05-IP转发基础命令
本章节下载: 05-IP转发基础命令 (545.00 KB)
1.1.2 fib consistency-check enable
1.1.4 forwarding split-horizon
1.1.5 forwarding vxlan-packet inner-protocol
1.1.8 ip forwarding-table save
1.1.9 snmp-agent trap enable fib
1.1.10 snmp-agent trap enable ip-forwarding
2.1.2 display ip load-sharing mode
2.1.3 display ip load-sharing mode per-packet interface
2.1.4 display ip load-sharing path
2.1.5 fabric load-sharing algorithm
2.1.6 fabric load-sharing flow-orchestration enable
2.1.7 fabric load-sharing mode
2.1.8 fabric load-sharing offset
2.1.9 fabric load-sharing seed
2.1.10 fabric load-sharing tunnel
2.1.12 ip load-sharing local-first enable
2.1.14 ip load-sharing mode per-packet
2.1.15 ip load-sharing symmetric enable
display fib命令用来显示FIB表项的信息。
display fib [vpn-instance vpn-instance-name ] [ ip-address [ mask | mask-length ] ]
vpn-instance vpn-instance-name:显示指定VPN实例的FIB表项的信息。vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。如果不指定VPN实例,则显示公网的FIB表项的信息。
ip-address:显示与指定目的IP地址匹配的FIB表项的信息。
mask:IP地址掩码。
mask-length:IP地址掩码长度,取值范围为0~32。
如果配置ip-address时不指定掩码和掩码长度,则显示与指定目的IP地址最长匹配的FIB表项的信息;如果配置ip-address时指定了掩码或掩码长度,则显示与指定目的IP地址和掩码精确匹配的FIB表项的信息。
# 显示公网的所有FIB表项的信息。
<Sysname> display fib
Destination count: 8 FIB entry count: 8
Flag:
U:Usable G:Gateway H:Host B:Blackhole D:Dynamic S:Static
R:Relay F:FRR
Destination/Mask Nexthop Flag OutInterface/Token Label
0.0.0.0/32 127.0.0.1 UH InLoop0 Null
127.0.0.0/8 127.0.0.1 U InLoop0 Null
127.0.0.0/32 127.0.0.1 UH InLoop0 Null
127.0.0.1/32 127.0.0.1 UH InLoop0 Null
127.255.255.255/32 127.0.0.1 UH InLoop0 Null
224.0.0.0/4 0.0.0.0 UB NULL0 Null
224.0.0.0/24 0.0.0.0 UB NULL0 Null
255.255.255.255/32 127.0.0.1 UH InLoop0 Null
# 显示私网的FIB表项的信息。
<Sysname> display fib vpn-instance vpn1
Destination count: 6 FIB entry count: 6
Flag:
R:Relay F:FRR
20.20.20.0/24 20.20.20.25 U M-GE0/0/0 Null
20.20.20.0/32 20.20.20.25 UBH M-GE0/0/0 Null
20.20.20.25/32 127.0.0.1 UH InLoop0 Null
20.20.20.25/32 20.20.20.25 H M-GE0/0/0 Null
20.20.20.255/32 20.20.20.25 UBH M-GE0/0/0 Null
# 显示目的地址为10.2.1.1的FIB表项的信息。
<Sysname> display fib 10.2.1.1
Flag:
R:Relay F:FRR
10.2.1.1/32 127.0.0.1 UH InLoop0 Null
表1-1 display fib命令显示信息描述表
Destination count |
目的地址的个数 |
FIB entry count |
FIB表项数目 |
Destination/Mask |
目的地址/掩码长度 |
Nexthop |
转发的下一跳地址 |
Flag |
路由的标志: · U:表示可用路由 · G:表示网关路由 · H:表示主机路由 · B:表示黑洞路由 · D:表示动态路由 · S:表示静态路由 · R:表示迭代路由 · F:表示快速重路由 |
OutInterface/Token |
转发接口/LSP索引号 |
Label |
内层标签值 |
fib consistency-check enable命令用来开启IPv4 FIB表项一致性检查功能。
undo fib consistency-check enable命令用来关闭IPv4 FIB表项一致性检查功能。
IPv4 FIB表项一致性检查功能处于关闭状态。
如果当前系统的IP报文转发效果达不到预期,可以通过本功能检查IPv4 FIB软件表项与驱动硬件表项的一致性。该功能开启后,设备将定时对所有的IPv4 FIB软件表项下发驱动进行检查,如果与驱动硬件表项不一致则打印日志信息,同时根据IPv4 FIB软件表项刷新驱动硬件表项。
# 开启IPv4 FIB表项一致性检查功能。
[Sysname] fib consistency-check enable
fib log enable命令用来开启FIB日志功能。
undo fib log enable命令用来关闭FIB日志功能。
fib log enable
undo fib log enable
FIB日志功能处于关闭状态。
FIB日志可以满足管理员对FIB模块的审计需求。设备生成FIB日志信息会交给信息中心模块处理,信息中心模块的配置将决定日志信息的发送规则和发送方向。关于信息中心的详细描述请参见“网络管理和监控配置指导”中的“信息中心”。
记录日志信息会消耗一定的内存,如果要避免此类内存消耗,可通过undo fib log enable命令关闭FIB日志信息功能。
# 开启FIB日志功能。
[Sysname] fib log enable
forwarding split-horizon命令用来开启转发水平分割功能。
undo forwarding split-horizon命令用来关闭转发水平分割功能。
对于S12500G-AF系列交换机,本功能仅在SF系列接口板和SG系列接口板上生效。
转发水平分割功能处于关闭状态。
通过开启转发水平分割功能,可以使从一个物理接口收到的IPv4、IPv6和MPLS报文不再从该接口向外发送,用于避免环路。
# 开启全局的转发水平分割功能。
[Sysname] forwarding split-horizon
forwarding vxlan-packet inner-protocol命令用来配置设备从VXLAN隧道收到指定协议类型的报文直接转发,不上送CPU。
undo forwarding vxlan-packet inner-protocol命令用来恢复缺省情况。
forwarding vxlan-packet inner-protocol { ipv4 | ipv6 } *
undo forwarding vxlan-packet inner-protocol [ ipv4 | ipv6 ]
设备从VXLAN隧道收到指定报文后将会上送CPU处理。
ipv4:表示VXLAN封装的内层协议为IPv4的报文。
ipv6:表示VXLAN封装的内层协议为IPv6的报文。
在EVPN分布式网关组网中,设备作为VTEP从VXLAN隧道口收到VXLAN封装的指定内层协议类型(VXLAN封装的内层报文的协议类型)的报文后,缺省情况会上送CPU进行处理。当指定内层协议类型的报文较多时,会被限速而导致丢包。这种情况下,VTEP的下行设备或终端可能因无法及时收到指定协议类型的报文,引发业务异常。
为避免此类情况,可配置对VXLAN隧道口收到指定协议类型的报文直接转发,不上送CPU。
# 配置设备从VXLAN隧道收到指定协议类型的报文直接转发,不上送CPU。
[Sysname] forwarding vxlan-packet inner-protocol ipv4
ip forwarding命令用来在接口未配置IPv4地址时,开启接口的IPv4报文转发功能。
undo ip forwarding命令用来在接口未配置IPv4地址时,关闭接口的IPv4报文转发功能。
ip forwarding
undo ip forwarding
在接口未配置IPv4地址时,接口的IPv4报文转发功能处于关闭状态。
在同时支持IPv4协议和IPv6协议的设备上,IPv4路由的下一跳可以是IPv4地址或IPv6地址。如果出接口上未配置IPv4地址,IPv4报文将无法在该接口上进行转发。通过配置本命令,可以在接口未配置IPv4地址的情况下,实现IPv4报文在接口上的转发功能。
# 在VLAN接口1未配置IPv4地址时,开启接口的IPv4报文转发功能。
[Sysname-Vlan-interface1] ip forwarding
ip forwarding fast-move命令用于开启IPv4转发路径快速迁移功能。
undo ip forwarding fast-move 命令用于关闭IPv4转发路径快速迁移功能。
· 对于S12500G-AF系列交换机,安装丝印前缀为LSXM1的主控板时,不支持本命令;安装其它主控板时,SE系列接口板不支持本命令。
· 对于S12500CR系列交换机,安装丝印前缀为LSXM1的主控板时,不支持本命令。
IPv4转发路径快速迁移功能处于关闭状态。
VLAN接口视图
在VLAN接口上开启IPv4转发路径快速迁移功能后,当发生网络拓扑变化或用户接入端口迁移等事件时,通过该VLAN接口转发的IPv4流量能够迅速迁移到其它转发路径,从而减少流量中断时间,提高网络的整体响应速度和用户体验。
在VLAN接口开启IPv4转发路径快速迁移功能时,该VLAN将不能用作link-aggregation management-vlan命令指定的聚合管理VLAN,否则聚合管理VLAN和聚合管理端口功能将失效。有关聚合管理VLAN和聚合管理端口功能的详细介绍,请参见“二层技术-以太网交换配置指导”中的“以太网链路聚合”。
# 开启IPv4转发路径快速迁移功能。
[Sysname-Vlan-interface2] ip forwarding fast-move
ip forwarding-table save命令用来将当前的IP转发表项保存到用户指定的文件中。
ip forwarding-table save filename filename
filename filename:目标文件名,长度不超过255字节。文件名取值范围的详细介绍,请参见“基础配置指导”中的“文件系统管理配置”。
执行本命令时,如果名称为filename的文件不存在,系统会先创建该文件,再保存;如果已存在,则会覆盖原文件的内容。
如果需要周期性地自动保存IP转发表,可以通过配置定时执行任务功能,采用循环执行方式,让设备在指定时间到达时,自动执行命令。关于配置定时执行任务功能的详细介绍,请参见“基础配置指导”中“设备管理”。
# 将IP转发表保存到名为fib.txt的文件中。
<Sysname> ip forwarding-table save filename fib.txt
snmp-agent trap enable fib命令用来开启FIB模块的告警功能。
undo snmp-agent trap enable fib命令用来关闭FIB模块的告警功能。
snmp-agent trap enable fib [ deliver-failed | ecmp-limit | entry-consistency | entry-limit ] *
undo snmp-agent trap enable fib [ deliver-failed | ecmp-limit | entry-consistency | entry-limit ] *
FIB模块的告警功能均处于开启状态。
deliver-failed:FIB表项下发硬件失败的告警功能。
ecmp-limit:等价路由超过系统支持的最大数量告警功能。
entry-consistency:FIB软件表项与驱动硬件表项不一致的告警功能。
entry-limit:FIB表项超过系统支持最大个数的告警功能。
开启FIB模块的告警功能后,该模块会生成告警信息,用于报告该模块的重要事件,设备将此信息记录在告警信息中,生成的告警信息将发送到设备的SNMP模块。
用户可根据业务需求开启指定功能的FIB模块的告警,当不指定任何参数时,代表打开全部开关:
· 开启等价路由超过系统支持的最大数量告警功能后,如果单板学习到的等价路由的数量超过了配置的系统支持最大等价路由条数,设备会将告警板号信息作为告警信息发送到设备的SNMP模块。
· 开启FIB软件表项与硬件表项不一致的告警功能后,如果单版FIB软件表项和硬件表项不一致,设备会将告警板号信息作为告警信息发送到设备的SNMP模块。
· 开启了FIB表项超过最大个数的告警功能后,如果设备FIB表项超过了告警阈值,设备会将FIB表项模块名信息作为告警信息发送到设备的SNMP模块。
· 开启FIB表项下发硬件失败的告警功能后,如果设备FIB表项下发硬件失败,设备会将下发失败的FIB表项的VRF、IP地址类型、IP地址、掩码、表项下发失败原因等信息作为告警信息发送到设备的SNMP模块。
通过设置SNMP中告警信息的发送参数,来决定告警信息输出的相关属性。有关告警信息的详细介绍,请参见“网络管理和监控配置指导”中的“SNMP”。
# 关闭FIB的告警功能。
[Sysname] undo snmp-agent trap enable fib
snmp-agent trap enable ip-forwarding命令用来开启IP转发模块的告警功能。
undo snmp-agent trap enable ip-forwarding命令用来关闭IP转发模块的告警功能
snmp-agent trap enable ip-forwarding [ ttl-expired | mbuf-alloc ]
IP转发模块的告警功能处于开启状态。
ttl-expired:开启TTL超时告警功能。
mbuf-alloc:开启MBUF内存申请失败告警功能。
开启IP转发模块的告警功能后,IP转发模块会生成告警信息报告该模块的重要事件。生成的告警信息将发送到设备的SNMP模块,通过设置SNMP中告警信息的发送参数,来决定告警信息输出的相关属性。有关告警信息的详细介绍,请参见“网络管理和监控配置指导”中的“SNMP”。
用户可根据业务需求开启指定功能的IP转发模块的告警:
· 开启了TTL超时告警功能后,设备会按照设置的时间间隔检查报文的丢弃个数,如果丢弃的报文数达到或超过了用户设置的告警阈值,将发送告警到告警中心。
· 开启了MBUF内存申请失败告警功能后,设备会MBUF内存申请失败时,将发送告警到告警中心。
本命令如果未指定任何参数,则表示开启或者关闭IP转发模块所有的告警功能。
关闭IP转发模块的告警功能后,设备将只发送日志信息到信息中心模块,此时可以配置信息中心的输出规则和输出方向来查看IPv6基础模块的日志信息。有关信息中心的详细介绍,请参见“网络管理和监控配置指导”中的“信息中心”。
# 关闭转发模块的告警功能。
[Sysname] undo snmp-agent trap enable ip-forwarding
bandwidth-based-sharing命令用来开启IPv4基于带宽的负载分担功能。
undo bandwidth-based-sharing命令用来关闭IPv4基于带宽的负载分担功能。
IPv4基于带宽的负载分担功能处于关闭状态。
开启IPv4基于带宽的负载分担功能情况下,如果转发时查到多个出接口/下一跳,则按照接口的带宽值计算出各个接口应该分配的报文比例,然后按照带宽比例对报文进行转发。
支持负载分担的协议(如LISP)的设备,无论是否配置bandwidth-based-sharing,负载分担比例以协议定义的负载分担比例为准。
本功能仅支持在等价路由普通模式下配置,有关等价路由模式的详细介绍,请参见“三层技术-IP路由命令参考”中的“IP路由基础命令”。
配置了逐包转发功能的多个接口,无法实现本功能。
# 开启IPv4基于带宽的负载分担功能。
[Sysname] bandwidth-based-sharing
display ip load-sharing mode命令用来显示当前使用的负载分担方式。
(独立运行模式)
display ip load-sharing mode slot slot-number
display ip load-sharing mode chassis chassis-number slot slot-number
slot slot-number:显示指定单板上的当前使用的负载分担方式。slot-number表示单板所在的槽位号。如果未指定本参数,则显示所有单板上的当前使用的负载分担方式。(独立运行模式)
chassis chassis-number slot slot-number:显示指定成员设备上指定单板上的当前使用的负载分担方式。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。如果未指定本参数,则显示所有单板上的当前使用的负载分担方式。(IRF模式)
# 显示当前使用的负载分担方式。
<Sysname> display ip load-sharing mode slot 1
Load-sharing mode: per-flow
Load-sharing options: dest-ip | src-ip | ip-pro | dest-port | src-port | ingress-port
Load-sharing algorithm: 1
IP tunnel load-sharing mode: outer
表2-1 display ip load-sharing mode命令显示信息描述表
Load-sharing mode |
采用的负载分担方式: · per-packet:基于报文逐包进行负载分担 · per-flow:基于报文逐流进行负载分担 |
Load-sharing options |
负载分担时的选项: · dest-ip:基于报文的目的IP地址进行负载分担 · src-ip:基于报文的源IP地址进行负载分担 · ip-pro:基于报文的IP协议号进行负载分担 · dest-port:基于报文的目的端口进行负载分担 · src-port:基于报文的源端口进行负载分担 · ingress-port:基于报文的入端口进行负载分担 · flow-label:基于IPv6报文的流标签进行负载分担 |
Load-sharing algorithm |
负载分担算法编号 |
IP tunnel load-sharing mode |
IP tunnel 采用的负载分担方式: · inner:基于内层信息进行负载分担 · outer:基于外层信息进行负载分担 |
· ip load-sharing mode
display ip load-sharing mode per-packet interface命令用来显示接口视图下配置了逐包负载分担方式的接口信息。
(独立运行模式)
display ip load-sharing mode per-packet interface [ slot slot-number ]
display ip load-sharing mode per-packet interface [ chassis chassis-number slot slot-number ]
slot slot-number:显示指定单板上在接口视图下配置了逐包负载分担方式的接口信息。slot-number表示单板所在的槽位号。如果未指定本参数,则显示所有单板上在接口视图下配置了逐包负载分担方式的接口信息。(独立运行模式)
chassis chassis-number slot slot-number:显示指定成员设备的指定单板上在接口视图下配置了逐包负载分担方式的接口信息。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。如果未指定本参数,则显示所有单板上在接口视图下配置了逐包负载分担方式的接口信息。(IRF模式)
通过本命令可以查看接口视图下执行了ip load-sharing mode per-packet命令的接口信息。
# 显示接口视图下执行了ip load-sharing mode per-packet命令的接口信息。
<Sysname> display ip load-sharing mode per-packet interface
Count: 3
Interface Algorithm Status
Ten-GigabitEthernet3/0/1 Spray Failed
Route-Aggregation1 Spray Succeed
Route-Aggregation2.1 Robin Failed
表2-2 命令显示信息描述表
Count |
接口视图下配置了逐包负载分担方式的接口总数 |
配置了逐包负载分担方式的接口名称 |
Algorithm |
逐包负载分担模式使用的算法,取值包括: · Spray算法 · Robin算法 |
Status |
接口下逐包负载分担功能的使能状态,取值及含义为: · Succeed:成功 · Failed:失败 |
· ip load-sharing mode per-packet
display ip load-sharing path命令用来指定计算等价路由哈希选路的参数并显示计算出的等价路由哈希选路信息。
display ip load-sharing path ingress-port interface-type interface-number packet-format { ipv4oe dest-ip ip-address [ src-ip ip-address ] | ipv6oe dest-ipv6 ipv6-address [ src-ipv6 ipv6-address | flow-label flow-label ] } [ dest-port port-id | ip-pro protocol-id | src-port port-id | vpn-instance vpn-instance-name ] *
ingress-port interface-type interface-number:指定设备计算等价路由选路信息时的报文入接口。interface-type interface-number为接口类型和接口编号。
packet-format { ipv4oe dest-ip ip-address [src-ip ip-address ] | ipv6oe dest-ipv6 ipv6-address [ src-ipv6 ipv6-address ] }:指定设备计算等价路由选路信息时的报文封装格式。
· ipv4oe:指定报文的封装格式为IPv4封装以太网。
· dest-ip ip-address:指定目的IP地址,为点分十进制格式。如果未指定该参数,则设备计算等价路由选路信息时使用的目的IP地址为0。
· src-ip ip-address:指定源IP地址,为点分十进制格式。如果未指定该参数,则设备计算等价路由选路信息时使用的源IP地址为0。
· ipv6oe:指定报文的封装格式为IPv6封装以太网。
· dest-ipv6 ipv6-address:指定目的IPv6地址。如果未指定该参数,则设备计算等价路由选路信息时使用的目的IPv6地址为0。
· src-ipv6 ipv6-address:指定源IPv6地址。如果未指定该参数,则设备计算等价路由选路信息时使用的源IPv6地址为0。
· flow-label flow-label:指定IPv6流标签,取值范围为0~1048575。如果未指定该参数,则设备计算等价路由选路信息时使用的流标签值为0。
dest-port port-id:指定设备计算等价路由选路信息时的目的端口号,port-id取值范围为1~65535。如果未指定该参数,则设备计算等价路由选路信息时使用的目的端口号为0。
ip-pro protocol-id:指定设备计算等价路由选路信息时使用的IP协议类型,protocol-id取值范围为1~65535。如果未指定该参数,则设备计算等价路由选路信息时使用的IP协议类型值为0。
src-port port-id:指定设备计算等价路由选路信息时的源端口号,port-id取值范围为1~65535。如果未指定该参数,则设备计算等价路由选路信息时使用的源端口号为0。
vpn-instance vpn-instance-name:指定设备计算等价路由选路信息时的VPN实例。vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。如果未指定该参数,则设备计算等价路由选路信息时不存在VPN实例信息(表示公网)。
本命令行的参数输入需要和display ip load-sharing mode命令显示的配置参数以及负载分担报文所携带的字段相匹配。如不匹配,则显示的等价路由哈希选路信息可能跟实际不一致。
本命令无法显示非已知单播报文的出接口信息和隧道封装报文信息。
当通过ip load-sharing mode命令配置基于报文逐包进行负载分担功能时,本命令显示的等价路由哈希选路信息会与实际不一致。
# 指定设备计算等价路由选路信息时的参数:接口Ten-GigabitEthernet3/0/3进入,目的IP地址为10.110.0.2、源IP地址10.100.0.2、IP协议类型编号为153、目的端口号为2000、源端口号为2000。并显示计算出的报文的等价路由选路信息。
<Sysname> display ip load-sharing path ingress-port ten-gigabitethernet 3/0/3 packet-format ipv4oe dest-ip 10.110.0.2 src-ip 10.100.0.2 ip-pro 153 dest-port 2000 src-port 2000
Load-sharing algorithm: 0
Load-sharing parameters:
Missing configured are set to 0.
ingress-port: Ten-GigabitEthernet3/0/3
packet-format: IPv4oE
dest-ip: 10.110.0.2
src-ip: 10.100.0.2
ip-pro: 153
dest-port: 2000
src-port: 2000
Path selected: 20.0.0.2(interface Ten-GigabitEthernet3/0/3)
表2-3 display ip load-sharing path命令显示信息描述表
用户配置的逐流负载分担算法编号 |
用户配置的逐流负载分担方式选项 |
Load-sharing parameters |
用户输入信息,用于显示等价路由哈希选路信息 |
Missing configured are set to 0. |
用户未明确输入参数采用缺省值0 |
ingress-port |
报文入接口 |
packet-format |
报文封装格式 |
dest-ip |
目的IP地址 |
src-ip |
源IP地址 |
ip-pro |
IP协议类型 |
dest-port |
目的端口号 |
src-port |
源端口号 |
flow-label |
IPv6报文流标签 |
Path selected |
计算出的等价路由哈希选路信息,包含下一跳的IP/IPv6地址和出接口 |
fabric load-sharing algorithm命令用来配置业务板的负载分担算法。
undo fabric load-sharing algorithm 命令用来恢复缺省情况。
对于S12500G-AF S系列交换机,仅SF系列接口板和SG系列接口板支持本命令。
(独立运行模式)
fabric load-sharing algorithm algorithm-number slot slot-number
undo fabric load-sharing algorithm algorithm-number slot slot-number
fabric load-sharing algorithm algorithm-number chassis chassis-number slot slot-number
undo fabric load-sharing algorithm algorithm-number chassis chassis-number slot slot-number
未配置负载分担算法。
algorithm-number:表示负载分担算法的编号,取值范围为1~13。
slot slot-number:表示单板所在的槽位号。(独立运行模式)
chassis chassis-number slot slot-number:chassis-number表示设备在IRF中的成员编号,slot-number为单板所在的槽位号。(IRF模式)
当在聚合链路上配置了聚合负载分担功能,且流量负载分担的结果与预期效果不一致时,可以配置业务板的负载分担功能来排查定位原因。
配置业务板的负载分担功能会影响指定slot上内部通信接口的流量负载分担。缺省情况下,无需配置业务板的负载分担功能,设备会根据聚合负载分担配置直接计算业务板的负载分担。如需配置,请在专业人士的指导下进行操作,以免影响聚合负载分担功能的正常运行。
仅在缺省MDC下支持本命令。
多次执行本命令,最后一次执行的命令生效。
# 配置指定slot按照算法3进行负载分担。(独立运行模式)
[Sysname] fabric load-sharing algorithm 3 slot 2
· fabric load-sharing mode
· fabric load-sharing offset
· fabric load-sharing seed
· fabric load-sharing tunne
fabric load-sharing flow-orchestration enable命令用来开启业务板的流量调整功能。
undo fabric load-sharing flow-orchestration enable命令用来关闭业务板的流量调整功能。
对于S12500G-AF系列交换机,仅安装丝印前缀为LSXM3的主控板与如下网板+接口板的搭配支持本命令。
· LSXM3SFS08G2网板+LSXM3CDQ8SF2接口板
· LSXM3SFS08G2网板+LSXM3CDQ16SF2接口板
· LSXM3SFS16G2网板+LSXM3CDQ8SF2接口板
· LSXM3SFS16G2网板+LSXM3CDQ16SF2接口板
· LSXM3SFS08K2网板+LSXM3CDHQ36SG2接口板
· LSXM3SFS08K2网板+LSXM3CCQ36SG2接口板
· LSXM3SFS04K2网板+LSXM3CDHQ36SG2接口板
· LSXM3SFS04K2网板+LSXM3CCQ36SG2接口板
对于S12500CR系列交换机,仅安装丝印前缀为LSXM3的主控板与如下网板+接口板的搭配支持本命令。
· LSXM3SFS08K2网板+LSXM3CDHQ36RSG2接口板
· LSXM3SFS04RK2网板+LSXM3CDHQ36RSG2接口板
· LSXM3SFS04RK2网板+LSXM3CCQ36SG2接口板
fabric load-sharing flow-orchestration enable [ ip-pair | nic-bandwidth { 100g | 200g | 400g } ] *
业务板的流量调整功能处于关闭状态。
ip-pair:配置基于IP地址对(源和目的IP地址)进行流量调整。如果未指定本参数,则基于五元组进行流量调整。
nic-bandwidth { 100g | 200g | 400g }:指定需要进行流量调整的网卡的速率。本参数需要与设备实际使用的网卡的速率保持一致。如果未指定本参数,则需要进行流量调整的网卡的速率为100G。
在大带宽、高并发和多用户接入的网络环境中,例如AI训练场景,当业务板入接口的带宽超过网板HG口带宽时,传统的LBN负载分担方式可能会导致设备内部部分线路的流量严重拥塞。为了解决这一问题,流量调整功能能够根据配置的算法和流量特征,调整业务板到网板的流量转发路径,从而实现更加均匀的负载均衡效果。
多次执行本命令,以最后一次执行结果为准。
在设备安装LSXM3SFS08K2网板的环境下执行本命令时,还需配置fabric load-sharing mode ingress-port slot命令,开启网板内联口的LBN功能。
本命令仅对IPv4 RoCEv2 RC模式中Opcode=6(Write First)的首个分片报文生效。设备通过识别该报文,根据流量调整策略调整转发路径。
当设备处于如下组网环境时,本功能不支持使用:
· 接口拆分与合并。有关接口拆分与合并的详细介绍,请参见“接口管理”中的“以太网接口”。
· M-LAG。有关M-LAG的详细介绍,请参见“虚拟化技术”中的“M-LAG”。
· IRF。有关IRF的详细介绍,请参见“二层技术-以太网交换”中的“IRF”。
隔离和插拔网板会导致本功能失效,完成上述操作后需重新配置本功能。有关隔离网板的详细介绍,请参见“基础配置”中的“设备管理”。
本功能不支持对封装报文(如MPLS、VXLAN和隧道等)进行流量调整。
在AI训练场景中,需要进行流量调整的网卡总带宽需与设备接口板总带宽保持一致。
内联口总带宽不能超过接口板入接口总带宽,否则本功能失效。
在接口板上同时配置本命令和fabric load-sharing mode ingress-port slot命令时,仅本命令生效。
当内联口带宽大于等于网卡接口带宽时,建议基于IP地址对(源和目的IP地址)进行流量调整。
配置本功能时,需注意:
· 当本功能与UDP智能流量分析或统一流量分析功能同时配置时,本功能失效。有关UDP智能流量分析、统一流量分析的详细配置,请参见“网络管理和监控配置指导”中的“NetAnalysis”。
· 当本功能与NetStream或Flow Group功能同时配置时,仅本功能生效。有关NetStream的详细介绍,请参见“网络管理和监控配置指导”中的“NetStream”。有关Flow Group的详细介绍,请参见“Telemetry”中的“Flow Group”。
本命令与fabric-mode命令互斥,当两者同时配置时,生效关系如下:
· 当fabric-mode指定rr参数时,仅fabric-mode命令生效。
· 当fabric-mode指定dlb、multiple-mapping或multiple-mapping-dlb参数时,仅本命令生效。
· 有关fabric-mode命令的详细介绍,请参见“基础配置”中的“设备管理”。
本功能与内联Traffic Matrix功能互斥,当两者同时配置时,仅内联Traffic Matrix功能生效。有关内联Traffic Matrix功能的介绍,请参见“ACL和QoS”中的“QoS”。
# 开启业务板流量调整功能,并指定网卡速率为200G。
[Sysname] fabric load-sharing flow-orchestration enable nic-bandwidth 200g
fabric load-sharing mode命令用来配置业务板的负载分担类型。
undo fabric load-sharing mode命令用来恢复缺省情况。
对于S12500G-AF S系列交换机,仅SF系列接口板和SG系列接口板、网板支持本命令。
(独立运行模式)
fabric load-sharing mode {{ destination-ip | destination-mac | ingress-port | source-ip | source-mac } * | destination-slot-port | flexible } slot slot-number
undo fabric load-sharing mode [ { destination-ip | destination-mac | ingress-port | source-ip | source-mac | source-port } * | destination-slot-port | flexible ] slot slot-number
fabric load-sharing mode { { destination-ip | destination-mac | ingress-port | source-ip | source-mac } * | destination-slot-port | flexible } chassis chassis-number slot slot-number
undo fabric load-sharing mode [ { destination-ip | destination-mac | ingress-port | source-ip | source-mac } * | destination-slot-port | flexible ] chassis chassis-number slot slot-number
未配置业务板的负载分担类型。
destination-ip:表示按报文的目的IP地址进行负载分担。
destination-mac:表示按报文的目的MAC地址进行负载分担。
destination-slot-port:表示按报文的目的slot上的服务端口进行负载分担。
ingress-port:表示按报文的入端口进行负载分担。
source-ip:表示按报文的源IP地址进行负载分担。
source-mac:表示按报文的源MAC地址进行负载分担,该负载分担类型仅对二层报文生效。
flexible:表示按报文类型(如二层、IPv4等)自动选择负载分担的类型。
slot slot-number:单板所在的槽位号。(独立运行模式)
本命令会影响隧道报文在业务板负载分担功能的计算结果。缺省情况下,无需配置。如需配置,请在专业人士的指导下进行操作,以免影响聚合负载分担功能的正常运行。
destination-slot-port参数仅S12500G-AF系列交换机的LSXM3CDQ16SF2和LSXM3CDQ8SF2接口板支持,且仅当这些接口板的400G端口上收到的流量从LSXM3CGQ36SF2接口板上转发时才生效。
# 配置指定slot按照报文目的MAC地址进行负载分担。(独立运行模式)
[Sysname] fabric load-sharing mode destination-mac slot 2
· fabric load-sharing algorithm
· fabric load-sharing tunnel
fabric load-sharing offset命令用来配置业务板负载分担计算结果的偏移量。
undo fabric load-sharing algorithm命令用来恢复缺省情况。
(独立运行模式)
fabric load-sharing offset offset-value slot slot-number
undo fabric load-sharing offset offset-value slot slot-number
fabric load-sharing offset offset-value chassis chassis-number slot slot-number
undo fabric load-sharing offset offset-value chassis chassis-number slot slot-number
未配置业务板负载分担计算结果的偏移量。
offset-value:负载分担计算结果的偏移量,取值范围为1~63。
本命令会影响业务板负载分担功能的计算结果。缺省情况下,无需配置。如需配置,请在专业人士的指导下进行操作,以免影响聚合负载分担功能的正常运行。
仅在缺省MDC下支持本命令。
# 配置slot2上聚合负载分担计算结果的偏移量为2比特(bit)。(独立运行模式)
[Sysname] fabric load-sharing offset 2 slot 2
fabric load-sharing seed命令用来配置业务板的负载HASH SEED。
undo fabric load-sharing seed命令用来恢复缺省情况。
(独立运行模式)
fabric load-sharing seed seed-number slot slot-number
undo fabric load-sharing seed seed-number slot slot-number
fabric load-sharing seed seed-number chassis chassis-number slot slot-number
undo fabric load-sharing seed seed-number chassis chassis-number slot slot-number
未配置业务板的负载HASH SEED。
seed-number:业务板采用的聚合流量负载分担算法HASH SEED。seed-number指定参与负载分担计算的HASH SEED值,取值范围为1~FFFFFFFF。
仅在缺省MDC下支持本命令。
# 配置指定slot按照HASH SEED值为3进行负载分担。(独立运行模式)
[Sysname] fabric load-sharing seed 3 slot 2
fabric load-sharing tunnel命令用来配置业务板对隧道报文采用的负载分担方式。
undo fabric load-sharing tunnel命令用来恢复缺省情况。
(独立运行模式)
fabric load-sharing tunnel { inner | outer } slot slot-number
undo fabric load-sharing tunnel { all | inner | outer } slot slot-number
fabric load-sharing tunnel { inner | outer } chassis chassis-number slot slot-number
undo fabric load-sharing tunnel { all | inner | outer } chassis chassis-number slot slot-number
未配置业务板对隧道报文采用的负载分担方式。
inner:表示按隧道报文基于内层IP信息的方式进行负载分担。
outer:表示按隧道报文基于外层IP信息的方式进行负载分担。
仅在缺省MDC下支持本命令。
# 配置业务板对隧道报文采用的负载分担方式为基于隧道报文内层IP信息进行负载分担(独立运行模式)
[Sysname] fabric load-sharing tunnel inner slot 2
ip load-sharing acl命令用来配置负载分担匹配的ACL规则。
undo ip load-sharing acl命令用来删除负载分担匹配的ACL规则。
ip load-sharing acl [ { ipv4 { ipv4-acl-number | name ipv4-acl-name } | ipv6 { ipv6-acl-number | name ipv6-acl-name } }* | user-defined { user-define-acl-number | name user-define-acl-name } ]
undo ip load-sharing acl [ { ipv4 { ipv4-acl-number | name ipv4-acl-name } | ipv6 { ipv6-acl-number | name ipv6-acl-name } }* | user-defined { user-define-acl-number | name user-define-acl-name } ]
未配置任何ACL规则。
ipv4 ipv4-acl-number:IPv4 ACL编号,取值范围为3000~3999。
name ipv4-acl-name:IPv4 ACL名称,1~63字符。
ipv6 ipv6-acl-number:IPv6 ACL编号,取值范围为3000~3999。
name ipv6-acl-name:IPv6 ACL名称,1~63字符。
user-defined user-define-acl-number:用户自定义ACL编号,取值范围为5000~5999。
name user-define-acl-name:用户自定义ACL名称,1~63字符。
在实际应用中,RoCE网络常面临大象流(如业务报文,具有流数少、数据量大、占用带宽大的特点)和老鼠流(如RoCE协议报文,具有流数多、数据量少、对丢包敏感的特点)共存的问题,对两种流量采用同一种负载分担方式容易导致负载分担不均和带宽利用率低。为了解决这一问题,可以通过配置负载分担匹配的ACL规则,进一步区分流量,并对不同类型流量采用不同的负载分担方式,从而实现更有效的负载均衡。
ACL规则下发驱动后,匹配上ACL规则的报文将采用非DLB,即逐流负载分担方式;未匹配上ACL规则的报文采用ip load-sharing mode per-packet robin命令配置的动态负载分担模式。
配置本命令未引用任何ACL规则时,系统会生成一个硬件驱动自定义的ACL规则,用于识别RoCE协议报文,并对这些报文进行逐流负载分担。而对于未匹配上该驱动自定义ACL规则的报文,系统将采用ip load-sharing mode per-packet robin命令配置的负载分担模式。
· IPv4和IPv6 ACL规则可以同时配置,也可以叠加配置。
· 命令行下发的ACL规则未配置时,不会将ACL规则下发给驱动,当用户下发的ACL规则创建后再将ACL规则下给驱动;当ACL规则被删除时,会通知驱动删除ACL规则。
· undo ip load-sharing acl命令未指定任何ACL时,将删除全部ACL规则引用关系。
# 配置负载分担匹配IPv4 ACL 3000。
<Sysname> system
[Sysname] ip load-sharing acl ipv4 3000
· acl advanced(ACL和QoS命令参考/ACL)
· acl ipv6 advanced(ACL和QoS命令参考/ACL)
· acl user-defined advanced(ACL和QoS命令参考/ACL)
ip load-sharing local-first enable命令用来开启等价路由负载分担本地优先功能。
undo ip load-sharing local-first enable命令用来关闭等价路由负载分担本地优先功能。
等价路由负载分担本地优先功能处于开启状态。
等价路由负载分担本地优先功能仅在IRF模式下生效。
# 开启等价路由负载分担本地优先功能。
[Sysname] ip load-sharing local-first enable
ip load-sharing mode命令用来配置负载分担方式。
undo ip load-sharing mode命令用来恢复缺省情况。
· 对于S12500G-AF系列交换机,配置基于报文逐包进行负载分担功能仅在SF系列接口板和SG系列接口板上生效。在VXLAN组网下,配置基于报文逐包进行负载分担功能在SF系列接口板和SG系列接口板上也无法生效。
· 对于S12500CR系列交换机,在VXLAN组网下,配置基于报文逐包进行负载分担功能无法生效。
(独立运行模式)
ip load-sharing mode { per-flow [ algorithm algorithm-number [ seed seed-number ] [ shift shift-number ] | [ dest-ip | dest-port | flow-label | ingress-port | ip-pro | src-ip | src-port ] * | tunnel { inner | outer } ] | per-packet } { global | slot slot-number }
undo ip load-sharing mode [ per-flow { algorithm | tunnel } ] { global | slot slot-number }
ip load-sharing mode { per-flow [ algorithm algorithm-number [ seed seed-number ] [ shift shift-number ] | [ dest-ip | dest-port | flow-label | ingress-port | ip-pro | src-ip | src-port ] * | tunnel { inner | outer } ] | per-packet } { chassis chassis-number slot slot-number | global }
undo ip load-sharing mode [ per-flow { algorithm | tunnel } ] { chassis chassis-number slot slot-number | global }
基于报文的源IP地址、目的IP地址、源端口、目的端口和IP协议号逐流进行负载分担。
algorithm algorithm-number:基于报文逐流进行负载分担的算法切换。algorithm-number指定要进行算法切换的算法编号。对于S12500CR系列交换机,取值范围为0~13。对于S12500G-AF系列交换机,在SF系列接口板和SG系列接口板上取值范围为0~13;在SE系列接口板上,实际取值范围为0~1。如果指定本参数,则使用undo ip load-sharing mode命令恢复缺省情况后,设备内的算法编号为0。
seed seed-number:负载分担算法的起始HASH值。取值范围为0~ffffffff。
对于S12500G-AF系列交换机,仅SF系列接口板和SG系列接口板支持本参数。
shift shift-number:负载分担算法计算结果的偏移量。取值范围为0~31。
per-flow:基于报文逐流进行负载分担。如果指定了本参数,但未指定dest-ip、dest-port、flow-label、ingress-port、ip-pro、src-ip以及src-port参数,则表示设备将基于缺省情况逐流进行负载分担。缺省使用的负载分担因子可通过display ip load-sharing mode命令查看。
flow-label:基于IPv6报文的流标签逐流进行负载分担,仅IPv6报文支持本参数。
对于S12500G-AF系列交换机,本参数仅在SF系列接口板和SG系列接口板上生效。
ingress-port:基于报文的入端口逐流进行负载分担。
tunnel { inner | outer }:指定对IP Tunnel报文采用的逐流负载分担方式,其中inner表示基于Tunnel内层信息进行逐流负载分担;outer表示基于Tunnel外层信息进行逐流负载分担。如果未指定本参数,则基于Tunnel外层信息进行逐流负载分担。
global:表示全局配置。
slot slot-number:在指定单板上配置负载分担方式。slot-number表示单板所在的槽位号。如果未指定本参数,则在所有单板上配置负载分担方式。(独立运行模式)
chassis chassis-number slot slot-number:在指定成员设备上指定单板上配置负载分担方式。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。如果未指定本参数,则在所有单板上配置负载分担方式。(IRF模式)
当负载分担不够均匀时,可以通过修改seed和shift参数的值来进行调整。
负载分担hash seed功能对非已知单播报文不生效。
IP Tunnel报文的负载分担功能对非已知单播报文不生效。
对于MPLS报文,设备仅支持基于报文的源IP地址逐流和基于报文的目的IP地址逐流进行负载分担的方式。
使用基于IPv6报文的流标签逐流进行负载分担功能时,无法支持内层是IPv6报文的MPLS数据包。
在设备开启对称负载分担功能的场景下,若按报文的源IP地址进行逐流负载分担,当源IP变化时,基于源IP的逐流负载分担可能不生效。
指定slot的负载分担方式的优先级高于全局负载分担方式。全局配置只对未指定负载分担方式的slot生效,对指定了负载分担方式的slot不生效。
配置基于报文逐包进行负载分担功能仅支持在等价路由普通模式下配置。有关等价路由模式的介绍,请参见“三层技术-IP路由命令参考”中的“IP路由基础命令”。
开启基于报文逐包进行负载分担功能后,报文会出现乱序。逐包负载分担仅适用于不关心报文乱序的场景。
缺省情况下,设备基于报文的源IP地址、目的IP地址、源端口、目的端口和IP协议号逐流进行负载分担,同一个报文的首包和分片报文可能会负载分担到不同的出端口进行转发。对于S12500G-AF系列交换机,使用SE系列接口板时,如果当前网络环境处理分片报文重组时与报文转发路径强相关,这可能导致报文重组失败。若出现此问题,请重新配置ip load-sharing mode命令,并且配置时不能指定dest-port和src-port参数。
当设备配置如下命令进行负载分担时,不能与RDMA Telemetry功能同时使用,否则会影响RDMA Telemetry功能的实现。有关RDMA Telemetry功能的详细介绍,请参见“Telemetry”中的“RDMA Telemetry”。
· ip load-sharing mode per-flow ingress-port
# 配置指定slot基于报文逐流进行负载分担。(独立运行模式)
[Sysname] ip load-sharing mode per-flow slot 1
# 配置指定slot基于报文目的IP地址、源IP地址逐流进行负载分担。(独立运行模式)
[Sysname] ip load-sharing mode per-flow dest-ip src-ip slot 1
# 配置指定slot对IP Tunnel报文基于Tunnel内层信息逐流进行负载分担。(独立运行模式)
[Sysname] ip load-sharing mode per-flow tunnel inner slot 1
# 配置指定slot基于报文逐流进行负载分担的算法切换,算法编号为1。(独立运行模式)
[Sysname] ip load-sharing mode per-flow algorithm 1 slot 1
· display ip load-sharing mode
ip load-sharing mode per-packet命令用来指定接口采用逐包方式进行负载分担,并指定负载分担的算法。
undo ip load-sharing mode per-packet命令用来恢复缺省情况。
对于S12500G-AF系列交换机,本功能仅在SF系列接口板和SG系列接口上生效。
不指定接口的负载分担方式,接口的负载分担方式继承系统视图下的ip load-sharing mode命令的配置。
三层接口视图
robin:指定robin算法,一种只考虑报文数量的轮询算法。
在业务流量和转发报文的接口均固定的场景下,逐包负载分担的性能比逐流负载分担稍高。在设备采取全局逐流负载分担的场景下,通过本命令可以指定接口为逐包负载分担,多用于测试设备的性能。在逐包情况下,robin算法不考虑报文大小。
配置完成后,接口将保持逐包负载分担,不再继承系统视图下ip load-sharing mode命令的配置。
VSI虚接口下不支持配置本功能。
配置本功能后,display ip load-sharing mode命令中的显示信息与实际情况可能会有差异。
本功能不能与RDMA Telemetry功能同时使用,否则会影响RDMA Telemetry功能的实现。有关RDMA Telemetry功能的详细介绍,请参见“Telemetry”中的“RDMA Telemetry”。
# 配置接口Ten-GigabitEthernet3/0/1采用逐包方式进行负载分担。
[systerm] interface ten-gigabitethernet 3/0/1
[systerm-Ten-GigabitEthernet3/0/1] ip load-sharing mode per-packet robin
ip load-sharing symmetric enable命令用来开启对称负载分担功能。
undo ip load-sharing symmetric enable命令用来关闭对称负载分担功能。
对于S12500G-AF系列交换机,仅SF系列接口板和SG系列接口板支持本功能。
开启对称负载分担功能后,对于源IP为A、目的IP为B的流量,和源IP为B、目的IP为A的流量,将负载分担到同一条路径。
对称负载分担功能仅对已知单播报文生效。
配置本命令后,当源IP地址发生变化时,可能导致基于报文源IP的负载分担策略失效。
# 开启对称负载分担功能。
[Sysname] ip load-sharing symmetric enable
