05-三层技术-IP业务命令参考
03-DHCP命令
本章节下载: 03-DHCP命令  (1.13 MB)
03-DHCP命令
1 DHCP
1.1 DHCP公共命令
1.1.1 dhcp client-detect
1.1.2 dhcp dscp
1.1.3 dhcp enable
1.1.4 dhcp flood-protection aging-time
1.1.5 dhcp flood-protection enable
1.1.6 dhcp flood-protection threshold
1.1.7 dhcp log enable
1.1.8 dhcp select
1.2 DHCP服务器配置命令
1.2.1 address range
1.2.2 bims-server
1.2.3 bootfile-name
1.2.4 class ip-pool
1.2.5 class option-group
1.2.6 class range
1.2.7 default ip-pool
1.2.8 dhcp apply-policy
1.2.9 dhcp class
1.2.10 dhcp option-group
1.2.11 dhcp policy
1.2.12 dhcp server always-broadcast
1.2.13 dhcp server apply ip-pool
1.2.14 dhcp server bootp ignore
1.2.15 dhcp server bootp reply-rfc-1048
1.2.16 dhcp server check mac-address
1.2.17 dhcp server database filename
1.2.18 dhcp server database update interval
1.2.19 dhcp server database update now
1.2.20 dhcp server database update stop
1.2.21 dhcp server forbidden-ip
1.2.22 dhcp server ip-pool
1.2.23 dhcp server ping packets
1.2.24 dhcp server ping timeout
1.2.25 dhcp server relay information enable
1.2.26 dhcp server request-ip-address check
1.2.27 display dhcp server conflict
1.2.28 display dhcp server database
1.2.29 display dhcp server expired
1.2.30 display dhcp server free-ip
1.2.31 display dhcp server ip-in-use
1.2.32 display dhcp server pool
1.2.33 display dhcp server statistics
1.2.34 dns-list
1.2.35 domain-name
1.2.36 exhaustion log enable
1.2.37 exhaustion trap enable
1.2.38 expired
1.2.39 forbidden-ip
1.2.40 gateway-list
1.2.41 if-match
1.2.42 ip-in-use threshold
1.2.43 nbns-list
1.2.44 netbios-type
1.2.45 network
1.2.46 next-server
1.2.47 option
1.2.48 reset dhcp server conflict
1.2.49 reset dhcp server expired
1.2.50 reset dhcp server ip-in-use
1.2.51 reset dhcp server statistics
1.2.52 snmp-agent trap enable dhcp server
1.2.53 static-bind
1.2.54 tftp-server domain-name
1.2.55 tftp-server ip-address
1.2.56 valid class
1.2.57 verify class
1.2.58 voice-config
1.2.59 vpn-instance
1.3 DHCP中继配置命令
1.3.1 dhcp relay check mac-address
1.3.2 dhcp relay check mac-address aging-time
1.3.3 dhcp relay client-information record
1.3.4 dhcp relay client-information refresh
1.3.5 dhcp relay client-information refresh enable
1.3.6 dhcp relay dhcp-server timeout
1.3.7 dhcp relay gateway
1.3.8 dhcp relay information circuit-id
1.3.9 dhcp relay information enable
1.3.10 dhcp relay information link-selection
1.3.11 dhcp relay information remote-id
1.3.12 dhcp relay information strategy
1.3.13 dhcp relay insert option60
1.3.14 dhcp relay mac-forward enable
1.3.15 dhcp relay master-server switch-delay
1.3.16 dhcp relay pool
1.3.17 dhcp relay release-agent
1.3.18 dhcp relay release ip
1.3.19 dhcp relay request-from-tunnel discard
1.3.20 dhcp relay server-address
1.3.21 dhcp relay server-address algorithm
1.3.22 dhcp relay source-address
1.3.23 dhcp smart-relay enable
1.3.24 dhcp-server timeout
1.3.25 display dhcp relay check mac-address
1.3.26 display dhcp relay client-information
1.3.27 display dhcp relay information
1.3.28 display dhcp relay m-lag-status
1.3.29 display dhcp relay server-address
1.3.30 display dhcp relay statistics
1.3.31 gateway-list
1.3.32 master-server switch-delay
1.3.33 remote-server
1.3.34 remote-server algorithm
1.3.35 reset dhcp relay client-information
1.3.36 reset dhcp relay statistics
1.4 DHCP客户端配置命令
1.4.1 dhcp client dad enable
1.4.2 dhcp client dscp
1.4.3 dhcp client identifier
1.4.4 display dhcp client
1.4.5 ip address dhcp-alloc
1.4.6 snmp-agent trap enable dhcp-client
1.5 DHCP Snooping配置命令
1.5.1 dhcp snooping alarm enable
1.5.2 dhcp snooping alarm threshold
1.5.3 dhcp snooping binding database filename
1.5.4 dhcp snooping binding database update interval
1.5.5 dhcp snooping binding database update now
1.5.6 dhcp snooping binding record
1.5.7 dhcp snooping check giaddr
1.5.8 dhcp snooping check mac-address
1.5.9 dhcp snooping check request-message
1.5.10 dhcp snooping client-detect
1.5.11 dhcp snooping deny
1.5.12 dhcp snooping disable
1.5.13 dhcp snooping enable
1.5.14 dhcp snooping enable vlan
1.5.15 dhcp snooping exhaustion trap enable
1.5.16 dhcp snooping information circuit-id
1.5.17 dhcp snooping information enable
1.5.18 dhcp snooping information remote-id
1.5.19 dhcp snooping information strategy
1.5.20 dhcp snooping information vendor-specific
1.5.21 dhcp snooping learning-num-threshold
1.5.22 dhcp snooping log enable
1.5.23 dhcp snooping max-learning-num
1.5.24 dhcp snooping rate-limit
1.5.25 dhcp snooping trap enable (interface view)
1.5.26 dhcp snooping trap enable (system view)
1.5.27 dhcp snooping trap threshold (interface view)
1.5.28 dhcp snooping trap threshold (system view)
1.5.29 dhcp snooping trust
1.5.30 dhcp snooping trust interface
1.5.31 dhcp snooping untrusted-server-record enable
1.5.32 display dhcp snooping alarm packet statistics
1.5.33 display dhcp snooping binding
1.5.34 display dhcp snooping binding database
1.5.35 display dhcp snooping m-lag-statistics
1.5.36 display dhcp snooping m-lag-status
1.5.37 display dhcp snooping information
1.5.38 display dhcp snooping packet statistics
1.5.39 display dhcp snooping trust
1.5.40 reset dhcp snooping alarm packet statistics
1.5.41 reset dhcp snooping binding
1.5.42 reset dhcp snooping m-lag-statistics
1.5.43 reset dhcp snooping packet statistics
1.5.44 snmp-agent trap enable dhcp snooping
1.6 BOOTP客户端配置命令
1.6.1 display bootp client
1.6.2 ip address bootp-alloc
1 DHCP
设备仅在独立运行模式下支持MDC。关于独立运行模式的详细介绍,请参见“虚拟化技术配置指导”中的“IRF”。具体支持配置MDC的机型,请参见“虚拟化技术配置指导”中的“MDC”。
1.1  DHCP公共命令
dhcp client-detect命令用来开启DHCP服务器或DHCP中继的用户下线探测功能。
undo dhcp client-detect命令用来关闭DHCP服务器或DHCP中继的用户下线探测功能。
dhcp client-detect
DHCP服务器或DHCP中继的用户下线探测功能处于关闭状态。
DHCP服务器开启该功能后,当设备上的ARP表项老化时,DHCP服务器认为该表项对应的DHCP客户端已经下线,DHCP服务器会删除对应的IP地址租约。
DHCP中继开启该功能后,当设备上的ARP表项老化时,DHCP中继认为该表项对应的DHCP客户端已经下线,DHCP中继会删除对应的用户地址表项,并通过发Release报文通知DHCP服务器删除下线用户的IP地址租约。
# 开启用户下线探测功能。
[Sysname-Vlan-interface10] dhcp client-detect
1.1.2  dhcp dscp
dhcp dscp命令用来配置DHCP服务器或DHCP中继发送DHCP报文的DSCP优先级。
undo dhcp dscp命令用来恢复缺省情况。
dhcp dscp dscp-value
undo dhcp dscp
DHCP服务器或DHCP中继发送DHCP报文的DSCP优先级为56。
dscp-value:DHCP报文的DSCP优先级,取值范围为0~63。
# 配置DHCP服务器或DHCP中继发送的DHCP报文的DSCP优先级为30。
[Sysname] dhcp dscp 30
1.1.3  dhcp enable
dhcp enable命令用来开启DHCP服务。
undo dhcp enable命令用来关闭DHCP服务。
dhcp enable
undo dhcp enable
DHCP服务处于关闭状态。
只有开启DHCP服务后,其它相关的DHCP配置才能生效。
配置DHCP服务器和DHCP中继时,都需要先开启DHCP服务。
# 开启DHCP服务。
[Sysname] dhcp enable
dhcp flood-protection aging-time命令用来配置DHCP Flood攻击表项老化时间。
undo dhcp flood-protection aging-time命令用来恢复缺省情况。
dhcp flood-protection aging-time time
DHCP Flood攻击表项老化时间为300秒。
time:DHCP Flood攻击表项老化时间,取值范围为30~600,单位为秒。
当某个MAC地址对应的DHCP Flood攻击表项老化时间到达后,设备会删除此表项,之后设备再次收到源MAC地址为此MAC地址的DHCP请求报文时会重新统计接收到的报文数目。
只有配置dhcp flood-protection enable命令开启了DHCP Flood攻击防范功能,本功能才生效。
多次执行本命令,最后一次执行的命令生效。
# 配置DHCP Flood攻击表项老化时间为90秒。
[Sysname] dhcp flood-protection aging-time 90
·     dhcp flood-protection enable
·     dhcp flood-protection threshold
dhcp flood-protection enable命令用来开启DHCP Flood攻击防范功能。
undo dhcp flood-protection enable命令用来关闭DHCP Flood攻击防范功能。
DHCP Flood攻击防范功能处于关闭状态。
VSI视图
本功能仅在LSCM2系列SC主控板、SD系列接口板和SF系列接口板上生效。
本功能仅系统工作模式为专家模式时才能使用。关于系统工作模式的详细介绍,请参见“基础配置指导”中的“设备管理”。
配置DHCP Flood攻击防范功能后,DHCP服务器会根据DHCP报文中的源MAC地址统计收到的DHCP报文数,并创建一个check状态的DHCP防Flood攻击表项。当收到某个MAC地址对应DHCP客户端发送的报文数在指定的时间内达到配置的最大报文数时,DHCP服务器认为受到了该DHCP客户端的攻击,DHCP防Flood攻击表项状态从check状态变成restrain状态,且DHCP服务器丢弃该DHCP客户端发送的DHCP报文。
# 在VSI 10上开启DHCP Flood攻击防范功能。
[Sysname] vsi 10
[Sysname-vsi-10] dhcp flood-protection enable
·     dhcp flood-protection aging-time
dhcp flood-protection threshold命令用来配置DHCP Flood攻击报文速率阈值。
undo dhcp flood-protection threshold命令用来恢复缺省情况。
dhcp flood-protection threshold packet-number milliseconds
DHCP Flood攻击检测的最大报文数为6,检测时间为5000毫秒。
packet-number:DHCP Flood攻击检测最大报文数,取值范围为2~200,单位为个。
milliseconds:DHCP Flood攻击检测时间,取值范围为1000~10000,单位为毫秒。
用户配置本命令来检测DHCP服务器或DHCP中继是否受到基于MAC地址的DHCP Flood攻击。当收到某个MAC地址对应DHCP客户端发送的报文数在配置的指定的时间内超过配置的最大报文数时,DHCP服务器认为收到了该DHCP客户端的攻击。
# 配置DHCP Flood攻击检测最大报文数为2,检测时间为9000毫秒。
[Sysname] dhcp flood-protection threshold 2 9000
dhcp log enable命令用来开启DHCP服务器日志信息功能。
undo dhcp log enable命令用来关闭DHCP服务器日志信息功能。
dhcp log enable
DHCP服务器日志信息功能处于关闭状态。
DHCP服务器日志可以方便管理员定位问题和解决问题。设备生成DHCP日志信息,并将DHCP日志信息交给信息中心模块处理,信息中心模块的配置将决定日志信息的发送规则和发送方向。关于信息中心的详细描述请参见“网络管理和监控配置指导”中的“信息中心”。
# 开启DHCP服务器日志信息功能。
[Sysname] dhcp log enable
1.1.8  dhcp select
dhcp select命令用来配置接口工作在DHCP服务器或DHCP中继模式。
undo dhcp select命令用来取消接口工作在DHCP服务器或DHCP中继模式,即接口将丢弃DHCP客户端发来的DHCP报文。
dhcp select { relay [ proxy ] | server }
undo dhcp select { relay | server }
接口工作在DHCP服务器模式,即当接口收到DHCP客户端发来的DHCP报文时,将从DHCP服务器的地址池中分配地址等参数。
relay:配置接口工作在DHCP中继模式。
proxy:配置接口工作在DHCP代理模式。
server:配置接口工作在DHCP服务器模式。
接口从DHCP服务器模式切换到DHCP中继模式后,设备不会删除IP地址绑定信息,也不会删除相应的授权ARP表项。这些表项可能会与DHCP中继新生成的ARP表项冲突。因此,建议接口从DHCP服务器模式切换到DHCP中继模式之前,通过reset dhcp server ip-in-use命令清除已有的IP地址绑定信息。
当接口工作在DHCP代理模式时,如果收到DHCP客户端发来的DHCP报文,将报文转发给DHCP服务器,由DHCP服务器为DHCP客户端分配地址等参数;如果转发DHCP服务器发来的应答报文,把报文中的DHCP服务器地址修改为中继接口地址。
# 配置VLAN接口2工作在DHCP中继模式。
[Sysname-Vlan-interface2] dhcp select relay
·     dhcp relay server-address
·     dhcp relay source-address
·     dhcp server request-ip-address check
·     dhcp smart-relay enable
·     reset dhcp server ip-in-use
1.2  DHCP服务器配置命令
1.2.1  address range
address range命令用来配置地址池动态分配的IP地址范围。
undo address range命令用来恢复缺省情况。
undo address range
未配置动态分配的IP地址范围。
DHCP地址池视图
start-ip-address:动态分配范围的起始IP地址。
end-ip-address:动态分配范围的结束IP地址。
如果未通过本命令配置地址池动态分配的IP地址范围,则地址池下network命令指定的网段地址都可以分配给DHCP客户端;如果通过本命令配置了地址池动态分配的IP地址范围,则只能从本命令指定的IP地址范围内选择地址分配给客户端。
address range命令和network secondary命令互斥,不能在同一地址池中配置。
address range命令指定的地址范围应该在network命令指定的网段范围内,网段范围外的地址将无法被分配。
# 配置地址池1动态分配的地址范围为192.168.8.1到192.168.8.150。
[Sysname] dhcp server ip-pool 1
[Sysname-dhcp-pool-1] network 192.168.8.1 mask 255.255.255.0
[Sysname-dhcp-pool-1] address range 192.168.8.1 192.168.8.150
·     class
·     dhcp class
·     display dhcp server pool
·     network
1.2.2  bims-server
bims-server命令用来配置DHCP地址池为DHCP客户端分配的BIMS服务器IP地址、端口及共享密钥信息。
undo bims-server命令用来恢复缺省情况。
undo bims-server
未配置DHCP地址池为DHCP客户端分配的BIMS服务器信息。
DHCP地址池视图
ip ip-address:指定BIMS服务器的IP地址。
port port-number:指定BIMS服务器的端口号。port-number为端口号,取值范围为1~65534。
cipher:以密文形式设置密钥。
simple:以明文形式设置密钥,该密钥将以密文方式存储。
string:密钥字符串,区分大小写。明文密钥为1~16个字符的字符串,密文密钥为1~53个字符的字符串。DHCP客户端获取到BIMS服务器的信息后,与BIMS服务器通信时,采用共享密钥对传递的消息进行加密,以保证消息传递的安全性。
# 配置DHCP地址池0为DHCP客户端分配的BIMS服务器的IP地址为1.1.1.1,端口号为80,共享密钥为aabbcc。
[Sysname] dhcp server ip-pool 0
[Sysname-dhcp-pool-0] bims-server ip 1.1.1.1 port 80 sharekey simple aabbcc
1.2.3  bootfile-name
bootfile-name命令用来配置DHCP客户端使用的启动文件名或远程启动文件的HTTP形式URL。
undo bootfile-name命令用来恢复缺省情况。
bootfile-name { bootfile-name | url }
undo bootfile-name
未配置DHCP客户端使用的启动文件名或远程启动文件的HTTP形式URL。
DHCP地址池视图
bootfile-name:启动文件名,为1~63个字符的字符串,区分大小写。
url:远程启动文件的HTTP形式URL,为1~63个字符的字符串,区分大小写。
当启动文件在TFTP服务器上,使用bootfile-name参数指定DHCP客户端使用的启动文件名;当启动文件在HTTP服务器上,使用url参数指定远程启动文件的HTTP形式URL。
# 配置DHCP地址池0为DHCP客户端分配的启动文件名为boot.cfg。
[Sysname-dhcp-pool-0] bootfile-name boot.cfg
# 配置DHCP地址池0为DHCP客户端分配的启动文件的HTTP URL为http://10.1.1.1/boot.cfg。
[Sysname-dhcp-pool-0] bootfile-name http://10.1.1.1/boot.cfg
·     next-server
·     tftp-server domain-name
·     tftp-server ip-address
1.2.4  class ip-pool
class ip-pool命令用来指定DHCP用户类关联的DHCP地址池。
undo class ip-pool命令删除为指定DHCP用户类关联的DHCP地址池。
undo class class-name ip-pool
未指定DHCP用户类关联的DHCP地址池。
DHCP策略视图
class-name:DHCP用户类名称,为1~63个字符的字符串,不区分大小写。
pool-name:DHCP地址池名称,为1~63个字符的字符串,不区分大小写。
对于一个DHCP用户类,在一个DHCP策略中只能关联一个DHCP地址池。
多次执行本命令为同一个DHCP用户类关联不同的DHCP地址池,最后一次执行的命令生效。
# 在DHCP策略1中,配置DHCP用户类test关联DHCP地址池pool1。
[Sysname] dhcp policy 1
[Sysname-dhcp-policy-1] class test ip-pool pool1
·     default ip-pool
·     dhcp policy
·     dhcp server ip-pool
class option-group命令用来配置DHCP地址池下DHCP用户类和DHCP选项组的关联。
undo class option-group命令用来删除DHCP地址池下DHCP用户类和DHCP选项组的关联。
undo class class-name option-group
未配置DHCP地址池的DHCP用户类和DHCP选项组的关联。
DHCP地址池视图
option-group-number:DHCP选项组编号,取值范围为1~32768。
DHCP服务器应答DHCP客户端报文时,首先根据配置顺序逐个匹配通过class option-group命令指定的DHCP用户类。如果匹配成功,则将该用户类对应的选项组中的选项填充到应答报文中;如果同时匹配多个DHCP用户类,且各用户类对应的选项组中有相同编号的选项,以最先匹配到DHCP用户类对应的选项组中的选项为准。
需要注意的是,对于一个DHCP用户类,在一个DHCP地址池中只能指定一个选项组。多次执行本命令为同一个DHCP用户类指定不同的选项组,最后一次执行的命令生效。
# 在DHCP地址池0中,配置DHCP用户类user和DHCP选项组1的关联。
[Sysname-dhcp-pool-0] class user option-group 1
·     dhcp option-group
1.2.6  class range
class range命令用来配置DHCP地址池为指定DHCP用户类动态分配的IP地址范围。
undo class range命令用来删除为指定DHCP用户类动态分配的IP地址范围。
undo class class-name range
未配置为指定DHCP用户类动态分配的IP地址范围。
DHCP地址池视图
class-name:DHCP用户类名称,为1~63个字符的字符串,不区分大小写。如果指定的DHCP用户类不存在,则为该用户类指定的地址范围不能分配给任何DHCP客户端。
DHCP服务器从地址池中选择地址分配给客户端时,首先根据配置顺序逐个匹配通过class range命令指定的DHCP用户类。如果匹配成功,则从为该用户类指定的地址范围内选择地址分配给DHCP客户端;如果该用户类中没有可供分配的地址,则继续匹配下一个用户类;如果所有匹配上的用户类地址范围都没有可供分配的地址,则从公共地址范围中选择地址分配给客户端;如果不匹配任何DHCP用户类,则会从地址池动态分配的IP地址范围(通过address range命令配置)中选择地址分配给DHCP客户端;如果address range命令指定的地址范围内也没有空闲地址,或者未配置address range命令,则地址分配失败,即DHCP服务器无法为DHCP客户端分配地址。
通过本配置可以实现将一个地址池下的地址范围划分成多个地址段,分别分配给属于不同DHCP用户类的DHCP客户端。
class range命令和network secondary命令互斥,不能在同一地址池中配置。
配置class range命令后,只能从class range命令或address range命令指定的地址范围内选择地址分配给客户端。
一个地址池中只能为一个DHCP用户类指定一个地址范围。多次执行本命令为同一个DHCP用户类指定不同的地址范围,最后一次执行的命令生效。
一个地址池中可以为多个不同的DHCP用户类指定地址范围。
class range命令指定的地址范围应该在network命令指定的主网段范围内,主网段范围外的地址将无法被分配。
# 在地址池1中配置为DHCP用户类user动态分配的地址范围为192.168.8.1到192.168.8.150。
[Sysname-dhcp-pool-1] class user range 192.168.8.1 192.168.8.150
·     address range
·     dhcp class
default ip-pool命令用来指定默认DHCP地址池。
undo default ip-pool命令用来恢复缺省情况。
default ip-pool pool-name
未指定默认DHCP地址池。
DHCP策略视图
pool-name:默认DHCP地址池名称,为1~63个字符的字符串,不区分大小写。
若匹配DHCP策略中的所有DHCP用户类失败,当配置了默认DHCP地址池时,则从该地址池中分配IP地址和其他参数;当未配置默认DHCP地址池或默认DHCP地址池中不存在可供分配的地址信息时,IP地址和其他参数分配失败。
在一个DHCP策略视图中,只能配置一个默认DHCP地址池。多次执行本命令,最后一次执行的命令生效。
# 在DHCP策略1中指定默认DHCP地址池pool1。
[Sysname-dhcp-policy-1] default ip-pool pool1
·     class ip-pool
·     dhcp policy
dhcp apply-policy命令用来指定接口引用的DHCP策略。
undo dhcp apply-policy命令用来恢复缺省情况。
dhcp apply-policy policy-name
接口未引用DHCP策略。
policy-name:DHCP策略名称,为1~63个字符的字符串,不区分大小写。
在一个接口上只能引用一条DHCP策略。在同一个接口上多次执行本命令,最后一次执行的命令生效。
# 指定VLAN接口10引用的DHCP策略test。
[Sysname-Vlan-interface10] dhcp apply-policy test
·     dhcp policy
1.2.9  dhcp class
dhcp class命令用来创建DHCP用户类并进入DHCP用户类视图,如果指定的DHCP用户类已存在,则直接进入用户类视图。
undo dhcp class命令用来删除指定的DHCP用户类。
dhcp class class-name
undo dhcp class class-name
不存在DHCP用户类。
class-name:DHCP用户类的名称,为1~63个字符的字符串,不区分大小写。
在DHCP用户类视图下,可以通过if-match命令配置DHCP用户类的匹配规则,根据匹配规则判断DHCP客户端属于的DHCP用户类,从而实现灵活的用户分类策略。
# 创建名称为test的DHCP用户类,并进入DHCP用户类视图。
[Sysname] dhcp class test
[Sysname-dhcp-class-test]
·     address range
·     class ip-pool
·     class option-group
·     class range
·     dhcp policy
·     if-match
dhcp option-group命令用来创建DHCP选项组并进入DHCP选项组视图,如果指定的DHCP选项组已存在,则直接进入DHCP选项组视图。
undo dhcp option-group命令用来删除指定的DHCP选项组。
undo dhcp option-group option-group-number
不存在DHCP选项组。
# 创建DHCP选项组1并进入该选项组视图。
[Sysname] dhcp option-group 1
[Sysname-dhcp-option-group-1]
·     option
1.2.11  dhcp policy
dhcp policy命令用来创建DHCP策略,并进入DHCP策略视图。如果指定的DHCP策略已存在,则直接进入DHCP策略视图。
undo dhcp policy命令用来删除已创建的DHCP策略。
dhcp policy policy-name
undo dhcp policy policy-name
不存在DHCP策略。
在DHCP策略视图下,可以通过class ip-pool命令指定DHCP用户类关联的DHCP地址池,使匹配该DHCP用户类的客户端可以从关联的地址池中获取到IP地址和其他参数。
需要注意的是,需要配置dhcp apply-policy命令在接口上引用DHCP策略后,DHCP策略才能生效。
# 创建DHCP策略test,并进入该DHCP策略视图。
[Sysname] dhcp policy test
[Sysname-dhcp-policy-test]
·     class ip-pool
·     default ip-pool
·     dhcp apply-policy
·     dhcp class
dhcp server always-broadcast命令用来开启DHCP服务器的广播回应报文功能。
undo dhcp server always-broadcast命令用来恢复缺省情况。
DHCP服务器的广播回应报文功能处于关闭状态。DHCP服务器根据请求报文中的广播标志位来决定以广播还是单播的形式发送应答报文。
开启DHCP服务器的广播回应报文功能后,DHCP服务器忽略请求报文中的广播标志位,以广播的形式发送应答报文。
# 开启DHCP服务器的广播回应报文功能。
[Sysname] dhcp server always-broadcast
dhcp server apply ip-pool命令用来指定接口引用的地址池。
undo dhcp server apply ip-pool命令用来恢复缺省情况。
接口未引用地址池。
如果接口上配置了本命令,则接口接收到DHCP请求后,将优先为客户端分配静态绑定的IP地址;如果不存在静态绑定的IP地址,则从引用的地址池中选择IP地址分配给客户端。引用的地址池中不存在可供分配的IP地址时,设备无法为客户端分配IP地址。
接口上配置了dhcp server apply ip-pool命令后,如果接口引用的地址池不存在,则无法为客户端动态分配IP地址。
# 配置VLAN接口2引用DHCP地址池0。
[Sysname-Vlan-interface2] dhcp server apply ip-pool 0
dhcp server bootp ignore命令用来配置DHCP服务器忽略BOOTP请求。
undo dhcp server bootp ignore命令用来恢复缺省情况。
DHCP服务器不会忽略BOOTP请求。
BOOTP客户端申请到的地址的租约是无限期的。在特殊的组网环境中,可能不希望出现无限期的地址租约。此时,可以通过配置DHCP服务器忽略BOOTP请求报文,避免分配无限期的地址租约。
# 配置DHCP服务器忽略BOOTP请求。
[Sysname] dhcp server bootp ignore
dhcp server bootp reply-rfc-1048命令用来开启DHCP服务器回应RFC 1048格式报文功能。
undo dhcp server bootp reply-rfc-1048命令用来关闭DHCP服务器回应RFC 1048格式报文功能。
DHCP服务器回应RFC 1048格式报文功能处于关闭状态。
# 开启DHCP服务器的回应RFC 1048格式报文功能。
[Sysname] dhcp server bootp reply-rfc-1048
dhcp server check mac-address命令用来开启DHCP服务器源MAC检查功能。
undo dhcp server check mac-address命令用来关闭DHCP服务器源MAC检查功能。
DHCP服务器源MAC检查功能处于关闭状态。
开启该功能后,DHCP服务器检查接收到的DHCP请求报文中的chaddr字段和数据帧的源MAC地址字段是否一致。如果一致,则认为该报文合法,继续后续处理;如果不一致,则丢弃该报文。
# 在VLAN接口10上开启DHCP服务器的MAC地址检查功能。
[Sysname-Vlan-interface10] dhcp server check mac-address
dhcp server database filename命令用来指定存储DHCP服务器表项的文件名称。
undo dhcp server database filename命令用来恢复缺省情况。
未指定存储DHCP服务器表项的文件名称。
url url:配置远程目标文件URL,为1~255个字符的字符串,区分大小写,该配置用于远程文件系统模式。此参数中不能包含用户名和密码,和参数username和string配合使用。
username username:配置远程目标文件URL时的用户名,为1~32个字符的字符串,区分大小写。如果未指定本参数,则表示登录远程目标文件URL时无需使用用户名。
cipher:表示以密文方式设置用户密码。
string:密码字符串,区分大小写。明文密码为1~32个字符的字符串,密文密码为1~73个字符的字符串。如果未指定本参数,则表示登录远程目标文件URL时无需使用密码。
存储DHCP服务器表项时,如果设备中还不存在对应名称的文件,则设备会自动创建该文件。
执行本命令后,会立即触发一次表项备份。之后,如果未配置dhcp server database update interval命令,若表项发生变化,默认在300秒之后刷新存储文件;若表项未发生变化,则不再刷新存储文件。如果配置了dhcp server database update interval命令,若表项发生变化,则到达刷新时间间隔后刷新存储文件;若表项未发生变化,则不再刷新存储文件。
参数filename不支持远程目标文件URL,配置远程目标文件URL请使用url、username、string配合使用。
频繁擦写本地存储介质可能会影响存储介质寿命,建议使用远程文件系统模式存储DHCP服务器表项文件。
当进行远程存储时,支持FTP和TFTP协议:
·     当采用FTP或TFTP协议时,服务器地址支持IPv4形式或IPv6形式,并且支持DNS域名方式。服务器地址为IPv6地址形式时需使用方括号(“[”和“]”)引用。配置服务器地址为DNS域名格式时请勿使用方括号引用。
·     当采用FTP协议时,URL采用“ftp://服务器地址[:端口号]/文件路径”的形式,如有用户名和密码请分别使用参数username和参数string进行配置,用户名和密码必须和服务器上的配置一致,如果服务器只对用户名进行认证,则不用输入密码。
·     当采用TFTP协议时,URL采用“tftp://服务器地址[:端口号]/文件路径”的形式。
# 配置存储DHCP服务器表项的文件名为database.dhcp。
[Sysname] dhcp server database filename database.dhcp
# 配置远程存储DHCP服务器表项至IP地址为10.1.1.1的FTP服务器工作目录下,用户名为1,密码为1,文件名为database.dhcp。
[Sysname] dhcp server database filename url ftp://10.1.1.1/database.dhcp username 1 password simple 1
·     dhcp server database update interval
·     dhcp server database update now
·     dhcp server database update stop
dhcp server database update interval命令用来配置刷新DHCP服务器表项存储文件的延迟时间。
undo dhcp server database update interval命令用来恢复缺省情况。
若DHCP服务器表项不变化,则不刷新表项存储文件;若DHCP服务器表项发生变化,默认在300秒后刷新表项存储文件。
执行本命令后,当服务器表项发生变化后,DHCP服务器开始计时,当本命令配置的延迟时间到达后,DHCP服务器会把这个时间段内表项所有的变化信息备份到固化文件中。
如果未通过dhcp server database filename命令指定存储表项的文件,则本命令的配置不会生效。
# 若DHCP服务器表项发生变化,在10分钟后刷新表项存储文件。
[Sysname] dhcp server database update interval 600
·     dhcp server database filename
dhcp server database update now命令用来将当前DHCP服务器表项保存到用户指定的文件中。
本命令只用来触发一次DHCP服务器表项的备份。
# 将当前的DHCP服务器表项保存到文件中。
[Sysname] dhcp server database update now
dhcp server database update stop命令用来终止当前的DHCP服务器表项恢复操作。
本命令只用来触发一次终止DHCP服务器表项的恢复操作。
从固化文件恢复表项的连接超时的最长时间为60分钟,可以通过本命令立刻终止远程恢复。DHCP服务器从固化文件中恢复表项的过程中,DHCP服务器不会学习新的表项。
# 终止当前的DHCP服务器表项恢复操作。
[Sysname] dhcp server database update stop
dhcp server forbidden-ip命令用来配置全局不参与自动分配的IP地址。
undo dhcp server forbidden-ip命令用来取消全局不参与自动分配的IP地址的配置。
undo dhcp server forbidden-ip start-ip-address [ end-ip-address ] [ vpn-instance vpn-instance-name ]
未配置全局不参与自动分配的IP地址。
start-ip-address:不参与自动分配的起始IP地址。
end-ip-address:不参与自动分配的结束IP地址,不能小于start-ip-address。如果未指定本参数,则表示只有一个不参与自动分配的IP地址,即start-ip-address;否则,表示start-ip-address到end-ip-address之间的IP地址均不能参与自动分配。
vpn-instance vpn-instance-name:指定不参与自动分配的IP地址所属的VPN实例。vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。如果未指定本参数,则表示配置的是公网中不参与自动分配的IP地址。
某些服务器占用的IP地址(如网关地址、FTP服务器地址),不能分配给DHCP客户端。通过本命令可以避免这些地址参与自动分配。
如果通过dhcp server forbidden-ip命令将已经静态绑定的IP地址配置为不参与自动分配的地址,则该地址仍然可以分配给静态绑定的用户。
执行undo dhcp server forbidden-ip命令取消不参与自动分配IP地址的配置时,指定的地址/地址范围必须与执行dhcp server forbidden-ip命令时指定的地址/地址范围保持一致。如果配置不参与自动分配的IP地址为某一地址范围,则只能同时取消该地址范围内所有IP地址的配置,不能单独取消其中某个IP地址的配置。
# 配置10.110.1.1到10.110.1.63之间的IP地址不参与地址自动分配。
[Sysname] dhcp server forbidden-ip 10.110.1.1 10.110.1.63
·     forbidden-ip
·     static-bind
dhcp server ip-pool命令用来创建DHCP地址池并进入DHCP地址池视图。如果已经创建了DHCP地址池,则直接进入该地址池视图。
undo dhcp server ip-pool命令用来删除指定的地址池。
dhcp server ip-pool pool-name
undo dhcp server ip-pool pool-name
不存在DHCP地址池。
pool-name:DHCP地址池名称,是地址池的唯一标识,为1~63个字符的字符串,不区分大小写。
在DHCP地址池下,可以配置为DHCP客户端分配的IP地址、网关地址等参数。
# 创建名称为pool1的DHCP地址池。
[Sysname] dhcp server ip-pool pool1
[Sysname-dhcp-pool-pool1]
·     class ip-pool
·     dhcp server apply ip-pool
dhcp server ping packets命令用来配置DHCP服务器发送ICMP回显请求报文的最大数目。
undo dhcp server ping packets命令用来恢复缺省情况。
DHCP服务器发送ICMP回显请求报文的最大数目为1。
number:发送ICMP回显请求报文的最大数目,取值范围为0~10。0表示DHCP服务器将IP地址分配给DHCP客户端之前,不会通过ping操作探测该地址是否冲突。
DHCP服务器的地址探测是通过ping功能实现的,通过检测是否能在指定时间内得到ping响应来判断是否存在地址冲突。DHCP服务器发送目的地址为待分配地址的ICMP回显请求报文。如果在指定时间内收到ICMP回显响应报文,则认为存在地址冲突。DHCP服务器从地址池中选择新的IP地址,并重复上述操作。如果在指定时间内未收到ICMP回显响应报文,则继续发送ICMP回显请求报文,直到发送的ICMP回显请求报文数目达到本命令配置的最大值。如果仍然未收到ICMP回显响应报文,则将地址分配给客户端,从而确保客户端获得的IP地址唯一。
# 配置DHCP服务器最多发送10个ICMP回显请求报文。
[Sysname] dhcp server ping packets 10
·     dhcp server ping timeout
·     display dhcp server conflict
·     reset dhcp server conflict
dhcp server ping timeout命令用来配置DHCP服务器等待ICMP回显响应报文的超时时间。
undo dhcp server ping timeout命令用来恢复缺省情况。
DHCP服务器等待ICMP回显响应报文的超时时间为500毫秒。
milliseconds:等待ICMP回显响应报文的超时时间,取值范围是0~10000,单位为毫秒。0表示DHCP服务器将IP地址分配给DHCP客户端之前,不会通过ping操作探测该地址是否冲突。
DHCP服务器的地址探测是通过ping功能实现的,通过检测是否能在指定时间内得到ping响应来判断是否存在地址冲突。DHCP服务器发送目的地址为待分配地址的ICMP回显请求报文。如果在本命令指定的时间内收到ICMP回显响应报文,则认为存在地址冲突。DHCP服务器从地址池中选择新的IP地址,并重复上述操作。如果在指定时间内未收到ICMP回显响应报文,则继续发送ICMP回显请求报文,直到发送的回显请求报文数目达到最大值。如果仍然未收到ICMP回显响应报文,则将地址分配给客户端,从而确保客户端获取的IP地址唯一。
# 配置DHCP服务器等待ICMP回显响应报文的超时时间为1000毫秒。
[Sysname] dhcp server ping timeout 1000
·     dhcp server ping packets
dhcp server relay information enable命令用来配置DHCP服务器处理Option 82。
undo dhcp server relay information enable命令用来配置DHCP服务器忽略Option 82。
DHCP服务器处理Option 82。
当DHCP服务器收到含有Option 82的报文时,如果DHCP服务器处理Option 82,则将请求报文中的Option 82原样复制到应答报文中;如果DHCP服务器忽略Option 82,则不会在应答报文中携带Option 82。
# 配置DHCP服务器忽略Option 82。
[Sysname] undo dhcp server relay information enable
dhcp server request-ip-address check命令用来配置当DHCP客户端请求的新地址与之前DHCP服务器分配的地址不同或该地址对应的租约不存在时,DHCP服务器回复NAK报文。
undo dhcp server request-ip-address check命令用来恢复缺省情况。
当DHCP客户端请求的新地址与之前使用的地址不同或该地址对应的租约不存在时,DHCP服务器不回复NAK报文。
未开启本功能时,如果DHCP客户端请求的新地址与之前使用的地址不同或该地址对应的租约不存在时,DHCP服务器不回复应答报文。当DHCP服务器上保存的地址租约到期后,DHCP服务器才会应答DHCP客户端的请求并分配新的IP地址。
开启本功能时,如果DHCP客户端请求的新地址与之前使用的地址不同或该地址对应的租约不存在时,DHCP服务器直接回复NAK报文拒绝DHCP客户端的地址请求,DHCP客户端收到NAK报文后,重新申请IP地址。
# 配置当DHCP客户端请求的新地址与之前使用的地址不同或该地址对应的租约不存在时,DHCP服务器直接回复NAK报文的功能。
[Sysname] dhcp server request-ip-address check
·     dhcp select server
display dhcp server conflict命令用来显示DHCP的地址冲突信息。
display dhcp server conflict [ ip ip-address ] [ vpn-instance vpn-instance-name ]
ip ip-address:显示指定IP地址的地址冲突信息。如果未指定本参数,则显示所有的地址冲突信息。
vpn-instance vpn-instance-name:显示指定VPN实例内的地址冲突信息。vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。如果未指定本参数,则表示显示的是公网中的地址冲突信息。
DHCP服务器在下列几种情况下会生成地址冲突信息:
·     DHCP服务器在为客户端分配IP地址前,通过ping操作检测到网络中已有主机使用该地址。
·     DHCP客户端向DHCP服务器发送Decline报文,报告DHCP服务器为其分配的地址存在冲突。
·     DHCP服务器检测到地址池内的可供分配的地址是设备自身的地址。
# 显示所有的地址冲突信息。
<Sysname> display dhcp server conflict
IP address          Detect time
4.4.4.1             Apr 25 16:57:20 2019
4.4.4.2             Apr 25 17:00:10 2019
表1-1 display dhcp server conflict命令显示信息描述表
IP address
发生冲突的IP地址
Detect time
检测到冲突的时间
display dhcp server database命令用来显示DHCP服务器的表项备份信息。
# 显示DHCP服务器的表项备份信息。
<Sysname> display dhcp server database
 Username                :
 Password                :
 Latest write time       :   Feb  8 16:09:53 2014
表1-2 display dhcp server database命令显示信息描述表
File name
存储DHCP服务器表项的文件名称
Username
配置远程目标文件时的用户名
Password
配置远程目标文件时的密码,有配置时显示为”******”
Update interval
定期刷新表项存储文件的刷新时间间隔,单位为秒
Latest write time
最近一次写文件的时间
Status
写文件的状态,即写文件是否成功
·     Writing:正在写文件
·     Last write succeeded.:上一次写文件成功
·     Last write failed.:上一次写文件失败
display dhcp server expired命令用来显示租约过期的地址绑定信息。
display dhcp server expired [ [ ip ip-address ] [ vpn-instance vpn-instance-name ] | pool pool-name ]
ip ip-address:显示指定IP地址的租约过期地址绑定信息。如果未指定本参数,则显示所有IP地址的租约过期地址绑定信息。
vpn-instance vpn-instance-name:显示指定VPN实例内的租约过期的地址绑定信息。vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。如果未指定本参数,则表示显示的是公网中的租约过期的地址绑定信息。
pool pool-name:显示指定地址池中租约过期的地址绑定信息。pool-name表示地址池名称,为1~63个字符的字符串,不区分大小写。如果未指定本参数,则显示所有地址池中的租约过期地址绑定信息。
在DHCP地址池的可用地址分配完后,租约过期的地址将被分配给DHCP客户端。
# 显示所有租约过期的地址绑定信息。
<Sysname> display dhcp server expired
IP address       Client-identifier/Hardware address    Lease expiration
4.4.4.6          3030-3066-2e65-3230-302e-3130-3234    Apr 25 17:10:47 2019
                 -2d45-7468-6572-6e65-7430-2f31
表1-3 display dhcp server expired命令显示信息描述表
IP address
租约过期的IP地址
租约过期的客户端ID或MAC地址
Lease expiration
租约过期的时间
·     reset dhcp server expired
display dhcp server free-ip命令用来显示DHCP地址池的空闲地址信息,即尚未分配给DHCP客户端的IP地址信息。
pool pool-name:显示指定地址池的空闲地址信息。pool-name表示地址池名称,为1~63个字符的字符串,不区分大小写。如果未指定本参数,则显示所有地址池的空闲地址信息。
vpn-instance vpn-instance-name:显示指定VPN实例内的地址池空闲地址信息。vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。如果未指定本参数,则表示显示的是公网中的地址池空闲地址信息。
# 显示所有DHCP地址池的空闲地址信息。
<Sysname> display dhcp server free-ip
Pool name: 1
  Network: 10.0.0.0 mask 255.0.0.0
    IP ranges from 10.0.0.10 to 10.0.0.100
    IP ranges from 10.0.0.105 to 10.0.0.255
  Secondary networks:
    10.1.0.0 mask 255.255.0.0
      IP ranges from 10.1.0.0 to 10.1.0.255
    10.2.0.0 mask 255.255.0.0
      IP Ranges from 10.2.0.0 to 10.2.0.255
Pool name: 2
  Network: 20.1.1.0 mask 255.255.255.0
    IP ranges from 20.1.1.0 to 20.1.1.255
表1-4 display dhcp server free-ip命令显示信息描述表
Pool name
地址池的名称
Network
可分配的地址网段
IP ranges
可分配的地址范围
Secondary networks
可分配的从地址网段
·     address range
·     network
display dhcp server ip-in-use命令用来显示DHCP地址绑定信息。
display dhcp server ip-in-use [ [ ip ip-address ] [ vpn-instance vpn-instance-name ] | pool pool-name ]
ip ip-address:显示指定IP地址的地址绑定信息。如果未指定本参数,则显示所有IP地址的地址绑定信息。
vpn-instance vpn-instance-name:显示指定VPN实例内的DHCP地址绑定信息。vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。如果未指定本参数,则表示显示的是公网中的DHCP地址绑定信息。
pool pool-name:显示指定地址池的地址绑定信息。pool-name表示地址池名称,为1~63个字符的字符串,不区分大小写。如果未指定本参数,则显示所有地址池的地址绑定信息。
当DHCP服务器作为DHCP客户端的网关设备时,DHCP服务器上记录的该DHCP客户端的地址绑定信息才会提供给其他安全特性使用。
需要注意的是,如果租约的截止时间超过2100年,则显示为After 2100。
# 显示所有DHCP地址绑定信息。
<Sysname> display dhcp server ip-in-use
IP address       Client-identifier/    Lease expiration      Type
                 Hardware address
10.1.1.1         4444-4444-4444        Not used              Static(F)
10.1.1.2         3030-3030-2e30-3030-  May 1 14:02:49 2015   Auto(C)
                 662e-3030-3033-2d45-
                 7468-6572-6e65-74
10.1.1.3         1111-1111-1111        After 2100            Static(C)
表1-5 display dhcp server ip-in-use命令显示信息描述表
IP address
分配给DHCP客户端的IP地址
客户端ID或客户端的硬件地址
Lease expiration
租约到期时间,取值包括:
·     具体的时间值(如May 1 14:02:49 2015):表示租约在该时间到期
·     Not used:表示静态绑定的地址尚未分配给特定客户端
·     Unlimited:表示租约为无限长
·     After 2100:表示租约过期时间超过2100年
地址绑定的类型,取值包括:
·     Static(F):表示尚未分配给客户端的静态绑定,即静态无效绑定
·     Static(O):服务器从地址池选择静态绑定的IP地址,并发送DHCP-OFFER报文为客户端提供该IP地址后产生该类型的地址绑定信息,即静态临时绑定
·     Static(C):表示已经分配给客户端的静态绑定,即静态正式绑定
·     Auto(O):表示动态绑定的临时租约,即从地址池中动态选择IP地址,并发送DHCP-OFFER报文为客户端提供该IP地址后,产生的租约
·     Auto(C):表示动态绑定的正式租约,即从地址池中动态选择IP地址,并发送DHCP-ACK报文成功将该IP地址分配给客户端后,产生的租约
display dhcp server pool命令用来显示DHCP地址池的信息。
display dhcp server pool [ pool-name | vpn-instance vpn-instance-name ]
pool-name:显示指定地址池的信息。pool-name表示地址池名称,为1~63个字符的字符串,不区分大小写。如果未指定本参数,则显示所有地址池的信息。
vpn-instance vpn-instance-name:显示指定VPN实例内的DHCP地址池信息。vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。如果未指定本参数,则表示显示的是公网中的DHCP地址池信息。
# 显示所有DHCP地址池的信息。
<Sysname> display dhcp server pool
Pool name: 0
  Network 20.1.1.0 mask 255.255.255.0
  class a range 20.1.1.50 20.1.1.60
  bootfile-name abc.cfg
  dns-list 20.1.1.66 20.1.1.67 20.1.1.68
  domain-name www.aabbcc.com
  bims-server ip 192.168.0.51 sharekey cipher $c$3$K13OmQPi791YvQoF2Gs1E+65LOU=
  option 2 ip-address 1.1.1.1
  expired day 1 hour 2 minute 3 second 0
  IP-in-use threshold 100
Pool name: 1
  Network 20.1.2.0 mask 255.255.255.0
  secondary networks:
    20.1.3.0 mask 255.255.255.0
    20.1.4.0 mask 255.255.255.0
  bims-server ip 192.168.0.51 port 50 sharekey cipher $c$3$K13OmQPi791YvQoF2Gs1E+65LOU=
  forbidden-ip 20.1.1.22 20.1.1.36 20.1.1.37
  forbidden-ip 20.1.1.22 20.1.1.23 20.1.1.24
  gateway-list 20.1.1.1 20.1.1.2 20.1.1.4
  nbns-list 20.1.1.5 20.1.1.6 20.1.1.7
  netbios-type m-node
  expired day 1 hour 0 minute 0 second 0
Pool name: 2
  Network 20.1.3.0 mask 255.255.255.0
  address range 20.1.3.1 to 20.1.3.15
  class departmentA range 20.1.3.20 to 20.1.3.29
  class departmentB range 20.1.3.30 to 20.1.3.40
  next-server 20.1.3.33
  tftp-server domain-name www.example.org.cn
  tftp-server ip-address 192.168.0.120
  voice-config ncp-ip 20.1.3.2
  voice-config as-ip 20.1.3.5
  voice-config voice-vlan 3 enable
  voice-config fail-over 20.1.3.6 123*
  option 2 ip-address 20.1.3.10
Pool name: 3
  static bindings:
    ip-address 10.10.1.2 mask 255.0.0.0
      hardware-address 00e0-00fc-0001 ethernet
    ip-address 10.10.1.3 mask 255.0.0.0
      client-identifier aaaa-bbbb
  expired unlimited
表1-6 display dhcp server pool命令显示信息描述表
Pool name
地址池的名称
Network
可分配的地址网段
secondary networks
可分配的从地址网段
address range
可分配的地址范围
为指定DHCP用户类分配的地址范围
static bindings
静态绑定的IP地址、硬件地址或客户端ID
option
自定义的DHCP选项
expired
租约期限,其后数值的单位分别为天、小时、分钟和秒
IP-in-use threshold
IP地址池地址使用率告警门限阈值,单位为百分比
bootfile-name
为DHCP客户端分配的启动文件名
dns-list
为DHCP客户端分配的DNS服务器地址
domain-name
为DHCP客户端分配的域名后缀
bims-server
forbidden-ip
DHCP地址池中不参与自动分配的IP地址
gateway-list
为DHCP客户端分配的网关地址
nbns-list
为DHCP客户端分配的WINS服务器地址
netbios-type
为DHCP客户端分配的NetBIOS节点类型
next-server
为DHCP客户端分配的下一个提供服务的服务器IP地址
为DHCP客户端分配的TFTP服务器名
为DHCP客户端分配的TFTP服务器地址
voice-config ncp-ip
为DHCP客户端分配的网络呼叫处理器的地址
voice-config as-ip
为DHCP客户端分配的备用服务器的地址
为DHCP客户端分配的语音VLAN
为DHCP客户端分配的自动故障转移呼叫路由
display dhcp server statistics命令用来显示DHCP服务器的统计信息。
pool pool-name:显示指定地址池的统计信息。pool-name表示地址池名称,为1~63个字符的字符串,不区分大小写。如果未指定本参数,则显示所有地址池的统计信息。
vpn-instance vpn-instance-name:显示指定VPN实例内的DHCP服务器的统计信息。vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。如果未指定本参数,则表示显示的是公网中的DHCP服务器的统计信息。
# 显示DHCP服务器的统计信息。
<Sysname> display dhcp server statistics
    Pool number:                       1
    Pool utilization:                  0.39%
    Bindings:
      Automatic:                       1
      Manual:                          0
      Expired:                         0
    Conflict:                          1
    Messages received:                10
      DHCPDISCOVER:                    5
      DHCPREQUEST:                     3
      DHCPDECLINE:                     0
      DHCPRELEASE:                     2
      DHCPINFORM:                      0
      BOOTPREQUEST:                    0
    Messages sent:                     6
      DHCPOFFER:                       3
      DHCPACK:                         3
      DHCPNAK:                         0
      BOOTPREPLY:                      0
    Bad Messages:                      0
表1-7 display dhcp server statistics命令显示信息描述表
Pool number
地址池的数目,显示指定地址池的统计信息时无此字段
Pool utilization
地址池利用率
·     显示所有DHCP租约统计信息时,表示所有地址池的总体利用率
·     显示指定地址池的租约统计信息时,表示该地址池的利用率
Bindings
各种状态的地址绑定数,包括:
·     Automatic:动态分配的IP地址绑定数
·     Manual:手工绑定的IP地址绑定数
·     Expired:租约过期的IP地址绑定数
Conflict
冲突地址的总数,显示指定地址池的统计信息时无此字段
Messages received
DHCP服务器接收到DHCP客户端发送的报文数,包括:
·     DHCPDISCOVER
·     DHCPREQUEST
·     DHCPDECLINE
·     DHCPRELEASE
·     DHCPINFORM
·     BOOTPREQUEST
显示指定地址池的统计信息时无此类字段
Messages sent
DHCP服务器发给DHCP客户端的报文数,包括:
·     DHCPOFFER
·     DHCPACK
·     DHCPNAK
·     BOOTPREPLY
显示指定地址池的统计信息时无此类字段
Bad Messages
错误信息数,显示指定地址池的统计信息时无此类字段
·     reset dhcp server statistics
1.2.34  dns-list
dns-list命令用来配置DHCP地址池为DHCP客户端分配的DNS服务器地址。
undo dns-list命令用来删除DHCP地址池为DHCP客户端分配的DNS服务器地址。
dns-list ip-address&<1-8>
undo dns-list [ ip-address&<1-8> ]
未配置DHCP地址池为DHCP客户端分配的DNS服务器地址。
DHCP地址池视图
ip-address&<1-8>:DNS服务器的IP地址。&<1-8>表示最多可以输入8个IP地址,每个IP地址之间用空格分隔。
多次执行该命令,最后一次执行的命令生效。
执行undo dns-list命令时,如果未指定任何参数,则删除DHCP地址池中的所有DNS服务器地址。
# 配置DHCP地址池0为DHCP客户端分配的DNS服务器地址为10.1.1.254。
[Sysname-dhcp-pool-0] dns-list 10.1.1.254
1.2.35  domain-name
domain-name命令用来配置DHCP地址池为DHCP客户端分配的域名。
undo domain-name命令用来恢复缺省情况。
domain-name domain-name
undo domain-name
未配置DHCP地址池为DHCP客户端分配的域名。
DHCP地址池视图
domain-name:DHCP客户端的域名,为1~50个字符的字符串,区分大小写。
# 配置DHCP地址池0为DHCP客户端分配的域名为example.com。
[Sysname-dhcp-pool-0] domain-name example.com
exhaustion log enable命令用来配置当IP地址池的可分配地址资源耗尽或资源恢复时,系统生成日志信息。
undo exhaustion log enable命令用来恢复缺省情况。
当IP地址池的可分配地址资源耗尽时,系统不会生成日志信息。
IP地址池视图
开启本功能后,当IP地址池中可分配的地址资源耗尽时,系统将生成DHCP日志信息,并交给信息中心模块处理,信息中心模块的配置将决定日志信息的发送规则和发送方向。关于信息中心的详细描述请参见“网络管理和监控配置指导”中的“信息中心”。
IP地址池中地址使用率的计算方式为:地址池中地址使用率=(总地址数—未分配地址数)/总地址数。当IP地址池中地址使用率重新下降到低于90%时,系统也会生成日志信息通知管理员。
如果通过ip-in-use threshold命令配置的地址使用率告警门限阈值为100%,则当IP地址池中地址资源耗尽或者重新下降到低于90%时,系统只会生成告警信息,不会生成日志信息。
# 在IP地址池pool1中,配置当地址池的可分配地址资源耗尽时,系统生成日志信息。
[Sysname-dhcp-pool-pool1] exhaustion log enable
·     ip-in-use threshold
exhaustion trap enable命令用来开启IP地址池资源耗尽告警功能。
undo exhaustion trap enable命令关闭IP地址池资源耗尽告警功能。
地址池资源耗尽告警功能处于开启状态。
IP地址池视图
IP地址中地址使用率的计算方式为:地址池中地址使用率=(总地址数-未分配地址数)/总地址数,开启地址池资源耗尽告警功能后,当地址池中地址使用率达到100%,即资源耗尽时,设备会生成告警信息提示管理员地址已耗尽。
只有开启DHCP服务器的告警功能(通过snmp-agent trap enable dhcp server address-exhaust命令)后,本命令才能生效。
使用IP地址池进行地址分配时,snmp-agent trap enable dhcp server address-exhaust命令会开启各个地址池的资源耗尽告警功能,为了减少告警信息的生成,请使用undo exhaustion trap enable命令关闭地址池资源耗尽告警功能。
# 关闭地址池pool1的资源耗尽告警功能。
[Sysname-dhcp-pool-pool1] undo exhaustion trap enable
·     snmp-agent trap enable dhcp server
1.2.38  expired
expired命令用来配置DHCP地址池中分配的IP地址的租约有效期限。
undo expired命令用来恢复缺省情况。
expired { day day [ hour hour [ minute minute [ second second ] ] ] | unlimited }
undo expired
DHCP地址池中IP地址的租约有效期限为1天。
DHCP地址池视图
day day:指定租约过期的天数,day取值范围为0~365。
hour hour:指定租约过期的小时数,hour取值范围为0~23。如果未指定本参数,则指定过期的小时数为0。
minute minute:指定租约过期的分钟数,minute取值范围为0~59。如果未指定本参数,则指定过期的分钟数为0。
second second:指定租约过期的秒数,second取值范围为0~59。如果未指定本参数,则指定过期的秒数为0。
unlimited:有效期限为无限长(实际上系统限定约为136年)。
DHCP服务器从DHCP地址池中选择IP地址分配给DHCP客户端时,会同时将该地址池中IP地址的租约有效期限通知给DHCP客户端。在租约有效期限到达之前,DHCP客户端需要进行续约申请。如果续约成功,则DHCP客户端可以继续使用该IP地址。否则,租约有效期限到达后,DHCP客户端不能再继续使用该IP地址,并且DHCP服务器会将该地址添加到过期租约信息中。
# 配置地址池0的IP地址租约有效期为1天2小时3分4秒。
[Sysname-dhcp-pool-0] expired day 1 hour 2 minute 3 second 4
·     display dhcp server expired
1.2.39  forbidden-ip
forbidden-ip命令用来配置地址池中不参与自动分配的IP地址。
undo forbidden-ip命令用来取消地址池中不参与自动分配的IP地址的配置。
forbidden-ip ip-address&<1-8>
undo forbidden-ip [ ip-address&<1-8> ]
未配置地址池中不参与自动分配的IP地址。
DHCP地址池视图
ip-address&<1-8>:地址池中不参与自动分配的IP地址。&<1-8>表示最多可以输入8个IP地址,每个IP地址之间用空格分隔。
在DHCP地址池视图下通过forbidden-ip命令配置不参与自动分配的IP地址后,只有当前的地址池不能分配这些IP地址,其他地址池仍然可以分配这些IP地址。
多次执行forbidden-ip命令,可以配置多个不参与自动分配的IP地址。每个地址池最多能配置4096个地址。
执行undo forbidden-ip命令时,如果未指定任何参数,则删除所有不参与自动分配的IP地址。
# 配置DHCP地址池0中不参与自动分配的IP地址为192.168.1.3和192.168.1.10。
[Sysname-dhcp-pool-0] forbidden-ip 192.168.1.3 192.168.1.10
·     dhcp server forbidden-ip
1.2.40  gateway-list
gateway-list命令用来配置DHCP服务器为DHCP客户端分配的网关地址。
undo gateway-list命令用来删除DHCP服务器为DHCP客户端分配的网关地址。
gateway-list ip-address&<1-63> [ export-route ]
undo gateway-list [ ip-address&<1-63> ] [ export-route ]
DHCP地址池、DHCP从网段下均未配置为DHCP客户端分配的网关地址。
DHCP地址池视图
DHCP从网段视图
ip-address&<1-63>:网关的IP地址。&<1-63>表示最多可以输入63个IP地址,每个IP地址之间用空格分隔。网关地址需要和DHCP客户端在同一个网段中。
export-route:将网关列表信息下发给地址管理,通过应答客户端的ARP请求,即可实现对不同类型的业务流量的引导。如果未指定本参数,则不将网关列表信息下发给地址管理。
DHCP地址池视图下执行gateway-list命令,配置的是为地址池中所有DHCP客户端分配的网关地址。如果用户需要为地址池下某个从网段的DHCP客户端分配其它的网关地址,可以在地址池的从网段视图下执行gateway-list命令。如果在地址池视图和从网段视图下都配置了网关地址,则优先将从网段视图下配置的网关地址分配给从网段的DHCP客户端。
执行undo gateway-list命令时,如果未指定任何参数,则删除所有配置的网关地址。
# 配置DHCP地址池0为DHCP客户端分配的网关地址为10.1.1.1。
[Sysname-dhcp-pool-0] gateway-list 10.1.1.1
1.2.41  if-match
if-match命令用来配置DHCP用户类的匹配规则。
undo if-match命令用来删除DHCP用户类的匹配规则。
未配置DHCP用户类的匹配规则。
DHCP用户类视图
hardware-address hardware-address:指定匹配规则的硬件地址。hardware-address表示客户端的硬件地址,为4~39个字符的字符串,字符串只能包含十六进制数和“-”,且形式为H-H-H,除最后一个H表示2位或4位十六进制数外,其他均表示4位十六进制数。例如:aabb-ccdd-ee为有效的硬件地址,aabb-c-dddd和aabb-cc-dddd为无效的客户端硬件地址。
mask hardware-address-mask:指定匹配规则的硬件地址掩码。长度需要与hardware-address保持一致。
option option-code:DHCP选项的数值,取值范围为1~254。option-code用于指定匹配DHCP客户端时从DHCP报文中获取哪个选项。
ascii ascii-string:指定用来匹配报文中指定选项的内容。ascii-string为1~128个字符的ACSII字符串。
offset offset:指定匹配DHCP客户端时获取选项内容的起始位置。offset为选项内容偏移量,取值范围为0~254,单位为字节。如果未指定本参数,则表示从选项值第一字节开始匹配整个选项的内容。
partial:指定部分匹配,即只要报文中的选项内容中包含指定的hex-string或ascii-string,即认为匹配通过。
length length:指定匹配DHCP客户端时获取选项内容的长度。length为选项内容的长度,取值范围为1~128,单位为字节。指定的选项内容长度必须和hex-string长度相同。
relay-agent gateway-address:指定匹配报文中的giaddr字段的内容。gateway-address为IP地址,为点分十进制形式。
DHCP服务器通过将DHCP客户端发送的报文与本命令配置的规则匹配,来判断DHCP客户端属于的DHCP用户类。DHCP用户类视图下通过多次执行if-match命令,可以配置多条匹配规则。只要任意一条规则匹配成功,就认为该DHCP客户端属于该用户类。
在同一用户类视图下配置匹配规则时:
·     多次执行相同rule-number的命令,如果规则类型(包括匹配option、relay-agent或hardware address)相同,最后一次执行的命令生效;如果规则类型不同,则新的配置和已有配置会共存。建议不同类型的规则不要使用同一个rule-number。
·     不同rule-number的匹配规则内容不能完全相同。
将报文与某一条if-match hardware-address命令配置的规则匹配的方式为:
·     匹配硬件地址类型,目前只支持以太类型的硬件地址(即MAC地址)匹配,非以太类型的硬件地址均会匹配失败。
·     如果报文中的客户端硬件地址与配置的客户端硬件地址及硬件地址掩码匹配,则认为匹配成功。否则,匹配失败。
·     匹配时报文中的客户端硬件地址长度与配置规则中的硬件地址长度一致时才进行匹配,否则直接认为不匹配。如匹配规则为if-match rule 1 hardware-address 0094-0000 mask ffff-0000,需匹配硬件地址长度为4字节的用户;若报文中客户端硬件地址长度为6字节(比如0094-0000-0010),则认为匹配失败。
·     匹配硬件地址时,可以配置不连续匹配的硬件地址,如匹配规则为if-match rule 1 hardware-address 0094-0000-1100 mask ffff-0000-ff00,则匹配硬件地址为0094-xxxx-11xx(x代表变量)的报文。
·     如果规则中只指定了option-code参数,则只要报文中包括该选项,就认为匹配成功。否则,匹配失败。
·     如果规则中只指定了option-code和hex-string/ascii-string参数,则报文中指定选项的值从第1位开始的部分与hex-string/ascii-string相同时,认为匹配成功。否则,匹配失败。
·     如果规则中指定了option-code、ascii-string和offset参数,则将指定选项的值的第offset+1位到最后一位的内容与acsii-string比较,二者相同时,认为匹配成功。否则,匹配失败。
·     如果规则中指定了option-code、hex-string、offset和length参数,则将指定选项值的第offset+1位到offset+length位的内容与hex-string比较,二者相同时,认为匹配成功。否则,匹配失败。
·     如果规则中指定了option-code、hex-string和mask参数,则将指定选项值的第1位到mask长度位的内容与mask进行与运算,将结果与hex-string与mask与运算的结果比较,二者相同时,认为匹配成功。否则,匹配失败。
·     如果规则中指定了option-code、hex-string/ascii-string和partial参数,则选项内容内包含了指定的hex-string/ascii-string,就认为匹配成功。否则,匹配失败。例如匹配字段为abc,那xabc、xyzabca、xabcyz和abcxyz均认为匹配通过。
将报文与某一条if-match relay-agent命令配置的规则匹配的方式是只要报文中的giaddr字段和指定的gateway-address一致时,认为匹配成功。否则,匹配失败。
# 配置DHCP用户类exam的匹配规则,匹配规则编号1,匹配硬件地址0094-0000-0101,硬件掩码长度为ffff-0000-0000。
<Sysname> syatem-view
[Sysname] dhcp class exam
[Sysname-dhcp-class-exam] if-match rule 1 hardware-address 0094-0000-0101 mask ffff-0000-0000
# 配置DHCP用户类exam的匹配规则,匹配规则编号2,报文中包含Option 82。
[Sysname-dhcp-class-exam] if-match rule 2 option 82
# 配置DHCP用户类exam的匹配规则,匹配规则编号3,报文中包含Option 82,并且该选项的十六进制数第四个字节的最高位为1。
[Sysname-dhcp-class-exam] if-match rule 3 option 82 hex 00000080 mask 00000080
# 配置DHCP用户类exam的匹配规则,匹配规则编号4,报文中包含Option 82,并且该选项的前三个字节为十六进制数13ae92。
[Sysname-dhcp-class-exam] if-match rule 4 option 82 hex 13ae92 offset 0 length 3
# 配置DHCP用户类exam的匹配规则,匹配规则编号5,报文中包含Option 82,并且该选项内容中包含指定的十六进制数13ae。
[Sysname-dhcp-class-exam] if-match rule 5 option 82 hex 13ae partial
# 配置DHCP用户类exam的匹配规则,匹配规则编号6,报文中包含的giaddr字段值为10.1.1.1。
[Sysname-dhcp-class-exam] if-match rule 6 relay-agent 10.1.1.1
·     dhcp class
ip-in-use threshold命令用来设置地址池使用率告警门限阈值。
undo ip-in-use threshold命令用来恢复缺省情况。
地址池使用率告警门限阈值为100%。
DHCP地址池视图
threshold-value:地址池使用率告警阈值,为百分比形式,取值范围为0~100。比如若设置为80,表示地址池使用率超过80%时,系统会生成告警信息。
执行ip-in-use threshold命令设置地址池使用率告警阈值,在地址池中地址使用率超过阈值时,系统会生成告警信息提醒管理员进行地址池规划,避免因为地址池中地址资源耗尽,后续用户不能上线。
在同一个视图下多次执行本命令,最后一次执行的命令生效。
系统将告警信息发送给信息中心,通过设置信息中心的参数,最终决定日志信息的输出规则(即是否允许输出以及输出方向)。有关信息中心参数配置请参见“网络管理和监控配置指导”中的“信息中心”。
# 配置地址池p1使用率告警门限阈值为85%。
[Sysname] dhcp server ip-pool p1
[Sysname-dhcp-pool-p1] ip-in-use threshold 85
1.2.43  nbns-list
nbns-list命令用来配置DHCP地址池为DHCP客户端分配的WINS服务器地址。
undo nbns-list命令用来删除DHCP地址池为DHCP客户端分配的WINS服务器地址。
nbns-list ip-address&<1-8>
undo nbns-list [ ip-address&<1-8> ]
未配置DHCP地址池为DHCP客户端分配的WINS服务器地址。
DHCP地址池视图
ip-address&<1-8>:WINS服务器的IP地址。&<1-8>表示最多可以输入8个IP地址,每个IP地址之间用空格分隔。
执行undo nbns-list命令时,如果未指定任何参数,则删除DHCP地址池中的所有WINS服务器地址。
# 配置DHCP地址池0为DHCP客户端分配WINS服务器地址为10.1.1.1。
[Sysname-dhcp-pool-0] nbns-list 10.1.1.1
·     netbios-type
1.2.44  netbios-type
netbios-type命令用来配置DHCP地址池为DHCP客户端分配的NetBIOS节点类型。
undo netbios-type命令用来恢复缺省情况。
undo netbios-type
未配置DHCP地址池为DHCP客户端分配的NetBIOS节点类型。
DHCP地址池视图
b-node:b类节点,“b”代表广播(broadcast),此类节点采用广播方式获取主机名和IP地址之间的映射。源节点通过发送带有目的节点主机名的广播报文来获取目的节点的IP地址,目的节点收到广播报文后,就将自己的IP地址返回给源节点。
h-node:h类节点,“h”代表混合(hybrid),是具备“端到端”通信机制的b类节点。此类节点首先发送单播报文与WINS服务器通信来获取映射关系,如果未获取到,再发送广播报文来获取映射关系。
m-node:m类节点,“m”代表混合(mixed),是具有部分广播特性的p类节点。此类节点首先发送广播报文来获取映射关系,如果未获取到,则再发送单播报文与WINS服务器通信来获取映射关系。
p-node:p类节点,“p”代表端到端(peer-to-peer),即此类节点采用发送单播报文与WINS服务器通信的方式获取映射关系。源节点给WINS服务器发送单播报文,WINS服务器收到单播报文后,返回源节点请求的目的节点名所对应的IP地址。
# 配置DHCP地址池0为DHCP客户端分配的NetBIOS节点类型为p类节点。
[Sysname-dhcp-pool-0] netbios-type p-node
·     nbns-list
1.2.45  network
network命令用来配置DHCP地址池动态分配的IP地址网段。
undo network命令用来删除已经创建的用于动态分配的IP地址网段。
network network-address [ mask-length | mask mask ] [ secondary ] [ export-route ]
undo network network-address [ mask-length | mask mask ] [ secondary ]
未配置动态分配的IP地址网段,即没有可供分配的IP地址。
DHCP地址池视图
network-address:用于动态分配的网段地址。未指定掩码长度和掩码时,表示采用自然掩码。
mask-length:IP地址的网络掩码长度,取值范围为1~30。
mask mask:IP地址的网络掩码,mask为点分十进制形式。
secondary:指定配置的网段为从网段。如果未指定本参数,则表示配置的网段为主网段。主网段中的地址分配完之后,DHCP服务器可以在从网段中选择地址分配给DHCP客户端。
export-route:将网段信息下发给路由管理,由路由管理发布指定网段信息的路由。引导指定网段的下行数据流量。如果未指定本参数,则不会将网段信息下发给路由管理。
执行本命令时如果指定了secondary参数,则会进入从网段视图。用户可以在该视图下通过gateway-list命令配置为从网段的DHCP客户端分配的网关地址。
每个DHCP地址池中只能配置一个主网段,多次执行network命令配置主网段,最后一次执行的命令生效。
每个DHCP地址池中最多可以配置32个从网段。
一个DHCP地址池中各个主、从网段的网络号和掩码不能完全相同。
network secondary命令与address range、class range命令互斥,不能在同一地址池中配置。
修改或删除network配置,会导致该地址池下现有的已分配地址被删除。
配置network export-route命令可以用来发布网段路由,多次执行本命令,最后一次执行的命令生效。
# 配置DHCP地址池0动态分配的主地址网段为192.168.8.0/24,从地址网段为192.168.10.0/24。
[Sysname-dhcp-pool-0] network 192.168.8.0 mask 255.255.255.0
[Sysname-dhcp-pool-0] network 192.168.10.0 mask 255.255.255.0 secondary
[Sysname-dhcp-pool-0-secondary]
·     gateway-list
1.2.46  next-server
next-server命令用来配置DHCP地址池为DHCP客户端分配的下一个提供服务的服务器IP地址。
undo next-server命令用来恢复缺省情况。
next-server ip-address
undo next-server
未配置DHCP地址池为DHCP客户端分配的下一个提供服务的服务器IP地址。
DHCP地址池视图
ip-address:下一个提供服务的服务器IP地址。
为DHCP客户端分配的下一个提供服务的服务器IP地址,是在DHCP客户端启动过程中,在获取到IP地址后,用于获取其他启动数据的服务器地址。例如,TFTP服务器地址。
# 配置DHCP地址池0为DHCP客户端分配的下一个提供服务的服务器IP地址为10.1.1.254。
[Sysname-dhcp-pool-0] next-server 10.1.1.254
1.2.47  option
option命令用来自定义DHCP选项。
undo option命令用来删除自定义的DHCP选项。
undo option code
未自定义DHCP选项。
DHCP地址池视图
DHCP选项组视图
code:选项的数值,取值范围为2~254,不包括50~54、56、58、59、61和82。
ascii ascii-string:指定选项内容为配置的ASCII字符串。ascii-string为1~255个字符的ASCII字符串,区分大小写。
hex hex-string:指定选项内容为配置的十六进制数。hex-string为十六进制数,位数的取值范围为2~256之间的偶数。
ip-address ip-address&<1-8>:指定选项内容为配置的IP地址。&<1-8>表示最多可以输入8个IP地址,每个IP地址之间用空格分隔。
通过执行本命令,可以配置编号为code的DHCP选项内容为指定的ASCII字符串、十六进制数或IP地址,即采用指定的内容来填充DHCP应答报文中编号为code的选项,以便将指定的选项内容分配给客户端。
本命令为DHCP服务器提供了灵活的选项配置方式,使得DHCP服务器可以为DHCP客户端提供更加丰富的选项内容。在以下情况下,可以使用本命令自定义DHCP选项:
·     随着DHCP的不断发展,新的DHCP选项会陆续出现。通过自定义DHCP选项,可以方便地添加新的DHCP选项。
·     有些选项的内容,RFC中没有统一规定。厂商可以根据需要定义选项的内容,如Option 43。通过自定义DHCP选项,可以为DHCP客户端提供厂商指定的信息。
·     设备上只提供了有限的选项配置命令(如gateway-list、dns-list命令),对于没有专门命令来配置的DHCP选项,可以通过option命令配置选项内容。例如,可以通过option 4 ip-address 1.1.1.1命令指定为DHCP客户端分配的时间服务器地址为1.1.1.1。
·     扩展已有的DHCP选项。当前已提供的方式无法满足用户需求时(比如通过dns-list命令最多只能配置8个DNS服务器地址,如果用户需要配置的DNS服务器地址数目大于8,则该命令无法满足需求),可以通过自定义DHCP选项的方式进行扩展。
有些DHCP选项既可以通过专门的命令来配置,也可以通过option命令来配置。例如,Option 6(DNS服务器地址选项)既可以通过dns-list命令配置,也可以通过option 6命令配置。如果同时通过上述两种方式配置了这些选项,则在填充DHCP应答报文的选项时,优先选择专门命令的配置。如果未通过专门命令来配置,则采用option命令配置的内容填充选项。
# 日志服务器选项的编号为7。在DHCP地址池0中配置为DHCP客户端分配的日志服务器地址为2.2.2.2。
[Sysname-dhcp-pool-0] option 7 ip-address 2.2.2.2
reset dhcp server conflict命令用来清除DHCP的地址冲突信息。
ip ip-address:清除指定IP地址的冲突信息。如果未指定本参数,则清除所有地址的冲突信息。
vpn-instance vpn-instance-name:清除指定VPN实例内的地址冲突信息。vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。如果未指定本参数,则表示清除的是公网中的地址冲突信息。
出现冲突地址,一般是由于网络配置不合理,动态分配的地址和网络中静态配置的地址冲突而产生的。在合理调整网络配置,不再存在冲突的情况后,原来的冲突地址可能不再冲突,可以被重新分配。此时,通过本命令,清除检测到的冲突地址,则该地址可以被重新分配。
# 清除全部地址冲突信息。
<Sysname> reset dhcp server conflict
reset dhcp server expired命令用来清除租约过期的地址绑定信息。
reset dhcp server expired [ [ ip ip-address ] [ vpn-instance vpn-instance-name ] | pool pool-name ]
ip ip-address:清除指定IP地址的租约过期地址绑定信息。如果未指定本参数,则清除所有IP地址的租约过期地址绑定信息。
vpn-instance vpn-instance-name:清除指定VPN实例内的租约过期的地址绑定信息。vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。如果未指定本参数,则表示清除的是公网中的租约过期的地址绑定信息。
pool pool-name:清除指定地址池中租约过期的地址绑定信息。pool-name表示地址池名称,为1~63个字符的字符串,不区分大小写。如果未指定本参数,则清除所有地址池的租约过期地址绑定信息。
# 清除所有租约过期的地址绑定信息。
<Sysname> reset dhcp server expired
reset dhcp server ip-in-use命令用来清除DHCP的正式绑定和临时绑定信息。
ip ip-address:清除指定IP地址的正式绑定和临时绑定信息。如果未指定本参数,则清除所有IP地址的正式绑定和临时绑定信息。
vpn-instance vpn-instance-name:清除指定VPN实例内的正式绑定和临时绑定信息。vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。如果未指定本参数,则表示清除的是公网中的正式绑定和临时绑定信息。
pool pool-name:清除指定地址池的正式绑定和临时绑定信息。pool-name表示地址池名称,为1~63个字符的字符串,不区分大小写。如果未指定本参数,则清除所有地址池的正式绑定和临时绑定信息。
清除静态正式绑定信息时,将使该绑定信息变为静态无效绑定。
# 清除地址10.110.1.1的正式绑定和临时绑定信息。
<Sysname> reset dhcp server ip-in-use ip 10.110.1.1
·     display dhcp server ip-in-use
reset dhcp server statistics命令用来清除DHCP服务器的统计信息。
vpn-instance vpn-instance-name:清除指定VPN实例内的DHCP服务器的统计信息。vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。如果未指定本参数,则表示清除的是公网中的DHCP服务器的统计信息。
# 清除DHCP服务器的统计信息。
<Sysname> reset dhcp server statistics
·     display dhcp server statistics
snmp-agent trap enable dhcp server命令用来开启DHCP服务器的告警功能。
undo snmp-agent trap enable dhcp server命令用来关闭DHCP服务器的告警功能。
snmp-agent trap enable dhcp server [ address-exhaust | ip-in-use ] *
undo snmp-agent trap enable dhcp server [ address-exhaust | ip-in-use ] *
DHCP服务器的告警功能均处于开启状态。
address-exhaust:表示单个IP地址池的地址资源耗尽/恢复的告警信息。
ip-in-use:表示单个IP地址池在采样时刻的地址使用率高于等于阈值或恢复到低于阈值的告警信息。使用命令ip-in-use threshold可配置门限阈值。
如果未指定任何参数,将开启DHCP服务器所有类型的告警功能。
开启DHCP服务器模块的告警功能后,该模块会生成告警信息,用于报告该模块的重要事件。生成的告警信息将发送到设备的SNMP模块,通过设置SNMP中告警信息的发送参数,来决定告警信息输出的相关属性。
# 关闭DHCP服务器的所有告警功能。
[Sysname] undo snmp-agent trap enable dhcp server
# 关闭DHCP服务器地址池的地址资源耗尽/恢复的告警功能。
[Sysname] undo snmp-agent trap enable dhcp server address-exhaust
# 关闭DHCP服务器地址池使用率高于等于门限阈值/恢复到低于阈值的告警功能。
[Sysname] undo snmp-agent trap enable dhcp server ip-in-use
·     snmp-agent target-host(网络管理和监控命令参考/SNMP)
1.2.53  static-bind
static-bind命令用来在DHCP地址池中配置静态地址绑定,以便实现DHCP服务器为客户端ID或硬件地址为指定值的客户端分配固定的IP地址。
undo static-bind命令用来删除DHCP地址池中的静态地址绑定。
undo static-bind ip-address ip-address
未在DHCP地址池中配置静态地址绑定。
DHCP地址池视图
ip-address ip-address:指定静态绑定的IP地址。未指定掩码长度和掩码时,表示采用自然掩码。
mask-length:静态绑定IP地址的掩码长度,即掩码中连续“1”的个数,取值范围为1~30。
mask mask:指定静态绑定IP地址的掩码,mask为点分十进制形式。
client-identifier client-identifier:指定静态绑定的客户端ID。client-identifier表示客户端ID,为4~254个字符的字符串,字符串中只能包括十六进制数和“-”,且形式为H-H-H…,除最后一个H表示2位或4位十六进制数外,其他均表示4位十六进制数。例如:aabb-cccc-dd为有效的ID,aabb-c-dddd和aabb-cc-dddd为无效客户端ID。
hardware-address hardware-address:指定静态绑定的客户端硬件地址。hardware-address表示客户端硬件地址,为4~39个字符的字符串,字符串中只能包括十六进制数和“-”,且形式为H-H-H…,除最后一个H表示2位或4位十六进制数外,其他均表示4位十六进制数。例如:aabb-cccc-dd为有效的客户端硬件地址,aabb-c-dddd和aabb-cc-dddd为无效的客户端硬件地址。
ethernet:指定客户端硬件地址类型为以太网,缺省为以太网类型。
token-ring:指定客户端硬件地址类型为令牌环网。
静态绑定的IP地址不能是DHCP服务器的接口IP地址,否则会导致IP地址冲突,被绑定的客户端将无法正常获取到IP地址。
同一地址池下可以配置多个静态地址绑定。所有地址池下配置的静态地址绑定一共不能超过8192个。
同一地址只能绑定给一个客户端。不能通过重复执行本命令修改IP地址与客户端的绑定关系。如需修改IP地址与客户端的绑定关系,请先通过undo static-bind命令删除静态地址绑定,再执行static-bind命令。
指定remote-server后作为DHCP中继地址池使用的DHCP地址池不支持配置本命令。
# 在DHCP地址池0中配置:为客户端ID为00aa-aabb的客户端,固定分配IP地址10.1.1.1/24。
[Sysname-dhcp-pool-0] static-bind ip-address 10.1.1.1 mask 255.255.255.0 client-identifier 00aa-aabb
tftp-server domain-name命令用来配置DHCP地址池为DHCP客户端分配的TFTP服务器域名。
undo tftp-server domain-name命令用来恢复缺省情况。
未配置DHCP地址池为DHCP客户端分配的TFTP服务器域名。
DHCP地址池视图
domain-name:TFTP服务器域名,为1~63个字符的字符串,区分大小写。
# 配置DHCP地址池0为DHCP客户端分配的TFTP服务器域名为aaa。
[Sysname-dhcp-pool-0] tftp-server domain-name aaa
tftp-server ip-address命令用来配置DHCP地址池为DHCP客户端分配的TFTP服务器地址。undo tftp-server ip-address命令用来恢复缺省情况。
未配置DHCP地址池为DHCP客户端分配的TFTP服务器地址。
DHCP地址池视图
ip-address:TFTP服务器的IP地址。
# 配置DHCP地址池0为DHCP客户端分配的TFTP服务器地址为10.1.1.1。
[Sysname-dhcp-pool-0] tftp-server ip-address 10.1.1.1
1.2.56  valid class
valid class命令用来配置DHCP白名单包括的用户类名。
undo valid class命令用来删除DHCP白名单中包括的用户类名。
valid class class-name&<1-8>
undo valid class class-name&<1-8>
未配置DHCP白名单包括的用户类。
DHCP地址池视图
class-name&<1-8>:DHCP白名单包括的用户类名列表。其中class-name为DHCP用户类名,为1~63个字符的字符串,不区分大小写。&<1-8>代表最多可以输入8个用户类名,每个用户类名之间用空格分隔。
在配置了DHCP地址池用户白名单功能后,DHCP服务器才会检查用户是否属于白名单包括的用户类。
# 在DHCP地址池0中配置DHCP白名单包括的用户类名为test1和test2。
[Sysname-dhcp-pool-0] valid class test1 test2
·     dhcp class
·     verify class
1.2.57  verify class
verify class命令用来开启DHCP用户类白名单功能。
undo verify class命令用来关闭DHCP用户类白名单功能。
verify class
undo verify class
DHCP用户类白名单功能处于关闭状态。
DHCP地址池视图
在开启了DHCP用户类白名单功能后,DHCP服务器才会检查用户是否属于白名单包括的用户类。
需要注意的是,DHCP用户类白名单功能对获取静态绑定租约的客户端不生效。
# 在DHCP地址池0中开启DHCP用户类白名单功能。
[Sysname] syatem-view
[Sysname-dhcp-pool-0] verify class
·     valid class
1.2.58  voice-config
voice-config命令用来配置DHCP地址池为DHCP客户端分配的Option 184内容。
undo voice-config命令用来删除DHCP地址池为DHCP客户端分配的Option 184内容。
voice-config { as-ip ip-address | fail-over ip-address dialer-string | ncp-ip ip-address | voice-vlan vlan-id { disable | enable } }
undo voice-config [ as-ip | fail-over | ncp-ip | voice-vlan ]
未配置DHCP地址池为DHCP客户端分配的Option 184内容。
DHCP地址池视图
as-ip ip-address:指定备用服务器的IP地址。
fail-over ip-address dialer-string:指定自动故障转移IP地址及呼叫字符串。dialer-string为1~39个字符的字符串,字符只能是数字0~9及“*”。
ncp-ip ip-address:指定网络呼叫处理器的IP地址。
voice-vlan vlan-id:指定语音VLAN的ID。vlan-id取值范围为2~4094。
·     disable:指定VLAN处于禁止状态,即DHCP客户端不会将所指定的VLAN ID作为语音VLAN。
·     enable:指定VLAN处于开启状态,即DHCP客户端会将所指定的VLAN ID作为语音VLAN。
# 为DHCP地址池0指定Option 184的内容:网络呼叫处理器的IP地址为10.1.1.1,备用服务器的IP地址为10.2.2.2,语音VLAN的ID为3,为开启状态,自动故障转移IP地址为10.3.3.3,呼叫字符串为99*。
[Sysname-dhcp-pool-0] voice-config ncp-ip 10.1.1.1
[Sysname-dhcp-pool-0] voice-config as-ip 10.2.2.2
[Sysname-dhcp-pool-0] voice-config voice-vlan 3 enable
[Sysname-dhcp-pool-0] voice-config fail-over 10.3.3.3 99*
1.2.59  vpn-instance
vpn-instance命令用来为DHCP服务器上的地址池绑定VPN实例。
undo vpn-instance命令用来恢复缺省情况。
undo vpn-instance
DHCP服务器上的地址池未绑定VPN实例。
DHCP地址池视图
vpn-instance-name:为DHCP地址池绑定的VPN实例名称。vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。
当地址池绑定了VPN实例后,DHCP服务器可以将网络划分成公网和VPN私网。未配置VPN属性的地址池被划分到公网,配置了VPN属性的地址池被划分到相应的VPN私网,这样,对于处于公网或VPN私网中的客户端,服务器都能够选择合适的地址池来为客户端分配租约并且记录该客户端的状态信息。
DHCP客户端的VPN信息可以从认证模块获取,也可以从DHCP服务器接收报文的接口配置的VPN信息获取。如果以上两种方式都可获取VPN信息,以从认证模块获取的VPN信息为准。
# 为DHCP地址池0绑定的VPN实例编号为abc。
[Sysname-dhcp-pool-0] vpn-instance abc
1.3  DHCP中继配置命令
dhcp relay check mac-address命令用来开启DHCP中继的MAC地址检查功能。
undo dhcp relay check mac-address命令用来关闭DHCP中继的MAC地址检查功能。
DHCP中继的MAC地址检查功能处于关闭状态。
开启该功能后,DHCP中继检查接收到的DHCP请求报文中的chaddr字段和数据帧的源MAC地址字段是否一致。如果一致,则认为该报文合法,将其转发给DHCP服务器;如果不一致,则丢弃该报文。
只有在接口上配置dhcp select relay后,DHCP中继的MAC地址检查功能才会生效。
由于DHCP中继转发DHCP报文时会修改报文的源MAC地址,所以只能在靠近DHCP客户端的第一跳DHCP中继设备上开启MAC地址检查功能。
# 开启DHCP中继的MAC地址检查功能。
[Sysname-Vlan-interface10] dhcp relay check mac-address
·     dhcp select relay
dhcp relay check mac-address aging-time命令用来配置DHCP中继的MAC地址检查表项的老化时间。
undo dhcp relay check mac-address aging-time命令用来恢复缺省情况。
MAC地址检查表项的老化时间为30秒。
如果未通过dhcp relay check mac-address命令开启DHCP中继的MAC地址检查功能,则本命令的配置不会生效。
time:DHCP中继的MAC地址检查表项的老化时间,取值范围为30~600,单位为秒。
# 配置DHCP中继的MAC地址检查表项的老化时间为60秒。
[Sysname] dhcp relay check mac-address aging-time 60
dhcp relay client-information record命令用来开启DHCP中继用户地址表项记录功能。
undo dhcp relay client-information record命令用来关闭DHCP中继用户地址表项记录功能。
DHCP中继用户地址表项记录功能处于关闭状态。
当DHCP中继作为DHCP客户端的网关设备时,才会记录此DHCP客户端的地址表项。DHCP中继用户地址表项记录了DHCP客户端的IP地址、MAC地址和用户地址表项类型等信息。
关闭DHCP中继用户地址表项记录功能时,会删除DHCP中继上记录的全部地址表项。
# 开启DHCP中继用户地址表项记录功能。
[Sysname] dhcp relay client-information record
·     dhcp relay client-information refresh
·     dhcp relay client-information refresh enable
dhcp relay client-information refresh命令用来配置DHCP中继动态用户地址表项的定时刷新周期。
undo dhcp relay client-information refresh命令用来恢复缺省情况。
dhcp relay client-information refresh { auto | interval interval }
定时刷新周期为auto,即根据表项的数目自动计算刷新时间间隔,且DHCP中继用户地址表项的保留时间为0分钟。
auto:指定根据表项的数目自动计算刷新时间间隔。表项越多,刷新时间间隔越短,但最短时间间隔不会小于50毫秒。
interval interval:刷新时间间隔,取值范围为1~120,单位为秒。
DHCP中继动态用户地址表项定时刷新功能开启时,DHCP中继每隔一个表项刷新周期采用服务器分配给客户端的IP地址和DHCP中继接口的MAC地址向DHCP服务器发送DHCP-REQUEST报文,如果DHCP中继在刷新周期内收到DHCP服务器响应的DHCP-ACK报文或未接收到DHCP服务器的响应报文,则表明这个IP地址可以被DHCP服务器再次分配给客户端,DHCP中继会删除动态用户地址表中对应的表项。
# 配置DHCP中继动态用户地址表项的刷新时间间隔为100秒。
[Sysname] dhcp relay client-information refresh interval 100
·     dhcp relay client-information record
dhcp relay client-information refresh enable命令用来开启DHCP中继动态用户地址表项定时刷新功能。
undo dhcp relay client-information refresh enable命令用来关闭DHCP中继动态用户地址表项定时刷新功能。
DHCP中继动态用户地址表项定时刷新功能处于开启状态。
DHCP中继动态用户地址表项定时刷新功能开启时,DHCP中继每隔指定时间采用客户端获取到的IP地址向DHCP服务器发送DHCP-REQUEST报文:
·     如果DHCP中继接收到DHCP服务器响应的DHCP-ACK报文或在指定时间内未接收到DHCP服务器的响应报文,则表明这个IP地址已经可以进行分配,DHCP中继会删除动态用户地址表中对应的表项,为了避免地址浪费,DHCP中继收到DHCP-ACK报文后,会发送DHCP-RELEASE报文释放申请到的IP地址。
·     如果DHCP中继接收到DHCP服务器响应的DHCP-NAK报文,则表示该IP地址的绑定信息仍然存在,DHCP中继不会删除该IP地址对应的表项。
需要注意的是,关闭DHCP中继动态用户地址表项定时刷新功能时,DHCP中继上记录的用户地址表项不会自动老化。DHCP客户端释放申请到的IP地址后,需要用户执行reset dhcp relay client-information命令删除DHCP中继上对应的用户地址表项。
# 关闭DHCP中继动态用户地址表项定时刷新功能。
[Sysname] undo dhcp relay client-information refresh enable
·     reset dhcp relay client-information
dhcp relay dhcp-server timeout命令用来配置DHCP服务器应答超时切换时间。
undo dhcp relay dhcp-server timeout命令用来恢复缺省情况。
dhcp relay dhcp-server timeout time
DHCP服务器应答超时切换时间为30秒。
time:超时切换时间,取值范围为1~65535,单位为秒。
# 在VLAN接口2上配置DHCP服务器应答超时切换时间为60秒。
[Sysname-Vlan-interface2] dhcp relay dhcp-server timeout 60
·     dhcp relay server-address algorithm
dhcp relay gateway命令用来配置DHCP中继在DHCP报文中填充的中继地址。
undo dhcp relay gateway命令用来恢复缺省情况。
dhcp relay gateway ip-address
DHCP中继在DHCP报文中填充的中继地址是接口下的主IP地址。
ip-address:中继地址。该地址必须属于命令行所在的接口。
在接口视图下配置此命令后,中继会使用此命令配置的地址作为中继地址。
# 在VLAN接口2上配置在DHCP报文中填充的中继地址为10.1.1.1。
[Sysname-Vlan-interface2] dhcp relay gateway 10.1.1.1
·     gateway-list
dhcp relay information circuit-id命令用来配置Option 82的Circuit ID子选项的填充模式和填充格式。
undo dhcp relay information circuit-id命令用来恢复缺省情况。
dhcp relay information circuit-id { bas | string circuit-id | { normal | verbose [ node-identifier { mac | sysname | user-defined node-identifier } ] [ interface ] } [ format { ascii | hex } ] }
Option 82的Circuit ID子选项的填充模式为Normal,填充格式为hex。
bas:表示支持使用工信部规范的格式填充Circuit ID子选项。填充内容包括接口信息、VLAN信息。
string circuit-id:指定以用户配置的字符串填充Circuit ID子选项。circuit-id表示用户配置的用来填充Circuit ID子选项的内容,为3~63个字符的字符串,区分大小写。
normal:指定以Normal模式填充Circuit ID子选项,填充内容为VLAN ID和端口号。
verbose:指定以Verbose模式填充Circuit ID子选项。填充的内容为节点标识、接口信息和接口所在的VLAN编号。节点标识缺省以节点的MAC地址构成;接口信息缺省由以太网类型(取值固定为“eth”)、框号、槽号、子槽号和接口编号组成。
node-identifier:指定接入节点的标识。
·     mac:表示以节点的MAC地址作为节点标识。
·     sysname:表示以节点的设备名称作为节点标识。设备的系统名称可以通过系统视图下的sysname命令配置。不管配置了哪种填充格式,设备的系统名称始终采用ASCII码格式填充。系统名称中不能包含空格,否则DHCP中继添加或替换Option 82失败。
·     user-defined node-identifier:表示以指定的字符串作为节点标识,node-identifier为1~50个字符的字符串,区分大小写。不管配置了哪种填充格式,指定的字符串始终采用ASCII码格式填充。
interface:表示以接口名构成接口信息,始终采用ASCII码格式填充。
format:指定Circuit ID子选项的填充格式。
ascii:指定以ASCII码格式填充Circuit ID子选项,即将数值转换为对应的ASCII码填充到Circuit ID子选项。
hex:指定以十六进制数值的格式填充Circuit ID子选项。
以不同模式填充Circuit ID子选项时,填充格式有所不同:
·     以用户配置的字符串填充Circuit ID子选项时,填充格式固定为ASCII码格式;
·     以Normal和Verbose模式填充Circuit ID子选项时,填充格式由本命令的配置决定。
如果本命令中未指定填充格式,则对于Normal模式,VLAN ID和端口号均以hex格式填充;对于Verbose模式,节点标识(MAC地址、设备的系统名称或指定的字符串)、以太网类型、框号、槽号、子槽号、接口编号均以ASCII码格式填充,VLAN ID以hex格式填充。
·     如果本命令中指定填充格式为ascii,则所有内容均以ASCII码格式填充。
·     如果本命令中指定填充格式为hex,则对于Normal模式,VLAN ID和端口号均以hex格式填充;对于Verbose模式,设备的节点标识、以太网类型以ASCII码格式填充,其余内容均以hex格式填充。
Option 82的Circuit ID子选项信息中无法携带接口拆分信息或子接口信息,关于“接口拆分”和“子接口”的详细介绍,请参见“接口管理配置指导”中的“以太网接口”。
# 配置以Verbose模式填充Option 82的Circuit ID子选项,节点标识为设备的系统名称,填充格式为ASCII码格式。
[Sysname-Vlan-interface10] dhcp relay information enable
[Sysname-Vlan-interface10] dhcp relay information strategy replace
[Sysname-Vlan-interface10] dhcp relay information circuit-id verbose node-identifier sysname format ascii
·     dhcp relay information enable
·     dhcp relay information strategy
·     display dhcp relay information
1.3.9  dhcp relay information enable
dhcp relay information enable命令用来开启DHCP中继支持Option 82功能。
undo dhcp relay information enable命令用来关闭DHCP中继支持Option 82功能。
DHCP中继支持Option 82功能处于关闭状态。
开启DHCP中继支持Option 82功能后,DHCP中继将向转发给DHCP服务器的请求报文中增加Option 82选项。选项内容由dhcp relay information circuit-id命令和dhcp relay information remote-id命令决定。如果DHCP中继收到的请求报文中已经包含Option 82选项,则按照dhcp relay information strategy命令配置的策略处理请求报文。
关闭DHCP中继支持Option 82功能后,DHCP中继不会向转发给DHCP服务器的请求报文中增加Option 82选项,也不检查收到的请求报文中是否包含Option 82选项。
# 开启DHCP中继支持Option 82功能。
·     dhcp relay information circuit-id
·     dhcp relay information remote-id
1.3.10  dhcp relay information link-selection
dhcp relay information link-selection命令用来指定Option 82子选项sub-option 5中填充的地址。
undo dhcp relay information link-selection命令用来恢复缺省情况。
dhcp relay information link-selection link-selection-address
Option 82子选项sub-option 5的填充内容为授权地址池/接口绑定地址池的gateway或开启DHCP中继功能的接口地址。
link-selection-address:Option 82子选项sub-option 5中填充的IPv4地址,格式为点分十进制。
在DHCP中继上配置dhcp relay information enable命令开启支持Option 82功能,并配置dhcp relay source-address后,Option 82选项中才会携带sub-option 5子选项,服务器可以根据中继填充在sub-option5中的地址来为DHCP客户端分配同网段的IP地址。
Option 82携带sub-option 5后,将按照如下优先级顺序选择地址填充到sub-option 5中:
·     dhcp relay information link-selection命令配置的地址。
·     授权地址池/接口绑定地址池的gateway。
·     开启DHCP中继功能的接口地址。
本命令配置的地址必须与授权地址池/接口绑定地址池的gateway或开启DHCP中继功能的接口地址同网段,否则DHCP用户无法分配到IP地址。
# 在VLAN接口2上指定Option 82 sub-option 5携带的地址为1.1.1.1
[Sysname-Vlan-interface2] dhcp relay information link-selection 1.1.1.1
1.3.11  dhcp relay information remote-id
dhcp relay information remote-id命令用来配置Option 82的Remote ID子选项的填充模式和填充格式。
undo dhcp relay information remote-id命令用来恢复缺省情况。
Option 82的Remote ID子选项的填充模式为Normal、填充格式为hex。
normal:指定以Normal模式填充Remote ID子选项,填充内容为接收报文接口的MAC地址。
format:指定Remote ID子选项的填充格式。如果未配置本参数,则以hex格式填充。
ascii:指定以ASCII码格式填充Remote ID子选项,即将数值转换为对应的ASCII码填充到Remote ID子选项。
hex:指定以十六进制数值的格式填充Remote ID子选项。
string remote-id:指定以用户配置的字符串填充Remote ID子选项。remote-id表示用户配置的用来填充Remote ID子选项的内容,为1~63个字符的字符串,区分大小写。
sysname:指定以设备的系统名称填充Remote ID子选项。设备的系统名称可以通过系统视图下的sysname命令配置。
以用户配置的字符串(string)和设备的系统名称(sysname)填充Remote ID子选项时,填充内容固定为ASCII格式;以Normal模式填充Remote ID子选项时,填充内容的格式由本命令配置的填充格式决定。
# 配置采用字符串device001填充Option 82的Remote ID子选项。
[Sysname-Vlan-interface10] dhcp relay information remote-id string device001
1.3.12  dhcp relay information strategy
dhcp relay information strategy命令用来配置DHCP中继对包含Option 82的请求报文的处理策略。
undo dhcp relay information strategy命令用来恢复缺省情况。
DHCP中继对带有Option 82的请求报文的处理策略为replace。
drop:如果报文中带有Option 82,则丢弃该报文。
keep:如果报文中带有Option 82,则保持该报文中的Option 82不变并进行转发。
replace:如果报文中带有Option 82,则按照配置的填充内容和填充格式填充Option 82,用该选项替换报文中原有的Option 82,并进行转发。
本命令仅对包含Option 82的请求报文有效。
如果开启了DHCP中继支持Option 82功能,则对于接收到的不包含Option 82的请求报文,DHCP中继的处理方式始终为在请求报文中添加Option 82,并转发给DHCP服务器。
DHCP中继对包含Option 82请求报文的处理策略为replace时,需要配置Option 82的填充模式和填充格式;处理策略为keep或drop时,不需要配置Option 82选项的填充模式和填充格式。
# 配置接收到的请求报文中带有Option 82时,DHCP中继保持该报文中的Option 82不变并进行转发。
[Sysname-Vlan-interface10] dhcp relay information strategy keep
1.3.13  dhcp relay insert option60
dhcp relay insert option60命令用来配置DHCP中继在DHCP请求报文中添加Option 60选项。
undo dhcp relay insert option60命令用来恢复缺省情况。
dhcp relay insert option60 option-text
DHCP中继不会在DHCP请求报文中添加Option 60选项。
option-text:Option 60选项内容,为1~128位的字符串,区分大小写。
Option 60字段记录的是客户端的厂商标识信息。当DHCP服务器收到带有Option 60选项的DHCP请求报文后,可以根据Option 60选项匹配正确的用户类,再从该用户类对应的地址空间选择地址分配给DHCP客户端,从而确保不同Option 60选项的DHCP客户端可以获取到不同范围的IP地址。
在DHCP中继上开启本功能,当DHCP中继收到DHCP请求报文后,先检查报文中是否存在Option 60选项。如果报文中不存在Option 60选项,则DHCP中继使用本命令指定的Option 60选项内容填充报文,再将报文转发给DHCP服务器;如果报文中存在Option 60选项,则DHCP中继不会处理该报文,将报文直接转发给DHCP服务器。
只有配置了dhcp select relay命令后,本功能才会生效。
# 在VLAN接口10上配置DHCP中继在DHCP请求报文中添加Option 60选项的内容为sysname.com。
[Sysname-Vlan-interface10] dhcp relay insert option60 sysname.com
·     dhcp select relay
1.3.14  dhcp relay mac-forward enable
dhcp relay mac-forward enable命令用来配置如果DHCP中继未记录收到的DHCP应答报文中DHCP客户端的MAC地址和中继出接口的对应关系,则根据客户端的MAC地址查询MAC地址表,在表项对应的出接口转发DHCP应答报文。
undo dhcp relay mac-forward enable命令用来恢复缺省情况。
dhcp relay mac-forward enable [ broadcast ]
如果DHCP中继未记录收到的DHCP应答报文中DHCP客户端的MAC地址和中继出接口的对应关系,则直接丢弃该应答报文。
broadcast:DHCP中继根据客户端的MAC地址查询MAC地址表,在表项对应的出接口广播DHCP应答报文。如果未指定本参数,则DHCP中继单播转发DHCP应答报文。
# 配置如果DHCP中继发现未记录收到的DHCP应答报文中DHCP客户端的MAC地址和中继出接口的对应关系,则根据客户端的MAC地址查询MAC地址表,在表项对应的出接口转发DHCP应答报文。
[Sysname] dhcp relay mac-forward enable
1.3.15  dhcp relay master-server switch-delay
dhcp relay master-server switch-delay命令用来配置回切主用DHCP服务器并指定回切延迟时间。
undo dhcp relay master-server switch-delay命令用来恢复缺省情况。
dhcp relay master-server switch-delay delay-time
DHCP中继不回切到主用DHCP服务器。
delay-time:延迟时间,取值范围为1~65535,单位为分钟。
# 在VLAN接口2上配置回切主用DHCP服务器并指定回切延迟时间为3分钟。
[Sysname-Vlan-interface2] dhcp relay master-server switch-delay 3
1.3.16  dhcp relay pool
dhcp relay pool命令用来指定DHCP客户端对应的DHCP中继地址池。
undo dhcp relay pool命令用来删除指定的指定DHCP客户端对应的DHCP中继地址池。
dhcp relay pool pool-name [ option code [ option-text ] ]
undo dhcp relay pool [ pool-name [ option code [ option-text ] ]
未指定DHCP客户端对应的DHCP中继地址池。
三层以太网接口视图
三层以太网子接口视图
三层聚合接口视图
三层聚合子接口视图
VLAN接口视图
pool-name:DHCP中继地址池名称,为1~63个字符的字符串,不区分大小写。
option code [ option-text ]:表示基于DHCP请求报文中携带的Option选项来选择使用的DHCP中继地址池。如果未指定本参数,则接口接收到的所有DHCP请求报文都会对应同一个DHCP中继地址池。其中:
·     code表示Option选项编号,取值范围为1~254。
·     只有当code取值为60时,才能配置option-text。option-text表示Option 60选项信息,为1~128位的字符串,区分大小写。本参数用来匹配DHCP请求报文中Option 60选项的内容,只有指定Option 60时才可以配置本字段。
通过本命令,可以在接口下直接指定DHCP客户端对应的地址池。如果希望更进一步根据DHCP客户端报文的Option信息来选择对应的DHCP中继地址池,则可以指定Option参数。
接口下可以通过多次配置本命令指定多个DHCP中继地址池,DHCP中继地址池的选择顺序为:
(1)     按照Option选项值从大到小的顺序依次匹配dhcp relay pool命令,选择匹配的第一条命令指定的地址池。当匹配的是Option 60时,优先选择指定了相同option-text参数的地址池,再选择未指定option-text参数的地址池。
(2)     选择dhcp relay pool(未指定option参数)命令指定的地址池。
如果在接口下同时配置了dhcp relay pool和dhcp relay server-address命令,dhcp relay pool命令生效。如果该DHCP中继地址池下未指定中继地址池对应的DHCP服务器地址(即未配置remote server命令),DHCP中继也不会向dhcp relay server-address命令配置的服务器地址转发DHCP请求报文,而是直接丢弃该报文。
多次执行本命令指定相同的DHCP客户端对应不同的中继地址池时,最后一次执行的命令生效。
执行undo dhcp relay pool命令时,如果未指定任何参数,则删除接口上指定的所有DHCP中继地址池。
# 在VLAN接口2上指定DHCP客户端对应的DHCP中继地址池为pool1。
[Sysname-Vlan-interface2] dhcp relay pool pool1
1.3.17  dhcp relay release-agent
dhcp relay release-agent命令用来配置清除用户表项时通知DHCP服务器释放租约。
undo dhcp relay release-agent命令用来配置清除用户表项时不通知DHCP服务器释放租约。
清除用户表项时,会通知DHCP服务器释放租约。
在无线组网环境中,用户可能会在不同的网关设备下漫游。当用户从某一台网关下漫游到其他网关下后,之前网关上用户的ARP表项会老化掉。如果DHCP中继开启了用户下线探测功能,则在ARP老化后删除对应的DHCP中继表项,并向DHCP服务器发送DHCP-RELEASE报文释放对应租约。当DHCP服务器将此租约再分配给其他用户后,就会发生地址冲突的问题。执行undo dhcp relay release-agent命令可以解决此问题。当同时配置了DHCP中继用户下线探测功能和undo dhcp relay release-agent命令时,DHCP中继发现用户下线后,会删除对应中继表项,但是不会向DHCP服务器发送DHCP-RELEASE报文。
执行undo dhcp relay release-agent命令后,DHCP中继收到DHCP客户端的DHCP-RELEASE报文,还会将其转发给DHCP服务器。
# 配置清除用户表项时,中继不会通知DHCP服务器释放租约。
[Sysname] undo dhcp relay release-agent
1.3.18  dhcp relay release ip
dhcp relay release ip命令用来配置向DHCP服务器请求释放客户端申请到的IP地址。
ip-address:请求释放的DHCP客户端IP地址。
vpn-instance vpn-instance-name:指定需要释放的IP地址所属的VPN实例。vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。如果未指定本参数,则表示释放公网IP地址。
如果DHCP中继上存在客户端IP地址对应的动态用户地址表项,则配置通过DHCP中继释放该客户端IP地址后,DHCP中继会主动向DHCP服务器发送DHCP-RELEASE报文。DHCP服务器收到该报文后,将会释放指定IP地址的绑定信息。DHCP中继也会删除该动态用户地址表项。
# 向DHCP服务器请求释放客户端申请到的IP地址1.1.1.1。
[Sysname] dhcp relay release ip 1.1.1.1
1.3.19  dhcp relay request-from-tunnel discard
dhcp relay request-from-tunnel discard命令用来配置DHCP中继丢弃从VXLAN隧道收到的DHCP请求报文。
undo dhcp relay request-from-tunnel discard命令用来恢复缺省情况。
DHCP中继转发从VXLAN隧道收到DHCP请求报文。
VXLAN中的VSI虚接口视图
VXLAN中的VLAN接口视图
在VXLAN组网中,用户可以在VTEP设备上的VSI虚接口/VLAN接口上配置DHCP中继功能。
当从AC链路或VLAN接口上收到DHCP请求报文时,DHCP中继将此DHCP请求报文转发给DHCP服务器。同时,VTEP还会将该请求报文广播到其他的VTEP。其他VTEP接收到后,其他VTEP如果配置了DHCP中继,则会在收到报文后,将其转发给其他DHCP服务器。
当多台VTEP设备配置了DHCP中继功能后,为了避免在DHCP服务器上收到多个相同的DHCP请求报文,需要在和DHCP客户端非直接相连的DHCP中继的VSI虚接口/VLAN接口上配置本功能丢弃从VXLAN隧道收到DHCP请求报文。
# 在VSI虚接口1配置DHCP中继丢弃从VXLAN隧道收到的请求报文。
[Sysname] interface vsi-interface 1
[Sysname-Vsi-interface1] dhcp relay request-from-tunnel discard
1.3.20  dhcp relay server-address
dhcp relay server-address命令用来在DHCP中继上指定DHCP服务器的地址。
undo dhcp relay server-address命令用来在DHCP中继上删除指定DHCP服务器的地址。
dhcp relay server-address ip-address [ class class-name ] [ public | vpn-instance vpn-instance-name ]
undo dhcp relay server-address [ ip-address [ class class-name ] [ public | vpn-instance vpn-instance-name ] ]
在DHCP中继上未指定DHCP服务器的地址。
ip-address:DHCP服务器的IP地址。DHCP中继将DHCP客户端发送的报文转发到该地址。
class class-name:指定DHCP请求报文需要匹配的DHCP用户类。class-name表示DHCP用户类名称,为1~63个字符的字符串,区分大小写。如果未指定本参数,则表示不需要匹配任何DHCP用户类。
public:指定DHCP中继配置的DHCP服务器地址属于公网。
vpn-instance vpn-instance-name:指定DHCP中继配置的DHCP服务器的地址所属的VPN实例。vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。
指定的DHCP服务器IP地址不能与DHCP中继的接口IP地址在同一网段。否则,可能导致客户端无法获得IP地址。
通过多次执行dhcp relay server-address命令可以指定多个DHCP服务器地址。一个接口上最多可以指定8个DHCP服务器地址。DHCP中继转发DHCP报文的规则如下:
·     只有接收到的DHCP请求报文匹配某个用户类中的规则时,DHCP中继才会将该报文转发给该用户类对应的DHCP服务器。
·     当接收到的DHCP请求报文不匹配任何用户类中的规则时,DHCP中继会将其转发给所有不带DHCP用户类参数的DHCP服务器。
多次配置dhcp relay server-address ip-address [ class class-name ],如果ip-address不同class class-name相同,则多个DHCP服务器关联同一个DHCP用户类;如果ip-address相同class class-name不同,则以最后一次执行的命令生效。
如果指定了vpn-instance参数,则DHCP中继根据配置的DHCP服务器地址对应的VPN信息,向该VPN内的DHCP服务器转发报文。如果未指定public和vpn-instance vpn-instance-name参数,则以当前DHCP客户端位置(公网或VPN)为准。
执行undo dhcp relay server-address命令时,如果未指定ip-address参数,则删除接口上的所有DHCP服务器地址。
当配置的DHCP中继选择DHCP服务器方式为主备方式时,需要保证所有的DHCP服务器地址都不匹配用户类或匹配完全相同的用户类,否则DHCP客户端无法正常获取到IP地址。
# 在VLAN接口10上为DHCP中继指定DHCP服务器的地址为1.1.1.1。
[Sysname-Vlan-interface10] dhcp relay server-address 1.1.1.1
·     dhcp select relay
·     display dhcp relay interface
1.3.21  dhcp relay server-address algorithm
dhcp relay server-address algorithm命令用来配置DHCP中继选择DHCP服务器方式。
undo dhcp relay server-address algorithm命令用来恢复缺省情况。
dhcp relay server-address algorithm { master-backup | polling }
DHCP中继同时向所有DHCP服务器转发DHCP请求报文(polling方式)。
master-backup:主备方式,即DHCP中继向主用DHCP服务器转发DHCP请求报文,当主用DHCP服务器不可用或没有空闲地址时,再按照服务器地址配置顺序依次向其他备用DHCP服务器发送DHCP请求报文。
polling:全部方式,即DHCP中继同时向所有DHCP服务器转发DHCP请求报文。
# 在VLAN接口2上配置DHCP中继使用主备方式选择DHCP服务器。
[Sysname-Vlan-interface2] dhcp relay server-address algorithm master-backup
·     dhcp relay dhcp-server timeout
·     dhcp relay master-server switch-delay
·     remote-server algorithm
1.3.22  dhcp relay source-address
dhcp relay source-address命令用来指定DHCP中继向DHCP服务器转发报文的源地址。
undo dhcp relay source-address命令用来恢复缺省情况。
dhcp relay source-address { ip-address | interface interface-type interface-number } [ default-giaddr ]
当DHCP中继连接服务器的接口和DHCP服务器属于同一个VPN时,DHCP中继向DHCP服务器转发报文出接口的地址作为报文源地址;当DHCP中继连接服务器的接口和DHCP服务器不属于同一个VPN时,DHCP中继会选择一个中继上和DHCP服务器同VPN的最小地址作为报文源地址。
ip-address:DHCP中继向DHCP服务器转发报文的源地址。
interface interface-type interface-number:指定该接口IP地址为发送到DHCP服务器的报文源地址。interface-type interface-number表示接口类型和接口编号。
default-giaddr:DHCP中继向DHCP服务器发送DHCP请求报文时,不修改报文的Giaddr。如果未指定本参数,DHCP中继向DHCP服务器发送DHCP请求报文时,会将Giaddr修改为本命令指定的ip-address或接口IP地址。
在某些组网中,多个DHCP中继接口IP地址相同或者中继接口IP到服务器没有可达路由,用户需要配置本命令选择中继设备上的另一个接口(一般选择的是Loopback口)的IP地址填充到发送到DHCP服务器的DHCP请求报文中的源地址字段和Giaddr中。
当多个DHCP中继接口IP地址相同时,导致DHCP中继转发DHCP应答报文时候无法根据目的IP地址找到唯一的出接口。配置本功能时需要先开启DHCP中继支持Option 82功能,DHCP中继收到DHCP请求报文时在Option 82中的子选项sub-option5填充正确的子网网段,服务器可以根据中继填充的sub-option5 来分配地址,之后DHCP中继处理DHCP应答报文时通过MAC地址表中的接口信息转发DHCP应答报文。
如果仅需要改变DHCP中继发送到DHCP服务器的请求报文中的源地址,而不改变DHCP请求报文中Giaddr字段的填充内容,则需要指定default-giaddr参数。
多次执行命令,最后一次执行的命令生效。
# 在VLAN接口2上指定DHCP中继向DHCP服务器转发报文的源地址为1.1.1.1
[Sysname-Vlan-interface2] dhcp relay source-address 1.1.1.1
·     dhcp select relay
1.3.23  dhcp smart-relay enable
dhcp smart-relay enable命令用来开启DHCP中继支持smart-relay功能。
undo dhcp smart-relay enable命令用来关闭DHCP中继支持smart-relay功能。
DHCP中继支持smart-relay功能处于关闭状态。
未开启smart-relay功能时,DHCP中继只能使用中继接口的主IP地址填充请求报文的giaddr字段。开启smart-relay功能后,当DHCP中继转发3次DHCP-DISCOVER报文后,若还未收到DHCP服务器的应答报文,则DHCP中继可以使用除中继接口主地址外的其他IP地址来填充giaddr字段。
# 开启DHCP中继支持smart-relay功能。
[Sysname] dhcp smart-relay enable
·     dhcp select
·     gateway-list
1.3.24  dhcp-server timeout
undo dhcp-server timeout命令用来恢复缺省情况。
配置DHCP服务器应答超时切换时间为30秒。
DHCP地址池视图
# 在中继地址池0中配置DHCP服务器应答超时切换时间为60秒。
[Sysname] dhcp server ip-pool 0
[Sysname-dhcp-pool-0] dhcp-server timeout 60
1.3.25  display dhcp relay check mac-address
display dhcp relay check mac-address命令用来显示DHCP中继的MAC地址检查表项。
# DHCP中继的MAC地址检查表项。
<Sysname> display dhcp relay check mac-address
Source-MAC        Interface                 Aging-time
23f3-1122-adf1    Vlan2                     10
23f3-1122-2230    Vlan3                     30
表1-8 display dhcp relay check mac-address命令显示信息描述表
Source MAC
检测到攻击的源MAC地址
攻击来源的接口
Aging-time
DDOS攻击检测表项剩余时间,单位为秒
1.3.26  display dhcp relay client-information
display dhcp relay client-information命令用来显示DHCP中继的用户地址表项信息。
interface interface-type interface-number:显示指定接口上的用户地址表项信息。interface-type interface-number为接口类型和接口编号。如果未指定本参数,则显示所有接口上的用户地址表项信息。
ip ip-address:显示指定IP地址的用户地址表项信息。如果未指定本参数,则显示所有IP地址的用户地址表项信息。
vpn-instance vpn-instance-name:显示指定VPN实例内指定IP地址的用户地址表项信息。vpn-instance-name表示MPLS L3VPN的VPN实例名,为1~31个字符的字符串,区分大小写。如果未指定本参数,则显示公网中的用户地址表项信息。
只有执行dhcp relay client-information record命令后,DHCP中继才会记录用户地址表项信息。
# 显示所有DHCP中继的用户地址表项信息。
<Sysname> display dhcp relay client-information
Total number of client-information items: 2
Total number of dynamic items: 1
Total number of temporary items: 1
IP address       MAC address      Type        Interface            VPN name
10.1.1.1         00e0-0000-0001   Dynamic     Vlan2                N/A
10.1.1.5         00e0-0000-0000   Temporary   Vlan2                N/A
表1-9 display dhcp relay client-information命令显示信息描述表
用户地址信息条目总数
动态用户地址条目总数
临时用户地址条目总数
IP address
DHCP客户端的IP地址
MAC address
DHCP客户端的MAC地址
用户地址表项类型的取值包括:
·     Dynamic:动态用户地址表项,接收到DHCP服务器对DHCP客户端REQUEST请求的ACK应答后,创建的用户表项
·     Temporary:临时用户地址表项,接收DHCP客户端的REQUEST请求,但未收到DHCP服务器ACK应答时,创建的用户表项
与DHCP客户端相连的三层接口。如果用户地址表项中未记录接口,则显示为”N/A”
VPN name
VPN实例名称,如果表项不属于任何VPN,则显示为”N/A”
1.3.27  display dhcp relay information
display dhcp relay information命令用来显示DHCP中继上的Option 82配置信息。
interface interface-type interface-number:显示指定接口上的Option 82配置信息。interface-type interface-number为接口类型和接口编号。如果未指定本参数,则显示所有接口上的Option 82配置信息。
# 显示所有接口上的Option 82配置信息。
<Sysname> display dhcp relay information
Interface: Vlan-interface100
   Status: Enable
   Strategy: Replace
   Circuit ID Pattern: Verbose
   Remote ID Pattern: Sysname
   Circuit ID format: Undefined
   Remote ID format: ASCII
   Node identifier: aabbcc
Interface: Vlan-interface200
   Status: Enable
   Strategy: Replace
   Circuit ID Pattern: User Defined
   Remote ID Pattern: User Defined
   Circuit ID format: ASCII
   User defined:
   Circuit ID: vlan100
   Remote ID: device001
表1-10 display dhcp relay information命令显示信息描述表
接口名
Status
Option 82的状态,取值包括:
·     Enable:开启了DHCP中继支持Option 82功能
·     Disable:未开启DHCP中继支持Option 82功能
Strategy
对包含Option 82的请求报文的处理策略,取值为Drop、Keep或Replace
Circuit ID Pattern
Circuit ID子选项的填充方式,取值为Verbose、Normal或User Defined
Remote ID Pattern
Remote ID子选项的填充方式,取值为Sysname、Normal或User Defined
Circuit ID format
Circuit ID子选项的填充格式,取值为ASCII、Hex或Undefined
Remote ID format
Remote ID子选项的填充格式,取值为ASCII、Hex或Undefined
Node identifier
接入节点的标识
User defined
用户自定义的子选项内容
Circuit ID
用户自定义的Circuit ID子选项的内容
Remote ID
用户自定义的Remote ID子选项的内容
1.3.28  display dhcp relay m-lag-status
display dhcp relay m-lag-status命令用来显示DHCP中继记录的M-LAG接口信息。
# 显示所有的DHCP中继记录的M-LAG接口信息。
<Sysname> display dhcp relay m-lag-status
M-LAG  role                : Secondary
Peer-link/Peer-link Index  : Bridge-Aggregation3/65540
Peer-link State            : UP
表1-11 display dhcp relay m-lag-status命令显示信息描述表
M-LAG role
M-LAG系统中运行设备角色,取值包括:
·     None:设备状态未知
·     Primary:主设备
·     Secondary:从设备
peer-link接口名称/peer-link接口索引
Peer-link State
peer-link接口的物理状态,取值包括:
·     UP:开启
·     DOWN:关闭
1.3.29  display dhcp relay server-address
display dhcp relay server-address命令用来显示接口上指定的DHCP服务器地址信息。
interface interface-type interface-number:显示指定接口上的DHCP服务器地址信息。interface-type interface-number为接口类型和接口编号。如果未指定本参数,则显示所有接口上的DHCP服务器地址信息。
# 显示所有接口上指定的DHCP服务器地址信息。
<Sysname> display dhcp relay server-address
Interface name      Server IP address   Public/VRF name      Class name
Vlan2               2.2.2.2             Y/--                 --
Vlan2               2.2.2.3             Y/--                 abc
表1-12 display dhcp relay server-address命令显示信息描述表
Interface name
接口名
Server IP address
DHCP服务器地址
Public/VRF name
DHCP服务器所在位置,取值包括:
·     当配置了dhcp relay server-address命令时,显示为--/--
·     当配置了dhcp relay server-address public命令时,显示为Y/--
·     当配置了dhcp relay server-address vpn-instance vpn-instance-name命令时,显示为--/VPN实例名称
Class name
DHCP请求报文需要匹配的DHCP用户类,如果dhcp relay server-address命令中未配置class参数,显示为--
1.3.30  display dhcp relay statistics
display dhcp relay statistics命令用来显示DHCP中继的相关报文统计信息。
interface interface-type interface-number:显示指定接口的DHCP中继相关报文统计信息。interface-type interface-number为接口类型和接口编号。如果未指定本参数,则显示所有的DHCP中继相关报文统计信息。
# 显示所有的DHCP中继相关报文统计信息。
<Sysname> display dhcp relay statistics
DHCP packets dropped:                  0
   Incorrect Message type:             0
   Option Parsing failed:              0
   Mac-check failed:                   0
   Other count:                        0
DHCP packets received from clients:    0
   DHCPDISCOVER:                       0
   DHCPREQUEST:                        0
   DHCPINFORM:                         0
   DHCPRELEASE:                        0
   DHCPDECLINE:                        0
   BOOTPREQUEST:                       0
DHCP packets received from servers:    0
   DHCPOFFER:                          0
   DHCPACK:                            0
   DHCPNAK:                            0
   BOOTPREPLY:                         0
DHCP packets relayed to servers:       0
   DHCPDISCOVER:                       0
   DHCPREQUEST:                        0
   DHCPINFORM:                         0
   DHCPRELEASE:                        0
   DHCPDECLINE:                        0
   BOOTPREQUEST:                       0
DHCP packets relayed to clients:       0
   DHCPOFFER:                          0
   DHCPACK:                            0
   DHCPNAK:                            0
   BOOTPREPLY:                         0
DHCP packets sent to servers:          0
   DHCPDISCOVER:                       0
   DHCPREQUEST:                        0
   DHCPINFORM:                         0
   DHCPRELEASE:                        0
   DHCPDECLINE:                        0
   BOOTPREQUEST:                       0
DHCP packets sent to clients:          0
   DHCPOFFER:                          0
   DHCPACK:                            0
   DHCPNAK:                            0
   BOOTPREPLY:                         0
表1-13 display dhcp relay statistics命令显示信息描述表
DHCP中继丢弃的报文总数
报文类型错误丢弃的报文数
Option选项解析失败丢弃的报文数
Mac-check failed
MAC地址检查不通过丢弃的报文数
Other count
其它原因丢弃的报文数
DHCP中继从客户端接收的DHCP报文数
DHCP中继从服务器接收的DHCP报文数
DHCP中继转发给服务器的报文数
DHCP中继转发给客户端的报文数
DHCP中继主动发送给服务器的DHCP报文数,用于实现动态用户地址表项的定时刷新
DHCP中继主动发送给客户端的DHCP报文数(目前设备作为DHCP中继时,不会主动发送DHCP报文给客户端)
·     reset dhcp relay statistics
1.3.31  gateway-list
gateway-list命令用来指定匹配该地址池的DHCP客户端所在的网段的地址。
undo gateway-list命令用来删除指定的匹配该地址池的DHCP客户端所在的网段的地址。
未指定匹配该地址池的DHCP客户端所在的网段地址。
DHCP地址池视图
ip-address&<1-63>:该地址池的DHCP客户端所在的网段的地址。&<1-63>表示最多可以输入63个IP地址,每个IP地址之间用空格分隔。
# 指定匹配该地址池0的DHCP客户端所在的网段的地址为10.1.1.1。
·     dhcp smart-relay enable
1.3.32  master-server switch-delay
undo master-server switch-delay命令用来恢复缺省情况。
DHCP地址池视图
# 在DHCP地址池0上,配置回切主用DHCP服务器并指定回切延迟时间为3分钟。
[Sysname-dhcp-pool-0] master-server switch-delay 3
1.3.33  remote-server
remote-server命令用来指定中继地址池对应的DHCP服务器地址。
undo remote-server命令用来删除为中继地址池指定的DHCP服务器地址。
remote-server ip-address&<1-8> [ public | vpn-instance vpn-instance-name ]
undo remote-server [ ip-address&<1-8> ]
未指定中继地址池的DHCP服务器的地址。
DHCP地址池视图
ip-address&<1-8>:DHCP服务器的IP地址。&<1-8>表示最多可以输入8个不同的IP地址,每个IP地址之间需要用空格分隔。
public:指定公网中的DHCP服务器。
vpn-instance vpn-instance-name:指定VPN实例内的DHCP地址池。vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。
执行undo remote-server命令时,如果未指定任何参数,则删除所有配置DHCP服务器地址。
如果未指定public或vpn-instance vpn-instance-name参数,则以当前DHCP客户端位置(公网或VPN)为准。
# 配置DHCP地址池0为中继配置的服务器地址为10.1.1.1。
[Sysname-dhcp-pool-0] remote-server 10.1.1.1
1.3.34  remote-server algorithm
remote-server algorithm命令用来配置DHCP中继选择DHCP服务器方式。
undo remote-server algorithm命令用来恢复缺省情况。
remote-server algorithm { master-backup | polling }
DHCP地址池视图
# 在中继地址池0内,配置DHCP中继使用主备方式选择DHCP服务器。
[Sysname-dhcp-pool-0] remote-server algorithm master-backup
·     dhcp-server timeout
·     master-server switch-delay
·     remote-server
1.3.35  reset dhcp relay client-information
reset dhcp relay client-information命令用来清除DHCP中继的用户地址表项信息。
interface interface-type interface-number:清除指定接口上的DHCP中继的用户地址表项信息。interface-type interface-number为接口类型和接口编号。如果未指定本参数,则清除所有接口的DHCP中继的用户地址表项信息。
ip ip-address:清除指定IP地址的用户地址表项信息。如果未指定本参数,则清除所有IP地址的DHCP中继的用户地址表项信息。
vpn-instance vpn-instance-name:清除指定VPN实例内指定IP地址的用户地址表项信息。vpn-name表示MPLS L3VPN的VPN实例名,为1~31个字符的字符串,区分大小写。如果未指定本参数,则表示清除公网的用户地址表项信息。
# 清除所有DHCP中继的用户地址表项信息。
<Sysname> reset dhcp relay client-information
·     display dhcp relay client-information
1.3.36  reset dhcp relay statistics
reset dhcp relay statistics命令用来清除DHCP中继的相关报文统计信息。
interface interface-type interface-number:清除指定接口的DHCP中继相关报文统计信息。interface-type interface-number为接口类型和接口编号。如果未指定本参数,则清除所有的DHCP中继相关报文统计信息。
# 清除所有的DHCP中继相关报文统计信息。
<Sysname> reset dhcp relay statistics
·     display dhcp relay statistics
1.4  DHCP客户端配置命令
1.4.1  dhcp client dad enable
dhcp client dad enable命令用来开启地址冲突检查功能。
undo dhcp client dad enable命令用来关闭地址冲突检查功能。
地址冲突检查功能处于开启状态。
DHCP客户端通过发送和接收ARP报文,对DHCP服务器分配的IP地址进行地址冲突检测,如果攻击者仿冒地址拥有者进行ARP应答,就可以欺骗DHCP客户端,导致DHCP客户端无法正常使用分配到的IP地址。在网络中存在上述攻击者时,建议在客户端上关闭地址冲突检查功能。
# 关闭地址冲突检查功能。
[Sysname] undo dhcp client dad enable
1.4.2  dhcp client dscp
dhcp client dscp命令用来配置DHCP客户端发送DHCP报文的DSCP优先级。
undo dhcp client dscp命令用来恢复缺省情况。
dhcp client dscp dscp-value
DHCP客户端发送DHCP报文的DSCP优先级为56。
dscp-value:DHCP请求报文的DSCP优先级,取值范围为0~63。
# 配置DHCP客户端发送的DHCP报文的DSCP优先级为30。
[Sysname] dhcp client dscp 30
1.4.3  dhcp client identifier
dhcp client identifier命令用来配置接口使用指定的DHCP客户端ID。
undo dhcp client identifier命令用来取消接口使用指定的DHCP客户端ID的配置。
空配置启动时:
根据本接口的MAC地址生成DHCP客户端ID。如果本接口没有MAC地址,则获取设备第一个以太接口的MAC地址生成DHCP客户端ID。
出厂配置启动时:
·     Vlan-interface1接口使用的DHCP客户端ID为ASCII字符串,形式为桥MAC-VLAN0001,例如:5cdd7000a07b-VLAN0001。
·     其余接口根据本接口的MAC地址生成DHCP客户端ID。如果本接口没有MAC地址,则获取设备第一个以太接口的MAC地址生成DHCP客户端ID。
关于空配置启动和出厂配置启动的详细介绍,请参见“基础配置指导”中的“配置文件管理”。
ascii ascii-string:使用指定的ASCII字符串作为该接口的客户端ID,为1~63个字符的字符串,区分大小写。
hex hex-string:使用指定的十六进制数作为该接口的客户端ID,为4~64个字符的字符串。
mac interface-type interface-number:使用指定接口的MAC地址作为客户端ID。interface-type interface-number表示接口类型和接口编号。
DHCP客户端ID用来填充DHCP报文Option 61,作为识别DHCP客户端的唯一标识。DHCP服务器可以根据客户端ID为特定的客户端分配特定的IP地址。用户可以通过以下三种方法指定DHCP客户端ID:ASCII字符串、十六进制数或使用指定接口的MAC地址作为DHCP客户端ID,以上三种方式都需要由用户保证不同客户端的客户端ID不会相同。
# 配置VLAN接口10使用的客户端ID为十六进制数FFFFFFFF。
[Sysname-Vlan-interface10] dhcp client identifier hex FFFFFFFF
·     display dhcp client
1.4.4  display dhcp client
display dhcp client命令用来显示DHCP客户端的相关信息。
verbose:显示DHCP客户端的详细信息。如果未指定本参数,则显示DHCP客户端简要信息。
interface interface-type interface-number:显示指定接口的DHCP客户端相关信息。interface-type interface-number为接口类型和接口编号。如果未指定本参数,则显示所有接口的DHCP客户端信息。
# 显示所有接口的DHCP客户端简要信息。
<Sysname> display dhcp client
Vlan-interface10 DHCP client information:
 Current state: BOUND
 Allocated IP: 40.1.1.20 255.255.255.0
 Allocated lease: 259200 seconds, T1: 129600 seconds, T2: 226800 seconds
 DHCP server: 40.1.1.2
# 显示所有接口的DHCP客户端详细信息。
<Sysname> display dhcp client verbose
 Transaction ID: 0x1c09322d
 TFTP server name: 123
 TFTP server address: 192.168.56.1
Classless static routes:
   Destination: 1.1.0.1, Mask: 255.0.0.0, NextHop: 192.168.40.16
   Destination: 10.198.122.63, Mask: 255.255.255.255, NextHop: 192.168.40.16
 DNS servers: 44.1.1.11 44.1.1.12
 Domain name: example.com
 Boot servers: 200.200.200.200  1.1.1.1
 ACS parameter:
   URL: https://192.168.1.1:7547/acs
   Username: bims
   Password: ******
 Client ID value: 000c.29d3.8659-Vlan10
                            6433-2e38-3635-392d-
                            4574-6830-2f30-2f32
 T1 will timeout in 1 day 11 hours 58 minutes 52 seconds.
表1-14 display dhcp client命令显示信息描述表
XXXX DHCP client information
作为DHCP客户端的接口信息
Current state
DHCP客户端状态机的当前状态,取值包括:
·     HALT:停止申请IP地址状态;
·     INIT:初始化状态;
·     SELECTING:发送DHCP-DISCOVER报文寻找DHCP服务器后,进入该状态,等待DHCP服务器的响应报文;
·     REQUESTING:发送DHCP-REQUEST报文请求IP地址后,进入该状态,等待DHCP服务器的响应报文;
·     BOUND:接收到DHCP服务器发送的DHCP-ACK报文,成功获取IP地址后,进入该状态;
·     RENEWING:T1定时器超时后,进入该状态;
·     REBOUNDING:T2定时器超时后,进入该状态。
Allocated IP
DHCP服务器为接口分配的IP地址
Allocated lease
租约时长
T1
DHCP客户端的一半左右租约时间(以秒为单位)
T2
DHCP客户端的7/8租约时间(以秒为单位)
Lease from…to…
租约起止时间
DHCP server
选择的DHCP服务器的地址
Transaction ID
DHCP客户端发起申请时生成的一个随机数,用来唯一标识一次申请过程
TFTP server name
为DHCP客户端指定的TFTP服务器名称
TFTP server address
为DHCP客户端指定的TFTP服务器地址
Default router
为DHCP客户端指定的网关地址
为DHCP客户端指定的无分类静态路由
Static routes
为DHCP客户端指定的有分类静态路由
DNS servers
为DHCP客户端指定的DNS服务器地址
Domain name
为DHCP客户端指定的域名后缀
Boot servers
为DHCP客户端指定的PXE引导服务器地址,通过Option 43获取,最多可以获取16个地址
ACS parameter
ACS参数
URL
ACS的URL地址
Username
登录ACS设备使用的用户名
Password
登录ACS设备使用的密码,若存在密码,则显示为“******”;若不存在密码,则不显示此项;
Client ID type
DHCP客户端ID的类型,type value表示类型值。类型为ASCII时,type value为00;为MAC address时,type value为01;为Hex时,type value为配置的十六进制数的前两位
Client ID value
DHCP客户端ID的取值
DHCP客户端ID的十六进制形式(带类型值字段)
在多少时间后T1定时器(即一半左右租约时间)将到期
·     dhcp client identifier
·     ip address dhcp-alloc
1.4.5  ip address dhcp-alloc
ip address dhcp-alloc命令用来配置接口通过DHCP协议获取IP地址。
undo ip address dhcp-alloc命令用来取消接口通过DHCP协议获取的IP地址。
·     空配置启动时,接口不通过DHCP协议获取IP地址。
·     出厂配置启动时,Vlan-interface1接口通过DHCP方式自动获取IP地址。
取消接口通过DHCP协议获取IP地址时,DHCP客户端会发送DHCP-RELEASE报文通知DHCP服务器释放租约。如果此时该接口处于down状态,则无法保证报文成功发送。
如果配置子接口通过DHCP协议获取IP地址,在其主接口上执行shutdown命令时,DHCP客户端不会发送请求释放子接口IP地址租约的DHCP-RELEASE报文。
# 在VLAN接口10上配置接口通过DHCP协议获取IP地址。
[Sysname-Vlan-interface10] ip address dhcp-alloc
1.4.6  snmp-agent trap enable dhcp-client
snmp-agent trap enable dhcp-client命令用来开启DHCP客户端的告警功能。
undo snmp-agent trap enable dhcp-client命令用来关闭DHCP客户端的告警功能。
snmp-agent trap enable dhcp-client [ ip-apply-failed | local-conflict ]*
undo snmp-agent trap enable dhcp-client [ ip-apply-failed | local-conflict ]*
DHCP客户端所有类型的告警功能均处于开启状态。
ip-apply-failed:表示DHCP客户端申请地址失败的告警功能。
local-conflict:表示DHCP客户端获得的IP地址与本设备上其它接口地址冲突(同网段)的告警功能。
开启DHCP客户端模块的告警功能后,该模块会生成告警信息,用于报告该模块的重要事件。生成的告警信息将发送到设备的SNMP模块,通过设置SNMP中告警信息的发送参数,来决定告警信息输出的相关属性。
# 开启DHCP客户端获得的IP地址与本设备上其它接口地址冲突的告警功能。
[Sysname] snmp-agent trap enable dhcp-client local-conflict
1.5  DHCP Snooping配置命令
设备只有位于DHCP客户端与DHCP服务器之间,或DHCP客户端与DHCP中继之间时,DHCP Snooping功能配置后才能正常工作;设备位于DHCP服务器与DHCP中继之间时,DHCP Snooping功能配置后不能正常工作。
1.5.1  dhcp snooping alarm enable
dhcp snooping alarm enable命令用来开启DHCP Snooping报文丢弃日志告警功能。
undo dhcp snooping alarm enable命令用来关闭DHCP Snooping报文丢弃日志告警功能。
dhcp snooping alarm { giaddr | mac-address | request-message } enable
undo dhcp snooping alarm { giaddr | mac-address | request-message } enable
DHCP Snooping报文丢弃日志告警功能处于关闭状态。
giaddr:DHCP请求方向报文的giaddr字段检查功能。
mac-address:DHCP Snooping的MAC地址检查功能。
request-message:DHCP Snooping的DHCP请求方向报文检查功能。
开启本功能后,当指定检查功能丢弃的报文数等于通过dhcp snooping alarm threshold命令指定的报文丢弃告警阈值后,设备就会生成相应的告警日志信息,并将日志信息交给信息中心模块处理,信息中心模块的配置将决定日志信息的发送规则和发送方向。关于信息中心的详细描述请参见“网络管理和监控配置指导”中的“信息中心”。
只有首先执行dhcp snooping log enable命令开启DHCP Snooping日志信息功能后,本功能才能生效。
# 开启DHCP请求方向报文的giaddr字段检查功能的报文丢弃日志告警功能。
[Sysname] dhcp snooping alarm giaddr enable
·     dhcp snooping alarm threshold
·     dhcp snooping check giaddr
·     dhcp snooping check mac-address
·     dhcp snooping check request-message
·     dhcp snooping log enable
1.5.2  dhcp snooping alarm threshold
dhcp snooping alarm threshold命令用来设置全局DHCP Snooping报文丢弃告警阈值。
undo dhcp snooping alarm threshold threshold命令用来恢复缺省情况。
dhcp snooping alarm { giaddr | mac-address | request-message } threshold threshold
undo dhcp snooping alarm { giaddr | mac-address | request-message } threshold
全局DHCP Snooping报文丢弃的告警阈值为100。
threshold:DHCP Snooping报文丢弃告警阈值,取值范围为1~1000,单位为个。
设置DHCP Snooping报文丢弃的告警阈值后,当DHCP Snooping丢弃的报文数等于设置的报文丢弃告警阈值时,设备就会生成相应的告警日志信息。告警后,只有执行reset dhcp snooping alarm packet statistics命令清除当前统计数据后,设备才会开启新一轮统计。当DHCP Snooping丢弃的报文数再次达到阈值时,设备会继续输出告警日志。
# 设置全局DHCP请求方向报文的giaddr字段检查功能的报文丢弃告警阈值为2。
[Sysname] dhcp snooping alarm request-message threshold 2
·     dhcp snooping alarm enable
1.5.3  dhcp snooping binding database filename
dhcp snooping binding database filename命令用来指定存储DHCP Snooping表项的文件名称。
undo dhcp snooping binding database filename命令用来恢复缺省情况。
dhcp snooping binding database filename { filename | url url [ username username [ password { cipher | simple } string ] ] }
未指定存储文件名称。
url url:配置远程目标文件URL,为1~255个字符的字符串,区分大小写,该配置用于远程文件系统模式。此参数中不能包含用户名和密码,和参数username和string配合使用。远程目标文件URL是否支持路径格式遵循远程服务器端规格。
username username:配置登录远程目标文件URL时的用户名,为1~32个字符的字符串,区分大小写。如果未指定本参数,则表示登录远程目标文件URL时无需使用用户名。
cipher:表示以密文方式设置用户密码。
string:密码字符串,区分大小写。明文密码为1~32个字符的字符串,密文密码为1~73个字符的字符串。如果未指定本参数,则表示登录远程目标文件URL时无需使用密码。
存储DHCP Snooping表项时,如果设备中还不存在对应名称的文件,则设备会自动创建该文件。
执行本命令后,会立即触发一次表项备份。之后,如果未配置dhcp snooping binding database update interval命令,若表项发生变化,默认在300秒之后刷新存储文件;若表项未发生变化,则不再刷新存储文件。如果配置了dhcp snooping binding database update interval命令,若表项发生变化,则到达刷新时间间隔后刷新存储文件;若表项未发生变化,则不再刷新存储文件。
参数filename不支持远程目标文件URL,配置远程目标文件URL请使用url、username、string配合使用。
频繁擦写本地存储介质可能会影响存储介质寿命,建议使用远程文件系统模式存储DHCP Snooping表项文件。
当进行远程存储时,支持FTP和TFTP协议:
·     当采用FTP或TFTP协议时,服务器地址支持IPv4形式或IPv6形式,并且支持DNS域名方式。服务器地址为IPv6地址形式时需使用方括号(“[”和“]”)引用。配置服务器地址为DNS域名格式时请勿使用方括号引用。
·     当采用FTP协议时,URL采用“ftp://服务器地址[:端口号]/文件路径”的形式,如有用户名和密码请分别使用参数username和参数string进行配置,用户名和密码必须和服务器上的配置一致,如果服务器只对用户名进行认证,则不用输入密码。
·     当采用TFTP协议时,URL采用“tftp://服务器地址[:端口号]/文件路径”的形式。
# 配置存储DHCP Snooping表项的文件名为database.dhcp。
[Sysname] dhcp snooping binding database filename database.dhcp
# 配置远程存储DHCP Snooping表项至IP地址为1.1.1.1的ftp服务器工作目录下,用户名为1,密码为1,文件名为database.dhcp。
[Sysname] dhcp snooping binding database filename url ftp://10.1.1.1/database.dhcp username 1 password simple 1
# 配置远程存储DHCP Snooping表项至IP地址为10.1.1.1的tftp服务器工作目录下,文件名为database.dhcp。
[Sysname] dhcp snooping binding database filename url tftp://10.1.1.1/database.dhcp
·     dhcp snooping binding database update interval
1.5.4  dhcp snooping binding database update interval
dhcp snooping binding database update interval命令用来配置刷新DHCP Snooping表项存储文件的延迟时间。
undo dhcp snooping binding database update interval命令用来恢复缺省情况。
dhcp snooping binding database update interval interval
若DHCP Snooping表项不变化,则不刷新存储文件;若DHCP Snooping表项发生变化,默认在300秒之后刷新存储文件。
执行本命令后,当DHCP Snooping表项发生变化后,DHCP Snooping设备开始计时,当本命令配置的延迟时间到达后,DHCP Snooping会把这个时间段内表项所有的变化信息备份到固化文件中。
如果未通过dhcp snooping binding database filename命令指定存储表项的文件,则本命令不会生效。
# 若DHCP Snooping表项发生变化,在600秒后刷新表项存储文件。
[Sysname] dhcp snooping binding database update interval 600
·     dhcp snooping binding database filename
1.5.5  dhcp snooping binding database update now
dhcp snooping binding database update now命令用来将当前的DHCP Snooping表项保存到用户指定的文件中。
本命令只用来触发一次DHCP Snooping表项的备份。
# 将当前的DHCP Snooping表项保存到文件中。
[Sysname] dhcp snooping binding database update now
1.5.6  dhcp snooping binding record
dhcp snooping binding record命令用来开启端口的DHCP Snooping表项记录功能。
undo dhcp snooping binding record命令用来关闭端口的DHCP Snooping表项记录功能。
端口DHCP Snooping表项记录功能处于关闭状态。
二层以太网接口视图/二层聚合接口视图
VLAN视图
用户可在DHCP Snooping设备直接与客户端连接的端口上开启DHCP Snooping表项记录功能。
在端口上开启DHCP Snooping表项记录功能后,设备将监听该端口上接收的报文,生成DHCP Snooping表项。
# 开启端口Ten-GigabitEthernet3/0/1的DHCP Snooping表项记录功能。
[Sysname]interface ten-gigabitethernet 3/0/1
[Sysname-Ten-GigabitEthernet3/0/1] dhcp snooping binding record
1.5.7  dhcp snooping check giaddr
dhcp snooping check giaddr命令用来开启DHCP Snooping的DHCP请求方向报文的giaddr字段检查功能。
undo dhcp snooping check giaddr命令用来关闭DHCP Snooping的DHCP请求方向报文的giaddr字段检查功能。
DHCP请求方向报文的giaddr字段检查功能处于关闭状态。
二层以太网接口视图
二层聚合接口视图
DHCP请求报文中的giaddr字段记录了请求报文经过的第一跳DHCP中继的地址信息。DHCP Snooping设备只有位于DHCP客户端与DHCP服务器之间,或DHCP客户端与DHCP中继之间时,才能正常工作。当DHCP Snooping收到的DHCP请求报文中的giaddr字段不为0,表示DHCP Snooping设备位于DHCP中继与DHCP服务器之间,DHCP Snooping无法正常工作。开启本功能后,DHCP Snooping收到giaddr字段不为0的DHCP请求报文后,直接丢弃该报文。当丢弃的报文数大于或等于阈值时,DHCP Snooping会生成日志信息。管理员看到相关日志信息后,可以及时调整DHCP设备的位置,使DHCP Snooping可以正常工作。
# 在接口Ten-GigabitEthernet3/0/1上开启DHCP Snooping的DHCP请求方向报文的giaddr字段检查功能。
[Sysname] interface ten-gigabitethernet 3/0/1
[Sysname-Ten-GigabitEthernet3/0/1] dhcp snooping check giaddr
1.5.8  dhcp snooping check mac-address
dhcp snooping check mac-address命令用来开启DHCP Snooping的MAC地址检查功能。
undo dhcp snooping check mac-address命令用来关闭DHCP Snooping的MAC地址检查功能。
DHCP Snooping的MAC地址检查功能处于关闭状态。
二层以太网接口视图/二层聚合接口视图
三层以太网接口视图/三层聚合接口视图
开启该功能后,DHCP Snooping检查接收到的DHCP请求报文中的chaddr字段和数据帧的源MAC地址字段是否一致。如果一致,则认为该报文合法,将其转发给DHCP服务器;如果不一致,则丢弃该报文。
# 开启DHCP Snooping的MAC地址检查功能。
[Sysname-Ten-GigabitEthernet3/0/1] dhcp snooping check mac-address
1.5.9  dhcp snooping check request-message
dhcp snooping check request-message命令用来开启DHCP Snooping的DHCP请求方向报文检查功能。
undo dhcp snooping check request-message命令用来关闭DHCP Snooping的DHCP请求方向报文检查功能。
DHCP Snooping的DHCP请求方向报文检查功能处于关闭状态。
二层以太网接口视图/二层聚合接口视图
如果开启了该功能,则DHCP Snooping设备接收到上述报文后,检查本地是否存在与接收报文匹配的DHCP Snooping表项。若存在,则接收报文信息与DHCP Snooping表项信息一致时,认为该报文为合法的请求方向报文,将其转发给DHCP服务器;不一致时,认为该报文为伪造的请求方向报文,将其丢弃。若不存在,则认为该报文合法,将其转发给DHCP服务器。
# 开启DHCP Snooping的DHCP请求方向报文检查功能。
[Sysname-Ten-GigabitEthernet3/0/1] dhcp snooping check request-message
1.5.10  dhcp snooping client-detect
dhcp snooping client-detect命令用来开启DHCP Snooping的用户下线探测功能。
undo dhcp snooping client-detect命令用来关闭DHCP Snooping的用户下线探测功能。
DHCP Snooping的用户下线探测功能处于关闭状态。
当DHCP客户端非正常下线时,不会向DHCP服务器发送报文释放地址租约,这会使DHCP服务器上无法获知DHCP客户端下线,导致地址租约浪费。开启本功能后,当设备上的某条ARP表项老化后,DHCP Snooping就认为该表项对应的DHCP客户端已经下线,则会删除对应的DHCP Snooping表项,并构造DHCP-RELEASE报文通知DHCP服务器删除对应的IP地址租约。
# 开启DHCP Snooping的用户下线探测功能。
[Sysname] dhcp snooping client-detect
1.5.11  dhcp snooping deny
dhcp snooping deny命令用来在端口上开启DHCP Snooping报文阻断功能。
undo dhcp snooping deny命令用来在端口上关闭DHCP Snooping报文阻断功能。
dhcp snooping deny
端口上的DHCP Snooping报文阻断功能处于关闭状态。
二层以太网接口视图/二层聚合接口视图
在端口上开启本功能后,DHCP Snooping设备会丢弃该端口收到的所有DHCP请求方向报文,这将导致该端口上的DHCP客户端无法申请到IP地址。因此,本功能只能在未连接DHCP客户端的端口上开启。
在某些组网环境下,用户需要在DHCP Snooping设备的某一端口上丢弃该端口收到的所有DHCP请求方向报文,而又不影响其他端口正常接收DHCP报文。这时,用户可以在该端口上开启DHCP Snooping报文阻断功能。
# 在端口Ten-GigabitEthernet3/0/1上开启DHCP Snooping报文阻断功能。
[Sysname-Ten-GigabitEthernet3/0/1] dhcp snooping deny
1.5.12  dhcp snooping disable
dhcp snooping disable命令用来关闭接口的DHCP Snooping功能。
undo dhcp snooping disable命令用来恢复缺省情况。
若接口所在设备或VLAN上已经开启DHCP Snooping功能,则接口的DHCP Snooping功能处于开启状态;若接口所在设备或VLAN上未开启DHCP Snooping功能,则接口的DHCP Snooping功能处于关闭状态。
当管理员在设备或VLAN中开启DHCP Snooping功能后,该设备或整个VLAN内的所有接口上也都开启了DHCP Snooping功能。为了能灵活控制DHCP Snooping功能生效的接口范围,用户可以通过本功能关闭某个接口上的DHCP Snooping功能。
# 关闭接口Ten-GigabitEthernet3/0/1上的DHCP Snooping功能。
[Sysname-Ten-GigabitEthernet3/0/1] dhcp snooping disable
1.5.13  dhcp snooping enable
dhcp snooping enable命令用来全局开启DHCP Snooping功能。
undo dhcp snooping enable命令用来全局关闭DHCP Snooping功能。
全局的DHCP Snooping功能处于关闭状态。
全局开启DHCP Snooping功能后,如果不信任端口接收到DHCP服务器发送的报文,将丢弃该报文,以保证客户端从合法的DHCP服务器获取IP地址。
在全局DHCP Snooping功能关闭后,所有端口都可转发DHCP服务器的响应报文。
# 全局开启DHCP Snooping功能。
[Sysname] dhcp snooping enable
1.5.14  dhcp snooping enable vlan
dhcp snooping enable vlan命令用来在指定VLAN内开启DHCP Snooping功能。
undo dhcp snooping enable vlan命令用来在指定VLAN内关闭DHCP Snooping功能。
dhcp snooping enable vlan vlan-id-list
undo dhcp snooping enable vlan vlan-id-list
所有VLAN内的DHCP Snooping功能均处于关闭状态。
vlan-id-list:VLAN列表,表示方式为vlan-id-list = { vlan-id1 [ to vlan-id2 ] }&<1-10>,vlan-id取值范围为1~4094,vlan-id2的值要大于或等于vlan-id1的值,&<1-10>表示前面的参数最多可以重复输入10次。
在指定VLAN内开启DHCP Snooping功能后,如果VLAN内的不信任端口接收到DHCP服务器发送的应答报文,该接口会丢弃该报文,以保证DHCP客户端从合法的DHCP服务器获取IP地址。
在指定VLAN内关闭DHCP Snooping功能后,该VLAN内所有接口都会转发DHCP服务器发送的应答报文。
# 在VLAN 5、VLAN 10到VLAN 20和VLAN 32中开启DHCP Snooping功能。
[Sysname] dhcp snooping enable vlan 5 10 to 20 32
1.5.15  dhcp snooping exhaustion trap enable
dhcp snooping exhaustion trap enable命令用来开启DHCP Snooping表项资源耗尽/恢复告警功能。
undo dhcp snooping exhaustion trap enable命令关闭DHCP Snooping表项资源耗尽/恢复告警功能。
DHCP Snooping表项资源耗尽/恢复告警功能处于关闭状态。
二层以太网接口视图/二层聚合接口视图
当动态学习到的DHCP Snooping绑定表项数目已经达到最大值,即资源耗尽时,设备会生成告警信息提示管理员表项资源已耗尽,新上线用户将生成不了绑定表项。
只有开启DHCP Snooping表项资源耗尽/恢复告警功能(执行snmp-agent trap enable dhcp snooping binding-exhaust命令)后,本命令才能生效。如果希望减少告警信息的生成,可以使用undo dhcp snooping exhaustion trap enable命令关闭部分接口的DHCP Snooping表项资源耗尽告警功能。
# 在接口Ten-GigabitEthernet3/0/1下关闭DHCP Snooping表项资源耗尽/恢复告警功能。
[Sys-Ten-GigabitEthernet3/0/1] undo dhcp snooping exhaustion trap enable
·     snmp-agent trap enable dhcp snooping
1.5.16  dhcp snooping information circuit-id
dhcp snooping information circuit-id命令用来配置Option 82的Circuit ID子选项的填充模式和填充格式。
undo dhcp snooping information circuit-id命令用来恢复缺省情况。
dhcp snooping information circuit-id { normal-extended | [ vlan vlan-id ] string circuit-id | { normal | verbose [ node-identifier { mac | sysname | user-defined node-identifier } ] } [ format { ascii | hex } ] }
undo dhcp snooping information circuit-id [ vlan vlan-id ]
二层以太网接口视图
二层聚合接口视图
VLAN视图
vlan vlan-id:为从指定VLAN内收到的DHCP报文填充Circuit ID子选项。如果未指定本参数,则表示为系统缺省VLAN(VLAN1)内收到的DHCP报文填充Circuit ID子选项。VLAN视图下不支持指定本参数。
normal-extended:指定以扩展Normal模式填充Circuit ID子选项,填充内容为收到DHCP报文的接口所属的VLAN ID、接口所在slot的编号和接口序号(例如接口GE1/0/3的接口序号为3)。
verbose:指定以Verbose模式填充Circuit ID子选项。填充的内容为节点标识、收到DHCP报文的接口信息和接口所在的VLAN编号。节点标识缺省以节点的MAC地址构成;接口信息缺省由以太网类型(取值固定为“eth”)、框号、槽号、子槽号和接口序号组成。
·     sysname:表示以节点的设备名称作为节点标识。设备的系统名称可以通过系统视图下的sysname命令配置。不管配置了哪种填充格式,设备的系统名称始终采用ASCII码格式填充。设备名称不能包含空格,否则DHCP Snooping设备无法正常添加Vendor-specific子选项内容。
以用户配置的字符串填充Circuit ID子选项时,填充格式固定为ASCII码格式。
·     如果本命令中未指定填充格式,则对于Normal模式,VLAN ID和端口号均以hex格式填充;对于Verbose模式,节点标识(MAC地址、设备的系统名称或指定的字符串)、以太网类型、框号、槽号、子槽号、接口序号均以ASCII码格式填充,VLAN ID以hex格式填充。
Option 82的Circuit ID子选项信息中无法携带接口拆分信息或子接口信息,关于“接口拆分”和“子接口”的详细介绍,请参见“以太网接口配置指导”中的“以太网接口通用配置”。
多次执行该命令,最后一次执行的命令生效。
[Sysname-Ten-GigabitEthernet3/0/1] dhcp snooping information enable
[Sysname-Ten-GigabitEthernet3/0/1] dhcp snooping information strategy replace
[Sysname-Ten-GigabitEthernet3/0/1] dhcp snooping information circuit-id verbose node-identifier sysname format ascii
·     dhcp snooping information enable
·     dhcp snooping information strategy
·     display dhcp snooping information
1.5.17  dhcp snooping information enable
dhcp snooping information enable命令用来开启DHCP Snooping支持Option 82功能。
undo dhcp snooping information enable命令用来关闭DHCP Snooping支持Option 82功能。
DHCP Snooping支持Option 82功能处于关闭状态。
二层以太网接口视图
二层聚合接口视图
VLAN视图
开启DHCP Snooping支持Option 82功能后,DHCP Snooping将向转发给DHCP服务器的请求报文中增加Option 82选项。选项内容由dhcp snooping information circuit-id和dhcp snooping information remote-id决定。如果DHCP Snooping收到的请求报文中已经包含Option 82选项,则按照dhcp snooping information strategy配置的策略处理请求报文。
# 开启DHCP Snooping支持Option 82功能。
·     dhcp snooping information circuit-id
·     dhcp snooping information remote-id
1.5.18  dhcp snooping information remote-id
dhcp snooping information remote-id命令用来配置Option 82的Remote ID子选项的填充模式和填充格式。
undo dhcp snooping information remote-id命令用来恢复缺省情况。
dhcp snooping information remote-id { normal [ format { ascii | hex } ] | [ vlan vlan-id ] { hex remote-id | string remote-id | sysname } }
undo dhcp snooping information remote-id [ vlan vlan-id ]
二层以太网接口视图
二层聚合接口视图
VLAN视图
normal:指定以Normal模式填充Remote ID子选项,填充内容为设备的桥MAC地址。有关桥MAC地址的详细介绍,请参见“虚拟化技术配置指导”中的“IRF”。
format:指定Remote ID子选项的填充格式。如果未指定本参数,则以hex模式填充。
vlan vlan-id:为从指定VLAN内收到的DHCP报文填充Remote ID子选项。如果未指定本参数,则表示为系统缺省VLAN(VLAN1)内收到的DHCP报文填充Remote ID子选项。VLAN视图下不支持指定本参数。
hex remote-id:指定以十六进制方式填充Remote ID子选项。remote-id表示用户配置的用来填充Remote ID子选项的内容,为2~256个字符的字符串,不区分大小写。
[Sysname-Ten-GigabitEthernet3/0/1] dhcp snooping information remote-id string device001
1.5.19  dhcp snooping information strategy
dhcp snooping information strategy命令用来配置DHCP Snooping对包含Option 82的请求报文的处理策略。
undo dhcp snooping information strategy命令用来恢复缺省情况。
dhcp snooping information strategy { append | drop | keep | replace }
二层以太网接口视图
二层聚合接口视图
VLAN视图
append:按照如下处理方式处理报文,并进行转发:
·     如果报文中未带有Option 82,则按照配置的填充模式填充Option 82;
·     如果报文中带有Option 82:
¡     若配置了dhcp snooping information vendor-specific命令,则按照此命令配置的内容向Option 82的Vendor-specific子选项添加内容;
¡     若未配置dhcp snooping information vendor-specific命令,则保持该报文中的Option 82不变。
replace:不管报文中是否带有Option 82,都按照配置的填充模式填充Option 82,用该选项替换报文中原有的Option 82,并进行转发。
如果开启了DHCP Snooping支持Option 82功能,则对于接收到的不包含Option 82的请求报文,DHCP Snooping的处理方式始终为在请求报文中添加Option 82,并将报文转发给DHCP服务器。
DHCP Snooping对包含Option 82请求报文的处理策略为append或replace时,需要配置Option 82的填充模式和填充格式;处理策略为keep或drop时,不需要配置Option 82选项的填充模式和填充格式。
# 配置DHCP Snooping对带有Option 82的请求报文使用keep策略。
[Sysname-Ten-GigabitEthernet3/0/1] dhcp snooping information strategy keep
·     dhcp snooping information vendor-specific
1.5.20  dhcp snooping information vendor-specific
dhcp snooping information vendor-specific命令用来配置Option 82的Vendor-specific子选项的填充模式。
undo dhcp snooping information vendor-specific命令用来恢复缺省情况。
dhcp snooping information vendor-specific [ vlan vlan-id ] bas [ node-identifier { mac | sysname | user-defined string } ]
undo dhcp snooping information vendor-specific [ vlan vlan-id ]
设备不会填充Option 82的Vendor-specific子选项。
二层以太网接口视图
二层聚合接口视图
VLAN视图
vlan vlan-id:为从指定VLAN内收到的DHCP报文填充Vendor-specific子选项。如果未指定本参数,则表示为接口收到的所有DHCP报文填充Vendor-specific子选项。VLAN视图下不支持指定本参数。
bas:表示使用工信部规范的格式填充Vendor-specific子选项。
node-identifier:指定接入节点标识。如果未指定本参数,则缺省以节点的桥MAC地址作为标识。不管采用哪种方式,都是用ASCII码格式填充。
·     mac:表示以节点的桥MAC地址作为节点标识。
·     sysname:表示以节点的设备名称作为节点标识。设备的系统名称可以通过系统视图下的sysname命令配置。设备名称不能包含空格,否则DHCP Snooping设备无法正常添加Vendor-specific子选项内容;若设备名称长度超过50个字符,则只截取前50个字符。
·     user-defined string:表示以指定的字符串作为节点标识,string为1~50个字符的字符串,区分大小写,不能包含空格。
执行了本命令后,DHCP snooping收到DHCP请求报文后,会填充Option 82的Vendor-specific子选项并转发该报文。
如果配置的是dhcp snooping information strategy append时,当收到的DHCP请求报文中的Option 82选项长度已经到达上限,DHCP Snooping直接转发该报文,不会继续填充Vendor-specific子选项。
# 在接口Ten-GigabitEthernet3/0/1上配置DHCP Snooping以bas模式填充Option 82的Vendor-specific子选项,节点标识为设备的系统名称。
[Sysname-Ten-GigabitEthernet3/0/1] dhcp snooping information vendor-specific bas node-identifier sysname
1.5.21  dhcp snooping learning-num-threshold
dhcp snooping learning-num-threshold命令用来设置DHCP Snooping表项资源使用率的告警门限阈值。
undo dhcp snooping learning-num-threshold命令用来恢复缺省情况。
dhcp snooping learning-num-threshold threshold-value
DHCP Snooping的表项使用率告警门限阈值为100%。
二层以太网接口视图/二层聚合接口视图
threshold-value:表项资源使用率告警阈值,为百分比形式,取值范围为1~100。
DHCP Snooping表项资源使用率=已经动态学习到的表项数目/允许动态学习的表项最大数目(通过dhcp snooping max-learning-num命令配置)。
当DHCP Snooping表项资源使用率大于等于本命令配置的阈值时,DHCP Snooping会生成告警信息提醒管理员。同时,设备将不会为该接口后续新上线的DHCP Snooping用户生成绑定表项,但是DHCP Snooping功能正常运行。当表项资源使用率重新下降到低于阈值时,DHCP Snooping同样会生成告警信息。
在同一个视图下多次执行本命令,最后一次执行的命令生效。
# 在接口Ten-GigabitEthernet3/0/1下设置表项资源使用率告警门限阈值为75%。
[Sysname-Ten-GigabitEthernet3/0/1] dhcp snooping learning-num-threshold 75
·     dhcp snooping max-learning-num
1.5.22  dhcp snooping log enable
dhcp snooping log enable命令用来开启DHCP Snooping日志信息功能。
undo dhcp snooping log enable命令关闭DHCP Snooping日志信息功能。
DHCP Snooping日志信息功能处于关闭状态。
DHCP Snooping日志可以方便管理员定位问题和解决问题。DHCP Snooping设备生成DHCP Snooping日志信息(例如DHCP Snooping丢弃的报文信息)会交给信息中心模块处理,信息中心模块的配置将决定日志信息的发送规则和发送方向。关于信息中心的详细描述请参见“网络管理和监控配置指导”中的“信息中心”。
当DHCP Snooping设备输出大量日志信息时,可能会降低设备性能。为了避免该情况的发生,用户可以关闭DHCP Snooping日志信息功能,使得DHCP Snooping设备不再输出日志信息。
# 开启DHCP Snooping日志信息功能。
[Sysname] dhcp snooping log enable
1.5.23  dhcp snooping max-learning-num
dhcp snooping max-learning-num命令用来配置接口动态学习DHCP Snooping表项的最大数目。
undo dhcp snooping max-learning-num命令用来恢复缺省情况。
dhcp snooping max-learning-num max-number
不限制接口动态学习DHCP Snooping表项的最大数目。
二层以太网接口视图/二层聚合接口视图
三层以太网接口视图/三层聚合接口视图
max-number:接口动态学习DHCP Snooping表项的最大数目。取值范围为1~4294967295。
接口动态学习的DHCP Snooping表项数达到最大数目后,不影响DHCP Snooping功能正常运行,但是接口不会继续学习新的DHCP Snooping表项。
# 配置二层以太网接口Ten-GigabitEthernet3/0/1动态学习DHCP Snooping表项的最大数目为10。
[Sysname-Ten-GigabitEthernet3/0/1] dhcp snooping max-learning-num 10
1.5.24  dhcp snooping rate-limit
dhcp snooping rate-limit命令用来开启DHCP Snooping的报文限速功能,即限制接口接收DHCP报文的速率。
undo dhcp snooping rate-limit命令用来关闭DHCP Snooping的报文限速功能。
dhcp snooping rate-limit rate
DHCP Snooping的报文限速功能处于关闭状态,即不限制接口接收DHCP报文的速率。
二层以太网接口视图/二层聚合接口视图
rate:接口接收DHCP报文的最高速率,单位为Kbps。取值范围为64~512。
只有开启DHCP Snooping功能后,本命令的配置才会生效。
仅LSCM2系列SC单板和SD系列接口板支持本功能。
如果接口接收到的DHCP报文速率超过了限制,则丢弃超过速率限制的DHCP报文。
如果二层以太网接口加入了聚合组,则该接口采用对应二层聚合接口下的DHCP报文限速配置。如果二层以太网接口离开聚合组,则该接口采用二层以太网接口下的DHCP报文限速配置。
设备支持的速率值是8的整数倍,当用户设置的速率值为67时,实际的生效值是64或72。
# 配置二层以太网接口Ten-GigabitEthernet3/0/1接收DHCP报文的最高速率为64Kbps。
[Sysname-Ten-GigabitEthernet3/0/1] dhcp snooping rate-limit 64
1.5.25  dhcp snooping trap enable (interface view)
dhcp snooping trap enable命令用来开启指定接口上的DHCP Snooping报文丢弃告警功能。
undo dhcp snooping trap enable命令用来关闭指定接口上的DHCP Snooping报文丢弃告警功能。
dhcp snooping trap { binding-mismatch | chaddr-mismatch | rate-limit | untrust-reply software } enable
undo dhcp snooping trap { binding-mismatch | chaddr-mismatch | rate-limit | untrust-reply software } enable
接口上DHCP Snooping所有类型的报文丢弃告警功能均处于关闭状态。
二层以太网接口视图/二层聚合接口视图
binding-mismatch:表示与DHCP Snooping表项不匹配而被丢弃的DHCP报文数达到阈值时的告警功能。
chaddr-mismatch:表示数据帧头MAC地址与DHCP报文中的CHADDR字段不一致而被丢弃的报文数达到阈值时的告警功能。
rate-limit:表示因接收的报文速率超过限速值而被丢弃的DHCP报文数达到阈值时的告警功能。
untrust-reply software:表示非信任接口通过CPU软件端丢弃的DHCP服务器回应报文数达到阈值时的告警功能。
开启本功能后,当接口丢弃的DHCP报文数等于通过dhcp snooping trap threshold命令指定的告警阈值后,设备就会发送告警信息。
本功能仅在通过snmp-agent trap enable dhcp snooping命令开启相应的DHCP Snooping告警功能的情况下才能生效。如果希望减少告警信息的生成,可以使用undo dhcp snooping trap enable命令关闭部分接口的DHCP Snooping报文丢弃告警功能。
# 在接口Ten-GigabitEthernet3/0/1下关闭与DHCP Snooping表项不匹配而被丢弃的DHCP报文数达到阈值时的告警功能。
[Sysname-Ten-GigabitEthernet3/0/1] dhcp snooping trap binding-mismatch enable
·     dhcp snooping trap threshold(interface view)
·     dhcp snooping trap enable(system view)
·     dhcp snooping trap threshold(system view)
1.5.26  dhcp snooping trap enable (system view)
dhcp snooping trap enable命令用来开启全局DHCP Snooping报文丢弃告警功能。
undo dhcp snooping trap enable命令用来关闭全局DHCP Snooping报文丢弃告警功能。
dhcp snooping trap { rate-limit | untrust-reply { software | hardware } } enable
undo dhcp snooping trap { rate-limit | untrust-reply { software | hardware } } enable
全局DHCP Snooping所有类型的报文丢弃告警功能均处于关闭状态。
untrust-reply:表示非信任接口丢弃DHCP服务器回应报文数达到阈值时的告警功能。
·     software:表示非信任接口接收到的DHCP服务器回应报文上送CPU后通过软件端丢弃的数目达到阈值时的告警功能。
·     hardware:表示非信任接口接收到的DHCP服务器回应报文通过设备硬件驱动丢弃的数目达到阈值时的告警功能。
工作机制
开启因接收的报文速率超过限速值而被丢弃的DHCP报文数达到阈值时的告警功能后,当接口丢弃的报文数等于dhcp snooping trap threshold rate-limit命令设置的告警阈值时,设备会发送告警信息。
开启非信任接口丢弃DHCP服务器回应报文数达到阈值时的告警功能后,因为CPU软件端和硬件驱动属于不同的丢弃途径且丢弃的报文不重合,因此是分别基于各自的统计数据触发告警:
·     指定software参数时,CPU软件端将基于单个非信任接口对丢弃的DHCP服务器回应报文数进行统计计数,单个接口上丢弃的报文数达到阈值时,都将发送告警信息。
·     指定hardware参数时,设备硬件不区分接口,将基于全局对所有单板上非信任接口丢弃的DHCP服务器回应报文数进行统计计数,全局丢弃的报文数达到阈值时,才会发送告警信息。
告警后当前统计数据保留,设备会继续进行统计计数,但不再生成告警信息。只有通过reset dhcp snooping packet statistics命令清除报文统计信息后,当丢弃报文数再次达到阈值时,设备才会再次生成告警信息。
配置准备
本功能仅在通过snmp-agent trap enable dhcp snooping命令开启相应的DHCP Snooping告警功能的情况下生效。
注意事项
DHCP Snooping报文丢弃告警功能支持在全局和接口视图下配置。全局配置对所有接口生效:
·     全局报文丢弃告警功能开启时,在接口视图下执行undo dhcp snooping trap enable命令,仅关闭该接口的报文丢弃告警功能。
·     全局报文丢弃告警功能关闭时,在接口视图下配置dhcp snooping trap enable命令,仅开启该接口的报文丢弃告警功能。
# 开启DHCP Snooping接收的报文速率超过限速值而被丢弃的DHCP报文数达到阈值时的告警功能。
[Sysname] dhcp snooping trap rate-limit enable
1.5.27  dhcp snooping trap threshold (interface view)
dhcp snooping trap threshold命令用来设置DHCP Snooping报文丢弃的告警阈值。
undo dhcp snooping trap threshold命令用来恢复缺省情况。
dhcp snooping trap { binding-mismatch | chaddr-mismatch | rate-limit | untrust-reply software } threshold threshold
undo dhcp snooping trap { binding-mismatch | chaddr-mismatch | rate-limit | untrust-reply  software } threshold
以全局系统视图下配置的告警阈值为准。
二层以太网接口视图/二层聚合接口视图
binding-mismatch:设置与DHCP Snooping表项不匹配而被丢弃的DHCP请求报文数的告警阈值。
chaddr-mismatch:设置数据帧头MAC地址与DHCP报文中的CHADDR字段不一致而被丢弃的DHCP报文数的告警阈值。
rate-limit:设置因接收到的DHCP请求报文速率超过限速值而被丢弃的DHCP报文数的告警阈值。
untrust-reply software:设置非信任接口通过CPU软件端丢弃的DHCP服务器回应报文数的告警阈值。
threshold:DHCP Snooping报文丢弃的告警阈值,取值范围为1~1000,单位为个。
设置DHCP Snooping报文丢弃的告警阈值后,当通过snmp-agent trap enable dhcp snooping命令开启指定的报文丢弃告警功能后,DHCP Snooping丢弃的报文数等于设置的告警阈值时,设备将会生成相应的告警信息。
除了接口视图,DHCP Snooping报文丢弃的告警阈值还支持在系统视图下配置。系统视图下对应的告警阈值配置命令如下:
·     设置与DHCP Snooping表项不匹配而被丢弃的DHCP请求报文数的告警阈值:dhcp snooping alarm request-message threshold。
·     设置数据帧头MAC地址与DHCP报文中的CHADDR字段不一致而被丢弃的DHCP报文数的告警阈值:dhcp snooping alarm mac-address threshold。
·     设置因接收到的DHCP请求报文速率超过限速值而被丢弃的DHCP报文数的告警阈值:dhcp snooping trap rate-limit。
·     设置非信任接口丢弃的DHCP服务器回应报文数的告警阈值:dhcp snooping trap untrust-reply。
系统视图下配置的阈值对所有接口生效,当接口视图下配置的阈值与系统视图下不一致时,接口视图下的阈值生效。
# 在接口Ten-GigabitEthernet3/0/1下设置与DHCP Snooping表项不匹配而被丢弃的DHCP请求报文数的地址不匹配的告警阈值为75。
[Sysname-Ten-GigabitEthernet3/0/1] dhcp snooping trap binding-mismatch threshold 75
·     dhcp snooping alarm enable(interface view)
1.5.28  dhcp snooping trap threshold (system view)
dhcp snooping trap threshold命令用来设置全局DHCP Snooping报文丢弃的告警阈值。
undo dhcp snooping trap threshold命令用来取消设置全局DHCP Snooping报文丢弃的告警阈值。
dhcp snooping trap { rate-limit | untrust-reply { software | hardware } } threshold threshold
undo dhcp snooping trap { rate-limit | untrust-reply { software | hardware } } threshold
各类全局DHCP Snooping报文丢弃告警功能的告警阈值均为100。
untrust-reply:设置非信任接口丢弃的DHCP服务器回应报文数的告警阈值。
·     software:表示非信任接口通过CPU软件端丢弃的DHCP服务器回应报文数的告警阈值。
·     hardware:表示非信任接口通过设备硬件驱动丢弃的DHCP服务器回应报文数的告警阈值。
全局DHCP Snooping报文丢弃的告警阈值对所有接口生效。当全局和接口同时设置告警阈值时,以接口的配置为准。
# 设置因接收到的DHCP请求报文速率超过限速值而被丢弃的DHCP报文数的告警阈值为200。
[Sysname] dhcp snooping trap rate-limit threshold 200
1.5.29  dhcp snooping trust
dhcp snooping trust命令用来配置端口为信任端口。
undo dhcp snooping trust命令用来恢复端口为不信任端口。
dhcp snooping trust
在开启DHCP Snooping功能后,设备上所有支持DHCP Snooping功能的端口均为不信任端口。
二层以太网接口视图/二层聚合接口视图
三层以太网接口视图/三层聚合接口视图
指向DHCP服务器方向的端口需要设置为信任端口,其他端口设置为不信任端口,从而保证DHCP客户端只能从合法的DHCP服务器获取IP地址,私自架设的伪DHCP服务器无法为DHCP客户端分配IP地址。
# 配置二层以太网接口Ten-GigabitEthernet3/0/1为信任端口。
[Sysname-Ten-GigabitEthernet3/0/1] dhcp snooping trust
·     display dhcp snooping trust
1.5.30  dhcp snooping trust interface
dhcp snooping trust interface命令用来配置指定端口为VLAN下DHCP Snooping功能的信任端口。
undo dhcp snooping trust interface命令用来恢复端口为不信任端口。
dhcp snooping trust interface interface-type interface-number
undo dhcp snooping trust interface interface-type interface-number
在VLAN内开启DHCP Snooping功能后,该VLAN内所有支持DHCP Snooping功能的接口均为不信任端口。
VLAN视图
interface-type interface-number:信任端口的类型和编号。
在VLAN内连接DHCP服务器的接口需要设置为信任端口,其他接口设置为不信任端口,从而保证DHCP客户端只能从合法的DHCP服务器获取IP地址,私自架设的伪DHCP服务器无法为DHCP客户端分配IP地址。
在同一VLAN下多次执行本命令,可以为该VLAN下的DHCP Snooping功能指定多个信任端口。
为使配置生效,请保证将指定的信任端口加入到VLAN中。
# 配置接口Ten-GigabitEthernet3/0/1为VLAN 1下DHCP Snooping功能的信任端口。
[Sysname] vlan 1
[Sysname-vlan 1] dhcp snooping trust interface ten-gigabitethernet 3/0/1
1.5.31  dhcp snooping untrusted-server-record enable
dhcp snooping untrusted-server-record enable命令用来开启DHCP Snooping记录非信任DHCP服务器信息功能。
undo dhcp snooping untrusted-server-record enable命令用来关闭DHCP Snooping记录非信任DHCP服务器信息功能。
DHCP Snooping记录非信任DHCP服务器信息功能处于关闭状态。
一般情况下,DHCP Snooping的非信任端口收到DHCP服务器的应答报文时,会认为是非信任DHCP服务器应答的报文,直接丢弃该报文。开启本功能后,DHCP Snooping的非信任端口收到DHCP服务器的应答报文时,除了丢弃该报文,还会记录非信任DHCP服务器的信息,并生成对应的日志信息提示管理员网络中存在非信任DHCP服务器。生成的DHCP日志信息会发送给信息中心模块处理,信息中心模块的配置将决定日志信息的发送规则和发送方向。
仅在指定VLAN内开启DHCP snooping功能后,本功能才能生效。
对于同一个的非信任DHCP服务器,当生成一次日志信息后,10分钟内再次收到同一个非信任DHCP服务器的应答报文,也不会再生成日志;10分钟后收到同一个非信任DHCP服务器的应答报文,才会重新生成日志。
# 开启DHCP Snooping记录非信任DHCP服务器信息功能。
[Sysname] dhcp snooping untrusted-server-record enable
1.5.32  display dhcp snooping alarm packet statistics
display dhcp snooping alarm packet statistics命令用来显示DHCP Snooping设备上指定接口的DHCP告警报文丢弃统计信息。
display dhcp snooping alarm packet statistics interface interface-type interface-number
interface interface-type interface-number:显示DHCP Snooping设备上指定接口的DHCP告警报文丢弃统计信息。interface-type interface-number为接口类型和接口编号。
本命令主要用于开启DHCP Snooping告警功能后查看当前丢弃的报文统计数据,可以显示以下两种场景下被丢弃的DHCP请求报文数:
·     通过dhcp snooping check mac-address命令开启MAC地址报文检查功能后,数据帧头中的源MAC地址与DHCP请求报文中的CHADDR字段不一致被丢弃的DHCP请求报文数。
·     通过dhcp snooping check request-message命令开启DHCP请求方向报文检查功能后,与DHCP Snooping表项不匹配而被丢弃的DHCP请求报文数。
报文统计计数是一个累计过程,不会自动清除数据。如果在开启DHCP Snooping告警功能前,长期累计的丢弃报文数已超过阈值,则开启DHCP Snooping告警功能时会立即生成告警信息,无法体现短时间内的报文丢弃状态。因此在开启DHCP Snooping告警功能前,可以先通过reset dhcp snooping alarm packet statistics命令清除接口上当前的报文丢弃统计信息。
# 显示接口Ten-GigabitEthernet3/0/1上的DHCP告警报文丢弃统计信息。
<Sysname> display dhcp snooping alarm packet statistics interface ten-gigabitethernet 3/0/1
Interface: Ten-GigabitEthernet3/0/1
 DHCP packets received                  : 5
 Binding-mismatch packets dropped       : 0
 Chaddr-mismatch packets dropped        : 5
表1-15 display dhcp snooping alarm packet statistics命令显示信息描述表
开启DHCP Snooping告警功能的接口
接收的DHCP报文数
·     reset dhcp snooping alarm packet statistics
1.5.33  display dhcp snooping binding
display dhcp snooping binding命令用来显示DHCP Snooping表项信息。
display dhcp snooping binding [ interface interface-type interface-number | ip ip-address [ vlan vlan-id ] ] [ verbose ]
interface interface-type interface-number:显示指定接口上的DHCP Snooping表项信息。interface-type interface-number表示接口类型和接口编号。如果未指定本参数,则显示所有接口上的DHCP Snooping表项信息。
ip ip-address:显示指定IP地址对应的DHCP Snooping表项信息。如果未指定本参数,则显示所有IP地址对应的DHCP Snooping表项信息。
vlan vlan-id:显示指定VLAN内的DHCP Snooping表项信息。如果未指定本参数,则显示所有VLAN内的DHCP Snooping表项信息。
verbose:显示DHCP Snooping表项的详细信息。如果未指定本参数,则显示DHCP Snooping表项的概要信息。
如果未指定interface和ip参数,则显示所有的DHCP Snooping表项信息。
# 显示DHCP Snooping表项的概要信息。
<Sysname> display dhcp snooping binding
 2 DHCP snooping entries found
 IP address      MAC address    Lease        VLAN  SVLAN Interface
 1.1.1.7         0000-0101-0107 16907533     2     3     XGE3/0/1
 1.1.1.11        0000-0101-010b 16907537     2     3     XGE3/0/3
# 显示DHCP Snooping表项的详细信息。
<Sysname> display dhcp snooping binding verbose
 IP address: 1.1.1.7
 MAC address: 0000-0101-0107
 Lease: 16907553 seconds
 VLAN: 2
 SVLAN: 3
 Parameter request list: 03 06 21
 Client Identifier: aabb-aabb-aab1
 Authorized Client Identifier: ccdd-eeff-aabb
 IP address: 1.1.1.104
 MAC address: 0000-0101-010b
 Lease: 16907537 seconds
 VLAN: 2
 SVLAN: 3
 Interface: Ten-GigabitEthernet3/0/3
 Parameter request list: 37 0B 01 0F 03 06 2C 2E 2F 1F 21 F9 2B
 Client Identifier: aabb-aabb-aab2
 Authorized Client Identifier: aabb-ccdd-eeff
表1-16 display dhcp snooping binding命令显示信息描述表
表项统计计数
IP address
DHCP服务器为DHCP客户端分配的IP地址
MAC address
DHCP客户端的MAC地址
Lease
绑定的租约剩余时间,单位为秒
VLAN
如果DHCP Snooping功能与QinQ功能同时使用,或接收到的DHCP报文带有两层VLAN Tag,则表示外层VLAN Tag;否则,表示与DHCP客户端连接的设备端口所属的VLAN
SVLAN
如果DHCP Snooping功能与QinQ功能同时使用,或接收到的DHCP报文带有两层VLAN Tag,则表示内层VLAN Tag;否则,显示为“N/A”
与DHCP客户端连接的设备端口
DHCP客户端的请求参数,为十六进制字符串
Client Identifier
客户端ID
授权客户端ID
·     dhcp snooping enable
·     reset dhcp snooping binding
1.5.34  display dhcp snooping binding database
display dhcp snooping binding database命令用来显示DHCP Snooping表项备份信息。
# 显示DHCP Snooping表项备份信息。
<Sysname> display dhcp snooping binding database
Username                :
Password                :
Update interval         :   600 seconds
Latest write time       :   Feb 27 18:48:04 2012
表1-17 display dhcp snooping binding database命令显示信息描述表
File name
Username
配置远程目标文件时的用户名
Password
配置远程目标文件时的密码,有配置时显示为”******”
Update interval
定期刷新表项存储文件的刷新时间间隔,单位为秒
Latest write time
最近一次写文件的时间
Status
写文件的状态,即写文件是否成功
·     Writing:正在写文件
·     Last write succeeded.:写文件成功
·     Last write failed.:写文件失败
1.5.35  display dhcp snooping m-lag-statistics
display dhcp snooping m-lag-statistics命令用来显示M-LAG组网中DHCP Snooping记录的同步表项统计信息。
该命令用于显示M-LAG组网中主从设备之间发送/接收同步DHCP Snooping表项报文的统计信息,并包括同步次数、备份DHCP Snooping表项数目等信息。M-LAG组网中的表项的同步是通过收发报文来完成的。
每执行一次开启peer-link接口操作后,就会触发一次主设备到从设备的表项同步操作。
# 在主设备上显示M-LAG组网中DHCP Snooping记录的同步表项统计信息。
<Sysname> display dhcp snooping m-lag-statistics
Send Statistics:
  Sync start number          : 1
  Binding valid records addr : 2
  Sync end abnormal          : NO
  Sync end number            : 1
  Sync start number          : 2
  Sync end number            : 2
  Sync start number          : 3
  Binding valid records addr : 1
  Sync end number            : 3
# 在从设备上显示M-LAG组网中DHCP Snooping记录的同步表项统计信息。
Recv Statistics:
  Sync end number            : 1
  Sync end number            : 2
  Sync end number            : 3
表1-18 display dhcp snooping m-lag-statistics命令显示信息描述表
Send Statistics
发送报文统计信息
Recv Statistics
接收报文统计信息
Sync start number
当次表项同步开始的次数
同步的DHCP Snooping用户有效表项数
Sync end abnormal
批备结束状态是否异常
·     NO:批备正常结束
·     YES:批备异常终止
Sync end number
当次表项同步结束的次数
·     reset dhcp snooping m-lag-statistics
1.5.36  display dhcp snooping m-lag-status
display dhcp snooping m-lag-status命令用来显示DHCP Snooping记录的M-LAG接口信息。
# 显示DHCP Snooping记录的M-LAG接口信息。
<Sysname> display dhcp snooping m-lag-status
Peer-link/Peer-link Index      : Bridge-Aggregation3/1297
M-LAG interface/M-LAG group ID : Bridge-Aggregation4/4
Local M-LAG interface state    : UP
Peer M-LAG interface state     : UP
M-LAG interface/M-LAG group ID : Bridge-Aggregation5/5
表1-19 display dhcp snooping m-lag-status命令显示信息描述表
M-LAG role
M-LAG网络运行的设备角色,取值包括:
·     None:设备状态未知
·     Primary:主设备
·     Secondary:从设备
Peer-link State
·     UP:开启
·     DOWN:关闭
M-LAG接口名/M-LAG组ID
本端M-LAG接口的状态,取值包括:
·     UP:当M-LAG接口所在聚合组中存在选中端口时,M-LAG接口处于UP状态
·     DOWN:当M-LAG接口所在聚合组中不存在选中端口时,M-LAG接口处于DOWN状态
对端M-LAG接口状态,取值包括:
·     UNKNOWN:当peer-link口变DOWN时,对端的M-LAG口状态变为未知状态
1.5.37  display dhcp snooping information
display dhcp snooping information命令用来显示DHCP Snooping上Option 82的配置信息。
display dhcp snooping information { all | interface interface-type interface-number }
all:显示所有二层以太网接口对应的Option 82配置信息。
interface interface-type interface-number:显示指定接口对应的Option 82配置信息。interface-type interface-number为接口类型和接口编号。
# 显示所有接口对应的Option 82配置信息。
<Sysname> display dhcp snooping information all
Interface: Bridge-Aggregation1
   Status: Disable
   Strategy: Drop
   Circuit ID:
     Padding format: User Defined
       User defined: abcd
     Format: ASCII
   Remote ID:
     Padding format: Normal
     Format: ASCII
   Vendor-specific:
     Padding format: BAS
     Node identifier: MAC
   VLAN 10:
     Circuit ID: abcd
     Remote ID: company
     Vendor-specific:
       Padding format: BAS
       Node identifier: User defined(abcd)
表1-20 display dhcp snooping information命令显示信息描述表
接口名
Status
Option 82的状态,取值为Enable或Disable
Strategy
Circuit ID
Circuit ID子选项的内容
Padding format
Option 82的填充模式:
·     在填充Circuit ID子选项时,取值为Normal、User Defined、Verbose(sysname)、Verbose(MAC)或Verbose(user defined)
·     在填充Remote ID子选项时,取值为Normal、Sysname或User Defined
·     在填充Vendor-specific子选项时,取值为BAS
Node identifier
接入节点的标识
·     在填充Circuit ID子选项时,取值为自定义的节点标识字符串
·     在填充Remote ID子选项时,取值为用户配置的字符串
·     在填充Vendor-specific子选项时,取值为MAC、Sysname或User Defined(string),括号内为自定义的字符串
User defined
用户自定义的子选项内容
Format
Option 82子选项的填充格式
·     在填充Circuit ID子选项时,取值为ASCII、Default或Hex
·     在填充Remote ID子选项时,取值为ASCII或Hex
Remote ID
Remote ID子选项的内容
Vendor-specific
Vendor-specific子选项的内容,只有配置了该子选项才会显示
VLAN
为指定VLAN内收到的DHCP报文填充的Circuit ID子选项、Remote ID子选项和Vendor-specific子选项内容
1.5.38  display dhcp snooping packet statistics
display dhcp snooping packet statistics命令用来显示DHCP Snooping设备上的DHCP报文统计信息。
(独立运行模式)
display dhcp snooping packet statistics [ slot slot-number ]
display dhcp snooping packet statistics [ chassis chassis-number slot slot-number ]
slot slot-number:显示指定单板的DHCP报文统计信息。slot-number表示单板所在的槽位号。如果未指定本参数,则显示主用主控板上的DHCP报文统计信息。(独立运行模式)
chassis chassis-number slot slot-number:显示指定成员设备上指定单板的DHCP报文统计信息。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。如果未指定本参数,则显示全局主用主控板上的DHCP报文统计信息。(IRF模式)
# 显示DHCP Snooping设备上的DHCP报文统计信息。
<Sysname> display dhcp snooping packet statistics
 DHCP packets received                  : 100
 DHCP packets sent                      : 200
 Invalid DHCP packets dropped           : 0
表1-21 display dhcp snooping packet statistics命令显示信息描述表
接收的DHCP报文数
DHCP packets sent
发送的DHCP报文数
丢弃的无效DHCP报文数
·     reset dhcp snooping packet statistics
1.5.39  display dhcp snooping trust
display dhcp snooping trust命令用来显示信任端口信息。
# 显示信任端口信息。
<Sysname> display dhcp snooping trust
DHCP snooping is enabled.
Interface                                        Trusted  VLAN
XGE3/0/1                                         Trusted  -
XGE3/0/2                                         -        100
VSI name                                        Tunnel trusted
a                                               Trusted
AC                                              Trusted
GE3/0/1 srv 1                                   Trusted
表1-22 display dhcp snooping trust命令显示信息描述表
DHCP snooping is
DHCP Snooping功能的开启状态,取值包括:
·     enabled:开启DHCP Snooping功能
·     disabled:未开启DHCP Snooping功能
接口名称
Trusted
全局DHCP Snooping功能中配置的信任接口。如果是VLAN内DHCP Snooping功能中配置的信任接口,则此处显示为“-”
VLAN
信任端口所属的VLAN。如果是全局DHCP Snooping功能中配置的信任接口,则此处显示为“-”
VSI name
(暂不支持)隧道接口的VSI名称,在VSI视图下配置dhcp snooping trust tunnel命令后,该项信息会显示
Tunnel trusted
(暂不支持)VXLAN内DHCP Snooping功能中配置的信任隧道接口
AC
AC链路,使用接口名称和以太网服务实例名称表示。在以太网服务实例视图下配置dhcp snooping trust命令后,该项信息会显示
Trusted
(暂不支持)VXLAN内DHCP Snooping功能中配置的信任AC链路
·     dhcp snooping trust
·     dhcp snooping trust interface
1.5.40  reset dhcp snooping alarm packet statistics
reset dhcp snooping alarm packet statistics命令用来清除DHCP Snooping设备上的DHCP告警报文丢弃统计信息。
reset dhcp snooping alarm packet statistics interface interface-type interface-number
interface interface-type interface-number:清除DHCP Snooping设备上指定接口的DHCP告警报文丢弃统计信息。interface-type interface-number为接口类型和接口编号。
# 清除接口Ten-GigabitEthernet3/0/1上的DHCP告警报文丢弃统计信息。
<Sysname> reset dhcp snooping alarm packet statistics interface ten-gigabitethernet 3/0/1
·     display dhcp snooping alarm packet statistics
1.5.41  reset dhcp snooping binding
reset dhcp snooping binding命令用来清除DHCP Snooping表项。
reset dhcp snooping binding { all | ip ip-address [ vlan vlan-id ] }
all:清除所有的DHCP Snooping表项。
ip ip-address:清除指定IP地址对应的DHCP Snooping表项。
vlan vlan-id:清除指定VLAN内的DHCP Snooping表项。如果未指定本参数,则清除缺省VLAN内的DHCP Snooping表项。
执行该命令后,将清除所有槽位上对应的DHCP Snooping表项。
# 清除所有的DHCP Snooping表项。
<Sysname> reset dhcp snooping binding all
·     display dhcp snooping binding
1.5.42  reset dhcp snooping m-lag-statistics
reset dhcp snooping m-lag-statistics命令用来清除DHCP Snooping记录的M-LAG同步表项统计信息。
# 清除DHCP Snooping记录的M-LAG同步表项统计信息。
<Sysname> reset dhcp snooping m-lag-statistics
·     display dhcp snooping m-lag-statistics
1.5.43  reset dhcp snooping packet statistics
reset dhcp snooping packet statistics命令用来清除DHCP Snooping设备上的DHCP报文统计信息。
(独立运行模式)
reset dhcp snooping packet statistics [ slot slot-number ]
reset dhcp snooping packet statistics [ chassis chassis-number slot slot-number ]
slot slot-number:清除指定单板的DHCP报文统计信息。slot-number为单板所在的槽位号。如果未指定本参数,则清除主用主控板上的DHCP报文统计信息。(独立运行模式)
chassis chassis-number slot slot-number:清除指定成员设备上指定单板的DHCP报文统计信息。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。如果未指定本参数,则清除全局主用主控板上的DHCP报文统计信息。(IRF模式)
# 清除DHCP Snooping设备上的DHCP报文统计信息。
<Sysname> reset dhcp snooping packet statistics
·     display dhcp snooping packet statistics
1.5.44  snmp-agent trap enable dhcp snooping
snmp-agent trap enable dhcp snooping命令用来开启DHCP Snooping的告警功能。
undo snmp-agent trap enable dhcp snooping命令用来关闭DHCP Snooping的告警功能。
snmp-agent trap enable dhcp snooping [ binding-exhaust | binding-mismatch | binding-threshold | chaddr-mismatch | rate-limit | untrust-reply ] *
undo snmp-agent trap enable dhcp snooping [ binding-exhaust | binding-mismatch | binding-threshold | chaddr-mismatch | rate-limit | untrust-reply ] *
DHCP Snooping所有类型的告警功能均处于关闭状态。
binding-exhaust:表示DHCP Snooping表项资源耗尽/恢复的告警功能。
binding-mismatch:表示与DHCP Snooping表项不匹配而被丢弃的请求报文数达到阈值时的告警功能。
binding-threshold:表示DHCP Snooping表项资源使用率大于等于阈值或恢复到低于阈值的告警功能。
chaddr-mismatch:表示数据帧头中的源MAC地址与DHCP请求报文中的CHADDR字段不一致被丢弃的报文数达到阈值时的告警功能。
rate-limit:表示因接收到的DHCP请求报文速率超过限速值而被丢弃的报文数达到阈值时的告警功能。
untrust-reply:表示非信任接口丢弃DHCP服务器的回应报文数达到阈值时的告警功能。
如果未指定任何参数,将开启DHCP Snooping所有类型的告警功能。
开启DHCP Snooping模块的告警功能后,该模块会生成告警信息,用于报告该模块的重要事件。生成的告警信息将发送到设备的SNMP模块,通过设置SNMP中告警信息的发送参数,来决定告警信息输出的相关属性。
开启chaddr-mismatch和binding-mismatch报文丢弃告警功能前,需要通过dhcp snooping check mac-address和dhcp snooping check request-message命令开启相应的报文检查功能。
当丢弃的报文数等于通过dhcp snooping trap threshold命令指定的报文丢弃告警阈值时,设备生成告警信息。告警后当前统计数据保留,设备会继续进行统计计数,但不再生成告警信息。只有通过reset dhcp snooping alarm packet statistics命令清除报文统计信息后,当丢弃报文数再次达到阈值时,设备才会再次生成告警信息。
# 关闭DHCP Snooping表项资源耗尽告警功能。
[Sysname] undo snmp-agent trap enable dhcp snooping binding-exhaust
·     dhcp snooping learning-num-threshold
·     snmp-agent target-host(网络管理和监控命令参考/SNMP)
1.6  BOOTP客户端配置命令
1.6.1  display bootp client
display bootp client命令用来显示BOOTP客户端的相关信息。
interface interface-type interface-number:显示指定接口的BOOTP客户端相关信息。interface-type interface-number为接口类型和接口编号。如果未指定本参数,则显示所有接口上的BOOTP客户端的相关信息。
# 显示VLAN接口10的BOOTP客户端相关信息。
<Sysname> display bootp client interface vlan-interface 10
Vlan-interface10 BOOTP client information:
 Allocated IP: 169.254.0.2 255.255.0.0
 Transaction ID: 0x3d8a7431
 MAC Address: 00e0-fc0a-c3ef
表1-23 display bootp client命令显示信息描述表
XXXX BOOTP client information
作为BOOTP客户端的接口信息
Allocated IP
BOOTP服务器为BOOTP客户端分配的IP地址
Transaction ID
BOOTP报文中XID字段值,即BOOTP客户端发送BOOTP请求报文时选择的随机数,用来与BOOTP服务器的响应报文相匹配。如果响应报文的XID字段值与请求报文的XID字段值不相同,则BOOTP客户端丢弃该响应报文
MAC Address
BOOTP客户端的MAC地址
·     ip address bootp-alloc
1.6.2  ip address bootp-alloc
ip address bootp-alloc命令用来配置接口通过BOOTP协议获取IP地址。
undo ip address bootp-alloc命令用来取消接口通过BOOTP协议获取的IP地址。
接口不通过BOOTP协议获取IP地址。
# 在VLAN接口10上配置接口通过BOOTP协议获取IP地址。
[Sysname-Vlan-interface10] ip address bootp-alloc
·     display bootp client
