开启NQA健康检测速率限制功能。
NQA健康检测速率限制功能处于开启状态。
context-admin
工作机制
开启本功能后,设备将对每秒可执行的NQA健康检测任务数进行限制。当新增NQA健康检测任务时,系统会结合当前已启动的所有任务计算设备NQA健康检测速率,并判断是否会超过最大NQA健康检测速率:若未超过,则启动任务;否则,将该任务加入等待队列。
等待队列的任务按以下从高到低的优先级启动(按名称的字典序):
(1)     ‍DNS服务器名称
(2)     链路名称
(3)     实服务器名称
(4)     DNS服务器池成员名称
(5)     链路组成员名称
(6)     实服务组成员名称
(7)     安全网元名称
(8)     安全资源池成员名称
而停止任务时则按从低到高的优先级执行。
若设备当前NQA健康检测任务启动速率已经超过最大NQA健康检测速率时,可通过延长健康检测模板的测试间隔或减少检测任务释放出一些资源。
通常情况下,建议开启NQA健康检测速率限制功能,防止任务数过多导致设备资源紧张。而在小型网络或故障排查等无需担心资源争用的场景下,可关闭本功能,以提升健康检测效率。
注意事项
修改NQA模板的测试间隔时,将首先影响关联该模板的任务启停。
每次启停本功能时,系统都会按照上述原则重新调整所有任务的队列。因此,反复操作可能导致任务队列的顺序变化。
最大NQA健康检测速率与设备型号有关,可以在Probe视图下执行display system internal loadbalance statistics probe命令查看。
# 开启NQA健康检测速率限制功能。
[Sysname] undo loadbalance probe nqa-task-restrict disable
1.1.17  mac-address
mac-address命令用来配置镜像模式的安全网元的MAC地址。
undo mac-address命令用来恢复缺省情况。
mac-address mac-address
undo mac-address
镜像模式的安全网元视图
未配置镜像模式的安全网元的MAC地址。
context-admin
mac-address:指定镜像模式的安全网元的MAC地址,格式为H-H-H。
工作机制
对于镜像部署模式的安全网元,需要配置其MAC地址,否则该安全网元不生效。
# 配置镜像模式安全网元sn1的MAC地址。
[Sysname-sslo-security-node-mirror-sn1] mac-address 5632-7542-5697
·     ip-address
match destination命令用来创建目的IP地址类型的匹配规则。
undo match命令用来删除指定的匹配规则。
match match-rule-name destination ipv4 { range start-ipv4-address end-ipv4-address | subnet ipv4-address { mask-length | mask } | object-group-name }
undo match match-rule-name
SSLO编排策略中不存在匹配规则。
SSLO编排策略视图
context-admin
match-rule-name:匹配规则的名称,为1~255个字符的字符串,不区分大小写。
ipv4:表示匹配IPv4地址。
range start-ipv4-address end-ipv4-address:表示以地址段方式配置的IPv4地址范围。start-ipv4-address表示起始目的IPv4地址,end-ipv4-address表示终止目的IPv4地址。
subnet ipv4-address { mask-length | mask }:表示以子网方式配置的IPv4地址范围。ipv4-address表示IPv4地址,mask-length表示IPv4地址的掩码长度,取值范围为0~32,mask表示IPv4地址子网掩码。
object-group-name:IPv4地址对象组的名称,为1~63个字符的字符串,不区分大小写,且对象组的名称必须全局唯一。
#在通用类型的SSLO编排策略sslop1中,创建目的IP子网方式匹配规则为:匹配子网1.1.1.1/24
[Sysname] sslo policy sslop1 type generic
[Sysname-sslo-policy-generic-sslop1] match r1 destination ipv4 subnet 1.1.1.1 24
·     sslo policy
·     object-group(安全命令参考/对象组)
match destination-port命令用来创建目的端口的匹配规则。
match match-rule-name destination-port port
SSLO编排策略中不存在匹配规则。
SSLO编排策略视图
context-admin
destination-port port:目的端口号,取值范围为0~65535,0表示任意端口号。
# 在通用类型的SSLO编排策略sslop1中,创建目的端口为80的匹配规则
[Sysname-sslo-policy-generic-sslop1] match m1 destnation-port 80
·     sslo policy
1.1.20  match header
match header命令用来创建HTTP首部匹配规则。
match match-rule-name header header-name pattern [ case-sensitive ] regex expression
SSLO编排策略中不存在匹配规则。
HTTP类型的SSLO编排策略视图
context-admin
header-name:HTTP报文首部的名称,为1~63个字符的字符串,不区分大小写。不包括(、)、<、>、@、,、;、:、\、"、/、[、]、?、=、{、}、SP(空格符)、HT(水平制表符),以及ASCII码中小于等于31、大于等于127的字符。
pattern:表示HTTP首部值。
case-sensitive:表示匹配正则表达式时区分大小写。若未指定本参数,则匹配正则表达式时不区分大小写。
regex:表示首部值的输入格式为正则表达式。
expression:首部值的正则表达式,为1~255个字符的字符串,不支持正则元字符?。
配置了本命令后,如果HTTP报文中携带有指定名称的首部,且首部值匹配了指定的正则表达式,便认为此报文匹配了该规则。
# 在HTTP类型的SSLO编排策略sslop1中,创建HTTP首部匹配规则为:名为user-agent的HTTP报文首部,其值为abcd。
[Sysname] sslo policy sslop1 type http
[Sys-name-sslo-policy-http-sslop1] match rule1 header user-agent pattern abcd
match interface命令用来创建入接口匹配规则。
match match-rule-name interface { interface-type interface-number | interface-name }
SSLO编排策略中不存在匹配规则。
SSLO编排策略视图
context-admin
interface-type interface-number:指定入接口类型和接口编号。
interface-name:指定入接口名称。
# 在通用类型的SSLO编排策略sslop1中,创建入接口匹配规则为:匹配接口GigabitEthernet1/0/1。
[Sysname-sslo-policy-generic-sslop1] match r1 interface gigabitethernet 1/0/1
·     sslo policy
1.1.22  match source
match source命令用来创建源IP地址类型的匹配规则。
match match-rule-name source ipv4 { range start-ipv4-address end-ipv4-address | subnet ipv4-address { mask-length | mask } | object-group-name }
SSLO编排策略中不存在匹配规则。
SSLO编排策略视图
context-admin
ipv4:表示匹配IPv4地址。
range start-ipv4-address end-ipv4-address:表示以地址段方式配置的IPv4地址范围。start-ipv4-address表示起始源IPv4地址,end-ipv4-address表示终止源IPv4地址。
#在通用类型的SSLO编排策略sslop1中,创建源IP子网方式匹配规则为:匹配子网1.1.1.1/24
[Sys-name-sslo-policy-generic-sslop1] match r1 source ipv4 subnet 1.1.1.1 24
·     sslo policy
1.1.23  match url
match url命令用来创建HTTP URL类型的匹配规则。
match match-rule-name url expression
SSLO编排策略中不存在匹配规则。
HTTP类型的SSLO编排策略视图
context-admin
expression:URL的正则表达式,为1~255个字符的字符串,区分大小写,不支持正则元字符?。
# 在HTTP类型的SSLO编排策略sslop1中,创建HTTP URL类型的匹配规则为:.*.html。
[Sysname-sslo-policy-http-sslop1] match r1 url .*.html
·     sslo policy
1.1.24  match user
match user命令用来创建基于用户的匹配规则。
match match-rule-name [ identity-domain domain-name ] user user-name
SSLO编排策略中不存在匹配规则。
SSLO编排策略视图
context-admin
identity-domain domain-name:表示在指定的身份识别域中匹配此用户。domain-name是身份识别域的名称,为1~255个字符的字符串,不区分大小写,不能包括字符“?”。若未指定本参数,则表示在不属于任何身份识别域的用户中匹配此用户。
user-name:用户名,为1~55个字符的字符串,区分大小写。
如果匹配规则中指定的用户或身份识别域不存在或者用户和身份识别域不匹配,则此规则不生效。
#在通用类型的SSLO编排策略sslop1中,创建基于用户的匹配规则为:匹配属于身份识别域domain1的用户u1。
[Sysname-sslo-policy-generic-sslop1] match r1 identity-domain domain1 user u1
·     sslo policy
·     user-identity enable(安全命令参考/用户身份识别与管理)
·     user-identity static-user(安全命令参考/用户身份识别与管理)
1.1.25  match-mode
match-mode命令用来配置SSLO编排策略的匹配方式。
undo match-mode命令用来恢复缺省情况。
match-mode { all-rules | any-rule }
undo match-mode
SSLO编排策略的匹配方式为匹配任一规则。
SSLO编排策略视图
context-admin
all-rules:表示匹配所有规则,即需要匹配所有规则才算匹配该SSLO编排策略。
any-rule:表示匹配任一规则,只需匹配任意一条规则就算匹配该SSLO编排策略。
# 在HTTP类型的SSLO编排策略视图sslop1下,配置SSLO编排策略的匹配方式为匹配所有规则。
[Sysname-sslo-policy-http-sslop1] match-mode all-rules
·     sslo policy
1.1.26  move match
move match命令用来调整匹配规则的排序。
move match match-rule-name1 { after match-rule-name2 | before match-rule-name2 | bottom | top }
SSLO编排策略的匹配规则按照创建时间的先后进行排序。
SSLO编排策略视图
context-admin
match-rule-name1:指定待移动的匹配规则的名称,为1~255个字符的字符串,不区分大小写。
after:将match-rule-name1移动到match-rule-name2后面。
before:将match-rule-name1移动到match-rule-name2前面。
rule-name2:表示用于参照的匹配规则的名称,为1~255个字符的字符串,不区分大小写。
bottom:将match-rule-name1移动到底部。
top:将match-rule-name1移动到顶部。
功能简介
管理员可通过执行本命令调整匹配规则的排序,报文会按照排序依次匹配。
注意事项
待移动的匹配规则和用于参照的匹配规则必须已存在,否则配置不生效。
# 在通用类型的SSLO编排策略sp1视图下,将匹配规则r1移动到匹配规则r2前面。
[Sysname] sslo policy sp1 type generic
[Sysname-sslo-policy-generic-sp1] move match r1 before r2
1.1.27  predictor
predictor命令用来配置安全资源池的调度算法。
undo predictor命令用来恢复缺省情况。
基于安全网元:
predictor least-connection
undo predictor
基于安全资源池成员:
predictor hash [ carp ] address { destination | source | source-ip-port } [ mask mask-length ]
predictor hash [ carp ] http [ offset offset ] [ start start-string ] [ end end-string | length length ]
predictor { least-connection member | least-time member | random | round-robin }
undo predictor
安全资源池的调度算法为加权轮转算法。
安全资源池视图
context-admin
hash address:根据IP地址进行的哈希算法。
carp:CARP(Cache Array Routing Protocol,缓存阵列路由协议)算法。当可用的网元数量发生变化时,采用CARP哈希算法,可使当前所有可用网元负载分担变动最小。
destination:根据目的IP地址进行的哈希算法。
source:根据源IP地址进行的哈希算法。
source-ip-port:根据源IP地址和端口号进行的哈希算法。
mask mask-length:IPv4地址的掩码长度,取值范围为0~32,缺省值为32。
http:根据HTTP载荷进行的哈希算法。
offset offset:基于HTTP载荷起始位置的偏移量,取值范围为0~1000,缺省值为0,单位为字节。
start start-string:HTTP载荷起始位置的正则表达式,即从offset起到本标记为开始,为1~127字符的字符串,区分大小写,不支持正则元字符?。
end end-string:HTTP载荷结束位置的正则表达式,即从start-string起到本标记为结束,为1~127字符的字符串,区分大小写,不支持正则元字符?。
length length:参与运算的HTTP载荷的长度,取值范围为0~1000,缺省值为0。
least-connection:基于安全网元的加权最小连接算法,即总是把新连接分发给加权活动连接数(当前安全网元在所有安全资源池中的活动连接总数/权值)最小的安全网元。该算法中使用的权值为安全网元视图下配置的权值。
least-connection member:基于安全资源池成员的加权最小连接算法,即总是把新连接分发给加权活动连接数(安全资源池成员在指定安全资源池中的活动连接数/权值)最小的安全资源池成员。该算法中使用的权值为安全资源池成员视图下配置的权值。
least-time member:基于安全资源池成员的最快响应算法,即根据安全资源池成员的响应时间计算出当前负载能力的权值。响应时间越短,权值越大,分配到的新连接越多。
random:随机算法,即把新连接随机分发给每个安全网元。
round-robin:加权轮转算法,即根据安全资源池成员视图下配置的权值的大小把新连接依次分发给每个安全资源池成员,权值越大,分配的新连接越多。
工作机制
设备根据安全资源池中配置的调度算法,计算出处理用户请求的安全网元或安全资源池成员。
# 配置安全资源池sp1的调度算法为根据IP地址进行的哈希算法。
[Sysname-sslo-security-pool-l2-sp1] predictor hash carp address source mask 24
priority命令用来配置资源池下引用的安全网元的调度优先级。
undo priority命令用来恢复缺省情况。
priority priority-value
undo priority
安全网元视图
安全网元的调度优先级为4。
context-admin
priority-value:安全网元调度优先级,取值范围为1~8。数值越大,越被优先调用。
工作机制
通常使用负载分担时,优先使用资源池下引用高优先级的安全网元的处理流量。如果最高优先级安全网元的个数少于配置的参与调度的最少个数,则在次高优先级中选择安全网元,达到配置的最少个数。
注意事项
本命令与安全资源池视图下的selected-node-limit命令配合使用。
# 配置安全资源池下引用二层安全网元n1,并配置调用优先级为3。
[Sysname] sslo security-pool p1 mode layer2
[Sysname-sslo-security-pool-l2-p1]security-node n1
[Sysname-sslo-security-pool-p1-#member#-n1] priority 3
·     selected-node-limit
probe命令用来指定安全网元的健康检测方法。
undo probe命令用来恢复缺省情况。
probe template-name [ from-security-node-interface | to-security-node-interface ]
undo probe template-name
安全网元视图
未指定安全网元的健康检测方法。
context-admin
template-name:健康检测方法所使用的NQA模板名称,为1~32个字符的字符串,不区分大小写。
to-security-node-interface:指定发送NQA探测报文的接口为设备的出接口。仅二层和三层模式的安全网元支持本参数。
from-security-node-interface:指定发送NQA探测报文的接口为设备的入接口。仅二层和三层模式的安全网元支持本参数。
工作机制
请使用nqa template命令创建健康检测方法所使用的NQA模板,通过健康检测可以对安全网元进行检测,保证其能够提供有效的服务。
注意事项
若配置本命令时,未指定NQA探测报文发送的接口,则必须在NQA模板中配置探测报文的目的地址。
镜像模式下,安全网元引用健康检测方法时,若指定了发送NQA探测报文的接口,探测的目的地址为网元IP地址;否则,使用NQA模板中配置的目的地址。
二层或三层模式下,安全网元引用健康检测方法时,建议配置发送NQA探测报文的接口,健康检测将使用该接口互联地址和VPN进行探测;否则,使用NQA模板中配置的目的地址。
目前,二层模式的安全网元只支持ICMP类型的健康检测模板,其他模式的安全网元只支持引用ICMP、TCP、UDP类型的健康检测模板。
# 创建ICMP类型的NQA模板t4,并将其指定为网元sn1的健康检测方法。
[Sysname] nqa template icmp t4
[Sysname-nqatplt-icmp-t4] quit
[Sysname-sslo-security-node-l2-sn1] probe t4 to-security-node-interface
·     nqa template(网络管理和监控命令参考/NQA)
·     probe (SSLO security pool view)
·     success-criteria (SSLO security node view)
probe命令用来指定安全资源池的健康检测方法。
undo probe命令用来删除指定安全资源池的健康检测方法。
未配置安全资源池的健康检测方法。
安全资源池视图
context-admin
工作机制
注意事项
镜像模式下,安全资源池引用健康检测方法时,若指定了发送NQA探测报文的接口,探测的目的地址为网元IP地址;否则,使用NQA模板中配置的目的地址。
二层或三层模式下,安全资源池引用健康检测方法时,建议配置发送NQA探测报文的接口,健康检测将使用该接口互联地址和VPN进行探测;否则,使用NQA模板中配置的目的地址。
# 创建ICMP类型的NQA模板t4,并将其指定为安全资源池sp1的健康检测方法。
[Sysname-sslo-security-pool-l2-sp1] probe t4 to-security-node-interface
·     probe (SSLO security node view)
·     success-criteria
probe log enable命令用来开启安全网元的健康检测日志功能。
undo probe log enable命令用来关闭安全网元的健康检测日志功能。
probe log enable
安全网元视图
安全网元的健康检测日志功能处于开启状态。
context-admin
工作机制
通过开启安全网元健康检测日志功能,可实现在安全网元的健康状态发生变化时输出日志信息。
# 开启安全网元sn1的健康检测日志功能。
[Sysname-sslo-security-node-l2-sn1] probe log enable
reset sslo security-node statistics命令用来清除安全网元或安全资源池成员的统计信息。
reset sslo security-node statistics [ security-node-name | service-chain service-chain-name [ security-pool security-pool-name [ name security-node-name ] ] ]
context-admin
security-node-name:清除指定安全网元的统计信息。security-node-name为安全网元的名称,为1~255个字符的字符串,不区分大小写。如果未指定本参数,将显示所有安全网元的统计信息。
service-chain service-chain-name:清除指定服务链下安全资源池中成员的统计信息。security-chain-name表示服务链的名称,为1~255个字符的字符串,不区分大小写。
security-pool security-pool-name:清除指定安全资源池下安全资源池成员的统计信息。security-pool-name表示安全资源池的名称,为1~255个字符的字符串,不区分大小写。
name security-node-name:清除指定名称的安全资源池成员的统计信息。security-node-name表示安全资源池成员的名称,为1~255个字符的字符串,不区分大小写。
# 清除所有安全网元的统计信息。
<Sysname> reset sslo security-node statistics
# 清除服务链sc下所有安全资源池成员的统计信息。
<Sysname> reset sslo security-node statistics service-chain sc
# 清除服务链sc下安全资源池sp下所有安全资源池成员的统计信息。
<Sysname> reset sslo security-node statistics service-chain sc security-pool sp
reset ssl-transparent bypass-decrypt ip命令用来清除SSL透明代理免卸载IP地址的信息。
context-admin
删除免卸载域名后,但未清除免卸载的IP地址,那么客户端请求匹配免卸载IP地址后还是不进行解密,直接进行SSLO流量编排。
# 清除免卸载IP地址。
<Sysname> reset ssl-transparent bypass-decrypt ip
·     display ssl-transparent bypass-decrypt
reset ssl-transparent server-certificate命令用来清除客户端访问的服务器的证书。
context-admin
# 清除客户端访问的服务器的证书。
<Sysname> reset ssl-transparent server-certificate
·     display ssl-transparent server-certificate
security-node命令用来添加安全资源池成员,并进入安全资源池成员视图。
undo security-node命令用来删除指定的安全资源池成员。
security-node node-name
undo security-node node-name
不存在安全资源池成员。
安全资源池视图
context-admin
node-name:安全资源池成员的名称,为1~255个字符的字符串,不区分大小写。
工作机制
安全资源池只能添加与自身部署模式相同的安全网元,如:二层模式的安全资源池只能添加二层模式的安全网元,三层模式的安全资源池只能添加三层模式的安全网元,镜像模式的安全资源池只能添加镜像模式的安全网元。
# 添加安全资源池池成员n1。
[Sysname-sslo-security-pool-l2-sp1] security-node sn1
[Sysname-sslo-security-pool-sp1-#member#-sn1]
·     sslo security-pool
security-pool命令用来向服务链中添加安全资源池,并调整安全资源池位置。
undo security-pool命令用来从服务链中删除指定的安全资源池。
security-pool security-pool-name1 [ insert-after security-pool-name-2 | insert-before security-pool-name-2 | bottom | top ]
undo security-pool security-pool-name1
服务链视图
服务链上未添加任何安全资源池。
context-admin
security-pool-name:安全资源池名称,为1~255个字符的字符串,不区分大小写。
insert-after:将security-pool-name插入到pool-name-2后面。
insert-before:将security-pool-name插入到pool-name-2前面。
security-pool-name-2:表示用于参照的安全资源池名称,为1~255个字符的字符串,不区分大小写。
bottom:将security-pool-name插入到底部。
top:将security-pool-name插入到顶部。
工作机制
在服务链中添加安全资源池,并调整安全资源池顺序,匹配上服务链的用户访问流量按照排列顺序通过各个安全资源池进行处理。
若未配置insert-after、insert-before、bottom或top,则表示插入到所有安全资源池底部。
# 向服务链sc中添加安全资源池sp,并插入到顶部。
[Sysname] sslo service-chain sc
[Sysname-sslo-service-chain-sc] security-pool sp top
selected-node-limit命令用来配置安全资源池中可被调度算法调用的安全网元数量限制。
undo selected-node-limit命令用来恢复缺省情况。
selected-node-limit min min-number max max-number
安全资源池中优先级最高的成员全部被调度算法调用。
安全资源池视图
context-admin
min min-number:可被调度算法调用的安全网元的最小数量,取值范围为1~32。
max max-number:可被调度算法调用的安全网元的最大数量,取值范围为1~32,且必须大于等于min-number。
工作机制
用户通过本命令可以限制可被调度算法调用的安全网元的数量:
·     如果调用优先级值最高的安全网元数量大于max-number时,则只选用max-number个安全网元。
·     如果调用优先级值最高的可用安全网元数量小于min-number时,除了调用全部优先级值最高的可用安全网元外,还会调用优先级值次高的可用安全网元,直至调用的可用安全网元数量达到min-number,或者没有可用的安全网元可调用为止。
# 配置安全资源池sp1中可被调度算法调用的安全网元的最小数量为2,最大数量为4。
[Sysname-sslo-security-pool-l2-sp1] selected-node-limit min 2 max 4
·     predictor
service enable命令用来开启安全网元。
undo service enable命令用来关闭安全网元。
service enable
undo service enable
安全网元视图
安全网元处于开启状态。
context-admin
工作机制
关闭安全网元后,流量会直接跳过所有资源池下引用的该网元,该网元不参与新的调度,但已经建立的连接会继续保持。
注意事项
配置undo service enable后,该网元和引用该网元的资源池下成员的状态为不可用,display sslo security-node和display sslo security-pool命令显示会带Disable标记。
# 关闭安全网元sn1。
[Sysname-sslo-security-node-l2-sn1] undo service enable
·     service enable (SSLO security pool member view)
service enable命令用来开启安全资源池成员。
undo service enable命令用来关闭安全资源池成员。
service enable
undo service enable
安全资源池成员视图
安全资源池下成员处于开启状态。
context-admin
工作机制
关闭安全资源池成员后,流量会直接跳过该资源池成员,该成员将不参与新的调度,但已经建立的连接会继续保持。
# 关闭安全资源池p1的成员n1。
[Sysname-sslo-security-pool-p1-#member#-n1] undo service enable
·     service enable (SSLO security node view)
service-chain命令用来在SSLO编排策略视图下添加服务链。
undo service-chain命令用来删除服务链。
undo service-chain
SSLO编排策略下不存在服务链。
SSLO编排策略视图
context-admin
service-chain-name:服务链的名称,为1~255个字符的字符串,不区分大小写。
如果指定的服务链不存在,则此命令不生效。
# 在HTTP类型的SSLO编排策略sslop1中添加服务链s1
[Sysname-sslo-policy-http-sslop1] service-chain s1
·     sslo policy
·     sslo service-chain
·     display sslo policy
ssl mapping-port命令用来配置安全资源池SSL流量的端口映射功能。
undo ssl mapping-port命令用来恢复缺省情况。
ssl mapping-port port
未配置安全资源池SSL流量的端口映射。
安全资源池视图
context-admin
port:SSL流量的映射端口号,取值范围为0~65535,0表示不映射端口,继续使用原报文携带的端口号。
工作机制
针对SSL卸载流量,如果直接将其发送给安全网元可能导致端口识别问题。通过本命令配置SSL流量的端口映射功能,将SSLO设备发送给安全网元的流量中的目的端口替换为指定端口号。当安全网元返回消息时,SSLO设备再将端口号替换回原始端口。这样可以确保流量在网络中正常传输并且端口识别不会受到影响。
# 配置安全资源池sp1的映射端口号为80。
[Sysname-sslo-security-pool-l2-sp1] ssl mapping-port 80
1.1.42  sslo policy
sslo policy命令用来创建SSLO编排策略,并进入SSLO编排策略视图。如果指定的SSLO编排策略已经存在,则直接进入SSLO编排策略视图。
undo sslo policy命令用来删除指定的SSLO编排策略。
sslo policy policy-name [ type { generic | http } ]
undo sslo policy policy-name
不存在SSLO编排策略。
context-admin
policy-name:SSLO编排策略的名称,为1~255个字符的字符串,不区分大小写。
type:SSLO编排策略的类型,创建SSLO编排策略时必须指定本参数;进入已创建的SSLO编排策略视图时可以不指定本参数,若要指定本参数,则必须与创建时的类型一致。包括:
·     generic:表示通用类型。
·     http:表示HTTP类型。
工作机制
通用类型的SSLO编排策略可被IP、TCP、UDP和HTTP类型的虚服务器引用。HTTP类型的SSLO编排策略可被HTTP类型的虚服务器引用。通过引用SSLO编排策略,可根据流量特征决定加解密处理及流量编排。
# 创建通用类型的SSLO编排策略sslop1,并进入SSLO编排策略视图。
sslo security-node命令用来创建安全网元,并进入安全网元视图。如果指定的安全网元已经存在,则直接进入安全网元视图。
undo sslo security-node命令用来删除指定的网元。
sslo security-node node-name [ mode { layer2 | layer3 | mirror } ]
undo sslo security-node node-name
未配置安全网元。
context-admin
node-name:安全网元的名称,为1~255个字符的字符串,不区分大小写。
mode:安全网元的部署模式,创建安全网元时必须指定本参数;进入已创建的安全网元视图时可以不指定本参数,若要指定本参数,则必须与创建时的类型一致。安全网元部署模式包括:
·     layer2:二层部署。
·     layer3:三层部署。
·     mirror:镜像部署。
工作机制
创建安全网元时,需要根据网络实际情况指定安全网元的部署模式。安全网元部署模式分为二层部署、三层部署以及镜像部署。
·     二层部署模式:安全网元工作在数据链路层,用于本地网络中的数据帧传输和交换,实现对本地网络内部流量的安全控制和保护。
·     三层部署模式:安全网元工作在网络层,对不同网络间的数据包进行安全控制和策略检查。
·     镜像部署模式:安全网元旁路连接到网络设备(如交换机)上的指定镜像端口,该端口复制的数据流量会发送到安全网元上进行实时监控和分析。
# 创建二层部署的安全网元sn1,并进入安全网元视图。
[Sysname] sslo security-node snl mode layer2
[Sysname-sslo-security-node-l2-snl]
sslo security-pool命令用来创建安全资源池,并进入安全资源池视图。如果指定的安全资源池已经存在,则直接进入安全资源池视图。
undo sslo security-pool命令用来恢复缺省情况。
sslo security-pool pool-name [ mode { layer2 | layer3 | mirror } ]
undo sslo security-pool pool-name
不存在任何安全资源池。
context-admin
pool-name:安全资源池的名称,为1~255个字符的字符串,不区分大小写。
mode:安全资源池中的安全网元的部署模式,包括:
·     layer2:安全资源池中的安全网元为二层部署模式。
·     layer3:安全资源池中的安全网元为三层部署模式。
·     mirror:安全资源池中的安全网元为镜像部署模式。
工作机制
根据安全网元的部署模式,创建相应的安全资源池部署模式并将同一模式的安全网元归入其中。部署模式包括二层部署、三层部署和镜像部署。通过这种方式可以更好地组织和管理安全网元,并实现安全网元的平滑扩展。
# 创建二层模式的安全资源池,并进入安全资源池视图。
sslo service-chain命令用来创建服务链,并进入服务链视图。如果指定的服务链已经存在,则直接进入服务链视图。
undo service-chain命令用来删除指定的服务链。
sslo service-chain service-chain-name
undo sslo service-chain service-chain-name
不存在服务链。
context-admin
service-chain-name:服务链的名称,为1~255的字符串,不区分大小写。
# 创建服务链sc,并进入服务链视图。
sslo work-mode命令用来配置服务链的工作模式。
undo sslo work-mode命令用来恢复缺省情况。
sslo work-mode { bypass | normal | shutdown }
undo sslo work-mode
服务链工作模式为通用模式。
context-admin
bypass:Bypass模式,报文跳过SSLO编排,直接转发。
normal:通用模式,报文走SSLO编排。
shutdown:阻断模式,关闭所有服务链,丢弃报文。
工作机制
该配置为全局配置,针对所有服务链生效。
服务链的工作模式包括Bypass、断网和通用模式。
·     Bypass模式:报文会直接跳过SSLO编排策略。在某些情况下,可能需要绕过安全设备对特定流量进行处理,或者避免对特定服务或应用进行安全设备流量管控时,可以使用Bypass模式。
·     断网模式:用来关闭所有服务链,丢弃所有走服务链的报文。当需要临时停止所有服务链的流量传送时,可以使用一键断网模式。例如,在网络维护、故障排查或安全漏洞修复过程中暂时关闭所有服务链的情况。
·     通用模式:报文按照设定的SSLO编排策略经过安全设备进行相关处理和分析。通用模式是服务链的默认工作模式,适用于大多数情况下的网络流量处理,确保所有流量按照规定的SSLO编排策略进行安全处理和管控。
# 配置SSLO服务链的工作模式为断网模式。
[Sysname] sslo work-mode shutdown
ssl-transparent bypass-decrypt activate命令用于激活SSL透明代理的免卸载域名。
未激活SSL透明代理的免卸载域名。
context-admin
SSL透明代理免卸载域名进行添加、修改和删除操作后,需要通过本命令激活SSL代理免卸载域名。
# 添加SSL透明代理免卸载域名1.example.com,并激活免卸载域名。
[Sysname] ssl-transparent bypass-decrypt domain-name 1.example.com
To activate the setting, execute ssl-transparent whitelist activate.
[Sysname] ssl-transparent bypass-decrypt activate
·     ssl-transparent bypass-decrypt domain
ssl-transparent bypass-decrypt domain命令用于添加SSL透明代理的免卸载域名。
undo ssl-transparent bypass-decrypt domain命令用于删除SSL透明代理指定的免卸载域名。
ssl-transparent bypass-decrypt domain domain-name
undo ssl-transparent bypass-decrypt domain [ domain-name ]
未配置SSL透明代理的免卸载域名。
context-admin
domain-name:表示服务器域名,为1~63个字符的字符串。执行删除免卸载域名命令时,若不指定服务器域名则表示删除SSL透明代理免卸载域名列表中的所有域名。
免卸载域名为PKI证书中的FQDN和通用名称(CN)字段。SSL透明代理时,优先匹配FQDN中的域名,当不存在FQDN,则检查CN字段中的域名是否为免卸载域名。添加免卸载域名后,匹配该域名的SSL流量将不进行解密,直接进行SSLO流量编排。此功能适用于需要保护隐私或避免解密干扰的特定域名。
多次执行本命令,可以添加多个域名,最多可以配置1000个。
# 添加免卸载域名1.example.com。
[Sysname] ssl-transparent bypass-decrypt domain 1.example.com
·     display ssl-transparent bypass-decrypt domain
ssl-transparent cm-certificate delete命令用来删除商密算法的SSL解密证书。
ssl-transparent cm-certificate delete { trusted | untrusted | both }
context-admin
trusted:表示删除可信的SSL代理证书。
untrusted:表示删除不可信的SSL代理证书。
both:表示删除可信和不可信的SSL代理证书。
如果删除SSL解密证书,设备将不能签发SSL代理服务器证书发送到客户端,SSL代理连接失败,设备将直接透传报文。
当证书成功导入设备后,文件类型会被改为CER格式,删除证书时需要将指定的证书后缀名改为.cer。
# 删除可信和不可信的SSL解密证书。
[Sysname] ssl-transparent cm-certificate delete both
·     ssl-transparent cm-certificate import
ssl-transparent cm-certificate import命令用于导入支持商密算法的SSL解密证书。
ssl-transparent cm-certificate import { trusted | untrusted | both } filename filename
不存在商密算法的SSL解密证书。
context-admin
trusted:表示SSL解密证书可以用于签发标识为可信的SSL代理证书。用于传递真实服务器证书合法的信息给客户端。
untrusted:表示SSL解密证书可以用于签发标识为不可信的SSL代理证书。客户端不信任的CA证书。用于传递真实服务器证书非法的信息给客户端,让用户感知到可能存在的安全风险。
both:表示SSL解密证书可以用于签发标识即为可信也为不可信的SSL代理证书。
filename filename:表示导入的证书文件的名称,filename为1~255个字符的字符串,不区分大小写。
工作原理
在出方向链路负载均衡进行SSLO流量编排的场景下,设备作为SSL代理服务器时,需要向内网客户端发送证书表明自身的身份。但设备并不是直接将客户端访问的服务器证书发送给客户端,也不是简单地将自己的证书发送给客户端,而是根据客户端访问的服务器证书的内容,使用导入的SSL解密证书重新签发一本新的“服务器证书”发送给客户端。
用户导入SSL解密证书时,需要为其标识为“可信”或者“不可信”,用于签发不同可信度的新的“服务器证书”:
·     可信:表示客户端信任的证书。
·     不可信:表示客户端不信任的证书。
当设备接收到服务器证书后,设备将使用PKI域中的CA证书替客户端验证服务器是否可信。有关PKI域的详细介绍,请参见“安全命令参考”中的“PKI”。根据验证结果不同,设备会使用不同标识的SSL解密证书:
·     当服务器可信时:设备将使用可签发“可信”标识的SSL解密证书,签发一个新的“服务器证书”发送给客户端。
·     当服务器不可信时:设备将使用可签发“不可信”标识的SSL解密证书,签发一个新的“服务器证书”给客户端,由客户端决定是否继续访问不可信的服务器。
注意事项
设备上只能存在一份可信SSL解密证书和一份不可信SSL解密证书,多次执行本命令,后续导入的可信或者不可信证书会覆盖原有的证书。
需要在客户端浏览器上安装并信任SSL解密证书。
为了正确导入SSL解密证书,需要满足以下要求:
·     证书应具备签发证书的功能。
·     证书必须是p12或pem格式,并且应包含私钥。同时,需要提供用于解密私钥的密码。
·     证书必须在有效期内。
导入成功后,设备将修改证书文件类型为CER格式。
设备不支持对HTTP2.0版本协议流量进行SSL代理。配置SSL透明代理功能后,如果服务器仅支持HTTP2.0版本协议,则会导致客户端无法访问服务器。
默认情况下,火狐浏览器不共享系统中的证书库,如果已经在其他浏览器上导入SSL卸载证书,则可以通过修改火狐浏览器中的高级设置,使其共享系统中的证书库,不再单独导入证书,具体操作步骤如下:
(1)     在地址栏中输入:about:config
(2)     搜索框中输入:security.enterprise_roots.enabled
(3)     双击选中的条目,或者单击鼠标右键,选择切换,修改其值为true
(4)     导入成功后,设备将修改证书文件类型为CER格式
# 导入PKCS#12编码格式的、用于签发可信SSL代理服务器证书的SSL解密证书。
[Sysname] ssl-transparent cm-certificate import trusted p12 filename example.p12
Password:
·     ssl-transparent cm-certificate delete
success-criteria命令用来配置安全网元健康检测的成功条件。
undo success-criteria命令用来恢复缺省情况。
success-criteria { all | at-least min-number }
安全网元视图
只有全部方法都通过检测才认为健康检测成功。
context-admin
all:只有全部方法都通过检测才认为健康检测成功。
at-least min-number:健康检测成功所需通过检测的最少方法数,取值范围为1~4294967295。
工作机制
当用户指定的最少方法数大于设备上实际存在的方法数量时,系统也将认为健康检测成功。
用户既可在安全资源池视图下对池内的所有安全网元进行配置,也可在安全网元视图下只对当前安全网元进行配置,后者的配置优先级较高。
# 配置网元sn1的健康检测成功所需通过检测的最少方法数为2个。
[Sysname-sslo-security-node-l2-sn1] success-criteria at-least 2
·     success-criteria (SSLO security pool view)
success-criteria命令用来配置安全资源池健康检测的成功条件。
安全资源池视图
context-admin
工作机制
# 配置安全资源池sp1的健康检测成功所需通过检测的最少方法数为2个。
[Sysname-sslo-security-pool-l2-sp1] success-criteria at-least 2
to-security-node-interface命令用来指定设备上请求流量流向安全网元的出接口。
undo to-security-node-interface命令用来恢复缺省情况。
to-security-node-interface { interface-name | interface-type interface-number }
二层/三层/镜像模式的安全网元视图
未配置设备上请求流量流向安全网元的出接口。
context-admin
interface-name:表示设备上请求流量流向安全网元的出接口名。
interface-type interface-number:表示出接口类型和接口编号。
工作机制
SSLO设备上请求流量流向安全网元的出接口,即客户端请求流量从此接口进入安全网元,到达安全网元的服务器应答流量从此接口返回设备。
注意事项
镜像部署模式的安全网元,数据流量通过设备的出接口复制到安全网元,安全检测后的报文不用再返回设备
# 配置设备上请求流量流向安全网元sn1的出接口为GigabitEthernet1/0/1。
[Sysname-sslo-security-node-l2-sn1]to-security-node-interface GigabitEthernet 1/0/1
·     from-security-node-interface
·     to-security-node-nexthop
to-security-node-nexthop命令用来配置设备上请求流量流向安全网元的出接口互联地址。
undo to-security-node-nexthop命令用来恢复缺省情况。
to-security-node-nexthop ipv4-address
二层/三层模式的安全网元视图
未配置设备上请求流量流向安全网元的出接口互联地址。
context-admin
ipv4-address:设备上请求流量流向安全网元的出接口互联IPv4地址,不能为环回地址、组播地址、广播地址和0.X.X.X。
工作机制
对于二层模式安全网元:出接口互联IP地址:即设备的入接口IP地址。
对于三层模式安全网元:出接口互联IP地址:即安全网元的入接口IP地址。
# 配置设备上请求流量流向安全网元sn1的出接口互联IP地址为1.1.1.1。
[Sysname-sslo-security-node-l2-sn1] to-security-node-nexthop 1.1.1.1
1.1.55  type
type命令用来配置安全资源池中安全网元的类型。
undo type命令用来恢复缺省情况。
type { acg | dlp | fw | ips | ngfw | waf |}
undo type
未配置安全资源池中安全网元的类型。
安全资源池视图
context-admin
acg:安全资源池中安全网元的类型为访问控制网关。
dlp:安全资源池中安全网元的类型为数据防泄漏。
fw:安全资源池中安全网元的类型为防火墙。
ips:安全资源池中安全网元的类型为入侵防御系统。
ngfw:安全资源池中安全网元的类型为下一代防火墙。
waf:安全资源池中安全网元的类型为Web应用防火墙。
工作机制
本命令用于配置安全资源池中安全网元的类型,以确保资源分配和管理的准确性。
配置本命令后,请确保添加的安全网元设备的类型与安全资源池的类型一致。
注意事项
多次执行本命令,最后一次执行的命令生效。
# 配置安全资源池sp1中安全网元的类型为防火墙。
[Sysname-sslo-security-pool-l2-sp1] type fw
weight命令用来配置安全网元的权值。
undo weight命令用来恢复缺省情况。
weight weight-value
undo weight
安全网元视图
安全网元的权值为100。
context-admin
weight-value:安全网元的权值,取值范围为1~255。
工作机制
通过本命令配置的权值主要被加权轮转和加权最小连接调度算法使用,该数值越大,对应的安全网元越被优先调用。
# 配置二层模式安全网元sn1的权值为150。
[Sysname-sslo-security-node-l2-sn1] weight 150
·     predictor (SSLO security pool view)
weight命令用来配置资源池下引用安全网元的权值。
weight weight-value
undo weight
安全网元视图
安全网元的权值为100。
context-admin
工作机制
通过本命令配置的权值主要被加权轮转和加权最小连接调度算法使用,该数值越大,对应的资源池下引用的安全网元越被优先调用。
# 配置二层模式资源池引用安全网元n1配置权值为150。
[Sysname-sslo-security-pool-p1-#member#-n1]weight 150
·     predictor
