02-静态路由配置
本章节下载: 02-静态路由配置 (515.55 KB)
静态路由是一种特殊的路由,由管理员手工配置。当网络结构比较简单时,只需配置静态路由就可以使网络正常工作。
静态路由不能自动适应网络拓扑结构的变化。当网络发生故障或者拓扑发生变化后,必须由网络管理员手工修改配置。
(2) 配置静态路由。
(公网)
¡ 指定出接口并指定下一跳
ip route-static dest-address { mask-length | mask } interface-type interface-number next-hop-address [ nexthop-index index-string ] [ permanent | track track-entry-number ] [ preference preference ] [ tag tag-value ] [ recursive-lookup ] [ description text ]
¡ 仅指定出接口、不指定下一跳
ip route-static dest-address { mask-length | mask } interface-type interface-number [ permanent | track track-entry-number ] [ preference preference ] [ tag tag-value ] [ recursive-lookup ] [ description text ]
¡ 不指定出接口、仅指定下一跳
ip route-static dest-address { mask-length | mask } next-hop-address [ nexthop-index index-string ] [ recursive-lookup { host-route | longest-match } ] [ permanent | track track-entry-number ] [ preference preference ] [ tag tag-value ] [ recursive-lookup ] [ description text ]
¡ 指定目的VPN实例并指定下一跳
ip route-static dest-address { mask-length | mask } vpn-instance d-vpn-instance-name next-hop-address [ nexthop-index index-string ] [ recursive-lookup { host-route | longest-match } ] [ permanent | track track-entry-number ] [ preference preference ] [ tag tag-value ] [ recursive-lookup ] [ description text ]
¡ 指定出接口、下一跳,并将静态路由与下一跳对应的ARP表项相关联
ip route-static dest-address { mask-length | mask } interface-type interface-number next-hop-address [ nexthop-index index-string ] track-arp [ preference preference ] [ tag tag-value ] [ description text ]
缺省情况下,未配置静态路由。
通过在Track模块和静态路由之间建立联动,可以实现静态路由可达性的实时判断。关于Track的详细介绍,请参见“可靠性配置指导”中的“Track”。
参数recursive-lookup host-route、recursive-lookup longest-match和recursive-lookup互斥,不能同时配置。
(VPN网络)
¡ 指定出接口并指定下一跳
ip route-static vpn-instance s-vpn-instance-name dest-address { mask-length | mask } interface-type interface-number next-hop-address [ nexthop-index index-string ] [ permanent | track track-entry-number ] [ preference preference ] [ tag tag-value ] [ recursive-lookup ] [ description text ]
¡ 仅指定出接口、不指定下一跳
ip route-static vpn-instance s-vpn-instance-name dest-address { mask-length | mask } interface-type interface-number [ permanent | track track-entry-number ] [ preference preference ] [ tag tag-value ] [ recursive-lookup ] [ description text ]
¡ 不指定出接口、仅指定下一跳
ip route-static vpn-instance s-vpn-instance-name dest-address { mask-length | mask } next-hop-address [ nexthop-index index-string ] [ recursive-lookup { host-route | longest-match } ] [ public ] [ permanent | track track-entry-number ] [ preference preference ] [ tag tag-value ] [ recursive-lookup ] [ description text ]
¡ 指定目的VPN实例并指定下一跳
ip route-static vpn-instance s-vpn-instance-name dest-address { mask-length | mask } vpn-instance d-vpn-instance-name next-hop-address [ nexthop-index index-string ] [ recursive-lookup { host-route | longest-match } ] [ permanent | track track-entry-number ] [ preference preference ] [ tag tag-value ] [ recursive-lookup ] [ description text ]
ip route-static vpn-instance s-vpn-instance-name dest-address { mask-length | mask } interface-type interface-number next-hop-address [ nexthop-index index-string ] track-arp [ preference preference ] [ tag tag-value ] [ description text ]
缺省情况下,未配置静态路由。
(3) (可选)配置静态路由向下一跳定时发送ARP。
ip route-static arp-request interval interval
缺省情况下,静态路由不发送ARP request。
(4) (可选)配置静态路由的缺省优先级。
ip route-static default-preference default-preference
缺省情况下,静态路由的缺省优先级为60。
当配置多条静态路由时,如果只是前缀不同,每条静态路由都要配置一遍命令,比较繁琐。可以配置静态路由配置组,对静态路由进行批量配置,节省配置工作量。
按配置组配置静态路由时,配置组下的所有前缀会应用相同的下一跳、出接口信息。
(2) 创建静态路由配置组,并进入静态路由配置组视图。
ip route-static-group group-name
缺省情况下,未配置静态路由配置组。
(3) 在静态路由配置组中增加前缀。
prefix dest-address { mask-length | mask }
缺省情况下,静态路由配置组中未配置前缀。
(4) 退回系统视图。
(5) 配置静态路由。
(公网)
¡ 指定出接口并指定下一跳
ip route-static group group-name interface-type interface-number next-hop-address [ permanent | track track-entry-number ] [ preference preference ] [ tag tag-value ] [ recursive-lookup ] [ description text ]
¡ 仅指定出接口、不指定下一跳
ip route-static group group-name interface-type interface-number [ permanent | track track-entry-number ] [ preference preference ] [ tag tag-value ] [ recursive-lookup ] [ description text ]
¡ 不指定出接口、仅指定下一跳
ip route-static group group-name next-hop-address [ recursive-lookup { host-route | longest-match } ] [ permanent | track track-entry-number ] [ preference preference ] [ tag tag-value ] [ recursive-lookup ] [ description text ]
¡ 指定目的VPN实例并指定下一跳
ip route-static group group-name vpn-instance d-vpn-instance-name next-hop-address [ recursive-lookup { host-route | longest-match } ] [ permanent | track track-entry-number ] [ preference preference ] [ tag tag-value ] [ recursive-lookup ] [ description text ]
ip route-static group group-name interface-type interface-number next-hop-address track-arp [ preference preference ] [ tag tag-value ] [ description text ]
(VPN网络)
¡ 指定出接口并指定下一跳
ip route-static vpn-instance s-vpn-instance-name group group-name interface-type interface-number next-hop-address [ permanent | track track-entry-number ] [ preference preference ] [ tag tag-value ] [ recursive-lookup ] [ description text ]
¡ 仅指定出接口、不指定下一跳
ip route-static vpn-instance s-vpn-instance-name group group-name interface-type interface-number [ permanent | track track-entry-number ] [ preference preference ] [ tag tag-value ] [ recursive-lookup ] [ description text ]
¡ 不指定出接口、仅指定下一跳
ip route-static vpn-instance s-vpn-instance-name group group-name next-hop-address [ recursive-lookup { host-route | longest-match } ] [ public ] [ permanent | track track-entry-number ] [ preference preference ] [ tag tag-value ] [ recursive-lookup ] [ description text ]
¡ 指定目的VPN实例并指定下一跳
ip route-static vpn-instance s-vpn-instance-name group group-name vpn-instance d-vpn-instance-name next-hop-address [ recursive-lookup { host-route | longest-match } ] [ permanent | track track-entry-number ] [ preference preference ] [ tag tag-value ] [ recursive-lookup ] [ description text ]
ip route-static vpn-instance s-vpn-instance-name group group-name interface-type interface-number next-hop-address track-arp [ preference preference ] [ tag tag-value ] [ description text ]
缺省情况下,未配置静态路由。
配置浮动静态路由可以实现路由备份,提高网络可靠性。
如果设备上已存在去往某一目的地址的静态或动态路由,则再配置一条低优先级的静态路由可以起到路由备份的作用,从而提高网络可靠性。这条优先级较低的静态路由称为浮动静态路由,只有当主路由不可用时该静态路由才会被激活,承担数据转发业务,在主路由恢复正常后,该静态路由又变为不活跃状态,数据转发业务仍然由主路由承担。
浮动静态路由有如下两种配置方式:
· 为目的地址相同的多条静态路由指定不同的优先级,则低优先级的静态路由自动成为备份路由。
· 如果设备上已存在去往某一目的地址的路由,则可以再配置一条低优先级的静态路由。
在配置浮动静态路由时,该路由优先级的值需大于主用路由优先级的值,具体的配置步骤请参见“配置静态路由”。
使用undo ip route-static命令可以删除一条静态路由,而使用delete static-routes all命令可以删除包括缺省路由在内的所有静态路由。
(2) 删除所有静态路由。
(公网)
(VPN网络)
delete vpn-instance vpn-instance-name static-routes all
删除全部静态路由可能导致网络不通,报文转发失败,请谨慎使用。
路由震荡时,使能BFD功能可能会加剧震荡,请谨慎使用。
BFD(Bidirectional Forwarding Detection,双向转发检测)提供了一个通用的、标准化的、介质无关、协议无关的快速故障检测机制,可以为上层协议(如路由协议)统一地快速检测两台路由器间双向转发路径的故障。
关于BFD的详细介绍,请参见“可靠性配置指导”中的“BFD”。
通过控制报文检测两个方向上的链路状态,实现毫秒级别的链路故障检测。
控制报文方式的BFD检测支持直连下一跳和非直连下一跳。
· 直连下一跳是指下一跳和本端是直连的,配置时必须指定出接口和下一跳。
· 非直连下一跳是指下一跳和本端不是直连的,中间还有其它设备。
本端配置控制报文方式的BFD检测时,需要对端也配置控制报文方式的BFD检测。
(2) 配置静态路由与BFD联动。
(公网)
¡ 普通静态路由与BFD联动(指定出接口并指定下一跳)
ip route-static dest-address { mask-length | mask } interface-type interface-number next-hop-address bfd control-packet [ preference preference ] [ tag tag-value ] [ description text ]
¡ 静态路由组与BFD联动(指定出接口并指定下一跳)
ip route-static group group-name interface-type interface-number next-hop-address bfd control-packet [ preference preference ] [ tag tag-value ] [ description text ]
(VPN网络)
ip route-static vpn-instance s-vpn-instance-name dest-address { mask-length | mask } interface-type interface-number next-hop-address bfd control-packet [ preference preference ] [ tag tag-value ] [ description text ]
ip route-static vpn-instance s-vpn-instance-name group group-name interface-type interface-number next-hop-address bfd control-packet [ preference preference ] [ tag tag-value ] [ description text ]
缺省情况下,未配置静态路由与BFD联动。
(2) 配置静态路由与BFD联动。
(公网)
¡ 普通静态路由与BFD联动(不指定出接口、仅指定下一跳)
ip route-static dest-address { mask-length | mask } next-hop-address bfd control-packet bfd-source ip-address [ preference preference ] [ tag tag-value ] [ description text ]
¡ 普通静态路由与BFD联动(指定目的VPN实例并指定下一跳)
ip route-static dest-address { mask-length | mask } vpn-instance d-vpn-instance-name next-hop-address bfd control-packet bfd-source ip-address [ preference preference ] [ tag tag-value ] [ description text ]
¡ 静态路由组与BFD联动(不指定出接口、仅指定下一跳)
ip route-static group group-name next-hop-address bfd control-packet bfd-source ip-address [ preference preference ] [ tag tag-value ] [ description text ]
¡ 静态路由组与BFD联动(指定目的VPN实例并指定下一跳)
ip route-static group group-name vpn-instance d-vpn-instance-name next-hop-address bfd control-packet bfd-source ip-address [ preference preference ] [ tag tag-value ] [ description text ]
(VPN网络)
ip route-static vpn-instance s-vpn-instance-name dest-address { mask-length | mask } next-hop-address bfd control-packet bfd-source ip-address [ preference preference ] [ tag tag-value ] [ description text ]
¡ 普通静态路由与BFD联动(指定目的VPN实例、指定下一跳)
ip route-static vpn-instance s-vpn-instance-name dest-address { mask-length | mask } vpn-instance d-vpn-instance-name next-hop-address bfd control-packet bfd-source ip-address [ preference preference ] [ tag tag-value ] [ description text ]
ip route-static vpn-instance s-vpn-instance-name group group-name next-hop-address bfd control-packet bfd-source ip-address [ preference preference ] [ tag tag-value ] [ description text ]
¡ 静态路由组与BFD联动(指定目的VPN实例、指定下一跳)
ip route-static vpn-instance s-vpn-instance-name group group-name vpn-instance d-vpn-instance-name next-hop-address bfd control-packet bfd-source ip-address [ preference preference ] [ tag tag-value ] [ description text ]
通过echo报文方式的BFD检测链路的状态时,echo报文的目的地址为本端接口地址,发送给下一跳设备后会直接转发回本端。
只需要在本端配置echo报文方式的BFD检测。
静态路由的出接口处于SPOOFING状态时,不能使用BFD进行检测。
(2) 配置echo报文的源IP地址。
bfd echo-source-ip ip-address
缺省情况下,未配置echo报文的源IP地址。
为了避免对端发送大量的ICMP重定向报文造成网络拥塞,建议配置的源IP地址不属于该设备任何一个接口所在网段。
本命令的详细情况请参见“可靠性命令参考”中的“BFD”。
(3) 配置静态路由与BFD联动。
(公网)
ip route-static dest-address { mask-length | mask } interface-type interface-number next-hop-address bfd echo-packet [ preference preference ] [ tag tag-value ] [ description text ]
ip route-static group group-name interface-type interface-number next-hop-address bfd echo-packet [ preference preference ] [ tag tag-value ] [ description text ]
(VPN网络)
ip route-static vpn-instance s-vpn-instance-name dest-address { mask-length | mask } interface-type interface-number next-hop-address bfd echo-packet [ preference preference ] [ tag tag-value ] [ description text ]
ip route-static vpn-instance s-vpn-instance-name group group-name interface-type interface-number next-hop-address bfd echo-packet [ preference preference ] [ tag tag-value ] [ description text ]
当网络中的链路或某台路由器发生故障时,需要通过故障链路或故障路由器传输才能到达目的地的报文将会丢失,数据流量将会被中断。
为了尽可能避免网络故障导致的流量中断,网络管理员可以根据需要配置静态路由快速重路由功能。
如图1-1所示,通过配置快速重路由功能,网络管理员可以为路由指定备份下一跳,也可以在存在低优先级静态路由的情况下,使能自动快速重路由功能,查找满足条件的低优先级路由的下一跳作为主路由的备份下一跳,当路由器检测到网络故障时,路由器会使用事先配置好的备份下一跳替换失效下一跳,通过备份下一跳来指导报文的转发,从而避免了流量中断。
静态路由快速重路由功能不能与静态路由BFD功能同时使用。
等价路由不支持配置静态路由快速重路由功能。
配置本功能后,当主链路三层接口up,主链路由双通变为单通或者不通时,设备会将流量快速地切换到备份路径上转发;当主链路三层接口down时,设备会暂时将流量快速地切换到备份路径上转发。同时,设备会重新查找到达目的地址的路由,并将流量切换到查找到的新的路径。如果没有查找到路由,则流量转发会中断。因此,除本配置创建的静态路由外,设备上还需要存在一条到达目的地址的路由。单通现象,即一条链路上的两端,有且只有一端可以收到另一端发来的报文,此链路称为单向链路。
静态路由配置的备份出接口拔出或者删除时,配置的路由会失效。备份出接口和下一跳不能直接修改,且不能和主出接口和下一跳相同。
(2) 配置静态路由快速重路由功能。
(公网)
ip route-static dest-address { mask-length | mask } interface-type interface-number [ next-hop-address [ backup-interface interface-type interface-number [ backup-nexthop backup-nexthop-address ] ] ] [ permanent ] [ preference preference ] [ tag tag-value ] [ description text ]
(VPN网络)
ip route-static vpn-instance s-vpn-instance-name dest-address { mask-length | mask } interface-type interface-number [ next-hop-address [ backup-interface interface-type interface-number [ backup-nexthop backup-nexthop-address ] ] ] [ permanent ] [ preference preference ] [ tag tag-value ] [ description text ]
缺省情况下,静态路由快速重路由功能处于关闭状态。
(2) 配置静态路由自动快速重路由功能。
ip route-static fast-reroute auto
缺省情况下,静态路由自动快速重路由功能处于关闭状态。
缺省情况下,静态路由通过ARP检测主路由的下一跳是否可达。配置本功能后,将使用BFD(Echo方式)检测主路由的下一跳是否可达,这种方式可以更快地检测到链路故障。
(2) 配置BFD Echo报文源地址。
缺省情况下,未配置BFD Echo报文源地址。
echo报文的源IP地址用户可以任意指定。为了避免对端发送大量的ICMP重定向报文造成网络拥塞,建议配置echo报文的源IP地址不属于该设备任何一个接口所在网段。
(3) 使能静态路由中主用链路的BFD(Echo方式)检测功能。
ip route-static primary-path-detect bfd echo
缺省情况下,静态路由中主用链路的BFD(Echo方式)检测功能处于关闭状态。
在完成上述配置后,在任意视图下执行display命令查看静态路由配置的运行情况并检验配置结果。
表1-1 静态路由显示和维护
查看静态路由表信息(本命令的详细情况请参见“三层技术-IP路由命令参考”中的“IP路由基础”) |
display ip routing-table protocol static [ inactive | verbose ] |
显示静态路由下一跳信息 |
display route-static nib [ nib-id ] [ verbose ] |
显示静态路由表信息 |
display route-static routing-table [ vpn-instance vpn-instance-name ] [ ip-address { mask-length | mask } ] |
交换机各接口及主机的IP地址和掩码如图1-2所示。要求采用静态路由,使图中任意两台主机之间都能互通。
(1) 创建VLAN,配置各接口的IP地址
# 配置Switch A。
[Sysname] sysname SwitchA
[SwitchA] vlan 300
[SwitchA-vlan300] port ten-gigabitethernet 1/0/1
[SwitchA-vlan300] quit
[SwitchA] interface vlan-interface 300
[SwitchA-Vlan-interface300] ip address 1.1.2.3 24
[SwitchA-Vlan-interface300] undo shutdown
[SwitchA-Vlan-interface300] quit
[SwitchA] vlan 500
[SwitchA-vlan500] port ten-gigabitethernet 1/0/2
[SwitchA] interface vlan-interface 500
[SwitchA-Vlan-interface500] ip address 1.1.4.1 30
[SwitchA-Vlan-interface500] undo shutdown
[SwitchA-Vlan-interface500] quit
[SwitchA] interface ten-gigabitethernet 1/0/1
[SwitchA-Ten-GigabitEthernet1/0/1] undo shutdown
[SwitchA-Ten-GigabitEthernet1/0/1] quit
[SwitchA] interface ten-gigabitethernet 1/0/2
[SwitchA-Ten-GigabitEthernet1/0/2] undo shutdown
[SwitchA-Ten-GigabitEthernet1/0/2] quit
# 配置Switch B。
[Sysname] sysname SwitchB
[SwitchB] vlan 500
[SwitchB-vlan500] port ten-gigabitethernet 1/0/1
[SwitchB-vlan500] quit
[SwitchB] interface vlan-interface 500
[SwitchB-Vlan-interface500] ip address 1.1.4.2 30
[SwitchB-Vlan-interface500] undo shutdown
[SwitchB-Vlan-interface500] quit
[SwitchB] vlan 600
[SwitchB-vlan600] port ten-gigabitethernet 1/0/2
[SwitchB-vlan600] quit
[SwitchB] interface vlan-interface 600
[SwitchB-Vlan-interface600] ip address 1.1.5.5 30
[SwitchB-Vlan-interface600] undo shutdown
[SwitchB-Vlan-interface600] quit
[SwitchB] vlan 100
[SwitchB-vlan100] port ten-gigabitethernet 1/0/3
[SwitchB-vlan100] quit
[SwitchB-Vlan-interface100] ip address 1.1.6.1 24
[SwitchB-Vlan-interface100] undo shutdown
[SwitchB] interface ten-gigabitethernet 1/0/1
[SwitchB-Ten-GigabitEthernet1/0/1] undo shutdown
[SwitchB-Ten-GigabitEthernet1/0/1] quit
[SwitchB] interface ten-gigabitethernet 1/0/2
[SwitchB-Ten-GigabitEthernet1/0/2] undo shutdown
[SwitchB-Ten-GigabitEthernet1/0/2] quit
[SwitchB] interface ten-gigabitethernet 1/0/3
[SwitchB-Ten-GigabitEthernet1/0/3] undo shutdown
[SwitchB-Ten-GigabitEthernet1/0/3] quit
# 配置Switch C。
[Sysname] sysname SwitchC
[SwitchC] vlan 900
[SwitchC-vlan900] port ten-gigabitethernet 1/0/1
[SwitchC-vlan900] quit
[SwitchC] interface vlan-interface 900
[SwitchC-Vlan-interface900] ip address 1.1.3.1 24
[SwitchC-Vlan-interface900] undo shutdown
[SwitchC-Vlan-interface900] quit
[SwitchC] vlan 600
[SwitchC-vlan600] port ten-gigabitethernet 1/0/2
[SwitchC-vlan600] quit
[SwitchC] interface vlan-interface 600
[SwitchC-Vlan-interface600] ip address 1.1.5.6 30
[SwitchC-Vlan-interface600] undo shutdown
[SwitchC-Vlan-interface600] quit
[SwitchC] interface ten-gigabitethernet 1/0/1
[SwitchC-Ten-GigabitEthernet1/0/1] undo shutdown
[SwitchC-Ten-GigabitEthernet1/0/1] quit
[SwitchC] interface ten-gigabitethernet 1/0/2
[SwitchC-Ten-GigabitEthernet1/0/2] undo shutdown
[SwitchC-Ten-GigabitEthernet1/0/2] quit
(2) 配置静态路由
# 在Switch A上配置缺省路由。
[SwitchA] ip route-static 0.0.0.0 0.0.0.0 1.1.4.2
# 在Switch B上配置两条静态路由。
[SwitchB] ip route-static 1.1.2.0 255.255.255.0 1.1.4.1
[SwitchB] ip route-static 1.1.3.0 255.255.255.0 1.1.5.6
# 在Switch C上配置缺省路由。
[SwitchC] ip route-static 0.0.0.0 0.0.0.0 1.1.5.5
(3) 配置主机
配置Host A的缺省网关为1.1.2.3,Host B的缺省网关为1.1.6.1,Host C的缺省网关为1.1.3.1,具体配置过程略。
# 查看Switch A的静态路由信息。
[SwitchA] display ip routing-table protocol static
Summary count : 1
Static Routing table status : <Active>
Summary count : 1
0.0.0.0/0 Static 60 0 1.1.4.2 Vlan500
Static Routing table status : <Inactive>
Summary count : 0
# 查看Switch B的静态路由信息。
[SwitchB] display ip routing-table protocol static
Summary count : 2
Summary count : 2
1.1.2.0/24 Static 60 0 1.1.4.1 Vlan500
1.1.3.0/24 Static 60 0 1.1.5.6 Vlan600
Summary count : 0
# 在Host B上使用ping命令验证Host A是否可达(假定主机安装的操作系统为Windows XP)。
C:\Documents and Settings\Administrator>ping 1.1.2.2
Pinging 1.1.2.2 with 32 bytes of data:
Reply from 1.1.2.2: bytes=32 time=1ms TTL=126
Ping statistics for 1.1.2.2:
# 在Host B上使用tracert命令验证Host A是否可达。
C:\Documents and Settings\Administrator>tracert 1.1.2.2
Tracing route to 1.1.2.2 over a maximum of 30 hops
1 <1 ms <1 ms <1 ms 1.1.6.1
2 <1 ms <1 ms <1 ms 1.1.4.1
3 1 ms <1 ms <1 ms 1.1.2.2
Trace complete.
· Switch A
sysname SwitchA
vlan 300
vlan 500
interface Vlan-interface300
ip address 1.1.2.3 255.255.255.0
interface Vlan-interface500
ip address 1.1.4.1 255.255.255.252
port access vlan 300
port access vlan 500
ip route-static 0.0.0.0 0 1.1.4.2
return
· Switch B
sysname SwitchB
vlan 100
vlan 500
vlan 600
ip address 1.1.4.2 255.255.255.252
interface Vlan-interface600
ip address 1.1.5.5 255.255.255.252
interface Vlan-interface100
ip address 1.1.6.1 255.255.255.0
port access vlan 600
port access vlan 100
ip route-static 1.1.2.0 24 1.1.4.1
ip route-static 1.1.3.0 24 1.1.5.6
return
· Switch C
sysname SwitchC
vlan 600
vlan 900
interface Vlan-interface900
ip address 1.1.3.1 255.255.255.0
ip address 1.1.5.6 255.255.255.252
port access vlan 900
ip route-static 0.0.0.0 0 1.1.5.5
return
· 在Switch A上配置静态路由可以到达120.1.1.0/24网段,在Switch B上配置静态路由可以到达121.1.1.0/24网段,并都使能BFD检测功能。
· 在Switch C上配置静态路由可以到达120.1.1.0/24网段和121.1.1.0/24网段。
· 当Switch A和Switch B通过L2 Switch通信的链路出现故障时,BFD能够快速感知,并且切换到Switch C进行通信。
图1-3 静态路由与BFD联动(直连)配置组网图
设备 |
接口 |
IP地址 |
设备 |
接口 |
IP地址 |
Switch A |
Vlan-int10 |
12.1.1.1/24 |
Switch B |
Vlan-int10 |
12.1.1.2/24 |
Vlan-int11 |
10.1.1.102/24 |
Vlan-int13 |
13.1.1.1/24 |
Switch C |
Vlan-int11 |
10.1.1.100/24 |
Vlan-int13 |
13.1.1.2/24 |
# 配置Switch A。
[SwitchA] vlan 10
[SwitchA-vlan10] port ten-gigabitethernet 1/0/1
[SwitchA-vlan10] quit
[SwitchA-Vlan-interface10] ip address 12.1.1.1 24
[SwitchA-Vlan-interface10] undo shutdown
[SwitchA] vlan 11
[SwitchA-vlan11] port ten-gigabitethernet 1/0/2
[SwitchA-Vlan-interface11] ip address 10.1.1.102 24
[SwitchA-Vlan-interface11] undo shutdown
# 配置Switch B。
[SwitchB] vlan 10
[SwitchB-vlan10] port ten-gigabitethernet 1/0/1
[SwitchB-vlan10] quit
[SwitchB-Vlan-interface10] ip address 12.1.1.2 24
[SwitchB-Vlan-interface10] undo shutdown
[SwitchB] vlan 13
[SwitchB-vlan13] port ten-gigabitethernet 1/0/2
[SwitchB-vlan13] quit
[SwitchB] interface vlan-interface 13
[SwitchB-Vlan-interface13] ip address 13.1.1.1 24
[SwitchB-Vlan-interface13] undo shutdown
[SwitchB-Vlan-interface13] quit
# 配置Switch C。
[SwitchC] vlan 11
[SwitchC-vlan11] port ten-gigabitethernet 1/0/1
[SwitchC-vlan11] quit
[SwitchC] interface vlan-interface 11
[SwitchC-Vlan-interface11] ip address 10.1.1.100 24
[SwitchC-Vlan-interface11] undo shutdown
[SwitchC-Vlan-interface11] quit
[SwitchC] vlan 13
[SwitchC-vlan13] port ten-gigabitethernet 1/0/2
[SwitchC-vlan13] quit
[SwitchC] interface vlan-interface 13
[SwitchC-Vlan-interface13] ip address 13.1.1.1 24
[SwitchC-Vlan-interface13] undo shutdown
[SwitchC-Vlan-interface13] quit
(2) 配置静态路由和BFD
# 在Switch A上配置静态路由,并使能BFD检测功能,使用控制报文方式。
[SwitchA-vlan-interface10] bfd min-transmit-interval 500
[SwitchA-vlan-interface10] bfd min-receive-interval 500
[SwitchA-vlan-interface10] bfd detect-multiplier 9
[SwitchA-vlan-interface10] quit
[SwitchA] ip route-static 120.1.1.0 24 vlan-interface 10 12.1.1.2 bfd control-packet
[SwitchA] ip route-static 120.1.1.0 24 vlan-interface 11 10.1.1.100 preference 65
[SwitchA] quit
# 在Switch B上配置静态路由,并使能BFD检测功能,使用控制报文方式。
[SwitchB-vlan-interface10] bfd min-transmit-interval 500
[SwitchB-vlan-interface10] bfd min-receive-interval 500
[SwitchB-vlan-interface10] bfd detect-multiplier 9
[SwitchB-vlan-interface10] quit
[SwitchB] ip route-static 121.1.1.0 24 vlan-interface 10 12.1.1.1 bfd control-packet
[SwitchB] ip route-static 121.1.1.0 24 vlan-interface 13 13.1.1.2 preference 65
[SwitchB] quit
# 在Switch C上配置静态路由。
[SwitchC] ip route-static 120.1.1.0 24 13.1.1.1
[SwitchC] ip route-static 121.1.1.0 24 10.1.1.102
下面以Switch A为例,Switch B和Switch A类似,不再赘述。
# 查看BFD会话,可以看到BFD会话已经创建。
<SwitchA> display bfd session
Total sessions: 1 Up sessions: 1 Init mode: Active
4/7 12.1.1.1 12.1.1.2 Up 2000ms Vlan10
# 查看静态路由,可以看到Switch A经过L2 Switch到达Switch B。
<SwitchA> display ip routing-table protocol static
Summary count : 1
Summary count : 1
120.1.1.0/24 Static 60 0 12.1.1.2 Vlan10
Summary count : 0
当Switch A和Switch B通过L2 Switch通信的链路出现故障时:
# 查看静态路由,可以看到Switch A经过Switch C到达Switch B。
Summary count : 1
Summary count : 1
120.1.1.0/24 Static 65 0 10.1.1.100 Vlan11
Summary count : 0
· Switch A
sysname SwitchA
vlan 10
vlan 11
ip address 12.1.1.1 255.255.255.0
interface Vlan-interface11
ip address 10.1.1.102 255.255.255.0
port access vlan 10
port access vlan 11
ip route-static 120.1.1.0 24 Vlan-interface10 12.1.1.2 bfd control-packet
ip route-static 120.1.1.0 24 Vlan-interface11 10.1.1.100 preference 65
return
· Switch B
sysname SwitchB
vlan 10
vlan 13
ip address 12.1.1.2 255.255.255.0
ip address 13.1.1.1 255.255.255.0
port access vlan 10
port access vlan 13
ip route-static 121.1.1.0 24 Vlan-interface10 12.1.1.1 bfd control-packet
ip route-static 121.1.1.0 24 Vlan-interface13 13.1.1.2 preference 65
return
· Switch C
sysname SwitchC
vlan 11
vlan 13
ip address 10.1.1.100 255.255.255.0
interface Vlan-interface13
ip address 13.1.1.3 255.255.255.0
port access vlan 11
port access vlan 13
return
· 在Switch C和Switch D上配置静态路由可以到达120.1.1.0/24网段和121.1.1.0/24网段。
· Switch A存在到Switch B的接口Loopback1(2.2.2.9/32)的路由,出接口为Vlan-interface10;Switch B存在到Switch A的接口Loopback1(1.1.1.9/32)的路由,出接口为Vlan-interface12;Switch D存在到1.1.1.9/32的路由,出接口为Vlan-interface10,存在到2.2.2.9/32的路由,出接口为Vlan-interface12。
· 当Switch A和Switch B通过Switch D通信的链路出现故障时,BFD能够快速感知,并且切换到Switch C进行通信。
图1-4 静态路由与BFD联动(非直连)配置组网图
设备 |
接口 |
IP地址 |
设备 |
接口 |
IP地址 |
Switch A |
Vlan-int10 |
12.1.1.1/24 |
Switch B |
Vlan-int12 |
11.1.1.1/24 |
Vlan-int11 |
10.1.1.102/24 |
Vlan-int13 |
13.1.1.1/24 |
Loop1 |
1.1.1.9/32 |
Loop1 |
2.2.2.9/32 |
Switch C |
Vlan-int11 |
10.1.1.100/24 |
Switch D |
Vlan-int10 |
12.1.1.2/24 |
Vlan-int13 |
13.1.1.2/24 |
Vlan-int12 |
11.1.1.2/24 |
[SwitchA] vlan 10
[SwitchA] vlan 11
[SwitchA] interface loopback 1
[SwitchA-LoopBack1] ip address 1.1.1.9 32
[SwitchA-LoopBack1] quit
# 配置Switch B。
[SwitchB] vlan 12
[SwitchB-vlan12] port ten-gigabitethernet 1/0/1
[SwitchB-vlan12] quit
[SwitchB] interface vlan-interface 12
[SwitchB-Vlan-interface12] ip address 11.1.1.1 24
[SwitchB-Vlan-interface12] undo shutdown
[SwitchB-Vlan-interface12] quit
[SwitchB] vlan 13
[SwitchB] interface loopback 1
[SwitchB-LoopBack1] ip address 2.2.2.9 32
[SwitchB-LoopBack1] quit
# 配置Switch C。
[SwitchC] vlan 11
[SwitchC] vlan 13
[SwitchC-Vlan-interface13] ip address 13.1.1.2 24
# 配置Switch D。
[Sysname] sysname SwitchD
[SwitchD] vlan 10
[SwitchD-vlan10] port ten-gigabitethernet 1/0/1
[SwitchD-vlan10] quit
[SwitchD] interface vlan-interface 10
[SwitchD-Vlan-interface10] ip address 12.1.1.2 24
[SwitchD-Vlan-interface10] undo shutdown
[SwitchD-Vlan-interface10] quit
[SwitchD] vlan 12
[SwitchD-vlan12] port ten-gigabitethernet 1/0/2
[SwitchD-vlan12] quit
[SwitchD] interface vlan-interface 12
[SwitchD-Vlan-interface12] ip address 11.1.1.2 24
[SwitchD-Vlan-interface12] undo shutdown
[SwitchD-Vlan-interface12] quit
[SwitchD] interface ten-gigabitethernet 1/0/1
[SwitchD-Ten-GigabitEthernet1/0/1] undo shutdown
[SwitchD-Ten-GigabitEthernet1/0/1] quit
[SwitchD] interface ten-gigabitethernet 1/0/2
[SwitchD-Ten-GigabitEthernet1/0/2] undo shutdown
[SwitchD-Ten-GigabitEthernet1/0/2] quit
(2) 配置静态路由和BFD
[SwitchA] bfd multi-hop min-transmit-interval 500
[SwitchA] bfd multi-hop min-receive-interval 500
[SwitchA] bfd multi-hop detect-multiplier 9
[SwitchA] ip route-static 2.2.2.9 32 12.1.1.2
[SwitchA] ip route-static 11.1.1.0 24 12.1.1.2
[SwitchA] ip route-static 13.1.1.0 24 10.1.1.100
[SwitchA] ip route-static 120.1.1.0 24 2.2.2.9 bfd control-packet bfd-source 1.1.1.9
[SwitchA] quit
[SwitchB] bfd multi-hop min-transmit-interval 500
[SwitchB] bfd multi-hop min-receive-interval 500
[SwitchB] bfd multi-hop detect-multiplier 9
[SwitchB] ip route-static 1.1.1.9 32 11.1.1.2
[SwitchB] ip route-static 10.1.1.0 24 13.1.1.2
[SwitchB] ip route-static 12.1.1.0 24 11.1.1.2
[SwitchB] ip route-static 121.1.1.0 24 1.1.1.9 bfd control-packet bfd-source 2.2.2.9
[SwitchB] quit
# 在Switch C上配置静态路由。
[SwitchC] ip route-static 11.1.1.0 24 13.1.1.1
[SwitchC] ip route-static 12.1.1.0 24 10.1.1.102
# 在Switch D上配置静态路由。
<SwitchD> system-view
[SwitchD] ip route-static 1.1.1.9 32 12.1.1.1
[SwitchD] ip route-static 2.2.2.9 32 11.1.1.2
[SwitchD] ip route-static 10.1.1.0 24 12.1.1.1
[SwitchD] ip route-static 13.1.1.0 24 11.1.1.2
[SwitchD] ip route-static 120.1.1.0 24 11.1.1.1
[SwitchD] ip route-static 121.1.1.0 24 12.1.1.1
[SwitchA] display bfd session
4/7 1.1.1.9 2.2.2.9 Up 2000ms N/A
# 查看静态路由,可以看到Switch A经过Switch D到达Switch B。
Summary count : 1
Summary count : 1
Summary count : 0
当Switch A和Switch B通过Switch D通信的链路出现故障时:
Summary count : 1
Summary count : 1
Summary count : 0
· Switch A
sysname SwitchA
interface LoopBack1
ip address 1.1.1.9 255.255.255.255
vlan 10
vlan 11
port access vlan 10
port access vlan 11
return
· Switch B
sysname SwitchB
interface LoopBack1
ip address 2.2.2.9 255.255.255.255
vlan 12
vlan 13
interface Vlan-interface12
ip address 11.1.1.1 255.255.255.0
port access vlan 12
port access vlan 13
ip route-static 1.1.1.9 32 11.1.1.1
ip route-static 12.1.1.0 24 11.1.1.1
return
· Switch C
sysname SwitchC
vlan 11
vlan 13
ip address 13.1.1.2 255.255.255.0
port access vlan 11
port access vlan 13
return
· Switch D
sysname SwitchD
vlan 10
vlan 12
ip address 11.1.1.2 255.255.255.0
port access vlan 10
port access vlan 12
ip route-static 120.1.1.0 24 11.1.1.2
return
如图1-5所示,Switch A、Switch B和Switch C通过静态路由实现网络互连。要求当Switch A和Switch B之间的链路A出现单通故障时,业务可以快速切换到链路B上。
设备 |
接口 |
IP地址 |
设备 |
接口 |
IP地址 |
Switch A |
Vlan-int100 |
12.12.12.1/24 |
Switch B |
Vlan-int101 |
24.24.24.4/24 |
Vlan-int200 |
13.13.13.1/24 |
Vlan-int200 |
13.13.13.2/24 |
Loop0 |
1.1.1.1/32 |
Loop0 |
4.4.4.4/32 |
Switch C |
Vlan-int100 |
12.12.12.2/24 |
Vlan-int101 |
24.24.24.2/24 |
[SwitchA] vlan 100
[SwitchA-vlan100] port ten-gigabitethernet 1/0/1
[SwitchA-vlan100] quit
[SwitchA-Vlan-interface100] ip address 12.12.12.1 24
[SwitchA-Vlan-interface100] undo shutdown
[SwitchA] vlan 200
[SwitchA-vlan200] port ten-gigabitethernet 1/0/2
[SwitchA-Vlan-interface200] ip address 13.13.13.1 24
[SwitchA-Vlan-interface200] undo shutdown
[SwitchA-LoopBack0] ip address 1.1.1.1 32
[SwitchA-LoopBack0] quit
# 配置Switch B。
[SwitchB] vlan 101
[SwitchB-vlan101] port ten-gigabitethernet 1/0/1
[SwitchB-vlan101] quit
[SwitchB-Vlan-interface101] ip address 24.24.24.4 24
[SwitchB-Vlan-interface101] undo shutdown
[SwitchB] vlan 200
[SwitchB-vlan200] port ten-gigabitethernet 1/0/2
[SwitchB-vlan200] quit
[SwitchB-Vlan-interface200] ip address 13.13.13.2 24
[SwitchB-Vlan-interface200] undo shutdown
[SwitchB-LoopBack0] ip address 4.4.4.4 32
[SwitchB-LoopBack0] quit
# 配置Switch C。
[SwitchC] vlan 100
[SwitchC-vlan100] port ten-gigabitethernet 1/0/1
[SwitchC-vlan100] quit
[SwitchC-Vlan-interface100] ip address 12.12.12.2 24
[SwitchC-Vlan-interface100] undo shutdown
[SwitchC] vlan 101
[SwitchC-vlan101] port ten-gigabitethernet 1/0/2
[SwitchC-vlan101] quit
[SwitchC] interface vlan-interface 101
[SwitchC-Vlan-interface101] ip address 24.24.24.2 24
[SwitchC-Vlan-interface101] undo shutdown
[SwitchC-Vlan-interface101] quit
(2) 配置链路A上的静态路由快速重路由
静态路由支持快速重路由配置有两种方法,可以任选一种
方法一:配置静态路由快速重路由功能(手工指定备份下一跳)
# 在Switch A上配置静态路由,并指定备份出接口和下一跳。
[SwitchA] ip route-static 4.4.4.4 32 vlan-interface 200 13.13.13.2 backup-interface vlan-interface 100 backup-nexthop 12.12.12.2
[SwitchA] ip route-static 24.24.24.0 24 vlan-interface 200 13.13.13.2 backup-interface vlan-interface 100 backup-nexthop 12.12.12.2
# 在Switch B上配置静态路由,并指定备份出接口和下一跳。
[SwitchB] ip route-static 1.1.1.1 32 vlan-interface 200 13.13.13.1 backup-interface vlan-interface 101 backup-nexthop 24.24.24.2
[SwitchB] ip route-static 12.12.12.0 24 vlan-interface 200 13.13.13.1 backup-interface vlan-interface 101 backup-nexthop 24.24.24.2
方法二:配置静态路由快速重路由功能(自动查找备份下一跳)
# 在Switch A上配置静态路由,并配置静态路由自动快速重路由功能。
[SwitchA] ip route-static 4.4.4.4 32 vlan-interface 100 12.12.12.2 preference 70
[SwitchA] ip route-static 24.24.24.0 24 vlan-interface 100 12.12.12.2 preference 70
[SwitchA] ip route-static fast-reroute auto
# 在Switch B上配置静态路由,并配置静态路由自动快速重路由功能。
[SwitchB] ip route-static 1.1.1.1 32 vlan-interface 101 24.24.24.2 preference 70
[SwitchB] ip route-static 12.12.12.0 24 vlan-interface 101 24.24.24.2 preference 70
[SwitchB] ip route-static fast-reroute auto
(3) 配置链路B上的静态路由
# 在Switch C上配置静态路由。
[SwitchC] ip route-static 4.4.4.4 32 vlan-interface 101 24.24.24.4
[SwitchC] ip route-static 1.1.1.1 32 vlan-interface 100 12.12.12.1
[SwitchC] ip route-static 13.13.13.0 24 vlan-interface 100 12.12.12.1
[SwitchC] ip route-static 13.13.13.0 24 vlan-interface 101 24.24.24.4 preference 70
# 在Switch A上查看4.4.4.4/32路由,可以看到备份下一跳信息。
[SwitchA] display ip routing-table 4.4.4.4 verbose
Summary count : 1
Destination: 4.4.4.4/32
Protocol: Static
Process ID: 0
SubProtID: 0x0 Age: 04h20m37s
Cost: 0 Preference: 60
IpPre: N/A QosLocalID: N/A
Tag: 0 State: Active Adv
TableID: 0x2 OrigAs: 0
NibID: 0x26000002 LastAs: 0
AttrID: 0xffffffff
BkAttrID: 0x6cb875b7 Neighbor: 0.0.0.0
Flags: 0x1008c OrigNextHop: 13.13.13.2
Label: NULL RealNextHop: 13.13.13.2
BkLabel: NULL BkNextHop: 12.12.12.2
SRLabel: NULL Interface: Vlan-interface200
BkSRLabel: NULL BkInterface: Vlan-interface100
Tunnel ID: Invalid IPInterface: Vlan-interface200
BkTunnel ID: Invalid BkIPInterface: Vlan-interface100
LinkCost: 0 MicroSegID: 0
RealFIRType: Normal RealThres: 0
InLabel: 0 ColorInterface: N/A
SIDIndex: NULL BkColorInterface: N/A
FtnIndex: 0x0 TunnelInterface: N/A
TrafficIndex: N/A BkTunnelInterface: N/A
Connector: N/A PathID: 0x0
SID Type: N/A NID: Invalid
FlushNID: Invalid BkNID: Invalid
BkFlushNID: Invalid StatFlags: 0x0
SID: N/A
BkSID: N/A
CommBlockLen: 0 SRTunnelID: Invalid
MemberPort: N/A ExtFlags: 0x0
SliceID: 0 BkSliceID: 0
# 在Switch B上查看1.1.1.1/32路由,可以看到备份下一跳信息。
[SwitchB] display ip routing-table 1.1.1.1 verbose
Summary count : 1
Destination: 1.1.1.1/32
Protocol: Static
Process ID: 0
AttrID: 0xffffffff
Flags: 0x1008c OrigNextHop: 13.13.13.1
Label: NULL RealNextHop: 13.13.13.1
BkLabel: NULL BkNextHop: 24.24.24.2
BkSRLabel: NULL BkInterface: Vlan-interface101
BkTunnel ID: Invalid BkIPInterface: Vlan-interface101
SID: N/A
BkSID: N/A
· Switch A
sysname SwitchA
vlan 100
vlan 200
interface LoopBack0
ip address 1.1.1.1 255.255.255.255
ip address 12.12.12.1 255.255.255.0
interface Vlan-interface200
ip address 13.13.13.1 255.255.255.0
port access vlan 200
ip route-static 4.4.4.4 32 Vlan-interface200 13.13.13.2
ip route-static 4.4.4.4 32 Vlan-interface100 12.12.12.2 preference 70
ip route-static 24.24.24.0 24 Vlan-interface200 13.13.13.2
ip route-static 24.24.24.0 24 Vlan-interface100 12.12.12.2 preference 70
return
· Switch B
sysname SwitchB
vlan 101
vlan 200
interface LoopBack0
ip address 4.4.4.4 255.255.255.255
interface Vlan-interface101
ip address 24.24.24.4 255.255.255.0
ip address 13.13.13.2 255.255.255.0
port access vlan 101
ip route-static 1.1.1.1 32 Vlan-interface200 13.13.13.1
ip route-static 1.1.1.1 32 Vlan-interface101 24.24.24.2 preference 70
ip route-static 12.12.12.0 24 Vlan-interface200 13.13.13.1
ip route-static 12.12.12.0 24 Vlan-interface101 24.24.24.2 preference 70
return
· Switch C
sysname SwitchC
vlan 100
vlan 101
ip address 12.12.12.2 255.255.255.0
ip address 24.24.24.2 255.255.255.0
ip route-static 1.1.1.1 32 Vlan-interface100 12.12.12.1
ip route-static 4.4.4.4 32 Vlan-interface101 24.24.24.4
ip route-static 13.13.13.0 24 Vlan-interface100 12.12.12.1
ip route-static 13.13.13.0 24 Vlan-interface101 24.24.24.4 preference 70
return
缺省路由是在路由器没有找到匹配的路由表项时使用的路由。
如果报文的目的地不在路由表中且没有配置缺省路由,那么该报文将被丢弃,将向源端返回一个ICMP报文报告该目的地址或网络不可达。
· 第一种是网络管理员手工配置。配置请参见“配置静态路由”,将目的地址与掩码配置为全零(0.0.0.0 0.0.0.0)。
· 第二种是动态路由协议生成(如OSPF、IS-IS和RIP),由路由能力比较强的路由器将缺省路由发布给其它路由器,其它路由器在自己的路由表里生成指向那台路由器的缺省路由。配置请参见各个路由协议手册。
如图2-1所示,Device A发往Device C、Device D和Device E的报文下一跳都是Device B,因此可在Device A上配置一条缺省路由,代替配置通往Device C、Device D和Device E网络的3条静态路由。配置完成后,如果报文没有其他满足匹配的路由表项,则会通过缺省路由转发出去。
在Device A上配置缺省路由时,需要将目的地址和掩码配置为全零(0.0.0.0 0.0.0.0),下一跳地址为Device B接口的地址1.1.1.2。
