06-终端接入命令参考
01-POS终端接入命令
本章节下载: 01-POS终端接入命令  (626.41 KB)
01-POS终端接入命令
1 POS终端接入
1.1 POS终端接入配置命令
1.1.1 app
1.1.2 auto-connect enable
1.1.3 backup app
1.1.4 backup app-group
1.1.5 caller-number enable
1.1.6 description
1.1.7 display fcm statistics
1.1.8 display posa app-group
1.1.9 display posa connection terminal
1.1.10 display posa load-sharing statistics
1.1.11 display posa statistics app
1.1.12 display posa statistics caller-id
1.1.13 display posa statistics caller-ip
1.1.14 display posa statistics nii
1.1.15 display posa statistics terminal
1.1.16 display posa status app
1.1.17 display posa status terminal
1.1.18 hello enable
1.1.19 host
1.1.20 ip
1.1.21 mode
1.1.22 negotiation hookoff
1.1.23 negotiation no-carrier-detect retry
1.1.24 negotiation scramble-binary1
1.1.25 negotiation silence
1.1.26 negotiation unscramble-binary1
1.1.27 posa app
1.1.28 posa app-connection keep
1.1.29 posa app-group
1.1.30 posa auto-stop-service enable
1.1.31 posa bind app
1.1.32 posa bind terminal
1.1.33 posa bind terminal first-terminal-id
1.1.34 posa calling-prefix
1.1.35 posa connection-threshold terminal
1.1.36 posa e1-dial-falling-threshold
1.1.37 posa fcm
1.1.38 posa map
1.1.39 posa server enable
1.1.40 posa statistics caller-id
1.1.41 posa statistics caller-ip
1.1.42 posa terminal
1.1.43 posa terminal description
1.1.44 posa terminal ssl-server-policy
1.1.45 posa tpdu-replace
1.1.46 posa trade-falling-threshold
1.1.47 posa trade-limit tcp
1.1.48 posa trade-timeout
1.1.49 reset fcm statistics
1.1.50 reset posa connection terminal
1.1.51 reset posa load-sharing statistics
1.1.52 reset posa statistics
1.1.53 snmp-agent trap enable posa
1.1.54 source ip
1.1.55 source port
1.1.56 tcp keepalive
1.1.57 tcp linking-time
1.1.58 terminal-ip append
1.1.59 threshold answer-tone
1.1.60 threshold rlsdoff
1.1.61 threshold rlsdon
1.1.62 threshold txpower
1.1.63 timer auto-connect
1.1.64 timer hello
1.1.65 timer quiet
1.1.66 tpdu-change
1.1.67 trade-exchanges
1 POS终端接入
说明: 说明
通过安装License,可以增加设备支持的TCP连接并发交易数目。有关License的详细介绍,请参见“基础配置指导”中的“License管理”。
本特性的支持情况与设备型号有关,请以设备的实际情况为准。
型号
MSR610
不支持
不支持
MSR810-LMS、MSR810-LUS
不支持
MSR810-SI、MSR810-LM-SI
不支持
MSR810-LMS-EA、MSR810-LME
不支持
MSR1004S-5G、MSR1004S-5G-CN
不支持
不支持
不支持
MSR2600-10-X1
不支持
MSR2630-G-X1
支持
MSR 2630
支持
MSR3600-28、MSR3600-51
支持
MSR3600-28-SI、MSR3600-51-SI
不支持
支持
支持
支持
不支持
MSR-iMC
不支持
支持
支持
MSR3610-G、MSR3620-G
支持
MSR3640-G
支持
MSR3640-X1-HI
支持
型号
不支持
MSR830-4LM-WiNet
不支持
不支持
不支持
MSR2600-6-WiNet
不支持
MSR2600-10-X1-WiNet
不支持
MSR2630-WiNet
支持
MSR3600-28-WiNet
支持
MSR3610-X1-WiNet
支持
MSR3620-X1-WiNet
支持
支持
型号
MSR860-6EI-XS
不支持
MSR860-6HI-XS
不支持
MSR2600-15-X1-XS
不支持
MSR2630-XS
不支持
MSR3600-28-XS
支持
MSR3610-XS
支持
MSR3620-XS
支持
MSR3610-I-XS
不支持
MSR3610-IE-XS
不支持
MSR3620-X1-XS
支持
MSR3640-XS
支持
MSR3660-XS
支持
型号
MSR810-LM-GL
不支持
MSR810-W-LM-GL
不支持
MSR830-6EI-GL
不支持
MSR830-10EI-GL
不支持
MSR830-6HI-GL
不支持
MSR830-10HI-GL
不支持
MSR1004S-5G-GL
不支持
MSR2600-6-X1-GL
不支持
MSR3600-28-SI-GL
不支持
1.1  POS终端接入配置命令
1.1.1  app
app命令用来在POS应用模板组中添加POS应用模板。
undo app命令用来在POS应用模板组中删除POS应用模板。
app app-id weight weight-value
undo app app-id
POS应用模板组中不存在POS应用模板。
POS应用模板组视图
app-id:POS应用模板ID,取值范围为1~1024,添加的POS应用模板必须为已经存在的TCP接入类型的POS应用模板。
weight weight-value:指定POS应用模板负载分担的权重,weight-value表示负载分担的权重,取值范围为1~100。POS应用模板根据权重确定转发流量的比例。POS应用模板的权重越大,其对应的前置机处理的POS交易报文越多。
将POS应用模板添加到POS应用模板组中后,在POS交易时,设备会根据POS应用模板组中各个POS应用模板的权重值、状态以及交易负荷情况,依次选择最优的前置机来处理POS交易报文。如果与选择的高优先级前置机TCP连接建立失败,则依次选择次优先级的前置机建立TCP连接。
被引用的POS应用模板必须为TCP类型,若指定的POS应用模板不存在或者类型不是TCP,则允许配置成功,但功能不生效。
一个POS应用模板组中最多支持添加16个POS应用模板。
# 将POS应用模板1添加到POS应用模板组ag1,并配置权重值为10。
[Sysname] posa app-group ag1
[Sysname-posa-appgrp-ag1] app 1 weight 10
·     posa app
·     posa app-group
auto-connect enable命令用来开启自动建立连接功能,即POS接入设备自动为长连接模式的POS应用模板建立与前置机之间的TCP连接。
undo auto-connect enable命令用来关闭自动建立连接功能。
auto-connect enable
POS应用模板自动建立连接功能处于关闭状态。
POS应用模板视图
只有长连接模式的TCP类型的POS应用模板才支持该配置,配置后POS应用模板会立即向前置机发起连接。当POS应用模板的连接模式由短连接修改为长连接时,POS接入设备会立即向前置机发起连接。
该连接建立后只能用于非透传模式下的TCP长连接复用。
# 开启长连接模式的POS应用模板1的自动建立连接功能。
[Sysname] posa app 1 type tcp
[Sysname-posa-app1] auto-connect enable
·     posa server enable
·     timer auto-connect
1.1.3  backup app
backup app命令用来配置备份POS应用模板。
undo backup app命令用来恢复缺省情况。
backup app app-id
undo backup app
未配置备份POS应用模板ID。
POS应用模板视图
app-id:备份应用ID,取值范围为1~1024。
POS交易时,若某POS应用模板对应的前置机不可达,则向其备份POS应用模板对应的前置机发起连接。仅TCP类型的POS应用模板支持备份POS应用模板。
若指定的APP不存在或者APP类型不是TCP,则允许配置成功,但不生效。
# 创建TCP连接方式的POS应用模板1。
# 创建TCP连接方式的POS应用模板2,配置其备份应用服务器为1。
[Sysname] posa app 2 type tcp
[Sysname-posa-app2] backup app 1
·     timer quiet
backup app-group命令用来配置备份POS应用模板组。
undo backup app-group命令用来恢复缺省情况。
backup app-group app-group-name
undo backup app-group app-group-name
不存在备份POS应用模板组。
POS应用模板组视图
app-group-name:POS应用模板组名称,为1~31个字符的字符串,不区分大小写。
POS交易时,若某POS应用模板组中的POS应用模板对应的前置机都不可达,则向备份POS应用模板组中的POS应用模板对应的前置机发起TCP连接。
一个POS应用模板组下仅支持配置一个备份POS应用模板组,且不能与主POS应用模板组名称相同。若在同一个POS应用模板组视图下多次使用本命令配置备份POS应用模板组,仅最后一次配置生效。
# 在POS应用模板组ag2下,配置POS应用模板组ag1作为备份POS应用模板组。
[Sysname-posa-appgrp-ag1] quit
[Sysname] posa app-group ag2
[Sysname-posa-appgrp-ag2] backup app-group ag1
·     posa app-group
caller-number enable命令用来开启主叫号码发送功能,即在进行POS交易时向前置机发送POS机的主叫号码。
undo caller-number enable命令用来关闭主叫号码发送功能。
主叫号码发送功能处于关闭状态。
POS应用模板视图
只有TCP类型的POS应用模板才支持此配置,且本功能只对FCM POS机和AM POS机有效:
·     对于AM POS机接入方式,需要将应用模板配置为短连接模式,此功能才能生效。
·     对于FCM POS机接入方式,需要将应用模板配置为非透传模式,此功能才能生效。
FCM POS机接入与AM POS机接入两种方式下发送主叫号码的格式不同。
# 配置TCP类型的POS应用模板1,使能主叫号码发送功能。
[Sysname-posa-app1] mode temporary
[Sysname-posa-app1] caller-number enable
1.1.6  description
description命令用来配置POS应用模板的描述信息。
undo description命令用来恢复缺省情况。
未配置POS应用模板的描述信息。
POS应用模板视图
text:POS应用模板的描述信息,为1~32字符的字符串,区分大小写,合法字符是不为“?”的可打印字符。
# 创建TCP连接方式的POS应用模板,并配置它的描述信息为“ChinaBank1”。
[Sysname-posa-app1] description ChinaBank1
display fcm statistics命令用来显示FCM接口的POS接入的统计信息。
display fcm statistics [ interface fcm { interface-number | interface-number:setnumber.subnumber } ]
interface fcm { interface-number | interface-number:setnumber.subnumber }:显示指定接口的POS接入统计信息。interface-number表示物理FCM接口编号,用来显示物理FCM接口的POS接入统计信息;interface-number:setnumber.subnumber表示FCM子接口的编号,用来显示指定通道化FCM接口下子接口的POS接入统计信息。如果不指定该参数,则显示所有物理FCM接口、通道化FCM接口的子接口的POS接入的统计信息。
设备重启、以及执行reset fcm statistics命令行会删除该统计值。
# 显示接口FCM2/1/0的POS接入的统计信息。
<Sysname> display fcm statistics interface fcm 2/1/0
Interface TerminalID ConnectFailed TimedOut Transactions (Total/Success)
Fcm2/1/0  5          20            30       100/20
表1-1 display fcm statistics命令显示信息描述表
接入的接口,只能为FCM接口
TerminalID
POS终端模板ID,若未绑定终端则显示为-
ConnectFailed
因拨号协商不成功的次数
TimedOut
因交易超时而断开的次数
Transactions
该接口下POS交易次数,包括:
·     Total:总交易数
·     Success:该接口下成功转发了交易报文的POS交易次数。在FCM交易过程中,POS机拨号后只要成功收发了交易报文,就认为本次交易成功,此统计值就加1。此值与TimedOut的统计不互斥,即交易了多个报文但总交易时间超时的交易,既统计为TimeOut又统计为Success
·     reset fcm
display posa app-group命令用来显示POS应用模板组的信息。
display posa app-group [ app-group-name ]
app-group-name:POS应用模板组名称,为1~31个字符的字符串,不区分大小写。如果不指定本参数,则显示所有POS应用模板组的信息。
# 显示所有的POS应用模板组信息。
<Sysname> display posa app-group
App group: ag1
  Backup: ag3
  AppID    Weight    Type     Mode          State
  1        20        TCP      Temporary     Linked
  2        30        TCP      Temporary     Blocked
App group: ag2
  Backup: ag4
  3        20        TCP      Temporary     Linked
  4        40        TCP      Temporary     Linked
Total number of POSA application group(s): 2
# 查看指定的POS应用模板组ag1信息。
<Sysname> display posa app-group ag1
App group: ag1
  Backup: ag3
表1-2 display posa app-group命令显示信息描述表
App group
POS应用模板组名称
Backup
备份应用模板组名称,未配置时,显示为”Not configured“
AppID
POS应用模板ID
Weight
POS应用模板负载分担的权重
POS应用模板组中POS应用模板的连接类型,取值包括:
·     Flow:表示流连接方式
·     TCP:表示TCP连接方式
·     -:表示POS应用模板不存在
Mode
POS应用模板组中POS应用模板建立的连接模式。
·     当连接不存在或者连接方式为Flow时,取值为“-”
·     当连接方式为TCP时,取值为:
¡     Permanent:长连接模式
¡     Temporary:短连接模式
POS应用模板组中POS应用模板的连接状态。
·     连接为Flow方式,取值为:
¡     Up:表示连接建立
¡     Down:表示连接断开
¡     Error:同异步接口切换到了同步模式
¡     -:表示POS应用模板未配置应用模板的接口
·     连接为TCP方式,取值为:
¡     Unlinked:表示连接未建立
¡     Linking:表示连接正在建立
¡     Linked:表示连接已建立
¡     Multilink(N):表示该应用下建立了N条TCP连接
¡     Blocked:表示该应用故障,被静默
¡     Error:表示应用模板表项不可用,原因为该表项使能失败(TCP绑定源端口失败)
¡     -:表示POS应用模板未配置应用模板的IP地址和端口号
·     连接不存在时,显示为“-”
POS应用模板组的总个数
display posa connection terminal命令用来显示POS终端模板的连接信息。
display posa connection terminal [ terminal-id ]
terminal-id:POS终端模板ID,取值范围为1~1024。如果不指定该参数,则显示所有POS终端的连接信息。
# 显示所有POS终端模板的连接信息。
<Sysname> display posa connection terminal
Total TCP connections : 2
Total FCM connections : 1
Total flow connections: 1
Max concurrent trades : 65535
Current non-TCP trades: 2
Current TCP trades    : 60
ID  Type  Interface    SrcIP:SrcPort         DstIP:DstPort Trades
1   TCP   -            192.168.100.100:1319  192.168.100.236:3000  10
1   TCP   -            192.168.100.100:1320  192.168.100.236:3000  20
5   TCP   -            192.168.100.200:1323  192.168.100.236:4000  30
6   FCM   Fcm10/0:0.0  -                     -                     1
7   Flow  Asy1/0       -                     -                     1
# 显示POS终端模板1的连接信息。
<Sysname> display posa connection terminal 1
表1-3 display posa status terminal命令显示信息描述表
TCP接入方式下的当前连接总数
FCM接入方式下的当前连接总数
Flow接入方式下的当前连接总数
Max coucurrent trades
系统支持的最大并发交易数
当前并发的所有非TCP交易数
Current TCP trades
当前并发的所有TCP交易数
ID
POS终端模板ID
POS终端模板的连接类型:
·     Flow:流接入方式
·     FCM:FCM拨号接入方式
·     TCP:TCP接入方式
接入的端口,TCP接入方式下显示为“-”
SrcIP
连接的源地址,非TCP接入方式下显示为“-”
SrcPort
连接的源端口,非TCP接入方式下显示为“-”
DstIP
连接目的地址,非TCP接入方式下显示为“-”
DstPort
连接目的端口,非TCP接入方式下显示为“-”
Trades
链接的当前并发交易数
display posa load-sharing statistics命令用来显示POS应用模板组的负载分担统计信息。
display posa load-sharing statistics [ app-group app-group-name ]
app-group app-group-name:指定POS应用模板组,app-group-name表示POS应用模板组的名称,为1~31个字符的字符串,不区分大小写。如果不指定本参数,则显示所有POS应用模板组的负载分担统计信息。
设备对POS应用模板组的负载分担统计周期为5秒,配置本命令可以查看设备在上一个统计周期内和设备启动直至当前的时间段内向前置机发送成功的POS交易请求报文信息。
POS应用模板组主备倒换后,历史统计数据仍会保留。
# 查看所有的POS应用模板组的负载分担信息。
<Sysname> display posa load-sharing statistics
App group: ag1
  AppID     Weight    Last 5 sec    History
  1         30        30            166
  2         40        42            178
  4         30        31            160
  6         80        80            390
App group: ag2
  1         90        90            466
  4         60        60            260
  8         40        40            190
# 查看指定的POS应用模板组ag1的负载分担信息。
<Sysname> display posa load-sharing statistics app-group ag1
App group: ag1
  1         30        30            166
  2         40        42            178
  4         30        31            160
  6         80        80            390
表1-4 display posa load-sharing statistics命令显示信息描述表
App group
POS应用模板组名称
AppID
POS应用模板ID
Weight
POS应用模板负载分担的权重
Last 5 sec
上一个统计周期内发送成功的POS交易请求报文数目
History
设备启动后发送成功的POS交易请求报文数目
·     reset posa load-sharing statistics
display posa statistics app命令用来显示POS应用模板的统计信息。
display posa statistics app [ app-id ]
app-id:POS应用模板ID,取值范围为1~1024。如果不指定该参数,则显示所有POS应用模板的统计信息。
对某一应用模板进行报文统计指的是该应用模板下所有应用实例接收发送的报文数目。
删除应用模板、设备重启、执行reset posa statistics命令会删除该统计值。
# 显示所有POS应用模板的统计信息。
<Sysname> display posa statistics app
ID  Received     Sent       PktErr      DisErr    InDiscarded    OutDiscarded
1   100          100        0           0         0              3
2   60           70         0           0         0              0
3   100          10         0           0         0              0
表1-5 display posa statistics app命令显示信息描述表
ID
POS应用模板ID
Received
从前置机接收到的报文数目(含PktErr和DisErr错误的报文数目,不含InDiscarded报文数目)
Sent
发送给前置机的报文数目(不包含链路不通丢弃的报文数目)
PktErr
格式错误的报文数目
DisErr
分发处理错误的报文数目,即找不到对应POS终端接入的报文数目
InDiscarded
接收缓冲区满丢弃的报文数目,是指从前置机接收报文时,因接收缓冲区满而丢弃的报文数目
OutDiscarded
链路不通丢弃的报文数目,是指应用发送报文时因链路不通丢弃报文数目
·     reset posa statistics
display posa statistics caller-id命令用来显示指定主叫号码的POS交易统计信息。.
display posa statistics caller-id [ caller-number ]
caller-number:终端主叫号码,为1~64个字符的字符串。
终端主叫号码仅可以为数字和字母,如01012345678。通常意义上的主叫号码都是由数字组成,但是不排除特殊情况使用字母。如果不指定该参数,则显示所有终端主叫号码的统计信息。
设备重启、执行reset posa statistics命令会清除该统计值。
# 显示终端主叫号码为01012345678的POS交易统计信息。
<Sysname> display posa statistics caller-id 01012345678
CID             Received  Sent      PktErr    MapErr    InDiscarded   OutDiscarded
01012345678     100       100       0         0         0             0
表1-6 display posa statistics caller-id命令显示信息描述表
CID
终端主叫号码
Received
Sent
PktErr
格式错误的报文数目
MapErr
应用映射失败,即查找不到应用对应关系的报文数目
InDiscarded
OutDiscarded
·     posa statistics caller-id
display posa statistics caller-ip命令用来显示指定源IP统计项的POS交易统计信息。
display posa statistics caller-ip [ group-id ]
group-id:统计项编号,取值范围为1~64。如果不指定该参数,则显示所有源IP统计项的状态信息。
# 显示源IP统计项1的POS机的交易统计信息。
<Sysname> display posa statistics caller-ip 1
ID  Type IP       Mask     Received Sent  PktErr MapErr InDiscarded OutDiscarded
64  IPv4 1.1.1.1  255.255. 150      2     0      0      0           0
                  255.0
表1-7 display posa statistics caller-ip命令显示信息描述表
ID
POS应用模板ID
IPType
IP类型值
CIP
源IP地址
IPMask
源IP地址子网掩码
Received
Sent
PktErr
格式错误的报文数目
MapErr
InDiscarded
OutDiscarded
·     posa statistics caller-ip
display posa statistics nii命令用来显示基于NII的POS交易统计信息。
display posa statistics nii [ nii-id ]
nii-id:TPDU目的地址,取值范围为十六进制数0000~ffff。如果不指定该参数,则显示所有NII的统计信息。
# 显示TPDU目的地址为0x15的POS交易统计信息。
<Sysname> display posa statistics nii 15
ID    Received    Sent   TotalTrade   SuccessTrade   SuccessRate
0x15  2           2      2            2              100.0%
表1-8 display posa statistics nii命令显示信息描述表
ID
TPDU目的地址
Received
Sent
TotalTrade
系统的报文总交易次数
SuccessTrade
系统POS交易成功次数
SuccessRate
基于NII的交易成功率
·     trade-exchanges
display posa statistics terminal命令用来查看POS终端模板的统计信息。
display posa statistics terminal [ terminal-id ]
terminal-id:终端ID,取值范围为1~1024。如果不指定该参数,则显示所有POS终端模板的统计信息。
某一终端的报文统计信息包括该终端下所有终端实例接收发送的报文数目
删除终端模板、设备重启、执行reset posa statistics命令会删除该统计值。
# 显示所有POS终端模板的统计信息。
<Sysname> display posa statistics terminal
ID  Received   Sent      PktErr    MapErr     InDiscarded   OutDiscarded  Notified
1   100        50        2         2          0             5             2
2   60         70        0         10         1             6             0
3   100        100       0         0          1             3             0
4   3          0         0         0          0             3             0
表1-9 display posa statistics terminal命令显示信息描述表
ID
POS终端模板ID
Received
从POS机接收到的报文数目(含PktErr和MapErr错误的报文数目,不含InDiscarded的报文数目)
Sent
发送给POS机的报文数目(不包含OutDiscarded和Notified的报文数目)
PktErr
从POS机收到的格式错误的报文数目
MapErr
InDiscarded
从POS机接收报文时,因接收缓冲区满或因获取交易号失败而丢弃的报文数目
OutDiscarded
设备通过对应终端模板发送报文时,因链路不通而丢弃的报文数目
Notified
设备向POS机发送的通告报文数目,是指当设备处理POS机报文应用映射失败、获取交易号失败或者向前置机转发POS机报文失败时,设备向POS机发送的通告报文数目
display posa status app命令用来显示POS应用模板的状态信息。
display posa status app [ app-id ]
app-id:POS应用模板ID,取值范围为1~1024。如果不指定该参数,则显示所有POS应用模板的状态信息。
# 显示所有POS应用模板的状态信息。
<Sysname> display posa status app
AppID : 0
  Type       : TCP                            Mode : Temporary
  Interface  : -
  Host name  : FrontServer.example.com
  IP Address : -                              Port : 1000
  State      : Linked
AppID : 1
  Type       : TCP                            Mode : Permanent
  Interface  : -
  Host name  : -
  IP Address : 192.168.7.254                  Port : 1000
  State      : Error
AppID : 2
  Type       : Flow                           Mode : -
  Interface  : Asy2/1/0
  Host name  : -
  IP Address : -                              Port : -
  State      : Down
表1-10 display posa status app命令显示信息描述表
AppID
POS应用模板ID
应用的连接类型:
·     Flow:流连接方式
·     TCP:TCP连接方式
Mode
应用模板的模式:
Flow:显示为“-”
TCP:
·     Permanent:长连接模式
·     Temporary:短连接模式
应用模板的接口(未配置或者TCP方式下该项为“-”)
Host name
应用模板的主机名(未配置或者Flow方式下该项为“-”)
IP Address
应用模板的IP地址(未配置或者Flow方式下该项为“-”)
·     若当前连接未中断,则显示当前连接使用的IP地址。
·     若当前连接中断但开启了自动建立连接和连接不中断功能,则显示尝试重新建立连接使用的IP地址(关于IP地址的选择请参见posa app-conntection keep命令)。
·     若当前连接中断且未开启连接不中断功能,则显示前置机主机名对应的IP地址。
Port
应用模板的端口号(未配置或者Flow方式下该项为“-”)
应用模板的连接状态:
Flow方式:
·     Up:连接建立
·     Down:连接断开
TCP方式:
·     Unlinked:连接未建立
·     Linking:连接正在建立
·     Linked:连接已建立
·     Multilink(N):标识该应用下建立了N条TCP连接
·     Blocked:标识该应用故障,被静默
·     Error:应用模板表项不可用,原因为该表项使能失败(TCP绑定源端口失败)
接口及IP地址和端口号均未配置时,该项为“-”
display posa status terminal命令用来显示POS终端模板的状态信息。
display posa status terminal [ terminal-id ]
terminal-id:POS终端模板ID,取值范围为1~1024。如果不指定该参数,则显示所有POS终端模板的状态信息。
# 显示所有POS终端模板的状态信息。
<Sysname> display posa status terminal
TerminalID  Type  Interface       ListenPort  State
1           TCP   -               2000        Unlinked
2           TCP   -               2000        Error
3           FCM   Fcm2/10/0:0.0   -           Down
254         TCP   -               3000        Multilink(2)
255         Flow  Asy2/1/0        -           Up
表1-11 display posa status terminal命令显示信息描述表
TerminalID
POS终端模板ID
POS终端模板的连接类型:
·     Flow:流接入方式
·     FCM:FCM拨号接入方式
·     TCP:TCP接入方式
接入的端口(TCP接入方式下该项为“-”)
ListenPort
TCP终端的监听端口(FCM/Flow接入方式下该项为“-”)
终端的连接状态:
Flow/FCM接入:
·     Up:连接建立
·     Down:连接断开
TCP接入:
·     Unlinked:连接未建立
·     Linking:连接正在建立
·     Linked:连接已建立
·     Multilink(N):标识该终端下建立了N条TCP连接
·     Error:表项不可用,该表项使能失败
1.1.18  hello enable
hello enable命令用来开启POS应用模板握手功能。
undo hello enable用来关闭POS应用模板握手功能。
hello enable
undo hello enable
POS应用模板握手功能处于关闭状态。
POS应用模板视图
只有TCP类型的POS应用模板支持此命令。
缺省情况下,设备只有在存在POS业务的情况下才会和前置机通信,并发现前置机是否故障,这样可能会使当前交易业务处理失败或者导致业务处理的时延较长。为了提前发现故障并做容错处理,尽量降低前置机故障对POS业务的影响,可通过开启POS应用模板周期性握手功能来主动探测前置机的状态。前置机也可以通过此功能来判断设备的可达性。
POS应用模板握手功能的流程为:设备以指定的间隔(可以通过timer hello命令设置)向当前POS应用模板对应的前置机发起TCP连接,TCP连接建立后,设备还会向前置机发送DATA字段为空的POS报文(报文内容固定为00056000000000,前置机并不会回应此报文)。
对于短连接应用,设备会新建一个TCP连接发报文,对于长连接应用,设备使用已经存在的长连接发送报文,若长连接不存在则创建,并在握手后继续保持。
握手功能会影响当前应用的静默状态:若处于静默状态的POS应用模板握手成功,则退出静默状态;若处于非静默状态的POS应用模板握手失败,则进入静默状态。
对于短连接应用,握手时发起连接成功不会发送前置机状态变化的告警信息。
# 开启应用1握手功能。
[Sysname-posa-app1] hello enable
·     timer hello
1.1.19  host
host命令用来配置当前POS应用模板对应的前置机的主机名和端口号。
undo host命令用来恢复缺省情况。
host host-name port port-number
undo host
未配置当前POS应用模板对应的前置机的主机名和端口号。
POS应用模板视图
host-name:POS应用模板银行前置机的主机名,为1~253个字符的字符串,不区分大小写,字符串中可以包含字母、数字、“-”、“_”和“.”。
port-number:POS应用模板银行前置机服务的端口号,取值范围为1~65535。
本命令只适用于TCP类型的POS应用模板。
同一个POS应用模板下只能配置一个主机名和端口,修改主机名或者端口号将会删除现有的该POS应用模板的所有TCP连接。
若在同一个POS应用模板下多次使用本命令和ip命令配置前置机,则最终生效配置为最后一次配置。
# 配置TCP类型的POS应用模板1,主机名为FrontServer.example.com,端口号为1000。
[Sysname-posa-app1] host FrontServer.example.com port 1000
# 修改主机名和端口。
[Sysname-posa-app1] host FrontServer1.example.com port 1001
Connections for the application have been reset.
·     posa app
·     ip
1.1.20  ip
ip命令用来配置当前POS应用模板对应的前置机的IP地址和端口号。
undo ip命令用来恢复缺省情况。
ip ip-address port port-number
undo ip
未配置当前POS应用模板对应的前置机的IP和端口号。
POS应用模板视图
ip-address:POS应用模板银行前置机的IP地址,为非环回的单播IPv4地址。
同一个POS应用模板下只能配置一个IP地址和端口,修改IP地址或者端口号将会删除现有的该POS应用模板的所有TCP连接。
若在同一个POS应用模板下多次使用本命令和host命令配置前置机,则最终生效配置为最后一次配置。
# 配置TCP类型的POS应用模板1,IP地址为1.1.1.1,端口号为3000。
[Sysname-posa-app1] ip 1.1.1.1 port 3000
# 修改IP地址和端口。
[Sysname-posa-app1] ip 1.1.1.2 port 3001
·     posa app
·     host
1.1.21  mode
mode命令用来配置当前POS应用模板的连接模式。
undo mode命令用来恢复缺省情况。
mode { permanent | temporary }
undo mode
POS应用模板的连接模式为长连接模式。
POS应用模板视图
permanent:设置连接模式为长连接模式。
temporary:设置连接模式为短连接模式。
在短连接模式下,终端每发起一次新的交易,设备都会向前置机创建一个新的连接,可并发多个与前置机的连接。每次POS业务结束时(终端挂机或者断开TCP连接时),设备都会断开与前置机应用的连接。
在长连接模式下,非透传终端每发起一次新的连接,只会使用设备与前置机之间现有的一条长连接不会创建新的连接,所以只创建一条与前置机的连接。有个例外情况:若终端配置透传APP,则无论该APP为长连接或者短连接,设备都会为该终端创建一条与前置机专用的连接,此时设备与前置机之间可并发多个连接。当第一次POS业务传送完毕后,这个TCP连接会一直保持用来传送后续的POS业务,即这个TCP连接一经建立就不会主动断开。将长连接修改为短连接时,会删除该模板下已经存在的TCP长连接。
该配置只对TCP连接方式的POS应用模板有效。
修改POS应用模板的连接模式会断开该模板的已建立的TCP连接。
# 配置TCP方式的POS应用模板1,配置POS应用模板1的连接模式为短连接,现有已经建立的长连接被删除。
·     posa app
negotiation hookoff命令用来设置FCM接口接收到铃流后FCM卡延时摘机时间。
undo negotiation hookoff命令用来恢复缺省情况。
negotiation hookoff delaytime
FCM接口接收到铃流后延时摘机时间为500毫秒。
FCM接口视图
delaytime:FCM接口收到铃流后FCM卡延时摘机时间,取值范围为100~6000,单位为毫秒。
# 设置FCM2/4/0接口接收到铃流后FCM卡延时摘机时间。
[Sysname] interface fcm 2/4/0
[Sysname-Fcm2/4/0] negotiation hookoff 2000
negotiation no-carrier-detect retry命令用来配置连续检测到线路为无载波状态的次数。
undo negotiation no-carrier-detect retry命令用来恢复缺省情况。
negotiation no-carrier-detect retry retries
连续检测到线路为无载波状态的次数为1。
FCM接口视图
retries:连续检测到线路为无载波状态的次数,取值范围为1~1000。当FCM卡连续检测到线路为无载波状态的次数为retries时,将挂机。
# 设置FCM2/4/0接口连续检测到线路为无载波状态的次数为20次。
[Sysname-Fcm2/4/0] negotiation no-carrier-detect retry 20
negotiation scramble-binary1命令用来设置Modem协商发送扰码1的持续时间。
undo negotiation scramble-binary1命令用来恢复缺省情况。
negotiation scramble-binary1 scramble-binary1time
Modem协商发送扰码1的持续时间为250毫秒。
FCM接口视图
scramble-binary1time:设置Modem协商发送扰码1的持续时间,取值范围为100~1500,单位为毫秒。
# 设置Modem协商发送扰码1的持续时间为200毫秒。
[Sysname-Fcm2/4/0] negotiation scramble-binary1 200
negotiation silence命令用来设置Modem协商的静默时间。
undo negotiation silence命令用来恢复缺省情况。
negotiation silence silencetime
Modem协商的静默时间为0毫秒。
FCM接口视图
silencetime:设置Modem协商的静默时间,取值范围为0~3000,单位为毫秒。
静默时间是指FCM卡从摘机到发送数据之间的时间,主要是应用于FCM卡和POS机握手,静默时间必须大于POS机的摘机响应时间小于POS机的最大等待时间:
·     如果静默时间大于POS机的最大等待时间,POS机会以为没有数据而挂机;
·     如果静默时间小于POS机的摘机响应时间,因POS机检测到FCM卡摘机需要一段时间,此时POS机还未检测到FCM卡摘机就已将数据发出,从而导致数据丢失。
# 设置Modem协商的静默时间为100毫秒。
[Sysname-Fcm2/4/0] negotiation silence 100
negotiation unscramble-binary1命令用来设置Modem协商发送非扰码1的持续时间。
undo negotiation unscramble-binary1命令用来恢复缺省情况。
negotiation unscramble-binary1 unscramble-binary1time
Modem协商发送非扰码1的持续时间为400毫秒。
FCM接口视图
unscramble-binary1time:设置Modem协商发送非扰码1持续时间,取值范围为300~1500,单位为毫秒。
# 设置Modem协商发送非扰码1的持续时间为900毫秒。
[Sysname-Fcm2/4/0] negotiation unscramble-binary1 900
1.1.27  posa app
posa app命令用来创建POS应用模板,并进入POS应用模板视图。如果指定的POS应用模板已经存在,则直接进入POS应用模板视图。
undo posa app用来删除配置的POS应用模板。
posa app app-id type { flow | tcp }
undo posa app app-id
不存在POS应用模板。
type:设备与银行前置机之间的连接方式。
flow:表示流连接方式。
tcp:表示TCP连接方式。
不能重复配置相同应用ID,并且不能更改已有的设备与前置机之间的连接方式。
创建流方式POS应用模板之后应将其绑定到接口(Async、Serial和Aux接口)上方可生效。
# 创建流连接方式的POS应用模板1,并绑定到Async2/7/0接口上。
[Sysname] posa app 1 type flow
[Sysname-posa-app1] quit
[Sysname] interface Async 2/7/0
[Sysname-Async2/7/0] posa bind app 1
# 创建TCP连接方式的POS应用模板2。
·     posa bind app
posa app-connection keep命令用来配置POS终端连接不中断功能,即前置机的主机名对应的IP地址发生改变时,POS接入设备仍会保持POS应用模板与前置机当前TCP连接不中断。
undo posa app-connection keep命令用来恢复缺省情况。
前置机主机名对应的IP地址发生改变时,POS接入设备会断开POS应用模板与前置机之间TCP连接,且使用新的IP地址建立TCP连接。
本命令仅适用于TCP类型的POS应用模板与前置机连接。在系统视图下配置本功能,对全局TCP连接均有效。
执行本命令后,POS应用模板中的前置机主机名对应的IP地址改变,POS接入设备不会断开当前的连接,且会在TCP keepalive报文检测到连接断开时立即发起连接,新建立连接时选择前置机的IP地址遵循以下原则(以下描述的域名为前置机主机名):
·     若DNS服务器中保存的域名与IP地址对应关系的缓存信息未超时,则选择当前前置机主机名对应的IP地址。
·     若DNS服务器中保存的域名与IP地址对应关系的缓存信息超时,则选择上一次TCP连接的前置机IP地址。
执行undo命令后,POS接入设备会继续保持POS应用模板与前置机当前连接不中断,当前置机的主机名对应的IP地址发生变化后,POS接入设备会断开当前连接并使用新的IP地址建立新连接。
# 配置POS应用模板中前置机的主机名对应的IP地址发生改变时,POS终端TCP连接不中断。
[Sysname] posa app-connection keep
posa app-group命令用来创建POS应用模板组,并进入POS应用模板组视图。如果指定的POS应用模板组已经存在,则直接进入POS应用模板组视图。
undo posa app-group命令用来删除POS应用模板组。
posa app-group app-group-name
undo posa app-group app-group-name
不存在POS应用模板组。
工作在透传模式下的POS终端模板或多应用的POS接入映射表项引用POS应用模板组后,可以在POS应用模板组下的各POS应用模板上进行流量的负载分担。
设备最多支持配置1024个POS应用模板组。
# 创建POS应用模板组ag1,并进入POS应用模板组视图。
posa auto-stop-service enable命令用来开启前置机不可达时的服务自动关闭功能,即当所有的前置机状态为不可达时,关闭TCP类型终端模板的监听端口,使E1POS类型终端模板回复忙音。
undo posa auto-stop-service enable命令用来关闭前置机不可达时的服务自动关闭功能。
前置机不可达时的服务自动关闭功能处于关闭状态。
前置机状态不可达是指POS终端接入设备与前置机发起连接失败(包含发起连接超时),或在连接过程中keepalive报文保活失败导致连接断开。
该命令仅对TCP类型的终端模板和E1POS类型的终端模板有效。当所有TCP类型的POS应用模板对应的前置机状态为不可达时,POS终端接入设备将主动关闭所有TCP类型终端模板的监听端口,并且使所有的E1POS类型终端模板的接口回复忙音。当POS终端接入设备检测到任意一个前置机可达时,则主动打开所有TCP类型终端模板的监听端口,取消所有E1POS类型终端模板的接口回复忙音。
# 开启前置机不可达时的服务自动关闭功能。
[Sysname] posa auto-stop-service enable
posa bind app命令用来绑定POS应用模板。
undo posa bind app命令用来恢复缺省情况。
posa bind app app-id
undo posa bind app
接口下未绑定任何POS应用模板。
异步接口视图
同异步接口视图
同异步接口绑定POS应用模板时,该接口必须工作在异步模式下。若接口不为异步模式则配置可以成功但是该模板的状态为error。
在接口下绑定POS应用模板之前,必须先在系统视图下创建该应用,且该应用的类型必须为Flow类型。
不能通过重复执行本命令修改POS应用模板。如需修改POS应用模板,请先通过undo posa bind app命令取消绑定POS应用模板,再执行posa bind app命令。
不同的接口上必须绑定不同的POS应用模板。
同一接口不能同时配置为接入POS终端模板的接口和绑定POS应用模板的接口。
接口必须工作在流模式下POS终端接入设备才能正常工作。
# 配置Flow类型的应用2。
[Sysname] posa app 2 type flow
[Sysname-posa-app2] quit
# 配置异步接口Async2/1/0与应用2相连。
[Sysname] interface async2/1/0
[Sysname-Async2/1/0] posa bind app 2
·     posa app
posa bind terminal命令用来为接口指定POS终端模板。
undo posa bind terminal命令用来恢复缺省情况。
posa bind terminal terminal-id [ app app-id | app-group app-group-name ]
当前接口未配置为任何POS终端模板的接入接口。
异步接口视图
同异步接口视图
物理AM接口视图
物理FCM接口视图
app app-id:指定该POS终端模板工作在透传模式下,并指定其对应的POS应用模板。app-id为POS应用模板ID,取值范围为1~1024。指定的POS应用模板必须为已经存在的TCP接入类型的POS应用模板。若不指定该参数,则表示该POS终端模板工作在非透传模式下。
app-group app-group-name:指定该POS终端模板工作在透传模式下,并指定其对应的POS应用模板组。app-group-name表示POS应用模板组的名称,为1~31个字符的字符串,不区分大小写。指定的POS应用模板组必须为已经存在的POS应用模板组。若不指定该参数,则表示该POS终端模板工作在非透传模式下。
同异步串口需要工作在异步方式下,才能配置该命令;若接口不为异步模式则配置可以成功但是该模板的状态为error。
同一个POS终端模板只能被指定给一个接口使用。同一个接口下只能配置一个POS终端模板,且不能同时配置为接入POS终端模板的接口和绑定POS应用模板的接口。
指定app app-id参数时,需要注意:
·     接口下配置的POS终端模板不能在非透传模式与透传模式之间的转换,也不能通过重复执行本命令修改POS终端模板的对应的POS应用模板或POS应用模板组。如需修改POS终端模板的POS应用模板或POS应用模板组,必须先配置undo posa bind terminal命令删除POS终端模板的POS应用模板或POS应用模板组,再重新配置。
·     不同POS终端模板可以指定一个相同的透传应用或POS应用模板组。若指定的是POS应用模板组,POS终端应用则会在POS应用模板组进行负载分担。
·     若指定的透传应用不存在或者指定的透传应用不是TCP类型或者指定的应用模板组不存在或者应用模板组内没有TCP类型的APP,允许配置,但不生效,终端交易时会失败。
# 配置Async2/1/0为POS终端模板1的接入接口。
[Sysname] interface async 2/1/0
[Sysname-Async2/1/0] posa bind terminal 1
·     posa app
·     posa app-group
posa bind terminal first-terminal-id命令用来批量指定接口的子接口为POS终端模板接入接口。
posa bind terminal first-terminal-id first-terminal-id [ app-list app-list [ reassemble ] ]
当前接口的子接口未配置为任何POS终端模板的接入接口。
通道化AM接口视图
通道化FCM接口视图
first-terminal-id:起始终端模板ID,取值范围为1~1024。从起始终端模板ID开始到1024之间的POS终端模板ID依次用来与FCM子接口或AM子接口进行绑定。
app-list app-list:指定POS终端模板工作在透传模式下,并指定自起始终端模板ID开始到终端模板ID 1024连续递增的一组终端对应的POS应用模板。app-list为POS应用模板ID列表。app-list取值包括数字、逗号“,”、连字符“-”和冒号“:”,不能包含空格。其中,逗号用来分隔单个数字或一组数字;连字符用来连接两个应用模板ID,表示从起始应用模板ID到结束应用模板ID之间连续的一串应用模板ID,且要求起始应用模板ID要小于结束应用模板ID;冒号用来连接两个数字,表示多次重复指定某一个应用模板ID,前面的数字表示应用模板ID,后面的数字表示重复的次数。应用模板ID的取值范围为1~1024;重复次数的取值范围为1~30。例如“1-14,15,16:13,127-128”表示前14个子接口对应的应用模板ID依次为1~14,第15个子接口对应的应用模板ID为15,第16到第28个子接口对应的应用模板ID均为16,第29和30个子接口对应的应用模板ID分别为127和128。如果不指定本参数,则表示POS终端模板工作在非透传模式下。
reassemble:指定透传模式下,POS终端接入设备对从POS机接收到的分片报文进行重组后,再发送给前置机。如果不指定本参数,则POS终端接入设备直接将接收到的分片报文发送给前置机。只有通道化AM接口视图下支持本参数。
一个物理类型为E1POS的CE1/PRI接口会生成多个FCM子接口,一个物理类型为E1DM的CE1/PRI接口会生成多个AM子接口。FCM子接口和AM子接口生成方式的详细介绍,请参见“接口管理配置指导”中的“WAN接口”。
要使本命令生效,需要注意:
·     指定的POS终端模板数目必须大于或等于子接口数目。例如,指定了起始POS终端模板ID为1020,若当前接口下的FCM子接口数目大于5,则由于绑定的POS终端模板只有5个(1020~1024),POS终端模板数不足导致批量配置失败。
·     指定的应用模板数目必须与子接口的数目一致,否则本命令执行失败。
·     如果要绑定的POS终端模板中存在非FCM/AM类型终端模板或已经与其它接口绑定的终端模板,则本命令执行失败。
如果指定的应用模板不存在或者不是TCP类型,则允许执行本命令,但配置不会生效,终端交易时会失败。
如果前置机不支持对POS交易报文进行分片重组,那么在透传模式下,需要指定reassemble参数,由POS终端接入设备对POS交易报文进行分片重组。
# 接口FCM2/4/0:15下存在30个子接口,批量将这些接口指定为POS终端模板1~30的接入接口,并指定与其绑定的应用模板ID为1~30。
<sysname> system-view
[sysname] interface fcm 2/4/0:15
[sysname-Fcm2/4/0:15] posa bind terminal first-terminal-id 1 app-list 1-30
·     posa app
·     posa bind terminal
posa calling-prefix命令用来配置在POS机的主叫号码前添加前缀。
undo posa calling-prefix命令用来恢复缺省情况。
posa calling-prefix string
设备不在POS机的主叫号码前添加前缀。
FCM接口视图
string:表示前缀码,为1~8个字符的字符串,只能包含数字。
本命令用来在POS机的主叫号码前添加前缀,此前缀码可作为POS机主叫号码的区号,用来标识POS机的地理位置。
本功能仅在开启了主叫号码发送功能后生效。
本命令仅在路由器安装了HMIM-1E1POS、DHMIM-1E1POS1DM接口模块时支持。
# 在接口FCM 2/4/0:15上配置在POS机的主叫号码前添加前缀010。
<Sysname>system-view
[Sysname] interface fcm 2/4/0:15
[Sysname-Fcm5/0:15] posa calling-prefix 010
·     caller-number enable
posa connection-threshold terminal命令用来设置终端并发连接数阈值。
undo posa connection-threshold terminal命令用来恢复缺省情况。
posa connection-threshold terminal { fcm fcm-threshold-value | tcp tcp-threshold-value }
undo posa connection-threshold terminal { fcm | tcp }
TCP接入方式的并发连接数阈值为4096,FCM拨号接入方式的并发连接数阈值为255。
fcm fcm-threshold-value:设置FCM拨号接入方式的并发连接数阈值,取值范围为1~255。
tcp tcp-threshold-value:设置TCP接入方式的并发连接数阈值,取值范围为1~4096。
如果开启了相应的POS终端接入告警功能,则当设备上的TCP或FCM拨号接入方式的终端并发连接数超过指定的阈值时,会生成相应的告警信息。
需要注意的是,终端并发连接数达到指定的阈值后,不会影响后续连接的建立。
# 设置TCP接入方式的并发连接数阈值为200。
[Sysname] posa connection-threshold terminal tcp 200
·     snmp-agent trap enable posa
posa e1-dial-falling-threshold命令用来配置E1POS接口拨号接通率告警阈值。
undo posa e1-dial-falling-threshold命令用来恢复缺省情况。
posa e1-dial-falling-threshold threshold-value
E1POS接口拨号接通率告警阈值为90%。
threshold-value:E1POS接口拨号接通率告警阈值,为百分比形式,取值范围为1~99。
如果设备开启了E1POS接口拨号接通率告警阈值,则当设备的拨号接通率低于配置的告警阈值时,设备会生成相应的告警信息。
# 设置E1POS接口拨号接通率告警阈值为80%。
[Sysname] posa e1-dial-falling-threshold 80
1.1.37  posa fcm
posa fcm命令用来设置在Modem协商过程中的FCM参数。
undo posa fcm命令用来将指定的FCM参数恢复为缺省值。
posa fcm { answer-time time1 | idle-time time2 | trade-time time3 }
undo posa fcm { answer-time | trade-time | idle-time }
Modem协商过程中,应答音时间为2000毫秒,空闲时间为180秒,交易时间为12000000毫秒。
answer-time time1:Modem协商时向POS机发送应答音的时间,取值范围为500~2000,单位为毫秒,缺省值为2000。
idle-time time2:POS机拨号后,链路上空闲最大时间,取值范围为1~12000,单位为秒,缺省值为180。
trade-time time3:单笔POS交易的持续时间,取值范围为30000~12000000,单位为毫秒,缺省值为12000000。
在POS接入应用中,设备上的Modem通常都是作为应答端,而POS机内嵌的Modem做主叫方。Modem通信的基本过程为POS机发起呼叫,应答端检测到呼叫信号时会摘机并发送应答音给POS机,POS机收到该应答音后双方同步开始Modem协商(V.22)过程。由于电话网络比较复杂,信号质量及延迟也不尽相同,对于网络质量较差的系统,应答音设置太短可能会造成Modem无法协商通过,在设备上将只能看到Modem端口不断的up、down,而没有数据包的收发,这时候可以适当增大answer-time参数时间值。
为了提高接入端口的利用效率,需要避免一台POS机拨号接入设备之后长时间占用系统资源,若一台POS机拨入后单笔交易时间超过设置的trade-time值,或空闲时间超过设置的idle-time值,则设备会主动挂机以释放链路资源。
一般情况下,各FCM参数的缺省值基本上都可以满足应用,但在通信出现异常的情况下需要根据上述说明修改各个参数。
# 配置answer-time为800毫秒,trade-time为20分钟(1200000毫秒),idle-time为6秒。
[Sysname] posa fcm answer-time 800
[Sysname] posa fcm trade-time 1200000
[Sysname] posa idle-time 6
1.1.38  posa map
posa map命令用来配置多应用的POS接入映射表项。
undo posa map命令用来删除指定的多应用的POS接入映射表项。
posa map { default | { destination des-code | source src-code } * } { app app-id | app-group app-group-name }
undo posa map { default | { destination des-code | source src-code } * }
无POS接入映射表项。
default:指定缺省的接入映射表项,即所有未找到匹配项的报文将被发送给指定的POS应用模板处理。
destination des-code:指定POS报文的TPDU头中的目的地址,des-code表示目的地址,是由四个十六进制数字表示的字符(如:ffff),一般用来区分不同的银行。它一般是由业务中心统一分配的。
source src-code:指定POS报文的TPDU头中的源地址,src-code表示源地址,是由四个十六进制数字表示的字符(如:0001),一般用来区分不同的POS机。
app app-id:指定POS应用模板ID,app-id为POS应用模板ID,取值范围为1~1024。指定的POS应用模板必须为已经存在的TCP接入类型的POS应用模板,若应用模板ID不存在,可以配置,但不生效。
app-group app-group-name:指定POS应用模板组,app-group-name表示POS应用模板组的名称,为1~31个字符的字符串,不区分大小写。指定的POS应用模板组必须为已经存在的POS应用模板组,若POS应用模板组不存在,可以配置,但不生效。
POS接入设备通过将收到的POS报文的TPDU头中的源地址和目的地址与配置的POS接入映射关系表项进行匹配,来决定将该报文发送到哪个POS应用模板上去处理。若POS报文的源地址、目的地址或者源地址和目的地址的组合与某一个映射关系表项对应,则该报文就被发送给该表项所对应的POS应用模板处理;若该报文未找到任何匹配项,则将被发送给缺省的POS应用模板处理。
同一个POS应用模板可对应多个POS接入映射表项,匹配时其中指定了源地址和目的地址的组合表项匹配优先级最高,缺省映射的优先级最低。
包括缺省POS接入映射表项在内,系统最多支持1024个POS接入映射表项。
在POS交易过程中修改POS接入映射表项的目的前置机,不会删除正在使用中的连接,但可能会影响正在进行的POS交易。
# 配置一个POS接入映射表项,将TPDU头中的目的地址为01f1的POS报文都发送给应用2去处理。
[Sysname] posa map destination 01f1 app 2
# 配置一个缺省的POS接入映射表项,将未能匹配到任何POS接入映射表项的POS报文都发送给POS应用模板1去处理。
[Sysname] posa map default app 1
·     posa app
·     posa app-group
posa server enable命令用来开启POS终端接入服务。
undo posa server enable命令用来关闭POS终端接入服务。
posa server enable
POS终端接入服务处于关闭状态。
要实现POS接入,必须先启动POS终端接入服务。若开启服务时部分功能可以配置但不生效(如TCP端口不可用),管理员通过display posa status查看状态为Error,此时将问题修改后重新使能即可。
# 开启POS终端接入服务。
[Sysname] posa server enable
·     display posa status
posa statistics caller-id命令用来创建一个主叫号码统计项,设备将根据该统计项中指定的终端主叫号码对POS机与前置机之间交互的终端报文数进行统计。
undo posa statistics caller-id命令用来取消指定主叫号码统计项。
posa statistics caller-id caller-number
undo posa statistics caller-id caller-number
无主叫号码统计项。
caller-number:终端主叫号码,为1~64个字符的字符串,仅可以为数字和字母,如01012345678。通常意义上的主叫号码都是由数字组成,但是不排除特殊情况使用字母。
该统计方式仅适用于通过拨号方式接入的POS终端模板。
重复配置则主叫号码统计项不提示错误。
最多支持配置64条统计项。
# 创建一个主叫号码统计项,统计主叫号码为01012345678的POS机报文数。
[Sysname] posa statistics caller-id 01012345678
posa statistics caller-ip命令用来创建一个源IP统计项,该统计项中指定了一个终端源IP地址或者一个源IP网段,设备将根据指定的源IP地址或者源IP网段对POS机与前置机之间交互的终端报文数进行统计。
undo posa statistics caller-ip命令用来删除指定的源IP统计项。
posa statistics caller-ip group-id ip-address ip-mask
undo posa statistics caller-ip group-id
无源IP统计项。
ip-address:终端源IP地址或源IP网段地址,为点分十进制格式。
ip-mask:终端源IP地址或源IP网段的子网掩码,为点分十进制格式。
该统计方式只适用于TCP接入方式的POS终端模板。
各源IP统计项网段之间可以相互重叠,甚至相同。
交易时,只要是源IP地址与统计项中指定的源IP地址或者源IP地址段匹配的POS机交易报文,都会被统计到该统计项,所以一个报文可能会被统计到多个表项中。
# 创建源IP统计项1,统计源IP地址为10.0.1.0/24网段内的POS机的交易报文数。
[Sysname] posa statistics caller-ip 1 10.0.1.0 255.255.255.0
posa terminal命令用来创建TCP接入方式的POS终端模板。
undo posa terminal命令用来删除指定的POS接入终端模板。
posa terminal terminal-id type tcp listen-port port [ idle-time time ] [ http | https | ssl ]
undo posa terminal terminal-id
未配置TCP方式的POS终端模板。
type tcp:创建TCP接入方式的POS终端模板。
listen-port port:指定监听端口号,取值范围为1~65535。
idle-time time:指定POS终端模板的空闲超时时间,取值范围0~1440,单位为分钟,缺省值为0,表示对POS终端模板的空闲时间没有限制。
http:指定POS机与POS终端接入设备之间采用HTTP报文通信。
https:指定POS机与POS终端接入设备之间采用HTTPS报文通信。
ssl:指定POS机与POS终端接入设备之间采用基于SSL的TCP连接来进行数据传输。
POS终端模板用于保存POS接入设备与每一个POS终端交互的相关配置信息。对于流接入方式或者拨号接入方式的POS终端模板,在指定POS终端模板的接入接口时,系统会自动创建对应的POS终端模板。对于TCP接入方式,需要手工配置POS终端模板。
TCP接入方式的POS终端模板上指定的监听端口唯一,不能相互冲突。不能通过重复执行本命令修改TCP终端的监听端口。如需修改TCP终端的监听端口,请先通过undo posa terminal命令删除TCP终端的监听端口,再执行posa terminal命令。
在指定的空闲超时时间内,如果POS机与POS终端模板之间没有报文的交互,则POS终端模板将断开与POS机之间的连接。
执行本命令时,如果指定了ssl或https参数,则需要执行posa terminal ssl-server-policy命令指定建立SSL连接或HTTPS连接时使用的SSL服务器端策略。
# 创建TCP接入方式的POS终端模板1,指定监听端口号为3000,并指定POS机与POS终端接入设备之间采用HTTPS报文通信。
[Sysname] posa terminal 1 type tcp listen-port 3000 https
·     posa terminal ssl-server-policy
posa terminal description命令用来配置POS终端模板的描述信息。
undo posa terminal description命令用来删除POS终端模板的描述信息。
posa terminal terminal-id description text
undo posa terminal terminal-id description
未配置POS终端模板的描述信息。
text:POS终端模板的描述信息,为1~32个字符的字符串,区分大小写,合法字符是不为‘?’的可打印字符。
允许先配置POS终端模板的描述信息再创建该POS终端模板。
# 为POS终端模板1配置描述信息为“Shopping1”。
[Sysname] posa terminal 1 description shopping1
·     posa terminal
posa terminal ssl-server-policy命令用来指定TCP类型终端模板引用的SSL服务器端策略。
undo posa terminal ssl-server-policy命令用来恢复缺省情况。
posa terminal ssl-server-policy policy-name
未指定TCP类型终端模板引用的SSL服务器端策略。
policy-name:TCP类型终端模板引用的SSL服务器端策略,为1~31个字符的字符串,不区分大小写。
对于TCP接入方式,如果执行posa terminal命令时指定了ssl或https参数,则需要执行本命令指定TCP类型终端模板引用的SSL服务器端策略,以便POS终端接入设备根据该策略中配置的SSL参数与POS机建立SSL连接或HTTPS连接。
# 配置TCP类型终端模板引用的SSL服务器端策略为policy1。
[Sysname] posa terminal ssl-server-policy policy1
·     posa terminal
·     ssl server-policy(安全命令参考/SSL)
posa tpdu-replace命令用来配置TPDU地址替换策略,即将符合匹配条件的POS报文TPDU头中的目的地址替换成指定的目的地址,并按新的目的地址查找映射表。
undo posa tpdu-replace命令用来删除指定的TPDU地址替换策略。
posa tpdu-replace match terminal { terminal-id | any } destination { des-code | any } to des-code
undo posa tpdu-replace match terminal { terminal-id | any } [ destination { des-code | any } ]
不对POS报文TPDU头中的目的地址进行替换。
terminal-id:POS终端模板ID。将该终端发送的POS报文TPDU头中的目的地址替换成指定的目的地址。
terminal any:任意POS终端模板ID。配置该参数表示,所有终端发送的POS报文,都将进行地址替换。
destination des-code:POS报文的TPDU头中的目的地址。如果POS报文TPDU头中的目的地址跟所配置的des-code相匹配,则将此地址替换成所需的目的地址。
destination any:任意的TPDU头中的目的地址。配置该参数表示,所有符合terminal匹配条件的POS报文TPDU头中的目的地址将替换成指定的目的地址。
to des-code:需要替换成的目的地址。
通过多次执行本命令可以配置多条TPDU地址替换策略。按照优先级由高到低的顺序,TPDU地址替换策略的匹配顺序为:
(1)     配置了terminal-id和des-code的策略;
(2)     配置了terminal-id和destination any的策略;
(3)     配置了terminal any和des-code的策略;
(4)     配置了terminal any和destination any的策略。
当POS终端模板给POS机返回回应消息时,会恢复原始的TPDU头中的目的地址。
# 将终端1发送的目的地址为0002的POS报文中的目的地址替换为0003。
[Sysname] posa tpdu-replace match terminal 1 destination 0002 to 0003
·     tpdu-change
posa trade-falling-threshold命令用来配置基于NII的交易成功率告警阈值。
undo posa trade-falling-threshold命令用来恢复缺省情况。
posa trade-falling-threshold threshold-value
基于NII的交易成功率告警阈值为90%。
threshold-value:基于NII的交易成功率告警阈值,为百分比形式,取值范围为1~99。
如果设备开启了基于NII的交易成功率告警阈值,则当交易成功率低于配置的阈值时,设备会生成相应的告警信息。
# 设置NII交易成功率过低告警阈值为80%。
[Sysname] posa trade-falling-threshold 80
posa trade-limit tcp命令用来设置TCP连接的并发交易数上限。
undo posa trade-limit tcp命令用来恢复缺省情况。
posa trade-limit tcp limit-value
不对TCP连接的并发交易数做限制。
limit-value:每条TCP连接的并发交易数上限值,取值范围为0~65535,0表示不对TCP连接的并发交易数做限制。
配置了TCP连接的并发交易数上限后,当设备收到的某个TCP连接上的并发交易数超过指定的上限时,会将超出限制的交易报文丢弃。同时,如果设备开启了关于TCP连接并发交易数超过上限的告警功能,还会生成相应的告警信息。
需要注意的是,为了避免在大交易流量时频繁生成告警信息,POS终端接入模块只在某个TCP连接上的并发交易数达到上限后第一次收到新交易报文时生成告警信息。此后,在并发交易数低于上限的90%前不再生成告警信息,当并发交易数低于上限的90%后又重新超出上限时才会再次生成告警信息。
# 配置每条TCP连接的并发交易数上限为1024。
[Sysname] posa trade-limit tcp 1024
posa trade-timeout命令用来设置每笔交易的超时时间。
undo posa trade-timeout命令用来恢复缺省情况。
posa trade-timeout timeout-value
每笔交易的超时时间为240秒。
timeout-value:每笔交易的超时时间,取值范围为1~240,单位为秒。
设备从POS终端收到交易报文后,如果在指定的时间内没有收到银行前置机的应答,则认为交易超时。超时之后再收到此交易的应答,设备会将报文丢弃。
需要注意的是,在网络拥塞的情况下,不能将交易超时时间配置的太小,否则可能会出现内部交易号串号的情况,即设备将已超时交易的内部交易号分配给了新交易,之后收到已超时交易的应答会被误认为是对新交易的应答。
# 配置每笔交易的超时时间为120秒。
[Sysname] posa trade-timeout 120
reset fcm statistics命令用来清除指定FCM接口的统计信息。
reset fcm statistics [ interface fcm { interface-number | interface-number:setnumber.subnumber } ]
interface fcm { interface-number | interface-number:setnumber.subnumber }:清除指定接口的POS接入统计信息。interface-number表示物理FCM接口编号,用来清除物理FCM接口的POS接入统计信息;interface-number:setnumber.subnumber表示FCM子接口的编号,用来清除指定通道化FCM接口下子接口的POS接入统计信息。如果不指定该参数,则清除所有物理FCM接口、通道化FCM接口的子接口的POS接入统计信息。
# 清除所有物理FCM接口、通道化FCM接口的子接口的POS接入统计信息。
<Sysname> reset fcm statistics
·     display fcm statistics
reset posa connection terminal命令用来断开设备与POS机之间的TCP连接。
reset posa connection terminal { all | destination-ip ip-addr2 | destination-port port-number | source-ip ip-addr1 }
all:断开设备与所有POS机之间的TCP连接。
destination-ip ip-addr2:目的IP地址。
destination-port port-number:目的端口号,取值范围为1~65535。
source-ip ip-addr1:源IP地址。
本命令可以根据用户指定的源IP地址、目的IP地址和目的端口号断开指定的单条或多条符合条件的TCP连接。
执行此命令行后会显示已断开的匹配的连接数。
# 断开所有POS机的TCP连接。
<Sysname> reset posa connection terminal all
100 connections have been deleted.
reset posa load-sharing statistics命令用来清除POS应用模板组的负载分担统计信息。
reset posa load-sharing statistics [ app-group app-group-name ]
app-group app-group-name:指定POS应用模板组,app-group-name表示POS应用模板组的名称,为1~31个字符的字符串,不区分大小写。如果不指定本参数,则清除所有POS应用模板组的负载分担统计信息。
# 清除所有的POS应用模板组的负载分担信息。
<Sysname> reset posa load-sharing statistics
·     display posa load-sharing statistics
reset posa statistics命令用来清空POS交易的相关统计信息。
reset posa statistics [ app [ app-id ] | terminal [ terminal-id ] | nii [ nii-id ] ]
本命令用来将display posa statistics app、display posa statistics nii和display posa statistics terminal三条命令显示的统计信息清理,从零开始重新对报文进行记数。
复位不存在的应用的统计信息或者复位不存在的终端的统计信息不提示错误。
# 清空POS交易的相关统计信息。
<Sysname> reset posa statistics
·     display posa statistics app
·     display posa statistics nii
·     display posa statistics terminal
·     trade-exchanges
snmp-agent trap enable posa命令用来开启POS终端接入的告警功能。
undo snmp-agent trap enable posa命令用来关闭指定的POS终端接入的告警功能。
snmp-agent trap enable posa [ app-state-change | e1-dial-falling | fcm-connection-exceed | fcm-link-failure | fcm-physical-failure | fcm-trade-abnomal | server-state-change | tcp-connection-exceed | tcp-trade-exceed | terminal-hangup | trade-success-falling ] *
undo snmp-agent trap enable posa [ app-state-change | e1-dial-falling | fcm-connection-exceed | fcm-link-failure | fcm-trade-abnomal | fcm-physical-failure | server-state-change | tcp-connection-exceed | tcp-trade-exceed | terminal-hangup | trade-success-falling ] *
所有POS终端接入告警功能均处于开启状态。
app-state-change:表示POS应用模板状态切换的告警信息。
e1-dial-falling:表示E1POS接口拨号接通率低于阈值的告警信息。
fcm-connection-exceed:表示FCM拨号接入方式并发连接数超过阈值的告警信息。
fcm-link-failure:表示FCM链路层协商失败的告警信息。
fcm-physical-failure:表示FCM物理层协商失败的告警信息。
fcm-trade-abnormal:表示FCM接口异常交易的告警信息,当FCM接口下交易报文未成对出现时触发此告警。
server-state-change:表示POS接入服务状态切换的告警信息。
tcp-connection-exceed:表示TCP接入方式并发连接数超过阈值的告警信息。
tcp-trade-exceed:表示TCP连接的并发交易数超过上限的告警信息。
terminal-hangup:表示终端自动挂机的告警信息。
trade-success-falling:表示基于NII的报文交易成功率低于阈值的告警信息。
开启POS终端接入模块告警功能后,系统触发相应事件后会生成指定类型的告警信息。通过设置SNMP中告警信息的发送参数,来决定告警信息输出的相关属性。有关告警信息的详细介绍,请参见“网络管理和监控配置指导”中的“SNMP”。
不指定可选参数时,表示开启/关闭所有类型的告警功能。
# 关闭FCM物理层协商失败的POS终端接入告警功能。
[Sysname] undo snmp-agent trap enable posa fcm-physical-failure
·     posa connection-threshold
·     posa trade-limit tcp
1.1.54  source ip
source ip命令用来配置绑定TCP连接的源地址。
undo source ip命令用来恢复缺省情况。
source ip ip-address
undo source ip
未配置绑定TCP连接的源地址。
POS应用模板视图
ip-address:与TCP连接绑定的IP地址。该IP地址必须与前置机之间路由可达,且为非环回的单播IPv4地址。
对于TCP方式连接的POS应用模板,缺省情况下设备以POS应用模板接入的接口的IP地址作为源IP地址向前置机发起TCP连接。这样会暴露设备上POS应用模板接入的接口的真实IP地址,为了满足一定的安全需求,可以通过在POS应用模板上配置源地址绑定功能,指定一个特殊的IP地址作为向前置机发起TCP连接的源IP。
修改绑定TCP连接的源地址会导致该模板下已经建立的TCP连接被删除。
# 配置POS应用模板1的源地址为1.1.1.1,删除现有的长连接。
[Sysname-posa-app1] source ip 1.1.1.1
1.1.55  source port
source port命令用来配置绑定TCP连接的源端口号,即与前置机建立TCP连接时,只能使用指定的源端口号。
undo source port命令用来恢复缺省情况。
source port port-number
undo source port
未绑定源端口号,与前置机建立TCP连接时将使用系统随机分配的一个未被占用的端口号。
POS应用模板视图
port-number:与TCP连接绑定的源端口号,取值范围为4000~4999。
有些前置机要求设备必须以一个特定的源端口发起TCP连接,可通过本命令指定一个特殊的端口号作为向前置机发起TCP连接的源端口号。
短连接模式下,也支持配置绑定TCP连接的源端口号,但此时,此APP最多创建一条与前置机的连接,所以使用该APP并发的交易会失败。
修改绑定TCP连接的源端口号会删除该模板下已经建立的TCP连接。
指定的源端口不能和终端的监听端口重复,不能和其它应用绑定的源端口重复。若指定源端口与系统其它进程端口重复,可配置,但该应用不生效,通过display posa status可看到当前系统已经占用的TCP端口。
# 配置TCP类型的POS应用模板1的源端口号为4001,删除已经存在的连接。
[Sysname-posa-app1] source port 4001
tcp keepalive命令用来设置发送TCP协议栈keepalive报文的相关参数。
undo tcp keepalive命令用来恢复缺省情况。
tcp keepalive interval interval count counts
undo tcp keepalive
发送TCP keepalive报文的周期为2秒,当连续发送3次TCP keepalive报文没有得到回应时设备断开与该POS应用模板对应的银行前置机的TCP连接。
POS应用模板视图
interval interval:表示keepalive报文发送时间间隔,取值范围为1~7200,单位为秒。
count counts:表示keepalive报文发送次数,取值范围为2~100。
修改后参数会立刻生效。
超时时间为keeplive报文发送间隔乘以keeplive报文发送次数。当报文在超时后没有得到回应,设备断开与该POS应用模板的TCP连接。
# 配置TCP类型的POS应用模板1的keepalive报文发送间隔为100秒,发送次数为4次。
[Sysname-posa-app1] tcp keepalive interval 100 count 4
tcp linking-time命令用来设置向前置机发起TCP连接请求的超时时间,即该POS应用模板的连接发起时处于Linking状态的最大时间。
undo tcp linking-time命令用来恢复缺省情况。
tcp linking-time time
允许向前置机发起TCP连接的超时时间为20秒。
POS应用模板视图
time:允许POS应用模板处于Linking状态的最大时间,取值范围为1~20,单位为秒。
设备向前置机发起TCP连接的时间若超过设置的最大值,则取消此次TCP连接请求,此次交易失败。该配置同样用于设备等待银行前置机应答AM POS机的主叫号码协商报文。
修改后的配置仅对新发起的TCP连接生效。
# 配置POS应用模板1的TCP连接状态时间为10秒。
[Sysname-posa-app1] tcp linking-time 10
terminal-ip append命令用来开启主叫IP地址发送功能,即发送给前置机的报文中包含有POS机的主叫IP地址。
undo terminal-ip append命令用来关闭主叫IP地址发送功能。
terminal-ip append
型号
MSR610
不支持
不支持
不支持
不支持
不支持
不支持
不支持
不支持
MSR2600-10-X1
不支持
MSR2630-G-X1
支持
MSR 2630
支持
支持
不支持
支持
支持
支持
不支持
MSR-iMC
不支持
支持
不支持
MSR3610-G、MSR3620-G
支持
MSR3640-G
支持
MSR3640-X1-HI
支持
型号
不支持
MSR830-4LM-WiNet
不支持
不支持
不支持
MSR2600-6-WiNet
不支持
MSR2600-10-X1-WiNet
不支持
MSR2630-WiNet
支持
MSR3600-28-WiNet
支持
MSR3610-X1-WiNet
支持
MSR3620-X1-WiNet
支持
不支持
型号
MSR860-6EI-XS
不支持
MSR860-6HI-XS
不支持
MSR2630-XS
不支持
MSR3600-28-XS
支持
MSR3610-XS
支持
MSR3620-XS
不支持
MSR3610-I-XS
不支持
MSR3610-IE-XS
不支持
MSR3620-X1-XS
支持
MSR3640-XS
支持
MSR3660-XS
支持
型号
MSR810-LM-GL
不支持
MSR810-W-LM-GL
不支持
MSR830-6EI-GL
不支持
MSR830-10EI-GL
不支持
MSR830-6HI-GL
不支持
MSR830-10HI-GL
不支持
MSR1004S-5G-GL
不支持
MSR2600-6-X1-GL
不支持
MSR3600-28-SI-GL
不支持
主叫IP地址发送功能处于关闭状态。
POS应用模板视图
使用主叫IP地址发送功能时,需要注意的是:
·     仅当POS终端的接入方式为终端TCP接入时支持此功能。
·     仅当前置机支持主叫IP地址显示功能的情况下,才需要在POS终端接入设备上使能主叫IP地址发送功能。
·     在级联连接方式下使用发送主叫IP地址功能时,需要在与前置机相连的路由器上开启该功能,在中继路由器上不需要开启。
# 开启POS应用模板1的主叫IP地址发送功能。
[Sysname-posa-app1] terminal-ip append
threshold answer-tone命令用来设置Modem发送应答音能量增益。
undo threshold answer-tone命令用来恢复缺省情况。
threshold answer-tone answertonetime
使用E1POS接口模块时,Modem发送应答音的能量增益缺省值为18-dBm。使用FCM接口模块时,Modem发送应答音的能量增益缺省值为9-dBm。
FCM接口视图
answertometime:Modem发送应答音的能量增益,取值范围是1~42,单位为-dBm。
# 设置FCM2/1/0下Modem发送应答音能量增益为-41dBm。
[Sysname] interface fcm 2/1/0
[Sysname–Fcm2/1/0] threshold answer-tone 41
threshold rlsdoff命令用来设置Modem协商的接收信号门限值下限。
undo threshold rlsdoff命令用来恢复缺省情况。
threshold rlsdoff rlsdofftime
Modem协商的接收信号门限值下限值为-48dBm。
FCM接口视图
rlsdofftime:Modem接收信号门限值下限,取值范围是0~75,单位为-dBm。
# 设置FCM2/1/0接口下Modem协商的接收信号门限值下限为-74dBm。
[Sysname–Fcm2/1/0] threshold rlsdoff 74
threshold rlsdon命令用来设置Modem协商的接收信号门限值上限。
undo threshold rlsdon命令用来恢复缺省情况。
threshold rlsdon rlsdontime
Modem协商的接收信号门限值上限值为-43dBm。
FCM接口视图
rlsdontime:Modem接收信号门限值上限,取值范围是0~75,单位为-dBm。
# 设置FCM2/1/0协商的接收信号门限值上限为-73dBm。
[Sysname–Fcm2/1/0] threshold rlsdon 73
threshold txpower命令用来设置Modem协商的发送能量增益的大小。
undo threshold txpower命令用来恢复缺省情况。
threshold txpower txpowertime
对于物理FCM接口,Modem协商的发送能量增益值为-10dBm;
对于通道化FCM接口,Modem协商的发送能量增益值为-18dBm。
FCM接口视图
txpowertime:Modem信号发送的能量增益,取值范围是1~42,单位为-dBm。
# 设置FCM2/1/0协商的发送能量增益的大小为-40dBm。
[Sysname–Fcm2/1/0] threshold txpower 40
timer auto-connect命令用来设置POS应用模板自动建立连接的时间间隔。
undo timer auto-connect命令用来恢复缺省情况。
timer auto-connect interval
POS应用模板自动建立连接的时间间隔为10分钟。
POS应用模板视图
interval:长连接模式的POS应用模板自动建立连接的时间间隔,取值范围为1~1440,单位为分钟。
只有长连接模式的TCP类型的POS应用模板才支持该配置。
配置该命令后,当POS应用模板与前置机之间没有建立可复用的长连接前,设备会以interval为时间间隔,周期性地向前置机主动发起连接。
# 设置自动建立连接的时间间隔为1分钟。
[Sysname-posa-app1] timer auto-connect 1
·     auto-connect enable
1.1.64  timer hello
timer hello用来设置POS应用模板发送握手报文的间隔时间。
undo timer hello命令用来恢复缺省情况。
timer hello interval
undo timer hello
POS应用模板发送握手报文间隔为1分钟。
POS应用模板视图
interval:POS应用模板发送握手报文的时间间隔,取值范围为1~600,单位为分钟。
当开启POS应用模板握手功能时,设备以interval为时间间隔周期性地向前置机发送握手报文。
# 设置POS应用模板发送握手报文的时间间隔为10分钟。
[Sysname-posa-app1] timer hello 10
·     hello enable
1.1.65  timer quiet
timer quiet用来设置POS应用模板的静默时间。
undo timer quiet命令用来恢复缺省情况。
timer quiet interval
undo timer quiet
POS应用模板的静默时间为600分钟。
POS应用模板视图
interval:POS应用模板的静默时间,范围为10~600,单位为分钟。
对于TCP类型的前置机,当POS机发起交易时,若设备尝试连接的前置机无响应,则将此前置机设置为Blocked状态,并开启静默定时器,在此期间,此前置机保持Blocked状态。
修改后的配置会立即生效,对已经处于静默状态的前置机重新计时。
#设置POS应用模板的静默时间为500分钟。
[Sysname-posa-app1] timer quiet 500
·     backup app
1.1.66  tpdu-change
tpdu-change命令用来配置TPDU地址的更改策略,即设备向该POS应用模板对应的前置机转发终端报文时,对报文TPDU地址的更改策略。
undo tpdu-change命令用来恢复缺省情况。
tpdu-change { destination | source }
undo tpdu-change
仅允许修改TPDU源地址。
POS应用模板视图
destination:修改转发给前置机的终端报文的TPDU目的地址。
source:修改转发给前置机的终端报文的TPDU源地址。
不同的前置机对可更改的TPDU地址字段的要求不同,要么仅允许更改TPDU源地址,要么仅允许更改TPDU目的地,因此需要根据前置机的要求来配置设备对于TPDU地址的更改策略。
对于非透传长连接,修改地址更改策略会删除该POS应用模板下的所有连接。
# 指定向POS应用模板1对应的前置机转发终端报文时,修改其TPDU目的地址,应用模板1为非透传长连接。
[Sysname-posa-app1] tpdu-change destination
trade-exchanges命令用来配置单次交易交互报文次数。
undo trade-exchanges命令用来恢复缺省情况。
trade-exchanges counts
单次交易交互报文次数为1。
POS应用模板视图
counts:单次交易成功的报文交互次数,取值范围为1~16。
可以根据业务需求配置单次交易交互报文次数来确定NII交易成功的判定标准,当交互报文成对出现时,并且前置机和POS接入设备之间报文交互次数大于等于设置的单次交易交互报文的次数时,表示交易成功。
# 设置单次交易成功的报文交互次数为5。
[Sysname-posa-app1] trade-exchanges 5
