14-IPv6 PIM命令
本章节下载: 14-IPv6 PIM命令 (617.13 KB)
1.1.1 anycast-rp (IPv6 PIM view)
1.1.2 bidir-pim enable (IPv6 PIM view)
1.1.3 bidir-rp-limit (IPv6 PIM view)
1.1.4 bsm-fragment enable (IPv6 PIM view)
1.1.5 bsm-reflection enable (IPv6 PIM view)
1.1.6 bsr-policy (IPv6 PIM view)
1.1.7 bsr-rp-mapping rfc2362 (IPv6 PIM view)
1.1.9 c-bsr holdtime (IPv6 PIM view)
1.1.10 c-bsr interval (IPv6 PIM view)
1.1.12 crp-policy (IPv6 PIM view)
1.1.13 display ipv6 pim bsr-info
1.1.14 display ipv6 pim claimed-route
1.1.16 display ipv6 pim df-info
1.1.17 display ipv6 pim interface
1.1.18 display ipv6 pim neighbor
1.1.19 display ipv6 pim routing-table
1.1.20 display ipv6 pim rp-info
1.1.21 display ipv6 pim statistics
1.1.24 hello-option dr-priority (IPv6 PIM view)
1.1.25 hello-option holdtime (IPv6 PIM view)
1.1.26 hello-option lan-delay (IPv6 PIM view)
1.1.27 hello-option neighbor-tracking (IPv6 PIM view)
1.1.28 hello-option override-interval (IPv6 PIM view)
1.1.29 holdtime join-prune (IPv6 PIM view)
1.1.33 ipv6 pim distributed-dr
1.1.35 ipv6 pim hello-option dr-priority
1.1.36 ipv6 pim hello-option holdtime
1.1.37 ipv6 pim hello-option lan-delay
1.1.38 ipv6 pim hello-option neighbor-tracking
1.1.39 ipv6 pim hello-option override-interval
1.1.40 ipv6 pim holdtime join-prune
1.1.44 ipv6 pim neighbor-policy
1.1.45 ipv6 pim non-stop-routing
1.1.49 ipv6 pim state-refresh-capable
1.1.50 ipv6 pim timer dr-elect-delay
1.1.51 ipv6 pim timer graft-retry
1.1.53 ipv6 pim timer join-prune
1.1.54 ipv6 pim triggered-hello-delay
1.1.55 ipv6 pim triggered-hello enable
1.1.56 jp-pkt-size (IPv6 PIM view)
1.1.57 register-policy (IPv6 PIM view)
1.1.58 register-suppression-timeout (IPv6 PIM view)
1.1.59 register-whole-checksum (IPv6 PIM view)
1.1.60 snmp-agent trap enable pim6
1.1.61 source-lifetime (IPv6 PIM view)
1.1.62 source-policy (IPv6 PIM view)
1.1.63 spt-switch-threshold (IPv6 PIM view)
1.1.64 ssm-policy (IPv6 PIM view)
1.1.65 state-refresh-hoplimit (IPv6 PIM view)
1.1.66 state-refresh-interval (IPv6 PIM view)
1.1.67 state-refresh-rate-limit (IPv6 PIM view)
1.1.68 static-rp (IPv6 PIM view)
1.1.69 timer hello (IPv6 PIM view)
1.1.70 timer join-prune (IPv6 PIM view)
anycast-rp命令用来配置Anycast-RP。
undo anycast-rp命令用来删除Anycast-RP。
anycast-rp ipv6-anycast-rp-address ipv6-member-address
undo anycast-rp ipv6-anycast-rp-address ipv6-member-address
不存在Anycast-RP。
IPv6 PIM视图
ipv6-anycast-rp-address:指定Anycast-RP地址。必须是合法的IPv6全球单播地址。
ipv6-member-address:指定Anycast-RP成员地址。必须是合法的IPv6全球单播地址。
处于同一个Anycast-RP集中的成员设备上,都必须存在相同的IPv6地址(LoopBack接口地址),并将该IPv6地址同时配置为Anycast-RP和C-RP。
多次执行本命令,可配置多个Anycast-RP。如果配置时指定了相同的Anycast-RP地址,则将Anycast-RP成员地址添加到该Anycast-RP地址所属的Anycast-RP集中。
Anycast-RP成员地址不能与Anycast-RP地址相同。
# 在公网实例中配置如下Anycast-RP集:Anycast-RP地址为1:1::0,两个成员的地址分别为1:1::1和1:2::1(前者为本地接口LoopBack1的地址)。
[Sysname] ipv6 pim
[Sysname-pim6] c-rp 1:1::0
[Sysname-pim6] anycast-rp 1:1::0 1:1::1
[Sysname-pim6] anycast-rp 1:1::0 1:2::1
· display ipv6 pim rp-info
bidir-pim enable命令用来使能IPv6双向PIM。
undo bidir-pim enable命令用来关闭IPv6双向PIM。
bidir-pim enable
IPv6双向PIM处于关闭状态。
IPv6 PIM视图
只有在相应实例中先使能了IPv6组播路由,本命令才能生效。
# 使能公网实例中的IPv6组播路由,并使能IPv6双向PIM。
[Sysname] ipv6 multicast routing
[Sysname-mrib6] quit
[Sysname] ipv6 pim
[Sysname-pim6] bidir-pim enable
· ipv6 multicast routing(IP组播命令参考/IPv6组播路由与转发)
bidir-rp-limit命令用来配置IPv6双向PIM RP的最大数目。
undo bidir-rp-limit命令用来恢复缺省情况。
bidir-rp-limit limit
undo bidir-rp-limit
IPv6双向PIM RP的最大数目为6。
IPv6 PIM视图
limit:指定IPv6双向PIM RP的最大数目,取值范围为1~32。
由于IPv6双向PIM为每个RP都要在所有IPv6 PIM接口上进行DF选举,因此实际组网中不建议配置多个IPv6双向PIM RP。通过本命令可以限制IPv6双向PIM RP的数目,超出限制值的RP不会生效,仅能进行DF选举而无法指导转发。
# 在公网实例中配置IPv6双向PIM RP的最大数目为3。
[Sysname] ipv6 pim
[Sysname-pim6] bidir-rp-limit 3
bsm-fragment enable命令用来开启自举报文语义分片功能。
undo bsm-fragment enable命令用来关闭自举报文语义分片功能。
bsm-fragment enable
自举报文语义分片功能处于开启状态。
IPv6 PIM视图
当IPv6 PIM-SM域或双向PIM域中存在不支持自举报文语义分片的设备时,请关闭本功能。
# 在公网实例中关闭自举报文语义分片功能。
[Sysname] ipv6 pim
[Sysname-pim6] undo bsm-fragment enable
bsm-reflection enable命令用来开启自举报文往报文入接口方向转发功能。
undo bsm-reflection enable命令用来关闭自举报文往报文入接口方向转发功能。
自举报文往报文入接口方向转发功能处于开启状态。
IPv6 PIM视图
当IPv6 PIM-SM或IPv6双向PIM域中不需要自举报文往报文入接口方向转发时,请关闭本功能。
# 在公网实例中关闭自举报文往报文入接口方向转发功能。
[Sysname] ipv6 pim
[Sysname-pim6] undo bsm-reflection enable
bsr-policy命令用来配置合法的BSR地址范围。
undo bsr-policy命令用来恢复缺省情况。
bsr-policy ipv6-acl-number
undo bsr-policy
BSR的地址范围不受限制,即认为来自任意源的自举报文都是合法的。
IPv6 PIM视图
ipv6-acl-number:指定IPv6基本ACL的编号,取值范围为2000~2999。
配置合法的BSR地址范围可以防止BSR欺骗。
该ACL规则中的source参数用来指定合法BSR的源地址范围,并且该规则中除source、fragment和time-range以外的其它可选参数都将被忽略。
在引用的ACL中,若某规则指定了vpn-instance参数,则该规则将不生效。
多次执行本命令,最后一次执行的命令生效。
# 在公网实例中配置合法的BSR地址范围,只允许网段2001::2/64中的设备充当BSR。
[Sysname] acl ipv6 basic 2000
[Sysname-acl-ipv6-basic-2000] rule permit source 2001::2 64
[Sysname] ipv6 pim
[Sysname-pim6] bsr-policy 2000
· c-bsr (IPv6 PIM view)
bsr-rp-mapping rfc2362命令用来配置RP映射采用RFC 2362中规定的哈希算法。
undo bsr-rp-mapping rfc2362命令用来恢复缺省情况。
RP映射采用RFC 4601中规定的哈希算法。
IPv6 PIM视图
为了确保本网络内各路由器上RP映射信息一致,请在所有路由器上配置相同的RP映射哈希算法。
# 在公网实例中RP映射采用RFC 2362中规定的哈希算法。
[Sysname] ipv6 pim
[Sysname-pim6] bsr-rp-mapping rfc2362
c-bsr命令用来配置C-BSR。
undo c-bsr命令用来删除C-BSR的相关配置。
c-bsr ipv6-address [ scope scope-id ] [ hash-length hash-length | priority priority ] *
undo c-bsr ipv6-address [ scope scope-id ]
不存在C-BSR。
IPv6 PIM视图
ipv6-address:指定C-BSR的IPv6地址,C-BSR的IPv6地址必须是本地接口的IPv6地址,且该接口上必须使能IPv6 PIM,否则配置不会生效。
scope scope-id:指定IPv6管理域的编号,取值范围为3~15。如果未指定本参数,表示配置服务于Global域的C-BSR。
hash-length hash-length:指定哈希掩码长度,取值范围为0~128,缺省值为126。
priority priority:指定C-BSR的优先级,取值范围为0~255,缺省值为64。数值越大,优先级越高。
如果对同一个域多次执行本命令,最后一次执行的命令生效;而针对不同域的C-BSR则允许指定相同的IPv6地址。
# 在公网实例中将IPv6地址为1101::1的设备配置为Global域的C-BSR。
[Sysname] ipv6 pim
[Sysname-pim6] c-bsr 1101::1
c-bsr holdtime命令用来配置C-BSR等待接收来自BSR的自举报文的超时时间。
undo c-bsr holdtime命令用来恢复缺省情况。
c-bsr holdtime hold-time
undo c-bsr holdtime
C-BSR等待接收来自BSR的自举报文超时时间为130秒。
IPv6 PIM视图
hold-time:C-BSR等待接收来自BSR的自举报文的超时时间(自举超时时间),取值范围为1~2147483647,单位为秒。
C-BSR一旦通过自举机制竞选为BSR后,其他C-BSR会在等待接收来自BSR的自举报文的超时时间内,停止向其所服务的区域内的其他设备发送自举报文,BSR选举过程暂停。当自举超时时间超时后,所有的C-BSR之间会互相发送自举报文,触发新一轮的BSR选举过程。
配置自举报文的超时时间(holdtime)和自举报文发送时间间隔(interval)时,需要注意:
· 如果同时配置了interval和holdtime,请保证interval小于holdtime,否则将导致频繁触发BSR选举过程。
· 如果只配置了其中之一,那么另一个取值可由以下公式计算得出:interval=(holdtime-10)÷2。
· 只配置了holdtime时,若根据公式计算得出的interval小于interval取值范围的最小值(1秒),interval的取值为1秒。
· 只配置了interval时,若根据公式计算得出的holdtime大于holdtime取值范围的最大值(2147483647秒),则holdtime取值为2147483647秒。
· 属于同一个IPv6 PIM域的所有C-BSR必须配置相同的interval和holdtime。如果配置值不同,则可能导致BSR选举不稳定,从而引发组播流量转发故障。
# 在公网实例中,配置自举超时时间为150秒。
[Sysname] ipv6 pim
[Sysname-pim6] c-bsr holdtime 150
# 在VPN实例mvpn中,配置自举超时时间为150秒。
[Sysname] ipv6 pim vpn-instance mvpn
[Sysname-pim6-mvpn] c-bsr holdtime 150
· c-bsr interval (IPv6 PIM view)
c-bsr interval命令用来配置C-BSR发送自举报文的时间间隔。
undo c-bsr interval命令用来恢复缺省情况。
c-bsr interval interval
undo c-bsr interval
C-BSR发送自举报文的时间间隔为60秒。
IPv6 PIM视图
interval:C-BSR发送自举报文的时间间隔,取值范围为1~1073741818,单位为秒。
C-BSR一旦通过自举机制竞选为BSR后,其他C-BSR会在等待接收来自BSR的自举报文的超时时间(holdtime,可通过c-bsr holdtime命令进行配置)内,停止向其所服务的区域内的其他设备发送自举报文,BSR选举过程暂停。之后,将由BSR会周期性地(发送的周期通过本命令配置)向其所服务的区域内的其他设备发送携带自己的IP地址、RP-Set信息和RP实际老化时间的自举报文,其他设备根据RP-Set信息计算出特定组播组范围所对应的RP。当自举超时时间超时后,所有的C-BSR之间会互相发送自举报文,触发新一轮的BSR选举过程。
在存在主备RP的IPv6双向PIM组网中,当主RP所在的组播流量转发链路发生故障时,备RP必须要等待主RP老化后才能将组播流量切换到备RP,导致组播流量转发中断时间较长。由于RP老化时间必须大于自举报文的发送时间间隔,因此,若要缩小RP老化时间,需要先通过本命令调小自举报文的发送时间间隔。
配置interval和holdtime时,请注意:
· 只配置了holdtime时,若根据公式计算得出的interval小于interval取值范围的最小值(1秒),则interval取值为1秒;
· 属于同一个IPv6 PIM域的所有C-BSR必须配置相同的interval和holdtime。如果配置值不同,有可能导致BSR选举不稳定,从而引发组播流量转发故障。
# 在公网实例中,配置C-BSR发送自举报文的时间间隔为30秒。
[Sysname] ipv6 pim
[Sysname-pim6] c-bsr interval 30
# 在VPN实例mvpn中,配置C-BSR发送自举报文的时间间隔为30秒。
[Sysname-pim6-mvpn] c-bsr interval 30
· c-bsr holdtime (IPv6 PIM view)
c-rp命令用来配置C-RP。
undo c-rp命令用来删除C-RP的相关配置。
c-rp ipv6-address [ advertisement-interval adv-interval | { group-policy { ipv6-acl-number | name ipv6-acl-name } | scope scope-id } | holdtime hold-time | priority priority ] * [ bidir ]
undo c-rp ipv6-address
不存在C-RP。
IPv6 PIM视图
ipv6-address:指定C-RP的IPv6地址,C-RP的IPv6地址必须有对应的本地接口,且该接口上必须使能IPv6 PIM,否则配置不会生效。
advertisement-interval adv-interval:指定发送宣告报文的间隔时间,取值范围为1~65535,单位为秒,缺省值为60。
group-policy:指定C-RP服务IPv6组播组的策略。如果未指定本参数,C-RP将为所有IPv6组播组服务。如果未指定本参数、指定的ACL名称不存在或ACL中未配置有效规则,则该C-RP将为所有IPv6组播组服务。其中:
· ipv6-acl-number:指定IPv6基本或高级ACL的编号,取值范围为2000~3999。如果指定了本参数,该C-RP将只为ACL规则所允许的IPv6组播组服务。
· name ipv6-acl-name:指定IPv6基本或高级ACL的名称,为1~63个字符的字符串,不区分大小写,必须以英文字母a~z或A~Z开头。为避免混淆,ACL的名称不允许使用英文单词all。如果指定了本参数,该C-RP将只为ACL规则所允许的IPv6组播组服务。
holdtime hold-time:指定C-RP的超时时间,取值范围为1~65535,单位为秒,缺省值为150。
priority priority:指定C-RP的优先级,取值范围为0~255,缺省值为192。该数值越大,优先级越低。
bidir:指定该C-RP服务于IPv6双向PIM。如果未指定本参数,该C-RP将服务于IPv6 PIM-SM。
如果设备想要成为多个组范围的C-RP,则需要在配置group-policy所对应的ACL时将多个组范围用多个rule规则表示出来。
本命令通过ACL规则中的source参数指定C-RP所服务的IPv6组播组范围(若指定的不是IPv6组播组地址,则此规则不生效),而其它可选参数都将被忽略。该ACL规则用来定义该C-RP所服务的IPv6组播组范围,只有permit的IPv6组播组才会作为RP的服务组范围通告出去。
如果对同一IPv6地址多次执行本命令,最后一次执行的命令生效。
# 在公网实例中将IPv6地址为2001::1配置为组播组FF0E:0:1391::/96的C-RP,且C-RP的优先级为10。
[Sysname-acl-ipv6-basic-2000] rule permit source ff0e:0:1391:: 96
[Sysname] ipv6 pim
[Sysname-pim6] c-rp 2001::1 group-policy 2000 priority 10
crp-policy命令用来配置合法的C-RP地址范围及其服务的IPv6组播组范围。
undo crp-policy命令用来恢复缺省情况。
crp-policy ipv6-acl-number
undo crp-policy
C-RP地址范围及其服务的IPv6组播组范围不受限制,即认为所有收到的C-RP报文都是合法的。
IPv6 PIM视图
ipv6-acl-number:指定IPv6高级ACL的编号,取值范围为3000~3999。
配置合法的C-RP地址范围及其服务的IPv6组播组范围可以防止C-RP欺骗。
本命令在对C-RP所宣告的IPv6组播组范围进行过滤时,只取其前缀部分进行匹配。例如,C-RP宣告的IPv6组播组范围为FF0E:0:1::/96,如果其前缀部分“FF0E:0:1::”能匹配上本命令所引用的ACL规则,就认为整个IPv6组播组范围“FF0E:0:1::/96”都通过了过滤。
该ACL规则中的source参数用来指定合法C-RP所服务的IPv6地址范围,destination参数用来指定该C-RP所服务的IPv6组播组地址范围,并且该规则中除source、destination、fragment和time-range以外的其它可选参数都将被忽略。
# 在公网实例中配置C-RP策略,只允许2001::2/64范围内的设备充当C-RP,且只允许其为FF03::101/64范围内的IPv6组播组服务。
[Sysname-acl-ipv6-adv-3000] rule permit ipv6 source 2001::2 64 destination ff03::101 64
[Sysname-acl-ipv6-adv-3000] quit
[Sysname] ipv6 pim
[Sysname-pim6] crp-policy 3000
· c-rp (IPv6 PIM view)
display ipv6 pim bsr-info命令用来显示IPv6 PIM-SM域中的BSR信息。
display ipv6 pim [ vpn-instance vpn-instance-name ] bsr-info
vpn-instance vpn-instance-name:显示指定VPN实例的BSR信息,vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。如果未指定本参数,将显示公网实例的BSR信息。
# 显示公网实例IPv6 PIM-SM域中的BSR信息。
<Sysname> display ipv6 pim bsr-info
Scope: non-scoped
State: Accept Preferred
Bootstrap timer: 00:01:44
Elected BSR address: 12:12::1
Priority: 64
Hash mask length: 126
Uptime: 00:21:56
Scope: 5
State: Accept Any
Scope-zone expiry timer: 00:21:12
Scope: 6
State: Elected
Bootstrap timer: 00:00:26
Elected BSR address: 17:11::1
Priority: 64
Uptime: 02:53:37
Candidate BSR address: 17:11::1
Priority: 64
Scope: 7
State: Candidate
Bootstrap timer: 00:01:56
Elected BSR address: 61:37::1
Priority: 64
Uptime: 02:53:32
Candidate BSR address: 17:12::1
Priority: 64
Scope: 8
State: Pending
Bootstrap timer: 00:00:07
Candidate BSR address: 17:13::1
Priority: 64
表1-1 display ipv6 pim bsr-info命令显示信息描述表
Scope |
域 |
State |
域状态 |
Bootstrap timer |
BSR定时器 |
Scope-zone expiry timer |
域老化定时器 |
Elected BSR address |
当选BSR的地址 |
Candidate BSR address |
候选BSR的地址 |
Priority |
BSR的优先级 |
Hash mask length |
哈希掩码长度 |
Uptime |
BSR已存在的时间 |
display ipv6 pim claimed-route命令用来显示IPv6 PIM所使用的路由信息。
display ipv6 pim [ vpn-instance vpn-instance-name ] claimed-route [ ipv6-source-address ]
vpn-instance vpn-instance-name:显示指定VPN实例的路由信息,vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。如果未指定本参数,将显示公网实例的路由信息。
ipv6-source-address:组播源的IPv6地址,显示到达指定组播源的路由信息。如果未指定本参数,将显示IPv6 PIM所使用的所有路由信息。
# 显示IPv6 PIM在公网实例中使用的所有路由信息。
<Sysname> display ipv6 pim claimed-route
RPF-route selecting rule: longest-match
Route/mask: 7:11::/64 (unicast (direct))
RPF interface: Vlan-interface2, RPF neighbor: 8::2
Total number of (S,G) or (*,G) dependent on this route entry: 4
(7:11::10, ff1e::1)
(7:11::10, ff1e::2)
(7:11::10, ff1e::3)
(*, ff1e::4)
Route/mask: 7:12::/64 (unicast)
RPF interface: Vlan-interface2, RPF neighbor: 8::3,
Total number of (S,G) or (*,G) dependent on this route entry: 2
(7:12::10, ff1e::1)
(7:12::10, ff1e::2)
表1-2 display ipv6 pim claimed-route命令显示信息描述表
RPF-route selecting rule |
RPF路由的选择规则 |
Route/mask |
路由项。括号内为路由类型,包括: · igp:单播路由(内部网关协议) · egp:单播路由(外部网关协议) · unicast (direct):单播路由(直连) · unicast:其它单播路由(如单播静态路由等) · mbgp:IPv6 MBGP路由 |
RPF interface |
RPF接口的名称 |
RPF neighbor |
RPF邻居的IPv6地址 |
Total number of (S,G) or (*,G) dependent on this route entry |
基于此RPF路由的(S,G)或(*,G)个数及列表 |
display ipv6 pim c-rp命令用来显示IPv6 PIM-SM域中的C-RP信息。
display ipv6 pim [ vpn-instance vpn-instance-name ] c-rp [ local ]
vpn-instance vpn-instance-name:显示指定VPN实例的C-RP信息,vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。如果未指定本参数,将显示公网实例的C-RP信息。
local:显示本地配置且生效的C-RP信息。如果未指定本参数,将显示所有学习到的C-RP信息。
只有当选的BSR上才会有学习到的C-RP信息,其它设备上只能查看到本地配置生效的C-RP信息。
# 显示公网实例中学习到的C-RP信息。
<Sysname> display ipv6 pim c-rp
Scope: non-scoped
Group/MaskLen: FF00::/8 [B]
C-RP address Priority HoldTime Uptime Expires
8:12::2 (local) 192 150 00:27:48 00:01:43
Group/MaskLen: FF23::/92 Expires: 00:02:07
# 显示本地配置生效的C-RP信息。
<Sysname> display ipv6 pim c-rp local
Candidate RP: 8:12::2(Loop1)
Priority: 192
HoldTime: 150
Advertisement interval: 60
Next advertisement scheduled at: 00:00:46
表1-3 display ipv6 pim c-rp命令显示信息描述表
Scope |
域 |
Group/MaskLen |
C-RP所服务的IPv6组播组 |
[B] |
表示C-RP服务于IPv6双向PIM。如果未显示本字段,则表示服务于IPv6 PIM-SM |
C-RP address |
C-RP的IPv6地址,local表示本地地址 |
Priority |
C-RP的优先级 |
HoldTime |
C-RP的超时时间 |
Uptime |
C-RP已存在的时间,w表示星期,d表示天,h表示小时 |
Expires |
C-RP/组播组的超时剩余时间 |
Candidate RP |
本地C-RP的IPv6地址 |
Advertisement interval |
本地C-RP发送通告报文时间间隔 |
Next advertisement scheduled at |
本地C-RP发送下一个通告报文的剩余时间 |
display ipv6 pim df-info命令用来显示IPv6双向PIM的DF信息。
display ipv6 pim [ vpn-instance vpn-instance-name ] df-info [ ipv6-rp-address ]
vpn-instance vpn-instance-name:显示指定VPN实例的IPv6双向PIM DF信息,vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。如果未指定本参数,将显示公网实例的IPv6双向PIM DF信息。
ipv6-rp-address:指定IPv6双向PIM的RP地址。
# 显示公网实例中IPv6双向PIM的DF信息。
<Sysname> display ipv6 pim df-info
RP address: 12::12
Interface: Vlan-interface4
State : Win DF preference: 10
DF metric : 1562 DF uptime : 00:07:15
DF address: FE80::202:FF:FE00:9 (local)
Interface: Tunnel2, FE80::20:12
State : Lose DF preference: 0
DF metric : 0 DF uptime : 00:07:15
DF address: FE80::20:12
表1-4 表1-3 display ipv6 pim df-info命令显示信息描述表
RP address |
IPv6双向PIM的RP地址 |
接口名称 |
State |
DF的选举状态: · Win:竞选DF成功 · Lose:竞选DF落败 · Offer:竞选DF的初始状态 · Backoff:正在充当DF,但有更优的设备正在竞选DF · -:不参与DF竞选 |
DF preference |
DF通告的路由优先级 |
DF metric |
DF通告的路由度量值 |
DF uptime |
DF已存在的时间 |
DF address |
DF的IPv6地址,local表示本地地址 |
display ipv6 pim interface命令用来显示接口上的IPv6 PIM信息。
display ipv6 pim [ vpn-instance vpn-instance-name ] interface [ interface-type interface-number ] [ verbose ]
vpn-instance vpn-instance-name:显示指定VPN实例的IPv6 PIM信息,vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。如果未指定本参数,将显示公网实例的IPv6 PIM信息。
interface-type interface-number:显示指定接口上的IPv6 PIM信息。如果未指定本参数,将显示所有接口上的IPv6 PIM信息。
# 显示公网实例所有接口上的IPv6 PIM概要信息。
<Sysname> display ipv6 pim interface
Interface: Vlan1
NbrCnt: 1
HelloInt: 30
DR priority: 1
DR address: FE80::200:5EFF:FE04:8700
表1-5 display ipv6 pim interface命令显示信息描述表
接口名称 |
NbrCnt |
IPv6 PIM邻居的数量 |
HelloInt |
发送Hello报文的时间间隔 |
DR priority |
竞选DR的优先级 |
DR address |
DR的IPv6地址(链路本地地址) |
# 显示公网实例接口Vlan-interface1上的IPv6 PIM详细信息。
<Sysname> display ipv6 pim interface vlan-interface 1 verbose
Interface: Vlan-interface1, FE80::200:5EFF:FE04:8700
PIM version: 2
PIM mode: Sparse
PIM DR: FE80::200:AFF:FE01:101
PIM DR Priority (configured): 1
PIM neighbors count: 1
PIM hello interval: 30 s
PIM LAN delay (negotiated): 500 ms
PIM LAN delay (configured): 500 ms
PIM override interval (negotiated): 2500 ms
PIM override interval (configured): 2500 ms
PIM neighbor tracking (negotiated): disabled
PIM neighbor tracking (configured): disabled
PIM generation ID: 0xF5712241
PIM require generation ID: disabled
PIM hello hold interval: 105 s
PIM assert hold interval: 180 s
PIM triggered hello delay: 5 s
PIM J/P interval: 60 s
PIM J/P hold interval: 210 s
PIM state-refresh capable (negotiated): enabled
PIM state-refresh capable (configured): enabled
PIM state-refresh interval: 60 s
PIM state-refresh rate limit: 30 s
PIM state-refresh hop limit: 255
PIM graft retry interval: 3 s
PIM BSR domain border: disabled
PIM BFD: disabled
PIM passive: disabled
PIM DR elect delay: 80 s
PIM DR remaining elect delay: 15 s
Number of routers on network not using DR priority: 0
Number of routers on network not using LAN delay: 0
Number of routers on network not using neighbor tracking: 2
表1-6 display ipv6 pim interface verbose命令显示信息描述表
接口名称与IPv6地址(链路本地地址) |
PIM version |
IPv6 PIM协议的版本号 |
PIM mode |
IPv6 PIM协议的模式,是密集模式还是稀疏模式 |
PIM DR |
DR的IPv6地址(链路本地地址) |
PIM DR Priority (configured) |
竞选DR优先级的配置值 |
PIM neighbors count |
IPv6 PIM邻居的总数 |
PIM hello interval |
发送Hello报文的时间间隔 |
PIM LAN delay (negotiated) |
剪枝报文传输延迟的协商值 |
PIM LAN delay (configured) |
剪枝报文传输延迟的配置值 |
PIM override interval (negotiated) |
剪枝否决时间的协商值 |
PIM override interval (configured) |
剪枝否决时间的配置值 |
PIM neighbor tracking (negotiated) |
邻居跟踪开启与否的协商情况 |
PIM neighbor tracking (configured) |
邻居跟踪开启与否的配置情况 |
PIM generation ID |
Generation_ID参数值 |
PIM require generation ID |
是否开启不接受无Generation ID的Hello报文 |
PIM hello hold interval |
保持IPv6 PIM邻居的可达状态的时间 |
PIM assert hold interval |
保持断言状态的时间 |
PIM triggered hello delay |
发送Hello报文的最大延迟时间 |
PIM J/P interval |
发送加入/剪枝报文的时间间隔 |
PIM J/P hold interval |
加入/剪枝状态的保持时间 |
PIM state-refresh capable (negotiated) |
状态刷新能力的协商值 |
PIM state-refresh capable (configured) |
状态刷新能力的配置值 |
PIM state-refresh interval |
发送状态刷新报文的时间间隔 |
PIM state-refresh rate limit |
接收新状态刷新报文的等待时间 |
PIM state-refresh hop limit |
接收新状态刷新报文的跳数限制 |
PIM graft retry interval |
嫁接报文的重传时间 |
PIM BSR domain border |
该接口是否配置了BSR的服务边界 |
PIM BFD |
该接口是否开启了IPv6 PIM与BFD联动功能 |
PIM passive |
该接口是否配置了IPv6 PIM消极模式 |
PIM DR elect delay time |
配置的DR选举延迟时间,单位为秒。如果未开启DR延迟选举功能,则不显示该字段 |
PIM DR remaining elect delay time |
DR选举延迟时间剩余的时间,单位为秒 如果未开启DR延迟选举功能或定时器超时,则不显示该字段;如果定时器超时,则显示为“--” |
Number of routers on network not using DR priority |
该接口所在网段上没有使用DR优先级字段的路由器数量 |
Number of routers on network not using LAN delay |
该接口所在网段上未使用LAN-delay字段的路由器数量 |
Number of routers on network not using neighbor tracking |
该接口所在网段上未开启邻居跟踪的路由器数量 |
display ipv6 pim neighbor命令用来显示IPv6 PIM邻居信息。
display ipv6 pim [ vpn-instance vpn-instance-name ] neighbor [ ipv6-neighbor-address | interface interface-type interface-number | verbose ] *
vpn-instance vpn-instance-name:显示指定VPN实例的IPv6 PIM邻居信息,vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。如果未指定本参数,将显示公网实例的IPv6 PIM邻居信息。
ipv6-neighbor-address:IPv6 PIM邻居的IPv6地址,显示指定IPv6 PIM邻居的信息。如果未指定本参数,将显示所有IPv6 PIM邻居的信息。
interface interface-type interface-number:接口类型和接口编号,显示指定接口上的IPv6 PIM邻居信息。如果未指定本参数,将显示所有接口上的IPv6 PIM邻居信息。
# 显示公网实例所有IPv6 PIM邻居的概要信息。
<Sysname> display ipv6 pim neighbor
Total IPv6 pim neighbors: 2
Neighbor: FE80::A01:101:1
Interface: Vlan1
Uptime: 02:50:49
Expiry time: 00:01:31
DR priority: 1
Mode: N/A
Neighbor: FE80::A01:102:1
Interface: Vlan2
Uptime: 02:49:39
Expiry time: 00:01:42
DR priority: 1
Mode: N/A
# 显示公网实例中IPv6地址为FE80::A01:101:1的IPv6 PIM邻居的详细信息。
<Sysname> display ipv6 pim neighbor fe80::a01:101:1 verbose
Interface: Vlan-interface3
Uptime: 00:00:10
Expiry time: 00:00:30
DR priority: 1
Generation ID: 0x2ACEFE15
Holdtime: 105 s
LAN delay: 500 ms
Override interval: 2500 ms
State refresh interval: 60 s
Neighbor tracking: Disabled
Bidirectional PIM: Disabled
RPF proxy vector: Disabled
Secondary address(es):
1::1
表1-7 display ipv6 pim neighbor命令显示信息描述表
Total Number of Neighbors |
IPv6 PIM邻居的总数 |
Neighbor |
IPv6 PIM邻居的IPv6主地址(链路本地地址) |
IPv6 PIM邻居所在接口的名称 |
Uptime |
IPv6 PIM邻居已存在的时间 |
Expiry time |
IPv6 PIM邻居超时的剩余时间,never表示IPv6 PIM邻居永不超时,即永远可达 |
DR priority |
IPv6 PIM邻居的优先级 |
Mode |
IPv6 PIM邻居的模式: · B表示IPv6双向PIM模式 · N/A:表示非IPv6双向PIM模式 |
Generation ID |
IPv6 PIM邻居的Generation ID(状态随机数) |
Holdtime |
IPv6 PIM邻居的生存时间,forever表示IPv6 PIM邻居永远存在,即永远可达 |
LAN delay |
IPv6 PIM报文在共享网段中的传输延迟 |
Override interval |
剪枝否决的时间间隔 |
State refresh interval |
状态刷新的时间间隔,只有当IPv6 PIM邻居工作在IPv6 PIM-DM模式下且具备状态刷新能力时才会显示本字段 |
Neighbor tracking |
邻居跟踪功能是否开启 |
Bidirectional PIM |
IPv6双向PIM是否使能 |
RPF proxy vector |
IPv6 PIM邻居是否支持RPF代理向量功能(请参见“IP组播配置指导”中的“组播VPN”) |
Secondary address(es) |
IPv6 PIM邻居的IPv6从地址(非链路本地地址) |
display ipv6 pim routing-table命令用来显示IPv6 PIM路由表的内容。
display ipv6 pim [ vpn-instance vpn-instance-name ] routing-table [ ipv6-group-address [ prefix-length ] | ipv6-source-address [ prefix-length ] | flags flag-value | fsm | incoming-interface interface-type interface-number | mode mode-type | outgoing-interface { exclude | include | match } interface-type interface-number | extranet { source-vpn-instance source-vpn-instance-name | source-public-instance | receive-vpn-instance receive-vpn-instance-name | receive-public-instance } ] *
vpn-instance vpn-instance-name:显示指定VPN实例的IPv6 PIM路由项,vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。如果未指定本参数,将显示公网实例的IPv6 PIM路由项。
ipv6-group-address:IPv6组播组地址,显示指定IPv6组播组的IPv6 PIM路由项,取值范围为FFxy::/16,其中x和y均代表0~F的任意一个十六进制数。如果未指定本参数,将显示所有IPv6组播组的IPv6 PIM路由项。
ipv6-source-address:IPv6组播源地址,显示包含指定IPv6组播源的IPv6 PIM路由项。
prefix-length:指定IPv6组播组或IPv6组播源地址的前缀长度。对于IPv6组播组地址,其取值范围为8~128,缺省值为128;对于IPv6组播源地址,其取值范围为0~128,缺省值为128。
flags flag-value:IPv6 PIM标志,显示包含指定标志的IPv6 PIM路由项。如果未指定本参数,将显示包含所有标志的IPv6 PIM路由项。flag-value的取值及含义如下:
· act:表示已经有实际数据到达的IPv6 PIM路由项;
· del:表示计划删除的IPv6 PIM路由项;
· exprune:表示某些出接口被其它IPv6组播路由协议剪枝的IPv6 PIM路由项;
· ext:表示包含了由其它IPv6组播路由协议提供出接口的IPv6 PIM路由项;
· loc:表示在与IPv6组播源处于同一网段的设备上的IPv6 PIM路由项;
· niif:表示未确定入接口的IPv6 PIM路由项;
· nonbr:表示IPv6 PIM邻居查找失败的IPv6 PIM路由项;
· rpt:表示向RP方向发送过(S,G)RPT位剪枝的IPv6 PIM路由项;
· rq:表示Data-MDT切换接收端的IPv6 PIM路由项;
· spt:表示SPT上的IPv6 PIM路由项;
· sq:表示Data-MDT切换发起端的IPv6 PIM路由项;
· swt:表示正处于向SPT切换过程中的IPv6 PIM路由项;
· wc:表示带WC通配符的IPv6 PIM路由项。
fsm:显示有限状态机的详细信息。
incoming-interface interface-type interface-number:显示指定入接口的IPv6 PIM路由项。如果未指定本参数,将显示所有入接口的PIM路由项。
mode mode-type:IPv6 PIM模式,显示指定模式下的IPv6 PIM路由项。如果未指定本参数,将显示所有模式下的IPv6 PIM路由项。mode-type的取值及含义如下:
· bidir:表示IPv6双向PIM模式;
· dm:表示IPv6 PIM-DM模式;
· sm:表示IPv6 PIM-SM模式;
· ssm:表示IPv6 PIM-SSM模式。
outgoing-interface { exclude | include | match } interface-type interface-number:显示指定出接口的IPv6 PIM路由项。其中,exclude表示不包含指定接口;include表示包含指定接口;match表示包含且仅包含指定接口。如果未指定本参数,将显示所有出接口的IPv6 PIM路由项。
extranet:显示指定跨VPN组播的IPv6 PIM路由项信息。
· source-vpn-instance source-vpn-instance-name:表示指定的组播源所在的VPN实例。source-vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。
· source-public-instance:表示指定的组播源位于公网中。
· receive-vpn-instance receive-vpn-instance-name:表示指定的接收者所在的VPN实例。receive-vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。
· receive-public-instance:表示指定的接收者位于公网中。
# 显示公网实例IPv6 PIM路由表的内容。
<Sysname> display ipv6 pim routing-table
Total 0 (*, G) entries; 1 (S, G) entries
(2001::2, FFE3::101)
RP: FE80::A01:100:1
Protocol: pim-sm, Flag: SPT LOC ACT
UpTime: 02:54:43
Upstream interface: Vlan-interface1
Upstream neighbor: NULL
RPF prime neighbor: NULL
Downstream interface information:
1: Vlan-interface3
Protocol: pim-sm, UpTime: 02:54:43, Expires: 00:02:47
# 显示公网实例IPv6 PIM路由表的状态机信息。
<Sysname> display ipv6 pim routing-table fsm
Abbreviations for FSM states:
NI - no info, J - joined, NJ - not joined, P - pruned,
NP - not pruned, PP - prune pending, W - winner, L - loser,
F - forwarding, AP - ack pending, DR - designated router,
NDR - non-designated router, RCV - downstream receivers
RP: FE80::A01:100:1
UpTime: 02:54:43
Join/Prune FSM: [SPT: J] [RPT: NP]
1: Vlan-interface2
DR state: [DR]
Join/Prune FSM: [NI]
Assert FSM: [NI]
FSM information for non-downstream interfaces: None
# 显示跨VPN组播的IPv6 PIM路由项信息。
<Sysname> display ipv6 pim vpn-instance vpn1 routing-table extranet receive-vpn-instance vpn2
Total 1 (*, G) entries; 1 (S, G) entries
(*, FFE3::101)
RP: FE80::A01:100:1
Protocol: pim-sm, Flag: WC
UpTime: 07:06:11
Upstream interface: Register-Tunnel0
Total number of downstream interfaces: 2
1: Vlan-interface1
Protocol: pim-sm, UpTime: 07:06:11, Expires: -
2: Extranet (VPN: vpn2)
Protocol: MD, UpTime: 01:12:52, Expires: -
RP: FE80::A01:100:1
UpTime: 07:06:10
Upstream interface: MTunnel0
Upstream neighbor: FE80::1
RPF prime neighbor: FE80::1
1: Vlan-interface1
Protocol: MD, UpTime: 01:29:07, Expires: -
表1-8 display ipv6 pim routing-table命令显示信息描述表
Total 0 (*, G) entries; 1 (S, G) entries |
IPv6 PIM路由表中(S,G)表项的总数与(*,G)表项的总数 |
Abbreviations for FSM states: NI - no info, J - joined, NJ - not joined, P – pruned NP - not pruned, PP - prune pending, W - winner, L – loser F - forwarding, AP - ack pending, DR - designated router NDR - non-designated router, RCV - downstream receivers |
状态机的缩写:NI表示初始状态,J表示加入状态,P表示剪枝状态,NP表示未剪枝状态,PP表示剪枝未决状态,W表示断言当选,L表示断言落选,F表示转发状态,AP表示嫁接确认状态,DR表示指定路由器,NDR表示非指定路由器,RCV表示下游接收者 |
(2001::2, FFE3::101) |
IPv6 PIM路由表中的(S,G)表项 |
RP |
RP的地址 |
Protocol |
IPv6 PIM的模式 |
Flag |
IPv6 PIM路由表中(S,G)或(*,G)表项的标志: · ACT:表示已有实际数据到达 · DEL:表示计划要删除 · EXPRUNE:表示某些出接口被其它IPv6组播路由协议剪枝 · EXT:表示包含了由其它IPv6组播路由协议提供的出接口 · LOC:表示与IPv6组播源处于同一网段 · NIIF:表示未确定入接口 · NONBR:表示IPv6 PIM邻居查找失败 · RPT:表示向RP方向发送过(S,G)RPT位剪枝 · RQ:表示Data-MDT切换接收端的PIM路由项 · SPT:表示在SPT上 · SQ:表示Data-MDT切换发起端的PIM路由项 · SWT:表示正在向SPT切换 · WC:表示带WC通配符 |
Uptime |
(S,G)或(*,G)表项已存在的时间 |
Upstream interface |
(S,G)或(*,G)表项的入接口 |
Upstream neighbor |
(S,G)或(*,G)表项的上游邻居 |
RPF prime neighbor |
(S,G)或(*,G)表项的RPF邻居: · 对(*,G)表项来说,当该路由器是RP时,(*,G)表项的RPF邻居是NULL · 对(S,G)表项来说,当该路由器直连源时,(S,G)表项的RPF邻居是NULL |
DR state |
DR的状态 |
Join/Prune FSM |
加入/剪枝状态机 |
Assert FSM |
断言状态机 |
Downstream interface information |
下游接口的信息,包括: · 下游接口的总数 · 下游接口的名称 · 下游接口使用的协议类型 · 下游接口的存在时间 · 下游接口的超时时间 如果某个出接口不参与组播数据转发,则会在该接口后面显示(inactive) |
FSM information for non-downstream interfaces |
非下游接口的状态机信息 |
Extranet |
表示跨VPN组播的相关表项 · 在上游接口列表里出现,Extranet (VPN: vpn1)表示流是从VPN1(源VPN)里面流出 · 在下游接口列表里出现,Extranet (VPN: vpn2)表示流是流入VPN2(接收者VPN) |
display ipv6 pim rp-info命令用来显示IPv6 PIM-SM域中的RP的信息。
display ipv6 pim [ vpn-instance vpn-instance-name ] rp-info [ ipv6-group-address ]
vpn-instance vpn-instance-name:显示指定VPN实例的RP信息,vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。如果未指定本参数,将显示公网实例的RP信息。
ipv6-group-address:IPv6组播组地址,显示指定IPv6组播组所对应的RP信息,取值范围为FFxy::/16(但不包括下列地址: FFx1::/16、FFx2::/16),其中x和y均代表0~F的任意一个十六进制数。如果未指定本参数,将显示所有IPv6组播组对应的RP信息。
# 显示公网实例中IPv6组播组FF73:130:7:12::1所对应的RP信息。
<Sysname> display ipv6 pim rp-info ff73:130:7:12::1
Embedded RP address is: 7:12::1
Configured ACL: 2000
BSR RP address is: 7:12::1
Priority: 192
HoldTime: 180
Uptime: 03:01:10
Expires: 00:02:30
Static RP address is: 7:12::1
Preferred: No
Configured ACL: 2003
RP mapping for this group is: 7:12::1 (local host)
Anycast-RP 7:12::1 members:
Member address State
1:1::1 Active
1:1::2 Local
1:2::1 Remote
# 显示所有IPv6组播组对应的RP信息。
IPv6 PIM-SM embedded RP information:
Embedded RP ACL: 2000
Group RP address
FF73:230:8:12:: 8:12::2
BSR RP information:
Scope: non-scoped
Group/MaskLen: FF73:230:8:12::/64
8:12::2 (local) 192 180 03:01:36 00:02:29
Group/MaskLen: FF23::/92 [B]
7:12::1 (local) 192 180 00:00:39 00:02:57
Static RP information:
RP address ACL Mode Preferred
3:3::1 2000 pim-sm No
3:3::2 2001 pim-sm Yes
3:3::3 2002 pim-sm No
3:3::4 pim-sm No
3:3::5 2002 pim-sm Yes
Anycast-RP information:
RP address Member address State
3:3::1 1:1::1 Active
3:3::1 1:1::2 Local
3:3::1 1:2::1 Remote
表1-9 display ipv6 pim rp-info命令显示信息描述表
Embedded RP address is |
嵌入式RP的IPv6地址 |
IPv6 PIM-SM Embedded RP information |
嵌入式RP的信息 |
Embedded RP ACL |
嵌入式RP关联的ACL |
Group |
嵌入式RP对应的IPv6组播组 |
BSR RP address is |
RP的IPv6地址 |
BSR RP information |
BSR RP信息 |
Scope |
域 |
Group/MaskLen |
RP所服务的IPv6组播组 |
[B] |
表示RP服务于IPv6双向PIM。如果不显示该字段,则表示RP服务于IPv6 PIM-SM |
RP address |
Priority |
RP的优先级 |
HoldTime |
RP的超时时间 |
Uptime |
RP已存在的时间 |
Expires |
RP超时的剩余时间 |
Static RP information |
静态RP信息 |
Static RP address is/RP address |
静态RP的IPv6地址 |
Preferred |
是否指定了静态RP优先 |
Configured ACL/ACL |
配置的RP所关联的ACL |
Mode |
为IPv6 PIM-SM服务还是为IPv6双向PIM服务 |
RP mapping for this group |
服务于当前组播组的RP的IPv6地址 |
Anycast-RP 7:12::1 members |
Anycast-RP 7:12::1的成员 |
Member address |
Anycast-RP成员的IPv6地址 |
State |
Anycast-RP成员地址的来源: · Active:表示本端激活接口的地址 · Local:表示本端未激活接口的地址 · Remote:表示远端的地址 |
Anycast-RP information |
Anycast-RP信息 |
display ipv6 pim statistics命令用来显示IPv6 PIM协议报文的统计信息。
# 显示IPv6 PIM协议报文的统计信息。
<Sysname> display ipv6 pim statistics
Received PIM packets: 3295
Sent PIM packets : 5975
Valid Invalid Succeeded Failed
Hello : 3128 0 4333 0
Reg : 14 0 0 0
Reg-stop : 0 0 0 0
JP : 151 0 561 0
BSM : 0 0 1081 0
Assert : 0 0 0 0
Graft : 0 0 0 0
Graft-ACK: 0 0 0 0
C-RP : 0 0 0 0
SRM : 0 0 0 0
DF : 0 0 0 0
AutoRP : 0 0 0 0
表1-10 display ipv6 pim statistics命令显示信息描述表
Received PIM packets |
收到的IPv6 PIM协议报文总数 |
Sent PIM packets |
发出的IPv6 PIM协议报文总数 |
Valid |
收到的合法IPv6 PIM协议报文数量 |
Invalid |
收到的非法IPv6 PIM协议报文数量 |
Succeeded |
发送成功的IPv6 PIM协议报文数量 |
Failed |
发送失败的IPv6 PIM协议报文数量 |
Hello |
Hello报文统计 |
Reg |
注册报文统计 |
Reg-stop |
注册停止报文统计 |
JP |
加入/剪枝报文统计 |
BSM |
自举报文统计 |
Assert |
断言报文统计 |
Graft |
嫁接报文统计 |
Graft-ACK |
嫁接应答报文统计 |
C-RP |
C-RP报文统计 |
SRM |
状态刷新报文统计 |
DF |
指定转发者报文统计 |
AutoRP |
自动RP报文统计 |
dscp命令用来配置设备发送IPv6 PIM协议报文的DSCP优先级。
undo dscp命令用来恢复缺省情况。
dscp dscp-value
undo dscp
设备发送IPv6 PIM协议报文的DSCP优先级为48。
IPv6 PIM视图
dscp-value:DSCP值,取值范围为0~63。
DSCP(Differentiated Services Code Point,差分服务编码点)携带在IP报文中的ToS字段,用来体现报文自身的优先等级,决定报文传输的优先程度。DSCP优先级的取值越大,报文的优先级越高。
# 配置设备发送IPv6 PIM报文的DSCP优先级为63。
[Sysname] ipv6 pim
[Sysname-pim6] dscp 63
embedded-rp命令用来开启嵌入式RP功能。
undo embedded-rp命令用来关闭嵌入式RP功能。
embedded-rp [ ipv6-acl-number ]
undo embedded-rp
嵌入式RP功能处于关闭状态。
IPv6 PIM视图
嵌入式RP(Embedded RP)是IPv6 PIM中特有的RP发现机制,该机制使用内嵌RP地址的IPv6组播地址,使得设备可以直接从该地址中解析出RP的地址。
只有组地址在为FF7x::/12或FFFx::/12,且符合格式要求的IPv6组播组支持嵌入式RP功能。有关嵌入式RP支持的组地址格式要求的详细介绍,请参见“IP组播”中的“IPv6 PIM”。
执行本命令时,如果未指定ipv6-acl-number参数,则对该范围内的所有IPv6组播组均开启嵌入式RP功能;如果指定了ipv6-acl-number参数,则只有在该范围内且通过了ACL检查的IPv6组播组才能开启嵌入式RP功能。
引用ACL时,需要注意的是:
· 若引用的ACL不存在,或者引用的ACL中没有配置规则,则表示对该范围内的所有IPv6组播组均开启嵌入式RP功能。
· 在引用的ACL中,若某规则指定了vpn-instance参数,则该规则将不生效。
# 为组地址在FF7E:140:20::101/64范围内的IPv6组播组开启嵌入式RP功能。
[Sysname-acl-ipv6-basic-2000] rule permit source ff7e:140:20::101 64
[Sysname] ipv6 pim
[Sysname-pim6] embedded-rp 2000
hello-option dr-priority命令用来全局配置竞选DR的优先级。
undo hello-option dr-priority命令用来恢复缺省情况。
竞选DR的优先级为1。
IPv6 PIM视图
priority:指定竞选DR的优先级,取值范围为0~4294967295。该数值越大,优先级越高。
本配置既可在IPv6 PIM视图又可在接口视图下进行,前者对所有接口都生效,而后者只对当前接口生效,但后者的配置优先级较高。
# 在公网实例中全局配置竞选DR的优先级为3。
[Sysname] ipv6 pim
[Sysname-pim6] hello-option dr-priority 3
· ipv6 pim hello-option dr-priority
hello-option holdtime命令用来全局配置保持IPv6 PIM邻居可达状态的时间。
undo hello-option holdtime命令用来恢复缺省情况。
hello-option holdtime time
保持IPv6 PIM邻居可达状态的时间为105秒。
IPv6 PIM视图
time:指定保持IPv6 PIM邻居可达状态的超时时间,取值范围为1~65535,单位为秒。如果指定为65535秒,则表示PIM邻居永远可达。
# 在公网实例中全局配置保持IPv6 PIM邻居可达状态的时间为120秒。
[Sysname] ipv6 pim
[Sysname-pim6] hello-option holdtime 120
· ipv6 pim hello-option holdtime
hello-option lan-delay命令用来全局配置IPv6 PIM报文在共享网段中的传输延迟。
undo hello-option lan-delay命令用来恢复缺省情况。
hello-option lan-delay delay
IPv6 PIM报文在共享网段中的传输延迟为500毫秒。
IPv6 PIM视图
delay:指定IPv6 PIM报文在共享网段中的传输延迟,取值范围为1~32767,单位为毫秒。
# 在公网实例中全局配置IPv6 PIM报文在共享网段中的传输延迟为200毫秒。
[Sysname] ipv6 pim
[Sysname-pim6] hello-option lan-delay 200
· hello-option override-interval (IPv6 PIM view)
· ipv6 pim hello-option lan-delay
· ipv6 pim hello-option override-interval
hello-option neighbor-tracking命令用来全局开启邻居跟踪功能。
undo hello-option neighbor-tracking命令用来全局关闭邻居跟踪功能。
邻居跟踪功能处于关闭状态。
IPv6 PIM视图
# 在公网实例中全局开启邻居跟踪功能。
[Sysname] ipv6 pim
[Sysname-pim6] hello-option neighbor-tracking
· ipv6 pim hello-option neighbor-tracking
hello-option override-interval命令用来全局配置剪枝否决时间。
undo hello-option override-interval命令用来恢复缺省情况。
剪枝否决时间为2500毫秒。
IPv6 PIM视图
interval:指定剪枝的否决时间,取值范围为1~65535,单位为毫秒。
# 在公网实例中全局配置剪枝否决时间为2000毫秒。
[Sysname] ipv6 pim
[Sysname-pim6] hello-option override-interval 2000
· hello-option lan-delay (IPv6 PIM view)
holdtime join-prune命令用来全局配置加入/剪枝状态的保持时间。
undo holdtime join-prune命令用来恢复缺省情况。
holdtime join-prune time
加入/剪枝状态的保持时间为210秒。
IPv6 PIM视图
time:指定加入/剪枝状态的保持时间,取值范围为1~65535,单位为秒。
IPv6 PIM接口向上游邻居发送加入/剪枝报文的时间间隔必须小于加入/剪枝状态的保持时间,以免上游邻居老化超时。
# 在公网实例中全局配置加入/剪枝状态的保持时间为280秒。
[Sysname] ipv6 pim
[Sysname-pim6] holdtime join-prune 280
· ipv6 pim holdtime join-prune
· timer join-prune (IPv6 PIM view)
ipv6 pim命令用来进入IPv6 PIM视图。
undo ipv6 pim命令用来清除IPv6 PIM视图下的所有配置。
undo ipv6 pim [ vpn-instance vpn-instance-name ]
# 先使能公网实例中的IPv6组播路由,再进入公网实例的IPv6 PIM视图。
[Sysname] ipv6 pim
[Sysname-pim6]
# 先使能VPN实例mvpn中的IPv6组播路由,再进入该VPN实例的IPv6 PIM视图。
[Sysname] ipv6 multicast routing vpn-instance mvpn
[Sysname-mrib6-mvpn] quit
[Sysname-pim6-mvpn]
ipv6 pim bfd enable命令用来开启IPv6 PIM与BFD联动功能。
undo ipv6 pim bfd enable命令用来关闭IPv6 PIM与BFD联动功能。
ipv6 pim bfd enable
IPv6 PIM与BFD联动功能处于关闭状态。
只有在接口上先使能了IPv6 PIM-DM或IPv6 PIM-SM,本命令才能生效。
# 使能公网实例中的IPv6组播路由,在接口Vlan-interface100上使能IPv6 PIM-DM,并开启IPv6 PIM与BFD联动功能。
[Sysname-Vlan-interface100] ipv6 pim dm
[Sysname-Vlan-interface100] ipv6 pim bfd enable
· ipv6 pim dm
· ipv6 pim sm
ipv6 pim bsr-boundary命令用来配置BSR的服务边界,即IPv6 PIM-SM域的边界。
undo ipv6 pim bsr-boundary命令用来恢复缺省情况。
不存在BSR的服务边界。
# 配置接口Vlan-interface100为BSR的服务边界。
[Sysname-Vlan-interface100] ipv6 pim bsr-boundary
· ipv6 multicast boundary(IP组播命令参考/IPv6组播路由与转发)
ipv6 pim distributed-dr命令用来配置接口为分布式DR接口。
undo ipv6 pim distributed-dr命令用来恢复缺省情况。
接口不是分布式DR接口。
VSI虚接口视图
VLAN接口视图
在组播VXLAN组网中,需要在分布式EVPN网关的VSI虚接口上执行本命令将VSI虚接口配置为分布式DR接口,从而强制指定自己为DR,以便将组播流量转发至本地站点。关于组播VXLAN的详细介绍,请参见“EVPN配置指导”中的“组播VXLAN”。
# 配置接口Vsi-interface1为分布式DR接口。
[Sysname] interface vsi-interface 1
[Sysname-Vsi-interface1] ipv6 pim distributed-dr
# 配置接口Vlan-interface1为分布式DR接口。
[Sysname-Vlan-interface1] ipv6 pim distributed-dr
ipv6 pim dm命令用来使能IPv6 PIM-DM。
undo ipv6 pim dm命令用来关闭IPv6 PIM-DM。
ipv6 pim dm
undo ipv6 pim dm
IPv6 PIM-DM处于关闭状态。
# 使能公网实例中的IPv6组播路由,并在接口Vlan-interface100上使能IPv6 PIM-DM。
ipv6 pim hello-option dr-priority命令用来在接口上配置竞选DR的优先级。
undo ipv6 pim hello-option dr-priority命令用来恢复缺省情况。
ipv6 pim hello-option dr-priority priority
竞选DR的优先级为1。
# 在接口Vlan-interface100上配置竞选DR的优先级为3。
[Sysname-Vlan-interface100] ipv6 pim hello-option dr-priority 3
· hello-option dr-priority (IPv6 PIM view)
ipv6 pim hello-option holdtime命令用来在接口上配置保持IPv6 PIM邻居的可达状态的时间。
undo ipv6 pim hello-option holdtime命令用来恢复缺省情况。
ipv6 pim hello-option holdtime time
time:指定保持IPv6 PIM邻居可达状态的时间,取值范围为1~65535,单位为秒。如果指定为65535秒,则表示PIM邻居永远可达。
# 在接口Vlan-interface100上配置保持IPv6 PIM邻居可达状态的时间为120秒。
[Sysname-Vlan-interface100] ipv6 pim hello-option holdtime 120
· hello-option holdtime (IPv6 PIM view)
ipv6 pim hello-option lan-delay命令用来在接口上配置IPv6 PIM报文在共享网段中的传输延迟。
undo ipv6 pim hello-option lan-delay命令用来恢复缺省情况。
ipv6 pim hello-option lan-delay delay
# 在接口Vlan-interface100上配置IPv6 PIM报文在共享网段中的传输延迟为200毫秒。
[Sysname-Vlan-interface100] ipv6 pim hello-option lan-delay 200
ipv6 pim hello-option neighbor-tracking命令用来在接口上开启邻居跟踪功能。
ipv6 pim hello-option neighbor-tracking disable命令用来在全局开启了邻居跟踪功能的情况下,关闭当前接口上的邻居跟踪功能。
undo ipv6 pim hello-option neighbor-tracking命令用来取消接口上的邻居跟踪功能配置,使得接口与全局配置保持一致。
接口上的邻居跟踪功能处于关闭状态。
# 在接口Vlan-interface100上开启邻居跟踪功能。
[Sysname-Vlan-interface100] ipv6 pim hello-option neighbor-tracking
# 在公网实例全局开启了邻居跟踪功能的情况下,关闭接口Vlan-interface100上的邻居跟踪功能。
[Sysname] ipv6 pim
[Sysname-pim6] quit
[Sysname-Vlan-interface100] ipv6 pim hello-option neighbor-tracking disable
· hello-option neighbor-tracking (IPv6 PIM view)
ipv6 pim hello-option override-interval命令用来在接口上配置剪枝否决时间。
undo ipv6 pim hello-option override-interval命令用来恢复缺省情况。
ipv6 pim hello-option override-interval interval
剪枝否决时间为2500毫秒。
# 在接口Vlan-interface100上配置剪枝否决时间为2000毫秒。
[Sysname-Vlan-interface100] ipv6 pim hello-option override-interval 2000
ipv6 pim holdtime join-prune命令用来在接口上配置加入/剪枝状态的保持时间。
undo ipv6 pim holdtime join-prune命令用来恢复缺省情况。
ipv6 pim holdtime join-prune time
加入/剪枝状态的保持时间为210秒。
# 在接口Vlan-interface100上配置加入/剪枝状态的保持时间为280秒。
[Sysname-Vlan-interface100] ipv6 pim holdtime join-prune 280
· holdtime join-prune (IPv6 PIM view)
ipv6 pim join-policy命令用来在接口上配置IPv6 PIM加入/剪枝报文中加入信息的过滤规则。
undo ipv6 pim join-policy命令用来恢复缺省情况。
ipv6 pim join-policy { { ipv6-acl-number | name ipv6-acl-name } | [ asm { ipv6-acl-number | name ipv6-acl-name } | ssm { ipv6-acl-number | name ipv6-acl-name } ] * }
不过滤IPv6 PIM加入/剪枝报文中的加入信息。
ipv6-acl-number:指定IPv6基本或高级ACL的编号,取值范围为2000~3999。当指定的ACL不存在或ACL中未配置有效规则,则过滤掉所有的加入信息。
name ipv6-acl-name:指定IPv6基本或高级ACL的名称,为1~63个字符的字符串,不区分大小写,必须以英文字母a~z或A~Z开头。为避免混淆,ACL的名称不允许使用英文单词all。如果指定的ACL不存在或ACL中未配置有效规则,则过滤掉所有的加入信息。
asm { ipv6-acl-number| name ipv6-acl-name }:过滤组地址在ASM范围内的加入信息,取值范围为2000~3999。如果未指定本参数、指定的ACL不存在或ACL中未配置有效规则,则过滤掉ASM范围内所有的加入信息。其中:
· name ipv6-acl-name:指定IPv6基本或者高级ACL的名称,为1~63个字符的字符串,不区分大小写,必须以英文字母a~z或A~Z开头。为避免混淆,ACL的名称不允许使用英文单词all。
ssm { ipv6-acl-number | name ipv6-acl-name }:过滤组地址在SSM范围内的加入信息。如果未指定本参数、指定的ACL不存在或ACL中未配置有效规则,则过滤掉SSM范围内所有的加入信息。其中:
此命令对IPv6 PIM-DM不生效。
为了防止设备受到非法IPv6 PIM加入/剪枝报文攻击,通过配置本功能可以配置过滤规则,限制IPv6 PIM加入/剪枝报文中(S,G)加入信息的合法源地址范围和组地址范围,丢弃不合法的(S,G)加入信息,不建立对应的(S,G)表项。
对于IPv6基本ACL,本命令通过ACL规则中的source参数指定IPv6 PIM加入/剪枝报文中加入信息的组播组地址范围,并且该规则中除source、fragment和time-range以外的其它可选参数都将被忽略。
对于IPv6高级ACL,本命令通过ACL规则中的source参数指定IPv6 PIM加入/剪枝报文中加入信息的组播源地址范围,对于(*,G)信息,组播源地址视为::,destination参数用来指定加入信息的组播组地址范围,并且该规则中除source、destination、fragment和time-range以外的其它可选参数都将被忽略。
# 在接口Vlan-interface100上配置过滤规则,只允许接收源地址范围是1::1/128、组地址范围是FF33::101/128的IPv6 PIM加入/剪枝报文。
[Sysname] acl ipv6 advanced 3005
[Sysname-acl-ipv6-adv-3005] rule permit ipv6 source 1::1 128 destination FF33::101 128
[Sysname-acl-ipv6-adv-3005] quit
[Sysname-Vlan-interface100] ipv6 pim join-policy ssm 3005
ipv6 pim log enable命令用来开启IPv6 PIM的日志信息功能。
undo ipv6 pim log enable命令用来关闭IPv6 PIM的日志信息功能。
ipv6 pim log enable [ dr | error-packet | neighbor | rp ] *
undo ipv6 pim log enable [ dr | error-packet | neighbor | rp ] *
IPv6 PIM的日志信息功能处于开启状态。
dr:DR选举相关的日志信息。
error-packet:IPv6 PIM错误报文类型的日志信息。
neighbor:IPv6 PIM邻居类型的日志信息。
rp:RP变化相关的日志信息。
IPv6 PIM日志信息可以方便管理员定位问题和解决问题,生成的日志信息会交给信息中心模块处理,信息中心模块的配置将决定日志信息的发送规则和发送方向。有关信息中心的详细描述,请参见“网络管理和监控配置指导”中的“信息中心”。
若设备输出大量IPv6 PIM日志信息导致设备性能降低,请按需关闭本功能或通过ipv6 pim log suppress命令开启IPv6 PIM日志限速功能。
执行本命令时,如果未指定任何参数,则表示开启或关闭IPv6 PIM所有类型日志信息功能。
# 开启IPv6 PIM所有类型日志信息功能。
[Sysname] ipv6 pim log enable
· ipv6 pim log suppress
ipv6 pim log suppress命令用来开启IPv6 PIM日志限速功能。
undo ipv6 pim log suppress命令用来关闭IPv6 PIM日志限速功能。
ipv6 pim log suppress [ dr | error-packet | neighbor | rp ] *
undo ipv6 pim log suppress [ dr | error-packet | neighbor | rp ] *
IPv6 PIM的日志限速功能处于开启状态。
dr:DR选举相关的日志信息。
rp:RP变化相关的日志信息。
当设备输出大量IPv6 PIM日志信息时,会降低设备性能。此时,可以通过本命令开启IPv6 PIM日志限速功能。开启本功能后,IPv6 PIM模块输出到信息中心的日志速度将会被限制,从而减轻设备的负担。
开启本命令前,请确保已通过ipv6 pim log enable命令开启了PIM日志功能。
执行本命令时,如果未指定任何参数,则表示开启或关闭IPv6 PIM所有类型日志限速功能。
# 开启IPv6 PIM的所有类型日志限速功能。
[Sysname] ipv6 pim log suppress
· ipv6 pim log enable
ipv6 pim neighbor-policy命令用来配置合法Hello报文的源地址范围。
undo ipv6 pim neighbor-policy命令用来恢复缺省情况。
ipv6 pim neighbor-policy { ipv6-acl-number | name ipv6-acl-name }
Hello报文的源地址范围不受限制,即认为所有收到的Hello报文都是合法的。
ipv6-acl-number:指定IPv6基本或高级ACL的编号,取值范围为2000~3999。如果指定的ACL不存在或ACL中未配置有效规则,则过滤所有的Hello报文源地址,即认为所有收到的Hello报文都是非法的。
name ipv6-acl-name:指定IPv6基本或高级ACL的名称,为1~63个字符的字符串,不区分大小写,必须以英文字母a~z或A~Z开头。为避免混淆,ACL的名称不允许使用英文单词all。如果指定的ACL不存在或ACL中未配置有效规则,则过滤所有的Hello报文源地址,即认为所有收到的Hello报文都是非法的。
配置合法Hello报文的源地址范围可以防止Hello报文欺骗。
本命令通过ACL规则中的source参数指定合法Hello报文的源组地址范围,并且该规则中除source、fragment和time-range以外的其它可选参数都将被忽略。
# 在接口Vlan-interface100上配置合法Hello报文的源地址范围,只允许与来自网段FE80:101::101/64中的设备建立IPv6 PIM邻居关系。
[Sysname-acl-ipv6-basic-2000] rule permit source fe80:101::101 64
[Sysname-Vlan-interface100] ipv6 pim neighbor-policy 2000
ipv6 pim non-stop-routing命令用来开启IPv6 PIM协议的NSR功能。
undo ipv6 pim non-stop-routing命令用来关闭IPv6 PIM协议的NSR功能。
IPv6 PIM协议的NSR功能处于关闭状态。
# 开启IPv6 PIM NSR功能。
[Sysname] ipv6 pim non-stop-routing
ipv6 pim passive命令用来在接口上开启IPv6 PIM消极模式。
undo ipv6 pim passive命令用来在接口上关闭IPv6 PIM消极模式。
ipv6 pim passive
接口上的IPv6 PIM消极模式处于关闭状态。
# 使能公网实例中的IPv6组播路由,在接口Vlan-interface100上使能IPv6 PIM-DM,并开启IPv6 PIM消极模式。
[Sysname-Vlan-interface100] ipv6 pim passive
ipv6 pim require-genid命令用来配置拒绝无Generation ID的Hello报文。
undo ipv6 pim require-genid命令用来恢复缺省情况。
接受无Generation ID的Hello报文。
# 配置接口Vlan-interface100拒绝无Generation ID的Hello报文。
[Sysname-Vlan-interface100] ipv6 pim require-genid
ipv6 pim sm命令用来使能IPv6 PIM-SM。
undo ipv6 pim sm命令用来关闭IPv6 PIM-SM。
ipv6 pim sm
undo ipv6 pim sm
IPv6 PIM-SM处于关闭状态。
# 使能公网实例中的IPv6组播路由,并在接口Vlan-interface100上使能IPv6 PIM-SM。
[Sysname-Vlan-interface100] ipv6 pim sm
ipv6 pim state-refresh-capable命令用来开启状态刷新能力。
undo ipv6 pim state-refresh-capable命令用来关闭状态刷新能力。
状态刷新能力处于开启状态。
# 在接口Vlan-interface100上关闭状态刷新能力。
[Sysname-Vlan-interface100] undo ipv6 pim state-refresh-capable
· state-refresh-hoplimit (IPv6 PIM view)
· state-refresh-interval (IPv6 PIM view)
· state-refresh-rate-limit (IPv6 PIM view)
ipv6 pim timer dr-elect-delay命令用来在接口上配置DR选举的延迟时间。
undo ipv6 pim timer dr-elect-delay命令用来恢复缺省情况。
ipv6 pim timer dr-elect-delay delay-time
DR选举不延时。
delay-time:DR选举的延迟时间,取值范围为10~3600,单位为秒。
在与接收者相连的共享网段上,通常同时连接着多台IPv6 PIM设备。多台IPv6 PIM设备会通过DR选举机制选举出一台负责转发组播报文的IPv6 PIM设备(即DR)。在某些场景下,比如原先故障的DR恢复正常后,发送IPv6 PIM Hello报文参与DR选举,会立即被选为DR,导致当前DR变成非DR。此时,恢复正常并当选为DR的那台设备尚未生成完整的组播转发表项,会导致短时间内有组播流量的丢失,造成组播数据断流。
配置本命令后,原先故障的DR设备在恢复正常后,不会立即发送IPv6 PIM Hello报文参与DR选举,而是需要等待delay-time,设备才开始参与DR选举。此时,在延迟时间超时前,IPv6组播数据仍然由当前DR进行转发,减少了IPv6组播流量的断流。
建议在DR设备用户侧接口(开启了MLD功能的接口)上配置本命令,非DR设备不需要配置。若DR设备和非DR设备都配置,则设备均故障重启后,DR选举的延迟时间超时之前会出现断流。
建议配置的DR选举的延迟时间大于IPv6 PIM Hello报文的发送间隔,否则会导致DR设备故障恢复后出现短暂的多包。
# 在接口Vlan-interface100上配置DR选举的延迟时间为70秒。
[Sysname-Vlan-interface100] ipv6 pim timer dr-elect-delay 70
ipv6 pim timer graft-retry命令用来配置嫁接报文的重传时间。
undo ipv6 pim timer graft-retry命令用来恢复缺省情况。
ipv6 pim timer graft-retry interval
嫁接报文的重传时间为3秒。
interval:指定嫁接报文的重传时间,取值范围为1~65535,单位为秒。
# 在接口Vlan-interface100上配置嫁接报文的重传时间为80秒。
[Sysname-Vlan-interface100] ipv6 pim timer graft-retry 80
ipv6 pim timer hello命令用来在接口上配置发送Hello报文的时间间隔。
undo ipv6 pim timer hello命令用来恢复缺省情况。
ipv6 pim timer hello interval
发送Hello报文的时间间隔为30秒。
interval:指定发送Hello报文的时间间隔,取值范围为0~18000,单位为秒。0表示无穷大,即永不发送Hello报文。
# 在接口Vlan-interface100上配置发送Hello报文的时间间隔为40秒。
[Sysname-Vlan-interface100] ipv6 pim timer hello 40
· timer hello (IPv6 PIM view)
ipv6 pim timer join-prune命令用来在接口上配置发送加入/剪枝报文的时间间隔。
undo ipv6 pim timer join-prune命令用来恢复缺省情况。
ipv6 pim timer join-prune interval
发送加入/剪枝报文的时间间隔为60秒。
interval:指定发送加入/剪枝报文的时间间隔,取值范围为0~18000,单位为秒。0表示无穷大,即永不发送加入/剪枝报文。
本命令不会立即生效,新配置的发送间隔将在当前发送间隔完成后生效。
# 在接口Vlan-interface100上配置发送加入/剪枝报文的时间间隔为80秒。
[Sysname-Vlan-interface100] ipv6 pim timer join-prune 80
ipv6 pim triggered-hello-delay命令用来配置触发Hello报文的最大延迟时间。
undo ipv6 pim triggered-hello-delay命令用来恢复缺省情况。
ipv6 pim triggered-hello-delay delay
触发Hello报文的最大延迟时间为5秒。
delay:指定触发Hello报文的最大延迟时间,取值范围为1~60,单位为秒。
# 在接口Vlan-interface100上配置触发Hello报文的最大延迟时间为3秒。
[Sysname-Vlan-interface100] ipv6 pim triggered-hello-delay 3
ipv6 pim triggered-hello enable命令用来配置设备在端口链路状态发生变化时立刻发送Generation ID变化的Hello报文,以及时更新组播转发表项。
undo ipv6 pim triggered-hello enable命令用来取消在端口链路状态发生变化时立刻发送Generation ID变化的Hello报文。
ipv6 pim triggered-hello enable { port-down | port-up } *
undo ipv6 pim triggered-hello enable [ port-down | port-up ] *
设备不会因为端口链路状态发生变化而立刻发送Generation ID变化的Hello报文。
VLAN接口视图
port-down:指定端口状态变为down时,立刻发送Generation ID变化的Hello报文。
port-up:指定端口状态变为up时,立刻发送Generation ID变化的Hello报文。
为了提高可靠性,组播转发路径中的下游设备通过同一VLAN内的多个二层接口接入上游设备。当上游设备上的二层端口链路状态发生故障或者故障恢复时,下游设备需要切换到新的端口或者回切到该端口接入设备。在这些情况下,下游设备通常不会立即发送IPv6 PIM加入报文,导致组播数据不能及时切换到变更后的路径上。执行本命令后,设备上指定VLAN接口对应VLAN内的端口链路状态变化时,设备主动发送Generation ID变化的Hello报文,以触发下游设备立即发送IPv6 PIM加入报文,更新组播转发表项,将组播数据流迅速切换到新的转发路径上。
执行undo ipv6 pim triggered-hello enable命令时,如果没有指定任何参数,则表示端口状态变为down和up时,都不会立刻发送Generation ID变化的Hello报文。
# 配置设备在端口链路状态发生变化时立刻发送Generation ID变化的Hello报文。
[Sysname-Vlan-interface10] ipv6 pim triggered-hello enable port-down port-up
jp-pkt-size命令用来配置加入/剪枝报文的最大长度。
undo jp-pkt-size命令用来恢复缺省情况。
jp-pkt-size size
undo jp-pkt-size
加入/剪枝报文的最大长度为1200字节。
IPv6 PIM视图
# 在公网实例中配置加入/剪枝报文的最大长度为1500字节。
[Sysname] ipv6 pim
[Sysname-pim6] jp-pkt-size 1500
register-policy命令用来配置注册报文的过滤策略。
undo register-policy命令用来恢复缺省情况。
register-policy { ipv6-acl-number | name ipv6-acl-name }
不存在注册报文的过滤策略。
IPv6 PIM视图
ipv6-acl-number:指定IPv6高级ACL的编号,取值范围为3000~3999。如果指定的ACL不存在或ACL中未配置有效规则,则过滤掉所有的注册报文。
name ipv6-acl-name:指定IPv6高级ACL的名称,为1~63个字符的字符串,不区分大小写,必须以英文字母a~z或A~Z开头。为避免混淆,ACL的名称不允许使用英文单词all。如果指定的ACL不存在或ACL中未配置有效规则,则过滤掉所有的注册报文。
本命令指定ACL规则中的source参数用来指定注册报文中的IPv6组播源地址范围,destination参数用来指定IPv6组播组地址范围,并且该规则中除source、destination、fragment和time-range以外的其它可选参数都将被忽略。
只有与该ACL规则中的permit语句匹配的注册报文才会被RP接受。
# 在公网实例中配置RP上对注册报文的过滤策略,只接收来自3:1::/64网段的IPv6组播源发向FF0E:13::/64网段的IPv6组播组的注册报文。
[Sysname-acl-ipv6-adv-3000] rule permit ipv6 source 3:1:: 64 destination ff0e:13:: 64
[Sysname] ipv6 pim
[Sysname-pim6] register-policy 3000
register-suppression-timeout命令用来配置注册抑制时间。
undo register-suppression-timeout命令用来恢复缺省情况。
注册抑制时间为60秒。
IPv6 PIM视图
interval:指定注册抑制时间,取值范围为1~65535,单位为秒。
# 在公网实例中配置注册抑制时间为70秒。
[Sysname] ipv6 pim
[Sysname-pim6] register-suppression-timeout 70
register-whole-checksum命令用来配置根据注册报文的全部内容来计算校验和。
undo register-whole-checksum命令用来恢复缺省情况。
仅根据注册报文头来计算校验和。
IPv6 PIM视图
# 在公网实例中配置根据注册报文的全部内容来计算校验和。
[Sysname] ipv6 pim
[Sysname-pim6] register-whole-checksum
snmp-agent trap enable pim6命令用来开启IPv6 PIM的告警功能。
undo snmp-agent trap enable pim6命令用来关闭IPv6 PIM的告警功能。
snmp-agent trap enable pim6 [ candidate-bsr-win-election | elected-bsr-lost-election | interface-election | invalid-join-prune | invalid-register | neighbor-loss | private-interface-election | private-neighbor-loss | private-new-neighbor | private-rp-mapping-change | rp-mapping-change ] *
undo snmp-agent trap enable pim6 [ candidate-bsr-win-election | elected-bsr-lost-election | interface-election | invalid-join-prune | invalid-register | neighbor-loss | private-interface-election | private-neighbor-loss | private-new-neighbor | private-rp-mapping-change | rp-mapping-change ] *
IPv6 PIM的告警功能处于开启状态。
candidate-bsr-win-election:表示C-BSR成功当选BSR的告警信息。
elected-bsr-lost-election:表示原BSR在新的选举中失败的告警信息。
interface-election:表示设备成功当选为DR的PIM-STD-MIB告警信息。
invalid-join-prune:表示IPv6 PIM收到无效的加入/剪枝报文的告警信息。
invalid-register:表示IPv6 PIM收到无效的注册报文的告警信息。
neighbor-loss:表示PIM邻居丢失的PIM-STD-MIB告警信息。
private-interface-election:表示设备成功当选为DR的告警信息。
private-neighbor-loss:表示IPv6 PIM邻居丢失的告警信息。
private-new-neighbor:表示IPv6 PIM邻居添加的告警信息。
private-rp-mapping-change:表示RP发生改变的告警信息。
rp-mapping-change:表示RP发生改变的PIM-STD-MIB告警信息。
如果未指定任何可选参数,表示开启或关闭IPv6 PIM的全部告警功能。
开启了IPv6 PIM的告警功能之后,IPv6 PIM会生成告警信息,以向网管软件报告本模块的重要事件。该信息将发送至SNMP模块,通过设置SNMP中告警信息的发送参数,来决定告警信息输出的相关属性。有关告警信息的详细介绍,请参见“网络管理和监控配置指导”中的“SNMP”。
# 关闭IPv6 PIM的全部告警功能。
[Sysname] undo snmp-agent trap enable pim6
source-lifetime命令用来配置IPv6组播源的生存时间。
undo source-lifetime命令用来恢复缺省情况。
source-lifetime time
IPv6组播源的生存时间为210秒。
IPv6 PIM视图
time:指定IPv6组播源的生存时间,取值范围为0~31536000,单位为秒。取值为0时,表示组播源永不老化。
建议配置的生存时间大于30秒。
组播源的实际生存时间可能大于配置的值。
# 在公网实例中配置IPv6组播源的生存时间为200秒。
[Sysname] ipv6 pim
[Sysname-pim6] source-lifetime 200
source-policy命令用来配置IPv6组播数据过滤器。
undo source-policy命令用来恢复缺省情况。
source-policy { ipv6-acl-number | name ipv6-acl-name }
undo source-policy
不存在IPv6组播数据过滤器,不对组播数据进行过滤。
IPv6 PIM视图
ipv6-acl-number:指定IPv6基本或高级ACL的编号,取值范围为2000~3999。如果指定的ACL不存在或ACL中未配置有效规则,则过滤掉所有IPv6组播数据。
name ipv6-acl-name:指定IPv6基本或高级ACL的名称,为1~63个字符的字符串,不区分大小写,必须以英文字母a~z或A~Z开头。为避免混淆,ACL的名称不允许使用英文单词all。如果指定的ACL不存在或ACL中未配置有效规则,则过滤掉所有IPv6组播数据。
对于IPv6基本ACL,本命令指定ACL规则中的source参数用来指定IPv6组播数据报文的源地址范围,并且该规则中除source、fragment和time-range以外的其它可选参数都将被忽略。
对于IPv6高级ACL,该ACL规则中的source参数用来指定IPv6组播数据报文的源地址范围,destination参数用来指定组播组地址范围,并且该规则中除source、destination、fragment和time-range以外的其它可选参数都将被忽略。
# 在公网实例中配置接收IPv6组播源3121::1的IPv6组播数据报文,丢弃IPv6组播源3121::2的IPv6组播数据报文。
[Sysname-acl-ipv6-basic-2000] rule permit source 3121::1 128
[Sysname-acl-ipv6-basic-2000] rule deny source 3121::2 128
[Sysname] ipv6 pim
[Sysname-pim6] source-policy 2000
[Sysname-pim6] quit
spt-switch-threshold命令用来配置发起SPT切换的条件。
undo spt-switch-threshold命令用来删除指定的发起SPT切换的条件。
spt-switch-threshold { immediacy | infinity } [ group-policy ipv6-acl-number ]
undo spt-switch-threshold [ immediacy | infinity ] [ group-policy ipv6-acl-number ]
设备收到第一个IPv6组播数据包后便立即向SPT切换。
IPv6 PIM视图
immediacy:表示立即发起SPT切换。
infinity:表示永不发起SPT切换。
group-policy ipv6-acl-number:表示组策略列表中的一项,与该组策略匹配的IPv6组播组将应用本配置。ipv6-acl-number表示IPv6基本ACL的编号,取值范围为2000~2999。如果未指定本参数指定的ACL不存在或ACL中未配置有效规则,则本配置将应用于所有IPv6组播组。
该ACL规则中的source参数用来指定IPv6组播组地址范围,并且该规则中除source、fragment和time-range以外的其它可选参数都将被忽略。
由于组播源侧DR在创建IPv6组播路由表项后,无法继续将IPv6组播报文封装在注册报文中发给RP,因此在可能成为RP的设备上仅支持配置立即发起SPT切换,否则会导致IPv6组播报文转发失败。
[Sysname-pim6] spt-switch-threshold infinity
ssm-policy命令用来配置IPv6 SSM组播组的范围。
undo ssm-policy命令用来恢复缺省情况。
ssm-policy { ipv6-acl-number | name ipv6-acl-name }
undo ssm-policy
IPv6 SSM组播组的范围为FF3x::/32,其中x表示任意合法的scope。
IPv6 PIM视图
ipv6-acl-number:指定IPv6基本ACL的编号,取值范围为2000~2999。如果指定的ACL不存在或ACL中未配置有效规则,则过滤掉所有SSM组播组地址。
name ipv6-acl-name:指定IPv6基本ACL的名称,为1~63个字符的字符串,不区分大小写,必须以英文字母a~z或A~Z开头。为避免混淆,ACL的名称不允许使用英文单词all。如果指定的ACL不存在或ACL中未配置有效规则,则过滤掉所有SSM组播组地址。
通过本命令可以定义允许或拒绝的IPv6组播组的地址范围:如果匹配通过,则组播运行模式为IPv6 PIM-SSM,否则为IPv6 PIM-SM。
本命令指定ACL规则中的source参数用来指定IPv6 SSM组播组范围,并且该规则中除source、fragment和time-range以外的其它可选参数都将被忽略。
# 配置IPv6 SSM组播组的范围为FF3E:0:8192::/96。
[Sysname-acl-ipv6-basic-2000] rule permit source ff3e:0:8192:: 96
[Sysname] ipv6 pim
[Sysname-pim6] ssm-policy 2000
state-refresh-hoplimit命令用来配置状态刷新报文的Hop Limit值。
undo state-refresh-hoplimit命令用来恢复缺省情况。
state-refresh-hoplimit hoplimit-value
状态刷新报文的Hop Limit值为255。
IPv6 PIM视图
hoplimit-value:指定状态刷新报文的Hop Limit值,取值范围为1~255。
# 在公网实例中配置状态刷新报文的Hop Limit值为45。
[Sysname] ipv6 pim
[Sysname-pim6] state-refresh-hoplimit 45
· ipv6 pim state-refresh-capable
state-refresh-interval命令用来配置发送状态刷新报文的时间间隔。
undo state-refresh-interval命令用来恢复缺省情况。
发送状态刷新报文的时间间隔为60秒。
IPv6 PIM视图
interval:指定发送状态刷新报文的时间间隔,取值范围为1~255,单位为秒。
# 在公网实例中配置发送状态刷新报文的时间间隔为70秒。
[Sysname] ipv6 pim
[Sysname-pim6] state-refresh-interval 70
state-refresh-rate-limit命令用来配置接收新状态刷新报文的等待时间。
undo state-refresh-rate-limit命令用来恢复缺省情况。
state-refresh-rate-limit time
接收新状态刷新报文的等待时间为30秒。
IPv6 PIM视图
time:指定接收新状态刷新报文的等待时间,取值范围为1~65535,单位为秒。
# 在公网实例中配置接收新状态刷新报文的等待时间为45秒。
[Sysname] ipv6 pim
[Sysname-pim6] state-refresh-rate-limit 45
static-rp命令用来配置静态RP。
undo static-rp命令用来删除静态RP。
static-rp ipv6-rp-address [ { ipv6-acl-number| name ipv6-acl-name } | bidir | preferred ] *
undo static-rp ipv6-rp-address
不存在静态RP。
IPv6 PIM视图
ipv6-rp-address:指定静态RP的IPv6地址。该地址必须是合法的IPv6全球单播地址。
ipv6-acl-number:指定IPv6基本或高级ACL的编号,取值范围为2000~3999。如果指定了本参数,该静态RP将只为能够通过该过滤规则的IPv6组播组服务;如果未指定本参数和name ipv6-acl-name、指定的ACL不存在或ACL中未配置有效规则,则该静态RP将为所有IPv6组播组服务。
name ipv6-acl-name:指定IPv6基本或高级ACL的名称,为1~63个字符的字符串,不区分大小写,必须以英文字母a~z或A~Z开头。为避免混淆,ACL的名称不允许使用英文单词all。如果指定了本参数,该静态RP将只为能够通过该过滤规则的IPv6组播组服务;如果未指定本参数和ipv6-acl-number参数、指定的ACL名称不存在或ACL中未配置有效规则,则该静态RP将为所有IPv6组播组服务。
bidir:指定该静态RP服务于IPv6双向PIM。如果未指定本参数,该静态RP将服务于IPv6 PIM-SM。
preferred:表示当网络中同时存在动态RP和静态RP时,优先选择静态RP,只有当静态RP失效时,动态RP才能生效。如果未指定本参数,则表示优先选择动态RP,只有当未配置动态RP或动态RP失效时,静态RP才能生效。
作为静态RP的接口不必使能IPv6 PIM。
本命令通过ACL规则中的source参数指定静态RP所服务的IPv6组播组范围,并且该规则中除source、fragment和time-range以外的其它可选参数都将被忽略。
当某个静态RP引用的ACL规则发生变化时,需要为所有IPv6组播组重新选举RP。
重复执行本命令,可以配置多个静态RP。但是,如果配置时所指定的静态RP地址或ACL规则相同,最后一次执行的命令生效;如果存在多个静态RP服务于同一组播组的情况,则选择IPv6地址最大的静态RP为该组服务。
# 在公网实例中配置IPv6地址为2001::2的接口为静态RP,为IPv6组播组FF03::101/64提供服务,并优先选择静态RP。
[Sysname] acl ipv6 basic 2001
[Sysname-acl-ipv6-basic-2001] rule permit source ff03::101 64
[Sysname] ipv6 pim
[Sysname-pim6] static-rp 2001::2 2001 preferred
timer hello命令用来全局配置发送Hello报文的时间间隔。
undo timer hello命令用来恢复缺省情况。
undo timer hello
发送Hello报文的时间间隔为30秒。
IPv6 PIM视图
# 在公网实例中全局配置发送Hello报文的时间间隔为40秒。
[Sysname] ipv6 pim
[Sysname-pim6] timer hello 40
· ipv6 pim timer hello
timer join-prune命令用来全局配置发送加入/剪枝报文的时间间隔。
undo timer join-prune命令用来恢复缺省情况。
发送加入/剪枝报文的时间间隔为60秒。
IPv6 PIM视图
# 在公网实例中全局配置发送加入/剪枝报文的时间间隔为80秒。
[Sysname] ipv6 pim
[Sysname-pim6] timer join-prune 80
· ipv6 pim timer join-prune
