01-AAA命令
本章节下载: 01-AAA命令 (1.83 MB)
1.1.2 aaa authorization-cache acl
1.1.3 aaa authorization-cache enable
1.1.4 aaa authorization-cache expiry
1.1.5 aaa authorization-cache max-number
1.1.7 aaa realtime-backup enable
1.1.8 aaa abnormal-offline-record enable
1.1.9 aaa normal-offline-record enable
1.1.10 aaa offline-record enable
1.1.11 aaa online-fail-record enable
1.1.23 authen-radius-unavailable online domain
1.1.25 authentication lan-access
1.1.31 authorization lan-access
1.1.32 authorization lan-access radius-cache enable
1.1.35 authorization-attribute (ISP domain view)
1.1.36 default critical-microsegment
1.1.38 display aaa author-profile
1.1.39 display aaa authorization-cache
1.1.40 display aaa normal-offline-record
1.1.41 display aaa online-fail-record
1.1.42 display aaa abnormal-offline-record
1.1.43 display aaa offline-record
1.1.49 if-match vpn-instance critical-microsegment
1.1.50 if-match vpn-instance microsegment
1.1.51 local-server log change-password-prompt
1.1.53 redirect move-temporarily enable
1.1.54 reset aaa abnormal-offline-record
1.1.55 reset aaa authorization-cache
1.1.56 reset aaa normal-offline-record
1.1.57 reset aaa offline-record
1.1.58 reset aaa online-fail-record
1.1.59 session-time include-idle-time
1.1.60 state (ISP domain view)
1.2.2 authorization-attribute (Local user view/user group view)
1.2.6 display local-guest waiting-approval
1.2.12 local-guest email format
1.2.13 local-guest email sender
1.2.14 local-guest email smtp-server
1.2.16 local-guest manager-email
1.2.20 local-user auto-delete enable
1.2.23 password (Device management user view)
1.2.24 password (Network access user view)
1.2.26 reset local-guest waiting-approval
1.2.27 service-type (Local user view)
1.2.28 snmp-agent trap enable local-server
1.2.32 state (Local user view)
1.3.10 attribute convert (RADIUS DAE server view)
1.3.11 attribute convert (RADIUS scheme view)
1.3.12 attribute reject (RADIUS DAE server view)
1.3.13 attribute reject (RADIUS scheme view)
1.3.14 attribute remanent-volume
1.3.18 data-flow-format (RADIUS scheme view)
1.3.21 display radius server-load statistics
1.3.22 display radius statistics
1.3.23 display stop-accounting-buffer (for RADIUS)
1.3.27 include-attribute 218 vendor-id 25506
1.3.28 key (RADIUS scheme view)
1.3.31 nas-ip (RADIUS scheme view)
1.3.33 primary accounting (RADIUS scheme view)
1.3.34 primary authentication (RADIUS scheme view)
1.3.35 radius attribute extended
1.3.36 radius attribute-test-group
1.3.37 radius authentication-request first
1.3.39 radius dynamic-author server
1.3.43 radius session-control client
1.3.44 radius session-control enable
1.3.46 radius-server authen-state-check interval
1.3.47 radius-server test-profile
1.3.48 reauthentication server-select
1.3.49 reset radius server-load statistics
1.3.50 reset radius statistics
1.3.51 reset stop-accounting-buffer (for RADIUS)
1.3.53 retry realtime-accounting
1.3.54 retry stop-accounting (RADIUS scheme view)
1.3.55 secondary accounting (RADIUS scheme view)
1.3.56 secondary authentication (RADIUS scheme view)
1.3.57 server-load-sharing enable
1.3.58 server-parallel-auth enable
1.3.59 snmp-agent trap enable radius
1.3.62 stop-accounting-buffer enable (RADIUS scheme view)
1.3.63 stop-accounting-packet send-force
1.3.65 timer quiet (RADIUS scheme view)
1.3.66 timer realtime-accounting (RADIUS scheme view)
1.3.67 timer response-timeout (RADIUS scheme view)
1.3.68 timer tls-idle-timeout (RADIUS scheme view)
1.3.69 timer tls-idle-timeout (RADIUS DAE server view)
1.3.71 user-name-format (RADIUS scheme view)
1.3.72 vpn-instance (RADIUS scheme view)
1.4.1 data-flow-format (HWTACACS scheme view)
1.4.3 display hwtacacs statistics
1.4.4 display stop-accounting-buffer (for HWTACACS)
1.4.8 key (HWTACACS scheme view)
1.4.9 nas-ip (HWTACACS scheme view)
1.4.10 primary accounting (HWTACACS scheme view)
1.4.11 primary authentication (HWTACACS scheme view)
1.4.13 reset hwtacacs statistics
1.4.14 reset stop-accounting-buffer (for HWTACACS )
1.4.15 retry stop-accounting (HWTACACS scheme view)
1.4.16 secondary accounting (HWTACACS scheme view)
1.4.17 secondary authentication (HWTACACS scheme view)
1.4.18 secondary authorization
1.4.19 snmp-agent trap enable hwtacacs
1.4.20 stop-accounting-buffer enable (HWTACACS scheme view)
1.4.21 timer quiet (HWTACACS scheme view)
1.4.22 timer realtime-accounting (HWTACACS scheme view)
1.4.23 timer response-timeout (HWTACACS scheme view)
1.4.24 user-name-format (HWTACACS scheme view)
1.4.25 vpn-instance (HWTACACS scheme view)
1.6.1 display radius-server active-client
1.6.2 display radius-server active-user
1.7.1 aaa connection-recording policy
aaa author-profile命令用来创建授权策略模板,并进入授权策略模板视图。如果指定的授权策略模板已经存在,则直接进入授权策略模板视图。
undo aaa author-profile命令用来删除指定的授权策略模板。
aaa author-profile profile-name
undo aaa author-profile profile-name
不存在授权策略模板。
profile-name:授权策略模板的名称,为1~31个字符的字符串,不区分大小写。
域内用户获取授权属性的途径包括三种:服务器授权、认证域下配置的授权属性、认证域下引用的授权策略模板。其中,服务器授权优先级最高,其次为域下配置的授权属性,仅当以上两者都不存在的情况下,才会采用认证域下引用的授权策略模板。
授权策略模板是一组授权属性的集合,可用于基于VPN授权网络资源,例如为不同的VPN用户授权不同的微分段。通过配置授权策略模板,并在用户所在的认证域中引用该模板,可以使得域内用户获得该模板内配置的相关网络资源。
系统支持配置多个授权策略模板,最多允许配置16个授权策略模板。
如果授权策略模板发生变化,包括授权策略模板被删除、模板的配置发生变化,不会对已经使用该授权策略模板的用户产生影响,仅对变化发生后新上线的用户生效。
# 创建授权策略模板abc,并进入授权策略模板视图。
[Sysname] aaa author-profile abc
[Sysname-author-profile-abc]
· display aaa author-profile
aaa authorization-cache acl命令用来配置匹配ACL规则用户的授权信息缓存过期时间。
undo aaa authorization-cache acl命令用来恢复缺省情况。
aaa authorization-cache acl acl-number expiry expiry-time
授权信息缓存的过期时间为aaa authorization-cache expiry配置的时间。
acl-number:指定访问控制列表编号,取值范围为4000~4999。
expiry expiry-time:指定授权信息缓存的过期时间,取值范围为0~2147483647,单位为小时。若过期时间取值为0,则表示授权信息缓存不会老化。
当用户下线后,设备将启动授权信息缓存的过期定时器。如果用户的MAC地址在配置的ACL规则中为允许,则过期定时器使用本命令配置的过期时间。否则,设备过期定时器使用aaa authorization-cache expiry命令配置的过期时间。
若用户下线后不再上线,且配置的过期时间为0,则会导致该用户的授权信息缓存残留。此时,可以通过display aaa authorization-cache命令查看残留的缓存信息,并使用reset aaa authorization-cache命令删除该缓存信息。
本命令配置的过期时间对已生成的授权信息缓存不影响。
多次执行本命令,可以配置最多16个ACL规则。
在M-LAG组网中,两端M-LAG设备上的配置需要保持一致。
# 配置匹配ACL规则为4000的用户的授权信息缓存过期时间为10小时。
[Sysname] aaa authorization-cache acl 4000 expiry 10
· aaa authorization-cache expiry
aaa authorization-cache enable命令用来开启AAA用户授权信息缓存功能。
undo authorization-cache enable命令用来关闭AAA用户授权信息缓存功能。
undo aaa authorization-cache enable
AAA用户授权信息缓存功能处于关闭状态。
开启本功能后,各ISP域下的认证过程将可以记录和查询用户的部分授权信息缓存。当关闭本功能后,所有ISP域下的认证将停止记录和查询用户的授权信息缓存,设备将立即删除当前记录的授权信息缓存。
AAA记录的授权信息可以通过display aaa authorization-cache命令查看。
# 开启AAA用户授权信息缓存功能。
[Sysname] aaa authorization-cache enable
· display aaa authorization-cache
· reset aaa authorization-cache
aaa authorization-cache expiry命令用来配置授权信息缓存的过期时间。
undo aaa authorization-cache expiry命令用来恢复缺省情况。
aaa authorization-cache expiry expiry-time
授权信息缓存的过期时间为336小时。
expiry-time:授权信息缓存的过期时间,取值范围为0~2147483647,单位为小时。
当用户下线后,设备将启动授权信息缓存的过期定时器,若用户在到达本命令配置的过期时间时没有再次通过RADIUS认证登录,则设备将删除该用户的授权信息缓存。
# 配置授权信息缓存的过期时间为10小时。
[Sysname] aaa authorization-cache expiry 10
aaa authorization-cache max-number命令用来配置AAA用户授权信息缓存功能的最大记录条数。
undo authorization-cache max-number命令用来恢复缺省情况。
aaa authorization-cache max-number max-number
undo aaa authorization-cache max-number
AAA用户授权信息缓存功能的最大记录条数为8K条。
max-number:授权信息缓存的记录条数,取值范围为1~4294967295。
开启AAA用户授权信息缓存功能后,各ISP域下的认证过程会生成用户的授权信息缓存并记录,该授权缓存信息在设备上能保存的最大条数可由本命令进行修改,最大支持4294967295。
超出最大条数的授权缓存信息将会被丢弃,不会添加到设备中。该配置在AAA授权缓存信息全局开关打开后生效。
# 修改AAA用户授权信息缓存功能的最大记录条数为10K条。
[Sysname] aaa authorization-cache max-number 10000
· aaa authorization-cache enable
aaa nas-id profile命令用来创建NAS-ID Profile,并进入NAS-ID-Profile视图。如果指定的NAS-ID Profile已经存在,则直接进入NAS-ID-Profile视图。
undo aaa nas-id profile命令用来删除指定的NAS-ID Profile。
undo aaa nas-id profile profile-name
不存在NAS-ID Profile。
profile-name:Profile名称,为1~31个字符的字符串,不区分大小写。
在某些应用环境中,网络运营商需要使用接入设备发送给RADIUS服务器的NAS-Identifier属性值来获知用户的接入位置,而用户的接入VLAN可标识用户的接入位置,因此接入设备上可通过建立用户接入VLAN与指定的NAS-ID之间的绑定关系来实现接入位置信息的映射。NAS-ID Profile用于保存NAS-ID和VLAN的绑定关系。这样,当用户上线时,设备会将与用户接入VLAN匹配的NAS-ID填充在RADIUS请求报文中的NAS-Identifier属性中发送给RADIUS服务器。
若以上配置都不存在,则使用设备的名称作为NAS-ID。
# 创建一个名称为aaa的NAS-ID Profile,并进入NAS-ID-Profile视图。
[Sysname] aaa nas-id profile aaa
[Sysname-nas-id-prof-aaa]
· nas-id bind vlan
· port-security nas-id-profile(安全命令参考/端口安全)
· portal nas-id-profile(安全命令参考/Portal)
aaa realtime-backup enable命令用来开启AAA用户上下线记录的实时备份功能。
undo aaa realtime-backup enable命令用来关闭AAA用户上下线记录的实时备份功能。
aaa { abnormal-offline-record | normal-offline-record | online-fail-record } * realtime-backup enable
undo aaa { abnormal-offline-record | normal-offline-record | online-fail-record } * realtime-backup enable
AAA用户上下线记录的实时备份功能处于关闭状态。
abnormal-offline-record:表示配置AAA用户异常下线记录的备份模式。
normal-offline-record:表示配置AAA用户正常下线记录的备份模式。
online-fail-record:表示配置AAA用户上线失败记录的备份模式。
在非实时备份模式下,AAA业务模块不会备份AAA用户上下线记录数据到设备。
在实时备份工作模式下,为避免因进程异常重启或者主备倒换等情况造成的数据丢失,AAA业务模块会将AAA用户上下线记录数据实时备份到设备。
如果当前配置为非实时备份,在指定种类的AAA用户上下线记录的备份模式配置为实时备份时,会立刻触发一次备份当前内存中指定种类的AAA用户上下线记录到设备的操作;如果当前配置为实时备份,在指定种类AAA用户上下线记录的备份模式配置为非实时备份时,会同步删除设备中备份的对应数据。因此,在大量AAA用户上下线记录存在的情况下,不建议频繁执行本命令切换AAA业务模块的数据备份模式,否则可能影响设备性能。
本功能需要先开启对应的用户上下线记录功能才能生效。
# 开启AAA用户上线失败记录的实时备份功能。
[Sysname] aaa online-fail-record realtime-backup enable
· aaa abnormal-offline-record enable
· aaa normal-offline-record enable
· aaa offline-record enable
· aaa online-fail-record enable
· display aaa abnormal-offline-record
· display aaa normal-offline-record
· display aaa online-fail-record
· reset aaa abnormal-offline-record
· reset aaa normal-offline-record
· reset aaa online-fail-record
aaa abnormal-offline-record enable命令用来开启用户异常下线记录功能。
undo aaa abnormal-offline-record enable命令用来关闭用户异常下线记录功能。
用户异常下线记录功能处于关闭状态。
开启本功能后,系统会将所有异常下线的用户信息(用户基本信息、下线原因等)记录到系统内存中,方便管理员进行管理和故障定位,具体内容可通过display aaa abnormal-offline-record命令进行查看。当管理员需要分析用户下线原因以及解决用户异常下线问题时,建议开启本功能。
只有用户下线记录功能处于开启状态,本功能才能生效。
设备最多支持存储32768条用户异常下线记录,超过该数目后,新的记录会覆盖旧的记录。
关闭本功能后,系统停止记录用户异常下线信息,可提高当前可用内存容量,但管理员将看不到用户异常下线信息,存在一定风险。
# 开启用户异常下线记录功能。
[Sysname] aaa abnormal-offline-record enable
aaa normal-offline-record enable命令用来开启用户正常下线记录功能。
undo aaa normal-offline-record enable命令用来关闭用户正常下线记录功能。
用户正常下线记录功能处于关闭状态。
开启本功能后,设备会将所有用户正常下线信息(用户基本信息、下线原因等)记录到系统内存中,具体内容可通过display aaa normal-offline-record命令进行查看。当管理员需要分析用户下线原因时,建议开启本功能。
设备最多支持存储32768条用户正常下线记录,超过该数目后,新的记录会覆盖旧的记录。
关闭本功能后,系统停止记录用户正常下线信息,可提高当前可用内存容量,但管理员将看不到用户正常下线信息。
# 开启用户正常下线记录功能。
[Sysname] aaa normal-offline-record enable
aaa offline-record enable命令用来开启用户下线记录功能。
undo aaa offline-record enable命令用来关闭用户下线记录功能。
用户下线记录功能处于关闭状态。
本功能用于总体控制用户下线记录功能是否开启。只有本功能处于开启状态,用户正常下线记录功能和用户异常下线记录功能才能生效。
开启本功能后,若用户正常下线记录功能、用户异常下线记录功能处于开启状态,设备会将所有用户正常下线、用户异常下线的信息(用户基本信息、下线原因等)记录到系统内存中,具体内容可通过display aaa offline-record命令进行查看。
设备最多支持存储65536条用户下线记录,超过该数目后,新的记录会覆盖旧的记录。
关闭本功能后,用户下线信息不会被记录到系统内存中,可提高系统当前可用内存容量,但管理员将看不到用户下线信息。
# 开启用户下线记录功能。
[Sysname] aaa offline-record enable
· display aaa offline-record
aaa online-fail-record enable命令用来开启用户上线失败记录功能。
undo aaa online-fail-record enable命令用来关闭用户上线失败记录功能。
用户上线失败记录功能处于关闭状态。
开启本功能后,设备会将所有用户上线失败信息(用户基本信息、上线失败原因等)记录到系统内存中,具体内容可通过display aaa online-fail-record命令进行查看。当管理员需要获取用户上线失败记录,以对恶意用户进行初步排查时,建议开启本功能。
设备最多支持存储32768条用户上线失败记录,超过该数目后,新的记录会覆盖旧的记录。
关闭本功能后,系统停止记录用户上线失败信息,可提高当前可用内存容量,但管理员将看不到用户上线失败信息,存在一定风险。
# 开启用户上线失败记录功能
[Sysname] aaa online-fail-record enable
aaa session-limit命令用来配置同时在线的最大用户连接数,即采用指定登录方式登录设备并同时在线的用户数。
undo aaa session-limit命令用来将指定登录方式的同时在线的最大用户连接数恢复为缺省情况。
(非FIPS模式)
aaa session-limit { ftp | http | https | ssh | telnet } max-sessions
undo aaa session-limit { ftp | http | https | ssh | telnet }
(FIPS模式)
aaa session-limit { https | ssh } max-sessions
undo aaa session-limit { https | ssh }
同时在线的各类型最大用户连接数均为32。
ftp:表示FTP用户。
http:表示HTTP用户。
https:表示HTTPS用户。
ssh:表示SSH用户。
telnet:表示Telnet用户。
max-sessions:允许同时在线的最大用户连接数,FTP/SSH/Telnet用户的取值范围为1~32,HTTP/HTTPS用户的取值范围为1~64。
配置本命令后,当指定类型的接入用户的用户数超过当前配置的最大连接数后,新的接入请求将被拒绝。
对于HTTP/HTTPS用户,不同上层应用的最大用户连接数单独受限。例如,若设置允许同时在线的HTTP最大用户连接数为20,则基于HTTP的RESTful用户、Web用户、NETCONF用户的最大连接数将均为20。
# 设置同时在线的最大FTP用户连接数为4。
[Sysname] aaa session-limit ftp 4
accounting command命令用来配置命令行计费方法。
undo accounting command命令用来恢复缺省情况。
accounting command hwtacacs-scheme hwtacacs-scheme-name
命令行计费采用当前ISP域的缺省计费方法。
ISP域视图
hwtacacs-scheme hwtacacs-scheme-name:指定HWTACACS方案。其中,hwtacacs-scheme-name表示HWTACACS方案名,为1~32个字符的字符串,不区分大小写。
命令行计费过程是指,用户执行过的合法命令会被发送给计费服务器进行记录。若未开启命令行授权功能,则计费服务器对用户执行过的所有合法命令进行记录;若开启了命令行授权功能,则计费服务器仅对授权通过的命令进行记录。
目前,仅支持使用远程HWTACACS服务器完成命令行计费功能。
# 在ISP域test下,配置使用HWTACACS计费方案hwtac进行命令行计费。
[Sysname] domain test
[Sysname-isp-test] accounting command hwtacacs-scheme hwtac
· accounting default
· command accounting(基础配置命令参考/登录设备)
· hwtacacs scheme
accounting default命令用来为当前ISP域配置缺省的计费方法。
undo accounting default命令用来恢复缺省情况。
(非FIPS模式)
accounting default { hwtacacs-scheme hwtacacs-scheme-name [ radius-scheme radius-scheme-name ] [ local ] [ none ] | local [ radius-scheme radius-scheme-name | hwtacacs-scheme hwtacacs-scheme-name ] * [ none ] | none | radius-scheme radius-scheme-name [ hwtacacs-scheme hwtacacs-scheme-name ] [ local ] [ none ] }
(FIPS模式)
accounting default { hwtacacs-scheme hwtacacs-scheme-name [ radius-scheme radius-scheme-name ] [ local ] | local [ radius-scheme radius-scheme-name | hwtacacs-scheme hwtacacs-scheme-name ] * | radius-scheme radius-scheme-name [ hwtacacs-scheme hwtacacs-scheme-name ] [ local ] }
当前ISP域的缺省计费方法为local。
ISP域视图
local:本地计费。
none:不计费。
radius-scheme radius-scheme-name:指定RADIUS方案。其中,radius-scheme-name表示RADIUS方案名,为1~32个字符的字符串,不区分大小写。
当前ISP域的缺省计费方法对于该域中未指定具体计费方法的所有接入用户都起作用,但是如果某类型的用户不支持指定的计费方法,则该计费方法对于这类用户不能生效。
本地计费只是为了支持本地用户的连接数管理,没有实际的计费相关的统计功能。
可以指定多个备选的计费方法,在当前的计费方法无效时按照配置顺序尝试使用备选的方法完成计费。例如,radius-scheme radius-scheme-name local none表示,先进行RADIUS计费,若RADIUS计费无效则进行本地计费,若本地计费也无效则不进行计费。远程计费无效是指,指定的计费方案不存在、计费报文发送失败或者服务器无响应。本地计费无效是指没有找到对应的本地用户配置。
当采用本地计费方法为主计费方法,且配置了备选计费方法时,仅当AAA处理过程异常、用户与设备断开连接或者没有本地用户配置的情况下,用户本地计费失败后才会尝试使用备选方法进行计费,其它情况下不会转换计费方法,直接认为计费失败。
# 在ISP域test下,配置缺省计费方法为使用RADIUS方案rd进行计费,并且使用local作为备选计费方法。
[Sysname-isp-test] accounting default radius-scheme rd local
· hwtacacs scheme
· local-user
· radius scheme
accounting lan-access命令用来为lan-access用户配置计费方法。
undo accounting lan-access命令用来恢复缺省情况。
(非FIPS模式)
accounting lan-access { broadcast radius-scheme radius-scheme-name1 radius-scheme radius-scheme-name2 [ local ] [ none ] | local [ radius-scheme radius-scheme-name ] [ none ] | none | radius-scheme radius-scheme-name [ local ] [ none ] }
(FIPS模式)
accounting lan-access { broadcast radius-scheme radius-scheme-name1 radius-scheme radius-scheme-name2 [ local ] | local [ radius-scheme radius-scheme-name ] | radius-scheme radius-scheme-name [ local ] }
lan-access用户采用当前ISP域的缺省计费方法。
ISP域视图
broadcast:指定广播RADIUS方案,即同时向指定的两个RADIUS方案中的计费服务器发送计费请求。
radius-scheme radius-scheme-name1:表示主送计费RADIUS方案名,为1~32个字符的字符串,不区分大小写;
radius-scheme radius-scheme-name2:表示抄送计费RADIUS方案名,为1~32个字符的字符串,不区分大小写。
local:本地计费。
none:不计费。
可以指定多个备选的计费方法。在当前的计费方法无效时按照配置顺序尝试使用备选的方法完成计费。例如,radius-scheme radius-scheme-name local none表示,先进行RADIUS计费,若RADIUS计费无效则进行本地计费,若本地计费也无效则不进行计费。远程计费无效是指,指定的计费方案不存在、计费报文发送失败或者服务器无响应。本地计费无效是指没有找到对应的本地用户配置。
指定broadcast关键字的情况下,设备将以主送RADIUS方案中的实时计费间隔同时向指定的两个RADIUS方案里的主计费服务器发送计费开始/更新/停止请求,若某RADIUS方案里的主计费服务器不可达,则按照配置顺序依次尝试向该RADIUS方案里的从计费服务器发送计费请求。主送计费方案计费成功时,表示用户计费成功;抄送计费方案的计费结果对用户无影响。
# 在ISP域test下,为lan-access用户配置计费方法为local。
[Sysname-isp-test] accounting lan-access local
# 在ISP域test下,配置lan-access用户使用RADIUS方案rd进行计费,并且使用local作为备选计费方法。
[Sysname-isp-test] accounting lan-access radius-scheme rd local
# 在ISP域test下,配置lan-access用户使用RADIUS方案rd1和rd2进行广播计费,并且使用local作为备选计费方法。
[Sysname-isp-test] accounting lan-access broadcast radius-scheme rd1 radius-scheme rd2 local
· local-user
· radius scheme
· timer realtime-accounting
accounting login命令用来为login用户配置计费方法。
undo accounting login命令用来恢复缺省情况。
(非FIPS模式)
accounting login { hwtacacs-scheme hwtacacs-scheme-name [ radius-scheme radius-scheme-name ] [ local ] [ none ] | local [ radius-scheme radius-scheme-name | hwtacacs-scheme hwtacacs-scheme-name ] * [ none ] | none | radius-scheme radius-scheme-name [ hwtacacs-scheme hwtacacs-scheme-name ] [ local ] [ none ] }
(FIPS模式)
accounting login { hwtacacs-scheme hwtacacs-scheme-name [ radius-scheme radius-scheme-name ] [ local ] | local [ radius-scheme radius-scheme-name | hwtacacs-scheme hwtacacs-scheme-name ] * | radius-scheme radius-scheme-name [ hwtacacs-scheme hwtacacs-scheme-name ] [ local ] }
login用户采用当前ISP域的缺省计费方法。
ISP域视图
local:本地计费。
none:不计费。
不支持对FTP、SFTP以及SCP类型的login用户进行计费。
# 在ISP域test下,为login用户配置计费方法为local。
[Sysname-isp-test] accounting login local
# 在ISP域test下,配置login用户使用RADIUS方案rd进行计费,并且使用local作为备选计费方法。
[Sysname-isp-test] accounting login radius-scheme rd local
· hwtacacs scheme
· local-user
· radius scheme
accounting portal命令用来为Portal用户配置计费方法。
undo accounting portal命令用来恢复缺省情况。
(非FIPS模式)
accounting portal { broadcast radius-scheme radius-scheme-name1 radius-scheme radius-scheme-name2 [ local ] [ none ] | local [ radius-scheme radius-scheme-name ] [ none ] | none | radius-scheme radius-scheme-name [ local ] [ none ] }
(FIPS模式)
accounting portal { broadcast radius-scheme radius-scheme-name1 radius-scheme radius-scheme-name2 [ local ] | local [ radius-scheme radius-scheme-name ] | radius-scheme radius-scheme-name [ local ] }
Portal用户采用当前ISP域的缺省计费方法。
ISP域视图
local:本地计费。
none:不计费。
# 在ISP域test下,为Portal用户配置计费方法为local。
[Sysname-isp-test] accounting portal local
# 在ISP域test下,配置Portal用户使用RADIUS方案rd进行计费,并且使用local作为备选计费方法。
[Sysname-isp-test] accounting portal radius-scheme rd local
# 在ISP域test下,配置Portal用户使用RADIUS方案rd1和rd2进行广播计费,并且使用local作为备选计费方法。
[Sysname-isp-test] accounting portal broadcast radius-scheme rd1 radius-scheme rd2 local
· local-user
· radius scheme
accounting quota-out命令用来配置用户计费配额(流量或时长)耗尽策略。
undo accounting quota-out命令用来恢复缺省情况。
accounting quota-out { offline | online }
用户的计费配额耗尽后将被强制下线。
ISP域视图
offline:当用户的整体配额耗尽后,强制用户下线。
online:当用户的整体配额耗尽后,允许用户保持在线状态。
需要注意的是,如果配置的用户计费配额耗尽策略为offline,则当服务器为Portal用户授权了计费配额时,强制该类用户下线的时间可能会不准确。
# 在ISP域test下,配置用户计费配额耗尽策略为:当配额耗尽后用户仍能保持在线状态。
[Sysname-isp-test] accounting quota-out online
accounting start-fail命令用来配置用户计费开始失败策略,即设备向计费服务器发送计费开始请求失败后,是否允许用户接入网络。
undo accounting start-fail命令用来恢复缺省情况。
accounting start-fail { offline | online }
如果用户计费开始失败,允许用户保持在线状态。
ISP域视图
offline:强制用户下线。
online:允许用户保持在线状态。
# 在ISP域test下,配置计费开始失败策略为:用户计费开始失败时允许用户保持在线状态。
[Sysname-isp-test] accounting start-fail online
accounting update-fail命令用来配置用户计费更新失败策略,即设备向计费服务器发送用户的计费更新报文失败时,是否允许用户接入网络。
undo accounting update-fail命令用来恢复缺省情况。
accounting update-fail { [ max-times max-times ] offline | online }
如果用户计费更新失败,允许用户保持在线状态。
ISP域视图
max-times max-times:允许用户连续计费更新失败的次数,取值范围1~255,缺省值为1。该参数仅对Portal用户生效,其它用户固定取值为1。
offline:如果用户连续计费更新失败的次数达到了指定的次数,则强制用户下线。
online:如果用户计费更新失败,允许用户保持在线状态。
假设设备发送RADIUS报文的最大尝试次数(retry命令设置)为x,设备的实时计费间隔(timer realtime-accounting命令设置)为y分钟,设备允许实时计费无响应的最大次数为z次(retry realtime-accounting命令设置),本命令设置的连续计费更新失败次数max-times为m,则:
· 对于Portal用户
设备每隔y分钟发起一次计费请求,如果在RADIUS服务器应答超时时长内得不到回应就重新发送一次计费请求报文。如果设备发送的x个计费请求报文都没有得到回应,就认为该次实时计费失败。如果连续(z×m)次尝试均失败,设备将认为用户计费更新失败。
· 对于其它用户
设备每隔y分钟发起一次计费请求,如果在RADIUS服务器应答超时时长内得不到回应就重新发送一次计费请求报文。如果设备发送的x个计费请求报文都没有得到回应,就认为该次实时计费失败。如果连续z次尝试均失败,设备将认为用户计费更新失败。
# 在ISP域test下,配置计费更新失败策略为:用户计费更新失败时允许用户保持在线状态。
[Sysname-isp-test] accounting update-fail online
· retry
· retry realtime-accounting
authen-fail命令用来配置用户认证失败后采取的处理策略。
undo authen-fail命令用来恢复缺省情况。
authen-fail { offline | online domain new-isp-name no-authen }
undo authen-fail
用户认证失败后采取的处理策略是无法成功上线,处于下线状态。
ISP域视图
offline:无法成功上线,处于下线状态。
online:处于在线状态。
domain new-isp-name:指定认证失败域,即认证失败后重新加入的域。new-isp-name表示ISP域的名称,为1~255个字符的字符串,不区分大小写,不能包括“/”、“\”、“|”、“””、“:”、“*”、“?”、“<”、“>”以及“@”字符,且必须已经存在。
no-authen:用户重新加入新域后,不需要重新进行认证,仅对其使用新域进行重新授权和计费。
不同的组网环境中,对于用户认证失败后的处理策略有所不同。缺省情况下,用户认证失败后无法成功上线。如果希望用户在首次认证失败后有机会尝试其它的授权/计费方案,则可以使其处于在线状态,并转至指定的认证失败域内重新进行授权/计费。认证失败域内也会预先配置一套独立的授权和计费策略,为加入此域的用户提供一定的网络资源。
被指定为认证失败后要切换的域不允许删除。若要删除该域,请先执行undo authen-fail命令取消对该域的引用。
该功能仅有线端口安全用户支持。
以下情况不会采用认证失败域:
· 因认证超时导致的认证失败,例如认证服务器无响应等。
· 因认证域的状态为block而引起的认证失败。
# 在ISP域视图test下,配置用户认证失败后采取的处理策略为:将用户加入新域dm1,且不需要重新进行认证,仅对其使用新域进行重新授权和计费。
[Sysname-isp-test] authen-fail online domain dm1 no-authen
· display domain
authen-radius-recover命令用来指定当用户因为RADIUS服务器不可达逃生后,在服务器恢复可达时的处理策略。
undo authen-radius-recover命令用来恢复缺省情况。
authen-radius-recover { offline | online domain new-isp-name | re-authen }
未指定用户因为RADIUS服务器不可达逃生后,在服务器又恢复可达时的处理策略。
ISP域视图
offline:用户直接下线。
online:用户保持在线,并切换到逃生恢复域。
domain new-isp-name:指定逃生恢复域。new-isp-name表示ISP域的名称,为1~255个字符的字符串,不区分大小写,不能包括“/”、“\”、“|”、“””、“:”、“*”、“?”、“<”、“>”以及“@”字符,且必须已经存在。
re-authen:触发用户返回到逃生之前所在的认证域中进行重认证。本参数仅适用于802.1X认证、MAC地址认证用户。
本特性仅适用于802.1X认证、MAC地址认证和Web认证用户。
不同的组网环境中,对于用户因为RADIUS服务器不可达切换到逃生域后,任一服务器又恢复可达时的处理策略有所不同:
· 如果希望用户重新进行认证/授权/计费,则可以直接使其下线。
· 如果希望用户保持在线,且无需重新认证,可配置一个逃生恢复域。
· 如果希望对用户直接重新认证,且无需用户感知,则可以配置重认证。
需要注意的是,当前通过online domain参数指定任一逃生恢复域后,用户并不会立即进入逃生恢复域,而是仍停留在逃生域中保持在线,直到服务器恢复可达时才会进入逃生恢复域。
关于逃生恢复域的配置,有如下使用指导和限制:
· 如果用户逃生之前所在的原认证域中,为RADIUS认证方案配置了none备份方案,则RADIUS服务器从不可达恢复为可达时,用户也会进入配置的逃生恢复域。
· 为了准确地判断RADIUS认证服务器是否可达,使得逃生恢复措施及时生效,建议配置RADIUS服务器探测功能。
· 被指定为逃生恢复域的域不允许删除。若要删除该域,请先执行undo authen-radius-recover命令取消对该域的引用。
· 目前,指定的逃生恢复域必须与该命令行所在的ISP视图同名。
# 在ISP域test下,指定当用户因为RADIUS服务器不可达逃生后,在服务器恢复可达时用户下线。
[Sysname-isp-test] authen-radius-recover offline
· authen-radius-unavailable online domain
· display domain
· radius-server test-profile
authen-radius-unavailable online domain命令用来配置用户认证过程中,RADIUS服务器不可达时的逃生域。
undo authen-radius-unavailable online domain命令用来恢复缺省情况。
authen-radius-unavailable online domain new-isp-name
未指定用户认证过程中RADIUS服务器不可达时的逃生域。
ISP域视图
new-isp-name:ISP域名,为1~255个字符的字符串,不区分大小写,不能包括“/”、“\”、“|”、“””、“:”、“*”、“?”、“<”、“>”以及“@”字符,且必须已经存在。
在用户认证过程中,如果出现认证方案下的所有RADIUS服务器不可达状况,设备发出的RADIUS认证请求报文将无法得到回应,从而影响用户正常上线。通过在当前域下配置逃生域,可以在这种情况发生时,保证用户能够“逃离”当前域,在新域中进行上线。通常情况下,逃生行为只是一个应急措施,因此用户可以无需再次认证而直接上线。
用户逃生后,仅当原认证域中的认证RADIUS服务器恢复可达,且原认证域中配置了逃生恢复域,用户才会离开逃生域。
关于逃生域的配置,有如下使用指导和限制:
· 逃生域不支持嵌套配置,包括两种情况:逃生域中配置的逃生域不会生效,已经配置了逃生域的认证域被指定为其它认证域的逃生域时不会生效。
· 被指定为逃生域的ISP域不允许删除。若要删除该域,请先执行undo authen-radius-unavailable online domain命令取消对该域的引用。
· 如果逃生域中配置了非none的认证/授权/计费方案,用户将不会使用该域的方案重新进行认证、授权,而是保持在线的情况下使用该域的计费方案进行计费。由于这会额外增加用户信息管理的成本,除非必要,通常不建议采用这种配置方式。
# 在ISP域test下,指定用户认证过程中,RADIUS服务器不可达时的逃生域为dm1。
[Sysname-isp-test] authen-radius-unavailable online domain dm1
· authen-radius-recover
· display domain
authentication default命令用来为当前ISP域配置缺省的认证方法。
undo authentication default命令用来为恢复缺省情况。
(非FIPS模式)
authentication default { hwtacacs-scheme hwtacacs-scheme-name [ radius-scheme radius-scheme-name ] [ local ] [ none ] | ldap-scheme ldap-scheme-name [ local ] [ none ] | local [ radius-scheme radius-scheme-name | hwtacacs-scheme hwtacacs-scheme-name ] * [ none ] | local [ ldap-scheme ldap-scheme-name ] [ none ] | none | radius-scheme radius-scheme-name [ hwtacacs-scheme hwtacacs-scheme-name ] [ local ] [ none ] }
(FIPS模式)
authentication default { hwtacacs-scheme hwtacacs-scheme-name [ radius-scheme radius-scheme-name ] [ local ] | ldap-scheme ldap-scheme-name [ local ] | local [ radius-scheme radius-scheme-name | hwtacacs-scheme hwtacacs-scheme-name ] * | local [ ldap-scheme ldap-scheme-name ] | radius-scheme radius-scheme-name [ hwtacacs-scheme hwtacacs-scheme-name ] [ local ] }
当前ISP域的缺省认证方法为local。
ISP域视图
ldap-scheme ldap-scheme-name:指定LDAP方案。其中ldap-scheme-name表示LDAP方案名,为1~32个字符的字符串,不区分大小写。
local:本地认证。
none:不进行认证。
当前ISP域的缺省的认证方法对于该域中未指定具体认证方法的所有接入用户都起作用,但是如果某类型的用户不支持指定的认证方法,则该认证方法对于这类用户不能生效。
可以指定多个备选的认证方法,在当前的认证方法无效时按照配置顺序尝试使用备选的方法完成认证。例如,radius-scheme radius-scheme-name local none表示,先进行RADIUS认证,若RADIUS认证无效则进行本地认证,若本地认证也无效则不进行认证。远程认证无效是指,指定的认证方案不存在、认证报文发送失败或者服务器无响应。本地认证无效是指没有找到对应的本地用户配置。
当采用本地认证方法为主认证方法,且配置了备选认证方法时,仅当AAA处理过程异常、用户与设备断开连接或者没有本地用户配置的情况下,用户本地认证失败后才会尝试使用备选方法进行认证,其它情况下不会转换认证方法,直接认为认证失败。
# 在ISP域test下,配置缺省认证方法为使用RADIUS方案rd进行认证,并且使用local作为备选认证方法。
[Sysname-isp-test] authentication default radius-scheme rd local
· hwtacacs scheme
· ldap scheme
· local-user
· radius scheme
authentication lan-access命令用来为lan-access用户配置认证方法。
undo authentication lan-access命令用来恢复缺省情况。
(非FIPS模式)
authentication lan-access { ldap-scheme ldap-scheme-name [ local ] [ none ] | local [ ldap-scheme ldap-scheme-name | radius-scheme radius-scheme-name ] [ none ] | none | radius-scheme radius-scheme-name [ local ] [ none ] }
(FIPS模式)
authentication lan-access { ldap-scheme ldap-scheme-name [ local ] | local [ ldap-scheme ldap-scheme-name | radius-scheme radius-scheme-name ] | radius-scheme radius-scheme-name [ local ] }
lan-access用户采用当前ISP域的缺省认证方法。
ISP域视图
local:本地认证。
none:不进行认证。
# 在ISP域test下,为lan-access用户配置认证方法为local。
[Sysname-isp-test] authentication lan-access local
# 在ISP域test下,配置lan-access用户使用RADIUS方案rd进行认证,并且使用local作为备选认证方法。
[Sysname-isp-test] authentication lan-access radius-scheme rd local
· authentication default
· ldap scheme
· local-user
· radius scheme
authentication login命令用来为login用户配置认证方法。
undo authentication login命令用来恢复缺省情况。
(非FIPS模式)
authentication login { hwtacacs-scheme hwtacacs-scheme-name [ radius-scheme radius-scheme-name ] [ local ] [ none ] | ldap-scheme ldap-scheme-name [ local ] [ none ] | local [ radius-scheme radius-scheme-name | hwtacacs-scheme hwtacacs-scheme-name ] * [ none ] | local [ ldap-scheme ldap-scheme-name ] [ none ] | none | radius-scheme radius-scheme-name [ hwtacacs-scheme hwtacacs-scheme-name ] [ local ] [ none ] }
(FIPS模式)
authentication login { hwtacacs-scheme hwtacacs-scheme-name [ radius-scheme radius-scheme-name ] [ local ] | ldap-scheme ldap-scheme-name [ local ] | local [ radius-scheme radius-scheme-name | hwtacacs-scheme hwtacacs-scheme-name ] * | local [ ldap-scheme ldap-scheme-name ] | radius-scheme radius-scheme-name [ hwtacacs-scheme hwtacacs-scheme-name ] [ local ] }
login用户采用当前ISP域的缺省认证方法。
ISP域视图
local:本地认证。
none:不进行认证。
# 在ISP域test下,为login用户配置认证方法为local。
[Sysname-isp-test] authentication login local
# 在ISP域test下,配置login用户使用RADIUS方案rd进行认证,并且使用local作为备选认证方法。
[Sysname-isp-test] authentication login radius-scheme rd local
· hwtacacs scheme
· ldap scheme
· local-user
· radius scheme
authentication portal命令用来为Portal用户配置认证方法。
undo authentication portal命令用来恢复缺省情况。
(非FIPS模式)
authentication portal { ldap-scheme ldap-scheme-name [ local ] [ none ] | local [ ldap-scheme ldap-scheme-name | radius-scheme radius-scheme-name ] [ none ] | none | radius-scheme radius-scheme-name [ local ] [ none ] }
(FIPS模式)
authentication portal { ldap-scheme ldap-scheme-name [ local ] | local [ ldap-scheme ldap-scheme-name | radius-scheme radius-scheme-name ] | radius-scheme radius-scheme-name [ local ] }
Portal用户采用当前ISP域的缺省认证方法。
ISP域视图
local:本地认证。
none:不进行认证。
# 在ISP域test下,为Portal用户配置认证方法为local。
[Sysname-isp-test] authentication portal local
# 在ISP域test下,配置Portal用户使用RADIUS方案rd进行认证,并且使用local作为备选认证方法。
[Sysname-isp-test] authentication portal radius-scheme rd local
· ldap scheme
· local-user
· radius scheme
authentication super命令用来配置用户角色切换认证方法。
undo authentication super命令用来恢复缺省情况。
authentication super { hwtacacs-scheme hwtacacs-scheme-name | radius-scheme radius-scheme-name } *
用户角色切换认证采用当前ISP域的缺省认证方法。
ISP域视图
切换用户角色是指在不退出当前登录、不断开当前连接的前提下修改用户的用户角色,改变用户所拥有的命令行权限。为了保证切换操作的安全性,需要在用户执行用户角色切换时进行身份认证。设备支持本地和远程两种认证方式,关于用户角色切换的详细介绍请参见“基础配置指导”中的“RBAC”。
可以指定一个备选的认证方法,在当前的认证方法无效时尝试使用备选的方法完成认证。
# 在ISP域test下,配置使用HWTACACS方案tac进行用户角色切换认证。
[Sysname] super authentication-mode scheme
[Sysname-isp-test] authentication super hwtacacs-scheme tac
· hwtacacs scheme
· radius scheme
authorization command命令用来配置命令行授权方法。
undo authorization command命令用来恢复缺省情况。
(非FIPS模式)
authorization command { hwtacacs-scheme hwtacacs-scheme-name [ local ] [ none ] | local [ none ] | none }
(FIPS模式)
authorization command { hwtacacs-scheme hwtacacs-scheme-name [ local ] | local }
命令行授权采用当前ISP域的缺省授权方法。
ISP域视图
local:本地授权。
none:不授权。用户执行角色所允许的命令时,无须接受授权服务器的检查。
命令行授权是指,用户执行的每一条命令都需要接受授权服务器的检查,只有授权成功的命令才被允许执行。用户登录后可以执行的命令受登录授权的用户角色和命令行授权的用户角色的双重限制,即,仅登录授权的用户角色和命令行授权的用户角色均允许执行的命令行,才能被执行。需要注意的是,命令行授权功能只利用角色中的权限规则对命令行执行权限检查,不进行其它方面的权限检查,例如资源控制策略等。
对用户采用本地命令行授权时,设备将根据用户登录设备时输入的用户名对应的本地用户配置来对用户输入的命令进行检查,只有本地用户中配置的授权用户角色所允许的命令才被允许执行。
可以指定多个备选的命令行授权方法,在当前的授权方法无效时按照配置顺序尝试使用备选的方法完成命令授权。例如,hwtacacs-scheme hwtacacs-scheme-name local none表示,先进行HWTACACS授权,若HWTACACS授权无效则进行本地授权,若本地授权也无效则不进行授权。远程授权无效是指,指定的授权方案不存在、授权报文发送失败或者服务器无响应。本地授权无效是指没有找到对应的本地用户配置。
# 在ISP域test下,配置命令行授权方法为local。
[Sysname-isp-test] authorization command local
# 在ISP域test下,配置使用HWTACACS方案hwtac进行命令行授权,并且使用local作为备选授权方法。
[Sysname-isp-test] authorization command hwtacacs-scheme hwtac local
· command authorization(基础配置命令参考/登录设备)
· hwtacacs scheme
· local-user
authorization default命令用来为当前ISP域配置缺省的授权方法。
undo authorization default命令用来恢复缺省情况。
(非FIPS模式)
authorization default { hwtacacs-scheme hwtacacs-scheme-name [ radius-scheme radius-scheme-name ] [ local ] [ none ] | local [ radius-scheme radius-scheme-name | hwtacacs-scheme hwtacacs-scheme-name ] * [ none ] | none | radius-scheme radius-scheme-name [ hwtacacs-scheme hwtacacs-scheme-name ] [ local ] [ none ] }
(FIPS模式)
authorization default { hwtacacs-scheme hwtacacs-scheme-name [ radius-scheme radius-scheme-name ] [ local ] | local [ radius-scheme radius-scheme-name | hwtacacs-scheme hwtacacs-scheme-name ] * | radius-scheme radius-scheme-name [ hwtacacs-scheme hwtacacs-scheme-name ] [ local ] }
当前ISP域的缺省授权方法为local。
ISP域视图
local:本地授权。
none:不授权。接入设备不请求授权信息,不对用户可以使用的操作以及用户允许使用的网络服务进行授权。此时,认证通过的Login用户(通过Console口或者Telnet、FTP/SFTP/SCP访问设备的用户)只有系统给予的缺省用户角色level-0,其中FTP/SFTP/SCP用户的工作目录是设备的根目录,但并无访问权限;认证通过的非Login用户可直接访问网络。关于用户角色色level-0的详细介绍请参见“基础配置指导”中的“RBAC”。
当前ISP域的缺省的授权方法对于该域中未指定具体授权方法的所有接入用户都起作用,但是如果某类型的用户不支持指定的授权方法,则该授权方法对于这类用户不能生效。
在一个ISP域中,只有配置的认证和授权方法中引用了相同的RADIUS方案时,RADIUS授权过程才能生效。
可以指定多个备选的授权方法,在当前的授权方法无效时按照配置顺序尝试使用备选的方法完成授权。例如,radius-scheme radius-scheme-name local none表示,先进行RADIUS授权,若RADIUS授权无效则进行本地授权,若本地授权也无效则不进行授权。远程授权无效是指,指定的授权方案不存在、授权报文发送失败或者服务器无响应。本地授权无效是指没有找到对应的本地用户配置。
当采用本地授权方法为主授权方法,且配置了备选授权方法时,仅当AAA处理过程异常、用户与设备断开连接或者没有本地用户配置的情况下,用户本地授权失败后才会尝试使用备选方法进行授权,其它情况下不会转换授权方法,直接认为授权失败。
# 在ISP域test下,配置缺省授权方法为使用RADIUS方案rd进行授权,并且使用local作为备选授权方法。
[Sysname-isp-test] authorization default radius-scheme rd local
· hwtacacs scheme
· local-user
· radius scheme
authorization lan-access命令用来为lan-access用户配置授权方法。
undo authorization lan-access命令用来恢复缺省情况。
(非FIPS模式)
authorization lan-access { local [ radius-scheme radius-scheme-name ] [ none ] | none | radius-scheme radius-scheme-name [ local ] [ none ] }
(FIPS模式)
authorization lan-access { local | radius-scheme radius-scheme-name } *
lan-access用户采用当前ISP域的缺省授权方法。
ISP域视图
local:本地授权。
none:不授权。接入设备不请求授权信息,不对用户可以使用的操作以及用户允许使用的网络服务进行授权,认证通过的lan-access用户可直接访问网络。
# 在ISP域test下,为lan-access用户配置授权方法为local。
[Sysname-isp-test] authorization lan-access local
# 在ISP域test下,配置lan-access用户使用RADIUS方案rd进行授权,并且使用local作为备选授权方法。
[Sysname-isp-test] authorization lan-access radius-scheme rd local
· authorization default
· local-user
· radius scheme
authorization lan-access radius-cache enable命令用来开启lan-access用户的RADIUS授权信息缓存功能。
undo authorization lan-access radius-cache enable命令用来关闭lan-access用户RADIUS授权信息缓存功能。
lan-access用户的RADIUS授权信息缓存功能处于关闭状态。
ISP域视图
开启本功能后,当ISP域下的lan-access用户通过RADIUS认证上线后,RADIUS服务器返回的授权信息将记录在授权缓存信息记录表中。后续通过此ISP域进行RADIUS认证的lan-access用户,如果在认证时获取不到可用服务器,则会尝试获取此用户的授权信息缓存记录,若能成功获取到相应记录,则使用该记录的授权缓存信息进行认证授权,并返回认证成功。
若关闭本功能,则通过RADIUS认证成功上线后,RADIUS服务器返回的授权信息不会记录在缓存表中。
本功能需要开启AAA用户授权信息缓存功能(通过aaa authorization-cache enable命令开启)才能生效。
开启此功能后,如果域下计费方案与认证方案相同,需要配置计费方案为radius转none或者开启计费失败用户保持在线功能。
# 开启lan-access用户的RADIUS授权信息缓存功能。
[Sysname-isp-test] authorization lan-access radius-cache enable
authorization login命令用来为login用户配置授权方法。
undo authorization login命令用来恢复缺省情况。
(非FIPS模式)
authorization login { hwtacacs-scheme hwtacacs-scheme-name [ radius-scheme radius-scheme-name ] [ local ] [ none ] | local [ radius-scheme radius-scheme-name | hwtacacs-scheme hwtacacs-scheme-name ] * [ none ] | none | radius-scheme radius-scheme-name [ hwtacacs-scheme hwtacacs-scheme-name ] [ local ] [ none ] }
(FIPS模式)
authorization login { hwtacacs-scheme hwtacacs-scheme-name [ radius-scheme radius-scheme-name ] [ local ] | local [ radius-scheme radius-scheme-name | hwtacacs-scheme hwtacacs-scheme-name ] * | radius-scheme radius-scheme-name [ hwtacacs-scheme hwtacacs-scheme-name ] [ local ] }
login用户采用当前ISP域的缺省授权方法。
ISP域视图
local:本地授权。
none:不授权。接入设备不请求授权信息,不对用户可以使用的操作以及用户允许使用的网络服务进行授权。此时,认证通过的Login用户(通过Console口或者Telnet、FTP/SFTP/SCP访问设备的用户)只有系统给予的缺省用户角色level-0,其中FTP/SFTP/SCP用户的工作目录是设备的根目录,但并无访问权限。关于用户角色level-0的详细介绍请参见“基础配置指导”中的“RBAC”。
# 在ISP域test下,为login用户配置授权方法为local。
[Sysname-isp-test] authorization login local
# 在ISP域test下,配置login用户使用RADIUS方案rd进行授权,并且使用local作为备选授权方法。
[Sysname-isp-test] authorization login radius-scheme rd local
· hwtacacs scheme
· local-user
· radius scheme
authorization portal命令用来为Portal用户配置授权方法。
undo authorization portal命令用来恢复缺省情况。
(非FIPS模式)
authorization portal { local [ radius-scheme radius-scheme-name ] [ none ] | none | radius-scheme radius-scheme-name [ local ] [ none ] }
(FIPS模式)
authorization portal { local | radius-scheme radius-scheme-name } *
Portal用户采用当前ISP域的缺省授权方法。
ISP域视图
local:本地授权。
none:不授权。接入设备不请求授权信息,不对用户可以使用的操作以及用户允许使用的网络服务进行授权,认证通过的Portal用户可直接访问网络。
# 在ISP域test下,为Portal用户配置授权方法为local。
[Sysname-isp-test] authorization portal local
# 在ISP域test下,配置Portal用户使用RADIUS方案rd进行授权,并且使用local作为备选授权方法。
[Sysname-isp-test] authorization portal radius-scheme rd local
· local-user
· radius scheme
authorization-attribute命令用来设置当前ISP域下的用户授权属性。
undo authorization-attribute命令用来删除指定的授权属性,恢复用户具有的缺省访问权限。
authorization-attribute { acl acl-number | author-profile profile-name | idle-cut minutes [ flow ] [ traffic { both | inbound | outbound } ] | igmp max-access-number max-access-number | ip-pool ipv4-pool-name | ipv6-pool ipv6-pool-name | microsegment microsegment-id | mld max-access-number max-access-number | redirect { deny | permit } user-agent match match-string | url url-string | user-group user-group-name | vlan vlan-id | vsi vsi-name }
undo authorization-attribute { acl | author-profile | idle-cut | igmp | ip-pool | ipv6-pool | microsegment | mld | redirect | url | user-group | vlan | vsi }
当前ISP域下的用户闲置切换功能处于关闭状态,IPv4用户可以同时点播的最大节目数为4,IPv6用户可以同时点播的最大节目数为4,无其它授权属性。
ISP域视图
acl acl-number:指定用于匹配用户流量的ACL。其中acl-number表示ACL编号,取值范围2000~4999。此属性只对Portal、lan-access用户生效。与授权ACL规则匹配的流量,将按照规则中指定的permit或deny动作进行处理。
author-profile profile-name:指定用户的授权策略模板。其中profile-name为授权策略模板的名称,为1~31个字符的字符串,不区分大小写。授权策略模板是一组授权属性的集合,可用于基于VPN授权网络资源,只对802.1X、MAC地址认证、Web认证用户生效。其中,Web认证用户仅支持授权策略模板下指定VPN实例的授权微分段参数,不支持VSI参数。
idle-cut minutes:指定用户的闲置切断时间。其中,minutes的取值范围为1~600,单位为分钟。此属性只对Portal用户生效。
flow:用户在闲置切断时间内产生的最小数据流量,取值范围1~10240000,单位为字节,缺省值为10240。
traffic:指定闲置切断时间内用户数据流量的统计方向。若不指定该参数,则表示统计用户双向数据流量。
· both:表示用户双向数据流量。
· inbound:表示用户上行数据流量。
· outbound:表示用户下行数据流量。
igmp max-access-number max-access-number:指定IPv4用户可以同时点播的最大节目数。其中,max-access-number的取值范围为1~64。此属性只对Portal用户生效。
ip-pool ipv4-pool-name:指定为用户分配IPv4地址的地址池。其中,ipv4-pool-name表示地址池名称,为1~63个字符的字符串,区分大小写。此属性只对Portal用户生效。
ipv6-pool ipv6-pool-name:指定为用户分配IPv6地址的地址池。其中,ipv6-pool-name表示地址池名称,为1~63个字符的字符串,不区分大小写。此属性只对Portal用户生效。
microsegment microsegment-id:指定用户的授权微分段。其中,microsegment-id为微分段ID,取值范围为1~65535。此属性只对802.1X、MAC地址认证用户生效。
mld max-access-number max-access-number:指定IPv6用户可以同时点播的最大节目数。其中,max-access-number的取值范围为1~64。此属性只对Portal用户生效。
redirect deny:表示禁止满足匹配规则的终端设备访问重定向URL。
redirect permit:表示允许满足匹配规则的终端设备访问重定向URL。
user-agent:表示使用HTTP或HTTPS请求报文中的user-agent字段,对配置的用户终端类型进行匹配。
match match-string:指定用户首次访问网络时,对用户终端类型进行匹配的规则。其中,match-string为1~255个字符的字符串,不区分大小写。字符串中可以使用|将不同匹配规则割开,其中,|表示匹配规则之间为“或”的关系;例如aa|bb表示aa和bb满足其中之一即可。此属性只对MAC地址认证用户生效。
url url-string:指定用户的重定向URL。其中,url-string为1~255个字符的字符串,区分大小写,且必须携带http://或https://前缀才可生效。重定向URL主要用于Web页面推送,例如,用户认证成功后首次访问网络时用于推送广告、通知类页面,或者用户欠费时将用于推送欠费提醒页面。此属性只lan-access用户生效。
user-group user-group-name:表示用户所属用户组。其中,user-group-name表示用户组名,为1~32个字符的字符串,不区分大小写。用户认证成功后,将继承该用户组中的所有属性。
vlan vlan-id:指定用户的授权VLAN。其中,vlan-id为VLAN编号,取值范围为1~4094。此属性只对有线802.1X、MAC地址认证、Web认证用户生效。
vsi vsi-name:指定用户的授权VSI。其中,vsi-name表示VSI名称,为1~31个字符的字符串,区分大小写。此属性只对有线802.1X和MAC地址认证用户生效。
用户认证成功之后,优先采用服务器下发的属性值(本地认证时为接入设备本地授权),其次采用ISP域下配置的各类型属性值。
用户上线后,设备会周期性检测用户的流量,若域内某用户在指定的闲置检测时间内产生的流量小于本命令中指定的最小数据流量,则会被强制下线。需要注意的是,服务器上也可以配置最大空闲时间实现对用户的闲置切断功能,具体为当用户在指定的闲置检测时间内产生的流量小于10240个字节(服务器上该阈值为固定值,不可配置)时,会被强制下线。但是,只有在设备上的闲置切断功能处于关闭状态时,服务器才会根据自身的配置来控制用户的闲置切断。
需要注意的是,可通过多次执行本命令配置多个授权属性,但对于相同授权属性,最后一次执行的命令生效。
指定授权ACL时,需要注意的是:
· 若引用的ACL不存在,或者引用的ACL中没有配置规则,则表示未授权ACL规则。如果同时开启了Portal授权ACL的严格检查模式,则此情况下Portal用户会被强制下线。
· 对于授权给lan-access用户的ACL,ACL规则是否支持vpn-instance参数,以及vpn-instance参数的生效情况与设备的型号有关,请以设备的实际情况为准。
· 对于授权给Portal用户的ACL,ACL规则是否支持vpn-instance参数,以及vpn-instance参数的生效情况与设备的型号有关,请以设备的实际情况为准。
· 授权给Portal用户的ACL中不能配置携带用户源IP地址和源MAC地址信息的规则,否则会导致用户上线失败。
由于授权VSI与授权VLAN互斥,请避免对在线用户动态授权互斥的授权属性导致用户下线,具体包括以下几种情况:
· 用户上线时被授权VLAN,后续服务器再通过session control报文或者COA报文为其授权VSI。
· 用户上线时被授权VSI,后续服务器再通过session control报文或者COA报文为其授权VLAN。
· 用户上线时未被授权VLAN和VSI,设备会默认该用户采取了授权VLAN方式,后续服务器再通过session control报文或者COA报文为其授权VSI。
指定用户终端匹配规则时,需要注意:
· |为匹配规则的分割符,不能作为匹配规则输入。
· 不能连续输入|,如||、|||、| |。
· 匹配规则中可以包含空格,但是空格不参与匹配,且空格会占用字符串的长度。
# 设置ISP域test的用户授权组为abc。
[Sysname-isp-test] authorization-attribute user-group abc
# 设置ISP域test的用户授权属性为禁止用户使用iPhone或Andriod的终端访问重定向URL。
[Sysname-isp-test] authorization-attribute redirect deny user-agent match iPhone|Andriod
· display domain
default critical-microsegment命令用来配置缺省Critical微分段。
undo default critical-microsegment命令用来删除缺省Critical微分段。
default critical-microsegment microsegment-id [ vsi vsi-name ] [ url-user-logoff ]
不存在缺省Critical微分段。
逃生策略模板视图
microsegment-id:Critical微分段ID,取值范围为1~65535。
vsi vsi-name:VSI名称,为1~31个字符的字符串,区分大小写。此参数仅在VXLAN组网环境下使用,但是是否需要配置要根据具体组网情况而定。
url-user-logoff:表示将用户加入Critical微分段之前,强制让当前端口上授权了重定向URL的MAC地址认证的所有用户均下线。若不指定此参数,则端口上的授权了重定向URL的MAC地址认证用户一直保持在线,直到MAC地址认证下线检测功能发现其没有流量时下线。
当用户进行认证时,若对应的ISP域下所有认证服务器都不可达,且认证端口上引用了逃生策略模板,则用户会被加入该模板中配置的Critical微分段。对于VPN中的用户,将会优先采用逃生策略模板中配置的对应VPN实例的Critical微分段,其次采用逃生策略模板下的缺省Critical微分段。
一个逃生策略模板视图下,最多允许配置一个缺省Critical微分段。多次执行本命令,最后一次的配置生效。
url-user-logoff参数只对MAC认证用户有效。
# 在逃生策略模板abc下,配置缺省Critical微分段ID为66。
[Sysname] aaa critical-profile abc
[Sysname-critical-profile-abc] default critical-microsegment 66
· if-match vpn-instance critical-microsegment
default microsegment命令用来配置授权策略模板下的缺省微分段。
undo default microsegment命令用来恢复缺省情况。
default microsegment microsegment-id [ vsi vsi-name ]
不存在缺省微分段。
授权策略模板视图
microsegment-id:微分段ID,取值范围为1~65535。
授权策略模板下的缺省微分段将被授权于非VPN用户,以及未匹配上模板中任何VPN实例绑定关系的VPN用户,即如果模板中未配置对应VPN实例的微分段(通过命令if-match vpn-instance microsegment),则该VPN用户将被授权模板中的缺省微分段。
一个授权策略模板视图下,最多允许配置一个缺省微分段。多次执行本命令,最后一次的配置生效。
# 在授权策略模板abc下,配置缺省微分段ID为66。
[Sysname-author-profile-abc] default microsegment 66
· if-match vpn-instance microsegment
display aaa author-profile命令用来显示授权策略模板的信息。
display aaa author-profile [ name profile-name ]
name profile-name:授权策略模板的名字,为1~31个字符的字符串,不区分大小写。若不指定该参数,则表示所有授权策略模板。
# 显示所有授权策略模板的信息。
<Sysname> display aaa author-profile
Total 2 aaa author-profiles
aaa author-profile: a
default microsegment 1 vsi 1
Total 3 match criteria.
if match vpn-instance 2 microsegment 2 vsi 2
if match vpn-instance 3 microsegment 3 vsi 3
if match vpn-instance 4 microsegment 3 vsi 4
aaa author-profile: b
Total 2 match criteria.
# 显示指定授权策略模板的信息。
<Sysname> display aaa author-profile name a
表1-1 display aaa author-profile命令显示信息描述表
Total xx aaa author-profiles |
总计有xx个授权策略模板 |
aaa author-profile |
授权策略模板名称 |
default microsegment xxx vsi xxx |
缺省微分段以及所属的VSI |
Total xx match criteria. |
总计有xx条VPN实例与微分段的绑定关系 |
if match vpn-instance xxx microsegment xxx vsi xxx |
指定VPN实例的微分段以及所属的VSI |
· aaa author-profile
display aaa authorization-cache命令用来显示设备记录的授权信息缓存表项。
display aaa authorization-cache [ dot1x | mac-auth | static | web-auth ] [ mac mac-address ]
dot1x:显示802.1X认证用户的授权信息缓存表项。
mac-auth:显示MAC地址认证用户的授权信息缓存表项。
static:显示静态用户的授权信息缓存表项。
web-auth:显示Web认证用户的授权信息缓存表项。
mac mac-address:显示指定MAC地址的授权信息缓存表项。mac-address为MAC地址,格式为H-H-H。若不指定该参数,则表示显示不同类型用户的所有授权信息缓存表项。
如果不指定任何参数,则显示设备记录的所有授权信息缓存表项。
# 显示设备记录的所有授权信息缓存表项。
<Sysname> display aaa authorization-cache
Total cache entries: 2
Username: ias
Access type: MAC authentication
UUID: ff ff ff ff
Remaining time: 335:58:16 (hh:mm:ss)
AAA authentication method: RADIUS
Authorization VSI: N/A
Authorization microsegment ID: N/A
Authorization microsegment name: N/A
Authorization VLAN ID: 6
Authorization VLAN name: N/A
Egress VLAN ID: N/A
Egress VLAN Name(untagged): 1 5 7 9 11 13 15
Authorization ACL number: 3001
Authorization ACL name: N/A
Authorization ACL version: N/A
User MAC address: 0015-e9a6-abcd
Username: luser
Access type: 802.1X authentication
UUID: 41 41 41 41 42 42 42
Authorization VLAN ID: 2
Egress VLAN ID(tagged): 17
Egress VLAN Name: N/A
Authorization ACL number: N/A
Authorization ACL name: DACL
Authorization ACL version: IPV4
表1-2 display aaa authorization-cache命令显示信息描述表
Total cache entries |
记录的授权信息缓存表项总数 |
User MAC address |
用户的MAC地址 |
Username |
用户名 |
Access type |
接入认证方式,取值包括: · 802.1X authentication:802.1X认证 · MAC authentication:MAC地址认证 · Web authentication:Web认证 · Static user access:静态接入用户 |
Remaining time |
过期定时器的剩余时间,取值包括: · Not expire:不过期 · xx:xx:xx (hh:mm:ss):过期时间 |
UUID |
UUID信息 |
AAA authentication method |
用户成功上线采用的AAA认证方法,取值包括: · Local:本地认证 · RADIUS:RADIUS认证 · TACACS:TACACS认证 |
Authorization VSI |
授权的VSI列表,若未授权VSI,则显示N/A |
Authorization microsegment ID |
授权的微分段ID,若未授权微分段,则显示N/A |
Authorization microsegment name |
授权的微分段Name,若未授权微分段,则显示N/A |
Authorization VLAN ID |
授权的VLAN的ID 。若未授权VLAN,则显示N/A |
Authorization VLAN name |
授权的VLAN的名称 |
Egress VLAN ID |
授权的出口VLAN的ID,若未授权,则显示N/A |
Egress VLAN Name |
授权的出口VLAN的名称,若未授权,则显示N/A |
Authorization ACL number |
授权的静态ACL的编号。若未授权静态ACL,则显示N/A |
Authorization ACL name |
授权的静态ACL的名称。 |
Authorization ACL version |
授权的ACL的版本,取值包括:IPV4、IPV6、MAC、USER、WLAN |
Authorization dynamic ACL name |
授权的动态ACL的名称。若未授权动态ACL,则显示N/A |
Authorization user profile |
授权用户的User profile名称 |
display aaa normal-offline-record命令用来显示用户正常下线记录。
display aaa normal-offline-record { access-type { lan-access | login | portal } | domain domain-name | interface interface-type interface-number | { ip ipv4-address | ipv6 ipv6-address } | mac-address mac-address | s-vlan svlan-id [ c-vlan cvlan-id ] | slot slot-number | username user-name [ fuzzy-match ] | reason-code code } * [ time begin-time end-time [ date begin-date end-date ] ] [ brief | count count ]
display aaa normal-offline-record time begin-time end-time [ date begin-date end-date ] [ brief ]
access-type:显示指定用户接入类型的正常下线记录。
lan-access:LAN接入用户,如802.1X认证、MAC地址认证用户。
login:登录设备的用户,如SSH、Telnet、FTP用户。
portal:Portal接入用户。
domain domain-name:显示通过指定ISP域上线的用户的正常下线记录。domain-name表示ISP域名,为1~255个字符的字符串,不区分大小写。
interface interface-type interface-number:显示通过指定接口上线的用户的正常下线信息。interface-type interface-number表示用户接入接口的类型和接口编号。
ip ipv4-address:显示指定IPv4地址的用户正常下线记录。
ipv6 ipv6-address:显示指定IPv6地址的用户正常下线记录。
mac-address mac-address:显示指定MAC地址的正常下线记录。mac-address为用户的MAC地址,格式为H-H-H。
slot slot-number:指定成员设备。slot-number为设备在IRF中的成员编号。
s-vlan svlan-id:显示通过指定服务提供商VLAN上线的用户的正常下线记录。svlan-id表示VLAN ID,取值范围为1~4094。
c-vlan cvlan-id:显示通过指定用户VLAN上线的用户的正常下线记录。cvlan-id表示VLAN ID,取值范围为1~4094。
username user-name:显示指定用户名的正常下线记录。user-name表示用户名,为1~253个字符的字符串,区分大小写。
fuzzy-match:表示松散匹配用户名,即只要user-name字符串能连续匹配用户记录中的部分或者完整用户名,则匹配成功。若不指定该参数,则表示精确匹配用户名,即user-name字符串必须完全匹配上完整的用户名,才表示匹配成功。
reason-code code:显示指定原因码编号的用户的下线记录,最小值为1,具体取值范围请在参数位置输入<?>查看。
time:显示指定时间范围内上线用户的正常下线记录。
begin-time:起始时间,格式为hh:mm:ss(小时:分钟:秒),hh取值范围为0~23,mm和ss取值范围为0~59。
end-time:结束时间,格式为hh:mm:ss(小时:分钟:秒),hh取值范围为0~23,mm和ss取值范围为0~59。
date:显示指定日期范围的正常下线记录。若不指定该参数,则表示仅查看当天的记录。
begin-date:起始日期,格式为MM/DD/YYYY(月/日/年)或者YYYY/MM/DD(年/月/日)。MM的取值范围为1~12,DD的取值范围与月份有关,YYYY的取值范围为2000~2035。
end-date:结束日期,格式为MM/DD/YYYY(月/日/年)或者YYYY/MM/DD(年/月/日)。MM的取值范围为1~12,DD的取值范围与月份有关,YYYY的取值范围为2000~2035。
brief:显示用户正常下线记录的简要信息。若不指定该参数,则表示显示用户正常下线记录的详细信息。
count count:显示指定数量的正常下线失败记录。count为记录的条目,取值范围为1~32768。
可通过指定多种组合条件按需查询用户的正常下线记录。系统将从最新的一条记录开始显示符合查询条件的记录。
无论当前系统中的用户正常下线记录功能是否处于开启状态,只要系统中存在用户正常下线记录,就能通过本命令进行查看。
若不指定任何参数,则显示当前系统中的所有用户正常下线记录的详细信息。
如果服务器传递给设备的用户名中携带不可见字符,则使用指定用户名方式查看该类用户信息时,必须指定fuzzy-match关键字,否则无法查看到该用户信息。
# 显示所有用户正常下线记录的详细信息。
<Sysname> display aaa normal-offline-record
Total count: 1
Username: jay
Domain: dm1
MAC address: -
Access type: Telnet
SVLAN/CVLAN: -/-
IP address: 19.19.0.2
IPv6 address: -
User ID: 0x8000004a
User state: AUTHED
Accounting state: Accounting
Online request time: 2019/01/02 15:20:33
Offline time: 2019/02/28 15:20:56
Offline reason: User request.
Offline reason code: 1
# 显示login用户正常下线记录的简要信息。
<Sysname> display aaa offline-record access-type login brief
Username: jay
MAC address: -
IP address: 11.2.2.41
IPv6 address: -
表1-3 display aaa normal-offline-record命令显示信息描述表
UP IDs |
UP ID列表 仅当管理员被分配了指定的UP管理权限时,才会显示本字段 |
Total count |
用户正常下线记录总计数 |
Username |
用户名(若不存在,则显示为空) |
Domain |
ISP域名(若不存在,则显示为空) |
MAC address |
用户的MAC地址(若不存在,则显示“-”) |
Access type |
用户的接入类型: · MAC authentication:MAC地址认证用户 · 802.1X:802.1X用户 · Web authentication:Web认证用户 · Telnet:Telnet用户 · FTP:FTP用户 · SSH:SSH用户 · Portal:Portal用户 · NETCONF over SOAP:NETCONF over SOAP用户 · NETCONF over RESTful:NETCONF over RESTful用户 · Web:通过Web登录设备的用户 · Terminal:Terminal用户,例如从Console口登录设备的终端用户 |
Access UP ID |
用户接入的UP ID |
Access interface |
用户接入的接口名(若不存在,则显示“-”) |
SVLAN/CVLAN |
服务提供商VLAN/用户VLAN(若不存在,则显示“-”) |
IP address |
用户的IPv4地址(若不存在,则显示“-”) |
IPv6 address |
用户的IPv6地址(若不存在,则显示“-”) |
User ID |
用户在UCM中的唯一标识ID |
User state |
用户下线时的状态: · INIT:初始化 · AUTHING:认证中 · ALLOC:认证失败和用户下线的中间状态 · AUTHED:已认证 · USER-ADDING:下内核和通知备用接口板,等待结果的中间状态 · UP:上线成功 · DELETING:正在删除 · DELETED:删除完成 · BINDING:绑定阶段(PPP MP才有) · REAUTH:重认证阶段(IPoE Web用户在Web认证阶段进行认证) · LOGOUT:退出当前认证阶段(IPoE Web用户从Web认证阶段退回到认证前域阶段) MODIFY:更新用户信息(例如COA) |
Accounting state |
用户下线时的计费状态: · - :表示没有计费配置或未进入计费状态 · Accounting:计费中 |
Online request time |
用户发起上线请求的时间 |
Offline time |
用户下线的时间 |
Offline reason |
用户的下线原因,详细介绍请参见表1-6 |
display aaa online-fail-record命令用来显示用户上线失败记录。
display aaa online-fail-record { access-type { lan-access | login | portal } | domain domain-name | interface interface-type interface-number | { ip ipv4-address | ipv6 ipv6-address } | mac-address mac-address | s-vlan svlan-id [ c-vlan cvlan-id ] | slot slot-number | username user-name [ fuzzy-match ] | reason-code code } * [ time begin-time end-time [ date begin-date end-date ] ] [ brief | count count ]
display aaa online-fail-record time begin-time end-time [ date begin-date end-date ] [ brief ]
access-type:显示指定用户接入类型的上线失败记录。
portal:Portal接入用户。
domain domain-name:显示通过指定ISP域上线的用户的上线失败记录。domain-name表示ISP域名,为1~255个字符的字符串,不区分大小写。
interface interface-type interface-number:显示通过指定接口上线的用户的上线失败信息。interface-type interface-number表示用户接入接口的类型和接口编号。
ip ipv4-address:显示指定IPv4地址的用户上线失败记录。
ipv6 ipv6-address:显示指定IPv6地址的用户上线失败记录。
mac-address mac-address:显示指定MAC地址的上线失败记录。mac-address为用户的MAC地址,格式为H-H-H。
s-vlan svlan-id:显示通过指定服务提供商VLAN上线的用户的上线失败记录。svlan-id表示VLAN ID,取值范围为1~4094。
c-vlan cvlan-id:显示通过指定用户VLAN上线的用户的上线失败记录。cvlan-id表示VLAN ID,取值范围为1~4094。
username user-name:显示指定用户名的上线失败记录。user-name表示用户名,为1~253个字符的字符串,区分大小写。
time:显示指定时间范围内上线用户的上线失败记录。
date:显示指定日期范围的上线失败记录。若不指定该参数,则表示仅查看当天的记录。
brief:显示用户上线失败记录的简要信息。若不指定该参数,则表示显示用户上线失败记录的详细信息。
count count:显示指定数量的上线失败记录。count为记录的条目,取值范围为1~32768。
可通过指定多种组合条件按需查询用户的上线失败记录。系统将从最新的一条记录开始显示符合查询条件的记录。
无论当前系统中的用户上线失败记录功能是否处于开启状态,只要系统中存在用户上线失败记录,就能通过本命令进行查看。
若不指定任何参数,则显示当前系统中的所有用户上线失败记录的详细信息。
# 显示2条用户名为aaa的login用户上线失败记录的详细信息。
<Sysname> display aaa online-fail-record username aaa access-type login count 2
Username: aaa
Domain: test
MAC address: -
Access type: Telnet
SVLAN/CVLAN: 100/-
IP address: 19.19.0.1
IPv6 address: -
User ID: 0x8000004b
User state: AUTHED
Online request time: 2019/01/02 15:20:37
Online failure reason: Authentication failed.
Online failure reason code: 17
Reply message: no user exists.
Username: aaa
Domain: test
MAC address: -
Access type: Telnet
SVLAN/CVLAN: -/-
IPv6 address: -
User ID: 0x8000004b
User state: AUTHED
# 显示2019/3/1的13:20:50 到2019/3/2的10:20:30这段时间内的上线失败用户记录的简要信息。
<Sysname> display aaa online-fail-record time 13:20:50 10:20:30 date 2019/3/1 2019/3/2 brief
Username: aaa
MAC address: -
IPv6 address: -
User ID: 0x8000004b
User state: Authened
Accounting state: AcctStart
# 显示2019/3/1的13:20:50至2019/3/2的17:20:30期间的用户上线失败记录。
<Sysname> display aaa online-fail-record time 13:20:50 17:20:30 date 2019/3/1 2019/3/2
Username: aaa
Domain: test
MAC address: -
Access type: Telnet
SVLAN/CVLAN: -/-
IPv6 address: -
User ID: 0x8000004b
User state: AUTHED
Online request time: 2019/03/02 16:20:33
Username: aaa
Domain: test
MAC address: -
Access type: Telnet
SVLAN/CVLAN: -/-
IPv6 address: -
User ID: 0x8000004c
User state: AUTHED
Online request time: 2019/03/01 15:20:51
Online failure reason code: 135
表1-4 display aaa online-fail-record命令显示信息描述表
UP IDs |
Total count |
用户上线失败记录总数 |
Username |
用户名(若不存在,则显示为空) |
Domain |
用户上线使用的ISP域名(若不存在,则显示为空) |
MAC address |
Access type |
Access UP ID |
用户接入的UP ID |
Access interface |
SVLAN/CVLAN |
IP address |
IPv6 address |
User ID |
用户在UCM中的唯一标识ID |
User state |
用户上线异常时的状态: · INIT:初始化 · AUTHING:认证中 · ALLOC:认证失败和用户下线的中间状态 · AUTHED:已认证 · USER-ADDING:下内核和通知备用接口板,等待结果的中间状态 · UP:上线成功 · DELETING:正在删除 · DELETED:删除完成 · BINDING:绑定阶段(PPP MP才有) · REAUTH:重认证阶段(IPoE Web用户在Web认证阶段进行认证) · LOGOUT:退出当前认证阶段(IPoE Web用户从Web认证阶段退回到认证前域阶段) MODIFY:更新用户信息(例如COA) |
Accounting state |
用户上线异常时的计费状态: · - :表示没有计费配置或未进入计费状态 · Accounting:计费中 |
用户发起上线请求的时间 |
Online failure reason |
用户的上线失败原因,详细介绍请参见表1-6 |
Reply message |
服务器下发的消息(若未下发,则不显示) |
Offline reason code |
用户下线原因对应的原因码 |
display aaa abnormal-offline-record命令用来显示用户异常下线记录。
display aaa abnormal-offline-record { access-type { lan-access | login | portal } | domain domain-name | interface interface-type interface-number | { ip ipv4-address | ipv6 ipv6-address } | mac-address mac-address | s-vlan svlan-id [ c-vlan cvlan-id ] | slot slot-number | username user-name [ fuzzy-match ] | reason-code code } * [ time begin-time end-time [ date begin-date end-date ] ] [ brief | count count ]
display aaa abnormal-offline-record offline-reason { idle-cut | quota-out | realtime-acct-fail | session-timeout | user-detect-fail } [ brief ]
display aaa abnormal-offline-record time begin-time end-time [ date begin-date end-date ] [ brief ]
access-type:显示指定用户接入类型的异常下线记录。
portal:Portal接入用户。
domain domain-name:显示通过指定ISP域上线的用户的异常下线记录。domain-name表示ISP域名,为1~255个字符的字符串,不区分大小写。
interface interface-type interface-number:显示通过指定接口上线的用户的异常下线信息。interface-type interface-number表示用户接入接口的类型和接口编号。
ip ipv4-address:显示指定IPv4地址的用户异常下线记录。
ipv6 ipv6-address:显示指定IPv6地址的用户异常下线记录。
mac-address mac-address:显示指定MAC地址的异常下线失败记录。mac-address为用户的MAC地址,格式为H-H-H。
s-vlan svlan-id:显示通过指定服务提供商VLAN上线的用户的异常下线记录。svlan-id表示VLAN ID,取值范围为1~4094。
c-vlan cvlan-id:显示通过指定用户VLAN上线的用户的异常下线记录。cvlan-id表示VLAN ID,取值范围为1~4094。
username user-name:显示指定用户名的异常下线记录。user-name表示用户名,为1~253个字符的字符串,区分大小写。
offline-reason:显示指定下线原因的用户异常下线记录。
· idle-cut:闲置超时后切断。
· quota-out:流量配额耗尽。
· realtime-acct-fail:实时计费失败。
· session-timeout:用户会话超时。
· user-detect-fail:802.1X用户探测失败。
time:显示指定时间范围内下线用户的异常下线记录。
date:显示指定日期范围的异常下线记录。若不指定该参数,则表示仅查看当天的记录。
brief:显示用户异常下线记录的简要信息。若不指定该参数,则表示显示用户异常下线记录的详细信息。
count count:显示指定数量的异常下线记录。count为记录的条目,取值范围为1~32768。
可通过指定多种组合条件按需查询用户的异常下线记录。系统将从最新的一条记录开始显示符合查询条件的记录。
无论当前系统中的用户异常下线记录功能是否处于开启状态,只要系统中存在用户异常下线记录,就能通过本命令进行查看。
若不指定任何参数,则显示当前系统中的所有用户异常下线记录的详细信息。
# 显示所有用户异常下线记录的详细信息。
<Sysname> display aaa abnormal-offline-record
Total count: 1
Username: jay
Domain: dm1
MAC address: -
Access type: SSH
SVLAN/CVLAN: -/-
IPv6 address: -
User ID: 0x8000004a
User state: AUTHED
Offline reason: User disconnected from the server.
Offline reason code: 763
# 显示login用户异常下线记录的简要信息。
<Sysname> display aaa abnormal-offline-record access-type login brief
Username: jay
MAC address: -
IPv6 address: -
表1-5 display aaa abnormal-offline-record命令显示信息描述表
UP IDs |
Total count |
用户异常下线记录总计数 |
Username |
用户名(若不存在,则显示为空) |
Domain |
ISP域名(若不存在,则显示为空) |
MAC address |
Access type |
Access UP ID |
用户接入的UP ID |
Access interface |
SVLAN/CVLAN |
IP address |
IPv6 address |
User ID |
用户在UCM中的唯一标识ID |
User state |
Accounting state |
用户发起上线请求的时间 |
Offline time |
用户下线的时间 |
Offline reason |
用户下线原因对应的原因码 |
下表罗列内容为所有产品可支持上/下线原因的合集,具体产品支持情况有所不同。
表1-6 用户上/下线原因描述表
Lost carrier. |
物理链路DOWN |
Lost service. |
用户业务不支持 |
NAS error. |
设备错误 |
NAS reboot. |
设备重启 |
Admin reboot. |
管理员重启设备 |
Process exit. |
接入进程退出 |
NAS request. |
设备请求用户下线 |
Cut command. |
管理员手动执行命令强制用户下线 |
Logged off by the RADIUS server. |
RADIUS服务器要求用户下线 |
User request. |
用户请求下线 |
Authentication failed |
认证失败 |
Authorization failed. |
授权失败 |
Start accounting failed. |
开始计费失败 |
No AAA response during authentication. |
用户在进行远端服务器认证时,设备在认证超时时间内未收到认证服务器的回应 |
RADIUS authentication rejected. |
用户名或密码与RADIUS服务器上的信息不一致,导致认证失败 |
AAA authorization information invalid. |
授权信息错误或者设备上没有对应的授权配置 |
No AAA response for accounting start. |
用户向远端服务器发送计费开始时,设备在计费开始超时时间内未收到认证服务器的回应 |
Authentication request to AAA failed. |
由于设备与RADIUS服务器间路由不可达,导致认证请求发送失败 |
Accounting request to AAA failed. |
由于设备与RADIUS服务器间路由不可达,导致计费请求发送失败 |
TACACS authentication rejected. |
用户名或密码与HWTACACS服务器上的信息不一致,导致认证失败 |
Authentication method error. |
接入模块的认证配置错误。可能是用户请求的认证类型与端口下配置的认证类型不一致 |
No AAA response for accounting stop. |
未收到服务器对停止计费请求的回应 |
The local user doesn't exist. |
设备上未配置该本地用户 |
Local authentication request was rejected. |
用户密码错误导致本地认证被拒绝 |
IP assignment failed. |
IP地址分配失败 |
Concurrent user login limit reached. |
一个本地用户用户名允许接入的用户数超过了限制 |
NAS interface access limit reached. |
NAS接口下上线的用户数已达到了该接口下配置的允许上线用户数目最大限制 |
Maximum number of concurrent users that use this account already reached. |
使用该账户的用户达到了上限个数 |
PPP negotiation terminated. |
PPP协商过程失败 |
Insufficient hardware resources. |
硬件资源不足 |
Failed to obtain IPv6 prefix. |
没有可用的IPv6地址前缀用来为用户分配 |
No response from DHCP server. |
设备向远端DHCP服务器申请IP地址时,没有收到远端服务器的响应 |
DHCP IP address allocation failure. |
DHCPv6地址分配失败,可能的原因包括: · AAA域下没有配置授权IPv6地址池 · IPv6地址池被锁定 |
DHCP session conflict. |
新建的DHCP会话与已有的会话冲突 |
DHCP user request. |
DHCP用户请求下线 |
DHCP lease timeout. |
DHCP用户地址租期到期下线 |
DHCP declined. |
已有主机使用服务器分配的IP地址 设备收到用户的DHCP-DECLINE报文,可能是客户端检测到用户网络中存在另一个相同的IP地址 |
DHCP configuration changed. |
DHCP配置变化触发用户下线 |
NAK from the DHCP server or tenant duration is 0. |
客户端请求的IP地址与设备分配的IP地址网段不一致或续租时间为0 |
IP conflict on DHCP server. |
设备检测到IP地址冲突 |
DHCP server notified. |
DHCP服务器通知用户下线 |
DHCP server notified, and the device deleted the user. |
DHCP服务器端通知用户下线,设备删除用户 |
DHCPv6 requests with DUID mismatch. |
配置ipv6 dhcp duid-mismatch offline命令后,DHCPv6服务器收到了与用户MAC相同但DUID不同的DHCPv6请求报文,删除在线用户租约 |
DHCP with dhcp user offline configured. |
配置dhcp user offline命令后,DHCP设备收到了相同MAC地址的DHCP-DISCOVER或REBOOT-REQUEST报文,删除在线用户租约 |
DHCP with the fast-renew method specified for roaming users. |
配置(ipv6)dhcp session-mismatch action fast-renew命令后,DHCP设备收到了物理位置变化、MAC地址不变的用户DHCP/DHCPv6请求报文,删除在线用户租约 |
DHCP with dhcp conflict-ip-address offline configured. |
配置dhcp conflict-ip-address offline命令后,设备检测到分配的地址与已在线用户地址冲突,删除在线用户 |
DHCP request interface address. |
DHCP用户请求的地址是设备的接口地址 |
DHCP lease release with ICMP. |
通过ICMP报文探测到用户地址冲突,释放租约 |
DHCP request IP is used. |
用户请求的地址已被使用 |
DHCP request info mismatch. |
DHCP已存在该PPP用户,且用户信息(VLAN等)不匹配 |
DHCP request IP conflict of NDRA relogin user. |
NDRA用户重上线请求的地址是冲突地址 |
DHCP reserve IP in detect subnet table. |
请求的占位地址已在detect subnet表中 |
DHCP reserve prefix failed due to share type conflict. |
用户请求的占位前缀共享类型与该前缀实际的共享类型不一致,请求占位前缀失败 |
DHCP reserve unshare prefix is used. |
请求的非共享占位前缀已被使用 |
DHCP reserve share prefix already used by another type user. |
请求的共享占位前缀已被其他类型的用户使用 |
DHCP reserve subnet is used. |
申请的占位子网段已被使用 |
DHCP reserve subnet in detect IP table. |
申请的占位子网段已在detect ip表中 |
DHCP reserve subnet is used by unknown source. |
申请的占位子网段已被未知源用户使用 |
Invalid DHCP request info, pool-group not exist. |
用户请求的地址池组不存在 |
DHCP temporarily not process the user request. |
暂未处理该用户请求 |
Invalid DHCP request info, pool VPN not exist. |
地址池下配置的VPN不存在 |
Invalid DHCP request info, VPN mismatch. |
用户所属VPN和地址池下配置的VPN不一致 |
Invalid DHCP request info, network not exist. |
用户请求的地址池下未配置network |
Invalid DHCP request info, pool not exist. |
用户请求的地址池不存在 |
DHCP smooth failed, lease not exist. |
PPP用户租约平滑失败,DHCP模块不存在该用户租约 |
DHCP reserve subnet not exist. |
申请的占位子网段不存在 |
DHCP lease initialization failed. |
初始化租约失败 |
DHCP reserve IP failed, invalid reserved ip. |
申请的占位地址是无效地址 |
DHCP PPP online failed, request lease failed. |
PPP用户租约申请失败,上线失败 |
DHCP delete user, VT interface deactive. |
DHCP收到虚拟模板接口的deactive事件,删除该接口下的用户 |
DHCP proxy entry timeout. |
Proxy表项老化删除 |
DHCP delete proxy entry upon NAK. |
中继收到DHCP-NAK报文,删除proxy表项 |
DHCP delete proxy entry. |
Proxy表项被删除 |
DHCP delete MAC-port entry. |
MAC-port表项被删除 |
DHCP delete timeout MAC-port entry. |
MAC-port表项老化删除 |
DHCP pool-group delete. |
上线地址池所属的地址池组被删除 |
DHCP delete pool from pool-group. |
上线地址池从地址池组下被删除 |
DHCP delete pool. |
上线地址池被删除 |
DHCP start ICMP failed. |
DHCP启动ICMP探测失败 |
DHCP NDRS request exceed maximum. |
NDRS的待处理请求数已达到最大,暂不接收新请求 |
DHCP NDRS online timeout. |
NDRS用户上线超时 |
DHCP pool locked. |
地址池被锁定 |
DHCP reserve subnet failed, subnet mask lower than network mask. |
因申请的子网段掩码比network网段的掩码小,占位子网段申请失败 |
DHCP reserve subnet failed, unusable network. |
网段可用性检查失败,占位子网段申请失败 |
DHCP reserve prefix failed, unusable prefix. |
前缀池可用性检查失败,占位前缀申请失败 |
DHCP NDRA relogin failed, no available pool in pool-group. |
地址池组中未匹配上地址池,NDRA用户重上线失败 |
DHCP NDRA relogin failed, lease pool not found. |
租约所属地址池不存在,NDRA用户重上线失败 |
DHCP NDRA relogin failed. |
NDRA用户重上线失败 |
DHCP NDRA smooth failed, another address lease already exist. |
NDRA用户平滑失败:该用户已有地址不一致的租约 |
DHCP prefix lease initialization failed. |
初始化前缀租约失败 |
DHCP delete lease after another module notify. |
其它模块通知DHCP删除租约 |
DHCP NDRA smooth failed. |
NDRA用户平滑失败 |
DHCP dual NDRS backup request failed. |
双活NDRS用户,备设备将地址请求消息发送给主设备失败 |
DHCP static reserve IP failed, unsable IP. |
因地址可用性检查失败,静态占位地址申请失败 |
DHCP alloc mode error. |
分配模式不正确 |
DHCP request timeout in pool-group. |
PPPOE地址池组上线的情况下,上线请求处理不及时,上线失败 |
DHCP request timeout in pool. |
PPPOE地址池上线的情况下,上线请求处理不及时,上线失败 |
DHCP Cinfo refresh by detecting lease released. |
相同租约分配给新用户,Cinfo信息刷新,原用户下线 |
DHCPv6 REPLY packet info invalid. |
DHCPv6 REPLY报文中携带的信息无效,导致上线/续约失败(租约时间或者status code中携带了失败的错误码) |
DHCP inform request has no response. |
因处理inform报文生成的临时用户,在未收到inform回复时,删除该用户 |
DHCP inform request process successfully. |
因处理inform报文生成的临时用户,inform处理完毕后,删除该用户 |
AM configuration error. |
AM模块配置错误 |
The static session already exists. |
新建IPoE动态会话与已有静态会话配置冲突 |
NAT444 failed. |
IPoE与NAT444联动失败 |
The ND RS session is updated. |
ND用户在线时,又收到该用户的ND上线请求,触发用户下线 |
L2TP tunnel terminated by the peer. |
对端拆除了L2TP隧道,可能是对端设备检测到用户下线 |
The peer did not respond to control packets. |
对端设备未回应本端的PPP控制报文 |
Failed to set up an L2TP session. |
L2TP会话创建失败 |
Repeated LCP negotiation packets. |
收到重复的LCP协商报文,可能是客户端断开后重新发起连接 |
Failed to assign a user rule. |
下发Portal用户规则失败 |
COA failure. |
设备处理COA授权消息失败 |
Failed to update authorization information. |
更新用户授权信息失败 |
Realtime accounting request to AAA failed. |
实时计费请求失败 |
Session timeout. |
用户会话超时 |
Data quota limit reached. |
用户可用流量额度已经达到限定值 |
Session idle cut. |
闲置切断,即单位时间内用户的流量小于指定值,设备强制用户下线 |
User online detection failure. |
用户在线探测失败 |
Port was removed from VLAN. |
用户上线的物理端口被移出所在VLAN |
Port error. |
端口错误 |
Interface down or deactive. |
接口协议down、链路down或接口未激活 |
VSRP status changed. |
VSRP状态变化 |
Backup device deleted user data that is inconsistent with data on the master device. |
VSRP备设备删除了与主设备上不一致的用户数据 |
MAC address change. |
用户MAC地址变化 |
Failed to recover AAA resources. |
恢复用户的AAA资源失败 |
Deleted users because of inter-card session conflict. |
不同单板上的会话冲突导致用户下线 |
User aged out before coming online. |
达到了接入模块的上线超时时间 |
MPU-LPU data synchronization failure. |
板间数据平滑失败 |
Failed to synchronize data with DHCP server. |
与DHCP服务器之间数据同步失败 |
Failed to synchronize data with portal server. |
与Portal服务器之间同步数据失败 |
Failed to synchronize user information with the server. |
与服务器同步用户信息失败 |
User recovery failure. |
用户数据恢复失败 |
Failed to obtain physical information. |
获取物理信息失败 |
Authorization ACL for the online user changed. |
授权的ACL配置变化 |
Authorization user profile for the online user changed. |
授权的User Profile配置变化 |
Magic number check failed. |
魔术字检查失败 |
Reauthentication failed. |
重认证失败 |
No AAA response during realtime accounting. |
实时计费无响应 |
Portal notified. |
Portal通知用户下线 |
Invalid username or password. |
无效用户名或者密码 |
No VTY line available. |
没有VTY资源,登录VTY的用户数达到了最大值 |
SSH server received a packet with an incorrect message authentication code. |
SSH客户端报文的消息认证码(Message Authentication Code)错误 |
User disconnected from the server. |
SSH或FTP用户与服务器断开连接 |
No working directory available. |
无可用工作路径错误 |
PTY allocation failed. |
PTY(伪终端)申请失败 |
FTP server error. |
用户连接的FTP服务器异常,由于FTP服务器自身的原因导致用户无法登录 |
Server is disabled. |
服务未开启 |
Service type not supported. |
服务类型不支持 |
RBAC denied file management operations in the login command. |
登录命令中的文件系统操作权限被RBAC禁止 |
Failed to issue RBAC access permissions to the login user. |
登录命令行执行权限被RBAC禁止 |
NETCONF inner error. |
NETCONF内部错误 |
NETCONF session was terminated by another NETCONF session. |
用户的Netconf会话被其它Netconf会话打断 |
Failed to allocate public network ports in a CGN network. |
CGN公网端口分配失败 |
Failed to obtain an IP address of the type specified for basic services of users. |
用户主业务依赖的IP地址分配失败 |
UserGroup configuration changed. |
用户组配置变化 |
MAC conflict. |
MAC地址冲突 |
RedisDBM clear. |
在数据迁出设备上执行RedisDBM的clear操作导致用户下线 |
RedisDBM conflict. |
在数据迁入设备上恢复Redis数据时发生数据冲突 |
RedisDBM block. |
在数据迁出设备上执行RedisDBM的block操作导致用户下线 |
Logged out by the RADIUS proxy |
被RADIUS代理强制下线 |
Logged out by the RADIUS proxy because of username change |
由于用户名变化,导致用户被RADIUS代理强制下线 |
NAT failed to issue the user port block info to the driver. |
用户上线成功之后,端口块会下发驱动,如果下发驱动失败,用户会下线 |
Failed to match NAT configuration. |
用户上线没有匹配上NAT的配置(比如nat outbound 3000 address-group 1配置的ACL与用户信息不符),或者用户平滑时没有匹配上NAT的配置 |
Failed to come online by using CGN because the matching NAT doesn't support port block-based NAT. |
用户上线时命中的NAT配置不支持端口块方式,导致用户联动上线失败 |
Failover group failure. |
备份组故障,导致用户下线 |
Failed to get NAT instance or NAT instance configuration is not correct. |
负载分担用户组获取NAT实例失败或者NAT实例配置有误,导致用户上线失败 |
The NAT address was released. |
由于NAT地址被回收,导致用户下线 |
NAT configured with flow-triggered port block assignment doesn't support CGN. |
目前仅有端口块方式支持联动上线,端口块的分配方式由命令行决定,如果开启了流量触发分配端口块,那么被重定向到这个实例的用户上线失败 |
Failed to come online by using CGN because of session service-location configuration matching failure. |
匹配session service-location命令失败,导致用户上线失败 |
Failed to obtain user group information. |
获取用户组信息失败 |
User authentication and NAT unification failed due to nat instance is sub type. |
联动上线消息中的NAT实例为子实例,用户上线失败 |
Login time beyond validity period. |
登录时间不在本地用户的有效期内 |
Maximum number of concurrent SSH users already reached. |
已达到同时在线的最大SSH用户连接数 |
Fail to add to RADIUS buffer queue |
加入Radius缓存队列失败 |
Service-type mismatch |
服务类型不匹配 |
The local user is blocked |
本地用户处于block状态 |
The lock flag of the local user is lock in the password control blacklist |
本地用户的Lock标记被锁定在密码管理黑名单 |
Binding attributes mismatch |
绑定属性不匹配 |
The ISP domain does not exist |
ISP域不存在 |
The ISP domain is blocked |
ISP域处于block状态 |
HWTACACS authorization server is unreachable or the server configuration does not exist |
HWTACACS授权服务器不可达或服务器配置不存在 |
Username is empty |
用户名为空 |
No password set for the virtual terminal |
虚拟终端未设置密码 |
User validity time expired |
用户有效时间超时 |
System Error |
系统错误 |
Client response timed out |
客户端响应超时 |
display aaa offline-record命令用来显示用户下线记录。
display aaa offline-record { access-type { lan-access | login | portal } | domain domain-name | interface interface-type interface-number | { ip ipv4-address | ipv6 ipv6-address } | mac-address mac-address | s-vlan svlan-id [ c-vlan cvlan-id ] | slot slot-number | username user-name [ fuzzy-match ] | reason-code code } * [ time begin-time end-time [ date begin-date end-date ] ] [ brief | count count ]
display aaa offline-record time begin-time end-time [ date begin-date end-date ] [ brief ]
access-type:显示指定用户接入类型的下线记录。
portal:Portal接入用户。
domain domain-name:显示通过指定ISP域上线的用户的下线记录。domain-name表示ISP域名,为1~255个字符的字符串,不区分大小写。
interface interface-type interface-number:显示通过指定接口上线的用户的下线信息。interface-type interface-number表示用户接入接口的类型和接口编号。
ip ipv4-address:显示指定IPv4地址的用户下线记录。
ipv6 ipv6-address:显示指定IPv6地址的用户下线记录。
mac-address mac-address:显示指定MAC地址的下线记录。mac-address为用户的MAC地址,格式为H-H-H。
s-vlan svlan-id:显示通过指定服务提供商VLAN上线的用户的下线记录。svlan-id表示VLAN ID,取值范围为1~4094。
c-vlan cvlan-id:显示通过指定用户VLAN上线的用户的下线记录。cvlan-id表示VLAN ID,取值范围为1~4094。
username user-name:显示指定用户名的下线记录。user-name表示用户名,为1~253个字符的字符串,区分大小写。
reason-code code:显示指定原因码编号的用户下线记录,最小值为1,具体取值范围请在参数位置输入<?>查看。
time:显示指定时间范围内下线用户的下线记录。
date:显示指定日期范围的下线记录。若不指定该参数,则表示仅查看当天的记录。
brief:显示用户下线记录的简要信息。若不指定该参数,则表示显示用户下线记录的详细信息。
count count:显示指定数量的下线记录。count为记录的条目,取值范围为1~65536。
可通过指定多种组合条件按需查询用户的下线记录。系统将从最新的一条记录开始显示符合查询条件的记录。
无论当前系统中的用户下线记录功能是否处于开启状态,只要系统中存在用户下线记录,就能通过本命令进行查看。
若不指定任何参数,则显示当前系统中的所有用户下线记录的详细信息。
# 显示所有用户下线记录的详细信息。
Total count: 1
Username: jay
Domain: dm1
MAC address: -
Access type: Telnet
SVLAN/CVLAN: -/-
IPv6 address:
User ID: 0x8000004a
User state: AUTHED
Accounting state: Accounting -
# 显示login用户下线记录的简要信息。
Username: jay
MAC address: -
IP address: 20.20.20.1
IPv6 address: -
Username: test
MAC address: -
IP address: 20.20.20.3
IPv6 address: -
表1-7 display aaa offline-record命令显示信息描述表
UP IDs |
Total count |
用户下线记录总计数 |
Username |
用户名(若不存在,则显示为空) |
Domain |
ISP域名(若不存在,则显示为空) |
MAC address |
Access type |
Access UP ID |
用户接入的UP ID |
Access interface |
SVLAN/CVLAN |
IP address |
IPv6 address |
User ID |
用户在UCM中的唯一标识ID |
User state |
Accounting state |
用户发起上线请求的时间 |
Offline time |
用户下线的时间 |
Offline reason |
用户下线原因对应的原因码 |
· reset aaa offline-record
display domain命令用来显示所有或指定ISP域的配置信息。
display domain [ isp-name ]
isp-name:ISP域名,为1~255个字符的字符串,不区分大小写。如果不指定该参数,则表示所有ISP域。
# 显示系统中所有ISP域的配置信息。
<Sysname> display domain
Total 2 domains
Domain: system
State: Active
Default authentication scheme: Local
Default authorization scheme: Local
Default accounting scheme: Local
Accounting start failure action: Online
Accounting update failure action: Online
Accounting quota out policy: Offline
Service type: HSI
Session time: Exclude idle time
Dual-stack accounting method: Merge
Authorization attributes:
Idle cut: Disabled
IGMP access limit: 4
MLD access limit: 4
Redirect match terminal rule:
Rule:iphone|ipad
Action:permit
Authen-fail action: Offline
Authen-radius-unavailable: Not configured
Authen-radius-recover: Not configured
Temporary redirect: Disabled
Domain: dm
State: Active
Login authentication scheme: RADIUS=rad
Login authorization scheme: HWTACACS=hw
Super authentication scheme: RADIUS=rad
Command authorization scheme: HWTACACS=hw
LAN access authentication scheme: RADIUS=r4
Portal authentication scheme: LDAP=ldp
Default authentication scheme: RADIUS=rad, Local, None
Default accounting scheme: None
Service type: HSI
Session time: Include idle time
Idle cut : Enabled
Idle timeout: 2 minutes
Flow: 10240 bytes
Traffic direction: Both
IP pool: appy
ACL number: 3000
User group: ugg
IPv6 pool: ipv6pool
URL: http://test
MLD access limit: 4
Rule: iphone|ipad
Action: permit
Authen-fail action: Online in domain dm1 without authentication
Authen-radius-unavailable: Online domain dm2
Authen-radius-recover: Offline
LAN access radius cache: Enabled
Default domain name: system
表1-8 display domain命令显示信息描述表
Total 2 domains |
总计2个ISP域 |
Domain |
ISP域名 |
State |
ISP域的状态 |
Default authentication scheme |
缺省的认证方案 |
Default authorization scheme |
缺省的授权方案 |
Default accounting scheme |
缺省的计费方案 |
Login authentication scheme |
Login用户认证方案 |
Login authorization scheme |
Login用户授权方案 |
Login accounting scheme |
Login用户计费方案 |
Super authentication scheme |
用户角色切换认证方案 |
Command authorization scheme |
命令行授权方案 |
Command accounting scheme |
命令行计费方案 |
LAN access authentication scheme |
lan-access用户认证方案 |
LAN access authorization scheme |
lan-access用户授权方案 |
LAN access accounting scheme |
lan-access用户计费方案 |
Portal authentication scheme |
Portal用户认证方案 |
Portal authorization scheme |
Portal用户授权方案 |
Portal accounting scheme |
Portal用户计费方案 |
RADIUS |
RADIUS方案 |
HWTACACS |
HWTACACS方案 |
LDAP |
LDAP方案 |
Local |
本地方案 |
None |
不认证、不授权和不计费 |
Accounting start failure action |
用户计费开始失败的动作,包括以下取值: · Online:如果用户计费开始失败,则保持用户在线 · Offline:如果用户计费开始失败,则强制用户下线 |
Accounting update failure max-times |
允许用户连续计费更新失败的次数 |
Accounting update failure action |
用户计费更新失败的动作,包括以下取值: · Online:如果用户计费更新失败,则保持用户在线 · Offline:如果用户计费更新失败,则强制用户下线 |
Accounting quota out policy |
用户计费配额耗尽策略,包括以下取值: · Online:如果用户计费配额耗尽,则保持用户在线 · Offline:如果用户计费配额耗尽,则强制用户下线 |
Service type |
ISP域的业务类型,取值为HSI,STB和VoIP |
Session time |
当用户异常下线时,设备上传到服务器的用户在线时间情况: · Include idle time:保留用户闲置切断时间 · Exclude idle time:扣除用户闲置切断时间 |
Dual-stack accounting method |
(暂不支持)双协议栈用户的计费方式,包括以下取值: · Merge:统一计费,即将双协议栈用户的IPv4流量和IPv6流量统一汇总后上送给计费服务器 · Separate:分别计费,即将双协议栈用户的IPv4流量和IPv6流量分别上送给计费服务器 |
Authorization attributes |
ISP的用户授权属性 |
Idle cut |
用户闲置切断功能,包括以下取值: · Enabled:处于开启状态,表示当ISP域中的用户在指定的最大闲置切断时间内产生的流量小于指定的最小数据流量时,会被强制下线 · Disabled:处于关闭状态,表示不对用户进行闲置切断控制,它为缺省状态 |
Idle timeout |
用户闲置切断时间(单位为分钟) |
Flow |
用户数据流量阈值(单位为字节) |
Traffic direction |
用户数据流量的统计方向,包括以下取值: · Both:表示用户双向数据流量 · Inbound:表示用户上行数据流量 · Outbound:表示用户下行数据流量 |
IP pool |
授权IPv4地址池的名称 |
ACL number |
授权ACL编号 |
User group |
授权User group的名称 |
IPv6 pool |
授权IPv6地址池的名称 |
URL |
授权重定向URL |
IGMP access limit |
授权IPv4用户可以同时点播的最大节目数 |
MLD access limit |
授权IPv6用户可以同时点播的最大节目数 |
VSI name |
授权VSI名称 |
VLAN ID |
授权VLAN ID |
Microsegment ID |
授权微分段ID |
Redirect match terminal rule |
授权重定向URL时,对用户终端进行匹配的规则 ISP域下的authorization-attribute命令未配置redirect参数时,本字段不显示 |
Rule |
匹配规则 |
Action |
授权属性的执行动作,取值包括: · deny:禁止满足匹配规则的终端设备访问重定向URL · permit:允许满足匹配规则的终端设备访问重定向URL |
Authen-fail action |
用户认证失败后采取的策略,包括以下取值: · Offline:直接下线 · Online in domain isp-name without authentication:保持在线,且采用指定的域重新进行授权/计费,不重新认证 |
Authen-radius-unavailable |
RADIUS认证服务器不可达时,用户的逃生域 |
Authen-radius-recover |
逃生域中的用户,在RADIUS认证服务器恢复可达后,认证失败后采取的策略,包括以下取值: · Offline:直接下线 · Online in domain isp-name:保持在线,且用户切换到指定逃生恢复域 · Reauthen:进行重认证 |
Temporary redirect |
表示是否开启暂时重定向功能 · Enabled:开启暂时重定向功能,发送给用户的HTTP/HTTPS重定向报文中携带的状态码为302 · Disabled:未开启暂时重定向功能,发送给用户的HTTP/HTTPS重定向报文中携带的状态码为200 |
LAN access radius cache |
表示是否开启lan-access用户的RADIUS授权信息缓存功能,取值包括: · Enabled:表示开启功能 · Disabled:表示关闭功能 |
Default domain name |
缺省ISP域名 |
display mubm record命令用来查询设备上记录的用户MAC地址与UUID的绑定表项。
display mubm record [ mac mac-address ] [ interface interface-type interface-number | slot slot-number ] [ access-type { dot1x | mac-auth } ]
mac mac-address:指定用户的MAC地址。mac-address为MAC地址,格式为H-H-H。若不指定该参数,则显示匹配上的所有MAC地址的UUID表项。
interface interface-type interface-number:指定用户的接入接口。interface-type interface-number为接口类型和接口编号。若不指定该参数,则显示匹配上的所有接口的UUID表项。
slot slot-number:指定成员设备。slot-number为设备在IRF中的成员编号。如果不指定本参数,则表示指定Master设备。
access-type:指定用户的接入类型。若不指定该参数,则显示匹配上的所有接入类型的UUID表项。
dot1x:表示802.1X认证接入。
mac-auth:表示MAC认证接入。
本命令用于显示设备上的UUID表项,该表项记录了MAC地址与UUID的映射关系,并在用户上线后自动生成,以及在用户下线时自动删除。若不指定任何参数,则表示显示所有UUID表项。
MAC地址和UUID的绑定关系由管理员根据实际的用户接入控制策略,在用户上线时使用的认证服务器上规划和管理,并在用户认证通过后通过授权属性下发给设备。客户端向DHCP服务器请求分配/释放IP地址时,设备上的DHCP snooping模块首先会基于UUID表项查找与客户端MAC地址绑定的UUID,并使用查找到的UUID对客户端DHCP报文中的Option 61取值(Client ID)进行替换,之后将DHCP报文发送给DHCP服务器。DHCP服务器收到客户端的DHCP报文后,将基于其中的UUID信息为特定的用户分配特定的IP地址。这种基于UUID的地址分配方式,可以非常灵活地满足不同场景下的IP地址分配需求。
# 显示与用户MAC地址0C-DA-41-1D-1E-EF绑定的UUID信息。
<Sysname> display mubm record mac 0C-DA-41-1D-1E-EF
Mac Address Access Type Interface UUID
0CDA-411D-1EEF Dot1x GE1/0/1 ff ff ff ff
0CDA-411D-1EEF MAC-auth GE1/0/2 41 41 41 41 42 42 42
表1-9 display mubm record命令显示信息描述表
Mac Address |
用户的MAC地址 |
Access Type |
用户的接入类型 · Dot1x:802.1X认证 · MAC-auth:MAC地址认证 |
用户的接入端口 |
UUID |
绑定的UUID值 该取值的内容与格式请以实际情况为准,本文仅为示例 |
domain命令用来创建ISP域,并进入ISP域视图。如果指定的ISP域已经存在,则直接进入ISP域视图。
undo domain命令用来删除指定的ISP域。
domain isp-name
undo domain isp-name
存在一个ISP域,名称为system。
isp-name:ISP域名,为1~255个字符的字符串,不区分大小写,不能包括“/”、“\”、“|”、“””、“:”、“*”、“?”、“<”、“>”以及“@”字符,且不能为字符串“d”、“de”、“def”、“defa”、“defau”、“defaul”、“default”、“i”、“if”、“if-”、“if-u”、“if-un”、“if-unk”、“if-unkn”、“if-unkno”、“if-unknow”和“if-unknown”。
所有的ISP域在创建后即处于active状态。
不能删除系统中预定义的ISP域system,只能修改该域的配置。
不能删除作为系统缺省ISP域的ISP域。如需删除一个系统缺省ISP域,请先使用undo domain default enable命令将其恢复为非缺省的ISP域。
建议设备上配置的ISP域名尽量短,避免用户输入的包含域名的用户名长度超过客户端可支持的最大用户名长度。
# 创建一个名称为test的ISP域,并进入其视图。
[Sysname] domain test
· display domain
· domain default enable
· domain if-unknown
· state (ISP domain view)
domain default enable命令用来配置系统缺省的ISP域,所有在登录时没有提供ISP域名的用户都属于这个域。
undo domain default enable命令用来恢复缺省情况。
domain default enable isp-name
存在一个系统缺省的ISP域,名称为system。
isp-name:ISP域名,为1~255个字符的字符串,不区分大小写,且必须已经存在。
系统中只能存在一个缺省的ISP域。
配置为缺省的ISP域不能被删除。如需删除一个系统缺省ISP域,请先使用undo domain default enable命令将其恢复为非缺省的ISP域。
# 创建一个新的ISP域test,并设置为系统缺省的ISP域。
[Sysname-isp-test] quit
[Sysname] domain default enable test
· display domain
· domain
domain if-unknown命令用来为未知域名的用户指定ISP域。
undo domain if-unknown命令用来恢复缺省情况。
domain if-unknown isp-name
没有为未知域名的用户指定ISP域。
isp-name:ISP域名。为1~255个字符的字符串,不区分大小写,不能包括“/”、“\”、“|”、“””、“:”、“*”、“?”、“<”、“>”以及“@”字符,且不能为字符串“d”、“de”、“def”、“defa”、“defau”、“defaul”、“default”、“i”、“if”、“if-”、“if-u”、“if-un”、“if-unk”、“if-unkn”、“if-unkno”、“if-unknow”和“if-unknown”。
设备将按照如下先后顺序选择认证域:接入模块指定的认证域-->用户名中指定的ISP域-->系统缺省的ISP域。其中,仅部分接入模块支持指定认证域。
如果根据以上原则决定的认证域在设备上不存在,但设备上为未知域名的用户指定了ISP域,则最终使用该指定的ISP域认证,否则,用户将无法认证。
# 为未知域名的用户指定ISP域为test。
[Sysname] domain if-unknown test
· display domain
if-match vpn-instance critical-microsegment命令用来配置指定VPN实例的Critical微分段。
undo if-match vpn-instance critical-microsegment命令用来删除指定VPN实例的Critical微分段。
if-match vpn-instance vpn-instance-name critical-microsegment microsegment-id [ vsi vsi-name ] [ url-user-logoff ]
undo if-match vpn-instance vpn-instance-name critical-microsegment
不存在VPN实例的Critical微分段。
逃生策略模板视图
vpn-instance-name:表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。
vsi vsi-name:VSI名称,为1~31个字符的字符串,区分大小写。此参数仅在VXLAN组网环境下使用,但是否需要配置要根据具体组网情况而定。
一个逃生策略模板视图下,最多允许配置128个不同VPN实例与微分段的绑定关系。
一个VPN实例只能与一个Critical微分段绑定,一个Critical微分段可以与不同的VPN实例绑定。
如果对一个VPN实例多次执行本命令绑定不同的Critical微分段,后配置的生效。
url-user-logoff参数仅对MAC地址认证用户生效。
# 在逃生策略模板abc下,配置与VPN test绑定的Critical微分段ID为123。
[Sysname-critical-profile-abc] if-match vpn-instance test critical-microsegment 123
· default critical-microsegment
if-match vpn-instance microsegment命令用来配置授权策略模板下指定VPN实例的微分段。
undo if-match vpn-instance microsegment命令用来删除授权策略模板下指定VPN实例的微分段。
if-match vpn-instance vpn-instance-name microsegment microsegment-id [ vsi vsi-name ]
undo if-match vpn-instance vpn-instance-name microsegment
不存在VPN实例的微分段。
授权策略模板视图
当用户所在的认证域中引用了授权策略模板,则非VPN用户可被授权该模板中配置的缺省微分段; VPN用户可被授权该模板中配置的对应VPN实例的微分段,如果模板中未配置对应VPN实例的微分段,则VPN用户将被授权模板中的缺省微分段。
一个授权策略模板视图下,最多允许配置128个不同VPN实例与微分段的绑定关系。
一个VPN实例只能与一个微分段绑定,一个微分段可以与不同的VPN实例绑定。
如果对一个VPN实例多次执行本命令绑定不同的微分段,后配置的生效。
# 在授权策略模板abc下,配置与VPN test绑定的微分段ID为123。
[Sysname] aaa author-profile abc
[Sysname-author-profile-abc] if-match vpn-instance test microsegment 123
· default microsegment
· display aaa author-profile
local-server log change-password-prompt命令用来开启密码修改周期性提醒日志功能。
undo local-server log change-password-prompt命令用来关闭密码修改周期性提醒日志功能。
密码修改周期性提醒日志功能处于开启状态。
为了提高系统的安全性,用户通过Telnet、SSH、HTTP、HTTPS、NETCONF over SSH、NETCONF over SOAP方式登录设备时,系统会根据指定的安全要求对用户密码进行检查。为了及时提醒用户修改不符合系统要求的密码,建议开启密码修改周期性提醒日志功能。
开启本功能后,系统将每隔24小时,对所有不符合密码检查策略的用户打印日志,提醒这些用户尽快修改当前密码。除了周期性提醒之外,系统还会在每个用户登录时,针对不符合密码检查策略的情况立即打印日志进行提醒。
· 对于通过Telnet、SSH、HTTP、HTTPS方式登录设备的用户,如果用户密码为弱密码,且系统在用户登录时未要求其立即更改密码,系统会打印此提醒日志。弱密码是指不符合如下任意一项要求的密码:
¡ 密码组合检测策略。
¡ 密码最小长度限制。
¡ 密码复杂度检查策略。
· 对于通过NETCONF over SSH、NETCONF over SOAP方式登录设备的用户,如果出现以下情况,系统会打印此提醒日志:
¡ 用户密码为弱密码。
¡ 用户密码为缺省密码。
¡ 全局密码管理功能开启后,用户首次登录或使用被更改过的密码。
¡ 用户密码已经过期。
仅当以下情况发生时,系统才会停止打印此提醒日志:
· 关闭了密码修改周期性提醒日志功能。
· 用户密码修改为符合系统安全要求的密码。
· 密码检查策略相关功能的开启状态发生变化,使得密码检查策略变得宽松。
· 密码检查策略的参数设置发生变化。
当前系统中的密码检查策略可通过display password-control命令查看。弱密码检查使用的密码组合检测策略、密码最小长度限制、密码复杂度检查策略可分别通过password-control composition、password-control length、password-control complexity命令修改。关于密码检查策略的具体介绍,请参见“安全命令参考”的“Password Control”。
# 开启密码修改周期性提醒日志功能。
[Sysname] local-server log change-password-prompt
· display password-control(安全命令参考/Password Control)
· password-control composition(安全命令参考/Password Control)
· password-control length(安全命令参考/Password Control)
nas-id bind vlan命令用来设置NAS-ID与VLAN的绑定关系。
undo nas-id bind vlan命令用来删除指定的NAS-ID和VLAN的绑定关系。
nas-id nas-identifier bind vlan vlan-id
undo nas-id nas-identifier bind vlan vlan-id
不存在NAS-ID与VLAN的绑定关系。
NAS-ID Profile视图
nas-identifier:NAS-ID名称,为1~31个字符的字符串,区分大小写。
vlan-id:与NAS-ID绑定的VLAN ID,取值范围为1~4094。
一个NAS-ID Profile视图下,可以指定多个NAS-ID与VLAN的绑定关系。
一个NAS-ID可以与多个VLAN绑定,但是一个VLAN只能与一个NAS-ID绑定。若多次将一个VLAN与不同的NAS-ID进行绑定,则最后的绑定关系生效。
# 在名称为aaa的NAS-ID Profile视图下,配置NAS-ID 222与VLAN 2的绑定关系。
[Sysname] aaa nas-id profile aaa
[Sysname-nas-id-prof-aaa] nas-id 222 bind vlan 2
· aaa nas-id profile
redirect move-temporarily enable命令用来开启暂时重定向功能。
undo redirect move-temporarily enable命令用来关闭暂时重定向功能。
暂时重定向功能处于关闭状态。
ISP域视图
缺省情况下,设备向用户发送HTTP/HTTPS重定向报文时采用Java Script的方式携带重定向URL,重定向报文中携带的状态码为200,用户终端通过解析HTTP/HTTPS报文中Java Script来获取重定向URL。如果用户访问网络的终端(例如APP)不支持解析HTTP/HTTPS报文中Java Script,将无法获取重定向URL,也就无法完成设备预期的重定向行为。这种情况下,设备管理员可以开启暂时重定向功能,改变设备发送HTTP/HTTPS重定向报文时携带重定向URL的方式来适配这些终端。
开启暂时重定向功能后,设备将通过发送状态码为302的暂时重定向响应报文向用户终端推送重定向URL。
目前,本功能仅对授权了重定向URL的有线802.1X和MAC地址认证用户生效。
若修改了本功能的配置,则修改后的配置仅对新上线的用户或已上线且重新授权的用户生效。
# 在ISP域test下,开启暂时重定向功能。
[Sysname-isp-test] redirect move-temporarily enable
· display domain
reset aaa abnormal-offline-record命令用来清除当前所有用户异常下线记录。
执行完该命令后,已被清除的记录不能恢复,因此需要谨慎使用。
# 清除当前所有用户异常下线记录。
<Sysname> reset aaa abnormal-offline-record
· display aaa abnormal-offline-record
reset aaa authorization-cache命令用来清除授权信息缓存表项。
reset aaa authorization-cache [ dot1x | mac-auth | static | web-auth ] [ mac mac-address ] [ username username ]
dot1x:清除802.1X认证用户的授权信息缓存表项。
mac-auth:清除MAC地址认证用户的授权信息缓存表项。
static:清除静态用户的授权信息缓存表项。
web-auth:清除Web认证用户的授权信息缓存表项。
mac mac-address:清除指定MAC地址的授权信息缓存表项。mac-address为MAC地址,格式为H-H-H。若不指定该参数,则表示清除不同类型用户的所有授权信息缓存表项。
username username:清除指定用户名的授权信息缓存表项。user-name为用户名,为1~253个字符的字符串,区分大小写。若不指定该参数,则表示清除所有用户名的授权信息缓存表项。
如果不指定任何参数,则清除所有已记录的授权信息缓存表项。
在M-LAG组网中,如需清除授权信息缓存表项,则两端M-LAG设备上需要同时执行本命令。
# 清除所有授权信息缓存表项。
<Sysname> reset aaa authorization-cache
· aaa authorization-cache enable
· display aaa authorization-cache
reset aaa normal-offline-record命令用来清除当前所有用户正常下线记录。
# 清除当前所有用户正常下线记录。
<Sysname> reset aaa normal-offline-record
reset aaa offline-record命令用来清除当前所有用户下线记录。
# 清除当前所有用户下线记录。
<Sysname> reset aaa offline-record
· display aaa offline-record
reset aaa online-fail-record命令用来清除当前所有用户上线失败记录。
# 清除当前所有用户上线失败记录。
<Sysname> reset aaa online-fail-record
· display aaa online-fail-record
session-time include-idle-time命令用来配置设备上传到服务器的用户在线时间中保留闲置切断时间。
undo session-time include-idle-time命令用来恢复缺省情况。
设备上传到服务器的用户在线时间中扣除闲置切断时间。
ISP域视图
请根据实际的计费策略决定是否在用户在线时间中保留闲置切断时间。该闲置切断时间在用户认证成功后由AAA授权,对于Portal认证用户,若接入接口上开启了Portal用户在线探测功能,则Portal在线探测闲置时长为闲置切断时间。
当用户正常下线时,设备上传到服务器上的用户在线时间为实际在线时间;当用户异常下线时,上传到服务器的用户在线时间具体如下:
· 若配置为保留闲置切断时间,则上传到服务器上的用户在线时间中包含了一定的闲置切断时间。此时,服务器上记录的用户时长将大于用户实际在线时长。
· 若配置为扣除闲置切断时间,则上传到服务器上的用户在线时间为,闲置切断检测机制计算出的用户已在线时长扣除掉一个闲置切断时间。此时,服务器上记录的用户时长将小于用户实际在线时长。
# 在ISP域test下,配置设备上传到服务器的用户在线时间中保留闲置切断时间。
[Sysname-isp-test] session-time include-idle-time
· display domain
state命令用来设置当前ISP域的状态。
undo state命令用来恢复缺省情况。
state { active | block }
undo state
当前ISP域处于活动状态。
ISP域视图
active:指定当前ISP域处于活动状态,即系统允许该域下的用户请求网络服务。
block:指定当前ISP域处于阻塞状态,即系统不允许该域下的用户请求网络服务。
当某个ISP域处于阻塞状态时,将不允许该域下的用户请求网络服务,但不影响已经在线的用户。
# 设置当前ISP域test处于阻塞状态。
[Sysname-isp-test] state block
· display domain
user-address-type命令用来设置当前ISP域的用户地址类型。
undo user-address-type命令用来恢复缺省情况。
user-address-type { ds-lite | ipv6 | nat64 | private-ds | private-ipv4 | public-ds | public-ipv4 }
未指定当前ISP域的用户地址类型。
ISP域视图
ds-lite:表示当前用户的地址类型为轻量级双栈地址。
ipv6:表示当前用户的地址类型为IPv6地址。
nat64:表示当前用户的地址类型为NAT64地址。
private-ds:表示当前用户的地址类型为私网双栈地址。
private-ipv4:表示当前用户的地址类型为私网IPv4地址。
public-ds:表示当前用户的地址类型为公网双栈地址。
public-ipv4:表示当前用户的地址类型为公网IPv4地址。
当更改当前ISP域的用户地址类型时,不影响已经在线的用户。
# 设置当前ISP域用户地址类型为私网IPv4地址。
[Sysname-isp-test] user-address-type private-ipv4
· display domain
access-limit命令用来设置使用当前本地用户名接入设备的最大用户数。
undo access-limit命令用来恢复缺省情况。
access-limit max-user-number
undo access-limit
不限制使用当前本地用户名接入的用户数。
本地用户视图
max-user-number:表示使用当前本地用户名接入设备的最大用户数,取值范围为1~1024。
本地用户视图下的access-limit命令只在该用户采用了本地计费方法的情况下生效。
对于网络接入类本地用户,还需要在用户接入的ISP域视图下配置accounting start-fail offline命令,否则使用当前用户名接入的用户数并不受access-limit命令的限制。
由于FTP/SFTP/SCP用户不支持计费,因此FTP/SFTP/SCP用户不受此属性限制。
# 允许同时以本地用户名abc在线的用户数为5。
[Sysname] local-user abc
[Sysname-luser-manage-abc] access-limit 5
· accounting start-fail offline
· display local-user
authorization-attribute命令用来设置本地用户或用户组的授权属性,该属性在本地用户认证通过之后,由设备下发给用户。
authorization-attribute { acl acl-number | idle-cut minutes | ip-pool ipv4-pool-name | ipv6-pool ipv6-pool-name | session-timeout minutes | url url-string | user-role role-name | vlan vlan-id | work-directory directory-name } *
undo authorization-attribute { acl | idle-cut | ip-pool | ipv6-pool | session-timeout | url | user-role role-name | vlan | work-directory } *
授权FTP/SFTP/SCP用户可以访问的目录为设备的根目录,但无访问权限。
由用户角色为network-admin、level-15或者system-admin的用户创建的设备管理类本地用户被授权用户角色network-operator。
本地用户视图
用户组视图
acl acl-number:指定本地用户的授权ACL。其中,acl-number为授权ACL的编号,取值范围2000~4999。与授权ACL规则匹配的流量,将按照规则中指定的permit或deny动作进行处理。
idle-cut minutes:设置本地用户的闲置切断时间。其中,minutes为设定的闲置切断时间,取值范围为1~120,单位为分钟。如果用户在线后连续闲置的时长超过该值,设备会强制该用户下线。
ip-pool ipv4-pool-name:指定本地用户的IPv4地址池信息。本地用户认证成功后,将允许使用该IPv4地址池分配地址。其中,ipv4-pool-name表示地址池名称,为1~63个字符的字符串,区分大小写。
ipv6-pool ipv6-pool-name:指定本地用户的IPv6地址池信息。本地用户认证成功后,将允许使用该IPv6地址池分配地址。其中,ipv6-pool-name表示地址池名称,为1~63个字符的字符串,不区分大小写。
session-timeout minutes:设置本地用户的会话超时时间。其中,minutes为设定的会话超时时间,取值范围为1~1440,单位为分钟。如果用户在线时长超过该值,设备会强制该用户下线。
url url-string:指定本地用户的重定向URL。其中,url-string为1~255个字符的字符串,区分大小写,且必须携带http://或https://前缀才可生效。重定向URL主要用于Web页面推送,例如,用户认证成功后首次访问网络时用于推送广告、通知类页面,或者用户欠费时将用于推送欠费提醒页面。此属性lan-access用户生效。
user-role role-name:指定本地用户的授权用户角色。其中,role-name表示用户角色名称,为1~63个字符的字符串,区分大小写。可以为每个用户最多指定64个用户角色。本地用户角色的相关命令请参见“基础配置命令参考”中的“RBAC”。该授权属性只能在本地用户视图下配置,不能在本地用户组视图下配置,且仅对设备管理类本地用户生效。
vlan vlan-id:指定本地用户的授权VLAN。其中,vlan-id为VLAN编号,取值范围为1~4094。本地用户认证成功后,将被授权仅可以访问指定VLAN内的网络资源。
work-directory directory-name:授权FTP/SFTP/SCP用户可以访问的目录。其中,directory-name表示FTP/SFTP/SCP用户可以访问的目录,为1~255个字符的字符串,不区分大小写,且该目录必须已经存在。
可配置的授权属性都有其明确的使用环境和用途,请针对用户的服务类型配置对应的授权属性:
· 对于Portal用户,仅授权属性ip-pool、ipv6-pool、session-timeout、acl有效。
· 对于Lan-access用户,仅授权属性acl、session-timeout、url、vlan有效。
· 对于Telnet、Terminal、SSH用户,仅授权属性idle-cut、user-role有效。
· 对于http、https用户,仅授权属性user-role有效。
· 对于FTP用户,仅授权属性user-role、work-directory有效。
· 对于其它类型的本地用户,所有授权属性均无效。
用户组的授权属性对于组内的所有本地用户生效,因此具有相同属性的用户可通过加入相同的用户组来统一配置和管理。
本地用户视图下未配置的授权属性继承所属用户组的授权属性配置,但是如果本地用户视图与所属的用户组视图下都配置了某授权属性,则本地用户视图下的授权属性生效。
指定授权ACL时,需要注意的是:
· 对于授权给lan-access用户的ACL,若某条rule规则中指定了vpn-instance,则该ACL不生效。不指定vpn-instance参数,表示该条规则对公网和私网报文都有效。
· 对于授权给Portal用户的ACL,若某条rule规则中指定了vpn-instance,则该ACL不生效。不指定vpn-instance参数,表示该条规则对公网和私网报文都有效。
在多台设备组成IRF的环境下,为了避免IRF系统进行主从倒换后FTP/SFTP/SCP用户无法正常登录,建议用户在指定工作目录时不要携带slot信息。
为确保本地用户仅使用本命令指定的授权用户角色,请先使用undo authorization-attribute user-role命令删除该用户已有的缺省用户角色。
被授权安全日志管理员的本地用户登录设备后,仅可执行安全日志文件管理相关的命令以及安全日志文件操作相关的命令,具体命令可通过display role name security-audit命令查看。安全日志文件管理相关命令的介绍,请参见“网络管理与监控”中的“信息中心”。文件系统管理相关命令的介绍,请参见“基础配置命令参考”中的“文件系统管理”。
为本地用户授权安全日志管理员角色时,需要注意的是:
· 安全日志管理员角色和其它用户角色互斥:
¡ 为一个用户授权安全日志管理员角色时,系统会通过提示信息请求确认是否删除当前用户的所有其它他用户角色;
¡ 如果已经授权当前用户安全日志管理员角色,再授权其它的用户角色时,系统会通过提示信息请求确认是否删除当前用户的安全日志管理员角色。
· 系统中的最后一个安全日志管理员角色的本地用户不可被删除。
为本地用户授权system-admin、security-admin、audit-admin角色时,需要注意的是:
· 这些角色和其它用户角色互斥,且彼此之间也互斥。
· 为一个用户授权这类用户角色时,系统会通过提示信息请求确认是否删除与当前用户角色互斥的其它用户角色。
# 配置网络接入类本地用户abc的授权VLAN为VLAN 2。
[Sysname] local-user abc class network
[Sysname-luser-network-abc] authorization-attribute vlan 2
# 配置用户组abc的授权VLAN为VLAN 3。
[Sysname] user-group abc
[Sysname-ugroup-abc] authorization-attribute vlan 3
# 配置设备管理类本地用户xyz的授权用户角色为security-audit(安全日志管理员)。
[Sysname] local-user xyz class manage
[Sysname-luser-manage-xyz] authorization-attribute user-role security-audit
This operation will delete all other roles of the user. Are you sure? [Y/N]:y
· display user-group
bind-attribute命令用来设置用户的绑定属性。
undo bind-attribute命令用来删除指定的用户绑定属性。
bind-attribute { ip ip-address | location interface interface-type interface-number | mac mac-address | vlan vlan-id } *
undo bind-attribute { ip | location | mac | vlan } *
未设置用户的绑定属性。
本地用户视图
ip ip-address:指定用户的IP地址。该绑定属性仅适用于lan-access类型中的802.1X用户。
location interface interface-type interface-number:指定用户绑定的接口。其中interface-type interface-number表示接口类型和接口编号。如果用户接入的接口与此处绑定的接口不一致,则认证失败。该绑定属性仅适用于设备管理、lan-access、Portal类型的用户。
mac mac-address:指定用户的MAC地址。其中,mac-address为H-H-H格式。该绑定属性仅适用于lan-access、Portal类型的用户。
vlan vlan-id:指定用户所属于的VLAN。其中,vlan-id为VLAN编号,取值范围为1~4094。该绑定属性仅适用于lan-access、Portal类型的用户。
设备对用户进行本地认证时,会检查用户的实际属性与配置的绑定属性是否一致,如果不一致或用户未携带该绑定属性则认证失败。
绑定属性的检测不区分用户的接入服务类型,因此在配置绑定属性时要考虑某接入类型的用户是否需要绑定某些属性。例如,只有支持IP地址上传功能的802.1X认证用户才可以配置绑定IP地址;对于不支持IP地址上传功能的MAC地址认证用户,如果配置了绑定IP地址,则会导致该用户的本地认证失败。
在绑定接口属性时要考虑绑定接口类型是否合理。对于不同接入类型的用户,请按照如下方式进行绑定接口属性的配置:
· 802.1X用户:配置绑定的接口为开启802.1X的二层以太网接口、二层聚合接口。
· MAC地址认证用户:配置绑定的接口为开启MAC地址认证的二层以太网接口、二层聚合接口。
· Web认证用户:配置绑定的接口为开启Web认证的二层以太网接口。
· Portal用户:若使能Portal的接口为VLAN接口,且没有通过portal roaming enable命令配置Portal用户漫游功能,则配置绑定的接口为用户实际接入的二层以太网接口;其它情况下,配置绑定的接口均为使能Portal的接口。
# 配置网络接入类本地用户abc的绑定MAC地址为11-11-11。
[Sysname-luser-network-abc] bind-attribute mac 11-11-11
company命令用来配置本地来宾用户所属公司。
undo company命令用来恢复缺省情况。
company company-name
undo company
未配置本地来宾用户所属公司。
本地来宾用户视图
company-name:本地来宾用户所属公司名称,为1~255个字符的字符串,区分大小写。
# 配置本地来宾用户abc所属的公司名称为yyy。
[Sysname] local-user abc class network guest
[Sysname-luser-network(guest)-abc] company yyy
description命令用来配置网络接入类本地用户的描述信息。
undo description命令用来恢复缺省情况。
未配置网络接入类本地用户的描述信息。
网络接入类本地用户视图
text:用户的描述信息,为1~255个字符的字符串,区分大小写。
# 配置网络接入类本地用户123的描述信息为Manager of MSC company。
[Sysname] local-user 123 class network
[Sysname-luser-network-123] description Manager of MSC company
display local-guest waiting-approval命令用来显示待审批来宾用户注册信息。
display local-guest waiting-approval [ user-name user-name ]
user-name user-name:来宾用户名称,为1~55个字符的字符串,区分大小写,不能携带域名,不能包括符号“\”、“|”、“/”、“:”、“*”、“?”、“<”、“>”和“@”,且不能为“a”、“al”或“all”。若不指定该参数,则表示所有来宾用户。
来宾可以通过Web页面注册为本地来宾用户,由来宾管理员对注册信息进行审批并补充用户信息,审批同意后,设备上将会创建相应的本地来宾用户,来宾可使用该用户接入访问网络。来宾管理员通过display命令可查询待审批来宾用户的注册信息。
# 显示所有待审批来宾用户的注册信息。
<Sysname> display local-guest waiting-approval
Total 1 guest entries matched.
Guest user Smith:
Full name : Smith Li
Company : YYY
Email : [email protected]
Phone : 139189301033
Description: The employee of YYY company
表1-10 display local-user-guest waiting-approval命令显示信息描述表
Total 1 guest entries matched. |
总计有1个来宾用户信息匹配 |
Full name |
来宾用户的姓名全称 |
Company |
来宾用户的公司名称 |
来宾用户的Email地址 |
Phone |
来宾用户的电话 |
来宾用户的描述信息 |
· reset local-guest waiting-approval
display local-user命令用来显示本地用户的配置信息和在线用户数的统计信息。
display local-user [ class { manage | network [ guest ] } | idle-cut { disable | enable } | service-type { ftp |http | https | lan-access | portal | ssh | telnet | terminal } | state { active | block } | user-name user-name class { manage | network [ guest ] } | vlan vlan-id ]
class:显示指定用户类别的本地用户信息。
manage:设备管理类用户。
network:网络接入类用户。
guest:来宾用户。
idle-cut { disable | enable }:显示开启或关闭闲置切断功能的本地用户信息。其中,disable表示未启用闲置切断功能的本地用户;enable表示启用了闲置切断功能并配置了闲置切断时间的本地用户。
service-type:显示指定用户类型的本地用户信息。
· ftp:FTP用户。
· http:HTTP用户。
· https:HTTPS用户。
· lan-access:lan-access类型用户(主要指以太网接入用户,比如802.1X用户)。
· portal:Portal用户。
· ssh:SSH用户。
· telnet:Telnet用户。
· terminal:从Console口登录的终端用户。
state { active | block }:显示处于指定状态的本地用户信息。其中,active表示用户处于活动状态,即系统允许该用户请求网络服务;block表示用户处于阻塞状态,即系统不允许用户请求网络服务。
user-name user-name:显示指定用户名的本地用户信息。其中,user-name表示本地用户名,为1~55个字符的字符串,区分大小写,不能携带域名,不能包括符号“\”、“|”、“/”、“:”、“*”、“?”、“<”、“>”和“@”,且不能为“a”、“al”或“all”。
vlan vlan-id:显示指定VLAN内的所有本地用户信息。其中,vlan-id为VLAN编号,取值范围为1~4094。
如果不指定任何参数,则显示所有本地用户信息。
# 显示所有本地用户的相关信息。
<Sysname> display local-user
Total 2 local users matched.
Device management user root:
State: Active
Service type: SSH/Telnet/Terminal
Access limit: Enabled Max access number: 3
Current access number: 1
User group: system
Bind attributes:
Work directory: flash:
User role list: network-admin
Password aging: 3 days
Password complexity: username checking
repeated characters checking
adjacent characters checking
Password history was last reset: 0 days ago
Network access user jj:
State: Active
Service type: LAN-access
User group: system
Bind attributes:
IP address: 2.2.2.2
Location bound: GigabitEthernet1/0/1
MAC address: 0001-0001-0001
VLAN ID: 2
Idle timeout: 33 minutes
ACL number: 2000
User role list: network-operator, level-0, level-3
Description: A network access user from company cc
Validity period:
Start date and time: 2016/01/01-00:01:01
Expiration date and time: 2017/01/01-01:01:01
Password length: 4 characters
Network access guest user1:
State: Active
Service type: LAN-access/Portal
User group: guest1
Full name: Jack
Company: cc
Email: [email protected]
Phone: 131129237
Sponsor full name: Sam
Sponsor department: security
Sponsor email: [email protected]
Description: A guest from company cc
Validity period:
Start date and time: 2016/04/01-08:00:00
Expiration date and time: 2017/04/03-18:00:00
表1-11 display local-user命令显示信息描述表
Total x local users matched. |
总计有x个本地用户匹配 |
State |
本地用户状态 · Active:活动状态 · Block:阻塞状态 |
Service type |
本地用户使用的服务类型 |
Access limit |
是否对使用该用户名的接入用户数进行限制 |
Max access number |
最大接入用户数 |
Current access number |
使用该用户名的当前接入用户数 |
User group |
本地用户所属的用户组 |
Bind attributes |
本地用户的绑定属性 |
IP address |
本地用户的IP地址 |
Location bound |
本地用户绑定的端口 |
MAC address |
本地用户的MAC地址 |
VLAN ID |
本地用户绑定的VLAN |
本地用户的授权属性 |
Idle timeout |
本地用户闲置切断时间(单位为分钟) |
Session-timeout |
本地用户的会话超时时间(单位为分钟) |
Work directory |
FTP/SFTP/SCP用户可以访问的目录 |
ACL number |
本地用户授权ACL |
VLAN ID |
本地用户授权VLAN |
User role list |
本地用户的授权用户角色列表 |
IP pool |
本地用户的授权IPv4地址池 |
IPv6 pool |
本地用户的授权IPv6地址池 |
URL |
本地用户的授权重定向URL |
Password control configurations |
本地用户的密码控制属性 |
Password aging |
密码老化时间 |
Password length |
密码最小长度 |
Password composition |
密码组合策略(密码元素的组合类型、至少要包含每种元素的个数) |
Password complexity |
密码复杂度检查策略(是否包含用户名或者颠倒的用户名;是否包含三个或以上相同字符;是否包含键盘上横向连续相邻的多个字符) |
Maximum login attempts |
用户最大登录尝试次数 |
Action for exceeding login attempts |
登录尝试次数达到设定次数后的用户账户锁定行为 |
Password history was last reset |
上一次清除密码历史记录的时间 |
Full name |
本地来宾用户的姓名 |
Company |
本地来宾用户的公司 |
本地来宾用户的Email地址 |
Phone |
本地来宾用户的电话号码 |
Sponsor full name |
本地来宾用户接待人的姓名 |
Sponsor department |
本地来宾用户接待人所属部门 |
Sponsor email |
本地来宾用户接待人的Email地址 |
网络接入类本地用户的描述信息 |
Validity period |
网络接入类本地用户有效期 |
Start date and time |
网络接入类本地用户开始生效的日期和时间 |
Expiration date and time |
网络接入类本地用户的失效日期和时间 |
display user-group命令用来显示用户组的配置信息。
display user-group { all | name group-name }
all:显示所有用户组的配置信息。
name group-name:显示指定用户组的配置。group-name表示用户组名称,为1~32个字符的字符串,不区分大小写。
# 显示所有用户组的相关配置。
<Sysname> display user-group all
Total 2 user groups matched.
User group: system
BYOD authorization attributes: Not configured
User group: jj
Work directory: flash:/
ACL number: 2000
VLAN ID: 2
Password aging: 2 days
表1-12 display user-group命令显示信息描述表
Total 2 user groups matched. |
总计有2个用户组匹配 |
User group |
用户组名称 |
授权属性信息 |
Idle timeout |
闲置切断时间(单位:分钟) |
Session-timeout |
会话超时时间(单位:分钟) |
Work directory |
ACL number |
授权ACL号 |
VLAN ID |
授权VLAN ID |
IP pool |
授权IPv4地址池 |
IPv6 pool |
授权IPv6地址池 |
URL |
授权重定向URL |
BYOD authorization attributes |
(暂不支持)BYOD授权属性信息 |
用户组的密码控制属性 |
Password aging |
密码老化时间 |
Password length |
密码最小长度 |
用户最大登录尝试次数 |
email命令用来配置本地来宾用户的Email地址。
undo email命令用来恢复缺省情况。
email email-string
undo email
未配置本地来宾用户的Email地址。
本地来宾用户视图
email-string:本地来宾用户的Email地址,为按照RFC 822定义的1~255个字符的字符串,区分大小写,例如[email protected]。
设备可以通过本命令配置的Email地址给来宾用户发送通知邮件。
# 配置本地来宾用户abc的Email地址为[email protected]。
[Sysname-luser-network(guest)-abc] email [email protected]
full-name命令用来配置本地来宾用户的姓名。
undo full-name命令用来恢复缺省情况。
full-name name-string
undo full-name
未配置本地来宾用户的姓名。
本地来宾用户视图
name-string:本地来宾用户的姓名,为1~255个字符的字符串,区分大小写。
# 配置本地来宾用户abc的姓名为abc Snow。
[Sysname-luser-network(guest)-abc] full-name abc Snow
group命令用来设置本地用户所属的用户组。
undo group命令用来恢复缺省配置。
group group-name
undo group
本地用户属于用户组system。
本地用户视图
group-name:用户组名称,为1~32个字符的字符串,不区分大小写。
# 设置设备管理类本地用户111所属的用户组为abc。
[Sysname] local-user 111 class manage
[Sysname-luser-manage-111] group abc
local-guest email format命令用来配置本地来宾用户通知邮件的主题和内容。
undo local-guest email format命令用来删除指定的本地来宾用户通知邮件的主题和内容。
local-guest email format to { guest | manager | sponsor } { body body-string | subject sub-string }
undo local-guest email format to { guest | manager | sponsor } { body | subject }
未配置本地来宾用户通知邮件的主题和内容。
to:指定邮件的收件人。
· guest:表示来宾用户。
· manager:表示来宾管理员。
· sponsor:表示来宾接待人。
body body-string:邮件的内容。其中,body-string为1~255个字符的字符串,区分大小写。
subject sub-string:邮件的主题。其中,sub-string为1~127个字符的字符串,区分大小写。
在本地来宾用户注册、创建过程中,设备需要向不同角色的用户发送通知邮件,邮件的主题和内容通过本命令设置,例如,本地来宾用户通过Web页面完成账户注册之后,设备会向来宾管理员发送该用户的审批申请邮件;本地来宾用户创建之后,设备会向本地来宾用户或来宾接待人邮箱发送注册成功通知邮件。
可对不同的收件人指定不同的邮件主题和内容。同一类收件人的邮件格式只能存在一种配置,新配置将覆盖已有配置。
必须同时配置收件人的邮件主题和内容,否则设备不会给该收件人发送邮件。
# 配置本地来宾用户通知邮件的主题和内容。
[Sysname] local-guest email format to guest subject Guest account information
[Sysname] local-guest email format to guest body A guest account has been created for you. The username, password, and validity period of the account are given below.
· local-guest email sender
· local-guest email smtp-server
· local-guest manager-email
· local-guest send-email
local-guest email sender命令用来配置本地来宾用户通知邮件的发件人地址。
undo local-guest email sender命令用来恢复缺省情况。
local-guest email sender email-address
未配置本地来宾用户通知邮件的发件人地址。
email-address:邮件发件人地址,为1~255个字符的字符串,区分大小写。
未配置发件人地址的情况下,设备无法向任何收件人发送关于本地来宾用户的通知邮件。
只能存在一个本地来宾用户的发件人地址。多次执行本命令,最后一次执行的命令生效。
# 配置本地来宾用户通知邮件的发件人地址为[email protected]。
[Sysname] local-guest email sender [email protected]
· local-guest email format
local-guest email smtp-server命令用来配置为本地来宾用户发送Email使用的SMTP服务器。
undo local-guest send-email smtp-server命令用来恢复缺省情况。
local-guest email smtp-server url-string
undo local-guest email smtp-server
未配置为本地来宾用户发送Email使用的SMTP服务器。
url-string:STMP服务器的URL,为1~255个字符的字符串,区分大小写,符合标准SMTP协议规范,以smtp://开头。
只能存在一个为本地来宾用户发送Email使用的SMTP服务器。多次执行本命令,最后一次执行的命令生效。
# 配置为本地来宾用户发送Email使用的SMTP服务器URL为smtp://www.test.com/smtp。
[Sysname] local-guest email smtp-server smtp://www.test.com/smtp
local-guest generate命令用来批量创建本地来宾用户。
local-guest generate username-prefix name-prefix [ password-prefix password-prefix ] suffix suffix-number [ group group-name ] count user-count validity-datetime start-date start-time to expiration-date expiration-time
username-prefix name-prefix:用户名前缀,name-prefix为1~45个字符的字符串,区分大小写,不能含有字符\、|、/、:、*、?、<、>或@。
password-prefix password-prefix:明文密码前缀,password-prefix为1~53个字符的字符串,区分大小写。若不指定该参数,则由系统为用户逐一生成随机密码
suffix suffix-string:用户名和密码的递增编号后缀,suffix-string为1~10个数字的字符串。
group group-name:用户所属用户组名,group-name为1~32个字符的字符串,区分大小写。若不指定该参数,则表示用户属于system组。
count user-count:批量创建用户的数量,user-count的取值范围为1~256。
validity-datetime:用户有效期。
start-date:用户有效期的开始日期,格式为MM/DD/YYYY(月/日/年)或者YYYY/MM/DD(年/月/日),MM的取值范围为1~12,DD的取值范围与月份有关,YYYY的取值范围为2000~2035。
start-time:用户有效期的开始时间,格式为HH:MM:SS(小时:分钟:秒),HH取值范围为0~23,MM和SS取值范围为0~59。如果要设置成整分,则可以不输入秒;如果要设置成整点,则可以不输入分和秒。比如将start-time参数设置为0表示零点。
to:指定用户有效期的结束日期和结束时间。
expiration-date:用户有效期的结束日期,格式为MM/DD/YYYY(月/日/年)或者YYYY/MM/DD(年/月/日),MM的取值范围为1~12,DD的取值范围与月份有关,YYYY的取值范围为2000~2035。
expiration-time:用户有效期的结束时间,格式为HH:MM:SS(小时:分钟:秒),HH取值范围为0~23,MM和SS取值范围为0~59。如果要设置成整分,则可以不输入秒;如果要设置成整点,则可以不输入分和秒。比如将expiration-time参数设置为0表示零点。
批量创建的本地来宾用户名由指定的用户名前缀和编号后缀组合而成,且每创建一个用户,用户名编号后缀递增1。例如,当用户名前缀为abc,递增编号后缀为1,生成用户数量为3时,生成的用户名分别为abc1、abc2和abc3。如果指定了密码前缀,则批量创建的本地来宾用户密码由密码前缀和编号后缀组合而成,且逐用户递增。
如果申请创建的本地来宾用户数量过多,导致资源不足时,部分本地来宾用户的批量创建将会失败。
如果批量创建的本地来宾用户与设备上已有的本地来宾用户重名,则批量创建的用户会覆盖已有的同名用户。
# 批量创建20个本地来宾用户,用户名从abc01递增到abc20,属于用户组visit,有效期为2014/10/01 00:00:00到2015/10/02 12:00:00。
[Sysname] local-guest generate username-prefix abc suffix 01 group visit count 20 validity-datetime 2014/10/01 00:00:00 to 2015/10/02 12:00:00
· local-user
local-guest manager-email命令用来配置来宾管理员的Email地址。
undo local-guest manager-email命令用来恢复缺省情况。
local-guest manager-email email-address
未配置来宾管理员的Email地址。
email-address:来宾管理员的Email地址,为按照RFC 822定义的1~255个字符的字符串,区分大小写,例如[email protected]。
在本地来宾用户通过Web页面完成账户注册之后,设备会向来宾管理员邮箱发送该用户的审批申请邮件。
只能存在一个来宾管理员的Email地址。多次执行本命令,最后一次执行的命令生效。
# 配置来宾管理员的Email地址为[email protected]。
[Sysname] local-guest manager-email [email protected]
local-guest send-email命令用来配置向本地来宾用户邮箱和来宾接待人邮箱发送邮件。
local-guest send-email user-name user-name to { guest | sponsor }
user-name user-name:本地来宾用户的用户名,为1~55个字符的字符串,区分大小写,不能携带ISP域名,不能包括符号“\”、“|”、“/”、“:”、“*”、“?”、“<”、“>”和“@”,且不能为“a”、“al”或“all”。
to:指定邮件的收件人。
· guest:本地来宾用户。
· sponsor:来宾接待人。
当本地来宾用户创建之后,设备管理员可通过此命令将用户的密码及有效期信息发送到本地来宾用户或来宾接待人邮箱中。
# 向本地来宾用户abc的邮箱发送有关该用户账号信息的通知邮件。
<Sysname> local-guest send-email user-name abc to guest
· sponsor-email
local-guest timer命令用来配置本地来宾用户的等待审批超时定时器。
local-guest timer waiting-approval time-value
undo local-guest timer waiting-approval
本地来宾用户的等待审批超时定时器值为24小时。
time-value:本地来宾用户等待审批的超时时间,取值范围为1~720,单位为小时。
当一个来宾用户在Web页面上完成账户注册之后,设备会为其开启一个来宾注册信息等待审批超时定时器,若在该定时器设置的时长内来宾管理员没有对其注册信息进行审批,则设备将删除该来宾注册信息。
# 配置本地来宾用户的等待审批超时定时器的值为12小时。
[Sysname] local-guest timer waiting-approval 12
local-user命令用来添加本地用户,并进入本地用户视图。如果指定的本地用户已经存在,则直接进入本地用户视图。
undo local-user命令用来删除指定的本地用户。
local-user user-name [ class { manage | network [ guest ] } ]
undo local-user { user-name class { manage | network [ guest ] } | all [ service-type { ftp | http | https | lan-access | portal | ssh | telnet | terminal } | class { manage | network [ guest ] } ] }
不存在本地用户。
user-name:表示本地用户名,为1~55个字符的字符串,区分大小写。用户名不能携带域名,不能包括符号“\”、“|”、“/”、“:”、“*”、“?”、“<”、“>”和“@”,且不能为与“all”或“auto-delete”中自第一个字母“a”起向右若干连续字符完全相同的字符串,例如不能为“a”、“al”、“all”、“au”、“aut”、“auto”、“auto-”、“auto-d”等。
class:指定本地用户的类别。若不指定本参数,则表示设备管理类用户。
manage:设备管理类用户,用于登录设备,对设备进行配置和监控。此类用户可以提供ftp、http、https、telnet、ssh、terminal服务。
network:网络接入类用户,用于通过设备接入网络,访问网络资源。此类用户可以提供lan-access、portal服务。
guest:来宾用户,仅能在账户有效期内提供lan-access和portal服务。
all:所有的用户。
service-type:指定用户的类型。
· ftp:表示FTP类型用户。
· http:表示HTTP类型用户。
· https:表示HTTPS类型用户。
· lan-access:表示lan-access类型用户(主要指以太网接入用户,比如802.1X用户)。
· portal:表示Portal用户。
· ssh:表示SSH用户。
· telnet:表示Telnet用户。
· terminal:表示从Console口登录的终端用户。
设备支持配置多个本地用户,设备管理类本地用户的最大数目为1024,网络接入类本地用户的最大数目为4294967295。
如果配置的本地用户名中包含中文,则需要该本地用户登录设备时使用的终端软件采用的字符集编码格式和设备保存该本地用户配置时采用的编码格式(GB18030)保持一致,否则,可能导致包含中文字符的用户名在设备上不能按照预期解析,甚至导致本地认证失败。
# 添加名称为user1的设备管理类本地用户。
[Sysname-luser-manage-user1]
# 添加名称为user2的网络接入类本地用户。
[Sysname] local-user user2 class network
[Sysname-luser-network-user2]
# 添加名称为user3的网络接入类本地来宾用户。
[Sysname] local-user user3 class network guest
[Sysname-luser-network(guest)-user3]
· service-type (Local user view)
local-user auto-delete enable命令用来开启本地用户过期自动删除功能。
undo local-user auto-delete enable命令用来恢复缺省情况。
本地用户过期自动删除功能处于关闭状态。
本地用户过期自动删除功能处于开启状态时,设备将定时(10分钟,不可配)检查网络接入类本地用户是否过期并自动删除过期的本地用户。
# 开启本地用户过期自动删除功能。
[Sysname] local-user auto-delete enable
· validity-datetime
local-user-export命令用来从设备导出本地来宾用户信息到指定路径的CSV文件。
local-user-export class network guest url url-string
class:指定本地用户的类别。
network:网络接入类用户。
guest:本地来宾用户。
url url-string:保存本地用户信息文件的URL,为1~255个字符的字符串,不区分大小写。
导出的CSV文件可直接或在编辑之后通过local-user-import命令导入到本设备或其它支持该命令的设备上使用,但文件内容必须符合该命令的要求。
本命令支持TFTP和FTP两种文件上传方式,具体的URL格式要求如下:
· TFTP协议URL格式:tftp://server/path/filename,server为TFTP服务器IP地址或主机名,path为TFTP工作目录的相对路径,例如tftp://1.1.1.1/user/user.csv。
· FTP协议URL格式:
¡ 携带用户名和密码的格式为ftp://username:password@server/path/filename。其中,username为FTP用户名,password为FTP认证密码,server为FTP服务器IP地址或主机名,path为FTP工作目录的相对路径,例如ftp://1:[email protected]/user/user.csv。如果FTP用户名中携带域名,则该域名会被设备忽略,例如ftp://1@abc:[email protected]/user/user.csv将被当作ftp://1:[email protected]/user/user.csv处理。
¡ 不需要携带用户名和密码的格式为ftp://server/path/filename,例如ftp://1.1.1.1/user/user.csv。
# 导出本地来宾用户信息到ftp://1.1.1.1/user/路径的guest.csv文件中。
[Sysname] local-user-export class network guest url ftp://1.1.1.1/user/guest.csv
· local-user-import
local-user-import命令用来从指定路径的文件中导入用户信息并创建本地用户。
local-user-import class network guest url url-string validity-datetime start-date start-time to expiration-date expiration-time [ auto-create-group | override | start-line line-number ] *
class:指定本地用户的类别。
network:网络接入类用户。
guest:本地来宾用户。
url url-string:要导入用户信息文件的URL。其中,url-string为1~255个字符的字符串,不区分大小写。
validity-datetime:指定用户的有效期。
auto-create-group:表示当设备上不存在用户所属的用户组时,系统会自动创建用户组,并将用户加入该用户组。若不指定该参数,则表示当设备上不存在用户所属的用户组时,系统不会创建对应的用户组,而是将该用户加入缺省用户组system。
override:表示当导入的用户名已经存在于设备上时,系统使用导入的用户信息覆盖掉已有的同名用户配置。若不指定该参数,则表示不导入文件中的同名用户信息,即保留设备上已有的同名用户配置。
start-line line-number:表示从文件的指定行开始导入用户信息。其中,line-number为文件内容的行编号。若不指定该参数,则表示导入文件中的所有用户信息。
用于导入的CSV文件中包含多个用户信息,每个用户的各项字段严格按照以下顺序出现:
· Username:用户名。该字段必须存在。
· Password:明文用户密码。若该字段为空,则导入时系统会生成一个密文随机密码。
· User group:所属用户组,用于本地授权。若该字段为空,则表示属于system组。
· Guest full name:来宾用户姓名。
· Guest company:来宾用户公司。
· Guest email:来宾用户Email地址。
· Guest phone:来宾用户电话号码。
· Guest description:来宾用户描述信息。
· Sponsor full name:接待人姓名。
· Sponsor department:接待人部门。
· Sponsor email:接待人Email地址。
以上所有字段的取值必须满足设备上本地用户相应属性的取值要求,否则当前用户的导入操作将会失败,且导入操作中止。之后,可以根据系统提示信息中的出错行编号选择下次从指定行开始导入剩余用户信息。
CSV文件中的不同用户信息之间用回车换行分隔,且每项信息之间以逗号分隔。如果某项信息中包含逗号,则必须在该条信息两端加双引号。例如:Jack,abc,visit,Jack Chen,ETP,[email protected],1399899,”The manager of ETP, come from TP.”,Sam Wang,Ministry of personnel,[email protected]
本命令支持TFTP和FTP两种文件下载方式,具体的文件URL格式要求如下:
· FTP协议URL格式:
¡ 不需要携带用户名和密码的格式为ftp://path/filename,例如ftp://1.1.1.1/user/user.csv。
# 从ftp://1.1.1.1/user/guest.csv路径中导入本地来宾用户信息,用户的有效期为2014/10/01 00:00:00到2014/10/02 12:00:00。
[Sysname] local-user-import class network guest url ftp://1.1.1.1/user/guest.csv validity-datetime 2014/10/01 00:00:00 to 2014/10/02 12:00:00
· local-user-export
password命令用来设置本地用户的密码。
undo password命令用来恢复缺省情况。
(非FIPS模式)
password [ { hash | simple } string ]
undo password
(FIPS模式)
password
(非FIPS模式)
不存在本地用户密码,即本地用户认证时无需输入密码,只要用户名有效且其它属性验证通过即可认证成功。
(FIPS模式)
不存在本地用户密码,但本地用户认证时不能成功。
设备管理类本地用户视图
hash:表示以哈希方式设置密码。
simple:表示以明文方式设置密码,该密码将以哈希方式存储,哈希加密算法为SHA-512。
string:密码字符串,区分大小写。非FIPS模式下,明文密码为1~63个字符的字符串;哈希密码为1~110个字符的字符串。FIPS模式下,明文密码为15~63个字符的字符串,密码元素的最少组合类型为4(必须包括数字、大写字母、小写字母以及特殊字符)。
如果不指定任何参数,则表示以交互式设置明文形式的密码。
在非FIPS模式下,可以不为本地用户设置密码。若不为本地用户设置密码,则该用户认证时无需输入密码,只要用户名有效且其它属性验证通过即可认证成功。为提高用户账户的安全性,建议设置本地用户密码。
在FIPS模式下,必须且只能通过交互式方式设置明文密码,否则用户的本地认证不能成功。
在全局Password Control功能处于开启的情况下,需要注意的是:
· 所有历史密码都以哈希方式存储。
· 当前登录用户以明文方式修改自己的密码时,需要首先提供现有的明文密码(如果现有密码为空密码,则无需提供现有密码),然后保证输入的新密码与所有历史密码不同,且至少要与现有密码存在4个不同字符的差异。
· 当前登录用户以明文方式修改其它用户的密码时,需要保证新密码与所有历史密码不同。
· 当前登录用户删除自己的密码时,需要提供现有的明文密码(如果现有密码为空密码,则无需提供现有密码)。
· 其它情况下,均不需要提供现有明文密码,也不与历史密码进行比较。
# 设置设备管理类本地用户user1的密码为明文123456TESTplat&!。
# 以交互式方式设置设备管理类本地用户test的密码。
[Sysname-luser-manage-test] password
Password:
confirm :
undo password
网络接入类本地用户视图
cipher:表示以密文方式设置密码。
simple:表示以明文方式设置密码,该密码将以密文形式存储,加密算法为AES-256。
string:密码字符串,区分大小写。明文密码为1~63个字符的字符串;密文密码为1~117个字符的字符串。
# 设置网络接入类本地用户user1的密码为明文123456TESTuser&!。
[Sysname] local-user user1 class network
[Sysname-luser-network-user1] password simple 123456TESTuser&!
phone命令用来配置本地来宾用户的电话号码。
undo phone命令用来恢复缺省情况。
phone phone-number
undo phone
未配置本地来宾用户电话号码。
本地来宾用户视图
phone-number:本地来宾用户的电话号码,为1~32个字符的字符串。
# 配置本地来宾用户abc的电话号码为13813723920。
[Sysname-luser-network(guest)-abc] phone 13813723920
reset local-guest waiting-approval命令用来清除待审批的来宾用户注册信息。
reset local-guest waiting-approval [ user-name user-name ]
# 清除所有待审批的来宾用户注册信息。
<Sysname> reset local-guest waiting-approval
· display local-guest waiting-approval
service-type命令用来设置用户可以使用的服务类型。
undo service-type命令用来删除用户可以使用的服务类型。
(非FIPS模式)
service-type { ftp | lan-access | { http | https | ssh | telnet | terminal } * | portal }
undo service-type { ftp | lan-access | { http | https | ssh | telnet | terminal } * | portal }
(FIPS模式)
service-type { lan-access | { https | ssh | terminal } * | portal }
undo service-type { lan-access | { https | ssh | terminal } * | portal }
系统不对用户授权任何服务,即用户不能使用任何服务。
本地用户视图
ftp:指定用户可以使用FTP服务。若授权FTP服务,授权目录可以通过authorization-attribute work-directory命令来设置。
http:指定用户可以使用HTTP服务。
https:指定用户可以使用HTTPS服务。
lan-access:指定用户可以使用lan-access服务。主要指以太网接入,比如用户可以通过802.1X认证接入。
ssh:指定用户可以使用SSH服务。
telnet:指定用户可以使用Telnet服务。
terminal:指定用户可以使用terminal服务(即从Console口登录)。
portal:指定用户可以使用Portal服务。
可以通过多次执行本命令,设置用户可以使用多种服务类型。
# 指定设备管理类用户可以使用Telnet服务和FTP服务。
[Sysname-luser-manage-user1] service-type telnet
[Sysname-luser-manage-user1] service-type ftp
snmp-agent trap enable local-server命令用来开启本地用户密码变化告警功能。
undo snmp-agent trap enable local-server命令用来关闭本地用户密码变化告警功能。
snmp-agent trap enable local-server [ manage-password-change | network-password-change ] *
undo snmp-agent trap enable local-server [ manage-password-change | network-password-change ] *
本地用户密码修改告警功能处于关闭状态。
manage-password-change:设备管理类本地用户的密码发生变化。
network-password-change:网络接入类本地用户的密码发生变化。
开启本地用户密码变化告警功能后,系统将在以下几种情况下生成告警信息:
· 通过命令行配置或者修改本地用户密码。
· 通过NETCONF、MIB、Web等方式修改本地用户密码。
· Portal本地认证用户在登录页面上在线修改密码。
生成的告警信息将发送到设备的SNMP模块,通过设置SNMP中告警信息的发送参数,来决定告警信息输出的相关属性。有关告警信息的详细介绍,请参见“网络管理和监控配置指导”中的“SNMP”
不指定任何参数时,表示同时开启或关闭设备管理类用户和网络接入类用户密码变化告警功能。
# 开启设备管理类本地用户密码变化告警功能。
[Sysname] snmp-agent trap enable local-server manage-password-change
sponsor-department命令用来配置本地来宾用户接待人所属部门。
undo sponsor-department命令用来恢复缺省情况。
sponsor-department department-string
未配置本地来宾用户接待人所属部门。
department-string:本地来宾用户接待人所属部门名称,为1~127个字符的字符串,区分大小写。
# 配置本地来宾用户abc的接待人所属部门为test。
[Sysname-luser-network(guest)-abc] sponsor-department test
sponsor-email命令用来配置本地来宾用户接待人的Email地址。
undo sponsor-email命令用来恢复缺省情况。
sponsor-email email-string
undo sponsor-email
未配置本地来宾用户接待人的Email地址。
本地来宾用户视图
email-string:本地来宾接待人的Email地址,为按照RFC 822定义的1~255个字符的字符串,区分大小写。
# 配置本地来宾用户abc的接待人Email地址为[email protected]。
[Sysname-luser-network(guest)-abc] sponsor-email [email protected]
sponsor-full-name命令用来配置本地来宾用户的接待人姓名。
undo sponsor-full-name命令用来恢复缺省情况。
sponsor-full-name name-string
未配置本地来宾用户的接待人姓名。
本地来宾用户视图
name-string:本地来宾用户接待人姓名,为1~255个字符的字符串,区分大小写。
# 配置本地来宾用户abc的接待人姓名为Sam Li。
[Sysname-luser-network(guest)-abc] sponsor-full-name Sam Li
state命令用来设置当前本地用户的状态。
undo state
本地用户处于活动状态。
本地用户视图
active:指定当前本地用户处于活动状态,即系统允许当前本地用户请求网络服务。
block:指定当前本地用户处于“阻塞”状态,即系统不允许当前本地用户请求网络服务。
# 设置设备管理类本地用户user1处于“阻塞”状态。
[Sysname-luser-manage-user1] state block
user-group命令用来创建用户组,并进入用户组视图。如果指定的用户组已经存在,则直接进入用户组视图。
undo user-group命令用来删除指定的用户组。
user-group group-name
undo user-group group-name
存在一个用户组,名称为system。
用户组是一个本地用户的集合,某些需要集中管理的属性可在用户组中统一配置和管理。
不允许删除一个包含本地用户的用户组。
不能删除系统中存在的默认用户组system,但可以修改该用户组的配置。
# 创建名称为abc的用户组并进入其视图。
validity-datetime命令用来配置网络接入类本地用户的有效期。
undo validity-datetime命令用来恢复缺省情况。
(网络接入类本地用户视图)
validity-datetime { from start-date start-time to expiration-date expiration-time | from start-date start-time | to expiration-date expiration-time }
(本地来宾用户视图)
validity-datetime from start-date start-time to expiration-date expiration-time
未限制本地用户的有效期,该用户始终有效。
网络接入类本地用户视图/本地来宾用户视图
to:指定用户有效期的结束日期和结束时间。若不指定该参数,则表示仅限定用户有效期的开始日期和时间。
网络接入类本地用户在有效期内才能认证成功。
若同时指定了有效期的开始时间和结束时间,则有效期的结束时间必须晚于起始时间。
如果仅指定了有效期的开始时间,则表示该时间到达后,用户一直有效。
如果仅指定了有效期的结束时间,则表示该时间到达前,用户一直有效。
设备作为RADIUS服务器时使用RADIUS用户数据库对接入用户进行身份验证,RADIUS用户数据由网络接入类本地用户配置直接生成,但设备仅关心RADIUS用户的有效期结束时间,不关心其有效期开始时间。
# 配置网络接入类本地用户123的有效期为2015/10/01 00:00:00到2016/10/02 12:00:00。
[Sysname-luser-network-123] validity-datetime from 2015/10/01 00:00:00 to 2016/10/02 12:00:00
aaa device-id命令用来配置设备ID。
undo aaa device-id命令用来恢复缺省情况。
aaa device-id device-id
undo aaa device-id
设备ID为0。
device-id:设备ID,取值范围为1~255。
RADIUS计费过程使用Acct-Session-Id属性作为用户的计费ID。设备使用系统时间、随机数以及设备ID为每个在线用户生成一个唯一的Acct-Session-Id值。
修改后的设备ID仅对新上线用户生效。
# 配置设备ID为1。
[Sysname] aaa device-id 1
accounting-on enable命令用来开启accounting-on功能。
undo accounting-on enable命令用来关闭accounting-on功能。
accounting-on enable [ interval interval | send send-times ] *
accounting-on功能处于关闭状态。
RADIUS方案视图
interval interval:指定accounting-on报文重发时间间隔,取值范围为1~15,单位为秒,缺省值为3。
send send-times:指定accounting-on报文的最大发送次数,取值范围为1~255,缺省值为50。
accounting-on功能使得整个设备在重启之后通过发送accounting-on报文通知该方案所使用的RADIUS计费服务器,要求RADIUS服务器停止计费且强制该设备的用户下线。
开启accounting-on功能后,请执行save命令保证accounting-on功能在整个设备下次重启后生效。关于命令的详细介绍请参见“基础配置命令参考”中的“配置文件管理”。
本命令设置的accounting-on参数会立即生效。
# 在RADIUS方案radius1中,开启accounting-on功能并配置accounting-on报文重发时间间隔为5秒、accounting-on报文的最大发送次数为15次。
[Sysname] radius scheme radius1
[Sysname-radius-radius1] accounting-on enable interval 5 send 15
· display radius scheme
accounting-on extended命令用来开启accounting-on扩展功能。
undo accounting-on extended命令用来关闭accounting-on扩展功能。
accounting-on扩展功能处于关闭状态。
RADIUS方案视图
accounting-on扩展功能是为了适应分布式架构而对accounting-on功能的增强。只有在accounting-on功能开启的情况下,accounting-on扩展功能才能生效。
accounting-on扩展功能适用于lan-access用户,该类型的用户数据均保存在用户接入的成员设备上。开启accounting-on扩展功能后,当有用户发起接入认证的成员设备重启时,设备会向RADIUS服务器发送携带成员设备标识的accounting-on报文,用于通知RADIUS服务器对该成员设备的用户停止计费且强制用户下线。accounting-on报文的重发间隔时间以及最大发送次数由accounting-on enable命令指定。如果自上一次重启之后,成员设备上没有用户接入认证的记录,则该成员设备再次重启,并不会触发设备向RADIUS服务器发送携带成员设备标识的accounting-on报文。
开启accounting-on扩展功能后,请执行save命令保证accounting-on扩展功能在成员设备下次重启后生效。关于save命令的详细介绍请参见“基础配置命令参考”中的“配置文件管理”。
# 在RADIUS方案radius1中,开启accounting-on扩展功能。
[Sysname-radius-radius1] accounting-on extended
· accounting-on enable
attribute 5 format命令用来配置RADIUS Attribute 5的格式。
undo attribute 5 format命令用来恢复缺省情况。
attribute 5 format port
采用单层VLAN格式封装RADIUS Attribute 5,具体为:成员设备编号(8bit)+槽位号(4bit)+端口号(8bit)+VLAN ID(12bit)。
RADIUS方案视图
port:表示采用端口号进行封装。
RADIUS Attribute 5为NAS-Port属性。不同的RADIUS服务器对NAS-Port属性的解析格式要求不同,为了保证RADIUS报文的正常交互,设备发送给服务器的NAS-Port属性的格式必须与服务器的要求保持一致。
配置RADIUS Attribute 5使用端口号进行封装后,填充在RADIUS Attribute 5中的内容为用户上线接口的接口编号中的最后一维。例如,若用户从接口GigabitEthernet1/0/2上线,则填充在RADIUS Attribute 5的字段为接口编号的最后一维“2”。
此配置不区分用户的接入类型,对所有用户的RADIUS报文均生效。
# 在RADIUS方案radius1中,配置RADIUS Attribute 5使用接口的端口号进行封装。
[Sysname-radius-radius1] attribute 5 format port
attribute 15 check-mode命令用来配置对RADIUS Attribute 15的检查方式。
undo attribute 15 check-mode命令用来恢复缺省情况。
attribute 15 check-mode { loose | strict }
对RADIUS Attribute 15的检查方式为strict方式。
RADIUS方案视图
loose:松散检查方式,设备使用RADIUS Attribute 15的标准属性值对用户业务类型进行检查。 对于SSH、FTP、Terminal、HTTP、HTTPS用户,在RADIUS服务器下发的Login-Service属性值为0(表示用户业务类型为Telnet)时才,这类用户才能够通过认证。
strict:严格检查方式,设备使用RADIUS Attribute 15的标准属性值以及扩展属性值对用户业务类型进行检查。对于SSH、FTP、Terminal、HTTP、HTTPS用户,当RADIUS服务器下发的Login-Service属性值为对应的扩展取值时,这类用户才能够通过认证。
由于某些RADIUS服务器不支持自定义的属性,无法下发扩展的Login-Service属性,若要使用这类RADIUS服务器对SSH、FTP、Terminal、HTTP、HTTPS用户进行认证,建议设备上对RADIUS 15号属性值采用松散检查方式。
# 在RADIUS方案radius1中,配置对RADIUS Attribute 15采用松散检查方式。
[Sysname-radius-radius1] attribute 15 check-mode loose
attribute 25 car命令用来开启RADIUS Attribute 25的CAR参数解析功能。
undo attribute 25 car命令用来关闭RADIUS Attribute 25的CAR参数解析功能。
attribute 25 car
RADIUS Attribute 25的CAR参数解析功能处于关闭状态。
RADIUS方案视图
RADIUS的25号属性为class属性,该属性由RADIUS服务器下发给设备。目前,某些RADIUS服务器利用class属性来对用户下发CAR参数,可以通过本特性来控制设备是否将RADIUS 25号属性解析为CAR参数,解析出的CAR参数可被用来进行基于用户的流量监管控制。
# 在RADIUS方案radius1中,开启RADIUS Attribute 25的CAR参数解析功能。
[Sysname-radius-radius1] attribute 25 car
attribute 30 mac-format命令用来配置RADIUS Attribute 30中的MAC地址格式。
undo attribute 30 mac-format命令用来恢复缺省情况。
attribute 30 mac-format section { one | { six | three } separator separator-character } { lowercase | uppercase }
RADIUS Attribute 30中的MAC地址为大写字母格式,且被分隔符“-”分成6段,即为HH-HH-HH-HH-HH-HH的格式。
RADIUS方案视图
section:指定MAC地址分段数。
· one:表示MAC地址被分为1段,格式为HHHHHHHHHHHH。
· six:表示MAC地址被分为6段,格式为HH-HH-HH-HH-HH-HH。
· three:表示MAC地址被分为3段,格式为HHHH-HHHH-HHHH。
separator separator-character:MAC地址的分隔符,为单个字符,区分大小写。
lowercase:表示MAC地址为小写字母格式。
uppercase:表示MAC地址为大写字母格式。
不同的RADIUS服务器对填充在RADIUS Attribute 30中的MAC地址有不同的格式要求,为了保证RADIUS报文的正常交互,设备发送给服务器的RADIUS Attribute 30号属性中MAC地址的格式必须与服务器的要求保持一致。
# 在RADIUS方案radius1中,配置RADIUS Attribute 30的MAC地址格式为hhhhhhhhhhhh。
[Sysname-radius-radius1] attribute 30 mac-format section one lowercase
attribute 31 mac-format命令用来配置RADIUS Attribute 31中的MAC地址格式。
undo attribute 31 mac-format命令用来恢复缺省情况。
attribute 31 mac-format section { one | { six | three } separator separator-character } { lowercase | uppercase }
RADIUS Attribute 31中的MAC地址为大写字母格式,且被分隔符“-”分成6段,即为HH-HH-HH-HH-HH-HH的格式。
RADIUS方案视图
section:指定MAC地址分段数。
不同的RADIUS服务器对填充在RADIUS Attribute 31中的MAC地址有不同的格式要求,为了保证RADIUS报文的正常交互,设备发送给服务器的RADIUS Attribute 31号属性中MAC地址的格式必须与服务器的要求保持一致。
# 在RADIUS方案radius1中,配置RADIUS Attribute 31的MAC地址格式为hh:hh:hh:hh:hh:hh。
[Sysname-radius-radius1] attribute 31 mac-format section six separator : lowercase
attribute 87 format命令用来配置RADIUS Attribute 87的格式。
undo attribute 87 format命令用来恢复缺省情况。
attribute 87 format interface-name
对于不同接入类型的用户,RADIUS Attribute 87的缺省格式有所不同:
· Portal用户:成员设备编号(2个字节)+00(固定字符,2个字节)+端口号(3个字节)+VLAN编号(9个字节)。
· 802.1X、MAC地址认证用户:slot=xx;subslot=xx;port=xx;vlanid=xx。其中,slot为成员设备编号,subslot为槽位号,port为端口号,vlanid为VLAN编号。
· Login用户:不携带Attribute 87属性。
RADIUS方案视图
interface-name:表示采用接口名称进行封装。
RADIUS Attribute 87为NAS-Port-ID属性。不同的RADIUS服务器对NAS-Port-ID属性的解析格式要求不同,为了保证RADIUS报文的正常交互,设备发送给服务器的NAS-Port-ID属性的格式必须与服务器的要求保持一致。
配置RADIUS Attribute 87使用接口名称进行封装后,填充在RADIUS Attribute 87中的内容为用户上线的接口名称。例如,若用户从接口GigabitEthernet1/0/1上线,则填充在RADIUS Attribute 5的字段为接口名称“GigabitEthernet1/0/1”。
# 在RADIUS方案radius1中,配置RADIUS Attribute 87的使用接口名称进行封装。
[Sysname-radius-radius1] attribute 87 format interface-name
attribute convert命令用来配置RADIUS属性转换规则。
undo attribute convert命令用来删除RADIUS属性转换规则。
attribute convert src-attr-name to dest-attr-name { { coa-ack | coa-request } * | { received | sent } * }
undo attribute convert [ src-attr-name ]
不存在RADIUS属性转换规则,系统按照标准RADIUS协议对RADIUS属性进行处理。
RADIUS DAE服务器视图
src-attr-name:源属性名称,为1~63个字符的字符串,不区分大小写。该属性必须为系统支持的属性。
dest-attr-name:目的属性名称,为1~63个字符的字符串,不区分大小写。该属性必须为系统支持的属性。
coa-ack:COA应答报文。
coa-request:COA请求报文。
received:接收到的DAE报文。
sent:发送的DAE报文。
RADIUS属性转换规则中的源属性内容将被按照目的属性的含义来处理。
只有在RADIUS属性解释功能开启之后,RADIUS属性转换规则才能生效。
配置RADIUS属性转换规则时,需要遵循以下原则:
· 源属性内容和目的属性内容的数据类型必须相同。
· 源属性和目的属性的名称不能相同。
· 一个属性只能按照一种方式(按报文类型或报文处理方向)进行转换。
· 一个源属性不能同时转换为多个目的属性。
执行undo attribute convert命令时,如果不指定源属性名称,则表示删除所有RADIUS属性转换规则。
# 在RADIUS DAE服务器视图下,配置一条RADIUS属性转换规则,指定将接收到的DAE报文中的Hw-Server-String属性转换为Connect-Info属性。
[Sysname] radius dynamic-author server
[Sysname-radius-da-server] attribute convert Hw-Server-String to Connect-Info received
· attribute translate
attribute convert src-attr-name to dest-attr-name { { access-accept | access-request | accounting } * | { received | sent } * }
RADIUS方案视图
access-accept:RADIUS认证成功报文。
access-request:RADIUS认证请求报文。
accounting:RADIUS计费报文。
received:接收到的RADIUS报文。
sent:发送的RADIUS报文。
· 源属性和目的属性的名称不能相同。
# 在RADIUS方案radius1中,配置一条RADIUS属性转换规则,指定将接收到的RADIUS报文中的Hw-Server-String属性转换为Connect-Info属性。
[Sysname-radius-radius1] attribute convert Hw-Server-String to Connect-Info received
attribute reject命令用来配置RADIUS属性禁用。
undo attribute reject命令用来取消配置的RADIUS属性禁用。
attribute reject attr-name { { coa-ack | coa-request } * | { received | sent } * }
undo attribute reject [ attr-name ]
不存在RADIUS属性禁用规则。
RADIUS DAE服务器视图
attr-name:RADIUS属性名称,为1~63个字符的字符串,不区分大小写。该属性必须为系统支持的属性。
coa-ack:COA应答报文。
received:接收到的DAE报文。
sent:发送的DAE报文。
当设备发送的RADIUS报文中携带了RADIUS服务器无法识别的属性时,可以定义基于发送方向的属性禁用规则,使得设备发送RADIUS报文时,将该属性从报文中删除。
当RADIUS服务器发送给设备的某些属性是设备不希望收到的属性时,可以定义基于接收方向的属性禁用规则,使得设备接收RADIUS报文时,不处理报文中的该属性。
当某些类型的属性是设备不希望处理的属性时,可以定义基于类型的属性禁用规则。
只有在RADIUS属性解释功能开启之后,RADIUS属性禁用规则才能生效。
一个属性只能按照一种方式(按报文类型或报文处理方向)进行禁用。
执行undo attribute reject命令时,如果不指定属性名称,则表示删除所有RADIUS属性禁用规则。
# 在RADIUS DAE服务器视图下,配置一条RADIUS属性禁用规则,指定禁用发送的DAE报文中的Connect-Info属性。
[Sysname-radius-da-server] attribute reject Connect-Info sent
attribute reject命令用来配置RADIUS属性禁用规则。
undo attribute reject命令用来删除RADIUS属性禁用规则。
attribute reject attr-name { { access-accept | access-request | accounting } * | { received | sent } * }
不存在RADIUS属性禁用规则。
RADIUS方案视图
sent:发送的RADIUS报文。
当RADIUS服务器发送给设备的某些属性是不希望收到的属性时,可以定义基于接收方向的属性禁用规则,使得设备接收RADIUS报文时,不处理报文中的该属性。
# 在RADIUS方案radius1中,配置一条RADIUS属性禁用规则,指定禁用发送的RADIUS报文中的Connect-Info属性。
[Sysname-radius-radius1] attribute reject Connect-Info sent
attribute remanent-volume命令用来配置RADIUS Remanent-Volume属性的流量单位。
undo attribute remanent-volume命令用来恢复缺省情况。
attribute remanent-volume unit { byte | giga-byte | kilo-byte | mega-byte }
undo attribute remanent-volume unit
Remanent-Volume属性的流量单位是千字节。
RADIUS方案视图
byte:表示流量单位为字节。
giga-byte:表示流量单位为千兆字节。
kilo-byte:表示流量单位为千字节。
mega-byte:表示流量单位为兆字节。
Remanent-Volume属性为H3C自定义RADIUS属性,携带在RADIUS服务器发送给接入设备的认证响应或实时计费响应报文中,用于向接入设备通知在线用户的剩余流量值。设备管理员通过本命令设置的流量单位应与RADIUS服务器上统计用户流量的单位保持一致,否则设备无法正确使用Remanent-Volume属性值对用户进行计费。
# 在RADIUS方案radius1中,设置RADIUS服务器下发的Remanent-Volume属性的流量单位为千字节。
[Sysname-radius-radius1] attribute remanent-volume unit kilo-byte
attribute translate命令用来开启RADIUS属性解释功能。
undo attribute translate命令用来关闭RADIUS属性解释功能。
attribute translate
RADIUS属性解释功能处于关闭状态。
RADIUS方案视图/RADIUS DAE服务器视图
不同厂商的RADIUS服务器所支持的RADIUS属性集有所不同,而且相同属性的用途也可能不同。为了兼容不同厂商的服务器的RADIUS属性,需要开启RADIUS属性解释功能,并定义相应的RADIUS属性转换规则和RADIUS属性禁用规则。
# 在RADIUS方案radius1中,开启RADIUS属性解释功能。
[Sysname-radius-radius1] attribute translate
· attribute convert
· attribute reject
ca-file命令用来配置EAP认证使用的CA证书。
undo ca-file命令用来恢复缺省情况。
ca-file file-name
undo ca-file
未配置CA证书。
EAP认证方案视图
file-name:表示CA证书文件名称,为1~91个字符的字符串,区分大小写。
当使用EAP认证方法为PEAP-GTC、PEAP-MSCHAPv2、TTLS-GTC、TTLS-MSCHAPv2时,可以选择校验服务器或客户端证书。配置CA证书即表示需要校验服务器证书。
若未配置CA证书,则表示EAP认证过程中不校验服务器证书。
配置CA证书之前,需要通过FTP或TFTP的方式将证书文件导入设备的存储介质的根目录下。在IRF组网环境中,需要保证主设备的存储介质的根目录下已经保存了CA证书文件。
一个EAP认证方案视图中只能指定一个CA证书,后配置的生效。
修改后的配置,将在下一个探测周期中生效。
# 在EAP认证方案eap1中,配置采用的CA证书文件为CA.der。
[Sysname] eap-profile eap1
[Sysname-eap-profile-eap1] ca-file CA.der
client命令用来指定RADIUS DAE客户端。
undo client命令用来删除指定的RADIUS DAE客户端。
client { ip ipv4-address | ipv6 ipv6-address } [ key { cipher | simple } string | ssl-server-policy policy-name | vpn-instance vpn-instance-name ] *
undo client { ip ipv4-address | ipv6 ipv6-address } [ vpn-instance vpn-instance-name ] [ ssl-server-policy ]
未指定RADIUS DAE客户端。
RADIUS DAE服务器视图
ip ipv4-address:RADIUS DAE客户端IPv4地址。
ipv6 ipv6-address:RADIUS DAE客户端IPv6地址。
key:与RADIUS DAE客户端交互DAE报文时使用的共享密钥。此共享密钥的设置必须与RADIUS DAE客户端的共享密钥设置保持一致。如果此处未指定本参数,则对应的RADIUS DAE客户端上也必须未指定。
cipher:以密文方式设置密钥。
simple:以明文方式设置密钥,该密钥将以密文形式存储。
string:密钥字符串,区分大小写。非FIPS模式下,明文密钥为1~64个字符的字符串;密文密钥为1~117个字符的字符串。FIPS模式下,明文密钥为15~64个字符的字符串,密钥元素的最少组合类型为4(必须包括数字、大写字母、小写字母以及特殊字符);密文密钥为15~117个字符的字符串。
vpn-instance vpn-instance-name:RADIUS DAE客户端所属的VPN实例。vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。如果未指定本参数,则表示RADIUS DAE客户端位于公网中。
ssl-server-policy:RADIUS DAE服务器使用的SSL服务器策略。配置此策略时,表示使用RADIUS over TLS方式与DAE 客户端通信;未配置此策略时,表示使用RADIUS over UDP方式与DAE 客户端通信。
policy-name:RADIUS DAE服务器使用的SSL服务器策略名,为1~31个字符的字符串,不区分大小写。
开启RADIUS DAE服务之后,设备会监听并处理指定的RADIUS DAE客户端发起的DAE请求消息(用于动态授权修改或断开连接),并向其发送应答消息。对于非指定的RADIUS DAE客户端的DAE报文进行丢弃处理。
可通过多次执行本命令指定多个RADIUS DAE客户端。
可以同时存在UDP和TLS的RADIUS DAE客户端。可以针对每个客户端指定对应的SSL服务器策略,即每个客户端都使用自己的证书。
DAE服务器与DAE客户端使用RADIUS over TLS方式通信时,如果本命令未指定共享密钥,则使用缺省的共享密钥radsec。
# 设置RADIUS DAE客户端的IP地址为10.110.1.2,与RADIUS DAE客户端交互DAE报文时使用的共享密钥为明文123456。
[Sysname-radius-da-server] client ip 10.110.1.2 key simple 123456
# 设置RADIUS DAE客户端的IP地址为10.110.1.2,使用的SSL服务器策略为policy1
[Sysname-radius-da-server] client ip 10.110.1.2 ssl-server-policy policy1
· radius dynamic-author server
· port
data-flow-format命令用来配置发送到RADIUS服务器的数据流及数据包的单位。
undo data-flow-format命令用来恢复缺省情况。
data-flow-format { data { byte | giga-byte | kilo-byte | mega-byte } | packet { giga-packet | kilo-packet | mega-packet | one-packet } } *
undo data-flow-format { data | packet }
数据流的单位为字节,数据包的单位为包。
RADIUS方案视图
data:设置数据流的单位。
· byte:数据流的单位为字节。
· giga-byte:数据流的单位千兆字节。
· kilo-byte:数据流的单位为千字节。
· mega-byte:数据流的单位为兆字节。
packet:设置数据包的单位。
· giga-packet:数据包的单位为千兆包。
· kilo-packet:数据包的单位为千包。
· mega-packet:数据包的单位为兆包。
· one-packet:数据包的单位为包。
设备上配置的发送给RADIUS服务器的数据流单位及数据包单位应与RADIUS服务器上的流量统计单位保持一致,否则无法正确计费。
# 在RADIUS方案radius1中,设置发往RADIUS服务器的数据流单位为千字节、数据包单位为千包。
[Sysname-radius-radius1] data-flow-format data kilo-byte packet kilo-packet
display radius buffer命令用来显示全局缓存的RADIUS报文的相关信息。
本命令可以显示主设备的RADIUS缓存报文个数,方便管理员实时查看RADIUS缓存报文的拥塞程度。
# 显示全局缓存的RADIUS报文的相关信息。
<Sysname> display radius buffer
Access type : lan-access
Slot Packets
1 10
2 12
表1-13 display radius buffer命令显示信息描述表
Access type |
接入类型,取值为lan-access |
Slot |
主设备编号 |
Packets |
报文个数 |
display radius scheme命令用来显示RADIUS方案的配置信息。
display radius scheme [ radius-scheme-name ]
radius-scheme-name:RADIUS方案名,为1~32个字符的字符串,不区分大小写。如果不指定该参数,则表示所有RADIUS方案。
显示指定RADIUS方案或者显示所有的RADIUS方案配置信息时,都会同时显示每一个RADIUS服务器当前Active状态的持续时间以及最近5次状态变化信息。
# 显示所有RADIUS方案的配置信息。
<Sysname> display radius scheme
Total 1 RADIUS schemes
RADIUS scheme name: radius1
Index : 0
Primary authentication server:
Host name: Not configured
IP : 2.2.2.2 Port: 2083
VPN : vpn1
SSL client policy : policy1
State: Active (duration: 1 weeks, 2 days, 1 hours, 32 minutes, 34 seconds)
Most recent state changes:
2021/08/15 20:38:45 Changed to active state
2021/08/15 20:33:45 Changed to blocked state
2021/08/15 20:31:19 Changed to active state
2021/08/15 20:26:19 Changed to blocked state
2021/08/15 20:26:00 Changed to active state
Test profile: 132
Probe username: test
Probe interval: 60 minutes
Confirm function: Enabled
Probe state: Detection
Confirm interval: 3
Confirm left count: 3
Weight: 40
Primary accounting server:
IP : 1.1.1.1 Port: 2083
VPN : Not configured
Weight: 40
Second authentication server:
IP : 3.3.3.3 Port: 1812
SSL client policy : Not configured
State: Blocked
Test profile: Not configured
Weight: 40
Second accounting server:
IP : 3.3.3.3 Port: 1813
State: Blocked (mandatory)
Weight: 0
Accounting-On function : Enabled
extended function : Disabled
retransmission times : 5
retransmission interval(seconds) : 2
Timeout Interval(seconds) : 3
TLS idle timeout(seconds) : 60
Retransmission Times : 3
Retransmission Times for Accounting Update : 5
Server Quiet Period(minutes) : 5
Realtime Accounting Interval(seconds) : 22
Stop-accounting packets buffering : Enabled
Retransmission times : 500
NAS IP Address : 1.1.1.1
Local NAS IP Address : Not configured
Peer NAS IP Address : Not configured
User Name Format : with-domain
Data flow unit : Megabyte
Packet unit : One
Attribute 5 format : Port
Attribute 15 check-mode : Strict
Attribute 25 : CAR
Attribute 87 format : Interface name
Attribute Remanent-Volume unit : Mega
server-parallel-auth : Disabled
server-load-sharing : Enabled
Attribute 30 format : hh:hh:hh:hh:hh:hh:SSID
Attribute 30 MAC format : hh:hh:hh:hh:hh:hh
Attribute 31 MAC format : hh:hh:hh:hh:hh:hh
Stop-accounting-packet send-force : Disabled
Reauthentication server selection : Reselect
Attribute 218 of vendor ID 25506 : DHCP-Option 61
Format 1 (1-byte Type field)
# 显示RADIUS方案radius1的配置信息。
<Sysname> display radius scheme radius1
Index: 0
Host name: Not Configured
VPN : vpn1
2019/12/08 20:38:45 Changed to active state
2019/12/08 20:33:45 Changed to blocked state
2019/12/08 20:31:19 Changed to active state
2019/12/08 20:26:19 Changed to blocked state
2019/12/08 20:26:00 Changed to active state
Test profile: 132
Confirm interval: 3
Weight: 40
IP : 1.1.1.1 Port: 1813
Weight: 40
2019/12/08 20:56:22 Changed to blocked state
2019/12/08 20:48:45 Changed to active state
2019/12/08 20:43:45 Changed to blocked state
2019/12/08 20:41:19 Changed to active state
2019/12/08 20:46:19 Changed to blocked state
Weight: 40
Weight: 0
Packet unit : One
Attribute 25 : CAR
Stop-accounting packets send-force : Disabled
表1-14 display radius scheme命令显示信息描述表
Total 1 RADIUS schemes. |
共计1个RADIUS方案 |
RADIUS scheme name |
RADIUS方案的名称 |
Index |
RADIUS方案的索引号 |
Primary authentication server |
主RADIUS认证服务器 |
Primary accounting server |
主RADIUS计费服务器 |
Second authentication server |
从RADIUS认证服务器 |
Second accounting server |
从RADIUS计费服务器 |
Host name |
RADIUS认证/计费服务器主机名 未配置时,显示为Not configured |
IP |
RADIUS认证/计费服务器IP地址 未配置时,显示为Not configured |
Port |
RADIUS认证/计费服务器接入端口号 未配置时,显示缺省值 |
SSL client policy |
TLS连接使用的SSL客户端策略名 |
State |
RADIUS认证/计费服务器目前状态 · Active:激活状态 · Blocked:自动转换的静默状态 · Blocked (mandatory):手工配置的静默状态 若状态为Active,则同时显示该状态的持续时间 |
duration |
RADIUS服务器当前Active状态的持续时间 |
Most recent blocked period |
RADIUS服务器最后一次转换为Block状态的开始时间及结束时间。若最终状态为Block状态,则结束时间用“now”表示 |
Most recent state changes |
RADIUS服务器最近5次的状态变化信息 |
VPN |
RADIUS认证/计费服务器或RADIUS方案所在的VPN 未配置时,显示为Not configured |
Test profile |
探测服务器状态使用的模板名称 |
Probe username |
探测服务器状态使用的用户名 |
Probe interval |
探测服务器状态的周期(单位为分钟) |
Probe eap-profile |
探测服务器使用的EAP认证方案 未配置时,则不显示该字段 |
Confirm function |
RADIUS服务器探测确认功能的开启情况,取值包括: · Disabled:关闭状态 · Enabled:开启状态 |
Probe state |
设备探测服务器可达功能当前所处的状态,取值包括: · Confirmation:探测确认状态 · Detection:探测状态 仅当RADIUS服务器探测确认功能开启时显示本字段 |
Confirm interval |
RADIUS服务器探测确认报文的发送时间间隔 仅当RADIUS服务器探测确认功能开启时显示本字段 |
Confirm left count |
RADIUS服务器探测确认报文的剩余发送次数 仅当RADIUS服务器探测确认功能开启时显示本字段 |
Weight |
RADIUS服务器权重值 |
Accounting-On function |
accounting-on功能的开启情况 |
extended function |
accounting-on扩展功能的开启情况 |
retransmission times |
accounting-on报文的发送尝试次数 |
retransmission interval(seconds) |
accounting-on报文的重发间隔(单位为秒) |
Timeout Interval(seconds) |
RADIUS服务器超时时间(单位为秒) |
TLS idle timeout(seconds) |
TLS连接的闲置超时时间(单位为秒) |
Retransmission Times |
发送RADIUS报文的最大尝试次数 |
Retransmission Times for Accounting Update |
实时计费更新报文的最大尝试次数 |
Server Quiet Period(minutes) |
RADIUS服务器恢复激活状态的时间(单位为分钟) |
Realtime Accounting Interval(seconds) |
实时计费更新报文的发送间隔(单位为秒) |
Stop-accounting packets buffering |
RADIUS停止计费请求报文缓存功能的开启情况 |
Retransmission times |
发起RADIUS停止计费请求的最大尝试次数 |
NAS IP Address |
发送RADIUS报文的源IP地址或源接口 未配置时,显示为Not configured |
Local NAS IP Address |
M-LAG场景下,本端M-LAG接口接入的用户发送RADIUS报文使用的源IP地址或源接口 未配置时,显示为Not configured |
Peer NAS IP Address |
M-LAG场景下,对端M-LAG接口接入的用户发送RADIUS报文使用的源IP地址或源接口 未配置时,显示为Not configured |
User Name Format |
发送给RADIUS服务器的用户名格式 · with-domain:携带域名 · without-domain:不携带域名 · keep-original:与用户输入保持一致 |
Data flow unit |
数据流的单位 |
Packet unit |
数据包的单位 |
Attribute 5 format |
RADIUS Attribute 5的格式,包括以下两种取值: · Port:表示使用端口号封装 · Default:表示使用缺省格式封装 |
Attribute 15 check-mode |
对RADIUS Attribute 15的检查方式,包括以下两种取值: · Strict:表示使用RADIUS标准属性值和私有扩展的属性值进行检查 · Loose:表示使用RADIUS标准属性值进行检查 |
Attribute 25 |
对RADIUS Attribute 25的处理,包括以下两种取值: · Standard:表示不对RADIUS Attribute 25进行解析 · CAR:表示将RADIUS 25号属性解析为CAR参数 |
Attribute 87 format |
RADIUS Attribute 87的格式,包括以下两种取值: · Interface name:表示使用接口名称封装 · Default:表示使用缺省格式封装 |
Attribute Remanent-Volume unit |
RADIUS Remanent-Volume属性的流量单位 |
server-parallel-auth |
RADIUS服务器并行认证功能的开启情况,取值包括: · Disabled:关闭状态 · Enabled:开启状态 |
server-load-sharing |
RADIUS服务器负载分担功能的开启情况 · Disabled:关闭状态,服务器工作于主/从模式 · Enabled:开启状态,服务器工作于负载分担模式 |
Attribute 30 format |
(暂不支持)RADIUS Attribute 30的格式 |
Attribute 30 MAC format |
RADIUS Attribute 30中携带的MAC地址格式 |
Attribute 31 MAC format |
RADIUS Attribute 31中携带的MAC地址格式 |
Stop-accounting-packet send-force |
用户下线时设备强制发送RADIUS计费停止报文功能的开启情况 |
Reauthentication server selection |
重认证时RADIUS服务器的选择模式: · Inherit:继承模式,即重认证时直接选择认证时的认证服务器 · Reselect:重新选择模式,即重认证时重新选择认证服务器 |
Attribute 218 vendor ID 25506 |
RADIUS报文中通过私有218号属性(Vendor ID为25506)携带的DHCP Option信息以及所采用的封装格式,其中: · Format 1 (1-byte Type field):封装该属性时,属性的Type字段长度为1字节。该方式封装的属性适用于与大多数的RADIUS服务器互通 · Format 2 (2-byte Type field):封装该属性时,属性的Type字段长度为2字节。该方式封装的属性适用于与特殊RADIUS服务器互通,例如HUAWEI的RADIUS服务器 如果RADIUS报文中不携带DHCP Option私有属性,则不显示该信息 |
display radius server-load statistics命令用来显示RADIUS服务器的负载统计信息。
本命令用来显示上一个5秒统计周期内设备发往RADIUS认证/计费服务器的认证/计费请求统计信息和自从设备启动后记录的历史认证/计费请求统计信息,具体统计过程如下:
· 系统从第一个用户认证请求开始,每隔5秒钟统计一次RADIUS认证/计费请求数目,并在下一个5秒内提供该统计值供查看。
· 只要设备发起一次用户认证请求或用户计费开始请求,对应服务器的历史负载统计数值随之加1,但后续不会因为用户下线、服务器响应或超时而减小该值。
前5秒的统计信息提供了RADIUS认证/计费服务器最近5秒的负载分担效果,管理员可以根据此统计信息调控RADIUS服务器的配置参数,比如配置顺序、权重参数等。当没有用户触发认证/计费时,前5秒的统计数据就不能给管理员提供有效的负载分担信息了,此时管理员可以参考历史负载统计信息对RADIUS认证/计费服务器的配置做调整。
· 所有RADIUS方案中,指定了IP地址的服务器,以及指定的主机名被成功解析为IP地址的服务器,都可以通过本命令查看到它的负载统计数据。
· 若RADIUS认证/计费服务器的配置被删除,或主认证/计费服务器的VPN、IP和端口参数发生变化,则该服务器的前5秒的统计数据及历史负载统计数据将会被删除。
· 主备倒换后,历史统计数据不会被删除,但会不准确。
# 显示RADIUS服务器的负载统计信息。
<Sysname> display radius server-load statistics
Authentication servers: 2
IP VPN Port Last 5 sec History
1.1.1.1 N/A 1812 20 100
2.2.2.2 ABC 1812 0 20
Accounting servers: 2
1.1.1.1 N/A 1813 20 100
2.2.2.2 ABC 1813 0 20
表1-15 display radius server-load statistics命令显示信息描述表
Authentication servers |
RADIUS认证服务器总个数 |
Accounting servers |
RADIUS计费服务器总个数 |
IP |
RADIUS认证/计费服务器的IP地址 |
VPN |
RADIUS认证/计费服务器所在的VPN 若未配置该参数,则显示N/A |
Port |
RADIUS认证/计费服务器的UDP端口号 |
Last 5 sec |
上一个5秒统计周期内发往RADIUS认证/计费服务器的请求数 |
History |
RADIUS认证/计费服务器的历史负载统计值 |
· reset radius server-load statistics
display radius statistics命令用来显示RADIUS报文的统计信息。
# 显示RADIUS报文的统计信息。
<Sysname> display radius statistics
Auth. Acct. SessCtrl.
Request Packet: 0 0 0
Retry Packet: 0 0 -
Timeout Packet: 0 0 -
Access Challenge: 0 - -
Account Start: - 0 -
Account Update: - 0 -
Account Stop: - 0 -
Terminate Request: - - 0
Set Policy: - - 0
Packet With Response: 0 0 0
Packet Without Response: 0 0 -
Access Rejects: 0 - -
Dropped Packet: 0 0 0
Check Failures: 0 0 0
TCP Connections: 2 2 0
TCP Connect Failures: 1 0 0
SSL Connections: 1 2 0
SSL Connect Failures: 1 0 0
Cache Search Requests : 3
Search Successes: 2 Search Failures: 1
Authentication servers: 1
IP: 1.1.1.1 Port: 1812
VPN:
Authentication packets:
Requests : 8 Retransmissions : 0
Pending requests : 0 Packet timeouts : 0
Challenge packets : 0 Accept responses : 0
Reject responses : 8 Unknown-type responses : 0
Malformed responses : 0 Bad authenticators : 0
Dropped responses : 0 TCP Connections : 2
TCP Connect Failures : 1 SSL Connections : 1
SSL Connect Failures : 1
Accounting servers: 1
VPN:
Accounting packets:
Start requests : 8 Realtime requests : 0
Stop requests : 0 Pending requests : 0
Packet timeouts : 0 Unknown-type responses : 0
Dropped responses : 0 Accept responses : 8
TCP Connections : 2 TCP Connect Failures : 0
SSL Connections : 2 SSL Connect Failures : 0
表1-16 display radius statistics命令显示信息描述表
Auth. |
认证报文 |
Acct. |
计费报文 |
SessCtrl. |
Session-control报文 |
Request Packet |
发送的请求报文总数 |
Retry Packet |
重传的请求报文总数 |
Timeout Packet |
超时的请求报文总数 |
Access Challenge |
Access challenge报文数 |
Account Start |
计费开始报文的数目 |
Account Update |
计费更新报文的数目 |
Account Stop |
计费结束报文的数目 |
Terminate Request |
服务器强制下线报文的数目 |
Set Policy |
更新用户授权信息报文的数目 |
Packet With Response |
有回应信息的报文数 |
Packet Without Response |
无回应信息的报文数 |
Access Rejects |
认证拒绝报文的数目 |
Dropped Packet |
丢弃的报文数 |
Check Failures |
报文校验错误的报文数目 |
Cache Search Requests |
授权信息缓存的查询请求总次数 |
Search Successes |
查询授权信息缓存成功次数 |
Search Failures |
未查询到授权信息缓存次数 |
TCP Connections |
TCP连接建立次数,认证和计费共用连接,使用创建连接时的服务器类型来归属认证和计费。 |
TCP Connect Failures |
TCP连接建立失败次数,认证和计费共用连接,使用创建连接时的服务器类型来归属认证和计费。 |
SSL Connection |
SSL连接建立次数,认证和计费共用连接,使用创建连接时的服务器类型来归属认证和计费。 |
SSL Connect Failures |
SSL连接建立失败次数,认证和计费共用连接,使用创建连接时的服务器类型来归属认证和计费。 |
认证服务器数目 |
计费服务器数目 |
IP |
服务器的IP地址 |
Port |
服务器的端口号 |
VPN |
服务器所在的VPN 若服务器属于公网,则该字段取值为空 |
Authentication packets |
认证服务器报文统计信息 |
Accounting packets |
计费服务器报文统计信息 |
Requests |
认证/计费请求报文数 该计数不包含报文重传计数,但增加时Pending Requests计数也会增加 |
Retransmissions |
重传的认证/计费请求报文数 该计数不会叠加在Requests计数中 |
Pending requests |
未得到服务器响应且未超时的认证/计费请求报文数 |
Packet timeouts |
超时的认证/计费请求报文数 |
Challenge packets |
认证挑战报文数 |
Accept responses |
认证接受报文数/计费响应报文数 |
Reject responses |
认证拒绝报文数 |
Unknown-type responses |
非标准定义的认证/计费响应报文数 |
Malformed responses |
长度不合法的认证/计费响应报文数 |
Bad authenticators |
验证字错误的认证/计费响应报文数 验证字错误的响应报文也属于不合法的响应报文 |
Dropped responses |
因为其它原因丢弃的认证/计费响应报文数 |
Start requests |
开始计费请求报文数 |
Realtime requests |
实时计费请求报文数 |
Stop requests |
计费停止请求报文数 |
· reset radius statistics
display stop-accounting-buffer命令用来显示缓存的RADIUS停止计费请求报文的相关信息。
display stop-accounting-buffer { radius-scheme radius-scheme-name | session-id session-id | time-range start-time end-time | user-name user-name }
radius-scheme radius-scheme-name:表示指定RADIUS方案的停止计费请求报文。其中,radius-scheme-name为RADIUS方案名,为1~32个字符的字符串,不区分大小写。
session-id session-id:表示指定会话的停止计费请求报文。其中,session-id表示会话ID,为1~64个字符的字符串,不包含字母。会话ID用于唯一标识当前的在线用户。
time-range start-time end-time:表示指定时间段内发送且被缓存的停止计费请求报文。其中,start-time为请求时间段的起始时间,end-time为请求时间段的结束时间,格式为hh:mm:ss-mm/dd/yyyy(时:分:秒-月/日/年)或hh:mm:ss-yyyy/mm/dd(时:分:秒-年/月/日)。
user-name user-name:表示指定用户的停止计费请求报文。其中,user-name表示用户名,为1~255个字符的字符串,区分大小写。输入的用户名是否携带ISP域名,必须与RADIUS方案中的user-name-format配置保持一致。
# 显示缓存的用户名为abc的RADIUS停止计费请求报文的相关信息。
<Sysname> display stop-accounting-buffer user-name abc
Total entries: 2
Scheme Session ID Username First sending time Attempts
rad1 1000326232325010 abc 23:27:16-08/31/2015 19
aaa 1000326232326010 abc 23:33:01-08/31/2015 20
表1-17 display stop-accounting-buffer命令显示信息描述表
Total entries: 2 |
共有两条记录匹配 |
Scheme |
RADIUS方案名 |
Session ID |
会话ID(Acct-Session-Id属性值) |
Username |
用户名 |
First sending time |
首次发送停止计费请求的时间 |
Attempts |
发起停止计费请求的次数 |
· reset stop-accounting-buffer (for RADIUS)
· retry
· retry stop-accounting (for RADIUS)
· stop-accounting-buffer enable (RADIUS scheme view)
· user-name-format (RADIUS scheme view)
eap-profile命令用来创建EAP认证方案,并进入EAP认证方案视图,如果指定的EAP认证方案已存在,则直接进入EAP认证方案视图。
undo eap-profile命令用来删除指定的EAP认证方案。
eap-profile eap-profile-name
undo eap-profile eap-profile-name
不存在EAP认证方案。
eap-profile-name:EAP认证方案的名称,为1~32个字符的字符串,区分大小写。
EAP认证方案是一个EAP认证选项的配置集合,用于指定设备采用的EAP认证方法以及某些EAP认证方法需要引用的CA证书,并被RADIUS服务器探测模板所引用。
一个EAP认证方案可以同时被多个探测模板引用。探测模板使用EAP认证方案进行探测时,不支持RADIUS over TLS方式与服务器进行通信。
系统最多支持配置16个EAP认证方案。
# 创建名为eap1的EAP认证方案,并进入其视图。
· radius-server test-profile
exclude命令用来配置RADIUS报文中不能携带的属性。
undo exclude命令用来取消在RADIUS报文中不能携带的属性配置。
exclude { accounting | authentication } name attribute-name
undo exclude { accounting | authentication } name attribute-name
未配置RADIUS报文中不能携带的属性。
RADIUS属性测试组视图
accounting:表示RADIUS计费请求报文。
authentication:表示RADIUS认证请求报文。
name attribute-name:RADIUS属性名称,为1~63个字符的字符串,不区分大小写。这些属性为RADIUS报文中缺省携带的属性,具体包括:Service-Type、Framed-Protocol、NAS-Identifier、Acct-Delay-Time、Acct-Session-Id、Acct-Terminate-Cause和NAS-Port-Type,其中Service-Type、Framed-Protocol、NAS-Identifier,Acct-Session-Id和NAS-Port-Type为认证请求报文缺省携带的属性,NAS-Identifier、Acct-Delay-Time、Acct-Session-Id和Acct-Terminate-Cause为计费请求报文缺省携带的属性。
通过本命令配置的RADIUS属性将不会在属性测试过程中被携带在相应的RADIUS请求报文中发送给RADIUS服务器。在实际测试过程中,可通过本命令排除掉RADIUS报文中携带的一些基础属性,来辅助排查认证/计费故障。
如果一个属性已经被配置为需要携带在RADIUS报文中(通过include命令),则需要先执行undo include命令取消该配置,才能将其配置为不携带在RADIUS报文中。
# 在RADIUS属性测试组t1中,配置在RADIUS认证请求报文中不携带属性名称为Service-Type的标准属性。
[Sysname] radius attribute-test-group t1
[Sysname-radius-attr-test-grp-t1] exclude authentication name Service-Type
· include
· test-aaa
include命令用来配置RADIUS报文中携带的属性。
undo include命令用来取消指定的属性配置。
include { accounting | authentication } { name attribute-name | [ vendor vendor-id ] code attribute-code } type { binary | date | integer | interface-id | ip | ipv6 | ipv6-prefix | octets | string } value attribute-value
undo include { accounting | authentication} { name attribute-name | [ vendor vendor-id ] code attribute-code }
未配置RADIUS报文中携带的属性。
RADIUS属性测试组视图
name attribute-name:标准RADIUS属性名称,为1~63个字符的字符串,不区分大小写。
vendor vendor-id:RADIUS属性所属的设备厂商标识。vendor-id为厂商标识号码,取值范围为1~65535。如果不指定该参数,则表示RADIUS属性为标准属性。
code attribute-code:RADIUS属性编号,取值范围为1~255。
type:属性内容的数据类型,包括以下取值:
· binary:二进制类型。
· date:时间类型。
· integer:整数类型。
· interface-id:接口ID类型。
· ip:IPv4地址类型。
· ipv6:IPv6地址类型。
· ipv6-prefix:IPv6地址前缀类型。
· octets:八进制类型。
· string:字符串类型。
value attribute-value:RADIUS属性值,取值与数据类型有关,具体如下:
· 二进制属性值:1~256个十六进制字符,表示最多128个字节的二进制数。
· 时间类型属性值:0~4294967295。
· 整数类型属性值:0~4294967295。
· 接口ID类型属性值:1~ffffffffffffffff。
· IPv6地址前缀类型属性值:prefix/prefix-length样式。
· 八进制属性值:1~256个十六进制字符,表示最多128个字节的八进制数。
· 字符串类型属性值:1~253个字符。
可以通过本命令配置RADIUS报文中携带的属性以及对应的属性值,具体情况如下:
· 对于RADIUS报文中默认携带的属性,可通过include命令来修改属性取值,并可通过undo include命令将该属性值恢复为缺省值。RADIUS报文中默认携带的能够修改的属性包括:
¡ 认证请求报文默认携带的属性:User-Name、CHAP-Password(User-Password)、CHAP-Challenge、NAS-IP-Address(NAS-IPv6-Address)、Service-Type、Framed-Protocol、NAS-Identifier、NAS-Port-Type、Acct-Session-Id。
¡ 计费请求报文默认携带的属性:User-Name、Acct-Status-Type、NAS-IP-Address(NAS-IPv6-Address)、NAS-Identifier、Acct-Session-Id、Acct-Delay-Time、Acct-Terminate-Cause。
· 对于并非RADIUS报文中默认携带的属性,可通过include命令将其添加在RADIUS报文中,并可通过undo include命令将该属性从RADIUS报文中删除。
为了保证测试效果的准确性,请务必保证各属性参数的匹配性,比如属性值要匹配属性类型。
保存在配置文件中的标准属性的属性名称将被转换为属性编号的形式。
如果一个属性已经被配置为不能携带在RADIUS报文中(通过exclude命令),则需要先执行undo exclude命令取消该配置,才能将其配置为携带在RADIUS报文中。
设备按照配置的先后顺序在RADIUS报文中添加RADIUS属性,由于RADIUS报文最大长度为4096个字节,如果配置了过多的RADIUS属性,则在报文长度超过最大值后,部分属性将不会被添加在报文中。因此,请合理规划要添加的RADIUS报文属性数目。
# 在RADIUS属性测试组t1中,配置在RADIUS认证请求报文中携带一个标准属性:名称为Calling-Station-Id,属性值为08-00-27-00-34-D8。
[Sysname-radius-attr-test-grp-t1] include authentication name Calling-Station-Id type string value 08-00-27-00-34-d8
· exclude
· test-aaa
include-attribute 218 vendor-id 25506命令用来配置RADIUS报文中携带Vendor ID为25506的私有218号属性。
undo include-attribute 218 vendor-id 25506命令用来取消在RADIUS报文中携带Vendor ID为25506的私有218号属性。
undo include-attribute 218 vendor-id 25506 dhcp-option命令用来恢复缺省情况。
include-attribute 218 vendor-id 25506 dhcp-option { 55 | 61 } * { format1 | format2 }
undo include-attribute 218 vendor-id 25506 [ dhcp-option ]
RADIUS报文中携带Vendor ID为25506的私有218号属性,且以format1格式封装DHCP Option 61信息。
RADIUS方案视图
dhcp-option:属性Value字段携带的DHCP Option信息。
· 55:表示DHCP Option 55。
· 61:表示DHCP Option 61。
format1:属性的Type字段长度为1字节。该格式封装的属性适用于与大多数的RADIUS服务器互通。
format2:属性的Type字段长度为2字节。该格式封装的属性适用于与特殊RADIUS服务器互通,例如HUAWEI的RADIUS服务器。
设备厂商可以通过对RADIUS协议中的26号属性进行扩展,以实现标准RADIUS未定义的功能。Vendor ID为25506的设备厂商定义了私有218号属性,用来携带客户端的DHCP Option信息。如果RADIUS服务器希望设备能够上报认证客户端的一些DHCP Option信息,就需要在客户端使用的RADIUS方案中配置本特性,使得设备能够将获取到的DHCP Option信息按照服务器要求的格式封装在私有属性中,并通过RADIUS计费开始请求报文或计费更新请求报文发送给服务器。
目前,本特性仅支持DHCP Option 55和DHCP Option 61。
如果在include-attribute 218 vendor-id 25506命令中同时指定了两个类型的DHCP Option,设备会将获取到的两类DHCP Option封装在两个私有218号属性中同时发送给服务器。每个封装在私有218号属性中的DHCP Option信息不超过246个字节。
# 在RADIUS方案rad中,配置在RADIUS报文中携带Vendor ID为25506的218号属性,属性值为DHCP Option 55信息,封装格式为format2。
[Sysname-radius-rad] include-attribute 218 vendor-id 25506 dhcp-option 55 format2
key命令用来配置RADIUS报文的共享密钥。
undo key命令用来删除RADIUS报文的共享密钥。
key { accounting | authentication } { cipher | simple } string
undo key { accounting | authentication }
未配置RADIUS报文的共享密钥。
RADIUS方案视图
accounting:指定RADIUS计费报文的共享密钥。
authentication:指定RADIUS认证报文的共享密钥。
cipher:以密文方式设置密钥。
设备优先采用配置RADIUS认证/计费服务器时指定的报文共享密钥,本配置中指定的报文共享密钥仅在配置RADIUS认证/计费服务器时未指定相应密钥的情况下使用。
必须保证设备上设置的共享密钥与RADIUS服务器上的完全一致。
# 在RADIUS方案radius1中,配置计费报文的共享密钥为明文ok。
[Sysname-radius-radius1] key accounting simple ok
method命令用来配置EAP认证方法。
undo method命令用来恢复缺省情况。
method { md5 | peap-gtc | peap-mschapv2 | ttls-gtc | ttls-mschapv2 }
undo method
采用的EAP认证方法为MD5-Challenge。
EAP认证方案视图
md5:表示采用的认证方法为MD5-Challenge。
peap-gtc:表示采用的认证方法为PEAP-GTC。
peap-mschapv2:表示采用的认证方法为PEAP-MSCHAPv2。
ttls-gtc:表示采用的认证方法为TTLS-GTC。
ttls-mschapv2:表示采用的认证方法为TTLS-MSCHAPv2。
配置的EAP认证方法必须和所探测的RADIUS服务器支持的EAP认证方法一致。
一个EAP认证方案视图中只能指定一个EAP认证方法,后配置的生效。
# 在EAP认证方案eap1中,配置认证方法为PEAP-GTC。
[Sysname-eap-profile-eap1] method peap-gtc
microsegment associate命令用来配置微分段与VSI的关联。
undo microsegment命令用来解除微分段与VSI的关联。
microsegment microsegment-id associate vsi vsi-name
undo microsegment { microsegment-id | all }
微分段与VSI无关联。
RADIUS方案视图
microsegment-id:微分段ID,取值范围为1~65535。
vsi vsi-name:VSI名称,为1~31个字符的字符串,区分大小写。
all:所有与VSI名称关联的微分段ID。
当RADIUS服务器向用户授权了微分段,但未授权VSI时,设备将会基于已建立的关联关系将该微分段ID和其关联的VSI名称一并授权给用户,用于实现VXLAN网络中基于微分段的访问控制;若设备未查找到服务器授权的微分段ID所关联的VSI名称,则只将微分段ID授权给用户。
可通过多次执行本命令建立多个关联关系,系统可支持的最大关联配置数目与设备的型号有关,请以设备的实际情况为准,最多支持1024条关联配置。
每个RADIUS方案下,一个微分段ID只能与一个VSI名称关联,但一个VSI名称可以关联多个微分段ID。对于同一个微分段ID,多次配置该命令,仅最后一次配置生效。
该配置仅对之后上线的用户生效,不影响已在线的用户。
如果设备不能直接解析RADIUS服务器授权的微分段ID,则需要在RADIUS方案下开启RADIUS属性解释功能,并配置RADIUS属性转换规则将RADIUS服务器下发的微分段ID属性转换为设备可识别的私有微分段ID属性H3C-Microsegment-Id。
# 在RADIUS方案radius1中,将微分段123和VSI test相关联。
[Sysname-radius-radius1] microsegment 123 associate vsi test
· attribute convert
nas-ip命令用来设置设备发送RADIUS报文使用的源IP地址。
undo nas-ip命令用来删除指定类型的发送RADIUS报文使用的源IP地址。
nas-ip [ m-lag { local | peer } ] { ipv4-address | interface interface-type interface-number | ipv6 ipv6-address }
undo nas-ip [ m-lag { local | peer } ] [ interface | ipv6 ]
未指定设备发送RADIUS报文使用的源IP地址,使用系统视图下由命令radius nas-ip指定的源IP地址。
RADIUS方案视图
m-lag:M-LAG场景下,为从M-LAG接口接入的用户指定发送RADIUS报文使用的源IP地址。
local:为从本端M-LAG接口接入的用户指定发送RADIUS报文使用的源IP地址。
peer:为从对端M-LAG接口接入且备份到本端的用户指定发送RADIUS报文使用的源IP地址。
interface interface-type interface-number:指定源接口,即发送RADIUS报文的源IPv4地址为该接口的主IPv4地址,发送RADIUS报文的源IPv6地址为该接口上配置的IPv6地址。interface-type interface-number为接口类型和接口编号。
ipv4-address:指定的源IPv4地址,应该为本机的地址,禁止配置全0地址、全1地址、D类地址、E类地址和环回地址。
ipv6 ipv6-address:指定的源IPv6地址,应该为本机的地址,必须是单播地址,不能为环回地址与本地链路地址。
RADIUS服务器上通过IP地址来标识接入设备,并根据收到的RADIUS报文的源IP地址是否与服务器所管理的接入设备的IP地址匹配,来决定是否处理来自该接入设备的认证或计费请求。因此,为保证RADIUS报文可被服务器正常接收并处理,接入设备上发送RADIUS报文使用的源地址必须与RADIUS服务器上指定的接入设备的IP地址保持一致。
为避免物理接口故障时从服务器返回的报文不可达,推荐使用Loopback接口地址为发送RADIUS报文使用的源IP地址。
M-LAG场景下,为了使得M-LAG设备故障导致用户流量切换后,RADIUS服务器不用感知到处理用户业务的接入设备发生变化,就需要保证已在线用户发送的RADIUS报文的源IP始终保持不变。因此,RADIUS方案视图下的源IP地址需要结合接入业务(如端口安全)在M-LAG接口上采用的用户处理模式进行设置:
· 集中处理模式下,需要在两台M-LAG设备上均配置相同的源IP地址。
当M-LAG系统中的一台M-LAG设备发生故障时,原故障设备上处理的用户在另外一台M-LAG设备上使用配置的源IP地址发送RADIUS报文。
· 分布处理模式下,需要在两台M-LAG设备上配置不同的源IP地址,或者在两台M-LAG设备上均配置一个local源IP地址和一个peer源IP地址,且两台设备上的这组地址彼此相反。前一种配置方式下,本端设备会通过M-LAG系统自动获得对端同步过来的源IP地址。
当M-LAG系统中的一台M-LAG设备发生故障时,原故障设备上处理的用户在另外一台M-LAG设备上将使用配置的peer源IP地址或者同步过来源IP地址发送RADIUS报文。
RADIUS方案视图和系统视图下均可以配置发送RADIUS报文使用的源IP地址,具体生效情况如下:
· RADIUS方案视图下配置的源IP地址(通过nas-ip命令)只对本方案有效。
· 系统视图下的配置的源IP地址(通过radius nas-ip命令)对所有RADIUS方案有效。
· RADIUS方案视图下的设置具有更高的优先级。
一个RADIUS方案视图下:
· 最多允许指定一个IPv4源地址和一个IPv6源地址。
· 最多允许指定一个源接口,请确保指定的源接口与RADIUS服务器路由可达。
· 源接口配置和源IP地址配置不能同时存在,后配置的生效。
如果undo nas-ip命令中不指定任何参数,则表示删除配置的发送RADIUS报文使用的源IPv4地址。
M-LAG组网环境中,必须通过本命令配置设备发送RADIUS报文使用的源IP地址,且该IP地址必须为M-LAG虚拟IP地址。关于M-LAG虚拟IP地址的详细介绍,请参见“二层技术-以太网交换”中的“M-LAG”。m-lag { local | peer }参数仅用于M-LAG场景。若不配置该参数,则设备重启不会发送accounting-on报文。在集中处理模式下,两台设备上可以都使用m-lag local参数或都不使用m-lag local参数来配置本端M-LAG接口使用的源IP地址,效果相同,后者配置更简便;在分布处理模式下,两台设备上可以都使用m-lag local参数和m-lag peer参数分别配置一组本端和对端的源IP地址,也可以都仅配置本端的源IP地址,效果相同,后者配置更简便。
# 在RADIUS方案radius1中,设置设备发送RADIUS报文使用的源IP地址为10.1.1.1。
[Sysname-radius-radius1] nas-ip 10.1.1.1
· radius nas-ip
port命令用来指定RADIUS DAE服务端口。
undo port命令用来恢复缺省情况。
port port-number
undo port
RADIUS DAE服务端口为3799。
RADIUS DAE服务器视图
port-number:DAE服务器接收DAE请求消息的UDP端口,取值范围为1~65535。
必须保证设备上的RADIUS DAE服务端口与RADIUS DAE客户端发送DAE报文的目的UDP端口一致。
# 开启RADIUS DAE服务后,指定DAE服务端口为3790。
[Sysname-radius-da-server] port 3790
· client
primary accounting命令用来配置主RADIUS计费服务器。
undo primary accounting命令用来恢复缺省情况。
primary accounting { host-name | ipv4-address | ipv6 ipv6-address } [ port-number | key { cipher | simple } string | ssl-client-policy policy-name | vpn-instance vpn-instance-name | weight weight-value ] *
未配置主RADIUS计费服务器。
RADIUS方案视图
host-name:主RADIUS计费服务器的主机名,为1~253个字符的字符串,不区分大小写。
ipv4-address:主RADIUS计费服务器的IPv4地址。
ipv6 ipv6-address:主RADIUS计费服务器的IPv6地址。
port-number:主RADIUS计费服务器的端口号,取值范围为1~65535。使用UDP方式通信时,缺省端口号为1813;使用TLS方式通信时,缺省端口号为2083。
key:与主RADIUS计费服务器交互的计费报文的共享密钥。
cipher:以密文方式设置密钥。
vpn-instance vpn-instance-name:主RADIUS计费服务器所属的VPN实例。vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。如果未指定本参数,则表示主RADIUS计费服务器位于公网中。
weight weight-value:RADIUS服务器负载分担的权重。weight-value表示权重值,取值范围为0~100,缺省值为0。0表示该服务器在负载分担调度时将不被使用。开启服务器负载分担功能后,该参数才能生效,且权重值越大的服务器可以处理的计费请求报文越多。
ssl-client-policy policy-name:主计费服务器使用的SSL客户端策略,为1~31个字符的字符串,不区分大小写。配置此策略时,表示使用RADIUS over TLS方式与服务器通信;未配置此策略时,表示使用RADIUS over UDP方式与服务器通信。
配置的主计费服务器的UDP端口号以及计费报文的共享密钥必须与服务器的配置保持一致。
在同一个方案中指定的主计费服务器和从计费服务器的VPN、主机名、IP地址、端口号不能完全相同。
设备与主计费服务器通信时优先使用本命令设置的共享密钥,如果此处未设置,则使用key accounting命令设置的共享密钥。如果key accounting命令也未设置且RADIUS服务器类型为RADIUS over TLS服务器,则使用缺省的共享密钥radsec。
若服务器位于MPLS VPN私网中,为保证RADIUS报文被发送到指定的私网服务器,必须指定服务器所属的VPN实例。本命令指定的服务器所属的VPN实例比RADIUS方案所属的VPN实例具有更高的优先级。
当RADIUS服务器负载分担功能处于关闭状态时,如果在计费开始请求报文发送过程中修改或删除了正在使用的主计费服务器配置,则设备在与当前服务器通信超时后,将会重新按照优先级顺序开始依次查找状态为active的服务器进行通信;当RADIUS服务器负载分担功能处于开启状态时,设备将仅与发起计费开始请求的服务器通信。
如果在线用户正在使用的计费服务器被删除,则设备将无法发送用户的实时计费请求和停止计费请求,且停止计费报文不会被缓存到本地,这将造成对用户计费的不准确。
配置相同IP地址(或hostName)、端口号、VPN的计费服务器时,只能配置RADIUS over UDP或RADIUS over TLS中的一种通信方式。如果配置了RADIUS over TLS通信方式,则各RADIUS方案下的SSL客户端策略名称必须相同。如果配置了RADIUS over UDP通信方式,则各RADIUS方案下都不能配置SSL客户端策略。
# 在RADIUS方案radius1中,配置主计费服务器的IP地址为10.110.1.2,使用UDP端口1813提供RADIUS计费服务,计费报文的共享密钥为明文123456TESTacct&!。
[Sysname-radius-radius1] primary accounting 10.110.1.2 1813 key simple 123456TESTacct&!
# 在RADIUS方案radius1中,配置主计费服务器的IP地址为10.110.1.2,SSL客户端策略为policy1。
[Sysname-radius-radius1] primary accounting 10.110.1.1 ssl-client-policy policy1
· key (RADIUS scheme view)
· secondary accounting (RADIUS scheme view)
· server-load-sharing enable
· vpn-instance (RADIUS scheme view)
primary authentication命令用来配置主RADIUS认证服务器。
undo primary authentication命令用来恢复缺省情况。
primary authentication { host-name | ipv4-address | ipv6 ipv6-address } [ port-number | key { cipher | simple } string | ssl-client-policy policy-name | test-profile profile-name | vpn-instance vpn-instance-name | weight weight-value ] *
未配置RADIUS主认证服务器。
RADIUS方案视图
host-name:主RADIUS认证服务器的主机名,为1~253个字符的字符串,不区分大小写。
ipv4-address:主RADIUS认证服务器的IPv4地址。
ipv6 ipv6-address:主RADIUS认证服务器的IPv6地址。
port-number:主RADIUS认证服务器的端口号,取值范围为1~65535。此端口号必须与服务器提供认证服务的端口号保持一致。使用UDP方式通信时,缺省端口号为1812;使用TLS方式通信时,缺省端口号为2083。
key:与主RADIUS认证服务器交互的认证报文的共享密钥。此共享密钥必须与服务器上配置的共享密钥保持一致。
cipher:以密文方式设置密钥。
test-profile profile-name:RADIUS服务器探测模板名称,为1~31个字符的字符串,区分大小写。
vpn-instance vpn-instance-name:主RADIUS认证服务器所属的VPN实例。vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。如果未指定本参数,则表示主RADIUS认证服务器位于公网中。
weight weight-value:RADIUS服务器负载分担的权重。weight-value表示权重值,取值范围为0~100,缺省值为0。0表示该服务器在负载分担调度时将不被使用。开启服务器负载分担功能后,该参数才能生效,且权重值越大的服务器可以处理的认证请求报文越多。
ssl-client-policy policy-name:主认证服务器使用的SSL客户端策略,为1~31个字符的字符串,不区分大小写。配置此策略时,表示使用RADIUS over TLS方式与服务器通信;未配置此策略时,表示使用RADIUS over UDP方式与服务器通信。
配置的主认证服务器的UDP端口号以及认证报文的共享密钥必须与服务器的配置保持一致。
在同一个方案中指定的主认证服务器和从认证服务器的VPN、主机名、IP地址、端口号不能完全相同。
设备与主认证服务器通信时优先使用本命令设置的共享密钥,如果本命令中未设置,则使用key authenticaiton命令设置的共享密钥。如果key authenticaiton命令也未设置且RADIUS服务器类型为RADIUS over TLS服务器,则使用缺省的共享密钥radsec。
RADIUS认证服务器引用了存在的服务器探测模板后,将会触发对该服务器的探测功能。
若服务器位于MPLS VPN私网中,为保证RADIUS报文被发送到指定的私网服务器,必须指定服务器所属的VPN实例。本命令指定的服务器所属的VPN比RADIUS方案所属的VPN优先级高。
当RADIUS服务器负载分担功能处于关闭状态时,如果在认证过程中修改或删除了正在使用的主认证服务器配置,则设备在与当前服务器通信超时后,将会重新按照优先级顺序开始依次查找状态为active的服务器进行通信;当RADIUS服务器负载分担功能处于开启状态时,如果在认证过程中修改或删除了正在使用的认证服务器配置,则设备在与当前服务器通信超时后,将会根据各服务器的权重以及服务器承载的用户负荷重新选择状态为active的服务器进行通信。
配置相同IP地址(或hostName)、端口号、VPN的认证服务器时,只能配置RADIUS over UDP或RADIUS over TLS中的一种通信方式。如果配置了RADIUS over TLS通信方式,则各RADIUS方案下的SSL客户端策略名称必须相同。如果配置了RADIUS over UDP通信方式,则各RADIUS方案下都不能配置SSL客户端策略。
# 在RADIUS方案radius1中,配置主认证服务器的IP地址为10.110.1.1,使用UDP端口1812提供RADIUS认证/授权服务,认证报文的共享密钥为明文123456TESTauth&!。
[Sysname-radius-radius1] primary authentication 10.110.1.1 1812 key simple 123456TESTauth&!
# 在RADIUS方案radius1中,配置主认证服务器的IP地址为10.110.1.1,SSL客户端策略为policy1。
[Sysname-radius-radius1] primary authentication 10.110.1.1 ssl-client-policy policy1
· secondary authentication (RADIUS scheme view)
radius attribute extended命令用来定义RADIUS扩展属性。
undo radius attribute extended命令用来删除定义的RADIUS扩展属性。
radius attribute extended attribute-name [ vendor vendor-id ] code attribute-code type { binary | date | integer | interface-id | ip | ipv6 | ipv6-prefix | octets | string }
undo radius attribute extended [ attribute-name ]
不存在自定义RADIUS扩展属性。
attribute-name:RADIUS属性名称,为1~63个字符的字符串,不区分大小写。该名称不能与系统已支持的(包括标准的以及自定义的)RADIUS属性名称相同。
code attribute-code:RADIUS属性在RADIUS属性集里的序号,取值范围为1~255。
· binary:二进制类型。
· date:时间类型。
· integer:整数类型。
· ip:IPv4地址类型。
· ipv6:IPv6地址类型。
· octets:八进制类型。
· string:字符串类型。
当系统需要支持其他厂商的私有RADIUS属性时,可以通过radius attribute extended命令为其定义为一个扩展属性,并通过attribute convert命令将其映射到系统可以识别的一个已知属性。这样,当RADIUS服务器发送给设备的RADIUS报文中携带了此类不可识别的私有属性时,设备将根据已定义的属性转换规则将其转换为可处理的属性。同理,设备在发送RADIUS报文时也可以将自己可识别的属性转换为服务器能识别的属性。
每一个RADIUS属性有唯一的属性名称,且该属性的名称、设备厂商标识以及序号的组合必须在设备上唯一。
执行undo radius attribute extended命令时,如果不指定属性名称,则表示删除所有已定义RADIUS扩展属性。
# 配置一个RADIUS扩展属性,名称为Owner-Password,Vendor ID为122,属性序号为80,类型为字符串。
[Sysname] radius attribute extended Owner-Password vendor 122 code 80 type string
· attribute convert
· attribute reject
radius attribute-test-group命令用来创建RADIUS属性测试组,并进入RADIUS属性测试组视图。如果指定的RADIUS属性测试组视图已经存在,则直接进入RADIUS属性测试组视图。
undo radius attribute-test-group命令用来删除指定的RADIUS属性测试组。
radius attribute-test-group attr-test-group-name
undo radius attribute-test-group attr-test-group-name
不存在RADIUS属性测试组。
attr-test-group-name:测试组名称,为1~31个字符的字符串,不区分大小写。
RADIUS属性测试组用于配置向RADIUS服务器发送的认证/计费请求报文中需要携带的RADIUS属性的集合。
系统支持配置多个RADIUS属性测试组。
# 创建名称为t1的RADIUS属性测试组,并进入该视图。
· exclude
· include
· test-aaa
radius authentication-request first命令用来开启RADIUS认证请求优先处理功能。
undo radius authentication-request first命令用来关闭RADIUS认证请求优先处理功能。
RADIUS认证请求优先处理功能处于关闭状态,设备依次处理接入模块发起的所有RADIUS请求。
接入模块发起的RADIUS请求包括RADIUS认证请求、RADIUS计费开始请求、RADIUS计费更新请求和RADIUS计费结束请求。缺省情况下,设备依次处理各接入模块发起的所有类型的RADIUS请求。此时,如果有大量用户下线后立即再次上线的情况发生,则会由于设备首先处理较早的停止计费请求,而导致处理后续的认证请求时,接入模块的认证请求已经超时。认证请求超时后,用户认证失败。为了解决这个问题,建议在有大量用户频繁上下线的组网环境中开启本功能,使得设备优先处理RADIUS认证请求,从而保证用户可以正常上线。
需要注意的是,当RADIUS服务器上以用户名标识用户,并且不允许相同用户名的用户重复认证的情况下,不建议开启此功能,否则可能会导致用户下线后再次认证失败。
当设备上有用户在线时,不建议修改此配置。
# 开启RADIUS认证请求优先处理功能。
[Sysname] radius authentication-request first
radius dscp命令用来配置RADIUS协议报文的DSCP优先级。
undo radius dscp命令用来恢复缺省情况。
radius [ ipv6 ] dscp dscp-value
undo radius [ ipv6 ] dscp
RADIUS报文的DSCP优先级为0。
ipv6:表示设置IPv6 RADIUS报文。若不指定该参数,则表示设置IPv4 RADIUS报文。
dscp-value:RADIUS报文的DSCP优先级,取值范围为0~63。取值越大,优先级越高。
DSCP携带在IPv4报文中的ToS字段以及IPv6报文中的Traffic Class字段中,用来体现报文自身的优先等级,决定报文传输的优先程度。通过本命令可以指定设备发送的RADIUS报文携带的DSCP优先级的取值。
# 配置IPv4 RADIUS报文的DSCP优先级为10。
[Sysname] radius dscp 10
radius dynamic-author server命令用来开启RADIUS DAE服务,并进入RADIUS DAE服务器视图。
undo radius dynamic-author server命令用来关闭RADIUS DAE服务。
RADIUS DAE服务处于关闭状态。
开启RADIUS DAE服务后,设备将会监听指定的RADIUS DAE客户端发送的DAE请求消息,然后根据请求消息修改用户授权信息、断开用户连接请求、关闭/重启用户接入端口或重认证用户。
# 开启RADIUS DAE服务,并进入RADIUS DAE服务器视图。
· client
· port
radius enable命令用来开启RADIUS协议功能。
undo radius enable命令用来关闭RADIUS协议功能。
radius enable
undo radius enable
RADIUS协议功能处于开启状态。
开启RADIUS协议功能后,设备可以接收和发送RADIUS报文。
由于攻击者可能会通过RADIUS的session control报文监听端口或RADIUS DAE服务端口向设备发起网络攻击,因此设备管理员可以通过临时关闭RADIUS协议功能来阻止攻击,并在网络环境恢复安全后,再重新打开RADIUS协议功能。另外,如果服务器需要调整配置或暂时不提供服务,则可以通过关闭设备上的RADIUS协议功能来协助完成此过程。
关闭RADIUS协议功能后,设备将停止接收和发送RADIUS报文,具体处理机制如下:
若有新用户上线,则根据配置的备份方案进行认证、授权和计费处理。
· 若已经为用户发送了RADIUS认证请求报文:
¡ 如果收到RADIUS服务器的响应报文,则根据响应完成认证和授权。
¡ 如果未收到RADIUS服务器响应报文,则根据配置的备份方案进行认证处理。
· 若已经为用户发送了RADIUS计费开始请求报文:
¡ 如果收到RADIUS服务器的响应报文,则用户上线,但后续计费更新和计费结束请求报文无法发出,也不能被缓存下来尝试继续发送。RADIUS服务器因为收不到在线用户的下线报文,会出现有一段时间用户已经下线,但RADIUS服务器上还有此用户的情况。另外,已缓存的计费报文也将从缓存中被删除。计费报文的发送失败,都会直接影响用户计费信息的准确性。
¡ 如果未收到RADIUS服务器的响应报文,则根据配置的备份方案进行处理。
关闭RADIUS协议功能对设备的RADIUS服务器功能没有影响。
关闭RADIUS协议功能后,若再重新开启RADIUS协议功能,已经使用其它方案进行的认证、授权或计费过程并不会切换为RADIUS方案来执行。
# 开启RADIUS协议功能。
[Sysname] radius enable
radius nas-ip命令用来设置设备发送RADIUS报文使用的源IP地址。
undo radius nas-ip命令用来删除指定的发送RADIUS报文使用的源IP地址。
radius nas-ip { interface interface-type interface-number | { ipv4-address | ipv6 ipv6-address } [ vpn-instance vpn-instance-name ] }
undo radius nas-ip { interface | { ipv4-address | ipv6 ipv6-address } [ vpn-instance vpn-instance-name ] }
未指定发送RADIUS报文使用的源IP地址,设备将使用到达RADIUS服务器的路由出接口的主IPv4地址或IPv6地址作为发送RADIUS报文的源IP地址。
ipv4-address:指定的源IPv4地址,应该为本机的地址,不能为全0地址、全1地址、D类地址、E类地址和环回地址。
vpn-instance vpn-instance-name:指定私网源IP地址所属的VPN实例。vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。若不指定该参数,则表示配置的是公网源地址。
RADIUS服务器上通过IP地址来标识接入设备,并根据收到的RADIUS报文的源IP地址是否与服务器所管理的接入设备的IP地址匹配,来决定是否处理来自该接入设备的认证或计费请求。为保证RADIUS报文可被服务器正常接收并处理,接入设备上发送RADIUS报文使用的源地址必须与RADIUS服务器上指定的接入设备的IP地址保持一致。
RADIUS方案视图和系统视图下均可以配置发送RADIUS报文使用的源IP地址,具体情况如下:
· RADIUS方案视图下配置的源IP地址(通过nas-ip命令)只对本RADIUS方案有效。
系统视图下最多允许指定16个源地址。其中,最多包括一个IPv4公网源地址和一个IPv6公网源地址,其余为私网源地址。对于同一个VPN,系统视图下最多允许指定一个IPv4私网源地址和一个IPv6私网源地址。
系统视图下,最多允许指定一个源接口,请确保指定的源接口与RADIUS服务器路由可达。
# 设置设备发送RADIUS报文使用的源IP地址为129.10.10.1。
[Sysname] radius nas-ip 129.10.10.1
· nas-ip (RADIUS scheme view)
radius scheme命令用来创建RADIUS方案,并进入RADIUS方案视图。如果指定的RADIUS方案已经存在,则直接进入RADIUS方案视图。
undo radius scheme命令用来删除指定的RADIUS方案。
radius scheme radius-scheme-name
undo radius scheme radius-scheme-name
不存在RADIUS方案。
radius-scheme-name:RADIUS方案的名称,为1~32个字符的字符串,不区分大小写。
一个RADIUS方案可以同时被多个ISP域引用。
系统最多支持配置16个RADIUS方案。
# 创建名为radius1的RADIUS方案并进入其视图。
radius session-control client命令用来指定session control客户端。
undo radius session-control client命令用来删除指定的session control客户端。
radius session-control client { ip ipv4-address | ipv6 ipv6-address } [ key { cipher | simple } string | vpn-instance vpn-instance-name ] *
undo radius session-control client { all | { ip ipv4-address | ipv6 ipv6-address } [ vpn-instance vpn-instance-name ] }
未指定session control客户端。
ip ipv4-address:session control客户端的IPv4地址。
ipv6 ipv6-address:session control客户端的IPv6地址。
key:与session control客户端交互的计费报文的共享密钥。
cipher:以密文方式设置密钥。
vpn-instance vpn-instance-name:session control客户端所属的VPN实例。vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。如果不指定本参数,则表示session control客户端属于公网。
all:表示所有session control客户端。
设备和iMC RADIUS服务器配合使用时,将作为session control服务器端与其交互,因此需要指定session control客户端来验证收到的session control报文的合法性。当设备收到服务器发送的session control报文时,直接根据报文的源IP地址、VPN属性与已有的session control客户端配置进行匹配,并使用匹配到的客户端共享密钥对报文进行验证。如果报文匹配失败或设备上未配置session control客户端,则使用已有的RADIUS方案配置进行匹配,并使用匹配到的认证服务器的共享密钥对报文进行验证。
指定的session control客户端仅在RADIUS session control功能处于开启状态时生效。
配置的session control客户端参数必须与服务器的配置保持一致。
系统支持指定多个session control客户端。
# 指定一个session control客户端IP地址为10.110.1.2,共享密钥为明文12345。
[Sysname] radius session-control client ip 10.110.1.2 key simple 12345
· radius session-control enable
radius session-control enable命令用来开启RADIUS session control功能。
undo radius session-control enable命令用来关闭RADIUS session control功能。
RADIUS session control功能处于关闭状态。
iMC RADIUS服务器使用session control报文向设备发送授权信息(例如授权ACL/VLAN/用户组/VSI/黑洞MAC)的动态修改请求以及断开连接请求。开启RADIUS session control功能后,设备会打开知名UDP端口1812来监听并接收RADIUS服务器发送的session control报文。
该功能仅能和iMC RADIUS服务器配合使用。
# 开启RADIUS session control功能。
[Sysname] radius session-control enable
radius trap-version命令用来配置发送RADIUS告警信息采用的MIB节点版本。
undo radius trap-version命令用来恢复缺省情况。
radius trap-version { v1 | v2 } [ accounting-server-down | accounting-server-up | authentication-server-down | authentication-server-up ] *
undo radius trap-version { v1 | v2 } [ accounting-server-down | accounting-server-up | authentication-server-down | authentication-server-up ] *
使用v1版本的MIB节点发送RADIUS告警信息。
v1:采用v1版本的MIB节点发送RADIUS告警信息。
v2:采用v2版本的MIB节点发送RADIUS告警信息。
accounting-server-down:表示RADIUS计费服务器可达状态变为down时发送告警信息。
accounting-server-up:表示RADIUS计费服务器可达状态变为up时发送告警信息。
authentication-server-down:表示RADIUS认证服务器可达状态变为down时发送告警信息。
authentication-server-up:表示RADIUS认证服务器可达状态变为up时发送告警信息。
请按照NMS(Network Management System,网络管理系统)的要求,选择设备需要采用的发送RADIUS告警信息采用的MIB节点版本。
表1-18 v1版本的MIB节点
MIB节点名 |
OID |
hh3cRadiusAuthServerUpTrap |
1.3.6.1.4.1.25506.2.13.3.0.1 |
hh3cRadiusAccServerUpTrap |
1.3.6.1.4.1.25506.2.13.3.0.2 |
hh3cRadiusAuthServerDownTrap |
1.3.6.1.4.1.25506.2.13.3.1 |
hh3cRadiusAccServerDownTrap |
1.3.6.1.4.1.25506.2.13.3.2 |
表1-19 v2版本的MIB节点
MIB节点名 |
OID |
hh3cRadiusAuthenticationServerUpTrap |
1.3.6.1.4.1.25506.2.13.3.0.4 |
hh3cRadiusAccountingServerUpTrap |
1.3.6.1.4.1.25506.2.13.3.0.5 |
hh3cRadiusAuthenticationServerDownTrap |
1.3.6.1.4.1.25506.2.13.3.0.6 |
hh3cRadiusAccountingServerDownTrap |
1.3.6.1.4.1.25506.2.13.3.0.7 |
若不指定任何参数,则表示设备发送所有类型的RADIUS服务器状态变化告警信息时,均采用相同版本的MIB节点。
多次执行本命令,最后一次执行的命令生效。
# 配置在RADIUS计费服务器可达状态变为down时发送告警信息采用v2版本的MIB节点。
[Sysname] radius trap-version v2 accounting-server-down
· snmp-agent trap enable radius
radius-server authen-state-check interval命令用来设置RADIUS认证服务器状态检查的时间间隔。
undo radius-server authen-state-check interval命令用来恢复缺省情况。
radius-server authen-state-check interval interval
RADIUS认证服务器状态检查的时间间隔为10分钟。
interval:状态检查的时间间隔,取值范围为1~120,单位为分钟。
本特性仅适用于802.1X认证、MAC地址认证和Web认证用户。
系统将以指定的时间间隔定期检查各RADIUS方案下的RADIUS认证服务器的状态,并通知接入模块将存在可达认证服务器的RADIUS方案下的已逃生用户取消逃生。
设备对RADIUS认证服务器状态变化的及时感知影响到用户逃生处理的准确性。配置了用户逃生功能的情况下,可能会有如下情况发生:
· RADIUS服务器探测功能开启后,如果RADIUS服务器的探测周期过长,那么在设备还未获得探测结果的情况下,如果服务器状态变为不可达,在此期间上线的用户将会进入逃生域,但是探测周期内设备上记录的服务器状态一直为active。
· RADIUS服务器探测功能未开启时,在RADIUS服务器响应超时时间内没有收到响应报文的认证用户将会进入逃生域,但是如果设备在此期间收到了来自该服务器对其它用户的认证请求响应报文,则设备上记录的服务器的状态将不会被置为block。如果后续用户的认证服务器状态一直保持可达,设备记录的服务器状态会一直为active。
以上两种情况下,设备均无法及时感知到服务器实际状态的变化,因而已经逃生的用户也无法在RADIUS认证服务器恢复可达后离开逃生域。RADIUS认证服务器状态检查功能可以解决这个问题,
如果设置的状态检查时间间隔过小,将会占用接入业务处理的系统资源;如果设置的状态检查时间间隔过大,对于服务器实际状态变化的感知将不够及时。
在有大量用户集中上线的情况下,建议综合考虑接入业务的处理效率和逃生处理的准确性。
# 设置RADIUS认证服务器状态检查的时间间隔为2分钟。
[Sysname] radius-server authen-state-check interval 2
· authen-radius-unavailable online domain
radius-server test-profile命令用来配置RADIUS服务器探测模板。
undo radius-server test-profile命令用来删除指定的RADIUS服务器探测模板。
radius-server test-profile profile-name username name [ password { cipher | simple } string ] [ interval interval ] [ confirm | eap-profile eap-profile-name ]
undo radius-server test-profile profile-name
不存在RADIUS服务器探测模板。
profile-name:探测模板名称,为1~31个字符的字符串,区分大小写。
username name:探测报文中的用户名,为1~253个字符的字符串,区分大小写。
password:探测报文中的用户密码。若不指定该参数,则表示探测报文中携带的用户密码为设备生成的随机密码。为避免携带随机密码的探测报文被RADIUS服务器判定为攻击报文,建议指定用户密码。
cipher:以密文方式设置用户密码。
simple:以明文方式设置用户密码,该密码将以密文形式存储。
interval interval:发送探测报文的周期,取值范围为1~3600,单位为分钟,缺省值为60。
confirm:表示设备将发送探测确认报文对服务器状态进行确认。
eap-profile eap-profile-name:引用的EAP认证方案的名称,为1~32个字符的字符串,区分大小写。
RADIUS方案视图下的RADIUS服务器配置成功引用了某探测模板后,若被引用的探测模板存在,则设备将会启动对该RADIUS服务器的可达性探测。若被引用的探测模板暂不存在,则当该探测模板被成功配置时,针对该服务器的探测过程才会开始。
目前,设备支持两种探测方式:
· 若探测模板中未引用EAP认证方案,则表示采用简单探测方式。该方式下,设备采用探测模板中配置的探测用户名、密码构造一个认证请求报文,并在探测周期内选择随机时间点向引用了探测模板的RADIUS服务器发送该报文。如果在本次探测周期内收到服务器的认证响应报文,则认为当前探测周期内该服务器可达。若配置了confirm参数,当设备探测到服务器可达状态发生变化时,将在短时间内连续发送三次探测确认报文,再次确认服务器的真实状态,若任意一次探测确认报文与探测报文探测的结果不一致,则设备将不会更改其保存的服务器状态信息。探测确认报文的回应超时时间可通过timer response-timeout命令进行配置。
· 若探测模板中引用了EAP认证方案,则表示采用EAP探测方式。该方式下,设备采用指定的EAP认证方案中配置的EAP认证方法启动服务器探测。在探测过程中,设备会在配置的探测周期超时后使用探测模板中配置的探测用户名和密码,模拟一个合法EAP认证用户向引用了该探测模板的RADIUS服务器发起一次EAP认证,如果在探测超时时间内(不可配)该次认证成功完成,则认为当前探测周期内该服务器可用。
EAP探测方式相较于简单探测方式,由于探测过程还原了完整的认证过程,更能保证RADIUS服务器探测结果的可靠性。建议在接入用户使用EAP认证方法的组网环境中,使用该方式的服务器探测功能。
若探测模板中引用的EAP认证方案不存在,则设备会暂时采用简单探测方式发起探测。当引用的EAP认证方案配置成功后,下一个探测周期将使用EAP方式发起探测。
删除一个RADIUS服务器探测模板时,引用该探测模板的所有RADIUS方案中的RADIUS服务器的探测功能也会被关闭。
系统支持配置多个RADIUS服务器探测模板。
# 配置RADIUS服务器探测模板abc,探测报文中携带的用户名为admin,密码为明文abc123,探测报文的发送间隔为10分钟。
[Sysname] radius-server test-profile abc username admin password simple abc123 interval 10
· eap-profile
· primary authentication (RADIUS scheme view)
· timer response-timeout (RADIUS scheme view)
reauthentication server-select命令用来配置重认证时RADIUS服务器的选择模式。
undo reauthentication server-select命令用来恢复缺省情况。
reauthentication server-select { inherit | reselect }
重认证时仍然选用认证时使用的认证服务器。
RADIUS方案视图
inherit:继承模式,即重认证时仍然选用认证时使用的认证服务器。
reselect:重新选择模式,即重认证时需要重新选择认证服务器。
对用户进行重认证时,可以通过本命令来控制认证服务器的选择模式:
· 继承模式也是缺省模式,该模式下,设备直接沿用用户认证时使用的服务器,不再做其它尝试。使用此模式可以达到快速重认证的效果,但如果该认证服务器不可达,则会导致重认证失败。
· 重新选择模式下,设备会根据当前RADIUS方案中服务器的配置、服务器负载分担功能的开启状态,以及各服务器的可达状态重新选择认证服务器。使用此模式,可以尽可能得保证重认证时选择到当前最优且可达的服务器。
· 本功能与RADIUS服务器并行认证功能(通过server-parallel-auth enable命令配置)同时开启时,本功能不生效。
# 在RADIUS方案radius1中,配置重认证时RADIUS服务器的选择模式为重新选择模式。
[Sysname-radius-radius1] reauthentication server-select reselect
· server-parallel-auth enable
reset radius server-load statistics命令用来清除所有RADIUS服务器的历史负载统计信息。
该命令只会清除所有RADIUS认证/计费服务器的历史负载统计数据,不会清除前5秒钟负载统计数据。
# 清除所有RADIUS服务器上的历史负载统计信息。
<Sysname> reset radius server-load statistics
· display radius server-load statistics
reset radius statistics命令用来清除RADIUS协议的统计信息。
# 清除RADIUS协议的统计信息。
<Sysname> reset radius statistics
· display radius statistics
reset stop-accounting-buffer命令用来清除缓存的RADIUS停止计费请求报文。
reset stop-accounting-buffer { radius-scheme radius-scheme-name | session-id session-id | time-range start-time end-time | user-name user-name }
radius-scheme radius-scheme-name:表示指定RADIUS方案的停止计费响应报文。其中,radius-scheme-name为RADIUS方案名,为1~32个字符的字符串,不区分大小写。
session-id session-id:表示指定会话的停止计费响应报文。其中,session-id表示会话ID,为1~64个字符的字符串,不包含字母。会话ID用于唯一标识当前的在线用户。
time-range start-time end-time:表示指定时间段内发送且被缓存的停止计费请求报文。其中,start-time为请求时间段的起始时间;end-time为请求时间段的结束时间,格式为hh:mm:ss-mm/dd/yyyy(时:分:秒-月/日/年)或hh:mm:ss-yyyy/mm/dd(时:分:秒-年/月/日)。
user-name user-name:表示指定用户名的停止计费响应报文。其中,user-name表示用户名,为1~255个字符的字符串,区分大小写。输入的用户名是否携带ISP域名,必须与RADIUS方案中配置的发送给RADIUS服务器的用户名格式保持一致。
# 清除缓存的用户user0001@test的RADIUS停止计费请求报文。
<Sysname> reset stop-accounting-buffer user-name user0001@test
# 清除从2015年8月31日0点0分0秒到2015年8月31日23点59分59秒期间内缓存的停止计费请求报文。
<Sysname> reset stop-accounting-buffer time-range 00:00:00-08/31/2015 23:59:59-08/31/2015
· display stop-accounting-buffer (for RADIUS)
retry命令用来设置发送RADIUS报文的最大尝试次数。
undo retry命令用来恢复缺省情况。
retry retries
undo retry
发送RADIUS报文的最大尝试次数为3次。
RADIUS方案视图
retries:发送RADIUS报文的最大尝试次数,取值范围为1~20。
由于RADIUS协议采用UDP报文来承载数据,因此其通信过程是不可靠的。如果设备在应答超时定时器规定的时长内(由timer response-timeout命令配置)没有收到RADIUS服务器的响应,则设备有必要向RADIUS服务器重传RADIUS请求报文。如果累计的传送次数已达到最大传送次数而RADIUS服务器仍旧没有响应,则设备将认为本次请求失败。
· 发送RADIUS报文的最大尝试次数、RADIUS服务器响应超时时间以及配置的RADIUS服务器总数,三者的乘积不能超过接入模块定义的用户认证超时时间,否则在RADIUS认证过程完成之前用户就有可能被强制下线。
· 设备在按照配置顺序尝试与下一个RADIUS服务器通信之前,会首先判断当前累计尝试持续时间是否达到或超过300秒,如果超过或达到300秒,将不再向下一个RADIUS服务器发送RADIUS请求报文,即认为该RADIUS请求发送失败。因此,为了避免某些已部署的RADIUS服务器由于此超时机制而无法被使用到,建议基于配置的RADIUS服务器总数,合理设置发送RADIUS报文的最大尝试次数以及RADIUS服务器响应超时时间。
# 在RADIUS方案radius1中,设置发送RADIUS报文的最大尝试次数为5次。
[Sysname-radius-radius1] retry 5
· radius scheme
retry realtime-accounting命令用来设置允许发起实时计费请求的最大尝试次数。
undo retry realtime-accounting命令用来恢复缺省情况。
retry realtime-accounting retries
设备允许发起实时计费请求的最大尝试次数为5。
RADIUS方案视图
retries:允许发起实时计费请求的最大尝试次数,取值范围为1~255。
RADIUS服务器通常通过连接超时定时器来判断用户是否在线。如果RADIUS服务器在连接超时时间之内一直收不到设备传来的实时计费报文,它会认为线路或设备故障并停止对用户记帐。为了配合RADIUS服务器的这种特性,有必要在不可预见的故障条件下,尽量保持设备端与RADIUS服务器同步切断用户连接。设备提供对实时计费请求连续无响应次数限制的设置,保证设备尽可能得在RADIUS服务器的连接超时时长内向RADIUS服务器尝试发出实时计费请求。如果设备没有收到响应的次数超过了设定的限度,才会认为用户的实时计费失败,然后采用设置的计费更新失败策略决定是否切断用户连接(由accounting update-fail命令设置)。
以lan-access用户为例,假设RADIUS服务器的应答超时时长(timer response-timeout命令设置)为3秒,发送RADIUS报文的最大尝试次数(retry命令设置)为3,设备的实时计费间隔(timer realtime-accounting命令设置)为12分钟,设备允许实时计费无响应的最大次数为5次(retry realtime-accounting命令设置),则其含义为:设备每隔12分钟发起一次计费请求,如果3秒钟得不到回应就重新发起一次请求,如果3次发送都没有得到回应就认为该次实时计费失败,然后每隔12分钟再发送一次,5次均失败以后,设备将认为用户实时计费失败。
# 在RADIUS方案radius1中,设置允许发起实时计费请求的最大尝试次数为10。
[Sysname-radius-radius1] retry realtime-accounting 10
· accounting update-fail
· retry
· timer realtime-accounting (RADIUS scheme view)
retry stop-accounting命令用来设置发起RADIUS停止计费请求的最大尝试次数。
undo retry stop-accounting命令用来恢复缺省情况。
retry stop-accounting retries
发起RADIUS停止计费请求的最大尝试次数为500。
RADIUS方案视图
retries:允许停止计费请求无响应的最大次数,取值范围为10~65535。
设备通过发起RADIUS停止计费请求的最大尝试次数与其它相关参数一起控制停止计费请求报文的发送。假设存在如下配置:
· RADIUS服务器的应答超时时长(由timer response-timeout命令设置)为3秒;
· 发送RADIUS报文的最大尝试次数(由retry命令设置)为5;
· 开启了对无响应的RADIUS停止计费请求报文的缓存功能;
· 设备发起停止计费请求的最大尝试次数为20(由retry stop-accounting命令设置)。
则,如果设备发送停止计费请求报文后的3秒内得不到服务器响应就重新发送该报文。如果设备发送5次之后仍然没有得到响应,会将该报文缓存在本机上,然后再发起一轮停止计费请求。20次请求尝试均失败以后,设备将缓存的报文丢弃。
# 在RADIUS方案radius1中,设置发起RADIUS停止计费请求的最大尝试次数为1000。
[Sysname-radius-radius1] retry stop-accounting 1000
· retry
secondary accounting命令用来配置从RADIUS计费服务器。
undo secondary accounting命令用来删除指定的从RADIUS计费服务器。
secondary accounting { host-name | ipv4-address | ipv6 ipv6-address } [ port-number | key { cipher | simple } string | ssl-client-policy policy-name | vpn-instance vpn-instance-name | weight weight-value ] *
undo secondary accounting [ { host-name | ipv4-address | ipv6 ipv6-address } [ port-number | vpn-instance vpn-instance-name | ssl-client-policy ] * ]
未配置从RADIUS计费服务器。
RADIUS方案视图
host-name:从RADIUS计费服务器的主机名,为1~253个字符的字符串,不区分大小写。
ipv4-address:从RADIUS计费服务器的IPv4地址。
ipv6 ipv6-address:从RADIUS计费服务器的IPv6地址。
port-number:从RADIUS计费服务器的端口号,取值范围为1~65535。使用UDP方式通信时,缺省端口号为1813;使用TLS方式通信时,缺省端口号为2083。
key:与从RADIUS计费服务器交互的计费报文的共享密钥。
cipher:以密文方式设置密钥。
vpn-instance vpn-instance-name:从RADIUS计费服务器所属的VPN实例。vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。如果未指定本参数,则表示从RADIUS计费服务器位于公网中。
ssl-client-policy:从计费服务器使用的SSL客户端策略。配置此策略时,表示使用RADIUS over TLS方式与服务器通信;未配置此策略时,表示使用RADIUS over UDP方式与服务器通信。
policy-name:从计费服务器使用的SSL客户端策略名,为1~31个字符的字符串,不区分大小写。
配置的从计费服务器的UDP端口号以及计费报文的共享密钥必须与服务器的配置保持一致。
每个RADIUS方案中最多支持配置16个从RADIUS计费服务器。当主服务器不可达时,设备根据从服务器的配置顺序由先到后查找状态为active的从服务器并与之交互。
在同一个方案中指定的主计费服务器和从计费服务器的VPN、主机名、IP地址、端口号不能完全相同,并且各从计费服务器的VPN、主机名、IP地址、端口号也不能完全相同。
设备与从计费服务器通信时优先使用本命令设置的共享密钥,如果此处未设置,则使用命令key accounting命令设置的共享密钥。如果key accounting命令也未设置且RADIUS服务器类型为RADIUS over TLS服务器,则使用缺省的共享密钥radsec。
当RADIUS服务器负载分担功能处于关闭状态时,如果在计费开始请求报文发送过程中删除了正在使用的从服务器配置,则设备在与当前服务器通信超时后,将会重新按照优先级顺序开始依次查找状态为active的服务器进行通信;在RADIUS服务器负载分担功能处于开启状态时,设备将仅与发起计费开始请求的服务器通信。
如果在线用户正在使用的计费服务器被删除,则设备将无法发送用户的实时计费请求和停止计费请求,且停止计费报文不会被缓存到本地。
# 在RADIUS方案radius1中,配置从计费服务器的IP地址为10.110.1.1,使用UDP端口1813提供RADIUS计费服务。
[Sysname-radius-radius1] secondary accounting 10.110.1.1 1813
# 在RADIUS方案radius2中,配置两个从计费服务器,IP地址分别为10.110.1.1、10.110.1.2,且均使用UDP端口1813提供RADIUS计费服务。
[Sysname] radius scheme radius2
[Sysname-radius-radius2] secondary accounting 10.110.1.1 1813
[Sysname-radius-radius2] secondary accounting 10.110.1.2 1813
# 在RADIUS方案radius1中,配置从计费服务器的IP地址为10.110.1.1,SSL客户端策略为policy1。
[Sysname-radius-radius1] secondary accounting 10.110.1.1 ssl-client-policy policy1
· primary accounting
secondary authentication命令用来配置从RADIUS认证服务器。
undo secondary authentication命令用来删除指定的从RADIUS认证服务器。
secondary authentication { host-name | ipv4-address | ipv6 ipv6-address } [ port-number | key { cipher | simple } string | ssl-client-policy policy-name | test-profile profile-name | vpn-instance vpn-instance-name | weight weight-value ] *
undo secondary authentication [ { host-name | ipv4-address | ipv6 ipv6-address } [ port-number | vpn-instance vpn-instance-name | ssl-client-policy ] * ]
未配置从RADIUS认证服务器。
RADIUS方案视图
host-name:从RADIUS认证服务器的主机名,为1~253个字符的字符串,不区分大小写。
ipv4-address:从RADIUS认证服务器的IPv4地址。
ipv6 ipv6-address:从RADIUS认证服务器的IPv6地址。
port-number:从RADIUS认证服务器的端口号,取值范围为1~65535。使用UDP方式通信时,缺省端口号为1812;使用TLS方式通信时,缺省端口号为2083。
key:与从RADIUS认证服务器交互的认证报文的共享密钥。
cipher:以密文方式设置密钥。
vpn-instance vpn-instance-name:从RADIUS认证服务器所属的VPN实例。vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。如果未指定本参数,则表示从RADIUS认证服务器位于公网中。
ssl-client-policy:从认证服务器使用的SSL客户端策略。配置此策略时,表示使用RADIUS over TLS方式与服务器通信;未配置此策略时,表示使用RADIUS over UDP方式与服务器通信。
policy-name:从认证服务器使用的SSL客户端策略名,为1~31个字符的字符串,不区分大小写。
配置的从认证服务器的UDP端口号以及认证报文的共享密钥必须与服务器的配置保持一致。
每个RADIUS方案中最多支持配置16个从RADIUS认证服务器。当主服务器不可达时,设备根据从服务器的配置顺序由先到后查找状态为active的从服务器并与之交互。
在同一个方案中指定的主认证服务器和从认证服务器的VPN、主机名、IP地址、端口号不能完全相同,并且各从认证服务器的VPN、主机名、IP地址、端口号也不能完全相同。
设备与从认证服务器通信时优先使用本命令设置的共享密钥,如果此处未设置,则使用命令key authentication命令设置的共享密钥。如果key authenticaiton命令也未设置且RADIUS服务器类型为RADIUS over TLS服务器,则使用缺省的共享密钥radsec。
当RADIUS服务器负载分担功能处于关闭状态时,如果在认证过程中删除了正在使用的从服务器配置,则设备在与当前服务器通信超时后,将会重新按照优先级顺序开始依次查找状态为active的服务器进行通信;在RADIUS服务器负载分担功能处于开启状态时,如果在认证过程中修改或删除了正在使用的认证服务器配置,则设备在与当前服务器通信超时后,将会根据各服务器的权重以及服务器承载的用户负荷重新选择状态为active的服务器进行通信。
# 在RADIUS方案radius1中,配置从认证服务器的IP地址为10.110.1.2,使用UDP端口1812提供RADIUS认证/授权服务。
[Sysname] radius scheme radius1
[Sysname-radius-radius1] secondary authentication 10.110.1.2 1812
# 在RADIUS方案radius2中,配置两个从认证服务器,IP地址分别为10.110.1.1、10.110.1.2,且均使用UDP端口1812提供RADIUS认证/授权服务。
[Sysname-radius-radius2] secondary authentication 10.110.1.1 1812
[Sysname-radius-radius2] secondary authentication 10.110.1.2 1812
# 在RADIUS方案radius1中,配置从认证服务器的IP地址为10.110.1.2,SSL客户端策略为policy1。
[Sysname-radius-radius1] secondary authentication 10.110.1.2 ssl-client-policy policy1
· display radius scheme
server-load-sharing enable命令用来开启RADIUS服务器负载分担功能。
undo server-load-sharing enable命令用来关闭RADIUS服务器负载分担功能。
RADIUS服务器负载分担功能处于关闭状态。
RADIUS方案视图
缺省情况下,RADIUS服务器负载分担功能处于关闭状态,RADIUS服务器的调度采用主/从模式。
主/从模式下,设备优先选取状态为active的主服务器进行交互,若主服务器不可达则尝试与从服务器交互。设备尝试与从服务器交互时,按照从服务器的配置顺序依次选择,先配置的服务器将优先被选取。
在主/从模式下,设备选择服务器的逻辑比较单一。如果RADIUS方案中的主服务器或者某一配置顺序靠前的从服务器始终可达,则该服务器将独立承载该方案下所有用户的AAA业务。在大用户量下,这类服务器的负荷过重,将会影响处理用户上线的整体性能。
RADIUS方案中开启服务器负载分担功能后,设备将根据当前各服务器承载的用户负荷调度合适的服务器发送认证/计费请求。考虑到各服务器的性能可能存在差异,设备支持管理员配置服务器时为各个服务器指定适应其性能的权重值(由weight关键字指定),权重值较大的服务器具备较大的被选取可能性。设备在处理用户认证/计费请求时,将综合各个服务器的权重值及当前用户负荷情况,按比例进行用户负荷分配并选择要交互的服务器。
需要注意的是,负载分担模式下,某台计费服务器开始对某用户计费后,该用户后续计费请求报文均会发往同一计费服务器。如果该计费服务器不可达,则直接返回计费失败。
# 在RADIUS方案radius1中,开启RADIUS服务器负载分担功能。
[Sysname-radius-radius1] server-load-sharing enable
· primary accounting (RADIUS scheme view)
server-parallel-auth enable命令用来开启RADIUS服务器并行认证功能。
undo server-parallel-auth enable命令用关闭RADIUS服务器并行认证功能。
RADIUS服务器并行认证功能处于关闭状态。
RADIUS方案视图
本功能对于不同认证方式的实现机制不同,具体区别如下:
· 对于802.1X EAP终结认证或MAC认证方式,设备将同时向所有Active状态的服务器发送认证请求报文,不区分主备。当设备接收到服务器的回应报文时,只要其中一个服务器回应认证成功,则用户认证将被视为成功。在所有服务器均未认证成功的情况下,若所有服务器均无响应,则用户认证将走逃生认证流程;若所有服务器有至少一次回应认证失败,则用户认证被视为失败。
· 对于802.1X EAP中继认证方式,设备将采用主备服务器方式进行认证。若主服务器回应认证失败,则设备会判断当前是否还存在其他Active状态的服务器,若存在,则通知设备向下一个服务器发送认证请求报文,进行重认证。若不存在Active状态的服务器,则认为用户认证失败。在该认证过程中,仅当上一个认证服务器回应认证失败或服务器无响应时,才会向下一个Active状态的服务器发送认证请求报文。只要其中一个服务器回应认证成功,则用户认证被视为成功。在所有服务器均未认证成功的情况下,若所有服务器均无响应,则用户认证将走逃生认证流程;若所有服务器有至少一次回应认证失败,则用户认证被视为失败。
本功能与RADIUS服务器负载分担功能(通过server-load-sharing enable命令开启)同时开启时,RADIUS服务器负载分担功能不生效。
本功能与重认证时RADIUS服务器的选择模式(通过reauthentication server-select命令配置)同时配置时,重认证时RADIUS服务器的选择模式配置不生效。
# 在RADIUS方案radius1中,开启RADIUS服务器并行认证功能。
[Sysname-radius-radius1] server-parallel-auth enable
· reauthentication server-select
snmp-agent trap enable radius命令用来开启RADIUS告警功能。
undo snmp-agent trap enable radius命令用来关闭指定的RADIUS告警功能。
snmp-agent trap enable radius [ accounting-server-down | accounting-server-up | authentication-error-threshold | authentication-server-down | authentication-server-up ] *
undo snmp-agent trap enable radius [ accounting-server-down | accounting-server-up | authentication-error-threshold | authentication-server-down | authentication-server-up ] *
所有类型的RADIUS告警功能处于关闭状态。
authentication-error-threshold:表示认证失败次数超过阈值时发送告警信息。该阈值为认证失败次数占认证请求总数的百分比数值,目前仅能通过MIB方式配置,取值范围为1~100,缺省为30。
不指定任何参数时,表示开启或关闭所有类型的RADIUS告警功能。
开启RADIUS服务器告警功能后,系统将会生成以下几种告警信息:
· RADIUS服务器不可达的告警:当NAS向RADIUS服务器发送计费或认证请求没有收到响应时,会重传请求,当重传次数达到最大传送次数时仍然没有收到响应时,则发送该告警信息。
· RADIUS服务器可达的告警:当timer quiet定时器设定的时间到达后,NAS将服务器的状态置为激活状态并发送该告警信息。
· 认证失败次数超过阈值的告警:当NAS发现认证失败次数与认证请求总数的百分比超过阈值时,会发送该告警信息。
# 开启RADIUS计费服务器可达状态变为down时的告警功能。
[Sysname] snmp-agent trap enable radius accounting-server-down
state primary命令用来设置主RADIUS服务器的状态。
state primary { accounting | authentication } { active | block }
主RADIUS服务器状态为active。
RADIUS方案视图
accounting:主RADIUS计费服务器。
authentication:主RADIUS认证服务器。
active:正常工作状态。
block:通信中断状态。
当RADIUS服务器负载分担功能处于关闭状态时,每次用户发起认证或计费,如果主服务器状态为active,则设备都会首先尝试与主服务器进行通信,如果主服务器不可达,则将主服务器的状态置为block,同时启动主服务器的timer quiet定时器,然后设备会严格按照从服务器的配置先后顺序依次查找状态为active的从服务器。在timer quiet定时器设定的时间到达之后,主服务器状态将由block恢复为active。若该定时器超时之前,通过本命令将主服务器的状态手工设置为block,则定时器超时之后主服务器状态不会自动恢复为active,除非通过本命令手工将其设置为active。
当RADIUS服务器负载分担功能处于开启状态时,设备仅根据当前各服务器承载的用户负荷调度状态为active的服务器发送认证或计费请求。
如果主服务器与所有从服务器状态都是block,则采用主服务器进行认证或计费。
认证服务器的状态会影响设备对该服务器可达性探测功能的开启。当指定的服务器状态为active,且该服务器通过radius-server test-profile命令成功引用了一个已存在的服务器探测模板时,则设备会开启对该服务器的可达性探测功能。当手工将该服务器状态置为block时,会关闭对该服务器的可达性探测功能。
# 在RADIUS方案radius1中,设置主认证服务器的状态为block。
[Sysname-radius-radius1] state primary authentication block
· state secondary
state secondary命令用来设置从RADIUS服务器的状态。
state secondary { accounting | authentication } [ { host-name | ipv4-address | ipv6 ipv6-address } [ port-number | vpn-instance vpn-instance-name ] * ] { active | block }
从RADIUS服务器状态为active。
RADIUS方案视图
accounting:从RADIUS计费服务器。
authentication:从RADIUS认证服务器。
host-name:从RADIUS服务器的主机名,为1~253个字符的字符串,不区分大小写。
ipv4-address:从RADIUS服务器的IPv4地址。
ipv6 ipv6-address:从RADIUS服务器的IPv6地址。
port-number:从RADIUS服务器的UDP端口号,取值范围为1~65535,从RADIUS计费服务器的缺省UDP端口号为1813,从RADIUS认证服务器的缺省UDP端口号为1812。
vpn-instance vpn-instance-name:从RADIUS服务器所属的VPN实例。vpn-instance-name表示MPLS L3VPN实例名称,为1~31个字符的字符串,区分大小写。
active:正常工作状态。
block:通信中断状态。
如果不指定从服务器IP地址,那么本命令将会修改所有已配置的从认证服务器或从计费服务器的状态。
当RADIUS服务器负载分担功能处于关闭状态时,如果设备查找到的状态为active的从服务器不可达,则设备会将该从服务器的状态置为block,同时启动该服务器的timer quiet定时器,并继续查找下一个状态为active的从服务器。在timer quiet定时器设定的时间到达之后,从服务器状态将由block恢复为active。若该定时器超时之前,通过本命令将从服务器的状态手工设置为block,则定时器超时之后从服务器状态不会自动恢复为active,除非通过本命令手工将其设置为active。如果所有已配置的从服务器都不可达,则本次认证或计费失败。
# 在RADIUS方案radius1中,设置从认证服务器的状态设置为block。
[Sysname-radius-radius1] state secondary authentication block
· state primary
stop-accounting-buffer enable命令用来开启对无响应的RADIUS停止计费请求报文的缓存功能。
undo stop-accounting-buffer enable命令用来关闭对无响应的RADIUS停止计费请求报文的缓存功能。
设备缓存未得到响应的RADIUS停止计费请求报文。
RADIUS方案视图
设备在发送停止计费请求报文而RADIUS服务器没有响应时,会尝试重传该报文,最大尝试次数由retry命令设置。如果设备发送该RADIUS报文的最大尝试次数超过最大值后,仍然没有得到响应,则该功能处于开启状态的情况下设备会缓存该报文,然后再发起一次请求,若仍然未得到响应,则重复上述过程,一定次数(由retry stop-accounting命令设置)之后,设备将其丢弃。
如果RADIUS方案中的某计费服务器被删除,则设备将会丢弃相应的已缓存停止计费请求报文。
# 开启对无响应的RADIUS停止计费请求报文的缓存功能。
[Sysname-radius-radius1] stop-accounting-buffer enable
stop-accounting-packet send-force命令用来配置用户下线时设备强制发送RADIUS计费停止报文。
undo stop-accounting-packet send-force命令用来恢复缺省情况。
用户下线时设备不会强制发送计费停止报文。
RADIUS方案视图
通常,RADIUS服务器在收到用户的计费开始报文后才会生成用户表项,但有一些RADIUS服务器在用户认证成功后会立即生成用户表项。如果设备使用该类RADIUS服务器进行认证/授权/计费,则在用户认证后,因为一些原因(比如授权失败)并未发送计费开始报文,则在该用户下线时设备也不会发送RADIUS计费停止报文,就会导致RADIUS服务器上该用户表项不能被及时释放,形成服务器和设备上用户信息不一致的问题。为了解决这个问题,建议开启本功能。
开启本功能后,只要用户使用RADIUS服务器进行计费,且设备未向RADIUS服务器发送计费开始报文,则在用户下线时设备会强制发送一个RADIUS计费停止报文给服务器,使得服务器收到此报文后及时释放用户表项。
# 在RADIUS方案radius1中,配置用户下线时设备强制发送RADIUS计费停止报文。
[Sysname-radius-radius1] stop-accounting-packet send-force
test-aaa命令用来发起一次AAA请求测试。
test-aaa user user-name password password radius-scheme radius-scheme-name [ radius-server { ipv4-address | ipv6 ipv6-address } port-number [ vpn-instance vpn-instance-name ] ] [ chap | pap ] [ attribute-test-group attr-test-group-name ] [ trace ]
user user-name:待测试的用户名,为1~80个字符的字符串,区分大小写。用户名中可以携带域名,形式为“纯用户名@域名”,其中纯用户名区分大小写,域名不区分大小写。
password password:待测试用户的明文密码,为1~63个字符的字符串,区分大小写。
radius-scheme radius-scheme-name:RADIUS方案名称,为1~32个字符的字符串,不区分大小写。
radius-server:指定具体的RADIUS服务器。
ipv4-address:RADIUS服务器的IPv4地址。
ipv6 ipv6-address:RADIUS服务器的IPv6地址。
port-number:RADIUS服务器的UDP端口号,取值范围为1~65535。
vpn-instance vpn-instance-name:RADIUS服务器所属的VPN实例。vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。如果未指定本参数,则表示待探测RADIUS服务器位于公网中。
chap:采用CHAP认证方式。该方式也是缺省认证方式。
pap:采用PAP认证方式。
attribute-test-group attr-test-group-name:RADIUS属性测试组的名称,为1~31个字符的字符串,不区分大小写。
trace:显示详细的RADIUS报文交互信息。若不指定该参数,则表示仅显示报文收发结果及最终的测试结果。
本命令主要用于排查设备与AAA服务器交互时的故障原因,目前仅支持对RADIUS服务器的测试。当故障发生时,执行本命令发起一次RADIUS请求测试,通过查看打印出的认证/计费请求结果以及报文交互信息,有利于快速定位故障发生的关键环节,以及及时排查影响认证/计费结果的RADIUS属性。
可以在执行本命令时指定RADIUS属性测试组,指定的测试组中定义了RADIUS请求报文中要携带的属性。如果本命令中未指定RADIUS属性测试组或指定的RADIUS属性测试组不存在,则测试过程中发送的RADIUS请求报文中将会携带一些缺省属性,缺省属性的介绍请参见AAA配置手册。
由于测试期间不能保证设备与AAA服务器可以正常通信,因此不建议同时允许用户进行正常的上线、下线操作。
测试过程中,如果引用的RADIUS方案配置发生变化,则仅在下次测试中生效,并不影响本次探测。
仅允许在同一时间内存在一个测试过程,下一次测试只能在当前测试过程完成后执行。
# 发起一次AAA请求测试,使用的测试用户名为user1,密码为123456,RADIUS方案名为test,同时打印详细的RADIUS报文交互信息。
<Sysname> test-aaa user user1 password 123456 radius-scheme test chap trace
Sent a RADIUS authentication request.
Server IP : 192.168.1.110
Source IP : 192.168.1.166
VPN instance : N/A
Server port : 1812
Packet type : Authentication request
Packet length: 118 bytes
Packet ID : 0
Attribute list:
[User-Name(1)] [6] [user1]
[CHAP-Password(3)] [19] [******]
[NAS-IP-Address(4)] [6] [192.168.1.166]
[Service-Type(6)] [6] [2] [Framed]
[Framed-Protocol(7)] [6] [1] [PPP]
[NAS-Identifier(32)] [5] [Sysname]
[Acct-Session-Id(44)] [40] [00000008201707241008280000000c16100171]
[CHAP-Challenge(60)] [18] [******]
[NAS-Port-Type(61)] [6] [15] [Ethernet]
Received a RADIUS authentication response.
VPN instance : N/A
Server port : 1812
Packet type : Access-Reject
Packet length: 20 bytes
Packet ID : 0
Reply-Message: "E63032: Incorrect password. You can retry 9 times."
Sent a RADIUS start-accounting request.
VPN instance : N/A
Server port : 1813
Packet type : Start-accounting request
Packet length: 63 bytes
Packet ID : 1
Attribute list:
[Acct-Status-Type(40)] [6] [1] [Start]
Received a RADIUS start-accounting response.
VPN instance : N/A
Server port : 1813
Packet type : Start-accounting response
Packet ID : 1
Sent a RADIUS stop-accounting request.
VPN instance : N/A
Server port : 1813
Packet type : Stop-accounting request
Packet length: 91 bytes
Packet ID : 1
Attribute list:
[Acct-Status-Type(40)] [6] [2] [Stop]
[Acct-Delay-Time(41)] [6] [0]
[Acct-Terminate-Cause(49)] [6] [1] [User Request]
Received a RADIUS stop-accounting response.
VPN instance : N/A
Server port : 1813
Packet type : Stop-accounting response
Packet ID : 1
Test result: Failed
# 发起一次AAA请求测试,使用的测试用户名为user1,密码为123456 ,RADIUS方案名为test,指定探测test下认证服务器192.168.1.110,且不打印详细的RADIUS报文交互信息。
<Sysname> test-aaa user user1 password 123456 radius-scheme test radius-server 192.168.1.110 1812
Test result: Successful
# 发起一次AAA请求测试,使用的测试用户名为user1,密码为123456 ,RADIUS方案名为rs1,且不打印详细的RADIUS报文交互信息。
< Sysname >test-aaa user user1 password 123456 radius-scheme rs1
Waiting to create a connection with the RADIUS over TLS server.
Failed to create a connection with the RADIUS over TLS server for packet, Server IP: 1.1.2.1, VPN instance: N/A, Server port: 2083, SSL client policy: s1, Packet type : Authentication request.
Failed to create a connection with the RADIUS over TLS server for packet, Server IP: 1.1.2.1, VPN instance: N/A, Server port: 2083, SSL client policy: s1, Packet type : Start-accounting request.
Test result: Successful.
表1-20 test-aaa命令显示信息描述表
Server IP |
服务器的IP地址 |
Source IP |
RADIUS报文源IP地址 |
VPN instance |
RADIUS认证/计费服务器所在的VPN,服务器位于公网时,显示为N/A |
Server port |
SSL client policy |
服务器配置的SSL客户端策略 |
Packet type |
RADIUS报文类型: · Authentication request:认证请求报文 · Access-Accept:认证接受报文 · Access-Reject:认证拒绝报文 · Start-accounting request:开始计费请求报文 · Start-accounting response:开始计费响应报文 · Stop-accounting request:停止计费请求报文 · Stop-accounting response:停止计费响应报文 |
Packet length |
报文总长度,单位为字节 |
Packet ID |
报文ID,用于匹配响应报文和对应的请求报文 |
[attribute-name (code)] [length] [value] [description] |
RADIUS属性信息: · attribute-name:属性名称 · code:属性编号 · length:属性值的长度,单位为字节 · value:属性值 · description:特殊属性值的描述信息 |
Waiting to create a connection with the RADIUS over TLS server. |
等待与RADIUS over TLS服务器建立连接 |
Failed to create a connection with the RADIUS over TLS server for packet, Server IP: server-ip, VPN instance: server-vpn, Server port: server-port, SSL client policy: ssl-client-policy, Packet type : packet-type. |
为报文与RADIUS over TLS服务器连接失败,服务器IP: server-ip, 服务器VPN: server-vpn, 服务器端口: server-port, 服务器SSL客户端策略:ssl-client-policy,报文类型:packet-type. |
Sent a RADIUS authentication request. |
成功发送了一个认证请求报文 |
Failed to receive a RADIUS authentication response. |
认证请求已超时,未收到应答 |
Received a RADIUS authentication response. |
接收到一个认证响应报文 |
Sent a RADIUS start-accounting request. |
成功发送了一个计费开始请求报文 |
Failed to receive a RADIUS start-accounting response. |
计费开始请求已超时,未收到应答 |
Received a RADIUS start-accounting response. |
接收到一个计费开始请求报文 |
Sent a RADIUS stop-accounting request. |
成功发送了一个计费停止请求报文 |
Failed to receive a RADIUS stop-accounting response. |
计费停止请求已超时,未收到应答 |
Received a RADIUS stop-accounting response. |
接收到一个计费停止请求报文 |
Reply-Message: |
RADIUS服务器拒绝此认证请求,并下发提示信息 |
The authentication server is not configured. |
指定的RADIUS方案中未配置要探测的认证服务器 |
The accounting server is not configured. |
指定的RADIUS方案中未配置要探测的计费服务器 |
Test result |
测试结果: · Successful:当前用户的AAA测试成功 · Failed:当前用户的AAA测试失败(只要有一个请求报文测试失败,即为失败) |
· radius attribute-test-group
· radius scheme
timer quiet命令用来设置服务器恢复激活状态的时间。
undo timer quiet命令用来恢复缺省情况。
timer quiet minutes
undo timer quiet
服务器恢复激活状态的时间为5分钟。
RADIUS方案视图
minutes:恢复激活状态的时间,取值范围为0~255,单位为分钟。该参数取值为0时,若当前用户使用的认证或计费服务器不可达,则设备并不会切换它的状态,而是保持其为active,并且将使用该服务器的用户认证或计费请求报文发送给下一个状态为active的服务器,而后续其它用户的认证/计费请求报文仍然可以发送给该服务器进行处理。
建议合理设置服务器恢复激活状态的时间:
· 如果服务器恢复激活状态时间设置的过短,就会出现设备反复尝试与状态active但实际不可达的服务器通信而导致的认证或计费频繁失败的问题。
· 如果服务器恢复激活状态时间设置的过长,当服务器恢复可达后,设备不能及时与其进行通信,会降低对用户进行认证或计费的效率。
# 在RADIUS方案radius1中,配置服务器恢复激活状态的时间为10分钟。
[Sysname-radius-radius1] timer quiet 10
timer realtime-accounting命令用来设置实时计费的时间间隔。
undo timer realtime-accounting命令用来恢复缺省情况。
timer realtime-accounting interval [ second ]
实时计费的时间间隔为12分钟。
RADIUS方案视图
interval:实时计费的时间间隔,取值范围为0~71582。
second:表示实时计费的时间间隔以秒为单位,缺省以分钟为单位。
为了对用户实施实时计费,有必要设置实时计费的时间间隔。不同的取值的处理有所不同:
· 若实时计费间隔不为0,则每隔设定的时间,设备会向RADIUS服务器发送一次在线用户的计费信息。
· 若实时计费间隔设置为0,且服务器上配置了实时计费间隔,则设备按照服务器上配置的实时计费间隔向RADIUS服务器发送在线用户的计费信息;如果服务器上没有配置该值,则设备不向RADIUS服务器发送在线用户的计费信息。
实时计费间隔的取值小,计费准确性高,但对设备和RADIUS服务器的性能要求就高。
用户数 |
实时计费间隔(分钟) |
1~99 |
3 |
100~499 |
6 |
500~999 |
12 |
大于等于1000 |
大于等于15 |
不同情况下修改的实时计费间隔,对于已在线用户的生效情况有所不同:
· 将实时计费间隔从非0有效值改为0,或者从0修改为非0有效值后,已在线用户会依然采用原有取值,修改后的取值对其不生效。
· 将实时计费间隔从某非0有效值修改为其它非0有效值后,已在线用户将会采用修改后的取值。
对于未进行RADIUS认证和授权,仅进行RADIUS计费的用户,只能使用计费方案下设置的实时计费间隔,不会使用RADIUS服务器设置的实时计费间隔。
# 在RADIUS方案radius1中,设置实时计费的时间间隔为51分钟。
[Sysname-radius-radius1] timer realtime-accounting 51
· retry realtime-accounting
timer response-timeout命令用来设置RADIUS服务器响应超时时间。
undo timer response-timeout命令用来恢复缺省情况。
timer response-timeout seconds
RADIUS服务器响应超时时间为3秒。
RADIUS方案视图
seconds:RADIUS服务器响应超时时间,取值范围为1~10,单位为秒。
如果在RADIUS请求报文传送出去一段时间后,设备还没有得到RADIUS服务器的响应,则有必要重传RADIUS请求报文,以保证用户尽可能地获得RADIUS服务,这段时间被称为RADIUS服务器响应超时时间,本命令用于调整这个时间。
# 在RADIUS方案radius1中,设置服务器响应超时时间设置为5秒。
[Sysname-radius-radius1] timer response-timeout 5
· retry
timer tls-idle-timeout命令用来配置RADIUS认证中TLS连接的闲置超时时间。
undo timer tls-idle-timeout命令用来恢复缺省情况。
timer tls-idle-timeout timeout-value
RADIUS认证中TLS连接的闲置超时时间为60秒。
RADIUS方案视图
timeout-value:RADIUS认证中TLS连接的闲置超时时间,取值范围为0~3600,单位为秒。
当设备处理完最后一个认证、计费请求后,会取用最后一个请求所在的RADIUS方案下配置的TLS连接的闲置超时时间,更新闲置超时定时器。在达到闲置超时时间后,若没有认证、计费请求,TLS连接将会自动断开。若TLS连接的闲置超时时间配置为0,则表示TLS连接不会超时断开。
将RADIUS方案下的闲置超时时间,由0配置为非0时,会遍历方案下服务器的连接,将闲置超时定时器更改为最新闲置超时时间。
# 在RADIUS方案radius1中,配置RADIUS认证中TLS连接的闲置超时时间为30秒。
[Sysname-radius-radius1] timer tls-idle-timeout 30
timer tls-idle-timeout命令用来配置RADIUS DAE服务中TLS连接的闲置超时时间。
TLS连接的闲置超时时间为60秒。
RADIUS DAE服务器视图
timeout-value:TLS连接的闲置超时时间,取值范围为0~3600,单位为秒。
当设备发送RADIUS DAE响应报文或接收RADIUS DAE请求报文后,会根据RADIUS DAE服务器视图下配置的TLS连接的闲置超时时间,更新闲置超时定时器。在达到闲置超时时间后,若没有响应报文被发送或接收到请求报文,TLS连接将会自动断开。若TLS连接的闲置超时时间配置为0,则表示TLS连接不会超时断开。
# 配置RADIUS DAE服务的TLS闲置超时时间为30秒。
[Sysname] radius dynamic-author server
tls-port命令用来配置RADIUS DAE服务的TLS连接监听端口号。
undo tls-port命令用来恢复缺省情况。
tls-port port-number
undo tls-port
RADIUS DAE服务的TLS连接监听端口号为2083。
RADIUS DAE服务器视图
port-number:RADIUS DAE服务的TLS连接监听端口号,取值范围为1~65535。
本命令配置RADIUS DAE服务的TLS连接监听端口号,必须与RADIUS DAE客户端发送的请求报文的TLS端口号一致。
# 开启RADIUS DAE服务后,指定DAE服务使用的TLS端口号为3790
[Sysname-radius-da-server] tls-port 3790
user-name-format命令用来设置发送给RADIUS服务器的用户名格式。
undo user-name-format命令用来恢复缺省情况。
user-name-format { keep-original | with-domain | without-domain }
发送给RADIUS服务器的用户名携带ISP域名。
RADIUS方案视图
keep-original:发送给RADIUS服务器的用户名与用户的输入保持一致。
with-domain:发送给RADIUS服务器的用户名携带ISP域名。
without-domain:发送给RADIUS服务器的用户名不携带ISP域名。
接入用户通常以“userid@isp-name”的格式命名,“@”后面的部分为ISP域名,设备就是通过该域名来决定将用户归于哪个ISP域的。但是,有些较早期的RADIUS服务器不能接受携带有ISP域名的用户名,在这种情况下,有必要将用户名中携带的域名去除后再传送给RADIUS服务器。因此,设备提供此命令以指定发送给RADIUS服务器的用户名是否携带有ISP域名。
如果指定某个RADIUS方案不允许用户名中携带有ISP域名,那么请不要在两个或两个以上的ISP域中同时设置使用该RADIUS方案。否则,会出现虽然实际用户不同(在不同的ISP域中),但RADIUS服务器认为用户相同(因为传送到它的用户名相同)的错误。
在802.1X用户采用EAP认证方式的情况下,RADIUS方案中配置的user-name-format命令无效,客户端传送给RADIUS服务器的用户名与用户输入的用户名保持一致。
# 在RADIUS方案radius1中,设置发送给RADIUS服务器的用户名不得携带域名。
[Sysname-radius-radius1] user-name-format without-domain
vpn-instance命令用来配置RADIUS方案所属的VPN。
undo vpn-instance命令用来恢复缺省情况。
undo vpn-instance
RADIUS方案属于公网。
RADIUS方案视图
vpn-instance-name:MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。
本命令配置的VPN对于该方案下的所有RADIUS认证/计费服务器生效,但设备优先使用配置RADIUS认证/计费服务器时为各服务器单独指定的VPN。
# 配置RADIUS方案radius1所属的VPN为test。
[Sysname-radius-radius1] vpn-instance test
data-flow-format命令用来配置发送到HWTACACS服务器的数据流或者数据包的单位。
undo data-flow-format命令用来恢复缺省情况。
data-flow-format { data { byte | giga-byte | kilo-byte | mega-byte } | packet { giga-packet | kilo-packet | mega-packet | one-packet } } *
undo data-flow-format { data | packet }
数据流的单位为byte,数据包的单位为one-packet。
HWTACACS方案视图
data:设置数据流的单位。
· byte:数据流的单位为字节。
· giga-byte:数据流的单位千兆字节。
· kilo-byte:数据流的单位为千字节。
· mega-byte:数据流的单位为兆字节。
packet:设置数据包的单位。
· giga-packet:数据包的单位为千兆包。
· kilo-packet:数据包的单位为千包。
· mega-packet:数据包的单位为兆包。
· one-packet:数据包的单位为包。
设备上配置的发送给HWTACACS服务器的数据流单位及数据包单位应与HWTACACS服务器上的流量统计单位保持一致,否则无法正确计费。
# 在HWTACACS方案hwt1中,设置发往HWTACACS服务器的数据流的数据单位为千字节、数据包的单位为千包。
[Sysname] hwtacacs scheme hwt1
[Sysname-hwtacacs-hwt1] data-flow-format data kilo-byte packet kilo-packet
· display hwtacacs scheme
display hwtacacs scheme命令用来查看HWTACACS方案的配置信息或HWTACACS服务相关的统计信息。
display hwtacacs scheme [ hwtacacs-scheme-name [ statistics ] ]
hwtacacs-scheme-name:HWTACACS方案的名称,为1~32个字符的字符串,不区分大小写。如果不指定该参数,则显示所有HWTACACS方案的配置信息。
statistics:显示HWTACACS服务相关的统计信息。不指定该参数,则显示HWTACACS方案的配置信息。
显示指定HWTACACS方案或者显示所有HWTACACS方案配置信息时,都会同时显示每一个HWTACACS服务器当前Active状态的持续时间以及最近5次状态变化信息。
# 查看所有HWTACACS方案的配置情况。
<Sysname> display hwtacacs scheme
Total 1 HWTACACS schemes
HWTACACS Scheme Name : hwtac
Index : 0
Primary Auth Server:
Host name: Not configured
IP : 2.2.2.2 Port: 49 State: Active
VPN Instance: 2
State: Active (duration: 1 weeks, 2 days, 1 hours, 32 minutes, 34 seconds)
Most recent state changes:
2021/08/15 21:01:23 Changed to active state
2021/08/15 20:56:22 Changed to blocked stat
Single-connection: Enabled
Primary Author Server:
VPN Instance: 2
Single-connection: Disabled
Primary Acct Server:
IP : Not Configured Port: 49 State: Block
VPN Instance: Not configured
State: Blocked
VPN Instance : 2
NAS IP Address : 2.2.2.3
Server Quiet Period(minutes) : 5
Realtime Accounting Interval(minutes) : 12
Stop-accounting packets buffering : Enabled
Retransmission times : 100
Response Timeout Interval(seconds) : 5
Username Format : with-domain
Data flow unit : Byte
Packet unit : one
# 显示HWTACACS方案hwtac的配置情况。
<Sysname> display hwtacacs scheme hwtac
Index : 0
VPN Instance: 2
2019/12/08 21:01:23 Changed to active state
2019/12/08 20:56:22 Changed to blocked state
VPN Instance: 2
State: Blocked
2019/12/08 22:16:52 Changed to blocked state
2019/12/08 22:01:25 Changed to active state
2019/12/08 21:56:22 Changed to blocked state
VPN Instance : 2
Packet unit : one
表1-22 display hwtacacs scheme命令显示信息描述表
Total 1 HWTACACS schemes |
共计1个HWTACACS方案 |
HWTACACS Scheme Name |
HWTACACS方案的名称 |
Index |
HWTACACS方案的索引号 |
Primary Auth Server |
主HWTACACS认证服务器 |
Primary Author Server |
主HWTACACS授权服务器 |
Primary Acct Server |
主HWTACACS计费服务器 |
Secondary Auth Server |
从HWTACACS认证服务器 |
Secondary Author Server |
从HWTACACS授权服务器 |
Secondary Acct Server |
从HWTACACS计费服务器 |
Host name |
HWTACACS服务器的主机名 未配置时,显示为Not configured |
IP |
HWTACACS服务器的IP地址 未配置时,显示为Not configured |
Port |
HWTACACS服务器的端口号 未配置时,显示缺省值 |
State |
HWTACACS服务器目前状态 · Active:激活状态 · Block:静默状态 |
VPN Instance |
HWTACACS服务器或HWTACACS方案所在的VPN 未配置时,显示为Not configured |
State |
HWTACACS服务器目前状态 · Active:激活状态 · Blocked:静默状态 若状态为Active,则同时显示该状态的持续时间 |
duration |
HWTACACS服务器当前Active状态的持续时间 |
Most recent blocked period |
HWTACACS服务器最后一次转换为Block状态的开始时间及结束时间。若最终状态为Block状态,则结束时间用“now”表示 |
Most recent state changes |
HWTACACS服务器最近5次的状态变化信息 |
Single-connection |
单连接状态 · Enabled:使用一条TCP连接与服务器通信 · Disabled:每次新建TCP连接与服务器通信 |
NAS IP Address |
配置的发送HWTACACS报文的源IP地址或源接口 未配置时,显示为Not configured |
Server Quiet Period(minutes) |
主HWTACACS服务器恢复激活状态的时间(分钟) |
Realtime Accounting Interval(minutes) |
实时HWTACACS计费更新报文的发送间隔(分钟) |
Stop-accounting packets buffering |
HWTACACS停止计费请求报文缓存功能的开启情况 |
Retransmission times |
发起HWTACACS停止计费请求的最大尝试次数 |
Response Timeout Interval(seconds) |
HWTACACS服务器超时时间(秒) |
Username Format |
用户名格式 · with-domain:携带域名 · without-domain:不携带域名 · keep-original:与用户输入保持一致 |
Data flow unit |
数据流的单位 |
Packet unit |
数据包的单位 |
# 查看HWTACACS方案tac的统计信息。
<Sysname> display hwtacacs scheme tac statistics
Primary authentication server : 111.8.0.244
Round trip time: 20 seconds
Request packets: 1
Login request packets: 1
Change-password request packets: 0
Request packets including plaintext passwords: 0
Request packets including ciphertext passwords: 0
Response packets: 2
Pass response packets: 1
Failure response packets: 0
Get-data response packets: 0
Get-username response packets: 0
Get-password response packets: 1
Restart response packets: 0
Error response packets: 0
Follow response packets: 0
Malformed response packets: 0
Continue packets: 1
Continue-abort packets: 0
Pending request packets: 0
Connection failure packets: 0
Connection timeout packets: 0
Response timeout packets: 0
Tx failure packets: 0
Unknown type response packets: 0
Dropped response packets: 0
Primary authorization server :111.8.0.244
Round trip time: 1 seconds
Request packets: 1
Response packets: 1
PassAdd response packets: 1
PassReply response packets: 0
Primary accounting server :111.8.0.244
Round trip time: 0 seconds
Request packets: 2
Accounting start request packets: 1
Accounting stop request packets: 1
Accounting update request packets: 0
Response packets: 2
Success response packets: 2
表1-23 display hwtacacs scheme statistics命令显示信息描述表
Primary authentication server |
主HWTACACS认证服务器 |
Primary authorization server |
主HWTACACS授权服务器 |
Primary accounting server |
主HWTACACS计费服务器 |
Secondary authentication server |
从HWTACACS认证服务器 |
Secondary authorization server |
从HWTACACS授权服务器 |
Secondary accounting server |
从HWTACACS计费服务器 |
Round trip time |
设备处理最近一组响应报文和请求报文的时间间隔(单位为秒) |
Request packets |
发送的请求报文个数 |
Login request packets |
发送的登录认证的请求报文个数 |
Change-password request packets |
发送的更改密码的请求报文个数 |
Request packets including plaintext passwords |
发送明文密码的请求报文个数 |
Request packets including ciphertext passwords |
发送密文密码的请求报文个数 |
Response packets |
接收到的响应报文个数 |
Pass response packets |
表示认证通过的响应报文个数 |
Failure response packets |
认证或授权失败的响应报文个数 |
Get-data response packets |
表示获取数据的响应报文个数 |
Get-username response packets |
表示获取用户名的响应报文个数 |
Get-password response packets |
表示获取密码的响应报文个数 |
Restart response packets |
要求重认证的响应报文个数 |
Error response packets |
错误类型的响应报文个数 |
Follow response packets |
Follow类型的响应报文的个数 |
Malformed response packets |
不合法的响应报文个数 |
Continue packets |
发送的Continue报文个数 |
Continue-abort packets |
发送的Continue-abort报文个数 |
Pending request packets |
等待响应的请求报文个数 |
Connection failure packets |
与服务器建立TCP连接失败的次数 |
Connection timeout packets |
与服务器建立TCP连接超时的次数 |
Response timeout packets |
超时的请求报文数 |
Tx failure packets |
发送失败的报文数 |
Unknown type response packets |
未知报文类型的响应报文个数 |
Dropped response packets |
被丢弃响应报文个数 |
PassAdd response packets |
接收到的PassAdd类型的响应报文个数。此报文表示同意授权所有请求的属性,并添加其他授权属性 |
PassReply response packets |
接收到的PassReply类型的响应报文个数。此报文表示采用响应报文中指定的授权属性替换请求的授权属性 |
Accounting start request packets |
发送的计费开始请求报文个数 |
Accounting stop request packets |
发送的计费结束请求报文个数 |
Accounting update request packets |
发送的计费更新请求报文个数 |
Success response packets |
接收到的计费成功的响应报文个数 |
· reset hwtacacs statistics
display hwtacacs statistics命令用来显示HWTACACS报文的统计信息。
# 显示HWTACACS报文的统计信息。
<Sysname> display hwtacacs statistics
Auth. Author. Acct.
Request Packet: 0 0 0
Response Packet: 0 0 0
Login Request: 0 - -
ChangePass Request: 0 - -
Account Start: - - 0
Account Update: - - 0
Account Stop: - - 0
Pass Response: 0 0 -
Failure Response: 0 0 -
Account Success: - - 0
Connection Failure: 0 0 0
Connection Timeout: 0 0 0
Response Timeout: 0 0 0
Send Failure: 0 0 0
Unknown Type: 0 0 0
Dropped Packet: 0 0 0
表1-24 display hwtacacs statistics命令显示信息描述表
Auth. |
认证报文 |
Author. |
授权报文 |
Acct. |
计费报文 |
Request Packet |
发送的请求报文个数 |
Response Packet |
接收到的响应报文个数 |
Login Request |
发送的登录认证请求报文个数 |
ChangePass Request |
发送的更改密码请求报文个数 |
Account Start |
发送的计费开始请求报文个数 |
Account Update |
发送的计费更新请求报文个数 |
Account Stop |
发送的计费结束请求报文个数 |
Pass Response |
表示认证或授权通过的响应报文个数 |
Failure Response |
认证或授权失败的响应报文个数 |
Account Success |
接收到的计费成功响应报文个数 |
Connection Failure |
与服务器建立TCP连接失败的次数 |
Connection Timeout |
与服务器建立TCP连接超时的次数 |
Response Timeout |
请求超时的次数 |
Send Failure |
报文发送失败的次数 |
Unknown Type |
未知报文类型的响应报文个数 |
Dropped Packet |
被丢弃的响应报文个数 |
display stop-accounting-buffer命令用来显示缓存的HWTACACS停止计费请求报文的相关信息。
display stop-accounting-buffer hwtacacs-scheme hwtacacs-scheme-name
hwtacacs-scheme hwtacacs-scheme-name:表示HWTACACS方案名,为1~32个字符的字符串,不区分大小写。
# 显示HWTACACS方案hwt1缓存的HWTACACS停止计费请求报文。
<Sysname> display stop-accounting-buffer hwtacacs-scheme hwt1
Total entries: 2
Scheme IP address Username First sending time Attempts
hwt1 192.168.100.1 abc 23:27:16-08/31/2015 19
hwt1 192.168.90.6 bob 23:33:01-08/31/2015 20
表1-25 display stop-accounting-buffer命令显示信息描述表
Total entries: 2 |
共有两条记录匹配 |
Scheme |
HWTACACS方案名 |
IP address |
用户IP地址 |
Username |
用户名 |
First sending time |
首次发送停止计费请求的时间 |
Attempts |
发送停止计费请求报文的次数 |
· retry stop-accounting (HWTACACS scheme view)
· reset stop-accounting-buffer (for HWTACACS)
· stop-accounting-buffer enable (HWTACACS scheme view)
· user-name-format (HWTACACS scheme view)
hwtacacs dscp命令用来配置HWTACACS协议报文的DSCP优先级。
undo hwtacacs dscp命令用来恢复缺省情况。
hwtacacs [ ipv6 ] dscp dscp-value
undo hwtacacs [ ipv6 ] dscp
HWTACACS报文的DSCP优先级为0。
ipv6:表示设置IPv6 HWTACACS报文。若不指定该参数,则表示设置IPv4 HWTACACS报文。
dscp-value:HWTACACS报文的DSCP优先级,取值范围为0~63。取值越大,优先级越高。
DSCP携带在IPv4报文中的ToS字段以及IPv6报文中的Traffic Class字段中,用来体现报文自身的优先等级,决定报文传输的优先程度。通过本命令可以指定设备发送的HWTACACS报文携带的DSCP优先级的取值。
# 配置IPv4 HWTACACS报文的DSCP优先级为10。
[Sysname] hwtacacs dscp 10
hwtacacs nas-ip命令用来设置设备发送HWTACACS报文使用的源IP地址。
undo hwtacacs nas-ip命令用来删除指定的发送HWTACACS报文使用的源IP地址。
hwtacacs nas-ip { interface interface-type interface-number | { ipv4-address | ipv6 ipv6-address } [ vpn-instance vpn-instance-name ] }
undo hwtacacs nas-ip { interface | { ipv4-address | ipv6 ipv6-address } [ vpn-instance vpn-instance-name ] }
未指定发送HWTACACS报文使用的源IP地址,设备将使用到达HWTACACS服务器的路由出接口的主IPv4地址或IPv6地址作为发送HWTACACS报文的源IP地址。
interface interface-type interface-number:指定源接口,即发送HWTACACS报文的源IPv4地址为该接口的主IPv4地址,发送HWTACACS报文的源IPv6地址为该接口上配置的IPv6地址。interface-type interface-number为接口类型和接口编号。
HWTACACS服务器上通过IP地址来标识接入设备,并根据收到的HWTACACS报文的源IP地址是否与服务器所管理的接入设备的IP地址匹配,来决定是否处理来自该接入设备的认证或计费请求。因此,为保证HWTACACS报文可被服务器正常接收并处理,接入设备上发送HWTACACS报文使用的源地址必须与HWTACACS服务器上指定的接入设备的IP地址保持一致。
为避免物理接口故障时从服务器返回的报文不可达,推荐使用Loopback接口地址为发送HWTACACS报文使用的源IP地址。
HWTACACS方案视图和系统视图下均可以配置发送HWTACACS报文使用的源IP地址,具体生效情况如下:
· HWTACACS方案视图下配置的源IP地址(通过nas-ip命令)只对本方案有效。
· 系统视图下的配置的源IP地址(通过hwtacacs nas-ip命令)对所有HWTACACS方案有效。
· HWTACACS方案视图下的设置具有更高的优先级。
系统视图下,最多允许指定一个源接口,请确保指定的源接口与HWTACACS服务器路由可达。
# 设置设备发送HWTACACS报文使用的源IP地址为129.10.10.1。
[Sysname] hwtacacs nas-ip 129.10.10.1
· nas-ip (HWTACACS scheme view)
hwtacacs scheme命令用来创建HWTACACS方案,并进入HWTACACS方案视图。如果指定的HWTACACS方案已经存在,则直接进入HWTACACS方案视图。
undo hwtacacs scheme命令用来删除指定的HWTACACS方案。
hwtacacs scheme hwtacacs-scheme-name
undo hwtacacs scheme hwtacacs-scheme-name
不存在HWTACACS方案。
hwtacacs-scheme-name:HWTACACS方案名称,为1~32个字符的字符串,不区分大小写。
一个HWTACACS方案可以同时被多个ISP域引用。
最多可以配置16个HWTACACS方案。
# 创建名称为hwt1的HWTACACS方案并进入相应的HWTACACS视图。
key命令用来配置HWTACACS认证、授权、计费报文的共享密钥。
undo key命令用来删除指定的HWTACACS报文的共享密钥。
key { accounting | authentication | authorization } { cipher | simple } string
undo key { accounting | authentication | authorization }
未配置HWTACACS报文的共享密钥。
HWTACACS方案视图
accounting:指定HWTACACS计费报文的共享密钥。
authentication:指定HWTACACS认证报文的共享密钥。
authorization:指定HWTACACS授权报文的共享密钥。
cipher:以密文方式设置密钥。
simple:以明文方式设置密钥,该密钥将以密文形式存储。
string:密钥字符串,区分大小写。非FIPS模式下,明文密钥为1~255个字符的字符串;密文密钥为1~373个字符的字符串。FIPS模式下,明文密钥为15~255个字符的字符串,密钥元素的最少组合类型为4(必须包括数字、大写字母、小写字母以及特殊字符);密文密钥为15~373个字符的字符串。
必须保证设备上设置的共享密钥与HWTACACS服务器上的完全一致。
# 在HWTACACS方案hwt1中,配置HWTACACS认证报文共享密钥为明文123456TESTauth&!。
[Sysname-hwtacacs-hwt1] key authentication simple 123456TESTauth&!
# 配置HWTACACS授权报文共享密钥为明文123456TESTautr&!。
[Sysname-hwtacacs-hwt1] key authorization simple 123456TESTautr&!
# 配置HWTACACS计费报文共享密钥为明文123456TESTacct&!。
[Sysname-hwtacacs-hwt1] key accounting simple 123456TESTacct&!
undo nas-ip命令用来删除指定类型的发送HWTACACS报文使用的源IP地址。
nas-ip { ipv4-address | interface interface-type interface-number | ipv6 ipv6-address }
undo nas-ip [ interface | ipv6 ]
未指定设备发送HWTACACS报文使用的源IP地址,使用系统视图下由命令hwtacacs nas-ip指定的源IP地址。
HWTACACS方案视图
HWTACACS服务器上通过IP地址来标识接入设备,并根据收到的HWTACACS报文的源IP地址是否与服务器所管理的接入设备的IP地址匹配,来决定是否处理来自该接入设备的认证、授权、计费请求。因此,为保证HWTACACS报文可被服务器正常接收并处理,接入设备上发送HWTACACS报文使用的源地址必须与HWTACACS服务器上指定的接入设备的IP地址保持一致。
一个HWTACACS方案视图下:
· 最多允许指定一个源接口,请确保指定的源接口与HWTACACS服务器路由可达。
如果undo nas-ip命令中不指定任何关键字,则表示删除发送HWTACACS报文使用的源IPv4地址。
# 在HWTACACS方案hwt1中,设置设备发送HWTACACS报文使用的源IP地址为10.1.1.1。
[Sysname-hwtacacs-hwt1] nas-ip 10.1.1.1
· hwtacacs nas-ip
primary accounting命令用来配置主HWTACACS计费服务器。
primary accounting { host-name | ipv4-address | ipv6 ipv6-address } [ port-number | key { cipher | simple } string | single-connection | vpn-instance vpn-instance-name ] *
未配置HWTACACS主计费服务器。
HWTACACS方案视图
host-name:主HWTACACS计费服务器的主机名,为1~253个字符的字符串,不区分大小写。
ipv4-address:主HWTACACS计费服务器的IPv4地址。
ipv6 ipv6-address:主HWTACACS计费服务器的IPv6地址。
port-number:主HWTACACS计费服务器的TCP端口号,取值范围为1~65535,缺省值为49。
key:与主HWTACACS计费服务器交互的计费报文的共享密钥。
cipher:以密文方式设置密钥。
single-connection:所有与主HWTACACS计费服务器交互的计费报文使用同一个TCP连接。如果未指定本参数,则表示每次计费都会使用一个新的TCP连接。
vpn-instance vpn-instance-name:主HWTACACS计费服务器所属的VPN实例。vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。如果未指定本参数,则表示主HWTACACS计费服务器位于公网中。
配置的主计费服务器的TCP端口号以及计费报文的共享密钥必须与服务器的配置保持一致。
若服务器位于MPLS VPN私网中,为保证HWTACACS报文被发送到指定的私网服务器,必须指定服务器所属的VPN实例。本命令指定的服务器所属的VPN比HWTACACS方案所属的VPN优先级高。
只有在设备与计费服务器没有报文交互时,才允许删除该服务器。计费服务器删除后,只对之后的计费过程有影响。
配置single-connection参数后可节省TCP连接资源,但有些HWTACACS服务器不支持这种方式,需要根据服务器支持情况进行配置。在服务器支持这种方式的情况下,建议配置single-connection参数,以提高性能和效率。
# 在HWTACACS方案hwt1中,配置主HWTACACS计费服务器的IP地址为10.163.155.12,使用TCP端口49与HWTACACS计费服务器通信,计费报文的共享密钥为明文123456TESTacct&!。
[Sysname] hwtacacs scheme hw1
[Sysname-hwtacacs-hw1] primary accounting 10.163.155.12 49 key simple 123456TESTacct&!
· key (HWTACACS scheme view)
· vpn-instance (HWTACACS scheme view)
primary authentication命令用来配置主HWTACACS认证服务器。
primary authentication { host-name | ipv4-address | ipv6 ipv6-address } [ port-number | key { cipher | simple } string | single-connection | vpn-instance vpn-instance-name ] *
未配置主HWTACACS认证服务器。
HWTACACS方案视图
host-name:主HWTACACS认证服务器的主机名,为1~253个字符的字符串,不区分大小写。
ipv4-address:主HWTACACS认证服务器的IPv4地址。
ipv6 ipv6-address:主HWTACACS认证服务器的IPv6地址。
port-number:主HWTACACS认证服务器的TCP端口号,取值范围为1~65535,缺省值为49。
key:与主HWTACACS认证服务器交互的认证报文的共享密钥。
cipher:以密文方式设置密钥。
single-connection:所有与主HWTACACS认证服务器交互的认证报文使用同一个TCP连接。如果未指定本参数,则表示每次认证都会使用一个新的TCP连接。
vpn-instance vpn-instance-name:主HWTACACS认证服务器所属的VPN实例。vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。如果未指定本参数,则表示主HWTACACS认证服务器位于公网中。
配置的主认证服务器的TCP端口号以及认证报文的共享密钥必须与服务器的配置保持一致。
只有在设备与认证服务器没有报文交互时,才允许删除该服务器。认证服务器删除后,只对之后的认证过程有影响。
# 在HWTACACS方案hwt1中,配置主HWTACACS认证服务器的IP地址为10.163.155.13,使用TCP端口49与HWTACACS认证服务器通信,认证报文的共享密钥为明文123456TESTauth&!。
[Sysname-hwtacacs-hwt1] primary authentication 10.163.155.13 49 key simple 123456TESTauth&!
primary authorization命令用来配置主HWTACACS授权服务器。
undo primary authorization命令用来恢复缺省情况。
primary authorization { host-name | ipv4-address | ipv6 ipv6-address } [ port-number | key { cipher | simple } string | single-connection | vpn-instance vpn-instance-name ] *
未配置主HWTACACS授权服务器。
HWTACACS方案视图
host-name:主HWTACACS授权服务器的主机名,为1~253个字符的字符串,不区分大小写。
ipv4-address:主HWTACACS授权服务器的IPv4地址。
ipv6 ipv6-address:主HWTACACS授权服务器的IPv6地址。
port-number:主HWTACACS授权服务器的TCP端口号,取值范围为1~65535,缺省值为49。
key:与主HWTACACS授权服务器交互的授权报文的共享密钥。
cipher:以密文方式设置密钥。
single-connection:所有与主HWTACACS授权服务器交互的授权报文使用同一个TCP连接。如果未指定本参数,则表示每次授权都会使用一个新的TCP连接。
vpn-instance vpn-instance-name:主HWTACACS授权服务器所属的VPN实例。vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。如果未指定本参数,则表示主HWTACACS授权服务器位于公网中。
配置的主授权服务器的TCP端口号以及授权报文的共享密钥必须与服务器的配置保持一致。
在同一个方案中指定的主授权服务器和从授权服务器的VPN、主机名、IP地址、端口号不能完全相同。
只有在设备与授权服务器没有报文交互时,才允许删除该服务器。授权服务器删除后,只对之后的授权过程有影响。
# 在HWTACACS方案hwt1中,配置主HWTACACS授权服务器的IP地址为10.163.155.13,使用TCP端口49与HWTACACS授权服务器通信,授权报文的共享密钥为明文123456TESTautr&!。
[Sysname-hwtacacs-hwt1] primary authorization 10.163.155.13 49 key simple 123456TESTautr&!
· secondary authorization
reset hwtacacs statistics命令用来清除HWTACACS协议的统计信息。
reset hwtacacs statistics { accounting | all | authentication | authorization }
accounting:清除HWTACACS协议关于计费的统计信息。
all:清除HWTACACS的所有统计信息。
authentication:清除HWTACACS协议关于认证的统计信息。
authorization:清除HWTACACS协议关于授权的统计信息。
# 清除HWTACACS协议的所有统计信息。
<Sysname> reset hwtacacs statistics all
reset stop-accounting-buffer命令用来清除缓存的HWTACACS停止计费请求报文。
reset stop-accounting-buffer hwtacacs-scheme hwtacacs-scheme-name
hwtacacs-scheme hwtacacs-scheme-name:表示指定HWTACACS方案的停止计费请求报文。其中,hwtacacs-scheme-name为HWTACACS方案名,为1~32个字符的字符串,不区分大小写。
# 清除缓存的HWTACACS方案hwt1的HWTACACS停止计费请求报文。
<Sysname> reset stop-accounting-buffer hwtacacs-scheme hwt1
· display stop-accounting-buffer (for HWTACACS)
retry stop-accounting命令用来设置发起HWTACACS停止计费请求的最大尝试次数。
发起HWTACACS停止计费请求的最大尝试次数为100。
HWTACACS方案视图
retries:允许停止计费请求无响应的最大次数,取值范围为1~300。
设备发送HWTACACS停止计费请求报文无响应后,将会缓存该报文并尝试重复发送该报文,当发送的停止计费请求总数达到指定的最大尝试次数之后仍未得到响应时,将其丢弃。
# 在HWTACACS方案hwt1中,设置发起HWTACACS停止计费请求的最大尝试次数为300。
[Sysname-hwtacacs-hwt1] retry stop-accounting 300
· timer response-timeout (HWTACACS scheme view)
secondary accounting命令用来配置从HWTACACS计费服务器。
undo secondary accounting命令用来删除指定的从HWTACACS计费服务器。
secondary accounting { host-name | ipv4-address | ipv6 ipv6-address } [ port-number | key { cipher | simple } string | single-connection | vpn-instance vpn-instance-name ] *
undo secondary accounting [ { host-name | ipv4-address | ipv6 ipv6-address } [ port-number | vpn-instance vpn-instance-name ] * ]
未配置从HWTACACS计费服务器。
HWTACACS方案视图
host-name:从HWTACACS计费服务器的主机名,为1~253个字符的字符串,不区分大小写。
ipv4-address:从HWTACACS计费服务器的IPv4地址。
ipv6 ipv6-address:从HWTACACS计费服务器的IPv6地址。
port-number:从HWTACACS计费服务器的端口号,取值范围为1~65535,缺省值为49。
key:与从HWTACACS计费服务器交互的计费报文的共享密钥。
cipher:以密文方式设置密钥。
single-connection:所有与从HWTACACS计费服务器交互的计费报文使用同一个TCP连接。如果未指定本参数,则表示每次计费都会使用一个新的TCP连接。
vpn-instance vpn-instance-name:从HWTACACS计费服务器所属的VPN实例。vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。如果未指定本参数,则表示从HWTACACS计费服务器位于公网中。
配置的从计费服务器的TCP端口号以及计费报文的共享密钥必须与服务器的配置保持一致。
每个HWTACACS方案中最多支持配置16个从HWTACACS计费服务器。当主服务器不可达时,设备根据从服务器的配置顺序由先到后查找状态为active的从服务器并与之交互。
如果不指定任何参数,则undo命令将删除所有从计费服务器。
配置single-connection参数后可节省TCP连接资源,但有些TACACS服务器不支持这种方式,需要根据服务器支持情况进行配置。在服务器支持这种方式的情况下,建议配置single-connection参数,以提高性能和效率。
# 在HWTACACS方案hwt1中,配置从HWTACACS计费服务器的IP地址为10.163.155.12,使用TCP端口49与HWTACACS计费服务器通信,计费报文的共享密钥为明文123456TESTacct&!。
[Sysname-hwtacacs-hwt1] secondary accounting 10.163.155.12 49 key simple 123456TESTacct&!
· primary accounting (HWTACACS scheme view)
secondary authentication命令用来配置从HWTACACS认证服务器。
undo secondary authentication命令用来删除指定的从HWTACACS认证服务器。
secondary authentication { host-name | ipv4-address | ipv6 ipv6-address } [ port-number | key { cipher | simple } string | single-connection | vpn-instance vpn-instance-name ] *
undo secondary authentication [ { host-name | ipv4-address | ipv6 ipv6-address } [ port-number | vpn-instance vpn-instance-name ] * ]
未配置从HWTACACS认证服务器。
HWTACACS方案视图
host-name:从HWTACACS认证服务器的主机名,为1~253个字符的字符串,不区分大小写。
ipv4-address:从HWTACACS认证服务器的IPv4地址。
ipv6 ipv6-address:从HWTACACS认证服务器的IPv6地址。
port-number:从HWTACACS认证服务器的TCP端口号,取值范围为1~65535,缺省值为49。
key:与从HWTACACS认证服务器交互的认证报文的共享密钥。
cipher:以密文方式设置密钥。
single-connection:所有与从HWTACACS认证服务器交互的认证报文使用同一个TCP连接。如果未指定本参数,则表示每次认证都会使用一个新的TCP连接。
vpn-instance vpn-instance-name:从HWTACACS认证服务器所属的VPN实例。vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。如果未指定本参数,则表示从HWTACACS服务器位于公网中。
配置的从认证服务器的TCP端口号以及认证报文的共享密钥必须与服务器的配置保持一致。
每个HWTACACS方案中最多支持配置16个从HWTACACS认证服务器。当主服务器不可达时,设备根据从服务器的配置顺序由先到后查找状态为active的从服务器并与之交互。
如果不指定任何参数,则undo命令将删除所有从认证服务器。
# 在HWTACACS方案hwt1中,配置从HWTACACS认证服务器的IP地址为10.163.155.13,使用TCP端口49与HWTACACS认证服务器通信,认证报文的共享密钥为明文123456TESTauth&!。
[Sysname-hwtacacs-hwt1] secondary authentication 10.163.155.13 49 key simple 123456TESTauth&!
· primary authentication (HWTACACS scheme view)
secondary authorization命令用来配置从HWTACACS授权服务器。
undo secondary authorization命令用来删除指定的从HWTACACS授权服务器。
secondary authorization { host-name | ipv4-address | ipv6 ipv6-address } [ port-number | key { cipher | simple } string | single-connection | vpn-instance vpn-instance-name ] *
undo secondary authorization [ { host-name | ipv4-address | ipv6 ipv6-address } [ port-number | vpn-instance vpn-instance-name ] * ]
未配置从HWTACACS授权服务器。
HWTACACS方案视图
host-name:从HWTACACS授权服务器的主机名,为1~253个字符的字符串,不区分大小写。
ipv4-address:从HWTACACS授权服务器的IPv4地址。
ipv6 ipv6-address:从HWTACACS授权服务器的IPv6地址。
port-number:从HWTACACS授权服务器的TCP端口号,取值范围为1~65535,缺省值为49。
key:与从HWTACACS授权服务器交互的授权报文的共享密钥。
cipher:以密文方式设置密钥。
single-connection:所有与从HWTACACS授权服务器交互的授权报文使用同一个TCP连接。如果未指定本参数,则表示每次授权都会使用一个新的TCP连接。
vpn-instance vpn-instance-name:从HWTACACS授权服务器所属的VPN实例。vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。如果未指定本参数,则表示从HWTACACS授权服务器位于公网中。
配置的从授权服务器的TCP端口号以及授权报文的共享密钥必须与服务器的配置保持一致。
每个HWTACACS方案中最多支持配置16个从HWTACACS授权服务器。当主服务器不可达时,设备根据从服务器的配置顺序由先到后查找状态为active的从服务器并与之交互。
如果不指定任何参数,则undo命令将删除所有从授权服务器。
在同一个方案中指定的主授权服务器和从授权服务器的VPN参数、主机名、IP地址、端口号不能完全相同,并且各从授权服务器的VPN、主机名、IP地址、端口号也不能完全相同。
# 在HWTACACS方案hwt1中,配置从HWTACACS授权服务器的IP地址为10.163.155.13,使用TCP端口49与HWTACACS授权服务器通信,授权报文的共享密钥为明文123456TESTautr&!。
[Sysname-hwtacacs-hwt1] secondary authorization 10.163.155.13 49 key simple 123456TESTautr&!
· primary authorization (HWTACACS scheme view)
snmp-agent trap enable hwtacacs命令用来开启HWTACACS告警功能。
undo snmp-agent trap enable hwtacacs命令用来关闭指定的HWTACACS告警功能。
snmp-agent trap enable hwtacacs [ accounting-server-down | accounting-server-up | authentication-server-down | authentication-server-up | authorization-server-down | authorization-server-up ] *
undo snmp-agent trap enable hwtacacs [ accounting-server-down | accounting-server-up | authentication-server-down | authentication-server-up | authorization-server-down | authorization-server-up ] *
所有类型的HWTACACS告警功能处于关闭状态。
accounting-server-down:表示HWTACACS计费服务器可达状态变为down时发送告警信息。
accounting-server-up:表示HWTACACS计费服务器可达状态变为up时发送告警信息。
authentication-server-down:表示HWTACACS认证服务器可达状态变为down时发送告警信息。
authentication-server-up:表示HWTACACS认证服务器可达状态变为up时发送告警信息。
authorization-server-down:表示HWTACACS授权服务器可达状态变为down时发送告警信息。
authorization-server-up:表示HWTACACS授权服务器可达状态变为up时发送告警信息。
不指定任何参数时,表示开启或关闭所有类型的HWTACACS告警功能。
开启HWTACACS服务器告警功能后,系统将会生成以下几种告警信息:
· HWTACACS服务器不可达的告警:当NAS向TACACS服务器发送计费、认证或授权请求没有收到响应时,会重传请求,当重传次数达到最大传送次数时仍然没有收到响应时,则发送该告警信息。
· HWTACACS服务器可达的告警:当timer quiet定时器设定的时间到达后,NAS将服务器的状态置为激活状态并发送该告警信息。
# 开启HWTACACS计费服务器可达状态变为down时的告警功能。
[Sysname] snmp-agent trap enable hwtacacs accounting-server-down
stop-accounting-buffer enable命令用来开启对无响应的HWTACACS停止计费请求报文的缓存功能。
undo stop-accounting-buffer enable命令用来关闭对无响应的HWTACACS停止计费请求报文的缓存功能。
设备缓存未得到响应的HWTACACS停止计费请求报文。
HWTACACS方案视图
开启对无响应的HWTACACS停止计费请求报文的缓存功能后,设备在发送停止计费请求报文而HWTACACS服务器没有响应时,会将其缓存在本机上,然后发送直到HWTACACS计费服务器产生响应,或者在发送的次数达到指定的次数限制(由retry stop-accounting命令设置)后将其丢弃。
如果HWTACACS方案中的某计费服务器被删除,则设备将会丢弃相应的已缓存停止计费报文。
# 开启对无响应的HWTACACS停止计费请求报文的缓存功能。
[Sysname-hwtacacs-hwt1] stop-accounting-buffer enable
timer quiet minutes
undo timer quiet
服务器恢复激活状态的时间为5分钟。
HWTACACS方案视图
minutes:恢复激活状态的时间,取值范围为1~255,单位为分钟。
# 设置服务器恢复激活状态的时间为10分钟。
[Sysname-hwtacacs-hwt1] timer quiet 10
timer realtime-accounting minutes
实时计费的时间间隔为12分钟。
HWTACACS方案视图
minutes:实时计费的时间间隔,取值范围为0~60,单位为分钟。0表示设备不向HWTACACS服务器发送在线用户的计费信息。
为了对用户实施实时计费,有必要设置实时计费的时间间隔。在设置了该属性以后,每隔设定的时间,设备会向HWTACACS服务器发送一次在线用户的计费信息。
实时计费间隔的取值小,计费准确性高,但对设备和HWTACACS服务器的性能要求就高。
用户数 |
实时计费间隔(分钟) |
1~99 |
3 |
100~499 |
6 |
500~999 |
12 |
大于等于1000 |
大于等于15 |
# 在HWTACACS方案hwt1中,设置实时计费的时间间隔为51分钟。
[Sysname-hwtacacs-hwt1] timer realtime-accounting 51
timer response-timeout命令用来设置HWTACACS服务器响应超时时间。
HWTACACS服务器响应超时时间为5秒。
HWTACACS方案视图
seconds:HWTACACS服务器响应超时时间,取值范围为1~300,单位为秒。
由于HWTACACS是基于TCP实现的,因此,服务器响应超时或TCP超时都可能导致与HWTACACS服务器的连接断开。
HWTACACS服务器响应超时时间与配置的HWTACACS服务器总数的乘积不能超过接入模块定义的用户认证超时时间,否则在HWTACACS认证过程完成之前用户就有可能被强制下线。
# 在HWTACACS方案hwt1中,设置HWTACACS服务器响应超时时间为30秒。
[Sysname-hwtacacs-hwt1] timer response-timeout 30
user-name-format命令用来设置发送给HWTACACS服务器的用户名格式。
发送给HWTACACS服务器的用户名携带ISP域名。
HWTACACS方案视图
keep-original:发送给HWTACACS服务器的用户名与用户输入的保持一致。
with-domain:发送给HWTACACS服务器的用户名携带ISP域名。
without-domain:发送给HWTACACS服务器的用户名不携带ISP域名。
接入用户通常以“userid@isp-name”的格式命名,“@”后面的部分为ISP域名,设备就是通过该域名来决定将用户归于哪个ISP域的。但是,有些HWTACACS服务器不能接受携带有ISP域名的用户名,在这种情况下,有必要将用户名中携带的域名去除后再传送给HWTACACS服务器。因此,设备提供此命令以指定发送给HWTACACS服务器的用户名是否携带有ISP域名。
如果指定某个HWTACACS方案不允许用户名中携带有ISP域名,那么请不要在两个乃至两个以上的ISP域中同时设置使用该HWTACACS方案。否则,会出现虽然实际用户不同(在不同的ISP域中),但HWTACACS服务器认为用户相同(因为传送到它的用户名相同)的错误。
# 在HWTACACS方案hwt1中,设置发送给HWTACACS服务器的用户名不携带ISP域名。
[Sysname-hwtacacs-hwt1] user-name-format without-domain
vpn-instance命令用来配置HWTACACS方案所属的VPN。
undo vpn-instance
HWTACACS方案属于公网。
HWTACACS方案视图
本命令配置的VPN对于该方案下的所有HWTACACS认证/授权/计费服务器生效,但设备优先使用配置认证/授权/计费服务器时指定的各服务器所属的VPN。
# 配置HWTACACS方案hw1所属的VPN为test。
[Sysname-hwtacacs-hwt1] vpn-instance test
attribute-map命令用来在LDAP方案中引用LDAP属性映射表。
undo attribute-map命令用来恢复缺省情况。
attribute-map map-name
undo attribute-map
未引用任何LDAP属性映射表。
LDAP方案视图
map-name:LDAP属性映射表的名称,为1~31个字符的字符串,不区分大小写。
在使用LDAP授权方案的情况下,可以通过在LDAP方案中引用LDAP属性映射表,将LDAP授权服务器下发给用户的LDAP属性映射为AAA模块可以解析的某类属性。
一个LDAP方案视图中只能引用一个LDAP属性映射表,后配置的生效。
如果在LDAP授权过程中修改了引用的LDAP属性映射表,或者修改了引用的LDAP属性映射表的内容,则该修改对当前的授权过程不会生效,只对修改后新的LDAP授权过程生效。
# 在LDAP方案ldap1中,引用名称为map1的LDAP属性映射表。
[Sysname] ldap scheme ldap1
[Sysname-ldap-ldap1] attribute-map map1
· display ldap scheme
· ldap attribute-map
authentication-server命令用来指定LDAP认证服务器。
undo authentication-server命令用来恢复缺省情况。
authentication-server server-name
未指定LDAP认证服务器。
LDAP方案视图
server-name:LDAP服务器的名称,为1~64个字符的字符串,不区分大小写。
一个LDAP方案视图下仅能指定一个LDAP认证服务器,多次执行本命令,最后一次执行的命令生效。
# 在LDAP方案ldap1中,指定LDAP认证服务器为ccc。
[Sysname-ldap-ldap1] authentication-server ccc
· ldap server
authorization-server命令用来指定LDAP授权服务器。
undo authorization-server命令用来恢复缺省情况。
authorization-server server-name
未指定LDAP授权服务器。
LDAP方案视图
一个LDAP方案视图下仅能指定一个LDAP授权服务器,多次执行本命令,最后一次执行的命令生效。
# 在LDAP方案ldap1中,指定LDAP授权服务器为ccc。
[Sysname-ldap-ldap1] authorization-server ccc
· ldap server
display ldap scheme命令用来查看LDAP方案的配置信息。
display ldap scheme [ ldap-scheme-name ]
ldap-scheme-name:LDAP方案的名称,为1~32个字符的字符串,不区分大小写。如果不指定该参数,则显示所有LDAP方案的配置信息。
# 查看所有LDAP方案的配置信息。
<Sysname> display ldap scheme
Total 1 LDAP schemes
LDAP scheme name : aaa
Authentication server : aaa
IP : 1.1.1.1
Port : 111
VPN instance : Not configured
LDAP protocol version : LDAPv3
Server timeout interval : 10 seconds
Login account DN : Not configured
Base DN : Not configured
Search scope : all-level
User searching parameters:
User object class : Not configured
Username attribute : cn
Username format : with-domain
Authorization server : aaa
IP : 1.1.1.1
Port : 111
Attribute map : map1
表1-27 display ldap scheme命令显示信息描述表
Total 1 LDAP schemes |
总共有1个LDAP方案 |
LDAP Scheme Name |
LDAP方案名称 |
Authentication Server |
LDAP认证服务器名称 未配置时,显示为Not configured |
Authorization server |
LDAP授权服务器名称 未配置时,显示为Not configured |
IP |
LDAP认证服务器的IP地址 未配置认证服务器IP时,IP地址显示为Not configured |
Port |
LDAP认证服务器的端口号 未配置认证服务器IP时,端口号显示为缺省值 |
VPN Instance |
VPN实例名称 未配置时,显示为Not configured |
LDAP Protocol Version |
LDAP协议的版本号(LDAPv2、LDAPv3) |
Server Timeout Interval |
LDAP服务器连接超时时间(单位为秒) |
Login Account DN |
管理员用户的DN |
Base DN |
用户DN查询的起始DN |
Search Scope |
用户DN查询的范围(all-level:所有子目录查询,single-level:下级目录查询) |
User Searching Parameters |
用户查询参数 |
User Object Class |
查询用户DN时使用的用户对象类型 未配置时,显示为Not configured |
Username Attribute |
用户登录账号的属性类型 |
Username Format |
发送给服务器的用户名格式 |
Attribute map |
引用的LDAP属性映射表名称 未配置时,显示为Not configured |
ip命令用来配置LDAP服务器的IP地址。
undo ip命令用来恢复缺省情况。
ip ip-address [ port port-number ] [ vpn-instance vpn-instance-name ]
undo ip
未配置LDAP服务器的IP地址。
LDAP服务器视图
ip-address:LDAP服务器的IP地址。
port port-number:LDAP服务器所使用的TCP端口号,取值范围为1~65535,缺省值为389。
vpn-instance vpn-instance-name:LDAP服务器所属的VPN实例。vpn-instance-name表示MPLS L3VPN实例的名称,为1~31个字符的字符串,区分大小写。不指定该参数时,表示LDAP服务器属于公网。
需保证设备上的LDAP服务端口与LDAP服务器上使用的端口设置一致。
更改后的服务器IP地址和端口号,只对更改之后进行的LDAP认证生效。
# 配置LDAP服务器ccc的IP地址为192.168.0.10、端口号为4300。
[Sysname] ldap server ccc
[Sysname-ldap-server-ccc] ip 192.168.0.10 port 4300
· ldap server
ipv6命令用来配置LDAP服务器的IPv6地址。
undo ipv6命令用来恢复缺省情况。
ipv6 ipv6-address [ port port-number ] [ vpn-instance vpn-instance-name ]
undo ipv6
未配置LDAP服务器的IP地址。
LDAP服务器视图
ipv6-address:LDAP服务器的IPv6地址。
更改后的服务器IP地址和端口号,只对更改之后的LDAP认证生效。
# 配置LDAP服务器ccc的IPv6地址为1:2::3:4、端口号为4300。
[Sysname-ldap-server-ccc] ipv6 1:2::3:4 port 4300
· ldap server
ldap attribute-map命令用来创建LDAP属性映射表,并进入LDAP属性映射表视图。如果指定的LDAP属性映射表已经存在,则直接进入LDAP属性映射表视图。
undo ldap attribute-map命令用来删除指定的LDAP属性映射表。
ldap attribute-map map-name
undo ldap attribute-map map-name
不存在LDAP属性映射表。
一个LDAP的属性映射表中可以添加多个LDAP属性映射表项,每个表项表示一个LDAP 属性和一个AAA属性的映射关系。
可以通过多次执行本命令配置多个LDAP的属性映射表。
# 创建名称为map1的LDAP属性映射表,并进入该属性映射表视图。
[Sysname] ldap attribute-map map1
[Sysname-ldap-map-map1]
· attribute-map
· ldap scheme
· map
ldap scheme命令用来创建LDAP方案,并进入LDAP方案视图。如果指定的LDAP方案已经存在,则直接进入LDAP方案视图。
undo ldap scheme命令用来删除指定的LDAP方案。
ldap scheme ldap-scheme-name
undo ldap scheme ldap-scheme-name
不存在LDAP方案。
一个LDAP方案可以同时被多个ISP域引用。
系统最多支持配置16个LDAP方案。
# 创建名称为ldap1的LDAP方案并进入其视图。
ldap server用来创建LDAP服务器,并进入LDAP服务器视图。如果指定的LDAP服务器已经存在,则直接进入LDAP服务器视图。
undo ldap server命令用来删除指定的LDAP服务器。
ldap server server-name
undo ldap server server-name
不存在LDAP服务器。
# 创建LDAP服务器ccc并进入其视图。
login-dn命令用来配置具有管理员权限的用户DN。
undo login-dn命令用来恢复缺省情况。
login-dn dn-string
undo login-dn
未配置具有管理员权限的用户DN。
LDAP服务器视图
dn-string:具有管理员权限的用户DN,是绑定服务器时使用的用户标识名,为1~255个字符的字符串,不区分大小写。
设备上的管理员DN必须与服务器上管理员的DN一致。
更改后的管理员DN,只对更改之后的LDAP认证生效。
# 在LDAP服务器视图ccc下,配置管理员权限的用户DN为uid=test, ou=people, o=example, c=city。
[Sysname-ldap-server-ccc] login-dn uid=test,ou=people,o=example,c=city
login-password命令用来配置LDAP认证中,绑定服务器时所使用的具有管理员权限的用户密码。
undo login-password命令用来恢复缺省情况。
login-password { cipher | simple } string
undo login-password
未配置具有管理权限的用户密码。
LDAP服务器视图
cipher:表示以密文方式设置密码。
simple:表示以明文方式设置密码,该密码将以密文形式存储。
string:密码字符串,区分大小写。明文密码为1~128个字符的字符串,密文密码为1~201个字符的字符串。
该命令只有在配置了login-dn的情况下生效。当未配置login-dn时,该命令不生效。
# 在LDAP服务器视图ccc下,配置具有管理员权限的用户密码为明文abcdefg。
[Sysname-ldap-server-ccc] login-password simple abcdefg
· login-dn
map命令用来配置LDAP属性映射表项。
undo map命令用来删除指定的LDAP属性映射表项。
map ldap-attribute ldap-attribute-name [ prefix prefix-value delimiter delimiter-value ] aaa-attribute user-group
undo map [ ldap-attribute ldap-attribute-name ]
未指定LDAP属性映射关系。
LDAP属性映射表视图
ldap-attribute ldap-attribute-name:表示要映射的LDAP属性。其中,ldap-attribute-name表示LDAP属性名称,为1~63个字符的字符串,不区分大小写。
prefix prefix-value delimiter delimiter-value:表示按照一定的格式提取LDAP属性字符串中的内容映射为AAA属性。其中,prefix-value表示LDAP属性字符串中的某内容前缀(例如cn=),为1~7个字符的字符串,不区分大小写;delimiter-value表示LDAP属性字符串中的内容分隔符(例如逗号)。若不指定该可选参数,则表示要将一个完整的LDAP属性字符串映射为指定的AAA属性。
aaa-attribute:表示要映射为的AAA属性。
user-group:表示User group类型的AAA属性。
如果某LDAP服务器下发给用户的属性不能被AAA模块解析,则该属性将被忽略。因此,需要通过本命令指定要获取哪些LDAP属性,以及LDAP服务器下发的这些属性将被AAA模块解析为什么类型的AAA属性,具体映射为哪种类型的AAA属性由实际应用需求决定。
一个LDAP服务器属性只能映射为一个AAA属性,但不同的LDAP服务器属性可映射为同一个AAA属性。
如果undo map命令中不指定ldap-attribute参数,则表示删除所有的LDAP属性映射表项。
# 在LDAP属性映射表视图map1下,配置将LDAP服务器属性memberof按照前缀为cn=、分隔符为逗号(,)的格式提取出的内容映射成AAA属性User group。
[Sysname-ldap-map-map1] map ldap-attribute memberof prefix cn= delimiter , aaa-attribute user-group
· user-group
protocol-version命令用来配置LDAP认证中所支持的LDAP协议的版本号。
undo protocol-version命令用来恢复缺省情况。
protocol-version { v2 | v3 }
LDAP版本号为LDAPv3。
LDAP服务器视图
v2:表示LDAP协议版本号为LDAPv2。
v3:表示LDAP协议版本号为LDAPv3。
为保证LDAP认证成功,请保证设备上的LDAP版本号与LDAP服务器上使用的版本号一致。
更改后的服务器版本号,只对更改之后的LDAP认证生效。
Microsoft的LDAP服务器只支持LDAPv3,配置LDAP版本为v2时无效。
# 在LDAP服务器视图ccc下,配置LDAP协议版本号为LDAPv2。
[Sysname-ldap-server-ccc] protocol-version v2
search-base-dn命令用来配置用户查询的起始DN。
undo search-base-dn命令用来恢复缺省情况。
search-base-dn base-dn
undo search-base-dn
未指定用户查询的起始DN。
LDAP服务器视图
base-dn:查询待认证用户的起始DN值,为1~255个字符的字符串,不区分大小写。
# 在LDAP服务器视图ccc下,配置用户查询的起始DN为dc=ldap,dc=com。
[Sysname-ldap-server-ccc] search-base-dn dc=ldap,dc=com
· ldap server
search-scope命令用来配置用户查询的范围。
undo search-scope命令用来恢复缺省情况。
search-scope { all-level | single-level }
undo search-scope
用户查询的范围为all-level。
LDAP服务器视图
all-level:表示在起始DN的所有子目录下进行查询。
single-level:表示只在起始DN的下一级子目录下进行查询。
# 在LDAP服务器视图ccc下,配置在起始DN的所有子目录下查询LDAP认证用户。
[Sysname-ldap-server-ccc] search-scope all-level
· ldap server
server-timeout命令用来配置LDAP服务器连接超时时间,即认证、授权时等待LDAP服务器回应的最大时间。
undo server-timeout命令用来恢复缺省情况。
server-timeout time-interval
undo server-timeout
LDAP服务器连接超时时间为10秒。
LDAP服务器视图
time-interval:LDAP服务器连接超时时间,取值范围为5~20,单位为秒。
更改后的连接超时时间,只对更改之后的LDAP认证生效。
# 在LDAP服务器视图ccc下,配置LDAP服务器连接超时时间为15秒。
[Sysname-ldap-server-ccc] server-timeout 15
user-parameters命令用来配置LDAP用户查询的属性参数,包括用户名属性、用户名格式和自定义用户对象类型。
undo user-parameters命令用来将指定的LDAP用户查询的属性参数恢复为缺省值。
user-parameters { user-name-attribute { name-attribute | cn | uid } | user-name-format { with-domain | without-domain } | user-object-class object-class-name }
undo user-parameters { user-name-attribute | user-name-format | user-object-class }
user-name-attribute为cn;user-name-format为without-domain;未指定自定义user-object-class,根据使用的LDAP服务器的类型使用各服务器缺省的用户对象类型。
LDAP服务器视图
user-name-attribute { name-attribute | cn | uid }:表示用户名的属性类型。其中,name-attribute表示属性类型值,为1~64个字符的字符串,不区分大小写;cn表示用户登录账号的属性为cn(Common Name);uid表示用户登录账号的属性为uid(User ID)。
user-name-format { with-domain | without-domain }:表示发送给服务器的用户名格式。其中,with-domain表示发送给服务器的用户名带ISP域名;without-domain表示发送给服务器的用户名不带ISP域名。
user-object-class object-class-name:表示查询用户DN时使用的用户对象类型。其中,object-class-name表示对象类型值,为1~64个字符的字符串,不区分大小写。
如果LDAP服务器上的用户名不包含域名,必须配置user-name-format为without-domain,将用户名的域名去除后再传送给LDAP服务器;如果包含域名则需配置user-name-format为with-domain。
# 在LDAP服务器视图ccc下,配置用户对象类型为person。
[Sysname-ldap-server-ccc] user-parameters user-object-class person
· login-dn
display radius-server active-client命令用来显示处于激活状态的RADIUS客户端信息。
可以通过本命令查看设备作为RADIUS服务器时,可用于认证的RADIUS客户端信息。
# 显示所有处于激活状态的RADIUS客户端信息。
<Sysname> display radius-server active-client
Total 2 RADIUS clients.
Client IP: 2.2.2.2
Client IP: 3.3.3.3
表1-28 display radius-server active-client命令显示信息描述表
Total 2 RADIUS clients |
共计2个RADIUS客户端 |
Client IP |
RADIUS客户端IP地址 |
· radius-server client
display radius-server active-user命令用来显示处于激活状态的RADIUS用户信息。
display radius-server active-user [ user-name ]
user-name:RADIUS用户名,为1~55个字符的字符串,区分大小写,用户名不能携带域名,不能包括符号“\”、“|”、“/”、“:”、“*”、“?”、“<”、“>”和“@”,且不能为“a”、“al”或“all”。若不指定该参数,则显示所有RADIUS用户信息。
可以通过本命令查看设备作为RADIUS服务器时,用于验证接入用户身份的RADIUS用户信息。
# 显示用户名为test的处于激活状态的RADIUS用户信息。
<Sysname> display radius-server active-user test
Total 1 RADIUS users matched.
Username: test
Description: A network access user from company cc
Authorization attributes:
VLAN ID: 2
ACL number: 2000
Validity period:
Expiration time: 2015/04/03-18:00:00
# 显示所有处于激活状态的RADIUS用户信息。
Total 2 RADIUS users matched.
Username: 123
VLAN ID: 2
ACL number: 3000
Validity period:
Expiration time: 2016/04/03-18:00:00
Username: 456
VLAN ID: 2
ACL number: 3000
Validity period:
表1-29 display radius-server active-user命令显示信息描述表
Username |
RADIUS用户名 |
用户的描述信息 |
Authorization attributes |
用户授权属性 |
VLAN ID |
授权VLAN |
ACL number |
授权ACL |
Validity period |
用户有效期 |
Expiration time |
有效期的结束日期和时间 |
· local-user
radius-server activate命令用来激活RADIUS服务器配置,即激活当前的RADIUS客户端和RADIUS用户配置。
设备启动后会自动激活已有的RADIUS客户端和RADIUS用户配置,其中的RADIUS用户配置是由设备上的网络接入类本地用户信息直接生成。之后若对RADIUS客户端和网络接入类本地用户进行了增加、修改或删除操作,则都需要使用此命令对其进行激活,否则更新后的配置无法生效。
执行此命令后,会导致RADIUS服务器进程重启。RADIUS服务器进程重启期间,设备无法作为RADIUS服务器为用户提供认证服务。
# 激活RADIUS服务器配置。
[Sysname] radius-server activate
· display radius-server active-client
· display radius-server active-user
radius-server client命令用来指定RADIUS客户端。
undo radius-server client命令用来删除指定的RADIUS客户端。
radius-server client ip ipv4-address key { cipher | simple } string
undo radius-server client { all | ip ipv4-address }
未指定RADIUS客户端。
ip ipv4-address:RADIUS客户端的IPv4地址,不能为0.X.X.X和127.X.X.X,以及A、B、C类以外的地址。
key:指定与RADIUS客户端通信的共享密钥。
cipher:表示以密文方式设置密钥。
simple:表示以明文方式设置密钥。
string:密钥字符串,区分大小写。明文密钥为1~64个字符的字符串;密文密钥为1~117个字符的字符串。
all:指定所有RADIUS客户端。
RADIUS服务器上指定的RADIUS客户端IP地址必须和RADIUS客户端上配置的发送RADIUS报文的源IP地址保持一致。
RADIUS服务器上指定的共享密钥必须和RADIUS客户端上配置的与RADIUS服务器通信的共享密钥保持一致。
可通过多次执行本命令,指定多个RADIUS客户端。
# 配置RADIUS客户端IP地址为2.2.2.2,共享密钥为明文test。
[Sysname] radius-server client ip 2.2.2.2 key simple test
aaa connection-recording policy命令用来创建连接记录策略,并进入连接记录策略视图。如果连接记录策略已经存在,则直接进入连接记录策略视图。
undo aaa connection-recording policy命令用来删除连接记录策略。
不存在连接记录策略。
创建连接记录策略后,当设备作为Telnet客户端或者FTP/SSH/SFTP客户端与服务器端成功建立连接时,系统会按照策略中指定的计费方案向AAA服务器发送计费开始报文,断开连接时发送计费结束报文。
# 创建连接记录策略,并进入其视图。
[Sysname] aaa connection-recording policy
[sysname-connection-recording-policy]
· accounting hwtacacs-scheme
· display aaa connection-recording policy
accounting hwtacacs-scheme命令用来指定连接记录策略采用的HWTACACS计费方案。
undo accounting命令用来恢复缺省情况。
accounting hwtacacs-scheme hwtacacs-scheme-name
undo accounting
未指定连接记录策略采用的HWTACACS计费方案。
连接记录策略视图
修改后的HWTACACS计费方案,仅对设备与远程服务器新建的Telnet/FTP/SSH/SFTP连接生效。
对于同一个连接,若系统已经将计费开始报文成功发送给HWTACACS方案中指定的HWTACACS服务器,则后续的计费停止报文也会发送给该服务器。
连接记录业务处理过程中,系统发送给AAA服务器的计费报文中封装的是用户输入的原始用户名,因此计费方案中通过user-name-format命令设置的用户名格式并不生效。
# 创建连接记录策略,并在其视图下指定连接记录策略采用的HWTACACS计费方案为tac。
[sysname-connection-recording-policy] accounting hwtacacs-scheme tac
· aaa connection-recording policy
display aaa connection-recording policy用来显示记录连接策略的配置信息。
# 显示记录连接策略的配置信息。
<Sysname> display aaa connection-recording policy
Connection-recording policy:
Accounting scheme: HWTACACS=tac1
